I wanted to boot from the USB flash drive and proceed step by step as described in the document, but when I finally inserted the USB flash drive and booted, I could not identify the USB. Does the BootLoader not support boot from USB flash drive? But I see the manual can be started from the U disk, help to see where the problem, thank you
[0002.451] I> Hit any key to stop autoboot: 4 3 2 1
[0004.459] initializing target
[0004.459] calling apps_init()
[0004.460] starting app kernel_boot_app
[0004.470] I> found decompressor handler: lz4-legacy
[0004.471] I> decompressing BMP blob …
[0004.482] I> Kernel type = Normal
[0004.482] I> ########## SD (0) boot ##########
[0004.483] W> Ignoring error getting sd-card params
[0004.483] I> sdcard-0 params source =
[0004.484] E> Blockdev open: exit error
[0004.484] E> SD boot failed, err: 724238353
[0004.484] I> ########## USB (0) boot ##########
[0004.489] W> No valid slot number is found in scratch register
[0004.490] W> Return default slot: _a
[0004.505] I> Validate XUSB-FW …
[0004.505] I> T19x: Authenticate XUSB-FW (bin_type: 11), max size 0x30000
[0004.507] I> Encryption fuse is not ON
[0004.508] I> USB Firmware Version: 60.09 release
[0004.565] I> regulator of usb2-0 already enabled
[0004.570] I> regulator of usb2-1 already enabled
[0004.575] I> regulator of usb2-2 already enabled
[0005.642] I> USB 2.0 port 2 new high-speed USB device detected
[0005.642] W> Change usb2 root port id to 3
[0005.642] W> Change usb2 root port id to 2
[0005.644] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa42d5a00, cmd_ring.dma = 0xa42d5ac0
[0005.745] I> Start to enumerate device
[0005.746] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa42d5a00, cmd_ring.dma = 0xa42d5ac0
[0005.751] I>
[0005.751] I> Enumerated USB Device 0424:2744
[0005.751] I>
[0005.752] I> Hub:
[0005.753] I> Downstream ports : 5
[0005.753] I> Power switching : Ganged
[0005.753] I> Compound device : No
[0005.754] I> Over-current protection : Global
[0005.758] I> Hub avg delay : 4 ns
[0005.762] I> Set interface = 1 (alt setting)
[0005.767] I> Enable hub ports
[0005.778] I> Device detected on port 4
[0005.779] I> Device detected on port 5
[0006.794] I> Reset port 4
[0006.849] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa42d5a00, cmd_ring.dma = 0xa42d5ac0
[0006.950] I> Start to enumerate device
[0006.952] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa42d5a00, cmd_ring.dma = 0xa42d5ac0
[0006.957] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa42d5b00, cmd_ring.dma = 0xa42d5ac0
[0006.958] I>
[0006.958] I> Enumerated USB Device 0951:1666
[0006.959] I>
[0006.960] I> Max LUN = 0
[0006.963] I> Vendor Identification : Kingston
[0006.964] I> Product Identification : DataTraveler 3.0
[0006.967] I> Product Revision Level : 0000
[0006.976] I> READ CAPACITY - last LBA = 121077761, 59120MB
[0006.976] I> -0 params source =
[0006.986] I> Found 1 partitions in USB_MS (instance 0)
[0006.986] I> Look for boot partition
[0006.988] I> Fallback: assuming 0th partition is boot partition
[0006.994] I> Detect filesystem
[0007.009] I> Loading kernel-bootctrl from partition
[0007.009] I> Loading partition kernel-bootctrl at 0xa4380000 from device(0x1)
[0007.017] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0007.018] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0007.022] I> Loading extlinux.conf …
[0007.026] I> Loading extlinux.conf binary from rootfs …
[0007.031] I> rootfs path: /usb/boot/extlinux/extlinux.conf
[0007.055] I> ext4_read_data_from_extent:298: Total file read should not be larger than file stat size
[0007.055] E> file /usb/boot/extlinux/extlinux.conf read failed!!
[0007.056] W> Failed to load extlinux.conf binary from rootfs (err=202113305)
[0007.058] E> Failed to find/load /boot/extlinux/extlinux.conf
[0007.064] I> Loading kernel …
[0007.067] I> No kernel binary path
[0007.070] I> Continue to load from partition …
[0007.074] W> No valid slot number is found in scratch register
[0007.080] W> Return default slot: _a
[0007.083] I> A/B: bin_type (37) slot 0
[0007.087] I> Loading kernel from partition
[0007.091] I> Loading partition kernel at 0xa4380000 from device(0x1)
[0007.838] I> Validate kernel …
[0007.839] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0008.218] I> Encryption fuse is not ON
[0008.249] I> Checking boot.img header magic … [0008.249] I> [OK]
[0008.249] I> Loading kernel-dtb …
[0008.249] I> No kernel-dtb binary path
[0008.250] I> Continue to load from partition …
[0008.250] W> No valid slot number is found in scratch register
[0008.250] W> Return default slot: _a
[0008.251] I> A/B: bin_type (38) slot 0
[0008.254] I> Loading kernel-dtb from partition
[0008.258] I> Loading partition kernel-dtb at 0x91000000 from device(0x1)
[0008.275] I> Validate kernel-dtb …
[0008.276] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0008.278] I> Encryption fuse is not ON
[0008.279] I> Kernel hdr @0xa4380000
[0008.282] I> Kernel dtb @0x90000000
[0008.285] I> decompressor handler not found
[0008.289] I> Copying kernel image (34484232 bytes) from 0xa4380800 to 0x80080000 … [0008.305] I> Done
[0008.306] I> Move ramdisk (len: 7238366) from 0xa6464000 to 0x92000000
[0008.309] I> Updated bpmp info to DTB
[0008.311] I> Ramdisk: Base: 0x92000000; Size: 0x6e72de
[0008.313] I> Updated initrd info to DTB
[0008.317] W> WARN: Fail to override “console=none” in commandline
[0008.323] I> Active rootfs suffix:
[0008.326] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0008.333] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0008.341] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0008.348] W> No valid slot number is found in scratch register
[0008.354] W> Return default slot: _a
[0008.357] I> Active slot suffix:
[0008.360] I> add_boot_slot_suffix: slot_suffix =
[0008.365] I> Linux Cmdline: console=ttyTCU0,115200 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=tegrafb earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[0008.399] I> Updated bootarg info to DTB
[0008.403] W> MAC addr invalid!
[0008.406] E> Failed to get WIFI MAC address
[0008.410] W> MAC addr invalid!
[0008.413] E> Failed to get Bluetooth MAC address
[0008.417] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:5f:ef:a8
[0008.424] W> “plugin-manager” doesn’t exist, creating
[0008.428] I> Adding /chosen/plugin-manager/cvm
[0008.432] W> “chip-id” doesn’t exist, creating
[0008.437] I> Adding /chosen/plugin-manager/chip-id
[0008.441] W> “configs” doesn’t exist, creating
[0008.446] I> Adding /chosen/plugin-manager/configs
[0008.450] W> “ids” doesn’t exist, creating
[0008.454] I> Adding /chosen/plugin-manager/ids
[0008.459] W> “odm-data” doesn’t exist, creating
[0008.463] I> Adding /chosen/plugin-manager/odm-data
[0008.470] W> “memory” doesn’t exist, creating
[0008.472] I> [0] START: 0x80000000, END: 0xac000000
[0008.476] I> [1] START: 0xac004000, END: 0xf0ad0000
[0008.481] I> [2] START: 0xf0adc000, END: 0xf0ae0000
[0008.486] I> dram_block larger than 80000000
[0008.490] I> [3] START: 0x100000000, END: 0x280000000
[0008.495] I> added [base:0x80000000, size:0x2c000000] to /memory
[0008.501] I> added [base:0xac200000, size:0x44800000] to /memory
[0008.507] I> added [base:0x100000000, size:0x180000000] to /memory
[0008.513] I> Updated memory info to DTB
[0008.517] E> add_disp_param: failed to get display params for du=0
[0008.523] W> “reset” doesn’t exist, creating
[0008.527] I> Adding ecid(000000016428a0010c0000000a0100c0) to DT
[0008.533] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0008.537] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0008.542] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0008.547] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0008.551] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0008.556] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0008.561] I> Deleted cpu@6 node in DT
[0008.564] I> Deleted cpu@7 node in DT
[0008.568] I> Deleted cluster3 node in FDT
[0008.572] I> Update arm-pmu in FDT
[0008.575] I> - update property: interrupts
[0008.579] I> - update property: interrupt-affinity
[0008.584] W> “misc-data” doesn’t exist, creating
[0008.588] I> Boot-device: QSPI
[0008.591] W> Unknown boot device
[0008.594] I> Add storage-qspi to plugin-manager/misc-data
[0008.599] W> Unknown storage device
[0008.603] I> Add serial number:1425021032197 as DT property
[0008.608] I> Plugin-manager override starting
[0008.612] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0008.619] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0008.625] I> node /plugin-manager/fragement-tegra-sdhci-sd-dis matches
[0008.632] I> Disable plugin-manager status in FDT
[0008.634] I> Plugin-manager override finished successfully
[0008.640] I> tegrabl_load_kernel_and_dtb: Done
[0008.644] E> tegrabl_display_clear: display is not initialized
[0008.650] W> Boot logo display failed…
[0008.653] I> Kernel EP: 0x80080000, DTB: 0x90000000
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.253-tegra (buildbrain@mobile-u64-5374-d5000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Sun Apr 17 02:37:44 PDT 2022
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44800000
[ 0.000000] OF: fdt: - 100000000 , 180000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options ‘’)
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[ 0.000000] cma: Reserved 64 MiB at 0x00000000c2000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s57624 r8192 d32488 u98304
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2001384
[ 0.000000] Kernel command line: console=ttyTCU0,115200 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=tegrafb earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 30132(91%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7190624K/8132608K available (15358K kernel code, 2956K rwdata, 6696K rodata, 8640K init, 612K bss, 188320K reserved, 753664K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f80000 ( 15360 KB)
[ 0.000000] .rodata : 0xffffff8008f80000 - 0xffffff8009610000 ( 6720 KB)
[ 0.000000] .init : 0xffffff8009610000 - 0xffffff8009e80000 ( 8640 KB)
[ 0.000000] .data : 0xffffff8009e80000 - 0xffffff800a163008 ( 2957 KB)
[ 0.000000] .bss : 0xffffff800a163008 - 0xffffff800a1fc0b4 ( 613 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf08000000 ( 128 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc200000000 ( 8192 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000006] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.008546] Console: colour dummy device 80x25
[ 0.012453] console [tty0] enabled
[ 0.015857] bootconsole [tegra_comb_uart0] disabled
[ 0.020855] kmemleak: Kernel memory leak detector disabled
[ 0.020889] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.020927] pid_max: default: 32768 minimum: 301
[ 0.021996] Security Framework initialized
[ 0.022545] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022572] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.024085] ftrace: allocating 47098 entries in 184 pages
[ 0.423086] sched-energy: Sched-energy-costs installed from DT
[ 0.423123] ASID allocator initialised with 65536 entries
[ 0.461351] tegra-id: chipid=21917.
[ 0.461377] tegra-id: opt_subrevision=1.
[ 0.461413] Tegra Revision: A02p SKU: 0xde CPU Process: 0 SoC Process: 0
[ 0.461476] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[ 0.461524] DTB Build time: Apr 17 2022 02:42:31
[ 0.509331] CPU1: Booted secondary processor [4e0f0040]
[ 0.541481] CPU2: Booted secondary processor [4e0f0040]
[ 0.573562] CPU3: Booted secondary processor [4e0f0040]
[ 0.605930] CPU4: Booted secondary processor [4e0f0040]
[ 0.637976] CPU5: Booted secondary processor [4e0f0040]
[ 0.638263] Brought up 6 CPUs
