Nano 4gB Boot up Issues
I was attempting to flash our Jetson 4gB Nano (Dev Kit). We followed the instructions from the NVIDIA Jetson website to get started with flashing the SD card. We then put the SD card into the Jetson. We connected the DC power supply to the Jetson and received power confirmation through the LED indicator. We connected the Jetson to a monitor through an HDMI Connection and then waited for our first boot. It was in this part that we ran into our first problems. The Jetson would not boot and we received no visual feedback on the monitor. We attempted to solve this issue by:
  • Confirming cable connections and power conditions
  • Switching HDMI Cables
  • Switching to Display Port cable
  • Trying new monitor
  • Using a new DC power supply
  • Powering the device through the 5V and GND pins on the Jetson
  • Rewriting the SD Card through a computer with a different OS
  • Downloading an older version of the SD Card Image
  • Buying a new SD Card and writing on that one
None of these attempts resulted in any visual feedback on a monitor. We then tried to install the image from the command line from an Ubunutu machine:
After booting up the Jetson, we were finally able to successfully get the NVIDIA logo to pop up. However, it proceeded to then crash with this error shown in the image.
https://developer.download.nvidia.com/embedded/L4T/r32-3-1_Release_v1.0/t186ref_release_aarch64/l4t_quick_start_guide.txt?szMfCaGgKjuRx_ubYl4_gitbttJSjxNK1LcEkg4lRZnpd4yeCQKw6Up6oKPCgBYniRp0ppep7mm8_S7i7-Xc6VnUiDg_qpm2DsOHTzynkVV2YxlrwMY2i3Gu0ieR7fKKHv-r2FNqYWTnuYGa2QWg5uiwuuoMzySoqQi-djxNoXR61y_0WAYfEJiJGd56B6JKnfE&t=eyJscyI6ImdzZW8iLCJsc2QiOiJodHRwczpcL1wvd3d3Lmdvb2dsZS5jb21cLyJ9
Please use this method to provide log:
This is the log file we got after following those directions:
e[!pe[?3;4le[4le>e[0me(Be[?1he=e[He[2Je[?12le[?25h
Welcome to minicom 2.7.1
OPTIONS: I18n
Compiled on Dec 23 2019, 02:06:26.
Port /dev/ttyUSB1, 17:23:47
Press CTRL-A Z for help on special keys
?[0000.125] [L4T TegraBoot] (version 00.00.2018.01-l4t-8728f3cb)
[0000.130] Processing in cold boot mode Bootloader 2
[0000.135] A02 Bootrom Patch rev = 1023
[0000.138] Power-up reason: pmc por
[0000.141] No Battery Present
[0000.144] pmic max77620 reset reason
[0000.147] pmic max77620 NVERC : 0x40
[0000.151] RamCode = 0
[0000.153] Platform has DDR4 type RAM
[0000.156] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0x2311aa
[0000.172] Entering ramdump check
[0000.175] Get RamDumpCarveOut = 0x0
[0000.179] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
e[23;80H e[24;1H[0000.184] Last reboot was clean, booting normally!
e[23;80H e[24;1H[0000.188] Sdram initialization is successful
e[23;80H e[24;1H[0000.192] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
e[23;80H e[24;1H[0000.199] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
e[23;80H e[24;1H[0000.204] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
e[23;80H e[24;1H[0000.210] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
e[23;80H e[24;1H[0000.216] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
e[23;80H e[24;1H[0000.222] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
e[23;80H e[24;1H[0000.228] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
e[23;80H e[24;1H[0000.234] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
e[23;80H e[24;1H[0000.250] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
e[23;80H e[24;1H[0000.256] Platform-DebugCarveout: 0
e[23;80H e[24;1H[0000.259] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
e[23;80H e[24;1H[0000.265] Non secure mode, and RB not enabled.
e[23;80H e[24;1H[0000.269] BoardID = 3448, SKU = 0x0
e[23;80H e[24;1H[0000.272] QSPI-ONLY: SkipQspiOnlyFlag = 0
e[23;80H e[24;1H[0000.276] Nano-SD: checking PT table on QSPI
e[23;80H e[24;1H[0000.281] Initialize FailControl
e[23;80H e[24;1H[0000.284] Read PT from (2:0)
e[23;80H e[24;1H[0000.314] PT crc32 and magic check passed.
e[23;80H e[24;1H[0000.318] Using BFS PT to query partitions
e[23;80H e[24;1H[0000.324] Loading Tboot-CPU binary
e[23;80H e[24;1H[0000.352] Verifying TBC in OdmNonSecureSBK mode
e[23;80H e[24;1H[0000.362] Bootloader load address is 0xa0000000, entry address is 0xa0000258
e[23;80H e[24;1H[0000.369] Bootloader downloaded successfully.
e[23;80H e[24;1H[0000.373] Downloaded Tboot-CPU binary to 0xa0000258
e[23;80H e[24;1H[0000.378] MAX77620_GPIO5 configured
e[23;80H e[24;1H[0000.381] CPU power rail is up
e[23;80H e[24;1H[0000.384] CPU clock enabled
e[23;80H e[24;1H[0000.388] Performing RAM repair
e[23;80H e[24;1H[0000.391] Updating A64 Warmreset Address to 0xa00002e9
e[23;80H e[24;1H[0000.396] BoardID = 3448, SKU = 0x0
e[23;80H e[24;1H[0000.399] QSPI-ONLY: SkipQspiOnlyFlag = 0
e[23;80H e[24;1H[0000.403] Nano-SD: checking PT table on QSPI
e[23;80H e[24;1H[0000.407] NvTbootFailControlDoFailover: No failover; Continuing
e[23;80H e[24;1H[0000.413] Loading NvTbootBootloaderDTB
e[23;80H e[24;1H[0000.480] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
e[23;80H e[24;1H[0000.551] Bootloader DTB Load Address: 0x83000000
e[23;80H e[24;1H[0000.556] BoardID = 3448, SKU = 0x0
e[23;80H e[24;1H[0000.559] QSPI-ONLY: SkipQspiOnlyFlag = 0
e[23;80H e[24;1H[0000.563] Nano-SD: checking PT table on QSPI
e[23;80H e[24;1H[0000.567] NvTbootFailControlDoFailover: No failover; Continuing
e[23;80H e[24;1H[0000.574] Loading NvTbootKernelDTB
e[23;80H e[24;1H[0000.640] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
e[23;80H e[24;1H[0000.711] Kernel DTB Load Address: 0x83100000
e[23;80H e[24;1H[0000.715] BoardID = 3448, SKU = 0x0
e[23;80H e[24;1H[0000.718] QSPI-ONLY: SkipQspiOnlyFlag = 0
e[23;80H e[24;1H[0000.722] Nano-SD: checking PT table on QSPI
e[23;80H e[24;1H[0000.727] NvTbootFailControlDoFailover: No failover; Continuing
e[23;80H e[24;1H[0000.734] Loading cboot binary
e[23;80H e[24;1H[0000.850] Verifying EBT in OdmNonSecureSBK mode
e[23;80H e[24;1H[0000.892] Bootloader load address is 0x92c00000, entry address is 0x92c00258
e[23;80H e[24;1H[0000.899] Bootloader downloaded successfully.
e[23;80H e[24;1H[0000.903] BoardID = 3448, SKU = 0x0
e[23;80H e[24;1H[0000.906] QSPI-ONLY: SkipQspiOnlyFlag = 0
e[23;80H e[24;1H[0000.910] Nano-SD: checking PT table on QSPI
e[23;80H e[24;1H[0000.914] NvTbootFailControlDoFailover: No failover; Continuing
e[23;80H e[24;1H[0000.921] PT: Partition NCT NOT found !
e[23;80H e[24;1H[0000.924] Warning: Find Partition via PT Failed
e[23;80H e[24;1H[0000.929] Next binary entry address: 0x92c00258
e[23;80H e[24;1H[0000.933] BoardId: 3448
e[23;80H e[24;1H[0000.938] Overriding pmu board id with proc board id
e[23;80H e[24;1H[0000.942] Display board id is not available
e[23;80H e[24;1H[0000.947] BoardID = 3448, SKU = 0x0
e[23;80H e[24;1H[0000.950] QSPI-ONLY: SkipQspiOnlyFlag = 0
e[23;80H e[24;1H[0000.954] Nano-SD: checking PT table on QSPI
e[23;80H e[24;1H[0000.958] NvTbootFailControlDoFailover: No failover; Continuing
e[23;80H e[24;1H[0001.065] Verifying SC7EntryFw in OdmNonSecureSBK mode
e[23;80H e[24;1H[0001.121] /bpmp deleted
e[23;80H e[24;1H[0001.123] SC7EntryFw header found loaded at 0xff700000
e[23;80H e[24;1H[0001.311] OVR2 PMIC
e[23;80H e[24;1H[0001.313] Bpmp FW successfully loaded
e[23;80H e[24;1H[0001.316] BoardID = 3448, SKU = 0x0
e[23;80H e[24;1H[0001.320] QSPI-ONLY: SkipQspiOnlyFlag = 0
e[23;80H e[24;1H[0001.323] Nano-SD: checking PT table on QSPI
e[23;80H e[24;1H[0001.328] NvTbootFailControlDoFailover: No failover; Continuing
e[23;80H e[24;1H[0001.335] WB0 init successfully at 0xff780000
e[23;80H e[24;1H[0001.339] Verifying NvTbootWb0 in OdmNonSecureSBK mode
e[23;80H e[24;1H[0001.344] Set NvDecSticky Bits
e[23;80H e[24;1H[0001.348] GSC2 address ff53fffc value c0edbbcc
e[23;80H e[24;1H[0001.354] GSC MC Settings done
e[23;80H e[24;1H[0001.357] BoardID = 3448, SKU = 0x0
e[23;80H e[24;1H[0001.360] QSPI-ONLY: SkipQspiOnlyFlag = 0
e[23;80H e[24;1H[0001.364] Nano-SD: checking PT table on QSPI
e[23;80H e[24;1H[0001.368] NvTbootFailControlDoFailover: No failover; Continuing
e[23;80H e[24;1H[0001.375] TOS Image length 53680
e[23;80H e[24;1H[0001.378] Monitor size 53680
e[23;80H e[24;1H[0001.381] OS size 0
e[23;80H e[24;1H[0001.396] Secure Os AES-CMAC Verification Success!
e[23;80H e[24;1H[0001.401] TOS image cipher info: plaintext
e[23;80H e[24;1H[0001.405] Loading and Validation of Secure OS Successful
e[23;80H e[24;1H[0001.421] SC7 Entry Firmware - 0xff700000, 0x4000
e[23;80H e[24;1H[0001.425] NvTbootPackSdramParams: start.
e[23;80H e[24;1H[0001.430] NvTbootPackSdramParams: done.
e[23;80H e[24;1H[0001.434] Tegraboot started after 51856 us
e[23;80H e[24;1H[0001.438] Basic modules init took 936024 us
e[23;80H e[24;1H[0001.442] Sec Bootdevice Read Time = 12 ms, Read Size = 61 KB
e[23;80H e[24;1H[0001.448] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
e[23;80H e[24;1H[0001.453] Next stage binary read took 102859 us
e[23;80H e[24;1H[0001.457] Carveout took -132462 us
e[23;80H e[24;1H[0001.461] CPU initialization took 510777 us
e[23;80H e[24;1H[0001.465] Total time taken by TegraBoot 1417198 us
e[23;80H e[24;1H
e[23;80H e[24;1H[0001.470] Starting CPU & Halting co-processor
e[23;80H e[24;1H
e[23;80H e[24;1H64NOTICE: BL31: v1.3(release):b5eeb33
e[23;80H e[24;1HNOTICE: BL31: Built : 14:22:20, Apr 20 2022
e[23;80H e[24;1HERROR: Error initializing runtime service trusty_fast
e[23;80H e[24;1H[0001.591] RamCode = 0
e[23;80H e[24;1H[0001.596] LPDDR4 Training: Read DT: Number of tables = 2
e[23;80H e[24;1H[0001.601] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
e[23;80H e[24;1H[0001.614] EMC Training Successful
e[23;80H e[24;1H[0001.617] 408000 not found in DVFS table
e[23;80H e[24;1H[0001.623] RamCode = 0
e[23;80H e[24;1H[0001.627] DT Write: emc-table@204000 succeeded
e[23;80H e[24;1H[0001.632] DT Write: emc-table@1600000 succeeded
e[23;80H e[24;1H[0001.636] LPDDR4 Training: Write DT: Number of tables = 2
e[23;80H e[24;1H[0001.685]
e[23;80H e[24;1H[0001.686] Debug Init done
e[23;80H e[24;1H[0001.688] Marked DTB cacheable
e[23;80H e[24;1H[0001.691] Bootloader DTB loaded at 0x83000000
e[23;80H e[24;1H[0001.696] Marked DTB cacheable
e[23;80H e[24;1H[0001.699] Kernel DTB loaded at 0x83100000
e[23;80H e[24;1H[0001.703] DeviceTree Init done
e[23;80H e[24;1H[0001.716] Pinmux applied successfully
e[23;80H e[24;1H[0001.720] gicd_base: 0x50041000
e[23;80H e[24;1H[0001.724] gicc_base: 0x50042000
e[23;80H e[24;1H[0001.727] Interrupts Init done
e[23;80H e[24;1H[0001.731] Using base:0x60005090 & irq:208 for tick-timer
e[23;80H e[24;1H[0001.736] Using base:0x60005098 for delay-timer
e[23;80H e[24;1H[0001.740] platform_init_timer: DONE
e[23;80H e[24;1H[0001.744] Timer(tick) Init done
e[23;80H e[24;1H[0001.748] osc freq = 38400 khz
e[23;80H e[24;1H[0001.752]
e[23;80H e[24;1H[0001.753] Welcome to L4T Cboot
e[23;80H e[24;1H[0001.756]
e[23;80H e[24;1H[0001.757] Cboot Version: 00.00.2018.01-t210-a2f2e4b8
e[23;80H e[24;1H[0001.762] calling constructors
e[23;80H e[24;1H[0001.765] initializing heap
e[23;80H e[24;1H[0001.767] initializing threads
e[23;80H e[24;1H[0001.770] initializing timers
e[23;80H e[24;1H[0001.773] creating bootstrap completion thread
e[23;80H e[24;1H[0001.778] top of bootstrap2()
e[23;80H e[24;1H[0001.780] CPU: ARM Cortex A57
e[23;80H e[24;1H[0001.783] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
e[23;80H e[24;1H[0001.788] initializing platform
e[23;80H e[24;1H[0001.795] Manufacturer: MF = 0xc2, ID MSB = 0x25
e[23;80H e[24;1H[0001.800] ID LSB = 0x36, ID-CFI len = 194 bytes
e[23;80H e[24;1H[0001.804] Macronix QSPI chip present
e[23;80H e[24;1H[0001.808] SPI device register
e[23;80H e[24;1H[0001.811] init boot device
e[23;80H e[24;1H[0001.813] allocating memory for boot device(SPI)
e[23;80H e[24;1H[0001.818] registering boot device
e[23;80H e[24;1H[0001.826] QSPI bdev is already initialized
e[23;80H e[24;1H[0001.830] Enable APE clock
e[23;80H e[24;1H[0001.833] Un-powergate APE partition
e[23;80H e[24;1H[0001.836] of_register: registering tegra_udc to of_hal
e[23;80H e[24;1H[0001.841] of_register: registering inv20628-driver to of_hal
e[23;80H e[24;1H[0001.847] of_register: registering ads1015-driver to of_hal
e[23;80H e[24;1H[0001.853] of_register: registering lp8557-bl-driver to of_hal
e[23;80H e[24;1H[0001.858] of_register: registering bq2419x_charger to of_hal
e[23;80H e[24;1H[0001.864] of_register: registering bq27441_fuel_gauge to of_hal
e[23;80H e[24;1H[0001.875] gpio framework initialized
e[23;80H e[24;1H[0001.879] of_register: registering tca9539_gpio to of_hal
e[23;80H e[24;1H[0001.884] of_register: registering tca9539_gpio to of_hal
e[23;80H e[24;1H[0001.890] of_register: registering i2c_bus_driver to of_hal
e[23;80H e[24;1H[0001.895] of_register: registering i2c_bus_driver to of_hal
e[23;80H e[24;1H[0001.901] of_register: registering i2c_bus_driver to of_hal
e[23;80H e[24;1H[0001.906] pmic framework initialized
e[23;80H e[24;1H[0001.910] of_register: registering max77620_pmic to of_hal
e[23;80H e[24;1H[0001.915] regulator framework initialized
e[23;80H e[24;1H[0001.919] of_register: registering tps65132_bl_driver to of_hal
e[23;80H e[24;1H[0001.925] initializing target
e[23;80H e[24;1H[0001.931] gpio_driver_register: register ‘tegra_gpio_driver’ driver
e[23;80H e[24;1H[0001.939] board ID = D78, board SKU = 0
e[23;80H e[24;1H[0001.943] Skipping Z3!
e[23;80H e[24;1H[0001.947] fixed regulator driver initialized
e[23;80H e[24;1H[0001.965] initializing OF layer
e[23;80H e[24;1H[0001.968] NCK carveout not present
e[23;80H e[24;1H[0001.971] Skipping dts_overrides
e[23;80H e[24;1H[0001.976] of_children_init: Ops found for compatible string nvidia,tegra210-i2e[24;80H
e[23;80Hce[24;1H[0001.992] I2C Bus Init done
e[23;80H e[24;1H[0001.995] of_children_init: Ops found for compatible string nvidia,tegra210-i2e[24;80H
e[23;80Hce[24;1H[0002.005] I2C Bus Init done
e[23;80H e[24;1H[0002.008] of_children_init: Ops found for compatible string nvidia,tegra210-i2e[24;80H
e[23;80Hce[24;1H[0002.018] I2C Bus Init done
e[23;80H e[24;1H[0002.021] of_children_init: Ops found for compatible string nvidia,tegra210-i2e[24;80H
e[23;80Hce[24;1H[0002.031] I2C Bus Init done
e[23;80H e[24;1H[0002.034] of_children_init: Ops found for compatible string nvidia,tegra210-i2e[24;80H
e[23;80Hce[24;1H[0002.044] I2C Bus Init done
e[23;80H e[24;1H[0002.047] of_children_init: Ops found for compatible string maxim,max77620
e[23;80H e[24;1H[0002.057] max77620_init using irq 118
e[23;80H e[24;1H[0002.062] register ‘maxim,max77620’ pmic
e[23;80H e[24;1H[0002.066] gpio_driver_register: register ‘max77620-gpio’ driver
e[23;80H e[24;1H[0002.072] of_children_init: Ops found for compatible string nvidia,tegra210-i2e[24;80H
e[23;80Hce[24;1H[0002.083] I2C Bus Init done
e[23;80H e[24;1H[0002.086] NCK carveout not present
e[23;80H e[24;1H[0002.096] Find /i2c@7000c000’s alias i2c0
e[23;80H e[24;1H[0002.100] get eeprom at 1-a0, size 256, type 0
e[23;80H e[24;1H[0002.109] Find /i2c@7000c500’s alias i2c2
e[23;80H e[24;1H[0002.112] get eeprom at 3-a0, size 256, type 0
e[23;80H e[24;1H[0002.117] get eeprom at 3-ae, size 256, type 0
e[23;80H e[24;1H[0002.121] pm_ids_update: Updating 1,a0, size 256, type 0
e[23;80H e[24;1H[0002.127] I2C slave not started
e[23;80H e[24;1H[0002.130] I2C write failed
e[23;80H e[24;1H[0002.132] Writing offset failed
e[23;80H e[24;1H[0002.135] eeprom_init: EEPROM read failed
e[23;80H e[24;1H[0002.139] pm_ids_update: eeprom init failed
e[23;80H e[24;1H[0002.143] pm_ids_update: Updating 3,a0, size 256, type 0
e[23;80H e[24;1H[0002.173] pm_ids_update: The pm board id is 3448-0000-401
e[23;80H e[24;1H[0002.180] Adding plugin-manager/ids/3448-0000-401=/i2c@7000c500:module@0x50
e[23;80H e[24;1H[0002.189] pm_ids_update: pm id update successful
e[23;80H e[24;1H[0002.193] pm_ids_update: Updating 3,ae, size 256, type 0
e[23;80H e[24;1H[0002.223] pm_ids_update: The pm board id is 3449-0000-400
e[23;80H e[24;1H[0002.229] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
e[23;80H e[24;1H[0002.237] pm_ids_update: pm id update successful
e[23;80H e[24;1H[0002.268] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
e[23;80H e[24;1H[0002.273] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
e[23;80H e[24;1H[0002.281] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
e[23;80H e[24;1H[0002.287] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
e[23;80H e[24;1H[0002.296] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:3c:d9:ae
e[23;80H e[24;1H[0002.302] Plugin Manager: Parse ODM data 0x000a4000
e[23;80H e[24;1H[0002.314] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x7e[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80H
e[23;80H e[24;1H[0002.329] Find /i2c@7000c000’s alias i2c0
e[23;80H e[24;1H[0002.333] get eeprom at 1-a0, size 256, type 0
e[23;80H e[24;1H[0002.341] Find /i2c@7000c500’s alias i2c2
e[23;80H e[24;1H[0002.345] get eeprom at 3-a0, size 256, type 0
e[23;80H e[24;1H[0002.350] get eeprom at 3-ae, size 256, type 0
e[23;80H e[24;1H[0002.354] pm_ids_update: Updating 1,a0, size 256, type 0
e[23;80H e[24;1H[0002.359] I2C slave not started
e[23;80H e[24;1H[0002.362] I2C write failed
e[23;80H e[24;1H[0002.365] Writing offset failed
e[23;80H e[24;1H[0002.368] eeprom_init: EEPROM read failed
e[23;80H e[24;1H[0002.372] pm_ids_update: eeprom init failed
e[23;80H e[24;1H[0002.376] pm_ids_update: Updating 3,a0, size 256, type 0
e[23;80H e[24;1H[0002.406] pm_ids_update: The pm board id is 3448-0000-401
e[23;80H e[24;1H[0002.413] Adding plugin-manager/ids/3448-0000-401=/i2c@7000c500:module@0x50
e[23;80H e[24;1H[0002.419] pm_ids_update: pm id update successful
e[23;80H e[24;1H[0002.424] pm_ids_update: Updating 3,ae, size 256, type 0
e[23;80H e[24;1H[0002.454] pm_ids_update: The pm board id is 3449-0000-400
e[23;80H e[24;1H[0002.460] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
e[23;80H e[24;1H[0002.467] pm_ids_update: pm id update successful
e[23;80H e[24;1H[0002.498] Add serial number:1421621055684 as DT property
e[23;80H e[24;1H[0002.505] Applying platform configs
e[23;80H e[24;1H[0002.512] platform-init is not present. Skipping
e[23;80H e[24;1H[0002.516] calling apps_init()
e[23;80H e[24;1H[0002.522] Couldn’t find GPT header
e[23;80H e[24;1H[0002.527] Proceeding to Cold Boot
e[23;80H e[24;1H[0002.530] starting app android_boot_app
e[23;80H e[24;1H[0002.534] Device state: unlocked
e[23;80H e[24;1H[0002.537] display console init
e[23;80H e[24;1H[0002.545] could not find regulator
e[23;80H e[24;1H[0002.568] hdmi cable not connected
e[23;80H e[24;1H[0002.572] is_hdmi_needed: HDMI not connected, returning false
e[23;80H e[24;1H[0002.577] hdmi is not connected
e[23;80H e[24;1H[0002.580] sor0 is not supportDT entry for leds-pwm not found
e[23;80H e[24;1He[0002.589] d
e[23;80H e[24;1H[0002.591] display_console_init: no valid display out_type
e[23;80H e[24;1H[0002.598] subnode volume_up is not found !
e[23;80H e[24;1H[0002.602] subnode back is not found !
e[23;80H e[24;1H[0002.606] subnode volume_down is not found !
e[23;80H e[24;1H[0002.610] subnode menu is not found !
e[23;80H e[24;1H[0002.614] Gpio keyboard init success
e[23;80H e[24;1H[0002.694] found decompressor handler: lz4-legacy
e[23;80H e[24;1H[0002.709] decompressing blob (type 1)
e[23;80H e[24;1H[0002.775] display_resolution: No display init
e[23;80H e[24;1H[0002.779] Failed to retrieve display resolution
e[23;80H e[24;1H[0002.783] Could not load/initialize BMP blob
ignoring
e[23;80H e[24;1H[0002.789] -------> se_aes_verify_sbk_clear: 747
e[23;80H e[24;1H[0002.793] se_aes_verify_sbk_clear: Error
e[23;80H e[24;1H[0002.797] SE operation failed
e[23;80H e[24;1H[0002.800] bl_battery_charging: connected to external power supply
e[23;80H e[24;1H[0002.809] display_console_ioctl: No display init
e[23;80H e[24;1H[0002.813] switch_backlight failed
e[23;80H e[24;1H[0002.820] device_query_partition_size: failed to open partition spiflash0:MSC e[24;80H
e[23;80H!e[24;1H[0002.827] MSC Partition not found
e[23;80H e[24;1H[0002.833] device_query_partition_size: failed to open partition spiflash0:USP e[24;80H
e[23;80H!e[24;1H[0002.841] USP partition read failed!
e[23;80H e[24;1H[0002.844] blob_init: blob-partition USP header read failed
e[23;80H e[24;1H[0002.850] android_boot Unable to update recovery partition
e[23;80H e[24;1H[0002.855] kfs_getpartname: name = LNX
e[23;80H e[24;1H[0002.859] Loading kernel from LNX
e[23;80H e[24;1H[0002.868] Found 19 BFS partitions in “spiflash0”
e[23;80H e[24;1H[0003.188] load kernel from storage
e[23;80H e[24;1H[0003.193] decompressor handler not found
e[23;80H e[24;1H[0003.459] Successfully loaded kernel and ramdisk images
e[23;80H e[24;1H[0003.464] board ID = D78, board SKU = 0
e[23;80H e[24;1H[0003.469] sdmmc node status = okay
e[23;80H e[24;1H[0003.472] sdcard instance = 0
e[23;80H e[24;1H[0003.475] sdmmc cd-inverted
e[23;80H e[24;1H[0003.478] sdcard gpio handle 0x5b
e[23;80H e[24;1H[0003.481] sdcard gpio pin 0xc9
e[23;80H e[24;1H[0003.484] sdcard gpio flags 0x0
e[23;80H e[24;1H[0003.487] vmmc-supply 0x9d
e[23;80H e[24;1H[0003.490] cd_gpio_pin = 201
e[23;80H e[24;1H[0003.492] pin_state = 0
e[23;80H e[24;1H[0003.495] Found sdcard
e[23;80H e[24;1H[0003.497] SD-card IS present
e[23;80H e[24;1H[0003.500] load_and_boot_kernel: SD card detected OK
e[23;80H e[24;1H[0003.506] display_resolution: No display init
e[23;80H e[24;1H[0003.510] Failed to retrieve display resolution
e[23;80H e[24;1H[0003.514] bmp blob is not loaded and initialized
e[23;80H e[24;1H[0003.519] Failed to display boot-logo
e[23;80H e[24;1H[0003.523] NCK carveout not present
e[23;80H e[24;1H[0003.526] Skipping dts_overrides
e[23;80H e[24;1H[0003.529] NCK carveout not present
e[23;80H e[24;1H[0003.539] Find /i2c@7000c000’s alias i2c0
e[23;80H e[24;1H[0003.543] get eeprom at 1-a0, size 256, type 0
e[23;80H e[24;1H[0003.551] Find /i2c@7000c500’s alias i2c2
e[23;80H e[24;1H[0003.555] get eeprom at 3-a0, size 256, type 0
e[23;80H e[24;1H[0003.559] get eeprom at 3-ae, size 256, type 0
e[23;80H e[24;1H[0003.564] pm_ids_update: Updating 1,a0, size 256, type 0
e[23;80H e[24;1H[0003.569] I2C slave not started
e[23;80H e[24;1H[0003.572] I2C write failed
e[23;80H e[24;1H[0003.575] Writing offset failed
e[23;80H e[24;1H[0003.578] eeprom_init: EEPROM read failed
e[23;80H e[24;1H[0003.582] pm_ids_update: eeprom init failed
e[23;80H e[24;1H[0003.586] pm_ids_update: Updating 3,a0, size 256, type 0
e[23;80H e[24;1H[0003.616] pm_ids_update: The pm board id is 3448-0000-401
e[23;80H e[24;1H[0003.623] Adding plugin-manager/ids/3448-0000-401=/i2c@7000c500:module@0x50
e[23;80H e[24;1H[0003.631] pm_ids_update: pm id update successful
e[23;80H e[24;1H[0003.636] pm_ids_update: Updating 3,ae, size 256, type 0
e[23;80H e[24;1H[0003.666] pm_ids_update: The pm board id is 3449-0000-400
e[23;80H e[24;1H[0003.672] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
e[23;80H e[24;1H[0003.680] pm_ids_update: pm id update successful
e[23;80H e[24;1H[0003.710] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
e[23;80H e[24;1H[0003.716] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
e[23;80H e[24;1H[0003.724] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
e[23;80H e[24;1H[0003.730] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
e[23;80H e[24;1H[0003.738] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:3c:d9:ae
e[23;80H e[24;1H[0003.745] Plugin Manager: Parse ODM data 0x000a4000
e[23;80H e[24;1H[0003.757] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x7e[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80H
e[23;80H e[24;1H[0003.765] Add serial number:1421621055684 as DT property
e[23;80H e[24;1H[0003.774] “bpmp” doesn’t exist, creating
e[23;80H e[24;1H[0003.780] Updated bpmp info to DTB
e[23;80H e[24;1H[0003.785] Updated initrd info to DTB
e[23;80H e[24;1H[0003.788] “proc-board” doesn’t exist, creating
e[23;80H e[24;1H[0003.794] Updated board info to DTB
e[23;80H e[24;1H[0003.797] “pmu-board” doesn’t exist, creating
e[23;80H e[24;1H[0003.803] Updated board info to DTB
e[23;80H e[24;1H[0003.807] “display-board” doesn’t exist, creating
e[23;80H e[24;1H[0003.813] Updated board info to DTB
e[23;80H e[24;1H[0003.816] “reset” doesn’t exist, creating
e[23;80H e[24;1H[0003.821] Updated reset info to DTB
e[23;80H e[24;1H[0003.824] display_console_ioctl: No display init
e[23;80H e[24;1H[0003.829] display_console_ioctl: No display init
e[23;80H e[24;1H[0003.833] display_console_ioctl: No display init
e[23;80H e[24;1H[0003.838] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtypee[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80H
e[23;80H e[24;1H[0003.872] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
e[23;80H e[24;1H[0003.878] boot image cmdline: root=/dev/mmcblk0pl rw rootwait rootfstype=ext4 e[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80H
e[23;80H e[24;1H[0003.891] Updated bootarg info to DTB
e[23;80H e[24;1H[0003.895] Adding uuid 00000001643035012000000007010480 to DT
e[23;80H e[24;1H[0003.901] Adding eks info 0 to DT
e[23;80H e[24;1H[0003.906] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
e[23;80H e[24;1H[0003.912] Updated memory info to DTB
e[23;80H e[24;1H[0003.920] set vdd_core voltage to 1125 mv
e[23;80H e[24;1H[0003.924] setting ‘vdd-core’ regulator to 1125000 micro volts
e[23;80H e[24;1H[0003.930] Found secure-pmc; disable BPMP
e[23;80H e[24;1H
e[23;80H e[24;1H
e[23;80H e[24;1HU-Boot 2020.04-g4335beb (Apr 20 2022 - 14:22:25 -0700)
e[23;80H e[24;1H
e[23;80H e[24;1HSoC: tegra210
e[23;80H e[24;1HModel: NVIDIA Jetson Nano Developer Kit
e[23;80H e[24;1HBoard: NVIDIA P3450-0000
e[23;80H e[24;1HDRAM: 4 GiB
e[23;80H e[24;1HMMC: sdhci@700b0000: 1, sdhci@700b0600: 0
e[23;80H e[24;1HLoading Environment from SPI Flash
 SF: Detected mx25u3235f with page size 25e[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80H
e[23;80HBe[24;1H*** Warning - bad CRC, using default environment
e[23;80H e[24;1H
e[23;80H e[24;1HIn: serial
e[23;80H e[24;1HOut: serial
e[23;80H e[24;1HErr: serial
e[23;80H e[24;1HNet: No ethernet found.
e[23;80H e[24;1HHit any key to stop autoboot: 2  1  0
e[23;80H e[24;1Hswitch to partitions #0, OK
e[23;80H e[24;1Hmmc1 is current device
e[23;80H e[24;1HScanning mmc 1:1
e[23;80H e[24;1HFound /boot/extlinux/extlinux.conf
e[23;80H e[24;1HRetrieving file: /boot/extlinux/extlinux.conf
e[23;80H e[24;1H844 bytes read in 21 ms (39.1 KiB/s)
e[23;80H e[24;1H1:e[24;9Hprimary kernel
e[23;80H e[24;1HRetrieving file: /boot/initrd
e[23;80H e[24;1H7160179 bytes read in 327 ms (20.9 MiB/s)
e[23;80H e[24;1HRetrieving file: /boot/Image
e[23;80H e[24;1H34484232 bytes read in 1514 ms (21.7 MiB/s)
e[23;80H e[24;1Happend: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80H
e[23;80H e[24;1H## Flattened Device Tree blob at 83100000
e[23;80H e[24;1H Booting using the fdt blob at 0x83100000
e[23;80H e[24;1HERROR: reserving fdt memory region failed (addr=0 size=0)
e[23;80H e[24;1H Using Device Tree in place at 0000000083100000, end 000000008317ced3
e[23;80H e[24;1Hcopying carveout for /host1x@50000000/dc@54200000
e[23;80H e[24;1Hcopying carveout for /host1x@50000000/dc@54240000
e[23;80H e[24;1H
e[23;80H e[24;1HStarting kernel
e[23;80H e[24;1H
e[23;80H e[24;1H[ 0.000000] Booting Linux on physical CPU 0x0
e[23;80H e[24;1H[ 0.000000] Linux version 4.9.253-tegra (buildbrain@mobile-u64-5494-d8000) (e[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80He[24;80H
e[23;80H2e[24;1H[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
e[23;80H e[24;1H[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
e[23;80H e[24;1H[ 0.000000] OF: fdt: - 80000000 , 7ee00000
e[23;80H e[24;1H[ 0.000000] OF: fdt: - 100000000 , 7f200000
e[23;80H e[24;1H[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options ‘’)
e[23;80H e[24;1H[ 0.000000] bootconsole [uart8250] enabled
e[23;80H e[24;1H[ 1.070769] tegradc tegradc.1: dpd enable lookup fail:-19
e[23;80H e[24;1H[ 1.576547] Host read timeout at address 545c00c4
e[23;80H e[24;1H[ 1.760421] imx219 7-0010: imx219_board_setup: error during i2c read probe (e[24;80He[24;80He[24;80He[24;80He[24;80H
e[23;80H)e[24;1H[ 1.768069] imx219 7-0010: board setup failed
e[23;80H e[24;1H[ 1.796565] imx219 8-0010: imx219_board_setup: error during i2c read probe (e[24;80He[24;80He[24;80He[24;80He[24;80H
e[23;80H)e[24;1H[ 1.804144] imx219 8-0010: board setup failed
e[23;80H e[24;1H
Any idea what is wrong? The messages at the end seem to match what loaded on our screen.
Please disable the “quiet” in your /boot/extlinux/extlinux.conf and dump the log again.
If you have no idea about what I am talking about, please let me know if you never use sdkmanager before.
Hello, I have used sdkmanager before. We have it downloaded on our computer. However, our machine is Ubuntu 20.04 LTS. NVIDIA sdkmanager can only flash NVIDIA Jetson Nano from Ubuntu 16.04 LTS or Ubunutu 18.04 LTS. Thus we cannot flash it with sdkmanager it. We are trying to figure out how to get an Ubuntu 18.04LTS partition on our main machine.
We followed the instructions in the video you linked on said Ubuntu 20.04 LTS machine.
Is the file you mentioned:
in our Ubuntu host machine?
When sdkmanager flash the board, it will download the whole “rootfs” folder to your host, this is what gets installed to your jetson.
/boot/extlinux/extlinux.conf is in that path.
I see. We will try to check that on our host computer once we get an 18.04 Ubuntu LTS partition on it.
actually, I guess flashing with sdkmanager can directly resolve your issue too
thus, you can dump the log if sdkmanager still cannot resolve your problem.
Is the log something different than what I posted previously?
Your kernel log only has these:
And generally kernel logs will be hundreds of lines. And what I asked you to remove is “quiet”. I guess you can know why I asked you to do that
I see. My course of action is:
  1. Get an Ubuntu 18.04 LTS partition.
  2. Use sdkmanager to flash the NVIDIA Jetson Nano
  3. Check if Jetson Nano boots
  4. If not, disable “quiet” in a file called ‘/boot/extlinux/extlinux.conf’ from host machine in the /rootfs/ folder and do the same process in the video.
  5. Post new log file here
Hi, we were able to get it to boot by using NVIDIA sdkmanager to flash from an Ubuntu 18.04 LTS host.
Hello, could you provide me how to to disable the “quiet”?
How about you go through the whole posts? The answer is already in the post
I am really newby with jetson nano, just one week. I have used the sdkmanager, and the flash.sh method. I have tried with differents micro SD, and different power suplies. However, the loop in the last step is still persisting. I have found the file ‘/boot/extlinux/extlinux.conf’ but I do not know how disable it. If you have other suggestion will be nice for me
Is there any problem in understanding this post?
Absolutely not. It is very clear. I found the file. My point is how to disable the "quiet
Read the file
 find where “quiet” is, remove it
And then go back and reflash your device
BTW, in case you didn’t know
 this is just to enable more logs. This won’t resolve any issue
So bad for me. Let me explain my situation. I have flashed the Jetson Nano DevKit A02. I have completed sucesfully the following steps
Review and accept NVIDIA Jetson software EULA
Select system language, keyboard layout, and time zone
Create username, password, and computer name
Select APP partition size—it is recommended to use the max size suggested
But after logging, the loop starts. I have tried several proposed solutions but nothing happens. The loop still persist
Please file a new topic for your own issue. Thanks.
