Orin Nano Black Screen
My jetson orin nano kit will not start properly at the moment.
When I insert the DC power cable in, it starts as usual until the NVIDIA logo page comes up as shown.
After the logo page, the screen turns black and the cooling fan on the kit stops working.
Following some existing topics here, I have reflashed one of my SD card with Jetpack 5.1.3 (to be updated to 6.0), and when I insert the flashed SD card in, the information (firmware version) remains the same, as well as the black screen issue.
I flashed the SD card on my own Windows PC and I wonder if there is any thing I did wrong or missed. Thank you.
We would suggest have a host PC in Ubuntu 20.04. So that you can re-flash the system through SDKManager.
Thanks for the reply.
For re-flashing the system through SDK Manager, I need to set the kit to recovery mode by using a jumper to connect GND and FC REC pins at the side of the board, correct?
Yes, please connect developer kit to host PC, short ground and force recovery pins, and power on the developer kit. You can run $ lsusb on host PC and see the device being listed.
thanks for your reply. I have tried to use SDK to flash and reinstall (through a Linux Virtual Machine on my Windows PC), however, I encountered a new error as follows.
In the VM and SDK manager, my jetson kit can be detected (both using lsusb in terminal and in the SDK manager). However, as I proceeded to STEP 03 - setup process, the installation kept failing. The detailed failure information in the terminal are as follows:
10:46:43 ERROR: Flash Jetson Linux - flash: Error: Return value 8
10:46:43 ERROR: Flash Jetson Linux - flash: [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_JETSON_LINUX_COMP.ruivm.sh; [error]: 84983 blocks (here, ruivm is the name of my VM)
10:46:43 ERROR: Flash Jetson Linux - flash: command terminated with error
The installation process was like this: I made sure the Jetson kit was powered off. Then I connected the USB cable between the kit and my host PC. I shorted the GND and FC REC pins on the board. Then I powered the kit on and after 5 seconds I took the jumper wire on GND and FC REC off. I opened SDK manager, and selected the correct Jetpack and hardware. Then I proceeded to setup.
Please also see my configuration options during flash as attached. As I mentioned above, I had difficulties using SD image, so Now I have just put a clean and formatted SD card in the slot in case of the interference from corrupted file.
Also, in about 7/10, the SDK manager shows an allert of “The target is in a bad state” as attached but my REC and GND pins are connected.
Capture
My Jetson kit setup is as attached:
I have also tried manual flashing with sudo ./flash.sh jetson-orin-nano mmcblk0p1
However, it seems to have failed again, and the logs are attached:
ruivm@ruivm-VirtualBox:~/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra$ sudo ./flash.sh jetson-orin-nano-devkit mmcblk0p1
# L4T BSP Information:
# R35 , REVISION: 5.0
# User release: 0.0
ECID is 0x80012344705DD3C97400000007010240
# Target Board Information:
# Name: jetson-orin-nano-devkit, Board Family: t186ref, SoC: Tegra 234,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
copying emc_fuse_dev_params(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-diag-boot.dts)... done.
copying device_config(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-device-p3767-0000.dts)... done.
copying misc_config(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-misc-p3767-0000.dts)... done.
./tegraflash.py --chip 0x23 --applet "/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3767-0000.dts --misc_config tegra234-mb1-bct-misc-p3767-0000.dts --bins "mb2_applet applet_t234.bin" --cmd "dump eeprom cvm cvm.bin; dump custinfo custinfo_out.bin; reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[   0.0200 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.0208 ] File rcm_state open failed
[   0.0213 ] ERROR: failed to read rcm_state
[   0.0295 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0297 ] Assuming zero filled SBK key
[   0.0285 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[   0.0343 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[   0.0430 ] Parsing partition layout
[   0.0438 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.0549 ] Kernel DTB used: None
[   0.0550 ] WARNING: dce base dtb is not provided
[   0.0550 ] Parsing partition layout
[   0.0560 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.0637 ] Creating list of images to be signed
[   0.0645 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[   0.0653 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.0665 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.0674 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.0719 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.0731 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.0794 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.0803 ] adding BCH for mb2_t234_aligned.bin
[   0.0830 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.0967 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.0977 ] adding BCH for mb2_t234_aligned.bin
[   0.1157 ] Filling MB1 storage info
[   0.1157 ] Parsing dev params for multi chains
[   0.1247 ] Generating br-bct
[   0.1254 ] Updating dev and MSS params in BR BCT
[   0.1255 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.1316 ] Updating bl info
[   0.1324 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[   0.1333 ] WARNING: boot chain is not completed. set to 0
[   0.1387 ] Generating signatures
[   0.1401 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.1403 ] Assuming zero filled SBK key
[   0.1980 ] Warning: pub_key.key is not found
[   0.1968 ] Parsing dev params for multi chains
[   0.1969 ] Generating br-bct
[   0.1976 ] Updating dev and MSS params in BR BCT
[   0.1977 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.2077 ] Updating bl info
[   0.2087 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.2096 ] WARNING: boot chain is not completed. set to 0
[   0.2156 ] Get Signed section of bct
[   0.2164 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   0.2237 ] Signing BCT
[   0.2251 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.2253 ] Assuming zero filled SBK key
[   0.2451 ] Sha saved in br_bct_BR.sha
[   0.2455 ] Warning: pub_key.key is not found
[   0.2441 ] Updating BCT with signature
[   0.2450 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   0.2459 ] Offset :4608 Len :3584
[   0.2517 ] Generating SHA2 Hash
[   0.2531 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   0.2533 ] Assuming zero filled SBK key
[   0.2691 ] Sha saved in br_bct_BR.sha
[   0.2714 ] Updating BCT with SHA2 Hash
[   0.2725 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   0.2735 ] Offset :4608 Len :3584
[   0.2740 ] Offset :68 Len :8124
[   0.2797 ] Generating coldboot mb1-bct
[   0.2805 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.2814 ] MB1-BCT version: 0.12
[   0.2817 ] ERROR: /misc/enable_dram_page_blacklisting is not supported
[   0.2825 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[   0.2835 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[   0.2845 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[   0.2854 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[   0.2864 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[   0.2873 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[   0.2883 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[   0.2891 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[   0.2901 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[   0.2910 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[   0.2911 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[   0.2911 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[   0.2911 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[   0.2911 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[   0.2911 ]
[   0.2912 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.2912 ] Added Platform Config 9 data with size :- 100
[   0.2912 ]
[   0.2912 ] Updating mb1-bct with firmware information
[   0.2920 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.3007 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   0.3122 ] Generating SHA2 Hash for mb1bct
[   0.3210 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[   0.3264 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[   0.3277 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   0.3285 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   0.3407 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.3409 ] Assuming zero filled SBK key
[   0.3493 ] Warning: pub_key.key is not found
[   0.3488 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.3558 ] Generating recovery mb1-bct
[   0.3568 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.3597 ] MB1-BCT version: 0.12
[   0.3601 ] ERROR: /misc/enable_dram_page_blacklisting is not supported
[   0.3609 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[   0.3619 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[   0.3628 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[   0.3638 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[   0.3648 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[   0.3656 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[   0.3666 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[   0.3674 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[   0.3684 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[   0.3734 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[   0.3743 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[   0.3751 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[   0.3763 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[   0.3763 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[   0.3763 ]
[   0.3764 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.3764 ] Added Platform Config 9 data with size :- 100
[   0.3764 ]
[   0.3765 ] Updating mb1-bct with firmware information
[   0.3774 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.3848 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[   0.3957 ] Generating SHA2 Hash for mb1bct
[   0.4050 ] Sha saved in mb1_bct_MB1_aligned.sha
[   0.4131 ] Sha saved in mb1_bct_MB1.sha
[   0.4125 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   0.4133 ] adding BCH for mb1_bct_MB1_aligned.bct
[   0.4203 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.4204 ] Assuming zero filled SBK key
[   0.4339 ] Warning: pub_key.key is not found
[   0.4334 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.4402 ] Error: Skip generating mem_bct because sdram_config is not defined
[   0.4403 ] Error: Skip generating mem_bct because sdram_config is not defined
[   0.4403 ] Copying signatures
[   0.4411 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.4482 ] Boot Rom communication
[   0.4491 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   0.4557 ] BR_CID: 0x80012344705DD3C97400000007010240
[   0.4883 ] Sending bct_br
[   0.5319 ] Sending mb1
[   0.5327 ] Sending psc_bl1
[   0.5450 ] Sending bct_mb1
[   0.5591 ] Boot Rom communication completed
[   0.5631 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[   0.5684 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --appendsigheader applet_t234_aligned.bin zerosbk
[   0.5692 ] adding BCH for applet_t234_aligned.bin
[   0.5852 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.5854 ] Assuming zero filled SBK key
[   0.5977 ] Warning: pub_key.key is not found
[   0.5973 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[   0.6084 ] Sending mb2_applet...
[   0.6096 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[   0.6104 ] BL: version 1.4.0.1-t234-54845784-08e631ca last_boot_error: 0
[   0.7574 ] Sending applet
[   0.8597 ] completed
[   0.8607 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.8615 ] MB2 Applet version 01.00.0000
[   1.0526 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   1.0534 ] MB2 Applet version 01.00.0000
[   1.0933 ] Retrieving board information
[   1.0941 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails chip chip_info.bin
[   1.0950 ] MB2 Applet version 01.00.0000
[   1.1242 ] Saved platform info in chip_info.bin
[   1.1309 ] Chip minor revision: 1
[   1.1310 ] Bootrom revision: 0x7
[   1.1311 ] Ram code: 0x2
[   1.1311 ] Chip sku: 0xd5
[   1.1311 ] Chip Sample: prod
[   1.1376 ] Retrieving EEPROM data
[   1.1376 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23 0
[   1.1416 ] MB2 Applet version 01.00.0000
[   1.1731 ] Saved platform info in /home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
[   1.2126 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   1.2134 ] MB2 Applet version 01.00.0000
[   1.2487 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   1.2497 ] MB2 Applet version 01.00.0000
[   1.2997 ] Dumping customer Info
[   1.3007 ] tegrarcm_v2 --chip 0x23 0 --oem dump bct tmp.bct
[   1.3016 ] MB2 Applet version 01.00.0000
[   1.3470 ] Saved bct in tmp.bct
[   1.3647 ] tegrabct_v2 --brbct tmp.bct --chip 0x23 0 --custinfo /home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/custinfo_out.bin
[   1.3657 ] Customer data saved in /home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/custinfo_out.bin successfully[   1.3717 ] Rebooting to recovery mode
[   1.3726 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[   1.4086 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   1.4095 ] MB2 Applet version 01.00.0000
[   1.4597 ] Booting to recovery mode
[   1.4606 ] tegrarcm_v2 --chip 0x23 0 --reboot recovery
[   1.4615 ] MB2 Applet version 01.00.0000
Board ID(3767) version(300) sku(0005) revision(L.1)
Chip SKU(00:00:00:D5) ramcode(00:00:00:02) fuselevel(fuselevel_production) board_FAB(300)
emc_opt_disable_fuse:(0)
Copy /home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/kernel/dtb/tegra234-p3767-0003-p3768-0000-a0.dtb to /home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/kernel/dtb/tegra234-p3767-0003-p3768-0000-a0.dtb.rec
copying bctfile(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-p3767-0001-sdram-l4t.dts)... done.
copying minratchet_config(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-ratchet-p3767-0000.dts)... done.
copying pinmux_config(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi)... done.
copying gpioint_config(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-gpioint-p3767-0000.dts)... done.
copying pmic_config(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-pmic-p3767-0000-a02.dts)... done.
copying pmc_config(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi)... done.
copying deviceprod_config(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-cprod-p3767-0000.dts)... done.
copying prod_config(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-prod-p3767-0000.dts)... done.
copying scr_config(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb2-bct-scr-p3767-0000.dts)... done.
copying wb0sdram(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-p3767-0001-wb0sdram-l4t.dts)... done.
copying bootrom_config(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-reset-p3767-0000.dts)... done.
Existing uphylane_config(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/tegra234-mb1-bct-uphylane-si.dtsi) reused.
copying dev_params(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-p3767-0000-l4t.dts)... done.
copying dev_params_b(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct_b-p3767-0000-l4t.dts)... done.
copying mb2bct_cfg(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb2-bct-misc-p3767-0000.dts)... done.
Existing pscfwfile(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/pscfw_t234_prod.bin) reused.
Existing pscbl1file(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/psc_bl1_t234_prod.bin) reused.
Existing mtsmcefile(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/mce_flash_o10_cr_prod.bin) reused.
Existing mb2applet(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/applet_t234.bin) reused.
Existing bootloader(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
copying initrd(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
bl is uefi
Making Boot image... done.
Not signing of boot.img
Making recovery ramdisk for recovery image...
Re-generating recovery ramdisk for recovery image...
/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/ramdisk_tmp /home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader /home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra
41966 blocks
gzip: /home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/kernel/Image: not in gzip format
_BASE_KERNEL_VERSION=5.10.192-tegra
58213 blocks
Making Recovery image...
copying recdtbfile(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/kernel/dtb/tegra234-p3767-0003-p3768-0000-a0.dtb.rec)... done.
20+0 records in
20+0 records out
20 bytes copied, 0.000186692 s, 107 kB/s
Existing sosfile(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing tegraboot(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing cpu_bootloader(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing mb2blfile(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing xusbfile(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/xusb_t234_prod.bin) reused.
Existing dcefile(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/display-t234-dce.bin) reused.
Existing nvdecfile(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/nvdec_t234_prod.fw) reused.
Existing psc_rf(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/psc_rf_t234_prod.bin) reused.
Existing mb2_rf(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/mb2rf_t234.bin) reused.
Existing mb1file(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing bpffile(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/bpmp_t234-TE950M-A1_prod.bin) reused.
copying bpfdtbfile(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/t186ref/tegra234-bpmp-3767-0003-3509-a02.dtb)... done.
Existing scefile(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/camera-rtcpu-t234-rce.img) reused.
Existing apefile(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/adsp-fw.bin) reused.
Existing spefile(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/spe_t234.bin) reused.
Existing wb0boot(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/sc7_t234_prod.bin) reused.
Existing tosfile(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/tos-optee_t234.img) reused.
Existing eksfile(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/eks_t234.img) reused.
copying dtbfile(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/kernel/dtb/tegra234-p3767-0003-p3768-0000-a0.dtb)... done.
Copying nv_boot_control.conf to rootfs
	populating kernel to rootfs... done.
	populating initrd to rootfs... done.
	populating kernel_tegra234-p3767-0003-p3768-0000-a0.dtb to rootfs... done.
Making system.img...
	Setting "FDT /boot/dtb/kernel_tegra234-p3767-0003-p3768-0000-a0.dtb" successfully in the extlinux.conf...done.
	populating rootfs from /home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs ... 	populating /boot/extlinux/extlinux.conf ... done.
	Sync'ing system.img ... done.
	Converting RAW image to Sparse image... done.
system.img built successfully.
Not signing of kernel-dtb
Existing tbcfile(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/uefi_jetson.bin) reused.
131072+0 records in
131072+0 records out
67108864 bytes (67 MB, 64 MiB) copied, 0.255109 s, 263 MB/s
	Sync'ing esp.img ... done.
copying tbcdtbfile(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/kernel/dtb/tegra234-p3767-0003-p3768-0000-a0.dtb)... done.
copying cfgfile(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/t186ref/cfg/flash_t234_qspi_sd.xml) to flash.xml... done.
Existing flashapp(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py) reused.
copying overlay_dtb(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/kernel/dtb/L4TConfiguration.dtbo)... done.
copying overlay_dtb(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/kernel/dtb/tegra234-p3767-overlay.dtbo)... done.
copying overlay_dtb(/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/kernel/dtb/tegra234-p3768-overlay.dtbo)... done.
/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration_updated.dts: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
/home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration.dtbo: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
./tegraflash.py  --bl uefi_jetson_with_dtb.bin  --odmdata gbe-uphy-config-8,hsstp-lane-map-3,hsio-uphy-config-0  --overlay_dtb L4TConfiguration.dtbo,tegra234-p3767-overlay.dtbo,tegra234-p3768-overlay.dtbo,  --bldtb tegra234-p3767-0003-p3768-0000-a0.dtb --applet mb1_t234_prod.bin --cmd "flash; reboot"  --cfg flash.xml --chip 0x23 --concat_cpubl_bldtb --cpubl uefi_jetson.bin --minratchet_config tegra234-mb1-bct-ratchet-p3767-0000.dts --device_config tegra234-mb1-bct-device-p3767-0000.dts --misc_config tegra234-mb1-bct-misc-p3767-0000.dts --pinmux_config tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi --gpioint_config tegra234-mb1-bct-gpioint-p3767-0000.dts --pmic_config tegra234-mb1-bct-pmic-p3767-0000-a02.dts --pmc_config tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi --deviceprod_config tegra234-mb1-bct-cprod-p3767-0000.dts --prod_config tegra234-mb1-bct-prod-p3767-0000.dts --scr_config tegra234-mb2-bct-scr-p3767-0000.dts --wb0sdram_config tegra234-p3767-0001-wb0sdram-l4t.dts --br_cmd_config tegra234-mb1-bct-reset-p3767-0000.dts --uphy tegra234-mb1-bct-uphylane-si.dtsi --dev_params tegra234-br-bct-p3767-0000-l4t.dts,tegra234-br-bct_b-p3767-0000-l4t.dts --mb2bct_cfg tegra234-mb2-bct-misc-p3767-0000.dts  --bins "psc_fw pscfw_t234_prod.bin; mts_mce mce_flash_o10_cr_prod.bin; mb2_applet applet_t234.bin; mb2_bootloader mb2_t234.bin; xusb_fw xusb_t234_prod.bin; dce_fw display-t234-dce.bin; nvdec nvdec_t234_prod.fw; bpmp_fw bpmp_t234-TE950M-A1_prod.bin; bpmp_fw_dtb tegra234-bpmp-3767-0003-3509-a02.dtb; sce_fw camera-rtcpu-sce.img; rce_fw camera-rtcpu-t234-rce.img; ape_fw adsp-fw.bin; spe_fw spe_t234.bin; tos tos-optee_t234.img; eks eks_t234.img" --sdram_config tegra234-p3767-0001-sdram-l4t.dts  --cust_info custinfo_out.bin   --bct_backup  --boot_chain A
saving flash command in /home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/ruivm/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[   0.0363 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0364 ] Assuming zero filled SBK key
[   0.0335 ] Parsing partition layout
[   0.0355 ] tegraparser_v2 --pt flash.xml.tmp
[   0.0478 ] Change tegra234-bpmp-3767-0003-3509-a02.dtb to tegra234-bpmp-3767-0003-3509-a02_with_odm.dtb
[   0.0827 ] /usr/bin/python3 dtbcheck.py -c t234 -o tegra234-bpmp-3767-0003-3509-a02_with_odm.dtb tegra234-bpmp-3767-0003-3509-a02_with_odm_tmp.dtb
[   0.3773 ] Concatenating L4TConfiguration.dtbo,tegra234-p3767-overlay.dtbo,tegra234-p3768-overlay.dtbo to tegra234-p3767-0003-p3768-0000-a0_with_odm_overlay.dtb
[   0.3775 ] Concatenating bl dtb to cpubl binary
[   0.3797 ] MB2 binary: mb2_t234.bin
[   0.3797 ] Pre-processing mb2bct config: tegra234-mb2-bct-misc-p3767-0000.dts
[   0.4414 ] Pre-processing mb2bct config: tegra234-mb2-bct-scr-p3767-0000.dts
[   0.8432 ] Generating coldboot mb2-bct
[   0.8433 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct.cfg --mb2bctcfg tegra234-mb2-bct-misc-p3767-0000_cpp.dtb --scr tegra234-mb2-bct-scr-p3767-0000_cpp.dtb
[   0.8443 ] ERROR: value 0x31 is out of range
[   0.8483 ] ERROR: value 0x31 is out of range
[   0.8488 ] ERROR: value 0x31 is out of range
[   0.8492 ] ERROR: value 0x31 is out of range
[   0.8497 ] WARNING: unknown property 'tfc_version'
[   0.8506 ] WARNING: unknown property 'addr_header_version'
[   0.8657 ] Updating mb2-bct with storage information
[   0.8671 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct_MB2.bct --updatestorageinfo flash.xml.bin
[   0.8777 ] Concatenating mb2-bct to mb2 binary
[   0.8778 ] mb2_bin_file = mb2_t234.bin
[   0.8778 ] mb2_bct_file = mb2_cold_boot_bct_MB2.bct
[   0.8818 ] DCE binary: display-t234-dce.bin
[   0.8819 ] Kernel DTB used: kernel_tegra234-p3767-0003-p3768-0000-a0.dtb
[   0.8819 ] Concatenating kernel-dtb to dce-fw binary
[   0.8819 ] dce_bin = display-t234-dce.bin
[   0.8820 ] kernel_dtb = kernel_tegra234-p3767-0003-p3768-0000-a0.dtb
[   0.8820 ] dce_with_dtb = display-t234-dce_with_kernel_tegra234-p3767-0003-p3768-0000-a0.bin
[   0.8951 ] Update display-t234-dce_with_kernel_tegra234-p3767-0003-p3768-0000-a0.bin to dce_fw partitions
[   0.8969 ] Parsing partition layout
[   0.8984 ] tegraparser_v2 --pt flash.xml.tmp
[   0.9057 ] Creating list of images to be signed
[   0.9116 ] Generating ratchet blob
[   0.9117 ] Pre-processing config: tegra234-mb1-bct-reset-p3767-0000.dts
[   0.9181 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[   0.9239 ] Pre-processing config: tegra234-mb1-bct-cprod-p3767-0000.dts
[   0.9291 ] Pre-processing config: tegra234-mb1-bct-gpioint-p3767-0000.dts
[   0.9378 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[   0.9519 ] Pre-processing config: tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi
[   0.9627 ] Pre-processing config: tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi
[   0.9709 ] Pre-processing config: tegra234-mb1-bct-pmic-p3767-0000-a02.dts
[   0.9811 ] Pre-processing config: tegra234-mb1-bct-prod-p3767-0000.dts
[   0.9870 ] Pre-processing config: tegra234-p3767-0001-sdram-l4t.dts
[   1.8705 ] Pre-processing config: tegra234-mb1-bct-uphylane-si.dtsi
[   1.8795 ] Pre-processing config: tegra234-p3767-0001-wb0sdram-l4t.dts
[   2.7636 ] Pre-processing config: tegra234-mb1-bct-ratchet-p3767-0000.dts
[   2.7700 ] Generating coldboot mb1-bct
[   2.7710 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3767-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3767-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[   2.7721 ] MB1-BCT version: 0.12
[   2.7725 ] ERROR: /misc/enable_dram_page_blacklisting is not supported
[   2.7733 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[   2.7763 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[   2.7772 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[   2.7781 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[   2.7791 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[   2.7800 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[   2.7810 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[   2.7818 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[   2.7835 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[   2.7845 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[   2.7854 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[   2.7865 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[   2.7875 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[   2.7947 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[   2.7956 ] Parsing config file :tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb
[   2.7964 ] Added Platform Config 0 data with size :- 2416
[   2.7977 ]
[   2.7978 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb
[   2.7978 ] WARNING: unknown node 'g2'
[   2.7978 ] WARNING: unknown node 'g9'
[   2.7979 ] WARNING: unknown node 'g9'
[   2.7979 ] Added Platform Config 2 data with size :- 24
[   2.7979 ]
[   2.7979 ] Parsing config file :tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb
[   2.7979 ] Added Platform Config 4 data with size :- 288
[   2.7980 ]
[   2.7980 ] Parsing config file :tegra234-mb1-bct-reset-p3767-0000_cpp.dtb
[   2.7980 ] Added Platform Config 3 data with size :- 52
[   2.7980 ]
[   2.7981 ] Parsing config file :tegra234-mb1-bct-prod-p3767-0000_cpp.dtb
[   2.7981 ] WARNING: unknown property 'major'
[   2.7981 ] WARNING: unknown property 'minor'
[   2.7981 ] Added Platform Config 5 data with size :- 512
[   2.7982 ]
[   2.7982 ] Parsing config file :tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb
[   2.7982 ] WARNING: unknown property 'major'
[   2.7982 ] WARNING: unknown property 'minor'
[   2.7982 ] Added Platform Config 7 data with size :- 380
[   2.7983 ]
[   2.7983 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[   2.7983 ] Added Platform Config 8 data with size :- 24
[   2.7983 ]
[   2.7983 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   2.7984 ] Added Platform Config 9 data with size :- 100
[   2.7984 ]
[   2.7984 ] Parsing config file :tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[   2.7984 ] ModuleCount 0 NumProdNames 0
[   2.7984 ] Added Platform Config 6 data with size :- 16
[   2.7985 ]
[   2.7985 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[   2.7985 ] ERROR: /ratchet/atf is not supported
[   2.7985 ]
[   2.7986 ] Updating mb1-bct with firmware information
[   2.8001 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[   2.8068 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   2.8137 ] Generating SHA2 Hash for mb1bct
[   2.8327 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[   2.8407 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[   2.8387 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   2.8397 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   2.8489 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.8491 ] Assuming zero filled SBK key
[   2.8566 ] Warning: pub_key.key is not found
[   2.8551 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   2.8660 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[   2.8675 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   2.8693 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   2.8703 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   2.8751 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   2.8759 ] Header already present for nvdec_t234_prod_aligned.fw
[   2.8794 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[   2.8865 ] adding BCH for xusb_t234_prod_aligned.bin
[   2.9015 ] Header already present for bpmp_t234-TE950M-A1_prod_aligned.bin
[   2.9086 ] adding BCH for tegra234-bpmp-3767-0003-3509-a02_with_odm_aligned.dtb
[   2.9238 ] Header already present for pscfw_t234_prod_aligned.bin
[   2.9339 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[   2.9397 ] Header already present for sc7_t234_prod.bin
[   2.9434 ] Header already present for psc_rf_t234_prod_aligned.bin
[   2.9491 ] adding BCH for mb2rf_t234_aligned.bin
[   2.9517 ] INFO: compressing uefi_jetson_with_dtb_aligned.bin
[   3.0049 ] INFO: complete compression, uefi_jetson_with_dtb_aligned.bin, ratio = 91%
[   3.0156 ] adding BCH for uefi_jetson_with_dtb_aligned_blob_w_bin_aligned.bin
[   3.0602 ] adding BCH for tos-optee_t234_aligned.img
[   3.1129 ] adding BCH for eks_t234_aligned.img
[   3.1502 ] INFO: compressing display-t234-dce_with_kernel_tegra234-p3767-0003-p3768-0000-a0_aligned.bin
[   3.2791 ] INFO: complete compression, display-t234-dce_with_kernel_tegra234-p3767-0003-p3768-0000-a0_aligned.bin, ratio = 7%
[   3.2971 ] adding BCH for display-t234-dce_with_kernel_tegra234-p3767-0003-p3768-0000-a0_aligned_blob_w_bin_aligned.bin
[   3.3162 ] adding BCH for spe_t234_aligned.bin
[   3.3287 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[   3.3387 ] adding BCH for adsp-fw_aligned.bin
[   3.3562 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   3.3693 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   3.3705 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   3.3785 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   3.3796 ] Header already present for nvdec_t234_prod_aligned.fw
[   3.3822 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[   3.3872 ] adding BCH for xusb_t234_prod_aligned.bin
[   3.4005 ] Header already present for bpmp_t234-TE950M-A1_prod_aligned.bin
[   3.4069 ] adding BCH for tegra234-bpmp-3767-0003-3509-a02_with_odm_aligned.dtb
[   3.4240 ] Header already present for pscfw_t234_prod_aligned.bin
[   3.4356 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[   3.4411 ] Header already present for sc7_t234_prod.bin
[   3.4441 ] Header already present for psc_rf_t234_prod_aligned.bin
[   3.4473 ] adding BCH for mb2rf_t234_aligned.bin
[   3.4495 ] INFO: compressing uefi_jetson_with_dtb_aligned.bin
[   3.5122 ] INFO: complete compression, uefi_jetson_with_dtb_aligned.bin, ratio = 91%
[   3.5173 ] adding BCH for uefi_jetson_with_dtb_aligned_blob_w_bin_aligned.bin
[   3.5762 ] adding BCH for tos-optee_t234_aligned.img
[   3.6213 ] adding BCH for eks_t234_aligned.img
[   3.6574 ] INFO: compressing display-t234-dce_with_kernel_tegra234-p3767-0003-p3768-0000-a0_aligned.bin
[   3.7878 ] INFO: complete compression, display-t234-dce_with_kernel_tegra234-p3767-0003-p3768-0000-a0_aligned.bin, ratio = 7%
[   3.8045 ] adding BCH for display-t234-dce_with_kernel_tegra234-p3767-0003-p3768-0000-a0_aligned_blob_w_bin_aligned.bin
[   3.8217 ] adding BCH for spe_t234_aligned.bin
[   3.8382 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[   3.8515 ] adding BCH for adsp-fw_aligned.bin
[   3.8864 ] Filling MB1 storage info
[   3.8865 ] Parsing dev params for multi chains
[   3.8942 ] Generating br-bct
[   3.8952 ] Updating dev and MSS params in BR BCT
[   3.8953 ] tegrabct_v2 --dev_param tegra234-br-bct-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   4.0297 ] Updating bl info
[   4.0313 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[   4.0462 ] Generating br-bct
[   4.0473 ] Updating dev and MSS params in BR BCT
[   4.0474 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   4.1817 ] Updating bl info
[   4.1832 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[   4.1897 ] Generating BCT backup image
[   4.1898 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[   4.1909 ] 32768+0 records in
[   4.2252 ] 32768+0 records out
[   4.2255 ] 32768 bytes (33 kB, 32 KiB) copied, 0.0342754 s, 956 kB/s
[   4.2298 ] Concatenating BCT for chain A to bct_backup.img
[   4.2298 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[   4.2313 ] 8192+0 records in
[   4.2359 ] 8192+0 records out
[   4.2361 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.00455377 s, 1.8 MB/s
[   4.2418 ] Concatenating BCT for chain B to bct_backup.img
[   4.2418 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[   4.2468 ] 8192+0 records in
[   4.2514 ] 8192+0 records out
[   4.2517 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.00460182 s, 1.8 MB/s
[   4.2577 ] Generating signatures
[   4.2608 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[   4.2610 ] Assuming zero filled SBK key
[   4.5742 ] Warning: pub_key.key is not found
[   4.5734 ] Parsing dev params for multi chains
[   4.5735 ] Generating br-bct
[   4.5747 ] Updating dev and MSS params in BR BCT
[   4.5748 ] tegrabct_v2 --dev_param tegra234-br-bct-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   4.7256 ] Updating customer data section
[   4.7272 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[   4.7336 ] Updating bl info
[   4.7347 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   4.7417 ] Get Signed section of bct
[   4.7439 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   4.7497 ] Signing BCT
[   4.7528 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   4.7530 ] Assuming zero filled SBK key
[   4.7728 ] Sha saved in br_bct_BR.sha
[   4.7731 ] Warning: pub_key.key is not found
[   4.7702 ] Updating BCT with signature
[   4.7715 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   4.7727 ] Offset :4608 Len :3584
[   4.7777 ] Generating SHA2 Hash
[   4.7808 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   4.7809 ] Assuming zero filled SBK key
[   4.7810 ] Assuming zero filled SBK key
[   4.7932 ] Sha saved in br_bct_BR.sha
[   4.7906 ] Updating BCT with SHA2 Hash
[   4.7916 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   4.7927 ] Offset :4608 Len :3584
[   4.7967 ] Offset :68 Len :8124
[   4.8020 ] Generating br-bct
[   4.8035 ] Updating dev and MSS params in BR BCT
[   4.8035 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   4.9377 ] Updating customer data section
[   4.9393 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[   4.9456 ] Updating bl info
[   4.9468 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   4.9537 ] Get Signed section of bct
[   4.9548 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   4.9617 ] Signing BCT
[   4.9648 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   4.9650 ] Assuming zero filled SBK key
[   4.9825 ] Sha saved in br_bct_BR.sha
[   4.9829 ] Warning: pub_key.key is not found
[   4.9800 ] Updating BCT with signature
[   4.9813 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   4.9826 ] Offset :4608 Len :3584
[   4.9897 ] Generating SHA2 Hash
[   4.9928 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   4.9930 ] Assuming zero filled SBK key
[   5.0087 ] Sha saved in br_bct_BR.sha
[   5.0061 ] Updating BCT with SHA2 Hash
[   5.0071 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   5.0083 ] Offset :4608 Len :3584
[   5.0088 ] Offset :68 Len :8124
[   5.0137 ] Generating BCT backup image
[   5.0138 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[   5.0148 ] 32768+0 records in
[   5.0482 ] 32768+0 records out
[   5.0485 ] 32768 bytes (33 kB, 32 KiB) copied, 0.0333944 s, 981 kB/s
[   5.0538 ] Concatenating BCT for chain A to bct_backup.img
[   5.0538 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[   5.0554 ] 8192+0 records in
[   5.0651 ] 8192+0 records out
[   5.0653 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.0097097 s, 844 kB/s
[   5.0704 ] Concatenating BCT for chain B to bct_backup.img
[   5.0705 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[   5.0720 ] 8192+0 records in
[   5.0765 ] 8192+0 records out
[   5.0767 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.00452215 s, 1.8 MB/s
[   5.0821 ] Generating coldboot mb1-bct
[   5.0831 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3767-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3767-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[   5.0844 ] MB1-BCT version: 0.12
[   5.0848 ] ERROR: /misc/enable_dram_page_blacklisting is not supported
[   5.0856 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[   5.0868 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[   5.0894 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[   5.0904 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[   5.0914 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[   5.0923 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[   5.0967 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[   5.0974 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[   5.0984 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[   5.1021 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[   5.1030 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[   5.1038 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[   5.1046 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[   5.1053 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[   5.1062 ] Parsing config file :tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb
[   5.1071 ] Added Platform Config 0 data with size :- 2416
[   5.1077 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb
[   5.1085 ] WARNING: unknown node 'g2'
[   5.1089 ] WARNING: unknown node 'g2'
[   5.1092 ] WARNING: unknown node 'g9'
[   5.1096 ] WARNING: unknown node 'g9'
[   5.1099 ] Added Platform Config 2 data with size :- 24
[   5.1105 ] Parsing config file :tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb
[   5.1113 ] Added Platform Config 4 data with size :- 288
[   5.1116 ]
[   5.1116 ] Parsing config file :tegra234-mb1-bct-reset-p3767-0000_cpp.dtb
[   5.1116 ] Added Platform Config 3 data with size :- 52
[   5.1116 ]
[   5.1117 ] Parsing config file :tegra234-mb1-bct-prod-p3767-0000_cpp.dtb
[   5.1117 ] WARNING: unknown property 'major'
[   5.1117 ] WARNING: unknown property 'minor'
[   5.1117 ] Added Platform Config 5 data with size :- 512
[   5.1117 ]
[   5.1118 ] Parsing config file :tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb
[   5.1118 ] WARNING: unknown property 'major'
[   5.1118 ] WARNING: unknown property 'minor'
[   5.1118 ] Added Platform Config 7 data with size :- 380
[   5.1118 ]
[   5.1118 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[   5.1119 ] Added Platform Config 8 data with size :- 24
[   5.1119 ]
[   5.1119 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   5.1119 ] Added Platform Config 9 data with size :- 100
[   5.1119 ]
[   5.1120 ] Parsing config file :tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[   5.1120 ] ModuleCount 0 NumProdNames 0
[   5.1120 ] Added Platform Config 6 data with size :- 16
[   5.1120 ]
[   5.1120 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[   5.1121 ] ERROR: /ratchet/atf is not supported
[   5.1121 ]
[   5.1121 ] Updating mb1-bct with firmware information
[   5.1137 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[   5.1236 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   5.1337 ] Generating SHA2 Hash for mb1bct
[   5.1447 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[   5.1512 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[   5.1512 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   5.1523 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   5.1617 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.1620 ] Assuming zero filled SBK key
[   5.1733 ] Warning: pub_key.key is not found
[   5.1719 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   5.1778 ] Generating recovery mb1-bct
[   5.1790 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3767-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3767-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[   5.1866 ] MB1-BCT version: 0.12
[   5.1870 ] ERROR: /misc/enable_dram_page_blacklisting is not supported
[   5.1878 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[   5.1888 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[   5.1898 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[   5.1907 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[   5.1917 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[   5.1926 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[   5.1936 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[   5.1944 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[   5.1954 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[   5.1986 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[   5.1995 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[   5.2003 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[   5.2011 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[   5.2018 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[   5.2027 ] Parsing config file :tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb
[   5.2036 ] Added Platform Config 0 data with size :- 2416
[   5.2041 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb
[   5.2050 ] WARNING: unknown node 'g2'
[   5.2053 ] WARNING: unknown node 'g2'
[   5.2057 ] WARNING: unknown node 'g9'
[   5.2061 ] WARNING: unknown node 'g9'
[   5.2064 ] Added Platform Config 2 data with size :- 24
[   5.2073 ]
[   5.2074 ] Parsing config file :tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb
[   5.2074 ] Added Platform Config 4 data with size :- 288
[   5.2074 ]
[   5.2074 ] Parsing config file :tegra234-mb1-bct-reset-p3767-0000_cpp.dtb
[   5.2075 ] Added Platform Config 3 data with size :- 52
[   5.2075 ]
[   5.2075 ] Parsing config file :tegra234-mb1-bct-prod-p3767-0000_cpp.dtb
[   5.2075 ] WARNING: unknown property 'major'
[   5.2076 ] WARNING: unknown property 'minor'
[   5.2076 ] Added Platform Config 5 data with size :- 512
[   5.2076 ]
[   5.2076 ] Parsing config file :tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb
[   5.2076 ] WARNING: unknown property 'major'
[   5.2077 ] WARNING: unknown property 'minor'
[   5.2077 ] Added Platform Config 7 data with size :- 380
[   5.2077 ]
[   5.2077 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[   5.2077 ] Added Platform Config 8 data with size :- 24
[   5.2078 ]
[   5.2078 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   5.2078 ] Added Platform Config 9 data with size :- 100
[   5.2078 ]
[   5.2078 ] Parsing config file :tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[   5.2079 ] ModuleCount 0 NumProdNames 0
[   5.2079 ] Added Platform Config 6 data with size :- 16
[   5.2079 ]
[   5.2079 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[   5.2080 ] ERROR: /ratchet/atf is not supported
[   5.2080 ]
[   5.2080 ] Updating mb1-bct with firmware information
[   5.2092 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo flash.xml.bin
[   5.2234 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[   5.2297 ] Generating SHA2 Hash for mb1bct
[   5.2407 ] Sha saved in mb1_bct_MB1_aligned.sha
[   5.2510 ] Sha saved in mb1_bct_MB1.sha
[   5.2497 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   5.2508 ] adding BCH for mb1_bct_MB1_aligned.bct
[   5.2609 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.2610 ] Assuming zero filled SBK key
[   5.2690 ] Warning: pub_key.key is not found
[   5.2671 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   5.2729 ] Generating coldboot mem-bct
[   5.2758 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --membct tegra234-p3767-0001-sdram-l4t_cpp_1.bct tegra234-p3767-0001-sdram-l4t_cpp_2.bct tegra234-p3767-0001-sdram-l4t_cpp_3.bct tegra234-p3767-0001-sdram-l4t_cpp_4.bct
[   5.2808 ]  packing sdram params with Wb0 file tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb
[   5.4088 ] Packing sdram param for instance[0]
[   5.4093 ] Packing sdram param for instance[1]
[   5.4098 ] Packing sdram param for instance[2]
[   5.4103 ] Packing sdram param for instance[3]
[   5.4108 ] Packing sdram param for instance[4]
[   5.4113 ] Packing sdram param for instance[5]
[   5.4118 ] Packing sdram param for instance[6]
[   5.4123 ] Packing sdram param for instance[7]
[   5.4127 ] Packing sdram param for instance[8]
[   5.4132 ] Packing sdram param for instance[9]
[   5.4137 ] Packing sdram param for instance[10]
[   5.4142 ] Packing sdram param for instance[11]
[   5.4147 ] Packing sdram param for instance[12]
[   5.4152 ] Packing sdram param for instance[13]
[   5.4157 ] Packing sdram param for instance[14]
[   5.4190 ] Packing sdram param for instance[15]
[   5.5497 ] Getting sector size from pt
[   5.5513 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[   5.5584 ] BlockSize read from layout is 0x200
[   5.5594 ] tegrahost_v2 --chip 0x23 0 --blocksize 512 --magicid MEMB --addsigheader_multi tegra234-p3767-0001-sdram-l4t_cpp_1.bct tegra234-p3767-0001-sdram-l4t_cpp_2.bct tegra234-p3767-0001-sdram-l4t_cpp_3.bct tegra234-p3767-0001-sdram-l4t_cpp_4.bct
[   5.5626 ] Binary 0 length is 58752
[   5.5630 ] Binary 0 align length is 58880
[   5.5641 ] Binary 1 length is 58752
[   5.5645 ] Binary 1 align length is 58880
[   5.5655 ] Binary 2 length is 58752
[   5.5660 ] Binary 2 align length is 58880
[   5.5670 ] Binary 3 length is 58752
[   5.5674 ] Binary 3 align length is 58880
[   5.5684 ] Buffer length is 235520
[   5.5687 ] adding BCH for tegra234-p3767-0001-sdram-l4t_cpp_1.bct
[   5.5694 ] new length is 243712
[   5.5754 ] tegrahost_v2 --chip 0x23 0 --align mem_coldboot_aligned.bct
[   5.5871 ] tegrahost_v2 --chip 0x23 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_coldboot_aligned.bct zerosbk
[   5.5881 ] Header already present for mem_coldboot_aligned.bct
[   5.6000 ] tegrasign_v3.py --key None --list mem_coldboot_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.6002 ] Assuming zero filled SBK key
[   5.6092 ] Warning: pub_key.key is not found
[   5.6078 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_coldboot_aligned_sigheader.bct.encrypt mem_coldboot_aligned_sigheader.bct.hash zerosbk
[   5.6220 ] Generating recovery mem-bct
[   5.6234 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --membct tegra234-p3767-0001-sdram-l4t_cpp_1.bct tegra234-p3767-0001-sdram-l4t_cpp_2.bct tegra234-p3767-0001-sdram-l4t_cpp_3.bct tegra234-p3767-0001-sdram-l4t_cpp_4.bct
[   5.6245 ]  packing sdram params with Wb0 file tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb
[   5.7534 ] Packing sdram param for instance[0]
[   5.7539 ] Packing sdram param for instance[1]
[   5.7544 ] Packing sdram param for instance[2]
[   5.7548 ] Packing sdram param for instance[3]
[   5.7553 ] Packing sdram param for instance[4]
[   5.7558 ] Packing sdram param for instance[5]
[   5.7563 ] Packing sdram param for instance[6]
[   5.7568 ] Packing sdram param for instance[7]
[   5.7572 ] Packing sdram param for instance[8]
[   5.7578 ] Packing sdram param for instance[9]
[   5.7582 ] Packing sdram param for instance[10]
[   5.7587 ] Packing sdram param for instance[11]
[   5.7592 ] Packing sdram param for instance[12]
[   5.7597 ] Packing sdram param for instance[13]
[   5.7602 ] Packing sdram param for instance[14]
[   5.7623 ] Packing sdram param for instance[15]
[   5.8978 ] Reading ramcode from backup chip_info.bin file
[   5.9001 ] RAMCODE Read from Device: 2
[   5.9002 ] Using ramcode 0
[   5.9002 ] Disabled BPMP dtb trim, using default dtb
[   5.9002 ]
[   5.9020 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_aligned.bct
[   5.9111 ] tegrahost_v2 --chip 0x23 0 --magicid MEM0 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_aligned.bct zerosbk
[   5.9123 ] adding BCH for mem_rcm_aligned.bct
[   5.9209 ] tegrasign_v3.py --key None --list mem_rcm_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.9211 ] Assuming zero filled SBK key
[   5.9295 ] Warning: pub_key.key is not found
[   5.9315 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_aligned_sigheader.bct.encrypt mem_rcm_aligned_sigheader.bct.hash zerosbk
[   5.9379 ] Copying signatures
[   5.9394 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[   5.9828 ] Boot Rom communication
[   5.9854 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
Command tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
Failed flashing t186ref.
Please the the initrd command:
Quick Start — NVIDIA Jetson Linux Developer Guide 1 documentation
Jetson Orin Nano Developer Kit (SD card):
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device mmcblk1p1 \
  -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" \
  --showlogs --network usb0 jetson-orin-nano-devkit internal
