Welcome to minicom 2.7.1
OPTIONS: I18n
Compiled on Dec 23 2019, 02:06:26.
Port /dev/ttyUSB0, 17:14:40
Press CTRL-A Z for help on special keys
[0000.025] W> RATCHET: MB1 binary ratchet value 4 is larger than ratchet level 2 from HW fuses.
[0000.033] I> MB1 (prd-version: 2.5.0.0-t194-41334769-d9272b5a)
[0000.039] I> Boot-mode: Coldboot
[0000.042] I> Platform: Silicon
[0000.044] I> Chip revision : A02P
[0000.047] I> Bootrom patch version : 15 (correctly patched)
[0000.053] I> ATE fuse revision : 0x200
[0000.056] I> Ram repair fuse : 0x0
[0000.059] I> Ram Code : 0x0
[0000.062] I> rst_source: 0x0, rst_level: 0x0
[0000.067] I> Boot-device: QSPI (instance: 0)
[0000.071] I> Qspi flash params source = brbct
[0000.075] I> Qspi clock source : pllp
[0000.078] I> Qspi-0 initialized successfully
[0000.082] I> Boot chain mechanism: A/B
[0000.085] I> Current Boot-Chain Slot: 0
[0000.089] I> BR-BCT Boot-Chain: 0, status: 0. update flag: 0
[0000.094] I> Qspi flash params source = brbct
[0000.101] W> PROD_CONFIG: device prod data is empty in MB1 BCT.
[0000.108] I> Temperature = 21500
[0000.111] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.115] W> Skipping boost for clk: BPMP_APB
[0000.119] W> Skipping boost for clk: AXI_CBB
[0000.123] W> Skipping boost for clk: AON_CPU_NIC
[0000.127] W> Skipping boost for clk: CAN1
[0000.131] W> Skipping boost for clk: CAN2
[0000.135] I> Boot-device: QSPI (instance: 0)
[0000.139] I> Qspi flash params source = mb1bct
[0000.143] I> Qspi clock source : pllc_out0
[0000.147] I> Qspi-0 reinitialized
[0000.150] I> Qspi flash params source = mb1bct
[0000.163] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.170] W> Thermal config not found in BCT
[0000.178] W> MEMIO rail config not found in BCT
[0000.188] I> Qspi flash params source = mb1bct
[0000.202] I> Qspi flash params source = mb1bct
[0000.236] I> Qspi flash params source = mb1bct
[0000.799] I> Qspi flash params source = mb1bct
[0000.816] I> Qspi flash params source = mb1bct
[0000.855] W> Platform config not found in BCT
[0000.882] I> Qspi flash params source = mb1bct
[0000.908] I> MB1 done
����main enter
SPE VERSION #: R01.00.18 Created: Jan 29 2021 @ 14:18:27
HW Function test
Start Scheduler.
in late init
[0000.917] I> Welcome to MB2(TBoot-BPMP) (version: default.t194-mobile-78ae5a2a)
[0000.918] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.918] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.919] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.925] W> device prod register failed
[0000.928] I> gpio framework initialized
[0000.932] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0000.939] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0000.947] I> sdcard_params [0, 55, 0, 50] in mb1_bct
[0000.952] I> Boot_device: QSPI_FLASH instance: 0
[0000.956] I> qspi flash-0 params source = boot args
[0000.962] I> QSPI-0l initialized successfully
[0000.972] I> Found 41 partitions in QSPI_FLASH (instance 0)
[0000.974] I> Active Boot chain : 0
[0001.655] I> Relocating BR-BCT
[0001.657] > DEVICE_PROD: device prod is not initialized.
[0001.968] I> Relocating OP-TEE dtb from: 0x6bfff240 to 0x70050000, size: 1008
[0001.969] I> [0] START: 0x80000000, SIZE: 0x2f000000
[0001.969] I> [1] START: 0xaf010000, SIZE: 0x18bf0000
[0001.970] I> [2] START: 0xc7d00000, SIZE: 0xc0000
[0001.970] I> [3] START: 0xca000000, SIZE: 0x800000
[0001.971] I> dram_block larger than 80000000
[0001.973] I> [4] START: 0x100000000, SIZE: 0x180000000
[0001.985] I> Setting NS memory ranges to OP-TEE dtb finished.
[0001.988] I> found decompressor handler: lz4
[0002.216] I> EKB detected (length: 0x410) @ VA:0x526ff400
[0002.218] I> Setting EKB blob info to OPTEE dtb finished.
��NOTICE: BL31: v2.6(release):6363e7382
NOTICE: BL31: Built : 15:09:29, Jan 24 2023
I/TC:
bpmp: init
bpmp: tag is 128431eec76692047e1ac1ebc0392266
sku_dt_init: not sku 0x00
clk_early initialized
��I/T��mail_early initialized
��C��fuse initialized
hwwdt initialized
��: Non��t194_ec_get_ec_list: found 45 ecs
��-secure ex��ec initialized
��t��vmon_setup_monitors: found 3 monitors
vmon initialized
��ern��adc initialized
fmon_populate_monitors: found 73 monitors
��al DT found
��fmon initialized
mc initialized
reset initialized
nvhs initialized
uphy_early initialized
emc_early initialized
392 clocks registered
clk initialized
io_dpd initialized
thermal initialized
thermal_mrq initialized
i2c initialized
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
vrmon initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
suspend initialized
pg_late initialized
pg_mrq_init initialized
strap initialized
nvl initialized
emc initialized
emc_mrq initialized
clk_dt initialized
tj_init initialized
uphy_dt initialized
uphy_mrq initialized
uphy initialized
ec_swd_poll_start: 281 reg polling start w period 47 ms
ec_late initialized
hwwdt_late initialized
reset_mrq initialized
ec_mrq initialized
fmon_mrq initialized
clk_mrq initialized
avfs_mrq initialized
mail_mrq initialized
i2c_mrq initialized
tag_mrq initialized
console_mrq initialized
mrq initialized
clk_sync_fmon_post initialized
��I/TC: OP-TEE version: 3.19 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Tu��clk_dt_late initialized
noc_late initialized
��e��pm_post initialized
dbells initialized
�� Ja��dmce initialized
��n��cvc initialized
�� 24 23:20:42��avfs_clk_mach_post initialized
�� UTC��avfs_clk_platform_post initialized
�� 20��cvc_late initialized
regulator_post initialized
��23 a��rm initialized
console_late initialized
clk_dt_post initialized
mc_reg initialized
��arch64
I/TC: WARNING:��pg_post initialized
profile initialized
fuse_late initialized
extras_post initialized
bpmp: init complete
entering main console loop
] �� This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: Primary CPU switching to normal world boot
[0002.837] I> Welcome to NVDisp-Init
[0002.837] I> NVDisp-Init version: t194-709c0123
[0002.837] I> CPU-BL Params @ 0xca020000
[0002.837] I> 0) Base:0x00000000 Size:0x00000000
[0002.838] I> 1) Base:0xc8300000 Size:0x00100000
[0002.838] I> 2) Base:0xc9800000 Size:0x00200000
[0002.838] I> 3) Base:0xc8600000 Size:0x00200000
[0002.841] I> 4) Base:0xc8200000 Size:0x00100000
[0002.845] I> 5) Base:0xc8100000 Size:0x00100000
[0002.850] I> 6) Base:0xc9400000 Size:0x00400000
[0002.854] I> 7) Base:0xc9000000 Size:0x00400000
[0002.859] I> 8) Base:0xc8000000 Size:0x00100000
[0002.863] I> 9) Base:0xc7f00000 Size:0x00100000
[0002.868] I> 10) Base:0xca800000 Size:0x00800000
[0002.872] I> 11) Base:0x40000000 Size:0x00040000
[0002.877] I> 12) Base:0xc7e00000 Size:0x00100000
[0002.881] I> 13) Base:0x40046000 Size:0x00002000
[0002.886] I> 14) Base:0x40048000 Size:0x00002000
[0002.890] I> 15) Base:0xaf000000 Size:0x00004000
[0002.895] I> 16) Base:0x4004a000 Size:0x00002000
[0002.899] I> 17) Base:0xc7c00000 Size:0x00100000
[0002.903] I> 18) Base:0x4004c000 Size:0x00002000
[0002.908] I> 19) Base:0xc9a00000 Size:0x00600000
[0002.912] I> 20) Base:0x4004e000 Size:0x00002000
[0002.917] I> 21) Base:0xc7dc0000 Size:0x0000c000
[0002.921] I> 22) Base:0x00000000 Size:0x00000000
[0002.926] I> 23) Base:0xc7de0000 Size:0x00020000
[0002.930] I> 24) Base:0xcc000000 Size:0x02000000
[0002.935] I> 25) Base:0x40050000 Size:0x00002000
[0002.939] I> 26) Base:0x40040000 Size:0x00006000
[0002.944] I> 27) Base:0xc8c00000 Size:0x00400000
[0002.948] I> 28) Base:0xc8400000 Size:0x00200000
[0002.953] I> 29) Base:0xc8800000 Size:0x00400000
[0002.957] I> 30) Base:0xc7dd0000 Size:0x00010000
[0002.961] I> 31) Base:0x00000000 Size:0x00000000
[0002.966] I> 32) Base:0xf8000000 Size:0x08000000
[0002.970] I> 33) Base:0xce000000 Size:0x2a000000
[0002.975] I> 34) Base:0xcb000000 Size:0x01000000
[0002.979] I> 35) Base:0xae000000 Size:0x01000000
[0002.984] I> 36) Base:0xa0000000 Size:0x0e000000
[0002.988] I> 37) Base:0xca000000 Size:0x00800000
[0002.993] I> 38) Base:0x80000000 Size:0x20000000
[0002.997] I> 39) Base:0xb0000000 Size:0x08000000
[0003.002] I> 40) Base:0x00000000 Size:0x00000000
[0003.006] I> 41) Base:0x00000000 Size:0x00000000
[0003.011] I> 42) Base:0x00000000 Size:0x00000000
[0003.015] I> 43) Base:0x00000000 Size:0x00000000
[0003.019] I> 44) Base:0x00000000 Size:0x00000000
[0003.024] I> 45) Base:0x00000000 Size:0x00000000
[0003.028] GIC-SPI Target CPU: 0
[0003.031] Interrupts Init done
[0003.034] calling constructors
[0003.037] initializing heap
[0003.040] I> Heap: [0xa0960000 ... 0xadf00000]
[0003.044] initializing threads
[0003.047] initializing timers
[0003.050] creating bootstrap completion thread
[0003.054] top of bootstrap2()
[0003.057] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0003.061] initializing platform
[0003.064] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0003.070] W> device prod register failed
[0003.074] I> Bl_dtb @0xadf00000
[0003.077] I> gpio framework initialized
[0003.087] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0003.092] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0003.099] I> fixed regulator driver initialized
[0003.114] I> register 'maxim' power off handle
[0003.117] I> virtual i2c enabled
[0003.117] I> registered 'maxim,max20024' pmic
[0003.118] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0003.118] I> Boot-device: QSPI
[0003.121] I> Boot_device: QSPI_FLASH instance: 0
[0003.125] I> configure_qspi_clk: qparams clk_src = 5, clk_div = 0, clk_src_freq = 800000000, interface_freq = 50000000
[0003.136] I> configure_qspi_clk: FORCING INTERFACE_FREQ TO 133000000!!
[0003.143] I> QSPI source rate = 204000 Khz
[0003.146] I> Requested rate for QSPI clock = 34000 Khz
[0003.151] I> BPMP-set rate for QSPI clk = 34000 Khz
[0003.156] I> tx_clk_tap_delay : 0
[0003.159] I> rx_clk_tap_delay : 16
[0003.162] I> QSPI Flash Size = 32 MB
[0003.170] I> Qspi initialized successfully
[0003.171] I> qspi flash-0 params source = boot args
[0003.175] W> No board IDs available
[0003.178] E> Failed to get board id info!
[0003.186] I> Found 41 partitions in QSPI_FLASH (instance 0)
[0003.204] I> regulator 'vdd-hdmi-5v0' already enabled
[0003.211] I> regulator 'vdd-hdmi-5v0' already enabled
[0003.212] I> hdmi cable connected
[0003.218] W> set volts not configured for 'vdd-1v0'
[0003.225] W> set volts not configured for 'vdd-1v8-hs'
[0003.225] I> retrieved tmds range from prod_list_hdmi_soc
[0003.227] E> cannot find any other nvdisp nodes
[0003.243] I> edid read success
[0003.256] I> edid read success
[0003.256] I> width = 640, height = 480, frequency = 25174825
[0003.257] I> width = 640, height = 480, frequency = 25174825
[0003.258] I> width = 1024, height = 768, frequency = 65000000
[0003.261] I> width = 1024, height = 768, frequency = 65000000
[0003.267] I> width = 1024, height = 768, frequency = 65000000
[0003.272] I> width = 2560, height = 1440, frequency = 580080000
[0003.278] I> width = 1920, height = 1080, frequency = 148500000
[0003.284] I> width = 1920, height = 1080, frequency = 148351648
[0003.290] I> width = 1920, height = 1080, frequency = 148351648
[0003.295] I> width = 1280, height = 720, frequency = 74175824
[0003.301] I> width = 1280, height = 720, frequency = 74175824
[0003.307] I> width = 720, height = 480, frequency = 26973026
[0003.312] I> width = 720, height = 576, frequency = 26973026
[0003.318] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0003.329] I> hdmi_enable, starting HDMI initialisation
[0003.334] I> hdmi_enable, HDMI initialisation complete
[0003.343] initializing target
[0003.344] calling apps_init()
[0003.345] starting app kernel_boot_app
[0003.346] I> Kernel type = Normal
Jetson UEFI firmware (version 2.1-32413640 built on 2023-01-24T23:12:27+00:00)
ASSERT [DxeCore] /out/nvidia/bootloader/uefi/Jetson_RELEASE/edk2/MdeModulePkg/Core/Dxe/DxeMain/DxeMain.c(562): !(((INTN)(RETURN_STATUS)(Statu)
Resetting the system in 5 seconds.
����Shutdown state requested 1
Rebooting system ...
[0000.062] I> rst_source: 0xb, rst_level: 0x1
[0000.085] I> Current Boot-Chain Slot: 1
[0000.089] I> BR-BCT Boot-Chain: 0, status: 1. update flag: 1
[0000.106] I> Temperature = 24500
[0000.109] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.114] W> Skipping boost for clk: BPMP_APB
[0000.118] W> Skipping boost for clk: AXI_CBB
[0000.122] W> Skipping boost for clk: AON_CPU_NIC
[0000.126] W> Skipping boost for clk: CAN1
[0000.130] W> Skipping boost for clk: CAN2
[0000.134] I> Boot-device: QSPI (instance: 0)
[0000.138] I> Qspi flash params source = mb1bct
[0000.142] I> Qspi clock source : pllc_out0
[0000.146] I> Qspi-0 reinitialized
[0000.149] I> Qspi flash params source = mb1bct
[0000.162] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.169] W> Thermal config not found in BCT
[0000.177] W> MEMIO rail config not found in BCT
[0000.187] I> Qspi flash params source = mb1bct
[0000.200] I> Qspi flash params source = mb1bct
[0000.234] I> Qspi flash params source = mb1bct
[0000.798] I> Qspi flash params source = mb1bct
[0000.815] I> Qspi flash params source = mb1bct
[0000.854] W> Platform config not found in BCT
[0000.881] I> Qspi flash params source = mb1bct
[0000.906] I> MB1 done
����main enter
HW Function test
Start Scheduler.
in late init
[0000.916] I> Welcome to MB2(TBoot-BPMP) (version: default.t194-mobile-78ae5a2a)
[0000.916] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.917] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.918] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.923] W> device prod register failed
[0000.927] I> gpio framework initialized
[0000.931] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0000.938] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0000.946] I> sdcard_params [0, 55, 0, 50] in mb1_bct
[0000.951] I> Boot_device: QSPI_FLASH instance: 0
[0000.955] I> qspi flash-0 params source = boot args
[0000.961] I> QSPI-0l initialized successfully
[0000.971] I> Found 41 partitions in QSPI_FLASH (instance 0)
[0000.972] I> Active Boot chain : 1
[0000.973] E> Cannot find partition bpmp-fw_b
[0000.977] E> Partition bpmp-fw_b not found
[0000.981] I> ���⟟����域����域����域�: execution failed
[0000.987] I> ���域����域����域����域�: execution failed
[0000.992] E> Top caller module: LOADER, error module: PARTITION_MANAGER, reason: 0x0d, aux_info: 0x09
[0001.002] I> AB warm reset
[0000.038] I> Boot-mode: Coldboot
[0000.041] I> Platform: Silicon
[0000.052] I> ATE fuse revision : 0x200
[0000.061] I> rst_source: 0xb, rst_level: 0x1
[0000.066] I> Boot-device: QSPI (instance: 0)
[0000.070] I> Qspi flash params source = brbct
[0000.074] I> Qspi clock source : pllp
[0000.089] E> Error, current slot 0 fails: sr_bl: 0x4d14ef1, sr_br: 0x0
[0000.095] I> Reset to recovery mode
Above is Xavier NX eMMC prod SoM flashed via
sudo BOARDID=3668 BOARDSKU=0001 FAB=100 ./tools/kernel_flash/l4t_initrd_flash.sh --no-flash --massflash 3 --network usb0 p3509-0000+p3668-0000-qspi nvme0n1p1
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only --massflash 3 --network usb0 --keep
Since it did not seem like the p3509-0000+p3668-0000-qspi did anything different in terms of providing fewer things to flash, and of course because it is failing to boot probably because this one is for flashing QSPI onto a development SD card sporting SoM, I’m going back to p3509-0000+p3668-0001-qspi-emmc and doing more tests to confirm that step 2 is all I need for NVMe bootability and will hack/adapt the scripts
