I’m making my own main board for Jetson nx.I have a trouble with booting.
The board can startup normal when I poweroff and restart.But it can’t startup when I use shell “sudo reboot”.
It will not happen if I switch the core board to the jetson-xavier-nx-devkit.
My Log:
~$ sudo reboot
[ 72.537774] watchdog: watchdog0: watchdog did not stop!
[ 72.544303] systemd-shutdow: 46 output lines suppressed due to ratelimiting
??WARNING: at platform/drivers/pg/pg-gpu-t194.c:185
??[ 73.042258] reboot: Restarting system
????Shutdown state requested 1
Rebooting system ...
[0000.024] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.033] I> MB1 (prd-version: 1.5.1.6-t194-41334769-1740dd39)
[0000.038] I> Boot-mode: Coldboot
[0000.041] I> Chip revision : A02P
[0000.044] I> Bootrom patch version : 15 (correctly patched)
[0000.049] I> ATE fuse revision : 0x200
[0000.053] I> Ram repair fuse : 0x0
[0000.056] I> Ram Code : 0x0
[0000.058] I> rst_source : 0xb
[0000.061] I> rst_level : 0x1
[0000.065] I> Boot-device: QSPI
[0000.067] I> Qspi flash params source = brbct
[0000.071] I> Qspi using bpmp-dma
[0000.074] I> Qspi clock source : pllp
[0000.078] I> QSPI Flash Size = 32 MB
[0000.081] I> Qspi initialized successfully
[0000.085] W> No valid slot number is found in scratch register
[0000.091] W> Return default slot: _a
[0000.094] I> Active Boot chain : 0
[0000.097] I> Boot-device: QSPI
[0000.100] I> Qspi flash params source = brbct
[0000.106] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.112] I> Temperature = 36000
[0000.115] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.119] W> Skipping boost for clk: BPMP_APB
[0000.123] W> Skipping boost for clk: AXI_CBB
[0000.127] W> Skipping boost for clk: AON_CPU_NIC
[0000.131] W> Skipping boost for clk: CAN1
[0000.135] W> Skipping boost for clk: CAN2
[0000.139] I> Boot-device: QSPI
[0000.142] I> Boot-device: QSPI
[0000.145] I> Qspi flash params source = mb1bct
[0000.149] I> Qspi using bpmp-dma
[0000.152] I> Qspi clock source : pllc_out0
[0000.156] I> Qspi reinitialized
[0000.159] I> Qspi flash params source = mb1bct
[0000.164] I> ECC region[0]: Start:0x0, End:0x0
[0000.168] I> ECC region[1]: Start:0x0, End:0x0
[0000.173] I> ECC region[2]: Start:0x0, End:0x0
[0000.177] I> ECC region[3]: Start:0x0, End:0x0
[0000.181] I> ECC region[4]: Start:0x0, End:0x0
[0000.185] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.191] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.195] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.200] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.204] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.209] E> FAILED: Thermal config
[0000.217] E> FAILED: MEMIO rail config
[0000.227] I> Boot-device: QSPI
[0000.230] I> Qspi flash params source = mb1bct
[0000.239] I> Qspi flash params source = mb1bct
[0000.250] I> Qspi flash params source = mb1bct
[0000.317] I> Qspi flash params source = mb1bct
[0000.326] I> Qspi flash params source = mb1bct
[0000.355] I> Qspi flash params source = mb1bct
[0000.366] I> MB1 done
????main enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
[0000.374] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-7515048c)
[0000.375] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.376] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.376] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.382] W> device prod register failed
[0000.386] I> Boot-device: QSPI
[0000.389] I> Boot_device: QSPI_FLASH instance: 0
[0000.394] I> QSPI Flash Size = 32 MB
[0000.400] I> Qspi initialized successfully
[0000.401] I> qspi flash-0 params source = boot args
[0000.405] E> Failed: Unknown device 6
[0000.414] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0000.415] W> No valid slot number is found in scratch register
[0000.420] W> Return default slot: _a
[0000.423] I> Active Boot chain : 0
[0000.427] I> parsing oem signed section of bpmp-fw header done
[0000.433] I> bpmp-fw binary init read from storage
[0000.437] I> oem authentication of bpmp-fw header done
[0000.451] I> bpmp-fw binary done read from storage
[0000.452] I> bpmp-fw: Authentication init Done
[0000.453] I> parsing oem signed section of cpubl header done
[0000.457] I> cpubl binary init read from storage
[0000.461] I> bpmp-fw: Authentication Finalize Done
[0000.466] I> oem authentication of cpubl header done
[0000.473] I> cpubl binary done read from storage
[0000.475] I> cpubl: Authentication init Done
[0000.479] I> parsing oem signed section of rce header done
[0000.484] I> rce binary init read from storage
[0000.489] I> Relocating BR-BCT
[0000.492] I> cpubl: Authentication Finalize Done
[0000.496] I> oem authentication of rce header done
[0000.501] I> rce binary done read from storage
[0000.505] I> rce: Authentication init Done
[0000.509] I> parsing oem signed section of ape header done
[0000.514] I> ape binary init read from storage
[0000.519] I> rce: Authentication Finalize Done
[0000.523] I> oem authentication of ape header done
[0000.527] I> ape binary done read from storage
[0000.532] I> ape: Authentication init Done
[0000.536] I> parsing oem signed section of tos header done
[0000.541] I> tos binary init read from storage
[0000.545] I> ape: Authentication Finalize Done
[0000.550] I> oem authentication of tos header done
[0000.556] I> tos binary done read from storage
[0000.558] I> tos: Authentication init Done
[0000.563] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.569] I> bpmp-fw-dtb binary init read from storage
[0000.573] I> tos: Authentication Finalize Done
[0000.579] I> oem authentication of bpmp-fw-dtb header done
[0000.583] I> bpmp-fw-dtb binary done read from storage
[0000.588] I> bpmp-fw-dtb: Authentication init Done
[0000.593] I> parsing oem signed section of cpubl-dtb header done
[0000.599] I> cpubl-dtb binary init read from storage
[0000.603] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.660] I> oem authentication of cpubl-dtb header done
[0000.661] I> cpubl-dtb binary done read from storage
[0000.661] I> cpubl-dtb: Authentication init Done
[0000.662] I> parsing oem signed section of eks header done
[0000.663] I> eks binary init read from storage
[0000.663] I> cpubl-dtb: Authentication Finalize Done
[0000.664] I> oem authentication of eks header done
[0000.669] I> eks binary done read from storage
[0000.673] I> eks: Authentication init Done
[0000.677] I> eks: Authentication Finalize Done
[0000.681] I> EKB detected (length: 0x410) @ VA:0x52700400
??NOTICE: BL31: v1.3(release):5b49e7f80
NOTICE: BL31: Built : 08:54:10, Jul 9 2021
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 40: hwkey-agent is running!!
hwkey-agent: 197: key_mgnt_processing .......
hwkey-agent: 189: Setting EKB key 0 to slot 14
hwkey-agent: 167: Init hweky-agent services!!
luks-srv: 40: luks-srv is running!!
luks-srv: 157: Init luks-srv IPC services!!
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is e73a758761f0c6d24a1e69a2ac6b5035
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
391 clocks registered
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform_init: bad clk id in clock@cluster1_avfs
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
[0001.022] I> Welcome to Cboot??mrq initialized
WARNING: no registered clock for FMON_NAFLL_CLUSTER1 (id 281)
fmon_post initialized
[0001.023] I> Cboot Version: t194-f9317da2
[0001.024] I> CPU-BL Params @ 0xf2820000
[0001.028] I> 0) Base:0x00000000 Size:0x00000000
[0001.032] I> 1) Base:0xf1100000 Size:0x00100000
[0001.037] I> 2) Base:0xf2000000 Size:0x00200000
[0001.041] I> 3) Base:0xf1200000 Size:0x00200000
??clk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
Failed to register PTO counter for id 281
clk_debugfs initialized
emc_debugfs initialized
dvs_debugfs initialized
fmon_debugfs_init_one: no clock debugfs node to attach FMON_NAFLL_CLUSTER1
fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_rail_debugfs_init: /rm/vdd_cpu: failed
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ??[0001.046] I> 4) Base:0xf1000000 Size:0x00100000
[0001.200] I> 5) Base:0xf0f00000 Size:0x00100000
[0001.204] I> 6) Base:0xf3800000 Size:0x00400000
[0001.209] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.213] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.218] I> 9) Base:0xf0d00000 Size:0x00100000
[0001.222] I> 10) Base:0xf3000000 Size:0x00800000
[0001.227] I> 11) Base:0x40000000 Size:0x00040000
[0001.231] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.236] I> 13) Base:0x40046000 Size:0x00002000
[0001.240] I> 14) Base:0x40048000 Size:0x00002000
[0001.245] I> 15) Base:0xac000000 Size:0x00004000
[0001.249] I> 16) Base:0x4004a000 Size:0x00002000
[0001.253] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.258] I> 18) Base:0x4004c000 Size:0x00002000
[0001.262] I> 19) Base:0xf2200000 Size:0x00600000
[0001.267] I> 20) Base:0x4004e000 Size:0x00002000
[0001.271] I> 21) Base:0xf0ad0000 Size:0x0000c000
[0001.276] I> 22) Base:0x00000000 Size:0x00000000
[0001.280] I> 23) Base:0xf0ae0000 Size:0x00020000
[0001.285] I> 24) Base:0xf6000000 Size:0x02000000
[0001.289] I> 25) Base:0x40050000 Size:0x00002000
[0001.294] I> 26) Base:0x40040000 Size:0x00006000
[0001.298] I> 27) Base:0xf1800000 Size:0x00400000
[0001.303] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.307] I> 29) Base:0xf1400000 Size:0x00400000
[0001.311] I> 30) Base:0x00000000 Size:0x00000000
[0001.316] I> 31) Base:0x00000000 Size:0x00000000
[0001.320] I> 32) Base:0xf8000000 Size:0x08000000
[0001.325] I> 33) Base:0x00000000 Size:0x00000000
[0001.329] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.334] I> 35) Base:0xab000000 Size:0x01000000
[0001.338] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.343] I> 37) Base:0xf2800000 Size:0x00800000
[0001.347] I> 38) Base:0x80000000 Size:0x20000000
[0001.352] I> 39) Base:0xb0000000 Size:0x08000000
[0001.356] I> 40) Base:0x00000000 Size:0x00000000
[0001.361] I> 41) Base:0x00000000 Size:0x00000000
[0001.365] I> 42) Base:0x00000000 Size:0x00000000
[0001.369] I> 43) Base:0x00000000 Size:0x00000000
[0001.374] I> 44) Base:0x00000000 Size:0x00000000
[0001.378] I> 45) Base:0x00000000 Size:0x00000000
[0001.383] GIC-SPI Target CPU: 0
[0001.386] Interrupts Init done
[0001.389] calling constructors
[0001.392] initializing heap
[0001.394] I> Heap: [0xa0694618 ... 0xab000000]
[0001.399] initializing threads
[0001.401] initializing timers
[0001.404] creating bootstrap completion thread
[0001.409] top of bootstrap2()
[0001.411] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.416] initializing platform
[0001.419] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.424] W> device prod register failed
[0001.428] I> Bl_dtb @0xaaf00000
[0001.433] W> "plugin-manager" doesn't exist, creating
[0001.436] W> "ids" doesn't exist, creating
[0001.440] W> "connection" doesn't exist, creating
[0001.445] W> "configs" doesn't exist, creating
[0001.454] I> Find /i2c@3160000's alias i2c0
[0001.454] I> Reading eeprom i2c=0 address=0x50
[0001.482] I> Device at /i2c@3160000:0x50
[0001.483] I> Reading eeprom i2c=0 address=0x57
[0001.483] E> I2C: slave not found in slaves.
[0001.483] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.484] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.485] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 0.
[0001.492] E> eeprom: Failed to read I2C slave device
[0001.497] I> Eeprom read failed 0x3526070d
[0001.502] I> Find /i2c@c240000's alias i2c1
[0001.505] I> Reading eeprom i2c=1 address=0x50
[0001.511] E> I2C: slave not found in slaves.
[0001.514] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.521] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.527] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.536] E> eeprom: Retry to read I2C slave device.
[0001.541] E> I2C: slave not found in slaves.
[0001.545] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.553] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.559] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.568] E> eeprom: Failed to read I2C slave device
[0001.573] I> Eeprom read failed 0x3526070d
[0001.577] I> create_pm_ids: id: 3668-0000-200-H, len: 15
[0001.582] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.593] I> Adding plugin-manager/ids/3668-0000-200=/i2c@3160000:module@0x50
[0001.601] W> "i2c@3160000" doesn't exist, creating
[0001.605] W> "module@0x50" doesn't exist, creating
[0001.611] I> Adding plugin-manager/cvm
[0001.613] W> "chip-id" doesn't exist, creating
[0001.617] I> Adding plugin-manager/chip-id/A02P
[0001.622] I> Plugin-manager override starting
[0001.627] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0001.635] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0001.641] I> node /plugin-manager/fragement-tegra-sdhci-emmc-dis matches
[0001.648] I> Disable plugin-manager status in FDT
[0001.649] I> Plugin-manager override finished successfully
[0001.654] I> gpio framework initialized
[0001.659] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0001.666] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0001.673] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0001.680] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.688] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.694] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.700] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0001.708] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.715] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.722] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.729] I> fixed regulator driver initialized
[0001.737] I> register 'maxim' power off handle
[0001.737] I> virtual i2c enabled
[0001.740] I> registered 'maxim,max20024' pmic
[0001.744] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0001.751] I> Boot-device: QSPI
[0001.754] I> Boot_device: QSPI_FLASH instance: 0
[0001.759] I> QSPI source rate = 204000 Khz
[0001.762] I> Requested rate for QSPI clock = 34000 Khz
[0001.767] I> BPMP-set rate for QSPI clk = 34000 Khz
[0001.772] I> QSPI Flash Size = 32 MB
[0001.780] I> Qspi initialized successfully
[0001.780] I> qspi flash-0 params source = boot args
[0001.784] I> create_pm_ids: id: 3668-0000-200-H, len: 15
[0001.789] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.800] I> Found sdcard
[0001.805] I> enabling 'vdd-sdmmc1-sw' regulator
[0001.811] I> regulator 'vdd-sdmmc1-sw' already enabled
[0001.979] I> sdmmc SDR mode
[0001.994] I> -0 params source =
[0001.996] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0002.006] I> Found 11 partitions in SDCARD (instance 0)
[0002.014] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.017] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.018] E> tegrabl_display_init_regulator: hdmi cable is not connected
[0002.018] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0002.021] E> invalid display type
[0002.022] E> cannot find any other nvdisp nodes
[0002.023] E> no valid display unit config found in dtb
[0002.025] W> display init failed
[0002.027] I> Load in CBoot Boot Options partition and parse it
[0002.033] E> Error -9 when finding node with path /boot-configuration
[0002.039] E> tegrabl_cbo_parse_info: "boot-configuration" not found in CBO file.
[0002.046] I> Using default boot order
[0002.050] I> boot-dev-order :-
[0002.053] I> 1.sd
[0002.054] I> 2.usb
[0002.056] I> 3.nvme
[0002.058] I> 4.emmc
[0002.060] I> 5.net
[0002.062] I> Hit any key to stop autoboot: 4 3 2 1
[0004.070] initializing target
[0004.070] calling apps_init()
[0004.071] starting app kernel_boot_app
[0004.081] I> found decompressor handler: lz4-legacy
[0004.082] I> decompressing BMP blob ...
[0004.094] I> Kernel type = Normal
[0004.094] I> Loading kernel-bootctrl from partition
[0004.095] I> Loading partition kernel-bootctrl at 0xa42d0000 from device(0x6)
[0004.120] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.121] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.122] I> ########## SD (0) boot ##########
[0004.122] I> Found sdcard
[0004.124] I> regulator 'vdd-sdmmc1-sw' already enabled
[0004.127] I> regulator 'vdd-sdmmc1-sw' already enabled
[0004.162] I> sdmmc SDR mode
[0004.177] I> -0 params source =
[0004.177] I> Already published: 00060000
[0004.177] I> Look for boot partition
[0004.178] I> Fallback: assuming 0th partition is boot partition
[0004.178] I> Detect filesystem
[0004.200] I> Loading extlinux.conf ...
[0004.200] I> rootfs path: /sd/boot/extlinux/extlinux.conf
[0004.229] I> L4T boot options
[0004.229] I> [1]: "primary kernel"
[0004.229] I> Enter choice:
[0007.230] I> Continuing with default option: 1
[0007.230] I> Loading kernel sig file from rootfs ...
[0007.230] I> rootfs path: /sd/boot/Image.sig
[0007.247] I> Loading kernel binary from rootfs ...
[0007.248] I> rootfs path: /sd/boot/Image
[0010.044] I> overload load_size to 34338824 (from 34338832)
[0010.067] I> Validate kernel ...
[0010.067] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0010.380] I> Encryption fuse is not ON
[0010.396] I> No kernel-dtb binary path
[0010.397] W> No valid slot number is found in scratch register
[0010.397] W> Return default slot: _a
[0010.397] I> A/B: bin_type (38) slot 0
[0010.398] I> Loading kernel-dtb from partition
[0010.398] I> Loading partition kernel-dtb at 0x91000000 from device(0x6)
[0010.441] I> Validate kernel-dtb ...
[0010.441] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0010.444] I> Encryption fuse is not ON
[0010.445] I> Loading ramdisk from rootfs ...
[0010.445] I> Loading initrd sig file from rootfs ...
[0010.446] I> rootfs path: /sd/boot/initrd.sig
[0010.459] I> Loading initrd binary from rootfs ...
[0010.459] I> rootfs path: /sd/boot/initrd
[0011.056] I> overload load_size to 7236840 (from 7236848)
[0011.059] I> Validate initrd ...
[0011.059] I> T19x: Authenticate initrd (bin_type: 49), max size 0x4000000
[0011.125] I> Encryption fuse is not ON
[0011.139] I> Kernel hdr @0xa42d0000
[0011.139] I> Kernel dtb @0x90000000
[0011.139] I> decompressor handler not found
[0011.139] I> Copying kernel image (34338824 bytes) from 0xa42d0000 to 0x80080000 ... [0011.150] I> Done
[0011.151] I> Updated bpmp info to DTB
[0011.152] I> Ramdisk: Base: 0x92000000; Size: 0x6e6ce8
[0011.152] I> Updated initrd info to DTB
[0011.152] W> WARN: Fail to override "console=none" in commandline
[0011.153] I> Active rootfs suffix:
[0011.155] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0011.162] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0011.169] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0011.177] W> No valid slot number is found in scratch register
[0011.182] W> Return default slot: _a
[0011.186] I> Active slot suffix:
[0011.189] I> add_boot_slot_suffix: slot_suffix =
[0011.194] I> Linux Cmdline: console=ttyTCU0,115200 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[0011.220] I> Updated bootarg info to DTB
[0011.224] W> MAC addr invalid!
[0011.226] E> Failed to get WIFI MAC address
[0011.230] W> MAC addr invalid!
[0011.233] E> Failed to get Bluetooth MAC address
[0011.238] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:07:7f:4d
[0011.244] W> "plugin-manager" doesn't exist, creating
[0011.249] I> Adding /chosen/plugin-manager/cvm
[0011.253] W> "chip-id" doesn't exist, creating
[0011.257] I> Adding /chosen/plugin-manager/chip-id
[0011.262] W> "configs" doesn't exist, creating
[0011.266] I> Adding /chosen/plugin-manager/configs
[0011.271] W> "ids" doesn't exist, creating
[0011.275] I> Adding /chosen/plugin-manager/ids
[0011.279] W> "odm-data" doesn't exist, creating
[0011.284] I> Adding /chosen/plugin-manager/odm-data
[0011.291] W> "memory" doesn't exist, creating
[0011.293] I> [0] START: 0x80000000, END: 0xac000000
[0011.297] I> [1] START: 0xac004000, END: 0xf0ad0000
[0011.302] I> [2] START: 0xf0adc000, END: 0xf0ae0000
[0011.307] I> dram_block larger than 80000000
[0011.311] I> [3] START: 0x100000000, END: 0x280000000
[0011.316] I> added [base:0x80000000, size:0x2c000000] to /memory
[0011.321] I> added [base:0xac200000, size:0x44800000] to /memory
[0011.327] I> added [base:0x100000000, size:0x180000000] to /memory
[0011.334] I> Updated memory info to DTB
[0011.337] E> add_disp_param: failed to get display params for du=0
[0011.343] W> "reset" doesn't exist, creating
[0011.348] I> Adding ecid(00000001647076c210000000150280c0) to DT
[0011.353] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0011.358] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0011.363] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0011.367] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0011.372] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0011.377] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0011.381] I> Deleted cpu@6 node in DT
[0011.385] I> Deleted cpu@7 node in DT
[0011.389] I> Deleted cluster3 node in FDT
[0011.392] I> Update arm-pmu in FDT
[0011.396] I> - update property: interrupts
[0011.399] I> - update property: interrupt-affinity
[0011.405] W> "misc-data" doesn't exist, creating
[0011.409] I> Boot-device: QSPI
[0011.411] W> Unknown boot device
[0011.414] I> Add storage-qspi to plugin-manager/misc-data
[0011.420] W> Unknown storage device
[0011.423] I> Add serial number:1422420034557 as DT property
[0011.429] I> Plugin-manager override starting
[0011.433] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0011.440] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0011.446] I> node /plugin-manager/fragement-tegra-sdhci-emmc-dis matches
[0011.453] I> Disable plugin-manager status in FDT
[0011.455] I> Plugin-manager override finished successfully
[0011.461] I> tegrabl_load_kernel_and_dtb: Done
[0011.465] E> tegrabl_display_clear: display is not initialized
[0011.471] W> Boot logo display failed...
[0011.474] I> Kernel EP: 0x80080000, DTB: 0x90000000
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.201-tegra (buildbrain@mobile-u64-5285-d7000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Fri Feb 19 08:42:04 PST 2021
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44800000
[ 0.000000] OF: fdt: - 100000000 , 180000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 2.049659] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[ 2.049962] imx219 9-0010: board setup failed
[ 2.073940] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[ 2.074229] imx219 10-0010: board setup failed
??WARNING: at platform/drivers/mailbox/mail_mach.c:148
WARNING: at platform/drivers/mailbox/mail_mach.c:161
WARNING: at platform/drivers/mailbox/mail_mach.c:177
Best Regards.
