Issue with initrd_flash on Xavier
Hello
I try to use the initrd_flash.sh to flash the nvme. However,when I run "sudo ROOTFS_ENC=1 ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c ./tools/kernel_flash/flash_l4t_nvme_rootfs_enc.xml -S 35GiB --erase-all --showlogs jetson-xavier external
the command to encrypt nvme and boot from it ,something bring the error
Please attach the full log.
And looks like you didn’t add “–external-only” in the command.
hello
I dont use the “–external-only” for flashing the emmc and the nvme together onetime and booting from nvme . As I can learn from the “README_initrd_flash.txt” is that if the AB can flash like this I also can get
disk encryption support and boot from external device.
and here the flash_log
root@guwen-Latitude-5491:/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra# sudo ROOTFS_ENC=1  ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1 -c ./tools/kernel_flash/flash_l4t_nvme_rootfs_enc.xml  -S 35GiB  --erase-all  --showlogs  jetson-xavier-nx-devkit-emmc external
/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh --no-flash --external-device nvme0n1 -c ./tools/kernel_flash/flash_l4t_nvme_rootfs_enc.xml -S 35GiB --erase-all --showlogs jetson-xavier-nx-devkit-emmc external
*  Step 1: Generate flash packages *
Create folder to store images to flash
Generate images to be flashed
BOOTDEV=external /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/flash.sh --no-flash --sign --external-device -c "./tools/kernel_flash/flash_l4t_nvme_rootfs_enc.xml" -S "35GiB"  jetson-xavier-nx-devkit-emmc external
# L4T BSP Information:
# R32 , REVISION: 7.1
Change device boot from external to internal
Board ID() version() sku() revision()
Copy /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb to /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb.rec
Using UUID 7c4de24d-2c52-4e44-abf5-39340a4fc6d6 for mounting root APP_ext partition.
Using UUID e5400d27-b21a-4fea-b637-04e100d11f2f for mounting root APP_ext_enc partition.
Using UUID 3c42f269-e226-4b51-abe3-2450286a48b7 for mounting boot APP_ext partition.
copying bctfile(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg)... done.
copying bctfile1(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-memcfg-sw-override.cfg)... done.
copying minratchet_config(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-ratchet-p3668.cfg)... done.
copying device_config(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-bct-device-qspi-p3668.cfg)... done.
copying misc_cold_boot_config(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-l4t.cfg)... done.
copying misc_config(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-flash.cfg)... done.
copying pinmux_config(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p3668-a01.cfg)... done.
copying gpioint_config(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg)... done.
copying pmic_config(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-pmic-p3668-0001-a00.cfg)... done.
copying pmc_config(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-padvoltage-p3668-a01.cfg)... done.
copying prod_config(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-prod-p3668-0001-a00.cfg)... done.
copying scr_config(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini-p3668.cfg)... done.
copying scr_cold_boot_config(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini-p3668.cfg)... done.
copying bootrom_config(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-reset-p3668-0001-a00.cfg)... done.
copying dev_params(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-br-bct-qspi.cfg)... done.
Using UUID 0b1cb7c7-bcd4-460f-9964-d7d1d1d2b764 for mounting UDA_ext partition.
Making system_uda_encrypted.img_ext...
ERROR: build_enc_fsimg: ECID is null .
Error: Failed to generate images for external device
Cleaning up...
copying soft_fuses(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)... done.
./tegraflash.py --chip 0x19 --applet "/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/mb1_t194_prod.bin" --skipuid --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins "mb2_applet nvtboot_applet_t194.bin" --cmd "dump eeprom boardinfo cvm.bin;reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[   0.0041 ] Generating RCM messages
[   0.0052 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/mb1_t194_prod.bin zerosbk
[   0.0058 ] Header already present for /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/mb1_t194_prod.bin
[   0.0084 ]
[   0.0105 ] tegrasign_v3.py --getmode mode.txt --key None
[   0.0106 ] Assuming zero filled SBK key
[   0.0126 ] tegrasign_v3.py --file /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[   0.0126 ] Assuming zero filled SBK key
[   0.0169 ] tegrahost_v2 --chip 0x19 0 --updatesigheader /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.hash zerosbk
[   0.0201 ]
[   0.0226 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg.pdf sfuse.bin
[   0.0233 ]
[   0.0252 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin 0 0
[   0.0258 ] RCM 0 is saved as rcm_0.rcm
[   0.0281 ] RCM 1 is saved as rcm_1.rcm
[   0.0281 ] RCM 2 is saved as rcm_2.rcm
[   0.0281 ] List of rcm files are saved in rcm_list.xml
[   0.0281 ]
[   0.0281 ] Signing RCM messages
[   0.0301 ] tegrasign_v3.py --getmontgomeryvalues montgomery.bin --key None --list rcm_list.xml --pubkeyhash pub_key.key
[   0.0302 ] Assuming zero filled SBK key
[   0.0369 ] Copying signature to RCM mesages
[   0.0390 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[   0.0405 ]
[   0.0405 ] Boot Rom communication
[   0.0423 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
[   0.0429 ] RCM version 0X190001
[   0.0694 ] Boot Rom communication completed
[   1.0878 ]
[   2.0934 ] tegrarcm_v2 --isapplet
[   2.0958 ] Applet version 01.00.0000
[   2.1240 ]
[   2.1283 ] tegrarcm_v2 --ismb2
[   2.2210 ]
[   2.2231 ] tegrahost_v2 --chip 0x19 --align nvtboot_applet_t194.bin
[   2.2238 ]
[   2.2256 ] tegrahost_v2 --chip 0x19 0 --magicid PLDT --appendsigheader nvtboot_applet_t194.bin zerosbk
[   2.2262 ] adding BCH for nvtboot_applet_t194.bin
[   2.2307 ]
[   2.2334 ] tegrasign_v3.py --key None --list nvtboot_applet_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   2.2335 ] Assuming zero filled SBK key
[   2.2383 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194_sigheader.bin.encrypt nvtboot_applet_t194_sigheader.bin.hash zerosbk
[   2.2408 ]
[   2.2429 ] tegrarcm_v2 --download mb2 nvtboot_applet_t194_sigheader.bin.encrypt
[   2.2437 ] Applet version 01.00.0000
[   2.3202 ] Sending mb2
[   2.3202 ] [................................................] 100%
[   2.3363 ]
[   2.3384 ] tegrarcm_v2 --boot recovery
[   2.3391 ] Applet version 01.00.0000
[   2.4148 ]
[   3.4206 ] tegrarcm_v2 --isapplet
[   3.4529 ]
[   3.4573 ] tegrarcm_v2 --ismb2
[   3.4599 ] MB2 Applet version 01.00.0000
[   3.5519 ]
[   3.5562 ] tegrarcm_v2 --ismb2
[   3.5587 ] MB2 Applet version 01.00.0000
[   3.6037 ]
[   3.6079 ] Retrieving board information
[   3.6123 ] tegrarcm_v2 --oem platformdetails chip chip_info.bin
[   3.6150 ] MB2 Applet version 01.00.0000
[   3.6950 ] Saved platform info in chip_info.bin
[   3.6993 ] Chip minor revision: 2
[   3.6994 ] Bootrom revision: 0xf
[   3.6995 ] Ram code: 0x0
[   3.6995 ] Chip sku: 0xde
[   3.6996 ] Chip Sample: non es
[   3.7000 ]
[   3.7001 ] Retrieving EEPROM data
[   3.7002 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/cvm.bin
[   3.7008 ] MB2 Applet version 01.00.0000
[   3.7790 ] Saved platform info in /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/cvm.bin
[   3.8134 ]
[   3.8135 ] Rebooting to recovery mode
[   3.8156 ] tegrarcm_v2 --ismb2
[   3.8164 ] MB2 Applet version 01.00.0000
[   3.8914 ]
[   3.8914 ] Rebooting to recovery mode
[   3.8937 ] tegrarcm_v2 --reboot recovery
[   3.8947 ] MB2 Applet version 01.00.0000
[   3.9937 ]
Board ID(3668) version(300) sku(0001) revision(B.0)
	Sync'ing system_uda_encrypted.img_ext ... done.
	Converting RAW image to Sparse image... done.
system_uda_encrypted.img_ext built successfully.
Existing bootloader(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
copying initrd(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
prepare_luks_initrd: Begin to copy binaries into initrd
30412 块
49616 块
prepare_luks_initrd: Finish copying binaries into initrd
done.
Making Boot image... done.
/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key  --minratchet_config tegra194-mb1-bct-ratchet-p3668.cfg --cmd sign boot.img kernel
version 1.0.0
[   0.0004 ] Generating signature
[   0.0027 ] tegrasign_v3.py --getmode mode.txt --key
[   0.0027 ] Assuming zero filled SBK key : not reading
[   0.0027 ] Generating ratchet blob
[   0.0046 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[   0.0052 ] FwIndex: 1, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 2, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 3, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 4, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 5, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 6, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 7, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 11, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 12, MinRatchetLevel: 0
[   0.0054 ] FwIndex: 13, MinRatchetLevel: 0
[   0.0054 ] FwIndex: 14, MinRatchetLevel: 0
[   0.0054 ] FwIndex: 15, MinRatchetLevel: 0
[   0.0054 ] FwIndex: 16, MinRatchetLevel: 0
[   0.0054 ] FwIndex: 17, MinRatchetLevel: 0
[   0.0054 ] FwIndex: 18, MinRatchetLevel: 0
[   0.0054 ] FwIndex: 19, MinRatchetLevel: 0
[   0.0054 ] FwIndex: 30, MinRatchetLevel: 0
[   0.0054 ] FwIndex: 31, MinRatchetLevel: 0
[   0.0054 ] FwIndex: 32, MinRatchetLevel: 0
[   0.0054 ]
[   0.0054 ] header_magic: 414e4452
[   0.0073 ] tegrahost_v2 --chip 0x19 --align 1_boot.img
[   0.0079 ]
[   0.0098 ] tegrahost_v2 --chip 0x19 0 --magicid KRNL --ratchet_blob ratchet_blob.bin --appendsigheader 1_boot.img zerosbk
[   0.0103 ] adding BCH for 1_boot.img
[   0.8213 ]
[   0.8240 ] tegrasign_v3.py --key  --list 1_boot_sigheader.img_list.xml --pubkeyhash pub_key.key
[   0.8241 ] Assuming zero filled SBK key : not reading
[   0.9044 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_boot_sigheader.img.encrypt 1_boot_sigheader.img.hash zerosbk
[   1.4213 ]
[   1.4516 ] Signed file: /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img.encrypt
l4t_sign_image.sh: Generate header for boot_sigheader.img.encrypt
l4t_sign_image.sh: chip 0x19: add 0x2d07800 to offset  0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for boot_sigheader.img.encrypt
l4t_sign_image.sh: the signed file is /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img.encrypt
done.
Making recovery ramdisk for recovery image...
Re-generating recovery ramdisk for recovery image...
/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/ramdisk_tmp /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra
30412 块
_BASE_KERNEL_VERSION=4.9.253-tegra
/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/ramdisk_tmp/lib /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/ramdisk_tmp /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra
115330 块
Making Recovery image...
copying recdtbfile(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb.rec)... done.
记录了20+0 的读入
记录了20+0 的写出
20 bytes copied, 0.000407947 s, 49.0 kB/s
Existing sosfile(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing tegraboot(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/nvtboot_t194.bin) reused.
Existing cpu_bootloader(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
Existing mb2blfile(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/nvtboot_recovery_t194.bin) reused.
Existing mtspreboot(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/preboot_c10_prod_cr.bin) reused.
Existing mcepreboot(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/mce_c10_prod_cr.bin) reused.
Existing mtsproper(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/mts_c10_prod_cr.bin) reused.
Existing mb1file(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing bpffile(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/bpmp_t194.bin) reused.
copying bpfdtbfile(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/t186ref/tegra194-a02-bpmp-p3668-a00.dtb)... done.
Existing scefile(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/camera-rtcpu-rce.img) reused.
Existing spefile(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/spe_t194.bin) reused.
Existing wb0boot(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/warmboot_t194_prod.bin) reused.
Existing tosfile(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/tos-trusty_t194.img) reused.
Existing eksfile(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb)... done.
Copying nv_boot_control.conf to rootfs
/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key  --minratchet_config tegra194-mb1-bct-ratchet-p3668.cfg --cmd sign kernel_tegra194-p3668-all-p3509-0000.dtb kernel_dtb
version 1.0.0
[   0.0005 ] Generating signature
[   0.0045 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[   0.0051 ] FwIndex: 1, MinRatchetLevel: 0
[   0.0052 ] FwIndex: 2, MinRatchetLevel: 0
[   0.0052 ] FwIndex: 3, MinRatchetLevel: 0
[   0.0052 ] FwIndex: 4, MinRatchetLevel: 0
[   0.0052 ] FwIndex: 5, MinRatchetLevel: 0
[   0.0052 ] FwIndex: 6, MinRatchetLevel: 0
[   0.0052 ] FwIndex: 7, MinRatchetLevel: 0
[   0.0052 ] FwIndex: 11, MinRatchetLevel: 0
[   0.0052 ] FwIndex: 12, MinRatchetLevel: 0
[   0.0052 ] FwIndex: 13, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 14, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 15, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 16, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 17, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 18, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 19, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 30, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 31, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 32, MinRatchetLevel: 0
[   0.0053 ]
[   0.0053 ] header_magic: d00dfeed
[   0.0073 ] tegrahost_v2 --chip 0x19 --align 1_kernel_tegra194-p3668-all-p3509-0000.dtb
[   0.0079 ]
[   0.0099 ] tegrahost_v2 --chip 0x19 0 --magicid KDTB --ratchet_blob ratchet_blob.bin --appendsigheader 1_kernel_tegra194-p3668-all-p3509-0000.dtb zerosbk
[   0.0105 ] adding BCH for 1_kernel_tegra194-p3668-all-p3509-0000.dtb
[   0.0147 ]
[   0.0172 ] tegrasign_v3.py --key  --list 1_kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[   0.0172 ] Assuming zero filled SBK key : not reading
[   0.0226 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt 1_kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.hash zerosbk
[   0.0255 ]
[   0.0259 ] Signed file: /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: Generate header for kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: chip 0x19: add 0x3a6a3 to offset  0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: the signed file is /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
done.
	populating kernel to rootfs... done.
	populating initrd to rootfs... done.
	populating kernel_tegra194-p3668-all-p3509-0000.dtb to rootfs... done.
Making system_boot.img...
	populating bootfs from /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/rootfs/boot ... done.
	populating extlinux/extlinux.conf ... done.
	generating sig file of Image ... /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key  --minratchet_config tegra194-mb1-bct-ratchet-p3668.cfg --cmd sign ./Image kernel
version 1.0.0
[   0.0017 ] Generating signature
[   0.0038 ] tegrasign_v3.py --getmode mode.txt --key
[   0.0038 ] Assuming zero filled SBK key : not reading
[   0.0038 ] Generating ratchet blob
[   0.0056 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[   0.0062 ] FwIndex: 1, MinRatchetLevel: 0
[   0.0064 ] FwIndex: 2, MinRatchetLevel: 0
[   0.0065 ] FwIndex: 3, MinRatchetLevel: 0
[   0.0065 ] FwIndex: 4, MinRatchetLevel: 0
[   0.0065 ] FwIndex: 5, MinRatchetLevel: 0
[   0.0065 ] FwIndex: 6, MinRatchetLevel: 0
[   0.0065 ] FwIndex: 7, MinRatchetLevel: 0
[   0.0065 ] FwIndex: 11, MinRatchetLevel: 0
[   0.0065 ] FwIndex: 12, MinRatchetLevel: 0
[   0.0065 ] FwIndex: 13, MinRatchetLevel: 0
[   0.0065 ] FwIndex: 14, MinRatchetLevel: 0
[   0.0065 ] FwIndex: 15, MinRatchetLevel: 0
[   0.0065 ] FwIndex: 16, MinRatchetLevel: 0
[   0.0065 ] FwIndex: 17, MinRatchetLevel: 0
[   0.0065 ] FwIndex: 18, MinRatchetLevel: 0
[   0.0065 ] FwIndex: 19, MinRatchetLevel: 0
[   0.0065 ] FwIndex: 30, MinRatchetLevel: 0
[   0.0065 ] FwIndex: 31, MinRatchetLevel: 0
[   0.0065 ] FwIndex: 32, MinRatchetLevel: 0
[   0.0065 ]
[   0.0066 ] header_magic: 5b14
[   0.0085 ] tegrahost_v2 --chip 0x19 --align 1_Image
[   0.0091 ]
[   0.0109 ] tegrahost_v2 --chip 0x19 0 --magicid KRNL --ratchet_blob ratchet_blob.bin --appendsigheader 1_Image zerosbk
[   0.0115 ] adding BCH for 1_Image
[   0.7339 ]
[   0.7367 ] tegrasign_v3.py --key  --list 1_Image_sigheader_list.xml --pubkeyhash pub_key.key
[   0.7367 ] Assuming zero filled SBK key : not reading
[   0.8003 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_Image_sigheader.encrypt 1_Image_sigheader.hash zerosbk
[   1.1279 ]
[   1.1520 ] Signed file: /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/mnt/Image_sigheader.encrypt
l4t_sign_image.sh: Generate header for Image_sigheader.encrypt
l4t_sign_image.sh: chip 0x19: add 0x2231008 to offset  0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for Image_sigheader.encrypt
l4t_sign_image.sh: the sign header is saved at ./Image.sig
done.
done.
	generating sig file of kernel_tegra194-p3668-all-p3509-0000.dtb ... /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key  --minratchet_config tegra194-mb1-bct-ratchet-p3668.cfg --cmd sign ./dtb/kernel_tegra194-p3668-all-p3509-0000.dtb kernel_dtb
version 1.0.0
[   0.0040 ] tegrasign_v3.py --getmode mode.txt --key
[   0.0041 ] Assuming zero filled SBK key : not reading
[   0.0040 ] Generating ratchet blob
[   0.0058 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[   0.0064 ] FwIndex: 1, MinRatchetLevel: 0
[   0.0065 ] FwIndex: 2, MinRatchetLevel: 0
[   0.0066 ] FwIndex: 32, MinRatchetLevel: 0
[   0.0066 ]
[   0.0066 ] header_magic: d00dfeed
[   0.0085 ] tegrahost_v2 --chip 0x19 --align 1_kernel_tegra194-p3668-all-p3509-0000.dtb
[   0.0091 ]
[   0.0110 ] tegrahost_v2 --chip 0x19 0 --magicid KDTB --ratchet_blob ratchet_blob.bin --appendsigheader 1_kernel_tegra194-p3668-all-p3509-0000.dtb zerosbk
[   0.0115 ] adding BCH for 1_kernel_tegra194-p3668-all-p3509-0000.dtb
[   0.0160 ]
[   0.0185 ] tegrasign_v3.py --key  --list 1_kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[   0.0186 ] Assuming zero filled SBK key : not reading
[   0.0228 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt 1_kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.hash zerosbk
[   0.0261 ]
[   0.4634 ] Signed file: /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/mnt/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: chip 0x19: add 0x3a6b0 to offset  0x8 in sig file
l4t_sign_image.sh: the sign header is saved at ./dtb/kernel_tegra194-p3668-all-p3509-0000.dtb.sig
Signed dir is already exist!
done.
done.
	generating sig file of initrd ... /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key  --cmd sign ./initrd data
version 1.0.0
[   0.0016 ] Generating signature
[   0.0039 ] Assuming zero filled SBK key : not reading
[   0.0038 ] header_magic: 1f8b0800
[   0.0057 ] tegrahost_v2 --chip 0x19 --align 1_initrd
[   0.0064 ]
[   0.0082 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_initrd zerosbk
[   0.0088 ] adding BCH for 1_initrd
[   0.2058 ]
[   0.2086 ] tegrasign_v3.py --key  --list 1_initrd_sigheader_list.xml --pubkeyhash pub_key.key
[   0.2087 ] Assuming zero filled SBK key : not reading
[   0.2317 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_initrd_sigheader.encrypt 1_initrd_sigheader.hash zerosbk
[   0.3378 ]
[   0.3466 ] Signed file: /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/mnt/initrd_sigheader.encrypt
l4t_sign_image.sh: Generate header for initrd_sigheader.encrypt
l4t_sign_image.sh: chip 0x19: add 0xad570b to offset  0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for initrd_sigheader.encrypt
l4t_sign_image.sh: the sign header is saved at ./initrd.sig
done.
done.
	generating sig file of extlinux/extlinux.conf ... /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key  --cmd sign extlinux/extlinux.conf data
version 1.0.0
[   0.0039 ] tegrasign_v3.py --getmode mode.txt --key
[   0.0039 ] header_magic: 54494d45
[   0.0058 ] tegrahost_v2 --chip 0x19 --align 1_extlinux.conf
[   0.0065 ]
[   0.0083 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_extlinux.conf zerosbk
[   0.0089 ] adding BCH for 1_extlinux.conf
[   0.0090 ]
[   0.0117 ] tegrasign_v3.py --key  --list 1_extlinux_sigheader.conf_list.xml --pubkeyhash pub_key.key
[   0.0117 ] Assuming zero filled SBK key : not reading
[   0.0155 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_extlinux_sigheader.conf.encrypt 1_extlinux_sigheader.conf.hash zerosbk
[   0.0162 ]
[   0.0164 ] Signed file: /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/mnt/extlinux_sigheader.conf.encrypt
l4t_sign_image.sh: Generate header for extlinux_sigheader.conf.encrypt
l4t_sign_image.sh: chip 0x19: add 0x3e0 to offset  0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for extlinux_sigheader.conf.encrypt
l4t_sign_image.sh: the sign header is saved at extlinux/extlinux.conf.sig
done.
done.
	Sync'ing system_boot.img ... done.
system_boot.img built successfully.
Making system_root_encrypted.img_ext...
	populating rootfs from /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/rootfs ... done.
	Sync'ing system_root_encrypted.img_ext ... done.
system_root_encrypted.img_ext built successfully.
Existing tbcfile(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/cboot_t194.bin) reused.
copying tbcdtbfile(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb)... done.
copying cfgfile(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/tools/kernel_flash/flash_l4t_nvme_rootfs_enc.xml) to flash.xml... done.
Existing flasher(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu_t194.bin) reused.
Existing flashapp(/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl nvtboot_recovery_cpu_t194.bin --sdram_config tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg,tegra194-memcfg-sw-override.cfg  --odmdata 0xB8190000 --applet mb1_t194_prod.bin --cmd "sign" --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg  --cfg flash.xml --chip 0x19 --minratchet_config tegra194-mb1-bct-ratchet-p3668.cfg --device_config tegra19x-mb1-bct-device-qspi-p3668.cfg --misc_cold_boot_config tegra194-mb1-bct-misc-l4t.cfg --misc_config tegra194-mb1-bct-misc-flash.cfg --pinmux_config tegra19x-mb1-pinmux-p3668-a01.cfg --gpioint_config tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg --pmic_config tegra194-mb1-bct-pmic-p3668-0001-a00.cfg --pmc_config tegra19x-mb1-padvoltage-p3668-a01.cfg --prod_config tegra19x-mb1-prod-p3668-0001-a00.cfg --scr_config tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --scr_cold_boot_config tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --br_cmd_config tegra194-mb1-bct-reset-p3668-0001-a00.cfg --dev_params tegra194-br-bct-qspi.cfg  --bin "mb2_bootloader nvtboot_recovery_t194.bin; mts_preboot preboot_c10_prod_cr.bin; mts_mce mce_c10_prod_cr.bin; mts_proper mts_c10_prod_cr.bin; bpmp_fw bpmp_t194.bin; bpmp_fw_dtb tegra194-a02-bpmp-p3668-a00.dtb; spe_fw spe_t194.bin; tlk tos-trusty_t194.img; eks eks.img; bootloader_dtb tegra194-p3668-all-p3509-0000.dtb"   --external_device
saving flash command in /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/flash_win.bat
*** Sign and generate flashing ready partition images... ***
version 1.0.0
[   0.0057 ] Reading ramcode from backup chip_info.bin file
[   0.0059 ] RAMCODE Read from Device: 0
[   0.0059 ] Disable BPMP dtb trim, using default dtb
[   0.0059 ]
[   0.0080 ] tegrasign_v3.py --getmode mode.txt --key None
[   0.0081 ] Assuming zero filled SBK key
[   0.0086 ] Generating RCM messages
[   0.0113 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod.bin zerosbk
[   0.0121 ] Header already present for mb1_t194_prod.bin
[   0.0181 ]
[   0.0206 ] tegrasign_v3.py --getmode mode.txt --key None
[   0.0208 ] Assuming zero filled SBK key
[   0.0249 ] tegrasign_v3.py --file mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[   0.0251 ] Assuming zero filled SBK key
[   0.0419 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin mb1_t194_prod_sigheader.hash zerosbk
[   0.0533 ]
[   0.0572 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
[   0.0629 ]
[   0.0668 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[   0.0691 ] FwIndex: 1, MinRatchetLevel: 0
[   0.0700 ] FwIndex: 2, MinRatchetLevel: 0
[   0.0700 ] FwIndex: 3, MinRatchetLevel: 0
[   0.0701 ] FwIndex: 4, MinRatchetLevel: 0
[   0.0701 ] FwIndex: 5, MinRatchetLevel: 0
[   0.0701 ] FwIndex: 6, MinRatchetLevel: 0
[   0.0701 ] FwIndex: 7, MinRatchetLevel: 0
[   0.0701 ] FwIndex: 11, MinRatchetLevel: 0
[   0.0702 ] FwIndex: 12, MinRatchetLevel: 0
[   0.0702 ] FwIndex: 13, MinRatchetLevel: 0
[   0.0702 ] FwIndex: 14, MinRatchetLevel: 0
[   0.0702 ] FwIndex: 15, MinRatchetLevel: 0
[   0.0703 ] FwIndex: 16, MinRatchetLevel: 0
[   0.0703 ] FwIndex: 17, MinRatchetLevel: 0
[   0.0703 ] FwIndex: 18, MinRatchetLevel: 0
[   0.0703 ] FwIndex: 19, MinRatchetLevel: 0
[   0.0703 ] FwIndex: 30, MinRatchetLevel: 0
[   0.0704 ] FwIndex: 31, MinRatchetLevel: 0
[   0.0704 ] FwIndex: 32, MinRatchetLevel: 0
[   0.0704 ]
[   0.0750 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_sigheader.bin 0 0
[   0.0772 ] RCM 0 is saved as rcm_0.rcm
[   0.0856 ] RCM 1 is saved as rcm_1.rcm
[   0.0858 ] RCM 2 is saved as rcm_2.rcm
[   0.0858 ] List of rcm files are saved in rcm_list.xml
[   0.0858 ]
[   0.0859 ] Signing RCM messages
[   0.0888 ] tegrasign_v3.py --getmontgomeryvalues montgomery.bin --key None --list rcm_list.xml --pubkeyhash pub_key.key
[   0.0889 ] Assuming zero filled SBK key
[   0.0983 ] Copying signature to RCM mesages
[   0.1005 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[   0.1023 ]
[   0.1023 ] Parsing partition layout
[   0.1041 ] tegraparser_v2 --pt flash.xml.tmp
[   0.1068 ]
[   0.1068 ] Creating list of images to be signed
[   0.1087 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[   0.1095 ] adding BCH for recovery.img
[   0.2375 ] adding BCH for tegra194-p3668-all-p3509-0000.dtb.rec
[   1.2397 ] adding BCH for boot.img
[   1.2647 ] adding BCH for boot.img
[   2.0731 ] adding BCH for kernel_tegra194-p3668-all-p3509-0000.dtb
[   2.9553 ] adding BCH for kernel_tegra194-p3668-all-p3509-0000.dtb
[   2.9817 ]
[   2.9818 ] Filling MB1 storage info
[   2.9818 ] Generating br-bct
[   2.9847 ] Performing cfg overlay
[   2.9848 ] ['tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg', 'tegra194-memcfg-sw-override.cfg']
[   2.9855 ] sw_memcfg_overlay.pl -c tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg -s tegra194-memcfg-sw-override.cfg -o /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/31767/tmpeiex9yui1.cfg
[   3.0583 ]
[   3.0584 ] Updating dev and MSS params in BR BCT
[   3.0584 ] tegrabct_v2 --dev_param tegra194-br-bct-qspi.cfg --sdram /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/31767/tmpeiex9yui1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[   3.1086 ]
[   3.1086 ] Updating bl info
[   3.1108 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[   3.1118 ]
[   3.1119 ] Generating signatures
[   3.1140 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key
[   3.1140 ] Assuming zero filled SBK key
[   4.1890 ] Copying signatures
[   4.1925 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[   6.0266 ]
[   6.0307 ] tegraparser_v2 --generategpt --pt flash.xml.bin
[   6.0335 ]
[   6.0411 ] tegrahost_v2 --chip 0x19 --align nvtboot_recovery_t194.bin
[   6.0435 ]
[   6.0474 ] tegrahost_v2 --chip 0x19 0 --magicid MB2B --ratchet_blob ratchet_blob.bin --appendsigheader nvtboot_recovery_t194.bin zerosbk
[   6.0482 ] adding BCH for nvtboot_recovery_t194.bin
[   6.0521 ]
[   6.0544 ] tegrasign_v3.py --key None --list nvtboot_recovery_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   6.0545 ] Assuming zero filled SBK key
[   6.0588 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_recovery_t194_sigheader.bin.encrypt nvtboot_recovery_t194_sigheader.bin.hash zerosbk
[   6.0612 ]
[   6.0632 ] tegrahost_v2 --chip 0x19 --align preboot_c10_prod_cr.bin
[   6.0638 ]
[   6.0656 ] tegrahost_v2 --chip 0x19 0 --magicid MTSP --appendsigheader preboot_c10_prod_cr.bin zerosbk
[   6.0663 ] Header already present for preboot_c10_prod_cr.bin
[   6.0669 ]
[   6.0695 ] tegrasign_v3.py --key None --list preboot_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   6.0695 ] Assuming zero filled SBK key
[   6.0735 ] tegrahost_v2 --chip 0x19 0 --updatesigheader preboot_c10_prod_cr_sigheader.bin.encrypt preboot_c10_prod_cr_sigheader.bin.hash zerosbk
[   6.0744 ]
[   6.0762 ] tegrahost_v2 --chip 0x19 --align mce_c10_prod_cr.bin
[   6.0768 ]
[   6.0788 ] tegrahost_v2 --chip 0x19 0 --magicid MTSM --appendsigheader mce_c10_prod_cr.bin zerosbk
[   6.0793 ] Header already present for mce_c10_prod_cr.bin
[   6.0813 ]
[   6.0836 ] tegrasign_v3.py --key None --list mce_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   6.0837 ] Assuming zero filled SBK key
[   6.0879 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mce_c10_prod_cr_sigheader.bin.encrypt mce_c10_prod_cr_sigheader.bin.hash zerosbk
[   6.0900 ]
[   6.0921 ] tegrahost_v2 --chip 0x19 --align mts_c10_prod_cr.bin
[   6.0927 ]
[   6.0948 ] tegrahost_v2 --chip 0x19 0 --magicid MTSB --appendsigheader mts_c10_prod_cr.bin zerosbk
[   6.0953 ] adding BCH for mts_c10_prod_cr.bin
[   6.1646 ]
[   6.1670 ] tegrasign_v3.py --key None --list mts_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   6.1671 ] Assuming zero filled SBK key
[   6.1765 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mts_c10_prod_cr_sigheader.bin.encrypt mts_c10_prod_cr_sigheader.bin.hash zerosbk
[   6.2084 ]
[   6.2105 ] tegrahost_v2 --chip 0x19 --align bpmp_t194.bin
[   6.2111 ]
[   6.2130 ] tegrahost_v2 --chip 0x19 0 --magicid BPMF --ratchet_blob ratchet_blob.bin --appendsigheader bpmp_t194.bin zerosbk
[   6.2137 ] adding BCH for bpmp_t194.bin
[   6.2337 ]
[   6.2362 ] tegrasign_v3.py --key None --list bpmp_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   6.2363 ] Assuming zero filled SBK key
[   6.2418 ] tegrahost_v2 --chip 0x19 0 --updatesigheader bpmp_t194_sigheader.bin.encrypt bpmp_t194_sigheader.bin.hash zerosbk
[   6.2512 ]
[   6.2535 ] tegrahost_v2 --chip 0x19 --align tegra194-a02-bpmp-p3668-a00.dtb
[   6.2554 ]
[   6.2574 ] tegrahost_v2 --chip 0x19 0 --magicid BPMD --ratchet_blob ratchet_blob.bin --appendsigheader tegra194-a02-bpmp-p3668-a00.dtb zerosbk
[   6.2582 ] adding BCH for tegra194-a02-bpmp-p3668-a00.dtb
[   6.2670 ]
[   6.2693 ] tegrasign_v3.py --key None --list tegra194-a02-bpmp-p3668-a00_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[   6.2694 ] Assuming zero filled SBK key
[   6.2746 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt tegra194-a02-bpmp-p3668-a00_sigheader.dtb.hash zerosbk
[   6.2794 ]
[   6.2815 ] tegrahost_v2 --chip 0x19 --align spe_t194.bin
[   6.2823 ]
[   6.2842 ] tegrahost_v2 --chip 0x19 0 --magicid SPEF --ratchet_blob ratchet_blob.bin --appendsigheader spe_t194.bin zerosbk
[   6.2850 ] adding BCH for spe_t194.bin
[   6.2875 ]
[   6.2901 ] tegrasign_v3.py --key None --list spe_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   6.2901 ] Assuming zero filled SBK key
[   6.2945 ] tegrahost_v2 --chip 0x19 0 --updatesigheader spe_t194_sigheader.bin.encrypt spe_t194_sigheader.bin.hash zerosbk
[   6.2962 ]
[   6.2981 ] tegrahost_v2 --chip 0x19 --align tos-trusty_t194.img
[   6.2988 ]
[   6.3007 ] tegrahost_v2 --chip 0x19 0 --magicid TOSB --ratchet_blob ratchet_blob.bin --appendsigheader tos-trusty_t194.img zerosbk
[   6.3017 ] adding BCH for tos-trusty_t194.img
[   6.3101 ]
[   6.3125 ] tegrasign_v3.py --key None --list tos-trusty_t194_sigheader.img_list.xml --pubkeyhash pub_key.key
[   6.3126 ] Assuming zero filled SBK key
[   6.3183 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tos-trusty_t194_sigheader.img.encrypt tos-trusty_t194_sigheader.img.hash zerosbk
[   6.3231 ]
[   6.3252 ] tegrahost_v2 --chip 0x19 --align eks.img
[   6.3259 ]
[   6.3279 ] tegrahost_v2 --chip 0x19 0 --magicid EKSB --ratchet_blob ratchet_blob.bin --appendsigheader eks.img zerosbk
[   6.3285 ] adding BCH for eks.img
[   6.3288 ]
[   6.3311 ] tegrasign_v3.py --key None --list eks_sigheader.img_list.xml --pubkeyhash pub_key.key
[   6.3312 ] Assuming zero filled SBK key
[   6.3353 ] tegrahost_v2 --chip 0x19 0 --updatesigheader eks_sigheader.img.encrypt eks_sigheader.img.hash zerosbk
[   6.3360 ]
[   6.3381 ] tegrahost_v2 --chip 0x19 --align tegra194-p3668-all-p3509-0000.dtb
[   6.3388 ]
[   6.3408 ] tegrahost_v2 --chip 0x19 0 --magicid CDTB --ratchet_blob ratchet_blob.bin --appendsigheader tegra194-p3668-all-p3509-0000.dtb zerosbk
[   6.3415 ] adding BCH for tegra194-p3668-all-p3509-0000.dtb
[   6.3461 ]
[   6.3485 ] tegrasign_v3.py --key None --list tegra194-p3668-all-p3509-0000_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[   6.3486 ] Assuming zero filled SBK key
[   6.3533 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt tegra194-p3668-all-p3509-0000_sigheader.dtb.hash zerosbk
[   6.3565 ]
[   6.3585 ] tegrahost_v2 --chip 0x19 --align nvtboot_recovery_cpu_t194.bin
[   6.3591 ]
[   6.3611 ] tegrahost_v2 --chip 0x19 0 --magicid CPBL --ratchet_blob ratchet_blob.bin --appendsigheader nvtboot_recovery_cpu_t194.bin zerosbk
[   6.3618 ] adding BCH for nvtboot_recovery_cpu_t194.bin
[   6.3665 ]
[   6.3687 ] tegrasign_v3.py --key None --list nvtboot_recovery_cpu_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   6.3688 ] Assuming zero filled SBK key
[   6.3731 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_recovery_cpu_t194_sigheader.bin.encrypt nvtboot_recovery_cpu_t194_sigheader.bin.hash zerosbk
[   6.3762 ]
[   6.3762 ] Copying signed file in /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/signed
[   6.5721 ] tegraparser_v2 --pt flash.xml.bin --generateflashindex /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/signed/flash.xml.tmp flash.idx
[   7.8533 ]
'/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/signed/flash.idx' -> '/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/tools/kernel_flash/images/external/flash.idx'
Flash index file is /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/signed/flash.idx
Number of lines is 15
max_index=14
Copying /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/signed/mbr_9_0.bin  /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/tools/kernel_flash/images/external/mbr_9_0.bin
'/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/signed/mbr_9_0.bin' -> '/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/tools/kernel_flash/images/external/mbr_9_0.bin'
Copying /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/signed/gpt_primary_9_0.bin  /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/tools/kernel_flash/images/external/gpt_primary_9_0.bin
'/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/signed/gpt_primary_9_0.bin' -> '/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/tools/kernel_flash/images/external/gpt_primary_9_0.bin'
Copying APP image into  /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/tools/kernel_flash/images/external/system_boot.img.raw
tar: 写入检查点  10000
tar: 写入检查点  20000
Copying /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/system_root_encrypted.img_ext  /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/tools/kernel_flash/images/external/system_root_encrypted.img_ext
'/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/system_root_encrypted.img_ext' -> '/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/tools/kernel_flash/images/external/system_root_encrypted.img_ext'
Copying /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/signed/recovery_sigheader.img.encrypt  /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/tools/kernel_flash/images/external/recovery_sigheader.img.encrypt
'/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/signed/recovery_sigheader.img.encrypt' -> '/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/tools/kernel_flash/images/external/recovery_sigheader.img.encrypt'
Copying /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/signed/tegra194-p3668-all-p3509-0000.dtb_sigheader.rec.encrypt  /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/tools/kernel_flash/images/external/tegra194-p3668-all-p3509-0000.dtb_sigheader.rec.encrypt
'/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/signed/tegra194-p3668-all-p3509-0000.dtb_sigheader.rec.encrypt' -> '/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/tools/kernel_flash/images/external/tegra194-p3668-all-p3509-0000.dtb_sigheader.rec.encrypt'
Copying /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/kernel_bootctrl.bin  /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/tools/kernel_flash/images/external/kernel_bootctrl.bin
'/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/kernel_bootctrl.bin' -> '/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/tools/kernel_flash/images/external/kernel_bootctrl.bin'
Copying /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/signed/boot_sigheader.img.encrypt  /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/tools/kernel_flash/images/external/boot_sigheader.img.encrypt
'/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/signed/boot_sigheader.img.encrypt' -> '/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/tools/kernel_flash/images/external/boot_sigheader.img.encrypt'
Copying /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/signed/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt  /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/tools/kernel_flash/images/external/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
'/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/signed/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt' -> '/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/tools/kernel_flash/images/external/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt'
Warning: skip writing RECROOTFS partition as no image is specified
Copying /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/system_uda_encrypted.img_ext  /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/tools/kernel_flash/images/external/system_uda_encrypted.img_ext
'/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/system_uda_encrypted.img_ext' -> '/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/tools/kernel_flash/images/external/system_uda_encrypted.img_ext'
Copying /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/signed/gpt_secondary_9_0.bin  /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/tools/kernel_flash/images/external/gpt_secondary_9_0.bin
'/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/bootloader/signed/gpt_secondary_9_0.bin' -> '/home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/tools/kernel_flash/images/external/gpt_secondary_9_0.bin'
 /home/guwen/545s/flashtool_tztek_geac_nx_jp4.6.1_545s2.0_v2.1.2/Linux_for_Tegra/flash.sh --no-flash --sign  jetson-xavier-nx-devkit-emmc external
Error: When disk encryption is enabled, root device cannot be external
Error: failed to generate images
Cleaning up...
below show the successful log when I run the command
sudo ROOTFS_ENC=1 ./tools/kernel_flash/l4t_initrd_flash.sh -u rsa_priv.pem -v sbk.key --external-device nvme0n1p1   -c ./tools/kernel_flash/flash_l4t_nvme_rootfs_enc.xml --external-only -S 35GiB     --showlogs jetson-xavier-nx-devkit-emmc external
NX_ext_encrypt.log (24.5 KB)
I am so confused about the log that where the “sde” come from? Is it the nvme? And the device boot from emmc .
And I want to know why I cant discard the emmc if I just use the nvme.
Hello
Here I have one question about the initrd_massflash. If I can massflash with the option “–network eth0” ?And if it can be achieved whats the IP need be set ?
Thank u
emmc is still needed for bootloader software on it. The so-called “boot from external drive” is just boot kernel/kernel-dtb and mount file system from it.
Thanks u
Can you give me answers to other questions?
Sorry for the late response, have you managed to get issue resolved or still need the support? Thanks
Yes,I need the support.Look back the last question.
Thank u
NO, that’s not supported.
Now,I know that.
