[0000.024] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.033] I> MB1 (prd-version: 1.5.1.7-t194-41334769-98030a79)
[0000.038] I> Boot-mode: Coldboot
[0000.041] I> Chip revision : A02P
[0000.044] I> Bootrom patch version : 15 (correctly patched)
[0000.049] I> ATE fuse revision : 0x200
[0000.053] I> Ram repair fuse : 0x0
[0000.056] I> Ram Code : 0x0
[0000.058] I> rst_source : 0x0
[0000.061] I> rst_level : 0x0
[0000.065] I> Boot-device: QSPI
[0000.067] I> Qspi flash params source = brbct
[0000.071] I> Qspi using bpmp-dma
[0000.074] I> Qspi clock source : pllp
[0000.078] I> QSPI Flash Size = 32 MB
[0000.081] I> Qspi initialized successfully
[0000.085] W> No valid slot number is found in scratch register
[0000.091] W> Return default slot: _a
[0000.094] I> Active Boot chain : 0
[0000.097] I> Boot-device: QSPI
[0000.100] I> Qspi flash params source = brbct
[0000.106] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.113] I> Temperature = 38000
[0000.116] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.121] W> Skipping boost for clk: BPMP_APB
[0000.125] W> Skipping boost for clk: AXI_CBB
[0000.129] W> Skipping boost for clk: AON_CPU_NIC
[0000.133] W> Skipping boost for clk: CAN1
[0000.137] W> Skipping boost for clk: CAN2
[0000.141] I> Boot-device: QSPI
[0000.144] I> Boot-device: QSPI
[0000.147] I> Qspi flash params source = mb1bct
[0000.151] I> Qspi using bpmp-dma
[0000.154] I> Qspi clock source : pllc_out0
[0000.158] I> Qspi reinitialized
[0000.160] I> Qspi flash params source = mb1bct
[0000.166] I> ECC region[0]: Start:0x0, End:0x0
[0000.170] I> ECC region[1]: Start:0x0, End:0x0
[0000.174] I> ECC region[2]: Start:0x0, End:0x0
[0000.178] I> ECC region[3]: Start:0x0, End:0x0
[0000.182] I> ECC region[4]: Start:0x0, End:0x0
[0000.186] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.192] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.197] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.201] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.206] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.211] E> FAILED: Thermal config
[0000.218] E> FAILED: MEMIO rail config
[0000.228] I> Boot-device: QSPI
[0000.231] I> Qspi flash params source = mb1bct
[0000.240] I> Qspi flash params source = mb1bct
[0000.252] I> Qspi flash params source = mb1bct
[0000.318] I> Qspi flash params source = mb1bct
[0000.327] I> Qspi flash params source = mb1bct
[0000.356] I> Qspi flash params source = mb1bct
[0000.368] I> MB1 done
����main enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
[0000.376] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-938a8cd8)
[0000.377] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.377] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.378] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.384] W> device prod register failed
[0000.388] I> Boot-device: QSPI
[0000.390] I> Boot_device: QSPI_FLASH instance: 0
[0000.396] I> QSPI Flash Size = 32 MB
[0000.401] I> Qspi initialized successfully
[0000.402] I> qspi flash-0 params source = boot args
[0000.407] E> Failed: Unknown device 6
[0000.415] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0000.416] W> No valid slot number is found in scratch register
[0000.422] W> Return default slot: _a
[0000.425] I> Active Boot chain : 0
[0000.429] I> parsing oem signed section of bpmp-fw header done
[0000.434] I> bpmp-fw binary init read from storage
[0000.439] I> oem authentication of bpmp-fw header done
[0000.453] I> bpmp-fw binary done read from storage
[0000.454] I> bpmp-fw: Authentication init Done
[0000.454] I> parsing oem signed section of cpubl header done
[0000.458] I> cpubl binary init read from storage
[0000.462] I> bpmp-fw: Authentication Finalize Done
[0000.467] I> oem authentication of cpubl header done
[0000.475] I> cpubl binary done read from storage
[0000.476] I> cpubl: Authentication init Done
[0000.481] I> parsing oem signed section of rce header done
[0000.486] I> rce binary init read from storage
[0000.490] I> Relocating BR-BCT
[0000.493] I> cpubl: Authentication Finalize Done
[0000.498] I> oem authentication of rce header done
[0000.502] I> rce binary done read from storage
[0000.506] I> rce: Authentication init Done
[0000.511] I> parsing oem signed section of ape header done
[0000.516] I> ape binary init read from storage
[0000.520] I> rce: Authentication Finalize Done
[0000.525] I> oem authentication of ape header done
[0000.529] I> ape binary done read from storage
[0000.533] I> ape: Authentication init Done
[0000.538] I> parsing oem signed section of tos header done
[0000.543] I> tos binary init read from storage
[0000.547] I> ape: Authentication Finalize Done
[0000.552] I> oem authentication of tos header done
[0000.558] I> tos binary done read from storage
[0000.560] I> tos: Authentication init Done
[0000.564] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.570] I> bpmp-fw-dtb binary init read from storage
[0000.575] I> tos: Authentication Finalize Done
[0000.581] I> oem authentication of bpmp-fw-dtb header done
[0000.585] I> bpmp-fw-dtb binary done read from storage
[0000.590] I> bpmp-fw-dtb: Authentication init Done
[0000.595] I> parsing oem signed section of cpubl-dtb header done
[0000.600] I> cpubl-dtb binary init read from storage
[0000.605] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.657] I> oem authentication of cpubl-dtb header done
[0000.658] I> cpubl-dtb binary done read from storage
[0000.658] I> cpubl-dtb: Authentication init Done
[0000.659] I> parsing oem signed section of eks header done
[0000.660] I> eks binary init read from storage
[0000.661] I> cpubl-dtb: Authentication Finalize Done
[0000.661] I> oem authentication of eks header done
[0000.666] I> eks binary done read from storage
[0000.670] I> eks: Authentication init Done
[0000.674] I> eks: Authentication Finalize Done
[0000.678] I> EKB detected (length: 0x410) @ VA:0x52700400
��NOTICE: BL31: v1.3(release):b5eeb33f7
NOTICE: BL31: Built : 12:15:32, Jul 26 2021
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 41: hwkey-agent is running!!
hwkey-agent: 315: key_mgnt_processing …
hwkey-agent: 223: Setting EKB key 0 to slot 14
hwkey-agent: 178: Init hweky-agent services!!
luks-srv: 40: luks-srv is running!!
luks-srv: 157: Init luks-srv IPC services!!
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is e73a758761f0c6d24a1e69a2ac6b5035
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
391 clocks registered
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform_init: bad clk id in clock@cluster1_avfs
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
mrq initialized
[0001.036] I> Welcome to Cboot
��WARNING: no registered clock for FMON_NAFLL_CLUSTER1 (id 281)
fmon_post initialized
��[0001.036] I> Cboot Version: t194-cfa2bc91
[0001.038] I> CPU-BL Params @ 0xf2820000
[0001.042] I> 0) Base:0x00000000 Size:0x00000000
[0001.046] I> 1) Base:0xf1100000 Size:0x00100000
��clk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
Failed to register PTO counter for id 281
clk_debugfs initialized
emc_debugfs initialized
dvs_debugfs initialized
fmon_debugfs_init_one: no clock debugfs node to attach FMON_NAFLL_CLUSTER1
fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_rail_debugfs_init: /rm/vdd_cpu: failed
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ��[0001.050] I> 2) Base:0xf2000000 Size:0x00200000
[0001.205] I> 3) Base:0xf1200000 Size:0x00200000
[0001.209] I> 4) Base:0xf1000000 Size:0x00100000
[0001.214] I> 5) Base:0xf0f00000 Size:0x00100000
[0001.218] I> 6) Base:0xf3800000 Size:0x00400000
[0001.223] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.227] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.231] I> 9) Base:0xf0d00000 Size:0x00100000
[0001.236] I> 10) Base:0xf3000000 Size:0x00800000
[0001.240] I> 11) Base:0x40000000 Size:0x00040000
[0001.245] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.249] I> 13) Base:0x40046000 Size:0x00002000
[0001.254] I> 14) Base:0x40048000 Size:0x00002000
[0001.258] I> 15) Base:0xac000000 Size:0x00004000
[0001.263] I> 16) Base:0x4004a000 Size:0x00002000
[0001.267] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.272] I> 18) Base:0x4004c000 Size:0x00002000
[0001.276] I> 19) Base:0xf2200000 Size:0x00600000
[0001.281] I> 20) Base:0x4004e000 Size:0x00002000
[0001.285] I> 21) Base:0xf0ad0000 Size:0x0000c000
[0001.289] I> 22) Base:0x00000000 Size:0x00000000
[0001.294] I> 23) Base:0xf0ae0000 Size:0x00020000
[0001.298] I> 24) Base:0xf6000000 Size:0x02000000
[0001.303] I> 25) Base:0x40050000 Size:0x00002000
[0001.307] I> 26) Base:0x40040000 Size:0x00006000
[0001.312] I> 27) Base:0xf1800000 Size:0x00400000
[0001.316] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.321] I> 29) Base:0xf1400000 Size:0x00400000
[0001.325] I> 30) Base:0x00000000 Size:0x00000000
[0001.330] I> 31) Base:0x00000000 Size:0x00000000
[0001.334] I> 32) Base:0xf8000000 Size:0x08000000
[0001.339] I> 33) Base:0x00000000 Size:0x00000000
[0001.343] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.347] I> 35) Base:0xab000000 Size:0x01000000
[0001.352] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.356] I> 37) Base:0xf2800000 Size:0x00800000
[0001.361] I> 38) Base:0x80000000 Size:0x20000000
[0001.365] I> 39) Base:0xb0000000 Size:0x08000000
[0001.370] I> 40) Base:0x00000000 Size:0x00000000
[0001.374] I> 41) Base:0x00000000 Size:0x00000000
[0001.379] I> 42) Base:0x00000000 Size:0x00000000
[0001.383] I> 43) Base:0x00000000 Size:0x00000000
[0001.388] I> 44) Base:0x00000000 Size:0x00000000
[0001.392] I> 45) Base:0x00000000 Size:0x00000000
[0001.397] GIC-SPI Target CPU: 0
[0001.400] Interrupts Init done
[0001.402] calling constructors
[0001.405] initializing heap
[0001.408] I> Heap: [0xa0699b80 … 0xab000000]
[0001.412] initializing threads
[0001.415] initializing timers
[0001.418] creating bootstrap completion thread
[0001.422] top of bootstrap2()
[0001.425] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.430] initializing platform
[0001.433] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.438] W> device prod register failed
[0001.442] I> Bl_dtb @0xaaf00000
[0001.447] W> “plugin-manager” doesn’t exist, creating
[0001.450] W> “ids” doesn’t exist, creating
[0001.454] W> “connection” doesn’t exist, creating
[0001.458] W> “configs” doesn’t exist, creating
[0001.469] E> failed to read label property for node 158736: 13
[0001.472] E> failed to read reg property for node 158800: 13
[0001.475] E> failed to read reg property for node 158852: 13
[0001.481] E> failed to read reg property for node 158936: 13
[0001.486] I> Find /i2c@3160000’s alias i2c0
[0001.489] I> Reading eeprom i2c=0 address=0x50
[0001.518] E> verify_cvm_eeprom_version: EEPROM incompatible version found
[0001.519] I> Eeprom read failed 0x35360018
[0001.519] I> Reading eeprom i2c=0 address=0x57
[0001.543] I> Device at /i2c@3160000:0x57
[0001.545] I> Find /i2c@c240000’s alias i2c1
[0001.545] I> Reading eeprom i2c=1 address=0x50
[0001.547] E> I2C: slave not found in slaves.
[0001.547] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.548] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.549] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.558] E> eeprom: Retry to read I2C slave device.
[0001.563] E> I2C: slave not found in slaves.
[0001.566] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.574] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.580] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.589] E> eeprom: Failed to read I2C slave device
[0001.594] I> Eeprom read failed 0x3526070d
[0001.598] I> create_pm_ids: id: 3509-0000-100-G, len: 15
[0001.603] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0001.614] I> Adding plugin-manager/ids/3509-0000-100=/i2c@3160000:module@0x57
[0001.622] W> “i2c@3160000” doesn’t exist, creating
[0001.626] W> “module@0x57” doesn’t exist, creating
[0001.632] W> “chip-id” doesn’t exist, creating
[0001.635] I> Adding plugin-manager/chip-id/A02P
[0001.639] I> Plugin-manager override starting
[0001.644] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0001.653] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0001.661] I> Disable plugin-manager status in FDT
[0001.661] I> Plugin-manager override finished successfully
[0001.665] I> gpio framework initialized
[0001.669] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio’ driver
[0001.677] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio-aon’ driver
[0001.684] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0001.691] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.698] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.705] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.711] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0001.718] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.726] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.733] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.740] I> fixed regulator driver initialized
[0001.748] I> register ‘maxim’ power off handle
[0001.748] I> virtual i2c enabled
[0001.751] I> registered ‘maxim,max20024’ pmic
[0001.755] I> tegrabl_gpio_driver_register: register ‘max20024-gpio’ driver
[0001.762] I> Boot-device: QSPI
[0001.765] I> Boot_device: QSPI_FLASH instance: 0
[0001.770] I> QSPI source rate = 204000 Khz
[0001.773] I> Requested rate for QSPI clock = 34000 Khz
[0001.778] I> BPMP-set rate for QSPI clk = 34000 Khz
[0001.783] I> QSPI Flash Size = 32 MB
[0001.791] I> Qspi initialized successfully
[0001.791] I> qspi flash-0 params source = boot args
[0001.795] I> create_pm_ids: id: 3509-0000-100-G, len: 15
[0001.800] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0001.811] I> Found sdcard
[0001.815] I> enabling ‘vdd-sdmmc1-sw’ regulator
[0001.821] I> regulator ‘vdd-sdmmc1-sw’ already enabled
[0002.026] I> sdmmc SDR mode
[0002.041] I> -0 params source =
[0002.043] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0002.051] I> Found 11 partitions in SDCARD (instance 0)
[0002.059] I> regulator ‘vdd-hdmi-5v0’ already enabled
[0002.063] I> regulator ‘vdd-hdmi-5v0’ already enabled
[0002.063] E> tegrabl_display_init_regulator: hdmi cable is not connected
[0002.064] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0002.067] E> invalid display type
[0002.067] E> cannot find any other nvdisp nodes
[0002.068] E> no valid display unit config found in dtb
[0002.070] W> display init failed
[0002.072] I> Load in CBoot Boot Options partition and parse it
[0002.078] E> Error -9 when finding node with path /boot-configuration
[0002.084] E> tegrabl_cbo_parse_info: “boot-configuration” not found in CBO file.
[0002.091] I> Using default boot order
[0002.095] I> boot-dev-order :-
[0002.098] I> 1.sd
[0002.099] I> 2.usb
[0002.101] I> 3.nvme
[0002.103] I> 4.emmc
[0002.105] I> 5.net
[0002.107] I> Hit any key to stop autoboot: 4 3 2 1
[0004.115] initializing target
[0004.115] calling apps_init()
[0004.116] starting app kernel_boot_app
[0004.126] I> found decompressor handler: lz4-legacy
[0004.127] I> decompressing BMP blob …
[0004.138] I> Kernel type = Normal
[0004.138] I> ########## SD (0) boot ##########
[0004.139] I> Found sdcard
[0004.140] I> regulator ‘vdd-sdmmc1-sw’ already enabled
[0004.144] I> regulator ‘vdd-sdmmc1-sw’ already enabled
[0004.179] I> sdmmc SDR mode
[0004.193] I> -0 params source =
[0004.193] I> Already published: 00060000
[0004.194] I> Look for boot partition
[0004.194] I> Fallback: assuming 0th partition is boot partition
[0004.195] I> Detect filesystem
[0004.211] I> Loading kernel-bootctrl from partition
[0004.211] I> Loading partition kernel-bootctrl at 0xa42d0000 from device(0x6)
[0004.236] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.236] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.237] I> Loading extlinux.conf …
[0004.237] I> Loading extlinux.conf binary from rootfs …
[0004.237] I> rootfs path: /sd/boot/extlinux/extlinux.conf
[0004.267] I> Loading extlinux.conf sig file from rootfs …
[0004.267] I> rootfs path: /sd/boot/extlinux/extlinux.conf.sig
[0004.288] I> Validate extlinux.conf …
[0004.288] I> T19x: Authenticate extlinux.conf (bin_type: 54), max size 0x2000
[0004.289] I> Encryption fuse is not ON
[0004.289] I> L4T boot options
[0004.289] I> [1]: “primary kernel”
[0004.290] I> Enter choice:
[0007.291] I> Continuing with default option: 1
[0007.291] I> Loading kernel …
[0007.291] I> Loading kernel binary from rootfs …
[0007.292] I> rootfs path: /sd/boot/Image
[0010.102] I> Loading kernel sig file from rootfs …
[0010.103] I> rootfs path: /sd/boot/Image.sig
[0010.115] I> overload load_size to 34484232 (from 34484240)
[0010.116] I> Validate kernel …
[0010.116] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0010.430] I> Encryption fuse is not ON
[0010.446] I> Loading kernel-dtb …
[0010.446] I> No kernel-dtb binary path
[0010.446] I> Continue to load from partition …
[0010.447] W> No valid slot number is found in scratch register
[0010.447] W> Return default slot: _a
[0010.447] I> A/B: bin_type (38) slot 0
[0010.448] I> Loading kernel-dtb from partition
[0010.449] I> Loading partition kernel-dtb at 0x91000000 from device(0x6)
[0010.496] I> Validate kernel-dtb …
[0010.497] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0010.499] I> Encryption fuse is not ON
[0010.500] I> Loading ramdisk from rootfs …
[0010.501] I> Loading ramdisk binary from rootfs …
[0010.501] I> rootfs path: /sd/boot/initrd
[0011.103] I> Loading ramdisk sig file from rootfs …
[0011.103] I> rootfs path: /sd/boot/initrd.sig
[0011.116] I> overload load_size to 7238344 (from 7238352)
[0011.116] I> Validate ramdisk …
[0011.116] I> T19x: Authenticate ramdisk (bin_type: 54), max size 0x4000000
[0011.183] I> Encryption fuse is not ON
[0011.190] I> Kernel hdr @0xa42d0000
[0011.191] I> Kernel dtb @0x90000000
[0011.191] I> decompressor handler not found
[0011.191] I> Copying kernel image (34484232 bytes) from 0xa42d0000 to 0x80080000 … [0011.198] I> Done
[0011.198] I> Updated bpmp info to DTB
[0011.199] I> Ramdisk: Base: 0x92000000; Size: 0x6e72c8
[0011.200] I> Updated initrd info to DTB
[0011.200] W> WARN: Fail to override “console=none” in commandline
[0011.203] I> Active rootfs suffix:
[0011.207] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0011.214] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0011.221] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0011.228] W> No valid slot number is found in scratch register
[0011.234] W> Return default slot: _a
[0011.237] I> Active slot suffix:
[0011.241] I> add_boot_slot_suffix: slot_suffix =
[0011.245] I> Linux Cmdline: console=ttyTCU0,115200 video=tegrafb earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suff
[0011.270] I> Updated bootarg info to DTB
[0011.273] E> Error 892665857: Failed to get CVM EEPROM contents
[0011.279] E> Booting w/o MAC ddresses for WIFI, Bluetooth & Ethernet
[0011.285] E> Failed to get WIFI MAC address
[0011.289] E> Error 892665857: Failed to get CVM EEPROM contents
[0011.295] E> Booting w/o MAC ddresses for WIFI, Bluetooth & Ethernet
[0011.301] E> Failed to get Bluetooth MAC address
[0011.306] E> Error 892665857: Failed to get CVM EEPROM contents
[0011.312] E> Booting w/o MAC ddresses for WIFI, Bluetooth & Ethernet
[0011.318] E> Failed to get Ethernet MAC address
[0011.323] W> “plugin-manager” doesn’t exist, creating
[0011.327] W> “chip-id” doesn’t exist, creating
[0011.331] I> Adding /chosen/plugin-manager/chip-id
[0011.336] W> “configs” doesn’t exist, creating
[0011.340] I> Adding /chosen/plugin-manager/configs
[0011.345] W> “ids” doesn’t exist, creating
[0011.349] I> Adding /chosen/plugin-manager/ids
[0011.353] W> “odm-data” doesn’t exist, creating
[0011.358] I> Adding /chosen/plugin-manager/odm-data
[0011.365] W> “memory” doesn’t exist, creating
[0011.367] I> [0] START: 0x80000000, END: 0xac000000
[0011.371] I> [1] START: 0xac004000, END: 0xf0ad0000
[0011.376] I> [2] START: 0xf0adc000, END: 0xf0ae0000
[0011.381] I> dram_block larger than 80000000
[0011.385] I> [3] START: 0x100000000, END: 0x280000000
[0011.390] I> added [base:0x80000000, size:0x2c000000] to /memory
[0011.395] I> added [base:0xac200000, size:0x44800000] to /memory
[0011.401] I> added [base:0x100000000, size:0x180000000] to /memory
[0011.408] I> Updated memory info to DTB
[0011.411] E> add_disp_param: failed to get display params for du=0
[0011.417] W> “reset” doesn’t exist, creating
[0011.422] I> Adding ecid(00000001647076c21000000006ff8280) to DT
[0011.427] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0011.432] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0011.437] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0011.441] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0011.446] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0011.451] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0011.455] I> Deleted cpu@6 node in DT
[0011.459] I> Deleted cpu@7 node in DT
[0011.462] I> Deleted cluster3 node in FDT
[0011.466] I> Update arm-pmu in FDT
[0011.470] I> - update property: interrupts
[0011.473] I> - update property: interrupt-affinity
[0011.479] W> “misc-data” doesn’t exist, creating
[0011.483] I> Boot-device: QSPI
[0011.485] W> Unknown boot device
[0011.488] I> Add storage-qspi to plugin-manager/misc-data
[0011.494] W> Unknown storage device
[0011.497] E> Error 892665857: Failed to read CVM EEPROM
[0011.502] E> Failed to get serial number
[0011.506] I> Plugin-manager override starting
[0011.511] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0011.517] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0011.525] I> Disable plugin-manager status in FDT
[0011.526] I> Plugin-manager override finished successfully
[0011.532] I> tegrabl_load_kernel_and_dtb: Done
[0011.536] E> tegrabl_display_clear: display is not initialized
[0011.541] W> Boot logo display failed…
[0011.545] I> Kernel EP: 0x80080000, DTB: 0x90000000
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.253-tegra (buildbrain@mobile-u64-5497-d3000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) )1
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44800000
[ 0.000000] OF: fdt: - 100000000 , 180000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options ‘’)
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[ 0.000000] cma: Reserved 64 MiB at 0x00000000c2000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s57624 r8192 d32488 u98304
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2001384
[ 0.000000] Kernel command line: console=ttyTCU0,115200 video=tegrafb earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.sl0
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 30132(91%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7190624K/8132608K available (15358K kernel code, 2956K rwdata, 6692K rodata, 8640K init, 612K bss, 188320K reserved, 753664K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f80000 ( 15360 KB)
[ 0.000000] .rodata : 0xffffff8008f80000 - 0xffffff8009610000 ( 6720 KB)
[ 0.000000] .init : 0xffffff8009610000 - 0xffffff8009e80000 ( 8640 KB)
[ 0.000000] .data : 0xffffff8009e80000 - 0xffffff800a163008 ( 2957 KB)
[ 0.000000] .bss : 0xffffff800a163008 - 0xffffff800a1fc0b4 ( 613 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf08000000 ( 128 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc200000000 ( 8192 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000006] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.008338] Console: colour dummy device 80x25
[ 0.012450] console [tty0] enabled
[ 0.015583] bootconsole [tegra_comb_uart0] disabled
��WARNING: pll_d2 has no dyn ramp
��[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.020850] kmemleak: Kernel memory leak detector disabled
[ 0.020887] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.020923] pid_max: default: 32768 minimum: 301
[ 0.022029] Security Framework initialized
[ 0.022594] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022619] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.024179] ftrace: allocating 47077 entries in 184 pages
[ 0.418766] sched-energy: Sched-energy-costs installed from DT
[ 0.418802] ASID allocator initialised with 65536 entries
[ 0.453991] tegra-id: chipid=21917.
[ 0.454017] tegra-id: opt_subrevision=1.
[ 0.454057] Tegra Revision: A02p SKU: 0xde CPU Process: 0 SoC Process: 0
[ 0.454107] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[ 0.454167] DTB Build time: Jul 26 2021 12:22:25
[ 0.502074] CPU1: Booted secondary processor [4e0f0040]
[ 0.534188] CPU2: Booted secondary processor [4e0f0040]
[ 0.566332] CPU3: Booted secondary processor [4e0f0040]
[ 0.598537] CPU4: Booted secondary processor [4e0f0040]
[ 0.630624] CPU5: Booted secondary processor [4e0f0040]
[ 0.630817] Brought up 6 CPUs
[ 0.631022] SMP: Total of 6 processors activated.
[ 0.631073] CPU features: detected feature: Privileged Access Never
[ 0.631101] CPU features: detected feature: LSE atomic instructions
[ 0.631148] CPU features: detected feature: User Access Override
[ 0.631180] CPU features: detected feature: 32-bit EL0 Support
[ 0.632714] CPU: All CPU(s) started at EL2
[ 0.632805] alternatives: patching kernel code
[ 0.639321] devtmpfs: initialized
[ 0.679197] Initilizing CustomIPI irq domain
[ 0.679453] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.679497] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.689714] pinctrl core: initialized pinctrl subsystem
[ 0.689937] OS set in device tree is not L4T.
[ 0.690219] regulator-dummy: no parameters
[ 0.690446] Initializing plugin-manager
[ 0.690525] Plugin module not found
[ 0.690573] Plugin-manager status disabled
[ 0.691807] NET: Registered protocol family 16
[ 0.692951] pstore: using zlib compression
[ 0.693678] console [pstore-1] enabled
[ 0.693701] pstore: Registered ramoops as persistent store backend
[ 0.693729] ramoops: attached 0x200000@0xf0800000, ecc: 0/0
[ 0.713747] cpuidle: using governor menu
[ 0.714825] bpmp: waiting for handshake
[ 0.714856] bpmp: handshake completed
[ 0.714924] bpmp: synchronizing channels
[ 0.714954] bpmp: channels synchronized
[ 0.714976] bpmp: mail init ok
[ 0.717595] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[ 0.717860] t19x-arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.717888] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.717931] t19x-arm-smmu 12000000.iommu: stage 1 translation
[ 0.717954] t19x-arm-smmu 12000000.iommu: stage 2 translation
[ 0.718000] t19x-arm-smmu 12000000.iommu: nested translation
[ 0.718027] t19x-arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.718084] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.718126] t19x-arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.718152] t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.718196] t19x-arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
[ 0.721138] vdso: 2 pages (1 code @ ffffff8008f87000, 1 data @ ffffff8009e84000)
[ 0.721216] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.723749] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.725063] tegra_aon_clk_init: ok
[ 0.725101] Registering BPMP clocks…
[ 0.725222] tegra_bpmp_clk_init: clock init ok (400 clks)
[ 0.725879] Serial: AMBA PL011 UART driver
[ 0.726070] tegra_powergate_init: DONE
[ 0.726130] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[ 0.726188] DTB Build time: Jul 26 2021 12:22:25
[ 0.728649] Tegra reboot handler registered.
[ 0.736280] iommu: Adding device 14160000.pcie to group 0
[ 0.736968] iommu: Adding device 141a0000.pcie to group 1
[ 0.738484] iommu: Adding device 2490000.ether_qos to group 2
[ 0.738995] iommu: Adding device 3100000.serial to group 3
[ 0.739542] iommu: Adding device 3110000.serial to group 4
[ 0.739947] iommu: Adding device 3140000.serial to group 5
[ 0.740644] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.740877] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.740929] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.740958] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 0.740984] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.741054] tegra-pmc: PMC Prod config success
[ 0.741285] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.741349] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.741793] iommu: Adding device 3460000.sdhci to group 6
[ 0.742444] iommu: Adding device 3400000.sdhci to group 7
[ 0.742992] iommu: Adding device 3210000.spi to group 8
[ 0.743457] iommu: Adding device 3230000.spi to group 9
[ 0.743882] iommu: Adding device 3270000.spi to group 10
[ 0.745114] iommu: Adding device 3160000.i2c to group 11
[ 0.745531] iommu: Adding device c240000.i2c to group 12
[ 0.745987] iommu: Adding device 3180000.i2c to group 13
[ 0.746423] iommu: Adding device 3190000.i2c to group 14
[ 0.747084] iommu: Adding device 31b0000.i2c to group 15
[ 0.747597] iommu: Adding device 31c0000.i2c to group 16
[ 0.748042] iommu: Adding device c250000.i2c to group 17
[ 0.748491] iommu: Adding device 31e0000.i2c to group 18
[ 0.749049] iommu: Adding device sound to group 19
[ 0.749684] iommu: Adding device 3510000.hda to group 20
[ 0.750302] iommu: Adding device bc00000.rtcpu to group 21
[ 0.752062] iommu: Adding device 13e10000.host1x to group 22
[ 0.752480] iommu: Adding device 13e10000.host1x:ctx0 to group 23
[ 0.752953] iommu: Adding device 13e10000.host1x:ctx1 to group 24
[ 0.753359] iommu: Adding device 13e10000.host1x:ctx2 to group 25
[ 0.753880] iommu: Adding device 13e10000.host1x:ctx3 to group 26
[ 0.754457] iommu: Adding device 13e10000.host1x:ctx4 to group 27
[ 0.754906] iommu: Adding device 13e10000.host1x:ctx5 to group 28
[ 0.755288] iommu: Adding device 13e10000.host1x:ctx6 to group 29
[ 0.755685] iommu: Adding device 13e10000.host1x:ctx7 to group 30
[ 0.756235] iommu: Adding device 15340000.vic to group 31
[ 0.756653] iommu: Adding device 15380000.nvjpg to group 32
[ 0.756983] iommu: Adding device 15500000.tsec to group 33
[ 0.757287] iommu: Adding device 15100000.tsecb to group 34
[ 0.757620] iommu: Adding device 15480000.nvdec to group 35
[ 0.757984] iommu: Adding device 15140000.nvdec1 to group 36
[ 0.758302] iommu: Adding device 154c0000.nvenc to group 37
[ 0.758617] iommu: Adding device 15a80000.nvenc1 to group 38
[ 0.759070] iommu: Adding device 15880000.nvdla0 to group 39
[ 0.759598] iommu: Adding device 158c0000.nvdla1 to group 40
[ 0.760249] iommu: Adding device 15200000.nvdisplay to group 41
[ 0.764364] platform 15200000.nvdisplay: IOVA linear map 0x00000000c6000000(2a000000)
[ 0.764483] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[ 0.765266] iommu: Adding device 15210000.nvdisplay to group 42
[ 0.765374] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[ 0.767664] iommu: Adding device 15c10000.vi to group 43
[ 0.767858] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[ 0.768329] iommu: Adding device 14800000.isp to group 44
[ 0.769316] iommu: Adding device 16000000.pva0 to group 45
[ 0.769964] iommu: Adding device 16800000.pva1 to group 46
[ 0.770485] iommu: Adding device 15810000.se to group 47
[ 0.770897] iommu: Adding device 15820000.se to group 48
[ 0.771204] iommu: Adding device 15830000.se to group 49
[ 0.771567] iommu: Adding device 15840000.se to group 50
[ 0.771862] iommu: Adding device c1a0000.aon to group 51
[ 0.773435] iommu: Adding device d000000.bpmp to group 52
[ 0.773778] bpmp: ping status is 0
[ 0.773927] bpmp d000000.bpmp: firmware tag is e73a758761f0c6d24a1e69a2ac6b5035
[ 0.777017] bpmp d000000.bpmp: probe ok
[ 0.778981] tegra-reset 0.bpmp_reset: registered 190 resets.
[ 0.779549] iommu: Adding device smmu_test to group 53
[ 0.780678] mc: mapped MMIO address: 0xffffff800a5e0000 → 0x2c10000
[ 0.780744] mc: mapped MMIO address: 0xffffff800a7b0000 → 0x2c20000
[ 0.780813] mc: mapped MMIO address: 0xffffff800a7d0000 → 0x2c30000
[ 0.780875] mc: mapped MMIO address: 0xffffff800b010000 → 0x2c40000
[ 0.780945] mc: mapped MMIO address: 0xffffff800b030000 → 0x2c50000
[ 0.780996] mc: mapped MMIO address: 0xffffff800b050000 → 0x2b80000
[ 0.781052] mc: mapped MMIO address: 0xffffff800b070000 → 0x2b90000
[ 0.781108] mc: mapped MMIO address: 0xffffff800b090000 → 0x2ba0000
[ 0.781166] mc: mapped MMIO address: 0xffffff800b0b0000 → 0x2bb0000
[ 0.781229] mc: mapped MMIO address: 0xffffff800b0d0000 → 0x1700000
[ 0.781306] mc: mapped MMIO address: 0xffffff800b0f0000 → 0x1710000
[ 0.781355] mc: mapped MMIO address: 0xffffff800b110000 → 0x1720000
[ 0.781424] mc: mapped MMIO address: 0xffffff800b130000 → 0x1730000
[ 0.781473] mc: mapped MMIO address: 0xffffff800b150000 → 0x1740000
[ 0.781541] mc: mapped MMIO address: 0xffffff800b170000 → 0x1750000
[ 0.781589] mc: mapped MMIO address: 0xffffff800b190000 → 0x1760000
[ 0.781660] mc: mapped MMIO address: 0xffffff800b1b0000 → 0x1770000
[ 0.781793] mc-err: mcerr ops are set to t19x
[ 0.788209] iommu: Adding device 2600000.dma to group 54
[ 0.793376] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 224 lines on the chip
[ 0.794782] GPIO line 339 (wifi-enable) hogged as output/high
[ 0.794853] GPIO line 412 (camera-control-output-low) hogged as output/low
[ 0.794916] GPIO line 413 (camera-control-output-low) hogged as output/low
[ 0.795263] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.803239] gpio gpiochip1: gpio-line-names specifies 21 line names but there are 40 lines on the chip
[ 0.803366] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[ 0.803432] GPIO line 266 (w-disable1) hogged as output/high
[ 0.803502] GPIO line 264 (w-disable2) hogged as output/high
[ 0.803565] GPIO line 265 (suspend-led-gpio) hogged as output/high
[ 0.803942] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[ 0.806420] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_83 = 0x10a
[ 0.806484] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.806514] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.807413] iommu: Adding device 3550000.xudc to group 55
[ 0.808182] iommu: Adding device 3610000.xhci to group 56
[ 0.810426] arm64_ras arm64_ras: probed
[ 0.810865] ras_fhi_enable: FHI 470 enabled on CPU0
[ 0.810932] ras_fhi_enable: FHI 471 enabled on CPU1
[ 0.811033] ras_fhi_enable: FHI 472 enabled on CPU2
[ 0.811127] ras_fhi_enable: FHI 473 enabled on CPU3
[ 0.811222] ras_fhi_enable: FHI 474 enabled on CPU4
[ 0.811349] ras_fhi_enable: FHI 475 enabled on CPU5
[ 0.811566] carmel_ras_enable: RAS enabled on cpu0
[ 0.811757] carmel_ras_enable: RAS enabled on cpu1
[ 0.811979] carmel_ras_enable: RAS enabled on cpu2
[ 0.812194] carmel_ras_enable: RAS enabled on cpu3
[ 0.812450] carmel_ras_enable: RAS enabled on cpu4
[ 0.812701] carmel_ras_enable: RAS enabled on cpu5
[ 0.812803] carmel_ras carmel_ras: probed
[ 0.813963] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 479, noc_nonsecure_irq = 478>
[ 0.814658] tegra-cbb c600000.aon-noc: noc_secure_irq = 481, noc_nonsecure_irq = 480>
[ 0.815911] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 483, noc_nonsecure_irq = 482>
[ 0.816801] tegra-cbb be00000.rce-noc: noc_secure_irq = 485, noc_nonsecure_irq = 484>
[ 0.817727] tegra-cbb b600000.sce-noc: noc_secure_irq = 487, noc_nonsecure_irq = 486>
[ 0.818198] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[ 0.819556] vdd-ac-bat: 5000 mV
[ 0.820088] vdd-sdmmc1-sw: 3300 mV
[ 0.820420] vdd-1v8-sd: 1800 mV
[ 0.820791] vdd-3v3-cvb: 3300 mV
[ 0.821131] vdd-1v8-cvb: 1800 mV
[ 0.821458] vdd-epb-1v0: 1000 mV
[ 0.821665] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 0.821993] avdd-cam-2v8: 2800 mV
[ 0.822349] vdd-fan: 5000 mV
[ 0.822707] vdd-hdmi-5v0: 5000 mV
[ 0.823042] vdd_sys_en: 1200 mV
[ 0.857104] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.861692] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.862036] SCSI subsystem initialized
[ 0.862568] usbcore: registered new interface driver usbfs
[ 0.862677] usbcore: registered new interface driver hub
[ 0.862749] usbcore: registered new device driver usb
[ 0.874425] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[ 0.877276] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 0.886961] vdd-1v0: at 1000 mV
[ 0.895033] vdd-1v8-hs: at 1800 mV
[ 0.903018] vdd-1v8-ls: at 1800 mV
[ 0.911043] vdd-1v8-ao: at 1800 mV
[ 0.919105] vddio-ddr-1v1: at 1100 mV
[ 0.926892] vdd-rtc: at 800 mV
[ 0.928446] spmic-ldo1: at 2375 mV
[ 0.938952] vdd-ao-3v3: at 3300 mV
[ 0.950989] vddio-emmc-3v3: at 3300 mV
[ 0.952370] spmic-ldo4: at 1587 mV
[ 0.963043] vdd-usb-3v3: at 3300 mV
[ 0.972626] vddio-sdmmc1-3v3: at 3300 mV
[ 0.976618] vdd-csi-1v2: at 1200 mV
[ 0.978308] spmic-ldo8: at 1800 mV
[ 0.983238] GPIO line 246 (gpio_default) hogged as output/high
[ 0.984681] GPIO line 247 (gpio_default) hogged as output/high
[ 0.985014] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[ 0.985456] max77620 4-003c: max77620 probe successful
[ 0.986211] media: Linux media interface: v0.10
[ 0.986338] Linux video capture interface: v2.00
[ 0.987935] pps_core: LinuxPPS API ver. 1 registered
[ 0.987970] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.988019] PTP clock support registered
[ 0.988318] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 0.988633] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.988718] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.991341] trusty trusty: trusty version: Built: 12:20:34 Jul 26 2021
[ 0.991419] trusty trusty: selected api version: 3 (requested 3)
[ 0.992438] Advanced Linux Sound Architecture Driver Initialized.
[ 0.993001] Bluetooth: Core ver 2.22
[ 0.993055] NET: Registered protocol family 31
[ 0.993075] Bluetooth: HCI device and connection manager initialized
[ 0.993104] Bluetooth: HCI socket layer initialized
[ 0.993150] Bluetooth: L2CAP socket layer initialized
[ 0.993202] Bluetooth: SCO socket layer initialized
[ 0.995924] camchar: rtcpu character device driver loaded
[ 0.996560] gpio tegra-gpio wake61 for gpio=201(Z:1)
[ 0.996679] extcon-gpio-states external-connection:extcon@1: Cable state:0, cable id:0
[ 0.997621] clocksource: Switched to clocksource arch_sys_counter
[ 1.043171] VFS: Disk quotas dquot_6.6.0
[ 1.043284] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.043627] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 1.044853] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[ 1.044946] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[ 1.045272] cma: enabled page replacement for spfn=c6000, epfn=f0000
[ 1.045297] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 1.045324] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[ 1.045353] nvmap_page_pool_init: Total RAM pages: 1986072
[ 1.045373] nvmap_page_pool_init: nvmap page pool size: 248259 pages (969 MB)
[ 1.045854] nvmap_background_zero_thread: PP zeroing thread starting.
[ 1.046409] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[ 1.047940] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 1.061473] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 1.061805] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 1.062059] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[ 1.062290] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[ 1.062498] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 1.063666] la/ptsa driver initialized.
[ 1.064017] NET: Registered protocol family 2
[ 1.064797] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 1.065158] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 1.065820] TCP: Hash tables configured (established 65536 bind 65536)
[ 1.065887] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 1.066029] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 1.066462] NET: Registered protocol family 1
[ 1.067065] RPC: Registered named UNIX socket transport module.
[ 1.067089] RPC: Registered udp transport module.
[ 1.067108] RPC: Registered tcp transport module.
[ 1.067126] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.067353] Trying to unpack rootfs image as initramfs…
[ 1.289400] Freeing initrd memory: 7068K
[ 1.307938] random: fast init done
[ 1.312110] host1x 13e10000.host1x: initialized
[ 1.313866] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.318410] audit: initializing netlink subsys (disabled)
[ 1.318478] audit: type=2000 audit(0.928:1): initialized
[ 1.319134] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 1.329236] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.330584] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.331233] 9p: Installing v9fs 9p2000 file system support
[ 1.336646] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.336844] io scheduler noop registered
[ 1.337138] io scheduler cfq registered (default)
[ 1.340804] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 1.375922] iommu: Adding device 2993000.adsp to group 57
[ 1.484175] iommu: Adding device aconnect@2a41000:adsp_audio to group 58
[ 1.485212] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.497956] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.498404] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.498989] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.499373] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[ 1.499750] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.502879] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.503111] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 1.505747] tsec 15500000.tsec: initialized
[ 1.507329] tsec 15100000.tsecb: initialized
[ 1.511064] nvdec 15480000.nvdec: initialized
[ 1.513635] nvdec 15140000.nvdec1: initialized
[ 1.518916] falcon 15340000.vic: initialized
[ 1.520912] falcon 15380000.nvjpg: initialized
[ 1.522969] falcon 154c0000.nvenc: initialized
[ 1.524954] falcon 15a80000.nvenc1: initialized
[ 1.528458] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.530144] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.531750] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.533363] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.534914] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.536396] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.538108] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.539696] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.543180] t194-nvcsi 15a00000.nvcsi: initialized
[ 1.548478] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 1.548866] scare-pigeon 14b00000.isp-thi: initialized
[ 1.554348] pva 16000000.pva0: initialized
[ 1.560075] pva 16800000.pva1: initialized
[ 1.564715] nvdla 15880000.nvdla0: initialized
[ 1.569086] nvdla 158c0000.nvdla1: initialized
[ 1.570748] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.570781] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.570828] tegradccommon 15200000.dc_common: dma mapping done
[ 1.571301] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor1
[ 1.571362] generic_infoframe_type: 0x87
[ 1.571451] tegradc 15200000.nvdisplay: DT parsed successfully
[ 1.571521] tegradc 15200000.nvdisplay: Display dc.ffffff800bd50000 registered with id=0
[ 1.575198] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 1.575234] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 933000000 Hz
[ 1.575257] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[ 1.575475] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[ 1.575500] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[ 1.578088] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.578123] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.613446] tegradc 15200000.nvdisplay: probed
[ 1.614308] Console: switching to colour frame buffer device 210x65
[ 1.614470] tegradc 15200000.nvdisplay: fb registered
[ 1.614726] gpio tegra-gpio wake63 for gpio=97(M:1)
[ 1.615595] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 1.615727] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 1.620417] Parent Clock set for DC plld2
[ 1.625442] tegradc 15200000.nvdisplay: hdmi: tmds rate:146361K prod-setting:prod_c_hdmi_111m_223m
[ 1.626799] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 1.661413] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 1.661435] Extcon AUX1(HDMI) enable
[ 1.661876] tegradc 15210000.nvdisplay: disp1 connected to head1->/host1x/sor
[ 1.661930] tegradc 15210000.nvdisplay: parse_dp_settings: No dp-lt-settings node
[ 1.662037] tegradc 15210000.nvdisplay: DT parsed successfully
[ 1.662093] tegradc 15210000.nvdisplay: Display dc.ffffff800be50000 registered with id=1
[ 1.662296] tegradc 15210000.nvdisplay: vblank syncpt # 11 for dc 1
[ 1.662318] tegradc 15210000.nvdisplay: vpulse3 syncpt # 12 for dc 1
[ 1.670480] tegradc 15210000.nvdisplay: probed
[ 1.670798] tegradc 15210000.nvdisplay: fb registered
[ 1.674135] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.674198] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.674224] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.674252] tegradc 15210000.nvdisplay: blank - powerdown
[ 1.674284] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[ 1.674302] Extcon DP: HPD disabled
[ 1.674317] hpd: hpd_switch 0
[ 1.674354] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.674377] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.674395] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.674703] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=78
[ 1.674728] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[ 1.674997] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 1.675141] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 1.675299] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 1.675318] tegra_cec 3960000.tegra_cec: probed
[ 1.685647] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[ 1.686416] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check disabled
[ 1.686448] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.686797] kfuse 3830000.kfuse: initialized
[ 1.693302] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.696276] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 47, base_baud = 0) is a TEGRA_UART
[ 1.697269] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 48, base_baud = 0) is a TEGRA_UART
[ 1.698352] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 49, base_baud = 0) is a TEGRA_UART
[ 2.689670] tegra_cec 3960000.tegra_cec: physical address: 10:00.
[ 2.754222] tegra_cec 3960000.tegra_cec: Sent res: -113.
[ 2.754252] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
��[ 4.294562] console [ttyTCU0] enabled
[ 4.294661] tegradc 15200000.nvdisplay: blank - powerdown
[ 4.294892] [drm] Initialized
[ 4.314511] brd: module loaded
[ 4.319619] loop: module loaded
[ 4.319676] tegra_profiler: version: 1.145, samples/io: 49/28
[ 4.319827] tegra_profiler: auth: init
[ 4.320458] THERMAL EST: found 3 subdevs
[ 4.320463] THERMAL EST num_resources: 0
[ 4.320467] [THERMAL EST subdev 0]
[ 4.320472] [THERMAL EST subdev 1]
[ 4.320476] [THERMAL EST subdev 2]
[ 4.320485] THERMAL EST: Found 2 profiles, default profile is quiet
[ 4.320877] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 4.320880] THERMAL EST: thz register success.
[ 4.321120] THERMAL EST: end of probe, return err: 0
[ 4.321800] sd: No Scsi addr parsed to reserve index
[ 4.321831] hisi_sas: driver version v1.6
[ 4.332202] qspi_mtd spi6.0: s25fs256s SSG 8 0 1000 2000000
[ 4.332208] qspi_mtd spi6.0: s25fs256s (32768 Kbytes)
[ 4.332216] qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x2000000 (32MiB) .erasesize = 0x00010000 (64KiB) .numeraseregions = 0
[ 4.332441] 1 ofpart partitions found on MTD device spi6.0
[ 4.332444] Creating 1 MTD partitions on “spi6.0”:
[ 4.332460] 0x000000000000-0x000002000000 : “Whole_flash0”
[ 4.334795] libphy: Fixed MDIO Bus: probed
[ 4.336584] tun: Universal TUN/TAP device driver, 1.6
[ 4.336588] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 4.337327] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 4.337330] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.337368] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 4.337371] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.337402] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 4.337405] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 4.337435] ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver - version 4.4.0-k
[ 4.337438] ixgbe: Copyright (c) 1999-2016 Intel Corporation.
[ 4.343701] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 4.343705] Extcon AUX1(HDMI) disable
[ 4.369220] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 4.370542] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 4.540903] tegradc 15200000.nvdisplay: unblank
[ 4.542971] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 4.543290] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 4.554336] Parent Clock set for DC plld2
[ 4.559161] tegradc 15200000.nvdisplay: hdmi: tmds rate:146250K prod-setting:prod_c_hdmi_111m_223m
[ 4.560588] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 4.580592] eqos 2490000.ether_qos: failed to read eqos_auto_cal_config_0_reg
[ 4.581107] eqos_get_mac_address_dtb: bad mac address at /chosen/nvidia,ether-mac: null.
[ 4.581117] eqos 2490000.ether_qos (unnamed net_device) (uninitialized): ether-mac read from DT failed -99
[ 4.581125] eqos 2490000.ether_qos (unnamed net_device) (uninitialized): EQOS using random MAC address: 4a:07:a8:21:36:72
[ 4.581140] Using phyrst_lpmode = 1 from DT
[ 4.581255] libphy: dwc_phy: probed
[ 4.583843] PPP generic driver version 2.4.2
[ 4.584043] PPP BSD Compression module registered
[ 4.584048] PPP Deflate Compression module registered
[ 4.584064] PPP MPPE Compression module registered
[ 4.584069] NET: Registered protocol family 24
[ 4.584118] usbcore: registered new interface driver r8152
[ 4.584153] usbcore: registered new interface driver asix
[ 4.584185] usbcore: registered new interface driver ax88179_178a
[ 4.584216] usbcore: registered new interface driver cdc_ether
[ 4.584244] usbcore: registered new interface driver net1080
[ 4.584271] usbcore: registered new interface driver cdc_subset
[ 4.584311] usbcore: registered new interface driver zaurus
[ 4.584356] usbcore: registered new interface driver cdc_ncm
[ 4.584615] VFIO - User Level meta-driver version: 0.3
[ 4.585924] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 4.585942] ehci-pci: EHCI PCI platform driver
[ 4.585971] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 4.585979] ohci-pci: OHCI PCI platform driver
[ 4.586032] ohci-platform: OHCI generic platform driver
[ 4.590771] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 4.592911] tegra-xusb 3610000.xhci: extcon 0: ffffffc1f4da8000 id
[ 4.593834] usbcore: registered new interface driver uas
[ 4.593895] usbcore: registered new interface driver usb-storage
[ 4.594144] usbcore: registered new interface driver usbserial
[ 4.595399] tegra-xusb 3610000.xhci: Firmware timestamp: 2020-09-11 16:55:03 UTC, Version: 60.09 release
[ 4.595430] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 4.595450] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 4.595679] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 4.595682] Extcon AUX1(HDMI) enable
[ 4.596160] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[ 4.596205] tegra-xusb 3610000.xhci: irq 465, io mem 0x03610000
[ 4.596507] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.596514] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.596518] usb usb1: Product: xHCI Host Controller
[ 4.596523] usb usb1: Manufacturer: Linux 4.9.253-tegra xhci-hcd
[ 4.596526] usb usb1: SerialNumber: 3610000.xhci
[ 4.597214] hub 1-0:1.0: USB hub found
[ 4.597315] hub 1-0:1.0: 4 ports detected
[ 4.597947] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 4.597959] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 4.597967] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 4.598178] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 4.598183] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.598187] usb usb2: Product: xHCI Host Controller
[ 4.598191] usb usb2: Manufacturer: Linux 4.9.253-tegra xhci-hcd
[ 4.598195] usb usb2: SerialNumber: 3610000.xhci
[ 4.599854] hub 2-0:1.0: USB hub found
[ 4.599901] hub 2-0:1.0: 4 ports detected
[ 4.601559] Wake76 for irq=199
[ 4.601563] Wake77 for irq=199
[ 4.601566] Wake78 for irq=199
[ 4.601569] Wake79 for irq=199
[ 4.601572] Wake80 for irq=199
[ 4.601575] Wake81 for irq=199
[ 4.601578] Wake82 for irq=199
[ 4.601726] tegra-xusb 3610000.xhci: Upgrade port 0 to USB3.0
[ 4.601732] tegra-xusb 3610000.xhci: Upgrade port 1 to USB3.0
[ 4.602059] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 4.602131] tegra-xudc-new 3550000.xudc: device count: 1
[ 4.603123] tegra-xudc-new 3550000.xudc: vbus state: 0
[ 4.603134] tegra-xudc-new 3550000.xudc: Initialize boost_cpufreq work
[ 4.603157] tegra-xudc-new 3550000.xudc: entering ELPG
[ 4.603440] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 4.604062] mousedev: PS/2 mouse device common for all mice
[ 4.604176] usbcore: registered new interface driver xpad
[ 4.610831] tegradc 15200000.nvdisplay: sync windows ret = 246
[ 4.702188] usb usb2: usb_suspend_both: status 0
[ 4.745155] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 4.755689] Wake73 for irq=42
[ 4.757079] rtc rtc1: alarm rtc device
[ 4.757094] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 4.757124] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.757374] i2c /dev entries driver
[ 4.759852] i2c i2c-2: Added multiplexed i2c bus 9
[ 4.760306] i2c i2c-2: Added multiplexed i2c bus 10
[ 4.760311] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[ 4.761024] imx219 9-0010: tegracam sensor driver:imx219_v2.0.6
[ 4.790173] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[ 4.790254] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[ 4.790358] imx219 9-0010: board setup failed
[ 4.790437] imx219: probe of 9-0010 failed with error -121
[ 4.790731] imx219 10-0010: tegracam sensor driver:imx219_v2.0.6
[ 4.821225] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[ 4.821312] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[ 4.821428] imx219 10-0010: board setup failed
[ 4.821526] imx219: probe of 10-0010 failed with error -121
[ 4.832004] max77620-power max20024-power: Event recorder REG_NVERC : 0x40
[ 4.937613] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 4.971505] tegra-thermal-throttle bthrot_cdev: cpufreq policy is not ready defer
[ 4.971962] FAN dev name: pwm-fan
[ 4.972004] FAN:gpio request success.
[ 4.972012] FAN: can’t find tach_gpio
[ 4.972021] pwm_fan_driver pwm-fan: Found 2 profiles, default profile is quiet
[ 4.972052] pwm_fan_driver pwm-fan: cap state:4, cap pwm:255
[ 4.972332] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 4.972337] pwm_fan_driver pwm-fan: tach period: 1000
[ 5.012932] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 5.012940] pwm_fan_driver pwm-fan: index 1: pwm=130, rpm=1000, rru=2, rrd=2, state:2
[ 5.012945] pwm_fan_driver pwm-fan: index 2: pwm=160, rpm=2000, rru=1, rrd=1, state:2
[ 5.012950] pwm_fan_driver pwm-fan: index 3: pwm=200, rpm=3000, rru=1, rrd=1, state:2
[ 5.012955] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 5.012960] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 5.012965] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 5.012970] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 5.012975] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 5.012980] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 5.014196] tegra-oc-event d280000.soctherm-oc-event: OC driver initialized
[ 5.015446] device-mapper: uevent: version 1.0.3
[ 5.016005] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 5.025199] usb 1-2: New USB device found, idVendor=0bda, idProduct=5489
[ 5.025205] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.025210] usb 1-2: Product: 4-Port USB 2.0 Hub
[ 5.025214] usb 1-2: Manufacturer: Generic
[ 5.037839] hub 1-2:1.0: USB hub found
[ 5.043690] hub 1-2:1.0: 4 ports detected
[ 5.495548] extcon-disp-state external-connection:disp-state: cable 51 state 1
[ 5.502640] Extcon HDMI: HPD enabled
[ 5.506079] tegradc 15200000.nvdisplay: hdmi: plugged
[ 5.513953] tegra194_cpufreq_probe: platform driver Initialization: pass
[ 5.519170] cpuidle: Initializing cpuidle driver
[ 5.523867] sdhci: Secure Digital Host Controller Interface driver
[ 5.529049] sdhci: Copyright(c) Pierre Ossman
[ 5.533075] sdhci-pltfm: SDHCI platform and OF driver helper
[ 5.540077] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 5.548538] CMDQ: cmdq_platfm_init successful
[ 5.550814] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 5.557643] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 5.564062] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 247
[ 5.573117] tegra-se-nvhost 15810000.se: initialized
[ 5.576028] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 5.580699] tegra-se-nvhost 15820000.se: initialized
[ 5.585752] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 5.591572] tegra-se-nvhost 15830000.se: initialized
[ 5.596310] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 5.597656] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 5.612169] tegra-se-nvhost 15840000.se: initialized
[ 5.617039] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 5.617727] gpio tegra-gpio wake8 for gpio=55(G:7)
[ 5.617785] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 5.637570] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 5.642773] hidraw: raw HID events driver (C) Jiri Kosina
[ 5.649258] usbcore: registered new interface driver usbhid
[ 5.653801] usbhid: USB HID core driver
[ 5.661892] tegra186-cam-rtcpu bc00000.rtcpu: deferring, 14800000.isp is not probed
[ 5.667118] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 5.671752] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 5.677901] denver_knobs_init:MTS_VERSION:53250041
[ 5.682356] tegra19x_actmon d230000.actmon: in actmon_register()…
[ 5.688833] tegra19x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 5.696724] t19x_cache tegra-cache: probed
[ 5.702730] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[ 5.708282] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[ 5.716647] carmel-pmu-drv carmel-pmu: Registered Carmel PMU
[ 5.721795] PLL_AON clock registered
[ 5.726575] Clocks initialized successfully
[ 5.730939] nvpmodel: initialized successfully
[ 5.734683] trusty-virtio trusty:virtio: initializing
[ 5.738646] trusty_ipc virtio0: vring0: va¶ ffffffc1e2758000(0) qsz 32 notifyid 1
[ 5.746416] usb 2-3: new SuperSpeedPlus USB device number 2 using tegra-xusb
[ 5.753264] trusty_ipc virtio0: vring1: va¶ ffffffc1e275a000(0) qsz 32 notifyid 2
[ 5.761101] trusty-virtio trusty:virtio: initializing done
[ 5.761220] trusty_ipc virtio0: is online
[ 5.771543] usbcore: registered new interface driver snd-usb-audio
[ 5.778187] tegra-hda 3510000.hda: Override SDO lines to 4
[ 5.787377] usb 2-3: New USB device found, idVendor=0bda, idProduct=0489
[ 5.788950] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.796159] usb 2-3: Product: 4-Port USB 3.0 Hub
[ 5.801058] usb 2-3: Manufacturer: Generic
[ 5.815701] hub 2-3:1.0: USB hub found
[ 5.819052] hub 2-3:1.0: 4 ports detected
[ 5.827015] input: tegra-hda-xnx HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 5.828882] input: tegra-hda-xnx HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 5.830789] input: tegra-hda-xnx HDMI/DP,pcm=8 as /devices/3510000.hda/sound/card0/input2
[ 5.838075] OPE platform probe
[ 5.838167] OPE platform probe successful
[ 5.845460] input: tegra-hda-xnx HDMI/DP,pcm=9 as /devices/3510000.hda/sound/card0/input3
[ 5.861895] mmc1: host does not support reading read-only switch, assuming write-enable
[ 5.865636] usb 1-2.3: new low-speed USB device number 3 using tegra-xusb
[ 5.903303] usb 1-2.3: New USB device found, idVendor=17ef, idProduct=6018
[ 5.904935] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.906561] usb 1-2.3: Product: Lenovo Low Profile USB Keyboard
[ 5.908084] usb 1-2.3: Manufacturer: Lite-On Technology Corp.
[ 5.912088] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 5.913877] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 5.915570] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 5.917209] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 5.918818] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 5.922103] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 5.923479] input: Lite-On Technology Corp. Lenovo Low Profile USB Keyboard as /devices/3610000.xhci/usb1/1-2/1-2.3/1-2.3:1.0/0003:17EF:6018.0001/input/input4
[ 5.942146] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 5.947891] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 5.953613] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 5.959281] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 5.965379] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 5.971611] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 5.977668] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 5.983503] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 5.986025] hid-generic 0003:17EF:6018.0001: input,hidraw0: USB HID v1.10 Keyboard [Lite-On Technology Corp. Lenovo Low Profile USB Keyboard] on usb-3610000.xhci-2.3/input0
[ 6.005321] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 6.011178] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 6.016956] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 6.023192] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 6.024168] input: Lite-On Technology Corp. Lenovo Low Profile USB Keyboard as /devices/3610000.xhci/usb1/1-2/1-2.3/1-2.3:1.1/0003:17EF:6018.0002/input/input5
[ 6.043208] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 6.049199] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 6.083429] hid-generic 0003:17EF:6018.0002: input,hidraw1: USB HID v1.10 Device [Lite-On Technology Corp. Lenovo Low Profile USB Keyboard] on usb-3610000.xhci-2.3/input1
[ 6.087061] u32 classifier
[ 6.088644] Actions configured
[ 6.090314] Initializing XFRM netlink socket
[ 6.092553] NET: Registered protocol family 10
[ 6.094934] NET: Registered protocol family 17
[ 6.096447] NET: Registered protocol family 15
[ 6.098055] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 6.107629] Bluetooth: RFCOMM socket layer initialized
[ 6.112654] Bluetooth: RFCOMM ver 1.11
[ 6.116488] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 6.122167] Bluetooth: HIDP socket layer initialized
[ 6.127432] 9pnet: Installing 9P2000 support
[ 6.131944] Key type dns_resolver registered
[ 6.136423] mmc1: hw tuning done …
[ 6.139554] Registered cp15_barrier emulation handler
[ 6.139585] mmc1: new ultra high speed SDR104 SDXC card at address aaaa
[ 6.140035] mmcblk1: mmc1:aaaa SD128 119 GiB
[ 6.144440] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[ 6.161280] Registered setend emulation handler
[ 6.168103] registered taskstats version 1
[ 6.169631] usb 1-2.4: new low-speed USB device number 4 using tegra-xusb
[ 6.177598] tegra-pcie-dw 14160000.pcie: Setting init speed to max speed
[ 6.185207] OF: PCI: host bridge /pcie@14160000 ranges:
[ 6.188918] OF: PCI: IO 0x36100000…0x361fffff → 0x36100000
[ 6.193950] usb 1-2.4: New USB device found, idVendor=046d, idProduct=c018
[ 6.193955] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.193958] usb 1-2.4: Product: USB Optical Mouse
[ 6.193962] usb 1-2.4: Manufacturer: Logitech
[ 6.196769] input: Logitech USB Optical Mouse as /devices/3610000.xhci/usb1/1-2/1-2.4/1-2.4:1.0/0003:046D:C018.0003/input/input6
[ 6.197155] hid-generic 0003:046D:C018.0003: input,hidraw2: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-3610000.xhci-2.4/input0
[ 6.241680] OF: PCI: MEM 0x1740000000…0x17ffffffff → 0x40000000
[ 6.247714] OF: PCI: MEM 0x1400000000…0x173fffffff → 0x1400000000
[ 6.365631] tegra-pcie-dw 14160000.pcie: link is up
[ 6.367519] tegra-pcie-dw 14160000.pcie: PCI host bridge to bus 0004:00
[ 6.369152] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 6.370785] pci_bus 0004:00: root bus resource [io 0x0000-0xfffff] (bus address [0x36100000-0x361fffff])
[ 6.372469] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[ 6.374204] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[ 6.376249] iommu: Adding device 0004:00:00.0 to group 59
[ 6.378304] pci 0004:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid
[ 6.381204] iommu: Adding device 0004:01:00.0 to group 60
[ 6.394550] pci 0004:00:00.0: BAR 14: assigned [mem 0x1740000000-0x17400fffff]
[ 6.396304] pci 0004:00:00.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 6.397991] usb 2-3: usb_suspend_both: status 0
[ 6.398207] usb usb2: usb_suspend_both: status 0
[ 6.401495] pci 0004:01:00.0: BAR 2: assigned [mem 0x1740000000-0x174000ffff 64bit]
[ 6.403329] pci 0004:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 6.404987] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 6.406607] pci 0004:00:00.0: bridge window [io 0x1000-0x1fff]
[ 6.408244] pci 0004:00:00.0: bridge window [mem 0x1740000000-0x17400fffff]
[ 6.409973] pci 0004:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 6.411832] pci 0004:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 6.413959] pcieport 0004:00:00.0: Signaling PME through PCIe PME interrupt
[ 6.418444] pci 0004:01:00.0: Signaling PME through PCIe PME interrupt
[ 6.425439] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[ 6.431531] tegra-pcie-dw 141a0000.pcie: Failed to get 3V slot regulator: -19
[ 6.438688] tegra-pcie-dw 141a0000.pcie: Failed to get 12V slot regulator: -19
[ 6.529611] usb 1-3: new full-speed USB device number 5 using tegra-xusb
[ 6.550843] usb 1-3: New USB device found, idVendor=13d3, idProduct=3549
[ 6.553742] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 6.555457] usb 1-3: Product: Bluetooth Radio
[ 6.557072] usb 1-3: Manufacturer: Realtek
[ 6.558663] usb 1-3: SerialNumber: 00e04c000001
[ 6.558670] OF: PCI: host bridge /pcie@141a0000 ranges:
[ 6.558696] OF: PCI: IO 0x3a100000…0x3a1fffff → 0x3a100000
[ 6.558712] OF: PCI: MEM 0x1f40000000…0x1fffffffff → 0x40000000
[ 6.558726] OF: PCI: MEM 0x1c00000000…0x1f3fffffff → 0x1c00000000
[ 7.078460] tegra-pcie-dw 141a0000.pcie: link is down
[ 7.080205] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0005:00
[ 7.081845] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 7.083383] pci_bus 0005:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x3a100000-0x3a1fffff])
[ 7.084987] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[ 7.086591] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[ 7.088482] iommu: Adding device 0005:00:00.0 to group 61
[ 7.090219] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 7.091752] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 7.093608] pcieport 0005:00:00.0: Signaling PME through PCIe PME interrupt
[ 7.095717] iommu: Removing device 0005:00:00.0 from group 61
[ 7.098784] tegra-pcie-dw 141a0000.pcie: PCIe link is not up…!
[ 7.110461] tegra-cbb 14040000.cv-noc: noc_secure_irq = 91, noc_nonsecure_irq = 90>
[ 7.116397] tegra194-isp5 14800000.isp: initialized
[ 7.125011] tegra194-vi5 15c10000.vi: using default number of vi channels, 36
[ 7.132409] tegra194-vi5 15c10000.vi: initialized
[ 7.138426] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi–2 bound
[ 7.140205] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi–1 bound
[ 7.142069] tegra-thermal-throttle bthrot_cdev: clk:cpu max:1907200000, min:115200000 steps:24
[ 7.148129] tegra-thermal-throttle bthrot_cdev: clk:gpu max:1109250000, min:114750000 steps:10
[ 7.149770] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
[ 7.151326] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
[ 7.152972] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:48 cutoff:0
[ 7.154563] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:0:cpu off:0 slope-adj:400
[ 7.161031] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:1:gpu off:0 slope-adj:400
[ 7.173572] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced max_state:40 cutoff:1
[ 7.177787] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:0:cpu off:0 slope-adj:200
[ 7.186714] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:1:gpu off:365500000 slope-adj:300
[ 7.196470] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced max_state:48 cutoff:0
[ 7.204214] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:0:cpu off:38400000 slope-adj:10
[ 7.213859] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:1:gpu off:25500000 slope-adj:10
[ 7.224341] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced max_state:2 cutoff:0
[ 7.232328] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:0:cpu off:0 slope-adj:400
[ 7.241268] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:1:gpu off:0 slope-adj:400
[ 7.250763] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced max_state:40 cutoff:1
[ 7.258685] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
��WARNING: at platform/drivers/pg/pg-gpu-t194.c:185
��[ 7.343202] tegra-ivc ivc-bc00000.rtcpu: region 0: iova=0xbfee0000-0xbfefffff size=131072
[ 7.344898] tegra-ivc ivc-bc00000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 7.346629] tegra-ivc ivc-bc00000.rtcpu:dbg@1: dbg: ver=0 grp=1 RX[1x384]=0x1900-0x1b00 TX[1x384]=0x1b00-0x1d00
[ 7.348237] tegra-ivc ivc-bc00000.rtcpu:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d00-0x3d80 TX[1x8192]=0x3d80-0x5e00
[ 7.350078] tegra-ivc ivc-bc00000.rtcpu:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e00-0xae80 TX[64x320]=0xae80-0xff00
[ 7.351637] tegra-ivc ivc-bc00000.rtcpu:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff00-0x17f80 TX[512x64]=0x17f80-0x20000
[ 7.353323] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (66)
[ 7.354746] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 7.357330] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=5 sha1=06bdc710c3c9a48de2881774602bbcf4d0114a58
[ 7.362989] Wake83 for irq=211
[ 7.366035] gpio tegra-gpio wake67 for gpio=48(G:0)
[ 7.370925] gpio tegra-gpio-aon wake29 for gpio=36(EE:4)
[ 7.376286] input: gpio-keys as /devices/gpio-keys/input/input7
[ 7.416084] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-01 01:00:19 UTC (946688419)
[ 7.418160] mmcblk mmc1:aaaa: Card claimed for testing.
[ 7.458494] bpmp: mounted debugfs mirror
[ 7.465998] ALSA device list:
[ 7.467445] #0: tegra-hda-xnx at 0x3518000 irq 65
[ 7.468898] #1: jetson-xaviernx-ape
[ 7.471791] Freeing unused kernel memory: 8640K
[ 7.513156] Root device found: mmcblk0p1
[ 17.734521] ERROR: mmcblk0p1 not found
[ 38.241752] vdd-1v8-sd: disabling
[ 38.243240] vdd-1v8-cvb: disabling
[ 38.244664] vdd-epb-1v0: disabling
[ 38.246103] avdd-cam-2v8: disabling
[ 38.247517] vdd-fan: disabling
[ 38.248924] vdd_sys_en: disabling
[ 142.081779] random: crng init done
