Hi WayneWWW,
Modify 1&2
Please help to check the debug uart message, thanks.
[0000.025] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.034] I> MB1 (prd-version: 1.5.1.7-t194-41334769-98030a79)
[0000.039] I> Boot-mode: Coldboot
[0000.042] I> Chip revision : A02P
[0000.045] I> Bootrom patch version : 15 (correctly patched)
[0000.050] I> ATE fuse revision : 0x200
[0000.054] I> Ram repair fuse : 0x0
[0000.057] I> Ram Code : 0x2
[0000.059] I> rst_source : 0x0
[0000.062] I> rst_level : 0x0
[0000.065] I> Boot-device: QSPI
[0000.068] I> Qspi flash params source = brbct
[0000.072] I> Qspi using bpmp-dma
[0000.075] I> Qspi clock source : pllp
[0000.079] I> QSPI Flash Size = 32 MB
[0000.082] I> Qspi initialized successfully
[0000.086] W> No valid slot number is found in scratch register
[0000.092] W> Return default slot: _a
[0000.095] I> Active Boot chain : 0
[0000.098] I> Boot-device: QSPI
[0000.101] I> Qspi flash params source = brbct
[0000.106] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.114] I> Temperature = 43000
[0000.117] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.122] W> Skipping boost for clk: BPMP_APB
[0000.126] W> Skipping boost for clk: AXI_CBB
[0000.130] W> Skipping boost for clk: AON_CPU_NIC
[0000.134] W> Skipping boost for clk: CAN1
[0000.138] W> Skipping boost for clk: CAN2
[0000.142] I> Boot-device: QSPI
[0000.145] I> Boot-device: QSPI
[0000.147] I> Qspi flash params source = mb1bct
[0000.152] I> Qspi using bpmp-dma
[0000.155] I> Qspi clock source : pllc_out0
[0000.158] I> Qspi reinitialized
[0000.161] I> Qspi flash params source = mb1bct
[0000.167] I> ECC region[0]: Start:0x0, End:0x0
[0000.171] I> ECC region[1]: Start:0x0, End:0x0
[0000.175] I> ECC region[2]: Start:0x0, End:0x0
[0000.179] I> ECC region[3]: Start:0x0, End:0x0
[0000.183] I> ECC region[4]: Start:0x0, End:0x0
[0000.187] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.193] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.198] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.202] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.206] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.212] E> FAILED: Thermal config
[0000.219] E> FAILED: MEMIO rail config
[0000.232] I> Boot-device: QSPI
[0000.235] I> Qspi flash params source = mb1bct
[0000.244] I> Qspi flash params source = mb1bct
[0000.255] I> Qspi flash params source = mb1bct
[0000.322] I> Qspi flash params source = mb1bct
[0000.331] I> Qspi flash params source = mb1bct
[0000.360] I> Qspi flash params source = mb1bct
[0000.371] I> MB1 done
\0?鄊ain enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
[0000.379] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-938a8cd8)
[0000.380] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.381] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.381] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.387] W> device prod register failed
[0000.391] I> Boot-device: QSPI
[0000.394] I> Boot_device: QSPI_FLASH instance: 0
[0000.399] I> QSPI Flash Size = 32 MB
[0000.405] I> Qspi initialized successfully
[0000.406] I> qspi flash-0 params source = boot args
[0000.786] I> sdmmc DDR50 mode
[0000.788] I> sdmmc-3 params source = safe params
[0000.793] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0000.796] W> Cannot find any partition table for 00000003
[0000.800] I> Found 11 partitions in SDMMC_USER (instance 3)
[0000.801] W> No valid slot number is found in scratch register
[0000.802] W> Return default slot: _a
[0000.802] I> Active Boot chain : 0
[0000.803] I> parsing oem signed section of bpmp-fw header done
[0000.804] I> bpmp-fw binary init read from storage
[0000.808] I> oem authentication of bpmp-fw header done
[0000.822] I> bpmp-fw binary done read from storage
[0000.822] I> bpmp-fw: Authentication init Done
[0000.823] I> parsing oem signed section of cpubl header done
[0000.827] I> cpubl binary init read from storage
[0000.831] I> bpmp-fw: Authentication Finalize Done
[0000.836] I> oem authentication of cpubl header done
[0000.844] I> cpubl binary done read from storage
[0000.845] I> cpubl: Authentication init Done
[0000.850] I> parsing oem signed section of rce header done
[0000.855] I> rce binary init read from storage
[0000.859] I> Relocating BR-BCT
[0000.862] I> cpubl: Authentication Finalize Done
[0000.867] I> oem authentication of rce header done
[0000.871] I> rce binary done read from storage
[0000.875] I> rce: Authentication init Done
[0000.880] I> parsing oem signed section of ape header done
[0000.885] I> ape binary init read from storage
[0000.889] I> rce: Authentication Finalize Done
[0000.893] I> oem authentication of ape header done
[0000.898] I> ape binary done read from storage
[0000.902] I> ape: Authentication init Done
[0000.906] I> parsing oem signed section of tos header done
[0000.911] I> tos binary init read from storage
[0000.916] I> ape: Authentication Finalize Done
[0000.920] I> oem authentication of tos header done
[0000.927] I> tos binary done read from storage
[0000.929] I> tos: Authentication init Done
[0000.933] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.939] I> bpmp-fw-dtb binary init read from storage
[0000.944] I> tos: Authentication Finalize Done
[0000.950] I> oem authentication of bpmp-fw-dtb header done
[0000.953] I> bpmp-fw-dtb binary done read from storage
[0000.958] I> bpmp-fw-dtb: Authentication init Done
[0000.963] I> parsing oem signed section of cpubl-dtb header done
[0000.969] I> cpubl-dtb binary init read from storage
[0000.974] I> bpmp-fw-dtb: Authentication Finalize Done
[0001.025] I> oem authentication of cpubl-dtb header done
[0001.026] I> cpubl-dtb binary done read from storage
[0001.026] I> cpubl-dtb: Authentication init Done
[0001.027] I> parsing oem signed section of eks header done
[0001.028] I> eks binary init read from storage
[0001.029] I> cpubl-dtb: Authentication Finalize Done
[0001.029] I> oem authentication of eks header done
[0001.034] I> eks binary done read from storage
[0001.038] I> eks: Authentication init Done
[0001.042] I> eks: Authentication Finalize Done
[0001.046] I> EKB detected (length: 0x410) @ VA:0x5270a400
銷OTICE: BL31: v1.3(release):b5eeb33f7
NOTICE: BL31: Built : 12:15:32, Jul 26 2021
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 41: hwkey-agent is running!!
hwkey-agent: 315: key_mgnt_processing .......
hwkey-agent: 223: Setting EKB key 0 to slot 14
hwkey-agent: 178: Init hweky-agent services!!
luks-srv: 40: luks-srv is running!!
luks-srv: 157: Init luks-srv IPC services!!
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is e73a758761f0c6d24a1e69a2ac6b5035
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
391 clocks registered
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform_init: bad clk id in clock@cluster1_avfs
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
[0001.414] I> Welcome to Cboot鈓rq initialized
WARNING: no registered clock for FMON_NAFLL_CLUSTER1 (id 281)
fmon_post initialized
[0001.415] I> Cboot Version: t194-cfa2bc91
[0001.416] I> CPU-BL Params @ 0xf2820000
[0001.420] I> 0) Base:0x00000000 Size:0x00000000
[0001.424] I> 1) Base:0xf1100000 Size:0x00100000
鈉lk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
Failed to register PTO counter for id 281
clk_debugfs initialized
emc_debugfs initialized
dvs_debugfs initialized
fmon_debugfs_init_one: no clock debugfs node to attach FMON_NAFLL_CLUSTER1
fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_rail_debugfs_init: /rm/vdd_cpu: failed
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] 醄0001.429] I> 2) Base:0xf2000000 Size:0x00200000
[0001.583] I> 3) Base:0xf1200000 Size:0x00200000
[0001.587] I> 4) Base:0xf1000000 Size:0x00100000
[0001.592] I> 5) Base:0xf0f00000 Size:0x00100000
[0001.596] I> 6) Base:0xf3800000 Size:0x00400000
[0001.601] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.605] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.609] I> 9) Base:0xf0d00000 Size:0x00100000
[0001.614] I> 10) Base:0xf3000000 Size:0x00800000
[0001.618] I> 11) Base:0x40000000 Size:0x00040000
[0001.623] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.627] I> 13) Base:0x40046000 Size:0x00002000
[0001.632] I> 14) Base:0x40048000 Size:0x00002000
[0001.636] I> 15) Base:0xac000000 Size:0x00004000
[0001.641] I> 16) Base:0x4004a000 Size:0x00002000
[0001.645] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.650] I> 18) Base:0x4004c000 Size:0x00002000
[0001.654] I> 19) Base:0xf2200000 Size:0x00600000
[0001.659] I> 20) Base:0x4004e000 Size:0x00002000
[0001.663] I> 21) Base:0xf0ad0000 Size:0x0000c000
[0001.668] I> 22) Base:0x00000000 Size:0x00000000
[0001.672] I> 23) Base:0xf0ae0000 Size:0x00020000
[0001.676] I> 24) Base:0xf6000000 Size:0x02000000
[0001.681] I> 25) Base:0x40050000 Size:0x00002000
[0001.685] I> 26) Base:0x40040000 Size:0x00006000
[0001.690] I> 27) Base:0xf1800000 Size:0x00400000
[0001.694] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.699] I> 29) Base:0xf1400000 Size:0x00400000
[0001.703] I> 30) Base:0x00000000 Size:0x00000000
[0001.708] I> 31) Base:0x00000000 Size:0x00000000
[0001.712] I> 32) Base:0xf8000000 Size:0x08000000
[0001.717] I> 33) Base:0x00000000 Size:0x00000000
[0001.721] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.726] I> 35) Base:0xab000000 Size:0x01000000
[0001.730] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.734] I> 37) Base:0xf2800000 Size:0x00800000
[0001.739] I> 38) Base:0x80000000 Size:0x20000000
[0001.743] I> 39) Base:0xb0000000 Size:0x08000000
[0001.748] I> 40) Base:0x00000000 Size:0x00000000
[0001.752] I> 41) Base:0x00000000 Size:0x00000000
[0001.757] I> 42) Base:0x00000000 Size:0x00000000
[0001.761] I> 43) Base:0x00000000 Size:0x00000000
[0001.766] I> 44) Base:0x00000000 Size:0x00000000
[0001.770] I> 45) Base:0x00000000 Size:0x00000000
[0001.775] GIC-SPI Target CPU: 0
[0001.778] Interrupts Init done
[0001.780] calling constructors
[0001.783] initializing heap
[0001.786] I> Heap: [0xa0699b80 ... 0xab000000]
[0001.790] initializing threads
[0001.793] initializing timers
[0001.796] creating bootstrap completion thread
[0001.800] top of bootstrap2()
[0001.803] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.808] initializing platform
[0001.811] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.816] W> device prod register failed
[0001.820] I> Bl_dtb @0xaaf00000
[0001.825] W> "plugin-manager" doesn't exist, creating
[0001.828] W> "ids" doesn't exist, creating
[0001.832] W> "connection" doesn't exist, creating
[0001.836] W> "configs" doesn't exist, creating
[0001.844] E> failed to read label property for node 158736: 13
[0001.847] E> failed to read reg property for node 158800: 13
[0001.853] E> failed to read reg property for node 158852: 13
[0001.859] E> failed to read reg property for node 158936: 13
[0001.865] I> Find /i2c@3160000's alias i2c0
[0001.867] I> Reading eeprom i2c=0 address=0x50
[0001.896] I> Device at /i2c@3160000:0x50
[0001.897] I> Reading eeprom i2c=0 address=0x57
[0001.921] I> Device at /i2c@3160000:0x57
[0001.923] I> Find /i2c@c240000's alias i2c1
[0001.924] I> Reading eeprom i2c=1 address=0x50
[0001.925] E> I2C: slave not found in slaves.
[0001.926] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.927] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.927] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.935] E> eeprom: Retry to read I2C slave device.
[0001.940] E> I2C: slave not found in slaves.
[0001.944] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.952] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.957] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.967] E> eeprom: Failed to read I2C slave device
[0001.972] I> Eeprom read failed 0x3526070d
[0001.976] I> create_pm_ids: id: 3668-0003-301-B, len: 15
[0001.981] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.992] I> create_pm_ids: id: 3449-0000-400-F, len: 15
[0001.997] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.008] I> Adding plugin-manager/ids/3668-0003-301=/i2c@3160000:module@0x50
[0002.016] W> "i2c@3160000" doesn't exist, creating
[0002.020] W> "module@0x50" doesn't exist, creating
[0002.025] I> Adding plugin-manager/ids/3449-0000-400=/i2c@3160000:module@0x57
[0002.032] W> "module@0x57" doesn't exist, creating
[0002.038] I> Adding plugin-manager/cvm
[0002.040] W> "chip-id" doesn't exist, creating
[0002.044] I> Adding plugin-manager/chip-id/A02P
[0002.048] I> Plugin-manager override starting
[0002.053] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0002.062] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0002.068] I> node /plugin-manager/fragement-tegra-pcie-c5-num-lanes matches
[0002.072] I> node /plugin-manager/fragement-tegra-pcie-c4-dis matches
[0002.080] I> Disable plugin-manager status in FDT
[0002.082] I> Plugin-manager override finished successfully
[0002.087] I> gpio framework initialized
[0002.092] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0002.099] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0002.106] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0002.113] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.121] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.127] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.133] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0002.141] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.148] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.155] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.162] I> fixed regulator driver initialized
[0002.169] I> register 'maxim' power off handle
[0002.170] I> virtual i2c enabled
[0002.173] I> registered 'maxim,max20024' pmic
[0002.177] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0002.184] I> Boot-device: QSPI
[0002.187] I> Boot_device: QSPI_FLASH instance: 0
[0002.192] I> QSPI source rate = 204000 Khz
[0002.195] I> Requested rate for QSPI clock = 34000 Khz
[0002.200] I> BPMP-set rate for QSPI clk = 34000 Khz
[0002.205] I> QSPI Flash Size = 32 MB
[0002.213] I> Qspi initialized successfully
[0002.213] I> qspi flash-0 params source = boot args
[0002.217] I> create_pm_ids: id: 3668-0003-301-B, len: 15
[0002.222] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.233] I> create_pm_ids: id: 3449-0000-400-F, len: 15
[0002.238] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.249] E> Invalid SKU: 3!
[0002.256] I> sdmmc-3 params source = safe params
[0002.258] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0002.278] W> Cannot find any partition table for 00000003
[0002.291] I> Found 11 partitions in SDMMC_USER (instance 3)
[0002.298] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.302] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.302] I> hdmi cable connected
[0002.303] W> set volts not configured for 'vdd-1v0'
[0002.305] W> set volts not configured for 'vdd-1v8-hs'
[0002.305] I> retrieved tmds range from prod_list_hdmi_soc
[0002.309] E> invalid display type
[0002.310] E> cannot find any other nvdisp nodes
[0002.325] I> edid read success
[0002.338] I> edid read success
[0002.338] I> width = 640, height = 480, frequency = 25174825
[0002.338] I> width = 1920, height = 1080, frequency = 148500000
[0002.339] I> width = 1360, height = 768, frequency = 85500000
[0002.339] I> width = 720, height = 480, frequency = 27000000
[0002.340] I> width = 720, height = 576, frequency = 27000000
[0002.343] I> width = 640, height = 480, frequency = 25174825
[0002.349] I> width = 720, height = 480, frequency = 26973026
[0002.354] I> width = 1280, height = 720, frequency = 74175824
[0002.360] I> width = 1920, height = 1080, frequency = 148351648
[0002.366] I> width = 720, height = 576, frequency = 26973026
[0002.371] I> width = 1280, height = 720, frequency = 74175824
[0002.377] I> width = 1920, height = 1080, frequency = 148351648
[0002.383] I> width = 1920, height = 1080, frequency = 74175824
[0002.388] I> width = 1920, height = 1080, frequency = 74175824
[0002.394] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.404] I> hdmi_enable, starting HDMI initialisation
[0002.409] I> hdmi_enable, HDMI initialisation complete
[0002.420] I> Load in CBoot Boot Options partition and parse it
[0002.421] E> Error -9 when finding node with path /boot-configuration
[0002.422] E> tegrabl_cbo_parse_info: "boot-configuration" not found in CBO file.
[0002.429] I> Using default boot order
[0002.433] I> boot-dev-order :-
[0002.436] I> 1.sd
[0002.438] I> 2.usb
[0002.439] I> 3.nvme
[0002.441] I> 4.emmc
[0002.443] I> 5.net
[0002.445] I> Hit any key to stop autoboot: 4 3 2 1
[0004.453] initializing target
[0004.453] calling apps_init()
[0004.454] starting app kernel_boot_app
[0004.464] I> found decompressor handler: lz4-legacy
[0004.465] I> decompressing BMP blob ...
[0004.475] I> Kernel type = Normal
[0004.475] I> ########## SD (0) boot ##########
[0004.476] I> No sdcard
[0004.476] I> -0 params source =
[0004.476] E> Blockdev open: exit error
[0004.477] E> SD boot failed, err: 724238353
[0004.477] I> ########## USB (0) boot ##########
[0004.482] W> No valid slot number is found in scratch register
[0004.482] W> Return default slot: _a
[0004.496] I> Validate XUSB-FW ...
[0004.496] I> T19x: Authenticate XUSB-FW (bin_type: 11), max size 0x30000
[0004.498] I> Encryption fuse is not ON
[0004.498] I> USB Firmware Version: 60.09 release
[0004.556] I> regulator of usb2-0 already enabled
[0004.561] I> regulator of usb2-1 already enabled
[0004.566] I> regulator of usb2-2 already enabled
[0005.632] I> USB 2.0 port 2 new high-speed USB device detected
[0005.634] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa4ada000, cmd_ring.dma = 0xa4ada0c0
[0005.735] I> Start to enumerate device
[0005.736] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa4ada000, cmd_ring.dma = 0xa4ada0c0
[0005.743] I>
[0005.743] I> Enumerated USB Device 0bda:5411
[0005.743] I>
[0005.745] I> Hub:
[0005.745] I> Downstream ports : 4
[0005.745] I> Power switching : Ganged
[0005.745] I> Compound device : No
[0005.746] I> Over-current protection : Global
[0005.748] I> Hub avg delay : 4 ns
[0005.752] I> Set interface = 1 (alt setting)
[0005.757] I> Enable hub ports
[0006.376] I> Device detected on port 1
[0006.785] I> Reset port 1
[0006.840] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa4ada000, cmd_ring.dma = 0xa4ada0c0
[0006.941] I> Start to enumerate device
[0006.943] W> handle_command_completion_event: WARNING: Command was not successfully completed (0x04)
[0009.951] W> xusbh_wait_irq: Timed out! status = 0x00
[0012.959] W> xusbh_wait_irq: Timed out! status = 0x00
[0012.959] E> Failed to enumerate USB device
[0012.960] E> failed to start xhci controller
[0012.960] E> Error in init of XUSB host driver, err: 7979000c
[0012.960] W> Failed to initialize device 5-0
[0012.961] E> USB boot failed, err: 2037973004
[0012.961] I> ########## NVME (0) boot ##########
[0012.965] I> Initializing nvme device instance 0
[0012.970] I> Initializing nvme controller
[0012.974] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14180000
[0012.980] I> vpcie3v3-supply not found
[0012.983] I> vpcie12v-supply not found
[0012.987] W> Failed to get nvidia,plat-gpios
[0012.991] I> tegrabl_pcie_soc_preinit: (0):
[0012.995] I> Unpowergate
[0012.998] I> tegrabl_car_clk_disable(0) ...
[0013.002] I> tegrabl_car_rst_set(CORE, 0) ...
[0013.006] I> tegrabl_car_rst_set(APB, 0) ...
[0013.010] I> tegrabl_car_clk_enable(0) ...
[0013.014] I> tegrabl_car_rst_clear(APB, 0) ...
[0013.018] I> tegrabl_set_ctrl_state(0)
[0013.022] I> CLR PCIE_APB:6
[0013.025] I> tegrabl_pcie_soc_init: (0):
[0013.028] I> APPL initialization ...
[0013.032] I> poweron phys
[0013.034] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14180000
[0013.040] I> tegrabl_power_on_phy: controller 0 not available
[0013.046] E> Failed to power on phy on controller-0
[0013.051] W> Failed tegrabl_pcie_soc_init(), error=0x1
[0013.056] I> Failed to initialize SoC Host PCIe controller
[0013.061] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(0); error=0x1
[0013.067] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800601
[0013.074] W> Failed to open NVME-0, err = 80800601
[0013.078] W> Failed to initialize device 10-0
[0013.083] E> NVME (0) boot failed, err: 0x80800601
[0013.087] I> ########## NVME (1) boot ##########
[0013.092] I> Initializing nvme device instance 1
[0013.096] I> Initializing nvme controller
[0013.100] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14100000
[0013.106] I> vpcie3v3-supply not found
[0013.110] I> vpcie12v-supply not found
[0013.114] W> Failed to get nvidia,plat-gpios
[0013.118] I> tegrabl_pcie_soc_preinit: (1):
[0013.122] I> Unpowergate
[0013.124] I> tegrabl_car_clk_disable(1) ...
[0013.128] I> tegrabl_car_rst_set(CORE, 1) ...
[0013.132] I> tegrabl_car_rst_set(APB, 1) ...
[0013.137] I> tegrabl_car_clk_enable(1) ...
[0013.141] I> tegrabl_car_rst_clear(APB, 1) ...
[0013.145] I> tegrabl_set_ctrl_state(1)
[0013.148] I> CLR PCIE_APB:6
[0013.151] I> tegrabl_pcie_soc_init: (1):
[0013.155] I> APPL initialization ...
[0013.158] I> poweron phys
[0013.161] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14100000
[0013.167] I> tegrabl_power_on_phy: controller 1 not available
[0013.173] E> Failed to power on phy on controller-1
[0013.178] W> Failed tegrabl_pcie_soc_init(), error=0x1
[0013.182] I> Failed to initialize SoC Host PCIe controller
[0013.188] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(1); error=0x1
[0013.194] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800601
[0013.200] W> Failed to open NVME-1, err = 80800601
[0013.205] W> Failed to initialize device 10-1
[0013.209] E> NVME (1) boot failed, err: 0x80800601
[0013.214] I> ########## NVME (2) boot ##########
[0013.218] I> Initializing nvme device instance 2
[0013.223] I> Initializing nvme controller
[0013.227] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14120000
[0013.233] I> vpcie3v3-supply not found
[0013.237] I> vpcie12v-supply not found
[0013.240] W> Failed to get nvidia,plat-gpios
[0013.244] I> tegrabl_pcie_soc_preinit: (2):
[0013.248] I> Unpowergate
[0013.251] I> tegrabl_car_clk_disable(2) ...
[0013.255] I> tegrabl_car_rst_set(CORE, 2) ...
[0013.259] I> tegrabl_car_rst_set(APB, 2) ...
[0013.263] I> tegrabl_car_clk_enable(2) ...
[0013.267] I> tegrabl_car_rst_clear(APB, 2) ...
[0013.271] I> tegrabl_set_ctrl_state(2)
[0013.275] I> CLR PCIE_APB:6
[0013.278] I> tegrabl_pcie_soc_init: (2):
[0013.281] I> APPL initialization ...
[0013.285] I> poweron phys
[0013.287] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14120000
[0013.294] I> tegrabl_power_on_phy: controller 2 not available
[0013.299] E> Failed to power on phy on controller-2
[0013.304] W> Failed tegrabl_pcie_soc_init(), error=0x1
[0013.309] I> Failed to initialize SoC Host PCIe controller
[0013.314] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(2); error=0x1
[0013.321] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800601
[0013.327] W> Failed to open NVME-2, err = 80800601
[0013.332] W> Failed to initialize device 10-2
[0013.336] E> NVME (2) boot failed, err: 0x80800601
[0013.341] I> ########## NVME (3) boot ##########
[0013.345] I> Initializing nvme device instance 3
[0013.349] I> Initializing nvme controller
[0013.354] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14140000
[0013.360] I> vpcie3v3-supply not found
[0013.363] I> vpcie12v-supply not found
[0013.367] W> Failed to get nvidia,plat-gpios
[0013.371] I> tegrabl_pcie_soc_preinit: (3):
[0013.375] I> Unpowergate
[0013.378] I> tegrabl_car_clk_disable(3) ...
[0013.381] I> tegrabl_car_rst_set(CORE, 3) ...
[0013.386] I> tegrabl_car_rst_set(APB, 3) ...
[0013.390] I> tegrabl_car_clk_enable(3) ...
[0013.394] I> tegrabl_car_rst_clear(APB, 3) ...
[0013.398] I> tegrabl_set_ctrl_state(3)
[0013.402] I> CLR PCIE_APB:6
[0013.404] I> tegrabl_pcie_soc_init: (3):
[0013.408] I> APPL initialization ...
[0013.411] I> poweron phys
[0013.414] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14140000
[0013.420] I> tegrabl_power_on_phy: controller 3 not available
[0013.426] E> Failed to power on phy on controller-3
[0013.431] W> Failed tegrabl_pcie_soc_init(), error=0x1
[0013.435] I> Failed to initialize SoC Host PCIe controller
[0013.441] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(3); error=0x1
[0013.447] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800601
[0013.454] W> Failed to open NVME-3, err = 80800601
[0013.458] W> Failed to initialize device 10-3
[0013.463] E> NVME (3) boot failed, err: 0x80800601
[0013.467] I> ########## NVME (4) boot ##########
[0013.472] I> Initializing nvme device instance 4
[0013.476] I> Initializing nvme controller
[0013.480] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14160000
[0013.486] I> vpcie3v3-supply not found
[0013.490] I> vpcie12v-supply not found
[0013.494] W> Failed to get nvidia,plat-gpios
[0013.498] I> tegrabl_pcie_soc_preinit: (4):
[0013.502] I> Unpowergate
[0013.504] I> tegrabl_car_clk_disable(4) ...
[0013.508] I> tegrabl_car_rst_set(CORE, 4) ...
[0013.512] I> tegrabl_car_rst_set(APB, 4) ...
[0013.516] I> tegrabl_car_clk_enable(4) ...
[0013.520] I> tegrabl_car_rst_clear(APB, 4) ...
[0013.525] I> tegrabl_set_ctrl_state(4)
[0013.528] I> CLR PCIE_APB:6
[0013.531] I> tegrabl_pcie_soc_init: (4):
[0013.535] I> APPL initialization ...
[0013.538] I> poweron phys
[0013.541] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14160000
[0013.547] I> tegrabl_power_on_phy: controller 4 not available
[0013.552] E> Failed to power on phy on controller-4
[0013.557] W> Failed tegrabl_pcie_soc_init(), error=0x1
[0013.562] I> Failed to initialize SoC Host PCIe controller
[0013.567] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(4); error=0x1
[0013.574] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800601
[0013.580] W> Failed to open NVME-4, err = 80800601
[0013.585] W> Failed to initialize device 10-4
[0013.589] E> NVME (4) boot failed, err: 0x80800601
[0013.594] I> ########## NVME (5) boot ##########
[0013.598] I> Initializing nvme device instance 5
[0013.603] I> Initializing nvme controller
[0013.607] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x141a0000
[0013.613] I> vpcie3v3-supply not found
[0013.617] I> vpcie12v-supply not found
[0013.620] W> Failed to get nvidia,plat-gpios
[0013.624] I> tegrabl_pcie_soc_preinit: (5):
[0013.628] I> Unpowergate
[0013.631] I> tegrabl_car_clk_disable(5) ...
[0013.635] I> tegrabl_car_rst_set(CORE, 5) ...
[0013.639] I> tegrabl_car_rst_set(APB, 5) ...
[0013.643] I> tegrabl_car_clk_enable(5) ...
[0013.647] I> tegrabl_car_rst_clear(APB, 5) ...
[0013.651] I> tegrabl_set_ctrl_state(5)
[0013.655] I> CLR PCIE_APB:6
[0013.658] I> tegrabl_pcie_soc_init: (5):
[0013.661] I> APPL initialization ...
[0013.665] I> poweron phys
[0013.668] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x141a0000
[0013.674] I> tegrabl_power_on_phy: power on phy @0x3eb0000
[0013.679] I> tegrabl_power_on_phy: power on phy @0x3ec0000
[0013.684] I> tegrabl_power_on_phy: power on phy @0x3ed0000
[0013.690] I> tegrabl_power_on_phy: power on phy @0x3ee0000
[0013.695] I> tegrabl_power_on_phy: power on phy @0x3ef0000
[0013.700] I> tegrabl_power_on_phy: power on phy @0x3f00000
[0013.706] I> tegrabl_power_on_phy: power on phy @0x3f10000
[0013.711] I> tegrabl_power_on_phy: power on phy @0x3f20000
[0014.816] C> Failed to link up controller-5
[0014.817] W> Failed tegrabl_pcie_soc_init(), error=0x12
[0014.817] I> Failed to initialize SoC Host PCIe controller
[0014.818] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(5); error=0x12
[0014.818] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800612
[0014.819] W> Failed to open NVME-5, err = 80800612
[0014.823] W> Failed to initialize device 10-5
[0014.827] E> NVME (5) boot failed, err: 0x80800612
[0014.832] I> ########## Fixed storage boot ##########
[0014.837] I> Loading kernel-bootctrl from partition
[0014.842] I> Loading partition kernel-bootctrl at 0xa4b60000 from device(0x1)
[0014.856] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0014.857] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0014.863] I> Already published: 00010003
[0014.866] I> Look for boot partition
[0014.870] I> Fallback: assuming 0th partition is boot partition
[0014.876] I> Detect filesystem
[0014.903] I> Loading extlinux.conf ...
[0014.903] I> Loading extlinux.conf binary from rootfs ...
[0014.903] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0014.952] I> Loading extlinux.conf sig file from rootfs ...
[0014.953] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf.sig
[0014.989] I> overload load_size to 848 (from 887)
[0014.990] I> Validate extlinux.conf ...
[0014.990] I> T19x: Authenticate extlinux.conf (bin_type: 54), max size 0x2000
[0014.991] E> digest on binary did not match!!
[0014.991] C> OEM authentication of extlinux.conf payload failed!
[0014.991] W> Failed to validate extlinux.conf binary from rootfs (err=1077936152, fail=0)
[0014.998] W> Security fuse not burned, ignore validation failure
[0015.004] I> restore load_size to 887
[0015.007] I> L4T boot options
[0015.010] I> [1]: "primary kernel"
[0015.013] I> [2]: "backup kernel"
[0015.016] I> Enter choice:
[0018.020] I> Continuing with default option: 1
[0018.020] I> Loading kernel ...
[0018.020] I> No kernel binary path
[0018.020] I> Continue to load from partition ...
[0018.021] W> No valid slot number is found in scratch register
[0018.021] W> Return default slot: _a
[0018.021] I> A/B: bin_type (37) slot 0
[0018.022] I> Loading kernel from partition
[0018.026] I> Loading partition kernel at 0xa4b60000 from device(0x1)
[0018.775] I> Validate kernel ...
[0018.775] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0019.158] I> Encryption fuse is not ON
[0019.189] I> Checking boot.img header magic ... [0019.189] I> [OK]
[0019.190] I> Loading kernel-dtb ...
[0019.190] I> Loading kernel-dtb binary from rootfs ...
[0019.190] I> rootfs path: /sdmmc_user/boot/tegra194-p3668-all-p3509-0000.dtb
[0019.228] I> Loading kernel-dtb sig file from rootfs ...
[0019.228] I> rootfs path: /sdmmc_user/boot/tegra194-p3668-all-p3509-0000.dtb.sig
[0019.265] I> Validate kernel-dtb ...
[0019.265] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0019.268] E> digest on binary did not match!!
[0019.268] C> OEM authentication of kernel-dtb payload failed!
[0019.268] W> Failed to validate kernel-dtb binary from rootfs (err=1077936152, fail=0)
[0019.269] W> Security fuse not burned, ignore validation failure
[0019.274] I> restore load_size to 198094
[0019.277] I> Kernel hdr @0xa4b60000
[0019.281] I> Kernel dtb @0x90000000
[0019.284] I> decompressor handler not found
[0019.288] I> Copying kernel image (34818056 bytes) from 0xa4b60800 to 0x80080000 ... [0019.304] I> Done
[0019.304] I> Move ramdisk (len: 7238344) from 0xa6c95800 to 0x91000000
[0019.307] I> Updated bpmp info to DTB
[0019.308] I> Ramdisk: Base: 0x91000000; Size: 0x6e72c8
[0019.312] I> Updated initrd info to DTB
[0019.316] W> WARN: Fail to override "console=none" in commandline
[0019.322] I> Active rootfs suffix:
[0019.325] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0019.332] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0019.340] W> No valid slot number is found in scratch register
[0019.345] W> Return default slot: _a
[0019.349] I> Active slot suffix:
[0019.352] I> add_boot_slot_suffix: slot_suffix =
[0019.356] I> Linux Cmdline: console=ttyTCU0,115200 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 fbcon=map:0 net.ifnames=0 rootfstype=ext4 console=none keep_bootcon video=tegrafb earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= tegra_fbmem=0x800000@0xa06b2000 lut_mem=0x2008@0xa06af000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[0019.396] I> Updated bootarg info to DTB
[0019.400] W> MAC addr invalid!
[0019.403] E> Failed to get WIFI MAC address
[0019.407] W> MAC addr invalid!
[0019.410] E> Failed to get Bluetooth MAC address
[0019.414] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:67:92:85
[0019.421] W> "plugin-manager" doesn't exist, creating
[0019.425] I> Adding /chosen/plugin-manager/cvm
[0019.429] W> "chip-id" doesn't exist, creating
[0019.434] I> Adding /chosen/plugin-manager/chip-id
[0019.438] W> "configs" doesn't exist, creating
[0019.443] I> Adding /chosen/plugin-manager/configs
[0019.447] W> "ids" doesn't exist, creating
[0019.451] I> Adding /chosen/plugin-manager/ids
[0019.456] W> "odm-data" doesn't exist, creating
[0019.460] I> Adding /chosen/plugin-manager/odm-data
[0019.468] W> "memory" doesn't exist, creating
[0019.469] I> [0] START: 0x80000000, END: 0xac000000
[0019.474] I> [1] START: 0xac004000, END: 0xf0ad0000
[0019.478] I> [2] START: 0xf0adc000, END: 0xf0ae0000
[0019.483] I> dram_block larger than 80000000
[0019.487] I> [3] START: 0x100000000, END: 0x480000000
[0019.492] I> added [base:0x80000000, size:0x2c000000] to /memory
[0019.498] I> added [base:0xac200000, size:0x44800000] to /memory
[0019.504] I> added [base:0x100000000, size:0x380000000] to /memory
[0019.511] I> Updated memory info to DTB
[0019.514] E> add_disp_param: failed to get display params for du=1
[0019.520] W> "reset" doesn't exist, creating
[0019.524] I> Adding ecid(000000016430b0071800000019038240) to DT
[0019.530] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0019.534] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0019.539] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0019.544] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0019.548] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0019.553] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0019.558] I> Deleted cpu@6 node in DT
[0019.561] I> Deleted cpu@7 node in DT
[0019.565] I> Deleted cluster3 node in FDT
[0019.569] I> Update arm-pmu in FDT
[0019.572] I> - update property: interrupts
[0019.576] I> - update property: interrupt-affinity
[0019.581] W> "misc-data" doesn't exist, creating
[0019.585] I> Boot-device: QSPI
[0019.588] W> Unknown boot device
[0019.591] I> Add storage-qspi to plugin-manager/misc-data
[0019.596] W> Unknown storage device
[0019.600] I> Add serial number:1421022081250 as DT property
[0019.606] I> Plugin-manager override starting
[0019.609] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0019.616] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0019.623] I> node /plugin-manager/fragement-tegra-pcie-c5-num-lanes matches
[0019.628] I> node /plugin-manager/fragement-tegra-pcie-c4-dis matches
[0019.635] I> Disable plugin-manager status in FDT
[0019.638] I> Plugin-manager override finished successfully
[0019.644] I> tegrabl_load_kernel_and_dtb: Done
[0019.666] I> Kernel EP: 0x80080000, DTB: 0x90000000
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.253-tegra (sz@twsrv01) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #20 SMP PREEMPT Fri Sep 23 11:20:06 CST 2022
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44800000
[ 0.000000] OF: fdt: - 100000000 , 380000000
[ 0.000000] debug: skip boot console de-registration.
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] Found tegra_fbmem: 00800000@a06b2000
[ 0.000000] Found lut_mem: 00002008@a06af000
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[ 0.000000] cma: Reserved 64 MiB at 0x00000000c2000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s57624 r8192 d32488 u98304
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 4063749
[ 0.000000] Kernel command line: console=ttyTCU0,115200 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 fbcon=map:0 net.ifnames=0 rootfstype=ext4 console=none keep_bootcon video=tegrafb earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= tegra_fbmem=0x800000@0xa06b2000 lut_mem=0x2008@0xa06af000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29928(91%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[ 0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Memory: 15427360K/16513012K available (15486K kernel code, 2962K rwdata, 6824K rodata, 8704K init, 618K bss, 331988K reserved, 753664K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008fa0000 ( 15488 KB)
[ 0.000000] .rodata : 0xffffff8008fa0000 - 0xffffff8009650000 ( 6848 KB)
[ 0.000000] .init : 0xffffff8009650000 - 0xffffff8009ed0000 ( 8704 KB)
[ 0.000000] .data : 0xffffff8009ed0000 - 0xffffff800a1b4808 ( 2963 KB)
[ 0.000000] .bss : 0xffffff800a1b4808 - 0xffffff800a24f034 ( 619 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf10000000 ( 256 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc400000000 ( 16384 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000006] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.008804] Console: colour dummy device 80x25
[ 0.012429] kmemleak: Kernel memory leak detector disabled
[ 0.017973] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.028087] pid_max: default: 32768 minimum: 301
[ 0.033812] Security Framework initialized
[ 0.037236] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.043773] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.052492] ftrace: allocating 47553 entries in 186 pages
[ 0.449200] sched-energy: Sched-energy-costs installed from DT
[ 0.449371] ASID allocator initialised with 65536 entries
[ 0.483870] tegra-id: chipid=21917.
[ 0.483957] tegra-id: opt_subrevision=1.
[ 0.484049] Tegra Revision: A02p SKU: 0xde CPU Process: 0 SoC Process: 0
[ 0.484183] DTS File Name: /home/sz/coding/xavier_r32.7/l4t-r32.6.1/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[ 0.484505] DTB Build time: Sep 14 2022 11:29:21
[ 0.531970] CPU1: Booted secondary processor [4e0f0040]
[ 0.564166] CPU2: Booted secondary processor [4e0f0040]
[ 0.596291] CPU3: Booted secondary processor [4e0f0040]
[ 0.628517] CPU4: Booted secondary processor [4e0f0040]
[ 0.660584] CPU5: Booted secondary processor [4e0f0040]
[ 0.660760] Brought up 6 CPUs
[ 0.661249] SMP: Total of 6 processors activated.
[ 0.661400] CPU features: detected feature: Privileged Access Never
[ 0.661508] CPU features: detected feature: LSE atomic instructions
[ 0.661617] CPU features: detected feature: User Access Override
[ 0.661719] CPU features: detected feature: 32-bit EL0 Support
[ 0.663428] CPU: All CPU(s) started at EL2
[ 0.663552] alternatives: patching kernel code
[ 0.670919] devtmpfs: initialized
[ 0.717021] Initilizing CustomIPI irq domain
[ 0.717302] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.717478] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.731540] pinctrl core: initialized pinctrl subsystem
[ 0.731908] OS set in device tree is not L4T.
[ 0.732279] regulator-dummy: no parameters
[ 0.732645] Initializing plugin-manager
[ 0.732764] Plugin module not found
[ 0.732877] Plugin-manager status disabled
[ 0.733986] NET: Registered protocol family 16
[ 0.735519] pstore: using zlib compression
[ 0.736321] console [pstore-1] enabled
[ 0.736407] pstore: Registered ramoops as persistent store backend
[ 0.736556] ramoops: attached 0x200000@0xf0800000, ecc: 0/0
[ 0.752727] cpuidle: using governor menu
[ 0.753931] bpmp: waiting for handshake
[ 0.754028] bpmp: handshake completed
[ 0.754120] bpmp: synchronizing channels
[ 0.754215] bpmp: channels synchronized
[ 0.754326] bpmp: mail init ok
[ 0.757125] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[ 0.757466] t19x-arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.757633] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.757747] t19x-arm-smmu 12000000.iommu: stage 1 translation
[ 0.757858] t19x-arm-smmu 12000000.iommu: stage 2 translation
[ 0.763418] t19x-arm-smmu 12000000.iommu: nested translation
[ 0.769027] t19x-arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.777682] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.788622] t19x-arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.795359] t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.802621] t19x-arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.813593] vdso: 2 pages (1 code @ ffffff8008fa7000, 1 data @ ffffff8009ed4000)
[ 0.817266] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.826257] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.832971] tegra_aon_clk_init: ok
[ 0.835416] Registering BPMP clocks...
[ 0.839206] tegra_bpmp_clk_init: clock init ok (400 clks)
[ 0.845494] Serial: AMBA PL011 UART driver
[ 0.848861] tegra_powergate_init: DONE
[ 0.852708] DTS File Name: /home/sz/coding/xavier_r32.7/l4t-r32.6.1/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[ 0.870976] DTB Build time: Sep 14 2022 11:29:21
[ 0.879238] Tegra reboot handler registered.
[ 0.887760] iommu: Adding device 141a0000.pcie to group 0
[ 0.889196] iommu: Adding device 2490000.ether_qos to group 1
[ 0.891970] iommu: Adding device 3100000.serial to group 2
[ 0.897780] iommu: Adding device 3110000.serial to group 3
[ 0.903075] iommu: Adding device 3140000.serial to group 4
[ 0.908529] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.914931] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.920250] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.926777] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 0.932554] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.937778] tegra-pmc: PMC Prod config success
[ 0.942215] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.949017] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.955564] iommu: Adding device 3460000.sdhci to group 5
[ 0.961250] iommu: Adding device 3440000.sdhci to group 6
[ 0.966708] iommu: Adding device 3400000.sdhci to group 7
[ 0.972436] iommu: Adding device 3210000.spi to group 8
[ 0.977408] iommu: Adding device 3230000.spi to group 9
[ 0.982512] iommu: Adding device 3270000.spi to group 10
[ 0.988704] iommu: Adding device 3160000.i2c to group 11
[ 0.993583] iommu: Adding device c240000.i2c to group 12
[ 0.998555] iommu: Adding device 3180000.i2c to group 13
[ 1.004119] iommu: Adding device 3190000.i2c to group 14
[ 1.009702] iommu: Adding device 31b0000.i2c to group 15
[ 1.015071] iommu: Adding device 31c0000.i2c to group 16
[ 1.020800] iommu: Adding device c250000.i2c to group 17
[ 1.026005] iommu: Adding device 31e0000.i2c to group 18
[ 1.031648] iommu: Adding device sound to group 19
[ 1.036770] iommu: Adding device 3510000.hda to group 20
[ 1.042216] iommu: Adding device bc00000.rtcpu to group 21
[ 1.048684] iommu: Adding device 13e10000.host1x to group 22
[ 1.053321] iommu: Adding device 13e10000.host1x:ctx0 to group 23
[ 1.059477] iommu: Adding device 13e10000.host1x:ctx1 to group 24
[ 1.065273] iommu: Adding device 13e10000.host1x:ctx2 to group 25
[ 1.071607] iommu: Adding device 13e10000.host1x:ctx3 to group 26
[ 1.077498] iommu: Adding device 13e10000.host1x:ctx4 to group 27
[ 1.083916] iommu: Adding device 13e10000.host1x:ctx5 to group 28
[ 1.089912] iommu: Adding device 13e10000.host1x:ctx6 to group 29
[ 1.095747] iommu: Adding device 13e10000.host1x:ctx7 to group 30
[ 1.101993] iommu: Adding device 15340000.vic to group 31
[ 1.107323] iommu: Adding device 15380000.nvjpg to group 32
[ 1.112971] iommu: Adding device 15500000.tsec to group 33
[ 1.118414] iommu: Adding device 15100000.tsecb to group 34
[ 1.124167] iommu: Adding device 15480000.nvdec to group 35
[ 1.129621] iommu: Adding device 15140000.nvdec1 to group 36
[ 1.135404] iommu: Adding device 154c0000.nvenc to group 37
[ 1.140766] iommu: Adding device 15a80000.nvenc1 to group 38
[ 1.146771] iommu: Adding device 15880000.nvdla0 to group 39
[ 1.152373] iommu: Adding device 158c0000.nvdla1 to group 40
[ 1.158056] iommu: Adding device 15200000.nvdisplay to group 41
[ 1.163301] platform 15200000.nvdisplay: IOVA linear map 0x00000000a06b2000(800000)
[ 1.171090] platform 15200000.nvdisplay: IOVA linear map 0x00000000a06af000(3000)
[ 1.182819] platform 15200000.nvdisplay: IOVA linear map 0x00000000c6000000(2a000000)
[ 1.186361] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[ 1.193464] iommu: Adding device 15210000.nvdisplay to group 42
[ 1.198883] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[ 1.206963] iommu: Adding device 15c10000.vi to group 43
[ 1.211107] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[ 1.217380] iommu: Adding device 14800000.isp to group 44
[ 1.223306] iommu: Adding device 16000000.pva0 to group 45
[ 1.227913] iommu: Adding device 16800000.pva1 to group 46
[ 1.233518] iommu: Adding device 15810000.se to group 47
[ 1.238570] iommu: Adding device 15820000.se to group 48
[ 1.244280] iommu: Adding device 15830000.se to group 49
[ 1.249425] iommu: Adding device 15840000.se to group 50
[ 1.255196] iommu: Adding device c1a0000.aon to group 51
[ 1.261870] iommu: Adding device d000000.bpmp to group 52
[ 1.265910] bpmp: ping status is 0
[ 1.269172] bpmp d000000.bpmp: firmware tag is e73a758761f0c6d24a1e69a2ac6b5035
[ 1.279371] bpmp d000000.bpmp: probe ok
[ 1.281800] tegra-reset 0.bpmp_reset: registered 190 resets.
[ 1.286035] iommu: Adding device smmu_test to group 53
[ 1.292151] mc: mapped MMIO address: 0xffffff800a610000 -> 0x2c10000
[ 1.297572] mc: mapped MMIO address: 0xffffff800a630000 -> 0x2c20000
[ 1.304115] mc: mapped MMIO address: 0xffffff800a650000 -> 0x2c30000
[ 1.310327] mc: mapped MMIO address: 0xffffff800a670000 -> 0x2c40000
[ 1.316699] mc: mapped MMIO address: 0xffffff800a690000 -> 0x2c50000
[ 1.323086] mc: mapped MMIO address: 0xffffff800a6b0000 -> 0x2b80000
[ 1.329214] mc: mapped MMIO address: 0xffffff800a6d0000 -> 0x2b90000
[ 1.335949] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2ba0000
[ 1.342535] mc: mapped MMIO address: 0xffffff800a7d0000 -> 0x2bb0000
[ 1.348987] mc: mapped MMIO address: 0xffffff800b110000 -> 0x1700000
[ 1.355206] mc: mapped MMIO address: 0xffffff800b130000 -> 0x1710000
[ 1.361930] mc: mapped MMIO address: 0xffffff800b150000 -> 0x1720000
[ 1.368314] mc: mapped MMIO address: 0xffffff800b170000 -> 0x1730000
[ 1.374444] mc: mapped MMIO address: 0xffffff800b190000 -> 0x1740000
[ 1.380827] mc: mapped MMIO address: 0xffffff800b1b0000 -> 0x1750000
[ 1.387485] mc: mapped MMIO address: 0xffffff800b1d0000 -> 0x1760000
[ 1.393604] mc: mapped MMIO address: 0xffffff800b1f0000 -> 0x1770000
[ 1.400063] mc-err: mcerr ops are set to t19x
[ 1.409916] iommu: Adding device 2600000.dma to group 54
[ 1.414374] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 224 lines on the chip
[ 1.420713] GPIO line 339 (wifi-enable) hogged as output/high
[ 1.424803] GPIO line 421 (usb-pwr-en) hogged as output/high
[ 1.430378] GPIO line 419 (tf-pwr-en) hogged as output/high
[ 1.435973] GPIO line 424 (gpio07) hogged as output/high
[ 1.441313] GPIO line 436 (cam-pwdn-high) hogged as output/high
[ 1.447431] GPIO line 417 (cam-pwdn-high) hogged as output/high
[ 1.453044] GPIO line 422 (cam-pwdn-high) hogged as output/high
[ 1.459068] GPIO line 417 (cam-pwdn-low) hogged as output/low
[ 1.464669] GPIO line 422 (cam-pwdn-low) hogged as output/low
[ 1.470753] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[ 1.484888] gpio gpiochip1: gpio-line-names specifies 21 line names but there are 40 lines on the chip
[ 1.488254] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[ 1.494514] GPIO line 264 (w-disable2) hogged as output/high
[ 1.499942] GPIO line 266 (gpio05) hogged as output/high
[ 1.505274] GPIO line 267 (gpio06) hogged as output/high
[ 1.511185] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[ 1.521506] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_83 = 0x10a
[ 1.526098] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 1.532102] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 1.539967] iommu: Adding device 3550000.xudc to group 55
[ 1.545123] iommu: Adding device 3610000.xhci to group 56
[ 1.551959] arm64_ras arm64_ras: probed
[ 1.554377] ras_fhi_enable: FHI 469 enabled on CPU0
[ 1.558737] ras_fhi_enable: FHI 470 enabled on CPU1
[ 1.563728] ras_fhi_enable: FHI 471 enabled on CPU2
[ 1.568967] ras_fhi_enable: FHI 472 enabled on CPU3
[ 1.573751] ras_fhi_enable: FHI 473 enabled on CPU4
[ 1.578556] ras_fhi_enable: FHI 474 enabled on CPU5
[ 1.583426] carmel_ras_enable: RAS enabled on cpu0
[ 1.588396] carmel_ras_enable: RAS enabled on cpu1
[ 1.593549] carmel_ras_enable: RAS enabled on cpu2
[ 1.598502] carmel_ras_enable: RAS enabled on cpu3
[ 1.603402] carmel_ras_enable: RAS enabled on cpu4
[ 1.608393] carmel_ras_enable: RAS enabled on cpu5
[ 1.613194] carmel_ras carmel_ras: probed
[ 1.618344] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 478, noc_nonsecure_irq = 477>
[ 1.625492] tegra-cbb c600000.aon-noc: noc_secure_irq = 480, noc_nonsecure_irq = 479>
[ 1.633436] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 482, noc_nonsecure_irq = 481>
[ 1.641388] tegra-cbb be00000.rce-noc: noc_secure_irq = 484, noc_nonsecure_irq = 483>
[ 1.649162] tegra-cbb b600000.sce-noc: noc_secure_irq = 486, noc_nonsecure_irq = 485>
[ 1.656166] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[ 1.664134] vdd-ac-bat: 5000 mV
[ 1.666378] vdd-sdmmc1-sw: 3300 mV
[ 1.669834] vdd-1v8-sd: 1800 mV
[ 1.673562] vdd-3v3-cvb: 3300 mV
[ 1.676728] vdd-1v8-cvb: 1800 mV
[ 1.679667] vdd-epb-1v0: 1000 mV
[ 1.683016] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 1.687637] avdd-cam-2v8: 2800 mV
[ 1.691082] vdd-fan: 5000 mV
[ 1.694525] vdd-hdmi-5v0: 5000 mV
[ 1.697915] vdd_sys_en: 1200 mV
[ 1.734050] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 1.738686] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.739106] SCSI subsystem initialized
[ 1.739647] usbcore: registered new interface driver usbfs
[ 1.739802] usbcore: registered new interface driver hub
[ 1.739966] usbcore: registered new device driver usb
[ 1.752034] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[ 1.755242] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x2
[ 1.763255] vdd-1v0: at 1000 mV
[ 1.765942] vdd-1v8-hs: at 1800 mV
[ 1.770295] vdd-1v8-ls: at 1800 mV
[ 1.774289] vdd-1v8-ao: at 1800 mV
[ 1.778298] vddio-ddr-1v1: at 1100 mV
[ 1.782072] vdd-rtc: at 800 mV
[ 1.783422] spmic-ldo1: at 2375 mV
[ 1.790099] vdd-ao-3v3: at 3300 mV
[ 1.797199] vddio-emmc-3v3: at 3300 mV
[ 1.798575] spmic-ldo4: at 1587 mV
[ 1.805237] vdd-usb-3v3: at 3300 mV
[ 1.813286] vddio-sdmmc1-3v3: at 3300 mV
[ 1.817309] vdd-csi-1v2: at 1200 mV
[ 1.818981] spmic-ldo8: at 1800 mV
[ 1.823957] GPIO line 246 (gpio_default) hogged as output/high
[ 1.825508] GPIO line 247 (gpio_default) hogged as output/high
[ 1.825930] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[ 1.826356] max77620 4-003c: max77620 probe successful
[ 1.827140] media: Linux media interface: v0.10
[ 1.830018] Linux video capture interface: v2.00
[ 1.835903] pps_core: LinuxPPS API ver. 1 registered
[ 1.839332] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.848286] PTP clock support registered
[ 1.852363] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 1.858605] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.865694] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 1.874574] trusty trusty: trusty version: Built: 12:20:34 Jul 26 2021
[ 1.878793] trusty trusty: selected api version: 3 (requested 3)
[ 1.885910] Advanced Linux Sound Architecture Driver Initialized.
[ 1.891245] Bluetooth: Core ver 2.22
[ 1.894285] NET: Registered protocol family 31
[ 1.898822] Bluetooth: HCI device and connection manager initialized
[ 1.905291] Bluetooth: HCI socket layer initialized
[ 1.910019] Bluetooth: L2CAP socket layer initialized
[ 1.915295] Bluetooth: SCO socket layer initialized
[ 1.923102] camchar: rtcpu character device driver loaded
[ 1.926378] gpio tegra-gpio wake61 for gpio=201(Z:1)
[ 1.930926] extcon-gpio-states external-connection:extcon@1: Cable state:1, cable id:1
[ 1.939640] clocksource: Switched to clocksource arch_sys_counter
[ 1.988377] VFS: Disk quotas dquot_6.6.0
[ 1.988577] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.989069] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 1.990388] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[ 1.990612] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[ 1.991218] cma: enabled page replacement for spfn=c6000, epfn=f0000
[ 1.991346] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful[ 1.992372] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 2.003550] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[ 2.009639] nvmap_page_pool_init: Total RAM pages: 4045256
[ 2.016063] nvmap_page_pool_init: nvmap page pool size: 505657 pages (1975 MB)
[ 2.019732] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 2.019927] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 2.020132] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[ 2.020280] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[ 2.020421] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 2.021581] la/ptsa driver initialized.
[ 2.021957] NET: Registered protocol family 2
[ 2.022878] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 2.023418] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 2.024036] TCP: Hash tables configured (established 131072 bind 65536)
[ 2.024091] UDP hash table entries: 8192 (order: 6, 262144 bytes)
[ 2.024316] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes)
[ 2.024873] NET: Registered protocol family 1
[ 2.025449] RPC: Registered named UNIX socket transport module.
[ 2.025453] RPC: Registered udp transport module.
[ 2.025457] RPC: Registered tcp transport module.
[ 2.025460] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.025679] Trying to unpack rootfs image as initramfs...
[ 2.138564] nvmap_background_zero_thread: PP zeroing thread starting.
[ 2.138961] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[ 2.252574] Freeing initrd memory: 7068K
[ 2.266042] random: fast init done
[ 2.270620] host1x 13e10000.host1x: initialized
[ 2.272685] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 2.277379] audit: initializing netlink subsys (disabled)
[ 2.277551] audit: type=2000 audit(1.560:1): initialized
[ 2.278255] workingset: timestamp_bits=46 max_order=22 bucket_order=0
[ 2.285810] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.286982] ntfs: driver 2.1.32 [Flags: R/W].
[ 2.287708] 9p: Installing v9fs 9p2000 file system support
[ 2.292963] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 2.293278] io scheduler noop registered
[ 2.293572] io scheduler cfq registered (default)
[ 2.297546] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 2.333144] iommu: Adding device 2993000.adsp to group 57
[ 2.443242] iommu: Adding device aconnect@2a41000:adsp_audio to group 58
[ 2.444337] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 2.457243] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 2.457813] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 2.458456] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 2.458980] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[ 2.459512] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 2.462288] sprd_pci_ep_dev_init Quectel_Linux&Android_SPRD_PCIE_Driver_V1.1.6
[ 2.462754] sipc: name=sprd,sipc
[ 2.462834] sipc: type=1
[ 2.462888] sipc: dst =1
[ 2.462947] sipc: ep_dev=0
[ 2.463003] sipc: smem_type = 0
[ 2.463359] sipc: smem_base=0x69800000, dst_smem_base=0x69800000, smem_size=0x300000
[ 2.463516] sipc: high_offset=0x0n[ 2.463585] smsg_ipc_create: sprd,sipc
[ 2.463905] smem_init: pool addr = 0x69800000, size = 0x300000 added.
[ 2.464042] smsg_ipc_smem_init: ring_base = 0x69800000, ring_size = 0x1000
[ 2.464231] CPU5: SError detected, daif=1c0, spsr=0x8000c5, mpidr=80000201, esr=be000000
[ 2.464242] CPU2: SError detected, daif=1c0, spsr=0xc000c5, mpidr=80000100, esr=be000000
[ 2.464249] CPU3: SError detected, daif=1c0, spsr=0x8000c5, mpidr=80000101, esr=be000000
[ 2.464257] CPU0: SError detected, daif=1c0, spsr=0x80c00045, mpidr=80000000, esr=be000000
[ 2.464266] CPU1: SError detected, daif=1c0, spsr=0xc000c5, mpidr=80000001, esr=be000000
[ 2.464273] CPU4: SError detected, daif=1c0, spsr=0x8000c5, mpidr=80000200, esr=be000000
[ 2.464286] ras_ccplex_serr_callback: Scanning CCPLEX Error Records for Uncorrectable Errors
[ 2.464321] ras_corecluster_serr_callback:Scanning CoreCluster Error Records for Uncorrectable Errors
[ 2.464334] **************************************
[ 2.464338] RAS Error in L2, ERRSELR_EL1=512:
[ 2.464341] Status = 0xfc00630d
[ 2.464346] IERR = SCF to L2 Decode Error Write: 0x63
[ 2.464349] SERR = Illegal address (software fault): 0xd
[ 2.464352] Overflow (there may be more errors) - Uncorrectable
[ 2.464354] Uncorrectable (this is fatal)
[ 2.464363] MISC0 = 0x80000000080000
[ 2.464366] MISC1 = 0x20ac0000000
[ 2.464372] ADDR = 0x8000000069800000
[ 2.464380] **************************************
[ 2.464425] ras_core_serr_callback: Scanning Core Error Records for Uncorrectable Errors
[ 2.464534] Bad mode in Error handler detected on CPU2, code 0xbe000000 -- SError
[ 2.464539] Kernel panic - not syncing: bad mode
[ 2.464549] CPU: 2 PID: 0 Comm: swapper/2 Not tainted 4.9.253-tegra #20
[ 2.464552] Hardware name: NVIDIA Jetson Xavier NX N205V1.0_ALG_ISX021 (DT)
[ 2.464555] Call trace:
[ 2.464576] [<ffffff800808ba40>] dump_backtrace+0x0/0x198
[ 2.464580] ras_ccplex_serr_callback: Scanning CCPLEX Error Records for Uncorrectable Errors
[ 2.464586] [<ffffff800808c004>] show_stack+0x24/0x30
[ 2.464595] [<ffffff8008f8408c>] dump_stack+0xa0/0xc4
[ 2.464603] [<ffffff8008f81130>] panic+0x12c/0x2a8
[ 2.464609] [<ffffff800808c894>] bad_mode+0x7c/0x80
[ 2.464613] ras_corecluster_serr_callback:Scanning CoreCluster Error Records for Uncorrectable Errors
[ 2.464618] [<ffffff800808ca5c>] handle_serr+0x124/0x128
[ 2.464624] [<ffffff8008082d98>] el1_serr+0xb0/0x144
[ 2.464630] [<ffffff80081116a8>] cpu_startup_entry+0x140/0x200
[ 2.464637] [<ffffff8008091cf8>] secondary_start_kernel+0x190/0x1f8
[ 2.464642] [<0000000080f911a8>] 0x80f911a8
[ 2.464650] SMP: stopping secondary CPUs
[ 2.464668] ras_core_serr_callback: Scanning Core Error Records for Uncorrectable Errors
[ 2.464804] ras_ccplex_serr_callback: Scanning CCPLEX Error Records for Uncorrectable Errors
[ 2.464837] ras_corecluster_serr_callback:Scanning CoreCluster Error Records for Uncorrectable Errors
[ 2.464885] ras_core_serr_callback: Scanning Core Error Records for Uncorrectable Errors
[ 2.465003] ras_ccplex_serr_callback: Scanning CCPLEX Error Records for Uncorrectable Errors
[ 2.465033] ras_corecluster_serr_callback:Scanning CoreCluster Error Records for Uncorrectable Errors
[ 2.465077] ras_core_serr_callback: Scanning Core Error Records for Uncorrectable Errors
[ 2.465182] ras_ccplex_serr_callback: Scanning CCPLEX Error Records for Uncorrectable Errors
[ 2.465215] ras_corecluster_serr_callback:Scanning CoreCluster Error Records for Uncorrectable Errors
[ 2.465246] ras_core_serr_callback: Scanning Core Error Records for Uncorrectable Errors
[ 2.754855] ras_ccplex_serr_callback: Scanning CCPLEX Error Records for Uncorrectable Errors
[ 2.763345] ras_corecluster_serr_callback:Scanning CoreCluster Error Records for Uncorrectable Errors
[ 2.772785] ras_core_serr_callback: Scanning Core Error Records for Uncorrectable Errors
[ 2.780773] Kernel Offset: disabled
[ 2.784405] Memory Limit: none
[ 2.793622] Rebooting in 5 seconds..
