Hello everybody,
I have bought a Jetson Nano Developer kit for some projects and I have an issue with it.
I followed all the Quick Start Guide, i’m writing the image on my SD card (with 2 differents software and two different computers). I have finally an SD card with 12 partitions.
I connect all the equipements on the Jetson Nano (HDMI display, keyboard, mouse and ethernet cable), I put my SD card into it, and I add the micro-usb plug (5V/2A, i tried two different power supply)
But nothing happend. I ear a strange sound from the heatsink, the green led in on, but nothing is displayed (I also tried two different screens)
Do you have any solution ? There is an hardware problem maybe ? I try to found a solution because is for an urgent project and the time for remplacing the card is too long …
Thanks in advance,
Have a good day,
Florian
[UPDATE]
I tried to connect a serial cable to see the different stages of the BOOT and here is what is returned in its entirety. Maybe the message that seems to say that a partition is invalid could be in question?
A problem that may not be ultimately due to the hardware?
[SCREENSHOOTS]
#1 : https://elasticbeanstalk-eu-west-3-150832573572.s3.eu-west-3.amazonaws.com/data_serialport_jetson_nano_1.JPG
#2 : https://elasticbeanstalk-eu-west-3-150832573572.s3.eu-west-3.amazonaws.com/data_serialport_jetson_nano_2.JPG
Thanks for your help !
Florian
Hi Florian,
Please do share the full boot log for such case. It is not good to share a screenshot.
Also, would you mind trying sdkmanager to flash your sdcard?
Hi WayneWWW,
I took the screenshoot from the terminal from another PC (using a serial USB cable), but there is the full boot log, nothing after the last line happend:
[0000.126] [TegraBoot] (version 00.00.2018.01-l4t-33e7fa82)
[0000.131] Processing in cold boot mode Bootloader 2
[0000.136] A02 Bootrom Patch rev = 1023
[0000.139] Power-up reason: pmc por
[0000.142] No Battery Present
[0000.145] pmic max77620 reset reason
[0000.148] pmic max77620 NVERC : 0x40
[0000.152] RamCode = 0
[0000.154] Platform has DDR4 type RAM
[0000.157] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0x334c8
[0000.173] Entering ramdump check
[0000.176] Get RamDumpCarveOut = 0x0
[0000.179] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.189] Sdram initialization is successful
[0000.193] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.199] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.205] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.211] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.217] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.223] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.228] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.234] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.250] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.256] Platform-DebugCarveout: 0
[0000.260] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.265] Non secure mode, and RB not enabled.
[0000.272] Invalid GPT Partition
[0000.287] Using BFS PT to query partitions
[0000.291] failed to load NvTbootTbootCpu from (2:0)
[0000.296] re-load NvTbootTbootCpu from (4:0)
[0000.386] Csd NumOfBlocks=60776448
[0000.445] Using GPT Primary to query partitions
[0000.453] Loading Tboot-CPU binary
[0000.834] Verifying TBC in OdmNonSecureSBK mode
[0000.844] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.851] Bootloader downloaded successfully.
[0000.855] Downloaded Tboot-CPU binary to 0xa0000258
[0000.860] MAX77620_GPIO5 configured
[0000.863] CPU power rail is up
[0000.866] CPU clock enabled
[0000.870] Performing RAM repair
[0000.873] Updating A64 Warmreset Address to 0xa00002e9
[0000.878] Loading NvTbootBootloaderDTB
[0002.200] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0002.266] Bootloader DTB Load Address: 0x83000000
[0002.270] Loading NvTbootKernelDTB
[0003.592] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0003.657] Kernel DTB Load Address: 0x83100000
[0003.665] Loading cboot binary
[0005.364] Verifying EBT in OdmNonSecureSBK mode
[0005.406] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0005.413] Bootloader downloaded successfully.
[0005.607] Using BFS PT to query partitions
[0005.611] Next binary entry address: 0x92c00258
[0005.616] BoardId: 3448
[0005.620] Overriding pmu board id with proc board id
[0005.625] Display board id is not available
[0007.137] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0007.189] /bpmp deleted
[0007.191] SC7EntryFw header found loaded at 0xff700000
[0007.379] OVR2 PMIC
[0007.381] Bpmp FW successfully loaded
[0007.397] WB0 init successfully at 0xff780000
[0007.402] Set NvDecSticky Bits
[0007.405] GSC2 address ff53fffc value c0edbbcc
[0007.412] GSC MC Settings done
[0007.417] TOS Image length 53680
[0007.420] Monitor size 53680
[0007.423] OS size 0
[0007.586] Secure Os AES-CMAC Verification Success!
[0007.590] TOS image cipher info: plaintext
[0007.594] Loading and Validation of Secure OS Successful
[0007.610] SC7 Entry Firmware - 0xff700000, 0x4000
[0007.615] NvTbootPackSdramParams: start.
[0007.620] NvTbootPackSdramParams: done.
[0007.623] Tegraboot started after 53291 us
[0007.627] Basic modules init took 5711814 us
[0007.631] NvTbootQspiFlashIoctl: Opcode = 1 not supported
[0007.637] Sec Bootdevice Read Time = 12 ms, Read Size = 65 KB
[0007.642] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0007.648] Storage Device Read Time = 6799 ms, Read Size = 2306 KB
[0007.653] Storage Device Write Time = 0 ms, Write Size = 0 KB
[0007.659] Next stage binary read took 1543571 us
[0007.663] Carveout took -1555250 us
[0007.667] CPU initialization took 2053338 us
[0007.671] Total time taken by TegraBoot 7753473 us
[0007.676] Starting CPU & Halting co-processor
Also, I’m on windows and it appear the SDK Manager is only available on Debian ?
I can mount a virtual machine to try but I don’t think it change something.
Thanks for your help.
There is no obvious error in your log. I would suggest to verify your device by finding a native ubuntu host and try sdkamanger.
Please note that
- sdkmanager does not work on VM.
- It is possible that sdkmanager works but sdcard image does not. Somehow many users have such issue.
I try to flash using the SDK manager and after a long time (around 2h30) the flash failed at 99.9%, there is the full log from sdkmanager:
DETAILS TERMINAL
Component Name: All
Message Type: All
Filter text here...
19:57:41 INFO : Flash Jetson Nano : [ 0.0029 ] Generating RCM messages
19:57:41 INFO : Flash Jetson Nano : [ 0.0055 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm /home/florian/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/nvtboot_recovery.bin 0 0
19:57:41 INFO : Flash Jetson Nano : [ 0.0069 ] RCM 0 is saved as rcm_0.rcm
19:57:41 INFO : Flash Jetson Nano : [ 0.0088 ] RCM 1 is saved as rcm_1.rcm
19:57:41 INFO : Flash Jetson Nano : [ 0.0088 ] List of rcm files are saved in rcm_list.xml
19:57:41 INFO : Flash Jetson Nano : [ 0.0088 ] Signing RCM messages
19:57:41 INFO : Flash Jetson Nano : [ 0.0112 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
19:57:41 INFO : Flash Jetson Nano : [ 0.0128 ] Assuming zero filled SBK key
19:57:41 INFO : Flash Jetson Nano : [ 0.0248 ]
19:57:41 INFO : Flash Jetson Nano : [ 0.0249 ] Copying signature to RCM mesages
19:57:41 INFO : Flash Jetson Nano : [ 0.0263 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
19:57:41 INFO : Flash Jetson Nano : [ 0.0282 ]
19:57:41 INFO : Flash Jetson Nano : [ 0.0282 ] Boot Rom communication
19:57:41 INFO : Flash Jetson Nano : [ 0.0295 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml --skipuid
19:57:41 INFO : Flash Jetson Nano : [ 0.0307 ] RCM version 0X210001
19:57:42 INFO : Flash Jetson Nano : [ 0.0746 ] Boot Rom communication completed
19:57:42 INFO : Flash Jetson Nano : [ 1.0833 ]
19:57:42 INFO : Flash Jetson Nano : [ 1.0835 ] dump EEPROM info
19:57:42 INFO : Flash Jetson Nano : [ 1.0896 ] tegrarcm --oem platformdetails eeprom /home/florian/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/cvm.bin
19:57:42 INFO : Flash Jetson Nano : [ 1.0924 ] Applet version 00.01.0000
19:57:42 INFO : Flash Jetson Nano : [ 1.0969 ] Saved platform info in /home/florian/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/cvm.bin
19:57:42 INFO : Flash Jetson Nano : [ 1.1730 ]
19:57:42 ERROR : Flash Jetson Nano : Board ID(3448) version(200)
19:57:42 INFO : Flash Jetson Nano : creating dummy /home/florian/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/badpage.bin
19:57:42 ERROR : Flash Jetson Nano : 1+0 records in
19:57:42 INFO : Flash Jetson Nano : 1+0 records out
19:57:42 INFO : Flash Jetson Nano : 4096 bytes (4.1 kB, 4.0 KiB) copied, 0.000142013 s, 28.8 MB/s
19:57:42 INFO : Flash Jetson Nano : copying bctfile(/home/florian/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/t210ref/BCT/P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg)... done.
19:57:42 INFO : Flash Jetson Nano : copying bootloader(/home/florian/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
19:57:42 INFO : Flash Jetson Nano : copying initrd(/home/florian/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
19:57:42 INFO : Flash Jetson Nano : populating kernel to rootfs... done.
19:57:42 INFO : Flash Jetson Nano : populating initrd to rootfs... done.
19:57:43 INFO : Flash Jetson Nano : populating /home/florian/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a02.dtb to rootfs... done.
19:57:43 INFO : Flash Jetson Nano : Making Boot image... done.
19:57:43 INFO : Flash Jetson Nano : Existing sosfile(/home/florian/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
19:57:43 INFO : Flash Jetson Nano : copying tegraboot(/home/florian/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/t210ref/nvtboot.bin)... done.
19:57:43 INFO : Flash Jetson Nano : copying cpu_bootloader(/home/florian/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
19:57:43 INFO : Flash Jetson Nano : copying bpffile(/home/florian/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/t210ref/sc7entry-firmware.bin)... done.
19:57:43 INFO : Flash Jetson Nano : Existing badpagefile(/home/florian/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/badpage.bin) reused.
19:57:43 INFO : Flash Jetson Nano : copying wb0boot(/home/florian/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/t210ref/warmboot.bin)... done.
19:57:43 INFO : Flash Jetson Nano : Existing tosfile(/home/florian/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/tos-mon-only.img) reused.
19:57:43 INFO : Flash Jetson Nano : Existing eksfile(/home/florian/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/eks.img) reused.
19:57:43 INFO : Flash Jetson Nano : copying dtbfile(/home/florian/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a02.dtb)... done.
19:57:43 INFO : Flash Jetson Nano : Copying nv_boot_control.conf to rootfs
19:57:43 INFO : Flash Jetson Nano : Making system.img...
19:59:23 INFO : Flash Jetson Nano : populating rootfs from /home/florian/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/rootfs ... done.
19:59:32 INFO : Flash Jetson Nano : Sync'ing system.img ... done.
19:59:32 INFO : Flash Jetson Nano : Converting RAW image to Sparse image...
19:59:32 ERROR : Flash Jetson Nano :
19:59:32 INFO : Flash Jetson Nano : ---- Raw to Sparse Image Converter v1.0 ----------------------------
19:59:32 ERROR : Flash Jetson Nano : 0: RAW: 5242880( 5 blks) ==> 28:5242892
19:59:32 ERROR : Flash Jetson Nano : 1: SKP: 32505856( 31 blks) ==> 5242920:12
19:59:32 ERROR : Flash Jetson Nano : 2: RAW: 1048576( 1 blks) ==> 5242932:1048588
19:59:32 ERROR : Flash Jetson Nano : 3: SKP: 95420416( 91 blks) ==> 6291520:12
19:59:32 ERROR : Flash Jetson Nano : 4: RAW: 1048576( 1 blks) ==> 6291532:1048588
19:59:32 ERROR : Flash Jetson Nano : 5: SKP: 3145728( 3 blks) ==> 7340120:12
19:59:32 ERROR : Flash Jetson Nano : 6: RAW: 27262976( 26 blks) ==> 7340132:27262988
19:59:32 ERROR : Flash Jetson Nano : 7: SKP: 1048576( 1 blks) ==> 34603120:12
19:59:33 ERROR : Flash Jetson Nano : 8: RAW: 127926272( 122 blks) ==> 34603132:127926284
19:59:33 ERROR : Flash Jetson Nano : 9: SKP: 15728640( 15 blks) ==> 162529416:12
19:59:33 ERROR : Flash Jetson Nano : 10: RAW: 4194304( 4 blks) ==> 162529428:4194316
19:59:33 ERROR : Flash Jetson Nano : 11: SKP: 4194304( 4 blks) ==> 166723744:12
19:59:33 ERROR : Flash Jetson Nano : 12: RAW: 84934656( 81 blks) ==> 166723756:84934668
19:59:33 ERROR : Flash Jetson Nano : 13: SKP: 3145728( 3 blks) ==> 251658424:12
19:59:33 ERROR : Flash Jetson Nano : 14: RAW: 14680064( 14 blks) ==> 251658436:14680076
19:59:33 ERROR : Flash Jetson Nano : 15: SKP: 6291456( 6 blks) ==> 266338512:12
19:59:33 ERROR : Flash Jetson Nano : 16: RAW: 202375168( 193 blks) ==> 266338524:202375180
19:59:33 ERROR : Flash Jetson Nano : 17: SKP: 40894464( 39 blks) ==> 468713704:12
19:59:33 ERROR : Flash Jetson Nano : 18: RAW: 1048576( 1 blks) ==> 468713716:1048588
19:59:33 ERROR : Flash Jetson Nano : 19: SKP: 3145728( 3 blks) ==> 469762304:12
19:59:34 ERROR : Flash Jetson Nano : 20: RAW: 91226112( 87 blks) ==> 469762316:91226124
19:59:34 ERROR : Flash Jetson Nano : 21: SKP: 5242880( 5 blks) ==> 560988440:12
19:59:35 ERROR : Flash Jetson Nano : 22: RAW: 88080384( 84 blks) ==> 560988452:88080396
19:59:35 ERROR : Flash Jetson Nano : 23: SKP: 4194304( 4 blks) ==> 649068848:12
19:59:35 ERROR : Flash Jetson Nano : 24: RAW: 54525952( 52 blks) ==> 649068860:54525964
19:59:35 ERROR : Flash Jetson Nano : 25: SKP: 1048576( 1 blks) ==> 703594824:12
19:59:35 ERROR : Flash Jetson Nano : 26: RAW: 2097152( 2 blks) ==> 703594836:2097164
19:59:35 ERROR : Flash Jetson Nano : 27: SKP: 1048576( 1 blks) ==> 705692000:12
19:59:35 ERROR : Flash Jetson Nano : 28: RAW: 17825792( 17 blks) ==> 705692012:17825804
19:59:35 ERROR : Flash Jetson Nano : 29: SKP: 7340032( 7 blks) ==> 723517816:12
19:59:35 ERROR : Flash Jetson Nano : 30: RAW: 38797312( 37 blks) ==> 723517828:38797324
19:59:35 ERROR : Flash Jetson Nano : 31: SKP: 3145728( 3 blks) ==> 762315152:12
19:59:35 ERROR : Flash Jetson Nano : 32: RAW: 30408704( 29 blks) ==> 762315164:30408716
19:59:35 ERROR : Flash Jetson Nano : 33: SKP: 3145728( 3 blks) ==> 792723880:12
19:59:35 ERROR : Flash Jetson Nano : 34: RAW: 30408704( 29 blks) ==> 792723892:30408716
19:59:35 ERROR : Flash Jetson Nano : 35: SKP: 3145728( 3 blks) ==> 823132608:12
19:59:35 ERROR : Flash Jetson Nano : 36: RAW: 152043520( 145 blks) ==> 823132620:152043532
19:59:35 ERROR : Flash Jetson Nano : 37: SKP: 3145728( 3 blks) ==> 975176152:12
19:59:35 ERROR : Flash Jetson Nano : 38: RAW: 70254592( 67 blks) ==> 975176164:70254604
19:59:35 ERROR : Flash Jetson Nano : 39: SKP: 1048576( 1 blks) ==> 1045430768:12
19:59:36 ERROR : Flash Jetson Nano : 40: RAW: 65011712( 62 blks) ==> 1045430780:65011724
19:59:36 ERROR : Flash Jetson Nano : 41: SKP: 2097152( 2 blks) ==> 1110442504:12
19:59:37 ERROR : Flash Jetson Nano : 42: RAW: 90177536( 86 blks) ==> 1110442516:90177548
19:59:37 ERROR : Flash Jetson Nano : 43: SKP: 2097152( 2 blks) ==> 1200620064:12
19:59:37 ERROR : Flash Jetson Nano : 44: RAW: 12582912( 12 blks) ==> 1200620076:12582924
19:59:37 ERROR : Flash Jetson Nano : 45: SKP: 4194304( 4 blks) ==> 1213203000:12
19:59:37 ERROR : Flash Jetson Nano : 46: RAW: 28311552( 27 blks) ==> 1213203012:28311564
19:59:37 ERROR : Flash Jetson Nano : 47: SKP: 1048576( 1 blks) ==> 1241514576:12
19:59:38 ERROR : Flash Jetson Nano : 48: RAW: 27262976( 26 blks) ==> 1241514588:27262988
19:59:38 ERROR : Flash Jetson Nano : 49: SKP: 2097152( 2 blks) ==> 1268777576:12
19:59:38 ERROR : Flash Jetson Nano : 50: RAW: 50331648( 48 blks) ==> 1268777588:50331660
19:59:38 ERROR : Flash Jetson Nano : 51: SKP: 1048576( 1 blks) ==> 1319109248:12
19:59:41 ERROR : Flash Jetson Nano : 52: RAW: 189792256( 181 blks) ==> 1319109260:189792268
19:59:41 ERROR : Flash Jetson Nano : 53: SKP: 2097152( 2 blks) ==> 1508901528:12
19:59:41 ERROR : Flash Jetson Nano : 54: RAW: 22020096( 21 blks) ==> 1508901540:22020108
19:59:41 ERROR : Flash Jetson Nano : 55: SKP: 3145728( 3 blks) ==> 1530921648:12
19:59:41 ERROR : Flash Jetson Nano : 56: RAW: 15728640( 15 blks) ==> 1530921660:15728652
19:59:41 ERROR : Flash Jetson Nano : 57: SKP: 1048576( 1 blks) ==> 1546650312:12
19:59:41 ERROR : Flash Jetson Nano : 58: RAW: 15728640( 15 blks) ==> 1546650324:15728652
19:59:41 ERROR : Flash Jetson Nano : 59: SKP: 328204288( 313 blks) ==> 1562378976:12
19:59:41 ERROR : Flash Jetson Nano : 60: RAW: 5242880( 5 blks) ==> 1562378988:5242892
19:59:41 ERROR : Flash Jetson Nano : 61: SKP: 28311552( 27 blks) ==> 1567621880:12
19:59:42 ERROR : Flash Jetson Nano : 62: RAW: 16777216( 16 blks) ==> 1567621892:16777228
19:59:42 ERROR : Flash Jetson Nano : 63: SKP: 83886080( 80 blks) ==> 1584399120:12
19:59:42 ERROR : Flash Jetson Nano : 64: RAW: 82837504( 79 blks) ==> 1584399132:82837516
19:59:43 ERROR : Flash Jetson Nano : 65: SKP: 17825792( 17 blks) ==> 1667236648:12
19:59:43 ERROR : Flash Jetson Nano : 66: RAW: 33554432( 32 blks) ==> 1667236660:33554444
19:59:43 ERROR : Flash Jetson Nano : 67: SKP: 939524096( 896 blks) ==> 1700791104:12
19:59:44 ERROR : Flash Jetson Nano : 68: RAW: 1048576( 1 blks) ==> 1700791116:1048588
19:59:44 ERROR : Flash Jetson Nano : 69: SKP: 267386880( 255 blks) ==> 1701839704:12
19:59:44 ERROR : Flash Jetson Nano : 70: RAW: 1048576( 1 blks) ==> 1701839716:1048588
19:59:44 ERROR : Flash Jetson Nano : 71: SKP: 670040064( 639 blks) ==> 1702888304:12
19:59:45 ERROR : Flash Jetson Nano : 72: RAW: 6291456( 6 blks) ==> 1702888316:6291468
19:59:45 ERROR : Flash Jetson Nano : 73: SKP: 27262976( 26 blks) ==> 1709179784:12
19:59:45 ERROR : Flash Jetson Nano : 74: RAW: 16777216( 16 blks) ==> 1709179796:16777228
19:59:45 ERROR : Flash Jetson Nano : 75: SKP: 83886080( 80 blks) ==> 1725957024:12
19:59:53 ERROR : Flash Jetson Nano : 76: RAW: 831520768( 793 blks) ==> 1725957036:831520780
19:59:54 ERROR : Flash Jetson Nano : 77: SKP: 1181745152( 1127 blks) ==> 2557477816:12
19:59:54 ERROR : Flash Jetson Nano : 78: RAW: 14680064( 14 blks) ==> 2557477828:14680076
19:59:54 ERROR : Flash Jetson Nano : 79: SKP: 18874368( 18 blks) ==> 2572157904:12
19:59:55 ERROR : Flash Jetson Nano : 80: RAW: 17825792( 17 blks) ==> 2572157916:17825804
19:59:55 ERROR : Flash Jetson Nano : 81: SKP: 82837504( 79 blks) ==> 2589983720:12
19:59:55 ERROR : Flash Jetson Nano : 82: RAW: 1048576( 1 blks) ==> 2589983732:1048588
19:59:55 ERROR : Flash Jetson Nano : 83: SKP: 3145728( 3 blks) ==> 2591032320:12
20:00:01 ERROR : Flash Jetson Nano : 84: RAW: 599785472( 572 blks) ==> 2591032332:599785484
20:00:01 ERROR : Flash Jetson Nano : 85: SKP: 33554432( 32 blks) ==> 3190817816:12
20:00:01 ERROR : Flash Jetson Nano : 86: RAW: 11534336( 11 blks) ==> 3190817828:11534348
20:00:02 ERROR : Flash Jetson Nano : 87: SKP: 1364197376( 1301 blks) ==> 3202352176:12
20:00:02 ERROR : Flash Jetson Nano : 88: RAW: 7340032( 7 blks) ==> 3202352188:7340044
20:00:02 ERROR : Flash Jetson Nano : 89: SKP: 26214400( 25 blks) ==> 3209692232:12
20:00:02 ERROR : Flash Jetson Nano : 90: RAW: 13631488( 13 blks) ==> 3209692244:13631500
20:00:02 ERROR : Flash Jetson Nano : 91: SKP: 87031808( 83 blks) ==> 3223323744:12
20:00:03 ERROR : Flash Jetson Nano : 92: RAW: 103809024( 99 blks) ==> 3223323756:103809036
20:00:03 ERROR : Flash Jetson Nano : 93: SKP: 1048576( 1 blks) ==> 3327132792:12
20:00:03 ERROR : Flash Jetson Nano : 94: RAW: 5242880( 5 blks) ==> 3327132804:5242892
20:00:03 ERROR : Flash Jetson Nano : 95: SKP: 1048576( 1 blks) ==> 3332375696:12
20:00:04 ERROR : Flash Jetson Nano : 96: RAW: 80740352( 77 blks) ==> 3332375708:80740364
20:00:04 ERROR : Flash Jetson Nano : 97: SKP: 2097152( 2 blks) ==> 3413116072:12
20:00:04 ERROR : Flash Jetson Nano : 98: RAW: 81788928( 78 blks) ==> 3413116084:81788940
20:00:05 ERROR : Flash Jetson Nano : 99: SKP: 1048576( 1 blks) ==> 3494905024:12
20:00:05 ERROR : Flash Jetson Nano : 100: RAW: 13631488( 13 blks) ==> 3494905036:13631500
20:00:05 ERROR : Flash Jetson Nano : 101: SKP: 1048576( 1 blks) ==> 3508536536:12
20:00:09 ERROR : Flash Jetson Nano : 102: RAW: 510656512( 487 blks) ==> 3508536548:510656524
20:00:10 ERROR : Flash Jetson Nano : 103: SKP: 1211105280( 1155 blks) ==> 4019193072:12
20:00:11 ERROR : Flash Jetson Nano : 104: RAW: 5242880( 5 blks) ==> 4019193084:5242892
20:00:11 ERROR : Flash Jetson Nano : 105: SKP: 28311552( 27 blks) ==> 4024435976:12
20:00:11 ERROR : Flash Jetson Nano : 106: RAW: 13631488( 13 blks) ==> 4024435988:13631500
20:00:11 ERROR : Flash Jetson Nano : 107: SKP: 87031808( 83 blks) ==> 4038067488:12
20:00:11 ERROR : Flash Jetson Nano : 108: RAW: 1048576( 1 blks) ==> 4038067500:1048588
20:00:11 ERROR : Flash Jetson Nano : 109: SKP: 3145728( 3 blks) ==> 4039116088:12
20:00:14 ERROR : Flash Jetson Nano : 110: RAW: 262144000( 250 blks) ==> 4039116100:262144012
20:00:15 ERROR : Flash Jetson Nano : 111: SKP: 1746927616( 1666 blks) ==> 4301260112:12
20:00:15 ERROR : Flash Jetson Nano : 112: RAW: 5242880( 5 blks) ==> 4301260124:5242892
20:00:15 ERROR : Flash Jetson Nano : 113: SKP: 28311552( 27 blks) ==> 4306503016:12
20:00:15 ERROR : Flash Jetson Nano : 114: RAW: 15728640( 15 blks) ==> 4306503028:15728652
20:00:15 ERROR : Flash Jetson Nano : 115: SKP: 84934656( 81 blks) ==> 4322231680:12
20:00:16 ERROR : Flash Jetson Nano : 116: RAW: 60817408( 58 blks) ==> 4322231692:60817420
20:00:16 ERROR : Flash Jetson Nano : 117: SKP: 6291456( 6 blks) ==> 4383049112:12
20:00:16 ERROR : Flash Jetson Nano : 118: RAW: 33554432( 32 blks) ==> 4383049124:33554444
20:00:18 ERROR : Flash Jetson Nano : 119: SKP: 1912602624( 1824 blks) ==> 4416603568:12
20:00:18 ERROR : Flash Jetson Nano : -- Total: ---------------------------------------------------
20:00:18 INFO : Flash Jetson Nano : 120 CHUNK 15032385536( 14336 blks) ==> 4416603580(4212 blks)
20:00:18 INFO : Flash Jetson Nano : done.
20:00:18 INFO : Flash Jetson Nano : system.img built successfully.
20:00:18 INFO : Flash Jetson Nano : Existing tbcfile(/home/florian/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
20:00:18 INFO : Flash Jetson Nano : copying tbcdtbfile(/home/florian/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a02.dtb)... done.
20:00:18 INFO : Flash Jetson Nano : copying cfgfile(/home/florian/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/t210ref/cfg/flash_l4t_t210_spi_sd_p3448.xml) to flash.xml... done.
20:00:19 INFO : Flash Jetson Nano : copying flasher(/home/florian/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
20:00:19 INFO : Flash Jetson Nano : Existing flashapp(/home/florian/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/tegraflash.py) reused.
20:00:19 INFO : Flash Jetson Nano : ./tegraflash.py --bl cboot.bin --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg --odmdata 0x94000 --bldtb tegra210-p3448-0000-p3449-0000-a02.dtb --applet nvtboot_recovery.bin --cmd "flash; reboot" --cfg flash.xml --chip 0x21 --bins "EBT cboot.bin; DTB tegra210-p3448-0000-p3449-0000-a02.dtb"
20:00:19 INFO : Flash Jetson Nano : saving flash command in /home/florian/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/flashcmd.txt
20:00:19 INFO : Flash Jetson Nano : saving Windows flash command to /home/florian/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/flash_win.bat
20:00:19 INFO : Flash Jetson Nano : *** Flashing target device started. ***
20:00:21 INFO : Flash Jetson Nano : Welcome to Tegra Flash
20:00:21 INFO : Flash Jetson Nano : version 1.0.0
20:00:21 INFO : Flash Jetson Nano : Type ? or help for help and q or quit to exit
20:00:21 INFO : Flash Jetson Nano : Use ! to execute system commands
20:00:21 INFO : Flash Jetson Nano : [ 0.0434 ] tegrasign --key None --getmode mode.txt
20:00:21 INFO : Flash Jetson Nano : [ 0.0469 ] Assuming zero filled SBK key
20:00:21 INFO : Flash Jetson Nano : [ 0.1215 ]
20:00:21 INFO : Flash Jetson Nano : [ 0.1217 ] Generating RCM messages
20:00:21 INFO : Flash Jetson Nano : [ 0.1388 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm nvtboot_recovery.bin 0 0
20:00:21 INFO : Flash Jetson Nano : [ 0.1405 ] RCM 0 is saved as rcm_0.rcm
20:00:21 INFO : Flash Jetson Nano : [ 0.1752 ] RCM 1 is saved as rcm_1.rcm
20:00:21 INFO : Flash Jetson Nano : [ 0.1752 ] List of rcm files are saved in rcm_list.xml
20:00:21 INFO : Flash Jetson Nano : [ 0.1752 ] Signing RCM messages
20:00:21 INFO : Flash Jetson Nano : [ 0.1765 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
20:00:21 INFO : Flash Jetson Nano : [ 0.1775 ] Assuming zero filled SBK key
20:00:21 INFO : Flash Jetson Nano : [ 0.1839 ]
20:00:21 INFO : Flash Jetson Nano : [ 0.1840 ] Copying signature to RCM mesages
20:00:21 INFO : Flash Jetson Nano : [ 0.1851 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
20:00:21 INFO : Flash Jetson Nano : [ 0.2201 ]
20:00:21 INFO : Flash Jetson Nano : [ 0.2201 ] Parsing partition layout
20:00:21 INFO : Flash Jetson Nano : [ 0.2432 ] tegraparser --pt flash.xml.tmp
20:00:21 INFO : Flash Jetson Nano : [ 0.2942 ]
20:00:21 INFO : Flash Jetson Nano : [ 0.2943 ] Creating list of images to be signed
20:00:21 INFO : Flash Jetson Nano : [ 0.3174 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --list images_list.xml
20:00:21 INFO : Flash Jetson Nano : [ 0.7531 ]
20:00:21 INFO : Flash Jetson Nano : [ 0.7531 ] Generating signatures
20:00:21 INFO : Flash Jetson Nano : [ 0.7544 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
20:00:21 INFO : Flash Jetson Nano : [ 0.7554 ] Assuming zero filled SBK key
20:00:22 INFO : Flash Jetson Nano : [ 0.8851 ]
20:00:22 INFO : Flash Jetson Nano : [ 0.8852 ] Generating br-bct
20:00:22 INFO : Flash Jetson Nano : [ 0.9011 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg --chip 0x21 0
20:00:22 INFO : Flash Jetson Nano : [ 0.9022 ] Copying Sdram info from 0 to 1 set
20:00:22 INFO : Flash Jetson Nano : [ 0.9492 ] Copying Sdram info from 1 to 2 set
20:00:22 INFO : Flash Jetson Nano : [ 0.9492 ] Copying Sdram info from 2 to 3 set
20:00:22 INFO : Flash Jetson Nano : [ 0.9492 ] Updating boot device parameters
20:00:22 INFO : Flash Jetson Nano : [ 0.9503 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatedevparam flash.xml.bin
20:00:22 INFO : Flash Jetson Nano : [ 0.9512 ] Warning: No sdram params
20:00:22 INFO : Flash Jetson Nano : [ 0.9598 ]
20:00:22 INFO : Flash Jetson Nano : [ 0.9598 ] Updating bl info
20:00:22 INFO : Flash Jetson Nano : [ 0.9611 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
20:00:22 INFO : Flash Jetson Nano : [ 1.0143 ]
20:00:22 INFO : Flash Jetson Nano : [ 1.0143 ] Updating secondary storage information into bct
20:00:22 INFO : Flash Jetson Nano : [ 1.0155 ] tegraparser --pt flash.xml.bin --chip 0x21 0 --updatecustinfo P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct
20:00:22 INFO : Flash Jetson Nano : [ 1.0329 ]
20:00:22 INFO : Flash Jetson Nano : [ 1.0330 ] Updating Odmdata
20:00:22 INFO : Flash Jetson Nano : [ 1.0342 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatefields Odmdata =0x94000
20:00:22 INFO : Flash Jetson Nano : [ 1.0352 ] Warning: No sdram params
20:00:22 INFO : Flash Jetson Nano : [ 1.0586 ]
20:00:22 INFO : Flash Jetson Nano : [ 1.0586 ] Get Signed section of bct
20:00:22 INFO : Flash Jetson Nano : [ 1.0600 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --listbct bct_list.xml
20:00:22 INFO : Flash Jetson Nano : [ 1.0615 ]
20:00:22 INFO : Flash Jetson Nano : [ 1.0616 ] Signing BCT
20:00:22 INFO : Flash Jetson Nano : [ 1.0640 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
20:00:22 INFO : Flash Jetson Nano : [ 1.0651 ] Assuming zero filled SBK key
20:00:22 INFO : Flash Jetson Nano : [ 1.0657 ]
20:00:22 INFO : Flash Jetson Nano : [ 1.0658 ] Updating BCT with signature
20:00:22 INFO : Flash Jetson Nano : [ 1.0668 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatesig bct_list_signed.xml
20:00:22 INFO : Flash Jetson Nano : [ 1.0705 ]
20:00:22 INFO : Flash Jetson Nano : [ 1.0706 ] Copying signatures
20:00:22 INFO : Flash Jetson Nano : [ 1.0718 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
20:00:22 INFO : Flash Jetson Nano : [ 1.2095 ]
20:00:22 INFO : Flash Jetson Nano : [ 1.2096 ] Updating BFS information on BCT
20:00:22 INFO : Flash Jetson Nano : [ 1.2108 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatebfsinfo flash.xml.bin
20:00:22 INFO : Flash Jetson Nano : [ 1.2248 ]
20:00:22 INFO : Flash Jetson Nano : [ 1.2249 ] Boot Rom communication
20:00:22 INFO : Flash Jetson Nano : [ 1.2263 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml
20:00:22 INFO : Flash Jetson Nano : [ 1.2274 ] BootRom is not running
20:00:22 INFO : Flash Jetson Nano : [ 1.2688 ]
20:00:22 INFO : Flash Jetson Nano : [ 1.2689 ] Sending BCTs
20:00:22 INFO : Flash Jetson Nano : [ 1.2704 ] tegrarcm --download bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct
20:00:22 INFO : Flash Jetson Nano : [ 1.2716 ] Applet version 00.01.0000
20:00:22 INFO : Flash Jetson Nano : [ 1.2739 ] Sending bct
20:00:22 INFO : Flash Jetson Nano : [ 1.2741 ] [...] 100%
20:00:22 INFO : Flash Jetson Nano : [ 1.4476 ]
20:00:22 INFO : Flash Jetson Nano : [ 1.4494 ] tegrahost --chip 0x21 --align cboot.bin
20:00:22 INFO : Flash Jetson Nano : [ 1.4509 ]
20:00:22 INFO : Flash Jetson Nano : [ 1.4521 ] tegrahost --magicid EBT --appendsigheader cboot.bin cboot.bin_blheader
20:00:22 INFO : Flash Jetson Nano : [ 1.4642 ]
20:00:22 INFO : Flash Jetson Nano : [ 1.4660 ] tegrasign --key None --list cboot.bin_list.xml
20:00:22 INFO : Flash Jetson Nano : [ 1.4674 ] Assuming zero filled SBK key
20:00:22 INFO : Flash Jetson Nano : [ 1.4918 ]
20:00:22 INFO : Flash Jetson Nano : [ 1.4935 ] tegrahost --updatesigheader cboot.bin_blheader.encrypt cboot.bin_blheader.hash zerosbk
20:00:22 INFO : Flash Jetson Nano : [ 1.4990 ]
20:00:22 INFO : Flash Jetson Nano : [ 1.5131 ] tegrahost --chip 0x21 --align tegra210-p3448-0000-p3449-0000-a02.dtb
20:00:22 INFO : Flash Jetson Nano : [ 1.5144 ]
20:00:22 INFO : Flash Jetson Nano : [ 1.5155 ] tegrahost --magicid DTB --appendsigheader tegra210-p3448-0000-p3449-0000-a02.dtb tegra210-p3448-0000-p3449-0000-a02.dtb_blheader
20:00:22 INFO : Flash Jetson Nano : [ 1.5297 ]
20:00:22 INFO : Flash Jetson Nano : [ 1.5315 ] tegrasign --key None --list tegra210-p3448-0000-p3449-0000-a02.dtb_list.xml
20:00:22 INFO : Flash Jetson Nano : [ 1.5328 ] Assuming zero filled SBK key
20:00:22 INFO : Flash Jetson Nano : [ 1.5403 ]
20:00:22 INFO : Flash Jetson Nano : [ 1.5418 ] tegrahost --updatesigheader tegra210-p3448-0000-p3449-0000-a02.dtb_blheader.encrypt tegra210-p3448-0000-p3449-0000-a02.dtb_blheader.hash zerosbk
20:00:22 INFO : Flash Jetson Nano : [ 1.5526 ]
20:00:22 INFO : Flash Jetson Nano : [ 1.6045 ] Sending bootloader and pre-requisite binaries
20:00:22 INFO : Flash Jetson Nano : [ 1.6056 ] tegrarcm --download ebt cboot.bin.encrypt 0 0 --download rp1 tegra210-p3448-0000-p3449-0000-a02.dtb.encrypt 0
20:00:22 INFO : Flash Jetson Nano : [ 1.6067 ] Applet version 00.01.0000
20:00:22 INFO : Flash Jetson Nano : [ 1.6229 ] Sending ebt
20:00:22 INFO : Flash Jetson Nano : [ 1.6236 ] [...] 100%
20:00:22 INFO : Flash Jetson Nano : [ 1.7308 ] Sending rp1
20:00:22 INFO : Flash Jetson Nano : [ 1.7352 ] [...] 100%
20:00:22 INFO : Flash Jetson Nano : [ 1.7855 ]
20:00:22 INFO : Flash Jetson Nano : [ 1.7869 ] tegrarcm --boot recovery
20:00:22 INFO : Flash Jetson Nano : [ 1.7892 ] Applet version 00.01.0000
21:50:35 INFO : Flash Jetson Nano : [ 1.7924 ]
21:50:35 INFO : Flash Jetson Nano : [ 1.7925 ] Retrieving storage infomation
21:50:35 INFO : Flash Jetson Nano : [ 1.7940 ] tegrarcm --oem platformdetails storage storage_info.bin
21:51:15 INFO : Flash Jetson Nano : [ 1.7953 ] Applet is not running on device. Continue with Bootloader
21:51:15 INFO : Flash Jetson Nano : [ 6614.6042 ]
21:51:15 INFO : Flash Jetson Nano : [ 6614.6107 ] tegradevflash --oem platformdetails storage storage_info.bin
21:51:15 INFO : Flash Jetson Nano : [ 6614.6126 ] Cannot Open USB
21:51:15 INFO : Flash Jetson Nano : [ 6653.9367 ]
21:51:15 INFO : Flash Jetson Nano : Error: Return value 8
21:51:15 INFO : Flash Jetson Nano : Command tegradevflash --oem platformdetails storage storage_info.bin
21:51:15 INFO : Flash Jetson Nano : Failed flashing t210ref.
21:51:15 INFO : Flash Jetson Nano : exit status 1
21:51:15 INFO : Flash Jetson Nano : [ Component Install Finished with Error ]
21:51:15 INFO : Flash Jetson Nano : [ 8.60 GB used. Disk Avail: 181.80 GB ]
21:51:15 INFO : Flash Jetson Nano : [ NV_L4T_FLASH_NANO_DEVKIT_WITH_OS_IMAGE_COMP Install took 1h53m35s ]
21:51:15 ERROR : Flash Jetson Nano : Run commands failed at step Install: command sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1 finished with error
21:51:15 ERROR : Flash Jetson Nano : command terminated with error
21:51:15 ERROR : install 'Flash Jetson Nano' failure, command < cd '/home/florian/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448' ; '/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter' -a='install' -c='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' -i='NV_L4T_FLASH_NANO_DEVKIT_WITH_OS_IMAGE_COMP' -v='32.2' -l='/home/florian/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448' -L='/home/florian/.nvsdkm/logs/JetPack_4.2.2_Linux_GA' -p='6407' -t='P3448-0000' -e='undefined' > terminated with error
21:51:28 INFO : install 'Device Mode Host Setup in Target SDK' Skipped
21:51:28 INFO : install 'DateTime Target Setup' Skipped
21:51:28 INFO : install 'CUDA Toolkit for L4T' Skipped
21:51:28 INFO : install 'cuDNN on Target' Skipped
21:51:28 INFO : install 'TensorRT on Target' Skipped
21:51:28 INFO : install 'OpenCV on Target' Skipped
21:51:28 INFO : install 'VisionWorks on Target' Skipped
21:51:28 INFO : install 'NVIDIA Container Runtime with Docker integration (Beta)' Skipped
21:51:28 INFO : install 'DeepStream' Skipped
21:51:28 INFO : install 'TensorFlow' Skipped
21:51:28 INFO : install 'Multimedia API' Skipped
21:51:29 INFO : All done!
I don’t know what i can do to resolve this issue.
There is an hardware issue or not ?
Because this if for an urgent project and an RMA will take a long time (around 1 or 2 week at least …)
PS: sdkmanager was install on Ubuntu 18.04, not on VM but directly on the PC.
Thanks for your help,
FLorian
The host is not able to detect the nano. Are you sure you put the device into recovery mode?
Please share the result of “lsusb” on your host when trying to flash.
