Flash external fails after a long period of processing
I am using Jetpack 6.0 with devkit for flashing and fusing Jetson Orin Nana 8G.
I successfully fused and flashed the Jetson and external NVME on the first try. Now, I am trying to flash another NVME card (the same size and model as the previous one). This time, I got an error :
*  Step 2: Generate rcm boot commandline *
ROOTFS_AB= ROOTFS_ENC= /opt/nvidia/Linux_for_Tegra/flash.sh  --no-flash --rcm-boot jetson-orin-nano-devkit mmcblk0p1
# L4T BSP Information:
# R36 , REVISION: 3.0
# User release: 0.0
ECID is
Board ID() version() sku() revision()
Chip SKU(00:00:00:D3) ramcode() fuselevel(fuselevel_production) board_FAB()
emc_opt_disable_fuse:(0)
Error: Unrecognized module SKU
Cleaning up...
The device is in recovery mode when I start the process (if its not, the command fails much earlier) but then it fails at later step.
Also, I can flash the Qspi again with no problem. What could be the problem? Do you have any suggestions on how to troubleshoot?
Command and full log:
sudo ROOTFS_ENC=1 EXT_NUM_SECTORS=468846000 ./tools/kernel_flash/l4t_initrd_flash.sh -S 221GiB --external-device nvme0n1p1 -i ./sym2_t234.key -c ./tools/kernel_flash/flash_l4t_t234_nvme_rootfs_enc.xml --external-only --showlogs --no-flash --network usb0 jetson-orin-nano-devkit external
[sudo] password for shai:
/opt/nvidia/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh --no-flash -S 221GiB --external-device nvme0n1p1 -i ./sym2_t234.key -c ./tools/kernel_flash/flash_l4t_t234_nvme_rootfs_enc.xml --external-only --showlogs --no-flash --network usb0 jetson-orin-nano-devkit external
*  Step 1: Generate flash packages *
Create folder to store images to flash
Generate image for external storage devices
Generate images to be flashed
BOOTDEV=external ADDITIONAL_DTB_OVERLAY=""  /opt/nvidia/Linux_for_Tegra/flash.sh --no-flash --sign --external-device -c "./tools/kernel_flash/flash_l4t_t234_nvme_rootfs_enc.xml" -S "221GiB" -i "./sym2_t234.key"  jetson-orin-nano-devkit external
# User release: 0.0
Change device boot from external to internal
ECID is 0xE9012344705DD4456400000001028280
Existing emcfuse(/opt/nvidia/Linux_for_Tegra/bootloader/fuse_t234.xml) reused.
copying emc_fuse_dev_params(/opt/nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct-diag-boot.dts)... done.
copying device_config(/opt/nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-device-p3767-0000.dts)... done.
copying misc_config(/opt/nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-misc-p3767-0000.dts)... done.
./tegraflash.py --chip "0x23" --applet "/opt/nvidia/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3767-0000.dts --misc_config tegra234-mb1-bct-misc-p3767-0000.dts --bins "mb2_applet applet_t234.bin" --cmd "readfuses fuse_t234.bin fuse_t234.xml; dump eeprom cvm cvm.bin; dump try_custinfo custinfo_out.bin; reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[   0.0300 ] Reading fuses
[   0.0304 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.0307 ] File rcm_state open failed
[   0.0309 ] ERROR: failed to read rcm_state
[   0.0309 ]
[   0.0320 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0321 ] Assuming zero filled SBK key
[   0.0312 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[   0.0368 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[   0.0453 ] Parsing partition layout
[   0.0456 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.0464 ] Kernel DTB used: None
[   0.0465 ] WARNING: dce base dtb is not provided
[   0.0465 ] Parsing partition layout
[   0.0467 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.0472 ] Creating list of images to be signed
[   0.0474 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[   0.0476 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.0494 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.0496 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.0528 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.0530 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.0567 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.0569 ] adding BCH for mb2_t234_aligned.bin
[   0.0599 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.0689 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.0691 ] adding BCH for mb2_t234_aligned.bin
[   0.0798 ] Filling MB1 storage info
[   0.0799 ] Parsing dev params for multi chains
[   0.0856 ] Generating br-bct
[   0.0858 ] Updating dev and MSS params in BR BCT
[   0.0858 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.0863 ] Updating bl info
[   0.0866 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[   0.0868 ] WARNING: boot chain is not completed. set to 0
[   0.0875 ] Generating signatures
[   0.0886 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.0887 ] Assuming zero filled SBK key
[   0.0968 ] Warning: pub_key.key is not found
[   0.0959 ] Parsing dev params for multi chains
[   0.0959 ] Generating br-bct
[   0.0962 ] Updating dev and MSS params in BR BCT
[   0.0963 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.0967 ] Updating bl info
[   0.0969 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.0971 ] WARNING: boot chain is not completed. set to 0
[   0.0978 ] Generating SHA2 Hash
[   0.0996 ] Sha saved in br_bct_BR.sha
[   0.0986 ] Get Signed section of bct
[   0.0988 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   0.0992 ] Signing BCT
[   0.1003 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.1004 ] Assuming zero filled SBK key
[   0.1020 ] Sha saved in br_bct_BR.sha
[   0.1022 ] Warning: pub_key.key is not found
[   0.1011 ] Updating BCT with signature
[   0.1013 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   0.1015 ] Offset :4608 Len :3584
[   0.1018 ] Generating SHA2 Hash
[   0.1029 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   0.1029 ] Assuming zero filled SBK key
[   0.1030 ] Assuming zero filled SBK key
[   0.1044 ] Sha saved in br_bct_BR.sha
[   0.1035 ] Updating BCT with SHA2 Hash
[   0.1037 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   0.1039 ] Offset :4608 Len :3584
[   0.1042 ] Offset :68 Len :8124
[   0.1043 ] Generating coldboot mb1-bct
[   0.1046 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.1048 ] MB1-BCT version: 0.13
[   0.1061 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.1063 ] Added Platform Config 9 data with size :- 100
[   0.1063 ]
[   0.1063 ] Updating mb1-bct with firmware information
[   0.1066 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.1074 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   0.1077 ] Generating SHA2 Hash for mb1bct
[   0.1095 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[   0.1102 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[   0.1094 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   0.1096 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   0.1113 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.1114 ] Assuming zero filled SBK key
[   0.1124 ] Warning: pub_key.key is not found
[   0.1116 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.1123 ] Generating recovery mb1-bct
[   0.1126 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.1128 ] MB1-BCT version: 0.13
[   0.1141 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.1142 ] Added Platform Config 9 data with size :- 100
[   0.1142 ]
[   0.1142 ] Updating mb1-bct with firmware information
[   0.1144 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.1152 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[   0.1155 ] Generating SHA2 Hash for mb1bct
[   0.1173 ] Sha saved in mb1_bct_MB1_aligned.sha
[   0.1180 ] Sha saved in mb1_bct_MB1.sha
[   0.1173 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   0.1175 ] adding BCH for mb1_bct_MB1_aligned.bct
[   0.1191 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.1192 ] Assuming zero filled SBK key
[   0.1202 ] Warning: pub_key.key is not found
[   0.1195 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.1201 ] Info: Skip generating mem_bct because sdram_config is not defined
[   0.1201 ] Copying signatures
[   0.1203 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.1231 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   0.1232 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   0.1232 ] Boot Rom communication
[   0.1235 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   0.1237 ] BR_CID: 0xE9012344705DD4456400000001028280
[   0.2181 ] Sending bct_br
[   0.2849 ] Sending mb1
[   0.2856 ] ERROR: might be timeout in USB write.
Error: Return value 3
Command tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   0.2912 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.2932 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.2940 ] Retrieving board information
[   0.2946 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails chip chip_info.bin
[   0.2951 ] Retrieving EEPROM data
[   0.2953 ] tegrarcm_v2 --oem platformdetails eeprom cvm /opt/nvidia/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23 0
[   0.2962 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.2971 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.2974 ] Dumping customer Info
[   0.2979 ] tegrarcm_v2 --chip 0x23 0 --oem dump bct tmp.bct
[   0.2986 ] tegrabct_v2 --brbct tmp.bct --chip 0x23 0 --custinfo /opt/nvidia/Linux_for_Tegra/bootloader/custinfo_out.bin
[   0.2990 ] File tmp.bct open failed
[   0.2992 ] Error: try getting custinfo fail. Moving on
[   0.2992 ] Rebooting to recovery mode
[   0.2997 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[   0.3002 ] Rebooting to recovery mode
[   0.3004 ] tegrarcm_v2 --chip 0x23 0 --reboot recovery
Board ID(3767) version(300) sku(0005) revision(K.2)
Chip SKU(00:00:00:D5) ramcode(00:00:00:02) fuselevel(fuselevel_production) board_FAB(300)
Copy /opt/nvidia/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0005-nv.dtb to /opt/nvidia/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0005-nv.dtb.rec
Generated UUID fbddd377-a337-4865-9210-aa65293e1512 for mounting root APP_ext partition.
Generated UUID b31a0901-15e1-4010-8a0c-8721c5f7e33c for mounting root APP_ext_enc partition.
Generated UUID 21c09334-0262-41a9-bb5c-79efab797400 for mounting boot APP_ext partition.
copying bctfile(/opt/nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-p3767-0001-sdram-l4t.dts)... done.
copying minratchet_config(/opt/nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-ratchet-p3767-0000.dts)... done.
copying pinmux_config(/opt/nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi)... done.
copying gpioint_config(/opt/nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-gpioint-p3767-0000.dts)... done.
copying pmic_config(/opt/nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-pmic-p3767-0000-a02.dts)... done.
copying pmc_config(/opt/nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi)... done.
copying deviceprod_config(/opt/nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-cprod-p3767-0000.dts)... done.
copying prod_config(/opt/nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-prod-p3767-0000.dts)... done.
copying scr_config(/opt/nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb2-bct-scr-p3767-0000.dts)... done.
copying wb0sdram(/opt/nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-p3767-0001-wb0sdram-l4t.dts)... done.
copying bootrom_config(/opt/nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-reset-p3767-0000.dts)... done.
Existing uphylane_config(/opt/nvidia/Linux_for_Tegra/bootloader/tegra234-mb1-bct-uphylane-si.dtsi) reused.
copying dev_params(/opt/nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct-p3767-0000-l4t.dts)... done.
copying dev_params_b(/opt/nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct_b-p3767-0000-l4t.dts)... done.
copying mb2bct_cfg(/opt/nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb2-bct-misc-p3767-0000.dts)... done.
Existing pscfwfile(/opt/nvidia/Linux_for_Tegra/bootloader/pscfw_t234_prod.bin) reused.
Existing pscbl1file(/opt/nvidia/Linux_for_Tegra/bootloader/psc_bl1_t234_prod.bin) reused.
Existing mtsmcefile(/opt/nvidia/Linux_for_Tegra/bootloader/mce_flash_o10_cr_prod.bin) reused.
Existing tscfwfile(/opt/nvidia/Linux_for_Tegra/bootloader/tsec_t234.bin) reused.
Existing mb2applet(/opt/nvidia/Linux_for_Tegra/bootloader/applet_t234.bin) reused.
Using UUID 2e3e4ffa-0a35-42a1-8128-2d8e6da0ae39 for mounting UDA_ext partition.
Making user_data_encrypted.img_ext...
	Sync'ing user_data_encrypted.img_ext ... done.
	Converting RAW image to Sparse image... done.
user_data_encrypted.img_ext built successfully.
Existing bootloader(/opt/nvidia/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
copying initrd(/opt/nvidia/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
prepare_luks_initrd: Begin to copy binaries into initrd
53899 blocks
install: target '' is not a directory: No such file or directory
72020 blocks
prepare_luks_initrd: Finish copying binaries into initrd
done.
bl is uefi
Making Boot image... done.
Not signing of boot.img
Making recovery ramdisk for recovery image...
Re-generating recovery ramdisk for recovery image...
/opt/nvidia/Linux_for_Tegra/bootloader/ramdisk_tmp /opt/nvidia/Linux_for_Tegra/bootloader /opt/nvidia/Linux_for_Tegra
53899 blocks
gzip: /opt/nvidia/Linux_for_Tegra/kernel/Image: not in gzip format
_BASE_KERNEL_VERSION=5.15.136-tegra
77459 blocks
77459 blocks
95581 blocks
Making Recovery image...
copying recdtbfile(/opt/nvidia/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0005-nv.dtb.rec)... done.
20+0 records in
20+0 records out
20 bytes copied, 0.000155777 s, 128 kB/s
Existing sosfile(/opt/nvidia/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing tegraboot(/opt/nvidia/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing cpu_bootloader(/opt/nvidia/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing mb2blfile(/opt/nvidia/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing xusbfile(/opt/nvidia/Linux_for_Tegra/bootloader/xusb_t234_prod.bin) reused.
Existing pvafile(/opt/nvidia/Linux_for_Tegra/bootloader/nvpva_020.fw) reused.
Existing dcefile(/opt/nvidia/Linux_for_Tegra/bootloader/display-t234-dce.bin) reused.
Existing nvdecfile(/opt/nvidia/Linux_for_Tegra/bootloader/nvdec_t234_prod.fw) reused.
Existing psc_rf(/opt/nvidia/Linux_for_Tegra/bootloader/psc_rf_t234_prod.bin) reused.
Existing mb2_rf(/opt/nvidia/Linux_for_Tegra/bootloader/mb2rf_t234.bin) reused.
Existing mb1file(/opt/nvidia/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing bpffile(/opt/nvidia/Linux_for_Tegra/bootloader/bpmp_t234-TE950M-A1_prod.bin) reused.
copying bpfdtbfile(/opt/nvidia/Linux_for_Tegra/bootloader/generic/tegra234-bpmp-3767-0003-3509-a02.dtb)... done.
Existing camerafw(/opt/nvidia/Linux_for_Tegra/bootloader/camera-rtcpu-t234-rce.img) reused.
Existing apefile(/opt/nvidia/Linux_for_Tegra/bootloader/adsp-fw.bin) reused.
Existing spefile(/opt/nvidia/Linux_for_Tegra/bootloader/spe_t234.bin) reused.
Existing wb0boot(/opt/nvidia/Linux_for_Tegra/bootloader/sc7_t234_prod.bin) reused.
Existing tosfile(/opt/nvidia/Linux_for_Tegra/bootloader/tos-optee_t234.img) reused.
Existing eksfile(/opt/nvidia/Linux_for_Tegra/bootloader/eks_t234.img) reused.
copying dtbfile(/opt/nvidia/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0005-nv.dtb)... done.
Copying nv_boot_control.conf to rootfs
	populating kernel to rootfs... done.
	populating initrd to rootfs... done.
	populating kernel_tegra234-p3768-0000+p3767-0005-nv.dtb to rootfs... done.
Making system_boot.img...
	populating bootfs from /opt/nvidia/Linux_for_Tegra/rootfs/boot ... done.
	populating extlinux/extlinux.conf ... done.
ln: failed to create symbolic link './boot': File exists
ln: failed to create symbolic link './kernel_tegra234-p3768-0000+p3767-0005-nv.dtb': File exists
	Sync'ing system_boot.img ... done.
system_boot.img built successfully.
Making system_root_encrypted.img_ext ...
	populating rootfs from /opt/nvidia/Linux_for_Tegra/rootfs ... done.
	Sync'ing system_root_encrypted.img_ext ... done.
system_root_encrypted.img_ext built successfully.
Not signing of kernel-dtb
Existing tbcfile(/opt/nvidia/Linux_for_Tegra/bootloader/uefi_jetson.bin) reused.
131072+0 records in
131072+0 records out
67108864 bytes (67 MB, 64 MiB) copied, 0.557829 s, 120 MB/s
	Sync'ing esp.img ... done.
copying tbcdtbfile(/opt/nvidia/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0005-nv.dtb)... done.
copying cfgfile(/opt/nvidia/Linux_for_Tegra/tools/kernel_flash/flash_l4t_t234_nvme_rootfs_enc.xml) to flash.xml... done.
Existing flashapp(/opt/nvidia/Linux_for_Tegra/bootloader/tegraflash.py) reused.
copying overlay_dtb(/opt/nvidia/Linux_for_Tegra/kernel/dtb/L4TConfiguration.dtbo)... done.
copying overlay_dtb(/opt/nvidia/Linux_for_Tegra/kernel/dtb/tegra234-carveouts.dtbo)... done.
copying overlay_dtb(/opt/nvidia/Linux_for_Tegra/kernel/dtb/tegra-optee.dtbo)... done.
copying overlay_dtb(/opt/nvidia/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0000-dynamic.dtbo)... done.
/opt/nvidia/Linux_for_Tegra/bootloader/L4TConfiguration_updated.dts: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
/opt/nvidia/Linux_for_Tegra/bootloader/L4TConfiguration.dtbo: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
./tegraflash.py --bl uefi_jetson_with_dtb.bin --odmdata gbe-uphy-config-8,hsstp-lane-map-3,hsio-uphy-config-0 --overlay_dtb L4TConfiguration.dtbo,tegra234-carveouts.dtbo,tegra-optee.dtbo,tegra234-p3768-0000+p3767-0000-dynamic.dtbo, --bldtb tegra234-p3768-0000+p3767-0005-nv.dtb --applet mb1_t234_prod.bin --cmd "sign" --cfg flash.xml --chip "0x23" --concat_cpubl_bldtb --cpubl uefi_jetson.bin --minratchet_config tegra234-mb1-bct-ratchet-p3767-0000.dts --device_config tegra234-mb1-bct-device-p3767-0000.dts --misc_config tegra234-mb1-bct-misc-p3767-0000.dts --pinmux_config tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi --gpioint_config tegra234-mb1-bct-gpioint-p3767-0000.dts --pmic_config tegra234-mb1-bct-pmic-p3767-0000-a02.dts --pmc_config tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi --deviceprod_config tegra234-mb1-bct-cprod-p3767-0000.dts --prod_config tegra234-mb1-bct-prod-p3767-0000.dts --scr_config tegra234-mb2-bct-scr-p3767-0000.dts --wb0sdram_config tegra234-p3767-0001-wb0sdram-l4t.dts --br_cmd_config tegra234-mb1-bct-reset-p3767-0000.dts --uphy tegra234-mb1-bct-uphylane-si.dtsi --dev_params tegra234-br-bct-p3767-0000-l4t.dts,tegra234-br-bct_b-p3767-0000-l4t.dts --mb2bct_cfg tegra234-mb2-bct-misc-p3767-0000.dts --bins "psc_fw pscfw_t234_prod.bin; mts_mce mce_flash_o10_cr_prod.bin; tsec_fw tsec_t234.bin; mb2_applet applet_t234.bin; mb2_bootloader mb2_t234.bin; xusb_fw xusb_t234_prod.bin; pva_fw nvpva_020.fw; dce_fw display-t234-dce.bin; nvdec nvdec_t234_prod.fw; bpmp_fw bpmp_t234-TE950M-A1_prod.bin; bpmp_fw_dtb tegra234-bpmp-3767-0003-3509-a02.dtb; rce_fw camera-rtcpu-t234-rce.img; ape_fw adsp-fw.bin; spe_fw spe_t234.bin; tos tos-optee_t234.img; eks eks_t234.img" --sdram_config tegra234-p3767-0001-sdram-l4t.dts --cust_info custinfo_out.bin --external_device --boot_chain A
version 1.0.0
[   0.0409 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0410 ] Assuming zero filled SBK key
[   0.0398 ] Parsing partition layout
[   0.0405 ] tegraparser_v2 --pt flash.xml.tmp
[   0.0807 ] /usr/bin/python3 dtbcheck.py -c t234 -o tegra234-bpmp-3767-0003-3509-a02_with_odm.dtb tegra234-bpmp-3767-0003-3509-a02_with_odm_tmp.dtb
[   0.3349 ] Concatenating L4TConfiguration.dtbo,tegra234-carveouts.dtbo,tegra-optee.dtbo,tegra234-p3768-0000+p3767-0000-dynamic.dtbo to tegra234-p3768-0000+p3767-0005-nv_with_odm_overlay.dtb.updated
[   0.3352 ] Concatenating bl dtb to cpubl binary
[   0.3372 ] Kernel DTB used: kernel_tegra234-p3768-0000+p3767-0005-nv.dtb
[   0.3372 ] Parsing partition layout
[   0.3379 ] tegraparser_v2 --pt flash.xml.tmp
[   0.3385 ] Creating list of images to be signed
[   0.3389 ] Generating ratchet blob
[   0.3389 ] Pre-processing config: tegra234-mb1-bct-reset-p3767-0000.dts
[   0.3569 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[   0.3624 ] Pre-processing config: tegra234-mb1-bct-cprod-p3767-0000.dts
[   0.3674 ] Pre-processing config: tegra234-mb1-bct-gpioint-p3767-0000.dts
[   0.3725 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[   0.3821 ] Pre-processing config: tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi
[   0.3920 ] Pre-processing config: tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi
[   0.3970 ] Pre-processing config: tegra234-mb1-bct-pmic-p3767-0000-a02.dts
[   0.4022 ] Pre-processing config: tegra234-mb1-bct-prod-p3767-0000.dts
[   0.4073 ] Pre-processing config: tegra234-mb2-bct-scr-p3767-0000.dts
[   0.6424 ] Pre-processing config: tegra234-p3767-0001-sdram-l4t.dts
[   1.5048 ] Pre-processing config: tegra234-mb1-bct-uphylane-si.dtsi
[   1.5197 ] Pre-processing config: tegra234-p3767-0001-wb0sdram-l4t.dts
[   2.3837 ] Pre-processing config: tegra234-mb1-bct-ratchet-p3767-0000.dts
[   2.3986 ] Generating coldboot mb1-bct
[   2.3990 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3767-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3767-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[   2.3994 ] MB1-BCT version: 0.13
[   2.4006 ] Parsing config file :tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb
[   2.4008 ] Added Platform Config 0 data with size :- 2416
[   2.4023 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb
[   2.4025 ] WARNING: unknown node 'g2'
[   2.4026 ] WARNING: unknown node 'g9'
[   2.4027 ] WARNING: unknown node 'g9'
[   2.4029 ] Added Platform Config 2 data with size :- 24
[   2.4029 ]
[   2.4029 ] Parsing config file :tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb
[   2.4029 ] Added Platform Config 4 data with size :- 288
[   2.4029 ]
[   2.4029 ] Parsing config file :tegra234-mb1-bct-reset-p3767-0000_cpp.dtb
[   2.4029 ] Added Platform Config 3 data with size :- 52
[   2.4029 ]
[   2.4029 ] Parsing config file :tegra234-mb1-bct-prod-p3767-0000_cpp.dtb
[   2.4029 ] WARNING: unknown property 'major'
[   2.4029 ] WARNING: unknown property 'minor'
[   2.4029 ] Added Platform Config 5 data with size :- 512
[   2.4029 ]
[   2.4029 ] Parsing config file :tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb
[   2.4029 ] Added Platform Config 7 data with size :- 380
[   2.4029 ]
[   2.4029 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[   2.4029 ] Added Platform Config 8 data with size :- 24
[   2.4029 ]
[   2.4029 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   2.4029 ] Added Platform Config 9 data with size :- 100
[   2.4029 ]
[   2.4029 ] Parsing config file :tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[   2.4029 ] ModuleCount 0 NumProdNames 0
[   2.4029 ] Added Platform Config 6 data with size :- 16
[   2.4029 ]
[   2.4029 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[   2.4029 ]
[   2.4029 ] Updating mb1-bct with firmware information
[   2.4033 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[   2.4043 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   2.4046 ] Generating SHA2 Hash for mb1bct
[   2.4068 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[   2.4076 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[   2.4065 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   2.4067 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   2.4089 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.4090 ] Assuming zero filled SBK key
[   2.4101 ] Warning: pub_key.key is not found
[   2.4092 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   2.4098 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[   2.4103 ] Filling MB1 storage info
[   2.4103 ] Parsing dev params for multi chains
[   2.4155 ] Generating br-bct
[   2.4157 ] Updating dev and MSS params in BR BCT
[   2.4157 ] tegrabct_v2 --dev_param tegra234-br-bct-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   2.5248 ] Updating bl info
[   2.5254 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[   2.5419 ] Generating br-bct
[   2.5424 ] Updating dev and MSS params in BR BCT
[   2.5424 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   2.6498 ] Updating bl info
[   2.6505 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[   2.6511 ] Generating signatures
[   2.6525 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.6526 ] Assuming zero filled SBK key
[   2.6528 ] Warning: pub_key.key is not found
[   2.6515 ] Parsing dev params for multi chains
[   2.6515 ] Generating br-bct
[   2.6519 ] Updating dev and MSS params in BR BCT
[   2.6519 ] tegrabct_v2 --dev_param tegra234-br-bct-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   2.7173 ] Updating customer data section
[   2.7179 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[   2.7186 ] Updating bl info
[   2.7190 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   2.7196 ] Generating SHA2 Hash
[   2.7219 ] Sha saved in br_bct_BR.sha
[   2.7206 ] Get Signed section of bct
[   2.7210 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   2.7214 ] Signing BCT
[   2.7228 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.7229 ] Assuming zero filled SBK key
[   2.7247 ] Sha saved in br_bct_BR.sha
[   2.7248 ] Warning: pub_key.key is not found
[   2.7235 ] Updating BCT with signature
[   2.7238 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   2.7240 ] Offset :4608 Len :3584
[   2.7244 ] Generating SHA2 Hash
[   2.7257 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   2.7258 ] Assuming zero filled SBK key
[   2.7275 ] Sha saved in br_bct_BR.sha
[   2.7263 ] Updating BCT with SHA2 Hash
[   2.7267 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   2.7268 ] Offset :4608 Len :3584
[   2.7271 ] Offset :68 Len :8124
[   2.7272 ] Generating br-bct
[   2.7275 ] Updating dev and MSS params in BR BCT
[   2.7275 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   2.8363 ] Updating customer data section
[   2.8372 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[   2.8378 ] Updating bl info
[   2.8384 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   2.8389 ] Generating SHA2 Hash
[   2.8413 ] Sha saved in br_bct_BR.sha
[   2.8401 ] Get Signed section of bct
[   2.8404 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   2.8409 ] Signing BCT
[   2.8423 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.8424 ] Assuming zero filled SBK key
[   2.8447 ] Sha saved in br_bct_BR.sha
[   2.8449 ] Warning: pub_key.key is not found
[   2.8435 ] Updating BCT with signature
[   2.8439 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   2.8441 ] Offset :4608 Len :3584
[   2.8444 ] Generating SHA2 Hash
[   2.8458 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   2.8458 ] Assuming zero filled SBK key
[   2.8482 ] Sha saved in br_bct_BR.sha
[   2.8470 ] Updating BCT with SHA2 Hash
[   2.8473 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   2.8476 ] Offset :4608 Len :3584
[   2.8478 ] Offset :68 Len :8124
[   2.8480 ] Generating coldboot mb1-bct
[   2.8483 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3767-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3767-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[   2.8486 ] MB1-BCT version: 0.13
[   2.8498 ] Parsing config file :tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb
[   2.8500 ] Added Platform Config 0 data with size :- 2416
[   2.8516 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb
[   2.8518 ] WARNING: unknown node 'g2'
[   2.8519 ] WARNING: unknown node 'g9'
[   2.8520 ] WARNING: unknown node 'g9'
[   2.8520 ] Added Platform Config 2 data with size :- 24
[   2.8520 ]
[   2.8520 ] Parsing config file :tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb
[   2.8520 ] Added Platform Config 4 data with size :- 288
[   2.8520 ]
[   2.8520 ] Parsing config file :tegra234-mb1-bct-reset-p3767-0000_cpp.dtb
[   2.8520 ] Added Platform Config 3 data with size :- 52
[   2.8520 ]
[   2.8520 ] Parsing config file :tegra234-mb1-bct-prod-p3767-0000_cpp.dtb
[   2.8520 ] WARNING: unknown property 'major'
[   2.8520 ] WARNING: unknown property 'minor'
[   2.8520 ] Added Platform Config 5 data with size :- 512
[   2.8520 ]
[   2.8520 ] Parsing config file :tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb
[   2.8520 ] Added Platform Config 7 data with size :- 380
[   2.8520 ]
[   2.8520 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[   2.8520 ] Added Platform Config 8 data with size :- 24
[   2.8520 ]
[   2.8520 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   2.8520 ] Added Platform Config 9 data with size :- 100
[   2.8520 ]
[   2.8520 ] Parsing config file :tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[   2.8520 ] ModuleCount 0 NumProdNames 0
[   2.8520 ] Added Platform Config 6 data with size :- 16
[   2.8520 ]
[   2.8520 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[   2.8520 ]
[   2.8520 ] Updating mb1-bct with firmware information
[   2.8523 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[   2.8536 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   2.8539 ] Generating SHA2 Hash for mb1bct
[   2.8560 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[   2.8567 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[   2.8556 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   2.8558 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   2.8578 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.8579 ] Assuming zero filled SBK key
[   2.8588 ] Warning: pub_key.key is not found
[   2.8579 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   2.8585 ] Generating recovery mb1-bct
[   2.8588 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3767-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3767-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[   2.8590 ] MB1-BCT version: 0.13
[   2.8602 ] Parsing config file :tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb
[   2.8604 ] Added Platform Config 0 data with size :- 2416
[   2.8619 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb
[   2.8621 ] WARNING: unknown node 'g2'
[   2.8622 ] WARNING: unknown node 'g2'
[   2.8623 ] WARNING: unknown node 'g9'
[   2.8624 ] Added Platform Config 2 data with size :- 24
[   2.8624 ]
[   2.8624 ] Parsing config file :tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb
[   2.8624 ] Added Platform Config 4 data with size :- 288
[   2.8624 ]
[   2.8624 ] Parsing config file :tegra234-mb1-bct-reset-p3767-0000_cpp.dtb
[   2.8624 ] Added Platform Config 3 data with size :- 52
[   2.8624 ]
[   2.8624 ] Parsing config file :tegra234-mb1-bct-prod-p3767-0000_cpp.dtb
[   2.8624 ] WARNING: unknown property 'major'
[   2.8624 ] WARNING: unknown property 'minor'
[   2.8624 ] Added Platform Config 5 data with size :- 512
[   2.8624 ]
[   2.8624 ] Parsing config file :tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb
[   2.8624 ] Added Platform Config 7 data with size :- 380
[   2.8624 ]
[   2.8624 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[   2.8624 ] Added Platform Config 8 data with size :- 24
[   2.8624 ]
[   2.8624 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   2.8624 ] Added Platform Config 9 data with size :- 100
[   2.8624 ]
[   2.8624 ] Parsing config file :tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[   2.8624 ] ModuleCount 0 NumProdNames 0
[   2.8624 ] Added Platform Config 6 data with size :- 16
[   2.8624 ]
[   2.8624 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[   2.8624 ]
[   2.8624 ] Updating mb1-bct with firmware information
[   2.8627 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo flash.xml.bin
[   2.8634 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[   2.8637 ] Generating SHA2 Hash for mb1bct
[   2.8658 ] Sha saved in mb1_bct_MB1_aligned.sha
[   2.8665 ] Sha saved in mb1_bct_MB1.sha
[   2.8654 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   2.8656 ] adding BCH for mb1_bct_MB1_aligned.bct
[   2.8677 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.8677 ] Assuming zero filled SBK key
[   2.8688 ] Warning: pub_key.key is not found
[   2.8677 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   2.8683 ] Generating coldboot mem-bct
[   2.8686 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --membct tegra234-p3767-0001-sdram-l4t_cpp_1.bct tegra234-p3767-0001-sdram-l4t_cpp_2.bct tegra234-p3767-0001-sdram-l4t_cpp_3.bct tegra234-p3767-0001-sdram-l4t_cpp_4.bct
[   2.8688 ]  packing sdram params with Wb0 file tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb
[   2.9785 ] Packing sdram param for instance[0]
[   2.9786 ] Packing sdram param for instance[1]
[   2.9787 ] Packing sdram param for instance[2]
[   2.9788 ] Packing sdram param for instance[3]
[   2.9789 ] Packing sdram param for instance[4]
[   2.9790 ] Packing sdram param for instance[5]
[   2.9791 ] Packing sdram param for instance[6]
[   2.9792 ] Packing sdram param for instance[7]
[   2.9793 ] Packing sdram param for instance[8]
[   2.9794 ] Packing sdram param for instance[9]
[   2.9794 ] Packing sdram param for instance[10]
[   2.9795 ] Packing sdram param for instance[11]
[   2.9796 ] Packing sdram param for instance[12]
[   2.9797 ] Packing sdram param for instance[13]
[   2.9798 ] Packing sdram param for instance[14]
[   2.9799 ] Packing sdram param for instance[15]
[   3.0870 ] Getting sector size from pt
[   3.0876 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[   3.0881 ] BlockSize read from layout is 0x200
[   3.0885 ] tegrahost_v2 --chip 0x23 0 --blocksize 512 --magicid MEMB --addsigheader_multi tegra234-p3767-0001-sdram-l4t_cpp_1.bct tegra234-p3767-0001-sdram-l4t_cpp_2.bct tegra234-p3767-0001-sdram-l4t_cpp_3.bct tegra234-p3767-0001-sdram-l4t_cpp_4.bct
[   3.0888 ] Binary 0 length is 58752
[   3.0890 ] Binary 0 align length is 58880
[   3.0896 ] Binary 1 length is 58752
[   3.0896 ] Binary 1 align length is 58880
[   3.0902 ] Binary 2 length is 58752
[   3.0902 ] Binary 2 align length is 58880
[   3.0908 ] Binary 3 length is 58752
[   3.0909 ] Binary 3 align length is 58880
[   3.0914 ] Buffer length is 235520
[   3.0915 ] adding BCH for tegra234-p3767-0001-sdram-l4t_cpp_1.bct
[   3.0917 ] new length is 243712
[   3.0924 ] tegrahost_v2 --chip 0x23 0 --align mem_coldboot_aligned.bct
[   3.0930 ] tegrahost_v2 --chip 0x23 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_coldboot_aligned.bct zerosbk
[   3.0932 ] Header already present for mem_coldboot_aligned.bct
[   3.0952 ] tegrasign_v3.py --key None --list mem_coldboot_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   3.0953 ] Assuming zero filled SBK key
[   3.0965 ] Warning: pub_key.key is not found
[   3.0955 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_coldboot_aligned_sigheader.bct.encrypt mem_coldboot_aligned_sigheader.bct.hash zerosbk
[   3.0964 ] Generating recovery mem-bct
[   3.0967 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --membct tegra234-p3767-0001-sdram-l4t_cpp_1.bct tegra234-p3767-0001-sdram-l4t_cpp_2.bct tegra234-p3767-0001-sdram-l4t_cpp_3.bct tegra234-p3767-0001-sdram-l4t_cpp_4.bct
[   3.0969 ]  packing sdram params with Wb0 file tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb
[   3.2054 ] Packing sdram param for instance[0]
[   3.2055 ] Packing sdram param for instance[1]
[   3.2056 ] Packing sdram param for instance[2]
[   3.2057 ] Packing sdram param for instance[3]
[   3.2058 ] Packing sdram param for instance[4]
[   3.2059 ] Packing sdram param for instance[5]
[   3.2060 ] Packing sdram param for instance[6]
[   3.2061 ] Packing sdram param for instance[7]
[   3.2062 ] Packing sdram param for instance[8]
[   3.2063 ] Packing sdram param for instance[9]
[   3.2064 ] Packing sdram param for instance[10]
[   3.2065 ] Packing sdram param for instance[11]
[   3.2066 ] Packing sdram param for instance[12]
[   3.2067 ] Packing sdram param for instance[13]
[   3.2068 ] Packing sdram param for instance[14]
[   3.2069 ] Packing sdram param for instance[15]
[   3.3136 ] Reading ramcode from backup chip_info.bin file
[   3.3216 ] RAMCODE Read from Device: 2
[   3.3216 ] Using ramcode 0
[   3.3216 ] Disabled BPMP dtb trim, using default dtb
[   3.3216 ]
[   3.3226 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_aligned.bct
[   3.3234 ] tegrahost_v2 --chip 0x23 0 --magicid MEM0 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_aligned.bct zerosbk
[   3.3238 ] adding BCH for mem_rcm_aligned.bct
[   3.3269 ] tegrasign_v3.py --key None --list mem_rcm_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   3.3270 ] Assuming zero filled SBK key
[   3.3284 ] Warning: pub_key.key is not found
[   3.3274 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_aligned_sigheader.bct.encrypt mem_rcm_aligned_sigheader.bct.hash zerosbk
[   3.3280 ] Copying signatures
[   3.3284 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[   3.3289 ] tegraparser_v2 --generategpt --pt flash.xml.bin
[   3.3291 ] gpt_primary_9_0.bin:
[   3.3294 ] partition_id	partition_name			      StartingLba	EndingLba
[   3.3296 ]            1	APP                                 	 3050048	 3869247
[   3.3297 ]            2	APP_ENC                             	 3869248	466520639
[   3.3299 ]            3	A_kernel                            	      40	  262183
[   3.3301 ]            4	A_kernel-dtb                        	  262184	  263719
[   3.3303 ]            5	A_reserved_on_user                  	  263720	  328487
[   3.3305 ]            6	B_kernel                            	  328488	  590631
[   3.3306 ]            7	B_kernel-dtb                        	  590632	  592167
[   3.3307 ]            8	B_reserved_on_user                  	  592168	  656935
[   3.3307 ]            9	recovery                            	  656936	  820775
[   3.3307 ]           10	recovery-dtb                        	  820776	  821799
[   3.3307 ]           11	esp                                 	  821800	  952871
[   3.3307 ]           12	recovery_alt                        	  952872	 1116711
[   3.3307 ]           13	recovery-dtb_alt                    	 1116712	 1117735
[   3.3307 ]           14	esp_alt                             	 1117736	 1248807
[   3.3307 ]           15	UDA                                 	 1248832	 2068031
[   3.3307 ]           16	reserved                            	 2068032	 3050047
[   3.3307 ] gpt_secondary_9_0.bin:
[   3.3307 ] partition_id	partition_name			      StartingLba	EndingLba
[   3.3307 ]            1	APP                                 	 3050048	 3869247
[   3.3307 ]            2	APP_ENC                             	 3869248	466520639
[   3.3307 ]            3	A_kernel                            	      40	  262183
[   3.3307 ]            4	A_kernel-dtb                        	  262184	  263719
[   3.3307 ]            5	A_reserved_on_user                  	  263720	  328487
[   3.3308 ]            6	B_kernel                            	  328488	  590631
[   3.3308 ]            7	B_kernel-dtb                        	  590632	  592167
[   3.3308 ]            8	B_reserved_on_user                  	  592168	  656935
[   3.3308 ]            9	recovery                            	  656936	  820775
[   3.3308 ]           10	recovery-dtb                        	  820776	  821799
[   3.3308 ]           11	esp                                 	  821800	  952871
[   3.3308 ]           12	recovery_alt                        	  952872	 1116711
[   3.3308 ]           13	recovery-dtb_alt                    	 1116712	 1117735
[   3.3308 ]           14	esp_alt                             	 1117736	 1248807
[   3.3308 ]           15	UDA                                 	 1248832	 2068031
[   3.3308 ]           16	reserved                            	 2068032	 3050047
[   3.3308 ]
[   3.3351 ] tegrahost_v2 --chip 0x23 0 --align uefi_jetson_with_dtb_aligned.bin
[   3.3358 ] tegrahost_v2 --chip 0x23 0 --magicid CPBL --ratchet_blob ratchet_blob.bin --appendsigheader uefi_jetson_with_dtb_aligned.bin zerosbk
[   3.3361 ] adding BCH for uefi_jetson_with_dtb_aligned.bin
[   3.4155 ] tegrasign_v3.py --key None --list uefi_jetson_with_dtb_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   3.4157 ] Assuming zero filled SBK key
[   3.4223 ] Warning: pub_key.key is not found
[   3.4215 ] tegrahost_v2 --chip 0x23 0 --updatesigheader uefi_jetson_with_dtb_aligned_sigheader.bin.encrypt uefi_jetson_with_dtb_aligned_sigheader.bin.hash zerosbk
[   3.4258 ] Copying enc\/signed file in /opt/nvidia/Linux_for_Tegra/bootloader/signed
[   3.4259 ] Copying br bct for multi chains
[   3.4260 ] Signed BCT for boot chain A is copied to /opt/nvidia/Linux_for_Tegra/bootloader/signed/br_bct_BR.bct
[   3.4261 ] Signed BCT for boot chain B is copied to /opt/nvidia/Linux_for_Tegra/bootloader/signed/br_bct_b_BR.bct
[   3.4274 ] Copying uefi_jetson_with_dtb_sigheader.bin.encrypt to /opt/nvidia/Linux_for_Tegra/bootloader/signed
[   3.4287 ] Signed file: /opt/nvidia/Linux_for_Tegra/bootloader/signed/uefi_jetson_with_dtb_sigheader.bin.encrypt
[   3.4305 ] tegraparser_v2 --pt flash.xml.bin --generateflashindex /opt/nvidia/Linux_for_Tegra/bootloader/signed/flash.xml.tmp flash.idx
Using bpmp-dtb concatenated with odmdata in blob for t23x
./tegraflash.py --bl uefi_jetson_with_dtb_sigheader.bin.encrypt --bct br_bct_BR.bct --bldtb tegra234-p3768-0000+p3767-0005-nv.dtb --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --cmd "secureflash;reboot"  --cfg secureflash.xml --chip 0x23 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mb1_bin mb1_t234_prod_aligned_sigheader.bin.encrypt --psc_bl1_bin psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt  --bins "psc_fw pscfw_t234_prod_sigheader.bin.encrypt; mts_mce mce_flash_o10_cr_prod_sigheader.bin.encrypt; tsec_fw tsec_t234_sigheader.bin.encrypt; mb2_applet applet_t234_sigheader.bin.encrypt; mb2_bootloader mb2_t234_with_mb2_bct_MB2_sigheader.bin.encrypt; xusb_fw xusb_t234_prod_sigheader.bin.encrypt; pva_fw nvpva_020_sigheader.fw.encrypt; dce_fw display-t234-dce_sigheader.bin.encrypt; nvdec nvdec_t234_prod_sigheader.fw.encrypt; bpmp_fw bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt; bpmp_fw_dtb tegra234-bpmp-3767-0003-3509-a02_with_odm_sigheader.dtb.encrypt; rce_fw camera-rtcpu-t234-rce_sigheader.img.encrypt; ape_fw adsp-fw_sigheader.bin.encrypt; spe_fw spe_t234_sigheader.bin.encrypt; tos tos-optee_t234_sigheader.img.encrypt; eks eks_t234_sigheader.img.encrypt"
saving flash command in flashcmd.txt
*** no-flash flag enabled. Exiting now... ***
User can run above saved command in factory environment without
providing pkc and sbk keys to flash a device
Example:
    $ cd bootloader
    $ sudo bash ./flashcmd.txt
'/opt/nvidia/Linux_for_Tegra/bootloader/signed/flash.idx' -> '/opt/nvidia/Linux_for_Tegra/tools/kernel_flash/images/external/flash.idx'
Flash index file is /opt/nvidia/Linux_for_Tegra/bootloader/signed/flash.idx
Number of lines is 19
max_index=18
Copying /opt/nvidia/Linux_for_Tegra/bootloader/signed/mbr_9_0.bin  /opt/nvidia/Linux_for_Tegra/tools/kernel_flash/images/external/mbr_9_0.bin
'/opt/nvidia/Linux_for_Tegra/bootloader/signed/mbr_9_0.bin' -> '/opt/nvidia/Linux_for_Tegra/tools/kernel_flash/images/external/mbr_9_0.bin'
Copying /opt/nvidia/Linux_for_Tegra/bootloader/signed/gpt_primary_9_0.bin  /opt/nvidia/Linux_for_Tegra/tools/kernel_flash/images/external/gpt_primary_9_0.bin
'/opt/nvidia/Linux_for_Tegra/bootloader/signed/gpt_primary_9_0.bin' -> '/opt/nvidia/Linux_for_Tegra/tools/kernel_flash/images/external/gpt_primary_9_0.bin'
Copying /opt/nvidia/Linux_for_Tegra/bootloader/boot.img  /opt/nvidia/Linux_for_Tegra/tools/kernel_flash/images/external/boot.img
'/opt/nvidia/Linux_for_Tegra/bootloader/boot.img' -> '/opt/nvidia/Linux_for_Tegra/tools/kernel_flash/images/external/boot.img'
Copying /opt/nvidia/Linux_for_Tegra/bootloader/kernel_tegra234-p3768-0000+p3767-0005-nv.dtb  /opt/nvidia/Linux_for_Tegra/tools/kernel_flash/images/external/kernel_tegra234-p3768-0000+p3767-0005-nv.dtb
'/opt/nvidia/Linux_for_Tegra/bootloader/kernel_tegra234-p3768-0000+p3767-0005-nv.dtb' -> '/opt/nvidia/Linux_for_Tegra/tools/kernel_flash/images/external/kernel_tegra234-p3768-0000+p3767-0005-nv.dtb'
Warning: skip writing A_reserved_on_user partition as no image is specified
Warning: skip writing B_reserved_on_user partition as no image is specified
Copying /opt/nvidia/Linux_for_Tegra/bootloader/recovery.img  /opt/nvidia/Linux_for_Tegra/tools/kernel_flash/images/external/recovery.img
'/opt/nvidia/Linux_for_Tegra/bootloader/recovery.img' -> '/opt/nvidia/Linux_for_Tegra/tools/kernel_flash/images/external/recovery.img'
Copying /opt/nvidia/Linux_for_Tegra/bootloader/tegra234-p3768-0000+p3767-0005-nv.dtb.rec  /opt/nvidia/Linux_for_Tegra/tools/kernel_flash/images/external/tegra234-p3768-0000+p3767-0005-nv.dtb.rec
'/opt/nvidia/Linux_for_Tegra/bootloader/tegra234-p3768-0000+p3767-0005-nv.dtb.rec' -> '/opt/nvidia/Linux_for_Tegra/tools/kernel_flash/images/external/tegra234-p3768-0000+p3767-0005-nv.dtb.rec'
Copying /opt/nvidia/Linux_for_Tegra/bootloader/esp.img  /opt/nvidia/Linux_for_Tegra/tools/kernel_flash/images/external/esp.img
'/opt/nvidia/Linux_for_Tegra/bootloader/esp.img' -> '/opt/nvidia/Linux_for_Tegra/tools/kernel_flash/images/external/esp.img'
Warning: skip writing recovery_alt partition as no image is specified
Warning: skip writing recovery-dtb_alt partition as no image is specified
Warning: skip writing esp_alt partition as no image is specified
Copying UDA image into  /opt/nvidia/Linux_for_Tegra/tools/kernel_flash/images/external/user_data_encrypted.img_ext
/opt/nvidia/Linux_for_Tegra/bootloader/user_data_encrypted.img_ext.raw : 14.07%   (419430400 => 59010029 bytes, /opt/nvidia/Linux_for_Tegra/tools/kernel_flash/images/external/user_data_encrypted.img_ext.zst)
Warning: skip writing reserved partition as no image is specified
Copying APP image into  /opt/nvidia/Linux_for_Tegra/tools/kernel_flash/images/external/system_boot.img
Copying APP_ENC image into  /opt/nvidia/Linux_for_Tegra/tools/kernel_flash/images/external/system_root_encrypted.img_ext
/opt/nvidia/Linux_for_Tegra/bootloader/system_root_encrypted.img_ext.raw :  3.76%   (236877512704 => 8912238074 bytes, /opt/nvidia/Linux_for_Tegra/tools/kernel_flash/images/external/system_root_encrypted.img_ext.zst)
Copying /opt/nvidia/Linux_for_Tegra/bootloader/signed/gpt_secondary_9_0.bin  /opt/nvidia/Linux_for_Tegra/tools/kernel_flash/images/external/gpt_secondary_9_0.bin
'/opt/nvidia/Linux_for_Tegra/bootloader/signed/gpt_secondary_9_0.bin' -> '/opt/nvidia/Linux_for_Tegra/tools/kernel_flash/images/external/gpt_secondary_9_0.bin'
Copy flash script to /opt/nvidia/Linux_for_Tegra/tools/kernel_flash/images
'/opt/nvidia/Linux_for_Tegra/tools/kernel_flash/l4t_flash_from_kernel.sh' -> '/opt/nvidia/Linux_for_Tegra/tools/kernel_flash/images/l4t_flash_from_kernel.sh'
Success
# User release: 0.0
ECID is
Cleaning up...
Hi shai.segev,
How did you flash it?
Do you put new NVMe SSD on the original devkit for flashing?
It seems you didn’t specify PKC, SBK key for the fused board.
And, why you add --no-flash here?
Thank you for the response,
Yes, I missed the keys on the second try.
It’s working ok now.
