In attempting workflow 10, example 2 (since it really is all I want)…
I am trying to run
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --no-flash jetson-xavier-nx-devkit-qspi internal
And it produces the output:
❯ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --no-flash jetson-xavier-nx-devkit-qspi internal
/home/slu/iai_data/2022-12-15/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh --no-flash --no-flash jetson-xavier-nx-devkit-qspi internal
Please install the Secureboot package to use initrd flash for fused board
* Step 1: Generate flash packages *
Create folder to store images to flash
Generate image for internal storage devices
Generate images to be flashed
/home/slu/iai_data/2022-12-15/Linux_for_Tegra/flash.sh --no-flash --sign jetson-xavier-nx-devkit-qspi internal
# L4T BSP Information:
# R35 , REVISION: 1.0
copying soft_fuses(/home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)... done.
./tegraflash.py --chip 0x19 --applet "/home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/mb1_t194_prod.bin" --skipuid --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins "mb2_applet nvtboot_applet_t194.bin" --cmd "dump eeprom boardinfo cvm.bin;reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0139 ] Generating RCM messages
[ 0.0160 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/mb1_t194_prod.bin zerosbk
[ 0.0170 ] Header already present for /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/mb1_t194_prod.bin
[ 0.0266 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0268 ] Assuming zero filled SBK key
[ 0.0287 ] tegrasign_v3.py --file /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[ 0.0289 ] Assuming zero filled SBK key
[ 0.0304 ] Warning: pub_key.key is not found
[ 0.0288 ] tegrahost_v2 --chip 0x19 0 --updatesigheader /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.hash zerosbk
[ 0.0344 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg.pdf sfuse.bin
[ 0.0365 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin 0 0
[ 0.0369 ] RCM 0 is saved as rcm_0.rcm
[ 0.0398 ] RCM 1 is saved as rcm_1.rcm
[ 0.0399 ] RCM 2 is saved as rcm_2.rcm
[ 0.0401 ] List of rcm files are saved in rcm_list.xml
[ 0.0401 ]
[ 0.0401 ] Signing RCM messages
[ 0.0454 ] tegrasign_v3.py --key None --list rcm_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[ 0.0454 ] Assuming zero filled SBK key
[ 0.0491 ] Warning: pub_key.key is not found
[ 0.0455 ] Copying signature to RCM mesages
[ 0.0471 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[ 0.0481 ] Boot Rom communication
[ 0.0497 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
[ 0.0502 ] RCM version 0X190001
[ 0.2550 ] Boot Rom communication completed
[ 2.2736 ] tegrarcm_v2 --isapplet
[ 2.2748 ] Applet version 01.00.0000
[ 2.6906 ] tegrarcm_v2 --ismb2
[ 3.1224 ] tegrahost_v2 --chip 0x19 --align nvtboot_applet_t194_aligned.bin
[ 3.1261 ] tegrahost_v2 --chip 0x19 0 --magicid PLDT --appendsigheader nvtboot_applet_t194_aligned.bin zerosbk
[ 3.1273 ] adding BCH for nvtboot_applet_t194_aligned.bin
[ 3.1378 ] tegrasign_v3.py --key None --list nvtboot_applet_t194_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 3.1380 ] Assuming zero filled SBK key
[ 3.1396 ] Warning: pub_key.key is not found
[ 3.1381 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194_aligned_sigheader.bin.encrypt nvtboot_applet_t194_aligned_sigheader.bin.hash zerosbk
[ 3.1421 ] tegrarcm_v2 --download mb2 nvtboot_applet_t194_sigheader.bin.encrypt
[ 3.1428 ] Applet version 01.00.0000
[ 3.5558 ] Sending mb2
[ 3.5559 ] [................................................] 100%
[ 3.5729 ] tegrarcm_v2 --boot recovery
[ 3.5737 ] Applet version 01.00.0000
[ 4.9871 ] tegrarcm_v2 --isapplet
[ 5.1143 ] tegrarcm_v2 --ismb2
[ 5.1152 ] MB2 Applet version 01.00.0000
[ 5.5670 ] tegrarcm_v2 --ismb2
[ 5.5683 ] MB2 Applet version 01.00.0000
[ 5.9543 ] Retrieving board information
[ 5.9564 ] tegrarcm_v2 --oem platformdetails chip chip_info.bin
[ 5.9573 ] MB2 Applet version 01.00.0000
[ 6.3898 ] Saved platform info in chip_info.bin
[ 6.3938 ] Chip minor revision: 2
[ 6.3938 ] Bootrom revision: 0xf
[ 6.3939 ] Ram code: 0x0
[ 6.3939 ] Chip sku: 0xde
[ 6.3940 ] Chip Sample: non es
[ 6.3946 ] Retrieving EEPROM data
[ 6.3947 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/cvm.bin
[ 6.3958 ] MB2 Applet version 01.00.0000
[ 6.8219 ] Saved platform info in /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/cvm.bin
[ 6.8607 ] Rebooting to recovery mode
[ 6.8628 ] tegrarcm_v2 --ismb2
[ 6.8636 ] MB2 Applet version 01.00.0000
[ 7.2805 ] Rebooting to recovery mode
[ 7.2829 ] tegrarcm_v2 --reboot recovery
[ 7.2840 ] MB2 Applet version 01.00.0000
Board ID(3668) version(301) sku(0001) revision(D.0)
lz4c installed at /usr/bin/lz4c
Compressing /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/t186ref/tegra194-a02-bpmp-p3668-a00.dtb ...
Copy /home/slu/iai_data/2022-12-15/Linux_for_Tegra/kernel/dtb/tegra194-p3668-0000-p3509-0000.dtb to /home/slu/iai_data/2022-12-15/Linux_for_Tegra/kernel/dtb/tegra194-p3668-0000-p3509-0000.dtb.rec
NVDISP+UEFI in bootloader/nvdisp-init.bin ..
Generated UUID abab7bb7-85b2-463d-976e-180c7b16aa8a for mounting root APP partition.
copying bctfile(/home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg)... done.
copying bctfile1(/home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-memcfg-sw-override.cfg)... done.
copying minratchet_config(/home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-ratchet-p3668.cfg)... done.
copying device_config(/home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-bct-device-qspi-p3668.cfg)... done.
copying misc_cold_boot_config(/home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-sd-l4t.cfg)... done.
copying misc_config(/home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-flash.cfg)... done.
copying pinmux_config(/home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p3668-a01.cfg)... done.
copying gpioint_config(/home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg)... done.
copying pmic_config(/home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-pmic-p3668-0001-a00.cfg)... done.
copying pmc_config(/home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-padvoltage-p3668-a01.cfg)... done.
copying prod_config(/home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-prod-p3668-0001-a00.cfg)... done.
copying scr_config(/home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini-p3668.cfg)... done.
copying scr_cold_boot_config(/home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini-p3668.cfg)... done.
copying bootrom_config(/home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-reset-p3668-0001-a00.cfg)... done.
copying dev_params(/home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-br-bct-qspi-l4t.cfg)... done.
copying dev_params_b(/home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-br-bct_b-qspi-l4t.cfg)... done.
Existing bootloader(/home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
copying initrd(/home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
Making Boot image... done.
/home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --minratchet_config tegra194-mb1-bct-ratchet-p3668.cfg --cmd sign boot.img kernel
version 1.0.0
[ 0.0008 ] Generating signature
[ 0.0031 ] tegrasign_v3.py --key --getmode mode.txt
[ 0.0033 ] Assuming zero filled SBK key : not reading
[ 0.0029 ] Generating ratchet blob
[ 0.0047 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[ 0.0055 ] FwIndex: 1, MinRatchetLevel: 0
[ 0.0060 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.0060 ] FwIndex: 3, MinRatchetLevel: 0
[ 0.0060 ] FwIndex: 4, MinRatchetLevel: 0
[ 0.0060 ] FwIndex: 5, MinRatchetLevel: 0
[ 0.0060 ] FwIndex: 6, MinRatchetLevel: 0
[ 0.0060 ] FwIndex: 7, MinRatchetLevel: 0
[ 0.0060 ] FwIndex: 11, MinRatchetLevel: 0
[ 0.0060 ] FwIndex: 12, MinRatchetLevel: 0
[ 0.0060 ] FwIndex: 13, MinRatchetLevel: 0
[ 0.0060 ] FwIndex: 14, MinRatchetLevel: 0
[ 0.0060 ] FwIndex: 15, MinRatchetLevel: 0
[ 0.0060 ] FwIndex: 16, MinRatchetLevel: 0
[ 0.0060 ] FwIndex: 17, MinRatchetLevel: 0
[ 0.0060 ] FwIndex: 18, MinRatchetLevel: 0
[ 0.0060 ] FwIndex: 19, MinRatchetLevel: 0
[ 0.0060 ] FwIndex: 30, MinRatchetLevel: 0
[ 0.0060 ] FwIndex: 31, MinRatchetLevel: 0
[ 0.0060 ]
[ 0.0061 ] header_magic: 414e4452
[ 0.0275 ] tegrahost_v2 --chip 0x19 --align 1_boot_aligned.img
[ 0.0300 ] tegrahost_v2 --chip 0x19 0 --magicid KRNL --ratchet_blob ratchet_blob.bin --appendsigheader 1_boot_aligned.img zerosbk
[ 0.0307 ] adding BCH for 1_boot_aligned.img
[ 0.6398 ] tegrasign_v3.py --key --list 1_boot_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 0.6400 ] Assuming zero filled SBK key : not reading
[ 0.6993 ] Warning: pub_key.key is not found
[ 0.7010 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_boot_aligned_sigheader.img.encrypt 1_boot_aligned_sigheader.img.hash zerosbk
[ 1.0837 ] Signed file: /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img.encrypt
l4t_sign_image.sh: Generate header for boot_sigheader.img.encrypt
l4t_sign_image.sh: chip 0x19: add 0x281c000 to offset 0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for boot_sigheader.img.encrypt
l4t_sign_image.sh: the signed file is /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img.encrypt
Making recovery ramdisk for recovery image...
Re-generating recovery ramdisk for recovery image...
/home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader /home/slu/iai_data/2022-12-15/Linux_for_Tegra
36144 blocks
gzip: /home/slu/iai_data/2022-12-15/Linux_for_Tegra/kernel/Image: not in gzip format
_BASE_KERNEL_VERSION=5.10.104-tegra
find: ‘/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib’: No such file or directory
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/bin/mv': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/bin/mv /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//bin/mv
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/bin/sync': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/bin/sync /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//bin/sync
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/sbin/blockdev': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/sbin/blockdev /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//bin/blockdev
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/bin/cut': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/bin/cut /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//bin/cut
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/bin/cksum': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/bin/cksum /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//bin/cksum
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/bin/sha1sum': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/bin/sha1sum /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//bin/sha1sum
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/bin/seq': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/bin/seq /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//bin/seq
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/bin/dirname': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/bin/dirname /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//bin/dirname
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/bin/tr': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/bin/tr /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//bin/tr
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/bin/du': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/bin/du /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//bin/du
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/sbin/mtd_debug': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/sbin/mtd_debug /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//bin/mtd_debug
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//ld-2.31.so': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//ld-2.31.so /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib//ld-2.31.so
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libc-2.31.so': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libc-2.31.so /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib//libc-2.31.so
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libdl-2.31.so': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libdl-2.31.so /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib//libdl-2.31.so
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libm-2.31.so': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libm-2.31.so /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib//libm-2.31.so
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libnsl-2.31.so': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libnsl-2.31.so /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib//libnsl-2.31.so
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libnss_files-2.31.so': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libnss_files-2.31.so /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib//libnss_files-2.31.so
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libnss_nis-2.31.so': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libnss_nis-2.31.so /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib//libnss_nis-2.31.so
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libpthread-2.31.so': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libpthread-2.31.so /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib//libpthread-2.31.so
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libresolv-2.31.so': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libresolv-2.31.so /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib//libresolv-2.31.so
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//librt-2.31.so': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//librt-2.31.so /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib//librt-2.31.so
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libwrap.so.0': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libwrap.so.0 /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib//libwrap.so.0
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libaudit.so.1': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libaudit.so.1 /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib//libaudit.so.1
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libpam.so.0': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libpam.so.0 /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib//libpam.so.0
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libpam_misc.so.0': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libpam_misc.so.0 /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib//libpam_misc.so.0
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libsystemd.so.0': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libsystemd.so.0 /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib//libsystemd.so.0
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//liblzma.so.5': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//liblzma.so.5 /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib//liblzma.so.5
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libgcrypt.so.20': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libgcrypt.so.20 /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib//libgcrypt.so.20
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libgpg-error.so.0': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libgpg-error.so.0 /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib//libgpg-error.so.0
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libutil.so.1': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libutil.so.1 /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib//libutil.so.1
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libcrypt.so.1': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libcrypt.so.1 /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib//libcrypt.so.1
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libz.so.1': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libz.so.1 /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib//libz.so.1
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libcap.so.2': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libcap.so.2 /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib//libcap.so.2
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libcap-ng.so.0': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libcap-ng.so.0 /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib//libcap-ng.so.0
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libprocps.so.8': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libprocps.so.8 /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib//libprocps.so.8
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libnss_compat.so.2': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libnss_compat.so.2 /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib//libnss_compat.so.2
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libmnl.so.0': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libmnl.so.0 /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib//libmnl.so.0
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libdbus-1.so.3': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libdbus-1.so.3 /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/libdbus-1.so.3
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libreadline.so.8': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libreadline.so.8 /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/libreadline.so.8
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libtinfo.so.6': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libtinfo.so.6 /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/libtinfo.so.6
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libdevmapper.so.1.02.1': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libdevmapper.so.1.02.1 /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/libdevmapper.so.1.02.1
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libblkid.so.1': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libblkid.so.1 /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/libblkid.so.1
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libuuid.so.1': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libuuid.so.1 /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/libuuid.so.1
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libudev.so.1': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libudev.so.1 /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/libudev.so.1
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libselinux.so.1': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libselinux.so.1 /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/libselinux.so.1
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libpcre.so.3': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib//libpcre.so.3 /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/libpcre.so.3
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/lib//libssl.so.1.1': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/lib//libssl.so.1.1 /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/libssl.so.1.1
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/lib//libgssapi_krb5.so.2': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/lib//libgssapi_krb5.so.2 /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib//libgssapi_krb5.so.2
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/lib//libkrb5.so.3': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/lib//libkrb5.so.3 /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib//libkrb5.so.3
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/lib//libk5crypto.so.3': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/lib//libk5crypto.so.3 /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib//libk5crypto.so.3
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/lib//libkrb5support.so.0': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/lib//libkrb5support.so.0 /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib//libkrb5support.so.0
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/lib//libcrypto.so.1.1': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/lib//libcrypto.so.1.1 /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib//libcrypto.so.1.1
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/lib//liblz4.so.1': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/lib//liblz4.so.1 /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib//liblz4.so.1
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/lib//libelf.so.1': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/lib//libelf.so.1 /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib//libelf.so.1
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib/modules/5.10.104-tegra/kernel/drivers/mtd/mtd.ko': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib/modules/5.10.104-tegra/kernel/drivers/mtd/mtd.ko /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/modules/5.10.104-tegra/kernel/drivers/mtd/mtd.ko
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib/modules/5.10.104-tegra/kernel/drivers/mtd/mtdblock.ko': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib/modules/5.10.104-tegra/kernel/drivers/mtd/mtdblock.ko /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/modules/5.10.104-tegra/kernel/drivers/mtd/mtdblock.ko
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib/modules/5.10.104-tegra/kernel/drivers/mtd/mtd_blkdevs.ko': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib/modules/5.10.104-tegra/kernel/drivers/mtd/mtd_blkdevs.ko /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/modules/5.10.104-tegra/kernel/drivers/mtd/mtd_blkdevs.ko
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib/modules/5.10.104-tegra/kernel/drivers/mtd/devices/qspi_mtd.ko': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib/modules/5.10.104-tegra/kernel/drivers/mtd/devices/qspi_mtd.ko /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/modules/5.10.104-tegra/kernel/drivers/mtd/devices/qspi_mtd.ko
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib/modules/5.10.104-tegra/kernel/drivers/spi/spi-tegra210-qspi.ko': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/lib/modules/5.10.104-tegra/kernel/drivers/spi/spi-tegra210-qspi.ko /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/modules/5.10.104-tegra/kernel/drivers/spi/spi-tegra210-qspi.ko
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/etc/ssh/sshd_config': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/etc/ssh/sshd_config /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//etc/ssh/sshd_config
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/sbin/sshd': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/sbin/sshd /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//bin/sshd
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/bin/su': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/bin/su /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//bin/su
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/bin/whoami': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/bin/whoami /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//bin/whoami
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/bin/passwd': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/bin/passwd /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//bin/passwd
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/bin/which': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/bin/which /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//bin/which
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/bin/ps': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/bin/ps /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//bin/ps
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/bin/ping': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/bin/ping /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//bin/ping
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/sbin/dhclient-script': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/sbin/dhclient-script /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//sbin/dhclient-script
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/bin/ip': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/bin/ip /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//bin/ip
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/bin/run-parts': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/bin/run-parts /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//bin/run-parts
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/bin/w.procps': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/bin/w.procps /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//bin/w
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/bin/scp': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/bin/scp /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//bin/scp
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/bin/find': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/bin/find /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//bin/find
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/bin/xxd': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/bin/xxd /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//bin/xxd
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/bin/head': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/bin/head /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//bin/head
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/bin/kmod': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/bin/kmod /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//bin/kmod
cp: cannot stat '/home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/bin/diff': No such file or directory
warning: cp -f /home/slu/iai_data/2022-12-15/Linux_for_Tegra/rootfs/usr/bin/diff /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//bin/diff
sed: can't read /home/slu/iai_data/2022-12-15/Linux_for_Tegra/bootloader/ramdisk_tmp//etc/ssh/sshd_config: No such file or directory
command is failed
Error: failed to generate images
Cleaning up...
Why is it trying to ungzip Image?
❯ l kernel/Image*
-rw-rw-r-- 1 slu slu 13M Aug 10 23:37 kernel/Image.gz
-rw-rw-r-- 1 slu slu 33M Aug 10 23:37 kernel/Image
I have manually moved Image.gz into Image, and now it’s
<snip>
36144 blocks
<snip>
Why is it trying to do some stuff with rootfs when I’m just trying to flash QSPI?
Edit: OK I think I’m supposed to download and unpack the rootfs separately, so it’s there for the script to go fetch these things that are on there. Stay tuned…
