Hi Team,
I have two Jetson Xavier NXs which have stopped booting up unexpectedly.
I tried accessing the debug console through minicom and I can see the following:
First NX: Prints the following and then gets stuck
[0000.024] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.033] I> MB1 (prd-version: 1.5.1.3-t194-41334769-d2a21c57)
[0000.038] I> Boot-mode: Coldboot
[0000.041] I> Chip revision : A02P
[0000.044] I> Bootrom patch version : 15 (correctly patched)
[0000.049] I> ATE fuse revision : 0x200
[0000.053] I> Ram repair fuse : 0x0
[0000.056] I> Ram Code : 0x0
[0000.059] I> rst_source : 0x0
[0000.061] I> rst_level : 0x0
[0000.065] I> Boot-device: QSPI
[0000.067] I> Qspi flash params source = brbct
[0000.072] I> Qspi using bpmp-dma
[0000.074] I> Qspi clock source : pllp
[0000.078] I> QSPI Flash Size = 32 MB
[0000.081] I> Qspi initialized successfully
[0000.085] I> Active Boot chain : 0
[0000.088] I> Boot-device: QSPI
[0000.091] I> Qspi flash params source = brbct
[0000.097] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.105] I> Temperature = 23000
[0000.108] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.112] W> Skipping boost for clk: BPMP_APB
[0000.116] W> Skipping boost for clk: AXI_CBB
[0000.120] W> Skipping boost for clk: AON_CPU_NIC
[0000.124] W> Skipping boost for clk: CAN1
[0000.128] W> Skipping boost for clk: CAN2
[0000.132] I> Boot-device: QSPI
[0000.135] I> Boot-device: QSPI
[0000.138] I> Qspi flash params source = mb1bct
[0000.142] I> Qspi using bpmp-dma
[0000.145] I> Qspi clock source : pllc_out0
[0000.149] I> Qspi reinitialized
[0000.152] I> Qspi flash params source = mb1bct
[0000.157] I> ECC region[0]: Start:0x0, End:0x0
[0000.161] I> ECC region[1]: Start:0x0, End:0x0
[0000.166] I> ECC region[2]: Start:0x0, End:0x0
[0000.170] I> ECC region[3]: Start:0x0, End:0x0
[0000.174] I> ECC region[4]: Start:0x0, End:0x0
[0000.178] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.184] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.188] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.193] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.197] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.202] E> FAILED: Thermal config
[0000.210] E> FAILED: MEMIO rail config
[0000.220] I> Boot-device: QSPI
[0000.223] I> Qspi flash params source = mb1bct
[0000.232] I> Qspi flash params source = mb1bct
[0000.244] I> Qspi flash params source = mb1bct
[0000.310] I> Qspi flash params source = mb1bct
[0000.319] I> Qspi flash params source = mb1bct
[0000.346] I> Qspi flash params source = mb1bct
[0000.358] I> MB1 done
����main enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
[0000.366] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-389501e9)
[0000.367] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.367] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.368] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.374] W> device prod register failed
[0000.378] I> Boot-device: QSPI
[0000.381] I> Boot_device: QSPI_FLASH instance: 0
[0000.386] I> QSPI Flash Size = 32 MB
[0000.391] I> Qspi initialized successfully
[0000.392] I> qspi flash-0 params source = boot args
[0000.397] E> Failed: Unknown device 6
[0000.404] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0000.407] I> Active Boot chain : 0
[0000.410] I> parsing oem signed section of bpmp-fw header done
[0000.415] I> bpmp-fw binary init read from storage
[0000.420] I> oem authentication of bpmp-fw header done
[0000.434] I> bpmp-fw binary done read from storage
[0000.435] I> bpmp-fw: Authentication init Done
[0000.436] I> parsing oem signed section of cpubl header done
[0000.439] I> cpubl binary init read from storage
[0000.444] I> bpmp-fw: Authentication Finalize Done
[0000.449] I> oem authentication of cpubl header done
[0000.456] I> cpubl binary done read from storage
[0000.458] I> cpubl: Authentication init Done
[0000.462] I> parsing oem signed section of rce header done
[0000.467] I> rce binary init read from storage
[0000.472] I> Relocating BR-BCT
[0000.474] I> cpubl: Authentication Finalize Done
[0000.479] I> oem authentication of rce header done
[0000.484] I> rce binary done read from storage
[0000.488] I> rce: Authentication init Done
[0000.492] I> parsing oem signed section of ape header done
[0000.497] I> ape binary init read from storage
[0000.501] I> rce: Authentication Finalize Done
[0000.506] I> oem authentication of ape header done
[0000.510] I> ape binary done read from storage
[0000.514] I> ape: Authentication init Done
[0000.519] I> parsing oem signed section of tos header done
[0000.524] I> tos binary init read from storage
[0000.528] I> ape: Authentication Finalize Done
[0000.533] I> oem authentication of tos header done
[0000.539] I> tos binary done read from storage
[0000.541] I> tos: Authentication init Done
[0000.546] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.551] I> bpmp-fw-dtb binary init read from storage
[0000.556] I> tos: Authentication Finalize Done
[0000.562] I> oem authentication of bpmp-fw-dtb header done
[0000.566] I> bpmp-fw-dtb binary done read from storage
[0000.571] I> bpmp-fw-dtb: Authentication init Done
[0000.576] I> parsing oem signed section of cpubl-dtb header done
[0000.581] I> cpubl-dtb binary init read from storage
[0000.586] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.642] I> oem authentication of cpubl-dtb header done
[0000.643] I> cpubl-dtb binary done read from storage
[0000.643] I> cpubl-dtb: Authentication init Done
[0000.644] I> parsing oem signed section of eks header done
[0000.645] I> eks binary init read from storage
[0000.645] I> cpubl-dtb: Authentication Finalize Done
[0000.646] I> oem authentication of eks header done
[0000.651] I> eks binary done read from storage
[0000.655] I> eks: Authentication init Done
[0000.659] I> eks: Authentication Finalize Done
[0000.663] I> EKB detected (length: 0x410) @ VA:0x52705400
��NOTICE: BL31: v1.3(release):de895fd9e
NOTICE: BL31: Built : 20:51:20, Oct 27 2020
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 40: hwkey-agent is running!!
hwkey-agent: 182: key_mgnt_processing .......
hwkey-agent: 157: Init hweky-agent services!!
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is 57f8a77779f848bf2ecf21dabee5645f
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
391 clocks registered
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform_init: bad clk id in clock@cluster1_avfs
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
[0001.004] I> Welcome to Cboot
[0001.005] I> Cboot Version: t194-aad9d75e
��mrq initialized
WARNING: no registered clock for FMON_NAFLL_CLUSTER1 (id 281)
fmon_post initialized
��[0001.005] I> CPU-BL Params @ 0xf2820000
[0001.010] I> 0) Base:0x00000000 Size:0x00000000
[0001.015] I> 1) Base:0xf1100000 Size:0x00100000
��clk_set_parent failed for clk can1, parent pll_aon (-22)
clk_set_parent failed for clk can2, parent pll_aon (-22)
clk_set_parent failed for clk dmic5, parent pll_aon (-22)
clk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_set_parent failed for clk spi2, parent pll_aon (-22)
clk_set_parent failed for clk pwm4, parent pll_aon (-22)
clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
Failed to register PTO counter for id 281
clk_debugfs initialized
emc_debugfs initialized
dvs_debugfs initialized
fmon_debugfs_init_one: no clock debugfs node to attach FMON_NAFLL_CLUSTER1
fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_rail_debugfs_init: /rm/vdd_cpu: failed
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ��[0001.019] I> 2) Base:0xf2000000 Size:0x00200000
[0001.199] I> 3) Base:0xf1200000 Size:0x00200000
[0001.203] I> 4) Base:0xf1000000 Size:0x00100000
[0001.208] I> 5) Base:0xf0f00000 Size:0x00100000
[0001.212] I> 6) Base:0xf3800000 Size:0x00400000
[0001.217] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.221] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.226] I> 9) Base:0xf0d00000 Size:0x00100000
[0001.230] I> 10) Base:0xf3000000 Size:0x00800000
[0001.235] I> 11) Base:0x40000000 Size:0x00040000
[0001.239] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.243] I> 13) Base:0x40046000 Size:0x00002000
[0001.248] I> 14) Base:0x40048000 Size:0x00002000
[0001.252] I> 15) Base:0xac000000 Size:0x00004000
[0001.257] I> 16) Base:0x4004a000 Size:0x00002000
[0001.261] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.266] I> 18) Base:0x4004c000 Size:0x00002000
[0001.270] I> 19) Base:0xf2200000 Size:0x00600000
[0001.275] I> 20) Base:0x4004e000 Size:0x00002000
[0001.279] I> 21) Base:0xf09d0000 Size:0x0000c000
[0001.284] I> 22) Base:0x00000000 Size:0x00000000
[0001.288] I> 23) Base:0xf09e0000 Size:0x00020000
[0001.293] I> 24) Base:0xf6000000 Size:0x02000000
[0001.297] I> 25) Base:0x40050000 Size:0x00002000
[0001.301] I> 26) Base:0x40040000 Size:0x00006000
[0001.306] I> 27) Base:0xf1800000 Size:0x00400000
[0001.310] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.315] I> 29) Base:0xf1400000 Size:0x00400000
[0001.319] I> 30) Base:0xf0a00000 Size:0x00100000
[0001.324] I> 31) Base:0x00000000 Size:0x00000000
[0001.328] I> 32) Base:0xf8000000 Size:0x08000000
[0001.333] I> 33) Base:0x00000000 Size:0x00000000
[0001.337] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.342] I> 35) Base:0xab000000 Size:0x01000000
[0001.346] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.351] I> 37) Base:0xf2800000 Size:0x00800000
[0001.355] I> 38) Base:0x80000000 Size:0x20000000
[0001.359] I> 39) Base:0xb0000000 Size:0x08000000
[0001.364] I> 40) Base:0x00000000 Size:0x00000000
[0001.368] I> 41) Base:0x00000000 Size:0x00000000
[0001.373] I> 42) Base:0x00000000 Size:0x00000000
[0001.377] I> 43) Base:0x00000000 Size:0x00000000
[0001.382] I> 44) Base:0x00000000 Size:0x00000000
[0001.386] I> 45) Base:0x00000000 Size:0x00000000
[0001.391] GIC-SPI Target CPU: 0
[0001.394] Interrupts Init done
[0001.397] calling constructors
[0001.399] initializing heap
[0001.402] I> Heap: [0xa0691568 ... 0xab000000]
[0001.406] initializing threads
[0001.409] initializing timers
[0001.412] creating bootstrap completion thread
[0001.416] top of bootstrap2()
[0001.419] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.424] initializing platform
[0001.427] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.432] W> device prod register failed
[0001.436] I> Bl_dtb @0xaaf00000
[0001.441] W> "plugin-manager" doesn't exist, creating
[0001.444] W> "ids" doesn't exist, creating
[0001.448] W> "connection" doesn't exist, creating
[0001.452] W> "configs" doesn't exist, creating
[0001.460] I> Find /i2c@3160000's alias i2c0
[0001.461] I> Reading eeprom i2c=0 address=0x50
[0001.490] I> Device at /i2c@3160000:0x50
[0001.491] I> Reading eeprom i2c=0 address=0x57
[0001.515] I> Device at /i2c@3160000:0x57
[0001.517] I> Find /i2c@c240000's alias i2c1
[0001.517] I> Reading eeprom i2c=1 address=0x50
[0001.519] E> I2C: slave not found in slaves.
[0001.519] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.520] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.521] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via insta.
[0001.529] E> eeprom: Retry to read I2C slave device.
[0001.534] E> I2C: slave not found in slaves.
[0001.538] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.546] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.551] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via insta.
[0001.561] E> eeprom: Failed to read I2C slave device
[0001.566] I> Eeprom read failed 0x3526070d
[0001.570] I> create_pm_ids: id: 3668-0000-200-H, len: 15
[0001.575] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,disp3
[0001.586] I> create_pm_ids: id: 3509-0000-100-G, len: 15
[0001.591] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,disp3
[0001.602] I> Adding plugin-manager/ids/3668-0000-200=/i2c@3160000:module@0x50
[0001.609] W> "i2c@3160000" doesn't exist, creating
[0001.614] W> "module@0x50" doesn't exist, creating
[0001.618] I> Adding plugin-manager/ids/3509-0000-100=/i2c@3160000:module@0x57
[0001.625] W> "module@0x57" doesn't exist, creating
[0001.632] I> Adding plugin-manager/cvm
[0001.634] W> "chip-id" doesn't exist, creating
[0001.638] I> Adding plugin-manager/chip-id/A02P
[0001.642] I> Plugin-manager override starting
[0001.647] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0001.657] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0001.662] I> node /plugin-manager/fragement-tegra-sdhci-emmc-dis matches
[0001.670] I> Disable plugin-manager status in FDT
[0001.670] I> Plugin-manager override finished successfully
[0001.674] I> gpio framework initialized
[0001.679] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0001.686] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0001.693] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0001.700] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.708] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.715] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.721] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0001.728] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.735] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.743] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.749] I> fixed regulator driver initialized
[0001.757] I> register 'maxim' power off handle
[0001.758] I> virtual i2c enabled
[0001.760] I> registered 'maxim,max20024' pmic
[0001.765] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0001.771] I> Boot-device: QSPI
[0001.774] I> Boot_device: QSPI_FLASH instance: 0
[0001.779] I> QSPI source rate = 204000 Khz
[0001.783] I> Requested rate for QSPI clock = 34000 Khz
[0001.788] I> BPMP-set rate for QSPI clk = 34000 Khz
[0001.793] I> QSPI Flash Size = 32 MB
[0001.800] I> Qspi initialized successfully
[0001.801] I> qspi flash-0 params source = boot args
[0001.804] I> create_pm_ids: id: 3668-0000-200-H, len: 15
[0001.810] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,disp3
[0001.821] I> create_pm_ids: id: 3509-0000-100-G, len: 15
[0001.826] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,disp3
[0001.837] I> Found sdcard
[0001.841] I> enabling 'vdd-sdmmc1-sw' regulator
[0001.847] I> regulator 'vdd-sdmmc1-sw' already enabled
[0001.853] E> Error in command_complete c8001 int_status
[0001.856] E> Error in command_complete c8001 int_status
[0001.861] E> Error in command_complete 18001 int_status
[0001.864] E> Sending CMD_SD_SEND_IF_COND failed
[0001.878] W> Error opening sdcard-0
[0001.878] I> -0 params source =
[0001.879] E> Failed to initialize device 6-0
[0001.879] E> Error config_storage
[0001.882] initializing target
[0001.885] calling apps_init()
[0001.887] starting app kernel_boot_app
[0001.891] E> Partition manager might not be initialized.
[0001.896] E> Failed to open partition[0001.900] E> tegrabl_load_bmp_blob: BMP blob initialization fad
[0001.906] W> Loading bmp blob to memory failed
[0001.910] I> Kernel type = Normal
[0001.913] I> Loading kernel-bootctrl from partition
[0001.918] E> Partition manager might not be initialized.
[0001.923] E> Cannot open partition kernel-bootctrl
[0001.928] W> tegrabl_get_kernel_bootctrl: failed to read primary bootctrl data
[0001.935] I> Loading kernel-bootctrl_b from partition
[0001.939] E> Partition manager might not be initialized.
[0001.945] E> Cannot open partition kernel-bootctrl_b
[0001.949] W> tegrabl_get_kernel_bootctrl: failed to read recovery bootctrl data
[0001.957] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0001.964]
[0001.965] -----------------------------------------------
[0001.970] Synchronous Exception: DATA ABORT (FAR: 0)
[0001.975] -----------------------------------------------
[0001.980] PAR_ELX: 0x80f
[0001.982]
[0001.984] ESR 0x96000007: ec 0x25, il 0x1, iss 0x7
[0001.988] -----------------------------------------------
[0001.993] [Stack Trace]
[0001.996]
[0001.997] => pc:0xA063FB44, sp:0xA0697380
[0002.001] => pc:0xA060F450, sp:0xA06975C0
[0002.005] => pc:0xA060F5EC, sp:0xA0697660
[0002.009] => pc:0xA060F600, sp:0xA06976D0
[0002.012] => pc:0xA060F284, sp:0xA0697710
[0002.016] => pc:0xA060E7F8, sp:0xA0697720
[0002.020] => pc:0xA060E7CC, sp:0xA0697730
[0002.024] -----------------------------------------------
[0002.029] iframe 0xa0697290:
[0002.032] x0 0x 0 x1 0x a06976a0 x2 0x a06976a8 x3 0x a06976b0
[0002.041] x4 0x 0 x5 0x 0 x6 0x 0 x7 0x 0
[0002.050] x8 0x 43 x9 0x a x10 0x a0697748 x11 0x 88a0
[0002.059] x12 0x a0691160 x13 0x 0 x14 0x 0 x15 0x 0
[0002.068] x16 0x 0 x17 0x 0 x18 0x 0 x19 0x 0
[0002.077] x20 0x a06976a8 x21 0x 0 x22 0x a066103f x23 0x a06976a0
[0002.086] x24 0x a06976b0 x25 0x a06976e0 x26 0x 0 x27 0x 0
[0002.096] x28 0x 0 x29 0x a06975c0 lr 0x a063fb34 sp 0x a0697380
[0002.105] elr 0x a063fb44
[0002.108] spsr 0x 20000209
[0002.111] -----------------------------------------------
[0002.116] panic (caller 0xa0601238): die
[0002.120] HALT: spinning forever...
Second NX: Prints the following in a loop:
Is it possible to get these working again?
What can I do for the same…?
Regards,
Ritvik
