* Step 1: Generate flash packages *
Create folder to store images to flash
Generate image for internal storage devices
Generate images to be flashed
copying emc_fuse_dev_params(/home/folder/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-diag-boot.dts)... done.
copying device_config(/home/folder/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-device-p3767-0000.dts)... done.
copying misc_config(/home/folder/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-misc-p3767-0000.dts)... done.
./tegraflash.py --chip 0x23 --applet "/home/folder/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3767-0000.dts --misc_config tegra234-mb1-bct-misc-p3767-0000.dts --bins "mb2_applet applet_t234.bin" --cmd "dump eeprom cvm cvm.bin; dump custinfo custinfo_out.bin; reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0227 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.0237 ] File rcm_state open failed
[ 0.0240 ] ERROR: failed to read rcm_state
[ 0.0240 ]
[ 0.0260 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0262 ] Assuming zero filled SBK key
[ 0.0246 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[ 0.0321 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[ 0.0446 ] Parsing partition layout
[ 0.0459 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0481 ] Kernel DTB used: None
[ 0.0481 ] WARNING: dce base dtb is not provided
[ 0.0481 ] Parsing partition layout
[ 0.0495 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0517 ] Creating list of images to be signed
[ 0.0536 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[ 0.0550 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0561 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0565 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0618 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0627 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0676 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0681 ] adding BCH for mb2_t234_aligned.bin
[ 0.0710 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0853 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0861 ] adding BCH for mb2_t234_aligned.bin
[ 0.1010 ] Filling MB1 storage info
[ 0.1011 ] Parsing dev params for multi chains
[ 0.1090 ] Generating br-bct
[ 0.1104 ] Updating dev and MSS params in BR BCT
[ 0.1105 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.1124 ] Updating bl info
[ 0.1138 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[ 0.1152 ] WARNING: boot chain is not completed. set to 0
[ 0.1163 ] Generating signatures
[ 0.1182 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1185 ] Assuming zero filled SBK key
[ 0.1336 ] Warning: pub_key.key is not found
[ 0.1321 ] Parsing dev params for multi chains
[ 0.1321 ] Generating br-bct
[ 0.1333 ] Updating dev and MSS params in BR BCT
[ 0.1334 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.1347 ] Updating bl info
[ 0.1358 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.1370 ] WARNING: boot chain is not completed. set to 0
[ 0.1380 ] Get Signed section of bct
[ 0.1392 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 0.1404 ] Signing BCT
[ 0.1423 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1426 ] Assuming zero filled SBK key
[ 0.1465 ] Sha saved in br_bct_BR.sha
[ 0.1471 ] Warning: pub_key.key is not found
[ 0.1453 ] Updating BCT with signature
[ 0.1469 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 0.1486 ] Offset :4608 Len :3584
[ 0.1495 ] Generating SHA2 Hash
[ 0.1514 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 0.1517 ] Assuming zero filled SBK key
[ 0.1553 ] Sha saved in br_bct_BR.sha
[ 0.1539 ] Updating BCT with SHA2 Hash
[ 0.1550 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 0.1559 ] Offset :4608 Len :3584
[ 0.1563 ] Offset :68 Len :8124
[ 0.1563 ]
[ 0.1564 ] Generating coldboot mb1-bct
[ 0.1578 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.1588 ] MB1-BCT version: 0.10
[ 0.1591 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.1598 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.1603 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.1609 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.1615 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.1615 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[ 0.1615 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[ 0.1615 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[ 0.1615 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[ 0.1615 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[ 0.1615 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[ 0.1615 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[ 0.1615 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[ 0.1615 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[ 0.1615 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[ 0.1615 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[ 0.1615 ]
[ 0.1615 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.1616 ] Added Platform Config 9 data with size :- 100
[ 0.1616 ]
[ 0.1616 ] Updating mb1-bct with firmware information
[ 0.1627 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.1659 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 0.1680 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 0.1693 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 0.1721 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1723 ] Assuming zero filled SBK key
[ 0.1743 ] Warning: pub_key.key is not found
[ 0.1740 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.1760 ] Generating recovery mb1-bct
[ 0.1778 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.1793 ] MB1-BCT version: 0.10
[ 0.1796 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.1803 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.1810 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.1816 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.1821 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.1821 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[ 0.1821 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[ 0.1822 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[ 0.1822 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[ 0.1822 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[ 0.1822 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[ 0.1822 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[ 0.1822 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[ 0.1822 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[ 0.1822 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[ 0.1822 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[ 0.1822 ]
[ 0.1822 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.1822 ] Added Platform Config 9 data with size :- 100
[ 0.1822 ]
[ 0.1823 ] Updating mb1-bct with firmware information
[ 0.1835 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.1870 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[ 0.1891 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 0.1902 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 0.1931 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1934 ] Assuming zero filled SBK key
[ 0.1955 ] Warning: pub_key.key is not found
[ 0.1949 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.1966 ] Error: Skip generating mem_bct because sdram_config is not defined
[ 0.1966 ] Copying signatures
[ 0.1978 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.2041 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.2042 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.2042 ] Boot Rom communication
[ 0.2059 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.2074 ] BR_CID: 0x80012344705DE5032C00000004028240
[ 0.2348 ] Sending bct_br
[ 0.2821 ] Sending mb1
[ 0.2831 ] Sending psc_bl1
[ 0.2939 ] Sending bct_mb1
[ 0.2995 ] Boot Rom communication completed
[ 0.3067 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[ 0.3179 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --appendsigheader applet_t234_aligned.bin zerosbk
[ 0.3236 ] adding BCH for applet_t234_aligned.bin
[ 0.3431 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.3434 ] Assuming zero filled SBK key
[ 0.3470 ] Warning: pub_key.key is not found
[ 0.3470 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[ 0.3501 ] Sending mb2_applet...
[ 0.3515 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[ 0.3531 ] BL: version 0.32.0.0-t234-54845784-57325615 last_boot_error: 0
[ 0.5084 ] Sending applet
[ 0.6210 ] completed
[ 0.6250 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.6283 ] MB2 Applet version 01.00.0000
[ 0.8420 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.8456 ] MB2 Applet version 01.00.0000
[ 0.8830 ] Retrieving board information
[ 0.8887 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails chip chip_info.bin
[ 0.8933 ] MB2 Applet version 01.00.0000
[ 0.9253 ] Saved platform info in chip_info.bin
[ 0.9313 ] Chip minor revision: 1
[ 0.9317 ] Bootrom revision: 0x7
[ 0.9317 ] Ram code: 0x2
[ 0.9318 ] Chip sku: 0xd5
[ 0.9318 ] Chip Sample: prod
[ 0.9318 ]
[ 0.9328 ] Retrieving EEPROM data
[ 0.9330 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/folder/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23 0
[ 0.9370 ] MB2 Applet version 01.00.0000
[ 0.9690 ] Saved platform info in /home/folde/Linux_for_Tegra/bootloader/cvm.bin
[ 1.0077 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 1.0133 ] MB2 Applet version 01.00.0000
[ 1.0536 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 1.0572 ] MB2 Applet version 01.00.0000
[ 1.0886 ] Dumping customer Info
[ 1.0932 ] tegrarcm_v2 --chip 0x23 0 --oem dump bct tmp.bct
[ 1.0977 ] MB2 Applet version 01.00.0000
[ 1.1303 ] Saved bct in tmp.bct
[ 1.1416 ] tegrabct_v2 --brbct tmp.bct --chip 0x23 0 --custinfo /home/folder/Linux_for_Tegra/bootloader/custinfo_out.bin
[ 1.1455 ] C[ 1.1465 ] ustomer data saved in /home/folder/Linux_for_Tegra/bootloader/custinfo_out.bin successfully
[ 1.1469 ] Rebooting to recovery mode
[ 1.1517 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[ 1.1884 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 1.1923 ] MB2 Applet version 01.00.0000
[ 1.2369 ] Booting to recovery mode
[ 1.2408 ] tegrarcm_v2 --chip 0x23 0 --reboot recovery
[ 1.2441 ] MB2 Applet version 01.00.0000
Parsing board information failed.
Error: failed to generate images
Cleaning up...
this is the error shown while flashing orin nano
ubuntu version 20.04
DevKit/custom board?
L4T/JetPack version?
Is it the first time this device is being flashed?
Or it was working before, but suddenly broke?
Please also do this:
Custom board
Jetpack 5.1.1
The board flashed before and now showing this error
Find a DevKit for verification and dump the log.
Then please still dump the log and tell me what flashing command you use.
The screenshot helps nothing at all.
Command used
./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p “-c bootloader/t186ref/cfg/flash_t234_qspi.xml” --showlogs --network usb0 jetson-orin-nano-devkit internal
orin nano error in flashing.pdf (52.1 KB)
we had USB write issue that got corrected with cat/sys/module/usbcore/parameters/autosuspend
later it shows
here is the flashing log
/home/orin/orin_nano/Jetson_Linux_R35.3.1_aarch64/Linux_for_Tegra# ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" --showlogs --network usb0 jetson-orin-nano-devkit internal
/home/orin/orin_nano/Jetson_Linux_R35.3.1_aarch64/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh --no-flash --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p -c bootloader/t186ref/cfg/flash_t234_qspi.xml --showlogs --network usb0 jetson-orin-nano-devkit internal
ADDITIONAL_DTB_OVERLAY="" /home/orin/orin_nano/Jetson_Linux_R35.3.1_aarch64/Linux_for_Tegra/flash.sh --no-flash --sign -c bootloader/t186ref/cfg/flash_t234_qspi.xml jetson-orin-nano-devkit internal
# L4T BSP Information:
# R35 , REVISION: 3.1
# User release: 0.0
copying emc_fuse_dev_params(/home/orin/orin_nano/Jetson_Linux_R35.3.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-diag-boot.dts)... done.
copying device_config(/home/orin/orin_nano/Jetson_Linux_R35.3.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-device-p3767-0000.dts)... done.
copying misc_config(/home/orin/orin_nano/Jetson_Linux_R35.3.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-misc-p3767-0000.dts)... done.
./tegraflash.py --chip 0x23 --applet "/home/orin/orin_nano/Jetson_Linux_R35.3.1_aarch64/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3767-0000.dts --misc_config tegra234-mb1-bct-misc-p3767-0000.dts --bins "mb2_applet applet_t234.bin" --cmd "dump eeprom cvm cvm.bin; dump custinfo custinfo_out.bin; reboot recovery"
version 1.0.0
[ 0.0330 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.0346 ] File rcm_state open failed
[ 0.0351 ] ERROR: failed to read rcm_state
[ 0.0351 ]
[ 0.0977 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0981 ] Assuming zero filled SBK key
[ 0.0358 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[ 0.0467 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[ 0.0637 ] Parsing partition layout
[ 0.0658 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0691 ] Kernel DTB used: None
[ 0.0691 ] WARNING: dce base dtb is not provided
[ 0.0691 ] Parsing partition layout
[ 0.0716 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0735 ] Creating list of images to be signed
[ 0.0752 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[ 0.0766 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0782 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0790 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0851 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0874 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0941 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0948 ] adding BCH for mb2_t234_aligned.bin
[ 0.0985 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.1167 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.1174 ] adding BCH for mb2_t234_aligned.bin
[ 0.1380 ] Filling MB1 storage info
[ 0.1380 ] Parsing dev params for multi chains
[ 0.1456 ] Generating br-bct
[ 0.1468 ] Updating dev and MSS params in BR BCT
[ 0.1469 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.1484 ] Updating bl info
[ 0.1497 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[ 0.1509 ] WARNING: boot chain is not completed. set to 0
[ 0.1518 ] Generating signatures
[ 0.2144 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.2147 ] Assuming zero filled SBK key
[ 0.2347 ] Warning: pub_key.key is not found
[ 0.1727 ] Parsing dev params for multi chains
[ 0.1728 ] Generating br-bct
[ 0.1744 ] Updating dev and MSS params in BR BCT
[ 0.1746 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.1763 ] Updating bl info
[ 0.1777 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.1793 ] WARNING: boot chain is not completed. set to 0
[ 0.1806 ] Get Signed section of bct
[ 0.1821 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 0.1852 ] Signing BCT
[ 0.2479 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.2483 ] Assuming zero filled SBK key
[ 0.2545 ] Sha saved in br_bct_BR.sha
[ 0.2550 ] Warning: pub_key.key is not found
[ 0.1925 ] Updating BCT with signature
[ 0.1940 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 0.1957 ] Offset :4608 Len :3584
[ 0.1963 ] Generating SHA2 Hash
[ 0.2588 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 0.2591 ] Assuming zero filled SBK key
[ 0.2592 ] Assuming zero filled SBK key
[ 0.2636 ] Sha saved in br_bct_BR.sha
[ 0.2016 ] Updating BCT with SHA2 Hash
[ 0.2031 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 0.2046 ] Offset :4608 Len :3584
[ 0.2052 ] Offset :68 Len :8124
[ 0.2054 ] Generating coldboot mb1-bct
[ 0.2069 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.2085 ] MB1-BCT version: 0.10
[ 0.2088 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.2095 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.2101 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.2107 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.2113 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.2116 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.2116 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[ 0.2116 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[ 0.2116 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[ 0.2116 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[ 0.2116 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[ 0.2116 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[ 0.2116 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[ 0.2117 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[ 0.2117 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[ 0.2117 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[ 0.2117 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[ 0.2117 ]
[ 0.2117 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.2117 ] Added Platform Config 9 data with size :- 100
[ 0.2117 ]
[ 0.2117 ] Updating mb1-bct with firmware information
[ 0.2132 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.2189 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 0.2238 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 0.2252 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 0.2889 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.2892 ] Assuming zero filled SBK key
[ 0.2919 ] Warning: pub_key.key is not found
[ 0.2312 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.2334 ] Generating recovery mb1-bct
[ 0.2350 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.2366 ] MB1-BCT version: 0.10
[ 0.2369 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.2376 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.2382 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.2388 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.2395 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.2397 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.2397 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[ 0.2397 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[ 0.2397 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[ 0.2397 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[ 0.2397 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[ 0.2397 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[ 0.2397 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[ 0.2397 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[ 0.2397 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[ 0.2397 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[ 0.2397 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[ 0.2397 ]
[ 0.2397 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.2397 ] Added Platform Config 9 data with size :- 100
[ 0.2397 ]
[ 0.2398 ] Updating mb1-bct with firmware information
[ 0.2412 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.2452 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[ 0.2483 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 0.2503 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 0.3141 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.3144 ] Assuming zero filled SBK key
[ 0.3187 ] Warning: pub_key.key is not found
[ 0.2580 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.2604 ] Error: Skip generating mem_bct because sdram_config is not defined
[ 0.2605 ] Copying signatures
[ 0.2620 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.2694 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.2697 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.2697 ] Boot Rom communication
[ 0.2713 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.2727 ] BR_CID: 0x80012344705DE5032C00000004028240
[ 0.3001 ] Sending bct_br
[ 0.3474 ] Sending mb1
[ 0.3479 ] Sending psc_bl1
[ 0.3570 ] Sending bct_mb1
[ 0.3622 ] Boot Rom communication completed
[ 0.3827 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[ 0.3859 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --appendsigheader applet_t234_aligned.bin zerosbk
[ 0.3878 ] adding BCH for applet_t234_aligned.bin
[ 0.4638 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.4642 ] Assuming zero filled SBK key
[ 0.4682 ] Warning: pub_key.key is not found
[ 0.4079 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[ 0.4117 ] Sending mb2_applet...
[ 0.4139 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[ 0.4155 ] BL: version 0.32.0.0-t234-54845784-57325615 last_boot_error: 0
[ 0.5705 ] Sending applet
[ 0.6815 ] completed
[ 0.6837 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.6857 ] MB2 Applet version 01.00.0000
[ 0.9001 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.9018 ] MB2 Applet version 01.00.0000
[ 0.9319 ] Retrieving board information
[ 0.9339 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails chip chip_info.bin
[ 0.9356 ] MB2 Applet version 01.00.0000
[ 0.9815 ] Saved platform info in chip_info.bin
[ 0.9870 ] Chip minor revision: 1
[ 0.9872 ] Bootrom revision: 0x7
[ 0.9873 ] Ram code: 0x2
[ 0.9875 ] Chip sku: 0xd5
[ 0.9877 ] Chip Sample: prod
[ 0.9877 ]
[ 0.9883 ] Retrieving EEPROM data
[ 0.9883 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/orin/orin_nano/Jetson_Linux_R35.3.1_aarch64/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23 0
[ 0.9909 ] MB2 Applet version 01.00.0000
[ 1.0336 ] Saved platform info in /home/orin/orin_nano/Jetson_Linux_R35.3.1_aarch64/Linux_for_Tegra/bootloader/cvm.bin
[ 1.0680 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 1.0695 ] MB2 Applet version 01.00.0000
[ 1.0994 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 1.1010 ] MB2 Applet version 01.00.0000
[ 1.1452 ] Dumping customer Info
[ 1.1484 ] tegrarcm_v2 --chip 0x23 0 --oem dump bct tmp.bct
[ 1.1503 ] MB2 Applet version 01.00.0000
[ 1.1935 ] Saved bct in tmp.bct
[ 1.2023 ] tegrabct_v2 --brbct tmp.bct --chip 0x23 0 --custinfo /home/orin/orin_nano/Jetson_Linux_R35.3.1_aarch64/Linux_for_Tegra/bootloader/custinfo_out.bin
[ 1.2040 ] C[ 1.2044 ] ustomer data saved in /home/orin/orin_nano/Jetson_Linux_R35.3.1_aarch64/Linux_for_Tegra/bootloader/custinfo_out.bin successfully
[ 1.2045 ] Rebooting to recovery mode
[ 1.2060 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[ 1.2392 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 1.2410 ] MB2 Applet version 01.00.0000
[ 1.2855 ] Booting to recovery mode
[ 1.2875 ] tegrarcm_v2 --chip 0x23 0 --reboot recovery
[ 1.2892 ] MB2 Applet version 01.00.0000
Cleaning up...
You didn’t run it with sudo?
Yes, this one was tried in root and also tried with sudo
Is the flashing command same
Environment variables value table:
# BOARDID BOARDSKU FAB BOARDREV
# jetson-agx-xavier-industrial 2888 0008 600 A.0
# clara-agx-xavier-devkit 3900 0000 001 C.0
# jetson-xavier-nx-devkit 3668 0000 100 N/A
# jetson-xavier-nx-devkit-emmc 3668 0001 100 N/A
# jetson-xavier-nx-devkit-emmc 3668 0003 N/A N/A
# jetson-agx-xavier-devkit (16GB) 2888 0001 400 H.0
# jetson-agx-xavier-devkit (32GB) 2888 0004 400 K.0
# jetson-agx-orin-devkit 3701 0001 TS1 C.2
# jetson-agx-orin-devkit 3701 0000 TS4 A.0
# jetson-agx-xavier-devkit (64GB) 2888 0005 402 B.0
# holoscan-devkit 3701 0002 TS1 A.0
# jetson-agx-orin-devkit 3701 0004 TS4 A.0
# jetson-agx-orin-devkit (64GB) 3701 0005 500
# jetson-orin-nano-devkit (NX 16GB) 3767 0000 300
# jetson-orin-nano-devkit (NX 8GB) 3767 0001 300
# jetson-orin-nano-devkit (Nano 4GB) 3767 0004 300
# jetson-orin-nano-devkit (Nano 8GB) 3767 0003 300
# jetson-orin-nano-devkit (Nano 8GB) 3767 0005 300
Do it like
sudo BOARDID=xxx BOARDSKU=yyy FAB=zzz ./tools/kernel_flash/l4t_initrd_flash.sh …
sudo BOARDID=3767 BOARDSKU=0000 FAB=300 ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" --showlogs --network usb0 jetson-orin-nano-devkit internal
[ 10.4156 ] MB1-BCT version: 0.10
[ 10.4158 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 10.4165 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 10.4171 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 10.4177 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 10.4183 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 10.4189 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 10.4196 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[ 10.4202 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[ 10.4208 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[ 10.4215 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[ 10.4215 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[ 10.4215 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[ 10.4215 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[ 10.4215 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[ 10.4215 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[ 10.4215 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[ 10.4215 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
given above are the errors
version 1.0.0
Entering RCM boot
[ 0.0412 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from --mb1_bin
[ 0.0412 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from --psc_bl1_bin
[ 0.0412 ] rcm boot with presigned binaries
[ 0.0425 ] tegrarcm_v2 --instance 1-2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.0436 ] BR_CID: 0x80012344705DE5032C00000004028240
[ 0.0545 ] Sending bct_br
[ 0.0637 ] Sending mb1
[ 0.0641 ] Sending psc_bl1
[ 0.0763 ] Sending bct_mb1
[ 0.0837 ] Generating blob for T23x
[ 0.0867 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[ 0.0886 ] The number of images in blob is 18
[ 0.0891 ] blobsize is 73485102
[ 0.0892 ] Added binary blob_uefi_jetson_with_dtb_sigheader.bin.encrypt of size 3174464
[ 0.1290 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 375168
[ 0.1298 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 190592
[ 0.1302 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 277312
[ 0.1307 ] Not supported type: mb2_applet
[ 0.1309 ] Added binary blob_mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt of size 437984
[ 0.1316 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164352
[ 0.1320 ] Added binary blob_display-t234-dce_sigheader.bin.encrypt of size 9097216
[ 0.1376 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[ 0.1399 ] Added binary blob_bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt of size 1048000
[ 0.1408 ] Added binary blob_tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt of size 138880
[ 0.1415 ] Added binary blob_camera-rtcpu-sce_sigheader.img.encrypt of size 166304
[ 0.1421 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 537952
[ 0.1426 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 400960
[ 0.1431 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[ 0.1435 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1064752
[ 0.1439 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[ 0.1447 ] Added binary blob_boot0.img of size 55496704
[ 0.1862 ] Added binary blob_tegra234-p3767-0000-p3768-0000-a0.dtb of size 338878
[ 0.2572 ] tegrarcm_v2 --instance 1-2 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[ 0.2583 ] BL: version 0.32.0.0-t234-54845784-57325615 last_boot_error: 0
[ 0.3135 ] Sending bct_mem
[ 0.3877 ] Sending blob
[ 0.5571 ] ERROR: might be timeout in USB write.
Error: Return value 3
Command tegrarcm_v2 --instance 1-2 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
Cleaning up...
I used the command cat /sys/module/usbcore/parameters/autosuspend and put the board in recovery mode and again run this command then also it shows the same error
If you are sure it’s Orin Nano instead of Orin NX, then it’s either BOARDSKU=0003/0004/0005 instead of BOARDSKU=0000.
Please read the table and don’t directly copy & paste…
sudo BOARDID=3767 BOARDSKU=0003 FAB=300 ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" --showlogs --network usb0 jetson-orin-nano-devkit internal
/home/FW_latest/jetson_linux_r35.3.1_aarch64/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh --no-flash --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p -c bootloader/t186ref/cfg/flash_t234_qspi.xml --showlogs --network usb0 jetson-orin-nano-devkit internal
ADDITIONAL_DTB_OVERLAY="" /home/FW_latest/jetson_linux_r35.3.1_aarch64/Linux_for_Tegra/flash.sh --no-flash --sign -c bootloader/t186ref/cfg/flash_t234_qspi.xml jetson-orin-nano-devkit internal
# User release: 0.0
Board ID(3767) version(300) sku(0003) revision()
Parsing chip_info.bin information failed.
Cleaning up...
Cleaning up...
Are you sure it’s SKU3? (Orin Nano 8GB w/o SD card)
Again, please first try on a DevKit.
I have a SD card externally,
previously when i used to flash with same command it worked,not its not working
Is it on the module itself? Then it’s SKU5 instead of SKU3.
If it’s on the carrier board, please ask the board vendor for help.
im using a customised carrier board
sorry its an ssd is connected externally
Then I can only say maybe the module itself is broken.
