Jetson Xavier NX not booting in custom carrier board
I have a general question regarding the pinmux configuration of the SoM.
I have a custom carrier board, where I adapted the kernel and device tree to enable a MIPI-CSI2 driver. This was all working fine, in L4T 32.6.1. The rest of the interfaces I left them untouched as if it was the carrier board delivered from NVIDIA, since the board booted anyways and there was no problem.
Right now, I am migrating to L4T 35.5.0, but the board is not able to boot from the carrier board. In my Custom carrier board, I am only having the following signals/interfaces:
  • MIPI CSI0/CSI4
  • HDMI DP0 and DP1
  • SPI0
  • SD Card
  • Ethernet
Rest of them are all currently unused. I know I am supposed to edit the pinmux of the chip and consequently the device tree so the SoM matches the board is plugged in. My question is the following:
Do to time constraints, I need to make the board somehow bootable by removing the interface or the part of the device tree that is causing the error and leaving the rest as is. Do you have any suggestions/tips on which interface might be preventing the board to boot? Maybe some PCI express bus?
Any suggestion or direction pointing would be helpful.
Please define what is your method to tell “this board is not booting up” first.
What you are talking about does not really matter to the problem now. They could be discussed later.
Board is getting stuck right before UEFI. See log of UART console:
[0000.024] W> RATCHET: MB1 binary ratchet value 4 is larger than ratchet level 2 from HW fuses.
[0000.033] I> MB1 (prd-version: 2.6.0.0-t194-41334769-cab45716)
[0000.038] I> Boot-mode: Coldboot
[0000.041] I> Platform: Silicon
[0000.044] I> Chip revision : A02P
[0000.047] I> Bootrom patch version : 15 (correctly patched)
[0000.052] I> ATE fuse revision : 0x200
[0000.055] I> Ram repair fuse : 0x0
[0000.059] I> Ram Code : 0x0
[0000.061] I> rst_source: 0x0, rst_level: 0x0
[0000.066] I> Boot-device: QSPI (instance: 0)
[0000.070] I> Qspi flash params source = brbct
[0000.074] I> Qspi clock source : pllp
[0000.077] I> Qspi-0 initialized successfully
[0000.081] I> Boot chain mechanism: A/B
[0000.085] I> Current Boot-Chain Slot: 0
[0000.088] I> BR-BCT Boot-Chain: 0, status: 0. update flag: 0
[0000.094] I> Qspi flash params source = brbct
[0000.100] W> PROD_CONFIG: device prod data is empty in MB1 BCT.
[0000.107] I> Temperature = 44000
[0000.110] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.115] W> Skipping boost for clk: BPMP_APB
[0000.119] W> Skipping boost for clk: AXI_CBB
[0000.123] W> Skipping boost for clk: AON_CPU_NIC
[0000.127] W> Skipping boost for clk: CAN1
[0000.131] W> Skipping boost for clk: CAN2
[0000.135] I> Boot-device: QSPI (instance: 0)
[0000.139] I> Qspi flash params source = mb1bct
[0000.143] I> Qspi clock source : pllc_out0
[0000.147] I> Qspi-0 reinitialized
[0000.150] I> Qspi flash params source = mb1bct
[0000.163] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.170] W>  Thermal config not found in BCT
[0000.178] W>  MEMIO rail config not found in BCT
[0000.188] I> Qspi flash params source = mb1bct
[0000.201] I> Qspi flash params source = mb1bct
[0000.235] I> Qspi flash params source = mb1bct
[0000.799] I> Qspi flash params source = mb1bct
[0000.816] I> Qspi flash params source = mb1bct
[0000.855] W>  Platform config not found in BCT
[0000.882] I> Qspi flash params source = mb1bct
[0000.908] I> MB1 done
▒▒▒▒main enter
SPE VERSION #: R01.00.18 Created: Jan 29 2021 @ 14:18:27
HW Function test
Start Scheduler.
in late init
  [0000.917] I> Welcome to MB2(TBoot-BPMP) (version: default.t194-mobile-8e4b789e)
[0000.918] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.918] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.919] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.925] W> device prod register failed
[0000.928] I> gpio framework initialized
[0000.932] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0000.939] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0000.947] I> sdcard_params [0, 55, 0, 50] in mb1_bct
[0000.952] I> Boot_device: QSPI_FLASH instance: 0
[0000.956] I> qspi flash-0 params source = boot args
[0000.962] I> QSPI-0l initialized successfully
[0000.965] I> sdcard-0 params source = mb1 bct
[0000.970] I> Found sdcard
[0001.176] I> sdmmc SDR mode
[0001.197] I> Found 41 partitions in QSPI_FLASH (instance 0)
[0001.209] I> Found 22 partitions in SDCARD (instance 0)
[0001.210] I> Active Boot chain : 0
[0001.892] I> Relocating BR-BCT
[0001.893]  > DEVICE_PROD: device prod is not initialized.
[0001.918] E> I2C: slave not found in slaves.
[0001.919] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.920] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.921] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 0.
[0001.922] E> eeprom: Failed to read I2C slave device
[0001.925] I> Failed to read CVB eeprom data @ AE
[0001.929] I> Retrying CVB eeprom read @ AC ...
[0001.934] E> I2C: slave not found in slaves.
[0001.938] E> I2C: Could not write 0 bytes to slave: 0x00ac with repeat start true.
[0001.946] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.951] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xac at 0x00000000 via instance 0.
[0001.961] E> eeprom: Failed to read I2C slave device
[0001.965] I> Failed to read CVB eeprom data @ AC
[0002.269] I> Relocating OP-TEE dtb from: 0x6bfff720 to 0x70050000, size: 1008
[0002.270] I> [0] START: 0x80000000, SIZE: 0x2f000000
[0002.270] I> [1] START: 0xaf010000, SIZE: 0x189f0000
[0002.271] I> [2] START: 0xc7b00000, SIZE: 0xc0000
[0002.271] I> [3] START: 0xca000000, SIZE: 0x800000
[0002.272] I> dram_block larger than 80000000
[0002.274] I> [4] START: 0x100000000, SIZE: 0x180000000
[0002.286] I> Setting NS memory ranges to OP-TEE dtb finished.
[0002.289] I> found decompressor handler: lz4
[0002.534] I> EKB detected (length: 0x410) @ VA:0x526ff400
[0002.536] I> Setting EKB blob info to OPTEE dtb finished.
▒▒NOTICE:  BL31: v2.6(release):cec9a2bc3
NOTICE:  BL31: Built : 20:19:41, Feb 19 2024
I/TC: Physical secure memory base 0xcb040000 size 0xf00000
  bpmp: init
bpmp: tag is 128431eec76692047e1ac1ebc0392266
sku_dt_init: not sku 0x00
clk_early initialized
mail_early initialized
fuse initialized
hwwdt initialized
t194_ec_get_ec_list: found 45 ecs
ec initialized
vmon_setup_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
mc initialized
reset initialized
nvhs initialized
uphy_early initialized
emc_early initialized
392 clocks registered
clk initialized
io_dpd initialized
thermal initialized
thermal_mrq initialized
i2c initialized
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
vrmon initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
suspend initialized
pg_late initialized
pg_mrq_init initialized
strap initialized
nvl initialized
emc initialized
emc_mrq initialized
clk_dt initialized
tj_init initialized
uphy_dt initialized
uphy_mrq initialized
▒▒uphy initialized
  ▒▒ec_swd_poll_start: 281 reg polling start w period 47 ms
ec_late initialized
hwwdt_late initialized
reset_mrq initialized
ec_mrq initialized
fmon_mrq initialized
clk_mrq initialized
avfs_mrq initialized
mail_mrq initialized
i2c_mrq initialized
tag_mrq initialized
console_mrq initialized
mrq initialized
clk_sync_fmon_post initialized
clk_dt_late initialized
noc_late initialized
pm_post initialized
dbells initialized
dmce initialized
cvc initialized
▒▒▒▒avfs_clk_mach_post initialized
▒▒I/TC▒▒avfs_clk_platform_post initialized
▒▒: N▒▒cvc_late initialized
regulator_post initialized
▒▒on-s▒▒rm initialized
console_late initialized
clk_dt_post initialized
▒▒ec▒▒mc_reg initialized
▒▒ure external DT found
▒▒pg_post initialized
profile initialized
fuse_late initialized
extras_post initialized
bpmp: init complete
entering main console loop
] ▒▒I/TC: OP-TEE version: 3.22 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Tue Feb 20 04:29:02 UTC 2024 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: Primary CPU switching to normal world boot
  [0003.250] I> Welcome to NVDisp-Init
[0003.250] I> NVDisp-Init version: t194-51f071e0
[0003.251] I> CPU-BL Params @ 0xca020000
[0003.251] I>  0) Base:0x00000000 Size:0x00000000
[0003.251] I>  1) Base:0xc8100000 Size:0x00100000
[0003.252] I>  2) Base:0xc9800000 Size:0x00200000
[0003.252] I>  3) Base:0xc8600000 Size:0x00200000
[0003.255] I>  4) Base:0xc8000000 Size:0x00100000
[0003.259] I>  5) Base:0xc7f00000 Size:0x00100000
[0003.263] I>  6) Base:0xc9400000 Size:0x00400000
[0003.268] I>  7) Base:0xc9000000 Size:0x00400000
[0003.272] I>  8) Base:0xc7e00000 Size:0x00100000
[0003.277] I>  9) Base:0xc7d00000 Size:0x00100000
[0003.281] I> 10) Base:0xca800000 Size:0x00800000
[0003.286] I> 11) Base:0x40000000 Size:0x00040000
[0003.290] I> 12) Base:0xc7c00000 Size:0x00100000
[0003.295] I> 13) Base:0x40046000 Size:0x00002000
[0003.299] I> 14) Base:0x40048000 Size:0x00002000
[0003.304] I> 15) Base:0xaf000000 Size:0x00004000
[0003.308] I> 16) Base:0x4004a000 Size:0x00002000
[0003.313] I> 17) Base:0xc7a00000 Size:0x00100000
[0003.317] I> 18) Base:0x4004c000 Size:0x00002000
[0003.321] I> 19) Base:0xc9a00000 Size:0x00600000
[0003.326] I> 20) Base:0x4004e000 Size:0x00002000
[0003.330] I> 21) Base:0xc7bc0000 Size:0x0000c000
[0003.335] I> 22) Base:0x00000000 Size:0x00000000
[0003.339] I> 23) Base:0xc7be0000 Size:0x00020000
[0003.344] I> 24) Base:0xcc000000 Size:0x02000000
[0003.348] I> 25) Base:0x40050000 Size:0x00002000
[0003.353] I> 26) Base:0x40040000 Size:0x00006000
[0003.357] I> 27) Base:0xc8c00000 Size:0x00400000
[0003.362] I> 28) Base:0xc8400000 Size:0x00200000
[0003.366] I> 29) Base:0xc8800000 Size:0x00400000
[0003.371] I> 30) Base:0xc7bd0000 Size:0x00010000
[0003.375] I> 31) Base:0x00000000 Size:0x00000000
[0003.379] I> 32) Base:0xf8000000 Size:0x08000000
[0003.384] I> 33) Base:0xce000000 Size:0x2a000000
[0003.388] I> 34) Base:0xcb000000 Size:0x01000000
[0003.393] I> 35) Base:0xae000000 Size:0x01000000
[0003.397] I> 36) Base:0xa0000000 Size:0x0e000000
[0003.402] I> 37) Base:0xca000000 Size:0x00800000
[0003.406] I> 38) Base:0x80000000 Size:0x20000000
[0003.411] I> 39) Base:0xb0000000 Size:0x08000000
[0003.415] I> 40) Base:0x00000000 Size:0x00000000
[0003.420] I> 41) Base:0x00000000 Size:0x00000000
[0003.424] I> 42) Base:0xc8200000 Size:0x00200000
[0003.429] I> 43) Base:0x00000000 Size:0x00000000
[0003.433] I> 44) Base:0x00000000 Size:0x00000000
[0003.437] I> 45) Base:0x00000000 Size:0x00000000
[0003.442] GIC-SPI Target CPU: 0
[0003.445] Interrupts Init done
[0003.448] calling constructors
[0003.451] initializing heap
[0003.453] I> Heap: [0xa0a60000 ... 0xadf00000]
[0003.458] initializing threads
[0003.461] initializing timers
[0003.463] creating bootstrap completion thread
[0003.468] top of bootstrap2()
[0003.470] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0003.475] initializing platform
[0003.478] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0003.483] W> device prod register failed
[0003.487] I> Bl_dtb @0xadf00000
[0003.490] I> gpio framework initialized
[0003.502] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0003.508] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0003.514] I> fixed regulator driver initialized
[0003.532] I> register 'maxim' power off handle
[0003.536] I> virtual i2c enabled
[0003.536] I> registered 'maxim,max20024' pmic
[0003.537] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0003.537] I> Boot-device: QSPI
[0003.538] I> Boot_device: QSPI_FLASH instance: 0
[0003.539] I> configure_qspi_clk: qparams clk_src = 5, clk_div = 0, clk_src_freq = 800000000, interface_freq = 50000000
[0003.549] I> configure_qspi_clk: FORCING INTERFACE_FREQ TO 133000000!!
[0003.557] I> QSPI source rate = 204000 Khz
[0003.560] I> Requested rate for QSPI clock = 34000 Khz
[0003.565] I> BPMP-set rate for QSPI clk = 34000 Khz
[0003.570] I> tx_clk_tap_delay : 0
[0003.573] I> rx_clk_tap_delay : 16
[0003.576] I> QSPI Flash Size = 32 MB
[0003.584] I> Qspi initialized successfully
[0003.584] I> qspi flash-0 params source = boot args
[0003.589] W> No board IDs available
[0003.591] E> Failed to get board id info!
[0003.595] E> Failed: Unknown device 6
[0003.603] I> Found 41 partitions in QSPI_FLASH (instance 0)
[0003.626] I> regulator 'vdd-hdmi-5v0' already enabled
[0003.634] I> regulator 'vdd-hdmi-5v0' already enabled
[0003.635] I> hdmi cable connected
[0003.641] W> set volts not configured for 'vdd-1v0'
[0003.648] W> set volts not configured for 'vdd-1v8-hs'
[0003.648] I> retrieved tmds range from prod_list_hdmi_soc
[0003.650] E> cannot find any other nvdisp nodes
[0003.655] E> I2C: slave not found in slaves.
[0003.655] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0003.656] E> I2C_DEV: Failed to send register address 0x00000000.
[0003.657] E> I2C_DEV: Could not read 128 registers of size 1 from slave 0xa0 at 0x00000000 via instance 3.
[0003.664] E> could not read edid
[0003.672] I> hdmi_enable, starting HDMI initialisation
[0003.677] I> hdmi_enable, HDMI initialisation complete
[0003.686] initializing target
[0003.687] calling apps_init()
[0003.687] starting app kernel_boot_app
[0003.688] I> Kernel type = Normal
Jetson UEFI firmware (version 5.0-35550185 built on 2024-02-20T04:21:22+00:00)
▒▒I/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
  ▒▒E/TC:? 0 get_rpc_alloc_res:645 RPC allocation failed. Non-secure world result: ret=0xffff0000 ret_origin=0
E/LD:  init_elf:486 sys_open_ta_bin(bc50d971-d4c9-42c4-82cb-343fb7f37896)
E/TC:? 0 ldelf_init_with_ldelf:131 ldelf failed with res: 0xffff000c
That is the reason why assume difference in custom/devkit board HW must be the problem, and why I was asking you if there are some known interfaces that could give trouble .
You should enable UEFI log by rebuilding the UEFI binary. There would be a debug version built out from it.
That log will tell you why it got stuck there.
Please check the UEFI source github.
It is not right before UEFI. UEFI already loaded.
Hi, just enabled the debug uefi version. Here is the log:
[0000.025] W> RATCHET: MB1 binary ratchet value 4 is larger than ratchet level 2 from HW fuses.
[0000.039] I> Boot-mode: Coldboot
[0000.042] I> Platform: Silicon
[0000.045] I> Chip revision : A02P
[0000.048] I> Bootrom patch version : 15 (correctly patched)
[0000.053] I> ATE fuse revision : 0x200
[0000.056] I> Ram repair fuse : 0x0
[0000.059] I> Ram Code : 0x2
[0000.062] I> rst_source: 0x0, rst_level: 0x0
[0000.067] I> Boot-device: QSPI (instance: 0)
[0000.071] I> Qspi flash params source = brbct
[0000.075] I> Qspi clock source : pllp
[0000.078] I> Qspi-0 initialized successfully
[0000.082] I> Boot chain mechanism: A/B
[0000.086] I> Current Boot-Chain Slot: 0
[0000.089] I> BR-BCT Boot-Chain: 0, status: 0. update flag: 0
[0000.101] W> PROD_CONFIG: device prod data is empty in MB1 BCT.
[0000.108] I> Temperature = 33500
[0000.111] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.128] W> Skipping boost for clk: CAN1
[0000.136] I> Boot-device: QSPI (instance: 0)
[0000.140] I> Qspi flash params source = mb1bct
[0000.144] I> Qspi clock source : pllc_out0
[0000.148] I> Qspi-0 reinitialized
[0000.151] I> Qspi flash params source = mb1bct
[0000.164] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.171] W>  Thermal config not found in BCT
[0000.179] W>  MEMIO rail config not found in BCT
[0000.191] I> Qspi flash params source = mb1bct
[0000.204] I> Qspi flash params source = mb1bct
[0000.238] I> Qspi flash params source = mb1bct
[0000.802] I> Qspi flash params source = mb1bct
[0000.818] I> Qspi flash params source = mb1bct
[0000.858] W>  Platform config not found in BCT
[0000.885] I> Qspi flash params source = mb1bct
[0000.910] I> MB1 done
▒▒▒▒main enter
HW Function test
Start Scheduler.
in late init
  [0000.919] I> Welcome to MB2(TBoot-BPMP) (version: default.t194-mobile-8e4b789e)
[0000.920] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.921] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.922] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.927] W> device prod register failed
[0000.931] I> gpio framework initialized
[0000.935] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0000.942] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0000.950] I> No valid sdcard_params in mb1_bct
[0000.954] I> Boot_device: QSPI_FLASH instance: 0
[0000.958] I> qspi flash-0 params source = boot args
[0000.964] I> QSPI-0l initialized successfully
[0000.967] I> sdmmc-3 params source = safe params
[0001.367] I> sdmmc DDR50 mode
[0001.384] I> Found 41 partitions in QSPI_FLASH (instance 0)
[0001.402] W> Cannot find any partition table for 00000003
[0001.403]  > PARTITION_MANAGER: Failed to publish partition.
[0001.418] I> Found 22 partitions in SDMMC_USER (instance 3)
[0001.420] I> Active Boot chain : 0
[0002.186] I> Relocating BR-BCT
[0002.187]  > DEVICE_PROD: device prod is not initialized.
[0002.213] E> I2C: slave not found in slaves.
[0002.214] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0002.215] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.216] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 0.
[0002.217] E> eeprom: Failed to read I2C slave device
[0002.220] I> Failed to read CVB eeprom data @ AE
[0002.224] I> Retrying CVB eeprom read @ AC ...
[0002.229] E> I2C: slave not found in slaves.
[0002.233] E> I2C: Could not write 0 bytes to slave: 0x00ac with repeat start true.
[0002.241] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.247] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xac at 0x00000000 via instance 0.
[0002.256] E> eeprom: Failed to read I2C slave device
[0002.261] I> Failed to read CVB eeprom data @ AC
[0002.564] I> Relocating OP-TEE dtb from: 0x6bfff720 to 0x70050000, size: 1008
[0002.565] I> [0] START: 0x80000000, SIZE: 0x2f000000
[0002.566] I> [1] START: 0xaf010000, SIZE: 0x189f0000
[0002.566] I> [2] START: 0xc7b00000, SIZE: 0xc0000
[0002.567] I> [3] START: 0xca000000, SIZE: 0x800000
[0002.567] I> dram_block larger than 80000000
[0002.569] I> [4] START: 0x100000000, SIZE: 0x380000000
[0002.581] I> Setting NS memory ranges to OP-TEE dtb finished.
[0002.584] I> found decompressor handler: lz4
[0002.992] I> EKB detected (length: 0x410) @ VA:0x52709400
[0002.994] I> Setting EKB blob info to OPTEE dtb finished.
  bpmp: init
fuse initialized
hwwdt initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
mc initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
vrmon initialized
aotag initialized
dvs initialized
pm initialized
suspend initialized
pg_late initialized
strap initialized
nvl initialized
emc initialized
emc_mrq initialized
clk_dt initialized
tj_init initialized
uphy_dt initialized
▒▒I/TC:
▒▒uphy initialized
ec_late initialized
ec_mrq initialized
clk_mrq initialized
i2c_mrq initialized
tag_mrq initialized
mrq initialized
pm_post initialized
dbells initialized
dmce initialized
cvc initialized
▒▒I/T▒▒avfs_clk_mach_post initialized
▒▒C: N▒▒avfs_clk_platform_post initialized
▒▒on-▒▒cvc_late initialized
▒▒secu▒▒rm initialized
▒▒re▒▒mc_reg initialized
▒▒ external DT found
profile initialized
bpmp: init complete
  [0003.718] I> Welcome to NVDisp-Init
[0003.718] I> NVDisp-Init version: t194-51f071e0
[0003.718] I> CPU-BL Params @ 0xca020000
[0003.719] I>  0) Base:0x00000000 Size:0x00000000
[0003.719] I>  1) Base:0xc8100000 Size:0x00100000
[0003.719] I>  2) Base:0xc9800000 Size:0x00200000
[0003.720] I>  3) Base:0xc8600000 Size:0x00200000
[0003.722] I>  4) Base:0xc8000000 Size:0x00100000
[0003.727] I>  5) Base:0xc7f00000 Size:0x00100000
[0003.731] I>  6) Base:0xc9400000 Size:0x00400000
[0003.735] I>  7) Base:0xc9000000 Size:0x00400000
[0003.740] I>  8) Base:0xc7e00000 Size:0x00100000
[0003.744] I>  9) Base:0xc7d00000 Size:0x00100000
[0003.749] I> 10) Base:0xca800000 Size:0x00800000
[0003.753] I> 11) Base:0x40000000 Size:0x00040000
[0003.758] I> 12) Base:0xc7c00000 Size:0x00100000
[0003.762] I> 13) Base:0x40046000 Size:0x00002000
[0003.767] I> 14) Base:0x40048000 Size:0x00002000
[0003.771] I> 15) Base:0xaf000000 Size:0x00004000
[0003.776] I> 16) Base:0x4004a000 Size:0x00002000
[0003.780] I> 17) Base:0xc7a00000 Size:0x00100000
[0003.785] I> 18) Base:0x4004c000 Size:0x00002000
[0003.789] I> 19) Base:0xc9a00000 Size:0x00600000
[0003.793] I> 20) Base:0x4004e000 Size:0x00002000
[0003.798] I> 21) Base:0xc7bc0000 Size:0x0000c000
[0003.802] I> 22) Base:0x00000000 Size:0x00000000
[0003.807] I> 23) Base:0xc7be0000 Size:0x00020000
[0003.811] I> 24) Base:0xcc000000 Size:0x02000000
[0003.816] I> 25) Base:0x40050000 Size:0x00002000
[0003.820] I> 26) Base:0x40040000 Size:0x00006000
[0003.825] I> 27) Base:0xc8c00000 Size:0x00400000
[0003.829] I> 28) Base:0xc8400000 Size:0x00200000
[0003.834] I> 29) Base:0xc8800000 Size:0x00400000
[0003.838] I> 30) Base:0xc7bd0000 Size:0x00010000
[0003.843] I> 31) Base:0x00000000 Size:0x00000000
[0003.847] I> 32) Base:0xf8000000 Size:0x08000000
[0003.851] I> 33) Base:0xce000000 Size:0x2a000000
[0003.856] I> 34) Base:0xcb000000 Size:0x01000000
[0003.860] I> 35) Base:0xae000000 Size:0x01000000
[0003.865] I> 36) Base:0xa0000000 Size:0x0e000000
[0003.869] I> 37) Base:0xca000000 Size:0x00800000
[0003.874] I> 38) Base:0x80000000 Size:0x20000000
[0003.878] I> 39) Base:0xb0000000 Size:0x08000000
[0003.883] I> 40) Base:0x00000000 Size:0x00000000
[0003.887] I> 41) Base:0x00000000 Size:0x00000000
[0003.892] I> 42) Base:0xc8200000 Size:0x00200000
[0003.896] I> 43) Base:0x00000000 Size:0x00000000
[0003.901] I> 44) Base:0x00000000 Size:0x00000000
[0003.905] I> 45) Base:0x00000000 Size:0x00000000
[0003.909] GIC-SPI Target CPU: 0
[0003.912] Interrupts Init done
[0003.915] calling constructors
[0003.918] initializing heap
[0003.921] I> Heap: [0xa0a60000 ... 0xadf00000]
[0003.925] initializing threads
[0003.928] initializing timers
[0003.931] creating bootstrap completion thread
[0003.935] top of bootstrap2()
[0003.938] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0003.943] initializing platform
[0003.946] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0003.951] W> device prod register failed
[0003.955] I> Bl_dtb @0xadf00000
[0003.958] I> gpio framework initialized
[0003.968] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0003.973] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0003.980] I> fixed regulator driver initialized
[0004.004] I> register 'maxim' power off handle
[0004.009] I> virtual i2c enabled
[0004.010] I> registered 'maxim,max20024' pmic
[0004.010] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0004.011] I> Boot-device: QSPI
[0004.011] I> Boot_device: QSPI_FLASH instance: 0
[0004.011] I> configure_qspi_clk: qparams clk_src = 5, clk_div = 0, clk_src_freq = 800000000, interface_freq = 50000000
[0004.017] I> configure_qspi_clk: FORCING INTERFACE_FREQ TO 133000000!!
[0004.024] I> QSPI source rate = 204000 Khz
[0004.027] I> Requested rate for QSPI clock = 34000 Khz
[0004.033] I> BPMP-set rate for QSPI clk = 34000 Khz
[0004.037] I> tx_clk_tap_delay : 0
[0004.040] I> rx_clk_tap_delay : 16
[0004.043] I> QSPI Flash Size = 32 MB
[0004.051] I> Qspi initialized successfully
[0004.052] I> qspi flash-0 params source = boot args
[0004.057] W> No board IDs available
[0004.059] E> Failed to get board id info!
[0004.065] I> sdmmc-3 params source = safe params
[0004.072] I> Found 41 partitions in QSPI_FLASH (instance 0)
[0004.073] W> Cannot find any partition table for 00000003
[0004.078] E> Failed to publish 00000003
[0004.087] I> Found 22 partitions in SDMMC_USER (instance 3)
[0004.111] I> regulator 'vdd-hdmi-5v0' already enabled
[0004.121] I> regulator 'vdd-hdmi-5v0' already enabled
[0004.122] I> hdmi cable connected
[0004.131] W> set volts not configured for 'vdd-1v0'
[0004.141] W> set volts not configured for 'vdd-1v8-hs'
[0004.142] I> retrieved tmds range from prod_list_hdmi_soc
[0004.144] E> cannot find any other nvdisp nodes
[0004.149] E> I2C: slave not found in slaves.
[0004.150] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0004.151] E> I2C_DEV: Failed to send register address 0x00000000.
[0004.151] E> I2C_DEV: Could not read 128 registers of size 1 from slave 0xa0 at 0x00000000 via instance 3.
[0004.158] E> could not read edid
[0004.166] I> hdmi_enable, starting HDMI initialisation
[0004.171] I> hdmi_enable, HDMI initialisation complete
[0004.180] initializing target
[0004.181] calling apps_init()
[0004.182] starting app kernel_boot_app
[0004.183] I> Kernel type = Normal
Jetson UEFI firmware (version 202409.0-d3a6ad99 built on 2025-02-21T13:26:25+01:00)
Carveout 1 Region: Base: 0x00000000C8100000, Size: 0x0000000000100000
Carveout 2 Region: Base: 0x00000000C9800000, Size: 0x0000000000200000
Carveout 3 Region: Base: 0x00000000C8600000, Size: 0x0000000000200000
Carveout 4 Region: Base: 0x00000000C8000000, Size: 0x0000000000100000
Carveout 5 Region: Base: 0x00000000C7F00000, Size: 0x0000000000100000
Carveout 6 Region: Base: 0x00000000C9400000, Size: 0x0000000000400000
Carveout 7 Region: Base: 0x00000000C9000000, Size: 0x0000000000400000
Carveout 8 Region: Base: 0x00000000C7E00000, Size: 0x0000000000100000
Carveout 9 Region: Base: 0x00000000C7D00000, Size: 0x0000000000100000
Carveout 10 Region: Base: 0x00000000CA800000, Size: 0x0000000000800000
Carveout 11 Region: Base: 0x0000000040000000, Size: 0x0000000000040000
Carveout 12 Region: Base: 0x00000000C7C00000, Size: 0x0000000000100000
Carveout 13 Region: Base: 0x0000000040046000, Size: 0x0000000000002000
Carveout 14 Region: Base: 0x0000000040048000, Size: 0x0000000000002000
Carveout 15 Region: Base: 0x00000000AF000000, Size: 0x0000000000004000
Carveout 16 Region: Base: 0x000000004004A000, Size: 0x0000000000002000
Carveout 17 Region: Base: 0x00000000C7A00000, Size: 0x0000000000100000
Carveout 18 Region: Base: 0x000000004004C000, Size: 0x0000000000002000
Carveout 19 Region: Base: 0x00000000C9A00000, Size: 0x0000000000600000
Carveout 20 Region: Base: 0x000000004004E000, Size: 0x0000000000002000
Carveout 21 Region: Base: 0x00000000C7BC0000, Size: 0x000000000000C000
Carveout 23 Region: Base: 0x00000000C7BE0000, Size: 0x0000000000020000
Carveout 24 Region: Base: 0x00000000CC000000, Size: 0x0000000002000000
Carveout 25 Region: Base: 0x0000000040050000, Size: 0x0000000000002000
Carveout 26 Region: Base: 0x0000000040040000, Size: 0x0000000000006000
Carveout 27 Region: Base: 0x00000000C8C00000, Size: 0x0000000000400000
Carveout 28 Region: Base: 0x00000000C8400000, Size: 0x0000000000200000
Carveout 29 Region: Base: 0x00000000C8800000, Size: 0x0000000000400000
Carveout 30 Region: Base: 0x00000000C7BD0000, Size: 0x0000000000010000
Carveout 32 Region: Base: 0x00000000F8000000, Size: 0x0000000008000000
Carveout 33 Region: Base: 0x00000000CE000000, Size: 0x000000002A000000
Carveout 34 Region: Base: 0x00000000CB000000, Size: 0x0000000001000000
Carveout 35 Region: Base: 0x00000000AE000000, Size: 0x0000000001000000
Carveout 36 Region: Base: 0x00000000A0000000, Size: 0x000000000E000000
Carveout 37 Region: Base: 0x00000000CA000000, Size: 0x0000000000800000
Carveout 38 Region: Base: 0x0000000080000000, Size: 0x0000000020000000
Carveout 39 Region: Base: 0x00000000B0000000, Size: 0x0000000008000000
Carveout 42 Region: Base: 0x00000000C8200000, Size: 0x0000000000200000
Processing "L4T Configuration Settings" DTB overlay
Processing "Jetson Xavier NX Overlay Support" DTB overlay
DTB maximums: sockets=1 clusters=4 cores=8
SocketMask=0x1 NumberOfEnabledCores=6
Model: NVIDIA Jetson Xavier NX Developer Kit
Main memory region: (0x0000000100000000, 0x0000000380000000)
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Core/Dxe/DxeMain/DEBUG/DxeCore.dll 0x47B942000
Loading DxeCore at 0x047B941000 EntryPoint=0x047B94B290
HOBLIST address in DXE = 0x478A57018
Memory Allocation 0x00000004 0xADEFF000 - 0xADEFFFFF
Memory Allocation 0x00000004 0xADEFE000 - 0xADEFEFFF
Memory Allocation 0x00000004 0xADEFD000 - 0xADEFDFFF
Memory Allocation 0x00000004 0xADEFC000 - 0xADEFCFFF
Memory Allocation 0x00000004 0xADEFB000 - 0xADEFBFFF
Memory Allocation 0x00000004 0xADEFA000 - 0xADEFAFFF
Memory Allocation 0x00000004 0xADEF9000 - 0xADEF9FFF
Memory Allocation 0x00000004 0xADEF8000 - 0xADEF8FFF
Memory Allocation 0x00000004 0xADEF7000 - 0xADEF7FFF
Memory Allocation 0x00000004 0xADEF6000 - 0xADEF6FFF
Memory Allocation 0x00000004 0xADEF5000 - 0xADEF5FFF
Memory Allocation 0x00000004 0xCA000000 - 0xCA7FFFFF
Memory Allocation 0x00000004 0xADEF4000 - 0xADEF4FFF
Memory Allocation 0x00000004 0xADEF3000 - 0xADEF3FFF
Memory Allocation 0x00000004 0xADEF2000 - 0xADEF2FFF
Memory Allocation 0x00000004 0xADEF1000 - 0xADEF1FFF
Memory Allocation 0x00000004 0xADEF0000 - 0xADEF0FFF
Memory Allocation 0x00000004 0xADEEF000 - 0xADEEFFFF
Memory Allocation 0x00000004 0x47FEC0000 - 0x47FFFFFFF
Memory Allocation 0x00000004 0x47FD80000 - 0x47FEBFFFF
Memory Allocation 0x00000004 0xADF00000 - 0xADF51FFF
Memory Allocation 0x00000004 0xADFDD000 - 0xADFFFFFF
Memory Allocation 0x00000004 0xA0660000 - 0xA098FFFF
Memory Allocation 0x00000004 0x47FD70000 - 0x47FD7FFFF
Memory Allocation 0x00000004 0x47DB7E000 - 0x47FD6FFFF
Memory Allocation 0x00000004 0x47B98D000 - 0x47DB7DFFF
Memory Allocation 0x00000003 0x47B941000 - 0x47B98CFFF
FV Hob            0xA0660000 - 0xA098FFFF
FV Hob            0x47B98D000 - 0x47DB7CFFF
FV2 Hob           0x47B98D000 - 0x47DB7CFFF
                  49A79A15-8F69-4BE7-A30C-A172F44ABCE7 - 9E21FD93-9C72-4C15-8C4B-E77F1DB2D792
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/PCD/Dxe/Pcd/DEBUG/PcdDxe.dll 0x4799F5000
Loading driver at 0x004799F4000 EntryPoint=0x004799FB0B8 PcdDxe.efi
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/TegraPlatformInit/TegraPlatformInitDxe/DEBUG/TegraPlatformInitDxe.dll 0x4799E4000
Loading driver at 0x004799E3000 EntryPoint=0x004799EB074 TegraPlatformInitDxe.efi
Core: 6 is not present
Core: 7 is not present
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/ArmPkg/Drivers/ArmGic/ArmGicDxe/DEBUG/ArmGicDxe.dll 0x4799DA000
Loading driver at 0x004799D9000 EntryPoint=0x004799DE638 ArmGicDxe.efi
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/ArmPkg/Drivers/CpuDxe/CpuDxe/DEBUG/ArmCpuDxe.dll 0x4799CB000
Loading driver at 0x004799CA000 EntryPoint=0x004799D00AC ArmCpuDxe.efi
ReplaceTableEntry: splitting block entry with MMU disabled
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Core/Dxe/DxeMain/DEBUG/DxeCore.dll
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/PCD/Dxe/Pcd/DEBUG/PcdDxe.dll
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/TegraPlatformInit/TegraPlatformInitDxe/DEBUG/TegraPlatformInitDxe.dll
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/ArmPkg/Drivers/ArmGic/ArmGicDxe/DEBUG/ArmGicDxe.dll
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/ArmPkg/Drivers/CpuDxe/CpuDxe/DEBUG/ArmCpuDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Bus/Pci/NonDiscoverablePciDeviceDxe/NonDiscoverablePciDeviceDxe/DEBUG/NonDiscoverablePciDeviceDxe.dll 0x4799C0000
Loading driver at 0x004799BF000 EntryPoint=0x004799C59AC NonDiscoverablePciDeviceDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Bus/Pci/NonDiscoverablePciDeviceDxe/NonDiscoverablePciDeviceDxe/DEBUG/NonDiscoverablePciDeviceDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Bus/Pci/SdMmcPciHcDxe/SdMmcPciHcDxe/DEBUG/SdMmcPciHcDxe.dll 0x4799AF000
Loading driver at 0x004799AE000 EntryPoint=0x004799B9510 SdMmcPciHcDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Bus/Pci/SdMmcPciHcDxe/SdMmcPciHcDxe/DEBUG/SdMmcPciHcDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Bus/Pci/UfsPciHcDxe/UfsPciHcDxe/DEBUG/UfsPciHcDxe.dll 0x4799A6000
Loading driver at 0x004799A5000 EntryPoint=0x004799AA164 UfsPciHcDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Bus/Pci/UfsPciHcDxe/UfsPciHcDxe/DEBUG/UfsPciHcDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Bus/Sd/EmmcDxe/EmmcDxe/DEBUG/EmmcDxe.dll 0x479998000
Loading driver at 0x00479997000 EntryPoint=0x0047999F9A8 EmmcDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Bus/Sd/EmmcDxe/EmmcDxe/DEBUG/EmmcDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Bus/Sd/SdDxe/SdDxe/DEBUG/SdDxe.dll 0x47998C000
Loading driver at 0x0047998B000 EntryPoint=0x004799927E4 SdDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Bus/Sd/SdDxe/SdDxe/DEBUG/SdDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Bus/Ufs/UfsPassThruDxe/UfsPassThruDxe/DEBUG/UfsPassThruDxe.dll 0x47997E000
Loading driver at 0x0047997D000 EntryPoint=0x00479985A40 UfsPassThruDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Bus/Ufs/UfsPassThruDxe/UfsPassThruDxe/DEBUG/UfsPassThruDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/Disk/DiskIoDxe/DiskIoDxe/DEBUG/DiskIoDxe.dll 0x479973000
Loading driver at 0x00479972000 EntryPoint=0x004799785F8 DiskIoDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/Disk/DiskIoDxe/DiskIoDxe/DEBUG/DiskIoDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/Disk/PartitionDxe/PartitionDxe/DEBUG/PartitionDxe.dll 0x479966000
Loading driver at 0x00479965000 EntryPoint=0x0047996D060 PartitionDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/Disk/PartitionDxe/PartitionDxe/DEBUG/PartitionDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Bus/I2c/I2cDxe/I2cDxe/DEBUG/I2cDxe.dll 0x47995A000
Loading driver at 0x00479959000 EntryPoint=0x0047995FD28 I2cDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Bus/I2c/I2cDxe/I2cDxe/DEBUG/I2cDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Bus/Scsi/ScsiBusDxe/ScsiBusDxe/DEBUG/ScsiBus.dll 0x47994F000
Loading driver at 0x0047994E000 EntryPoint=0x00479954424 ScsiBus.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Bus/Scsi/ScsiBusDxe/ScsiBusDxe/DEBUG/ScsiBus.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Bus/Scsi/ScsiDiskDxe/ScsiDiskDxe/DEBUG/ScsiDisk.dll 0x47993E000
Loading driver at 0x0047993D000 EntryPoint=0x004799496C8 ScsiDisk.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Bus/Scsi/ScsiDiskDxe/ScsiDiskDxe/DEBUG/ScsiDisk.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/Disk/UnicodeCollation/EnglishDxe/EnglishDxe/DEBUG/EnglishDxe.dll 0x479935000
Loading driver at 0x00479934000 EntryPoint=0x00479938644 EnglishDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/Disk/UnicodeCollation/EnglishDxe/EnglishDxe/DEBUG/EnglishDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/FatPkg/EnhancedFatDxe/Fat/DEBUG/Fat.dll 0x479924000
Loading driver at 0x00479923000 EntryPoint=0x0047992E5F0 Fat.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/FatPkg/EnhancedFatDxe/Fat/DEBUG/Fat.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/ReportStatusCodeRouter/RuntimeDxe/ReportStatusCodeRouterRuntimeDxe/DEBUG/ReportStatusCodeRouterRuntimeDxe.dll 0x47A960000
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/ReportStatusCodeRouter/RuntimeDxe/ReportStatusCodeRouterRuntimeDxe/DEBUG/ReportStatusCodeRouterRuntimeDxe.dll
Loading driver at 0x0047A950000 EntryPoint=0x0047A963CA0 ReportStatusCodeRouterRuntimeDxe.efi
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Core/RuntimeDxe/RuntimeDxe/DEBUG/RuntimeDxe.dll 0x47A910000
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Core/RuntimeDxe/RuntimeDxe/DEBUG/RuntimeDxe.dll
Loading driver at 0x0047A900000 EntryPoint=0x0047A913BBC RuntimeDxe.efi
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/SecurityStubDxe/SecurityStubDxe/DEBUG/SecurityStubDxe.dll 0x47981D000
Loading driver at 0x0047981C000 EntryPoint=0x0047982552C SecurityStubDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/SecurityStubDxe/SecurityStubDxe/DEBUG/SecurityStubDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/SectionExtractionDxe/SectionExtractionDxe/DEBUG/SectionExtractionDxe.dll 0x479814000
Loading driver at 0x00479813000 EntryPoint=0x00479817440 SectionExtractionDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/SectionExtractionDxe/SectionExtractionDxe/DEBUG/SectionExtractionDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/Metronome/Metronome/DEBUG/Metronome.dll 0x47980C000
Loading driver at 0x0047980B000 EntryPoint=0x0047980F304 Metronome.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/Metronome/Metronome/DEBUG/Metronome.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/ResetSystemRuntimeDxe/ResetSystemRuntimeDxe/DEBUG/ResetSystemRuntimeDxe.dll 0x47A8C0000
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/ResetSystemRuntimeDxe/ResetSystemRuntimeDxe/DEBUG/ResetSystemRuntimeDxe.dll
Loading driver at 0x0047A8B0000 EntryPoint=0x0047A8C3F70 ResetSystemRuntimeDxe.efi
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/DefaultVariableDxe/DefaultVariableDxe/DEBUG/DefaultVariableDxe.dll 0x4797FF000
Loading driver at 0x004797FE000 EntryPoint=0x00479806060 DefaultVariableDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/DefaultVariableDxe/DefaultVariableDxe/DEBUG/DefaultVariableDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/TimestampDxe/TimestampDxe/DEBUG/TimestampDxe.dll 0x4797F7000
Loading driver at 0x004797F6000 EntryPoint=0x004797FA340 TimestampDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/TimestampDxe/TimestampDxe/DEBUG/TimestampDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/FwImageDxe/FwImageDxe/DEBUG/FwImageDxe.dll 0x47A870000
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/FwImageDxe/FwImageDxe/DEBUG/FwImageDxe.dll
Loading driver at 0x0047A860000 EntryPoint=0x0047A874718 FwImageDxe.efi
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/EsrtFmpDxe/EsrtFmpDxe/DEBUG/EsrtFmpDxe.dll 0x4797ED000
Loading driver at 0x004797EC000 EntryPoint=0x004797F1048 EsrtFmpDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/EsrtFmpDxe/EsrtFmpDxe/DEBUG/EsrtFmpDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/AmlGenerationDxe/AmlGenerationDxe/DEBUG/AmlGenerationDxe.dll 0x4797E4000
Loading driver at 0x004797E3000 EntryPoint=0x004797E7920 AmlGenerationDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/AmlGenerationDxe/AmlGenerationDxe/DEBUG/AmlGenerationDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/AmlPatchDxe/AmlPatchDxe/DEBUG/AmlPatchDxe.dll 0x4797DB000
Loading driver at 0x004797DA000 EntryPoint=0x004797DEB18 AmlPatchDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/AmlPatchDxe/AmlPatchDxe/DEBUG/AmlPatchDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/ConfigurationManagerTokenDxe/ConfigurationManagerTokenDxe/DEBUG/ConfigurationManagerTokenDxe.dll 0x4797D2000
Loading driver at 0x004797D1000 EntryPoint=0x004797D54C0 ConfigurationManagerTokenDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/ConfigurationManagerTokenDxe/ConfigurationManagerTokenDxe/DEBUG/ConfigurationManagerTokenDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/DynamicTablesPkg/Drivers/DynamicTableFactoryDxe/DynamicTableFactoryDxe/DEBUG/DynamicTableFactoryDxe.dll 0x479798000
Loading driver at 0x00479797000 EntryPoint=0x004797A2860 DynamicTableFactoryDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/DynamicTablesPkg/Drivers/DynamicTableFactoryDxe/DynamicTableFactoryDxe/DEBUG/DynamicTableFactoryDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/HiiDatabaseDxe/HiiDatabaseDxe/DEBUG/HiiDatabase.dll 0x479775000
Loading driver at 0x00479774000 EntryPoint=0x004797789AC HiiDatabase.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/HiiDatabaseDxe/HiiDatabaseDxe/DEBUG/HiiDatabase.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/PrintDxe/PrintDxe/DEBUG/PrintDxe.dll 0x47976C000
Loading driver at 0x0047976B000 EntryPoint=0x0047976FED0 PrintDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/PrintDxe/PrintDxe/DEBUG/PrintDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/BpmpIpc/BpmpIpcDxe/DEBUG/BpmpIpcDxe.dll 0x47975E000
Loading driver at 0x0047975D000 EntryPoint=0x00479765890 BpmpIpcDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/BpmpIpc/BpmpIpcDxe/DEBUG/BpmpIpcDxe.dll
HspDoorbellEnableChannel: Waiting for HSP Doorbell Channel Enabled.
HspDoorbellEnableChannel: HSP Doorbell Channel Enabled.
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/BpmpI2c/BpmpI2cDxe/DEBUG/BpmpI2cDxe.dll 0x479753000
Loading driver at 0x00479752000 EntryPoint=0x004797581B4 BpmpI2cDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/BpmpI2c/BpmpI2cDxe/DEBUG/BpmpI2cDxe.dll
BuildI2cDevices: maxim,max20024 detected
BuildI2cDevices: Address 3C
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/I2cExpanderGpio/I2cExpanderGpio/DEBUG/I2cExpanderGpio.dll 0x47974A000
Loading driver at 0x00479749000 EntryPoint=0x0047974DD48 I2cExpanderGpio.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/I2cExpanderGpio/I2cExpanderGpio/DEBUG/I2cExpanderGpio.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/IpmiNullDxe/IpmiNullDxe/DEBUG/IpmiNullDxe.dll 0x479741000
Loading driver at 0x00479740000 EntryPoint=0x00479744448 IpmiNullDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/IpmiNullDxe/IpmiNullDxe/DEBUG/IpmiNullDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/Logo/LogoDxe/DEBUG/LogoDxe.dll 0x479737000
Loading driver at 0x00479736000 EntryPoint=0x0047973AE04 LogoDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/Logo/LogoDxe/DEBUG/LogoDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/ArmPkg/Drivers/TimerDxe/TimerDxe/DEBUG/ArmTimerDxe.dll 0x47972E000
Loading driver at 0x0047972D000 EntryPoint=0x004797314EC ArmTimerDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/ArmPkg/Drivers/TimerDxe/TimerDxe/DEBUG/ArmTimerDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/BootWatchdog/BootWatchdog/DEBUG/BootWatchdog.dll 0x479725000
Loading driver at 0x00479724000 EntryPoint=0x00479728AC4 BootWatchdog.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/BootWatchdog/BootWatchdog/DEBUG/BootWatchdog.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/UsbFirmwareDxe/UsbFirmwareDxe/DEBUG/UsbFirmwareDxe.dll 0x47971C000
Loading driver at 0x0047971B000 EntryPoint=0x0047971FBFC UsbFirmwareDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/UsbFirmwareDxe/UsbFirmwareDxe/DEBUG/UsbFirmwareDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/ArmPkg/Drivers/ArmPciCpuIo2Dxe/ArmPciCpuIo2Dxe/DEBUG/ArmPciCpuIo2Dxe.dll 0x479713000
Loading driver at 0x00479712000 EntryPoint=0x004797167C0 ArmPciCpuIo2Dxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/ArmPkg/Drivers/ArmPciCpuIo2Dxe/ArmPciCpuIo2Dxe/DEBUG/ArmPciCpuIo2Dxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/TegraP2UDxe/TegraP2UDxe/DEBUG/TegraP2UDxe.dll 0x479709000
Loading driver at 0x00479708000 EntryPoint=0x0047970CFA0 TegraP2UDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/TegraP2UDxe/TegraP2UDxe/DEBUG/TegraP2UDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/VPRDxe/VPRDxe/DEBUG/VPRDxe.dll 0x479700000
Loading driver at 0x004796FF000 EntryPoint=0x004797042D8 VPRDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/VPRDxe/VPRDxe/DEBUG/VPRDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/GoldenRegisterDxe/GoldenRegisterDxe/DEBUG/GoldenRegisterDxe.dll 0x4796F7000
Loading driver at 0x004796F6000 EntryPoint=0x004796FA734 GoldenRegisterDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/GoldenRegisterDxe/GoldenRegisterDxe/DEBUG/GoldenRegisterDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/FSIDxe/FSIDxe/DEBUG/FSIDxe.dll 0x4796EE000
Loading driver at 0x004796ED000 EntryPoint=0x004796F20CC FSIDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/FSIDxe/FSIDxe/DEBUG/FSIDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/BasicProfilerDxe/BasicProfilerDxe/DEBUG/BasicProfilerDxe.dll 0x4796E5000
Loading driver at 0x004796E4000 EntryPoint=0x004796E84C0 BasicProfilerDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/BasicProfilerDxe/BasicProfilerDxe/DEBUG/BasicProfilerDxe.dll
Invalid profiler carveout information
Error: Image at 004796E4000 start failed: Not Found
remove-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/BasicProfilerDxe/BasicProfilerDxe/DEBUG/BasicProfilerDxe.dll 0x796E5000
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/NetworkPkg/DpcDxe/DpcDxe/DEBUG/DpcDxe.dll 0x4796E5000
Loading driver at 0x004796E4000 EntryPoint=0x004796E8730 DpcDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/NetworkPkg/DpcDxe/DpcDxe/DEBUG/DpcDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/SmbiosDxe/SmbiosDxe/DEBUG/SmbiosDxe.dll 0x4796DA000
Loading driver at 0x004796D9000 EntryPoint=0x004796DF288 SmbiosDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/SmbiosDxe/SmbiosDxe/DEBUG/SmbiosDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/DevicePathDxe/DevicePathDxe/DEBUG/DevicePathDxe.dll 0x4796C7000
Loading driver at 0x004796C6000 EntryPoint=0x004796D2888 DevicePathDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/DevicePathDxe/DevicePathDxe/DEBUG/DevicePathDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/SecureBootBmcEvent/SecureBootBmcEvent/DEBUG/SecureBootBmcEvent.dll 0x4796BD000
Loading driver at 0x004796BC000 EntryPoint=0x004796C1668 SecureBootBmcEvent.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/SecureBootBmcEvent/SecureBootBmcEvent/DEBUG/SecureBootBmcEvent.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/SecurityPkg/RandomNumberGenerator/RngDxe/RngDxe/DEBUG/RngDxe.dll 0x4796B4000
Loading driver at 0x004796B3000 EntryPoint=0x004796B7B94 RngDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/SecurityPkg/RandomNumberGenerator/RngDxe/RngDxe/DEBUG/RngDxe.dll
ArmTrngLib could not be correctly initialized.
RngLib uses an Unsafe algorithm and must not be used for production builds.
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/SecurityPkg/Pkcs7Verify/Pkcs7VerifyDxe/Pkcs7VerifyDxe/DEBUG/Pkcs7VerifyDxe.dll 0x4795B6000
Loading driver at 0x004795B5000 EntryPoint=0x004795B812C Pkcs7VerifyDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/SecurityPkg/Pkcs7Verify/Pkcs7VerifyDxe/Pkcs7VerifyDxe/DEBUG/Pkcs7VerifyDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/RcmDxe/RcmDxe/DEBUG/RcmDxe.dll 0x4795AD000
Loading driver at 0x004795AC000 EntryPoint=0x004795B03E4 RcmDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/RcmDxe/RcmDxe/DEBUG/RcmDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/PlatformToDriverConfiguration/PlatformToDriverConfiguration/DEBUG/PlatformToDriverConfiguration.dll 0x4795A3000
Loading driver at 0x004795A2000 EntryPoint=0x004795A7CC8 PlatformToDriverConfiguration.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/PlatformToDriverConfiguration/PlatformToDriverConfiguration/DEBUG/PlatformToDriverConfiguration.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/RegulatorDxe/RegulatorDxe/DEBUG/RegulatorDxe.dll 0x479597000
Loading driver at 0x00479596000 EntryPoint=0x0047959C668 RegulatorDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/RegulatorDxe/RegulatorDxe/DEBUG/RegulatorDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/NorFlashDxe/NorFlashDxe/DEBUG/NorFlashDxe.dll 0x47A820000
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/NorFlashDxe/NorFlashDxe/DEBUG/NorFlashDxe.dll
Loading driver at 0x0047A810000 EntryPoint=0x0047A826540 NorFlashDxe.efi
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/CapsuleUpdatePolicyDxe/CapsuleUpdatePolicyDxe/DEBUG/CapsuleUpdatePolicyDxe.dll 0x47A7D0000
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/CapsuleUpdatePolicyDxe/CapsuleUpdatePolicyDxe/DEBUG/CapsuleUpdatePolicyDxe.dll
Loading driver at 0x0047A7C0000 EntryPoint=0x0047A7D3248 CapsuleUpdatePolicyDxe.efi
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/EepromDxe/Eeprom/DEBUG/EepromDxe.dll 0x47958D000
Loading driver at 0x0047958C000 EntryPoint=0x004795911E8 EepromDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/EepromDxe/Eeprom/DEBUG/EepromDxe.dll
Cvm Eeprom Product Id: 699-13668-0003-301 B.0
Cvb Eeprom data validation failed(Success)
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/NvSecureBootProvisionDxe/NvSecureBootProvisionDxe/DEBUG/NvSecureBootProvisionDxe.dll 0x479581000
Loading driver at 0x00479580000 EntryPoint=0x00479585E4C NvSecureBootProvisionDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/NvSecureBootProvisionDxe/NvSecureBootProvisionDxe/DEBUG/NvSecureBootProvisionDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/ArmPkg/Drivers/ArmPsciMpServicesDxe/ArmPsciMpServicesDxe/DEBUG/ArmPsciMpServicesDxe.dll 0x479572000
Loading driver at 0x00479571000 EntryPoint=0x00479577708 ArmPsciMpServicesDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/ArmPkg/Drivers/ArmPsciMpServicesDxe/ArmPsciMpServicesDxe/DEBUG/ArmPsciMpServicesDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/MmCommunicationOpteeDxe/MmCommunicationOptee/DEBUG/MmCommunicationOptee.dll 0x47A780000
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/MmCommunicationOpteeDxe/MmCommunicationOptee/DEBUG/MmCommunicationOptee.dll
Loading driver at 0x0047A770000 EntryPoint=0x0047A7846A0 MmCommunicationOptee.efi
▒▒add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/DebugStatusCodeDxe/DebugStatusCodeDxe/DEBUG/DebugStatusCodeDxe.dll 0x47A730000
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/DebugStatusCodeDxe/DebugStatusCodeDxe/DEBUG/DebugStatusCodeDxe.dll
Loading driver at 0x0047A720000 EntryPoint=0x0047A733910 DebugStatusCodeDxe.efi
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/Acpi/FirmwarePerformanceDataTableDxe/FirmwarePerformanceDxe/DEBUG/FirmwarePerformanceDxe.dll 0x479568000
Loading driver at 0x00479567000 EntryPoint=0x0047956BD20 FirmwarePerformanceDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/Acpi/FirmwarePerformanceDataTableDxe/FirmwarePerformanceDxe/DEBUG/FirmwarePerformanceDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/Variable/RuntimeDxe/VariableSmmRuntimeDxe/DEBUG/VariableSmmRuntimeDxe.dll 0x47A6E0000
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/Variable/RuntimeDxe/VariableSmmRuntimeDxe/DEBUG/VariableSmmRuntimeDxe.dll
Loading driver at 0x0047A6D0000 EntryPoint=0x0047A6E5D5C VariableSmmRuntimeDxe.efi
Failed to Locate System Partition Guid Not Found
VariableReady: Failed to Process ESP Partition Variables Not Found
CheckVarStoreState: VarIntCheckFailed not found Not Found
AppendKeys Failed to get dbxSigned_0 Not Found
AppendKeys Failed to get dbSigned_0 Not Found
AppendKeys Failed to get kekSigned_0 Not Found
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/StatusCodeHandler/RuntimeDxe/StatusCodeHandlerRuntimeDxe/DEBUG/StatusCodeHandlerRuntimeDxe.dll 0x47A690000
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/StatusCodeHandler/RuntimeDxe/StatusCodeHandlerRuntimeDxe/DEBUG/StatusCodeHandlerRuntimeDxe.dll
Loading driver at 0x0047A680000 EntryPoint=0x0047A693364 StatusCodeHandlerRuntimeDxe.efi
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/FwPartitionMmDxe/FwPartitionMmDxe/DEBUG/FwPartitionMmDxe.dll 0x47A640000
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/FwPartitionMmDxe/FwPartitionMmDxe/DEBUG/FwPartitionMmDxe.dll
Loading driver at 0x0047A630000 EntryPoint=0x0047A645C78 FwPartitionMmDxe.efi
FwPartitionMmDxeInitialize - Failed to locate MmCommunication protocol! Not Found
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/BpmpScmi/BpmpScmiDxe/DEBUG/BpmpScmiDxe.dll 0x47955E000
Loading driver at 0x0047955D000 EntryPoint=0x004795621AC BpmpScmiDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/BpmpScmi/BpmpScmiDxe/DEBUG/BpmpScmiDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/ArmSbmrStatusCodeDxe/ArmSbmrStatusCodeDxe/DEBUG/ArmSbmrStatusCodeDxe.dll 0x47A5F0000
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/ArmSbmrStatusCodeDxe/ArmSbmrStatusCodeDxe/DEBUG/ArmSbmrStatusCodeDxe.dll
Loading driver at 0x0047A5E0000 EntryPoint=0x0047A5F3424 ArmSbmrStatusCodeDxe.efi
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/OemDescStatusCodeDxe/OemDescStatusCodeDxe/DEBUG/OemDescStatusCodeDxe.dll 0x47A5A0000
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/OemDescStatusCodeDxe/OemDescStatusCodeDxe/DEBUG/OemDescStatusCodeDxe.dll
Loading driver at 0x0047A590000 EntryPoint=0x0047A5A5F2C OemDescStatusCodeDxe.efi
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/IpmiFeaturePkg/Frb/FrbDxe/DEBUG/FrbDxe.dll 0x479555000
Loading driver at 0x00479554000 EntryPoint=0x004795584FC FrbDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/IpmiFeaturePkg/Frb/FrbDxe/DEBUG/FrbDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/IpmiBlobTransferDxe/IpmiBlobTransferDxe/DEBUG/IpmiBlobTransferDxe.dll 0x47954B000
Loading driver at 0x0047954A000 EntryPoint=0x0047954F450 IpmiBlobTransferDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/IpmiBlobTransferDxe/IpmiBlobTransferDxe/DEBUG/IpmiBlobTransferDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/WatchdogTimerDxe/WatchdogTimer/DEBUG/WatchdogTimer.dll 0x479542000
Loading driver at 0x00479541000 EntryPoint=0x00479545400 WatchdogTimer.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/WatchdogTimerDxe/WatchdogTimer/DEBUG/WatchdogTimer.dll
WatchDogTimerReady: 5 minute boot watchdog installed
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/NetworkPkg/HttpUtilitiesDxe/HttpUtilitiesDxe/DEBUG/HttpUtilitiesDxe.dll 0x479539000
Loading driver at 0x00479538000 EntryPoint=0x0047953CEAC HttpUtilitiesDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/NetworkPkg/HttpUtilitiesDxe/HttpUtilitiesDxe/DEBUG/HttpUtilitiesDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/ShellPkg/DynamicCommand/HttpDynamicCommand/HttpDynamicCommand/DEBUG/httpDynamicCommand.dll 0x479525000
Loading driver at 0x00479524000 EntryPoint=0x0047952F1C0 httpDynamicCommand.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/ShellPkg/DynamicCommand/HttpDynamicCommand/HttpDynamicCommand/DEBUG/httpDynamicCommand.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/ShellPkg/DynamicCommand/TftpDynamicCommand/TftpDynamicCommand/DEBUG/tftpDynamicCommand.dll 0x479514000
Loading driver at 0x00479513000 EntryPoint=0x0047951CC50 tftpDynamicCommand.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/ShellPkg/DynamicCommand/TftpDynamicCommand/TftpDynamicCommand/DEBUG/tftpDynamicCommand.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/ShellPkg/DynamicCommand/DpDynamicCommand/DpDynamicCommand/DEBUG/dpDynamicCommand.dll 0x4794FE000
Loading driver at 0x004794FD000 EntryPoint=0x00479506E10 dpDynamicCommand.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/ShellPkg/DynamicCommand/DpDynamicCommand/DpDynamicCommand/DEBUG/dpDynamicCommand.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/SetupBrowserDxe/SetupBrowserDxe/DEBUG/SetupBrowser.dll 0x4794E0000
Loading driver at 0x004794DF000 EntryPoint=0x004794E0D5C SetupBrowser.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/SetupBrowserDxe/SetupBrowserDxe/DEBUG/SetupBrowser.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/ThreadingDxe/ThreadingDxe/DEBUG/ThreadingDxe.dll 0x4794D6000
Loading driver at 0x004794D5000 EntryPoint=0x004794DA48C ThreadingDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/ThreadingDxe/ThreadingDxe/DEBUG/ThreadingDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/CapsuleRuntimeDxe/CapsuleRuntimeDxe/DEBUG/CapsuleRuntimeDxe.dll 0x47A550000
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/CapsuleRuntimeDxe/CapsuleRuntimeDxe/DEBUG/CapsuleRuntimeDxe.dll
Loading driver at 0x0047A540000 EntryPoint=0x0047A555D84 CapsuleRuntimeDxe.efi
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/MonotonicCounterRuntimeDxe/MonotonicCounterRuntimeDxe/DEBUG/MonotonicCounterRuntimeDxe.dll 0x47A500000
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/MonotonicCounterRuntimeDxe/MonotonicCounterRuntimeDxe/DEBUG/MonotonicCounterRuntimeDxe.dll
Loading driver at 0x0047A4F0000 EntryPoint=0x0047A5033A4 MonotonicCounterRuntimeDxe.efi
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/EmbeddedPkg/RealTimeClockRuntimeDxe/RealTimeClockRuntimeDxe/DEBUG/RealTimeClock.dll 0x47A4B0000
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/EmbeddedPkg/RealTimeClockRuntimeDxe/RealTimeClockRuntimeDxe/DEBUG/RealTimeClock.dll
Loading driver at 0x0047A4A0000 EntryPoint=0x0047A4B47CC RealTimeClock.efi
InitializeRealTimeClock: using default timezone/daylight settings
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/Disk/RamDiskDxe/RamDiskDxe/DEBUG/RamDiskDxe.dll 0x4794C5000
Loading driver at 0x004794C4000 EntryPoint=0x004794CE75C RamDiskDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/Disk/RamDiskDxe/RamDiskDxe/DEBUG/RamDiskDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/TegraGpio/TegraGpioDxe/DEBUG/TegraGpioDxe.dll 0x4794B7000
Loading driver at 0x004794B6000 EntryPoint=0x004794BE16C TegraGpioDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/TegraGpio/TegraGpioDxe/DEBUG/TegraGpioDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/SmbiosHmcTransfer/SmbiosHmcTransfer/DEBUG/SmbiosHmcTransfer.dll 0x4794AE000
Loading driver at 0x004794AD000 EntryPoint=0x004794B1E54 SmbiosHmcTransfer.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/SmbiosHmcTransfer/SmbiosHmcTransfer/DEBUG/SmbiosHmcTransfer.dll
IsHmcSupport: Fail to find SMBIOS overlay
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/PciGenericControllerDxe/PcieGenericControllerDxe/DEBUG/PcieGenericControllerDxe.dll 0x47949E000
Loading driver at 0x0047949D000 EntryPoint=0x004794A6F24 PcieGenericControllerDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/PciGenericControllerDxe/PcieGenericControllerDxe/DEBUG/PcieGenericControllerDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/UfsControllerDxe/UfsControllerDxe/DEBUG/UfsControllerDxe.dll 0x479490000
Loading driver at 0x0047948F000 EntryPoint=0x0047949771C UfsControllerDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/UfsControllerDxe/UfsControllerDxe/DEBUG/UfsControllerDxe.dll
UfsControllerDxe:DeviceDiscoveryStart, Failed supported check
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/NvDisplayControllerDxe/NvDisplayControllerDxe/DEBUG/NvDisplayControllerDxe.dll 0x47947F000
Loading driver at 0x0047947E000 EntryPoint=0x00479488B44 NvDisplayControllerDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/NvDisplayControllerDxe/NvDisplayControllerDxe/DEBUG/NvDisplayControllerDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Tegra/T194/Drivers/SeRngDxe/SeRngDxe/DEBUG/SeRngDxe.dll 0x479472000
Loading driver at 0x00479471000 EntryPoint=0x004794790BC SeRngDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Tegra/T194/Drivers/SeRngDxe/SeRngDxe/DEBUG/SeRngDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Tegra/T234/Drivers/SeRngDxe/SeRngDxe/DEBUG/SeRngDxe.dll 0x479465000
Loading driver at 0x00479464000 EntryPoint=0x0047946BEA8 SeRngDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Tegra/T234/Drivers/SeRngDxe/SeRngDxe/DEBUG/SeRngDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/PinMuxDxe/PinMuxDxe/DEBUG/PinMuxDxe.dll 0x479458000
Loading driver at 0x00479457000 EntryPoint=0x0047945EDC4 PinMuxDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/PinMuxDxe/PinMuxDxe/DEBUG/PinMuxDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/TegraPwmDxe/TegraPwmDxe/DEBUG/TegraPwmDxe.dll 0x47944B000
Loading driver at 0x0047944A000 EntryPoint=0x00479451DD0 TegraPwmDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/TegraPwmDxe/TegraPwmDxe/DEBUG/TegraPwmDxe.dll
TegraPwmDxe:DeviceDiscoveryStart, Failed supported check
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/NetworkPkg/TlsAuthConfigDxe/TlsAuthConfigDxe/DEBUG/TlsAuthConfigDxe.dll 0x479438000
Loading driver at 0x00479437000 EntryPoint=0x0047943FD58 TlsAuthConfigDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/NetworkPkg/TlsAuthConfigDxe/TlsAuthConfigDxe/DEBUG/TlsAuthConfigDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/DisplayEngineDxe/DisplayEngineDxe/DEBUG/DisplayEngine.dll 0x47941E000
Loading driver at 0x0047941D000 EntryPoint=0x0047941EAE0 DisplayEngine.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/DisplayEngineDxe/DisplayEngineDxe/DEBUG/DisplayEngine.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/BdsDxe/BdsDxe/DEBUG/BdsDxe.dll 0x4793EF000
Loading driver at 0x004793EE000 EntryPoint=0x004793F44BC BdsDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/BdsDxe/BdsDxe/DEBUG/BdsDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/DriverHealthManagerDxe/DriverHealthManagerDxe/DEBUG/DriverHealthManagerDxe.dll 0x4793E0000
Loading driver at 0x004793DF000 EntryPoint=0x004793E7E84 DriverHealthManagerDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/DriverHealthManagerDxe/DriverHealthManagerDxe/DEBUG/DriverHealthManagerDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/TegraPlatformBootManager/TegraPlatformBootManagerDxe/DEBUG/TegraPlatformBootManagerDxe.dll 0x4793D3000
Loading driver at 0x004793D2000 EntryPoint=0x004793D9A58 TegraPlatformBootManagerDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/TegraPlatformBootManager/TegraPlatformBootManagerDxe/DEBUG/TegraPlatformBootManagerDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/NvidiaConfigDxe/NvidiaConfigDxe/DEBUG/NvidiaConfigDxe.dll 0x479399000
Loading driver at 0x00479398000 EntryPoint=0x004793A1288 NvidiaConfigDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/NvidiaConfigDxe/NvidiaConfigDxe/DEBUG/NvidiaConfigDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/SecurityPkg/VariableAuthenticated/SecureBootConfigDxe/SecureBootConfigDxe/DEBUG/SecureBootConfigDxe.dll 0x4792A9000
Loading driver at 0x004792A8000 EntryPoint=0x004792AE4EC SecureBootConfigDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/SecurityPkg/VariableAuthenticated/SecureBootConfigDxe/SecureBootConfigDxe/DEBUG/SecureBootConfigDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/QspiControllerDxe/QspiControllerDxe/DEBUG/QspiControllerDxe.dll 0x47A460000
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/QspiControllerDxe/QspiControllerDxe/DEBUG/QspiControllerDxe.dll
Loading driver at 0x0047A450000 EntryPoint=0x0047A468168 QspiControllerDxe.efi
QspiControllerDxe:DeviceDiscoveryStart, Failed supported check
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/TegraPinControlDxe/TegraPinControlDxe/DEBUG/TegraPinControlDxe.dll 0x47929C000
Loading driver at 0x0047929B000 EntryPoint=0x004792A31E4 TegraPinControlDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/TegraPinControlDxe/TegraPinControlDxe/DEBUG/TegraPinControlDxe.dll
!!!!PinCtr -28
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/TegraCpuFreqDxe/TegraCpuFreqDxe/DEBUG/TegraCpuFreqDxe.dll 0x47928F000
Loading driver at 0x0047928E000 EntryPoint=0x004792964BC TegraCpuFreqDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/TegraCpuFreqDxe/TegraCpuFreqDxe/DEBUG/TegraCpuFreqDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/TegraControllerEnableDxe/TegraControllerEnableDxe/DEBUG/TegraControllerEnableDxe.dll 0x479282000
Loading driver at 0x00479281000 EntryPoint=0x00479288960 TegraControllerEnableDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/TegraControllerEnableDxe/TegraControllerEnableDxe/DEBUG/TegraControllerEnableDxe.dll
TegraControllerEnableDxe:DeviceDiscoveryStart, failed to reset moduleDevice Error
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/EFuseDxe/EFuseDxe/DEBUG/EFuseDxe.dll 0x479275000
Loading driver at 0x00479274000 EntryPoint=0x0047927BB6C EFuseDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/EFuseDxe/EFuseDxe/DEBUG/EFuseDxe.dll
DeviceDiscoveryNotify: Efuse Installed
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/SecurityPkg/Tcg/Tcg2Dxe/Tcg2Dxe/DEBUG/Tcg2Dxe.dll 0x479260000
Loading driver at 0x0047925F000 EntryPoint=0x0047926A7B4 Tcg2Dxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/SecurityPkg/Tcg/Tcg2Dxe/Tcg2Dxe/DEBUG/Tcg2Dxe.dll
Unhandled command 0
▒▒OpteeCallWithArg: Function 0xFFFF0002 not implemented.
OpenSessionToFtpm: Failed to open fTPM ssesion , OP-TEE return 4294901772
Tpm2RequestUseTpm: Failed to open session to fTPM Unsupported
TPM2 not detected!
Error: Image at 0047925F000 start failed: Unsupported
remove-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/SecurityPkg/Tcg/Tcg2Dxe/Tcg2Dxe/DEBUG/Tcg2Dxe.dll 0x79260000
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/EmbeddedPkg/Drivers/DtPlatformDxe/DtPlatformDxe/DEBUG/DtPlatformDxe.dll 0x479262000
Loading driver at 0x00479261000 EntryPoint=0x0047926BA9C DtPlatformDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/EmbeddedPkg/Drivers/DtPlatformDxe/DtPlatformDxe/DEBUG/DtPlatformDxe.dll
DtPlatformLoadDtb: Defaulting to UEFI DTB
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/Console/ConPlatformDxe/ConPlatformDxe/DEBUG/ConPlatformDxe.dll 0x479257000
Loading driver at 0x00479256000 EntryPoint=0x0047925BE98 ConPlatformDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/Console/ConPlatformDxe/ConPlatformDxe/DEBUG/ConPlatformDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/Console/ConSplitterDxe/ConSplitterDxe/DEBUG/ConSplitterDxe.dll 0x479249000
Loading driver at 0x00479248000 EntryPoint=0x004792511F0 ConSplitterDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/Console/ConSplitterDxe/ConSplitterDxe/DEBUG/ConSplitterDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/Console/GraphicsConsoleDxe/GraphicsConsoleDxe/DEBUG/GraphicsConsoleDxe.dll 0x47923D000
Loading driver at 0x0047923C000 EntryPoint=0x004792427B8 GraphicsConsoleDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/Console/GraphicsConsoleDxe/GraphicsConsoleDxe/DEBUG/GraphicsConsoleDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/Console/TerminalDxe/TerminalDxe/DEBUG/TerminalDxe.dll 0x47922E000
Loading driver at 0x0047922D000 EntryPoint=0x004792377FC TerminalDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/Console/TerminalDxe/TerminalDxe/DEBUG/TerminalDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/TegraI2c/TegraI2cDxe/DEBUG/TegraI2cDxe.dll 0x47A410000
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/TegraI2c/TegraI2cDxe/DEBUG/TegraI2cDxe.dll
Loading driver at 0x0047A400000 EntryPoint=0x0047A419A7C TegraI2cDxe.efi
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/I2cIoBmcSsifDxe/I2cIoBmcSsifDxe/DEBUG/I2cIoBmcSsifDxe.dll 0x479224000
Loading driver at 0x00479223000 EntryPoint=0x00479228508 I2cIoBmcSsifDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/I2cIoBmcSsifDxe/I2cIoBmcSsifDxe/DEBUG/I2cIoBmcSsifDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/Acpi/BootGraphicsResourceTableDxe/BootGraphicsResourceTableDxe/DEBUG/BootGraphicsResourceTableDxe.dll 0x47921B000
Loading driver at 0x0047921A000 EntryPoint=0x0047921EB48 BootGraphicsResourceTableDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/Acpi/BootGraphicsResourceTableDxe/BootGraphicsResourceTableDxe/DEBUG/BootGraphicsResourceTableDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/Disk/UdfDxe/UdfDxe/DEBUG/UdfDxe.dll 0x47920E000
Loading driver at 0x0047920D000 EntryPoint=0x00479214EB8 UdfDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/Disk/UdfDxe/UdfDxe/DEBUG/UdfDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/FvSimpleFileSystemDxe/FvSimpleFileSystemDxe/DEBUG/FvSimpleFileSystem.dll 0x479202000
Loading driver at 0x00479201000 EntryPoint=0x00479208630 FvSimpleFileSystem.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/FvSimpleFileSystemDxe/FvSimpleFileSystemDxe/DEBUG/FvSimpleFileSystem.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Features/Ext4Pkg/Ext4Dxe/Ext4Dxe/DEBUG/Ext4Dxe.dll 0x4791F1000
Loading driver at 0x004791F0000 EntryPoint=0x004791FAD7C Ext4Dxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Features/Ext4Pkg/Ext4Dxe/Ext4Dxe/DEBUG/Ext4Dxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/UsbPadCtlDxe/UsbPadCtlDxe/DEBUG/UsbPadCtlDxe.dll 0x4791E0000
Loading driver at 0x004791DF000 EntryPoint=0x004791EA9D0 UsbPadCtlDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/UsbPadCtlDxe/UsbPadCtlDxe/DEBUG/UsbPadCtlDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Bus/Pci/EhciDxe/EhciDxe/DEBUG/EhciDxe.dll 0x4791D0000
Loading driver at 0x004791CF000 EntryPoint=0x004791D9104 EhciDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Bus/Pci/EhciDxe/EhciDxe/DEBUG/EhciDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Bus/Pci/XhciDxe/XhciDxe/DEBUG/XhciDxe.dll 0x4791BC000
Loading driver at 0x004791BB000 EntryPoint=0x004791BD2EC XhciDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Bus/Pci/XhciDxe/XhciDxe/DEBUG/XhciDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Bus/Usb/UsbBusDxe/UsbBusDxe/DEBUG/UsbBusDxe.dll 0x4791AC000
Loading driver at 0x004791AB000 EntryPoint=0x004791B595C UsbBusDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Bus/Usb/UsbBusDxe/UsbBusDxe/DEBUG/UsbBusDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Bus/Usb/UsbKbDxe/UsbKbDxe/DEBUG/UsbKbDxe.dll 0x47919F000
Loading driver at 0x0047919E000 EntryPoint=0x004791A5CB8 UsbKbDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Bus/Usb/UsbKbDxe/UsbKbDxe/DEBUG/UsbKbDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Bus/Usb/UsbMouseDxe/UsbMouseDxe/DEBUG/UsbMouseDxe.dll 0x479194000
Loading driver at 0x00479193000 EntryPoint=0x00479199060 UsbMouseDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Bus/Usb/UsbMouseDxe/UsbMouseDxe/DEBUG/UsbMouseDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Bus/Usb/UsbMouseAbsolutePointerDxe/UsbMouseAbsolutePointerDxe/DEBUG/UsbMouseAbsolutePointerDxe.dll 0x479189000
Loading driver at 0x00479188000 EntryPoint=0x0047918E0D0 UsbMouseAbsolutePointerDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Bus/Usb/UsbMouseAbsolutePointerDxe/UsbMouseAbsolutePointerDxe/DEBUG/UsbMouseAbsolutePointerDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Bus/Usb/UsbMassStorageDxe/UsbMassStorageDxe/DEBUG/UsbMassStorageDxe.dll 0x47917C000
Loading driver at 0x0047917B000 EntryPoint=0x00479182A90 UsbMassStorageDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Bus/Usb/UsbMassStorageDxe/UsbMassStorageDxe/DEBUG/UsbMassStorageDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/TegraUartDxe/TegraUartDxe/DEBUG/TegraUartDxe.dll 0x47916D000
Loading driver at 0x0047916C000 EntryPoint=0x0047917579C TegraUartDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/TegraUartDxe/TegraUartDxe/DEBUG/TegraUartDxe.dll
TegraUartDxe:DeviceDiscoveryStart, Failed supported check
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Bus/Pci/PciBusDxe/PciBusDxe/DEBUG/PciBusDxe.dll 0x479154000
Loading driver at 0x00479153000 EntryPoint=0x0047915C144 PciBusDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Bus/Pci/PciBusDxe/PciBusDxe/DEBUG/PciBusDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/PcieDWControllerDxe/PcieControllerDxe/DEBUG/PcieControllerDxe.dll 0x47913F000
Loading driver at 0x0047913E000 EntryPoint=0x004791498AC PcieControllerDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/PcieDWControllerDxe/PcieControllerDxe/DEBUG/PcieControllerDxe.dll
PCIE Controller ID-4, Bpmp Phandle-4
ParseGicMsiBase: cannot retrieve property 'msi-parent': FDT_ERR_NOTFOUND
PCIE Controller ID-5, Bpmp Phandle-4
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Bus/Pci/NvmExpressDxe/NvmExpressDxe/DEBUG/NvmExpressDxe.dll 0x47912E000
Loading driver at 0x0047912D000 EntryPoint=0x00479137EA8 NvmExpressDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Bus/Pci/NvmExpressDxe/NvmExpressDxe/DEBUG/NvmExpressDxe.dll
add-symbol-file /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/SdMmcControllerDxe/SdMmcControllerDxe/DEBUG/SdMmcControllerDxe.dll 0x479120000
Loading driver at 0x0047911F000 EntryPoint=0x00479127BC4 SdMmcControllerDxe.efi
 Image - /home/kappa/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/SdMmcControllerDxe/SdMmcControllerDxe/DEBUG/SdMmcControllerDxe.dll
PCIe Controller-4 Link is DOWN
DeviceTreeGetNodePropertyValue64: NodeOffset 0x2D500 doesn't have #address-cells, so defaulting to 2
DeviceTreeGetInterruptMap: DTB might have missing required #address-cells field. Trying to work around it by using zero for the value
Error reported by SDHCI
Interrupt status = 8001
Error interrupt status = 1
TRB failed with Device Error
Printing SD_MMC_HC_TRB
Slot: 0
BlockSize: 512
Data: 0
DataLen: 0
Read: 0
DataPhy: 0
DataMap: 0
Mode: 0
AdmaLengthMode: 0
Event: 0
Started: 0
CommandComplete: 0
Timeout: 2500000
Retries: 5
PioModeTransferCompleted: 0
PioBlockIndex: 0
Adma32Desc: 0
Adma64V3Desc: 0
Adma64V4Desc: 0
AdmaMap: 0
AdmaPages: 0
Printing EFI_SD_MMC_PASS_THRU_COMMAND_PACKET
Command index: 7, argument: 0
Command type: 2, response type: 0
Response 0: 0, 1: 0, 2: 0, 3: 0
Timeout: 2500000
InDataBuffer: 0
OutDataBuffer: 0
InTransferLength: 0
OutTransferLength: 0
TransactionStatus: Success
What do you think?
As the error is reported from sdmmc, please disable your sdmmc3 in the device tree, doing full reflash and see if you could bypass this error.
Could you point where I can disable it? I have checked in Jakku device tree, but I only found one reference which I don’t think is the right one. I found it under jakku/kernel-dts/common/tegra194-p3668-common.dtsi:
	pmc@c360000 {
		iopad_defaults: iopad-defaults {
			sdmmc-io-pads {
				pins = "sdmmc1-hv", "sdmmc3-hv";
				nvidia,enable-voltage-switching;
You mentioned that you have sdcard on your board. Did you ever enable that thing in your device tree? sdhci@3440000.
If you don’t know what I am talking about, then it might not be the problem here.
it is routed in the HW, correct, but never really used it, since we are currently using the EMMC version chip.
I will check device tree for the node you pointed and see if it is disabled, but in that point of view I never touched that device tree side.
Is there any PCIe device connected on the board?
I removed the SDMMC3 reference that I quoted here, rebuilt device tree and it seems to be booting now. I do not really know what the change I did actually does tho
I asked my HW enginner colleague. They routed indeed a PCIExpress interface to an FPGA, but this interface is fully unused; it is just physically in the HW. Could this also give any problem?
From your comment, I really suspect there has nothing that is really “unused”. Did you ever touched the device tree before?
For example, some PCIe controllers by default are enabled. Sdmmc3 controller by default didn’t. If NV devkit has it enabled, then it would be enabled, and vice versa.
i touched in the past yes, but for the sake of simplicity in debugging this issue I went back to a fully untouched kernel + device tree. Goal is to make the chip bootable in the custom board and once that is done, I will redo the changes made in the past. In the end, only changes I made in the past was adding a custom MIPI camrea driver.
And correct, if in the devkit that SD card is not enabled (which I do not know by heart, that is the reason for my comment) I did not touch it then
Hello, any more tips on the topic?
I thought the conclusion was you are going to use some clean software setup to test first?
Did you disable those PCIe controllers and see if it changed anything?
