Jetpack 5.1.3
Jetson Orin Nano 8G
I use the below command to generate factory image dictory according to “README_initrd_flash.txt”.
sudo ./tools/kernel_flash/l4t_initrd_flash.sh -p "--no-systemimg -c bootloader/t186ref/cfg/flash_t234_qspi.xml" --network usb0 --massflash 1 --no-flash jetson-orin-nano-devkit nvme0n1p1
Then I get the “mfi_jetson-orin-nano-devkit.tar.gz” and deploy it into the factory computer.
Then Use the Commad below:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only
And I get the error result like Timeout in USB, but there is no problem in my computer.
~/clq/mfi_jetson-orin-nano-devkit$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only
/home/clq/mfi_jetson-orin-nano-devkit/tools/kernel_flash/l4t_initrd_flash_internal.sh --usb-instance 1-7 --device-instance 0 --flash-only --network usb0 jetson-orin-nano-devkit nvme0n1p1
* Step 1: Build the flashing environment *
Create flash environment 0
/home/clq/mfi_jetson-orin-nano-devkit/bootloader /home/seer/clq/mfi_jetson-orin-nano-devkit
Finish creating flash environment 0.
* Step 2: Boot the device with flash initrd image *
./tegraflash.py --bl uefi_jetson_with_dtb_sigheader.bin.encrypt --bct br_bct_BR.bct --securedev --bldtb tegra234-p3767-0000-p3768-0000-a0.dtb --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --cmd "rcmboot" --cfg secureflash.xml --chip 0x23 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mb1_bin mb1_t234_prod_aligned_sigheader.bin.encrypt --psc_bl1_bin psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt --bins "psc_fw pscfw_t234_prod_sigheader.bin.encrypt; mts_mce mce_flash_o10_cr_prod_sigheader.bin.encrypt; mb2_applet applet_t234_sigheader.bin.encrypt; mb2_bootloader mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt; xusb_fw xusb_t234_prod_sigheader.bin.encrypt; dce_fw display-t234-dce_sigheader.bin.encrypt; nvdec nvdec_t234_prod_sigheader.fw.encrypt; bpmp_fw bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt; bpmp_fw_dtb tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt; sce_fw camera-rtcpu-sce_sigheader.img.encrypt; rce_fw camera-rtcpu-t234-rce_sigheader.img.encrypt; ape_fw adsp-fw_sigheader.bin.encrypt; spe_fw spe_t234_sigheader.bin.encrypt; tos tos-optee_t234_sigheader.img.encrypt; eks eks_t234_sigheader.img.encrypt; kernel boot0.img; kernel_dtb tegra234-p3767-0000-p3768-0000-a0.dtb" --bct_backup --instance 1-7
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
Entering RCM boot
[ 0.0458 ] rcm boot with presigned binaries
[ 0.0469 ] tegrarcm_v2 --instance 1-7 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.0480 ] BR_CID: 0x80012344705DE7E08400000016030240
[ 0.0568 ] Sending bct_br
[ 0.0642 ] Sending mb1
[ 0.0648 ] Sending psc_bl1
[ 0.0764 ] Sending bct_mb1
[ 0.0824 ] Generating blob for T23x
[ 0.0852 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[ 0.0867 ] The number of images in blob is 18
[ 0.0882 ] blobsize is 73308923
[ 0.0885 ] Added binary blob_uefi_jetson_with_dtb_sigheader.bin.encrypt of size 2662464
[ 0.1355 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 375168
[ 0.1364 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 190592
[ 0.1370 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 277312
[ 0.1374 ] Not supported type: mb2_applet
[ 0.1376 ] Added binary blob_mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt of size 437008
[ 0.1381 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164864
[ 0.1386 ] Added binary blob_display-t234-dce_sigheader.bin.encrypt of size 9097216
[ 0.1451 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[ 0.1479 ] Added binary blob_bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt of size 1027008
[ 0.1492 ] Added binary blob_tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt of size 258752
[ 0.1504 ] Added binary blob_camera-rtcpu-sce_sigheader.img.encrypt of size 166304
[ 0.1511 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 540000
[ 0.1517 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 400960
[ 0.1523 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[ 0.1532 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1288096
[ 0.1542 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[ 0.1556 ] Added binary blob_boot0.img of size 55500800
[ 0.2018 ] Added binary blob_tegra234-p3767-0000-p3768-0000-a0.dtb of size 346795
[ 0.2828 ] tegrarcm_v2 --instance 1-7 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[ 0.2839 ] BL: version 1.4.0.1-t234-54845784-08e631ca last_boot_error: 0
[ 0.3261 ] Sending bct_mem
[ 0.3333 ] Sending blob
[ 0.4532 ] ERROR: might be timeout in USB write.
Error: Return value 3
Command tegrarcm_v2 --instance 1-7 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
Cleaning up...
My demmand is just to flash the Qspi. Please help me to solve this problem or tell me the right method to do this.
Couple of things to clarify:
If you only need to flash the QSPI memory, it makes no sense to make a whole massflash package. Also, why are you doing it with only --massflash 1?
Please try again with either
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --massflash 1 --network usb0 --flash-only
sudo ./flash.sh --no-systemimg -c bootloader/t186ref/cfg/flash_t234_qspi.xml jetson-orin-nano-devkit internal
Put the serial console log when flashing fails here.
https://jetsonhacks.com/2019/04/19/jetson-nano-serial-console/
Beacuse according to the script “l4t_initrd_flash.sh”, it won’t generate the “mfi_jetson-orin-nano-devkit.tar.gz” if the command without “massflash”.
And, the “mfi_jetson-orin-nano-devkit.tar.gz” hasn’t got the “flash.sh”.
Flashing only QSPI memory does not require initrd flash.
The command I mentioned is enough.
Run the cmd “sudo ./tools/kernel_flash/l4t_initrd_flash.sh --massflash 1 --network usb0 --flash-only”
dar@dar-pc:/home2/jetson/jetson-rootfs-builder/Linux_for_Tegra/mfi_jetson-orin-nano-devkit$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --massflash 1 --network usb0 --flash-only
[sudo] password for dar:
/home2/jetson/jetson-rootfs-builder/Linux_for_Tegra/mfi_jetson-orin-nano-devkit/tools/kernel_flash/l4t_initrd_flash_internal.sh --network usb0 --usb-instance 1-4 --device-instance 0 --flash-only --network usb0 jetson-orin-nano-devkit nvme0n1p1
/home2/jetson/jetson-rootfs-builder/Linux_for_Tegra/mfi_jetson-orin-nano-devkit/bootloader /home2/jetson/jetson-rootfs-builder/Linux_for_Tegra/mfi_jetson-orin-nano-devkit
/home2/jetson/jetson-rootfs-builder/Linux_for_Tegra/mfi_jetson-orin-nano-devkit/temp_initrdflash/bootloader0 /home2/jetson/jetson-rootfs-builder/Linux_for_Tegra/mfi_jetson-orin-nano-devkit
./tegraflash.py --bl uefi_jetson_with_dtb_sigheader.bin.encrypt --bct br_bct_BR.bct --securedev --bldtb tegra234-p3767-0000-p3768-0000-a0.dtb --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --cmd "rcmboot" --cfg secureflash.xml --chip 0x23 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mb1_bin mb1_t234_prod_aligned_sigheader.bin.encrypt --psc_bl1_bin psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt --bins "psc_fw pscfw_t234_prod_sigheader.bin.encrypt; mts_mce mce_flash_o10_cr_prod_sigheader.bin.encrypt; mb2_applet applet_t234_sigheader.bin.encrypt; mb2_bootloader mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt; xusb_fw xusb_t234_prod_sigheader.bin.encrypt; dce_fw display-t234-dce_sigheader.bin.encrypt; nvdec nvdec_t234_prod_sigheader.fw.encrypt; bpmp_fw bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt; bpmp_fw_dtb tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt; sce_fw camera-rtcpu-sce_sigheader.img.encrypt; rce_fw camera-rtcpu-t234-rce_sigheader.img.encrypt; ape_fw adsp-fw_sigheader.bin.encrypt; spe_fw spe_t234_sigheader.bin.encrypt; tos tos-optee_t234_sigheader.img.encrypt; eks eks_t234_sigheader.img.encrypt; kernel boot0.img; kernel_dtb tegra234-p3767-0000-p3768-0000-a0.dtb" --bct_backup --instance 1-4
version 1.0.0
Entering RCM boot
[ 0.0299 ] rcm boot with presigned binaries
[ 0.0307 ] tegrarcm_v2 --instance 1-4 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.0313 ] BR_CID: 0x80012344705DE7D41000000015FD01C0
[ 0.0385 ] Sending bct_br
[ 0.0442 ] Sending mb1
[ 0.0446 ] Sending psc_bl1
[ 0.0538 ] Sending bct_mb1
[ 0.0594 ] Generating blob for T23x
[ 0.0608 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[ 0.0615 ] The number of images in blob is 18
[ 0.0617 ] blobsize is 73308923
[ 0.0618 ] Added binary blob_uefi_jetson_with_dtb_sigheader.bin.encrypt of size 2662464
[ 0.0869 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 375168
[ 0.0873 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 190592
[ 0.0874 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 277312
[ 0.0875 ] Not supported type: mb2_applet
[ 0.0876 ] Added binary blob_mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt of size 437008
[ 0.0877 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164864
[ 0.0879 ] Added binary blob_display-t234-dce_sigheader.bin.encrypt of size 9097216
[ 0.0938 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[ 0.0946 ] Added binary blob_bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt of size 1027008
[ 0.0952 ] Added binary blob_tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt of size 258752
[ 0.0954 ] Added binary blob_camera-rtcpu-sce_sigheader.img.encrypt of size 166304
[ 0.0955 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 540000
[ 0.0957 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 400960
[ 0.0958 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[ 0.0959 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1288096
[ 0.0967 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[ 0.0968 ] Added binary blob_boot0.img of size 55500800
[ 0.1409 ] Added binary blob_tegra234-p3767-0000-p3768-0000-a0.dtb of size 346795
[ 0.1879 ] tegrarcm_v2 --instance 1-4 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[ 0.1885 ] BL: version 1.4.0.1-t234-54845784-08e631ca last_boot_error: 0
[ 0.3014 ] Sending bct_mem
[ 0.3075 ] Sending blob
[ 0.4011 ] ERROR: might be timeout in USB write.
Command tegrarcm_v2 --instance 1-4 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
Cleaning up...
Serial Console
[0012.967] I> MB1 (version: 1.4.0.1-t234-54845784-08e631ca)
[0012.973] I> t234-A01-1-Silicon (0x12347) Prod
[0012.977] I> Boot-mode : Coldboot
[0012.980] I> Entry timestamp: 0x00000000
[0012.984] I> last_boot_error: 0x0
[0012.987] I> BR-BCT: preprod_dev_sign: 0
[0012.991] I> rst_source: 0x0, rst_level: 0x0
[0012.995] I> Task: SE error check
[0012.998] I> Task: Bootchain select WAR set
[0013.002] I> Task: Enable SLCG
[0013.005] I> Task: CRC check
[0013.008] I> Task: Initialize MB2 params
[0013.012] I> MB2-params @ 0x40060000
[0013.016] I> Task: Crypto init
[0013.019] I> Task: Perform MB1 KAT tests
[0013.023] I> Task: NVRNG health check
[0013.026] I> NVRNG: Health check success
[0013.030] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0013.036] I> Task: Enabling and initialization of Bandwidth limiter
[0013.042] I> No request to configure MBWT settings for any PC!
[0013.048] I> Task: Secure debug controls
[0013.052] I> Task: strap war set
[0013.055] I> Task: Initialize SOC Therm
[0013.058] I> Task: Program NV master stream id
[0013.063] I> Task: Verify boot mode
[0013.068] I> Task: Alias fuses
[0013.072] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0013.079] I> Task: Print SKU type
[0013.082] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c8
[0013.087] I> FUSE_OPT_GPC_DISABLE = 0x00000002
[0013.092] I> FUSE_OPT_TPC_DISABLE = 0x000000fc
[0013.096] I> FUSE_OPT_DLA_DISABLE = 0x00000003
[0013.100] I> FUSE_OPT_PVA_DISABLE = 0x00000001
[0013.104] I> FUSE_OPT_NVENC_DISABLE = 0x00000001
[0013.109] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0013.113] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0013.118] I> FUSE_OPT_EMC_DISABLE = 0x0000000c
[0013.122] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0013.126] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0013.130] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0013.134] I> FUSE_SKU_INFO_0 = 0xd6
[0013.138] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0013.142] I> FUSE_PACKAGE_INFO_0 = 0x2
[0013.145] I> SKU: Prod
[0013.148] I> Task: Boost clocks
[0013.151] I> Initializing PLLC2 for AXI_CBB.
[0013.155] I> AXI_CBB : src = 35, divisor = 0
[0013.159] I> Task: Voltage monitor
[0013.162] I> VMON: Vmon re-calibration and fine tuning done
[0013.168] I> Task: UPHY init
[0013.173] I> HSIO UPHY init done
[0013.176] W> Skipping GBE UPHY config
[0013.179] I> Task: Boot device init
[0013.182] I> Boot_device: RCM
[0013.185] I> USB configuration success
[0013.189] I> Task: TSC init
[0013.192] I> Task: Load membct
[0013.195] I> RAM_CODE 0x4000041
[0013.198] I> Loading MEMBCT
[0013.201] I> Slot: 0
[0013.203] I> Binary[1] block-0 (partition size: 0x40000)
[0013.208] I> Binary name: MEM-BCT-1
[0013.211] I> Size of crypto header is 8192
[0013.215] I> Size of crypto header is 8192
[0013.219] I> BCH of MEM-BCT-1 read from storage
[0013.224] I> BCH address is : 0x40050000
[0013.228] I> MEM-BCT-1 header integrity check is success
[0013.233] I> Binary magic in BCH component 0 is MEM1
[0013.238] I> component binary type is 1
[0013.243] I> MEM-BCT-1 binary is read from storage
[0013.247] I> MEM-BCT-1 binary integrity check is success
[0013.253] I> Binary MEM-BCT-1 loaded successfully at 0x40040000 (0xe580)
[0013.259] I> RAM_CODE 0x4000041
[0013.265] I> RAM_CODE 0x4000041
[0013.268] I> Task: Load Page retirement list
[0013.272] I> Task: SDRAM params override
[0013.276] I> Task: Save mem-bct info
[0013.280] I> Task: Carveout allocate
[0013.283] I> Update CCPLEX IST carveout from MB1-BCT
[0013.288] I> ECC region[0]: Start:0x0, End:0x0
[0013.292] I> ECC region[1]: Start:0x0, End:0x0
[0013.297] I> ECC region[2]: Start:0x0, End:0x0
[0013.301] I> ECC region[3]: Start:0x0, End:0x0
[0013.305] I> ECC region[4]: Start:0x0, End:0x0
[0013.309] I> Non-ECC region[0]: Start:0x80000000, End:0x80000000
[0013.315] I> Non-ECC region[1]: Start:0x0, End:0x0
[0013.320] I> Non-ECC region[2]: Start:0x0, End:0x0
[0013.324] I> Non-ECC region[3]: Start:0x0, End:0x0
[0013.329] I> Non-ECC region[4]: Start:0x0, End:0x0
[0013.340] E> BL_CARVEOUT: Failed to allocate memory of size 0x4000000 for CO:43.
[0013.347] C> Task 0x20 failed (err: 0x49490403)
[0013.352] E> Top caller module: BL_CARVEOUT, error module: BL_CARVEOUT, reason: 0x03, aux_info: 0x04
[0013.361] C> Boot Info Table status dump :
01111111001110001111111111111111
Is the device really put in force recovery mode when you generate the massflash package?
LitchiCheng:
This means the wrong memory config is used.
Unlike flash.sh, initrd flash does not check whether there is any device in RCM when it starts running, and if there is no, it uses the default SKU0 (Orin NX 16GB for P3767) device tree and memory config, which is not suitable for your Orin Nano 8GB.
Is is clearly the more convinient way.
There is no “flash.sh” script in massflash package.
dar@dar-pc:/home2/jetson/jetson-rootfs-builder/Linux_for_Tegra/mfi_jetson-orin-nano-devkit$ tree -L 2
├── bootloader
│ ├── adsp-fw.bin
│ ├── adsp-fw_sigheader.bin.encrypt
│ ├── applet_t234.bin
│ ├── applet_t234_sigheader.bin.encrypt
│ ├── boot0.img
│ ├── boot.img
│ ├── bpmp-2_t194.bin
│ ├── bpmp.bin
│ ├── bpmp_t194.bin
│ ├── bpmp_t234-TA990SA-A1_prod.bin
│ ├── bpmp_t234-TE950M-A1_prod.bin
│ ├── bpmp_t234-TE980M-A1_prod.bin
│ ├── bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt
│ ├── bpmp_t234-TE990M-A1_prod.bin
│ ├── bpmp_t234-TE992M-A1_prod.bin
│ ├── br_bct_BR.bct
│ ├── BUP_generator.py
│ ├── camera-rtcpu-sce_sigheader.img.encrypt
│ ├── camera-rtcpu-t234-rce_sigheader.img.encrypt
│ ├── custinfo_out.bin
│ ├── cvm.bin
│ ├── display-t234-dce.bin
│ ├── display-t234-dce_sigheader.bin.encrypt
│ ├── dram-ecc-t194.bin
│ ├── dtbcheck.py
│ ├── ed25519.py
│ ├── eks_t234_sigheader.img.encrypt
│ ├── flashcmd.txt
│ ├── flash.xml.bin
│ ├── fsi-fw-ecc.bin
│ ├── fskp_t234.bin
│ ├── gpt_backup_secondary_3_0.bin
│ ├── gpt_primary_6_0.bin
│ ├── gpt_secondary_3_0.bin
│ ├── gpt_secondary_6_0.bin
│ ├── kernel_bootctrl.bin
│ ├── kernel_tegra234-p3767-0000-p3768-0000-a0.dtb
│ ├── kernel_tegra234-p3767-0004-p3768-0000-a0.dtb
│ ├── LICENSE.nvdisp-init.bin
│ ├── LICENSE.spe.bin
│ ├── LICENSE.spe_t194.bin
│ ├── LICENSE.spe_t234.bin
│ ├── LICENSE.standalonemm_optee_t194.bin
│ ├── LICENSE.standalonemm_optee_t234.bin
│ ├── mb1_bct_MB1_sigheader.bct.encrypt
│ ├── mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
│ ├── mb1_t194_prod.bin
│ ├── mb1_t234_prod_aligned_sigheader.bin.encrypt
│ ├── mb1_t234_prod.bin
│ ├── mb2rf_t234.bin
│ ├── mb2_t234.bin
│ ├── mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt
│ ├── mbr_6_0.bin
│ ├── mce_c10_prod_cr.bin
│ ├── mce_flash_o10_cr_prod.bin
│ ├── mce_flash_o10_cr_prod_sigheader.bin.encrypt
│ ├── mem_coldboot_sigheader.bct.encrypt
│ ├── mem_rcm_sigheader.bct.encrypt
│ ├── mts_c10_prod_cr.bin
│ ├── nvdec_t234_prod_sigheader.fw.encrypt
│ ├── nvdisp-init.bin
│ ├── nvtboot_applet_t194.bin
│ ├── nvtboot_cpurf_t234.bin
│ ├── nvtboot_cpu_t194.bin
│ ├── nvtboot_recovery_cpu_t194.bin
│ ├── nvtboot_recovery_t194.bin
│ ├── nvtboot_t194.bin
│ ├── pinctrl-tegra.h
│ ├── preboot_c10_prod_cr.bin
│ ├── psc_bl1_t234_prod_aligned_sigheader.bin.encrypt
│ ├── psc_bl1_t234_prod.bin
│ ├── pscfw_t234_prod.bin
│ ├── pscfw_t234_prod_sigheader.bin.encrypt
│ ├── psc_rf_t234_prod.bin
│ ├── pyfdt
│ ├── recovery.img
│ ├── sc7_t234_prod.bin
│ ├── sce_t194.bin
│ ├── secureflash.xml
│ ├── spe.bin
│ ├── spe_t194.bin
│ ├── spe_t234.bin
│ ├── spe_t234_sigheader.bin.encrypt
│ ├── standalonemm_optee_t194.bin
│ ├── standalonemm_optee_t234.bin
│ ├── t194.py
│ ├── t234.py
│ ├── tegra234-bpmp-3767-0000-a02-3509-a02.dtb
│ ├── tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt
│ ├── tegra234-bpmp-3767-0004-3509-a02.dtb
│ ├── tegra234-br-bct_b-p3767-0000-l4t.dts
│ ├── tegra234-br-bct-diag-boot.dts
│ ├── tegra234-br-bct-p3767-0000-l4t.dts
│ ├── tegra234-chip.dtsi
│ ├── tegra234-firewall-config-base.dtsi
│ ├── tegra234-gpio.h
│ ├── tegra234-mb1-bct-carveout-common.dtsi
│ ├── tegra234-mb1-bct-carveout-l4t.dtsi
│ ├── tegra234-mb1-bct-cprod-p3767-0000.dts
│ ├── tegra234-mb1-bct-device-common.dtsi
│ ├── tegra234-mb1-bct-device-p3767-0000.dts
│ ├── tegra234-mb1-bct-disable-fsi-carveouts.dtsi
│ ├── tegra234-mb1-bct-dram-ecc.dtsi
│ ├── tegra234-mb1-bct-dram-ecc-l4t.dtsi
│ ├── tegra234-mb1-bct-gpioint-p3767-0000.dts
│ ├── tegra234-mb1-bct-gpio-p3701-0000-a04.dtsi
│ ├── tegra234-mb1-bct-gpio-p3701-0000.dtsi
│ ├── tegra234-mb1-bct-gpio-p3701-0002-P3711-0000.dtsi
│ ├── tegra234-mb1-bct-gpio-p3701-0002-p3740-0002-b01.dtsi
│ ├── tegra234-mb1-bct-gpio-p3701-0002-p3740-0002.dtsi
│ ├── tegra234-mb1-bct-gpio-p3701-0008-p3740-0002-c01.dtsi
│ ├── tegra234-mb1-bct-gpio-p3767-dp-a03.dtsi
│ ├── tegra234-mb1-bct-gpio-p3767-hdmi-a03.dtsi
│ ├── tegra234-mb1-bct-misc-common.dtsi
│ ├── tegra234-mb1-bct-misc-p3767-0000.dts
│ ├── tegra234-mb1-bct-p3701-0000-as-p3767-0000-rc00-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-as-p3767-0000-rc00-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-as-p3767-0004-rc00-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-as-p3767-0004-rc00-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-as-p3767-0004-rc01-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-as-p3767-0004-rc01-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-as-p3767-0004-rc02-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-as-p3767-0004-rc02-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-as-p3767-0004-rc03-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-as-p3767-0004-rc03-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-as-p3767-0004-rc04-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-as-p3767-0004-rc04-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-as-p3767-0004-rc05-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-as-p3767-0004-rc05-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-as-p3767-0004-rc06-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-as-p3767-0004-rc06-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-as-p3767-0004-rc07-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-as-p3767-0004-rc07-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-as-p3767-0004-rc08-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-as-p3767-0004-rc08-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-as-p3767-0004-rc09-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-as-p3767-0004-rc09-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-as-p3767-0004-rc10-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-as-p3767-0004-rc10-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-as-p3767-0004-rc11-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-as-p3767-0004-rc11-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-as-p3767-0004-rc12-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-as-p3767-0004-rc12-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-as-p3767-0004-rc13-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-as-p3767-0004-rc13-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-as-p3767-0004-rc14-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-as-p3767-0004-rc14-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-as-p3767-0004-rc15-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-as-p3767-0004-rc15-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-rc00-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-rc00-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-rc01-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-rc01-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-rc02-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-rc02-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-rc03-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-rc03-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-rc04-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-rc04-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-rc05-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-rc05-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-rc06-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-rc06-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-rc07-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-rc07-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-rc08-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-rc08-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-rc09-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-rc09-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-rc10-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-rc10-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-rc11-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-rc11-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-rc12-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-rc12-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-rc13-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-rc13-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-rc14-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-rc14-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-rc15-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0000-rc15-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0002-p3711-0000-sdram-16gb-Micron-lpddr5-204MHz.dtsi
│ ├── tegra234-mb1-bct-p3701-0002-p3711-0000-sdram-16gb-Micron-lpddr5-204MHz-ecc.dtsi
│ ├── tegra234-mb1-bct-p3701-0002-p3711-0000-sdram-16gb-Micron-lpddr5-204MHz-ecc-encr.dtsi
│ ├── tegra234-mb1-bct-p3701-0002-p3711-0000-sdram-16gb-Micron-lpddr5-204MHz-encr.dtsi
│ ├── tegra234-mb1-bct-p3701-0002-p3711-0000-sdram-32gb-Micron-lpddr5-204MHz-bct.dtsi
│ ├── tegra234-mb1-bct-p3701-0002-p3711-0000-sdram-32gb-Micron-lpddr5-204MHz-bct-ecc.dtsi
│ ├── tegra234-mb1-bct-p3701-0002-p3711-0000-sdram-32gb-Micron-lpddr5-204MHz-bct-ecc-encr.dtsi
│ ├── tegra234-mb1-bct-p3701-0002-p3711-0000-sdram-32gb-Micron-lpddr5-204MHz-bct-encr.dtsi
│ ├── tegra234-mb1-bct-p3701-0002-p3740-0002-sdram-16gb-Micron-lpddr5-204MHz.dtsi
│ ├── tegra234-mb1-bct-p3701-0002-p3740-0002-sdram-16gb-Micron-lpddr5-204MHz-ecc.dtsi
│ ├── tegra234-mb1-bct-p3701-0002-p3740-0002-sdram-16gb-Micron-lpddr5-204MHz-ecc-encr.dtsi
│ ├── tegra234-mb1-bct-p3701-0002-p3740-0002-sdram-16gb-Micron-lpddr5-204MHz-encr.dtsi
│ ├── tegra234-mb1-bct-p3701-0002-p3740-0002-sdram-32gb-Micron-lpddr5-204MHz-bct.dtsi
│ ├── tegra234-mb1-bct-p3701-0002-p3740-0002-sdram-32gb-Micron-lpddr5-204MHz-bct-ecc.dtsi
│ ├── tegra234-mb1-bct-p3701-0002-p3740-0002-sdram-32gb-Micron-lpddr5-204MHz-bct-ecc-encr.dtsi
│ ├── tegra234-mb1-bct-p3701-0002-p3740-0002-sdram-32gb-Micron-lpddr5-204MHz-bct-encr.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0000-rc00-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0000-rc00-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0000-rc01-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0000-rc01-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0000-rc02-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0000-rc02-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0000-rc03-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0000-rc03-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0000-rc04-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0000-rc04-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0000-rc05-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0000-rc05-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0000-rc06-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0000-rc06-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0000-rc07-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0000-rc07-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0000-rc08-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0000-rc08-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0000-rc09-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0000-rc09-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0000-rc10-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0000-rc10-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0000-rc11-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0000-rc11-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0000-rc12-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0000-rc12-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0000-rc13-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0000-rc13-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0000-rc14-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0000-rc14-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0000-rc15-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0000-rc15-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0004-rc00-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0004-rc00-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0004-rc01-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0004-rc01-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0004-rc02-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0004-rc02-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0004-rc03-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0004-rc03-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0004-rc04-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0004-rc04-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0004-rc05-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0004-rc05-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0004-rc06-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0004-rc06-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0004-rc07-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0004-rc07-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0004-rc08-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0004-rc08-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0004-rc09-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0004-rc09-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0004-rc10-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0004-rc10-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0004-rc11-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0004-rc11-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0004-rc12-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0004-rc12-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0004-rc13-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0004-rc13-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0004-rc14-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0004-rc14-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0004-rc15-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-as-p3767-0004-rc15-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-rc00-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-rc00-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-rc01-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-rc01-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-rc02-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-rc02-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-rc03-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-rc03-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-rc04-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-rc04-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-rc05-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-rc05-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-rc06-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-rc06-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-rc07-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-rc07-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-rc08-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-rc08-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-rc09-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-rc09-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-rc10-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-rc10-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-rc11-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-rc11-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-rc12-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-rc12-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-rc13-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-rc13-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-rc14-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-rc14-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-rc15-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0005-rc15-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3701-0008-rc00-204mhz-ecc.dtsi
│ ├── tegra234-mb1-bct-p3701-0008-rc00-665mhz-ecc.dtsi
│ ├── tegra234-mb1-bct-p3701-0008-rc01-204mhz-ecc.dtsi
│ ├── tegra234-mb1-bct-p3701-0008-rc01-665mhz-ecc.dtsi
│ ├── tegra234-mb1-bct-p3701-0008-rc02-204mhz-ecc.dtsi
│ ├── tegra234-mb1-bct-p3701-0008-rc02-665mhz-ecc.dtsi
│ ├── tegra234-mb1-bct-p3701-0008-rc03-204mhz-ecc.dtsi
│ ├── tegra234-mb1-bct-p3701-0008-rc03-665mhz-ecc.dtsi
│ ├── tegra234-mb1-bct-p3701-0008-rc04-204mhz-ecc.dtsi
│ ├── tegra234-mb1-bct-p3701-0008-rc04-665mhz-ecc.dtsi
│ ├── tegra234-mb1-bct-p3701-0008-rc05-204mhz-ecc.dtsi
│ ├── tegra234-mb1-bct-p3701-0008-rc05-665mhz-ecc.dtsi
│ ├── tegra234-mb1-bct-p3701-0008-rc06-204mhz-ecc.dtsi
│ ├── tegra234-mb1-bct-p3701-0008-rc06-665mhz-ecc.dtsi
│ ├── tegra234-mb1-bct-p3701-0008-rc07-204mhz-ecc.dtsi
│ ├── tegra234-mb1-bct-p3701-0008-rc07-665mhz-ecc.dtsi
│ ├── tegra234-mb1-bct-p3701-0008-rc08-204mhz-ecc.dtsi
│ ├── tegra234-mb1-bct-p3701-0008-rc08-665mhz-ecc.dtsi
│ ├── tegra234-mb1-bct-p3701-0008-rc09-204mhz-ecc.dtsi
│ ├── tegra234-mb1-bct-p3701-0008-rc09-665mhz-ecc.dtsi
│ ├── tegra234-mb1-bct-p3701-0008-rc10-204mhz-ecc.dtsi
│ ├── tegra234-mb1-bct-p3701-0008-rc10-665mhz-ecc.dtsi
│ ├── tegra234-mb1-bct-p3701-0008-rc11-204mhz-ecc.dtsi
│ ├── tegra234-mb1-bct-p3701-0008-rc11-665mhz-ecc.dtsi
│ ├── tegra234-mb1-bct-p3701-0008-rc12-204mhz-ecc.dtsi
│ ├── tegra234-mb1-bct-p3701-0008-rc12-665mhz-ecc.dtsi
│ ├── tegra234-mb1-bct-p3701-0008-rc13-204mhz-ecc.dtsi
│ ├── tegra234-mb1-bct-p3701-0008-rc13-665mhz-ecc.dtsi
│ ├── tegra234-mb1-bct-p3701-0008-rc14-204mhz-ecc.dtsi
│ ├── tegra234-mb1-bct-p3701-0008-rc14-665mhz-ecc.dtsi
│ ├── tegra234-mb1-bct-p3701-0008-rc15-204mhz-ecc.dtsi
│ ├── tegra234-mb1-bct-p3701-0008-rc15-665mhz-ecc.dtsi
│ ├── tegra234-mb1-bct-p3767-0000-as-Nano-rc00-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0000-rc00-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0000-rc00-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0000-rc01-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0000-rc01-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0000-rc02-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0000-rc02-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0000-rc03-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0000-rc03-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0000-rc04-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0000-rc04-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0000-rc05-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0000-rc05-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0000-rc06-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0000-rc06-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0000-rc07-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0000-rc07-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0000-rc08-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0000-rc08-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0000-rc09-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0000-rc09-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0000-rc10-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0000-rc10-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0000-rc11-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0000-rc11-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0000-rc12-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0000-rc12-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0000-rc13-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0000-rc13-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0000-rc14-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0000-rc14-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0000-rc15-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0000-rc15-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0001-rc00-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0001-rc00-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0001-rc01-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0001-rc01-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0001-rc02-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0001-rc02-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0001-rc03-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0001-rc03-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0001-rc04-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0001-rc04-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0001-rc05-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0001-rc05-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0001-rc06-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0001-rc06-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0001-rc07-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0001-rc07-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0001-rc08-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0001-rc08-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0001-rc09-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0001-rc09-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0001-rc10-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0001-rc10-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0001-rc11-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0001-rc11-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0001-rc12-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0001-rc12-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0001-rc13-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0001-rc13-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0001-rc14-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0001-rc14-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0001-rc15-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0001-rc15-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0004-rc00-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0004-rc00-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0004-rc01-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0004-rc01-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0004-rc02-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0004-rc02-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0004-rc03-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0004-rc03-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0004-rc04-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0004-rc04-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0004-rc05-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0004-rc05-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0004-rc06-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0004-rc06-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0004-rc07-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0004-rc07-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0004-rc08-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0004-rc08-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0004-rc09-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0004-rc09-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0004-rc10-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0004-rc10-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0004-rc11-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0004-rc11-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0004-rc12-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0004-rc12-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0004-rc13-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0004-rc13-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0004-rc14-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0004-rc14-665mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0004-rc15-204mhz.dtsi
│ ├── tegra234-mb1-bct-p3767-0004-rc15-665mhz.dtsi
│ ├── tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi
│ ├── tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi
│ ├── tegra234-mb1-bct-pmic-p3767-0000-a02.dts
│ ├── tegra234-mb1-bct-prod-p3767-0000.dts
│ ├── tegra234-mb1-bct-ratchet-p3767-0000.dts
│ ├── tegra234-mb1-bct-reset-p3767-0000.dts
│ ├── tegra234-mb1-bct-uphylane-si-c7x1.dtsi
│ ├── tegra234-mb1-bct-uphylane-si-c7x2.dtsi
│ ├── tegra234-mb1-bct-uphylane-si.dtsi
│ ├── tegra234-mb2-bct-common.dtsi
│ ├── tegra234-mb2-bct-firewall-common.dts
│ ├── tegra234-mb2-bct-misc-p3767-0000.dts
│ ├── tegra234-mb2-bct-scr-p3701-0000-override.dts
│ ├── tegra234-mb2-bct-scr-p3767-0000.dts
│ ├── tegra234-mem-bct-sw-override-carveout-common.dtsi
│ ├── tegra234-mem-bct-sw-override-carveout-l4t.dtsi
│ ├── tegra234-mem-bct-sw-override-non-carveout-common.dtsi
│ ├── tegra234-mem-bct-sw-override-non-carveout-l4t.dtsi
│ ├── tegra234-p3701-0000-as-p3767-0000-sdram.dtsi
│ ├── tegra234-p3701-0000-as-p3767-0000-wb0sdram.dtsi
│ ├── tegra234-p3701-0000-as-p3767-0004-sdram.dtsi
│ ├── tegra234-p3701-0000-as-p3767-0004-wb0sdram.dtsi
│ ├── tegra234-p3701-0000-sdram.dtsi
│ ├── tegra234-p3701-0000-wb0sdram.dtsi
│ ├── tegra234-p3701-0005-as-p3767-0000-sdram.dtsi
│ ├── tegra234-p3701-0005-as-p3767-0000-wb0sdram.dtsi
│ ├── tegra234-p3701-0005-as-p3767-0004-sdram.dtsi
│ ├── tegra234-p3701-0005-as-p3767-0004-wb0sdram.dtsi
│ ├── tegra234-p3701-0005-sdram.dtsi
│ ├── tegra234-p3701-0005-wb0sdram.dtsi
│ ├── tegra234-p3701-0008-sdram.dtsi
│ ├── tegra234-p3701-0008-wb0sdram.dtsi
│ ├── tegra234-p3767-0000-as-Nano-sdram.dtsi
│ ├── tegra234-p3767-0000-p3768-0000-a0.dtb
│ ├── tegra234-p3767-0000-p3768-0000-a0.dtb.rec
│ ├── tegra234-p3767-0000-sdram.dtsi
│ ├── tegra234-p3767-0000-sdram-l4t.dts
│ ├── tegra234-p3767-0000-wb0sdram.dtsi
│ ├── tegra234-p3767-0000-wb0sdram-l4t.dts
│ ├── tegra234-p3767-0001-sdram.dtsi
│ ├── tegra234-p3767-0001-wb0sdram.dtsi
│ ├── tegra234-p3767-0004-p3768-0000-a0.dtb
│ ├── tegra234-p3767-0004-p3768-0000-a0.dtb.rec
│ ├── tegra234-p3767-0004-sdram.dtsi
│ ├── tegra234-p3767-0004-sdram-l4t.dts
│ ├── tegra234-p3767-0004-wb0sdram.dtsi
│ ├── tegra234-p3767-0004-wb0sdram-l4t.dts
│ ├── tegrabct_v2
│ ├── tegrabl_carveout_id.h
│ ├── tegradevflash_v2
│ ├── tegraflash_impl_t234.py
│ ├── tegraflash_internal.py
│ ├── tegraflash.py
│ ├── tegrahost_v2
│ ├── tegraopenssl
│ ├── tegraparser_v2
│ ├── tegrarcm_v2
│ ├── tegrasign_v3_hsm.py
│ ├── tegrasign_v3_internal.py
│ ├── tegrasign_v3.py
│ ├── tegrasign_v3_util.py
│ ├── tos-optee_t234_sigheader.img.encrypt
│ ├── uefi_jetson.bin
│ ├── uefi_jetson_with_dtb.bin
│ ├── uefi_jetson_with_dtb_sigheader.bin.encrypt
│ ├── warmboot_t194_prod.bin
│ ├── xusb_t234_prod.bin
│ └── xusb_t234_prod_sigheader.bin.encrypt
├── initrdlog
│ ├── flash_1-4_0_20240626-104756.log
│ └── flash_1-4_0_20240626-105233.log
├── jetson-orin-nano-devkit.conf
├── p2972-0000.conf.common
├── p3668.conf.common
├── p3701.conf.common
├── p3767.conf.common
├── rootfs
│ ├── bin -> usr/bin
│ ├── boot
│ ├── dev
│ ├── etc
│ ├── home
│ ├── lib -> usr/lib
│ ├── media
│ ├── mnt
│ ├── opt
│ ├── proc
│ ├── root
│ ├── run
│ ├── sbin -> usr/sbin
│ ├── srv
│ ├── sys
│ ├── tmp
│ ├── usr
│ └── var
├── temp_initrdflash
└── tools
└── kernel_flash
25 directories, 496 files
I told you that there is completely no need of massflash in your usecase…
Go back to Linux_for_Tegra.
I need to release the package to the factory,the size of Linux_for_Tegra is too large.
33.8 GiB (36,344,146,658)
Before I check it, please help me to ensure the step whether correct.
Let the Jetson Orin Nano into Recovery Mode and connect with USB
cd Linux_for_Tegra
sudo ./tools/kernel_flash/l4t_initrd_flash.sh -p "--no-systemimg -c bootloader/t186ref/cfg/flash_t234_qspi.xml" --network usb0 --massflash 1 --no-flash jetson-orin-nano-devkit nvme0n1p1 to generate “mfi_jetson-orin-nano-devkit.tar.gz”
Then extract the mfi_jetson-orin-nano-devkit.tar.gz into the annother computer.
cd mfi_jetson-orin-nano-devkit
system
Closed
July 17, 2024, 3:00am
16
