Jetson Nano B01 Boot Issue
After purchasing eight Jetson Nano B01s, I wrote and booted images to the MicroSD Card in the way Get Started With Jetson Nano Developer Kit | NVIDIA Developer told me. However, the four Jetson Nano boots normally, and the rest do not connect to the monitor even though the power LED is on. The same symptoms were shown when the MicroSD Card mounted on the precision-operated Jetson Nano was mounted on the problematic Jetson Nano and then booted. I’d like you to tell me the solution.
please re-flash with SDK Manager to update the bootloader on modules that do not operate correctly.
Bootloader resides in the QSPI memory on the module, not SD cards, so plugging a working SD card onto a device with problematic bootloader is not going to work.
VMware installed SDK Manager in Ubuntu 18.04 LTS environment.
The Jetson Nano Flash operation did not go further at 99%.
Can’t I leave the product A/S?
then please try with a real Ubuntu host PC.
Flashing with virtual machines may be unstable.
Tried with an real Ubuntu host PC but shows the same symptoms.
so the flashing ended without issues?
Any UART log here when the device fails to boot up?
03:14:14 SUMMARY: Flash Jetson Nano - flash: Depends on failed component
04:16:15 DEBUG: Flash Jetson Nano - flash: using adapter to install NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP@JETSON_NANO_TARGETS to /home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_NANO_TARGETS
04:16:15 INFO: Flash Jetson Nano - flash: [host] [ Disk Avail:402.65 GB ]
04:16:15 INFO: Flash Jetson Nano - flash: Installing component 'Flash Jetson Nano' (NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP)
04:16:15 INFO: Flash Jetson Nano - flash: change working directory to /home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra
04:16:15 INFO: Flash Jetson Nano - flash: [ Component Install Started ]
04:16:15 INFO: Flash Jetson Nano - flash: current working directory is /home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra
04:16:15 INFO: Flash Jetson Nano - flash: exec_command [host]:
04:16:15 INFO: Flash Jetson Nano - flash: **********************
04:16:15 INFO: Flash Jetson Nano - flash: #!/bin/bash
04:16:15 INFO: Flash Jetson Nano - flash: set -e
04:16:15 INFO: Flash Jetson Nano - flash: unset LC_ALL
04:16:15 INFO: Flash Jetson Nano - flash: echo sudo ./nvsdkmanager_flash.sh --nv-auto-config --username ubuntu
04:16:15 INFO: Flash Jetson Nano - flash: sudo ./nvsdkmanager_flash.sh --nv-auto-config --username ubuntu
04:16:15 INFO: Flash Jetson Nano - flash: sleep 20
04:16:15 INFO: Flash Jetson Nano - flash: exec_command: /tmp/tmp_NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP.sh
04:16:15 INFO: Flash Jetson Nano - flash: [OEMPreconfig] SDKM_INSTALL_ERROR Password for L4T new user ubuntu:
04:16:15 INFO: Flash Jetson Nano - flash: *** Checking ONLINE mode ... OK.
04:16:15 INFO: Flash Jetson Nano - flash: *** Checking target board connection ... 1 connections found.
04:16:15 INFO: Flash Jetson Nano - flash: *** Reading ECID ... FUSELEVEL=fuselevel_production hwchipid=0x21 bootauth=
04:16:15 INFO: Flash Jetson Nano - flash: *** Reading EEPROM ... "/home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py" --chip 0x21 --applet "/home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/nvtboot_recovery.bin" --skipuid --cmd "dump eeprom boardinfo cvm.bin; dump eeprom baseinfo bbd.bin"
04:16:15 INFO: Flash Jetson Nano - flash: Welcome to Tegra Flash
04:16:15 INFO: Flash Jetson Nano - flash: version 1.0.0
04:16:15 INFO: Flash Jetson Nano - flash: Type ? or help for help and q or quit to exit
04:16:15 INFO: Flash Jetson Nano - flash: Use ! to execute system commands
04:16:15 INFO: Flash Jetson Nano - flash: [ 0.0013 ] Generating RCM messages
04:16:15 INFO: Flash Jetson Nano - flash: [ 0.0034 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm /home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/nvtboot_recovery.bin 0 0
04:16:15 INFO: Flash Jetson Nano - flash: [ 0.0044 ] RCM 0 is saved as rcm_0.rcm
04:16:15 INFO: Flash Jetson Nano - flash: [ 0.0048 ] RCM 1 is saved as rcm_1.rcm
04:16:15 INFO: Flash Jetson Nano - flash: [ 0.0048 ] List of rcm files are saved in rcm_list.xml
04:16:15 INFO: Flash Jetson Nano - flash: [ 0.0048 ] Signing RCM messages
04:16:15 INFO: Flash Jetson Nano - flash: [ 0.0069 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
04:16:15 INFO: Flash Jetson Nano - flash: [ 0.0079 ] Assuming zero filled SBK key
04:16:15 INFO: Flash Jetson Nano - flash: [ 0.0140 ]
04:16:15 INFO: Flash Jetson Nano - flash: [ 0.0141 ] Copying signature to RCM mesages
04:16:15 INFO: Flash Jetson Nano - flash: [ 0.0180 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
04:16:15 INFO: Flash Jetson Nano - flash: [ 0.0230 ]
04:16:15 INFO: Flash Jetson Nano - flash: [ 0.0230 ] Boot Rom communication
04:16:15 INFO: Flash Jetson Nano - flash: [ 0.0252 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml --skipuid
04:16:15 INFO: Flash Jetson Nano - flash: [ 0.0263 ] RCM version 0X210001
04:16:16 INFO: Flash Jetson Nano - flash: [ 0.0683 ] Boot Rom communication completed
04:16:16 INFO: Flash Jetson Nano - flash: [ 1.0754 ]
04:16:16 INFO: Flash Jetson Nano - flash: [ 1.0756 ] dump EEPROM info
04:16:16 INFO: Flash Jetson Nano - flash: [ 1.0806 ] tegrarcm --oem platformdetails eeprom /home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
04:16:16 INFO: Flash Jetson Nano - flash: [ 1.0849 ] Applet version 00.01.0000
04:16:16 INFO: Flash Jetson Nano - flash: [ 1.1029 ] Saved platform info in /home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
04:16:16 INFO: Flash Jetson Nano - flash: [ 1.1793 ]
04:16:16 INFO: Flash Jetson Nano - flash: [ 1.1835 ] tegrarcm --reboot recovery
04:16:16 INFO: Flash Jetson Nano - flash: [ 1.1860 ] Applet version 00.01.0000
04:16:18 INFO: Flash Jetson Nano - flash: [ 1.2026 ]
04:16:18 INFO: Flash Jetson Nano - flash: [ 3.2041 ] Generating RCM messages
04:16:18 INFO: Flash Jetson Nano - flash: [ 3.2091 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm /home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/nvtboot_recovery.bin 0 0
04:16:18 INFO: Flash Jetson Nano - flash: [ 3.2120 ] RCM 0 is saved as rcm_0.rcm
04:16:18 INFO: Flash Jetson Nano - flash: [ 3.2147 ] RCM 1 is saved as rcm_1.rcm
04:16:18 INFO: Flash Jetson Nano - flash: [ 3.2156 ] List of rcm files are saved in rcm_list.xml
04:16:18 INFO: Flash Jetson Nano - flash: [ 3.2157 ]
04:16:18 INFO: Flash Jetson Nano - flash: [ 3.2158 ] Signing RCM messages
04:16:18 INFO: Flash Jetson Nano - flash: [ 3.2216 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
04:16:18 INFO: Flash Jetson Nano - flash: [ 3.2248 ] Assuming zero filled SBK key
04:16:18 INFO: Flash Jetson Nano - flash: [ 3.2542 ]
04:16:18 INFO: Flash Jetson Nano - flash: [ 3.2543 ] Copying signature to RCM mesages
04:16:18 INFO: Flash Jetson Nano - flash: [ 3.2610 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
04:16:18 INFO: Flash Jetson Nano - flash: [ 3.2680 ]
04:16:18 INFO: Flash Jetson Nano - flash: [ 3.2682 ] Boot Rom communication
04:16:18 INFO: Flash Jetson Nano - flash: [ 3.2737 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml
04:16:18 INFO: Flash Jetson Nano - flash: [ 3.2771 ] BR_CID: 0x32101001642c52c90000000005ff0140
04:16:18 INFO: Flash Jetson Nano - flash: [ 3.2805 ] RCM version 0X210001
04:16:19 INFO: Flash Jetson Nano - flash: [ 3.2930 ] Boot Rom communication completed
04:16:19 INFO: Flash Jetson Nano - flash: [ 4.3028 ]
04:16:19 INFO: Flash Jetson Nano - flash: [ 4.3029 ] dump EEPROM info
04:16:19 INFO: Flash Jetson Nano - flash: [ 4.3080 ] tegrarcm --oem platformdetails eeprom /home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/bbd.bin
04:16:19 INFO: Flash Jetson Nano - flash: [ 4.3106 ] Applet version 00.01.0000
04:16:20 INFO: Flash Jetson Nano - flash: [ 4.3267 ] Saved platform info in /home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/bbd.bin
04:16:20 INFO: Flash Jetson Nano - flash: [ 4.4026 ]
04:16:20 INFO: Flash Jetson Nano - flash: [ 4.4061 ] tegrarcm --reboot recovery
04:16:22 INFO: Flash Jetson Nano - flash: [ 4.4088 ] Applet version 00.01.0000
04:16:22 INFO: Flash Jetson Nano - flash: [ 4.4266 ]
04:16:22 INFO: Flash Jetson Nano - flash: --- Reading board information succeeded.
04:16:22 INFO: Flash Jetson Nano - flash: Parsing baseboard EEPROM:
04:16:22 INFO: Flash Jetson Nano - flash: --- Parsing board ID (3448) succeeded.
04:16:22 INFO: Flash Jetson Nano - flash: --- Parsing board version (402) succeeded.
04:16:22 INFO: Flash Jetson Nano - flash: --- Parsing board SKU (0000) succeeded.
04:16:22 INFO: Flash Jetson Nano - flash: --- Parsing board REV (F.0) succeeded.
04:16:22 INFO: Flash Jetson Nano - flash: jetson-nano-devkit found.
04:16:22 INFO: Flash Jetson Nano - flash: *** Finding boot device ... Boot device mmcblk0p1 found.
04:16:22 INFO: Flash Jetson Nano - flash: "/home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/flash.sh" -C nv-auto-config jetson-nano-devkit mmcblk0p1
04:16:22 INFO: Flash Jetson Nano - flash: ###############################################################################
04:16:22 INFO: Flash Jetson Nano - flash: # L4T BSP Information:
04:16:22 INFO: Flash Jetson Nano - flash: # R32 , REVISION: 7.4
04:16:22 INFO: Flash Jetson Nano - flash: # Target Board Information:
04:16:22 INFO: Flash Jetson Nano - flash: # Name: jetson-nano-devkit, Board Family: t210ref, SoC: Tegra 210,
04:16:22 INFO: Flash Jetson Nano - flash: # OpMode: production, Boot Authentication: ,
04:16:22 INFO: Flash Jetson Nano - flash: # Disk encryption: disabled ,
04:16:22 INFO: Flash Jetson Nano - flash: ./tegraflash.py --chip 0x21 --applet "/home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/nvtboot_recovery.bin" --skipuid --cmd "dump eeprom boardinfo cvm.bin"
04:16:22 INFO: Flash Jetson Nano - flash: Welcome to Tegra Flash
04:16:22 INFO: Flash Jetson Nano - flash: version 1.0.0
04:16:22 INFO: Flash Jetson Nano - flash: Type ? or help for help and q or quit to exit
04:16:22 INFO: Flash Jetson Nano - flash: Use ! to execute system commands
04:16:22 INFO: Flash Jetson Nano - flash: [ 0.0012 ] Generating RCM messages
04:16:22 INFO: Flash Jetson Nano - flash: [ 0.0038 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm /home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/nvtboot_recovery.bin 0 0
04:16:22 INFO: Flash Jetson Nano - flash: [ 0.0047 ] RCM 0 is saved as rcm_0.rcm
04:16:22 INFO: Flash Jetson Nano - flash: [ 0.0052 ] RCM 1 is saved as rcm_1.rcm
04:16:22 INFO: Flash Jetson Nano - flash: [ 0.0052 ] List of rcm files are saved in rcm_list.xml
04:16:22 INFO: Flash Jetson Nano - flash: [ 0.0052 ] Signing RCM messages
04:16:22 INFO: Flash Jetson Nano - flash: [ 0.0063 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
04:16:22 INFO: Flash Jetson Nano - flash: [ 0.0070 ] Assuming zero filled SBK key
04:16:22 INFO: Flash Jetson Nano - flash: [ 0.0111 ]
04:16:22 INFO: Flash Jetson Nano - flash: [ 0.0112 ] Copying signature to RCM mesages
04:16:22 INFO: Flash Jetson Nano - flash: [ 0.0123 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
04:16:22 INFO: Flash Jetson Nano - flash: [ 0.0133 ]
04:16:22 INFO: Flash Jetson Nano - flash: [ 0.0134 ] Boot Rom communication
04:16:22 INFO: Flash Jetson Nano - flash: [ 0.0142 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml --skipuid
04:16:22 INFO: Flash Jetson Nano - flash: [ 0.0154 ] RCM version 0X210001
04:16:23 INFO: Flash Jetson Nano - flash: [ 0.0568 ] Boot Rom communication completed
04:16:23 INFO: Flash Jetson Nano - flash: [ 1.0636 ]
04:16:23 INFO: Flash Jetson Nano - flash: [ 1.0638 ] dump EEPROM info
04:16:23 INFO: Flash Jetson Nano - flash: [ 1.0690 ] tegrarcm --oem platformdetails eeprom /home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
04:16:23 INFO: Flash Jetson Nano - flash: [ 1.0728 ] Applet version 00.01.0000
04:16:23 INFO: Flash Jetson Nano - flash: [ 1.0913 ] Saved platform info in /home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
04:16:23 INFO: Flash Jetson Nano - flash: [ 1.1682 ]
04:16:23 INFO: Flash Jetson Nano - flash: [ 1.1710 ] tegrarcm --reboot recovery
04:16:23 INFO: Flash Jetson Nano - flash: [ 1.1719 ] Applet version 00.01.0000
04:16:25 INFO: Flash Jetson Nano - flash: [ 1.1743 ]
04:16:25 ERROR: Flash Jetson Nano - flash: Board ID(3448) version(402)
04:16:25 INFO: Flash Jetson Nano - flash: copying bctfile(/home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/t210ref/BCT/P3448_A00_lpddr4_204Mhz_P987.cfg)... done.
04:16:25 INFO: Flash Jetson Nano - flash: copying bootloader(/home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
04:16:25 INFO: Flash Jetson Nano - flash: copying initrd(/home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
04:16:25 INFO: Flash Jetson Nano - flash: Making Boot image... done.
04:16:25 INFO: Flash Jetson Nano - flash: Existing sosfile(/home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
04:16:25 INFO: Flash Jetson Nano - flash: copying tegraboot(/home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/t210ref/nvtboot.bin)... done.
04:16:25 INFO: Flash Jetson Nano - flash: copying cpu_bootloader(/home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
04:16:25 INFO: Flash Jetson Nano - flash: copying bpffile(/home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/t210ref/sc7entry-firmware.bin)... done.
04:16:25 INFO: Flash Jetson Nano - flash: copying wb0boot(/home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/t210ref/warmboot.bin)... done.
04:16:25 INFO: Flash Jetson Nano - flash: Existing tosfile(/home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/tos-mon-only.img) reused.
04:16:25 INFO: Flash Jetson Nano - flash: Existing eksfile(/home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/eks.img) reused.
04:16:25 ERROR: Flash Jetson Nano - flash: /home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/flash.sh: line 2661: [: : integer expression expected
04:16:25 INFO: Flash Jetson Nano - flash: copying dtbfile(/home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-b00.dtb)... done.
04:16:25 INFO: Flash Jetson Nano - flash: Copying nv_boot_control.conf to root
This is the flashing log, not UART log…
I don’t have the cable from the video
Then please get one, or we cannot know why the device is not booting up properly.
Just want to clarify, is it that you still failed to flash the device, or the device failed to boot up?
Both.
First the device failed to boot up
so you said me “please re-flash with SDK Manager to update the bootloader on modules that do not operate correctly.”
However, flash operation did not improve to 99% in both VMware and Ubuntu host PC environments
So I still failed to falsh the device and the device failed to boot up
can you try flashing with scripts in our BSP and attach the log here?
https://docs.nvidia.com/jetson/archives/l4t-archived/l4t-3274/index.html
