JetPack 5.0.2 Kernel Panic While Reboot on Xavier-NX
We are using yolov5 with deepstream on xavier nx on ssd and a service file to start deepstream on boot. We encountered a problem while rebooting. When we reboot the module, while shut down sequence it is outputing kernel panic error and waits around 10 minutes. Then it reboot normally. We did not face this problem every reboot sequence. It is occuring one from ten times.
[jp5.0.2 reboot|attachment](upload://bmOtgksJJDu9Jot88dirA2TZig8.2 reboot) (79.7 KB)
Looks like the log is not successfully attached. Please upload again.
[0000.024] W> RATCHET: MB1 binary ratchet value 4 is larger than ratchet level 2 from HW fuses.
[0000.033] I> MB1 (prd-version: 2.3.0.0-t194-41334769-0a17edc1)
[0000.038] I> Boot-mode: Coldboot
[0000.041] I> Platform: Silicon
[0000.044] I> Chip revision : A02P
[0000.047] I> Bootrom patch version : 15 (correctly patched)
[0000.052] I> ATE fuse revision : 0x200
[0000.055] I> Ram repair fuse : 0x0
[0000.058] I> Ram Code : 0x0
[0000.061] I> rst_source: 0xb, rst_level: 0x1
[0000.066] I> Boot-device: QSPI (instance: 0)
[0000.070] I> Qspi flash params source = brbct
[0000.074] I> Qspi clock source : pllp
[0000.077] I> Qspi-0 initialized successfully
[0000.081] I> Boot chain mechanism: A/B
[0000.085] I> Current Boot-Chain Slot: 0
[0000.088] I> BR-BCT Boot-Chain: 0, status: 0. update flag: 0
[0000.094] I> Qspi flash params source = brbct
[0000.100] W> PROD_CONFIG: device prod data is empty in MB1 BCT.
[0000.106] I> Temperature = 40000
[0000.109] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.113] W> Skipping boost for clk: BPMP_APB
[0000.117] W> Skipping boost for clk: AXI_CBB
[0000.121] W> Skipping boost for clk: AON_CPU_NIC
[0000.125] W> Skipping boost for clk: CAN1
[0000.129] W> Skipping boost for clk: CAN2
[0000.133] I> Boot-device: QSPI (instance: 0)
[0000.137] I> Qspi flash params source = mb1bct
[0000.141] I> Qspi clock source : pllc_out0
[0000.145] I> Qspi-0 reinitialized
[0000.148] I> Qspi flash params source = mb1bct
[0000.161] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.168] W>  Thermal config not found in BCT
[0000.176] W>  MEMIO rail config not found in BCT
[0000.187] I> Qspi flash params source = mb1bct
[0000.200] I> Qspi flash params source = mb1bct
[0000.234] I> Qspi flash params source = mb1bct
[0000.798] I> Qspi flash params source = mb1bct
[0000.815] I> Qspi flash params source = mb1bct
[0000.854] W>  Platform config not found in BCT
[0000.881] I> Qspi flash params source = mb1bct
[0000.906] I> MB1 done
����main enter
SPE VERSION #: R01.00.18 Created: Jan 29 2021 @ 14:18:27
HW Function test
Start Scheduler.
in late init
  [0000.915] I> Welcome to MB2(TBoot-BPMP) (version: default.t194-mobile-1ca012e4)
[0000.916] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.917] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.918] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.923] W> device prod register failed
[0000.927] I> gpio framework initialized
[0000.931] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0000.938] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0000.946] I> No valid sdcard_params in mb1_bct
[0000.950] I> Boot_device: QSPI_FLASH instance: 0
[0000.954] I> qspi flash-0 params source = boot args
[0000.960] I> QSPI-0l initialized successfully
[0000.963] I> sdmmc-3 params source = safe params
[0001.308] I> sdmmc DDR50 mode
[0001.326] I> Found 41 partitions in QSPI_FLASH (instance 0)
[0001.343] W> Cannot find any partition table for 00000003
[0001.344]  > PARTITION_MANAGER: Failed to publish partition.
[0001.360] I> Found 19 partitions in SDMMC_USER (instance 3)
[0001.361] I> Active Boot chain : 0
[0002.032] I> Relocating BR-BCT
[0002.034]  > DEVICE_PROD: device prod is not initialized.
[0002.059] E> I2C: slave not found in slaves.
[0002.060] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0002.061] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.062] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 0.
[0002.063] E> eeprom: Failed to read I2C slave device
[0002.066] I> Failed to read CVB eeprom data @ AE
[0002.071] I> Retrying CVB eeprom read @ AC ...
[0002.076] E> I2C: slave not found in slaves.
[0002.080] E> I2C: Could not write 0 bytes to slave: 0x00ac with repeat start true.
[0002.087] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.093] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xac at 0x00000000 via instance 0.
[0002.102] E> eeprom: Failed to read I2C slave device
[0002.107] I> Failed to read CVB eeprom data @ AC
[0002.368] I> Relocating OP-TEE dtb from: 0x6bfff1d0 to 0x70050000, size: 1008
[0002.369] I> [0] START: 0x80000000, SIZE: 0x2f000000
[0002.370] I> [1] START: 0xaf010000, SIZE: 0x18bf0000
[0002.370] I> [2] START: 0xc7d00000, SIZE: 0xc0000
[0002.371] I> [3] START: 0xca000000, SIZE: 0x800000
[0002.371] I> dram_block larger than 80000000
[0002.373] I> [4] START: 0x100000000, SIZE: 0x180000000
[0002.385] I> Setting NS memory ranges to OP-TEE dtb finished.
[0002.388] I> found decompressor handler: lz4
[0002.616] I> EKB detected (length: 0x410) @ VA:0x52709400
[0002.617] I> Setting EKB blob info to OPTEE dtb finished.
��NOTICE:  BL31: v2.6(release):4fa405dbd
NOTICE:  BL31: Built : 20:16:55, Aug 10 2022
I/TC:
  bpmp: init
bpmp: tag is 128431eec76692047e1ac1ebc0392266
sku_dt_init: not sku 0x00
��I��clk_early initialized
��/TC: ��mail_early initialized
��No��fuse initialized
hwwdt initialized
��n-se��t194_ec_get_ec_list: found 45 ecs
��cure extern��ec initialized
vmon_setup_monitors: found 3 monitors
vmon initialized
��al ��adc initialized
��D��fmon_populate_monitors: found 73 monitors
��T found
��fmon initialized
mc initialized
reset initialized
nvhs initialized
uphy_early initialized
emc_early initialized
392 clocks registered
clk initialized
io_dpd initialized
thermal initialized
thermal_mrq initialized
i2c initialized
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
vrmon initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
suspend initialized
pg_late initialized
pg_mrq_init initialized
strap initialized
nvl initialized
emc initialized
emc_mrq initialized
clk_dt initialized
tj_init initialized
uphy_dt initialized
uphy_mrq initialized
uphy initialized
ec_swd_poll_start: 281 reg polling start w period 47 ms
ec_late initialized
hwwdt_late initialized
reset_mrq initialized
ec_mrq initialized
fmon_mrq initialized
clk_mrq initialized
avfs_mrq initialized
mail_mrq initialized
i2c_mrq initialized
tag_mrq initialized
console_mrq initialized
mrq initialized
clk_sync_fmon_post initialized
��I/TC: OP-TEE version: 3.16 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Thu Aug��clk_dt_late initialized
noc_late initialized
�� ��pm_post initialized
dbells initialized
��11 ��dmce initialized
��0��cvc initialized
��3:23:20 UTC ��avfs_clk_mach_post initialized
��2022��avfs_clk_platform_post initialized
�� aa��cvc_late initialized
regulator_post initialized
��rch6��rm initialized
console_late initialized
clk_dt_post initialized
mc_reg initialized
��4
I/TC: WARNIN��pg_post initialized
profile initialized
fuse_late initialized
extras_post initialized
bpmp: init complete
entering main console loop
] ��G: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: Primary CPU switching to normal world boot
  [0003.236] I> Welcome to NVDisp-Init
[0003.236] I> NVDisp-Init version: t194-f9ecfedc
[0003.237] I> CPU-BL Params @ 0xca020000
[0003.237] I>  0) Base:0x00000000 Size:0x00000000
[0003.237] I>  1) Base:0xc8300000 Size:0x00100000
[0003.238] I>  2) Base:0xc9800000 Size:0x00200000
[0003.238] I>  3) Base:0xc8600000 Size:0x00200000
[0003.240] I>  4) Base:0xc8200000 Size:0x00100000
[0003.245] I>  5) Base:0xc8100000 Size:0x00100000
[0003.249] I>  6) Base:0xc9400000 Size:0x00400000
[0003.254] I>  7) Base:0xc9000000 Size:0x00400000
[0003.258] I>  8) Base:0xc8000000 Size:0x00100000
[0003.263] I>  9) Base:0xc7f00000 Size:0x00100000
[0003.267] I> 10) Base:0xca800000 Size:0x00800000
[0003.272] I> 11) Base:0x40000000 Size:0x00040000
[0003.276] I> 12) Base:0xc7e00000 Size:0x00100000
[0003.281] I> 13) Base:0x40046000 Size:0x00002000
[0003.285] I> 14) Base:0x40048000 Size:0x00002000
[0003.290] I> 15) Base:0xaf000000 Size:0x00004000
[0003.294] I> 16) Base:0x4004a000 Size:0x00002000
[0003.298] I> 17) Base:0xc7c00000 Size:0x00100000
[0003.303] I> 18) Base:0x4004c000 Size:0x00002000
[0003.307] I> 19) Base:0xc9a00000 Size:0x00600000
[0003.312] I> 20) Base:0x4004e000 Size:0x00002000
[0003.316] I> 21) Base:0xc7dc0000 Size:0x0000c000
[0003.321] I> 22) Base:0x00000000 Size:0x00000000
[0003.325] I> 23) Base:0xc7de0000 Size:0x00020000
[0003.330] I> 24) Base:0xcc000000 Size:0x02000000
[0003.334] I> 25) Base:0x40050000 Size:0x00002000
[0003.339] I> 26) Base:0x40040000 Size:0x00006000
[0003.343] I> 27) Base:0xc8c00000 Size:0x00400000
[0003.348] I> 28) Base:0xc8400000 Size:0x00200000
[0003.352] I> 29) Base:0xc8800000 Size:0x00400000
[0003.356] I> 30) Base:0xc7dd0000 Size:0x00010000
[0003.361] I> 31) Base:0x00000000 Size:0x00000000
[0003.365] I> 32) Base:0xf8000000 Size:0x08000000
[0003.370] I> 33) Base:0xce000000 Size:0x2a000000
[0003.374] I> 34) Base:0xcb000000 Size:0x01000000
[0003.379] I> 35) Base:0xae000000 Size:0x01000000
[0003.383] I> 36) Base:0xa0000000 Size:0x0e000000
[0003.388] I> 37) Base:0xca000000 Size:0x00800000
[0003.392] I> 38) Base:0x80000000 Size:0x20000000
[0003.397] I> 39) Base:0xb0000000 Size:0x08000000
[0003.401] I> 40) Base:0x00000000 Size:0x00000000
[0003.406] I> 41) Base:0x00000000 Size:0x00000000
[0003.410] I> 42) Base:0x00000000 Size:0x00000000
[0003.414] I> 43) Base:0x00000000 Size:0x00000000
[0003.419] I> 44) Base:0x00000000 Size:0x00000000
[0003.423] I> 45) Base:0x00000000 Size:0x00000000
[0003.428] GIC-SPI Target CPU: 0
[0003.431] Interrupts Init done
[0003.434] calling constructors
[0003.437] initializing heap
[0003.439] I> Heap: [0xa0960000 ... 0xadf00000]
[0003.444] initializing threads
[0003.446] initializing timers
[0003.449] creating bootstrap completion thread
[0003.454] top of bootstrap2()
[0003.456] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0003.461] initializing platform
[0003.464] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0003.469] W> device prod register failed
[0003.473] I> Bl_dtb @0xadf00000
[0003.476] I> gpio framework initialized
[0003.487] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0003.490] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0003.499] I> fixed regulator driver initialized
[0003.516] I> register 'maxim' power off handle
[0003.518] I> virtual i2c enabled
[0003.518] I> registered 'maxim,max20024' pmic
[0003.519] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0003.519] I> Boot-device: QSPI
[0003.520] I> Boot_device: QSPI_FLASH instance: 0
[0003.525] I> configure_qspi_clk: qparams clk_src = 5, clk_div = 0, clk_src_freq = 800000000, interface_freq = 50000000
[0003.535] I> configure_qspi_clk: FORCING INTERFACE_FREQ TO 133000000!!
[0003.543] I> QSPI source rate = 204000 Khz
[0003.546] I> Requested rate for QSPI clock = 34000 Khz
[0003.551] I> BPMP-set rate for QSPI clk = 34000 Khz
[0003.556] I> tx_clk_tap_delay : 0
[0003.559] I> rx_clk_tap_delay : 16
[0003.562] I> QSPI Flash Size = 32 MB
[0003.570] I> Qspi initialized successfully
[0003.570] I> qspi flash-0 params source = boot args
[0003.574] W> No board IDs available
[0003.577] E> Failed to get board id info!
[0003.583] I> sdmmc-3 params source = safe params
[0003.590] I> Found 41 partitions in QSPI_FLASH (instance 0)
[0003.592] W> Cannot find any partition table for 00000003
[0003.596] E> Failed to publish 00000003
[0003.601] I> Found 19 partitions in SDMMC_USER (instance 3)
[0003.624] I> regulator 'vdd-hdmi-5v0' already enabled
[0003.631] I> regulator 'vdd-hdmi-5v0' already enabled
[0003.632] I> hdmi cable connected
[0003.637] W> set volts not configured for 'vdd-1v0'
[0003.642] W> set volts not configured for 'vdd-1v8-hs'
[0003.642] I> retrieved tmds range from prod_list_hdmi_soc
[0003.648] E> invalid display type
[0003.649] E> cannot find any other nvdisp nodes
[0003.665] I> edid read success
[0003.678] I> edid read success
[0003.678] I> width = 640, height = 480, frequency = 25174825
[0003.679] I> width = 1920, height = 1080, frequency = 148500000
[0003.679] I> width = 1920, height = 1080, frequency = 148351648
[0003.684] I> width = 1280, height = 720, frequency = 74175824
[0003.689] I> width = 720, height = 480, frequency = 26973026
[0003.695] I> width = 720, height = 480, frequency = 26973026
[0003.700] I> width = 640, height = 480, frequency = 25174825
[0003.706] I> width = 1920, height = 1080, frequency = 148351648
[0003.712] I> width = 720, height = 576, frequency = 26973026
[0003.717] I> width = 1280, height = 720, frequency = 74175824
[0003.723] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0003.734] I> hdmi_enable, starting HDMI initialisation
[0003.739] I> hdmi_enable, HDMI initialisation complete
[0003.748] initializing target
[0003.749] calling apps_init()
[0003.750] starting app kernel_boot_app
[0003.751] I> Kernel type = Normal
Jetson UEFI firmware (version 1.0-d7fb19b built on 2022-08-10T20:18:13-07:00)
**  WARNING: Test Key is used.  **
L4TLauncher: Attempting GRUB Boot
L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map...
��I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
��[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x4e0f0040]
[    0.000000] Linux version 5.10.104-tegra (ubuntu@ubuntu-desktop) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #2 SMP PREEMPT Tue Oct 18 12:07:52 +03 2022
[    0.000000] Machine model: NVIDIA Jetson Xavier NX for DSBOARD-NX2 (rev-1.22)
[    0.000000] efi: EFI v2.70 by EDK II
[    0.000000] efi: RTPROP=0x27757c518 SMBIOS=0xc7db0000 SMBIOS 3.0=0x258980000 MEMATTR=0x25943e018 ESRT=0x25944f418 RNG=0x27c595918 MEMRESERVE=0x25943ff18
[    0.000000] efi: seeding entropy pool
[    0.000000] esrt: Reserving ESRT space from 0x000000025944f418 to 0x000000025944f450.
[    0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb3_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x000000027fffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000a0973fff]
[    0.000000]   node   0: [mem 0x00000000a0974000-0x00000000a0975fff]
[    0.000000]   node   0: [mem 0x00000000a0977000-0x00000000aeffffff]
[    0.000000]   node   0: [mem 0x00000000af010000-0x00000000c7bfffff]
[    0.000000]   node   0: [mem 0x00000000c7d00000-0x00000000c7d9ffff]
[    0.000000]   node   0: [mem 0x00000000c7da0000-0x00000000c7dbffff]
[    0.000000]   node   0: [mem 0x00000000ca000000-0x00000000ca5fffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x00000002577affff]
[    0.000000]   node   0: [mem 0x00000002577b0000-0x00000002577dffff]
[    0.000000]   node   0: [mem 0x00000002577e0000-0x0000000257c8ffff]
[    0.000000]   node   0: [mem 0x0000000257c90000-0x00000002584fffff]
[    0.000000]   node   0: [mem 0x0000000258500000-0x0000000258526fff]
[    0.000000]   node   0: [mem 0x0000000258527000-0x00000002586eefff]
[    0.000000]   node   0: [mem 0x00000002586ef000-0x000000025896ffff]
[    0.000000]   node   0: [mem 0x0000000258970000-0x000000025898ffff]
[    0.000000]   node   0: [mem 0x0000000258990000-0x000000025920ffff]
[    0.000000]   node   0: [mem 0x0000000259210000-0x000000025939ffff]
[    0.000000]   node   0: [mem 0x00000002593a0000-0x000000025944ffff]
[    0.000000]   node   0: [mem 0x0000000259450000-0x000000025961ffff]
[    0.000000]   node   0: [mem 0x0000000259620000-0x000000025962ffff]
[    0.000000]   node   0: [mem 0x0000000259630000-0x00000002596fffff]
[    0.000000]   node   0: [mem 0x0000000259700000-0x000000025978ffff]
[    0.000000]   node   0: [mem 0x0000000259790000-0x0000000259aaffff]
[    0.000000]   node   0: [mem 0x0000000259ab0000-0x0000000259abffff]
[    0.000000]   node   0: [mem 0x0000000259ac0000-0x0000000259b2ffff]
[    0.000000]   node   0: [mem 0x0000000259b30000-0x0000000259fbffff]
[    0.000000]   node   0: [mem 0x0000000259fc0000-0x000000025a00ffff]
[    0.000000]   node   0: [mem 0x000000025a010000-0x000000025a1cffff]
[    0.000000]   node   0: [mem 0x000000025a1d0000-0x000000025a26ffff]
[    0.000000]   node   0: [mem 0x000000025a270000-0x000000025a31ffff]
[    0.000000]   node   0: [mem 0x000000025a320000-0x000000025a3bffff]
[    0.000000]   node   0: [mem 0x000000025a3c0000-0x000000025a44ffff]
[    0.000000]   node   0: [mem 0x000000025a450000-0x000000025a4effff]
[    0.000000]   node   0: [mem 0x000000025a4f0000-0x000000025adbffff]
[    0.000000]   node   0: [mem 0x000000025adc0000-0x000000025af9ffff]
[    0.000000]   node   0: [mem 0x000000025afa0000-0x000000027c54ffff]
[    0.000000]   node   0: [mem 0x000000027c550000-0x000000027c59ffff]
[    0.000000]   node   0: [mem 0x000000027c5a0000-0x000000027fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000027fffffff]
[    0.000000] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.000000] cma: Reserved 64 MiB at 0x00000000c3c00000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 32 pages/cpu s90136 r8192 d32744 u131072
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] CPU features: detected: Spectre-v2
[    0.000000] CPU features: detected: NVIDIA Carmel CNP erratum
[    0.000000] alternatives: patching kernel code
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1839268
[    0.000000] Kernel command line: root=/dev/nvme0n1p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000b3c00000-0x00000000c3c00000] (256MB)
[    0.000000] Memory: 6933112K/7473852K available (18176K kernel code, 3174K rwdata, 7216K rodata, 4032K init, 1095K bss, 475204K reserved, 65536K cma-reserved)
[    0.000000] random: get_random_u64 called from __kmem_cache_create+0x34/0x420 with crng_init=0
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Rude variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000004] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.000781] Console: colour dummy device 80x25
[    0.002161] printk: console [tty0] enabled
[    0.002244] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.002277] pid_max: default: 32768 minimum: 301
[    0.002482] LSM: Security Framework initializing
[    0.002544] Yama: becoming mindful.
[    0.002583] SELinux:  Initializing.
[    0.002737] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.002792] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.005972] rcu: Hierarchical SRCU implementation.
[    0.006237] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[    0.006953] DTS File Name: /media/ubuntu/Extra/forecr_kernel_sources/jetpack-502-bsp/forecr_xavier_kernel/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-dsboard-nx2-0000.dts
[    0.007008] DTB Build time: Oct  3 2022 15:11:39
[    0.009812] Tegra Revision: A02 SKU: 0xde CPU Process: 0 SoC Process: 0
[    0.010064] Remapping and enabling EFI services.
[    0.012668] smp: Bringing up secondary CPUs ...
[    0.041718] Detected PIPT I-cache on CPU1
[    0.041818] CPU1: Booted secondary processor 0x0000000001 [0x4e0f0040]
[    0.071283] Detected PIPT I-cache on CPU2
[    0.071375] CPU2: Booted secondary processor 0x0000000100 [0x4e0f0040]
[    0.100930] Detected PIPT I-cache on CPU3
[    0.101014] CPU3: Booted secondary processor 0x0000000101 [0x4e0f0040]
[    0.130698] Detected PIPT I-cache on CPU4
[    0.130791] CPU4: Booted secondary processor 0x0000000200 [0x4e0f0040]
[    0.160470] Detected PIPT I-cache on CPU5
[    0.160658] CPU5: Booted secondary processor 0x0000000201 [0x4e0f0040]
[    0.160973] smp: Brought up 1 node, 6 CPUs
[    0.161124] SMP: Total of 6 processors activated.
[    0.161194] CPU features: detected: Privileged Access Never
[    0.161218] CPU features: detected: LSE atomic instructions
[    0.161229] CPU features: detected: User Access Override
[    0.161241] CPU features: detected: 32-bit EL0 Support
[    0.161251] CPU features: detected: RAS Extension Support
[    0.161261] CPU features: detected: CRC32 instructions
[    0.161272] CPU features: detected: 32-bit EL1 Support
[    0.230292] CPU: All CPU(s) started at EL2
[    0.235800] devtmpfs: initialized
[    0.274585] Registered cp15_barrier emulation handler
[    0.274700] Registered setend emulation handler
[    0.274721] KASLR enabled
[    0.274998] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.275020] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.275894] pinctrl core: initialized pinctrl subsystem
[    0.276947] SMBIOS 3.0.0 present.
[    0.276978] DMI: Unknown NVIDIA Jetson Xavier NX for DSBOARD-NX2 (rev-1.22)/NVIDIA Jetson Xavier NX for DSBOARD-NX2 (rev-1.22), BIOS 1.0-d7fb19b
[    0.277647] NET: Registered protocol family 16
[    0.279313] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.279786] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.280415] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.280467] audit: initializing netlink subsys (disabled)
[    0.280712] audit: type=2000 audit(0.276:1): state=initialized audit_enabled=0 res=1
[    0.281095] thermal_sys: Registered thermal governor 'step_wise'
[    0.281101] thermal_sys: Registered thermal governor 'power_allocator'
[    0.281116] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[    0.283371] cpuidle: using governor menu
[    0.283600] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.283985] ASID allocator initialised with 32768 entries
[    0.284213] Serial: AMBA PL011 UART driver
[    0.287019] Tegra reboot handler registered.
[    0.355577] tegra19x-cbb 2300000.cbb-noc: axi2apb bridge info present
[    0.355745] tegra19x-cbb 2300000.cbb-noc: secure_irq = 15, nonsecure_irq = 14>
[    0.356024] tegra19x-cbb c600000.aon-noc: axi2apb bridge info present
[    0.356073] tegra19x-cbb c600000.aon-noc: secure_irq = 17, nonsecure_irq = 16>
[    0.356193] tegra19x-cbb d600000.bpmp-noc: axi2apb bridge info present
[    0.356239] tegra19x-cbb d600000.bpmp-noc: secure_irq = 19, nonsecure_irq = 18>
[    0.356366] tegra19x-cbb be00000.rce-noc: axi2apb bridge info present
[    0.356427] tegra19x-cbb be00000.rce-noc: secure_irq = 21, nonsecure_irq = 20>
[    0.356563] tegra19x-cbb b600000.sce-noc: axi2apb bridge info present
[    0.356609] tegra19x-cbb b600000.sce-noc: secure_irq = 23, nonsecure_irq = 22>
[    0.358644] mc: mapped MMIO address: 0xffff800010580000 -> 0x2c10000
[    0.358681] mc: mapped MMIO address: 0xffff8000105a0000 -> 0x2c20000
[    0.358711] mc: mapped MMIO address: 0xffff8000105c0000 -> 0x2c30000
[    0.358753] mc: mapped MMIO address: 0xffff8000105e0000 -> 0x2c40000
[    0.358788] mc: mapped MMIO address: 0xffff800010600000 -> 0x2c50000
[    0.358813] mc: mapped MMIO address: 0xffff800010620000 -> 0x2b80000
[    0.358839] mc: mapped MMIO address: 0xffff800010640000 -> 0x2b90000
[    0.358863] mc: mapped MMIO address: 0xffff800010660000 -> 0x2ba0000
[    0.358891] mc: mapped MMIO address: 0xffff800010680000 -> 0x2bb0000
[    0.358916] mc: mapped MMIO address: 0xffff8000106a0000 -> 0x1700000
[    0.358940] mc: mapped MMIO address: 0xffff8000106c0000 -> 0x1710000
[    0.358996] mc: mapped MMIO address: 0xffff8000106e0000 -> 0x1720000
[    0.359039] mc: mapped MMIO address: 0xffff800010700000 -> 0x1730000
[    0.359066] mc: mapped MMIO address: 0xffff800010720000 -> 0x1740000
[    0.359110] mc: mapped MMIO address: 0xffff800010740000 -> 0x1750000
[    0.359137] mc: mapped MMIO address: 0xffff800010760000 -> 0x1760000
[    0.359162] mc: mapped MMIO address: 0xffff800010780000 -> 0x1770000
[    0.359265] mc-err: mcerr ops are set to t19x
[    0.371419] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.371439] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.371451] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.371462] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.377246] ACPI: Interpreter disabled.
[    0.378426] vdd-epb-1v0: supplied by vdd-3v3-cvb
[    0.379597] iommu: Default domain type: Translated
[    0.379663] eventlib_kernel: keventlib is initialized, test id: 0
[    0.380003] SCSI subsystem initialized
[    0.380153] usbcore: registered new interface driver usbfs
[    0.380192] usbcore: registered new interface driver hub
[    0.380225] usbcore: registered new device driver usb
[    0.380586] mc: Linux media interface: v0.10
[    0.380619] videodev: Linux video capture interface: v2.00
[    0.380882] pps_core: LinuxPPS API ver. 1 registered
[    0.380892] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.380913] PTP clock support registered
[    0.381099] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[    0.381385] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[    0.381472] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[    0.382035] Registered efivars operations
[    0.387594] FPGA manager framework
[    0.387668] Advanced Linux Sound Architecture Driver Initialized.
[    0.388233] Bluetooth: Core ver 2.22
[    0.388268] NET: Registered protocol family 31
[    0.388280] Bluetooth: HCI device and connection manager initialized
[    0.388296] Bluetooth: HCI socket layer initialized
[    0.388310] Bluetooth: L2CAP socket layer initialized
[    0.388330] Bluetooth: SCO socket layer initialized
[    0.389819] camchar: rtcpu character device driver loaded
[    0.390496] clocksource: Switched to clocksource arch_sys_counter
[    0.671202] VFS: Disk quotas dquot_6.6.0
[    0.671298] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.671629] pnp: PnP ACPI: disabled
[    0.682985] la/ptsa driver initialized.
[    0.683100] NET: Registered protocol family 2
[    0.683274] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.688588] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    0.688710] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.688956] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.689389] TCP: Hash tables configured (established 65536 bind 65536)
[    0.689495] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.689610] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.689790] NET: Registered protocol family 1
[    0.690801] RPC: Registered named UNIX socket transport module.
[    0.690835] RPC: Registered udp transport module.
[    0.690852] RPC: Registered tcp transport module.
[    0.690867] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.690891] PCI: CLS 0 bytes, default 64
[    0.691154] Trying to unpack rootfs image as initramfs...
[    0.957966] Initramfs unpacking failed: invalid magic at start of compressed archive
[    0.960757] Freeing initrd memory: 8196K
[    0.965647] hw perfevents: failed to parse interrupt-affinity[6] for arm-pmu
[    0.965682] hw perfevents: /arm-pmu: failed to register PMU devices!
[    0.965729] armv8-pmu: probe of arm-pmu failed with error -22
[    0.966133] kvm [1]: IPA Size Limit: 40 bits
[    0.966777] kvm [1]: vgic interrupt IRQ9
[    0.967426] kvm [1]: VHE mode initialized successfully
[    0.968993] Initialise system trusted keyrings
[    0.969299] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[    0.976107] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.977085] NFS: Registering the id_resolver key type
[    0.977121] Key type id_resolver registered
[    0.977137] Key type id_legacy registered
[    0.977238] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.977276] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.977322] ntfs: driver 2.1.32 [Flags: R/W].
[    0.988638] NET: Registered protocol family 38
[    0.988662] Key type asymmetric registered
[    0.988676] Asymmetric key parser 'x509' registered
[    0.988733] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[    0.989026] io scheduler mq-deadline registered
[    0.989045] io scheduler kyber registered
[    0.995610] tegra186-dpaux-pinctrl 155f0000.dpaux: can not get clock
[    0.998997] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    0.999075] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[    0.999147] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    0.999216] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[    0.999283] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[    1.005244] scrncapt: init (heads:4 wins:6 planes:4)
[    1.005595] tegradccommon 15200000.display-hub: Nvhost Channel map failed
[    1.006579] EINJ: ACPI disabled.
[    1.010138] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[    1.010162] tegra-pmc: ### PMC reset source: MAINSWRST
[    1.010176] tegra-pmc: ### PMC reset level: L1
[    1.010189] tegra-pmc: ### PMC reset status reg: 0x2d
[    1.010241] tegra-pmc: PMC Prod config success
[    1.016136] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.043812] random: fast init done
[    1.044859] printk: console [ttyTCU0] enabled
[    2.592694] arm-smmu 10000000.iommu: probing hardware configuration...
[    2.596749] arm-smmu 10000000.iommu: SMMUv2 with:
[    2.601560] arm-smmu 10000000.iommu: 	stage 1 translation
[    2.606930] arm-smmu 10000000.iommu: 	stage 2 translation
[    2.612550] arm-smmu 10000000.iommu: 	nested translation
[    2.617638] arm-smmu 10000000.iommu: 	stream matching with 128 register groups
[    2.624787] arm-smmu 10000000.iommu: 	64 context banks (0 stage-2 only)
[    2.636660] arm-smmu 10000000.iommu: 	Supported page sizes: 0x00001000
[    2.638144] arm-smmu 10000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    2.644475] arm-smmu 10000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    2.652540] arm-smmu 12000000.iommu: probing hardware configuration...
[    2.657771] arm-smmu 12000000.iommu: SMMUv2 with:
[    2.662233] arm-smmu 12000000.iommu: 	stage 1 translation
[    2.668000] arm-smmu 12000000.iommu: 	stage 2 translation
[    2.673425] arm-smmu 12000000.iommu: 	nested translation
[    2.678881] arm-smmu 12000000.iommu: 	stream matching with 128 register groups
[    2.685776] arm-smmu 12000000.iommu: 	64 context banks (0 stage-2 only)
[    2.697250] arm-smmu 12000000.iommu: 	Supported page sizes: 0x00001000
[    2.699153] arm-smmu 12000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    2.705456] arm-smmu 12000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    2.713279] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[    2.723228] tegra_profiler: version: 1.147, samples/io: 49/28
[    2.726128] tegra_profiler: auth: init
[    2.730098] THERMAL EST: found 3 subdevs
[    2.733820] THERMAL EST num_resources: 0
[    2.737396] [THERMAL EST subdev 0]
[    2.740976] [THERMAL EST subdev 1]
[    2.744388] [THERMAL EST subdev 2]
[    2.747641] THERMAL EST: Found 2 profiles, default profile is quiet
[    2.754117] THERMAL EST: thz register success.
[    2.758352] THERMAL EST: end of probe, return err: 0
[    2.763388] nvsciipc: loaded module
[    2.770787] tun: Universal TUN/TAP device driver, 1.6
[    2.773147] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    2.779162] hns3: Copyright (c) 2017 Huawei Corporation.
[    2.784712] e1000e: Intel(R) PRO/1000 Network Driver
[    2.789631] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    2.795712] igb: Intel(R) Gigabit Ethernet Network Driver
[    2.801007] igb: Copyright (c) 2007-2014 Intel Corporation.
[    2.807405] PPP generic driver version 2.4.2
[    2.811695] PPP BSD Compression module registered
[    2.816256] PPP Deflate Compression module registered
[    2.821517] PPP MPPE Compression module registered
[    2.826269] usbcore: registered new interface driver r8152
[    2.831720] hso: drivers/net/usb/hso.c: Option Wireless
[    2.837122] usbcore: registered new interface driver hso
[    2.842197] usbcore: registered new interface driver asix
[    2.847847] usbcore: registered new interface driver ax88179_178a
[    2.853965] usbcore: registered new interface driver cdc_ether
[    2.859773] usbcore: registered new interface driver net1080
[    2.865437] usbcore: registered new interface driver cdc_subset
[    2.871650] usbcore: registered new interface driver zaurus
[    2.877003] usbcore: registered new interface driver sierra_net
[    2.883110] usbcore: registered new interface driver cdc_ncm
[    2.888708] usbcore: registered new interface driver qmi_wwan
[    2.894307] usbcore: registered new interface driver cdc_mbim
[    2.899820] usbcore: registered new interface driver aqc111
[    2.905852] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.911734] ohci-pci: OHCI PCI platform driver
[    2.916126] ohci-platform: OHCI generic platform driver
[    2.922024] tegra-xusb 3610000.xhci: Adding to iommu group 0
[    2.928181] usbcore: registered new interface driver cdc_wdm
[    2.933005] usbcore: registered new interface driver uas
[    2.938195] usbcore: registered new interface driver usb-storage
[    2.944067] usbcore: registered new interface driver option
[    2.949428] usbserial: USB Serial support registered for GSM modem (1-port)
[    2.956687] usbcore: registered new interface driver qcserial
[    2.962204] usbserial: USB Serial support registered for Qualcomm USB modem
[    2.969587] usbcore: registered new interface driver sierra
[    2.975184] usbserial: USB Serial support registered for Sierra USB modem
[    2.982255] tegra-xudc 3550000.xudc: Adding to iommu group 1
[    2.988426] mousedev: PS/2 mouse device common for all mice
[    2.993393] usbcore: registered new interface driver xpad
[    3.001304] tegra_rtc c2a0000.rtc: registered as rtc1
[    3.004106] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:26 UTC (26)
[    3.012036] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    3.018717] i2c /dev entries driver
[    3.021795] tegra-i2c 3160000.i2c: Adding to iommu group 2
[    3.027637] tegra-i2c c240000.i2c: Adding to iommu group 2
[    3.033000] tegra-i2c 3180000.i2c: Adding to iommu group 2
[    3.038219] tegra-i2c 3190000.i2c: Adding to iommu group 2
[    3.043497] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[    3.049288] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[    3.054745] tegra-i2c c250000.i2c: Adding to iommu group 2
[    3.068204] device-mapper: uevent: version 1.0.3
[    3.068677] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[    3.075039] cpuidle: Initializing cpuidle driver
[    3.079213] sdhci: Secure Digital Host Controller Interface driver
[    3.083818] sdhci: Copyright(c) Pierre Ossman
[    3.087910] Synopsys Designware Multimedia Card Interface Driver
[    3.093850] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.100065] sdhci-tegra 3460000.sdhci: Adding to iommu group 3
[    3.102831] sdhci-tegra 3440000.sdhci: Adding to iommu group 4
[    3.111753] SMCCC: SOC_ID: ID = jep106:036b:0019 Revision = 0x00000102
[    3.119199] tegra-bpmp bpmp: firmware: 128431eec76692047e1ac1ebc0392266
[    3.144059] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[    3.153996] vdd-1v0: supplied by regulator-dummy
[    3.159694] vdd-1v8-hs: supplied by regulator-dummy
[    3.164625] vdd-1v8-ls: supplied by regulator-dummy
[    3.169632] vdd-1v8-ao: supplied by regulator-dummy
[    3.173650] vddio-ddr-1v1: supplied by regulator-dummy
[    3.178219] vdd-rtc: supplied by regulator-dummy
[    3.180072] spmic-ldo1: supplied by regulator-dummy
[    3.181442] vdd-ao-3v3: supplied by regulator-dummy
[    3.187801] vddio-emmc-3v3: supplied by regulator-dummy
[    3.194162] spmic-ldo4: supplied by regulator-dummy
[    3.195505] vdd-usb-3v3: supplied by regulator-dummy
[    3.201764] vddio-sdmmc1-3v3: supplied by regulator-dummy
[    3.208094] vdd-csi-1v2: supplied by vdd-1v8-ls
[    3.213698] spmic-ldo8: supplied by vdd-1v8-ls
[    3.215239] gpio-510 (gpio_default): hogged as output/high
[    3.216582] gpio-511 (gpio_default): hogged as output/high
[    3.219461] gpiochip0: registered GPIOs 504 to 511 on max77620-gpio
[    3.355415] max77686-rtc max77620-rtc: registered as rtc0
[    3.356810] max77620-power max20024-power: Event recorder REG_NVERC : 0x0
[    3.357180] max77620 4-003c: max77620 probe successful
��rm_rail_debugfs_init: /rm/vdd_cpu: failed
debugfs initialized
��[    4.166870] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[    4.168140] hid: raw HID events driver (C) Jiri Kosina
[    4.169060] usbcore: registered new interface driver usbhid
[    4.169224] usbhid: USB HID core driver
[    4.171376] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 5
[    4.172538] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
��[    27.312013] Camera-FW on t194-rce-safe started
TCU early console enabled.
[    27.386487] Camera-FW on t194-rce-safe ready SHA1=d48f1e27 (crt 0.781 ms, total boot 75.284 ms)
��[    4.257168] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[    4.257918] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[    4.259821] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[    4.260978] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[    4.263262] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[    4.263949] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[    4.264570] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[    4.266153] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (50)
[    4.266884] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[    4.269331] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=d48f1e279e6679b09020947e8de088eabfeaa475
[    4.273082] tegra_aon c1a0000.aon: Adding to iommu group 6
[    4.279620] tegra_aon c1a0000.aon: tegra aon driver probe OK
[    4.284959] tegra186-aondbg aondbg: aondbg driver probe() OK
[    4.291520] denver_knobs_init:MTS_VERSION:55637613
[    4.304737] t19x_cache tegra-cache: probed
[    4.307592] Clocks initialized successfully
[    4.309335] optee: probing for conduit method.
[    4.310186] optee: revision 3.16 (65cc2218)
[    4.311487] optee: dynamic shared memory is enabled
[    4.316159] optee: initialized driver
[    4.322370] nvpmodel: initialized successfully
[    4.323746] tegra_hv: get_hvd: not initialized yet
[    4.328255] user_ivc_mempool: hypervisor not present
[    4.334169] usbcore: registered new interface driver snd-usb-audio
[    4.341067] u32 classifier
[    4.342153]     input device check on
[    4.345859]     Actions configured
[    4.349242] Initializing XFRM netlink socket
[    4.354211] NET: Registered protocol family 10
[    4.361734] Segment Routing with IPv6
[    4.362017] NET: Registered protocol family 17
[    4.366162] NET: Registered protocol family 15
[    4.371006] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    4.383807] Bluetooth: RFCOMM socket layer initialized
[    4.388496] Bluetooth: RFCOMM ver 1.11
[    4.392619] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    4.398209] Bluetooth: HIDP socket layer initialized
[    4.404677] 9pnet: Installing 9P2000 support
[    4.407901] Key type dns_resolver registered
[    4.413084] registered taskstats version 1
[    4.416354] Loading compiled-in X.509 certificates
[    4.430169] Loaded X.509 cert 'Build time autogenerated kernel key: c3d66804619b817e74b28a23dda402b0986c24a3'
[    4.432437] tegra194-pcie 14160000.pcie: Adding to iommu group 7
[    4.443298] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[    4.444272] tegra194-pcie 14160000.pcie:       IO 0x0036100000..0x00361fffff -> 0x0036100000
[    4.452626] tegra194-pcie 14160000.pcie:      MEM 0x1400000000..0x173fffffff -> 0x1400000000
[    4.461211] tegra194-pcie 14160000.pcie:      MEM 0x1740000000..0x17ffffffff -> 0x0040000000
[    5.579568] tegra194-pcie 14160000.pcie: Phy link never came up
[    5.580300] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[    5.580549] pci_bus 0004:00: root bus resource [bus 00-ff]
[    5.580688] pci_bus 0004:00: root bus resource [io  0x0000-0xfffff] (bus address [0x36100000-0x361fffff])
[    5.580992] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[    5.581247] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[    5.581814] pci 0004:00:00.0: [10de:1ad1] type 01 class 0x060400
[    5.582456] pci 0004:00:00.0: PME# supported from D0 D3hot D3cold
[    5.604911] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[    5.605276] pci 0004:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    5.607709] pcieport 0004:00:00.0: Adding to iommu group 7
[    5.609166] pcieport 0004:00:00.0: PME: Signaling with IRQ 24
[    5.611156] pcieport 0004:00:00.0: AER: enabled with IRQ 24
[    5.613210] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[    5.614220] pci 0004:00:00.0: Removing from iommu group 7
[    5.614653] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[    5.619110] tegra194-pcie 141a0000.pcie: Adding to iommu group 8
[    5.625550] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[    5.625904] tegra194-pcie 141a0000.pcie:       IO 0x003a100000..0x003a1fffff -> 0x003a100000
[    5.626358] tegra194-pcie 141a0000.pcie:      MEM 0x1c00000000..0x1f3fffffff -> 0x1c00000000
[    5.626831] tegra194-pcie 141a0000.pcie:      MEM 0x1f40000000..0x1fffffffff -> 0x0040000000
[    5.738585] tegra194-pcie 141a0000.pcie: Link up
[    5.741472] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[    5.741688] pci_bus 0005:00: root bus resource [bus 00-ff]
[    5.741854] pci_bus 0005:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x3a100000-0x3a1fffff])
[    5.742204] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[    5.742550] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[    5.743029] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[    5.743550] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[    5.755154] pci 0005:01:00.0: [15b7:501a] type 00 class 0x010802
[    5.755719] pci 0005:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[    5.756351] pci 0005:01:00.0: reg 0x20: [mem 0x00000000-0x000000ff 64bit]
[    5.768278] pci 0005:00:00.0: BAR 14: assigned [mem 0x1f40000000-0x1f400fffff]
[    5.768587] pci 0005:01:00.0: BAR 0: assigned [mem 0x1f40000000-0x1f40003fff 64bit]
[    5.768962] pci 0005:01:00.0: BAR 4: assigned [mem 0x1f40004000-0x1f400040ff 64bit]
[    5.769391] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[    5.769588] pci 0005:00:00.0:   bridge window [mem 0x1f40000000-0x1f400fffff]
[    5.769861] pci 0005:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    5.770341] pci 0005:01:00.0: Max Payload Size set to  256/ 512 (was  128), Max Read Rq  512
[    5.778388] pcieport 0005:00:00.0: Adding to iommu group 8
[    5.783443] pcieport 0005:00:00.0: PME: Signaling with IRQ 26
[    5.789344] pcieport 0005:00:00.0: AER: enabled with IRQ 26
[    5.795549] nvme 0005:01:00.0: Adding to iommu group 8
[    5.801128] nvme nvme0: pci function 0005:01:00.0
[    5.803749] nvme 0005:01:00.0: enabling device (0000 -> 0002)
[    5.841362] host1x 13e10000.host1x: Adding to iommu group 9
[    5.845485] nvme nvme0: allocated 32 MiB host memory buffer.
[    5.853613] nvme nvme0: 6/0/0 default/read/poll queues
[    5.863747]  nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9
[    5.872742] host1x 13e10000.host1x: initialized
[    5.875228] iommu_context_dev 13e10000.host1x:ctx0: Adding to iommu group 10
[    5.876159] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[    5.877012] iommu_context_dev 13e10000.host1x:ctx1: Adding to iommu group 11
[    5.877669] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[    5.878696] iommu_context_dev 13e10000.host1x:ctx2: Adding to iommu group 12
[    5.879529] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[    5.885704] iommu_context_dev 13e10000.host1x:ctx3: Adding to iommu group 13
[    5.892920] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[    5.902592] iommu_context_dev 13e10000.host1x:ctx4: Adding to iommu group 14
[    5.909682] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[    5.919630] iommu_context_dev 13e10000.host1x:ctx5: Adding to iommu group 15
[    5.926220] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61, iommu=smmu.0x0000000012000000)
[    5.936432] iommu_context_dev 13e10000.host1x:ctx6: Adding to iommu group 16
[    5.943529] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62, iommu=smmu.0x0000000012000000)
[    5.953232] iommu_context_dev 13e10000.host1x:ctx7: Adding to iommu group 17
[    5.960507] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63, iommu=smmu.0x0000000012000000)
[    5.970211] falcon 15340000.vic: Adding to iommu group 18
[    5.986380] falcon 15340000.vic: initialized
[    5.987741] falcon 15380000.nvjpg: Adding to iommu group 18
[    5.994133] falcon 15380000.nvjpg: initialized
[    5.994997] falcon 154c0000.nvenc: Adding to iommu group 18
[    6.004185] falcon 154c0000.nvenc: initialized
[    6.005100] falcon 15a80000.nvenc1: Adding to iommu group 18
[    6.015034] falcon 15a80000.nvenc1: initialized
[    6.016073] nvdec 15480000.nvdec: Adding to iommu group 18
[    6.028559] nvdec 15480000.nvdec: initialized
[    6.029648] nvdec 15140000.nvdec1: Adding to iommu group 18
[    6.042036] nvdec 15140000.nvdec1: initialized
[    6.042967] tsec 15500000.tsec: Adding to iommu group 19
[    6.049663] tsec 15500000.tsec: initialized
[    6.050299] tsec 15100000.tsecb: Adding to iommu group 20
[    6.056182] tsec 15100000.tsecb: initialized
[    6.060538] gic 2a41000.agic-controller: GIC IRQ controller registered
[    6.088871] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[    6.105921] gpio-374 (wifi-enable): hogged as output/high
[    6.106225] gpio-431 (camera-control-output-low): hogged as output/low
[    6.106827] gpio-432 (camera-control-output-low): hogged as output/low
[    6.109390] gpiochip1: registered GPIOs 335 to 503 on tegra194-gpio
[    6.112271] gpiochip2: registered GPIOs 305 to 334 on tegra194-gpio-aon
[    6.112960] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    6.115073] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[    6.116606] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    6.118114] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[    6.119564] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[    6.126962] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[    6.134028] tegra194-isp5 13e10000.host1x:isp@14800000: Adding to iommu group 21
[    6.146012] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[    6.150756] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: initialized
[    6.156643] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e10000.host1x:nvcsi@15a00000- bound
[    6.165489] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e10000.host1x:nvcsi@15a00000- bound
[    6.174657] tegra194-vi5 15c10000.vi: Adding to iommu group 22
[    6.182199] scare-pigeon 13e10000.host1x:vi-thi@15f00000: context isolation disabled due to no IOMMU
[    6.189470] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[    6.195850] scare-pigeon 13e10000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[    6.205324] scare-pigeon 13e10000.host1x:isp-thi@14b00000: initialized
[    6.211498] pva 16000000.pva0: Adding to iommu group 23
[    6.240908] pva 16000000.pva0: initialized
[    6.246022] pva 16800000.pva1: Adding to iommu group 24
[    6.258579] pva 16800000.pva1: initialized
[    6.263287] nvdla 15880000.nvdla0: Adding to iommu group 25
[    6.276919] nvdla 15880000.nvdla0: initialized
[    6.278413] nvdla 158c0000.nvdla1: Adding to iommu group 26
[    6.289124] nvdla 158c0000.nvdla1: initialized
[    6.294141] tegradccommon 15200000.display-hub: host1x channel mapped
[    6.294742] tegradccommon 15200000.display-hub: dc_common syncpt # 1 allocated
[    6.295089] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=64
[    6.295181] tegradccommon 15200000.display-hub: dma mapping done
[    6.295494] tegra_cec 3960000.tegra_cec: Unpowergated DISP
[    6.295886] tegradc 15200000.display: Adding to iommu group 27
[    6.295980] tegradc 15210000.display: Adding to iommu group 27
[    6.296604] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[    6.301564] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[    6.305331] tegradc 15200000.display: disp0 connected to head0->sor1
[    6.307416] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[    6.314012] generic_infoframe_type: 0x87
[    6.319223] tegra_cec 3960000.tegra_cec: probed
[    6.320225] tegra-gpcdma 2600000.dma: Adding to iommu group 2
[    6.323015] tegradc 15200000.display: DT parsed successfully
[    6.330425] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[    6.333595] tegradc 15200000.display: Display dc.(____ptrval____) registered with id=0
[    6.339628] kfuse 3830000.kfuse: initialized
[    6.350739] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[    6.354996] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[    6.358428] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 933000000 Hz
[    6.366380] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[    6.367155] serial-tegra 3100000.serial: Adding to iommu group 2
[    6.373015] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[    6.393887] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 31, base_baud = 0) is a TEGRA_UART
[    6.402982] tegradc 15200000.display: vblank syncpt # 8 for dc 0
[    6.412488] serial-tegra 3110000.serial: Adding to iommu group 2
[    6.416831] tegradc 15200000.display: vpulse3 syncpt # 9 for dc 0
[    6.429191] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 32, base_baud = 0) is a TEGRA_UART
[    6.431002] tegradc 15200000.display: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[    6.439349] serial-tegra 3140000.serial: Adding to iommu group 2
[    6.452877] tegradc 15200000.display: hdmi: can't get adpater for ddc bus 3
[    6.461615] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 33, base_baud = 0) is a TEGRA_UART
[    6.462685] tegradc 15200000.display: out->type:1 out_ops->init err = -517
[    6.481681] tegradc 15210000.display: disp0 connected to head1->sor
[    6.483825] tegradc 15210000.display: parse_dp_settings: No dp-lt-settings node
[    6.485609] tegra-xusb 3610000.xhci: Firmware timestamp: 2022-03-16 11:07:43 UTC, Version: 60.13 release
[    6.490988] tegradc 15210000.display: DT parsed successfully
[    6.500357] tegra-xusb 3610000.xhci: xHCI Host Controller
[    6.505965] tegradc 15210000.display: dc.1 probe not in device tree order, deferring
[    6.511270] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[    6.527584] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x0000000000050810
[    6.536133] tegra-xusb 3610000.xhci: irq 190, io mem 0x03610000
[    6.543086] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    6.550061] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.557635] usb usb1: Product: xHCI Host Controller
[    6.562362] usb usb1: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[    6.568526] usb usb1: SerialNumber: 3610000.xhci
[    6.574723] hub 1-0:1.0: USB hub found
[    6.577413] hub 1-0:1.0: 4 ports detected
[    6.582405] tegra-xusb 3610000.xhci: xHCI Host Controller
[    6.586836] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[    6.594371] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[    6.602439] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    6.610157] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.617057] usb usb2: Product: xHCI Host Controller
[    6.622039] usb usb2: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[    6.628267] usb usb2: SerialNumber: 3610000.xhci
[    6.634160] hub 2-0:1.0: USB hub found
[    6.636766] hub 2-0:1.0: 4 ports detected
[    6.687550] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[    6.693244] gpiochip3: registered GPIOs 297 to 304 on pcf8574a
[    6.693482] pcf857x 8-0038: probed
[    6.696315] i2c i2c-2: Added multiplexed i2c bus 9
[    6.697565] i2c i2c-2: Added multiplexed i2c bus 10
[    6.697785] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[    6.711273] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1903000 KHz, changing to: 1907200 KHz
[    6.712386] tegra194-cpufreq ccplex: probed with BWMGR
[    6.713785] sdhci-tegra 3460000.sdhci: BWMGR client registration for eMC Successful
[    6.714366] irq: IRQ271: trimming hierarchy from :pmc@c360000
[    6.714874] usb-conn-gpio 3520000.xusb_padctl:ports:usb2-0:connector: repeated role: 0
[    6.714891] sdhci-tegra 3440000.sdhci: BWMGR client registration for eMC Successful
[    6.718470] tegra194-isp5 13e10000.host1x:isp@14800000: initialized
[    6.727268] mmc0: CQHCI version 5.10
[    6.731071] tegra194-vi5 15c10000.vi: initialized
[    6.732282] tegradc 15200000.display: disp0 connected to head0->sor1
[    6.732721] nvethernet 2490000.ethernet: Adding to iommu group 28
[    6.738025] generic_infoframe_type: 0x87
[    6.744526] nvethernet 2490000.ethernet: failed to read skip mac reset flag, default 0
[    6.748220] tegradc 15200000.display: DT parsed successfully
[    6.756026] nvethernet 2490000.ethernet: failed to read MDIO address
[    6.761522] tegradc 15200000.display: Display dc.(____ptrval____) registered with id=0
[    6.767946] nvethernet 2490000.ethernet: setting to default DMA bit mask
[    6.777827] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[    6.782761] nvethernet 2490000.ethernet: set default TXQ to TC mapping
[    6.782766] nvethernet 2490000.ethernet: Setting default PTP RX queue
[    6.789621] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[    6.790549] nvethernet 2490000.ethernet: failed to get eqos_rx_m clk
[    6.790556] nvethernet 2490000.ethernet: failed to get eqos_rx_input clk
[    6.790562] nvethernet 2490000.ethernet: failed to get eqos_tx_divider clk
[    6.791074] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit
[    6.791156] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 933000000 Hz
[    6.791160] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[    6.791751] tegradc 15200000.display: vblank syncpt # 11 for dc 0
[    6.792100] nvethernet 2490000.ethernet: Ethernet MAC address: 48:b0:2d:03:51:96
[    6.792163] nvethernet 2490000.ethernet: Macsec not supported
[    6.793416] nvethernet 2490000.ethernet: eth0 (HW ver: 50) created with 1 DMA channels
[    6.794376] irq: IRQ273: trimming hierarchy from :pmc@c360000
[    6.794549] irq: IRQ274: trimming hierarchy from :interrupt-controller@3881000
[    6.794656] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    6.795539] tegra-se-nvhost 15810000.se: Adding to iommu group 29
[    6.797122] tegra-se-nvhost 15810000.se: initialized
[    6.802882] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[    6.803774] tegradc 15200000.display: vpulse3 syncpt # 13 for dc 0
[    6.812093] tegra-se-nvhost 15820000.se: Adding to iommu group 30
[    6.818481] tegradc 15200000.display: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[    6.825564] tegra-se-nvhost 15820000.se: initialized
[    6.833120] tegradc 15200000.display: hdmi: invalid prod list prod_list_hdmi_board
[    6.841986] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[    6.846538] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[    6.847608] tegradc 15200000.display: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[    6.849558] tegradc 15200000.display: probed
[    6.855985] tegra-se-nvhost 15830000.se: Adding to iommu group 31
[    6.932720] mmc0: Command Queue Engine enabled
[    6.932725] mmc0: periodic cache flush enabled
[    6.932737] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[    6.944608] tegra-se-nvhost 15830000.se: initialized
[    6.949423] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[    6.957310] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[    6.962539] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB, chardev (509:0)
[    6.969320] tegra-se-nvhost 15840000.se: Adding to iommu group 32
[    6.987226]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19
[    6.999140] usb 1-2: New USB device found, idVendor=04b4, idProduct=6506, bcdDevice=50.00
[    7.003384] tegra-se-nvhost 15840000.se: initialized
[    7.007212] usb 1-2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    7.008543] hub 1-2:1.0: USB hub found
[    7.013837] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[    7.018243] hub 1-2:1.0: 2 ports detected
[    7.027067] tegra_actmon d230000.actmon: in actmon_register()...
[    7.080301] tegra_actmon d230000.actmon: bwmgr_disable = 0
[    7.080445] Console: switching to colour frame buffer device 240x67
[    7.080759] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[    7.085707] tegradc 15200000.display: fb registered
[    7.092398] hvc_sysfs: hypervisor is not present
[    7.099766] irq: IRQ275: trimming hierarchy from :pmc@c360000
[    7.126854] usb 2-3: new SuperSpeed Gen 1 USB device number 2 using tegra-xusb
[    7.134705] ALSA device list:
[    7.134803]   No soundcards found.
[    7.135956] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[    7.136319] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[    7.147103] usb 2-3: New USB device found, idVendor=04b4, idProduct=6504, bcdDevice=50.00
[    7.148671] usb 2-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    7.158573] hub 2-3:1.0: USB hub found
[    7.160046] hub 2-3:1.0: 2 ports detected
[    7.197438] tegradc 15200000.display: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_111m_223m
[    7.198734] tegradc 15200000.display: hdmi: get RGB quant from REG programmed by BL.
[    7.198945] tegradc 15200000.display: hdmi: get YCC quant from REG programmed by BL.
[    7.199908] extcon-disp-state external-connection:disp-state: cable 47 state 1
[    7.200112] Extcon AUX1(HDMI) enable
[    7.200397] tegradc 15210000.display: disp1 connected to head1->sor
[    7.205831] tegradc 15210000.display: parse_dp_settings: No dp-lt-settings node
[    7.213075] tegradc 15210000.display: DT parsed successfully
[    7.218906] tegradc 15210000.display: Display dc.(____ptrval____) registered with id=1
[    7.226775] tegradc 15210000.display: vblank syncpt # 17 for dc 1
[    7.232772] tegradc 15210000.display: vpulse3 syncpt # 18 for dc 1
[    7.245485] tegradc 15210000.display: probed
[    7.245820] tegradc 15210000.display: fb registered
[    7.251464] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[    7.255611] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[    7.257219] Freeing unused kernel memory: 4032K
[    7.263394] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[    7.268560] random: crng init done
[    7.273449] Run /init as init process
[    7.280656] tegradc 15210000.display: blank - powerdown
[    7.285576] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[    7.285579] Extcon DP: HPD disabled
[    7.285582] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[    7.285589] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[    7.285593] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[    7.318601] usb 1-2.2: new high-speed USB device number 3 using tegra-xusb
[    7.326567] tegra_cec 3960000.tegra_cec: Can't find physical address.
[    7.330323] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
��WARNING: clock_disable: clk_power_ungate on gated domain 27 for gpcclk
��[    7.340234] tegradc 15200000.display: blank - powerdown
[    7.366377] Root device found: nvme0n1p1
[    7.368398] Found dev node: /dev/nvme0n1p1
[    7.381117] extcon-disp-state external-connection:disp-state: cable 47 state 0
[    7.381123] Extcon AUX1(HDMI) disable
[    7.404008] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null)
[    7.404407] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[    7.405233] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[    7.407974] Rootfs mounted over nvme0n1p1
[    7.418737] tegradc 15200000.display: unblank
[    7.419762] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[    7.419951] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[    7.425719] tegradc 15200000.display: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[    7.427610] tegradc 15200000.display: hdmi: get YCC quant from EDID.
[    7.431615] extcon-disp-state external-connection:disp-state: cable 47 state 1
[    7.431620] Extcon AUX1(HDMI) enable
[    7.433817] Switching from initrd to actual rootfs
[    7.437269] usb 1-2.2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 6.63
[    7.437277] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    7.437281] usb 1-2.2: Product: USB2.1 Hub
[    7.437284] usb 1-2.2: Manufacturer: GenesysLogic
[    7.438821] hub 1-2.2:1.0: USB hub found
[    7.439123] hub 1-2.2:1.0: 4 ports detected
[    7.444403] tegradc 15200000.display: sync windows ret = 247
[    7.489293] extcon-disp-state external-connection:disp-state: cable 53 state 1
[    7.496567] Extcon HDMI: HPD enabled
[    7.500457] tegradc 15200000.display: hdmi: plugged
[    7.522879] usb 2-3.2: new SuperSpeed Gen 1 USB device number 3 using tegra-xusb
[    7.550516] usb 2-3.2: New USB device found, idVendor=05e3, idProduct=0626, bcdDevice= 6.63
[    7.551942] usb 2-3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    7.553292] usb 2-3.2: Product: USB3.1 Hub
[    7.554593] usb 2-3.2: Manufacturer: GenesysLogic
[    7.560581] hub 2-3.2:1.0: USB hub found
[    7.562796] hub 2-3.2:1.0: 4 ports detected
[    7.575580] systemd[1]: System time before build time, advancing clock.
[    7.593253] x_tables: module verification failed: signature and/or required key missing - tainting kernel
[    7.625891] systemd[1]: systemd 245.4-4ubuntu3.18 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[    7.630820] systemd[1]: Detected architecture arm64.
[    7.674904] systemd[1]: Set hostname to <tegra-ubuntu>.
[    7.754544] usb 1-2.2.2: new high-speed USB device number 4 using tegra-xusb
[    7.897507] usb 1-2.2.2: New USB device found, idVendor=0bda, idProduct=5409, bcdDevice= 1.41
[    7.899096] usb 1-2.2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    7.900520] usb 1-2.2.2: Product: 4-Port USB 2.0 Hub
[    7.901861] usb 1-2.2.2: Manufacturer: Generic
[    7.905220] hub 1-2.2.2:1.0: USB hub found
[    7.907803] hub 1-2.2.2:1.0: 4 ports detected
[    8.113754] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    8.115467] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    8.121766] systemd[1]: Created slice system-modprobe.slice.
[    8.126815] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    8.131443] systemd[1]: Created slice User and Session Slice.
[    8.134787] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    8.138822] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    8.142016] systemd[1]: Reached target User and Group Name Lookups.
[    8.145075] systemd[1]: Reached target Slices.
[    8.148033] systemd[1]: Reached target Swap.
[    8.151778] systemd[1]: Listening on RPCbind Server Activation Socket.
[    8.155287] systemd[1]: Listening on Syslog Socket.
[    8.158677] systemd[1]: Listening on fsck to fsckd communication Socket.
[    8.161865] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    8.165914] systemd[1]: Listening on Journal Audit Socket.
[    8.171003] systemd[1]: Listening on Journal Socket (/dev/log).
[    8.174683] systemd[1]: Listening on Journal Socket.
[    8.179398] systemd[1]: Listening on udev Control Socket.
[    8.182801] systemd[1]: Listening on udev Kernel Socket.
[    8.191309] systemd[1]: Mounting Huge Pages File System...
[    8.198611] usb 1-2.2.2.2: new low-speed USB device number 5 using tegra-xusb
[    8.199768] systemd[1]: Mounting POSIX Message Queue File System...
[    8.208386] systemd[1]: Mounting RPC Pipe File System...
[    8.217379] systemd[1]: Mounting Kernel Debug File System...
[    8.225945] systemd[1]: Mounting Kernel Trace File System...
[    8.236067] systemd[1]: Starting Journal Service...
[    8.245314] systemd[1]: Starting Set the console keyboard layout...
[    8.253551] systemd[1]: Starting Create list of static device nodes for the current kernel...
[    8.262577] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[    8.266348] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[    8.272429] systemd[1]: Starting Load Kernel Module efi_pstore...
[    8.280194] systemd[1]: Starting Load Kernel Module pstore_blk...
[    8.287778] systemd[1]: Starting Load Kernel Module pstore_zone...
[    8.295528] systemd[1]: Starting Load Kernel Module ramoops...
[    8.303380] systemd[1]: Starting NVIDIA specific first-boot udev script...
[    8.310779] ramoops reserved-memory:ramoops_carveout: failed to locate DT /reserved-memory resource
[    8.311382] systemd[1]: Started Nameserver information manager.
[    8.312499] ramoops: probe of reserved-memory:ramoops_carveout failed with error -22
[    8.313106] usb 1-2.2.2.2: New USB device found, idVendor=413c, idProduct=2113, bcdDevice= 1.08
[    8.317540] usb 1-2.2.2.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[    8.317546] usb 1-2.2.2.2: Product: Dell KB216 Wired Keyboard
[    8.322847] systemd[1]: Reached target Network (Pre).
[    8.324075] input: Dell KB216 Wired Keyboard as /devices/platform/3610000.xhci/usb1/1-2/1-2.2/1-2.2.2/1-2.2.2.2/1-2.2.2.2:1.0/0003:413C:2113.0001/input/input1
[    8.328861] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    8.330731] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    8.338235] systemd[1]: Starting Load Kernel Modules...
[    8.346196] systemd[1]: Starting Remount Root and Kernel File Systems...
[    8.355106] systemd[1]: Starting udev Coldplug all Devices...
[    8.365785] systemd[1]: Mounted Huge Pages File System.
[    8.369495] systemd[1]: Mounted POSIX Message Queue File System.
[    8.371443] EXT4-fs (nvme0n1p1): re-mounted. Opts: (null)
[    8.372246] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    8.374969] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x00000000ce000000,704643072
[    8.374976] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[    8.374986] nvmap_page_pool_init: Total RAM pages: 1752719
[    8.374989] nvmap_page_pool_init: nvmap page pool size: 219089 pages (855 MB)
[    8.375650] nvmap_background_zero_thread: PP zeroing thread starting.
[    8.375802] misc nvmap: created heap vpr base 0x00000000ce000000 size (688128KiB)
[    8.375959] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[    8.382787] hid-generic 0003:413C:2113.0001: input,hidraw0: USB HID v1.11 Keyboard [Dell KB216 Wired Keyboard] on usb-3610000.xhci-2.2.2.2/input0
[    8.389314] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[    8.416856] input: Dell KB216 Wired Keyboard System Control as /devices/platform/3610000.xhci/usb1/1-2/1-2.2/1-2.2.2/1-2.2.2.2/1-2.2.2.2:1.1/0003:413C:2113.0002/input/input2
[    8.463676] systemd[1]: Mounted RPC Pipe File System.
[    8.467821] systemd[1]: Mounted Kernel Debug File System.
[    8.472846] systemd[1]: Mounted Kernel Trace File System.
[    8.482878] systemd[1]: Finished Create list of static device nodes for the current kernel.
[    8.487789] systemd[1]: modprobe@chromeos_pstore.service: Succeeded.
[    8.493256] systemd[1]: Finished Load Kernel Module chromeos_pstore.
[    8.501460] systemd[1]: modprobe@efi_pstore.service: Succeeded.
[    8.506676] nvgpu: 17000000.gv11b          nvgpu_nvhost_syncpt_init:135  [INFO]  syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[    8.506676]
[    8.507877] systemd[1]: Finished Load Kernel Module efi_pstore.
[    8.522873] input: Dell KB216 Wired Keyboard Consumer Control as /devices/platform/3610000.xhci/usb1/1-2/1-2.2/1-2.2.2/1-2.2.2.2/1-2.2.2.2:1.1/0003:413C:2113.0002/input/input3
[    8.539598] hid-generic 0003:413C:2113.0002: input,hidraw1: USB HID v1.11 Device [Dell KB216 Wired Keyboard] on usb-3610000.xhci-2.2.2.2/input1
[    8.554031] systemd[1]: modprobe@pstore_blk.service: Succeeded.
[    8.559964] systemd[1]: Finished Load Kernel Module pstore_blk.
[    8.570239] systemd[1]: Finished Set the console keyboard layout.
[    8.575493] systemd[1]: modprobe@pstore_zone.service: Succeeded.
[    8.579286] systemd[1]: Finished Load Kernel Module pstore_zone.
[    8.586027] systemd[1]: modprobe@ramoops.service: Succeeded.
[    8.589864] systemd[1]: Finished Load Kernel Module ramoops.
[    8.597045] systemd[1]: nvfb-udev.service: Succeeded.
[    8.601740] systemd[1]: Finished NVIDIA specific first-boot udev script.
[    8.614624] systemd[1]: Finished Load Kernel Modules.
[    8.618609] usb 1-2.2.2.4: new low-speed USB device number 6 using tegra-xusb
[    8.621867] systemd[1]: Finished Remount Root and Kernel File Systems.
[    8.631402] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[    8.638043] systemd[1]: Mounting Kernel Configuration File System...
[    8.647992] systemd[1]: Started OP-TEE Client Supplicant.
[    8.653530] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[    8.655562] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[    8.667869] systemd[1]: Starting Load/Save Random Seed...
[    8.676006] systemd[1]: Starting Apply Kernel Variables...
[    8.684204] systemd[1]: Starting Create System Users...
[    8.691678] systemd[1]: Started Journal Service.
[    9.728567] using random self ethernet address
[    9.729696] using random host ethernet address
[   10.520871] using random self ethernet address
[   10.522341] using random host ethernet address
[   11.279723] IRQ218: set affinity failed(-22).
[   11.280125] CPU4: shutdown
[   11.395804] IRQ218: set affinity failed(-22).
[   11.396546] CPU5: shutdown
[   11.461260] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[   11.483130] imx219 9-0010: board setup failed
[   11.484684] imx219: probe of 9-0010 failed with error -121
[   11.548544] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[   11.558530] imx219 10-0010: board setup failed
[   11.560518] imx219: probe of 10-0010 failed with error -121
[   14.111649] 1 fixed-partitions partitions found on MTD device spi6.0
[   14.113187] Creating 1 MTD partitions on "spi6.0":
[   14.115299] 0x000000000000-0x000002000000 : "Whole_flash0"
[   14.197144] ------------[ cut here ]------------
[   14.205783] WARNING: CPU: 0 PID: 330 at drivers/spi/spidev.c:781 init_module+0x15c1e0/0x15e19c [spidev]
[   14.208097] ---[ end trace 6456bf540a51e84f ]---
[   18.671480] FAT-fs (mmcblk0p18): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   23.873062] Bridge firewalling registered
Ubuntu 20.04.5 LTS tegra-ubuntu ttyTCU0
tegra-ubuntu login: [   27.087343] nvmap_alloc_handle: PID 1293: deepstream-app: WARNING: All NvMap Allocations must have a tag to identify the subsystem allocating memory.Please pass the tag to the API call NvRmMemHanldeAllocAttr() or relevant.
[   30.343913] nvidia: loading out-of-tree module taints kernel.
[  203.486108] watchdog: watchdog0: watchdog did not stop!
[  203.833846] Trying to unregister non-registered hwtime source
[  203.836743] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000040
[  203.837819] Mem abort info:
[  203.838740]   ESR = 0x96000004
[  203.839643]   EC = 0x25: DABT (current EL), IL = 32 bits
[  203.840605]   SET = 0, FnV = 0
[  203.841541]   EA = 0, S1PTW = 0
[  203.842459] Data abort info:
[  203.843363]   ISV = 0, ISS = 0x00000004
[  203.844296]   CM = 0, WnR = 0
[  203.845270] user pgtable: 4k pages, 48-bit VAs, pgdp=000000011d3c2000
[  203.846334] [0000000000000040] pgd=0000000000000000, p4d=0000000000000000
[  203.847437] Internal error: Oops: 96000004 [#1] PREEMPT SMP
[  203.848475] Modules linked in: fuse(E) xt_conntrack(E) xt_MASQUERADE(E) nf_conntrack_netlink(E) nfnetlink(E) xt_addrtype(E) iptable_filter(E) iptable_nat(E) nf_nat(E) nf_conntrack(E) nf_defrag_ipv6(E) nf_defrag_ipv4(E) libcrc32c(E) br_netfilter(E) lzo_rle(E) lzo_compress(E) zram(E) overlay(E) snd_soc_tegra210_ope(E) snd_soc_tegra186_asrc(E) snd_soc_tegra186_dspk(E) snd_soc_tegra210_iqc(E) snd_soc_tegra210_mvc(E) snd_soc_tegra186_arad(E) snd_soc_tegra210_afc(E) snd_soc_tegra210_mixer(E) snd_soc_tegra210_dmic(E) snd_soc_tegra210_adx(E) snd_soc_tegra210_amx(E) snd_soc_tegra210_i2s(E) snd_soc_tegra210_sfc(E) snd_soc_tegra210_admaif(E) snd_soc_tegra_pcm(E) spidev(E) ofpart(E) cmdlinepart(E) qspi_mtd(E) mtd(E) aes_ce_blk(E) crypto_simd(E) cryptd(E) aes_ce_cipher(E) ghash_ce(E) sha2_ce(E) sha256_arm64(E) sha1_ce(E) snd_soc_spdif_tx(E) snd_soc_tegra_machine_driver(E) leds_gpio(E) max77620_thermal(E) snd_soc_tegra210_adsp(E) tegra_bpmp_thermal(E) snd_soc_tegra_utils(E) snd_soc_simple_card_utils(E)
[  203.848651]  userspace_alert(E) nvadsp(E) nv_imx219(E) snd_soc_tegra210_ahub(E) tegra210_adma(E) snd_hda_codec_hdmi(E) snd_hda_tegra(E) snd_hda_codec(E) realtek(E) snd_hda_core(E) spi_tegra210_qspi(E) spi_tegra114(E) input_leds(E) loop(E) binfmt_misc(E) ina3221(E) pwm_fan(E) nvgpu(E) nvmap(E) ramoops(E) reed_solomon(E) ip_tables(E) x_tables(E)
[  203.922186] CPU: 2 PID: 2972 Comm: kworker/u12:4 Tainted: G        W  OE     5.10.104-tegra #2
[  203.931089] Hardware name: Unknown NVIDIA Jetson Xavier NX for DSBOARD-NX2 (rev-1.22)/NVIDIA Jetson Xavier NX for DSBOARD-NX2 (rev-1.22), BIOS 1.0-d7fb19b
[  203.945014] Workqueue: events_power_efficient phy_state_machine
[  203.951044] pstate: 60c00009 (nZCv daif +PAN +UAO -TCO BTYPE=--)
[  203.957101] pc : netif_carrier_off+0x18/0x90
[  203.961539] lr : netif_carrier_off+0x18/0x90
[  203.966003] sp : ffff80002f8c3d00
[  203.969157] x29: ffff80002f8c3d00 x28: ffffc90c41266000
[  203.974685] x27: ffff8000108fbca8 x26: ffff4ee3b30391c8
[  203.980438] x25: 0000000000000000 x24: 0000000000000000
[  203.985693] x23: ffff4ee2e6ebb4f8 x22: ffff4ee3a79a0000
[  203.991374] x21: 0000000000000000 x20: 0000000000000000
[  203.996631] x19: 0000000000000000 x18: 000000000000001c
[  204.002144] x17: 0000000000000007 x16: 000000000000000e
[  204.007655] x15: 0000000000000004 x14: 0000000000000019
[  204.013167] x13: 0000000000000000 x12: ffff4ee2e8509dd8
[  204.018851] x11: ffff4ee2e8509da8 x10: 0000000000000a80
[  204.024361] x9 : ffff4ee3b33ef57c x8 : fefefefefefefeff
[  204.029443] x7 : 0000000000000018 x6 : ffff4ee3b33ef56c
[  204.035038] x5 : 0000746e65696369 x4 : 000000000000002f
[  204.040462] x3 : 0000000000000000 x2 : ffffc90c3f737380
[  204.045547] x1 : 0000000000000000 x0 : ffffc90c3f737380
[  204.051138] Call trace:
[  204.053597]  netif_carrier_off+0x18/0x90
[  204.057357]  phy_link_change+0x68/0x70
[  204.061034]  phy_state_machine+0x17c/0x220
[  204.065062]  process_one_work+0x1c0/0x4a0
[  204.069083]  worker_thread+0x50/0x420
[  204.073017]  kthread+0x148/0x170
[  204.076254]  ret_from_fork+0x10/0x18
[  204.079759] Code: f9000bf3 aa0003f3 aa1e03e0 97c2df92 (f9402260)
[  204.085883] ---[ end trace 6456bf540a51e850 ]---
[  204.090168] Kernel panic - not syncing: Oops: Fatal exception
[  204.095799] Kernel Offset: 0x490c2f580000 from 0xffff800010000000
[  204.101892] PHYS_OFFSET: 0xffffb11e40000000
[  204.105920] CPU features: 0x8240002,03802a30
[  204.110462] Memory Limit: none
[  204.113617] ---[ end Kernel panic - not syncing: Oops: Fatal exception ]---
Please apply this workaround to your device tree.
Please try to remove below in your kernel-dts/t19x-common-platforms/tegra194-platforms-eqos.dtsi
  interrupt-parent = <&tegra_main_gpio>;
  interrupts = <TEGRA194_MAIN_GPIO(G, 4) IRQ_TYPE_LEVEL_LOW>;
Thanks for your reply. I got another kernel panic error while booting. It behaves like before (Not happening every time).
[0000.024] W> RATCHET: MB1 binary ratchet value 4 is larger than ratchet level 2 from HW fuses.
[0000.032] I> MB1 (prd-version: 2.3.0.0-t194-41334769-0a17edc1)
[0000.038] I> Boot-mode: Coldboot
[0000.041] I> Platform: Silicon
[0000.044] I> Chip revision : A02P
[0000.047] I> Bootrom patch version : 15 (correctly patched)
[0000.052] I> ATE fuse revision : 0x200
[0000.055] I> Ram repair fuse : 0x0
[0000.058] I> Ram Code : 0x0
[0000.061] I> rst_source: 0xb, rst_level: 0x1
[0000.066] I> Boot-device: QSPI (instance: 0)
[0000.070] I> Qspi flash params source = brbct
[0000.074] I> Qspi clock source : pllp
[0000.077] I> Qspi-0 initialized successfully
[0000.081] I> Boot chain mechanism: A/B
[0000.085] I> Current Boot-Chain Slot: 0
[0000.088] I> BR-BCT Boot-Chain: 0, status: 0. update flag: 0
[0000.093] I> Qspi flash params source = brbct
[0000.100] W> PROD_CONFIG: device prod data is empty in MB1 BCT.
[0000.106] I> Temperature = 51000
[0000.109] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.113] W> Skipping boost for clk: BPMP_APB
[0000.117] W> Skipping boost for clk: AXI_CBB
[0000.121] W> Skipping boost for clk: AON_CPU_NIC
[0000.125] W> Skipping boost for clk: CAN1
[0000.129] W> Skipping boost for clk: CAN2
[0000.133] I> Boot-device: QSPI (instance: 0)
[0000.137] I> Qspi flash params source = mb1bct
[0000.141] I> Qspi clock source : pllc_out0
[0000.145] I> Qspi-0 reinitialized
[0000.148] I> Qspi flash params source = mb1bct
[0000.161] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.168] W>  Thermal config not found in BCT
[0000.176] W>  MEMIO rail config not found in BCT
[0000.186] I> Qspi flash params source = mb1bct
[0000.199] I> Qspi flash params source = mb1bct
[0000.233] I> Qspi flash params source = mb1bct
[0000.797] I> Qspi flash params source = mb1bct
[0000.814] I> Qspi flash params source = mb1bct
[0000.853] W>  Platform config not found in BCT
[0000.880] I> Qspi flash params source = mb1bct
[0000.906] I> MB1 done
����main enter
SPE VERSION #: R01.00.18 Created: Jan 29 2021 @ 14:18:27
HW Function test
Start Scheduler.
in late init
  [0000.915] I> Welcome to MB2(TBoot-BPMP) (version: default.t194-mobile-1ca012e4)
[0000.916] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.916] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.917] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.923] W> device prod register failed
[0000.926] I> gpio framework initialized
[0000.930] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0000.937] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0000.945] I> No valid sdcard_params in mb1_bct
[0000.950] I> Boot_device: QSPI_FLASH instance: 0
[0000.954] I> qspi flash-0 params source = boot args
[0000.959] I> QSPI-0l initialized successfully
[0000.963] I> sdmmc-3 params source = safe params
[0001.306] I> sdmmc DDR50 mode
[0001.324] I> Found 41 partitions in QSPI_FLASH (instance 0)
[0001.341] W> Cannot find any partition table for 00000003
[0001.342]  > PARTITION_MANAGER: Failed to publish partition.
[0001.358] I> Found 19 partitions in SDMMC_USER (instance 3)
[0001.359] I> Active Boot chain : 0
[0002.030] I> Relocating BR-BCT
[0002.032]  > DEVICE_PROD: device prod is not initialized.
[0002.057] E> I2C: slave not found in slaves.
[0002.058] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0002.059] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.060] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 0.
[0002.060] E> eeprom: Failed to read I2C slave device
[0002.064] I> Failed to read CVB eeprom data @ AE
[0002.068] I> Retrying CVB eeprom read @ AC ...
[0002.073] E> I2C: slave not found in slaves.
[0002.077] E> I2C: Could not write 0 bytes to slave: 0x00ac with repeat start true.
[0002.085] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.091] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xac at 0x00000000 via instance 0.
[0002.100] E> eeprom: Failed to read I2C slave device
[0002.104] I> Failed to read CVB eeprom data @ AC
[0002.366] I> Relocating OP-TEE dtb from: 0x6bfff1d0 to 0x70050000, size: 1008
[0002.367] I> [0] START: 0x80000000, SIZE: 0x2f000000
[0002.367] I> [1] START: 0xaf010000, SIZE: 0x18bf0000
[0002.368] I> [2] START: 0xc7d00000, SIZE: 0xc0000
[0002.368] I> [3] START: 0xca000000, SIZE: 0x800000
[0002.368] I> dram_block larger than 80000000
[0002.371] I> [4] START: 0x100000000, SIZE: 0x180000000
[0002.382] I> Setting NS memory ranges to OP-TEE dtb finished.
[0002.385] I> found decompressor handler: lz4
[0002.613] I> EKB detected (length: 0x410) @ VA:0x52709400
[0002.615] I> Setting EKB blob info to OPTEE dtb finished.
��NOTICE:  BL31: v2.6(release):4fa405dbd
NOTICE:  BL31: Built : 20:16:55, Aug 10 2022
I/TC:
  bpmp: init
bpmp: tag is 128431eec76692047e1ac1ebc0392266
sku_dt_init: not sku 0x00
��I��clk_early initialized
��/TC:��mail_early initialized
�� N��fuse initialized
hwwdt initialized
��on-s��t194_ec_get_ec_list: found 45 ecs
��ecure exter��ec initialized
��n��vmon_setup_monitors: found 3 monitors
vmon initialized
��al ��adc initialized
fmon_populate_monitors: found 73 monitors
��DT found
��fmon initialized
mc initialized
reset initialized
nvhs initialized
uphy_early initialized
emc_early initialized
392 clocks registered
clk initialized
io_dpd initialized
thermal initialized
thermal_mrq initialized
i2c initialized
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
vrmon initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
suspend initialized
pg_late initialized
pg_mrq_init initialized
strap initialized
nvl initialized
emc initialized
emc_mrq initialized
clk_dt initialized
tj_init initialized
uphy_dt initialized
uphy_mrq initialized
uphy initialized
ec_swd_poll_start: 281 reg polling start w period 47 ms
ec_late initialized
hwwdt_late initialized
reset_mrq initialized
ec_mrq initialized
fmon_mrq initialized
clk_mrq initialized
avfs_mrq initialized
mail_mrq initialized
i2c_mrq initialized
tag_mrq initialized
console_mrq initialized
mrq initialized
clk_sync_fmon_post initialized
��I/TC: OP-TEE version: 3.16 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Thu A��clk_dt_late initialized
��u��noc_late initialized
��g��pm_post initialized
dbells initialized
�� 11��dmce initialized
cvc initialized
�� 03:23:20 UTC��avfs_clk_mach_post initialized
�� 202��avfs_clk_platform_post initialized
��2 ��cvc_late initialized
regulator_post initialized
��aarch��rm initialized
console_late initialized
clk_dt_post initialized
mc_reg initialized
��64
I/TC: WARNIN��pg_post initialized
profile initialized
fuse_late initialized
extras_post initialized
bpmp: init complete
entering main console loop
] ��G: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: Primary CPU switching to normal world boot
  [0003.233] I> Welcome to NVDisp-Init
[0003.234] I> NVDisp-Init version: t194-f9ecfedc
[0003.234] I> CPU-BL Params @ 0xca020000
[0003.234] I>  0) Base:0x00000000 Size:0x00000000
[0003.235] I>  1) Base:0xc8300000 Size:0x00100000
[0003.235] I>  2) Base:0xc9800000 Size:0x00200000
[0003.235] I>  3) Base:0xc8600000 Size:0x00200000
[0003.238] I>  4) Base:0xc8200000 Size:0x00100000
[0003.242] I>  5) Base:0xc8100000 Size:0x00100000
[0003.247] I>  6) Base:0xc9400000 Size:0x00400000
[0003.251] I>  7) Base:0xc9000000 Size:0x00400000
[0003.256] I>  8) Base:0xc8000000 Size:0x00100000
[0003.260] I>  9) Base:0xc7f00000 Size:0x00100000
[0003.264] I> 10) Base:0xca800000 Size:0x00800000
[0003.269] I> 11) Base:0x40000000 Size:0x00040000
[0003.273] I> 12) Base:0xc7e00000 Size:0x00100000
[0003.278] I> 13) Base:0x40046000 Size:0x00002000
[0003.282] I> 14) Base:0x40048000 Size:0x00002000
[0003.287] I> 15) Base:0xaf000000 Size:0x00004000
[0003.291] I> 16) Base:0x4004a000 Size:0x00002000
[0003.296] I> 17) Base:0xc7c00000 Size:0x00100000
[0003.300] I> 18) Base:0x4004c000 Size:0x00002000
[0003.305] I> 19) Base:0xc9a00000 Size:0x00600000
[0003.309] I> 20) Base:0x4004e000 Size:0x00002000
[0003.314] I> 21) Base:0xc7dc0000 Size:0x0000c000
[0003.318] I> 22) Base:0x00000000 Size:0x00000000
[0003.322] I> 23) Base:0xc7de0000 Size:0x00020000
[0003.327] I> 24) Base:0xcc000000 Size:0x02000000
[0003.331] I> 25) Base:0x40050000 Size:0x00002000
[0003.336] I> 26) Base:0x40040000 Size:0x00006000
[0003.340] I> 27) Base:0xc8c00000 Size:0x00400000
[0003.345] I> 28) Base:0xc8400000 Size:0x00200000
[0003.349] I> 29) Base:0xc8800000 Size:0x00400000
[0003.354] I> 30) Base:0xc7dd0000 Size:0x00010000
[0003.358] I> 31) Base:0x00000000 Size:0x00000000
[0003.363] I> 32) Base:0xf8000000 Size:0x08000000
[0003.367] I> 33) Base:0xce000000 Size:0x2a000000
[0003.372] I> 34) Base:0xcb000000 Size:0x01000000
[0003.376] I> 35) Base:0xae000000 Size:0x01000000
[0003.380] I> 36) Base:0xa0000000 Size:0x0e000000
[0003.385] I> 37) Base:0xca000000 Size:0x00800000
[0003.389] I> 38) Base:0x80000000 Size:0x20000000
[0003.394] I> 39) Base:0xb0000000 Size:0x08000000
[0003.398] I> 40) Base:0x00000000 Size:0x00000000
[0003.403] I> 41) Base:0x00000000 Size:0x00000000
[0003.407] I> 42) Base:0x00000000 Size:0x00000000
[0003.412] I> 43) Base:0x00000000 Size:0x00000000
[0003.416] I> 44) Base:0x00000000 Size:0x00000000
[0003.421] I> 45) Base:0x00000000 Size:0x00000000
[0003.425] GIC-SPI Target CPU: 0
[0003.428] Interrupts Init done
[0003.431] calling constructors
[0003.434] initializing heap
[0003.436] I> Heap: [0xa0960000 ... 0xadf00000]
[0003.441] initializing threads
[0003.444] initializing timers
[0003.446] creating bootstrap completion thread
[0003.451] top of bootstrap2()
[0003.454] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0003.458] initializing platform
[0003.461] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0003.467] W> device prod register failed
[0003.470] I> Bl_dtb @0xadf00000
[0003.473] I> gpio framework initialized
[0003.485] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0003.490] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0003.496] I> fixed regulator driver initialized
[0003.508] I> register 'maxim' power off handle
[0003.510] I> virtual i2c enabled
[0003.510] I> registered 'maxim,max20024' pmic
[0003.510] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0003.515] I> Boot-device: QSPI
[0003.518] I> Boot_device: QSPI_FLASH instance: 0
[0003.522] I> configure_qspi_clk: qparams clk_src = 5, clk_div = 0, clk_src_freq = 800000000, interface_freq = 50000000
[0003.533] I> configure_qspi_clk: FORCING INTERFACE_FREQ TO 133000000!!
[0003.540] I> QSPI source rate = 204000 Khz
[0003.543] I> Requested rate for QSPI clock = 34000 Khz
[0003.548] I> BPMP-set rate for QSPI clk = 34000 Khz
[0003.553] I> tx_clk_tap_delay : 0
[0003.556] I> rx_clk_tap_delay : 16
[0003.559] I> QSPI Flash Size = 32 MB
[0003.567] I> Qspi initialized successfully
[0003.567] I> qspi flash-0 params source = boot args
[0003.572] W> No board IDs available
[0003.574] E> Failed to get board id info!
[0003.580] I> sdmmc-3 params source = safe params
[0003.587] I> Found 41 partitions in QSPI_FLASH (instance 0)
[0003.589] W> Cannot find any partition table for 00000003
[0003.593] E> Failed to publish 00000003
[0003.598] I> Found 19 partitions in SDMMC_USER (instance 3)
[0003.617] I> regulator 'vdd-hdmi-5v0' already enabled
[0003.622] I> regulator 'vdd-hdmi-5v0' already enabled
[0003.622] I> hdmi cable connected
[0003.627] W> set volts not configured for 'vdd-1v0'
[0003.632] W> set volts not configured for 'vdd-1v8-hs'
[0003.633] I> retrieved tmds range from prod_list_hdmi_soc
[0003.638] E> invalid display type
[0003.639] E> cannot find any other nvdisp nodes
[0003.655] I> edid read success
[0003.668] I> edid read success
[0003.668] I> width = 640, height = 480, frequency = 25174825
[0003.669] I> width = 640, height = 480, frequency = 25174825
[0003.669] I> width = 1920, height = 1080, frequency = 148500000
[0003.670] I> width = 1920, height = 1080, frequency = 148351648
[0003.674] I> width = 1280, height = 720, frequency = 74175824
[0003.680] I> width = 720, height = 480, frequency = 26973026
[0003.685] I> width = 720, height = 480, frequency = 26973026
[0003.691] I> width = 640, height = 480, frequency = 25174825
[0003.696] I> width = 1920, height = 1080, frequency = 148351648
[0003.702] I> width = 720, height = 576, frequency = 26973026
[0003.708] I> width = 1280, height = 720, frequency = 74175824
[0003.713] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0003.724] I> hdmi_enable, starting HDMI initialisation
[0003.729] I> hdmi_enable, HDMI initialisation complete
[0003.738] initializing target
[0003.739] calling apps_init()
[0003.740] starting app kernel_boot_app
[0003.741] I> Kernel type = Normal
Jetson UEFI firmware (version 1.0-d7fb19b built on 2022-08-10T20:18:13-07:00)
**  WARNING: Test Key is used.  **
L4TLauncher: Attempting GRUB Boot
L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map...
��I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
��[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x4e0f0040]
[    0.000000] Linux version 5.10.104-tegra (ubuntu@ubuntu-desktop) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #2 SMP PREEMPT Tue Oct 18 12:07:52 +03 2022
[    0.000000] Machine model: NVIDIA Jetson Xavier NX for DSBOARD-NX2 (rev-1.22)
[    0.000000] efi: EFI v2.70 by EDK II
[    0.000000] efi: RTPROP=0x27757c518 SMBIOS=0xc7db0000 SMBIOS 3.0=0x258980000 MEMATTR=0x25943d018 ESRT=0x25944fa18 RNG=0x27c595918 MEMRESERVE=0x25943ef18
[    0.000000] efi: seeding entropy pool
[    0.000000] esrt: Reserving ESRT space from 0x000000025944fa18 to 0x000000025944fa50.
[    0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb3_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x000000027fffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000a0973fff]
[    0.000000]   node   0: [mem 0x00000000a0974000-0x00000000a0975fff]
[    0.000000]   node   0: [mem 0x00000000a0977000-0x00000000aeffffff]
[    0.000000]   node   0: [mem 0x00000000af010000-0x00000000c7bfffff]
[    0.000000]   node   0: [mem 0x00000000c7d00000-0x00000000c7d9ffff]
[    0.000000]   node   0: [mem 0x00000000c7da0000-0x00000000c7dbffff]
[    0.000000]   node   0: [mem 0x00000000ca000000-0x00000000ca5fffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x00000002577affff]
[    0.000000]   node   0: [mem 0x00000002577b0000-0x00000002577dffff]
[    0.000000]   node   0: [mem 0x00000002577e0000-0x0000000257c8ffff]
[    0.000000]   node   0: [mem 0x0000000257c90000-0x00000002584fffff]
[    0.000000]   node   0: [mem 0x0000000258500000-0x0000000258526fff]
[    0.000000]   node   0: [mem 0x0000000258527000-0x00000002586eefff]
[    0.000000]   node   0: [mem 0x00000002586ef000-0x000000025896ffff]
[    0.000000]   node   0: [mem 0x0000000258970000-0x000000025898ffff]
[    0.000000]   node   0: [mem 0x0000000258990000-0x000000025920ffff]
[    0.000000]   node   0: [mem 0x0000000259210000-0x000000025939ffff]
[    0.000000]   node   0: [mem 0x00000002593a0000-0x000000025944ffff]
[    0.000000]   node   0: [mem 0x0000000259450000-0x000000025961ffff]
[    0.000000]   node   0: [mem 0x0000000259620000-0x000000025962ffff]
[    0.000000]   node   0: [mem 0x0000000259630000-0x00000002596fffff]
[    0.000000]   node   0: [mem 0x0000000259700000-0x000000025978ffff]
[    0.000000]   node   0: [mem 0x0000000259790000-0x0000000259aaffff]
[    0.000000]   node   0: [mem 0x0000000259ab0000-0x0000000259abffff]
[    0.000000]   node   0: [mem 0x0000000259ac0000-0x0000000259b2ffff]
[    0.000000]   node   0: [mem 0x0000000259b30000-0x0000000259fbffff]
[    0.000000]   node   0: [mem 0x0000000259fc0000-0x000000025a00ffff]
[    0.000000]   node   0: [mem 0x000000025a010000-0x000000025a1cffff]
[    0.000000]   node   0: [mem 0x000000025a1d0000-0x000000025a26ffff]
[    0.000000]   node   0: [mem 0x000000025a270000-0x000000025a31ffff]
[    0.000000]   node   0: [mem 0x000000025a320000-0x000000025a3bffff]
[    0.000000]   node   0: [mem 0x000000025a3c0000-0x000000025a44ffff]
[    0.000000]   node   0: [mem 0x000000025a450000-0x000000025a4effff]
[    0.000000]   node   0: [mem 0x000000025a4f0000-0x000000025adbffff]
[    0.000000]   node   0: [mem 0x000000025adc0000-0x000000025af9ffff]
[    0.000000]   node   0: [mem 0x000000025afa0000-0x000000027c54ffff]
[    0.000000]   node   0: [mem 0x000000027c550000-0x000000027c59ffff]
[    0.000000]   node   0: [mem 0x000000027c5a0000-0x000000027fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000027fffffff]
[    0.000000] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.000000] cma: Reserved 64 MiB at 0x00000000c3c00000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 32 pages/cpu s90136 r8192 d32744 u131072
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] CPU features: detected: Spectre-v2
[    0.000000] CPU features: detected: NVIDIA Carmel CNP erratum
[    0.000000] alternatives: patching kernel code
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1839268
[    0.000000] Kernel command line: root=/dev/nvme0n1p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000b3c00000-0x00000000c3c00000] (256MB)
[    0.000000] Memory: 6933112K/7473852K available (18176K kernel code, 3174K rwdata, 7216K rodata, 4032K init, 1095K bss, 475204K reserved, 65536K cma-reserved)
[    0.000000] random: get_random_u64 called from __kmem_cache_create+0x34/0x420 with crng_init=0
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Rude variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000004] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.000730] Console: colour dummy device 80x25
[    0.002181] printk: console [tty0] enabled
[    0.002242] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.002277] pid_max: default: 32768 minimum: 301
[    0.002488] LSM: Security Framework initializing
[    0.002551] Yama: becoming mindful.
[    0.002591] SELinux:  Initializing.
[    0.002765] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.002803] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.005526] rcu: Hierarchical SRCU implementation.
[    0.005743] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[    0.006498] DTS File Name: /media/ubuntu/Extra/forecr_kernel_sources/jetpack-502-bsp/forecr_xavier_kernel/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-dsboard-nx2-0000.dts
[    0.006553] DTB Build time: Oct  3 2022 15:11:39
[    0.009346] Tegra Revision: A02 SKU: 0xde CPU Process: 0 SoC Process: 0
[    0.009622] Remapping and enabling EFI services.
[    0.011535] smp: Bringing up secondary CPUs ...
[    0.042334] Detected PIPT I-cache on CPU1
[    0.042408] CPU1: Booted secondary processor 0x0000000001 [0x4e0f0040]
[    0.071948] Detected PIPT I-cache on CPU2
[    0.072041] CPU2: Booted secondary processor 0x0000000100 [0x4e0f0040]
[    0.101579] Detected PIPT I-cache on CPU3
[    0.101663] CPU3: Booted secondary processor 0x0000000101 [0x4e0f0040]
[    0.131353] Detected PIPT I-cache on CPU4
[    0.131531] CPU4: Booted secondary processor 0x0000000200 [0x4e0f0040]
[    0.161268] Detected PIPT I-cache on CPU5
[    0.161416] CPU5: Booted secondary processor 0x0000000201 [0x4e0f0040]
[    0.161788] smp: Brought up 1 node, 6 CPUs
[    0.161987] SMP: Total of 6 processors activated.
[    0.162036] CPU features: detected: Privileged Access Never
[    0.162058] CPU features: detected: LSE atomic instructions
[    0.162071] CPU features: detected: User Access Override
[    0.162084] CPU features: detected: 32-bit EL0 Support
[    0.162096] CPU features: detected: RAS Extension Support
[    0.162108] CPU features: detected: CRC32 instructions
[    0.162121] CPU features: detected: 32-bit EL1 Support
[    0.231306] CPU: All CPU(s) started at EL2
[    0.237755] devtmpfs: initialized
[    0.277636] Registered cp15_barrier emulation handler
[    0.277756] Registered setend emulation handler
[    0.277775] KASLR enabled
[    0.278034] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.278056] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.279413] pinctrl core: initialized pinctrl subsystem
[    0.280351] SMBIOS 3.0.0 present.
[    0.280400] DMI: Unknown NVIDIA Jetson Xavier NX for DSBOARD-NX2 (rev-1.22)/NVIDIA Jetson Xavier NX for DSBOARD-NX2 (rev-1.22), BIOS 1.0-d7fb19b
[    0.281000] NET: Registered protocol family 16
[    0.282853] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.283363] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.284043] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.284096] audit: initializing netlink subsys (disabled)
[    0.284400] audit: type=2000 audit(0.280:1): state=initialized audit_enabled=0 res=1
[    0.284809] thermal_sys: Registered thermal governor 'step_wise'
[    0.284816] thermal_sys: Registered thermal governor 'power_allocator'
[    0.284831] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[    0.286973] cpuidle: using governor menu
[    0.287341] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.287784] ASID allocator initialised with 32768 entries
[    0.288008] Serial: AMBA PL011 UART driver
[    0.291015] Tegra reboot handler registered.
[    0.355713] tegra19x-cbb 2300000.cbb-noc: axi2apb bridge info present
[    0.355872] tegra19x-cbb 2300000.cbb-noc: secure_irq = 15, nonsecure_irq = 14>
[    0.356055] tegra19x-cbb c600000.aon-noc: axi2apb bridge info present
[    0.356100] tegra19x-cbb c600000.aon-noc: secure_irq = 17, nonsecure_irq = 16>
[    0.356204] tegra19x-cbb d600000.bpmp-noc: axi2apb bridge info present
[    0.356246] tegra19x-cbb d600000.bpmp-noc: secure_irq = 19, nonsecure_irq = 18>
[    0.356383] tegra19x-cbb be00000.rce-noc: axi2apb bridge info present
[    0.356444] tegra19x-cbb be00000.rce-noc: secure_irq = 21, nonsecure_irq = 20>
[    0.356555] tegra19x-cbb b600000.sce-noc: axi2apb bridge info present
[    0.356599] tegra19x-cbb b600000.sce-noc: secure_irq = 23, nonsecure_irq = 22>
[    0.358597] mc: mapped MMIO address: 0xffff800010580000 -> 0x2c10000
[    0.358650] mc: mapped MMIO address: 0xffff8000105a0000 -> 0x2c20000
[    0.358677] mc: mapped MMIO address: 0xffff8000105c0000 -> 0x2c30000
[    0.358704] mc: mapped MMIO address: 0xffff8000105e0000 -> 0x2c40000
[    0.358730] mc: mapped MMIO address: 0xffff800010600000 -> 0x2c50000
[    0.358756] mc: mapped MMIO address: 0xffff800010620000 -> 0x2b80000
[    0.358829] mc: mapped MMIO address: 0xffff800010640000 -> 0x2b90000
[    0.358862] mc: mapped MMIO address: 0xffff800010660000 -> 0x2ba0000
[    0.358888] mc: mapped MMIO address: 0xffff800010680000 -> 0x2bb0000
[    0.358910] mc: mapped MMIO address: 0xffff8000106a0000 -> 0x1700000
[    0.358932] mc: mapped MMIO address: 0xffff8000106c0000 -> 0x1710000
[    0.358953] mc: mapped MMIO address: 0xffff8000106e0000 -> 0x1720000
[    0.358975] mc: mapped MMIO address: 0xffff800010700000 -> 0x1730000
[    0.359013] mc: mapped MMIO address: 0xffff800010720000 -> 0x1740000
[    0.359036] mc: mapped MMIO address: 0xffff800010740000 -> 0x1750000
[    0.359073] mc: mapped MMIO address: 0xffff800010760000 -> 0x1760000
[    0.359095] mc: mapped MMIO address: 0xffff800010780000 -> 0x1770000
[    0.359202] mc-err: mcerr ops are set to t19x
[    0.370663] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.370685] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.370697] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.370708] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.377643] ACPI: Interpreter disabled.
[    0.378651] vdd-epb-1v0: supplied by vdd-3v3-cvb
[    0.379765] iommu: Default domain type: Translated
[    0.379839] eventlib_kernel: keventlib is initialized, test id: 0
[    0.380169] SCSI subsystem initialized
[    0.380310] usbcore: registered new interface driver usbfs
[    0.380348] usbcore: registered new interface driver hub
[    0.380379] usbcore: registered new device driver usb
[    0.380809] mc: Linux media interface: v0.10
[    0.380839] videodev: Linux video capture interface: v2.00
[    0.381215] pps_core: LinuxPPS API ver. 1 registered
[    0.381226] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.381247] PTP clock support registered
[    0.381451] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[    0.381723] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[    0.381798] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[    0.382371] Registered efivars operations
[    0.387691] FPGA manager framework
[    0.387759] Advanced Linux Sound Architecture Driver Initialized.
[    0.388286] Bluetooth: Core ver 2.22
[    0.388321] NET: Registered protocol family 31
[    0.388331] Bluetooth: HCI device and connection manager initialized
[    0.388345] Bluetooth: HCI socket layer initialized
[    0.388359] Bluetooth: L2CAP socket layer initialized
[    0.388377] Bluetooth: SCO socket layer initialized
[    0.389797] camchar: rtcpu character device driver loaded
[    0.390440] clocksource: Switched to clocksource arch_sys_counter
[    0.746175] VFS: Disk quotas dquot_6.6.0
[    0.746239] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.746589] pnp: PnP ACPI: disabled
[    0.757422] la/ptsa driver initialized.
[    0.757529] NET: Registered protocol family 2
[    0.757728] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.762312] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    0.762379] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.762725] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.763159] TCP: Hash tables configured (established 65536 bind 65536)
[    0.763298] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.763388] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.763573] NET: Registered protocol family 1
[    0.764259] RPC: Registered named UNIX socket transport module.
[    0.764274] RPC: Registered udp transport module.
[    0.764283] RPC: Registered tcp transport module.
[    0.764291] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.764316] PCI: CLS 0 bytes, default 64
[    0.764497] Trying to unpack rootfs image as initramfs...
[    0.948787] Initramfs unpacking failed: invalid magic at start of compressed archive
[    0.950715] Freeing initrd memory: 8196K
[    0.955023] hw perfevents: failed to parse interrupt-affinity[6] for arm-pmu
[    0.955066] hw perfevents: /arm-pmu: failed to register PMU devices!
[    0.955133] armv8-pmu: probe of arm-pmu failed with error -22
[    0.955641] kvm [1]: IPA Size Limit: 40 bits
[    0.956204] kvm [1]: vgic interrupt IRQ9
[    0.956751] kvm [1]: VHE mode initialized successfully
[    0.958040] Initialise system trusted keyrings
[    0.958323] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[    0.962843] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.963517] NFS: Registering the id_resolver key type
[    0.963538] Key type id_resolver registered
[    0.963547] Key type id_legacy registered
[    0.963611] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.963628] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.963651] ntfs: driver 2.1.32 [Flags: R/W].
[    0.972942] NET: Registered protocol family 38
[    0.972962] Key type asymmetric registered
[    0.972971] Asymmetric key parser 'x509' registered
[    0.973026] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[    0.973197] io scheduler mq-deadline registered
[    0.973208] io scheduler kyber registered
[    0.977587] tegra186-dpaux-pinctrl 155f0000.dpaux: can not get clock
[    0.979784] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    0.979859] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[    0.979922] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    0.979983] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[    0.980029] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[    0.983958] scrncapt: init (heads:4 wins:6 planes:4)
[    0.984493] tegradccommon 15200000.display-hub: Nvhost Channel map failed
[    0.985080] EINJ: ACPI disabled.
[    0.987466] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[    0.987484] tegra-pmc: ### PMC reset source: MAINSWRST
[    0.987494] tegra-pmc: ### PMC reset level: L1
[    0.987503] tegra-pmc: ### PMC reset status reg: 0x2d
[    0.987556] tegra-pmc: PMC Prod config success
[    0.992263] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.996087] random: fast init done
[    0.996236] printk: console [ttyTCU0] enabled
[    2.567057] arm-smmu 10000000.iommu: probing hardware configuration...
[    2.571713] arm-smmu 10000000.iommu: SMMUv2 with:
[    2.576066] arm-smmu 10000000.iommu: 	stage 1 translation
[    2.581497] arm-smmu 10000000.iommu: 	stage 2 translation
[    2.587254] arm-smmu 10000000.iommu: 	nested translation
[    2.592339] arm-smmu 10000000.iommu: 	stream matching with 128 register groups
[    2.599514] arm-smmu 10000000.iommu: 	64 context banks (0 stage-2 only)
[    2.610937] arm-smmu 10000000.iommu: 	Supported page sizes: 0x00001000
[    2.612611] arm-smmu 10000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    2.619200] arm-smmu 10000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    2.627137] arm-smmu 12000000.iommu: probing hardware configuration...
[    2.632498] arm-smmu 12000000.iommu: SMMUv2 with:
[    2.636976] arm-smmu 12000000.iommu: 	stage 1 translation
[    2.642727] arm-smmu 12000000.iommu: 	stage 2 translation
[    2.647897] arm-smmu 12000000.iommu: 	nested translation
[    2.653325] arm-smmu 12000000.iommu: 	stream matching with 128 register groups
[    2.660532] arm-smmu 12000000.iommu: 	64 context banks (0 stage-2 only)
[    2.672203] arm-smmu 12000000.iommu: 	Supported page sizes: 0x00001000
[    2.673623] arm-smmu 12000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    2.680444] arm-smmu 12000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    2.687617] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[    2.697319] tegra_profiler: version: 1.147, samples/io: 49/28
[    2.700899] tegra_profiler: auth: init
[    2.705077] THERMAL EST: found 3 subdevs
[    2.708282] THERMAL EST num_resources: 0
[    2.712120] [THERMAL EST subdev 0]
[    2.715453] [THERMAL EST subdev 1]
[    2.719124] [THERMAL EST subdev 2]
[    2.722084] THERMAL EST: Found 2 profiles, default profile is quiet
[    2.728554] THERMAL EST: thz register success.
[    2.732808] THERMAL EST: end of probe, return err: 0
[    2.738416] nvsciipc: loaded module
[    2.745426] tun: Universal TUN/TAP device driver, 1.6
[    2.747681] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    2.754155] hns3: Copyright (c) 2017 Huawei Corporation.
[    2.759466] e1000e: Intel(R) PRO/1000 Network Driver
[    2.764367] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    2.770697] igb: Intel(R) Gigabit Ethernet Network Driver
[    2.775990] igb: Copyright (c) 2007-2014 Intel Corporation.
[    2.782190] PPP generic driver version 2.4.2
[    2.786233] PPP BSD Compression module registered
[    2.790971] PPP Deflate Compression module registered
[    2.796211] PPP MPPE Compression module registered
[    2.801244] usbcore: registered new interface driver r8152
[    2.806486] hso: drivers/net/usb/hso.c: Option Wireless
[    2.811842] usbcore: registered new interface driver hso
[    2.816912] usbcore: registered new interface driver asix
[    2.822319] usbcore: registered new interface driver ax88179_178a
[    2.828433] usbcore: registered new interface driver cdc_ether
[    2.834753] usbcore: registered new interface driver net1080
[    2.840442] usbcore: registered new interface driver cdc_subset
[    2.846393] usbcore: registered new interface driver zaurus
[    2.851967] usbcore: registered new interface driver sierra_net
[    2.857593] usbcore: registered new interface driver cdc_ncm
[    2.863173] usbcore: registered new interface driver qmi_wwan
[    2.868775] usbcore: registered new interface driver cdc_mbim
[    2.874542] usbcore: registered new interface driver aqc111
[    2.880820] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.886488] ohci-pci: OHCI PCI platform driver
[    2.891079] ohci-platform: OHCI generic platform driver
[    2.896924] tegra-xusb 3610000.xhci: Adding to iommu group 0
[    2.902611] usbcore: registered new interface driver cdc_wdm
[    2.907448] usbcore: registered new interface driver uas
[    2.912627] usbcore: registered new interface driver usb-storage
[    2.918802] usbcore: registered new interface driver option
[    2.924150] usbserial: USB Serial support registered for GSM modem (1-port)
[    2.931439] usbcore: registered new interface driver qcserial
[    2.936953] usbserial: USB Serial support registered for Qualcomm USB modem
[    2.944285] usbcore: registered new interface driver sierra
[    2.949877] usbserial: USB Serial support registered for Sierra USB modem
[    2.956958] tegra-xudc 3550000.xudc: Adding to iommu group 1
[    2.962828] mousedev: PS/2 mouse device common for all mice
[    2.967848] usbcore: registered new interface driver xpad
[    2.976132] tegra_rtc c2a0000.rtc: registered as rtc1
[    2.979068] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:26 UTC (26)
[    2.986767] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    2.993030] i2c /dev entries driver
[    2.996465] tegra-i2c 3160000.i2c: Adding to iommu group 2
[    3.002216] tegra-i2c c240000.i2c: Adding to iommu group 2
[    3.007940] tegra-i2c 3180000.i2c: Adding to iommu group 2
[    3.012853] tegra-i2c 3190000.i2c: Adding to iommu group 2
[    3.018504] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[    3.023798] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[    3.029129] tegra-i2c c250000.i2c: Adding to iommu group 2
[    3.043453] device-mapper: uevent: version 1.0.3
[    3.043999] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[    3.049802] cpuidle: Initializing cpuidle driver
[    3.054040] sdhci: Secure Digital Host Controller Interface driver
[    3.058548] sdhci: Copyright(c) Pierre Ossman
[    3.062359] Synopsys Designware Multimedia Card Interface Driver
[    3.068846] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.075006] sdhci-tegra 3460000.sdhci: Adding to iommu group 3
[    3.075163] sdhci-tegra 3440000.sdhci: Adding to iommu group 4
[    3.075895] SMCCC: SOC_ID: ID = jep106:036b:0019 Revision = 0x00000102
[    3.076899] tegra-bpmp bpmp: firmware: 128431eec76692047e1ac1ebc0392266
[    3.092447] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[    3.115579] vdd-1v0: supplied by regulator-dummy
[    3.121186] vdd-1v8-hs: supplied by regulator-dummy
[    3.126057] vdd-1v8-ls: supplied by regulator-dummy
[    3.131038] vdd-1v8-ao: supplied by regulator-dummy
[    3.135017] vddio-ddr-1v1: supplied by regulator-dummy
[    3.139708] vdd-rtc: supplied by regulator-dummy
[    3.141523] spmic-ldo1: supplied by regulator-dummy
[    3.142858] vdd-ao-3v3: supplied by regulator-dummy
[    3.150586] vddio-emmc-3v3: supplied by regulator-dummy
[    3.156971] spmic-ldo4: supplied by regulator-dummy
[    3.158320] vdd-usb-3v3: supplied by regulator-dummy
[    3.165543] vddio-sdmmc1-3v3: supplied by regulator-dummy
[    3.171810] vdd-csi-1v2: supplied by vdd-1v8-ls
[    3.177460] spmic-ldo8: supplied by vdd-1v8-ls
[    3.178929] gpio-510 (gpio_default): hogged as output/high
[    3.180721] gpio-511 (gpio_default): hogged as output/high
[    3.187420] gpiochip0: registered GPIOs 504 to 511 on max77620-gpio
[    3.327054] max77686-rtc max77620-rtc: registered as rtc0
[    3.328393] max77620-power max20024-power: Event recorder REG_NVERC : 0x0
[    3.328725] max77620 4-003c: max77620 probe successful
��rm_rail_debugfs_init: /rm/vdd_cpu: failed
debugfs initialized
��[    4.201469] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[    4.202907] hid: raw HID events driver (C) Jiri Kosina
[    4.203852] usbcore: registered new interface driver usbhid
[    4.204011] usbhid: USB HID core driver
[    4.206247] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 5
[    4.207473] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
��[    27.791742] Camera-FW on t194-rce-safe started
TCU early console enabled.
[    27.866050] Camera-FW on t194-rce-safe ready SHA1=d48f1e27 (crt 0.781 ms, total boot 75.119 ms)
��[    4.291557] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[    4.292285] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[    4.293952] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[    4.295412] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[    4.297487] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[    4.298254] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[    4.299139] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[    4.300768] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (50)
[    4.301171] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[    4.303228] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=d48f1e279e6679b09020947e8de088eabfeaa475
[    4.307894] tegra_aon c1a0000.aon: Adding to iommu group 6
[    4.314248] tegra_aon c1a0000.aon: tegra aon driver probe OK
[    4.319516] tegra186-aondbg aondbg: aondbg driver probe() OK
[    4.326797] denver_knobs_init:MTS_VERSION:55637613
[    4.339377] t19x_cache tegra-cache: probed
[    4.341683] Clocks initialized successfully
[    4.343496] optee: probing for conduit method.
[    4.344396] optee: revision 3.16 (65cc2218)
[    4.345738] optee: dynamic shared memory is enabled
[    4.350825] optee: initialized driver
[    4.357473] nvpmodel: initialized successfully
[    4.358283] tegra_hv: get_hvd: not initialized yet
[    4.362964] user_ivc_mempool: hypervisor not present
[    4.368666] usbcore: registered new interface driver snd-usb-audio
[    4.375023] u32 classifier
[    4.376533]     input device check on
[    4.380253]     Actions configured
[    4.384139] Initializing XFRM netlink socket
[    4.389012] NET: Registered protocol family 10
[    4.396174] Segment Routing with IPv6
[    4.396489] NET: Registered protocol family 17
[    4.400766] NET: Registered protocol family 15
[    4.405079] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    4.419066] Bluetooth: RFCOMM socket layer initialized
[    4.423451] Bluetooth: RFCOMM ver 1.11
[    4.427321] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    4.432862] Bluetooth: HIDP socket layer initialized
[    4.439416] 9pnet: Installing 9P2000 support
[    4.442593] Key type dns_resolver registered
[    4.447992] registered taskstats version 1
[    4.450749] Loading compiled-in X.509 certificates
[    4.463180] Loaded X.509 cert 'Build time autogenerated kernel key: c3d66804619b817e74b28a23dda402b0986c24a3'
[    4.466864] tegra194-pcie 14160000.pcie: Adding to iommu group 7
[    4.477664] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[    4.479028] tegra194-pcie 14160000.pcie:       IO 0x0036100000..0x00361fffff -> 0x0036100000
[    4.487223] tegra194-pcie 14160000.pcie:      MEM 0x1400000000..0x173fffffff -> 0x1400000000
[    4.495853] tegra194-pcie 14160000.pcie:      MEM 0x1740000000..0x17ffffffff -> 0x0040000000
[    5.611309] tegra194-pcie 14160000.pcie: Phy link never came up
[    5.611997] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[    5.612215] pci_bus 0004:00: root bus resource [bus 00-ff]
[    5.612359] pci_bus 0004:00: root bus resource [io  0x0000-0xfffff] (bus address [0x36100000-0x361fffff])
[    5.612588] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[    5.612854] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[    5.613296] pci 0004:00:00.0: [10de:1ad1] type 01 class 0x060400
[    5.613729] pci 0004:00:00.0: PME# supported from D0 D3hot D3cold
[    5.632391] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[    5.632679] pci 0004:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    5.634862] pcieport 0004:00:00.0: Adding to iommu group 7
[    5.636183] pcieport 0004:00:00.0: PME: Signaling with IRQ 24
[    5.637633] pcieport 0004:00:00.0: AER: enabled with IRQ 24
[    5.639071] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[    5.639997] pci 0004:00:00.0: Removing from iommu group 7
[    5.640278] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[    5.643701] tegra194-pcie 141a0000.pcie: Adding to iommu group 8
[    5.648925] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[    5.649279] tegra194-pcie 141a0000.pcie:       IO 0x003a100000..0x003a1fffff -> 0x003a100000
[    5.649591] tegra194-pcie 141a0000.pcie:      MEM 0x1c00000000..0x1f3fffffff -> 0x1c00000000
[    5.656771] tegra194-pcie 141a0000.pcie:      MEM 0x1f40000000..0x1fffffffff -> 0x0040000000
[    5.770657] tegra194-pcie 141a0000.pcie: Link up
[    5.773447] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[    5.773695] pci_bus 0005:00: root bus resource [bus 00-ff]
[    5.773851] pci_bus 0005:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x3a100000-0x3a1fffff])
[    5.774149] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[    5.774340] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[    5.774784] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[    5.775186] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[    5.784743] pci 0005:01:00.0: [15b7:501a] type 00 class 0x010802
[    5.785199] pci 0005:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[    5.785700] pci 0005:01:00.0: reg 0x20: [mem 0x00000000-0x000000ff 64bit]
[    5.795747] pci 0005:00:00.0: BAR 14: assigned [mem 0x1f40000000-0x1f400fffff]
[    5.796206] pci 0005:01:00.0: BAR 0: assigned [mem 0x1f40000000-0x1f40003fff 64bit]
[    5.796605] pci 0005:01:00.0: BAR 4: assigned [mem 0x1f40004000-0x1f400040ff 64bit]
[    5.796979] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[    5.797171] pci 0005:00:00.0:   bridge window [mem 0x1f40000000-0x1f400fffff]
[    5.797484] pci 0005:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    5.800330] pci 0005:01:00.0: Max Payload Size set to  256/ 512 (was  128), Max Read Rq  512
[    5.810804] pcieport 0005:00:00.0: Adding to iommu group 8
[    5.815233] pcieport 0005:00:00.0: PME: Signaling with IRQ 26
[    5.821251] pcieport 0005:00:00.0: AER: enabled with IRQ 26
[    5.827716] nvme 0005:01:00.0: Adding to iommu group 8
[    5.832863] nvme nvme0: pci function 0005:01:00.0
[    5.835926] nvme 0005:01:00.0: enabling device (0000 -> 0002)
[    5.866392] host1x 13e10000.host1x: Adding to iommu group 9
[    5.879049] nvme nvme0: allocated 32 MiB host memory buffer.
[    5.884783] nvme nvme0: 6/0/0 default/read/poll queues
[    5.890676] host1x 13e10000.host1x: initialized
[    5.892864] iommu_context_dev 13e10000.host1x:ctx0: Adding to iommu group 10
[    5.893763] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[    5.894756] iommu_context_dev 13e10000.host1x:ctx1: Adding to iommu group 11
[    5.895495] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[    5.896350] iommu_context_dev 13e10000.host1x:ctx2: Adding to iommu group 12
[    5.896554]  nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9
[    5.903810] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[    5.918052] iommu_context_dev 13e10000.host1x:ctx3: Adding to iommu group 13
[    5.924674] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[    5.934633] iommu_context_dev 13e10000.host1x:ctx4: Adding to iommu group 14
[    5.941464] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[    5.951398] iommu_context_dev 13e10000.host1x:ctx5: Adding to iommu group 15
[    5.958779] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61, iommu=smmu.0x0000000012000000)
[    5.968647] iommu_context_dev 13e10000.host1x:ctx6: Adding to iommu group 16
[    5.975330] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62, iommu=smmu.0x0000000012000000)
[    5.985158] iommu_context_dev 13e10000.host1x:ctx7: Adding to iommu group 17
[    5.992521] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63, iommu=smmu.0x0000000012000000)
[    6.002520] falcon 15340000.vic: Adding to iommu group 18
[    6.016334] falcon 15340000.vic: initialized
[    6.017318] falcon 15380000.nvjpg: Adding to iommu group 18
[    6.022894] falcon 15380000.nvjpg: initialized
[    6.023427] falcon 154c0000.nvenc: Adding to iommu group 18
[    6.034832] falcon 154c0000.nvenc: initialized
[    6.035384] falcon 15a80000.nvenc1: Adding to iommu group 18
[    6.044954] falcon 15a80000.nvenc1: initialized
[    6.045524] nvdec 15480000.nvdec: Adding to iommu group 18
[    6.058626] nvdec 15480000.nvdec: initialized
[    6.059189] nvdec 15140000.nvdec1: Adding to iommu group 18
[    6.068537] nvdec 15140000.nvdec1: initialized
[    6.069123] tsec 15500000.tsec: Adding to iommu group 19
[    6.074389] tsec 15500000.tsec: initialized
[    6.074932] tsec 15100000.tsecb: Adding to iommu group 20
[    6.082178] tsec 15100000.tsecb: initialized
[    6.086101] gic 2a41000.agic-controller: GIC IRQ controller registered
[    6.111353] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[    6.122293] gpio-374 (wifi-enable): hogged as output/high
[    6.122695] gpio-431 (camera-control-output-low): hogged as output/low
[    6.122943] gpio-432 (camera-control-output-low): hogged as output/low
[    6.124660] gpiochip1: registered GPIOs 335 to 503 on tegra194-gpio
[    6.126112] gpiochip2: registered GPIOs 305 to 334 on tegra194-gpio-aon
[    6.127148] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    6.133826] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[    6.139000] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    6.144793] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[    6.150828] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[    6.158993] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[    6.166247] tegra194-isp5 13e10000.host1x:isp@14800000: Adding to iommu group 21
[    6.177822] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[    6.182895] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: initialized
[    6.188733] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e10000.host1x:nvcsi@15a00000- bound
[    6.197615] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e10000.host1x:nvcsi@15a00000- bound
[    6.206920] tegra194-vi5 15c10000.vi: Adding to iommu group 22
[    6.214179] scare-pigeon 13e10000.host1x:vi-thi@15f00000: context isolation disabled due to no IOMMU
[    6.221631] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[    6.227691] scare-pigeon 13e10000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[    6.237393] scare-pigeon 13e10000.host1x:isp-thi@14b00000: initialized
[    6.244042] pva 16000000.pva0: Adding to iommu group 23
[    6.269788] pva 16000000.pva0: initialized
[    6.274851] pva 16800000.pva1: Adding to iommu group 24
[    6.285637] pva 16800000.pva1: initialized
[    6.289855] nvdla 15880000.nvdla0: Adding to iommu group 25
[    6.310531] nvdla 15880000.nvdla0: initialized
[    6.312093] nvdla 158c0000.nvdla1: Adding to iommu group 26
[    6.321064] nvdla 158c0000.nvdla1: initialized
[    6.323592] tegradccommon 15200000.display-hub: host1x channel mapped
[    6.323861] tegradccommon 15200000.display-hub: dc_common syncpt # 1 allocated
[    6.324143] tegradccommon 15200000.display-hub: dma mapping done
[    6.325994] tegradc 15200000.display: Adding to iommu group 27
[    6.333281] tegradc 15200000.display: disp0 connected to head0->sor1
[    6.333640] generic_infoframe_type: 0x87
[    6.333890] tegradc 15200000.display: DT parsed successfully
[    6.334207] tegradc 15200000.display: Display dc.(____ptrval____) registered with id=0
[    6.336883] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=64
[    6.338233] tegradc 15210000.display: Adding to iommu group 27
[    6.339746] tegra_cec 3960000.tegra_cec: Unpowergated DISP
[    6.351396] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[    6.357615] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[    6.358813] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[    6.363485] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[    6.371377] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 933000000 Hz
[    6.371388] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[    6.372588] tegradc 15200000.display: vblank syncpt # 8 for dc 0
[    6.377223] tegra_cec 3960000.tegra_cec: probed
[    6.378164] tegra-gpcdma 2600000.dma: Adding to iommu group 2
[    6.385185] tegradc 15200000.display: vpulse3 syncpt # 9 for dc 0
[    6.386724] tegradc 15200000.display: Bootloader disp_param detected. Detected mode: 8x4 (on 0x0mm) pclk=148350937
[    6.395711] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[    6.402882] tegradc 15200000.display: hdmi: can't get adpater for ddc bus 3
[    6.404463] kfuse 3830000.kfuse: initialized
[    6.410307] tegradc 15200000.display: out->type:1 out_ops->init err = -517
[    6.416460] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[    6.428719] tegradc 15210000.display: disp0 connected to head1->sor
[    6.433164] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[    6.433993] serial-tegra 3100000.serial: Adding to iommu group 2
[    6.440336] tegradc 15210000.display: parse_dp_settings: No dp-lt-settings node
[    6.458037] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 31, base_baud = 0) is a TEGRA_UART
[    6.464517] tegradc 15210000.display: DT parsed successfully
[    6.472443] serial-tegra 3110000.serial: Adding to iommu group 2
[    6.476677] tegradc 15210000.display: dc.1 probe not in device tree order, deferring
[    6.498702] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 32, base_baud = 0) is a TEGRA_UART
[    6.522616] serial-tegra 3140000.serial: Adding to iommu group 2
[    6.527681] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 33, base_baud = 0) is a TEGRA_UART
[    6.546756] tegra-xusb 3610000.xhci: Firmware timestamp: 2022-03-16 11:07:43 UTC, Version: 60.13 release
[    6.547124] tegra-xusb 3610000.xhci: xHCI Host Controller
[    6.551017] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[    6.559183] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x0000000000050810
[    6.567859] tegra-xusb 3610000.xhci: irq 190, io mem 0x03610000
[    6.574609] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    6.581781] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.589230] usb usb1: Product: xHCI Host Controller
[    6.594194] usb usb1: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[    6.600491] usb usb1: SerialNumber: 3610000.xhci
[    6.606211] hub 1-0:1.0: USB hub found
[    6.608962] hub 1-0:1.0: 4 ports detected
[    6.614185] tegra-xusb 3610000.xhci: xHCI Host Controller
[    6.618594] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[    6.625847] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[    6.633554] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    6.641650] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.648890] usb usb2: Product: xHCI Host Controller
[    6.653610] usb usb2: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[    6.659834] usb usb2: SerialNumber: 3610000.xhci
[    6.666015] hub 2-0:1.0: USB hub found
[    6.668808] hub 2-0:1.0: 4 ports detected
[    6.709432] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[    6.714009] gpiochip3: registered GPIOs 297 to 304 on pcf8574a
[    6.714257] pcf857x 8-0038: probed
[    6.716215] i2c i2c-2: Added multiplexed i2c bus 9
[    6.717161] i2c i2c-2: Added multiplexed i2c bus 10
[    6.717341] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[    6.730182] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1895000 KHz, changing to: 1907200 KHz
[    6.731399] tegra194-cpufreq ccplex: probed with BWMGR
[    6.733054] sdhci-tegra 3460000.sdhci: BWMGR client registration for eMC Successful
[    6.733401] irq: IRQ271: trimming hierarchy from :pmc@c360000
[    6.734008] sdhci-tegra 3440000.sdhci: BWMGR client registration for eMC Successful
[    6.734058] usb-conn-gpio 3520000.xusb_padctl:ports:usb2-0:connector: repeated role: 0
[    6.735457] tegra194-isp5 13e10000.host1x:isp@14800000: initialized
[    6.740666] tegra194-vi5 15c10000.vi: initialized
[    6.744728] mmc0: CQHCI version 5.10
[    6.763825] tegradc 15200000.display: disp0 connected to head0->sor1
[    6.764562] nvethernet 2490000.ethernet: Adding to iommu group 28
[    6.769512] generic_infoframe_type: 0x87
[    6.775812] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[    6.778707] nvethernet 2490000.ethernet: failed to read skip mac reset flag, default 0
[    6.778713] nvethernet 2490000.ethernet: failed to read MDIO address
[    6.778720] nvethernet 2490000.ethernet: setting to default DMA bit mask
[    6.778725] nvethernet 2490000.ethernet: set default TXQ to TC mapping
[    6.778729] nvethernet 2490000.ethernet: Setting default PTP RX queue
[    6.779772] tegradc 15200000.display: DT parsed successfully
[    6.827344] tegradc 15200000.display: Display dc.(____ptrval____) registered with id=0
[    6.828290] nvethernet 2490000.ethernet: failed to get eqos_rx_m clk
[    6.836013] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[    6.841471] nvethernet 2490000.ethernet: failed to get eqos_rx_input clk
[    6.841478] nvethernet 2490000.ethernet: failed to get eqos_tx_divider clk
[    6.841962] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit
[    6.849991] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 933000000 Hz
[    6.879709] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[    6.880985] nvethernet 2490000.ethernet: Ethernet MAC address: 48:b0:2d:03:51:96
[    6.886486] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[    6.888086] tegradc 15200000.display: vblank syncpt # 11 for dc 0
[    6.901856] tegradc 15200000.display: vpulse3 syncpt # 12 for dc 0
[    6.914010] nvethernet 2490000.ethernet: Macsec not supported
[    6.914231] tegradc 15200000.display: Bootloader disp_param detected. Detected mode: 8x4 (on 0x0mm) pclk=148350937
[    6.921174] nvethernet 2490000.ethernet: eth0 (HW ver: 50) created with 1 DMA channels
[    6.931444] tegradc 15200000.display: hdmi: invalid prod list prod_list_hdmi_board
[    6.939041] irq: IRQ273: trimming hierarchy from :pmc@c360000
[    6.945593] tegradc 15200000.display: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[    6.955945] CPU:0, Error:cbb-noc@0x2300000,irq=15
[    6.956177] irq: IRQ274: trimming hierarchy from :interrupt-controller@3881000
[    6.959213] **************************************
[    6.959217] CPU:0, Error:cbb-noc
[    6.959221] 	Error Logger		: 0
[    6.959230] 	ErrLog0			: 0x80030000
[    6.959233] 	  Transaction Type	: RD  - Read, Incrementing
[    6.959236] 	  Error Code		: SLV
[    6.959242] 	  Error Source		: Target
[    6.963640] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    6.970771] 	  Error Description	: Target error detected by CBB slave
[    6.970781] 	  AXI2APB_5 bridge error: RDFIFOF - Read Response FIFO Full interrupt
[    6.970787] 	  Packet header Lock	: 0
[    6.970789] 	  Packet header Len1	: 3
[    6.970792] 	  NOC protocol version	: version >= 2.7
[    6.970795] 	ErrLog1			: 0x352424
[    6.970797] 	ErrLog2			: 0x0
[    6.970800] 	  RouteId		: 0x352424
[    6.970803] 	  InitFlow		: ccroc_p2ps/I/ccroc_p2ps
[    6.970810] 	  Targflow		: host1x_p2pm/T/host1x_p2pm
[    6.976710] tegra-se-nvhost 15810000.se: Adding to iommu group 29
[    6.978994] 	  TargSubRange		: 18
[    6.978998] 	  SeqId			: 0
[    6.979001] 	ErrLog3			: 0x4045c
[    6.979004] 	ErrLog4			: 0x0
[    6.979008] 	  Address accessed	: 0x15b4045c
[    6.979011] 	ErrLog5			: 0x909f851
[    6.979014] 	  Non-Modify		: 0x1
[    6.979016] 	  AXI ID		: 0x12
[    6.979019] 	  Master ID		: CCPLEX
[    6.979022] 	  Security Group(GRPSEC): 0x7e
[    6.979025] 	  Cache			: 0x1 -- Bufferable
[    6.979047] 	  Protection		: 0x2 -- Unprivileged, Non-Secure, Data Access
[    7.102109] 	  FALCONSEC		: 0x0
[    7.105254] 	  Virtual Queuing Channel(VQC): 0x0
[    7.109725] 	**************************************
[    7.114843] ------------[ cut here ]------------
[    7.119517] kernel BUG at drivers/soc/tegra/cbb/tegra194-cbb.c:1896!
[    7.125906] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
[    7.131156] Modules linked in:
[    7.134145] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 5.10.104-tegra #2
[    7.140781] Hardware name: Unknown NVIDIA Jetson Xavier NX for DSBOARD-NX2 (rev-1.22)/NVIDIA Jetson Xavier NX for DSBOARD-NX2 (rev-1.22), BIOS 1.0-d7fb19b
[    7.154363] pstate: 60400089 (nZCv daIf +PAN -UAO -TCO BTYPE=--)
[    7.160387] pc : tegra194_cbb_err_isr+0x188/0x1a0
[    7.164849] lr : tegra194_cbb_err_isr+0x10c/0x1a0
[    7.169851] sp : ffff800010003b30
[    7.173245] x29: ffff800010003b30 x28: 0000000000000001
[    7.178409] x27: 0000000000000005 x26: ffffc80a3eb867b0
[    7.183834] x25: ffffc80a3f4ece10 x24: 0000000000000001
[    7.189258] x23: ffffc80a3ee77000 x22: ffffc80a3f30eaf8
[    7.194870] x21: 000000000000000f x20: ffff20e240ea6e80
[    7.200021] x19: ffffc80a3f30eaf8 x18: 0000000000000010
[    7.205792] x17: 0000000000000007 x16: 00000000829f6d71
[    7.211128] x15: ffffc80a3f182bf0 x14: 0720072007200720
[    7.216641] x13: 0720072007200720 x12: 0720072007200720
[    7.222153] x11: 0720072007200720 x10: 0720072007200720
[    7.227668] x9 : 0720072007200720 x8 : 07200720072a072a
[    7.233178] x7 : 072a072a072a072a x6 : c0000000ffffefff
[    7.238691] x5 : 0000000000057fa8 x4 : ffffc80a3f197968
[    7.244116] x3 : 00000000ffffffff x2 : ffffc80a3d647380
[    7.249454] x1 : ffffc80a3f182680 x0 : 0000000000010101
[    7.254534] Call trace:
[    7.257259]  tegra194_cbb_err_isr+0x188/0x1a0
[    7.261277]  __handle_irq_event_percpu+0x60/0x2a0
[    7.266000]  handle_irq_event_percpu+0x3c/0xa0
[    7.270545]  handle_irq_event+0x4c/0xf0
[    7.274315]  handle_fasteoi_irq+0xbc/0x170
[    7.278353]  generic_handle_irq+0x3c/0x60
[    7.282099]  __handle_domain_irq+0x6c/0xc0
[    7.286300]  efi_header_end+0xa8/0xf0
[    7.290073]  el1_irq+0xd0/0x180
[    7.293031]  __do_softirq+0xb0/0x3e0
[    7.296451]  irq_exit+0xc0/0xe0
[    7.299438]  __handle_domain_irq+0x70/0xc0
[    7.303705]  efi_header_end+0xa8/0xf0
[    7.307379]  el1_irq+0xd0/0x180
[    7.310101]  cpuidle_enter_state+0xb4/0x400
[    7.314124]  cpuidle_enter+0x3c/0x50
[    7.317798]  call_cpuidle+0x40/0x70
[    7.321554]  do_idle+0x1fc/0x260
[    7.324792]  cpu_startup_entry+0x2c/0x70
[    7.328645]  rest_init+0xd8/0xe4
[    7.331816]  arch_call_rest_init+0x14/0x1c
[    7.336255]  start_kernel+0x50c/0x540
[    7.339593] Code: a9425bf5 a9446bf9 a8c77bfd d65f03c0 (d4210000)
[    7.345821] ---[ end trace c1094497cef3c933 ]---
[    7.350347] Kernel panic - not syncing: Oops - BUG: Fatal exception in interrupt
[    7.358129] SMP: stopping secondary CPUs
[    7.361991] Kernel Offset: 0x480a2d490000 from 0xffff800010000000
[    7.368297] PHYS_OFFSET: 0xffffdf1ec0000000
[    7.372398] CPU features: 0x8240002,03802a30
[    7.376596] Memory Limit: none
[    7.380009] ---[ end Kernel panic - not syncing: Oops - BUG: Fatal exception in interrupt ]---
And my first problem occurred again after i did that changes.
[0000.024] W> RATCHET: MB1 binary ratchet value 4 is larger than ratchet level 2 from HW fuses.
[0000.032] I> MB1 (prd-version: 2.3.0.0-t194-41334769-0a17edc1)
[0000.038] I> Boot-mode: Coldboot
[0000.041] I> Platform: Silicon
[0000.044] I> Chip revision : A02P
[0000.047] I> Bootrom patch version : 15 (correctly patched)
[0000.052] I> ATE fuse revision : 0x200
[0000.055] I> Ram repair fuse : 0x0
[0000.058] I> Ram Code : 0x0
[0000.061] I> rst_source: 0xb, rst_level: 0x1
[0000.066] I> Boot-device: QSPI (instance: 0)
[0000.070] I> Qspi flash params source = brbct
[0000.074] I> Qspi clock source : pllp
[0000.077] I> Qspi-0 initialized successfully
[0000.081] I> Boot chain mechanism: A/B
[0000.085] I> Current Boot-Chain Slot: 0
[0000.088] I> BR-BCT Boot-Chain: 0, status: 0. update flag: 0
[0000.093] I> Qspi flash params source = brbct
[0000.100] W> PROD_CONFIG: device prod data is empty in MB1 BCT.
[0000.106] I> Temperature = 43000
[0000.109] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.113] W> Skipping boost for clk: BPMP_APB
[0000.117] W> Skipping boost for clk: AXI_CBB
[0000.121] W> Skipping boost for clk: AON_CPU_NIC
[0000.125] W> Skipping boost for clk: CAN1
[0000.129] W> Skipping boost for clk: CAN2
[0000.133] I> Boot-device: QSPI (instance: 0)
[0000.137] I> Qspi flash params source = mb1bct
[0000.141] I> Qspi clock source : pllc_out0
[0000.145] I> Qspi-0 reinitialized
[0000.148] I> Qspi flash params source = mb1bct
[0000.161] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.168] W>  Thermal config not found in BCT
[0000.176] W>  MEMIO rail config not found in BCT
[0000.186] I> Qspi flash params source = mb1bct
[0000.200] I> Qspi flash params source = mb1bct
[0000.234] I> Qspi flash params source = mb1bct
[0000.797] I> Qspi flash params source = mb1bct
[0000.814] I> Qspi flash params source = mb1bct
[0000.853] W>  Platform config not found in BCT
[0000.880] I> Qspi flash params source = mb1bct
[0000.906] I> MB1 done
����main enter
SPE VERSION #: R01.00.18 Created: Jan 29 2021 @ 14:18:27
HW Function test
Start Scheduler.
in late init
  [0000.915] I> Welcome to MB2(TBoot-BPMP) (version: default.t194-mobile-1ca012e4)
[0000.916] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.916] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.917] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.923] W> device prod register failed
[0000.927] I> gpio framework initialized
[0000.930] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0000.938] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0000.945] I> No valid sdcard_params in mb1_bct
[0000.950] I> Boot_device: QSPI_FLASH instance: 0
[0000.954] I> qspi flash-0 params source = boot args
[0000.960] I> QSPI-0l initialized successfully
[0000.963] I> sdmmc-3 params source = safe params
[0001.306] I> sdmmc DDR50 mode
[0001.324] I> Found 41 partitions in QSPI_FLASH (instance 0)
[0001.341] W> Cannot find any partition table for 00000003
[0001.342]  > PARTITION_MANAGER: Failed to publish partition.
[0001.357] I> Found 19 partitions in SDMMC_USER (instance 3)
[0001.358] I> Active Boot chain : 0
[0002.030] I> Relocating BR-BCT
[0002.031]  > DEVICE_PROD: device prod is not initialized.
[0002.057] E> I2C: slave not found in slaves.
[0002.058] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0002.059] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.060] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 0.
[0002.061] E> eeprom: Failed to read I2C slave device
[0002.064] I> Failed to read CVB eeprom data @ AE
[0002.068] I> Retrying CVB eeprom read @ AC ...
[0002.073] E> I2C: slave not found in slaves.
[0002.077] E> I2C: Could not write 0 bytes to slave: 0x00ac with repeat start true.
[0002.085] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.091] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xac at 0x00000000 via instance 0.
[0002.100] E> eeprom: Failed to read I2C slave device
[0002.105] I> Failed to read CVB eeprom data @ AC
[0002.366] I> Relocating OP-TEE dtb from: 0x6bfff1d0 to 0x70050000, size: 1008
[0002.367] I> [0] START: 0x80000000, SIZE: 0x2f000000
[0002.367] I> [1] START: 0xaf010000, SIZE: 0x18bf0000
[0002.368] I> [2] START: 0xc7d00000, SIZE: 0xc0000
[0002.368] I> [3] START: 0xca000000, SIZE: 0x800000
[0002.369] I> dram_block larger than 80000000
[0002.371] I> [4] START: 0x100000000, SIZE: 0x180000000
[0002.382] I> Setting NS memory ranges to OP-TEE dtb finished.
[0002.386] I> found decompressor handler: lz4
[0002.615] I> EKB detected (length: 0x410) @ VA:0x52709400
[0002.616] I> Setting EKB blob info to OPTEE dtb finished.
��NOTICE:  BL31: v2.6(release):4fa405dbd
NOTICE:  BL31: Built : 20:16:55, Aug 10 2022
I/TC:
  bpmp: init
bpmp: tag is 128431eec76692047e1ac1ebc0392266
sku_dt_init: not sku 0x00
��I��clk_early initialized
��/TC: ��mail_early initialized
��N��fuse initialized
hwwdt initialized
��on-se��t194_ec_get_ec_list: found 45 ecs
��cure extern��ec initialized
vmon_setup_monitors: found 3 monitors
vmon initialized
��al ��adc initialized
��D��fmon_populate_monitors: found 73 monitors
��T found
��fmon initialized
mc initialized
reset initialized
nvhs initialized
uphy_early initialized
emc_early initialized
392 clocks registered
clk initialized
io_dpd initialized
thermal initialized
thermal_mrq initialized
i2c initialized
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
vrmon initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
suspend initialized
pg_late initialized
pg_mrq_init initialized
strap initialized
nvl initialized
emc initialized
emc_mrq initialized
clk_dt initialized
tj_init initialized
uphy_dt initialized
uphy_mrq initialized
uphy initialized
ec_swd_poll_start: 281 reg polling start w period 47 ms
ec_late initialized
hwwdt_late initialized
reset_mrq initialized
ec_mrq initialized
fmon_mrq initialized
clk_mrq initialized
avfs_mrq initialized
mail_mrq initialized
i2c_mrq initialized
tag_mrq initialized
console_mrq initialized
mrq initialized
clk_sync_fmon_post initialized
��I/TC: OP-TEE version: 3.16 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Thu Au��clk_dt_late initialized
noc_late initialized
��g��pm_post initialized
dbells initialized
�� 11��dmce initialized
�� ��cvc initialized
��03:23:20 UTC��avfs_clk_mach_post initialized
�� 202��avfs_clk_platform_post initialized
��2 a��cvc_late initialized
regulator_post initialized
��arch��rm initialized
console_late initialized
clk_dt_post initialized
mc_reg initialized
��64
I/TC: WARNIN��pg_post initialized
profile initialized
fuse_late initialized
extras_post initialized
bpmp: init complete
entering main console loop
] ��G: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: Primary CPU switching to normal world boot
  [0003.235] I> Welcome to NVDisp-Init
[0003.235] I> NVDisp-Init version: t194-f9ecfedc
[0003.236] I> CPU-BL Params @ 0xca020000
[0003.236] I>  0) Base:0x00000000 Size:0x00000000
[0003.236] I>  1) Base:0xc8300000 Size:0x00100000
[0003.236] I>  2) Base:0xc9800000 Size:0x00200000
[0003.237] I>  3) Base:0xc8600000 Size:0x00200000
[0003.239] I>  4) Base:0xc8200000 Size:0x00100000
[0003.244] I>  5) Base:0xc8100000 Size:0x00100000
[0003.248] I>  6) Base:0xc9400000 Size:0x00400000
[0003.253] I>  7) Base:0xc9000000 Size:0x00400000
[0003.257] I>  8) Base:0xc8000000 Size:0x00100000
[0003.262] I>  9) Base:0xc7f00000 Size:0x00100000
[0003.266] I> 10) Base:0xca800000 Size:0x00800000
[0003.271] I> 11) Base:0x40000000 Size:0x00040000
[0003.275] I> 12) Base:0xc7e00000 Size:0x00100000
[0003.279] I> 13) Base:0x40046000 Size:0x00002000
[0003.284] I> 14) Base:0x40048000 Size:0x00002000
[0003.288] I> 15) Base:0xaf000000 Size:0x00004000
[0003.293] I> 16) Base:0x4004a000 Size:0x00002000
[0003.297] I> 17) Base:0xc7c00000 Size:0x00100000
[0003.302] I> 18) Base:0x4004c000 Size:0x00002000
[0003.306] I> 19) Base:0xc9a00000 Size:0x00600000
[0003.311] I> 20) Base:0x4004e000 Size:0x00002000
[0003.315] I> 21) Base:0xc7dc0000 Size:0x0000c000
[0003.320] I> 22) Base:0x00000000 Size:0x00000000
[0003.324] I> 23) Base:0xc7de0000 Size:0x00020000
[0003.329] I> 24) Base:0xcc000000 Size:0x02000000
[0003.333] I> 25) Base:0x40050000 Size:0x00002000
[0003.337] I> 26) Base:0x40040000 Size:0x00006000
[0003.342] I> 27) Base:0xc8c00000 Size:0x00400000
[0003.346] I> 28) Base:0xc8400000 Size:0x00200000
[0003.351] I> 29) Base:0xc8800000 Size:0x00400000
[0003.355] I> 30) Base:0xc7dd0000 Size:0x00010000
[0003.360] I> 31) Base:0x00000000 Size:0x00000000
[0003.364] I> 32) Base:0xf8000000 Size:0x08000000
[0003.369] I> 33) Base:0xce000000 Size:0x2a000000
[0003.373] I> 34) Base:0xcb000000 Size:0x01000000
[0003.378] I> 35) Base:0xae000000 Size:0x01000000
[0003.382] I> 36) Base:0xa0000000 Size:0x0e000000
[0003.387] I> 37) Base:0xca000000 Size:0x00800000
[0003.391] I> 38) Base:0x80000000 Size:0x20000000
[0003.395] I> 39) Base:0xb0000000 Size:0x08000000
[0003.400] I> 40) Base:0x00000000 Size:0x00000000
[0003.404] I> 41) Base:0x00000000 Size:0x00000000
[0003.409] I> 42) Base:0x00000000 Size:0x00000000
[0003.413] I> 43) Base:0x00000000 Size:0x00000000
[0003.418] I> 44) Base:0x00000000 Size:0x00000000
[0003.422] I> 45) Base:0x00000000 Size:0x00000000
[0003.427] GIC-SPI Target CPU: 0
[0003.430] Interrupts Init done
[0003.433] calling constructors
[0003.435] initializing heap
[0003.438] I> Heap: [0xa0960000 ... 0xadf00000]
[0003.442] initializing threads
[0003.445] initializing timers
[0003.448] creating bootstrap completion thread
[0003.452] top of bootstrap2()
[0003.455] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0003.460] initializing platform
[0003.463] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0003.468] W> device prod register failed
[0003.472] I> Bl_dtb @0xadf00000
[0003.475] I> gpio framework initialized
[0003.487] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0003.492] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0003.497] I> fixed regulator driver initialized
[0003.512] I> register 'maxim' power off handle
[0003.514] I> virtual i2c enabled
[0003.514] I> registered 'maxim,max20024' pmic
[0003.514] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0003.516] I> Boot-device: QSPI
[0003.519] I> Boot_device: QSPI_FLASH instance: 0
[0003.524] I> configure_qspi_clk: qparams clk_src = 5, clk_div = 0, clk_src_freq = 800000000, interface_freq = 50000000
[0003.534] I> configure_qspi_clk: FORCING INTERFACE_FREQ TO 133000000!!
[0003.542] I> QSPI source rate = 204000 Khz
[0003.545] I> Requested rate for QSPI clock = 34000 Khz
[0003.550] I> BPMP-set rate for QSPI clk = 34000 Khz
[0003.555] I> tx_clk_tap_delay : 0
[0003.557] I> rx_clk_tap_delay : 16
[0003.561] I> QSPI Flash Size = 32 MB
[0003.569] I> Qspi initialized successfully
[0003.569] I> qspi flash-0 params source = boot args
[0003.573] W> No board IDs available
[0003.576] E> Failed to get board id info!
[0003.582] I> sdmmc-3 params source = safe params
[0003.589] I> Found 41 partitions in QSPI_FLASH (instance 0)
[0003.591] W> Cannot find any partition table for 00000003
[0003.595] E> Failed to publish 00000003
[0003.600] I> Found 19 partitions in SDMMC_USER (instance 3)
[0003.622] I> regulator 'vdd-hdmi-5v0' already enabled
[0003.629] I> regulator 'vdd-hdmi-5v0' already enabled
[0003.629] I> hdmi cable connected
[0003.634] W> set volts not configured for 'vdd-1v0'
[0003.640] W> set volts not configured for 'vdd-1v8-hs'
[0003.640] I> retrieved tmds range from prod_list_hdmi_soc
[0003.647] E> invalid display type
[0003.648] E> cannot find any other nvdisp nodes
[0003.665] I> edid read success
[0003.677] I> edid read success
[0003.677] I> width = 640, height = 480, frequency = 25174825
[0003.678] I> width = 640, height = 480, frequency = 25174825
[0003.678] I> width = 1920, height = 1080, frequency = 148500000
[0003.679] I> width = 1920, height = 1080, frequency = 148500000
[0003.679] I> width = 1920, height = 1080, frequency = 148351648
[0003.683] I> width = 1280, height = 720, frequency = 74175824
[0003.689] I> width = 720, height = 480, frequency = 26973026
[0003.694] I> width = 720, height = 480, frequency = 26973026
[0003.700] I> width = 640, height = 480, frequency = 25174825
[0003.705] I> width = 1920, height = 1080, frequency = 148351648
[0003.711] I> width = 720, height = 576, frequency = 26973026
[0003.717] I> width = 1280, height = 720, frequency = 74175824
[0003.722] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0003.734] I> hdmi_enable, starting HDMI initialisation
[0003.739] I> hdmi_enable, HDMI initialisation complete
[0003.748] initializing target
[0003.749] calling apps_init()
[0003.750] starting app kernel_boot_app
[0003.750] I> Kernel type = Normal
Jetson UEFI firmware (version 1.0-d7fb19b built on 2022-08-10T20:18:13-07:00)
**  WARNING: Test Key is used.  **
L4TLauncher: Attempting GRUB Boot
L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map...
��I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
��[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x4e0f0040]
[    0.000000] Linux version 5.10.104-tegra (ubuntu@ubuntu-desktop) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #2 SMP PREEMPT Tue Oct 18 12:07:52 +03 2022
[    0.000000] Machine model: NVIDIA Jetson Xavier NX for DSBOARD-NX2 (rev-1.22)
[    0.000000] efi: EFI v2.70 by EDK II
[    0.000000] efi: RTPROP=0x27757c518 SMBIOS=0xc7db0000 SMBIOS 3.0=0x258980000 MEMATTR=0x25943d018 ESRT=0x25944f398 RNG=0x27c595918 MEMRESERVE=0x25943ef18
[    0.000000] efi: seeding entropy pool
[    0.000000] esrt: Reserving ESRT space from 0x000000025944f398 to 0x000000025944f3d0.
[    0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb3_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x000000027fffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000a0973fff]
[    0.000000]   node   0: [mem 0x00000000a0974000-0x00000000a0975fff]
[    0.000000]   node   0: [mem 0x00000000a0977000-0x00000000aeffffff]
[    0.000000]   node   0: [mem 0x00000000af010000-0x00000000c7bfffff]
[    0.000000]   node   0: [mem 0x00000000c7d00000-0x00000000c7d9ffff]
[    0.000000]   node   0: [mem 0x00000000c7da0000-0x00000000c7dbffff]
[    0.000000]   node   0: [mem 0x00000000ca000000-0x00000000ca5fffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x00000002577affff]
[    0.000000]   node   0: [mem 0x00000002577b0000-0x00000002577dffff]
[    0.000000]   node   0: [mem 0x00000002577e0000-0x0000000257c8ffff]
[    0.000000]   node   0: [mem 0x0000000257c90000-0x00000002584fffff]
[    0.000000]   node   0: [mem 0x0000000258500000-0x0000000258526fff]
[    0.000000]   node   0: [mem 0x0000000258527000-0x00000002586eefff]
[    0.000000]   node   0: [mem 0x00000002586ef000-0x000000025896ffff]
[    0.000000]   node   0: [mem 0x0000000258970000-0x000000025898ffff]
[    0.000000]   node   0: [mem 0x0000000258990000-0x000000025920ffff]
[    0.000000]   node   0: [mem 0x0000000259210000-0x000000025939ffff]
[    0.000000]   node   0: [mem 0x00000002593a0000-0x000000025944ffff]
[    0.000000]   node   0: [mem 0x0000000259450000-0x000000025961ffff]
[    0.000000]   node   0: [mem 0x0000000259620000-0x000000025962ffff]
[    0.000000]   node   0: [mem 0x0000000259630000-0x00000002596fffff]
[    0.000000]   node   0: [mem 0x0000000259700000-0x000000025978ffff]
[    0.000000]   node   0: [mem 0x0000000259790000-0x0000000259aaffff]
[    0.000000]   node   0: [mem 0x0000000259ab0000-0x0000000259abffff]
[    0.000000]   node   0: [mem 0x0000000259ac0000-0x0000000259b2ffff]
[    0.000000]   node   0: [mem 0x0000000259b30000-0x0000000259fbffff]
[    0.000000]   node   0: [mem 0x0000000259fc0000-0x000000025a00ffff]
[    0.000000]   node   0: [mem 0x000000025a010000-0x000000025a1cffff]
[    0.000000]   node   0: [mem 0x000000025a1d0000-0x000000025a26ffff]
[    0.000000]   node   0: [mem 0x000000025a270000-0x000000025a31ffff]
[    0.000000]   node   0: [mem 0x000000025a320000-0x000000025a3bffff]
[    0.000000]   node   0: [mem 0x000000025a3c0000-0x000000025a44ffff]
[    0.000000]   node   0: [mem 0x000000025a450000-0x000000025a4effff]
[    0.000000]   node   0: [mem 0x000000025a4f0000-0x000000025adbffff]
[    0.000000]   node   0: [mem 0x000000025adc0000-0x000000025af9ffff]
[    0.000000]   node   0: [mem 0x000000025afa0000-0x000000027c54ffff]
[    0.000000]   node   0: [mem 0x000000027c550000-0x000000027c59ffff]
[    0.000000]   node   0: [mem 0x000000027c5a0000-0x000000027fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000027fffffff]
[    0.000000] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.000000] cma: Reserved 64 MiB at 0x00000000c3c00000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 32 pages/cpu s90136 r8192 d32744 u131072
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] CPU features: detected: Spectre-v2
[    0.000000] CPU features: detected: NVIDIA Carmel CNP erratum
[    0.000000] alternatives: patching kernel code
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1839268
[    0.000000] Kernel command line: root=/dev/nvme0n1p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000b3c00000-0x00000000c3c00000] (256MB)
[    0.000000] Memory: 6933116K/7473852K available (18176K kernel code, 3174K rwdata, 7216K rodata, 4032K init, 1095K bss, 475200K reserved, 65536K cma-reserved)
[    0.000000] random: get_random_u64 called from __kmem_cache_create+0x34/0x420 with crng_init=0
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Rude variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000004] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.000696] Console: colour dummy device 80x25
[    0.001972] printk: console [tty0] enabled
[    0.002031] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.002063] pid_max: default: 32768 minimum: 301
[    0.002231] LSM: Security Framework initializing
[    0.002284] Yama: becoming mindful.
[    0.002330] SELinux:  Initializing.
[    0.002473] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.002509] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.005620] rcu: Hierarchical SRCU implementation.
[    0.005846] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[    0.006757] DTS File Name: /media/ubuntu/Extra/forecr_kernel_sources/jetpack-502-bsp/forecr_xavier_kernel/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-dsboard-nx2-0000.dts
[    0.006813] DTB Build time: Oct  3 2022 15:11:39
[    0.009558] Tegra Revision: A02 SKU: 0xde CPU Process: 0 SoC Process: 0
[    0.009823] Remapping and enabling EFI services.
[    0.011775] smp: Bringing up secondary CPUs ...
[    0.040921] Detected PIPT I-cache on CPU1
[    0.041022] CPU1: Booted secondary processor 0x0000000001 [0x4e0f0040]
[    0.075303] Detected PIPT I-cache on CPU2
[    0.075444] CPU2: Booted secondary processor 0x0000000100 [0x4e0f0040]
[    0.105038] Detected PIPT I-cache on CPU3
[    0.105164] CPU3: Booted secondary processor 0x0000000101 [0x4e0f0040]
[    0.134776] Detected PIPT I-cache on CPU4
[    0.134872] CPU4: Booted secondary processor 0x0000000200 [0x4e0f0040]
[    0.164557] Detected PIPT I-cache on CPU5
[    0.164735] CPU5: Booted secondary processor 0x0000000201 [0x4e0f0040]
[    0.165149] smp: Brought up 1 node, 6 CPUs
[    0.165280] SMP: Total of 6 processors activated.
[    0.165318] CPU features: detected: Privileged Access Never
[    0.165339] CPU features: detected: LSE atomic instructions
[    0.165351] CPU features: detected: User Access Override
[    0.165363] CPU features: detected: 32-bit EL0 Support
[    0.165374] CPU features: detected: RAS Extension Support
[    0.165385] CPU features: detected: CRC32 instructions
[    0.165397] CPU features: detected: 32-bit EL1 Support
[    0.238645] CPU: All CPU(s) started at EL2
[    0.244067] devtmpfs: initialized
[    0.288485] Registered cp15_barrier emulation handler
[    0.288607] Registered setend emulation handler
[    0.288630] KASLR enabled
[    0.288884] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.288905] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.290192] pinctrl core: initialized pinctrl subsystem
[    0.291219] SMBIOS 3.0.0 present.
[    0.291258] DMI: Unknown NVIDIA Jetson Xavier NX for DSBOARD-NX2 (rev-1.22)/NVIDIA Jetson Xavier NX for DSBOARD-NX2 (rev-1.22), BIOS 1.0-d7fb19b
[    0.291814] NET: Registered protocol family 16
[    0.293615] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.294139] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.295074] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.295127] audit: initializing netlink subsys (disabled)
[    0.295403] audit: type=2000 audit(0.292:1): state=initialized audit_enabled=0 res=1
[    0.295829] thermal_sys: Registered thermal governor 'step_wise'
[    0.295836] thermal_sys: Registered thermal governor 'power_allocator'
[    0.295851] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[    0.298215] cpuidle: using governor menu
[    0.298533] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.298959] ASID allocator initialised with 32768 entries
[    0.299160] Serial: AMBA PL011 UART driver
[    0.302008] Tegra reboot handler registered.
[    0.370396] tegra19x-cbb 2300000.cbb-noc: axi2apb bridge info present
[    0.370538] tegra19x-cbb 2300000.cbb-noc: secure_irq = 15, nonsecure_irq = 14>
[    0.370722] tegra19x-cbb c600000.aon-noc: axi2apb bridge info present
[    0.370770] tegra19x-cbb c600000.aon-noc: secure_irq = 17, nonsecure_irq = 16>
[    0.370900] tegra19x-cbb d600000.bpmp-noc: axi2apb bridge info present
[    0.370942] tegra19x-cbb d600000.bpmp-noc: secure_irq = 19, nonsecure_irq = 18>
[    0.371051] tegra19x-cbb be00000.rce-noc: axi2apb bridge info present
[    0.371092] tegra19x-cbb be00000.rce-noc: secure_irq = 21, nonsecure_irq = 20>
[    0.371238] tegra19x-cbb b600000.sce-noc: axi2apb bridge info present
[    0.371280] tegra19x-cbb b600000.sce-noc: secure_irq = 23, nonsecure_irq = 22>
[    0.373273] mc: mapped MMIO address: 0xffff800010580000 -> 0x2c10000
[    0.373304] mc: mapped MMIO address: 0xffff8000105a0000 -> 0x2c20000
[    0.373330] mc: mapped MMIO address: 0xffff8000105c0000 -> 0x2c30000
[    0.373355] mc: mapped MMIO address: 0xffff8000105e0000 -> 0x2c40000
[    0.373381] mc: mapped MMIO address: 0xffff800010600000 -> 0x2c50000
[    0.373407] mc: mapped MMIO address: 0xffff800010620000 -> 0x2b80000
[    0.373446] mc: mapped MMIO address: 0xffff800010640000 -> 0x2b90000
[    0.373474] mc: mapped MMIO address: 0xffff800010660000 -> 0x2ba0000
[    0.373504] mc: mapped MMIO address: 0xffff800010680000 -> 0x2bb0000
[    0.373526] mc: mapped MMIO address: 0xffff8000106a0000 -> 0x1700000
[    0.373547] mc: mapped MMIO address: 0xffff8000106c0000 -> 0x1710000
[    0.373585] mc: mapped MMIO address: 0xffff8000106e0000 -> 0x1720000
[    0.373607] mc: mapped MMIO address: 0xffff800010700000 -> 0x1730000
[    0.373645] mc: mapped MMIO address: 0xffff800010720000 -> 0x1740000
[    0.373681] mc: mapped MMIO address: 0xffff800010740000 -> 0x1750000
[    0.373704] mc: mapped MMIO address: 0xffff800010760000 -> 0x1760000
[    0.373725] mc: mapped MMIO address: 0xffff800010780000 -> 0x1770000
[    0.373806] mc-err: mcerr ops are set to t19x
[    0.387072] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.387094] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.387105] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.387119] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.392946] ACPI: Interpreter disabled.
[    0.394037] vdd-epb-1v0: supplied by vdd-3v3-cvb
[    0.395271] iommu: Default domain type: Translated
[    0.395385] eventlib_kernel: keventlib is initialized, test id: 0
[    0.395812] SCSI subsystem initialized
[    0.396008] usbcore: registered new interface driver usbfs
[    0.396053] usbcore: registered new interface driver hub
[    0.396104] usbcore: registered new device driver usb
[    0.396564] mc: Linux media interface: v0.10
[    0.396599] videodev: Linux video capture interface: v2.00
[    0.396941] pps_core: LinuxPPS API ver. 1 registered
[    0.396952] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.396977] PTP clock support registered
[    0.397238] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[    0.397533] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[    0.397616] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[    0.398284] Registered efivars operations
[    0.404054] FPGA manager framework
[    0.404131] Advanced Linux Sound Architecture Driver Initialized.
[    0.404697] Bluetooth: Core ver 2.22
[    0.404733] NET: Registered protocol family 31
[    0.404743] Bluetooth: HCI device and connection manager initialized
[    0.404757] Bluetooth: HCI socket layer initialized
[    0.404770] Bluetooth: L2CAP socket layer initialized
[    0.404789] Bluetooth: SCO socket layer initialized
[    0.406322] camchar: rtcpu character device driver loaded
[    0.407074] clocksource: Switched to clocksource arch_sys_counter
[    0.690126] VFS: Disk quotas dquot_6.6.0
[    0.690195] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.690468] pnp: PnP ACPI: disabled
[    0.701996] la/ptsa driver initialized.
[    0.702097] NET: Registered protocol family 2
[    0.702267] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.706810] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    0.706887] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.707202] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.707612] TCP: Hash tables configured (established 65536 bind 65536)
[    0.707734] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.707821] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.708017] NET: Registered protocol family 1
[    0.708885] RPC: Registered named UNIX socket transport module.
[    0.708914] RPC: Registered udp transport module.
[    0.708927] RPC: Registered tcp transport module.
[    0.708964] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.708984] PCI: CLS 0 bytes, default 64
[    0.709197] Trying to unpack rootfs image as initramfs...
[    0.972300] Initramfs unpacking failed: invalid magic at start of compressed archive
[    0.975312] Freeing initrd memory: 8196K
[    0.979972] hw perfevents: failed to parse interrupt-affinity[6] for arm-pmu
[    0.980003] hw perfevents: /arm-pmu: failed to register PMU devices!
[    0.980052] armv8-pmu: probe of arm-pmu failed with error -22
[    0.980428] kvm [1]: IPA Size Limit: 40 bits
[    0.980905] kvm [1]: vgic interrupt IRQ9
[    0.981345] kvm [1]: VHE mode initialized successfully
[    0.983020] Initialise system trusted keyrings
[    0.983327] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[    0.990542] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.991823] NFS: Registering the id_resolver key type
[    0.991865] Key type id_resolver registered
[    0.991878] Key type id_legacy registered
[    0.992028] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.992051] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.992082] ntfs: driver 2.1.32 [Flags: R/W].
[    1.001881] NET: Registered protocol family 38
[    1.001903] Key type asymmetric registered
[    1.001917] Asymmetric key parser 'x509' registered
[    1.001963] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[    1.002244] io scheduler mq-deadline registered
[    1.002262] io scheduler kyber registered
[    1.008148] tegra186-dpaux-pinctrl 155f0000.dpaux: can not get clock
[    1.011354] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    1.011428] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[    1.011495] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    1.011558] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[    1.011654] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[    1.018242] scrncapt: init (heads:4 wins:6 planes:4)
[    1.018391] tegradccommon 15200000.display-hub: Nvhost Channel map failed
[    1.019635] EINJ: ACPI disabled.
[    1.023558] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[    1.023581] tegra-pmc: ### PMC reset source: MAINSWRST
[    1.023594] tegra-pmc: ### PMC reset level: L1
[    1.023606] tegra-pmc: ### PMC reset status reg: 0x2d
[    1.023651] tegra-pmc: PMC Prod config success
[    1.028706] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.037630] random: fast init done
[    1.046112] printk: console [ttyTCU0] enabled
[    2.604592] arm-smmu 10000000.iommu: probing hardware configuration...
[    2.609180] arm-smmu 10000000.iommu: SMMUv2 with:
[    2.613756] arm-smmu 10000000.iommu: 	stage 1 translation
[    2.619615] arm-smmu 10000000.iommu: 	stage 2 translation
[    2.624737] arm-smmu 10000000.iommu: 	nested translation
[    2.630072] arm-smmu 10000000.iommu: 	stream matching with 128 register groups
[    2.637243] arm-smmu 10000000.iommu: 	64 context banks (0 stage-2 only)
[    2.648068] arm-smmu 10000000.iommu: 	Supported page sizes: 0x00001000
[    2.650603] arm-smmu 10000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    2.656952] arm-smmu 10000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    2.664897] arm-smmu 12000000.iommu: probing hardware configuration...
[    2.670259] arm-smmu 12000000.iommu: SMMUv2 with:
[    2.674951] arm-smmu 12000000.iommu: 	stage 1 translation
[    2.680203] arm-smmu 12000000.iommu: 	stage 2 translation
[    2.685885] arm-smmu 12000000.iommu: 	nested translation
[    2.691056] arm-smmu 12000000.iommu: 	stream matching with 128 register groups
[    2.698238] arm-smmu 12000000.iommu: 	64 context banks (0 stage-2 only)
[    2.709050] arm-smmu 12000000.iommu: 	Supported page sizes: 0x00001000
[    2.711611] arm-smmu 12000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    2.717916] arm-smmu 12000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    2.725550] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[    2.735156] tegra_profiler: version: 1.147, samples/io: 49/28
[    2.738535] tegra_profiler: auth: init
[    2.742553] THERMAL EST: found 3 subdevs
[    2.746270] THERMAL EST num_resources: 0
[    2.750112] [THERMAL EST subdev 0]
[    2.753199] [THERMAL EST subdev 1]
[    2.756846] [THERMAL EST subdev 2]
[    2.759857] THERMAL EST: Found 2 profiles, default profile is quiet
[    2.766359] THERMAL EST: thz register success.
[    2.770532] THERMAL EST: end of probe, return err: 0
[    2.776101] nvsciipc: loaded module
[    2.783276] tun: Universal TUN/TAP device driver, 1.6
[    2.785609] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    2.791862] hns3: Copyright (c) 2017 Huawei Corporation.
[    2.797156] e1000e: Intel(R) PRO/1000 Network Driver
[    2.802345] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    2.808167] igb: Intel(R) Gigabit Ethernet Network Driver
[    2.813721] igb: Copyright (c) 2007-2014 Intel Corporation.
[    2.819963] PPP generic driver version 2.4.2
[    2.824132] PPP BSD Compression module registered
[    2.828700] PPP Deflate Compression module registered
[    2.833946] PPP MPPE Compression module registered
[    2.838700] usbcore: registered new interface driver r8152
[    2.844457] hso: drivers/net/usb/hso.c: Option Wireless
[    2.849327] usbcore: registered new interface driver hso
[    2.854893] usbcore: registered new interface driver asix
[    2.860330] usbcore: registered new interface driver ax88179_178a
[    2.866424] usbcore: registered new interface driver cdc_ether
[    2.872207] usbcore: registered new interface driver net1080
[    2.877915] usbcore: registered new interface driver cdc_subset
[    2.884105] usbcore: registered new interface driver zaurus
[    2.889701] usbcore: registered new interface driver sierra_net
[    2.895309] usbcore: registered new interface driver cdc_ncm
[    2.900916] usbcore: registered new interface driver qmi_wwan
[    2.906503] usbcore: registered new interface driver cdc_mbim
[    2.912286] usbcore: registered new interface driver aqc111
[    2.918550] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.924433] ohci-pci: OHCI PCI platform driver
[    2.928556] ohci-platform: OHCI generic platform driver
[    2.934666] tegra-xusb 3610000.xhci: Adding to iommu group 0
[    2.940236] usbcore: registered new interface driver cdc_wdm
[    2.945185] usbcore: registered new interface driver uas
[    2.950658] usbcore: registered new interface driver usb-storage
[    2.956263] usbcore: registered new interface driver option
[    2.961892] usbserial: USB Serial support registered for GSM modem (1-port)
[    2.968888] usbcore: registered new interface driver qcserial
[    2.974683] usbserial: USB Serial support registered for Qualcomm USB modem
[    2.982009] usbcore: registered new interface driver sierra
[    2.987603] usbserial: USB Serial support registered for Sierra USB modem
[    2.994660] tegra-xudc 3550000.xudc: Adding to iommu group 1
[    3.000543] mousedev: PS/2 mouse device common for all mice
[    3.005578] usbcore: registered new interface driver xpad
[    3.013856] tegra_rtc c2a0000.rtc: registered as rtc1
[    3.016767] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:26 UTC (26)
[    3.024459] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    3.030793] i2c /dev entries driver
[    3.034192] tegra-i2c 3160000.i2c: Adding to iommu group 2
[    3.039782] tegra-i2c c240000.i2c: Adding to iommu group 2
[    3.045221] tegra-i2c 3180000.i2c: Adding to iommu group 2
[    3.050593] tegra-i2c 3190000.i2c: Adding to iommu group 2
[    3.055909] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[    3.061480] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[    3.067202] tegra-i2c c250000.i2c: Adding to iommu group 2
[    3.080144] device-mapper: uevent: version 1.0.3
[    3.080584] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[    3.087470] cpuidle: Initializing cpuidle driver
[    3.091623] sdhci: Secure Digital Host Controller Interface driver
[    3.096017] sdhci: Copyright(c) Pierre Ossman
[    3.100374] Synopsys Designware Multimedia Card Interface Driver
[    3.106345] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.112309] sdhci-tegra 3460000.sdhci: Adding to iommu group 3
[    3.112613] sdhci-tegra 3440000.sdhci: Adding to iommu group 4
[    3.113256] SMCCC: SOC_ID: ID = jep106:036b:0019 Revision = 0x00000102
[    3.124055] tegra-bpmp bpmp: firmware: 128431eec76692047e1ac1ebc0392266
[    3.152503] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[    3.161872] vdd-1v0: supplied by regulator-dummy
[    3.167280] vdd-1v8-hs: supplied by regulator-dummy
[    3.172113] vdd-1v8-ls: supplied by regulator-dummy
[    3.176853] vdd-1v8-ao: supplied by regulator-dummy
[    3.180807] vddio-ddr-1v1: supplied by regulator-dummy
[    3.185248] vdd-rtc: supplied by regulator-dummy
[    3.187040] spmic-ldo1: supplied by regulator-dummy
[    3.188312] vdd-ao-3v3: supplied by regulator-dummy
[    3.194496] vddio-emmc-3v3: supplied by regulator-dummy
[    3.200805] spmic-ldo4: supplied by regulator-dummy
[    3.202002] vdd-usb-3v3: supplied by regulator-dummy
[    3.208208] vddio-sdmmc1-3v3: supplied by regulator-dummy
[    3.214368] vdd-csi-1v2: supplied by vdd-1v8-ls
[    3.219911] spmic-ldo8: supplied by vdd-1v8-ls
[    3.221319] gpio-510 (gpio_default): hogged as output/high
[    3.222654] gpio-511 (gpio_default): hogged as output/high
[    3.225535] gpiochip0: registered GPIOs 504 to 511 on max77620-gpio
[    3.364216] max77686-rtc max77620-rtc: registered as rtc0
[    3.365501] max77620-power max20024-power: Event recorder REG_NVERC : 0x0
[    3.365835] max77620 4-003c: max77620 probe successful
��rm_rail_debugfs_init: /rm/vdd_cpu: failed
debugfs initialized
��[    4.185652] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[    4.186796] hid: raw HID events driver (C) Jiri Kosina
[    4.187649] usbcore: registered new interface driver usbhid
[    4.187818] usbhid: USB HID core driver
[    4.189951] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 5
[    4.191182] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
��[    27.830469] Camera-FW on t194-rce-safe started
TCU early console enabled.
[    27.904956] Camera-FW on t194-rce-safe ready SHA1=d48f1e27 (crt 0.779 ms, total boot 75.295 ms)
��[    4.275643] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[    4.276192] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[    4.277448] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[    4.278425] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[    4.280147] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[    4.280856] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[    4.281664] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[    4.283248] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (50)
[    4.283540] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[    4.286536] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=d48f1e279e6679b09020947e8de088eabfeaa475
[    4.292266] tegra_aon c1a0000.aon: Adding to iommu group 6
[    4.298542] tegra_aon c1a0000.aon: tegra aon driver probe OK
[    4.303809] tegra186-aondbg aondbg: aondbg driver probe() OK
[    4.309912] denver_knobs_init:MTS_VERSION:55637613
[    4.321912] t19x_cache tegra-cache: probed
[    4.323348] Clocks initialized successfully
[    4.325205] optee: probing for conduit method.
[    4.326092] optee: revision 3.16 (65cc2218)
[    4.327251] optee: dynamic shared memory is enabled
[    4.334952] optee: initialized driver
[    4.342804] nvpmodel: initialized successfully
[    4.343694] tegra_hv: get_hvd: not initialized yet
[    4.346655] user_ivc_mempool: hypervisor not present
[    4.353047] usbcore: registered new interface driver snd-usb-audio
[    4.359683] u32 classifier
[    4.360643]     input device check on
[    4.364491]     Actions configured
[    4.368154] Initializing XFRM netlink socket
[    4.373231] NET: Registered protocol family 10
[    4.379053] Segment Routing with IPv6
[    4.380105] NET: Registered protocol family 17
[    4.384693] NET: Registered protocol family 15
[    4.389048] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    4.402747] Bluetooth: RFCOMM socket layer initialized
[    4.407610] Bluetooth: RFCOMM ver 1.11
[    4.411442] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    4.416989] Bluetooth: HIDP socket layer initialized
[    4.422836] 9pnet: Installing 9P2000 support
[    4.426500] Key type dns_resolver registered
[    4.431942] registered taskstats version 1
[    4.434794] Loading compiled-in X.509 certificates
[    4.447030] Loaded X.509 cert 'Build time autogenerated kernel key: c3d66804619b817e74b28a23dda402b0986c24a3'
[    4.450936] tegra194-pcie 14160000.pcie: Adding to iommu group 7
[    4.460628] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[    4.462739] tegra194-pcie 14160000.pcie:       IO 0x0036100000..0x00361fffff -> 0x0036100000
[    4.471605] tegra194-pcie 14160000.pcie:      MEM 0x1400000000..0x173fffffff -> 0x1400000000
[    4.479697] tegra194-pcie 14160000.pcie:      MEM 0x1740000000..0x17ffffffff -> 0x0040000000
[    5.595992] tegra194-pcie 14160000.pcie: Phy link never came up
[    5.596589] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[    5.596776] pci_bus 0004:00: root bus resource [bus 00-ff]
[    5.596938] pci_bus 0004:00: root bus resource [io  0x0000-0xfffff] (bus address [0x36100000-0x361fffff])
[    5.597158] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[    5.597353] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[    5.597719] pci 0004:00:00.0: [10de:1ad1] type 01 class 0x060400
[    5.598198] pci 0004:00:00.0: PME# supported from D0 D3hot D3cold
[    5.617787] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[    5.618060] pci 0004:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    5.620106] pcieport 0004:00:00.0: Adding to iommu group 7
[    5.621375] pcieport 0004:00:00.0: PME: Signaling with IRQ 24
[    5.622932] pcieport 0004:00:00.0: AER: enabled with IRQ 24
[    5.624470] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[    5.625474] pci 0004:00:00.0: Removing from iommu group 7
[    5.625727] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[    5.629310] tegra194-pcie 141a0000.pcie: Adding to iommu group 8
[    5.634455] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[    5.634779] tegra194-pcie 141a0000.pcie:       IO 0x003a100000..0x003a1fffff -> 0x003a100000
[    5.635061] tegra194-pcie 141a0000.pcie:      MEM 0x1c00000000..0x1f3fffffff -> 0x1c00000000
[    5.641203] tegra194-pcie 141a0000.pcie:      MEM 0x1f40000000..0x1fffffffff -> 0x0040000000
[    5.755187] tegra194-pcie 141a0000.pcie: Link up
[    5.757722] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[    5.757945] pci_bus 0005:00: root bus resource [bus 00-ff]
[    5.758098] pci_bus 0005:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x3a100000-0x3a1fffff])
[    5.758340] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[    5.758534] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[    5.758904] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[    5.759374] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[    5.768613] pci 0005:01:00.0: [15b7:501a] type 00 class 0x010802
[    5.769178] pci 0005:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[    5.769696] pci 0005:01:00.0: reg 0x20: [mem 0x00000000-0x000000ff 64bit]
[    5.779542] pci 0005:00:00.0: BAR 14: assigned [mem 0x1f40000000-0x1f400fffff]
[    5.779913] pci 0005:01:00.0: BAR 0: assigned [mem 0x1f40000000-0x1f40003fff 64bit]
[    5.780337] pci 0005:01:00.0: BAR 4: assigned [mem 0x1f40004000-0x1f400040ff 64bit]
[    5.780749] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[    5.780932] pci 0005:00:00.0:   bridge window [mem 0x1f40000000-0x1f400fffff]
[    5.781250] pci 0005:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    5.784541] pci 0005:01:00.0: Max Payload Size set to  256/ 512 (was  128), Max Read Rq  512
[    5.794884] pcieport 0005:00:00.0: Adding to iommu group 8
[    5.799723] pcieport 0005:00:00.0: PME: Signaling with IRQ 26
[    5.805810] pcieport 0005:00:00.0: AER: enabled with IRQ 26
[    5.811887] nvme 0005:01:00.0: Adding to iommu group 8
[    5.817251] nvme nvme0: pci function 0005:01:00.0
[    5.820231] nvme 0005:01:00.0: enabling device (0000 -> 0002)
[    5.856448] nvme nvme0: allocated 32 MiB host memory buffer.
[    5.858253] host1x 13e10000.host1x: Adding to iommu group 9
[    5.866512] nvme nvme0: 6/0/0 default/read/poll queues
[    5.875560]  nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9
[    5.884756] host1x 13e10000.host1x: initialized
[    5.886322] iommu_context_dev 13e10000.host1x:ctx0: Adding to iommu group 10
[    5.887301] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[    5.888198] iommu_context_dev 13e10000.host1x:ctx1: Adding to iommu group 11
[    5.888894] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[    5.889621] iommu_context_dev 13e10000.host1x:ctx2: Adding to iommu group 12
[    5.892416] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[    5.902318] iommu_context_dev 13e10000.host1x:ctx3: Adding to iommu group 13
[    5.909381] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[    5.919218] iommu_context_dev 13e10000.host1x:ctx4: Adding to iommu group 14
[    5.925813] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[    5.935944] iommu_context_dev 13e10000.host1x:ctx5: Adding to iommu group 15
[    5.942901] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61, iommu=smmu.0x0000000012000000)
[    5.952797] iommu_context_dev 13e10000.host1x:ctx6: Adding to iommu group 16
[    5.959985] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62, iommu=smmu.0x0000000012000000)
[    5.969686] iommu_context_dev 13e10000.host1x:ctx7: Adding to iommu group 17
[    5.976806] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63, iommu=smmu.0x0000000012000000)
[    5.986745] falcon 15340000.vic: Adding to iommu group 18
[    6.001645] falcon 15340000.vic: initialized
[    6.002675] falcon 15380000.nvjpg: Adding to iommu group 18
[    6.008188] falcon 15380000.nvjpg: initialized
[    6.008728] falcon 154c0000.nvenc: Adding to iommu group 18
[    6.020064] falcon 154c0000.nvenc: initialized
[    6.020633] falcon 15a80000.nvenc1: Adding to iommu group 18
[    6.029151] falcon 15a80000.nvenc1: initialized
[    6.029747] nvdec 15480000.nvdec: Adding to iommu group 18
[    6.043503] nvdec 15480000.nvdec: initialized
[    6.044091] nvdec 15140000.nvdec1: Adding to iommu group 18
[    6.053497] nvdec 15140000.nvdec1: initialized
[    6.054106] tsec 15500000.tsec: Adding to iommu group 19
[    6.059589] tsec 15500000.tsec: initialized
[    6.060125] tsec 15100000.tsecb: Adding to iommu group 20
[    6.067161] tsec 15100000.tsecb: initialized
[    6.070962] gic 2a41000.agic-controller: GIC IRQ controller registered
[    6.098419] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[    6.110974] gpio-374 (wifi-enable): hogged as output/high
[    6.111425] gpio-431 (camera-control-output-low): hogged as output/low
[    6.111888] gpio-432 (camera-control-output-low): hogged as output/low
[    6.113396] gpiochip1: registered GPIOs 335 to 503 on tegra194-gpio
[    6.115333] gpiochip2: registered GPIOs 305 to 334 on tegra194-gpio-aon
[    6.115919] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    6.118380] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[    6.124133] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    6.129605] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[    6.134933] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[    6.143382] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[    6.150773] tegra194-isp5 13e10000.host1x:isp@14800000: Adding to iommu group 21
[    6.162143] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[    6.167228] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: initialized
[    6.172955] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e10000.host1x:nvcsi@15a00000- bound
[    6.182113] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e10000.host1x:nvcsi@15a00000- bound
[    6.191167] tegra194-vi5 15c10000.vi: Adding to iommu group 22
[    6.198251] scare-pigeon 13e10000.host1x:vi-thi@15f00000: context isolation disabled due to no IOMMU
[    6.206040] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[    6.212427] scare-pigeon 13e10000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[    6.221736] scare-pigeon 13e10000.host1x:isp-thi@14b00000: initialized
[    6.228062] pva 16000000.pva0: Adding to iommu group 23
[    6.255294] pva 16000000.pva0: initialized
[    6.259556] pva 16800000.pva1: Adding to iommu group 24
[    6.270442] pva 16800000.pva1: initialized
[    6.273846] nvdla 15880000.nvdla0: Adding to iommu group 25
[    6.294919] nvdla 15880000.nvdla0: initialized
[    6.296381] nvdla 158c0000.nvdla1: Adding to iommu group 26
[    6.305643] nvdla 158c0000.nvdla1: initialized
[    6.309943] tegradccommon 15200000.display-hub: host1x channel mapped
[    6.310497] tegradccommon 15200000.display-hub: dc_common syncpt # 1 allocated
[    6.310907] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=64
[    6.310920] tegradccommon 15200000.display-hub: dma mapping done
[    6.310949] tegradc 15200000.display: Adding to iommu group 27
[    6.311370] tegra_cec 3960000.tegra_cec: Unpowergated DISP
[    6.311852] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[    6.313580] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[    6.318302] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[    6.320014] tegradc 15210000.display: Adding to iommu group 27
[    6.320115] tegradc 15200000.display: disp0 connected to head0->sor1
[    6.320214] generic_infoframe_type: 0x87
[    6.320317] tegradc 15200000.display: DT parsed successfully
[    6.320390] tegradc 15200000.display: Display dc.(____ptrval____) registered with id=0
[    6.323254] tegra_cec 3960000.tegra_cec: probed
[    6.324567] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[    6.324582] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 933000000 Hz
[    6.324585] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[    6.325558] tegradc 15200000.display: vblank syncpt # 8 for dc 0
[    6.325567] tegradc 15200000.display: vpulse3 syncpt # 9 for dc 0
[    6.326793] tegradc 15200000.display: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[    6.329698] tegradc 15200000.display: hdmi: can't get adpater for ddc bus 3
[    6.336677] tegra-gpcdma 2600000.dma: Adding to iommu group 2
[    6.340586] tegradc 15200000.display: out->type:1 out_ops->init err = -517
[    6.355352] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[    6.360293] tegradc 15210000.display: disp0 connected to head1->sor
[    6.366930] kfuse 3830000.kfuse: initialized
[    6.375014] tegradc 15210000.display: parse_dp_settings: No dp-lt-settings node
[    6.383801] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[    6.388736] tegradc 15210000.display: DT parsed successfully
[    6.394881] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[    6.405979] tegradc 15210000.display: dc.1 probe not in device tree order, deferring
[    6.413045] serial-tegra 3100000.serial: Adding to iommu group 2
[    6.483587] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 31, base_baud = 0) is a TEGRA_UART
[    6.493162] serial-tegra 3110000.serial: Adding to iommu group 2
[    6.497835] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 32, base_baud = 0) is a TEGRA_UART
[    6.507487] serial-tegra 3140000.serial: Adding to iommu group 2
[    6.512656] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 33, base_baud = 0) is a TEGRA_UART
[    6.533653] tegra-xusb 3610000.xhci: Firmware timestamp: 2022-03-16 11:07:43 UTC, Version: 60.13 release
[    6.534020] tegra-xusb 3610000.xhci: xHCI Host Controller
[    6.535931] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[    6.543987] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x0000000000050810
[    6.552941] tegra-xusb 3610000.xhci: irq 190, io mem 0x03610000
[    6.559580] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    6.566860] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.574011] usb usb1: Product: xHCI Host Controller
[    6.579252] usb usb1: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[    6.585555] usb usb1: SerialNumber: 3610000.xhci
[    6.591054] hub 1-0:1.0: USB hub found
[    6.594214] hub 1-0:1.0: 4 ports detected
[    6.597650] random: crng init done
[    6.598653] tegra-xusb 3610000.xhci: xHCI Host Controller
[    6.607249] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[    6.614538] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[    6.622138] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    6.629866] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.637123] usb usb2: Product: xHCI Host Controller
[    6.642253] usb usb2: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[    6.648471] usb usb2: SerialNumber: 3610000.xhci
[    6.653862] hub 2-0:1.0: USB hub found
[    6.656962] hub 2-0:1.0: 4 ports detected
[    6.699069] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[    6.704124] gpiochip3: registered GPIOs 297 to 304 on pcf8574a
[    6.704364] pcf857x 8-0038: probed
[    6.706691] i2c i2c-2: Added multiplexed i2c bus 9
[    6.708127] i2c i2c-2: Added multiplexed i2c bus 10
[    6.708309] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[    6.721201] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1903000 KHz, changing to: 1907200 KHz
[    6.722240] tegra194-cpufreq ccplex: probed with BWMGR
[    6.723651] sdhci-tegra 3460000.sdhci: BWMGR client registration for eMC Successful
[    6.724062] irq: IRQ271: trimming hierarchy from :pmc@c360000
[    6.724475] usb-conn-gpio 3520000.xusb_padctl:ports:usb2-0:connector: repeated role: 0
[    6.725710] sdhci-tegra 3440000.sdhci: BWMGR client registration for eMC Successful
[    6.726302] tegra194-isp5 13e10000.host1x:isp@14800000: initialized
[    6.733042] tegra194-vi5 15c10000.vi: initialized
[    6.735297] mmc0: CQHCI version 5.10
[    6.752245] tegradc 15200000.display: disp0 connected to head0->sor1
[    6.753029] nvethernet 2490000.ethernet: Adding to iommu group 28
[    6.757707] generic_infoframe_type: 0x87
[    6.764129] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[    6.764484] nvethernet 2490000.ethernet: failed to read skip mac reset flag, default 0
[    6.767980] tegradc 15200000.display: DT parsed successfully
[    6.775530] nvethernet 2490000.ethernet: failed to read MDIO address
[    6.783826] tegradc 15200000.display: Display dc.00000000dcaf5c79 registered with id=0
[    6.789506] nvethernet 2490000.ethernet: setting to default DMA bit mask
[    6.789511] nvethernet 2490000.ethernet: set default TXQ to TC mapping
[    6.789516] nvethernet 2490000.ethernet: Setting default PTP RX queue
[    6.824747] nvethernet 2490000.ethernet: failed to get eqos_rx_m clk
[    6.825340] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[    6.829953] nvethernet 2490000.ethernet: failed to get eqos_rx_input clk
[    6.829960] nvethernet 2490000.ethernet: failed to get eqos_tx_divider clk
[    6.850689] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit
[    6.851113] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[    6.852196] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 933000000 Hz
[    6.853127] nvethernet 2490000.ethernet: Ethernet MAC address: 48:b0:2d:03:51:96
[    6.853172] nvethernet 2490000.ethernet: Macsec not supported
[    6.854370] nvethernet 2490000.ethernet: eth0 (HW ver: 50) created with 1 DMA channels
[    6.855205] irq: IRQ273: trimming hierarchy from :pmc@c360000
[    6.855306] irq: IRQ274: trimming hierarchy from :interrupt-controller@3881000
[    6.855425] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    6.856125] tegra-se-nvhost 15810000.se: Adding to iommu group 29
[    6.857623] tegra-se-nvhost 15810000.se: initialized
[    6.862662] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[    6.866517] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[    6.866876] tegradc 15200000.display: vblank syncpt # 12 for dc 0
[    6.875004] tegra-se-nvhost 15820000.se: Adding to iommu group 30
[    6.882300] tegradc 15200000.display: vpulse3 syncpt # 13 for dc 0
[    6.888821] tegra-se-nvhost 15820000.se: initialized
[    6.896094] tegradc 15200000.display: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[    6.903657] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[    6.909762] tegradc 15200000.display: hdmi: invalid prod list prod_list_hdmi_board
[    6.915565] tegra-se-nvhost 15830000.se: Adding to iommu group 31
[    6.921528] tegradc 15200000.display: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[    6.947457] tegra-se-nvhost 15830000.se: initialized
[    6.955683] tegradc 15200000.display: probed
[    6.961003] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[    6.972149] mmc0: Command Queue Engine enabled
[    6.975840] tegra-se-nvhost 15840000.se: Adding to iommu group 32
[    6.981762] mmc0: periodic cache flush enabled
[    7.022694] tegra-se-nvhost 15840000.se: initialized
[    7.029036] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[    7.034828] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[    7.038928] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[    7.044775] usb 1-2: New USB device found, idVendor=04b4, idProduct=6506, bcdDevice=50.00
[    7.048284] tegra_actmon d230000.actmon: in actmon_register()...
[    7.050857] tegra_actmon d230000.actmon: bwmgr_disable = 0
[    7.051155] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB, chardev (509:0)
[    7.055770] usb 1-2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    7.057033] hub 1-2:1.0: USB hub found
[    7.062554]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19
[    7.064539] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[    7.069796] hub 1-2:1.0: 2 ports detected
[    7.075923] hvc_sysfs: hypervisor is not present
[    7.118527] Console: switching to colour frame buffer device 240x67
[    7.124558] tegradc 15200000.display: fb registered
[    7.129605] irq: IRQ275: trimming hierarchy from :pmc@c360000
[    7.147744] ALSA device list:
[    7.147852]   No soundcards found.
[    7.149474] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[    7.149836] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[    7.159381] usb 2-3: new SuperSpeed Gen 1 USB device number 2 using tegra-xusb
[    7.179708] usb 2-3: New USB device found, idVendor=04b4, idProduct=6504, bcdDevice=50.00
[    7.179926] usb 2-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    7.182195] hub 2-3:1.0: USB hub found
[    7.182385] hub 2-3:1.0: 2 ports detected
[    7.214427] tegradc 15200000.display: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_111m_223m
[    7.215773] tegradc 15200000.display: hdmi: get RGB quant from REG programmed by BL.
[    7.215976] tegradc 15200000.display: hdmi: get YCC quant from REG programmed by BL.
[    7.216964] extcon-disp-state external-connection:disp-state: cable 47 state 1
[    7.217149] Extcon AUX1(HDMI) enable
[    7.219633] tegradc 15210000.display: disp1 connected to head1->sor
[    7.226359] tegradc 15210000.display: parse_dp_settings: No dp-lt-settings node
[    7.233398] tegradc 15210000.display: DT parsed successfully
[    7.238943] tegradc 15210000.display: Display dc.00000000d3c4a0b7 registered with id=1
[    7.246732] tegradc 15210000.display: vblank syncpt # 17 for dc 1
[    7.252835] tegradc 15210000.display: vpulse3 syncpt # 18 for dc 1
[    7.265541] tegradc 15210000.display: probed
[    7.265855] tegradc 15210000.display: fb registered
[    7.271744] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[    7.275658] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[    7.277219] Freeing unused kernel memory: 4032K
[    7.283201] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[    7.293639] tegradc 15210000.display: blank - powerdown
[    7.293688] Run /init as init process
[    7.298639] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[    7.310962] Extcon DP: HPD disabled
[    7.314469] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[    7.321021] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[    7.327147] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[    7.327161] tegra_cec 3960000.tegra_cec: Can't find physical address.
[    7.340092] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[    7.361222] Root device found: nvme0n1p1
��WARNING: clock_disable: clk_power_ungate on gated domain 27 for gpcclk
��[    7.362930] tegradc 15200000.display: blank - powerdown
[    7.363515] Found dev node: /dev/nvme0n1p1
[    7.382404] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null)
[    7.386142] Rootfs mounted over nvme0n1p1
[    7.398098] extcon-disp-state external-connection:disp-state: cable 47 state 0
[    7.398103] Extcon AUX1(HDMI) disable
[    7.399108] usb 1-2.2: new high-speed USB device number 3 using tegra-xusb
[    7.412087] Switching from initrd to actual rootfs
[    7.421373] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[    7.422207] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[    7.434375] tegradc 15200000.display: unblank
[    7.435454] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[    7.435656] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[    7.441476] tegradc 15200000.display: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[    7.443300] tegradc 15200000.display: hdmi: get YCC quant from EDID.
[    7.447322] extcon-disp-state external-connection:disp-state: cable 47 state 1
[    7.447342] Extcon AUX1(HDMI) enable
[    7.460068] tegradc 15200000.display: sync windows ret = 247
[    7.487783] extcon-disp-state external-connection:disp-state: cable 53 state 1
[    7.489276] Extcon HDMI: HPD enabled
[    7.490603] tegradc 15200000.display: hdmi: plugged
[    7.505015] systemd[1]: System time before build time, advancing clock.
[    7.505974] usb 1-2.2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 6.63
[    7.507769] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    7.507774] usb 1-2.2: Product: USB2.1 Hub
[    7.507777] usb 1-2.2: Manufacturer: GenesysLogic
[    7.509272] hub 1-2.2:1.0: USB hub found
[    7.524457] hub 1-2.2:1.0: 4 ports detected
[    7.539542] x_tables: module verification failed: signature and/or required key missing - tainting kernel
[    7.572350] systemd[1]: systemd 245.4-4ubuntu3.18 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[    7.577175] systemd[1]: Detected architecture arm64.
[    7.583541] usb 2-3.2: new SuperSpeed Gen 1 USB device number 3 using tegra-xusb
[    7.606307] systemd[1]: Set hostname to <tegra-ubuntu>.
[    7.610602] usb 2-3.2: New USB device found, idVendor=05e3, idProduct=0626, bcdDevice= 6.63
[    7.612093] usb 2-3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    7.613570] usb 2-3.2: Product: USB3.1 Hub
[    7.614902] usb 2-3.2: Manufacturer: GenesysLogic
[    7.620871] hub 2-3.2:1.0: USB hub found
[    7.623179] hub 2-3.2:1.0: 4 ports detected
[    7.847121] usb 1-2.2.2: new high-speed USB device number 4 using tegra-xusb
[    7.989721] usb 1-2.2.2: New USB device found, idVendor=0bda, idProduct=5409, bcdDevice= 1.41
[    7.991278] usb 1-2.2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    7.992682] usb 1-2.2.2: Product: 4-Port USB 2.0 Hub
[    7.994019] usb 1-2.2.2: Manufacturer: Generic
[    7.997577] hub 1-2.2.2:1.0: USB hub found
[    8.000195] hub 1-2.2.2:1.0: 4 ports detected
[    8.061828] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    8.063540] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    8.069453] systemd[1]: Created slice system-modprobe.slice.
[    8.074382] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    8.079103] systemd[1]: Created slice User and Session Slice.
[    8.082399] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    8.086422] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    8.089643] systemd[1]: Reached target User and Group Name Lookups.
[    8.092631] systemd[1]: Reached target Slices.
[    8.095570] systemd[1]: Reached target Swap.
[    8.099346] systemd[1]: Listening on RPCbind Server Activation Socket.
[    8.102719] systemd[1]: Listening on Syslog Socket.
[    8.106117] systemd[1]: Listening on fsck to fsckd communication Socket.
[    8.109276] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    8.113274] systemd[1]: Listening on Journal Audit Socket.
[    8.116697] systemd[1]: Listening on Journal Socket (/dev/log).
[    8.120719] systemd[1]: Listening on Journal Socket.
[    8.126405] systemd[1]: Listening on udev Control Socket.
[    8.129777] systemd[1]: Listening on udev Kernel Socket.
[    8.138092] systemd[1]: Mounting Huge Pages File System...
[    8.146350] systemd[1]: Mounting POSIX Message Queue File System...
[    8.154680] systemd[1]: Mounting RPC Pipe File System...
[    8.163400] systemd[1]: Mounting Kernel Debug File System...
[    8.171982] systemd[1]: Mounting Kernel Trace File System...
[    8.181498] systemd[1]: Starting Journal Service...
[    8.189809] systemd[1]: Starting Set the console keyboard layout...
[    8.197759] systemd[1]: Starting Create list of static device nodes for the current kernel...
[    8.205134] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[    8.208826] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[    8.215103] systemd[1]: Starting Load Kernel Module efi_pstore...
[    8.223156] systemd[1]: Starting Load Kernel Module pstore_blk...
[    8.230555] systemd[1]: Starting Load Kernel Module pstore_zone...
[    8.237963] systemd[1]: Starting Load Kernel Module ramoops...
[    8.246290] systemd[1]: Starting NVIDIA specific first-boot udev script...
[    8.251367] ramoops reserved-memory:ramoops_carveout: failed to locate DT /reserved-memory resource
[    8.252997] ramoops: probe of reserved-memory:ramoops_carveout failed with error -22
[    8.254024] systemd[1]: Started Nameserver information manager.
[    8.259793] systemd[1]: Reached target Network (Pre).
[    8.263731] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    8.265498] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    8.272843] systemd[1]: Starting Load Kernel Modules...
[    8.280547] systemd[1]: Starting Remount Root and Kernel File Systems...
[    8.288525] systemd[1]: Starting udev Coldplug all Devices...
[    8.299156] usb 1-2.2.2.2: new low-speed USB device number 5 using tegra-xusb
[    8.300231] systemd[1]: Mounted Huge Pages File System.
[    8.304341] systemd[1]: Mounted POSIX Message Queue File System.
[    8.306476] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    8.307271] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x00000000ce000000,704643072
[    8.308384] EXT4-fs (nvme0n1p1): re-mounted. Opts: (null)
[    8.309719] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[    8.309733] nvmap_page_pool_init: Total RAM pages: 1752720
[    8.314185] nvmap_page_pool_init: nvmap page pool size: 219090 pages (855 MB)
[    8.314361] nvmap_background_zero_thread: PP zeroing thread starting.
[    8.314606] misc nvmap: created heap vpr base 0x00000000ce000000 size (688128KiB)
[    8.314761] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[    8.314769] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[    8.347768] systemd[1]: Mounted RPC Pipe File System.
[    8.351215] systemd[1]: Mounted Kernel Debug File System.
[    8.355743] systemd[1]: Mounted Kernel Trace File System.
[    8.364678] systemd[1]: Finished Create list of static device nodes for the current kernel.
[    8.370841] systemd[1]: modprobe@chromeos_pstore.service: Succeeded.
[    8.376478] systemd[1]: Finished Load Kernel Module chromeos_pstore.
[    8.383187] nvgpu: 17000000.gv11b          nvgpu_nvhost_syncpt_init:135  [INFO]  syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[    8.383187]
[    8.383804] systemd[1]: modprobe@efi_pstore.service: Succeeded.
[    8.403586] systemd[1]: Finished Load Kernel Module efi_pstore.
[    8.409644] systemd[1]: modprobe@pstore_blk.service: Succeeded.
[    8.415061] systemd[1]: Finished Load Kernel Module pstore_blk.
[    8.421817] systemd[1]: modprobe@pstore_zone.service: Succeeded.
[    8.426424] systemd[1]: Finished Load Kernel Module pstore_zone.
[    8.429625] usb 1-2.2.2.2: New USB device found, idVendor=413c, idProduct=2113, bcdDevice= 1.08
[    8.439469] usb 1-2.2.2.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[    8.439474] usb 1-2.2.2.2: Product: Dell KB216 Wired Keyboard
[    8.445717] input: Dell KB216 Wired Keyboard as /devices/platform/3610000.xhci/usb1/1-2/1-2.2/1-2.2.2/1-2.2.2.2/1-2.2.2.2:1.0/0003:413C:2113.0001/input/input1
[    8.473086] systemd[1]: Finished Set the console keyboard layout.
[    8.477687] systemd[1]: modprobe@ramoops.service: Succeeded.
[    8.481277] systemd[1]: Finished Load Kernel Module ramoops.
[    8.487492] systemd[1]: nvfb-udev.service: Succeeded.
[    8.493104] systemd[1]: Finished NVIDIA specific first-boot udev script.
[    8.506052] systemd[1]: Finished Load Kernel Modules.
[    8.513761] systemd[1]: Finished Remount Root and Kernel File Systems.
[    8.521114] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[    8.523555] hid-generic 0003:413C:2113.0001: input,hidraw0: USB HID v1.11 Keyboard [Dell KB216 Wired Keyboard] on usb-3610000.xhci-2.2.2.2/input0
[    8.527744] systemd[1]: Mounting Kernel Configuration File System...
[    8.534290] input: Dell KB216 Wired Keyboard System Control as /devices/platform/3610000.xhci/usb1/1-2/1-2.2/1-2.2.2/1-2.2.2.2/1-2.2.2.2:1.1/0003:413C:2113.0002/input/input2
[    8.557701] systemd[1]: Started OP-TEE Client Supplicant.
[    8.563025] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[    8.565324] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[    8.579388] systemd[1]: Starting Load/Save Random Seed...
[    8.587374] systemd[1]: Starting Apply Kernel Variables...
[    8.596131] systemd[1]: Starting Create System Users...
[    8.604686] systemd[1]: Mounted Kernel Configuration File System.
[    8.612035] systemd[1]: Finished Load/Save Random Seed.
[    9.619822] using random self ethernet address
[    9.620895] using random host ethernet address
[   10.475778] using random self ethernet address
[   10.476871] using random host ethernet address
[   10.948685] IRQ218: set affinity failed(-22).
[   10.948972] CPU4: shutdown
[   11.004244] IRQ218: set affinity failed(-22).
[   11.010076] CPU5: shutdown
[   11.024165] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[   11.030511] imx219 9-0010: board setup failed
[   11.031753] imx219: probe of 9-0010 failed with error -121
[   11.044462] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[   11.059579] imx219 10-0010: board setup failed
[   11.071307] imx219: probe of 10-0010 failed with error -121
[   14.070893] ------------[ cut here ]------------
[   14.103696] WARNING: CPU: 2 PID: 336 at drivers/spi/spidev.c:781 init_module+0x2d81e0/0x2da19c [spidev]
[   14.104044] ---[ end trace c9bab87d75540233 ]---
[   14.148389] 1 fixed-partitions partitions found on MTD device spi6.0
[   14.149551] Creating 1 MTD partitions on "spi6.0":
[   14.150617] 0x000000000000-0x000002000000 : "Whole_flash0"
[   18.353063] FAT-fs (mmcblk0p18): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   23.581613] Bridge firewalling registered
Ubuntu 20.04.5 LTS tegra-ubuntu ttyTCU0
tegra-ubuntu login: [   26.888947] nvmap_alloc_handle: PID 1283: deepstream-app: WARNING: All NvMap Allocations must have a tag to identify the subsystem allocating memory.Please pass the tag to the API call NvRmMemHanldeAllocAttr() or relevant.
[   29.317825] nvidia: loading out-of-tree module taints kernel.
[   93.959930] watchdog: watchdog0: watchdog did not stop!
[   94.322437] Trying to unregister non-registered hwtime source
[   94.325288] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000040
[   94.326434] Mem abort info:
[   94.327335]   ESR = 0x96000004
[   94.328230]   EC = 0x25: DABT (current EL), IL = 32 bits
[   94.329209]   SET = 0, FnV = 0
[   94.330164]   EA = 0, S1PTW = 0
[   94.331067] Data abort info:
[   94.331958]   ISV = 0, ISS = 0x00000004
[   94.332920]   CM = 0, WnR = 0
[   94.333840] user pgtable: 4k pages, 48-bit VAs, pgdp=0000000119c4a000
[   94.334903] [0000000000000040] pgd=0000000000000000, p4d=0000000000000000
[   94.335953] Internal error: Oops: 96000004 [#1] PREEMPT SMP
[   94.336977] Modules linked in: fuse(E) xt_conntrack(E) xt_MASQUERADE(E) nf_conntrack_netlink(E) nfnetlink(E) xt_addrtype(E) iptable_filter(E) iptable_nat(E) nf_nat(E) nf_conntrack(E) nf_defrag_ipv6(E) nf_defrag_ipv4(E) libcrc32c(E) br_netfilter(E) lzo_rle(E) lzo_compress(E) zram(E) overlay(E) snd_soc_tegra210_ope(E) snd_soc_tegra186_asrc(E) snd_soc_tegra186_dspk(E) snd_soc_tegra210_mvc(E) snd_soc_tegra186_arad(E) snd_soc_tegra210_iqc(E) snd_soc_tegra210_afc(E) snd_soc_tegra210_dmic(E) snd_soc_tegra210_adx(E) snd_soc_tegra210_mixer(E) snd_soc_tegra210_amx(E) snd_soc_tegra210_i2s(E) snd_soc_tegra210_admaif(E) snd_soc_tegra210_sfc(E) snd_soc_tegra_pcm(E) ofpart(E) cmdlinepart(E) qspi_mtd(E) spidev(E) mtd(E) aes_ce_blk(E) crypto_simd(E) cryptd(E) aes_ce_cipher(E) ghash_ce(E) sha2_ce(E) sha256_arm64(E) sha1_ce(E) snd_soc_spdif_tx(E) snd_soc_tegra_machine_driver(E) leds_gpio(E) max77620_thermal(E) snd_soc_tegra210_adsp(E) snd_soc_tegra_utils(E) snd_soc_simple_card_utils(E) tegra_bpmp_thermal(E)
[   94.337182]  nvadsp(E) snd_soc_tegra210_ahub(E) userspace_alert(E) snd_hda_codec_hdmi(E) tegra210_adma(E) realtek(E) nv_imx219(E) snd_hda_tegra(E) snd_hda_codec(E) spi_tegra210_qspi(E) snd_hda_core(E) spi_tegra114(E) input_leds(E) loop(E) binfmt_misc(E) ina3221(E) pwm_fan(E) nvgpu(E) nvmap(E) ramoops(E) reed_solomon(E) ip_tables(E) x_tables(E)
[   94.410737] CPU: 3 PID: 2908 Comm: kworker/u12:4 Tainted: G        W  OE     5.10.104-tegra #2
[   94.419390] Hardware name: Unknown NVIDIA Jetson Xavier NX for DSBOARD-NX2 (rev-1.22)/NVIDIA Jetson Xavier NX for DSBOARD-NX2 (rev-1.22), BIOS 1.0-d7fb19b
[   94.433574] Workqueue: events_power_efficient phy_state_machine
[   94.439604] pstate: 60c00009 (nZCv daif +PAN +UAO -TCO BTYPE=--)
[   94.445385] pc : netif_carrier_off+0x18/0x90
[   94.450104] lr : netif_carrier_off+0x18/0x90
[   94.454303] sp : ffff80002fa3bd00
[   94.457717] x29: ffff80002fa3bd00 x28: ffffbec1f5e86000
[   94.463487] x27: ffff80001173bca8 x26: ffff26bdb2288fc8
[   94.468742] x25: 0000000000000000 x24: 0000000000000000
[   94.474256] x23: ffff26bcde7514f8 x22: ffff26bd9658e580
[   94.479679] x21: 0000000000000000 x20: 0000000000000000
[   94.485449] x19: 0000000000000000 x18: 0000000000000013
[   94.490960] x17: 0000000000000007 x16: 000000000000000e
[   94.496473] x15: 0000000000000004 x14: 0000000000000019
[   94.501987] x13: 0000000000000000 x12: ffff26bce6406518
[   94.507409] x11: 0000000000000040 x10: ffffbec1f5ea2250
[   94.512925] x9 : ffff26bd966b317c x8 : fefefefefefefeff
[   94.518261] x7 : 0000000000000018 x6 : ffff26bd966b316c
[   94.523617] x5 : 0000746e65696369 x4 : 000000000000002f
[   94.528766] x3 : 0000000000000000 x2 : ffffbec1f4357380
[   94.534361] x1 : 0000000000000000 x0 : ffffbec1f4357380
[   94.539456] Call trace:
[   94.542173]  netif_carrier_off+0x18/0x90
[   94.545661]  phy_link_change+0x68/0x70
[   94.549855]  phy_state_machine+0x17c/0x220
[   94.553622]  process_one_work+0x1c0/0x4a0
[   94.557658]  worker_thread+0x50/0x420
[   94.561575]  kthread+0x148/0x170
[   94.564574]  ret_from_fork+0x10/0x18
[   94.568065] Code: f9000bf3 aa0003f3 aa1e03e0 97c2df92 (f9402260)
[   94.574464] ---[ end trace c9bab87d75540234 ]---
[   94.579004] Kernel panic - not syncing: Oops: Fatal exception
[   94.584598] Kernel Offset: 0x3ec1e41a0000 from 0xffff800010000000
[   94.590711] PHYS_OFFSET: 0xffffd94440000000
[   94.594736] CPU features: 0x8240002,03802a30
[   94.599021] Memory Limit: none
[   94.601920] ---[ end Kernel panic - not syncing: Oops: Fatal exception ]---
  1. For the phy link panic, I am sure the patch can resolve issue. Please tell us how did you update your device tree and if runtime device tree really has the change you added.
  2. For another new panic, do you connect only HDMI monitor or you are using DP?
I am using hdmi, ethernet, usb and debug ports.
I converted my dtb file to dts and added below.
tegra194-p3668-dsboard-nx2-0000.dts (390.7 KB)
I don’t think it would be hard for you to just remove 2 lines.
It does matter to me your device tree content. The point here is how did you update the device tree ?
Here is my workflow,
I made the changes and compiled kernel files.
Took dtb file and copy it to the mensioned location in FDT line in extlinux.conf file and changed its name to what exlinux file has already.
Please also check the node /proc/device-tree and see if your change is really taking effect.
That has been the issue, change did not take effect. But it is weird that after i updated emmc side dtb, it resolved.
Thanks for your help.
