SD card error 110 on production module NX 16GB
I am trying to enable the usage of SD card in the system using a Jetson Xavier NX 16 GB module and the Auvidea JNX30D as the carrier.
I saw there is the “contact the vendor” policy (which I already did, waiting for the response), but I would hope to get pointed towards the correct direction so I learn a bit more about the inner working on the Jetson world (or more precisely, the embedded linux).
So, about the system
$ cat /etc/nv_tegra_release
# R35 (release), REVISION: 1.0, GCID: 31250864, BOARD: t186ref, EABI: aarch64, DATE: Thu Aug 11 03:40:29 UTC 2022
The error I am experiencing is that, when I insert the SD card I get this statement
# dmesg | tail -n 1
[15504.033465] mmc1: error -110 whilst initialising SD card
# cat /sys/kernel/debug/mmc1/ios
clock:          0 Hz
vdd:            0 (invalid)
bus mode:       2 (push-pull)
chip select:    0 (don't care)
power mode:     0 (off)
bus width:      0 (1 bits)
timing spec:    0 (legacy)
signal voltage: 0 (3.30 V)
driver type:    0 (driver type B)
To install it, I applied some binaries upon the downloaded Jetpack as per their instructions, so the system is slightly different than one within a devkit.
There is one manual process which is not explained in details that says
Standard pinout.
Needs device tree changes to be activated which includes enabling socket pin 211.
Following that, I tried to export the socket pin 211 which, as far as I understood from their docs, is mapped to GPIO3_PS.04, but I didn’t understand if this choice is specifically made because of the carrier or if it is the mapping NVIDIA provides.
I then exported such GPIO using this command
export 453 > /sys/class/gpio/export
which seems to be explained here.
Changing the “value” of such pin, seems to disable the recognition of the SD card: no error thrown, but no device appearing in lsblk
Following some more thread I found in the forum, I tried to edit the dtb file in the /boot/dtb directory using this command
dtb -I dtb -O dts -o kernel_tegra194-p3668-0001-p3509-0000.dts kernel_tegra194-p3668-0001-p3509-0000.dtb
but the source is not neat as the one in the forum, which I finally located in the kernel source under hardware/nvidia/platform/t19x/jakku/kernel-dts/.... The source diff is as following
Only in ./common: tegra194-camera-jakku-rbpcv2-imx219-auvidea.dtsi
Only in ./common: tegra194-camera-rbpcv2-imx219-auvidea.dtsi
diff -r ./common/tegra194-p3509-0000-a00.dtsi /home/saldegheri/jetson/Linux_for_Tegra/sources/hardware/nvidia/platform/t19x/jakku/kernel-dts/common/tegra194-p3509-0000-a00.dtsi
19,22c19,20
< // #include "tegra194-camera-jakku-rbpcv3-imx477.dtsi"              // Remove include for imx477 implementation
< // #include "tegra194-camera-jakku-rbpcv2-imx219.dtsi"              // Remove include for imx219 implementation
< #include "tegra194-camera-rbpcv2-imx219-auvidea.dtsi"         // Add auvidea imx219 support
diff -r ./common/tegra194-p3668-common.dtsi /home/saldegheri/jetson/Linux_for_Tegra/sources/hardware/nvidia/platform/t19x/jakku/kernel-dts/common/tegra194-p3668-common.dtsi
319,359d318
<       sdmmc3: sdhci@3440000 {                                         //added for sd card reader working on JNX30(fd)
<               status = "okay";
<               compatible = "nvidia,tegra194-sdhci";
<               reg = <0x0 0x3440000 0x0 0x00020000>;
<               interrupts = < 0 TEGRA194_IRQ_SDMMC3 0x04>;
<               iommus = <&smmu TEGRA_SID_SDMMC3A>;
<               dma-coherent;
<               max-clk-limit = <208000000>;
<               cd-gpios = <&tegra_main_gpio TEGRA194_MAIN_GPIO(Q, 2) 0>;
<               bus-width = <4>;
<               cap-mmc-highspeed;
<               cap-sd-highspeed;
<               sd-uhs-sdr104;
<               sd-uhs-sdr50;
<               sd-uhs-sdr25;
<               sd-uhs-sdr12;
<               mmc-ddr-1_8v;
<               mmc-hs200-1_8v;
<               cd-inverted;
<               nvidia,min-tap-delay = <96>;
<               nvidia,max-tap-delay = <139>;
<               nvidia,vqmmc-always-on;
<               pwrdet-support;
<               pinctrl-names = "sdmmc_e_33v_enable", "sdmmc_e_33v_disable";
<               pinctrl-0 = <&sdmmc3_e_33V_enable>;
<               pinctrl-1 = <&sdmmc3_e_33V_disable>;
<               ignore-pm-notify;
<               resets = <&bpmp_resets TEGRA194_RESET_SDMMC3>;
<               reset-names = "sdhci";
<               pll_source = "pll_p", "pll_c4_muxed";
<               nvidia,set-parent-clk;
<               nvidia,parent_clk_list = "pll_p", "pll_p", "pll_p", "pll_p", "pll_p", "pll_c4_muxed", "pll_c4_muxed", "pll_c4_muxed", "pll_c4_muxed", "pll_c4_muxed", "NULL";
<               clocks = <&bpmp_clks TEGRA194_CLK_SDMMC3>,
<                       <&bpmp_clks TEGRA194_CLK_PLLP_OUT0>,
<                       <&bpmp_clks TEGRA194_CLK_PLLC4_MUXED>,
<                       <&bpmp_clks TEGRA194_CLK_SDMMC_LEGACY_TM>;
<               clock-names = "sdmmc", "pll_p", "pll_c4_muxed", "sdmmc_legacy_tm";
<               uhs-mask = <0x08>;
<               nvidia,en-periodic-calib;
404c363
<               /*suspend_gpio: suspend-led-gpio {                                              //remove for ethernet on JNX400(fd)
412c371
586c545
<       /*leds {        //remove for ethernet on JNX400(fd)
>       leds {
593c552
Wrapping it up, the question is: am I going into the right direction for searching the issue? Am I missing a stupid flag somewhere?
To apply a different device tree, must I re-use the flash.sh with the according option? Or is it enough to have the FTD entry in extlinux.conf to point to the modified dtb?
Right now, I am building the kernel to be more flexible if some patching is needed.
Please let me know if further output is needed, in every case I will update the answer as soon the vendor answer me
Thank you!
I cannot tell whether you are doing it right or not because I don’t know anything about their carrier board.
The reason to contact the vendor is because they have the custom board schematic… And the “enable sdcard slot” process requires their hardware schematic to work on…
You need to tell the device tree about vmmc-supply and cd-gpios.
vmmc-supply is for the sdcard 3.3v power supply.
cd-gpios is the card detection gpio port which is responsible for hotplug detection.
The rest of properties are not needed to be changed.
Thank you for your answer, I am approaching for the first time into such low-level stuff, so it is not immediate where do I have to search for.
But maybe I am approaching the problem in the wrong way: there is the message “Error 110”, so it seems the hotplug works, so in consequence the power should be on too, right?
You mentioned vmmc-supply, but in my dts file (provided by the vendor) I have the line nvidia,vqmmc-always-on;. Is it supposed to be like this?
I don’t currently have any other SD card to test, but could it be just a “wrong” SD card or configuration?
My card is the Sandisk Pro Extreme 128 GB (SDSQXCD-128G-GN6MA), could it be the root problem? In a Nano devkit this SD card model works.
However, I attach the DTS file and dmesg output (both filtered with mmc and full) plus the DTS relevant for the SD card. Could be the error related to sdhci-tegra 3440000.sdhci: there is not valid maps for state sdmmc_e_33v_enable? Does it indicates a possible device tree indication that is not fully correct?
# dmesg | grep mmc
[    0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[    3.087665] sdhci-tegra 3440000.sdhci: there is not valid maps for state sdmmc_e_33v_enable
[    3.095892] sdhci-tegra 3440000.sdhci: there is not valid maps for state sdmmc_e_33v_disable
[    3.183210] vddio-emmc-3v3: supplied by regulator-dummy
[    3.197038] vddio-sdmmc1-3v3: supplied by regulator-dummy
[    7.647258] sdhci-tegra 3440000.sdhci: there is not valid maps for state sdmmc_e_33v_enable
[    7.647578] sdhci-tegra 3440000.sdhci: there is not valid maps for state sdmmc_e_33v_disable
[    7.649470] sdhci-tegra 3440000.sdhci: there is not valid maps for state sdmmc_e_33v_enable
[    7.658603] sdhci-tegra 3440000.sdhci: there is not valid maps for state sdmmc_e_33v_disable
[    7.664952] mmc0: CQHCI version 5.10
[    7.777517] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[    7.814874] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit
[    7.874868] mmc0: Command Queue Engine enabled
[    7.881085] mmc0: periodic cache flush enabled
[    7.881102] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[    7.895241] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[    7.905808] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB, chardev (510:0)
[    7.926921]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19
[    8.245836] Root device found: mmcblk0p1
[    8.248039] Found dev node: /dev/mmcblk0p1
[    8.282557] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[    8.286653] Rootfs mounted over mmcblk0p1
[    9.349734] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[   60.882363] mmc1: error -110 whilst initialising SD card
# dmesg
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x4e0f0040]
[    0.000000] Linux version 5.10.104-tegra (buildbrain@mobile-u64-5273-d7000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Wed Aug 10 20:17:07 PDT 2022
[    0.000000] Machine model: NVIDIA Jetson Xavier NX Developer Kit
[    0.000000] efi: EFI v2.70 by EDK II
[    0.000000] efi: RTPROP=0x47756c518 SMBIOS=0xc7db0000 SMBIOS 3.0=0x458990000 MEMATTR=0x45942b018 ESRT=0x45943fc98 RNG=0x47c585918 MEMRESERVE=0x45942df18
[    0.000000] efi: seeding entropy pool
[    0.000000] esrt: Reserving ESRT space from 0x000000045943fc98 to 0x000000045943fcd0.
[    0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb3_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x000000047fffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000aeffffff]
[    0.000000]   node   0: [mem 0x00000000af010000-0x00000000c7bfffff]
[    0.000000]   node   0: [mem 0x00000000c7d00000-0x00000000c7d9ffff]
[    0.000000]   node   0: [mem 0x00000000c7da0000-0x00000000c7dbffff]
[    0.000000]   node   0: [mem 0x00000000ca000000-0x00000000ca5fffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x0000000458558fff]
[    0.000000]   node   0: [mem 0x0000000458559000-0x0000000458719fff]
[    0.000000]   node   0: [mem 0x000000045871a000-0x000000045897ffff]
[    0.000000]   node   0: [mem 0x0000000458980000-0x000000045899ffff]
[    0.000000]   node   0: [mem 0x00000004589a0000-0x00000004591fffff]
[    0.000000]   node   0: [mem 0x0000000459200000-0x000000045938ffff]
[    0.000000]   node   0: [mem 0x0000000459390000-0x00000004593bffff]
[    0.000000]   node   0: [mem 0x00000004593c0000-0x00000004593effff]
[    0.000000]   node   0: [mem 0x00000004593f0000-0x000000045943ffff]
[    0.000000]   node   0: [mem 0x0000000459440000-0x000000045960ffff]
[    0.000000]   node   0: [mem 0x0000000459610000-0x000000045961ffff]
[    0.000000]   node   0: [mem 0x0000000459620000-0x00000004596effff]
[    0.000000]   node   0: [mem 0x00000004596f0000-0x000000045977ffff]
[    0.000000]   node   0: [mem 0x0000000459780000-0x0000000459a9ffff]
[    0.000000]   node   0: [mem 0x0000000459aa0000-0x0000000459aaffff]
[    0.000000]   node   0: [mem 0x0000000459ab0000-0x0000000459b1ffff]
[    0.000000]   node   0: [mem 0x0000000459b20000-0x0000000459faffff]
[    0.000000]   node   0: [mem 0x0000000459fb0000-0x0000000459ffffff]
[    0.000000]   node   0: [mem 0x000000045a000000-0x000000045a1bffff]
[    0.000000]   node   0: [mem 0x000000045a1c0000-0x000000045a25ffff]
[    0.000000]   node   0: [mem 0x000000045a260000-0x000000045a30ffff]
[    0.000000]   node   0: [mem 0x000000045a310000-0x000000045a3affff]
[    0.000000]   node   0: [mem 0x000000045a3b0000-0x000000045a43ffff]
[    0.000000]   node   0: [mem 0x000000045a440000-0x000000045a4dffff]
[    0.000000]   node   0: [mem 0x000000045a4e0000-0x000000045adaffff]
[    0.000000]   node   0: [mem 0x000000045adb0000-0x000000045af8ffff]
[    0.000000]   node   0: [mem 0x000000045af90000-0x000000047c53ffff]
[    0.000000]   node   0: [mem 0x000000047c540000-0x000000047c58ffff]
[    0.000000]   node   0: [mem 0x000000047c590000-0x000000047fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000047fffffff]
[    0.000000] On node 0 totalpages: 3965616
[    0.000000]   DMA zone: 4619 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 295600 pages, LIFO batch:63
[    0.000000]   Normal zone: 57344 pages used for memmap
[    0.000000]   Normal zone: 3670016 pages, LIFO batch:63
[    0.000000] cma: Reserved 64 MiB at 0x00000000c3c00000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 32 pages/cpu s90136 r8192 d32744 u131072
[    0.000000] pcpu-alloc: s90136 r8192 d32744 u131072 alloc=32*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] CPU features: detected: Spectre-v2
[    0.000000] CPU features: detected: NVIDIA Carmel CNP erratum
[    0.000000] alternatives: patching kernel code
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 3903653
[    0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000b3c00000-0x00000000c3c00000] (256MB)
[    0.000000] Memory: 15186880K/15862464K available (18432K kernel code, 3172K rwdata, 7156K rodata, 3968K init, 1095K bss, 610048K reserved, 65536K cma-reserved)
[    0.000000] random: get_random_u64 called from __kmem_cache_create+0x38/0x420 with crng_init=0
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000004] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.000715] Console: colour dummy device 80x25
[    0.002220] printk: console [tty0] enabled
[    0.002283] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.002335] pid_max: default: 32768 minimum: 301
[    0.002536] LSM: Security Framework initializing
[    0.002595] Yama: becoming mindful.
[    0.002661] SELinux:  Initializing.
[    0.002856] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.002906] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.006058] rcu: Hierarchical SRCU implementation.
[    0.006388] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[    0.007127] DTS File Name: /home/auvidea/Downloads/Jetpack_5_0/Jetpack_5_0_2_GA/Xavier_NX/Linux_for_Tegra/source/public/kernel_src/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-0001-p3509-0000.dts
[    0.007222] DTB Build time: Aug 31 2022 10:43:03
[    0.009957] Tegra Revision: A02 SKU: 0xde CPU Process: 0 SoC Process: 0
[    0.010215] Remapping and enabling EFI services.
[    0.012211] smp: Bringing up secondary CPUs ...
[    0.042450] Detected PIPT I-cache on CPU1
[    0.042548] CPU1: Booted secondary processor 0x0000000001 [0x4e0f0040]
[    0.071927] Detected PIPT I-cache on CPU2
[    0.072070] CPU2: Booted secondary processor 0x0000000100 [0x4e0f0040]
[    0.101529] Detected PIPT I-cache on CPU3
[    0.101663] CPU3: Booted secondary processor 0x0000000101 [0x4e0f0040]
[    0.131248] Detected PIPT I-cache on CPU4
[    0.131411] CPU4: Booted secondary processor 0x0000000200 [0x4e0f0040]
[    0.161002] Detected PIPT I-cache on CPU5
[    0.161189] CPU5: Booted secondary processor 0x0000000201 [0x4e0f0040]
[    0.161518] smp: Brought up 1 node, 6 CPUs
[    0.161821] SMP: Total of 6 processors activated.
[    0.161907] CPU features: detected: Privileged Access Never
[    0.161942] CPU features: detected: LSE atomic instructions
[    0.161966] CPU features: detected: User Access Override
[    0.161989] CPU features: detected: 32-bit EL0 Support
[    0.162011] CPU features: detected: RAS Extension Support
[    0.162033] CPU features: detected: CRC32 instructions
[    0.162055] CPU features: detected: 32-bit EL1 Support
[    0.229967] CPU: All CPU(s) started at EL2
[    0.237801] devtmpfs: initialized
[    0.289747] Registered cp15_barrier emulation handler
[    0.289912] Registered setend emulation handler
[    0.289942] KASLR enabled
[    0.290179] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.290227] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.291582] pinctrl core: initialized pinctrl subsystem
[    0.292603] SMBIOS 3.0.0 present.
[    0.292639] DMI: Unknown NVIDIA Jetson Xavier NX Developer Kit/NVIDIA Jetson Xavier NX Developer Kit, BIOS 1.0-d7fb19b 08/10/2022
[    0.293365] NET: Registered protocol family 16
[    0.295572] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.296528] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.298193] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.298273] audit: initializing netlink subsys (disabled)
[    0.298597] audit: type=2000 audit(0.296:1): state=initialized audit_enabled=0 res=1
[    0.299094] thermal_sys: Registered thermal governor 'step_wise'
[    0.299100] thermal_sys: Registered thermal governor 'power_allocator'
[    0.299126] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[    0.301334] cpuidle: using governor menu
[    0.301685] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.302150] ASID allocator initialised with 32768 entries
[    0.302387] Serial: AMBA PL011 UART driver
[    0.306490] Tegra reboot handler registered.
[    0.379537] tegra19x-cbb 2300000.cbb-noc: axi2apb bridge info present
[    0.379665] tegra19x-cbb 2300000.cbb-noc: secure_irq = 15, nonsecure_irq = 14>
[    0.379850] tegra19x-cbb c600000.aon-noc: axi2apb bridge info present
[    0.379904] tegra19x-cbb c600000.aon-noc: secure_irq = 17, nonsecure_irq = 16>
[    0.380051] tegra19x-cbb d600000.bpmp-noc: axi2apb bridge info present
[    0.380106] tegra19x-cbb d600000.bpmp-noc: secure_irq = 19, nonsecure_irq = 18>
[    0.380244] tegra19x-cbb be00000.rce-noc: axi2apb bridge info present
[    0.380297] tegra19x-cbb be00000.rce-noc: secure_irq = 21, nonsecure_irq = 20>
[    0.380455] tegra19x-cbb b600000.sce-noc: axi2apb bridge info present
[    0.380509] tegra19x-cbb b600000.sce-noc: secure_irq = 23, nonsecure_irq = 22>
[    0.382654] mc: mapped MMIO address: 0xffff800010880000 -> 0x2c10000
[    0.382702] mc: mapped MMIO address: 0xffff8000108a0000 -> 0x2c20000
[    0.382743] mc: mapped MMIO address: 0xffff8000108c0000 -> 0x2c30000
[    0.382784] mc: mapped MMIO address: 0xffff8000108e0000 -> 0x2c40000
[    0.382824] mc: mapped MMIO address: 0xffff800010900000 -> 0x2c50000
[    0.382869] mc: mapped MMIO address: 0xffff800010920000 -> 0x2b80000
[    0.382922] mc: mapped MMIO address: 0xffff800010940000 -> 0x2b90000
[    0.382968] mc: mapped MMIO address: 0xffff800010960000 -> 0x2ba0000
[    0.383005] mc: mapped MMIO address: 0xffff800010980000 -> 0x2bb0000
[    0.383059] mc: mapped MMIO address: 0xffff8000109a0000 -> 0x1700000
[    0.383111] mc: mapped MMIO address: 0xffff8000109c0000 -> 0x1710000
[    0.383147] mc: mapped MMIO address: 0xffff8000109e0000 -> 0x1720000
[    0.383189] mc: mapped MMIO address: 0xffff800010a00000 -> 0x1730000
[    0.383225] mc: mapped MMIO address: 0xffff800010a20000 -> 0x1740000
[    0.383259] mc: mapped MMIO address: 0xffff800010a40000 -> 0x1750000
[    0.383295] mc: mapped MMIO address: 0xffff800010a60000 -> 0x1760000
[    0.383330] mc: mapped MMIO address: 0xffff800010a80000 -> 0x1770000
[    0.383444] mc-err: mcerr ops are set to t19x
[    0.395590] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.395627] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.395662] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.395687] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.402071] ACPI: Interpreter disabled.
[    0.403305] vdd-epb-1v0: supplied by vdd-3v3-cvb
[    0.404688] iommu: Default domain type: Translated
[    0.404771] eventlib_kernel: keventlib is initialized, test id: 0
[    0.405194] SCSI subsystem initialized
[    0.405365] usbcore: registered new interface driver usbfs
[    0.405419] usbcore: registered new interface driver hub
[    0.405466] usbcore: registered new device driver usb
[    0.405860] mc: Linux media interface: v0.10
[    0.405897] videodev: Linux video capture interface: v2.00
[    0.406258] pps_core: LinuxPPS API ver. 1 registered
[    0.406281] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.406318] PTP clock support registered
[    0.406543] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[    0.406833] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[    0.406930] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[    0.407559] Registered efivars operations
[    0.407885] FPGA manager framework
[    0.407990] Advanced Linux Sound Architecture Driver Initialized.
[    0.408564] Bluetooth: Core ver 2.22
[    0.408610] NET: Registered protocol family 31
[    0.408629] Bluetooth: HCI device and connection manager initialized
[    0.408657] Bluetooth: HCI socket layer initialized
[    0.408683] Bluetooth: L2CAP socket layer initialized
[    0.408731] Bluetooth: SCO socket layer initialized
[    0.411147] camchar: rtcpu character device driver loaded
[    0.412345] clocksource: Switched to clocksource arch_sys_counter
[    0.826782] VFS: Disk quotas dquot_6.6.0
[    0.826884] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.827368] pnp: PnP ACPI: disabled
[    0.841149] la/ptsa driver initialized.
[    0.841294] NET: Registered protocol family 2
[    0.841648] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.856614] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    0.856782] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.857476] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.858122] TCP: Hash tables configured (established 131072 bind 65536)
[    0.858308] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.858568] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.858951] NET: Registered protocol family 1
[    0.859797] RPC: Registered named UNIX socket transport module.
[    0.859834] RPC: Registered udp transport module.
[    0.859848] RPC: Registered tcp transport module.
[    0.859860] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.859899] PCI: CLS 0 bytes, default 64
[    0.860124] Trying to unpack rootfs image as initramfs...
[    1.045440] Initramfs unpacking failed: invalid magic at start of compressed archive
[    1.047547] Freeing initrd memory: 8196K
[    1.051134] hw perfevents: failed to parse interrupt-affinity[6] for arm-pmu
[    1.051187] hw perfevents: /arm-pmu: failed to register PMU devices!
[    1.051220] armv8-pmu: probe of arm-pmu failed with error -22
[    1.051496] kvm [1]: IPA Size Limit: 40 bits
[    1.051900] kvm [1]: vgic interrupt IRQ9
[    1.052345] kvm [1]: VHE mode initialized successfully
[    1.053560] Initialise system trusted keyrings
[    1.053877] workingset: timestamp_bits=46 max_order=22 bucket_order=0
[    1.057929] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.058570] NFS: Registering the id_resolver key type
[    1.058597] Key type id_resolver registered
[    1.058607] Key type id_legacy registered
[    1.058710] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.058731] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    1.058780] ntfs: driver 2.1.32 [Flags: R/W].
[    1.065880] NET: Registered protocol family 38
[    1.065902] Key type asymmetric registered
[    1.065915] Asymmetric key parser 'x509' registered
[    1.065964] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[    1.066220] io scheduler mq-deadline registered
[    1.066233] io scheduler kyber registered
[    1.070497] tegra186-dpaux-pinctrl 155f0000.dpaux: can not get clock
[    1.073023] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    1.073101] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[    1.073161] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    1.073215] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[    1.073265] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[    1.077275] scrncapt: init (heads:4 wins:6 planes:4)
[    1.077344] tegradccommon 15200000.display-hub: Nvhost Channel map failed
[    1.078125] EINJ: ACPI disabled.
[    1.080225] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[    1.080245] tegra-pmc: ### PMC reset source: MAINSWRST
[    1.080256] tegra-pmc: ### PMC reset level: L1
[    1.080266] tegra-pmc: ### PMC reset status reg: 0x2d
[    1.080382] tegra-pmc: PMC Prod config success
[    1.084250] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.088161] random: fast init done
[    1.088421] printk: console [ttyTCU0] enabled
[    2.651467] arm-smmu 10000000.iommu: probing hardware configuration...
[    2.656557] arm-smmu 10000000.iommu: SMMUv2 with:
[    2.661078] arm-smmu 10000000.iommu:         stage 1 translation
[    2.666588] arm-smmu 10000000.iommu:         stage 2 translation
[    2.672102] arm-smmu 10000000.iommu:         nested translation
[    2.677455] arm-smmu 10000000.iommu:         stream matching with 128 register groups
[    2.684617] arm-smmu 10000000.iommu:         64 context banks (0 stage-2 only)
[    2.693431] arm-smmu 10000000.iommu:         Supported page sizes: 0x00001000
[    2.697491] arm-smmu 10000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    2.704045] arm-smmu 10000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    2.711448] arm-smmu 12000000.iommu: probing hardware configuration...
[    2.717088] arm-smmu 12000000.iommu: SMMUv2 with:
[    2.721810] arm-smmu 12000000.iommu:         stage 1 translation
[    2.727317] arm-smmu 12000000.iommu:         stage 2 translation
[    2.733002] arm-smmu 12000000.iommu:         nested translation
[    2.738455] arm-smmu 12000000.iommu:         stream matching with 128 register groups
[    2.745349] arm-smmu 12000000.iommu:         64 context banks (0 stage-2 only)
[    2.754642] arm-smmu 12000000.iommu:         Supported page sizes: 0x00001000
[    2.758735] arm-smmu 12000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    2.765033] arm-smmu 12000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    2.772380] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[    2.782256] tegra_profiler: version: 1.147, samples/io: 49/28
[    2.785668] tegra_profiler: auth: init
[    2.789846] THERMAL EST: found 3 subdevs
[    2.793391] THERMAL EST num_resources: 0
[    2.797235] [THERMAL EST subdev 0]
[    2.800281] [THERMAL EST subdev 1]
[    2.803706] [THERMAL EST subdev 2]
[    2.807209] THERMAL EST: Found 2 profiles, default profile is quiet
[    2.813356] THERMAL EST: thz register success.
[    2.817647] THERMAL EST: end of probe, return err: 0
[    2.823125] nvsciipc: loaded module
[    2.829567] tun: Universal TUN/TAP device driver, 1.6
[    2.832601] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    2.838964] hns3: Copyright (c) 2017 Huawei Corporation.
[    2.844253] e1000e: Intel(R) PRO/1000 Network Driver
[    2.849205] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    2.855590] igb: Intel(R) Gigabit Ethernet Network Driver
[    2.860597] igb: Copyright (c) 2007-2014 Intel Corporation.
[    2.866962] PPP generic driver version 2.4.2
[    2.871216] PPP BSD Compression module registered
[    2.875814] PPP Deflate Compression module registered
[    2.880830] PPP MPPE Compression module registered
[    2.886069] usbcore: registered new interface driver r8152
[    2.891319] usbcore: registered new interface driver asix
[    2.896661] usbcore: registered new interface driver ax88179_178a
[    2.902775] usbcore: registered new interface driver cdc_ether
[    2.908723] usbcore: registered new interface driver net1080
[    2.914324] usbcore: registered new interface driver cdc_subset
[    2.920646] usbcore: registered new interface driver zaurus
[    2.926329] usbcore: registered new interface driver cdc_ncm
[    2.931995] usbcore: registered new interface driver aqc111
[    2.937369] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.943728] ohci-pci: OHCI PCI platform driver
[    2.948033] ohci-platform: OHCI generic platform driver
[    2.953282] tegra-xusb 3610000.xhci: Adding to iommu group 0
[    2.959615] usbcore: registered new interface driver uas
[    2.964315] usbcore: registered new interface driver usb-storage
[    2.970436] tegra-xudc 3550000.xudc: Adding to iommu group 1
[    2.976063] mousedev: PS/2 mouse device common for all mice
[    2.981478] usbcore: registered new interface driver xpad
[    2.988977] tegra_rtc c2a0000.rtc: registered as rtc1
[    2.991932] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:28 UTC (28)
[    2.999778] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    3.006520] i2c /dev entries driver
[    3.009584] tegra-i2c 3160000.i2c: Adding to iommu group 2
[    3.015508] tegra-i2c c240000.i2c: Adding to iommu group 2
[    3.020926] tegra-i2c 3180000.i2c: Adding to iommu group 2
[    3.026352] tegra-i2c 3190000.i2c: Adding to iommu group 2
[    3.031399] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[    3.036891] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[    3.042318] tegra-i2c c250000.i2c: Adding to iommu group 2
[    3.054477] device-mapper: uevent: version 1.0.3
[    3.054883] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[    3.062822] cpuidle: Initializing cpuidle driver
[    3.066834] sdhci: Secure Digital Host Controller Interface driver
[    3.071820] sdhci: Copyright(c) Pierre Ossman
[    3.075934] Synopsys Designware Multimedia Card Interface Driver
[    3.081819] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.087702] sdhci-tegra 3460000.sdhci: Adding to iommu group 3
[    3.097288] SMCCC: SOC_ID: ID = jep106:036b:0019 Revision = 0x00000102
[    3.110633] tegra-bpmp bpmp: firmware: 128431eec76692047e1ac1ebc0392266
[    3.117244] sdhci-tegra 3440000.sdhci: Adding to iommu group 4
[    3.140831] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x2
[    3.150424] vdd-1v0: supplied by regulator-dummy
[    3.155951] vdd-1v8-hs: supplied by regulator-dummy
[    3.160806] vdd-1v8-ls: supplied by regulator-dummy
[    3.165627] vdd-1v8-ao: supplied by regulator-dummy
[    3.169585] vddio-ddr-1v1: supplied by regulator-dummy
[    3.174019] vdd-rtc: supplied by regulator-dummy
[    3.175837] spmic-ldo1: supplied by regulator-dummy
[    3.177063] vdd-ao-3v3: supplied by regulator-dummy
[    3.189636] spmic-ldo4: supplied by regulator-dummy
[    3.190862] vdd-usb-3v3: supplied by regulator-dummy
[    3.203299] vdd-csi-1v2: supplied by vdd-1v8-ls
[    3.208851] spmic-ldo8: supplied by vdd-1v8-ls
[    3.210348] gpio-510 (gpio_default): hogged as output/high
[    3.211806] gpio-511 (gpio_default): hogged as output/high
[    3.217662] gpiochip0: registered GPIOs 504 to 511 on max77620-gpio
[    3.356780] max77686-rtc max77620-rtc: registered as rtc0
[    3.357897] max77620-power max20024-power: Event recorder REG_NVERC : 0x0
[    3.358231] max77620 4-003c: max77620 probe successful
[    4.166744] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[    4.168089] hid: raw HID events driver (C) Jiri Kosina
[    4.168950] usbcore: registered new interface driver usbhid
[    4.169086] usbhid: USB HID core driver
[    4.171530] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 5
[    4.173037] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[    4.256674] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[    4.257334] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[    4.258386] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[    4.259513] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[    4.261343] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[    4.261912] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[    4.262515] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[    4.263961] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (50)
[    4.264194] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[    4.267331] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=d48f1e279e6679b09020947e8de088eabfeaa475
[    4.272741] tegra_aon c1a0000.aon: Adding to iommu group 6
[    4.279170] tegra_aon c1a0000.aon: tegra aon driver probe OK
[    4.283705] tegra186-aondbg aondbg: aondbg driver probe() OK
[    4.290794] denver_knobs_init:MTS_VERSION:55637613
[    4.302628] t19x_cache tegra-cache: probed
[    4.305770] optee: probing for conduit method.
[    4.306635] optee: revision 3.16 (65cc2218)
[    4.307548] optee: dynamic shared memory is enabled
[    4.311916] optee: initialized driver
[    4.318493] nvpmodel: initialized successfully
[    4.319212] tegra_hv: get_hvd: not initialized yet
[    4.324014] user_ivc_mempool: hypervisor not present
[    4.329670] usbcore: registered new interface driver snd-usb-audio
[    4.336220] u32 classifier
[    4.337549]     input device check on
[    4.341310]     Actions configured
[    4.345261] Initializing XFRM netlink socket
[    4.350034] NET: Registered protocol family 10
[    4.356829] Segment Routing with IPv6
[    4.357192] NET: Registered protocol family 17
[    4.361687] NET: Registered protocol family 15
[    4.366069] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    4.379743] Bluetooth: RFCOMM socket layer initialized
[    4.384187] Bluetooth: RFCOMM ver 1.11
[    4.388258] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    4.394085] Bluetooth: HIDP socket layer initialized
[    4.399744] 9pnet: Installing 9P2000 support
[    4.403259] Key type dns_resolver registered
[    4.408552] registered taskstats version 1
[    4.411666] Loading compiled-in X.509 certificates
[    4.423853] Loaded X.509 cert 'Build time autogenerated kernel key: 90ac610178c49616e6b7af33d5f8183bf0ea1ee9'
[    4.427874] tegra194-pcie 14160000.pcie: Adding to iommu group 7
[    4.437516] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[    4.439635] tegra194-pcie 14160000.pcie:       IO 0x0036100000..0x00361fffff -> 0x0036100000
[    4.448374] tegra194-pcie 14160000.pcie:      MEM 0x1400000000..0x173fffffff -> 0x1400000000
[    4.456917] tegra194-pcie 14160000.pcie:      MEM 0x1740000000..0x17ffffffff -> 0x0040000000
[    5.573258] tegra194-pcie 14160000.pcie: Phy link never came up
[    5.573883] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[    5.574101] pci_bus 0004:00: root bus resource [bus 00-ff]
[    5.574239] pci_bus 0004:00: root bus resource [io  0x0000-0xfffff] (bus address [0x36100000-0x361fffff])
[    5.574429] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[    5.574612] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[    5.574956] pci 0004:00:00.0: [10de:1ad1] type 01 class 0x060400
[    5.575356] pci 0004:00:00.0: PME# supported from D0 D3hot D3cold
[    5.593470] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[    5.593838] pci 0004:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    5.595666] pcieport 0004:00:00.0: Adding to iommu group 7
[    5.597200] pcieport 0004:00:00.0: PME: Signaling with IRQ 24
[    5.598828] pcieport 0004:00:00.0: AER: enabled with IRQ 24
[    5.600190] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[    5.601244] pci 0004:00:00.0: Removing from iommu group 7
[    5.601498] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[    5.604993] tegra194-pcie 141a0000.pcie: Adding to iommu group 8
[    5.609793] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[    5.610119] tegra194-pcie 141a0000.pcie:       IO 0x003a100000..0x003a1fffff -> 0x003a100000
[    5.610380] tegra194-pcie 141a0000.pcie:      MEM 0x1c00000000..0x1f3fffffff -> 0x1c00000000
[    5.618456] tegra194-pcie 141a0000.pcie:      MEM 0x1f40000000..0x1fffffffff -> 0x0040000000
[    6.733109] tegra194-pcie 141a0000.pcie: Phy link never came up
[    6.733782] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[    6.734019] pci_bus 0005:00: root bus resource [bus 00-ff]
[    6.734158] pci_bus 0005:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x3a100000-0x3a1fffff])
[    6.734355] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[    6.734558] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[    6.734919] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[    6.735294] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[    6.750720] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[    6.751129] pci 0005:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    6.753035] pcieport 0005:00:00.0: Adding to iommu group 8
[    6.754361] pcieport 0005:00:00.0: PME: Signaling with IRQ 26
[    6.755728] pcieport 0005:00:00.0: AER: enabled with IRQ 26
[    6.757302] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[    6.758166] pci 0005:00:00.0: Removing from iommu group 8
[    6.758422] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[    6.786947] host1x 13e10000.host1x: Adding to iommu group 9
[    6.807722] host1x 13e10000.host1x: initialized
[    6.809297] iommu_context_dev 13e10000.host1x:ctx0: Adding to iommu group 10
[    6.810162] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[    6.811203] iommu_context_dev 13e10000.host1x:ctx1: Adding to iommu group 11
[    6.811955] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[    6.813088] iommu_context_dev 13e10000.host1x:ctx2: Adding to iommu group 12
[    6.813616] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[    6.814514] iommu_context_dev 13e10000.host1x:ctx3: Adding to iommu group 13
[    6.816636] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[    6.826391] iommu_context_dev 13e10000.host1x:ctx4: Adding to iommu group 14
[    6.833352] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[    6.843362] iommu_context_dev 13e10000.host1x:ctx5: Adding to iommu group 15
[    6.850056] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61, iommu=smmu.0x0000000012000000)
[    6.860007] iommu_context_dev 13e10000.host1x:ctx6: Adding to iommu group 16
[    6.867121] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62, iommu=smmu.0x0000000012000000)
[    6.877179] iommu_context_dev 13e10000.host1x:ctx7: Adding to iommu group 17
[    6.883999] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63, iommu=smmu.0x0000000012000000)
[    6.894112] falcon 15340000.vic: Adding to iommu group 18
[    6.908145] falcon 15340000.vic: initialized
[    6.909097] falcon 15380000.nvjpg: Adding to iommu group 18
[    6.914196] falcon 15380000.nvjpg: initialized
[    6.914898] falcon 154c0000.nvenc: Adding to iommu group 18
[    6.927131] falcon 154c0000.nvenc: initialized
[    6.927766] falcon 15a80000.nvenc1: Adding to iommu group 18
[    6.937090] falcon 15a80000.nvenc1: initialized
[    6.937729] nvdec 15480000.nvdec: Adding to iommu group 18
[    6.949700] nvdec 15480000.nvdec: initialized
[    6.950335] nvdec 15140000.nvdec1: Adding to iommu group 18
[    6.959404] nvdec 15140000.nvdec1: initialized
[    6.959976] tsec 15500000.tsec: Adding to iommu group 19
[    6.965238] tsec 15500000.tsec: initialized
[    6.965705] tsec 15100000.tsecb: Adding to iommu group 20
[    6.973928] tsec 15100000.tsecb: initialized
[    6.977400] gic 2a41000.agic-controller: GIC IRQ controller registered
[    7.003255] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[    7.016513] gpio-374 (wifi-enable): hogged as output/high
[    7.016765] gpio-443 (camera-trigger-high): hogged as output/high
[    7.017015] gpio-432 (camera-control-output-low): hogged as output/low
[    7.017259] gpio-431 (camera-control-output-low): hogged as output/low
[    7.017498] gpio-440 (camera-control-output-low): hogged as output/low
[    7.018020] gpio-441 (camera-control-output-low): hogged as output/low
[    7.026241] gpiochip1: registered GPIOs 335 to 503 on tegra194-gpio
[    7.032425] gpiochip2: registered GPIOs 305 to 334 on tegra194-gpio-aon
[    7.037952] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    7.044233] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[    7.049966] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    7.055410] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[    7.061022] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[    7.068924] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=2250000, max_bw=2250000
[    7.076791] tegra194-isp5 13e10000.host1x:isp@14800000: Adding to iommu group 21
[    7.087722] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[    7.093465] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: initialized
[    7.099461] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e10000.host1x:nvcsi@15a00000- bound
[    7.108371] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e10000.host1x:nvcsi@15a00000- bound
[    7.117403] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e10000.host1x:nvcsi@15a00000- bound
[    7.126159] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e10000.host1x:nvcsi@15a00000- bound
[    7.135371] tegra194-vi5 15c10000.vi: Adding to iommu group 22
[    7.142634] scare-pigeon 13e10000.host1x:vi-thi@15f00000: context isolation disabled due to no IOMMU
[    7.150781] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[    7.156837] scare-pigeon 13e10000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[    7.166397] scare-pigeon 13e10000.host1x:isp-thi@14b00000: initialized
[    7.173262] pva 16000000.pva0: Adding to iommu group 23
[    7.199606] pva 16000000.pva0: initialized
[    7.204895] pva 16800000.pva1: Adding to iommu group 24
[    7.215767] pva 16800000.pva1: initialized
[    7.220508] nvdla 15880000.nvdla0: Adding to iommu group 25
[    7.240804] nvdla 15880000.nvdla0: initialized
[    7.242141] nvdla 158c0000.nvdla1: Adding to iommu group 26
[    7.250551] nvdla 158c0000.nvdla1: initialized
[    7.252903] tegradccommon 15200000.display-hub: host1x channel mapped
[    7.253160] tegradccommon 15200000.display-hub: dc_common syncpt # 1 allocated
[    7.253463] tegradc 15200000.display: Adding to iommu group 27
[    7.253514] tegradccommon 15200000.display-hub: dma mapping done
[    7.255480] tegradc 15200000.display: disp0 connected to head0->sor1
[    7.255807] generic_infoframe_type: 0x87
[    7.256077] tegradc 15200000.display: DT parsed successfully
[    7.256426] tegradc 15200000.display: Display dc.(____ptrval____) registered with id=0
[    7.263097] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=64
[    7.263527] tegradc 15210000.display: Adding to iommu group 27
[    7.268993] tegra_cec 3960000.tegra_cec: Unpowergated DISP
[    7.282612] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[    7.283540] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[    7.288440] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 933000000 Hz
[    7.288495] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[    7.295225] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[    7.316835] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[    7.316952] tegradc 15200000.display: vblank syncpt # 8 for dc 0
[    7.322516] tegra_cec 3960000.tegra_cec: probed
[    7.323186] tegra-gpcdma 2600000.dma: Adding to iommu group 2
[    7.328126] tegradc 15200000.display: vpulse3 syncpt # 9 for dc 0
[    7.339506] tegradc 15200000.display: hdmi: can't get adpater for ddc bus 3
[    7.346948] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[    7.359110] tegradc 15200000.display: out->type:1 out_ops->init err = -517
[    7.359278] kfuse 3830000.kfuse: initialized
[    7.367480] tegradc 15210000.display: disp0 connected to head1->sor
[    7.371032] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[    7.376502] tegradc 15210000.display: parse_dp_settings: No dp-lt-settings node
[    7.382831] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[    7.390167] tegradc 15210000.display: DT parsed successfully
[    7.397539] serial-tegra 3100000.serial: Adding to iommu group 2
[    7.402381] tegradc 15210000.display: dc.1 probe not in device tree order, deferring
[    7.416887] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 31, base_baud = 0) is a TEGRA_UART
[    7.426773] serial-tegra 3110000.serial: Adding to iommu group 2
[    7.431758] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 32, base_baud = 0) is a TEGRA_UART
[    7.440907] serial-tegra 3140000.serial: Adding to iommu group 2
[    7.446030] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 33, base_baud = 0) is a TEGRA_UART
[    7.465777] tegra-xusb 3610000.xhci: Firmware timestamp: 2022-03-16 11:07:43 UTC, Version: 60.13 release
[    7.466150] tegra-xusb 3610000.xhci: xHCI Host Controller
[    7.469482] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[    7.477829] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x0000000000050810
[    7.486591] tegra-xusb 3610000.xhci: irq 190, io mem 0x03610000
[    7.492992] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    7.500434] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.507613] usb usb1: Product: xHCI Host Controller
[    7.512550] usb usb1: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[    7.518845] usb usb1: SerialNumber: 3610000.xhci
[    7.524508] hub 1-0:1.0: USB hub found
[    7.527395] hub 1-0:1.0: 4 ports detected
[    7.531992] tegra-xusb 3610000.xhci: xHCI Host Controller
[    7.536867] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[    7.544421] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[    7.552022] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    7.560260] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.567252] usb usb2: Product: xHCI Host Controller
[    7.572480] usb usb2: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[    7.578447] usb usb2: SerialNumber: 3610000.xhci
[    7.583977] hub 2-0:1.0: USB hub found
[    7.586938] hub 2-0:1.0: 4 ports detected
[    7.626865] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[    7.644728] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1907000 KHz, changing to: 1907200 KHz
[    7.645758] tegra194-cpufreq ccplex: probed with BWMGR
[    7.647312] sdhci-tegra 3460000.sdhci: BWMGR client registration for eMC Successful
[    7.648777] irq: IRQ264: trimming hierarchy from :pmc@c360000
[    7.649441] usb-conn-gpio 3520000.xusb_padctl:ports:usb2-0:connector: repeated role: 0
[    7.650725] tegra194-isp5 13e10000.host1x:isp@14800000: initialized
[    7.658497] tegra194-vi5 15c10000.vi: initialized
[    7.665845] tegradc 15200000.display: disp0 connected to head0->sor1
[    7.665947] generic_infoframe_type: 0x87
[    7.665981] tegradc 15200000.display: DT parsed successfully
[    7.666010] tegradc 15200000.display: Display dc.(____ptrval____) registered with id=0
[    7.666756] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[    7.666760] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 933000000 Hz
[    7.666762] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[    7.667119] tegradc 15200000.display: vblank syncpt # 11 for dc 0
[    7.667125] tegradc 15200000.display: vpulse3 syncpt # 12 for dc 0
[    7.668156] tegradc 15200000.display: hdmi: invalid prod list prod_list_hdmi_board
[    7.668160] tegradc 15200000.display: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[    7.669873] sdhci-tegra 3440000.sdhci: Missing 3.3V pad state, err: -19
[    7.669982] sdhci-tegra 3440000.sdhci: Got CD GPIO
[    7.670501] tegradc 15200000.display: probed
[    7.673793] nvethernet 2490000.ethernet: Adding to iommu group 28
[    7.674016] nvethernet 2490000.ethernet: failed to read skip mac reset flag, default 0
[    7.674023] nvethernet 2490000.ethernet: failed to read MDIO address
[    7.674029] nvethernet 2490000.ethernet: setting to default DMA bit mask
[    7.674034] nvethernet 2490000.ethernet: set default TXQ to TC mapping
[    7.674038] nvethernet 2490000.ethernet: Setting default PTP RX queue
[    7.680405] nvethernet 2490000.ethernet: failed to get eqos_rx_m clk
[    7.681762] sdhci-tegra 3440000.sdhci: BWMGR client registration for eMC Successful
[    7.688514] nvethernet 2490000.ethernet: failed to get eqos_rx_input clk
[    7.692437] sdhci-tegra 3440000.sdhci: failed to get tmclk: -2
[    7.780264] nvethernet 2490000.ethernet: failed to get eqos_tx_divider clk
[    7.802708] irq: IRQ265: trimming hierarchy from :pmc@c360000
[    7.809407] nvethernet 2490000.ethernet: Ethernet MAC address: 48:b0:2d:76:70:d8
[    7.821037] -->macsec_probe()
[    7.876716] <--macsec_probe()
[    7.876723] nvethernet 2490000.ethernet: Macsec not supported
[    7.878013] nvethernet 2490000.ethernet: eth0 (HW ver: 50) created with 1 DMA channels
[    7.887863] irq: IRQ267: trimming hierarchy from :pmc@c360000
[    7.899729] irq: IRQ268: trimming hierarchy from :interrupt-controller@3881000
[    7.911355] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    7.931656] tegra-se-nvhost 15810000.se: Adding to iommu group 29
[    7.952051] Console: switching to colour frame buffer device 80x30
[    7.958115] tegradc 15200000.display: fb registered
[    7.962731] irq: IRQ269: trimming hierarchy from :pmc@c360000
[    7.969120] tegradc 15210000.display: disp1 connected to head1->sor
[    7.970289] tegra-se-nvhost 15810000.se: initialized
[    7.974609] tegradc 15210000.display: parse_dp_settings: No dp-lt-settings node
[    7.985294] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[    7.987047] tegradc 15210000.display: DT parsed successfully
[    7.993748] tegra-se-nvhost 15820000.se: Adding to iommu group 30
[    7.998998] tegradc 15210000.display: Display dc.(____ptrval____) registered with id=1
[    8.005900] tegra-se-nvhost 15820000.se: initialized
[    8.013370] tegradc 15210000.display: vblank syncpt # 14 for dc 1
[    8.020118] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[    8.024067] tegradc 15210000.display: vpulse3 syncpt # 16 for dc 1
[    8.032116] tegradc 15210000.display: probed
[    8.037055] tegra-se-nvhost 15830000.se: Adding to iommu group 31
[    8.047388] tegradc 15210000.display: fb registered
[    8.053428] tegra-se-nvhost 15830000.se: initialized
[    8.056351] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[    8.058890] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[    8.064520] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[    8.071212] tegra-se-nvhost 15840000.se: Adding to iommu group 32
[    8.078688] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[    8.090059] tegradc 15210000.display: blank - powerdown
[    8.095415] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[    8.103556] Extcon DP: HPD disabled
[    8.103619] tegra-se-nvhost 15840000.se: initialized
[    8.106923] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[    8.106954] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[    8.113938] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[    8.118320] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[    8.126032] tegra_actmon d230000.actmon: in actmon_register()...
[    8.143851] tegra_actmon d230000.actmon: bwmgr_disable = 0
[    8.149319] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[    8.157743] hvc_sysfs: hypervisor is not present
[    8.190155] ALSA device list:
[    8.190252]   No soundcards found.
[    8.191367] Freeing unused kernel memory: 3968K
[    8.192458] Run /init as init process
[    8.192561]   with arguments:
[    8.192565]     /init
[    8.192569]   with environment:
[    8.192573]     HOME=/
[    8.192577]     TERM=linux
[    8.316945] Switching from initrd to actual rootfs
[    8.356397] tegra_cec 3960000.tegra_cec: Can't find physical address.
[    8.356572] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[    8.467027] systemd[1]: System time before build time, advancing clock.
[    8.541996] systemd[1]: systemd 245.4-4ubuntu3.18 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[    8.544209] systemd[1]: Detected architecture arm64.
[    8.576427] systemd[1]: Set hostname to <jetsonzed03>.
[    9.093187] random: systemd: uninitialized urandom read (16 bytes read)
[    9.093578] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    9.093863] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    9.098824] systemd[1]: Created slice system-modprobe.slice.
[    9.099534] random: systemd: uninitialized urandom read (16 bytes read)
[    9.101439] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    9.101917] random: systemd: uninitialized urandom read (16 bytes read)
[    9.103664] systemd[1]: Created slice User and Session Slice.
[    9.104558] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    9.105970] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    9.106581] systemd[1]: Reached target User and Group Name Lookups.
[    9.107057] systemd[1]: Reached target Slices.
[    9.107411] systemd[1]: Reached target Swap.
[    9.107779] systemd[1]: Reached target System Time Set.
[    9.109149] systemd[1]: Listening on RPCbind Server Activation Socket.
[    9.109756] random: crng init done
[    9.109873] random: 7 urandom warning(s) missed due to ratelimiting
[    9.110048] systemd[1]: Listening on Syslog Socket.
[    9.120071] systemd[1]: Listening on fsck to fsckd communication Socket.
[    9.126329] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    9.133843] systemd[1]: Listening on Journal Audit Socket.
[    9.138436] systemd[1]: Listening on Journal Socket (/dev/log).
[    9.144818] systemd[1]: Listening on Journal Socket.
[    9.149788] systemd[1]: Listening on udev Control Socket.
[    9.155040] systemd[1]: Listening on udev Kernel Socket.
[    9.165731] systemd[1]: Mounting Huge Pages File System...
[    9.171866] systemd[1]: Mounting POSIX Message Queue File System...
[    9.177811] systemd[1]: Mounting RPC Pipe File System...
[    9.184155] systemd[1]: Mounting Kernel Debug File System...
[    9.190299] systemd[1]: Mounting Kernel Trace File System...
[    9.198084] systemd[1]: Starting Journal Service...
[    9.205046] systemd[1]: Starting Set the console keyboard layout...
[    9.211065] systemd[1]: Starting Create list of static device nodes for the current kernel...
[    9.216130] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[    9.216857] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[    9.228111] systemd[1]: Starting Load Kernel Module efi_pstore...
[    9.234685] systemd[1]: Starting Load Kernel Module pstore_blk...
[    9.240892] systemd[1]: Starting Load Kernel Module pstore_zone...
[    9.247735] systemd[1]: Starting Load Kernel Module ramoops...
[    9.255052] systemd[1]: Starting NVIDIA specific first-boot udev script...
[    9.261162] systemd[1]: Started Nameserver information manager.
[    9.262277] systemd[1]: Reached target Network (Pre).
[    9.269101] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    9.275147] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    9.275241] ramoops reserved-memory:ramoops_carveout: failed to locate DT /reserved-memory resource
[    9.292084] systemd[1]: Starting Load Kernel Modules...
[    9.293896] ramoops: probe of reserved-memory:ramoops_carveout failed with error -22
[    9.310944] systemd[1]: Starting Remount Root and Kernel File Systems...
[    9.317851] systemd[1]: Starting udev Coldplug all Devices...
[    9.327471] systemd[1]: Mounted Huge Pages File System.
[    9.328481] systemd[1]: Mounted POSIX Message Queue File System.
[    9.329877] systemd[1]: Mounted RPC Pipe File System.
[    9.336499] systemd[1]: Mounted Kernel Debug File System.
[    9.337412] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    9.347482] systemd[1]: Mounted Kernel Trace File System.
[    9.348116] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x00000000ce000000,704643072
[    9.366539] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[    9.366561] nvmap_page_pool_init: Total RAM pages: 3816145
[    9.380612] nvmap_page_pool_init: nvmap page pool size: 477018 pages (1863 MB)
[    9.387305] systemd[1]: Finished Create list of static device nodes for the current kernel.
[    9.388484] nvmap_background_zero_thread: PP zeroing thread starting.
[    9.396219] misc nvmap: created heap vpr base 0x00000000ce000000 size (688128KiB)
[    9.409978] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[    9.411720] systemd[1]: modprobe@chromeos_pstore.service: Succeeded.
[    9.417541] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[    9.434268] systemd[1]: Finished Load Kernel Module chromeos_pstore.
[    9.441348] systemd[1]: modprobe@efi_pstore.service: Succeeded.
[    9.446899] systemd[1]: Finished Load Kernel Module efi_pstore.
[    9.455042] systemd[1]: Finished Set the console keyboard layout.
[    9.458489] systemd[1]: modprobe@pstore_blk.service: Succeeded.
[    9.464791] systemd[1]: Finished Load Kernel Module pstore_blk.
[    9.470263] systemd[1]: modprobe@pstore_zone.service: Succeeded.
[    9.476695] systemd[1]: Finished Load Kernel Module pstore_zone.
[    9.482892] systemd[1]: modprobe@ramoops.service: Succeeded.
[    9.488294] systemd[1]: Finished Load Kernel Module ramoops.
[    9.493991] systemd[1]: nvfb-udev.service: Succeeded.
[    9.500216] systemd[1]: Finished NVIDIA specific first-boot udev script.
[    9.511656] nvgpu: 17000000.gv11b          nvgpu_nvhost_syncpt_init:135  [INFO]  syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[    9.513899] systemd[1]: Finished Remount Root and Kernel File Systems.
[    9.532512] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[    9.532935] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[    9.547433] systemd[1]: Starting Load/Save Random Seed...
[    9.554194] systemd[1]: Starting Create System Users...
[    9.564382] systemd[1]: Finished Load Kernel Modules.
[    9.566183] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[    9.572526] systemd[1]: Mounting Kernel Configuration File System...
[    9.578188] systemd[1]: Started OP-TEE Client Supplicant.
[    9.584044] systemd[1]: Starting Apply Kernel Variables...
[    9.590549] systemd[1]: Started Journal Service.
[    9.629072] systemd-journald[258]: Received client request to flush runtime journal.
[   10.096542] tegra-xusb 3610000.xhci: entering ELPG done
[   10.404154] using random self ethernet address
[   10.404299] using random host ethernet address
[   10.853544] loop: module loaded
[   11.369181] Mass Storage Function, version: 2009/09/11
[   11.369194] LUN: removable file: (no medium)
[   11.382017] using random self ethernet address
[   11.382153] using random host ethernet address
[   11.424281] rndis0: HOST MAC 26:41:8d:60:be:38
[   11.424292] rndis0: MAC 26:41:8d:60:be:39
[   11.426760] usb0: HOST MAC 26:41:8d:60:be:3a
[   11.426770] usb0: MAC 26:41:8d:60:be:3b
[   11.429105] tegra-xudc 3550000.xudc: EP 0 (type: ctrl, dir: out) enabled
[   11.440175] l4tbr0: port 1(rndis0) entered blocking state
[   11.440224] l4tbr0: port 1(rndis0) entered disabled state
[   11.440706] device rndis0 entered promiscuous mode
[   11.463152] l4tbr0: port 2(usb0) entered blocking state
[   11.463190] l4tbr0: port 2(usb0) entered disabled state
[   11.463609] device usb0 entered promiscuous mode
[   11.929229] tegra-qspi 3270000.spi: Adding to iommu group 2
[   11.948488] spi-tegra114 3210000.spi: Adding to iommu group 2
[   11.957951] spi-tegra114 3230000.spi: Adding to iommu group 2
[   11.979593] imx219 0-0010: tegracam sensor driver:imx219_v2.0.6
[   11.986692] irq: IRQ270: trimming hierarchy from :interrupt-controller@3881000
[   11.996918] imx219 0-0010: imx219_board_setup: error during i2c read probe (-121)
[   12.007747] imx219 0-0010: board setup failed
[   12.019554] imx219: probe of 0-0010 failed with error -121
[   12.031167] imx219 1-0010: tegracam sensor driver:imx219_v2.0.6
[   12.051852] imx219 1-0010: imx219_board_setup: error during i2c read probe (-121)
[   12.064494] imx219 1-0010: board setup failed
[   12.064732] imx219: probe of 1-0010 failed with error -121
[   12.066405] imx219 2-0010: tegracam sensor driver:imx219_v2.0.6
[   12.077058] imx219 2-0010: imx219_board_setup: error during i2c read probe (-121)
[   12.081002] nvethernet 2490000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[   12.081058] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   12.103085] imx219 2-0010: board setup failed
[   12.103310] imx219: probe of 2-0010 failed with error -121
[   12.116217] imx219 8-0010: tegracam sensor driver:imx219_v2.0.6
[   12.121512] tegra-hda 3510000.hda: Adding to iommu group 33
[   12.122756] tegra-hda 3510000.hda: Override SDO lines to 4
[   12.135512] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[   12.144505] imx219 8-0010: board setup failed
[   12.144747] imx219: probe of 8-0010 failed with error -121
[   12.151382] cpu-throttle-alert cooling device registered.
[   12.151977] gpu-throttle-alert cooling device registered.
[   12.152614] aux-throttle-alert cooling device registered.
[   12.153042] hot-surface-alert cooling device registered.
[   12.167053] input: NVIDIA Jetson Xavier NX HDA HDMI/DP,pcm=3 as /devices/platform/3510000.hda/sound/card0/input1
[   12.167302] input: NVIDIA Jetson Xavier NX HDA HDMI/DP,pcm=7 as /devices/platform/3510000.hda/sound/card0/input2
[   12.167526] input: NVIDIA Jetson Xavier NX HDA HDMI/DP,pcm=8 as /devices/platform/3510000.hda/sound/card0/input3
[   12.167729] input: NVIDIA Jetson Xavier NX HDA HDMI/DP,pcm=9 as /devices/platform/3510000.hda/sound/card0/input4
[   12.254364] CPU4: shutdown
[   12.254585] psci: CPU4 killed (polled 0 ms)
[   12.309841] CPU5: shutdown
[   12.309973] psci: CPU5 killed (polled 0 ms)
[   12.313118] nvgpu: 17000000.gv11b                 tpc_pg_mask_store:1067 [INFO]  no value change, same mask already set
[   12.353150] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
[   12.358651] nvadsp 2993000.adsp: Adding to iommu group 34
[   12.358867] nvadsp 2993000.adsp: in probe()...
[   12.405061] nvadsp 2993000.adsp: nvadsp_app_module_probe
[   12.464486] tegra210-adsp aconnect@2a41000:adsp_audio: Adding to iommu group 34
[   12.464540] tegra210_adsp_audio_probe: platform probe started
[   12.493854] tegra210-adsp tegra210-adsp: Default param-type to BYTE for mp3-dec1
[   12.495721] tegra210-adsp tegra210-adsp: Default param-type to BYTE for spkprot
[   12.496803] tegra210-adsp tegra210-adsp: Default param-type to BYTE for src
[   12.500638] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aac-dec1
[   12.501501] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aec
[   12.505280] tegra210-adsp tegra210-adsp: Default param-type to BYTE for wire
[   12.505295] tegra210-adsp tegra210-adsp: adma channel page address dt entry not found
[   12.505300] tegra210-adsp tegra210-adsp: using adma channel page 0
[   12.505433] nvadsp 2993000.adsp: ADSP OS firmware already loaded
[   12.836416] tegra-asoc: sound: Adding to iommu group 34
[   12.956974] tegra210-adsp tegra210-adsp: Loaded app wire
[   12.956988] tegra210-adsp tegra210-adsp: Loaded app apm
[   12.956994] tegra210-adsp tegra210-adsp: Loaded app adma
[   12.956999] tegra210-adsp tegra210-adsp: Loaded app adma_tx
[   12.957010] nvadsp_set_adma_dump_reg: callback for adma reg dump is sent to 000000004939f02b
[   12.985311] tegra210-adsp tegra210-adsp: Tegra210 ADSP driver successfully registered
[   13.740049] cryptd: max_cpu_qlen set to 1000
[   14.482404] qspi_mtd spi6.0: s25fs256s SSG 8 0 1000 2000000
[   14.482417] qspi_mtd spi6.0: s25fs256s (32768 Kbytes)
[   14.482425] qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x2000000 (32MiB) .erasesize = 0x00010000 (64KiB) .numeraseregions = 0
[   14.527562] 1 fixed-partitions partitions found on MTD device spi6.0
[   14.527753] Creating 1 MTD partitions on "spi6.0":
[   14.527866] 0x000000000000-0x000002000000 : "Whole_flash0"
[   19.389653] zram: Added device: zram0
[   19.394726] zram: Added device: zram1
[   19.397537] zram: Added device: zram2
[   19.425205] zram: Added device: zram3
[   19.514898] zram0: detected capacity change from 0 to 1953865728
[   19.592573] Adding 1908068k swap on /dev/zram0.  Priority:5 extents:1 across:1908068k SS
[   19.609918] zram1: detected capacity change from 0 to 1953865728
[   19.704619] Adding 1908068k swap on /dev/zram1.  Priority:5 extents:1 across:1908068k SS
[   19.707153] zram2: detected capacity change from 0 to 1953865728
[   19.760545] Adding 1908068k swap on /dev/zram2.  Priority:5 extents:1 across:1908068k SS
[   19.762952] zram3: detected capacity change from 0 to 1953865728
[   19.828472] Adding 1908068k swap on /dev/zram3.  Priority:5 extents:1 across:1908068k SS
[   24.574584] Bridge firewalling registered
[   35.195589] fuse: init (API version 7.32)
[   35.369989] tegradc 15200000.display: blank - powerdown
[   35.370009] tegradc 15210000.display: blank - powerdown
[   35.484787] nvidia: loading out-of-tree module taints kernel.
[   35.496297] NVRM: No NVIDIA GPU found.
[   35.753438] tegradc 15200000.display: blank - powerdown
[   35.753557] tegradc 15210000.display: blank - powerdown
[   35.755327] tegradc 15200000.display: blank - powerdown
[   36.978779] tegradc 15200000.display: blank - powerdown
[   36.978799] tegradc 15210000.display: blank - powerdown
[   37.141044] NVRM: No NVIDIA GPU found.
[   37.401630] tegradc 15200000.display: blank - powerdown
[   37.401649] tegradc 15210000.display: blank - powerdown
[   37.406613] tegradc 15200000.display: blank - powerdown
[   39.907922] vdd-1v8-sd: disabling
[   39.907932] vdd-3v3-cvb: disabling
[   39.907938] vdd-1v8-cvb: disabling
[   39.907943] vdd-epb-1v0: disabling
[   39.907948] vdd-fan: disabling
[   39.907953] vdd_sys_en: disabling
This should be the relevant part of the DTS file
sdhci@3440000 {
                compatible = "nvidia,tegra194-sdhci";
                reg = <0x00 0x3440000 0x00 0x20000>;
                interrupts = <0x00 0x40 0x04>;
                iommus = <0x02 0x18>;
                interconnects = <0x03 0x62 0x03 0x66>;
                interconnect-names = "dma-mem\0dma-mem";
                dma-coherent;
                max-clk-limit = <0xc65d400>;
                ddr-clk-limit = <0x30a32c0>;
                bus-width = <0x04>;
                cap-mmc-highspeed;
                cap-sd-highspeed;
                sd-uhs-sdr104;
                sd-uhs-sdr50;
                sd-uhs-sdr25;
                sd-uhs-sdr12;
                mmc-ddr-1_8v;
                mmc-hs200-1_8v;
                cd-inverted;
                nvidia,min-tap-delay = <0x60>;
                nvidia,max-tap-delay = <0x8b>;
                nvidia,vqmmc-always-on;
                pwrdet-support;
                nvidia,pad-autocal-pull-up-offset-1v8 = <0x00>;
                nvidia,pad-autocal-pull-down-offset-1v8 = <0x7a>;
                nvidia,pad-autocal-pull-up-offset-3v3-timeout = <0x07>;
                nvidia,pad-autocal-pull-down-offset-3v3-timeout = <0x07>;
                nvidia,pad-autocal-pull-up-offset-1v8-timeout = <0x06>;
                nvidia,pad-autocal-pull-down-offset-1v8-timeout = <0x07>;
                nvidia,pad-autocal-pull-up-offset-sdr104 = <0x00>;
                nvidia,pad-autocal-pull-down-offset-sdr104 = <0x00>;
                nvidia,default-tap = <0x09>;
                nvidia,default-trim = <0x05>;
                pinctrl-names = "sdmmc_e_33v_enable\0sdmmc_e_33v_disable";
                pinctrl-0 = <0x21>;
                pinctrl-1 = <0x22>;
                assigned-clocks = <0x04 0x7a 0x04 0xf1>;
                assigned-clock-parents = <0x04 0xf1>;
                ignore-pm-notify;
                resets = <0x04 0x54>;
                reset-names = "sdhci";
                pll_source = "pll_p\0pll_c4_muxed";
                nvidia,set-parent-clk;
                nvidia,parent_clk_list = "pll_p\0pll_p\0pll_p\0pll_p\0pll_p\0pll_c4_muxed\0pll_c4_muxed\0pll_c4_muxed\0pll_c4_muxed\0pll_c4_muxed\0NULL";
                clocks = <0x04 0x7a 0x04 0x66 0x04 0xf1 0x04 0xdb>;
                clock-names = "sdmmc\0pll_p\0pll_c4_muxed\0sdmmc_legacy_tm";
                uhs-mask = <0x08>;
                status = "okay";
                cd-gpios = <0x0c 0x82 0x00>;
                nvidia,en-periodic-calib;
                phandle = <0x2cd>;
                prod-settings {
                        #prod-cells = <0x04>;
                        prod_c_1_8v {
                                prod = <0x00 0x1e0 0x7f00000 0x600000>;
                        prod_c_3_3v {
                                prod = <0x00 0x1e0 0x7f00000 0x800000>;
                        prod {
                                prod = <0x00 0x04 0xfff 0x200 0x00 0x28 0x22 0x02 0x00 0x100 0x1fff004a 0x5090000 0x00 0x128 0x42000000 0x00 0x00 0x1ac 0x04 0x00 0x00 0x1c0 0x1fc0 0x40 0x00 0x1c4 0x3ff77 0x400 0x00 0x1e0 0x8007f000 0x7000 0x00 0x1e4 0x20000000 0x20000000 0x00 0x204 0x80000000 0x00>;
                        prod_c_ds {
                                prod = <0x00 0x100 0x1fff0000 0x5090000>;
                        prod_c_hs {
                        prod_c_ddr52 {
                                prod = <0x00 0x3c 0x70000 0x40000 0x00 0x120 0xfffe 0x298>;
                        prod_c_hs200 {
                                prod = <0x00 0x3c 0x70000 0x30000 0x00 0x1c0 0xe000 0x4000>;
                        prod_c_sdr104 {
                        prod_c_sdr12 {
                                prod = <0x00 0x3c 0x70000 0x00>;
                        prod_c_sdr25 {
                                prod = <0x00 0x3c 0x70000 0x10000>;
                        prod_c_sdr50 {
                                prod = <0x00 0x3c 0x70000 0x20000 0x00 0x1c0 0xe000 0x8000>;
I would suggest you can search “sdmmc3” in this jetson NX forum…
Also, I still cannot reply your question because I don’t know anything about your carrier board.
You can see what info I asked from other users to help them enable their sdcard slot.
