The jetson xavier NX can not boot from SD card
The jetson xavier NX can not boot from SD card,after configuring the GPIO by "gunzip < /proc/config.gz | grep CONFIG_PPS_CLIENT_GPIO CONFIG_PPS_CLIENT_GPIO=y ", “sudo apt-get install pps-tools”,“sudo apt-get update” and reboot. The screen is flashing “_” on the left corner of the screen after displaying the “NVIDIA boot animation”, and the log of the console port output listed as following.
[0000.024] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet leve        l 2 from HW fuses.
[0000.033] I> MB1 (prd-version: 1.5.1.3-t194-41334769-d2a21c57)
[0000.038] I> Boot-mode: Coldboot
[0000.041] I> Chip revision : A02P
[0000.044] I> Bootrom patch version : 15 (correctly patched)
[0000.049] I> ATE fuse revision : 0x200
[0000.053] I> Ram repair fuse : 0x0
[0000.056] I> Ram Code : 0x0
[0000.058] I> rst_source : 0x0
[0000.061] I> rst_level : 0x0
[0000.065] I> Boot-device: QSPI
[0000.067] I> Qspi flash params source = brbct
[0000.071] I> Qspi using bpmp-dma
[0000.074] I> Qspi clock source : pllp
[0000.078] I> QSPI Flash Size = 32 MB
[0000.081] I> Qspi initialized successfully
[0000.085] I> Active Boot chain : 0
[0000.088] I> Boot-device: QSPI
[0000.091] I> Qspi flash params source = brbct
[0000.097] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.105] I> Temperature = 40000
[0000.108] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.112] W> Skipping boost for clk: BPMP_APB
[0000.116] W> Skipping boost for clk: AXI_CBB
[0000.120] W> Skipping boost for clk: AON_CPU_NIC
[0000.124] W> Skipping boost for clk: CAN1
[0000.128] W> Skipping boost for clk: CAN2
[0000.132] I> Boot-device: QSPI
[0000.135] I> Boot-device: QSPI
[0000.138] I> Qspi flash params source = mb1bct
[0000.142] I> Qspi using bpmp-dma
[0000.145] I> Qspi clock source : pllc_out0
[0000.149] I> Qspi reinitialized
[0000.152] I> Qspi flash params source = mb1bct
[0000.157] I> ECC region[0]: Start:0x0, End:0x0
[0000.161] I> ECC region[1]: Start:0x0, End:0x0
[0000.165] I> ECC region[2]: Start:0x0, End:0x0
[0000.170] I> ECC region[3]: Start:0x0, End:0x0
[0000.174] I> ECC region[4]: Start:0x0, End:0x0
[0000.178] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.184] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.188] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.193] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.197] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.202] E> FAILED: Thermal config
[0000.210] E> FAILED: MEMIO rail config
[0000.220] I> Boot-device: QSPI
[0000.223] I> Qspi flash params source = mb1bct
[0000.232] I> Qspi flash params source = mb1bct
[0000.244] I> Qspi flash params source = mb1bct
[0000.310] I> Qspi flash params source = mb1bct
[0000.319] I> Qspi flash params source = mb1bct
[0000.346] I> Qspi flash params source = mb1bct
[0000.358] I> MB1 done
▒▒▒▒main enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
  [0000.366] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-2dfe4b        eb)
[0000.367] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.368] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.368] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.374] W> device prod register failed
[0000.378] I> Boot-device: QSPI
[0000.381] I> Boot_device: QSPI_FLASH instance: 0
[0000.386] I> QSPI Flash Size = 32 MB
[0000.392] I> Qspi initialized successfully
[0000.393] I> qspi flash-0 params source = boot args
[0000.397] E> Failed: Unknown device 6
[0000.404] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0000.407] I> Active Boot chain : 0
[0000.410] I> parsing oem signed section of bpmp-fw header done
[0000.415] I> bpmp-fw binary init read from storage
[0000.420] I> oem authentication of bpmp-fw header done
[0000.434] I> bpmp-fw binary done read from storage
[0000.435] I> bpmp-fw: Authentication init Done
[0000.436] I> parsing oem signed section of cpubl header done
[0000.439] I> cpubl binary init read from storage
[0000.444] I> bpmp-fw: Authentication Finalize Done
[0000.449] I> oem authentication of cpubl header done
[0000.456] I> cpubl binary done read from storage
[0000.458] I> cpubl: Authentication init Done
[0000.462] I> parsing oem signed section of rce header done
[0000.467] I> rce binary init read from storage
[0000.472] I> Relocating BR-BCT
[0000.475] I> cpubl: Authentication Finalize Done
[0000.479] I> oem authentication of rce header done
[0000.484] I> rce binary done read from storage
[0000.488] I> rce: Authentication init Done
[0000.492] I> parsing oem signed section of ape header done
[0000.497] I> ape binary init read from storage
[0000.501] I> rce: Authentication Finalize Done
[0000.506] I> oem authentication of ape header done
[0000.510] I> ape binary done read from storage
[0000.514] I> ape: Authentication init Done
[0000.519] I> parsing oem signed section of tos header done
[0000.524] I> tos binary init read from storage
[0000.528] I> ape: Authentication Finalize Done
[0000.533] I> oem authentication of tos header done
[0000.539] I> tos binary done read from storage
[0000.541] I> tos: Authentication init Done
[0000.546] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.551] I> bpmp-fw-dtb binary init read from storage
[0000.556] I> tos: Authentication Finalize Done
[0000.562] I> oem authentication of bpmp-fw-dtb header done
[0000.566] I> bpmp-fw-dtb binary done read from storage
[0000.571] I> bpmp-fw-dtb: Authentication init Done
[0000.576] I> parsing oem signed section of cpubl-dtb header done
[0000.581] I> cpubl-dtb binary init read from storage
[0000.586] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.633] I> oem authentication of cpubl-dtb header done
[0000.634] I> cpubl-dtb binary done read from storage
[0000.634] I> cpubl-dtb: Authentication init Done
[0000.635] I> parsing oem signed section of eks header done
[0000.636] I> eks binary init read from storage
[0000.636] I> cpubl-dtb: Authentication Finalize Done
[0000.637] I> oem authentication of eks header done
[0000.642] I> eks binary done read from storage
[0000.646] I> eks: Authentication init Done
[0000.650] I> eks: Authentication Finalize Done
[0000.654] I> EKB detected (length: 0x410) @ VA:0x52705400
▒▒NOTICE:  BL31: v1.3(release):41d46a9cf
NOTICE:  BL31: Built : 21:14:52, Jun 25 2020
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 40: hwkey-agent is running!!
hwkey-agent: 182: key_mgnt_processing .......
hwkey-agent: 157: Init hweky-agent services!!
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is 57f8a77779f848bf2ecf21dabee5645f
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
391 clocks registered
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform_init: bad clk id in clock@cluster1_avfs
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
mrq initialized
  [0000.996] I> Welcome to Cboot
▒▒WARNING: no registered clock for FMON_NAFLL_CLUSTER1 (id 281)
fmon_post initialized
▒▒[0000.997] I> Cboot Version: t194-18fdfe28
[0000.999] I> CPU-BL Params @ 0xf2820000
[0001.002] I>  0) Base:0x00000000 Size:0x00000000
[0001.007] I>  1) Base:0xf1100000 Size:0x00100000
▒▒clk_set_parent failed for clk can1, parent pll_aon (-22)
clk_set_parent failed for clk can2, parent pll_aon (-22)
clk_set_parent failed for clk dmic5, parent pll_aon (-22)
clk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_set_parent failed for clk spi2, parent pll_aon (-22)
clk_set_parent failed for clk pwm4, parent pll_aon (-22)
clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
Failed to register PTO counter for id 281
clk_debugfs initialized
emc_debugfs initialized
dvs_debugfs initialized
fmon_debugfs_init_one: no clock debugfs node to attach FMON_NAFLL_CLUSTER1
fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_rail_debugfs_init: /rm/vdd_cpu: failed
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ▒▒[0001.011] I>  2) Base:0xf2000000 Size:0x00200000
[0001.191] I>  3) Base:0xf1200000 Size:0x00200000
[0001.195] I>  4) Base:0xf1000000 Size:0x00100000
[0001.200] I>  5) Base:0xf0f00000 Size:0x00100000
[0001.204] I>  6) Base:0xf3800000 Size:0x00400000
[0001.209] I>  7) Base:0xf1c00000 Size:0x00400000
[0001.213] I>  8) Base:0xf0e00000 Size:0x00100000
[0001.218] I>  9) Base:0xf0d00000 Size:0x00100000
[0001.222] I> 10) Base:0xf3000000 Size:0x00800000
[0001.226] I> 11) Base:0x40000000 Size:0x00040000
[0001.231] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.235] I> 13) Base:0x40046000 Size:0x00002000
[0001.240] I> 14) Base:0x40048000 Size:0x00002000
[0001.244] I> 15) Base:0xac000000 Size:0x00004000
[0001.249] I> 16) Base:0x4004a000 Size:0x00002000
[0001.253] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.258] I> 18) Base:0x4004c000 Size:0x00002000
[0001.262] I> 19) Base:0xf2200000 Size:0x00600000
[0001.267] I> 20) Base:0x4004e000 Size:0x00002000
[0001.271] I> 21) Base:0xf09d0000 Size:0x0000c000
[0001.276] I> 22) Base:0x00000000 Size:0x00000000
[0001.280] I> 23) Base:0xf09e0000 Size:0x00020000
[0001.284] I> 24) Base:0xf6000000 Size:0x02000000
[0001.289] I> 25) Base:0x40050000 Size:0x00002000
[0001.293] I> 26) Base:0x40040000 Size:0x00006000
[0001.298] I> 27) Base:0xf1800000 Size:0x00400000
[0001.302] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.307] I> 29) Base:0xf1400000 Size:0x00400000
[0001.311] I> 30) Base:0xf0a00000 Size:0x00100000
[0001.316] I> 31) Base:0x00000000 Size:0x00000000
[0001.320] I> 32) Base:0xf8000000 Size:0x08000000
[0001.325] I> 33) Base:0x00000000 Size:0x00000000
[0001.329] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.334] I> 35) Base:0xab000000 Size:0x01000000
[0001.338] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.342] I> 37) Base:0xf2800000 Size:0x00800000
[0001.347] I> 38) Base:0x80000000 Size:0x20000000
[0001.351] I> 39) Base:0xb0000000 Size:0x08000000
[0001.356] I> 40) Base:0x00000000 Size:0x00000000
[0001.360] I> 41) Base:0x00000000 Size:0x00000000
[0001.365] I> 42) Base:0x00000000 Size:0x00000000
[0001.369] I> 43) Base:0x00000000 Size:0x00000000
[0001.374] I> 44) Base:0x00000000 Size:0x00000000
[0001.378] I> 45) Base:0x00000000 Size:0x00000000
[0001.383] GIC-SPI Target CPU: 0
[0001.386] Interrupts Init done
[0001.388] calling constructors
[0001.391] initializing heap
[0001.394] I> Heap: [0xa06905a8 ... 0xab000000]
[0001.398] initializing threads
[0001.401] initializing timers
[0001.404] creating bootstrap completion thread
[0001.408] top of bootstrap2()
[0001.411] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.416] initializing platform
[0001.419] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.424] W> device prod register failed
[0001.428] I> Bl_dtb @0xaaf00000
[0001.433] W> "plugin-manager" doesn't exist, creating
[0001.436] W> "ids" doesn't exist, creating
[0001.440] W> "connection" doesn't exist, creating
[0001.444] W> "configs" doesn't exist, creating
[0001.455] I> Find /i2c@3160000's alias i2c0
[0001.455] I> Reading eeprom i2c=0 address=0x50
[0001.482] I> Device at /i2c@3160000:0x50
[0001.482] I> Reading eeprom i2c=0 address=0x57
[0001.507] I> Device at /i2c@3160000:0x57
[0001.509] I> Find /i2c@c240000's alias i2c1
[0001.510] I> Reading eeprom i2c=1 address=0x50
[0001.511] E> I2C: slave not found in slaves.
[0001.512] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start tr        ue.
[0001.513] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.513] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at        0x00000000 via instance 1.
[0001.521] E> eeprom: Retry to read I2C slave device.
[0001.526] E> I2C: slave not found in slaves.
[0001.530] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start tr        ue.
[0001.538] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.543] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at        0x00000000 via instance 1.
[0001.553] E> eeprom: Failed to read I2C slave device
[0001.558] I> Eeprom read failed 0x3526070d
[0001.562] I> create_pm_ids: id: 3668-0000-300-B, len: 15
[0001.567] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00        ,touch-config:00,display-config:00,, len: 93
[0001.578] I> create_pm_ids: id: 3509-0000-100-H, len: 15
[0001.583] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00        ,touch-config:00,display-config:00,, len: 93
[0001.594] I> Adding plugin-manager/ids/3668-0000-300=/i2c@3160000:module@0x50
[0001.602] W> "i2c@3160000" doesn't exist, creating
[0001.606] W> "module@0x50" doesn't exist, creating
[0001.610] I> Adding plugin-manager/ids/3509-0000-100=/i2c@3160000:module@0x57
[0001.617] W> "module@0x57" doesn't exist, creating
[0001.625] I> Adding plugin-manager/cvm
[0001.626] W> "chip-id" doesn't exist, creating
[0001.630] I> Adding plugin-manager/chip-id/A02P
[0001.634] I> Plugin-manager override starting
[0001.640] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0001.648] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0001.653] I> node /plugin-manager/fragement-tegra-sdhci-emmc-dis matches
[0001.661] I> Disable plugin-manager status in FDT
[0001.661] I> Plugin-manager override finished successfully
[0001.666] I> gpio framework initialized
[0001.671] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driv        er
[0001.678] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon'        driver
[0001.685] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0001.692] E> fetch_driver_phandle_from_dt: failed to get node with compatible t        i,tca9539
[0001.700] E> fetch_driver_phandle_from_dt: failed to get node with compatible n        xp,tca9539
[0001.707] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.713] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0001.720] E> fetch_driver_phandle_from_dt: failed to get node with compatible t        i,tca9539
[0001.728] E> fetch_driver_phandle_from_dt: failed to get node with compatible n        xp,tca9539
[0001.735] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.742] I> fixed regulator driver initialized
[0001.750] I> register 'maxim' power off handle
[0001.751] I> virtual i2c enabled
[0001.752] I> registered 'maxim,max20024' pmic
[0001.757] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0001.763] I> Boot-device: QSPI
[0001.766] I> Boot_device: QSPI_FLASH instance: 0
[0001.771] I> QSPI source rate = 204000 Khz
[0001.775] I> Requested rate for QSPI clock = 34000 Khz
[0001.780] I> BPMP-set rate for QSPI clk = 34000 Khz
[0001.785] I> QSPI Flash Size = 32 MB
[0001.792] I> Qspi initialized successfully
[0001.792] I> qspi flash-0 params source = boot args
[0001.796] I> create_pm_ids: id: 3668-0000-300-B, len: 15
[0001.802] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00        ,touch-config:00,display-config:00,, len: 93
[0001.813] I> create_pm_ids: id: 3509-0000-100-H, len: 15
[0001.818] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00        ,touch-config:00,display-config:00,, len: 93
[0001.829] I> Found sdcard
[0001.833] I> enabling 'vdd-sdmmc1-sw' regulator
[0001.839] I> regulator 'vdd-sdmmc1-sw' already enabled
[0001.903] I> sdmmc SDR mode
[0001.918] I> -0 params source =
[0001.919] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0001.927] I> Found 11 partitions in SDCARD (instance 0)
[0001.935] I> regulator 'vdd-hdmi-5v0' already enabled
[0001.939] I> regulator 'vdd-hdmi-5v0' already enabled
[0001.939] E> tegrabl_display_init_regulator: hdmi cable is not connected
[0001.940] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0001.943] E> invalid display type
[0001.944] E> cannot find any other nvdisp nodes
[0001.944] E> no valid display unit config found in dtb
[0001.946] W> display init failed
[0001.948] I> Load in CBoot Boot Options partition and parse it
[0001.954] E> Error -9 when finding node with path /boot-configuration
[0001.960] E> tegrabl_cbo_parse_info: "boot-configuration" not found in CBO file        .
[0001.967] I> Hit any key to stop autoboot:     4       3       2       1
[0003.975] initializing target
[0003.975] calling apps_init()
[0003.976] starting app kernel_boot_app
[0003.982] I> found decompressor handler: lz4-legacy
[0003.982] I> decompressing BMP blob ...
[0003.986] I> Kernel type = Normal
[0003.986] I> Loading kernel-bootctrl from partition
[0003.986] I> Loading partition kernel-bootctrl at 0xa42b0000 from device(0x6)
[0004.011] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.012] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.012] I> ########## SD boot ##########
[0004.013] I> Found sdcard
[0004.014] I> regulator 'vdd-sdmmc1-sw' already enabled
[0004.018] I> regulator 'vdd-sdmmc1-sw' already enabled
[0004.045] I> sdmmc SDR mode
[0004.059] I> -0 params source =
[0004.060] I> Already published: 00060000
[0004.060] I> Look for boot partition
[0004.060] I> Fallback: assuming 0th partition is boot partition
[0004.061] I> Detect filesystem
[0004.077] I> Loading extlinux.conf ...
[0004.077] I> rootfs path: /sd/boot/extlinux/extlinux.conf
[0004.106] I> L4T boot options
[0004.106] I> [1]: "primary kernel"
[0004.107] I> [2]: "Adafruit SPH0645LM4H"
[0004.107] I> [3]: "FE-PI Audio Z V2"
[0004.107] I> Enter choice:
[0007.108] I> Continuing with default option: 3
[0007.108] I> Loading kernel sig file from rootfs ...
[0007.108] I> rootfs path: /sd/boot/Image.sig
[0007.121] I> Loading kernel binary from rootfs ...
[0007.121] I> rootfs path: /sd/boot/Image
[0009.966] I> Validate kernel ...
[0009.967] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0010.295] I> Loading kernel-dtb sig file from rootfs ...
[0010.296] I> rootfs path: /sd/boot/tegra194-p3668-all-p3509-0000-fe-pi-audio-z-v2.dtb.sig
[0014.430] I> lookup_linear_dir:441: Invalid file block num
[0014.430] I> ext2_walk:142: 'tegra194-p3668-all-p3509-0000-fe-pi-audio-z-v2.dtb.sig' lookup failed
[0014.431] I> ext4_open_file:647: '/boot/tegra194-p3668-all-p3509-0000-fe-pi-audio-z-v2.dtb.sig' lookup failed
[0014.431] E> file /sd/boot/tegra194-p3668-all-p3509-0000-fe-pi-audio-z-v2.dtb.sig open failed!!
[0014.437] W> Failed to load kernel-dtb sig file (err=202113041)
[0014.443] I> Loading kernel-dtb binary from rootfs ...
[0014.448] I> rootfs path: /sd/boot/tegra194-p3668-all-p3509-0000-fe-pi-audio-z-v2.dtb
[0014.487] I> Validate kernel-dtb ...
[0014.487] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0014.488] E> Stage2Signature validation failed with SHA2!!
[0014.488] C> OEM authentication of kernel-dtb header failed!
[0014.488] W> Failed to validate kernel-dtb binary (err=1077936152, fail=1)
[0014.490] W> Security fuse not burned, ignore validation failure
[0014.496] I> Loading ramdisk from rootfs ...
[0014.500] I> rootfs path: /sd/boot/initrd
[0014.966] I> Kernel hdr @0xa42b0000
[0014.966] I> Kernel dtb @0x90000000
[0014.966] I> decompressor handler not found
[0014.967] I> Copying kernel image (34330640 bytes) from 0xa42b0000 to 0x80080000 ... [0014.977] I> Done
[0014.978] I> Updated bpmp info to DTB
[0014.979] I> Ramdisk: Base: 0x91000000; Size: 0x54ecaf
[0014.979] I> Updated initrd info to DTB
[0014.980] W> WARN: Fail to override "console=none" in commandline
[0014.980] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0014.986] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0014.993] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0015.001] I> Active slot suffix:
[0015.004] I> add_boot_slot_suffix: slot_suffix =
[0015.008] I> Linux Cmdline: console=ttyTCU0,115200 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[0015.033] I> Updated bootarg info to DTB
[0015.037] W> MAC addr invalid!
[0015.040] E> Failed to get WIFI MAC address
[0015.044] W> MAC addr invalid!
[0015.046] E> Failed to get Bluetooth MAC address
[0015.051] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:2f:89:d1
[0015.057] W> "plugin-manager" doesn't exist, creating
[0015.062] I> Adding /chosen/plugin-manager/cvm
[0015.066] W> "chip-id" doesn't exist, creating
[0015.070] I> Adding /chosen/plugin-manager/chip-id
[0015.075] W> "configs" doesn't exist, creating
[0015.079] I> Adding /chosen/plugin-manager/configs
[0015.084] W> "ids" doesn't exist, creating
[0015.088] I> Adding /chosen/plugin-manager/ids
[0015.093] W> "odm-data" doesn't exist, creating
[0015.097] I> Adding /chosen/plugin-manager/odm-data
[0015.104] W> "memory" doesn't exist, creating
[0015.106] I> [0] START: 0x80000000, END: 0xac000000
[0015.110] I> [1] START: 0xac004000, END: 0xf09d0000
[0015.115] I> [2] START: 0xf09dc000, END: 0xf09e0000
[0015.120] I> dram_block larger than 80000000
[0015.124] I> [3] START: 0x100000000, END: 0x280000000
[0015.129] I> added [base:0x80000000, size:0x2c000000] to /memory
[0015.135] I> added [base:0xac200000, size:0x44600000] to /memory
[0015.140] I> added [base:0x100000000, size:0x180000000] to /memory
[0015.147] I> Updated memory info to DTB
[0015.150] E> add_disp_param: failed to get display params for du=0
[0015.156] W> "reset" doesn't exist, creating
[0015.161] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0015.165] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0015.170] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0015.174] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0015.179] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0015.184] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0015.189] I> Deleted cpu@6 node in DT
[0015.192] I> Deleted cpu@7 node in DT
[0015.196] I> Deleted cluster3 node in FDT
[0015.200] I> Update arm-pmu in FDT
[0015.203] I> - update property: interrupts
[0015.207] I> - update property: interrupt-affinity
[0015.212] W> "misc-data" doesn't exist, creating
[0015.216] I> Boot-device: QSPI
[0015.219] W> Unknown boot device
[0015.222] I> Add storage-qspi to plugin-manager/misc-data
[0015.227] W> Unknown storage device
[0015.231] I> Ad
                [0015.901] I> QSPI: erasing sectors from 177 - 177
[0015.901] I> QSPI: recoverying tail blocks from 22664 - 22784
[0016.501] I> Kernel EP: 0x80080000, DTB: 0x90000000
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-3357) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Thu Jun 25 21:22:12 PDT 2020
[    0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[    0.000000] OF: fdt:memory scan node memory, reg size 48,
[    0.000000] OF: fdt: - 80000000 ,  2c000000
[    0.000000] OF: fdt: - ac200000 ,  44600000
[    0.000000] OF: fdt: - 100000000 ,  180000000
[    0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[    0.000000] bootconsole [tegra_comb_uart0] enabled
[    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb3_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[    0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[    0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[    0.000000] cma: Reserved 64 MiB at 0x00000000c2000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] percpu: Embedded 25 pages/cpu @ffffffc1ffd04000 s61656 r8192 d32552 u102400
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 2000880
[    0.000000] Kernel command line: console=ttyTCU0,115200 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[    0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[    0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[    0.000000] log_buf_len min size: 32768 bytes
[    0.000000] log_buf_len: 262144 bytes
[    0.000000] early log buf free: 29200(89%)
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Memory: 7190388K/8130560K available (15294K kernel code, 2934K rwdata, 6640K rodata, 8576K init, 609K bss, 186508K reserved, 753664K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008f70000   ( 15296 KB)
[    0.000000]     .rodata : 0xffffff8008f70000 - 0xffffff8009600000   (  6720 KB)
[    0.000000]       .init : 0xffffff8009600000 - 0xffffff8009e60000   (  8576 KB)
[    0.000000]       .data : 0xffffff8009e60000 - 0xffffff800a13d808   (  2935 KB)
[    0.000000]        .bss : 0xffffff800a13d808 - 0xffffff800a1d5f7c   (   610 KB)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf08000000   (   128 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc200000000   (  8192 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 64.
[    0.000000]  RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000006] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.008756] Console: colour dummy device 80x25
[    0.012170] kmemleak: Kernel memory leak detector disabled
[    0.018006] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.028087] pid_max: default: 32768 minimum: 301
[    0.033829] Security Framework initialized
[    0.037230] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[    0.043772] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[    0.052818] ftrace: allocating 47104 entries in 185 pages
[    0.451519] sched-energy: Sched-energy-costs installed from DT
[    0.451704] ASID allocator initialised with 65536 entries
[    0.486799] tegra-id: chipid=21917.
[    0.486886] tegra-id: opt_subrevision=1.
[    0.486973] Tegra Revision: A02 SKU: 0xde CPU Process: 0 SoC Process: 0
[    0.487125] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[    0.487402] DTB Build time: Jun 25 2020 21:27:47
[    0.534787] CPU1: Booted secondary processor [4e0f0040]
[    0.566901] CPU2: Booted secondary processor [4e0f0040]
[    0.598981] CPU3: Booted secondary processor [4e0f0040]
[    0.631247] CPU4: Booted secondary processor [4e0f0040]
[    0.663377] CPU5: Booted secondary processor [4e0f0040]
[    0.663569] Brought up 6 CPUs
[    0.664131] SMP: Total of 6 processors activated.
[    0.664219] CPU features: detected feature: Privileged Access Never
[    0.664322] CPU features: detected feature: LSE atomic instructions
[    0.664443] CPU features: detected feature: User Access Override
[    0.664541] CPU features: detected feature: 32-bit EL0 Support
[    0.666153] CPU: All CPU(s) started at EL2
[    0.666300] alternatives: patching kernel code
[    0.673771] devtmpfs: initialized
[    0.708650] Initilizing CustomIPI irq domain
[    0.708974] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.709152] futex hash table entries: 2048 (order: 5, 131072 bytes)
[    0.719250] pinctrl core: initialized pinctrl subsystem
[    0.719591] OS set in device tree is not L4T.
[    0.719914] regulator-dummy: no parameters
[    0.720274] Initializing plugin-manager
[    0.720397] Plugin module not found
[    0.720497] Plugin-manager status disabled
[    0.721906] NET: Registered protocol family 16
[    0.722981] pstore: using zlib compression
[    0.724026] console [pstore-1] enabled
[    0.724111] pstore: Registered ramoops as persistent store backend
[    0.724217] ramoops: attached 0x200000@0xf0600000, ecc: 0/0
[    0.743219] cpuidle: using governor menu
[    0.744422] bpmp: waiting for handshake
[    0.744518] bpmp: handshake completed
[    0.744600] bpmp: synchronizing channels
[    0.744707] bpmp: channels synchronized
[    0.744793] bpmp: mail init ok
[    0.747451] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[    0.747753] t19x-arm-smmu 12000000.iommu: probing hardware configuration...
[    0.749181] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[    0.754252] t19x-arm-smmu 12000000.iommu:    stage 1 translation
[    0.759942] t19x-arm-smmu 12000000.iommu:    stage 2 translation
[    0.766147] t19x-arm-smmu 12000000.iommu:    nested translation
[    0.771754] t19x-arm-smmu 12000000.iommu:    stream matching with 128 register groups, mask 0x7f80
[    0.780152] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[    0.791092] t19x-arm-smmu 12000000.iommu:    64 context banks (0 stage-2 only)
[    0.798346] t19x-arm-smmu 12000000.iommu:    Stage-1: 39-bit VA -> 48-bit IPA
[    0.805349] t19x-arm-smmu 12000000.iommu:    Stage-2: 39-bit IPA -> 48-bit PA
[    0.815441] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009e64000)
[    0.819724] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.828848] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[    0.836910] tegra_aon_clk_init: ok
[    0.837888] Registering BPMP clocks...
[    0.842190] tegra_bpmp_clk_init: clock init ok (400 clks)
[    0.847967] Serial: AMBA PL011 UART driver
[    0.851850] tegra_powergate_init: DONE
[    0.855428] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[    0.872913] DTB Build time: Jun 25 2020 21:27:47
[    0.881181] Tegra reboot handler registered.
[    0.888725] iommu: Adding device 14160000.pcie to group 0
[    0.889390] iommu: Adding device 141a0000.pcie to group 1
[    0.893948] iommu: Adding device 2490000.ether_qos to group 2
[    0.899314] iommu: Adding device 3100000.serial to group 3
[    0.904776] iommu: Adding device 3110000.serial to group 4
[    0.909986] iommu: Adding device 3140000.serial to group 5
[    0.915315] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[    0.922171] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[    0.927949] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[    0.933990] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[    0.940199] tegra-pmc: ### PMC reset status reg: 0x0
[    0.945120] tegra-pmc: PMC Prod config success
[    0.949554] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[    0.956680] tegra-pmc c360000.pmc: IO padctrl driver initialized
[    0.962603] iommu: Adding device 3400000.sdhci to group 6
[    0.968558] iommu: Adding device 3210000.spi to group 7
[    0.973666] iommu: Adding device 3230000.spi to group 8
[    0.978911] iommu: Adding device 3270000.spi to group 9
[    0.984467] iommu: Adding device 3160000.i2c to group 10
[    0.989586] iommu: Adding device c240000.i2c to group 11
[    0.995014] iommu: Adding device 3180000.i2c to group 12
[    1.000720] iommu: Adding device 3190000.i2c to group 13
[    1.006182] iommu: Adding device 31b0000.i2c to group 14
[    1.011205] iommu: Adding device 31c0000.i2c to group 15
[    1.016873] iommu: Adding device c250000.i2c to group 16
[    1.022633] iommu: Adding device 31e0000.i2c to group 17
[    1.028056] iommu: Adding device sound to group 18
[    1.033172] iommu: Adding device 3510000.hda to group 19
[    1.038312] iommu: Adding device bc00000.rtcpu to group 20
[    1.045397] iommu: Adding device 13e10000.host1x to group 21
[    1.049571] iommu: Adding device 13e10000.host1x:ctx0 to group 22
[    1.056120] iommu: Adding device 13e10000.host1x:ctx1 to group 23
[    1.061885] iommu: Adding device 13e10000.host1x:ctx2 to group 24
[    1.068035] iommu: Adding device 13e10000.host1x:ctx3 to group 25
[    1.073826] iommu: Adding device 13e10000.host1x:ctx4 to group 26
[    1.080144] iommu: Adding device 13e10000.host1x:ctx5 to group 27
[    1.086024] iommu: Adding device 13e10000.host1x:ctx6 to group 28
[    1.092381] iommu: Adding device 13e10000.host1x:ctx7 to group 29
[    1.098572] iommu: Adding device 15340000.vic to group 30
[    1.103728] iommu: Adding device 15380000.nvjpg to group 31
[    1.109398] iommu: Adding device 15500000.tsec to group 32
[    1.114841] iommu: Adding device 15100000.tsecb to group 33
[    1.120588] iommu: Adding device 15480000.nvdec to group 34
[    1.126185] iommu: Adding device 15140000.nvdec1 to group 35
[    1.131763] iommu: Adding device 154c0000.nvenc to group 36
[    1.137363] iommu: Adding device 15a80000.nvenc1 to group 37
[    1.143077] iommu: Adding device 15880000.nvdla0 to group 38
[    1.148717] iommu: Adding device 158c0000.nvdla1 to group 39
[    1.154418] iommu: Adding device 15200000.nvdisplay to group 40
[    1.163301] platform 15200000.nvdisplay: IOVA linear map 0x00000000c6000000(2a000000)
[    1.167635] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[    1.174588] iommu: Adding device 15210000.nvdisplay to group 41
[    1.179897] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[    1.188050] iommu: Adding device 15c10000.vi to group 42
[    1.192293] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[    1.198087] iommu: Adding device 14800000.isp to group 43
[    1.203963] iommu: Adding device 16000000.pva0 to group 44
[    1.208961] iommu: Adding device 16800000.pva1 to group 45
[    1.214284] iommu: Adding device 15810000.se to group 46
[    1.220092] iommu: Adding device 15820000.se to group 47
[    1.225422] iommu: Adding device 15830000.se to group 48
[    1.230887] iommu: Adding device 15840000.se to group 49
[    1.236328] iommu: Adding device c1a0000.aon to group 50
[    1.242630] iommu: Adding device d000000.bpmp to group 51
[    1.247003] bpmp: ping status is 0
[    1.250377] bpmp d000000.bpmp: firmware tag is 57f8a77779f848bf2ecf21dabee5645f
[    1.260489] bpmp d000000.bpmp: probe ok
[    1.262360] tegra-reset 0.bpmp_reset: registered 190 resets.
[    1.267397] iommu: Adding device smmu_test to group 52
[    1.273061] mc: mapped MMIO address: 0xffffff800a590000 -> 0x2c10000
[    1.278747] mc: mapped MMIO address: 0xffffff800a5b0000 -> 0x2c20000
[    1.285301] mc: mapped MMIO address: 0xffffff800a5d0000 -> 0x2c30000
[    1.291504] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2c40000
[    1.297641] mc: mapped MMIO address: 0xffffff800a7d0000 -> 0x2c50000
[    1.304281] mc: mapped MMIO address: 0xffffff800b010000 -> 0x2b80000
[    1.310408] mc: mapped MMIO address: 0xffffff800b030000 -> 0x2b90000
[    1.316883] mc: mapped MMIO address: 0xffffff800b050000 -> 0x2ba0000
[    1.323705] mc: mapped MMIO address: 0xffffff800b070000 -> 0x2bb0000
[    1.330187] mc: mapped MMIO address: 0xffffff800b090000 -> 0x1700000
[    1.336659] mc: mapped MMIO address: 0xffffff800b0b0000 -> 0x1710000
[    1.342868] mc: mapped MMIO address: 0xffffff800b0d0000 -> 0x1720000
[    1.349514] mc: mapped MMIO address: 0xffffff800b0f0000 -> 0x1730000
[    1.355896] mc: mapped MMIO address: 0xffffff800b110000 -> 0x1740000
[    1.362285] mc: mapped MMIO address: 0xffffff800b130000 -> 0x1750000
[    1.368672] mc: mapped MMIO address: 0xffffff800b150000 -> 0x1760000
[    1.375062] mc: mapped MMIO address: 0xffffff800b170000 -> 0x1770000
[    1.381262] mc-err: mcerr ops are set to t19x
[    1.389798] iommu: Adding device 2600000.dma to group 53
[    1.394833] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 224 lines on the chip
[    1.401862] GPIO line 339 (wifi-enable) hogged as output/high
[    1.406246] GPIO line 412 (camera-control-output-low) hogged as output/low
[    1.413157] GPIO line 413 (camera-control-output-low) hogged as output/low
[    1.420053] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[    1.433418] gpio gpiochip1: gpio-line-names specifies 21 line names but there are 40 lines on the chip
[    1.437681] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[    1.443770] GPIO line 266 (w-disable1) hogged as output/high
[    1.449137] GPIO line 264 (w-disable2) hogged as output/high
[    1.455305] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[    1.465608] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[    1.469660] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[    1.477485] iommu: Adding device 3550000.xudc to group 54
[    1.482444] iommu: Adding device 3610000.xhci to group 55
[    1.489162] arm64_ras arm64_ras: probed
[    1.491386] ras_fhi_enable: FHI 468 enabled on CPU0
[    1.496023] ras_fhi_enable: FHI 469 enabled on CPU1
[    1.501312] ras_fhi_enable: FHI 470 enabled on CPU2
[    1.505967] ras_fhi_enable: FHI 471 enabled on CPU3
[    1.511181] ras_fhi_enable: FHI 472 enabled on CPU4
[    1.516105] ras_fhi_enable: FHI 473 enabled on CPU5
[    1.520932] carmel_ras_enable: RAS enabled on cpu0
[    1.525816] carmel_ras_enable: RAS enabled on cpu1
[    1.531078] carmel_ras_enable: RAS enabled on cpu2
[    1.535792] carmel_ras_enable: RAS enabled on cpu3
[    1.540969] carmel_ras_enable: RAS enabled on cpu4
[    1.545938] carmel_ras_enable: RAS enabled on cpu5
[    1.550740] carmel_ras carmel_ras: probed
[    1.555826] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 477, noc_nonsecure_irq = 476>
[    1.562712] tegra-cbb c600000.aon-noc: noc_secure_irq = 479, noc_nonsecure_irq = 478>
[    1.570625] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 481, noc_nonsecure_irq = 480>
[    1.578673] tegra-cbb be00000.rce-noc: noc_secure_irq = 483, noc_nonsecure_irq = 482>
[    1.586605] tegra-cbb b600000.sce-noc: noc_secure_irq = 485, noc_nonsecure_irq = 484>
[    1.593923] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[    1.601595] vdd-ac-bat: 5000 mV
[    1.603828] vdd-sdmmc1-sw: 3300 mV
[    1.607577] vdd-1v8-sd: 1800 mV
[    1.610991] vdd-3v3-cvb: 3300 mV
[    1.613954] vdd-1v8-cvb: 1800 mV
[    1.617448] vdd-epb-1v0: supplied by vdd-3v3-cvb
[    1.621503] vdd-epb-1v0: 1000 mV
[    1.625548] avdd-cam-2v8: 2800 mV
[    1.628785] vdd-fan: 5000 mV
[    1.631954] vdd-hdmi-5v0: 5000 mV
[    1.635342] vdd_sys_en: 1200 mV
[    1.663547] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    1.668409] eventlib_kernel: keventlib is initialized, test id: 0
[    1.668838] SCSI subsystem initialized
[    1.669268] usbcore: registered new interface driver usbfs
[    1.669411] usbcore: registered new interface driver hub
[    1.669626] usbcore: registered new device driver usb
[    1.682008] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[    1.684902] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[    1.695535] vdd-1v0: at 1000 mV
[    1.702320] vdd-1v8-hs: at 1800 mV
[    1.710246] vdd-1v8-ls: at 1800 mV
[    1.718283] vdd-1v8-ao: at 1800 mV
[    1.726331] vddio-ddr-1v1: at 1100 mV
[    1.734107] vdd-rtc: at 800 mV
[    1.735412] spmic-ldo1: at 2375 mV
[    1.746142] vdd-ao-3v3: at 3300 mV
[    1.758189] vddio-emmc-3v3: at 3300 mV
[    1.759569] spmic-ldo4: at 1587 mV
[    1.766755] vdd-usb-3v3: at 3300 mV
[    1.774777] vddio-sdmmc1-3v3: at 3300 mV
[    1.778821] vdd-csi-1v2: at 1200 mV
[    1.780425] spmic-ldo8: at 1800 mV
[    1.785324] GPIO line 246 (gpio_default) hogged as output/high
[    1.786776] GPIO line 247 (gpio_default) hogged as output/high
[    1.787187] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[    1.787560] max77620 4-003c: max77620 probe successful
[    1.788363] media: Linux media interface: v0.10
[    1.788535] Linux video capture interface: v2.00
[    1.789962] pps_core: LinuxPPS API ver. 1 registered
[    1.790065] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.790335] PTP clock support registered
[    1.790797] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[    1.796145] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[    1.803004] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[    1.811828] trusty trusty: trusty version: Built: 21:16:17 Jun 25 2020
[    1.816299] trusty trusty: selected api version: 3 (requested 3)
[    1.823118] Advanced Linux Sound Architecture Driver Initialized.
[    1.828803] Bluetooth: Core ver 2.22
[    1.832098] NET: Registered protocol family 31
[    1.836362] Bluetooth: HCI device and connection manager initialized
[    1.842577] Bluetooth: HCI socket layer initialized
[    1.847824] Bluetooth: L2CAP socket layer initialized
[    1.853094] Bluetooth: SCO socket layer initialized
[    1.860328] camchar: rtcpu character device driver loaded
[    1.863902] gpio tegra-gpio wake61 for gpio=201(Z:1)
[    1.868190] extcon-gpio-states external-connection:extcon@1: Cable state:0, cable id:0
[    1.877011] clocksource: Switched to clocksource arch_sys_counter
[    1.927786] VFS: Disk quotas dquot_6.6.0
[    1.928003] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.928463] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    1.929825] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[    1.930047] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[    1.930632] cma: enabled page replacement for spfn=c6000, epfn=f0000
[    1.930766] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful[    1.932824] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[    1.940775] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[    1.943351] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[    1.943476] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[    1.943594] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[    1.943741] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[    1.943907] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[    1.945252] la/ptsa driver initialized.
[    1.945565] NET: Registered protocol family 2
[    1.946417] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[    1.946710] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[    1.947299] TCP: Hash tables configured (established 65536 bind 65536)
[    1.947341] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[    1.947462] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[    1.947893] NET: Registered protocol family 1
[    1.948415] RPC: Registered named UNIX socket transport module.
[    1.948418] RPC: Registered udp transport module.
[    1.948421] RPC: Registered tcp transport module.
[    1.948424] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.948633] Trying to unpack rootfs image as initramfs...
[    2.062556] nvmap_page_pool_init: Total RAM pages: 1986013
[    2.068242] nvmap_page_pool_init: nvmap page pool size: 248251 pages (969 MB)
[    2.075733] nvmap_background_zero_thread: PP zeroing thread starting.
[    2.076149] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[    2.128510] Freeing initrd memory: 5432K
[    2.140114] random: fast init done
[    2.144634] host1x 13e10000.host1x: initialized
[    2.146300] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    2.150343] audit: initializing netlink subsys (disabled)
[    2.150497] audit: type=2000 audit(1.456:1): initialized
[    2.151249] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[    2.158041] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    2.159201] ntfs: driver 2.1.32 [Flags: R/W].
[    2.159865] 9p: Installing v9fs 9p2000 file system support
[    2.164700] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[    2.165078] io scheduler noop registered
[    2.165394] io scheduler cfq registered (default)
[    2.168651] gic 2a41000.agic-controller: GIC IRQ controller registered
[    2.172255] iommu: Adding device 2993000.adsp to group 56
[    2.198984] iommu: Adding device aconnect@2a41000:adsp_audio to group 57
[    2.200038] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[    2.211903] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    2.212504] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[    2.213301] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    2.213909] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[    2.214489] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[    2.217758] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[    2.222029] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[    2.235829] tsec 15500000.tsec: initialized
[    2.238612] tsec 15100000.tsecb: initialized
[    2.244615] nvdec 15480000.nvdec: initialized
[    2.248180] nvdec 15140000.nvdec1: initialized
[    2.256142] falcon 15340000.vic: initialized
[    2.258002] falcon 15380000.nvjpg: initialized
[    2.260483] falcon 154c0000.nvenc: initialized
[    2.264807] falcon 15a80000.nvenc1: initialized
[    2.271220] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[    2.276310] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[    2.283557] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[    2.290612] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[    2.298028] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[    2.305482] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[    2.312970] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[    2.319574] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[    2.329169] t194-nvcsi 15a00000.nvcsi: initialized
[    2.336200] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[    2.337234] scare-pigeon 14b00000.isp-thi: initialized
[    2.346894] pva 16000000.pva0: initialized
[    2.352715] pva 16800000.pva1: initialized
[    2.357881] nvdla 15880000.nvdla0: initialized
[    2.362644] nvdla 158c0000.nvdla1: initialized
[    2.364525] tegradccommon 15200000.dc_common: host1x channel mapped
[    2.365055] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[    2.372003] tegradccommon 15200000.dc_common: dma mapping done
[    2.377747] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=77
[    2.385521] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[    2.391407] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[    2.396770] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[    2.401360] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[    2.401365] tegra_cec 3960000.tegra_cec: probed
[    2.401862] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor1
[    2.401899] generic_infoframe_type: 0x87
[    2.401984] tegradc 15200000.nvdisplay: DT parsed successfully
[    2.402042] tegradc 15200000.nvdisplay: Display dc.ffffff800bd10000 registered with id=0
[    2.442714] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 7088400 KB/s
[    2.446616] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 800000000 Hz
[    2.447552] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[    2.448181] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check disabled
[    2.448186] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[    2.448523] kfuse 3830000.kfuse: initialized
[    2.459067] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    2.461406] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 47, base_baud = 0) is a TEGRA_UART
[    2.462357] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 48, base_baud = 0) is a TEGRA_UART
[    2.463103] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 49, base_baud = 0) is a TEGRA_UART
[    2.515190] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[    2.515474] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[    2.515480] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[    2.518070] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[    2.518075] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[    2.521365] tegradc 15200000.nvdisplay: probed
[    2.595645] console [ttyTCU0] enabled
[    2.595650] bootconsole [tegra_comb_uart0] disabled
[    2.595917] Console: switching to colour frame buffer device 80x30
[    2.625370] tegradc 15200000.nvdisplay: fb registered
[    2.625625] gpio tegra-gpio wake63 for gpio=97(M:1)
[    2.625960] tegradc 15210000.nvdisplay: disp1 connected to head1->/host1x/sor
[    2.625984] tegradc 15210000.nvdisplay: parse_dp_settings: No dp-lt-settings node
[    2.626062] tegradc 15210000.nvdisplay: DT parsed successfully
[    2.626092] tegradc 15210000.nvdisplay: Display dc.ffffff800bfb0000 registered with id=1
[    2.626249] tegradc 15210000.nvdisplay: vblank syncpt # 11 for dc 1
[    2.626255] tegradc 15210000.nvdisplay: vpulse3 syncpt # 12 for dc 1
[    2.634988] tegradc 15210000.nvdisplay: probed
[    2.681643] tegradc 15210000.nvdisplay: fb registered
[    2.681963] [drm] Initialized
[    2.693463] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[    2.697045] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[    2.704897] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[    2.707615] brd: module loaded
[    2.713315] tegradc 15210000.nvdisplay: blank - powerdown
[    2.714643] loop: module loaded
[    2.714709] tegra_profiler: version: 1.141, samples/io: 48/28
[    2.714837] tegra_profiler: auth: init
[    2.715347] THERMAL EST: found 3 subdevs
[    2.715351] THERMAL EST num_resources: 0
[    2.715356] [THERMAL EST subdev 0]
[    2.715360] [THERMAL EST subdev 1]
[    2.715364] [THERMAL EST subdev 2]
[    2.715372] THERMAL EST: Found 2 profiles, default profile is quiet
[    2.715615] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[    2.715617] THERMAL EST: thz register success.
[    2.715735] THERMAL EST: end of probe, return err: 0
[    2.716425] sd: No Scsi addr parsed to reserve index
[    2.716460] hisi_sas: driver version v1.6
[    2.782614] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[    2.791178] Extcon DP: HPD disabled
[    2.794866] hpd: hpd_switch 0
[    2.797835] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[    2.804412] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[    2.810437] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[    2.821300] qspi_mtd spi6.0: s25fs256s SSG 8 0 1000 2000000
[    2.823513] qspi_mtd spi6.0: s25fs256s (32768 Kbytes)
[    2.828538] qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x2000000 (32MiB) .erasesize = 0x00010000 (64KiB) .numeraseregions = 0
[    2.840397] 1 ofpart partitions found on MTD device spi6.0
[    2.845673] Creating 1 MTD partitions on "spi6.0":
[    2.850499] 0x000000000000-0x000002000000 : "Whole_flash0"
[    2.857899] libphy: Fixed MDIO Bus: probed
[    2.860647] tun: Universal TUN/TAP device driver, 1.6
[    2.865099] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    2.871733] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    2.876915] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    2.883253] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[    2.889945] igb: Copyright (c) 2007-2014 Intel Corporation.
[    2.895587] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[    2.903161] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    2.909510] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[    2.916368] Copyright(c) 1999 - 2017 Intel Corporation.
▒▒WARNING: at platform/drivers/pg/pg-cv-t194.c:73
▒▒[    3.164394] eqos 2490000.ether_qos: Setting local MAC: 48 b0 2d 2f 89 d1
[    3.164697] libphy: dwc_phy: probed
[    3.167370] PPP generic driver version 2.4.2
[    3.167703] PPP BSD Compression module registered
[    3.167816] PPP Deflate Compression module registered
[    3.167932] PPP MPPE Compression module registered
[    3.168027] NET: Registered protocol family 24
[    3.168189] usbcore: registered new interface driver r8152
[    3.168350] usbcore: registered new interface driver asix
[    3.168494] usbcore: registered new interface driver ax88179_178a
[    3.168711] usbcore: registered new interface driver cdc_ether
[    3.168852] usbcore: registered new interface driver net1080
[    3.168986] usbcore: registered new interface driver cdc_subset
[    3.169237] usbcore: registered new interface driver zaurus
[    3.169388] usbcore: registered new interface driver cdc_ncm
[    3.169741] VFIO - User Level meta-driver version: 0.3
[    3.171052] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.171236] ehci-pci: EHCI PCI platform driver
[    3.171364] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    3.175133] ohci-pci: OHCI PCI platform driver
[    3.179606] ohci-platform: OHCI generic platform driver
[    3.189511] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[    3.192191] tegra-xusb 3610000.xhci: extcon 0: ffffffc1f4cd1400 id
[    3.197097] usbcore: registered new interface driver uas
[    3.201920] tegra-xusb 3610000.xhci: Firmware timestamp: 2019-07-24 05:47:34 UTC, Version: 60.06 release
[    3.201947] tegra-xusb 3610000.xhci: xHCI Host Controller
[    3.201962] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[    3.202702] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[    3.202740] tegra-xusb 3610000.xhci: irq 463, io mem 0x03610000
[    3.203059] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    3.203065] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.203069] usb usb1: Product: xHCI Host Controller
[    3.203073] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[    3.203079] usb usb1: SerialNumber: 3610000.xhci
[    3.211963] hub 1-0:1.0: USB hub found
[    3.212052] hub 1-0:1.0: 4 ports detected
[    3.212398] tegra-xusb 3610000.xhci: xHCI Host Controller
[    3.212410] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[    3.212418] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[    3.212730] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    3.212735] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.212740] usb usb2: Product: xHCI Host Controller
[    3.212743] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[    3.212747] usb usb2: SerialNumber: 3610000.xhci
[    3.213307] hub 2-0:1.0: USB hub found
[    3.213387] hub 2-0:1.0: 4 ports detected
[    3.334955] usbcore: registered new interface driver usb-storage
[    3.340519] usbcore: registered new interface driver usbserial
[    3.349618] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[    3.352531] tegra-xudc-new 3550000.xudc: device count: 1
[    3.358651] tegra-xudc-new 3550000.xudc: vbus state: 0
[    3.363250] tegra-xudc-new 3550000.xudc: Initialize boost_cpufreq work
[    3.369733] tegra-xudc-new 3550000.xudc: entering ELPG
[    3.375180] tegra-xudc-new 3550000.xudc: entering ELPG done
[    3.375615] mousedev: PS/2 mouse device common for all mice
[    3.375670] usbcore: registered new interface driver xpad
[    3.441105] tegra_cec 3960000.tegra_cec: Can't find physical addresse.
[    3.441240] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[    3.524280] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[    3.526015] Wake73 for irq=42
[    3.527396] rtc rtc1: alarm rtc device
[    3.527511] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[    3.527679] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    3.528099] i2c /dev entries driver
[    3.530247] i2c i2c-2: Added multiplexed i2c bus 9
[    3.530817] i2c i2c-2: Added multiplexed i2c bus 10
[    3.530926] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[    3.531625] imx219 9-0010: tegracam sensor driver:imx219_v2.0.6
[    3.537048] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[    3.555241] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[    3.555437] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[    3.555650] imx219 9-0010: board setup failed
[    3.555867] imx219: probe of 9-0010 failed with error -121
[    3.556449] imx219 10-0010: tegracam sensor driver:imx219_v2.0.6
[    3.576099] usb 1-2: New USB device found, idVendor=0bda, idProduct=5489
[    3.576268] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.576412] usb 1-2: Product: 4-Port USB 2.0 Hub
[    3.576496] usb 1-2: Manufacturer: Generic
[    3.577882] hub 1-2:1.0: USB hub found
[    3.579256] hub 1-2:1.0: 4 ports detected
[    3.579829] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[    3.580005] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[    3.580173] imx219 10-0010: board setup failed
[    3.580453] imx219: probe of 10-0010 failed with error -121
[    3.582600] max77620-power max20024-power: Event recorder REG_NVERC : 0x40
[    3.591963] tegra-thermal-throttle bthrot_cdev: clk:cpu max:1907200000, min:115200000 steps:24
[    3.596655] tegra-thermal-throttle bthrot_cdev: clk:gpu max:1109250000, min:114750000 steps:10
[    3.601449] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
[    3.610080] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
[    3.618569] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:48 cutoff:0
[    3.626764] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:0:cpu off:0 slope-adj:400
[    3.635422] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:1:gpu off:0 slope-adj:400
[    3.644638] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced max_state:40 cutoff:1
[    3.652401] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:0:cpu off:0 slope-adj:200
[    3.661269] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:1:gpu off:365500000 slope-adj:300
[    3.670988] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced max_state:48 cutoff:0
[    3.678831] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:0:cpu off:38400000 slope-adj:10
[    3.688658] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:1:gpu off:25500000 slope-adj:10
[    3.698999] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced max_state:2 cutoff:0
[    3.706962] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:0:cpu off:0 slope-adj:400
[    3.715869] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:1:gpu off:0 slope-adj:400
[    3.724759] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced max_state:40 cutoff:1
[    3.733288] FAN dev name: pwm-fan
[    3.736089] FAN:gpio request success.
[    3.739753] FAN: can't find tach_gpio
[    3.743420] pwm_fan_driver pwm-fan: Found 2 profiles, default profile is quiet
[    3.750716] pwm_fan_driver pwm-fan: cap state:4, cap pwm:255
[    3.756455] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[    3.763112] pwm_fan_driver pwm-fan: tach period: 1000
[    3.768796] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[    3.775630] pwm_fan_driver pwm-fan: index 1: pwm=130, rpm=1000, rru=2, rrd=2, state:2
[    3.783329] pwm_fan_driver pwm-fan: index 2: pwm=160, rpm=2000, rru=1, rrd=1, state:2
[    3.791023] pwm_fan_driver pwm-fan: index 3: pwm=200, rpm=3000, rru=1, rrd=1, state:2
[    3.798818] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[    3.806341] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[    3.814220] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[    3.822001] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[    3.829665] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[    3.837614] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[    3.847173] device-mapper: uevent: version 1.0.3
[    3.851130] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[    3.863094] tegra194_cpufreq_probe: platform driver Initialization: pass
[    3.866959] cpuidle: Initializing cpuidle driver
[    3.871790] sdhci: Secure Digital Host Controller Interface driver
[    3.877222] sdhci: Copyright(c) Pierre Ossman
[    3.881669] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.887732] sdhci-tegra 3400000.sdhci: Got CD GPIO
[    3.893166] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[    3.901356] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 245
[    3.910261] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[    3.913498] tegra-se-nvhost 15810000.se: initialized
[    3.918109] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[    3.923875] tegra-se-nvhost 15820000.se: initialized
[    3.929377] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[    3.935246] tegra-se-nvhost 15830000.se: initialized
[    3.940194] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[    3.946268] tegra-se-nvhost 15840000.se: initialized
[    3.951410] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[    3.956649] gpio tegra-gpio wake8 for gpio=55(G:7)
[    3.961177] hidraw: raw HID events driver (C) Jiri Kosina
[    3.962250] usbcore: registered new interface driver usbhid
[    3.962252] usbhid: USB HID core driver
[    3.976626] mmc0: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[    3.988577] tegra186-cam-rtcpu bc00000.rtcpu: deferring, 14800000.isp is not probed
[    3.994696] tegra_aon c1a0000.aon: tegra aon driver probe OK
[    3.999846] tegra186-aondbg aondbg: aondbg driver probe() OK
[    4.005661] denver_knobs_init:MTS_VERSION:50168445
[    4.009861] tegra19x_actmon d230000.actmon: in actmon_register()...
[    4.016777] tegra19x_actmon d230000.actmon: initialization Completed for the device mc_all
[    4.024769] t19x_cache tegra-cache: probed
[    4.030787] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[    4.036112] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[    4.043732] carmel-pmu-drv carmel-pmu: Registered Carmel PMU
[    4.049403] PLL_AON clock registered
[    4.054051] Clocks initialized successfully
[    4.059549] nvpmodel: initialized successfully
[    4.062602] trusty-virtio trusty:virtio: initializing
[    4.066788] trusty_ipc virtio0: vring0: va(pa)  ffffffc1f2fd0000(0) qsz 32 notifyid 1
[    4.074030] trusty_ipc virtio0: vring1: va(pa)  ffffffc1f2fd2000(0) qsz 32 notifyid 2
[    4.080912] mmc0: host does not support reading read-only switch, assuming write-enable
[    4.090241] trusty-virtio trusty:virtio: initializing done
[    4.090403] trusty_ipc virtio0: is online
[    4.102413] tegra-hda 3510000.hda: Override SDO lines to 4
[    4.105378] usbcore: registered new interface driver snd-usb-audio
[    4.147069] input: tegra-hda-xnx HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[    4.147484] input: tegra-hda-xnx HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[    4.147827] input: tegra-hda-xnx HDMI/DP,pcm=8 as /devices/3510000.hda/sound/card0/input2
[    4.148223] input: tegra-hda-xnx HDMI/DP,pcm=9 as /devices/3510000.hda/sound/card0/input3
▒▒WARNING: at platform/drivers/pg/pg-gpu-t194.c:185
▒▒[    4.248921] mmc0: hw tuning done ...
[    4.249098] mmc0: new ultra high speed SDR104 SDXC card at address 0001
[    4.249711] mmcblk0: mmc0:0001 SD 58.2 GiB
[    4.254841]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[    4.263471] OPE platform probe
[    4.263671] OPE platform probe successful
[    4.275038] tegra-asoc: sound: ASoC: CODEC DAI sgtl5000 not registered
[    4.275206] tegra-asoc: sound: snd_soc_register_card failed (-517)
[    4.275772] u32 classifier
[    4.275828]     Actions configured
[    4.275967] Initializing XFRM netlink socket
[    4.276609] NET: Registered protocol family 10
[    4.277476] NET: Registered protocol family 17
[    4.277575] NET: Registered protocol family 15
[    4.277764] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    4.278090] Bluetooth: RFCOMM socket layer initialized
[    4.278199] Bluetooth: RFCOMM ver 1.11
[    4.278274] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    4.278382] Bluetooth: HIDP socket layer initialized
[    4.278498] 9pnet: Installing 9P2000 support
[    4.278605] Key type dns_resolver registered
[    4.278840] Registered cp15_barrier emulation handler
[    4.278962] Registered setend emulation handler
[    4.280903] registered taskstats version 1
[    4.281459] tegra-pcie-dw 14160000.pcie: Setting init speed to max speed
[    4.284921] OF: PCI: host bridge /pcie@14160000 ranges:
[    4.289077] OF: PCI:    IO 0x36100000..0x361fffff -> 0x36100000
[    4.295045] OF: PCI:   MEM 0x1740000000..0x17ffffffff -> 0x40000000
[    4.301299] OF: PCI:   MEM 0x1400000000..0x173fffffff -> 0x1400000000
[    4.305045] usb 1-2.3: new high-speed USB device number 3 using tegra-xusb
[    4.325408] usb 1-2.3: New USB device found, idVendor=1a40, idProduct=0101
[    4.325556] usb 1-2.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    4.328558] usb 1-2.3: Product: USB2.0 HUB
[    4.333678] hub 1-2.3:1.0: USB hub found
[    4.336424] hub 1-2.3:1.0: 4 ports detected
[    4.425048] tegra-pcie-dw 14160000.pcie: link is up
[    4.425315] tegra-pcie-dw 14160000.pcie: PCI host bridge to bus 0004:00
[    4.425439] pci_bus 0004:00: root bus resource [bus 00-ff]
[    4.425551] pci_bus 0004:00: root bus resource [io  0x0000-0xfffff] (bus address [0x36100000-0x361fffff])
[    4.425724] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[    4.425905] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[    4.426353] iommu: Adding device 0004:00:00.0 to group 58
[    4.426884] pci 0004:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid
[    4.428213] iommu: Adding device 0004:01:00.0 to group 59
[    4.438565] pci 0004:00:00.0: BAR 14: assigned [mem 0x1740000000-0x17400fffff]
[    4.438709] pci 0004:00:00.0: BAR 13: assigned [io  0x1000-0x1fff]
[    4.438844] pci 0004:01:00.0: BAR 2: assigned [mem 0x1740000000-0x174000ffff 64bit]
[    4.439082] pci 0004:01:00.0: BAR 0: assigned [io  0x1000-0x10ff]
[    4.439231] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[    4.439371] pci 0004:00:00.0:   bridge window [io  0x1000-0x1fff]
[    4.442400] pci 0004:00:00.0:   bridge window [mem 0x1740000000-0x17400fffff]
[    4.449836] pci 0004:00:00.0: Max Payload Size set to  128/ 256 (was  256), Max Read Rq  512
[    4.458270] pci 0004:01:00.0: Max Payload Size set to  128/ 128 (was  128), Max Read Rq  512
[    4.466914] pcieport 0004:00:00.0: Signaling PME through PCIe PME interrupt
[    4.473624] pci 0004:01:00.0: Signaling PME through PCIe PME interrupt
[    4.480841] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[    4.487113] usb 1-2.3: usb_suspend_both: status 0
[    4.492946] OF: PCI: host bridge /pcie@141a0000 ranges:
[    4.496663] OF: PCI:    IO 0x3a100000..0x3a1fffff -> 0x3a100000
[    4.502797] OF: PCI:   MEM 0x1f40000000..0x1fffffffff -> 0x40000000
[    4.508919] OF: PCI:   MEM 0x1c00000000..0x1f3fffffff -> 0x1c00000000
[    4.533057] usb 1-2: usb_suspend_both: status 0
[    4.609032] usb 1-3: new full-speed USB device number 4 using tegra-xusb
[    4.625033] tegra-pcie-dw 141a0000.pcie: link is up
[    4.625339] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0005:00
[    4.625464] pci_bus 0005:00: root bus resource [bus 00-ff]
[    4.625598] pci_bus 0005:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x3a100000-0x3a1fffff])
[    4.625802] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[    4.625979] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[    4.626453] iommu: Adding device 0005:00:00.0 to group 60
[    4.627868] iommu: Adding device 0005:01:00.0 to group 61
[    4.630149] usb 1-3: New USB device found, idVendor=13d3, idProduct=3549
[    4.630298] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    4.630443] usb 1-3: Product: Bluetooth Radio
[    4.630519] usb 1-3: Manufacturer: Realtek
[    4.630591] usb 1-3: SerialNumber: 00e04c000001
[    4.638127] pci 0005:00:00.0: BAR 14: assigned [mem 0x1f40000000-0x1f400fffff]
[    4.638257] pci 0005:01:00.0: BAR 0: assigned [mem 0x1f40000000-0x1f40003fff 64bit]
[    4.638451] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[    4.638576] pci 0005:00:00.0:   bridge window [mem 0x1f40000000-0x1f400fffff]
[    4.644751] pci 0005:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    4.652920] pci 0005:01:00.0: Max Payload Size set to  256/ 256 (was  128), Max Read Rq  512
[    4.661938] pcieport 0005:00:00.0: Signaling PME through PCIe PME interrupt
[    4.668480] pci 0005:01:00.0: Signaling PME through PCIe PME interrupt
[    4.675432] nvme nvme0: pci function 0005:01:00.0
[    4.679701] nvme 0005:01:00.0: enabling device (0000 -> 0002)
[    4.690724] tegra-cbb 14040000.cv-noc: noc_secure_irq = 89, noc_nonsecure_irq = 88>
[    4.696177] tegra-i2c 31e0000.i2c: no acknowledge from address 0xa
[    4.699210] sgtl5000 8-000a: Error reading chip id -121
[    4.704264] sgtl5000: probe of 8-000a failed with error -121
[    4.711860] tegra194-isp5 14800000.isp: initialized
[    4.722017] tegra194-vi5 15c10000.vi: using default number of vi channels, 36
[    4.724757] tegra194-vi5 15c10000.vi: initialized
[    4.731184] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--2 bound
[    4.733371] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--1 bound
[    4.740316] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[    4.801619]  nvme0n1: p1 p2
▒▒[    4.830788] tegra-ivc ivc-bc00000.rtcpu: region 0: iova=0xbfee0000-0xbfefffff size=131072
[    4.831354] tegra-ivc ivc-bc00000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[    4.831861] tegra-ivc ivc-bc00000.rtcpu:dbg@1: dbg: ver=0 grp=1 RX[1x384]=0x1900-0x1b00 TX[1x384]=0x1b00-0x1d00
[    4.832256] tegra-ivc ivc-bc00000.rtcpu:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d00-0x3d80 TX[1x8192]=0x3d80-0x5e00
[    4.832859] tegra-ivc ivc-bc00000.rtcpu:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e00-0xae80 TX[64x320]=0xae80-0xff00
[    4.833214] tegra-ivc ivc-bc00000.rtcpu:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff00-0x17f80 TX[512x64]=0x17f80-0x20000
[    4.833751] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (65)
[    4.833891] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[    4.835221] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=5 sha1=cf2bef3ad10e437272857b76308abef8ffb80bda
[    4.844472] tegra-asoc: sound: ASoC: CODEC DAI sgtl5000 not registered
[    4.849391] tegra-asoc: sound: snd_soc_register_card failed (-517)
[    4.856116] gpio tegra-gpio wake67 for gpio=48(G:0)
[    4.860369] gpio tegra-gpio-aon wake29 for gpio=36(EE:4)
[    4.866124] input: gpio-keys as /devices/gpio-keys/input/input4
[    4.873787] tegra-asoc: sound: ASoC: CODEC DAI sgtl5000 not registered
[    4.878482] tegra-asoc: sound: snd_soc_register_card failed (-517)
[    4.907045] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-01 01:00:22 UTC (946688422)
[    4.907779] mmcblk mmc0:0001: Card claimed for testing.
[    4.950984] bpmp: mounted debugfs mirror
[    4.957646] vdd-1v8-sd: disabling
[    4.957753] vdd-1v8-cvb: disabling
[    4.957817] vdd-epb-1v0: disabling
[    4.957909] avdd-cam-2v8: disabling
[    4.957980] vdd-fan: disabling
[    4.958044] vdd_sys_en: disabling
[    4.958122] ALSA device list:
[    4.958180]   #0: tegra-hda-xnx at 0x3518000 irq 64
[    4.960210] Freeing unused kernel memory: 8576K
[    4.994603] No root-device: Mount failed
[    7.387231] tegra-asoc: sound: ASoC: CODEC DAI sgtl5000 not registered
[    7.387408] tegra-asoc: sound: snd_soc_register_card failed (-517)
[    7.387832] Wake76 for irq=199
[    7.387894] Wake77 for irq=199
[    7.387950] Wake78 for irq=199
[    7.388005] Wake79 for irq=199
[    7.388061] Wake80 for irq=199
[    7.388116] Wake81 for irq=199
[    7.388172] Wake82 for irq=199
[    7.388251] tegra-xusb 3610000.xhci: Upgrade port 0 to USB3.0
[    7.388347] tegra-xusb 3610000.xhci: Upgrade port 1 to USB3.0
[    7.713888] usb 2-3: new SuperSpeedPlus USB device number 2 using tegra-xusb
[    7.750442] usb 2-3: New USB device found, idVendor=0bda, idProduct=0489
[    7.750581] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    7.750697] usb 2-3: Product: 4-Port USB 3.0 Hub
[    7.750776] usb 2-3: Manufacturer: Generic
[    7.760990] hub 2-3:1.0: USB hub found
[    7.763039] hub 2-3:1.0: 4 ports detected
[    7.771867] tegra-asoc: sound: ASoC: CODEC DAI sgtl5000 not registered
[    7.772028] tegra-asoc: sound: snd_soc_register_card failed (-517)
[    8.333036] usb 2-3: usb_suspend_both: status 0
[    8.333288] usb usb2: usb_suspend_both: status 0
hello Daniel_Zhao,
it looks your system is boot-up according to those logs,
may I know what’s the status from the display monitor side, are you able to see login options or it’s complete dark?
Hi Daniel_Zhao,
Any update? still an issue to support?
Thanks Jerry!
There are no login options.
I had solved the issue. The reason is that I had configure the GPIO with the jetson_GPIO.py,and had select the wrong device IO, that changed the defualt boot shedule.
The way to modifing is following:
  1. Using console serial to see the log text, and changing the boot device.
  2. Modifing the boot config file.
This topic was automatically closed 2 days after the last reply. New replies are no longer allowed.
