Cboot in 32.7.2 fails to read extlinux.conf
Please try this within your cboot, reflash the cboot and it shall work with extlinux.conf.
diff --git a/lib/fs/ext4/ext4.c b/lib/fs/ext4/ext4.c
index c994c0f..6e8e2e7 100644
--- a/lib/fs/ext4/ext4.c
+++ b/lib/fs/ext4/ext4.c
@@ -244,6 +244,9 @@
     uint8_t *buf_ptr = NULL;
     off_t total_bytes_read = 0;
     int err = 0;
+    uint32_t file_len_in_blocks = 0;
+    uint32_t total_blocks_read;
+    uint32_t block_size;
     LTRACE_ENTRY;
@@ -254,6 +257,15 @@
     buf_ptr = (uint8_t *)buf;
+    block_size = E2FS_BLOCK_SIZE(ext2->super_blk);
+    if (len != 0UL) {
+        file_len_in_blocks = len/block_size;
+        if ((len % block_size) != 0U) {
+            file_len_in_blocks++;
+        LTRACEF("file_len_in_blocks: %u\n", file_len_in_blocks);
     /* Extract extents info */
     extent_header = (struct ext4_extent_header *)inode->e2di_blocks;
@@ -284,21 +296,37 @@
             err = ext4_read_extent(ext2, (struct ext4_extent_header *)buf2, buf_ptr, &bytes_read);
             total_bytes_read += bytes_read;
             buf_ptr += bytes_read;
-			if ((len != 0) && (total_bytes_read > len)) {
-				TRACEF("Total file read should not be larger than file stat size\n");
-				err = ERR_NOT_VALID;
-				goto fail;
+            total_blocks_read = total_bytes_read/block_size;
+            if ((total_bytes_read % block_size) != 0U) {
+                total_blocks_read++;
+            /* Check if extra block isn't read */
+            if ((len != 0) && (total_blocks_read > file_len_in_blocks)) {
+                TRACEF("More blocks are read (%u) than file block count (%u)\n",
+                        total_blocks_read, file_len_in_blocks);
+                err = ERR_NOT_VALID;
+                goto fail;
     } else {
         /* Read leaf node */
         err = ext4_read_extent(ext2, extent_header, buf_ptr, &bytes_read);
-			goto fail;
+            goto fail;
     LTRACEF("err %d, bytes_read %lu\n", err, total_bytes_read);
