How to reflash QSPI in mass deployments
Hey guys,
followed this guide for mass deployment.
orin-nx-mass-deployment-flashing
“You could use the following command to flash QSPI in the Orin NX module only.”
$sudo ./flash.sh -c bootloader/t186ref/cfg/flash_t234_qspi.xml jetson-orin-nano-devkit mmcblk0p1
Just works, great, thank you.
But now i wonder how to rerun the QPI flash in case we have to reflash many devices in case of adjustemnts/bug fixing?
The flash command just works 1 time, did not find any instruction for reflash…
To use SDK GUI is great for 1 system, not for many,
Thank you in advance
BR
I think they should be the same as normal massflash, but you just don’t give info about external devices.
Maybe something like:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --no-flash --massflash <x> -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" \
  --showlogs --network usb0 jetson-orin-nano-devkit internal
Hi, thank you for your answer.
Maybe I was not clear, pretty new to this, so sorry.
We need to make a lot of the Jetson Orin NX ready to run.
So we want use an image for OS drive, and flash onyl QSPI (boot + initrd + kernel, right?).
Problem is:
If we run the flash command as explained in the thread, everything is fine.
if we run the same command a second time on a system that was already flashed (changes, bugs, …), it does not work any more:
[  21.4101 ] Start flashing
[  21.4137 ] tegradevflash_v2 --pt flash.xml.bin --create
[  21.4170 ] Bootloader version 01.00.0000
[  21.4500 ] Erasing spi: 0 ......... [Done]
[  22.4567 ] Writing partition secondary_gpt with gpt_secondary_3_0.bin [ 16896 bytes ]
[  22.4577 ] [................................................] 100%
[  22.4607 ] 000000004d4d2c01: E> NV3P_SERVER: Failed to initialize partition table from GPT.
[  22.6810 ]
[  22.6810 ]
If we usel4t_ initrd_flash directly, it does not work, too, but for othe reasons, I guess:
./l4t_initrd_flash.sh -c ../../bootloader/t186ref/cfg/flash_t234_qspi.xml jetson-orin-nano-devkit mmcblk0p1
*  Step 2: Generate rcm boot commandline *
ROOTFS_AB= ROOTFS_ENC= /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/flash.sh  --no-flash --rcm-boot jetson-orin-nano-devkit mmcblk0p1
Error: Invalid target board - jetson-orin-nano-devkit.
If we use the SDKmanager GUI and run a “full flash” including os drive setup, it works…
So I may just oversea something.
Thank you for all the help
BR
We also have other users reporting it, and we are still debugging it.
Can you please tell me if this command works or not?
For partition layouts of internal storage devices (QSPI, eMMC), you have to use
-p "-c xxx.xml"
. not just
-c xxx.xml
unfortunately I get the same error message as without the “-p” in front:
complete:
# ./l4t_initrd_flash.sh -p "-c ../../bootloader/t186ref/cfg/flash_t234_qspi.xml" jetson-orin-nano-devkit mmcblk0p1
/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh --no-flash -p -c ../../bootloader/t186ref/cfg/flash_t234_qspi.xml jetson-orin-nano-devkit mmcblk0p1
*  Step 1: Generate flash packages *
Create folder to store images to flash
Generate image for internal storage devices
Generate images to be flashed
ADDITIONAL_DTB_OVERLAY=""  /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/flash.sh --no-flash --sign  -c ../../bootloader/t186ref/cfg/flash_t234_qspi.xml jetson-orin-nano-devkit mmcblk0p1
Usage: sudo ./flash.sh [options] <target_board> <rootdev>
  Where,
	target board: Valid target board name.
	rootdev: Proper root device.
    options:
        -c <cfgfile> ---------- Flash partition table config file.
        -d <dtbfile> ---------- device tree file.
        -f <flashapp> --------- Path to flash application (tegraflash.py)
        -h -------------------- print this message.
        -i <enc rfs key file>-- key for disk encryption support.
        -k <partition id> ----- partition name or number specified in flash.cfg.
        -m <mts preboot> ------ MTS preboot such as mts_preboot_si.
        -n <nfs args> --------- Static nfs network assignments
                                <Client IP>:<Server IP>:<Gateway IP>:<Netmask>
        -o <odmdata> ---------- ODM data.
        -r -------------------- skip building and reuse existing system.img.
        -t <tegraboot> -------- tegraboot binary such as nvtboot.bin
        -u <PKC key file>------ PKC key used for odm fused board.
        -v <SBK key file>------ Secure Boot Key (SBK) key used for ODM fused board.
        -w <wb0boot> ---------- warm boot binary such as nvtbootwb0.bin
        -x <tegraid> ---------- Tegra CHIPID.
        -B <boardid> ---------- BoardId.
        -C <cmdline> ---------- Kernel commandline arguments.
                                WARNING:
                                Each option in this kernel commandline gets
                                higher preference over the values set by
                                flash.sh. In case of NFS booting, this script
                                adds NFS booting related arguments, if -i option
                                is omitted.
        -F <flasher> ---------- Flash server such as cboot.bin.
        -G <file name> -------- Read partition and save image to file.
        -I <initrd> ----------- initrd file. Null initrd is default.
        -K <kernel> ----------- Kernel image file such as zImage or Image.
        -L <bootloader> ------- Bootloader such as cboot.bin or u-boot-dtb.bin.
        -M <mts boot> --------- MTS boot file such as mts_si.
        -N <nfsroot> ---------- i.e. <my IP addr>:/my/exported/nfs/rootfs.
        -R <rootfs dir> ------- Sample rootfs directory.
        -S <size> ------------- Rootfs size in bytes. Valid only for internal
                                rootdev. KiB, MiB, GiB short hands are allowed,
                                for example, 1GiB means 1024 * 1024 * 1024 bytes.
        -T <ext num sectors> ---The number of the sectors of the external storage device.
                                The default value is 122159104 if this option is not set.
        -Z -------------------- Print configurations and then exit.
        --no-flash ------------ perform all steps except physically flashing the board.
                                This will create a system.img.
        --external-device------ Generate flash images for external devices
        --sparseupdate--------- only flash partitions that have changed. Currently only support SPI flash memory
        --no-systemimg -------- Do not create or re-create system.img.
        --bup ----------------- Generate bootloader update payload(BUP).
        --single-image-bup <part name> Generate specified single image BUP, this must work with --bup.
        --bup-type <type> ----- Generate specific type bootloader update payload(BUP), such as bl or kernel.
        --multi-spec----------- Enable support for building multi-spec BUP.
        --clean-up------------- Clean up BUP buffer when multi-spec is enabled.
        --usb-instance <id> --- Specify the USB instance to connect to;
                                <id> = USB port path (e.g. 3-14).
        --no-root-check ------- Typical usage of this script require root permissions.
                                Pass this option to allow running the script as a
                                regular user, in which case only specific combinations
                                of command-line options will be functional.
        --uefi-keys <keys_conf> Specify UEFI keys configuration file.
        --rcm-boot ------------ Do RCM boot instead of physically flashing the board.
        --sign ---------------- Sign images and store them under "bootloader/signed"
                                directory. The board will not be physically flashed.
        --image --------------- Specify the image to be written into board.
        --boot-chain-flash <c>  Flash only a specific boot chain (ex. "A, "B", "all").
                                Defaults to "all", inputs are case insensitive.
                                Not suitable for production.
        --boot-chain-select <c> Specify booting chain (ex. "A" or "B") after the board is flashed.
                                Defaults to "A", inputs are case insensitive.
        --pv-crt -------------- The certificate for the key that is used to sign cpu_bootloader
        --with-systemimg ------ Generate system images also when using -k option
        --pv-enc <enc_key>----- The encryption key that is used to encrypt cpu_bootloader.
        --uefi-enc <uefi_enc_key> Key file (0x19: 16-byte; 0x23: 32-byte) to encrypt UEFI payloads
        --uda-dir-------------- Directory to store user data that will be encrypted in UDA partition.
'/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/flash.idx' -> '/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/flash.idx'
Flash index file is /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/flash.idx
Number of lines is 76
max_index=75
Copying /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/br_bct_BR.bct  /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/br_bct_BR.bct
'/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/br_bct_BR.bct' -> '/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/br_bct_BR.bct'
Copying /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/mb1_t234_prod_aligned_sigheader.bin.encrypt  /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/mb1_t234_prod_aligned_sigheader.bin.encrypt
'/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/mb1_t234_prod_aligned_sigheader.bin.encrypt' -> '/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/mb1_t234_prod_aligned_sigheader.bin.encrypt'
Copying /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/psc_bl1_t234_prod_aligned_sigheader.bin.encrypt  /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/psc_bl1_t234_prod_aligned_sigheader.bin.encrypt
'/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/psc_bl1_t234_prod_aligned_sigheader.bin.encrypt' -> '/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/psc_bl1_t234_prod_aligned_sigheader.bin.encrypt'
Copying /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt  /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
'/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt' -> '/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt'
Copying /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/mem_coldboot_sigheader.bct.encrypt  /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/mem_coldboot_sigheader.bct.encrypt
'/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/mem_coldboot_sigheader.bct.encrypt' -> '/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/mem_coldboot_sigheader.bct.encrypt'
Warning: skip writing A_tsec-fw partition as no image is specified
Copying /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/nvdec_t234_prod_sigheader.fw.encrypt  /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/nvdec_t234_prod_sigheader.fw.encrypt
'/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/nvdec_t234_prod_sigheader.fw.encrypt' -> '/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/nvdec_t234_prod_sigheader.fw.encrypt'
Copying /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt  /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt
'/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt' -> '/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt'
Copying /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/xusb_t234_prod_sigheader.bin.encrypt  /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/xusb_t234_prod_sigheader.bin.encrypt
'/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/xusb_t234_prod_sigheader.bin.encrypt' -> '/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/xusb_t234_prod_sigheader.bin.encrypt'
Copying /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt  /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt
'/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt' -> '/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt'
Copying /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/tegra234-bpmp-3767-0001-3509-a02_with_odm_sigheader.dtb.encrypt  /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/tegra234-bpmp-3767-0001-3509-a02_with_odm_sigheader.dtb.encrypt
'/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/tegra234-bpmp-3767-0001-3509-a02_with_odm_sigheader.dtb.encrypt' -> '/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/tegra234-bpmp-3767-0001-3509-a02_with_odm_sigheader.dtb.encrypt'
Copying /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/pscfw_t234_prod_sigheader.bin.encrypt  /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/pscfw_t234_prod_sigheader.bin.encrypt
'/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/pscfw_t234_prod_sigheader.bin.encrypt' -> '/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/pscfw_t234_prod_sigheader.bin.encrypt'
Copying /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/mce_flash_o10_cr_prod_sigheader.bin.encrypt  /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/mce_flash_o10_cr_prod_sigheader.bin.encrypt
'/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/mce_flash_o10_cr_prod_sigheader.bin.encrypt' -> '/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/mce_flash_o10_cr_prod_sigheader.bin.encrypt'
Copying /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/sc7_t234_prod_sigheader.bin.encrypt  /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/sc7_t234_prod_sigheader.bin.encrypt
'/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/sc7_t234_prod_sigheader.bin.encrypt' -> '/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/sc7_t234_prod_sigheader.bin.encrypt'
Copying /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/psc_rf_t234_prod_sigheader.bin.encrypt  /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/psc_rf_t234_prod_sigheader.bin.encrypt
'/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/psc_rf_t234_prod_sigheader.bin.encrypt' -> '/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/psc_rf_t234_prod_sigheader.bin.encrypt'
Copying /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/mb2rf_t234_sigheader.bin.encrypt  /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/mb2rf_t234_sigheader.bin.encrypt
'/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/mb2rf_t234_sigheader.bin.encrypt' -> '/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/mb2rf_t234_sigheader.bin.encrypt'
Copying /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/uefi_jetson_with_dtb_sigheader.bin.encrypt  /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/uefi_jetson_with_dtb_sigheader.bin.encrypt
'/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/uefi_jetson_with_dtb_sigheader.bin.encrypt' -> '/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/uefi_jetson_with_dtb_sigheader.bin.encrypt'
Copying /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/tos-optee_t234_sigheader.img.encrypt  /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/tos-optee_t234_sigheader.img.encrypt
'/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/tos-optee_t234_sigheader.img.encrypt' -> '/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/tos-optee_t234_sigheader.img.encrypt'
Warning: skip writing A_smm-fw partition as no image is specified
Copying /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/eks_t234_sigheader.img.encrypt  /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/eks_t234_sigheader.img.encrypt
'/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/eks_t234_sigheader.img.encrypt' -> '/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/eks_t234_sigheader.img.encrypt'
Copying /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/display-t234-dce_with_kernel_tegra234-p3767-0001-p3768-0000-a0_aligned_blob_w_bin_sigheader.bin.encrypt  /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/display-t234-dce_with_kernel_tegra234-p3767-0001-p3768-0000-a0_aligned_blob_w_bin_sigheader.bin.encrypt
'/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/display-t234-dce_with_kernel_tegra234-p3767-0001-p3768-0000-a0_aligned_blob_w_bin_sigheader.bin.encrypt' -> '/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/display-t234-dce_with_kernel_tegra234-p3767-0001-p3768-0000-a0_aligned_blob_w_bin_sigheader.bin.encrypt'
Copying /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/spe_t234_sigheader.bin.encrypt  /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/spe_t234_sigheader.bin.encrypt
'/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/spe_t234_sigheader.bin.encrypt' -> '/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/spe_t234_sigheader.bin.encrypt'
Copying /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/camera-rtcpu-t234-rce_sigheader.img.encrypt  /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/camera-rtcpu-t234-rce_sigheader.img.encrypt
'/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/camera-rtcpu-t234-rce_sigheader.img.encrypt' -> '/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/camera-rtcpu-t234-rce_sigheader.img.encrypt'
Copying /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/adsp-fw_sigheader.bin.encrypt  /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/adsp-fw_sigheader.bin.encrypt
'/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/adsp-fw_sigheader.bin.encrypt' -> '/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/adsp-fw_sigheader.bin.encrypt'
Warning: skip writing A_reserved_on_boot partition as no image is specified
Warning: skip writing B_tsec-fw partition as no image is specified
Warning: skip writing B_smm-fw partition as no image is specified
Warning: skip writing B_reserved_on_boot partition as no image is specified
Warning: skip writing uefi_variables partition as no image is specified
Warning: skip writing uefi_ftw partition as no image is specified
Warning: skip writing worm partition as no image is specified
Copying /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/bct_backup.img  /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/bct_backup.img
'/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/bct_backup.img' -> '/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/bct_backup.img'
Warning: skip writing reserved_partition partition as no image is specified
Copying /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/gpt_secondary_3_0.bin  /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/gpt_secondary_3_0.bin
'/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/gpt_secondary_3_0.bin' -> '/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/gpt_secondary_3_0.bin'
Copying /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/qspi_bootblob_ver.txt  /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/qspi_bootblob_ver.txt
'/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/qspi_bootblob_ver.txt' -> '/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/qspi_bootblob_ver.txt'
Copying /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/mbr_6_0.bin  /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/mbr_6_0.bin
'/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/mbr_6_0.bin' -> '/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/mbr_6_0.bin'
Copying /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/gpt_primary_6_0.bin  /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/gpt_primary_6_0.bin
'/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/gpt_primary_6_0.bin' -> '/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/gpt_primary_6_0.bin'
Copying /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/boot.img  /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/boot.img
'/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/boot.img' -> '/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/boot.img'
Copying /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/kernel_tegra234-p3767-0001-p3768-0000-a0.dtb  /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/kernel_tegra234-p3767-0001-p3768-0000-a0.dtb
'/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/kernel_tegra234-p3767-0001-p3768-0000-a0.dtb' -> '/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/kernel_tegra234-p3767-0001-p3768-0000-a0.dtb'
Warning: skip writing A_reserved_on_user partition as no image is specified
Warning: skip writing B_reserved_on_user partition as no image is specified
Copying /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/recovery.img  /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/recovery.img
'/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/recovery.img' -> '/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/recovery.img'
Copying /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/tegra234-p3767-0001-p3768-0000-a0.dtb.rec  /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/tegra234-p3767-0001-p3768-0000-a0.dtb.rec
'/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/tegra234-p3767-0001-p3768-0000-a0.dtb.rec' -> '/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/tegra234-p3767-0001-p3768-0000-a0.dtb.rec'
Copying /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/esp.img  /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/esp.img
'/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/esp.img' -> '/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/esp.img'
Warning: skip writing recovery_alt partition as no image is specified
Warning: skip writing recovery-dtb_alt partition as no image is specified
Warning: skip writing esp_alt partition as no image is specified
Warning: skip writing UDA partition as no image is specified
Warning: skip writing reserved partition as no image is specified
Copying APP image into  /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/system.img.raw
tar: Write checkpoint 10000
tar: Write checkpoint 20000
tar: Write checkpoint 30000
tar: Write checkpoint 40000
tar: Write checkpoint 50000
tar: Write checkpoint 60000
tar: Write checkpoint 70000
tar: Write checkpoint 80000
tar: Write checkpoint 90000
tar: Write checkpoint 100000
tar: Write checkpoint 110000
tar: Write checkpoint 120000
tar: Write checkpoint 130000
tar: Write checkpoint 140000
tar: Write checkpoint 150000
tar: Write checkpoint 160000
tar: Write checkpoint 170000
tar: Write checkpoint 180000
tar: Write checkpoint 190000
tar: Write checkpoint 200000
tar: Write checkpoint 210000
tar: Write checkpoint 220000
tar: Write checkpoint 230000
tar: Write checkpoint 240000
tar: Write checkpoint 250000
tar: Write checkpoint 260000
tar: Write checkpoint 270000
tar: Write checkpoint 280000
tar: Write checkpoint 290000
tar: Write checkpoint 300000
tar: Write checkpoint 310000
tar: Write checkpoint 320000
tar: Write checkpoint 330000
tar: Write checkpoint 340000
tar: Write checkpoint 350000
tar: Write checkpoint 360000
tar: Write checkpoint 370000
tar: Write checkpoint 380000
tar: Write checkpoint 390000
tar: Write checkpoint 400000
tar: Write checkpoint 410000
tar: Write checkpoint 420000
tar: Write checkpoint 430000
tar: Write checkpoint 440000
tar: Write checkpoint 450000
tar: Write checkpoint 460000
tar: Write checkpoint 470000
tar: Write checkpoint 480000
tar: Write checkpoint 490000
tar: Write checkpoint 500000
tar: Write checkpoint 510000
tar: Write checkpoint 520000
tar: Write checkpoint 530000
tar: Write checkpoint 540000
tar: Write checkpoint 550000
tar: Write checkpoint 560000
Copying /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/gpt_secondary_6_0.bin  /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/gpt_secondary_6_0.bin
'/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/gpt_secondary_6_0.bin' -> '/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/gpt_secondary_6_0.bin'
Copy flash script to /home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images
'/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/l4t_flash_from_kernel.sh' -> '/home/localadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/l4t_flash_from_kernel.sh'
Success
  Where,
    options:
                                WARNING:
                                is omitted.
Cleaning up...
Everything has to be run under /Linux_for_Tegra; I don’t think we have ever taught users to cd into sub folders.
Hello
starting the l4t_initrd_flash.sh from the /Linux_for_Tegra path has an effect, flash process goes further, but always stops with an timeout in Step 3 (while the same nodes run through the complete process started in SDK MANAGER GUI, still):
*  Step 3: Start the flashing process *
Waiting for target to boot-up...
Timeout
Cleaning up...
Dump the log so we know what happens behind the scene:
Sorry, which log do you need?
Thank you
BR
I mean serial console log.
How to dump it is stated in the link I posted.
