I am trying to get encrypted rootfs working with an NVME without an SD card.
My commands
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --network usb0 --no-flash --showlogs -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" jetson-orin-nano-devkit internal
sudo ROOTFS_ENC=1 ./tools/kernel_flash/l4t_initrd_flash.sh --showlogs --no-flash --external-device nvme0n1p1 -i ./sym2_t234.key -c ./tools/kernel_flash/flash_l4t_t234_nvme_rootfs_enc.xml -S 60GiB --external-only --append --network usb0 jetson-orin-nano-devkit external
Output
/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh --no-flash --showlogs --no-flash --external-device nvme0n1p1 -i ./sym2_t234.key -c ./tools/kernel_flash/flash_l4t_t234_nvme_rootfs_enc.xml -S 60GiB --external-only --append --network usb0 jetson-orin-nano-devkit external
* Step 1: Generate flash packages *
Create folder to store images to flash
Generate image for external storage devices
Generate images to be flashed
BOOTDEV=external ADDITIONAL_DTB_OVERLAY="" /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/flash.sh --no-flash --sign --external-device -c "./tools/kernel_flash/flash_l4t_t234_nvme_rootfs_enc.xml" -S "60GiB" -i "./sym2_t234.key" jetson-orin-nano-devkit external
# L4T BSP Information:
# R35 , REVISION: 4.1
# User release: 0.0
Change device boot from external to internal
copying emc_fuse_dev_params(/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-diag-boot.dts)... done.
copying device_config(/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-device-p3767-0000.dts)... done.
copying misc_config(/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-misc-p3767-0000.dts)... done.
./tegraflash.py --chip 0x23 --applet "/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3767-0000.dts --misc_config tegra234-mb1-bct-misc-p3767-0000.dts --bins "mb2_applet applet_t234.bin" --cmd "dump eeprom cvm cvm.bin; dump custinfo custinfo_out.bin; reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0129 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.0135 ] File rcm_state open failed
[ 0.0137 ] ERROR: failed to read rcm_state
[ 0.0137 ]
[ 0.0148 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0149 ] Assuming zero filled SBK key
[ 0.0139 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[ 0.0184 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[ 0.0243 ] Parsing partition layout
[ 0.0249 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0258 ] Kernel DTB used: None
[ 0.0258 ] WARNING: dce base dtb is not provided
[ 0.0258 ] Parsing partition layout
[ 0.0264 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0270 ] Creating list of images to be signed
[ 0.0276 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[ 0.0280 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0286 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0288 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0322 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0324 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0356 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0357 ] adding BCH for mb2_t234_aligned.bin
[ 0.0377 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0458 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0459 ] adding BCH for mb2_t234_aligned.bin
[ 0.0557 ] Filling MB1 storage info
[ 0.0557 ] Parsing dev params for multi chains
[ 0.0603 ] Generating br-bct
[ 0.0608 ] Updating dev and MSS params in BR BCT
[ 0.0609 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.0615 ] Updating bl info
[ 0.0620 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[ 0.0624 ] WARNING: boot chain is not completed. set to 0
[ 0.0629 ] Generating signatures
[ 0.0640 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.0642 ] Assuming zero filled SBK key
[ 0.0719 ] Warning: pub_key.key is not found
[ 0.0710 ] Parsing dev params for multi chains
[ 0.0710 ] Generating br-bct
[ 0.0715 ] Updating dev and MSS params in BR BCT
[ 0.0716 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.0722 ] Updating bl info
[ 0.0727 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.0732 ] WARNING: boot chain is not completed. set to 0
[ 0.0737 ] Get Signed section of bct
[ 0.0741 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 0.0747 ] Signing BCT
[ 0.0758 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.0760 ] Assuming zero filled SBK key
[ 0.0776 ] Sha saved in br_bct_BR.sha
[ 0.0778 ] Warning: pub_key.key is not found
[ 0.0768 ] Updating BCT with signature
[ 0.0773 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 0.0777 ] Offset :4608 Len :3584
[ 0.0780 ] Generating SHA2 Hash
[ 0.0791 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 0.0793 ] Assuming zero filled SBK key
[ 0.0813 ] Sha saved in br_bct_BR.sha
[ 0.0804 ] Updating BCT with SHA2 Hash
[ 0.0810 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 0.0815 ] Offset :4608 Len :3584
[ 0.0817 ] Offset :68 Len :8124
[ 0.0818 ] Generating coldboot mb1-bct
[ 0.0823 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.0828 ] MB1-BCT version: 0.10
[ 0.0829 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 0.0831 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 0.0833 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 0.0834 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[ 0.0835 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[ 0.0837 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[ 0.0839 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[ 0.0840 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[ 0.0842 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[ 0.0842 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[ 0.0842 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[ 0.0842 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[ 0.0842 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[ 0.0842 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[ 0.0842 ]
[ 0.0842 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.0842 ] Added Platform Config 9 data with size :- 100
[ 0.0842 ]
[ 0.0842 ] Updating mb1-bct with firmware information
[ 0.0849 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.0864 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 0.0876 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 0.0881 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 0.0898 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.0899 ] Assuming zero filled SBK key
[ 0.0912 ] Warning: pub_key.key is not found
[ 0.0910 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.0920 ] Generating recovery mb1-bct
[ 0.0926 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.0931 ] MB1-BCT version: 0.10
[ 0.0932 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 0.0934 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 0.0936 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 0.0938 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[ 0.0938 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[ 0.0940 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[ 0.0941 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[ 0.0942 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[ 0.0943 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[ 0.0945 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[ 0.0947 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[ 0.0947 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[ 0.0947 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[ 0.0947 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[ 0.0947 ]
[ 0.0947 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.0947 ] Added Platform Config 9 data with size :- 100
[ 0.0947 ]
[ 0.0947 ] Updating mb1-bct with firmware information
[ 0.0954 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.0968 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[ 0.0984 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 0.0990 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 0.1006 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1007 ] Assuming zero filled SBK key
[ 0.1019 ] Warning: pub_key.key is not found
[ 0.1015 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.1031 ] Error: Skip generating mem_bct because sdram_config is not defined
[ 0.1031 ] Copying signatures
[ 0.1038 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.1071 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.1072 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.1072 ] Boot Rom communication
[ 0.1079 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.1084 ] BR_CID: 0x80012344705DE2891C00000019000100
[ 0.1360 ] Sending bct_br
[ 0.1793 ] ERROR: might be timeout in USB write.
Error: Return value 3
Command tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
Reading board information failed.
'/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/flash.idx' -> '/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/flash.idx'
Flash index file is /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/flash.idx
Number of lines is 76
max_index=75
Copying /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/br_bct_BR.bct /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/br_bct_BR.bct
'/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/br_bct_BR.bct' -> '/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/br_bct_BR.bct'
Copying /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/mb1_t234_prod_aligned_sigheader.bin.encrypt /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/mb1_t234_prod_aligned_sigheader.bin.encrypt
'/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/mb1_t234_prod_aligned_sigheader.bin.encrypt' -> '/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/mb1_t234_prod_aligned_sigheader.bin.encrypt'
Copying /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/psc_bl1_t234_prod_aligned_sigheader.bin.encrypt /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/psc_bl1_t234_prod_aligned_sigheader.bin.encrypt
'/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/psc_bl1_t234_prod_aligned_sigheader.bin.encrypt' -> '/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/psc_bl1_t234_prod_aligned_sigheader.bin.encrypt'
Copying /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
'/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt' -> '/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt'
Copying /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/mem_coldboot_sigheader.bct.encrypt /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/mem_coldboot_sigheader.bct.encrypt
'/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/mem_coldboot_sigheader.bct.encrypt' -> '/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/mem_coldboot_sigheader.bct.encrypt'
Warning: skip writing A_tsec-fw partition as no image is specified
Copying /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/nvdec_t234_prod_sigheader.fw.encrypt /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/nvdec_t234_prod_sigheader.fw.encrypt
'/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/nvdec_t234_prod_sigheader.fw.encrypt' -> '/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/nvdec_t234_prod_sigheader.fw.encrypt'
Copying /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt
'/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt' -> '/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt'
Copying /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/xusb_t234_prod_sigheader.bin.encrypt /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/xusb_t234_prod_sigheader.bin.encrypt
'/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/xusb_t234_prod_sigheader.bin.encrypt' -> '/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/xusb_t234_prod_sigheader.bin.encrypt'
Copying /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt
'/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt' -> '/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt'
Copying /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/tegra234-bpmp-3767-0003-3509-a02_with_odm_sigheader.dtb.encrypt /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/tegra234-bpmp-3767-0003-3509-a02_with_odm_sigheader.dtb.encrypt
'/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/tegra234-bpmp-3767-0003-3509-a02_with_odm_sigheader.dtb.encrypt' -> '/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/tegra234-bpmp-3767-0003-3509-a02_with_odm_sigheader.dtb.encrypt'
Copying /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/pscfw_t234_prod_sigheader.bin.encrypt /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/pscfw_t234_prod_sigheader.bin.encrypt
'/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/pscfw_t234_prod_sigheader.bin.encrypt' -> '/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/pscfw_t234_prod_sigheader.bin.encrypt'
Copying /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/mce_flash_o10_cr_prod_sigheader.bin.encrypt /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/mce_flash_o10_cr_prod_sigheader.bin.encrypt
'/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/mce_flash_o10_cr_prod_sigheader.bin.encrypt' -> '/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/mce_flash_o10_cr_prod_sigheader.bin.encrypt'
Copying /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/sc7_t234_prod_sigheader.bin.encrypt /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/sc7_t234_prod_sigheader.bin.encrypt
'/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/sc7_t234_prod_sigheader.bin.encrypt' -> '/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/sc7_t234_prod_sigheader.bin.encrypt'
Copying /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/psc_rf_t234_prod_sigheader.bin.encrypt /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/psc_rf_t234_prod_sigheader.bin.encrypt
'/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/psc_rf_t234_prod_sigheader.bin.encrypt' -> '/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/psc_rf_t234_prod_sigheader.bin.encrypt'
Copying /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/mb2rf_t234_sigheader.bin.encrypt /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/mb2rf_t234_sigheader.bin.encrypt
'/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/mb2rf_t234_sigheader.bin.encrypt' -> '/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/mb2rf_t234_sigheader.bin.encrypt'
Copying /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/uefi_jetson_with_dtb_sigheader.bin.encrypt /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/uefi_jetson_with_dtb_sigheader.bin.encrypt
'/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/uefi_jetson_with_dtb_sigheader.bin.encrypt' -> '/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/uefi_jetson_with_dtb_sigheader.bin.encrypt'
Copying /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/tos-optee_t234_sigheader.img.encrypt /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/tos-optee_t234_sigheader.img.encrypt
'/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/tos-optee_t234_sigheader.img.encrypt' -> '/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/tos-optee_t234_sigheader.img.encrypt'
Warning: skip writing A_smm-fw partition as no image is specified
Copying /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/eks_t234_sigheader.img.encrypt /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/eks_t234_sigheader.img.encrypt
'/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/eks_t234_sigheader.img.encrypt' -> '/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/eks_t234_sigheader.img.encrypt'
Copying /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/display-t234-dce_with_kernel_tegra234-p3767-0003-p3768-0000-a0_aligned_blob_w_bin_sigheader.bin.encrypt /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/display-t234-dce_with_kernel_tegra234-p3767-0003-p3768-0000-a0_aligned_blob_w_bin_sigheader.bin.encrypt
'/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/display-t234-dce_with_kernel_tegra234-p3767-0003-p3768-0000-a0_aligned_blob_w_bin_sigheader.bin.encrypt' -> '/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/display-t234-dce_with_kernel_tegra234-p3767-0003-p3768-0000-a0_aligned_blob_w_bin_sigheader.bin.encrypt'
Copying /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/spe_t234_sigheader.bin.encrypt /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/spe_t234_sigheader.bin.encrypt
'/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/spe_t234_sigheader.bin.encrypt' -> '/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/spe_t234_sigheader.bin.encrypt'
Copying /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/camera-rtcpu-t234-rce_sigheader.img.encrypt /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/camera-rtcpu-t234-rce_sigheader.img.encrypt
'/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/camera-rtcpu-t234-rce_sigheader.img.encrypt' -> '/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/camera-rtcpu-t234-rce_sigheader.img.encrypt'
Copying /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/adsp-fw_sigheader.bin.encrypt /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/adsp-fw_sigheader.bin.encrypt
'/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/adsp-fw_sigheader.bin.encrypt' -> '/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/adsp-fw_sigheader.bin.encrypt'
Warning: skip writing A_reserved_on_boot partition as no image is specified
Warning: skip writing B_tsec-fw partition as no image is specified
Warning: skip writing B_smm-fw partition as no image is specified
Warning: skip writing B_reserved_on_boot partition as no image is specified
Warning: skip writing uefi_variables partition as no image is specified
Warning: skip writing uefi_ftw partition as no image is specified
Warning: skip writing worm partition as no image is specified
Copying /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/bct_backup.img /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/bct_backup.img
'/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/bct_backup.img' -> '/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/bct_backup.img'
Warning: skip writing reserved_partition partition as no image is specified
Copying /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/gpt_secondary_3_0.bin /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/gpt_secondary_3_0.bin
'/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/gpt_secondary_3_0.bin' -> '/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/gpt_secondary_3_0.bin'
Copying /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/qspi_bootblob_ver.txt /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/qspi_bootblob_ver.txt
'/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/qspi_bootblob_ver.txt' -> '/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/qspi_bootblob_ver.txt'
Copying /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/mbr_6_0.bin /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/mbr_6_0.bin
'/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/mbr_6_0.bin' -> '/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/mbr_6_0.bin'
Copying /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/gpt_primary_6_0.bin /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/gpt_primary_6_0.bin
'/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/gpt_primary_6_0.bin' -> '/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/gpt_primary_6_0.bin'
Copying /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/boot.img /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/boot.img
'/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/boot.img' -> '/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/boot.img'
Copying /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/kernel_tegra234-p3767-0003-p3768-0000-a0.dtb /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/kernel_tegra234-p3767-0003-p3768-0000-a0.dtb
'/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/kernel_tegra234-p3767-0003-p3768-0000-a0.dtb' -> '/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/kernel_tegra234-p3767-0003-p3768-0000-a0.dtb'
Warning: skip writing A_reserved_on_user partition as no image is specified
Warning: skip writing B_reserved_on_user partition as no image is specified
Copying /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/recovery.img /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/recovery.img
'/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/recovery.img' -> '/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/recovery.img'
Copying /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/tegra234-p3767-0003-p3768-0000-a0.dtb.rec /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/tegra234-p3767-0003-p3768-0000-a0.dtb.rec
'/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/tegra234-p3767-0003-p3768-0000-a0.dtb.rec' -> '/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/tegra234-p3767-0003-p3768-0000-a0.dtb.rec'
Copying /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/esp.img /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/esp.img
'/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/esp.img' -> '/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/esp.img'
Warning: skip writing recovery_alt partition as no image is specified
Warning: skip writing recovery-dtb_alt partition as no image is specified
Warning: skip writing esp_alt partition as no image is specified
Warning: skip writing UDA partition as no image is specified
Warning: skip writing reserved partition as no image is specified
Copying APP image into /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/system.img.raw
tar: Write checkpoint 10000
tar: Write checkpoint 20000
tar: Write checkpoint 30000
tar: Write checkpoint 40000
tar: Write checkpoint 50000
tar: Write checkpoint 60000
tar: Write checkpoint 70000
tar: Write checkpoint 80000
tar: Write checkpoint 90000
tar: Write checkpoint 100000
tar: Write checkpoint 110000
tar: Write checkpoint 120000
tar: Write checkpoint 130000
tar: Write checkpoint 140000
tar: Write checkpoint 150000
tar: Write checkpoint 160000
tar: Write checkpoint 170000
tar: Write checkpoint 180000
tar: Write checkpoint 190000
tar: Write checkpoint 200000
tar: Write checkpoint 210000
tar: Write checkpoint 220000
tar: Write checkpoint 230000
tar: Write checkpoint 240000
tar: Write checkpoint 250000
tar: Write checkpoint 260000
tar: Write checkpoint 270000
tar: Write checkpoint 280000
tar: Write checkpoint 290000
tar: Write checkpoint 300000
tar: Write checkpoint 310000
tar: Write checkpoint 320000
tar: Write checkpoint 330000
tar: Write checkpoint 340000
tar: Write checkpoint 350000
tar: Write checkpoint 360000
tar: Write checkpoint 370000
tar: Write checkpoint 380000
tar: Write checkpoint 390000
tar: Write checkpoint 400000
tar: Write checkpoint 410000
tar: Write checkpoint 420000
tar: Write checkpoint 430000
tar: Write checkpoint 440000
tar: Write checkpoint 450000
tar: Write checkpoint 460000
tar: Write checkpoint 470000
tar: Write checkpoint 480000
tar: Write checkpoint 490000
tar: Write checkpoint 500000
tar: Write checkpoint 510000
tar: Write checkpoint 520000
tar: Write checkpoint 530000
tar: Write checkpoint 540000
tar: Write checkpoint 550000
tar: Write checkpoint 560000
Copying /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/gpt_secondary_6_0.bin /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/gpt_secondary_6_0.bin
'/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/signed/gpt_secondary_6_0.bin' -> '/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/gpt_secondary_6_0.bin'
Copy flash script to /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images
'/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/l4t_flash_from_kernel.sh' -> '/home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/l4t_flash_from_kernel.sh'
Success
* Step 2: Generate rcm boot commandline *
ROOTFS_AB= ROOTFS_ENC= /home/chris/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/flash.sh --no-flash --rcm-boot jetson-orin-nano-devkit mmcblk0p1
# User release: 0.0
version 1.0.0
[ 0.0133 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.0139 ] File rcm_state open failed
[ 0.0141 ] ERROR: failed to read rcm_state
[ 0.0141 ]
[ 0.0160 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0162 ] Assuming zero filled SBK key
[ 0.0145 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[ 0.0218 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[ 0.0281 ] Parsing partition layout
[ 0.0292 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0302 ] Kernel DTB used: None
[ 0.0302 ] WARNING: dce base dtb is not provided
[ 0.0302 ] Parsing partition layout
[ 0.0308 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0314 ] Creating list of images to be signed
[ 0.0322 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[ 0.0328 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0338 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0340 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0373 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0376 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0414 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0417 ] adding BCH for mb2_t234_aligned.bin
[ 0.0437 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0520 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0521 ] adding BCH for mb2_t234_aligned.bin
[ 0.0624 ] Filling MB1 storage info
[ 0.0624 ] Parsing dev params for multi chains
[ 0.0671 ] Generating br-bct
[ 0.0680 ] Updating dev and MSS params in BR BCT
[ 0.0680 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.0688 ] Updating bl info
[ 0.0695 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[ 0.0701 ] WARNING: boot chain is not completed. set to 0
[ 0.0705 ] Generating signatures
[ 0.0723 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.0725 ] Assuming zero filled SBK key
[ 0.0806 ] Warning: pub_key.key is not found
[ 0.0790 ] Parsing dev params for multi chains
[ 0.0791 ] Generating br-bct
[ 0.0796 ] Updating dev and MSS params in BR BCT
[ 0.0796 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.0803 ] Updating bl info
[ 0.0808 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.0813 ] WARNING: boot chain is not completed. set to 0
[ 0.0818 ] Get Signed section of bct
[ 0.0823 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 0.0830 ] Signing BCT
[ 0.0848 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.0849 ] Assuming zero filled SBK key
[ 0.0867 ] Sha saved in br_bct_BR.sha
[ 0.0869 ] Warning: pub_key.key is not found
[ 0.0851 ] Updating BCT with signature
[ 0.0856 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 0.0861 ] Offset :4608 Len :3584
[ 0.0864 ] Generating SHA2 Hash
[ 0.0882 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 0.0883 ] Assuming zero filled SBK key
[ 0.0884 ] Assuming zero filled SBK key
[ 0.0904 ] Sha saved in br_bct_BR.sha
[ 0.0888 ] Updating BCT with SHA2 Hash
[ 0.0895 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 0.0900 ] Offset :4608 Len :3584
[ 0.0901 ] Offset :68 Len :8124
[ 0.0902 ] Generating coldboot mb1-bct
[ 0.0910 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.0915 ] MB1-BCT version: 0.10
[ 0.0916 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 0.0919 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 0.0920 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 0.0922 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[ 0.0924 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[ 0.0925 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[ 0.0927 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[ 0.0929 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[ 0.0929 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[ 0.0929 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[ 0.0929 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[ 0.0929 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[ 0.0929 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[ 0.0929 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[ 0.0929 ]
[ 0.0929 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.0929 ] Added Platform Config 9 data with size :- 100
[ 0.0929 ]
[ 0.0930 ] Updating mb1-bct with firmware information
[ 0.0936 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.0951 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 0.0962 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 0.0967 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 0.0991 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.0992 ] Assuming zero filled SBK key
[ 0.1004 ] Warning: pub_key.key is not found
[ 0.0993 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.1004 ] Generating recovery mb1-bct
[ 0.1009 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.1014 ] MB1-BCT version: 0.10
[ 0.1015 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 0.1018 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 0.1020 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 0.1023 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[ 0.1024 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[ 0.1026 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[ 0.1029 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[ 0.1029 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[ 0.1029 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[ 0.1029 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[ 0.1029 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[ 0.1029 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[ 0.1029 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[ 0.1029 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[ 0.1029 ]
[ 0.1029 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.1029 ] Added Platform Config 9 data with size :- 100
[ 0.1029 ]
[ 0.1030 ] Updating mb1-bct with firmware information
[ 0.1035 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.1052 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[ 0.1063 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 0.1068 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 0.1091 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1093 ] Assuming zero filled SBK key
[ 0.1107 ] Warning: pub_key.key is not found
[ 0.1096 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.1105 ] Error: Skip generating mem_bct because sdram_config is not defined
[ 0.1105 ] Copying signatures
[ 0.1111 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.1142 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.1143 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.1144 ] Boot Rom communication
[ 0.1149 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.1154 ] BR_CID: 0x80012344705DE2891C00000019000100
[ 0.1418 ] Sending bct_br
[ 0.1849 ] ERROR: might be timeout in USB write.
Cleaning up...
I have tried 3 different USB cables and 2 Ubuntu 20.04 machines and 1 Ubuntu 18.04 machine and I always get this same error. Is my input incorrect or is it possible something is wrong with my Jetson Orin Nano Devkit?
