$ sudo reboot
[sudo] password for fnaiot:
[ 43.095260] watchdog: watchdog0: watchdog did not stop!
[ 43.101789] systemd-shutdow: 45 output lines suppressed due to ratelimiting
??WARNING: at platform/drivers/pg/pg-gpu-t194.c:185
??[ 43.587204] reboot: Restarting system
????Shutdown state requested 1
Rebooting system ...
[0000.024] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.033] I> MB1 (prd-version: 1.5.1.6-t194-41334769-1740dd39)
[0000.038] I> Boot-mode: Coldboot
[0000.041] I> Chip revision : A02P
[0000.044] I> Bootrom patch version : 15 (correctly patched)
[0000.049] I> ATE fuse revision : 0x200
[0000.053] I> Ram repair fuse : 0x0
[0000.056] I> Ram Code : 0x0
[0000.058] I> rst_source : 0xb
[0000.061] I> rst_level : 0x1
[0000.065] I> Boot-device: QSPI
[0000.067] I> Qspi flash params source = brbct
[0000.071] I> Qspi using bpmp-dma
[0000.074] I> Qspi clock source : pllp
[0000.078] I> QSPI Flash Size = 32 MB
[0000.081] I> Qspi initialized successfully
[0000.085] W> No valid slot number is found in scratch register
[0000.091] W> Return default slot: _a
[0000.094] I> Active Boot chain : 0
[0000.097] I> Boot-device: QSPI
[0000.100] I> Qspi flash params source = brbct
[0000.106] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.112] I> Temperature = 35500
[0000.115] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.119] W> Skipping boost for clk: BPMP_APB
[0000.123] W> Skipping boost for clk: AXI_CBB
[0000.127] W> Skipping boost for clk: AON_CPU_NIC
[0000.131] W> Skipping boost for clk: CAN1
[0000.135] W> Skipping boost for clk: CAN2
[0000.139] I> Boot-device: QSPI
[0000.142] I> Boot-device: QSPI
[0000.145] I> Qspi flash params source = mb1bct
[0000.149] I> Qspi using bpmp-dma
[0000.152] I> Qspi clock source : pllc_out0
[0000.156] I> Qspi reinitialized
[0000.159] I> Qspi flash params source = mb1bct
[0000.164] I> ECC region[0]: Start:0x0, End:0x0
[0000.168] I> ECC region[1]: Start:0x0, End:0x0
[0000.173] I> ECC region[2]: Start:0x0, End:0x0
[0000.177] I> ECC region[3]: Start:0x0, End:0x0
[0000.181] I> ECC region[4]: Start:0x0, End:0x0
[0000.185] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.191] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.195] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.200] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.204] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.209] E> FAILED: Thermal config
[0000.217] E> FAILED: MEMIO rail config
[0000.227] I> Boot-device: QSPI
[0000.230] I> Qspi flash params source = mb1bct
[0000.239] I> Qspi flash params source = mb1bct
[0000.250] I> Qspi flash params source = mb1bct
[0000.317] I> Qspi flash params source = mb1bct
[0000.326] I> Qspi flash params source = mb1bct
[0000.355] I> Qspi flash params source = mb1bct
[0000.366] I> MB1 done
????main enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
[0000.374] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-7515048c)
[0000.375] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.376] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.376] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.382] W> device prod register failed
[0000.386] I> Boot-device: QSPI
[0000.389] I> Boot_device: QSPI_FLASH instance: 0
[0000.394] I> QSPI Flash Size = 32 MB
[0000.400] I> Qspi initialized successfully
[0000.401] I> qspi flash-0 params source = boot args
[0000.405] E> Failed: Unknown device 6
[0000.414] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0000.415] W> No valid slot number is found in scratch register
[0000.420] W> Return default slot: _a
[0000.423] I> Active Boot chain : 0
[0000.427] I> parsing oem signed section of bpmp-fw header done
[0000.433] I> bpmp-fw binary init read from storage
[0000.437] I> oem authentication of bpmp-fw header done
[0000.451] I> bpmp-fw binary done read from storage
[0000.452] I> bpmp-fw: Authentication init Done
[0000.453] I> parsing oem signed section of cpubl header done
[0000.457] I> cpubl binary init read from storage
[0000.461] I> bpmp-fw: Authentication Finalize Done
[0000.466] I> oem authentication of cpubl header done
[0000.473] I> cpubl binary done read from storage
[0000.475] I> cpubl: Authentication init Done
[0000.479] I> parsing oem signed section of rce header done
[0000.484] I> rce binary init read from storage
[0000.489] I> Relocating BR-BCT
[0000.492] I> cpubl: Authentication Finalize Done
[0000.496] I> oem authentication of rce header done
[0000.501] I> rce binary done read from storage
[0000.505] I> rce: Authentication init Done
[0000.509] I> parsing oem signed section of ape header done
[0000.514] I> ape binary init read from storage
[0000.519] I> rce: Authentication Finalize Done
[0000.523] I> oem authentication of ape header done
[0000.527] I> ape binary done read from storage
[0000.532] I> ape: Authentication init Done
[0000.536] I> parsing oem signed section of tos header done
[0000.541] I> tos binary init read from storage
[0000.545] I> ape: Authentication Finalize Done
[0000.550] I> oem authentication of tos header done
[0000.556] I> tos binary done read from storage
[0000.558] I> tos: Authentication init Done
[0000.563] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.569] I> bpmp-fw-dtb binary init read from storage
[0000.573] I> tos: Authentication Finalize Done
[0000.579] I> oem authentication of bpmp-fw-dtb header done
[0000.583] I> bpmp-fw-dtb binary done read from storage
[0000.588] I> bpmp-fw-dtb: Authentication init Done
[0000.593] I> parsing oem signed section of cpubl-dtb header done
[0000.599] I> cpubl-dtb binary init read from storage
[0000.603] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.660] I> oem authentication of cpubl-dtb header done
[0000.660] I> cpubl-dtb binary done read from storage
[0000.661] I> cpubl-dtb: Authentication init Done
[0000.662] I> parsing oem signed section of eks header done
[0000.663] I> eks binary init read from storage
[0000.663] I> cpubl-dtb: Authentication Finalize Done
[0000.664] I> oem authentication of eks header done
[0000.668] I> eks binary done read from storage
[0000.673] I> eks: Authentication init Done
[0000.676] I> eks: Authentication Finalize Done
[0000.681] I> EKB detected (length: 0x410) @ VA:0x52700400
??NOTICE: BL31: v1.3(release):5b49e7f80
NOTICE: BL31: Built : 08:54:10, Jul 9 2021
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 40: hwkey-agent is running!!
hwkey-agent: 197: key_mgnt_processing .......
hwkey-agent: 189: Setting EKB key 0 to slot 14
hwkey-agent: 167: Init hweky-agent services!!
luks-srv: 40: luks-srv is running!!
luks-srv: 157: Init luks-srv IPC services!!
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is e73a758761f0c6d24a1e69a2ac6b5035
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
391 clocks registered
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform_init: bad clk id in clock@cluster1_avfs
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
[0001.021] I> Welcome to Cboot??mrq initialized
WARNING: no registered clock for FMON_NAFLL_CLUSTER1 (id 281)
fmon_post initialized
[0001.022] I> Cboot Version: t194-f9317da2
[0001.024] I> CPU-BL Params @ 0xf2820000
[0001.027] I> 0) Base:0x00000000 Size:0x00000000
[0001.032] I> 1) Base:0xf1100000 Size:0x00100000
??clk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
Failed to register PTO counter for id 281
clk_debugfs initialized
emc_debugfs initialized
dvs_debugfs initialized
fmon_debugfs_init_one: no clock debugfs node to attach FMON_NAFLL_CLUSTER1
fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_rail_debugfs_init: /rm/vdd_cpu: failed
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ??[0001.036] I> 2) Base:0xf2000000 Size:0x00200000
[0001.191] I> 3) Base:0xf1200000 Size:0x00200000
[0001.195] I> 4) Base:0xf1000000 Size:0x00100000
[0001.199] I> 5) Base:0xf0f00000 Size:0x00100000
[0001.204] I> 6) Base:0xf3800000 Size:0x00400000
[0001.208] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.213] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.217] I> 9) Base:0xf0d00000 Size:0x00100000
[0001.222] I> 10) Base:0xf3000000 Size:0x00800000
[0001.226] I> 11) Base:0x40000000 Size:0x00040000
[0001.231] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.235] I> 13) Base:0x40046000 Size:0x00002000
[0001.240] I> 14) Base:0x40048000 Size:0x00002000
[0001.244] I> 15) Base:0xac000000 Size:0x00004000
[0001.249] I> 16) Base:0x4004a000 Size:0x00002000
[0001.253] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.257] I> 18) Base:0x4004c000 Size:0x00002000
[0001.262] I> 19) Base:0xf2200000 Size:0x00600000
[0001.266] I> 20) Base:0x4004e000 Size:0x00002000
[0001.271] I> 21) Base:0xf0ad0000 Size:0x0000c000
[0001.275] I> 22) Base:0x00000000 Size:0x00000000
[0001.280] I> 23) Base:0xf0ae0000 Size:0x00020000
[0001.284] I> 24) Base:0xf6000000 Size:0x02000000
[0001.289] I> 25) Base:0x40050000 Size:0x00002000
[0001.293] I> 26) Base:0x40040000 Size:0x00006000
[0001.298] I> 27) Base:0xf1800000 Size:0x00400000
[0001.302] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.307] I> 29) Base:0xf1400000 Size:0x00400000
[0001.311] I> 30) Base:0x00000000 Size:0x00000000
[0001.315] I> 31) Base:0x00000000 Size:0x00000000
[0001.320] I> 32) Base:0xf8000000 Size:0x08000000
[0001.324] I> 33) Base:0x00000000 Size:0x00000000
[0001.329] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.333] I> 35) Base:0xab000000 Size:0x01000000
[0001.338] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.342] I> 37) Base:0xf2800000 Size:0x00800000
[0001.347] I> 38) Base:0x80000000 Size:0x20000000
[0001.351] I> 39) Base:0xb0000000 Size:0x08000000
[0001.356] I> 40) Base:0x00000000 Size:0x00000000
[0001.360] I> 41) Base:0x00000000 Size:0x00000000
[0001.365] I> 42) Base:0x00000000 Size:0x00000000
[0001.369] I> 43) Base:0x00000000 Size:0x00000000
[0001.374] I> 44) Base:0x00000000 Size:0x00000000
[0001.378] I> 45) Base:0x00000000 Size:0x00000000
[0001.382] GIC-SPI Target CPU: 0
[0001.385] Interrupts Init done
[0001.388] calling constructors
[0001.391] initializing heap
[0001.394] I> Heap: [0xa0694618 ... 0xab000000]
[0001.398] initializing threads
[0001.401] initializing timers
[0001.404] creating bootstrap completion thread
[0001.408] top of bootstrap2()
[0001.411] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.416] initializing platform
[0001.418] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.424] W> device prod register failed
[0001.428] I> Bl_dtb @0xaaf00000
[0001.433] W> "plugin-manager" doesn't exist, creating
[0001.436] W> "ids" doesn't exist, creating
[0001.440] W> "connection" doesn't exist, creating
[0001.444] W> "configs" doesn't exist, creating
[0001.454] I> Find /i2c@3160000's alias i2c0
[0001.455] I> Reading eeprom i2c=0 address=0x50
[0001.482] I> Device at /i2c@3160000:0x50
[0001.482] I> Reading eeprom i2c=0 address=0x57
[0001.483] E> I2C: slave not found in slaves.
[0001.483] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.484] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.485] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 0.
[0001.492] E> eeprom: Failed to read I2C slave device
[0001.497] I> Eeprom read failed 0x3526070d
[0001.502] I> Find /i2c@c240000's alias i2c1
[0001.505] I> Reading eeprom i2c=1 address=0x50
[0001.510] E> I2C: slave not found in slaves.
[0001.513] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.521] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.527] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.536] E> eeprom: Retry to read I2C slave device.
[0001.541] E> I2C: slave not found in slaves.
[0001.545] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.553] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.558] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.568] E> eeprom: Failed to read I2C slave device
[0001.573] I> Eeprom read failed 0x3526070d
[0001.577] I> create_pm_ids: id: 3668-0000-200-H, len: 15
[0001.582] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.593] I> Adding plugin-manager/ids/3668-0000-200=/i2c@3160000:module@0x50
[0001.600] W> "i2c@3160000" doesn't exist, creating
[0001.605] W> "module@0x50" doesn't exist, creating
[0001.611] I> Adding plugin-manager/cvm
[0001.613] W> "chip-id" doesn't exist, creating
[0001.617] I> Adding plugin-manager/chip-id/A02P
[0001.622] I> Plugin-manager override starting
[0001.626] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0001.635] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0001.641] I> node /plugin-manager/fragement-tegra-sdhci-emmc-dis matches
[0001.648] I> Disable plugin-manager status in FDT
[0001.649] I> Plugin-manager override finished successfully
[0001.653] I> gpio framework initialized
[0001.659] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0001.666] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0001.672] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0001.679] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.687] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.694] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.700] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0001.708] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.715] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.722] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.729] I> fixed regulator driver initialized
[0001.736] I> register 'maxim' power off handle
[0001.737] I> virtual i2c enabled
[0001.740] I> registered 'maxim,max20024' pmic
[0001.744] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0001.751] I> Boot-device: QSPI
[0001.753] I> Boot_device: QSPI_FLASH instance: 0
[0001.758] I> QSPI source rate = 204000 Khz
[0001.762] I> Requested rate for QSPI clock = 34000 Khz
[0001.767] I> BPMP-set rate for QSPI clk = 34000 Khz
[0001.772] I> QSPI Flash Size = 32 MB
[0001.779] I> Qspi initialized successfully
[0001.780] I> qspi flash-0 params source = boot args
[0001.784] I> create_pm_ids: id: 3668-0000-200-H, len: 15
[0001.789] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.800] I> Found sdcard
[0001.804] I> enabling 'vdd-sdmmc1-sw' regulator
[0001.810] I> regulator 'vdd-sdmmc1-sw' already enabled
[0001.979] I> sdmmc SDR mode
[0001.993] I> -0 params source =
[0001.995] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0002.005] I> Found 11 partitions in SDCARD (instance 0)
[0002.012] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.016] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.016] E> tegrabl_display_init_regulator: hdmi cable is not connected
[0002.017] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0002.020] E> invalid display type
[0002.021] E> cannot find any other nvdisp nodes
[0002.021] E> no valid display unit config found in dtb
[0002.023] W> display init failed
[0002.025] I> Load in CBoot Boot Options partition and parse it
[0002.031] E> Error -9 when finding node with path /boot-configuration
[0002.037] E> tegrabl_cbo_parse_info: "boot-configuration" not found in CBO file.
[0002.045] I> Using default boot order
[0002.048] I> boot-dev-order :-
[0002.051] I> 1.sd
[0002.053] I> 2.usb
[0002.055] I> 3.nvme
[0002.056] I> 4.emmc
[0002.058] I> 5.net
[0002.060] I> Hit any key to stop autoboot: 4 3 2 1
[0004.068] initializing target
[0004.068] calling apps_init()
[0004.069] starting app kernel_boot_app
[0004.079] I> found decompressor handler: lz4-legacy
[0004.080] I> decompressing BMP blob ...
[0004.092] I> Kernel type = Normal
[0004.092] I> Loading kernel-bootctrl from partition
[0004.092] I> Loading partition kernel-bootctrl at 0xa42d0000 from device(0x6)
[0004.118] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.119] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.120] I> ########## SD (0) boot ##########
[0004.120] I> Found sdcard
[0004.122] I> regulator 'vdd-sdmmc1-sw' already enabled
[0004.125] I> regulator 'vdd-sdmmc1-sw' already enabled
[0004.161] I> sdmmc SDR mode
[0004.175] I> -0 params source =
[0004.175] I> Already published: 00060000
[0004.176] I> Look for boot partition
[0004.176] I> Fallback: assuming 0th partition is boot partition
[0004.176] I> Detect filesystem
[0004.198] I> Loading extlinux.conf ...
[0004.199] I> rootfs path: /sd/boot/extlinux/extlinux.conf
[0004.227] I> L4T boot options
[0004.228] I> [1]: "primary kernel"
[0004.228] I> Enter choice:
[0007.229] I> Continuing with default option: 1
[0007.229] I> Loading kernel sig file from rootfs ...
[0007.229] I> rootfs path: /sd/boot/Image.sig
[0007.242] I> Loading kernel binary from rootfs ...
[0007.243] I> rootfs path: /sd/boot/Image
[0010.034] I> overload load_size to 34273288 (from 34273296)
[0010.057] I> Validate kernel ...
[0010.057] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0010.370] I> Encryption fuse is not ON
[0010.386] I> No kernel-dtb binary path
[0010.387] W> No valid slot number is found in scratch register
[0010.387] W> Return default slot: _a
[0010.387] I> A/B: bin_type (38) slot 0
[0010.388] I> Loading kernel-dtb from partition
[0010.388] I> Loading partition kernel-dtb at 0x91000000 from device(0x6)
[0010.431] I> Validate kernel-dtb ...
[0010.431] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0010.434] I> Encryption fuse is not ON
[0010.435] I> Loading ramdisk from rootfs ...
[0010.435] I> Loading initrd sig file from rootfs ...
[0010.436] I> rootfs path: /sd/boot/initrd.sig
[0010.453] I> Loading initrd binary from rootfs ...
[0010.453] I> rootfs path: /sd/boot/initrd
[0011.050] I> overload load_size to 7237307 (from 7237312)
[0011.053] I> Validate initrd ...
[0011.053] I> T19x: Authenticate initrd (bin_type: 49), max size 0x4000000
[0011.119] I> Encryption fuse is not ON
[0011.133] I> Kernel hdr @0xa42d0000
[0011.133] I> Kernel dtb @0x90000000
[0011.133] I> decompressor handler not found
[0011.134] I> Copying kernel image (34273288 bytes) from 0xa42d0000 to 0x80080000 ... [0011.144] I> Done
[0011.145] I> Updated bpmp info to DTB
[0011.146] I> Ramdisk: Base: 0x92000000; Size: 0x6e6ebb
[0011.146] I> Updated initrd info to DTB
[0011.147] W> WARN: Fail to override "console=none" in commandline
[0011.147] I> Active rootfs suffix:
[0011.149] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0011.156] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0011.164] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0011.171] W> No valid slot number is found in scratch register
[0011.177] W> Return default slot: _a
[0011.180] I> Active slot suffix:
[0011.183] I> add_boot_slot_suffix: slot_suffix =
[0011.188] I> Linux Cmdline: console=ttyTCU0,115200 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[0011.214] I> Updated bootarg info to DTB
[0011.218] W> MAC addr invalid!
[0011.221] E> Failed to get WIFI MAC address
[0011.225] W> MAC addr invalid!
[0011.228] E> Failed to get Bluetooth MAC address
[0011.232] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:07:7f:4d
[0011.239] W> "plugin-manager" doesn't exist, creating
[0011.243] I> Adding /chosen/plugin-manager/cvm
[0011.247] W> "chip-id" doesn't exist, creating
[0011.252] I> Adding /chosen/plugin-manager/chip-id
[0011.256] W> "configs" doesn't exist, creating
[0011.260] I> Adding /chosen/plugin-manager/configs
[0011.265] W> "ids" doesn't exist, creating
[0011.269] I> Adding /chosen/plugin-manager/ids
[0011.273] W> "odm-data" doesn't exist, creating
[0011.278] I> Adding /chosen/plugin-manager/odm-data
[0011.285] W> "memory" doesn't exist, creating
[0011.287] I> [0] START: 0x80000000, END: 0xac000000
[0011.291] I> [1] START: 0xac004000, END: 0xf0ad0000
[0011.296] I> [2] START: 0xf0adc000, END: 0xf0ae0000
[0011.301] I> dram_block larger than 80000000
[0011.305] I> [3] START: 0x100000000, END: 0x280000000
[0011.310] I> added [base:0x80000000, size:0x2c000000] to /memory
[0011.316] I> added [base:0xac200000, size:0x44800000] to /memory
[0011.322] I> added [base:0x100000000, size:0x180000000] to /memory
[0011.328] I> Updated memory info to DTB
[0011.331] E> add_disp_param: failed to get display params for du=0
[0011.338] W> "reset" doesn't exist, creating
[0011.342] I> Adding ecid(00000001647076c210000000150280c0) to DT
[0011.347] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0011.352] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0011.357] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0011.361] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0011.366] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0011.371] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0011.376] I> Deleted cpu@6 node in DT
[0011.379] I> Deleted cpu@7 node in DT
[0011.383] I> Deleted cluster3 node in FDT
[0011.387] I> Update arm-pmu in FDT
[0011.390] I> - update property: interrupts
[0011.394] I> - update property: interrupt-affinity
[0011.399] W> "misc-data" doesn't exist, creating
[0011.403] I> Boot-device: QSPI
[0011.406] W> Unknown boot device
[0011.409] I> Add storage-qspi to plugin-manager/misc-data
[0011.414] W> Unknown storage device
[0011.418] I> Add serial number:1422420034557 as DT property
[0011.423] I> Plugin-manager override starting
[0011.427] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0011.434] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0011.441] I> node /plugin-manager/fragement-tegra-sdhci-emmc-dis matches
[0011.447] I> Disable plugin-manager status in FDT
[0011.449] I> Plugin-manager override finished successfully
[0011.455] I> tegrabl_load_kernel_and_dtb: Done
[0011.459] E> tegrabl_display_clear: display is not initialized
[0011.465] W> Boot logo display failed...
[0011.469] I> Kernel EP: 0x80080000, DTB: 0x90000000
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.201-tegra (liwei@ubuntu) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Mon Aug 2 16:39:50 CST 2021
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44800000
[ 0.000000] OF: fdt: - 100000000 , 180000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb3_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[ 0.000000] cma: Reserved 64 MiB at 0x00000000c2000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s57560 r8192 d32552 u98304
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2001384
[ 0.000000] Kernel command line: console=ttyTCU0,115200 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29108(88%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7190872K/8132608K available (15294K kernel code, 2942K rwdata, 6604K rodata, 8576K init, 609K bss, 188072K reserved, 753664K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f70000 ( 15296 KB)
[ 0.000000] .rodata : 0xffffff8008f70000 - 0xffffff80095f0000 ( 6656 KB)
[ 0.000000] .init : 0xffffff80095f0000 - 0xffffff8009e50000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e50000 - 0xffffff800a12f808 ( 2943 KB)
[ 0.000000] .bss : 0xffffff800a12f808 - 0xffffff800a1c7cbc ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf08000000 ( 128 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc200000000 ( 8192 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000006] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.008443] Console: colour dummy device 80x25
[ 0.012449] console [tty0] enabled
[ 0.015851] bootconsole [tegra_comb_uart0] disabled
[ 0.020850] kmemleak: Kernel memory leak detector disabled
[ 0.020884] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.020920] pid_max: default: 32768 minimum: 301
[ 0.022024] Security Framework initialized
[ 0.022587] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022612] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.024152] ftrace: allocating 47208 entries in 185 pages
[ 0.419195] sched-energy: Sched-energy-costs installed from DT
[ 0.419255] ASID allocator initialised with 65536 entries
[ 0.453955] tegra-id: chipid=21917.
[ 0.453979] tegra-id: opt_subrevision=1.
[ 0.454015] Tegra Revision: A02p SKU: 0xde CPU Process: 0 SoC Process: 0
[ 0.454063] DTS File Name: ../arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[ 0.454110] DTB Build time: Aug 2 2021 21:29:10
[ 0.501871] CPU1: Booted secondary processor [4e0f0040]
[ 0.533918] CPU2: Booted secondary processor [4e0f0040]
[ 0.566086] CPU3: Booted secondary processor [4e0f0040]
[ 0.598309] CPU4: Booted secondary processor [4e0f0040]
[ 0.630424] CPU5: Booted secondary processor [4e0f0040]
[ 0.630685] Brought up 6 CPUs
[ 0.630794] SMP: Total of 6 processors activated.
[ 0.630850] CPU features: detected feature: Privileged Access Never
[ 0.630903] CPU features: detected feature: LSE atomic instructions
[ 0.630944] CPU features: detected feature: User Access Override
[ 0.630970] CPU features: detected feature: 32-bit EL0 Support
[ 0.632566] CPU: All CPU(s) started at EL2
[ 0.632659] alternatives: patching kernel code
[ 0.639057] devtmpfs: initialized
[ 0.678661] Initilizing CustomIPI irq domain
[ 0.678956] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.678992] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.689617] pinctrl core: initialized pinctrl subsystem
[ 0.689922] OS set in device tree is not L4T.
[ 0.690187] regulator-dummy: no parameters
[ 0.690459] Initializing plugin-manager
[ 0.690523] Plugin module not found
[ 0.690571] Plugin-manager status disabled
[ 0.691917] NET: Registered protocol family 16
[ 0.697744] pstore: using zlib compression
[ 0.698567] console [pstore-1] enabled
[ 0.698590] pstore: Registered ramoops as persistent store backend
[ 0.698616] ramoops: attached 0x200000@0xf0800000, ecc: 0/0
[ 0.713569] cpuidle: using governor menu
[ 0.714748] bpmp: waiting for handshake
[ 0.714778] bpmp: handshake completed
[ 0.714833] bpmp: synchronizing channels
[ 0.714858] bpmp: channels synchronized
[ 0.714882] bpmp: mail init ok
[ 0.717687] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[ 0.717875] t19x-arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.717903] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.717926] t19x-arm-smmu 12000000.iommu: stage 1 translation
[ 0.717978] t19x-arm-smmu 12000000.iommu: stage 2 translation
[ 0.718011] t19x-arm-smmu 12000000.iommu: nested translation
[ 0.718037] t19x-arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.718086] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.718135] t19x-arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.718163] t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.718205] t19x-arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.721468] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009e54000)
[ 0.721520] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.723964] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.725395] tegra_aon_clk_init: ok
[ 0.725425] Registering BPMP clocks...
[ 0.725556] tegra_bpmp_clk_init: clock init ok (400 clks)
[ 0.726191] Serial: AMBA PL011 UART driver
[ 0.726322] tegra_powergate_init: DONE
[ 0.726457] DTS File Name: ../arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[ 0.726496] DTB Build time: Aug 2 2021 21:29:10
[ 0.729208] Tegra reboot handler registered.
[ 0.737659] iommu: Adding device 14160000.pcie to group 0
[ 0.738392] iommu: Adding device 141a0000.pcie to group 1
[ 0.739775] iommu: Adding device 2490000.ether_qos to group 2
[ 0.740371] iommu: Adding device 3100000.serial to group 3
[ 0.740904] iommu: Adding device 3110000.serial to group 4
[ 0.741331] iommu: Adding device 3140000.serial to group 5
[ 0.742129] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.742573] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.742622] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[ 0.742647] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L1
[ 0.742672] tegra-pmc: ### PMC reset status reg: 0x2d
[ 0.742761] tegra-pmc: PMC Prod config success
[ 0.742996] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.743047] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.743408] iommu: Adding device 3400000.sdhci to group 6
[ 0.743981] iommu: Adding device 3210000.spi to group 7
[ 0.744464] iommu: Adding device 3230000.spi to group 8
[ 0.744891] iommu: Adding device 3270000.spi to group 9
[ 0.746206] iommu: Adding device 3160000.i2c to group 10
[ 0.746660] iommu: Adding device c240000.i2c to group 11
[ 0.747099] iommu: Adding device 3180000.i2c to group 12
[ 0.747508] iommu: Adding device 3190000.i2c to group 13
[ 0.748083] iommu: Adding device 31b0000.i2c to group 14
[ 0.748528] iommu: Adding device 31c0000.i2c to group 15
[ 0.748935] iommu: Adding device c250000.i2c to group 16
[ 0.749338] iommu: Adding device 31e0000.i2c to group 17
[ 0.750118] iommu: Adding device sound to group 18
[ 0.750715] iommu: Adding device 3510000.hda to group 19
[ 0.751297] iommu: Adding device bc00000.rtcpu to group 20
[ 0.753636] iommu: Adding device 13e10000.host1x to group 21
[ 0.754116] iommu: Adding device 13e10000.host1x:ctx0 to group 22
[ 0.754551] iommu: Adding device 13e10000.host1x:ctx1 to group 23
[ 0.754953] iommu: Adding device 13e10000.host1x:ctx2 to group 24
[ 0.755372] iommu: Adding device 13e10000.host1x:ctx3 to group 25
[ 0.755796] iommu: Adding device 13e10000.host1x:ctx4 to group 26
[ 0.756193] iommu: Adding device 13e10000.host1x:ctx5 to group 27
[ 0.756615] iommu: Adding device 13e10000.host1x:ctx6 to group 28
[ 0.757023] iommu: Adding device 13e10000.host1x:ctx7 to group 29
[ 0.757843] iommu: Adding device 15340000.vic to group 30
[ 0.758294] iommu: Adding device 15380000.nvjpg to group 31
[ 0.758637] iommu: Adding device 15500000.tsec to group 32
[ 0.758944] iommu: Adding device 15100000.tsecb to group 33
[ 0.759263] iommu: Adding device 15480000.nvdec to group 34
[ 0.759604] iommu: Adding device 15140000.nvdec1 to group 35
[ 0.759915] iommu: Adding device 154c0000.nvenc to group 36
[ 0.760218] iommu: Adding device 15a80000.nvenc1 to group 37
[ 0.760691] iommu: Adding device 15880000.nvdla0 to group 38
[ 0.761128] iommu: Adding device 158c0000.nvdla1 to group 39
[ 0.761735] iommu: Adding device 15200000.nvdisplay to group 40
[ 0.765885] platform 15200000.nvdisplay: IOVA linear map 0x00000000c6000000(2a000000)
[ 0.766001] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[ 0.766780] iommu: Adding device 15210000.nvdisplay to group 41
[ 0.766877] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[ 0.768689] iommu: Adding device 15c10000.vi to group 42
[ 0.768934] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[ 0.769409] iommu: Adding device 14800000.isp to group 43
[ 0.770463] iommu: Adding device 16000000.pva0 to group 44
[ 0.771084] iommu: Adding device 16800000.pva1 to group 45
[ 0.771531] iommu: Adding device 15810000.se to group 46
[ 0.771952] iommu: Adding device 15820000.se to group 47
[ 0.772282] iommu: Adding device 15830000.se to group 48
[ 0.772632] iommu: Adding device 15840000.se to group 49
[ 0.773034] iommu: Adding device c1a0000.aon to group 50
[ 0.774668] iommu: Adding device d000000.bpmp to group 51
[ 0.775011] bpmp: ping status is 0
[ 0.775172] bpmp d000000.bpmp: firmware tag is e73a758761f0c6d24a1e69a2ac6b5035
[ 0.778647] bpmp d000000.bpmp: probe ok
[ 0.781068] tegra-reset 0.bpmp_reset: registered 190 resets.
[ 0.781545] iommu: Adding device smmu_test to group 52
[ 0.782671] mc: mapped MMIO address: 0xffffff800a590000 -> 0x2c10000
[ 0.782722] mc: mapped MMIO address: 0xffffff800a5b0000 -> 0x2c20000
[ 0.782768] mc: mapped MMIO address: 0xffffff800a5d0000 -> 0x2c30000
[ 0.782821] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2c40000
[ 0.782866] mc: mapped MMIO address: 0xffffff800a7d0000 -> 0x2c50000
[ 0.782912] mc: mapped MMIO address: 0xffffff800b010000 -> 0x2b80000
[ 0.782955] mc: mapped MMIO address: 0xffffff800b030000 -> 0x2b90000
[ 0.783002] mc: mapped MMIO address: 0xffffff800b050000 -> 0x2ba0000
[ 0.783045] mc: mapped MMIO address: 0xffffff800b070000 -> 0x2bb0000
[ 0.783104] mc: mapped MMIO address: 0xffffff800b090000 -> 0x1700000
[ 0.783147] mc: mapped MMIO address: 0xffffff800b0b0000 -> 0x1710000
[ 0.783190] mc: mapped MMIO address: 0xffffff800b0d0000 -> 0x1720000
[ 0.783233] mc: mapped MMIO address: 0xffffff800b0f0000 -> 0x1730000
[ 0.783275] mc: mapped MMIO address: 0xffffff800b110000 -> 0x1740000
[ 0.783318] mc: mapped MMIO address: 0xffffff800b130000 -> 0x1750000
[ 0.783360] mc: mapped MMIO address: 0xffffff800b150000 -> 0x1760000
[ 0.783403] mc: mapped MMIO address: 0xffffff800b170000 -> 0x1770000
[ 0.783514] mc-err: mcerr ops are set to t19x
[ 0.789424] iommu: Adding device 2600000.dma to group 53
[ 0.795244] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 224 lines on the chip
[ 0.796563] GPIO line 339 (wifi-enable) hogged as output/high
[ 0.796637] GPIO line 412 (camera-control-output-low) hogged as output/low
[ 0.796711] GPIO line 413 (camera-control-output-low) hogged as output/low
[ 0.797036] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.805986] gpio gpiochip1: gpio-line-names specifies 21 line names but there are 40 lines on the chip
[ 0.806109] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[ 0.806177] GPIO line 266 (w-disable1) hogged as output/high
[ 0.806238] GPIO line 264 (w-disable2) hogged as output/high
[ 0.806306] GPIO line 265 (suspend-led-gpio) hogged as output/high
[ 0.806618] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[ 0.809063] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_83 = 0x10a
[ 0.809098] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.809128] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.810042] iommu: Adding device 3550000.xudc to group 54
[ 0.810852] iommu: Adding device 3610000.xhci to group 55
[ 0.813038] arm64_ras arm64_ras: probed
[ 0.813496] ras_fhi_enable: FHI 469 enabled on CPU0
[ 0.813571] ras_fhi_enable: FHI 470 enabled on CPU1
[ 0.813695] ras_fhi_enable: FHI 471 enabled on CPU2
[ 0.813811] ras_fhi_enable: FHI 472 enabled on CPU3
[ 0.813915] ras_fhi_enable: FHI 473 enabled on CPU4
[ 0.814037] ras_fhi_enable: FHI 474 enabled on CPU5
[ 0.814254] carmel_ras_enable: RAS enabled on cpu0
[ 0.814453] carmel_ras_enable: RAS enabled on cpu1
[ 0.814702] carmel_ras_enable: RAS enabled on cpu2
[ 0.814912] carmel_ras_enable: RAS enabled on cpu3
[ 0.815162] carmel_ras_enable: RAS enabled on cpu4
[ 0.815389] carmel_ras_enable: RAS enabled on cpu5
[ 0.815499] carmel_ras carmel_ras: probed
[ 0.816841] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 478, noc_nonsecure_irq = 477>
[ 0.817486] tegra-cbb c600000.aon-noc: noc_secure_irq = 480, noc_nonsecure_irq = 479>
[ 0.818511] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 482, noc_nonsecure_irq = 481>
[ 0.819439] tegra-cbb be00000.rce-noc: noc_secure_irq = 484, noc_nonsecure_irq = 483>
[ 0.820386] tegra-cbb b600000.sce-noc: noc_secure_irq = 486, noc_nonsecure_irq = 485>
[ 0.820798] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[ 0.822147] vdd-ac-bat: 5000 mV
[ 0.822628] vdd-sdmmc1-sw: 3300 mV
[ 0.822996] vdd-1v8-sd: 1800 mV
[ 0.823329] vdd-3v3-cvb: 3300 mV
[ 0.823690] vdd-1v8-cvb: 1800 mV
[ 0.824106] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 0.824167] vdd-epb-1v0: 1000 mV
[ 0.824577] avdd-cam-2v8: 2800 mV
[ 0.824960] vdd-fan: 5000 mV
[ 0.825376] vdd-hdmi-5v0: 5000 mV
[ 0.825717] vdd_sys_en: 1200 mV
[ 0.870520] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.875262] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.875631] SCSI subsystem initialized
[ 0.876151] usbcore: registered new interface driver usbfs
[ 0.876277] usbcore: registered new interface driver hub
[ 0.876392] usbcore: registered new device driver usb
[ 0.887555] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[ 0.890958] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 0.897971] vdd-1v0: at 1000 mV
[ 0.902023] vdd-1v8-hs: at 1800 mV
[ 0.906024] vdd-1v8-ls: at 1800 mV
[ 0.910021] vdd-1v8-ao: at 1800 mV
[ 0.914056] vddio-ddr-1v1: at 1100 mV
[ 0.917841] vdd-rtc: at 800 mV
[ 0.918961] spmic-ldo1: at 2375 mV
[ 0.925892] vdd-ao-3v3: at 3300 mV
[ 0.933929] vddio-emmc-3v3: at 3300 mV
[ 0.934991] spmic-ldo4: at 1587 mV
[ 0.941969] vdd-usb-3v3: at 3300 mV
[ 0.950010] vddio-sdmmc1-3v3: at 3300 mV
[ 0.954069] vdd-csi-1v2: at 1200 mV
[ 0.955295] spmic-ldo8: at 1800 mV
[ 0.959645] GPIO line 246 (gpio_default) hogged as output/high
[ 0.960621] GPIO line 247 (gpio_default) hogged as output/high
[ 0.961023] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[ 0.961406] max77620 4-003c: max77620 probe successful
[ 0.962238] media: Linux media interface: v0.10
[ 0.962373] Linux video capture interface: v2.00
[ 0.963744] pps_core: LinuxPPS API ver. 1 registered
[ 0.963777] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.963855] PTP clock support registered
[ 0.964105] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 0.964416] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.964470] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.967251] trusty trusty: trusty version: Built: 08:56:10 Jul 9 2021
[ 0.967350] trusty trusty: selected api version: 3 (requested 3)
[ 0.968778] Advanced Linux Sound Architecture Driver Initialized.
[ 0.969424] Bluetooth: Core ver 2.22
[ 0.969484] NET: Registered protocol family 31
[ 0.969533] Bluetooth: HCI device and connection manager initialized
[ 0.969574] Bluetooth: HCI socket layer initialized
[ 0.969611] Bluetooth: L2CAP socket layer initialized
[ 0.969657] Bluetooth: SCO socket layer initialized
[ 0.972275] camchar: rtcpu character device driver loaded
[ 0.972822] gpio tegra-gpio wake61 for gpio=201(Z:1)
[ 0.972944] extcon-gpio-states external-connection:extcon@1: Cable state:0, cable id:0
[ 0.973959] clocksource: Switched to clocksource arch_sys_counter
[ 1.016590] VFS: Disk quotas dquot_6.6.0
[ 1.016714] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.017089] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 1.018314] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[ 1.018400] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[ 1.018669] cma: enabled page replacement for spfn=c6000, epfn=f0000
[ 1.018704] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 1.018753] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[ 1.018792] nvmap_page_pool_init: Total RAM pages: 1986134
[ 1.018823] nvmap_page_pool_init: nvmap page pool size: 248266 pages (969 MB)
[ 1.019169] nvmap_background_zero_thread: PP zeroing thread starting.
[ 1.019538] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[ 1.021570] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 1.035411] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 1.035684] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 1.035950] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[ 1.036178] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[ 1.036415] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 1.037596] la/ptsa driver initialized.
[ 1.038008] NET: Registered protocol family 2
[ 1.038818] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 1.039197] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 1.039842] TCP: Hash tables configured (established 65536 bind 65536)
[ 1.039949] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 1.040099] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 1.040553] NET: Registered protocol family 1
[ 1.041181] RPC: Registered named UNIX socket transport module.
[ 1.041213] RPC: Registered udp transport module.
[ 1.041237] RPC: Registered tcp transport module.
[ 1.041261] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.041541] Trying to unpack rootfs image as initramfs...
[ 1.264100] Freeing initrd memory: 7064K
[ 1.288423] host1x 13e10000.host1x: initialized
[ 1.290114] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.295202] audit: initializing netlink subsys (disabled)
[ 1.295271] audit: type=2000 audit(0.904:1): initialized
[ 1.296141] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 1.306369] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.307767] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.308434] 9p: Installing v9fs 9p2000 file system support
[ 1.313821] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.314131] io scheduler noop registered
[ 1.314430] io scheduler cfq registered (default)
[ 1.318124] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 1.319418] random: fast init done
[ 1.347788] iommu: Adding device 2993000.adsp to group 56
[ 1.365396] iommu: Adding device aconnect@2a41000:adsp_audio to group 57
[ 1.366490] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.379188] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.379664] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.380255] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.380674] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[ 1.381099] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.384208] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.384498] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 1.387214] tsec 15500000.tsec: initialized
[ 1.388872] tsec 15100000.tsecb: initialized
[ 1.392540] nvdec 15480000.nvdec: initialized
[ 1.395254] nvdec 15140000.nvdec1: initialized
[ 1.400833] falcon 15340000.vic: initialized
[ 1.402737] falcon 15380000.nvjpg: initialized
[ 1.404555] falcon 154c0000.nvenc: initialized
[ 1.406604] falcon 15a80000.nvenc1: initialized
[ 1.410438] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.413076] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.414593] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.416089] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.417687] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.419277] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.420734] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.422142] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.425552] t194-nvcsi 15a00000.nvcsi: initialized
[ 1.430746] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 1.431193] scare-pigeon 14b00000.isp-thi: initialized
[ 1.436729] pva 16000000.pva0: initialized
[ 1.442367] pva 16800000.pva1: initialized
[ 1.447434] nvdla 15880000.nvdla0: initialized
[ 1.452027] nvdla 158c0000.nvdla1: initialized
[ 1.453606] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.453637] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.453708] tegradccommon 15200000.dc_common: dma mapping done
[ 1.453882] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=77
[ 1.453938] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[ 1.454273] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 1.454324] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 1.454629] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 1.454690] tegra_cec 3960000.tegra_cec: probed
[ 1.455269] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor1
[ 1.455342] generic_infoframe_type: 0x87
[ 1.455466] tegradc 15200000.nvdisplay: DT parsed successfully
[ 1.455520] tegradc 15200000.nvdisplay: Display dc.ffffff800bd10000 registered with id=0
[ 1.460411] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 7088400 KB/s
[ 1.460440] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 800000000 Hz
[ 1.460464] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[ 1.460692] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[ 1.460721] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[ 1.463850] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.463884] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.467124] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[ 1.468033] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check disabled
[ 1.468066] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.468448] kfuse 3830000.kfuse: initialized
[ 1.468642] tegradc 15200000.nvdisplay: probed
[ 1.470007] Console: switching to colour frame buffer device 80x30
[ 1.470060] tegradc 15200000.nvdisplay: fb registered
[ 1.470599] gpio tegra-gpio wake63 for gpio=97(M:1)
[ 1.472217] tegradc 15210000.nvdisplay: disp1 connected to head1->/host1x/sor
[ 1.472443] tegradc 15210000.nvdisplay: parse_dp_settings: No dp-lt-settings node
[ 1.472834] tegradc 15210000.nvdisplay: DT parsed successfully
[ 1.473081] tegradc 15210000.nvdisplay: Display dc.ffffff800be90000 registered with id=1
[ 1.473725] tegradc 15210000.nvdisplay: vblank syncpt # 11 for dc 1
[ 1.473785] tegradc 15210000.nvdisplay: vpulse3 syncpt # 12 for dc 1
[ 1.473851] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.476839] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 47, base_baud = 0) is a TEGRA_UART
[ 1.478281] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 48, base_baud = 0) is a TEGRA_UART
[ 1.479300] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 49, base_baud = 0) is a TEGRA_UART
[ 1.483777] tegradc 15210000.nvdisplay: probed
[ 2.469965] tegra_cec 3960000.tegra_cec: Can't find physical addresse.
[ 2.469972] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 4.035257] console [ttyTCU0] enabled
[ 4.035713] [drm] Initialized
[ 4.042322] tegradc 15210000.nvdisplay: fb registered
[ 4.051245] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 4.054764] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 4.062578] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 4.067794] tegradc 15210000.nvdisplay: blank - powerdown
[ 4.069797] brd: module loaded
[ 4.076196] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[ 4.084681] Extcon DP: HPD disabled
[ 4.087926] hpd: hpd_switch 0
[ 4.091308] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 4.096441] loop: module loaded
[ 4.096520] tegra_profiler: version: 1.143, samples/io: 48/28
[ 4.096658] tegra_profiler: auth: init
[ 4.097368] THERMAL EST: found 3 subdevs
[ 4.097372] THERMAL EST num_resources: 0
[ 4.097380] [THERMAL EST subdev 0]
[ 4.097384] [THERMAL EST subdev 1]
[ 4.097388] [THERMAL EST subdev 2]
[ 4.097429] THERMAL EST: Found 2 profiles, default profile is quiet
[ 4.097859] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 4.097862] THERMAL EST: thz register success.
[ 4.098099] THERMAL EST: end of probe, return err: 0
[ 4.098846] sd: No Scsi addr parsed to reserve index
[ 4.098871] hisi_sas: driver version v1.6
[ 4.109525] qspi_mtd spi6.0: s25fs256s SSG 8 0 1000 2000000
[ 4.109531] qspi_mtd spi6.0: s25fs256s (32768 Kbytes)
[ 4.109540] qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x2000000 (32MiB) .erasesize = 0x00010000 (64KiB) .numeraseregions = 0
[ 4.109866] 1 ofpart partitions found on MTD device spi6.0
[ 4.109870] Creating 1 MTD partitions on "spi6.0":
[ 4.109886] 0x000000000000-0x000002000000 : "Whole_flash0"
[ 4.116428] libphy: Fixed MDIO Bus: probed
[ 4.118236] tun: Universal TUN/TAP device driver, 1.6
[ 4.118240] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 4.122288] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 4.122291] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.122389] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 4.122392] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.122442] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 4.122445] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 4.122499] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 4.122502] Copyright(c) 1999 - 2017 Intel Corporation.
[ 4.266246] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 4.272438] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 4.361129] eqos 2490000.ether_qos: failed to read eqos_auto_cal_config_0_reg
[ 4.361853] eqos 2490000.ether_qos: Setting local MAC: 48 b0 2d 7 7f 4d
[ 4.362218] libphy: dwc_phy: probed
[ 4.364764] PPP generic driver version 2.4.2
[ 4.365284] PPP BSD Compression module registered
[ 4.365399] PPP Deflate Compression module registered
[ 4.365534] PPP MPPE Compression module registered
[ 4.365643] NET: Registered protocol family 24
[ 4.365818] usbcore: registered new interface driver r8152
[ 4.366021] usbcore: registered new interface driver asix
[ 4.366198] usbcore: registered new interface driver ax88179_178a
[ 4.366353] usbcore: registered new interface driver cdc_ether
[ 4.366513] usbcore: registered new interface driver net1080
[ 4.366670] usbcore: registered new interface driver cdc_subset
[ 4.366826] usbcore: registered new interface driver zaurus
[ 4.366989] usbcore: registered new interface driver cdc_ncm
[ 4.367400] VFIO - User Level meta-driver version: 0.3
[ 4.372784] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 4.377715] ehci-pci: EHCI PCI platform driver
[ 4.382029] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 4.388312] ohci-pci: OHCI PCI platform driver
[ 4.392784] ohci-platform: OHCI generic platform driver
[ 4.402545] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 4.405240] tegra-xusb 3610000.xhci: extcon 0: ffffffc1f4d0a400 id
[ 4.410023] usbcore: registered new interface driver uas
[ 4.415086] tegra-xusb 3610000.xhci: Firmware timestamp: 2019-07-24 05:47:34 UTC, Version: 60.06 release
[ 4.415115] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 4.415132] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 4.415823] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[ 4.415874] tegra-xusb 3610000.xhci: irq 464, io mem 0x03610000
[ 4.416154] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.416159] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.416163] usb usb1: Product: xHCI Host Controller
[ 4.416167] usb usb1: Manufacturer: Linux 4.9.201-tegra xhci-hcd
[ 4.416171] usb usb1: SerialNumber: 3610000.xhci
[ 4.424733] hub 1-0:1.0: USB hub found
[ 4.424781] hub 1-0:1.0: 4 ports detected
[ 4.425312] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 4.425321] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 4.425329] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 4.425661] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 4.425666] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.425670] usb usb2: Product: xHCI Host Controller
[ 4.425674] usb usb2: Manufacturer: Linux 4.9.201-tegra xhci-hcd
[ 4.425678] usb usb2: SerialNumber: 3610000.xhci
[ 4.429993] hub 2-0:1.0: USB hub found
[ 4.430041] hub 2-0:1.0: 4 ports detected
[ 4.466025] Wake76 for irq=199
[ 4.466029] Wake77 for irq=199
[ 4.466031] Wake78 for irq=199
[ 4.466033] Wake79 for irq=199
[ 4.466036] Wake80 for irq=199
[ 4.466038] Wake81 for irq=199
[ 4.466040] Wake82 for irq=199
[ 4.466077] tegra-xusb 3610000.xhci: Upgrade port 0 to USB3.0
[ 4.466082] tegra-xusb 3610000.xhci: Upgrade port 1 to USB3.0
[ 4.551232] usb usb2: usb_suspend_both: status 0
[ 4.585611] usbcore: registered new interface driver usb-storage
[ 4.591551] usbcore: registered new interface driver usbserial
[ 4.600295] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 4.603283] tegra-xudc-new 3550000.xudc: device count: 1
[ 4.609492] tegra-xudc-new 3550000.xudc: vbus state: 0
[ 4.613785] tegra-xudc-new 3550000.xudc: Initialize boost_cpufreq work
[ 4.619932] tegra-xudc-new 3550000.xudc: entering ELPG
[ 4.625562] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 4.631488] mousedev: PS/2 mouse device common for all mice
[ 4.636613] usbcore: registered new interface driver xpad
[ 4.761978] usb 1-3: new high-speed USB device number 2 using tegra-xusb
[ 4.762876] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 4.764403] Wake73 for irq=42
[ 4.765748] rtc rtc1: alarm rtc device
[ 4.765853] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 4.766030] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.766403] i2c /dev entries driver
[ 4.768723] i2c i2c-2: Added multiplexed i2c bus 9
[ 4.769346] i2c i2c-2: Added multiplexed i2c bus 10
[ 4.769456] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[ 4.770128] imx219 9-0010: tegracam sensor driver:imx219_v2.0.6
[ 4.782351] usb 1-3: New USB device found, idVendor=0424, idProduct=2514
[ 4.782487] usb 1-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.783568] hub 1-3:1.0: USB hub found
[ 4.783729] hub 1-3:1.0: 4 ports detected
[ 4.793804] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[ 4.794005] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[ 4.794232] imx219 9-0010: board setup failed
[ 4.794415] imx219: probe of 9-0010 failed with error -121
[ 4.794971] imx219 10-0010: tegracam sensor driver:imx219_v2.0.6
[ 4.818358] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[ 4.818555] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[ 4.818812] imx219 10-0010: board setup failed
[ 4.818979] imx219: probe of 10-0010 failed with error -121
[ 4.820186] max77620-power max20024-power: Event recorder REG_NVERC : 0x0
[ 4.827759] tegra-thermal-throttle bthrot_cdev: cpufreq policy is not ready defer
[ 4.828302] FAN dev name: pwm-fan
[ 4.828418] FAN:gpio request success.
[ 4.828521] FAN: can't find tach_gpio
[ 4.830378] pwm_fan_driver pwm-fan: Found 2 profiles, default profile is quiet
[ 4.837589] pwm_fan_driver pwm-fan: cap state:4, cap pwm:255
[ 4.843553] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 4.850405] pwm_fan_driver pwm-fan: tach period: 1000
[ 4.856237] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 4.863263] pwm_fan_driver pwm-fan: index 1: pwm=130, rpm=1000, rru=2, rrd=2, state:2
[ 4.870869] pwm_fan_driver pwm-fan: index 2: pwm=160, rpm=2000, rru=1, rrd=1, state:2
[ 4.878830] pwm_fan_driver pwm-fan: index 3: pwm=200, rpm=3000, rru=1, rrd=1, state:2
[ 4.886768] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 4.894223] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 4.902360] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 4.910146] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 4.917483] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 4.925396] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 4.934758] tegra-oc-event d280000.soctherm-oc-event: OC driver initialized
[ 4.941670] device-mapper: uevent: version 1.0.3
[ 4.946107] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 4.953971] usb 1-3: usb_suspend_both: status 0
[ 4.954095] usb usb1: usb_suspend_both: status 0
[ 4.967502] tegra194_cpufreq_probe: platform driver Initialization: pass
[ 4.971750] cpuidle: Initializing cpuidle driver
[ 4.976326] sdhci: Secure Digital Host Controller Interface driver
[ 4.981554] sdhci: Copyright(c) Pierre Ossman
[ 4.985758] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.992118] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 4.997749] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 5.006375] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 246
[ 5.014846] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 5.017954] tegra-se-nvhost 15810000.se: initialized
[ 5.022612] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 5.028111] tegra-se-nvhost 15820000.se: initialized
[ 5.033805] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 5.039027] tegra-se-nvhost 15830000.se: initialized
[ 5.043981] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 5.050557] tegra-se-nvhost 15840000.se: initialized
[ 5.055506] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 5.058120] gpio tegra-gpio wake8 for gpio=55(G:7)
[ 5.058187] mmc0: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 5.075085] hidraw: raw HID events driver (C) Jiri Kosina
[ 5.081842] usbcore: registered new interface driver usbhid
[ 5.085771] usbhid: USB HID core driver
[ 5.095078] tegra186-cam-rtcpu bc00000.rtcpu: deferring, 14800000.isp is not probed
[ 5.098755] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 5.103876] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 5.109419] denver_knobs_init:MTS_VERSION:51035886
[ 5.114114] tegra19x_actmon d230000.actmon: in actmon_register()...
[ 5.121007] tegra19x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 5.128501] t19x_cache tegra-cache: probed
[ 5.134465] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[ 5.140217] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[ 5.148009] carmel-pmu-drv carmel-pmu: Registered Carmel PMU
[ 5.153672] PLL_AON clock registered
[ 5.157783] Clocks initialized successfully
[ 5.163082] nvpmodel: initialized successfully
[ 5.166739] trusty-virtio trusty:virtio: initializing
[ 5.170502] trusty_ipc virtio0: vring0: va(pa) ffffffc1f26f6000(0) qsz 32 notifyid 1
[ 5.178018] trusty_ipc virtio0: vring1: va(pa) ffffffc1f2720000(0) qsz 32 notifyid 2
[ 5.185867] trusty-virtio trusty:virtio: initializing done
[ 5.186101] trusty_ipc virtio0: is online
[ 5.196793] tegra-hda 3510000.hda: Override SDO lines to 4
[ 5.198195] usbcore: registered new interface driver snd-usb-audio
[ 5.220142] input: tegra-hda-xnx HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 5.220549] input: tegra-hda-xnx HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 5.224232] input: tegra-hda-xnx HDMI/DP,pcm=8 as /devices/3510000.hda/sound/card0/input2
[ 5.232203] input: tegra-hda-xnx HDMI/DP,pcm=9 as /devices/3510000.hda/sound/card0/input3
[ 5.270982] mmc0: host does not support reading read-only switch, assuming write-enable
[ 5.332509] OPE platform probe
[ 5.332718] OPE platform probe successful
[ 5.411171] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 5.411427] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 5.411645] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 5.411847] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 5.412074] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 5.412290] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 5.412495] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 5.412702] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 5.412898] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 5.413096] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 5.413296] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 5.413416] mmc0: hw tuning done ...
[ 5.413516] mmc0: new ultra high speed SDR104 SDXC card at address aaaa
[ 5.413519] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 5.413874] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 5.414101] mmcblk0: mmc0:aaaa SC64G 59.5 GiB
[ 5.414110] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 5.414209] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 5.414315] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 5.414412] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 5.414510] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 5.414607] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 5.414722] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 5.444861] u32 classifier
[ 5.444865] Actions configured
[ 5.444963] Initializing XFRM netlink socket
[ 5.445588] NET: Registered protocol family 10
[ 5.446377] NET: Registered protocol family 17
[ 5.446391] NET: Registered protocol family 15
[ 5.446445] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 5.446530] Bluetooth: RFCOMM socket layer initialized
[ 5.446546] Bluetooth: RFCOMM ver 1.11
[ 5.446552] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 5.446557] Bluetooth: HIDP socket layer initialized
[ 5.446573] 9pnet: Installing 9P2000 support
[ 5.446612] Key type dns_resolver registered
[ 5.451971] Registered cp15_barrier emulation handler
[ 5.451987] Registered setend emulation handler
[ 5.454123] registered taskstats version 1
[ 5.454649] tegra-pcie-dw 14160000.pcie: Setting init speed to max speed
[ 5.455862] OF: PCI: host bridge /pcie@14160000 ranges:
[ 5.455881] OF: PCI: IO 0x36100000..0x361fffff -> 0x36100000
[ 5.455891] OF: PCI: MEM 0x1740000000..0x17ffffffff -> 0x40000000
[ 5.455895] OF: PCI: MEM 0x1400000000..0x173fffffff -> 0x1400000000
??WARNING: at platform/drivers/mailbox/mail_mach.c:148
WARNING: at platform/drivers/mailbox/mail_mach.c:161
WARNING: at platform/drivers/mailbox/mail_mach.c:177
