NVIDIA Jetson Linux 35.6.0 flash failed -- boot/extlinux/extlinux.conf is not found
There is no “boot/extlinux/extlinux.conf”, so “./nvautoflash.sh” failed. How to flash 35.6.0?
$ sudo tar xvf jetson_linux_r35.6.0_aarch64.tbz2
$ sudo tar xvpf tegra_linux_sample-root-filesystem_r35.6.0_aarch64.tbz2 -C Linux_for_Tegra/rootfs/
daniel@daniel-ThinkPad-SL410:~/Jetson/Linux_for_Tegra$ sudo ./nvautoflash.sh
*** Checking ONLINE mode ... OK.
*** Checking target board connection ... 1 connections found.
*** Reading ECID ... FUSELEVEL=fuselevel_production hwchipid=0x23 bootauth=NS
*** Reading EEPROM ... "/home/daniel/Jetson/Linux_for_Tegra/bootloader/tegraflash.py" --chip 0x23 --applet "/home/daniel/Jetson/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3701-0000.dts --misc_config tegra234-mb1-bct-misc-p3701-0000.dts --bins "mb2_applet applet_t234.bin" --skipuid --cmd "dump eeprom cvm cvm.bin; reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[   0.0622 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.0631 ] File rcm_state open failed
[   0.0636 ] ERROR: failed to read rcm_state
[   0.0636 ]
[   0.0711 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0713 ] Assuming zero filled SBK key
[   0.0642 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
[   0.0802 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0000.dts
[   0.1032 ] Parsing partition layout
[   0.1041 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.1064 ] Kernel DTB used: None
[   0.1065 ] WARNING: dce base dtb is not provided
[   0.1065 ] Parsing partition layout
[   0.1074 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.1089 ] Creating list of images to be signed
[   0.1098 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[   0.1105 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.1145 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.1180 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.1269 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.1306 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.1402 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.1431 ] adding BCH for mb2_t234_aligned.bin
[   0.1472 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.1781 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.1789 ] adding BCH for mb2_t234_aligned.bin
[   0.2160 ] Filling MB1 storage info
[   0.2160 ] Parsing dev params for multi chains
[   0.2322 ] Generating br-bct
[   0.2331 ] Updating dev and MSS params in BR BCT
[   0.2332 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.2347 ] Updating bl info
[   0.2355 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[   0.2365 ] WARNING: boot chain is not completed. set to 0
[   0.2384 ] Generating signatures
[   0.2458 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.2461 ] Assuming zero filled SBK key
[   0.2684 ] Warning: pub_key.key is not found
[   0.2617 ] Parsing dev params for multi chains
[   0.2617 ] Generating br-bct
[   0.2625 ] Updating dev and MSS params in BR BCT
[   0.2627 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.2641 ] Updating bl info
[   0.2650 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.2661 ] WARNING: boot chain is not completed. set to 0
[   0.2682 ] Get Signed section of bct
[   0.2691 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   0.2707 ] Signing BCT
[   0.2781 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.2784 ] Assuming zero filled SBK key
[   0.2825 ] Sha saved in br_bct_BR.sha
[   0.2831 ] Warning: pub_key.key is not found
[   0.2758 ] Updating BCT with signature
[   0.2766 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   0.2775 ] Offset :4608 Len :3584
[   0.2785 ] Generating SHA2 Hash
[   0.2862 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   0.2866 ] Assuming zero filled SBK key
[   0.2867 ] Assuming zero filled SBK key
[   0.2911 ] Sha saved in br_bct_BR.sha
[   0.2843 ] Updating BCT with SHA2 Hash
[   0.2851 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   0.2863 ] Offset :4608 Len :3584
[   0.2867 ] Offset :68 Len :8124
[   0.2874 ] Generating coldboot mb1-bct
[   0.2883 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.2894 ] MB1-BCT version: 0.13
[   0.2931 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.2935 ] Added Platform Config 9 data with size :- 100
[   0.2935 ]
[   0.2936 ] Updating mb1-bct with firmware information
[   0.2944 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.2974 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   0.2984 ] Generating SHA2 Hash for mb1bct
[   0.3077 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[   0.3097 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[   0.3033 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   0.3042 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   0.3134 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.3137 ] Assuming zero filled SBK key
[   0.3164 ] Warning: pub_key.key is not found
[   0.3101 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.3124 ] Generating recovery mb1-bct
[   0.3133 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.3144 ] MB1-BCT version: 0.13
[   0.3181 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.3186 ] Added Platform Config 9 data with size :- 100
[   0.3186 ]
[   0.3187 ] Updating mb1-bct with firmware information
[   0.3195 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.3223 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[   0.3233 ] Generating SHA2 Hash for mb1bct
[   0.3326 ] Sha saved in mb1_bct_MB1_aligned.sha
[   0.3346 ] Sha saved in mb1_bct_MB1.sha
[   0.3282 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   0.3297 ] adding BCH for mb1_bct_MB1_aligned.bct
[   0.3382 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.3385 ] Assuming zero filled SBK key
[   0.3412 ] Warning: pub_key.key is not found
[   0.3349 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.3371 ] Error: Skip generating mem_bct because sdram_config is not defined
[   0.3372 ] Error: Skip generating mem_bct because sdram_config is not defined
[   0.3372 ] Copying signatures
[   0.3381 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.3501 ] Boot Rom communication
[   0.3511 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   0.3523 ] BR_CID: 0x80012344705DF1047C00000006FD8200
[   0.4418 ] Sending bct_br
[   0.5293 ] Sending mb1
[   0.5310 ] Sending psc_bl1
[   0.5517 ] Sending bct_mb1
[   0.5603 ] Boot Rom communication completed
[   0.5628 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[   0.5655 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --appendsigheader applet_t234_aligned.bin zerosbk
[   0.5667 ] adding BCH for applet_t234_aligned.bin
[   0.6050 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.6053 ] Assuming zero filled SBK key
[   0.6095 ] Warning: pub_key.key is not found
[   0.6032 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[   0.6068 ] Sending mb2_applet...
[   0.6078 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[   0.6088 ] BL: version 1.4.0.4-t234-54845784-e89ea9bc last_boot_error: 0
[   0.7674 ] Sending applet
[   0.9005 ] completed
[   0.9016 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.9029 ] MB2 Applet version 01.00.0000
[   1.0953 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   1.0966 ] MB2 Applet version 01.00.0000
[   1.1899 ] Retrieving board information
[   1.1919 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails chip chip_info.bin
[   1.1932 ] MB2 Applet version 01.00.0000
[   1.2869 ] Saved platform info in chip_info.bin
[   1.2941 ] Chip minor revision: 1
[   1.2945 ] Bootrom revision: 0x7
[   1.2950 ] Ram code: 0x2
[   1.2952 ] Chip sku: 0xd5
[   1.2952 ] Chip Sample: prod
[   1.2952 ]
[   1.2958 ] Retrieving EEPROM data
[   1.2959 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/daniel/Jetson/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23 0
[   1.2968 ] MB2 Applet version 01.00.0000
[   1.3931 ] Saved platform info in /home/daniel/Jetson/Linux_for_Tegra/bootloader/cvm.bin
[   1.4276 ] Rebooting to recovery mode
[   1.4288 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[   1.5237 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   1.5250 ] MB2 Applet version 01.00.0000
[   1.6175 ] Booting to recovery mode
[   1.6188 ] tegrarcm_v2 --chip 0x23 0 --reboot recovery
[   1.6204 ] MB2 Applet version 01.00.0000
--- Reading board information succeeded.
--- Parsing chip_info.bin information failed. succeeded.
Chip SKU(00:00:00:D5) ramcode(00:00:00:02)
Parsing module EEPROM:
--- Parsing board ID (3767) succeeded.
--- Parsing board version (300) succeeded.
--- Parsing board SKU (0005) succeeded.
--- Parsing board REV (M.1) succeeded.
jetson-orin-nano-devkit found.
*** Finding boot device ... Boot device internal found.
"/home/daniel/Jetson/Linux_for_Tegra/flash.sh"  jetson-orin-nano-devkit internal
# L4T BSP Information:
# R35 , REVISION: 6.0
# User release: 0.0
ECID is 0x80012344705DF1047C00000006FD8200
# Target Board Information:
# Name: jetson-orin-nano-devkit, Board Family: t186ref, SoC: Tegra 234,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
copying emc_fuse_dev_params(/home/daniel/Jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-diag-boot.dts)... done.
copying device_config(/home/daniel/Jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-device-p3767-0000.dts)... done.
copying misc_config(/home/daniel/Jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-misc-p3767-0000.dts)... done.
./tegraflash.py --chip 0x23 --applet "/home/daniel/Jetson/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3767-0000.dts --misc_config tegra234-mb1-bct-misc-p3767-0000.dts --bins "mb2_applet applet_t234.bin" --cmd "dump eeprom cvm cvm.bin; dump custinfo custinfo_out.bin; reboot recovery"
version 1.0.0
[   0.0606 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.0618 ] File rcm_state open failed
[   0.0618 ] ERROR: failed to read rcm_state
[   0.0618 ]
[   0.0692 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0696 ] Assuming zero filled SBK key
[   0.0626 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[   0.0780 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[   0.1026 ] Parsing partition layout
[   0.1035 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.1060 ] Kernel DTB used: None
[   0.1060 ] WARNING: dce base dtb is not provided
[   0.1060 ] Parsing partition layout
[   0.1069 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.1084 ] Creating list of images to be signed
[   0.1093 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[   0.1101 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.1127 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.1162 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.1281 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.1288 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.1418 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.1445 ] adding BCH for mb2_t234_aligned.bin
[   0.1483 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.1788 ] adding BCH for mb2_t234_aligned.bin
[   0.2514 ] Filling MB1 storage info
[   0.2515 ] Parsing dev params for multi chains
[   0.2701 ] Generating br-bct
[   0.2710 ] Updating dev and MSS params in BR BCT
[   0.2710 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.2726 ] Updating bl info
[   0.2734 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[   0.2744 ] WARNING: boot chain is not completed. set to 0
[   0.2765 ] Generating signatures
[   0.2838 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.2841 ] Assuming zero filled SBK key
[   0.3064 ] Warning: pub_key.key is not found
[   0.2997 ] Parsing dev params for multi chains
[   0.2997 ] Generating br-bct
[   0.3006 ] Updating dev and MSS params in BR BCT
[   0.3007 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.3517 ] Updating bl info
[   0.3530 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.3544 ] WARNING: boot chain is not completed. set to 0
[   0.4338 ] Get Signed section of bct
[   0.4357 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   0.4375 ] Signing BCT
[   0.4449 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.4452 ] Assuming zero filled SBK key
[   0.4503 ] Sha saved in br_bct_BR.sha
[   0.4510 ] Warning: pub_key.key is not found
[   0.4437 ] Updating BCT with signature
[   0.4447 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   0.4459 ] Offset :4608 Len :3584
[   0.4470 ] Generating SHA2 Hash
[   0.4545 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   0.4548 ] Assuming zero filled SBK key
[   0.4549 ] Assuming zero filled SBK key
[   0.4603 ] Sha saved in br_bct_BR.sha
[   0.4538 ] Updating BCT with SHA2 Hash
[   0.4548 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   0.4560 ] Offset :4608 Len :3584
[   0.4566 ] Offset :68 Len :8124
[   0.4573 ] Generating coldboot mb1-bct
[   0.4582 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.4592 ] MB1-BCT version: 0.13
[   0.4633 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.4637 ] Added Platform Config 9 data with size :- 100
[   0.4638 ]
[   0.4638 ] Updating mb1-bct with firmware information
[   0.4647 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.4676 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   0.4686 ] Generating SHA2 Hash for mb1bct
[   0.4779 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[   0.4798 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[   0.4735 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   0.4743 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   0.4834 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.4837 ] Assuming zero filled SBK key
[   0.4863 ] Warning: pub_key.key is not found
[   0.4801 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.4823 ] Generating recovery mb1-bct
[   0.4832 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.4843 ] MB1-BCT version: 0.13
[   0.4880 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.4885 ] Added Platform Config 9 data with size :- 100
[   0.4885 ]
[   0.4886 ] Updating mb1-bct with firmware information
[   0.4896 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.4926 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[   0.4937 ] Generating SHA2 Hash for mb1bct
[   0.5031 ] Sha saved in mb1_bct_MB1_aligned.sha
[   0.5050 ] Sha saved in mb1_bct_MB1.sha
[   0.4987 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   0.4993 ] adding BCH for mb1_bct_MB1_aligned.bct
[   0.5085 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.5087 ] Assuming zero filled SBK key
[   0.5114 ] Warning: pub_key.key is not found
[   0.5051 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.5074 ] Error: Skip generating mem_bct because sdram_config is not defined
[   0.5075 ] Copying signatures
[   0.5084 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.5207 ] Boot Rom communication
[   0.5217 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   0.5227 ] BR_CID: 0x80012344705DF1047C00000006FD8200
[   0.6138 ] Sending bct_br
[   0.7025 ] Sending mb1
[   0.7043 ] Sending psc_bl1
[   0.7238 ] Sending bct_mb1
[   0.7336 ] Boot Rom communication completed
[   0.7361 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[   0.7389 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --appendsigheader applet_t234_aligned.bin zerosbk
[   0.7401 ] adding BCH for applet_t234_aligned.bin
[   0.7774 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.7777 ] Assuming zero filled SBK key
[   0.7818 ] Warning: pub_key.key is not found
[   0.7757 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[   0.7792 ] Sending mb2_applet...
[   0.7802 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[   0.7810 ] BL: version 1.4.0.4-t234-54845784-e89ea9bc last_boot_error: 0
[   0.9404 ] Sending applet
[   1.0742 ] completed
[   1.0756 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   1.0772 ] MB2 Applet version 01.00.0000
[   1.2702 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   1.2717 ] MB2 Applet version 01.00.0000
[   1.3688 ] Retrieving board information
[   1.3702 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails chip chip_info.bin
[   1.3716 ] MB2 Applet version 01.00.0000
[   1.4648 ] Saved platform info in chip_info.bin
[   1.4718 ] Chip minor revision: 1
[   1.4724 ] Bootrom revision: 0x7
[   1.4730 ] Ram code: 0x2
[   1.4731 ] Chip sku: 0xd5
[   1.4731 ] Chip Sample: prod
[   1.4731 ]
[   1.4739 ] Retrieving EEPROM data
[   1.4740 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/daniel/Jetson/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23 0
[   1.4754 ] MB2 Applet version 01.00.0000
[   1.5711 ] Saved platform info in /home/daniel/Jetson/Linux_for_Tegra/bootloader/cvm.bin
[   1.6066 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   1.6074 ] MB2 Applet version 01.00.0000
[   1.7024 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   1.7034 ] MB2 Applet version 01.00.0000
[   1.7964 ] Dumping customer Info
[   1.7973 ] tegrarcm_v2 --chip 0x23 0 --oem dump bct tmp.bct
[   1.7983 ] MB2 Applet version 01.00.0000
[   1.8910 ] Saved bct in tmp.bct
[   1.9015 ] tegrabct_v2 --brbct tmp.bct --chip 0x23 0 --custinfo /home/daniel/Jetson/Linux_for_Tegra/bootloader/custinfo_out.bin
[   1.9031 ] C[   1.9039 ] ustomer data saved in /home/daniel/Jetson/Linux_for_Tegra/bootloader/custinfo_out.bin successfully
[   1.9040 ] Rebooting to recovery mode
[   1.9064 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[   2.0028 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   2.0040 ] MB2 Applet version 01.00.0000
[   2.0968 ] Booting to recovery mode
[   2.0982 ] tegrarcm_v2 --chip 0x23 0 --reboot recovery
[   2.0994 ] MB2 Applet version 01.00.0000
Board ID(3767) version(300) sku(0005) revision(M.1)
Chip SKU(00:00:00:D5) ramcode(2) fuselevel(fuselevel_production) board_FAB(300)
emc_opt_disable_fuse:(0)
Copy /home/daniel/Jetson/Linux_for_Tegra/kernel/dtb/tegra234-p3767-0003-p3768-0000-a0.dtb to /home/daniel/Jetson/Linux_for_Tegra/kernel/dtb/tegra234-p3767-0003-p3768-0000-a0.dtb.rec
Generated UUID 4ec6331f-2744-42a9-8cea-273b2c7525ae for mounting root APP partition.
copying bctfile(/home/daniel/Jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-p3767-0001-sdram-l4t.dts)... done.
copying minratchet_config(/home/daniel/Jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-ratchet-p3767-0000.dts)... done.
copying pinmux_config(/home/daniel/Jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi)... done.
copying gpioint_config(/home/daniel/Jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-gpioint-p3767-0000.dts)... done.
copying pmic_config(/home/daniel/Jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-pmic-p3767-0000-a02.dts)... done.
copying pmc_config(/home/daniel/Jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi)... done.
copying deviceprod_config(/home/daniel/Jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-cprod-p3767-0000.dts)... done.
copying prod_config(/home/daniel/Jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-prod-p3767-0000.dts)... done.
copying scr_config(/home/daniel/Jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb2-bct-scr-p3767-0000.dts)... done.
copying wb0sdram(/home/daniel/Jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-p3767-0001-wb0sdram-l4t.dts)... done.
copying bootrom_config(/home/daniel/Jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-reset-p3767-0000.dts)... done.
Existing uphylane_config(/home/daniel/Jetson/Linux_for_Tegra/bootloader/tegra234-mb1-bct-uphylane-si.dtsi) reused.
copying dev_params(/home/daniel/Jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-p3767-0000-l4t.dts)... done.
copying dev_params_b(/home/daniel/Jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct_b-p3767-0000-l4t.dts)... done.
copying mb2bct_cfg(/home/daniel/Jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb2-bct-misc-p3767-0000.dts)... done.
Existing pscfwfile(/home/daniel/Jetson/Linux_for_Tegra/bootloader/pscfw_t234_prod.bin) reused.
Existing pscbl1file(/home/daniel/Jetson/Linux_for_Tegra/bootloader/psc_bl1_t234_prod.bin) reused.
Existing mtsmcefile(/home/daniel/Jetson/Linux_for_Tegra/bootloader/mce_flash_o10_cr_prod.bin) reused.
Existing mb2applet(/home/daniel/Jetson/Linux_for_Tegra/bootloader/applet_t234.bin) reused.
Existing bootloader(/home/daniel/Jetson/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
copying initrd(/home/daniel/Jetson/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
bl is uefi
Making Boot image... done.
Not signing of boot.img
Making recovery ramdisk for recovery image...
Re-generating recovery ramdisk for recovery image...
/home/daniel/Jetson/Linux_for_Tegra/bootloader/ramdisk_tmp /home/daniel/Jetson/Linux_for_Tegra/bootloader /home/daniel/Jetson/Linux_for_Tegra
42011 blocks
gzip: /home/daniel/Jetson/Linux_for_Tegra/kernel/Image: not in gzip format
_BASE_KERNEL_VERSION=5.10.216-tegra
cp: cannot stat '/home/daniel/Jetson/Linux_for_Tegra/rootfs/lib/modules/5.10.216-tegra/kernel/drivers/mtd/mtd.ko': No such file or directory
warning: cp -f /home/daniel/Jetson/Linux_for_Tegra/rootfs/lib/modules/5.10.216-tegra/kernel/drivers/mtd/mtd.ko /home/daniel/Jetson/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/modules/5.10.216-tegra/kernel/drivers/mtd/mtd.ko
cp: cannot stat '/home/daniel/Jetson/Linux_for_Tegra/rootfs/lib/modules/5.10.216-tegra/kernel/drivers/mtd/mtdblock.ko': No such file or directory
warning: cp -f /home/daniel/Jetson/Linux_for_Tegra/rootfs/lib/modules/5.10.216-tegra/kernel/drivers/mtd/mtdblock.ko /home/daniel/Jetson/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/modules/5.10.216-tegra/kernel/drivers/mtd/mtdblock.ko
cp: cannot stat '/home/daniel/Jetson/Linux_for_Tegra/rootfs/lib/modules/5.10.216-tegra/kernel/drivers/mtd/mtd_blkdevs.ko': No such file or directory
warning: cp -f /home/daniel/Jetson/Linux_for_Tegra/rootfs/lib/modules/5.10.216-tegra/kernel/drivers/mtd/mtd_blkdevs.ko /home/daniel/Jetson/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/modules/5.10.216-tegra/kernel/drivers/mtd/mtd_blkdevs.ko
cp: cannot stat '/home/daniel/Jetson/Linux_for_Tegra/rootfs/lib/modules/5.10.216-tegra/kernel/drivers/mtd/devices/qspi_mtd.ko': No such file or directory
warning: cp -f /home/daniel/Jetson/Linux_for_Tegra/rootfs/lib/modules/5.10.216-tegra/kernel/drivers/mtd/devices/qspi_mtd.ko /home/daniel/Jetson/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/modules/5.10.216-tegra/kernel/drivers/mtd/devices/qspi_mtd.ko
cp: cannot stat '/home/daniel/Jetson/Linux_for_Tegra/rootfs/lib/modules/5.10.216-tegra/kernel/drivers/spi/spi-tegra210-qspi.ko': No such file or directory
warning: cp -f /home/daniel/Jetson/Linux_for_Tegra/rootfs/lib/modules/5.10.216-tegra/kernel/drivers/spi/spi-tegra210-qspi.ko /home/daniel/Jetson/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/modules/5.10.216-tegra/kernel/drivers/spi/spi-tegra210-qspi.ko
cp: cannot stat '/home/daniel/Jetson/Linux_for_Tegra/rootfs/usr/lib/modules/5.10.216-tegra/kernel/drivers/net/ethernet/realtek/r8168/r8168.ko': No such file or directory
warning: cp -f /home/daniel/Jetson/Linux_for_Tegra/rootfs/usr/lib/modules/5.10.216-tegra/kernel/drivers/net/ethernet/realtek/r8168/r8168.ko /home/daniel/Jetson/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/modules/5.10.216-tegra/kernel/drivers/net/ethernet/realtek/r8168/r8168.ko
57838 blocks
Making Recovery image...
copying recdtbfile(/home/daniel/Jetson/Linux_for_Tegra/kernel/dtb/tegra234-p3767-0003-p3768-0000-a0.dtb.rec)... done.
20+0 records in
20+0 records out
20 bytes copied, 0.000601194 s, 33.3 kB/s
Existing sosfile(/home/daniel/Jetson/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing tegraboot(/home/daniel/Jetson/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing cpu_bootloader(/home/daniel/Jetson/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing mb2blfile(/home/daniel/Jetson/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing xusbfile(/home/daniel/Jetson/Linux_for_Tegra/bootloader/xusb_t234_prod.bin) reused.
Existing dcefile(/home/daniel/Jetson/Linux_for_Tegra/bootloader/display-t234-dce.bin) reused.
Existing nvdecfile(/home/daniel/Jetson/Linux_for_Tegra/bootloader/nvdec_t234_prod.fw) reused.
Existing psc_rf(/home/daniel/Jetson/Linux_for_Tegra/bootloader/psc_rf_t234_prod.bin) reused.
Existing mb2_rf(/home/daniel/Jetson/Linux_for_Tegra/bootloader/mb2rf_t234.bin) reused.
Existing mb1file(/home/daniel/Jetson/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing bpffile(/home/daniel/Jetson/Linux_for_Tegra/bootloader/bpmp_t234-TE950M-A1_prod.bin) reused.
copying bpfdtbfile(/home/daniel/Jetson/Linux_for_Tegra/bootloader/t186ref/tegra234-bpmp-3767-0003-3509-a02.dtb)... done.
Existing scefile(/home/daniel/Jetson/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/home/daniel/Jetson/Linux_for_Tegra/bootloader/camera-rtcpu-t234-rce.img) reused.
Existing apefile(/home/daniel/Jetson/Linux_for_Tegra/bootloader/adsp-fw.bin) reused.
Existing spefile(/home/daniel/Jetson/Linux_for_Tegra/bootloader/spe_t234.bin) reused.
Existing wb0boot(/home/daniel/Jetson/Linux_for_Tegra/bootloader/sc7_t234_prod.bin) reused.
Existing tosfile(/home/daniel/Jetson/Linux_for_Tegra/bootloader/tos-optee_t234.img) reused.
Existing eksfile(/home/daniel/Jetson/Linux_for_Tegra/bootloader/eks_t234.img) reused.
copying dtbfile(/home/daniel/Jetson/Linux_for_Tegra/kernel/dtb/tegra234-p3767-0003-p3768-0000-a0.dtb)... done.
Copying nv_boot_control.conf to rootfs
        populating kernel to rootfs... done.
        populating initrd to rootfs... done.
        populating kernel_tegra234-p3767-0003-p3768-0000-a0.dtb to rootfs... done.
Making system.img...
/home/daniel/Jetson/Linux_for_Tegra/rootfs/boot/extlinux/extlinux.conf is not found, exiting...
*** ERROR: flashing failed.
Hi daniel2008_12,
Are you using the devkit or custom board for Orin Nano?
Please also run the following command in your BSP package.
$ sudo ./apply_binaries.sh
Yeah, the script is going, but not good " Error: failed to get storage info"…
10169 seconds??? passed… how much time it will take???
version 1.0.0
[   0.1725 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.1738 ] File rcm_state open failed
[   0.1738 ] ERROR: failed to read rcm_state
[   0.1738 ]
[   0.2451 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.2456 ] Assuming zero filled SBK key
[   0.1747 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
[   0.1915 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0000.dts
[   0.2227 ] Parsing partition layout
[   0.2282 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.2415 ] Kernel DTB used: None
[   0.2416 ] WARNING: dce base dtb is not provided
[   0.2416 ] Parsing partition layout
[   0.2425 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.2441 ] Creating list of images to be signed
[   0.2482 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[   0.2489 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.2763 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.2805 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.2950 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.2986 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.3102 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.3139 ] adding BCH for mb2_t234_aligned.bin
[   0.3637 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.4093 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.4123 ] adding BCH for mb2_t234_aligned.bin
[   0.4477 ] Filling MB1 storage info
[   0.4478 ] Parsing dev params for multi chains
[   0.4642 ] Generating br-bct
[   0.4892 ] Updating dev and MSS params in BR BCT
[   0.4892 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.5164 ] Updating bl info
[   0.5173 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[   0.5184 ] WARNING: boot chain is not completed. set to 0
[   0.5203 ] Generating signatures
[   0.5916 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.5919 ] Assuming zero filled SBK key
[   0.6849 ] Warning: pub_key.key is not found
[   0.6145 ] Parsing dev params for multi chains
[   0.6145 ] Generating br-bct
[   0.6155 ] Updating dev and MSS params in BR BCT
[   0.6156 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.6198 ] Updating bl info
[   0.6209 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.6222 ] WARNING: boot chain is not completed. set to 0
[   0.6253 ] Get Signed section of bct
[   0.6263 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   0.6279 ] Signing BCT
[   0.6992 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.6995 ] Assuming zero filled SBK key
[   0.7043 ] Sha saved in br_bct_BR.sha
[   0.7050 ] Warning: pub_key.key is not found
[   0.6338 ] Updating BCT with signature
[   0.6347 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   0.6357 ] Offset :4608 Len :3584
[   0.6372 ] Generating SHA2 Hash
[   0.7084 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   0.7087 ] Assuming zero filled SBK key
[   0.7088 ] Assuming zero filled SBK key
[   0.7132 ] Sha saved in br_bct_BR.sha
[   0.6426 ] Updating BCT with SHA2 Hash
[   0.6435 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   0.6445 ] Offset :4608 Len :3584
[   0.6453 ] Offset :68 Len :8124
[   0.6462 ] Generating coldboot mb1-bct
[   0.6471 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.6481 ] MB1-BCT version: 0.13
[   0.6524 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.6530 ] Added Platform Config 9 data with size :- 100
[   0.6530 ]
[   0.6531 ] Updating mb1-bct with firmware information
[   0.6541 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.6571 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   0.6581 ] Generating SHA2 Hash for mb1bct
[   0.7314 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[   0.7335 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[   0.6633 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   0.6641 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   0.7372 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.7376 ] Assuming zero filled SBK key
[   0.7405 ] Warning: pub_key.key is not found
[   0.6704 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.6726 ] Generating recovery mb1-bct
[   0.6736 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.6748 ] MB1-BCT version: 0.13
[   0.6787 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.6794 ] Added Platform Config 9 data with size :- 100
[   0.6794 ]
[   0.6794 ] Updating mb1-bct with firmware information
[   0.6804 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.6833 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[   0.6845 ] Generating SHA2 Hash for mb1bct
[   0.7577 ] Sha saved in mb1_bct_MB1_aligned.sha
[   0.7597 ] Sha saved in mb1_bct_MB1.sha
[   0.6895 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   0.6910 ] adding BCH for mb1_bct_MB1_aligned.bct
[   0.7635 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.7637 ] Assuming zero filled SBK key
[   0.7665 ] Warning: pub_key.key is not found
[   0.6964 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.6987 ] Error: Skip generating mem_bct because sdram_config is not defined
[   0.6988 ] Copying signatures
[   0.6997 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.7121 ] Boot Rom communication
[   0.7132 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   0.7143 ] BR_CID: 0x80012344705DF1047C00000006FD8200
[   0.8038 ] Sending bct_br
[   0.8914 ] Sending mb1
[   0.8926 ] Sending psc_bl1
[   0.9136 ] Sending bct_mb1
[   0.9231 ] Boot Rom communication completed
[   0.9407 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[   0.9425 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --appendsigheader applet_t234_aligned.bin zerosbk
[   0.9433 ] adding BCH for applet_t234_aligned.bin
[   1.0377 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   1.0380 ] Assuming zero filled SBK key
[   1.0417 ] Warning: pub_key.key is not found
[   0.9717 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[   0.9754 ] Sending mb2_applet...
[   0.9765 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[   0.9776 ] BL: version 1.4.0.4-t234-54845784-e89ea9bc last_boot_error: 0
[   1.1300 ] Sending applet
[   1.2652 ] completed
[   1.2663 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   1.2676 ] MB2 Applet version 01.00.0000
[   1.4602 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   1.4615 ] MB2 Applet version 01.00.0000
[   1.5564 ] Retrieving board information
[   1.5577 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails chip chip_info.bin
[   1.5591 ] MB2 Applet version 01.00.0000
[   1.6534 ] Saved platform info in chip_info.bin
[   1.6601 ] Chip minor revision: 1
[   1.6607 ] Bootrom revision: 0x7
[   1.6613 ] Ram code: 0x2
[   1.6614 ] Chip sku: 0xd5
[   1.6614 ] Chip Sample: prod
[   1.6614 ]
[   1.6619 ] Retrieving EEPROM data
[   1.6620 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/daniel/Jetson/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23 0
[   1.6630 ] MB2 Applet version 01.00.0000
[   1.7583 ] Saved platform info in /home/daniel/Jetson/Linux_for_Tegra/bootloader/cvm.bin
[   1.7932 ] Rebooting to recovery mode
[   1.7944 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[   1.8921 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   1.8934 ] MB2 Applet version 01.00.0000
[   1.9867 ] Booting to recovery mode
[   1.9877 ] tegrarcm_v2 --chip 0x23 0 --reboot recovery
[   1.9888 ] MB2 Applet version 01.00.0000
# User release: 0.0
version 1.0.0
[   0.0629 ] File rcm_state open failed
[   0.0635 ] ERROR: failed to read rcm_state
[   0.0635 ]
[   0.0710 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0714 ] Assuming zero filled SBK key
[   0.0643 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[   0.1253 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[   0.1785 ] Parsing partition layout
[   0.1794 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.1820 ] Kernel DTB used: None
[   0.1820 ] WARNING: dce base dtb is not provided
[   0.1820 ] Parsing partition layout
[   0.1830 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.1844 ] Creating list of images to be signed
[   0.1854 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[   0.1862 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.1893 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.1900 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.2063 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.2100 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.2220 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.2228 ] adding BCH for mb2_t234_aligned.bin
[   0.2299 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.2614 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.2622 ] adding BCH for mb2_t234_aligned.bin
[   0.2995 ] Filling MB1 storage info
[   0.2995 ] Parsing dev params for multi chains
[   0.3151 ] Generating br-bct
[   0.3159 ] Updating dev and MSS params in BR BCT
[   0.3160 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.3175 ] Updating bl info
[   0.3185 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[   0.3194 ] WARNING: boot chain is not completed. set to 0
[   0.3215 ] Generating signatures
[   0.3289 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.3292 ] Assuming zero filled SBK key
[   0.3520 ] Warning: pub_key.key is not found
[   0.3451 ] Parsing dev params for multi chains
[   0.3452 ] Generating br-bct
[   0.3461 ] Updating dev and MSS params in BR BCT
[   0.3461 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.3476 ] Updating bl info
[   0.3486 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.3498 ] WARNING: boot chain is not completed. set to 0
[   0.3522 ] Get Signed section of bct
[   0.3532 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   0.3546 ] Signing BCT
[   0.3621 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.3624 ] Assuming zero filled SBK key
[   0.3666 ] Sha saved in br_bct_BR.sha
[   0.3673 ] Warning: pub_key.key is not found
[   0.3599 ] Updating BCT with signature
[   0.3607 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   0.3619 ] Offset :4608 Len :3584
[   0.3626 ] Generating SHA2 Hash
[   0.3701 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   0.3704 ] Assuming zero filled SBK key
[   0.3749 ] Sha saved in br_bct_BR.sha
[   0.3681 ] Updating BCT with SHA2 Hash
[   0.3690 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   0.3700 ] Offset :4608 Len :3584
[   0.3710 ] Offset :68 Len :8124
[   0.3715 ] Generating coldboot mb1-bct
[   0.3724 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.3736 ] MB1-BCT version: 0.13
[   0.3773 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.3779 ] Added Platform Config 9 data with size :- 100
[   0.3779 ]
[   0.3779 ] Updating mb1-bct with firmware information
[   0.3789 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.3819 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   0.3829 ] Generating SHA2 Hash for mb1bct
[   0.3924 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[   0.3945 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[   0.3881 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   0.3890 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   0.3983 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.3987 ] Assuming zero filled SBK key
[   0.4016 ] Warning: pub_key.key is not found
[   0.3953 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.3975 ] Generating recovery mb1-bct
[   0.3985 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.3996 ] MB1-BCT version: 0.13
[   0.4033 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.4039 ] Added Platform Config 9 data with size :- 100
[   0.4039 ]
[   0.4040 ] Updating mb1-bct with firmware information
[   0.4058 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.4086 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[   0.4097 ] Generating SHA2 Hash for mb1bct
[   0.4192 ] Sha saved in mb1_bct_MB1_aligned.sha
[   0.4212 ] Sha saved in mb1_bct_MB1.sha
[   0.4148 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   0.4156 ] adding BCH for mb1_bct_MB1_aligned.bct
[   0.4249 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.4253 ] Assuming zero filled SBK key
[   0.4280 ] Warning: pub_key.key is not found
[   0.4217 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.4239 ] Error: Skip generating mem_bct because sdram_config is not defined
[   0.4239 ] Copying signatures
[   0.4249 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.4371 ] Boot Rom communication
[   0.4381 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   0.4393 ] BR_CID: 0x80012344705DF1047C00000006FD8200
[   0.5284 ] Sending bct_br
[   0.6204 ] Sending mb1
[   0.6218 ] Sending psc_bl1
[   0.6400 ] Sending bct_mb1
[   0.6497 ] Boot Rom communication completed
[   0.6522 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[   0.6549 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --appendsigheader applet_t234_aligned.bin zerosbk
[   0.6562 ] adding BCH for applet_t234_aligned.bin
[   0.6955 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.6959 ] Assuming zero filled SBK key
[   0.7002 ] Warning: pub_key.key is not found
[   0.6940 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[   0.6976 ] Sending mb2_applet...
[   0.6985 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[   0.6997 ] BL: version 1.4.0.4-t234-54845784-e89ea9bc last_boot_error: 0
[   0.8548 ] Sending applet
[   0.9890 ] completed
[   0.9901 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.9914 ] MB2 Applet version 01.00.0000
[   1.1847 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   1.1856 ] MB2 Applet version 01.00.0000
[   1.2802 ] Retrieving board information
[   1.2816 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails chip chip_info.bin
[   1.2829 ] MB2 Applet version 01.00.0000
[   1.3762 ] Saved platform info in chip_info.bin
[   1.3829 ] Chip minor revision: 1
[   1.3834 ] Bootrom revision: 0x7
[   1.3841 ] Ram code: 0x2
[   1.3847 ] Chip sku: 0xd5
[   1.3847 ] Chip Sample: prod
[   1.3848 ]
[   1.3853 ] Retrieving EEPROM data
[   1.3854 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/daniel/Jetson/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23 0
[   1.3865 ] MB2 Applet version 01.00.0000
[   1.4819 ] Saved platform info in /home/daniel/Jetson/Linux_for_Tegra/bootloader/cvm.bin
[   1.5185 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   1.5199 ] MB2 Applet version 01.00.0000
[   1.6139 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   1.6154 ] MB2 Applet version 01.00.0000
[   1.7086 ] Dumping customer Info
[   1.7100 ] tegrarcm_v2 --chip 0x23 0 --oem dump bct tmp.bct
[   1.7111 ] MB2 Applet version 01.00.0000
[   1.8054 ] Saved bct in tmp.bct
[   1.8156 ] tegrabct_v2 --brbct tmp.bct --chip 0x23 0 --custinfo /home/daniel/Jetson/Linux_for_Tegra/bootloader/custinfo_out.bin
[   1.8169 ] C[   1.8175 ] ustomer data saved in /home/daniel/Jetson/Linux_for_Tegra/bootloader/custinfo_out.bin successfully
[   1.8176 ] Rebooting to recovery mode
[   1.8186 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[   1.9140 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   1.9155 ] MB2 Applet version 01.00.0000
[   2.0087 ] Booting to recovery mode
[   2.0099 ] tegrarcm_v2 --chip 0x23 0 --reboot recovery
[   2.0116 ] MB2 Applet version 01.00.0000
Generated UUID ea385210-5d8f-4603-90de-80af16a54683 for mounting root APP partition.
bl is uefi
42011 blocks
58274 blocks
20+0 records in
20+0 records out
20 bytes copied, 0.000319034 s, 62.7 kB/s
        Setting "FDT /boot/dtb/kernel_tegra234-p3767-0003-p3768-0000-a0.dtb" successfully in the extlinux.conf...done.
        populating rootfs from /home/daniel/Jetson/Linux_for_Tegra/rootfs ...   populating /boot/extlinux/extlinux.conf ... done.
        Sync'ing system.img ... done.
        Converting RAW image to Sparse image... done.
system.img built successfully.
Not signing of kernel-dtb
Existing tbcfile(/home/daniel/Jetson/Linux_for_Tegra/bootloader/uefi_jetson.bin) reused.
131072+0 records in
131072+0 records out
67108864 bytes (67 MB, 64 MiB) copied, 0.445204 s, 151 MB/s
        Sync'ing esp.img ... done.
copying tbcdtbfile(/home/daniel/Jetson/Linux_for_Tegra/kernel/dtb/tegra234-p3767-0003-p3768-0000-a0.dtb)... done.
copying cfgfile(/home/daniel/Jetson/Linux_for_Tegra/bootloader/t186ref/cfg/flash_t234_qspi_sd.xml) to flash.xml... done.
Existing flashapp(/home/daniel/Jetson/Linux_for_Tegra/bootloader/tegraflash.py) reused.
copying overlay_dtb(/home/daniel/Jetson/Linux_for_Tegra/kernel/dtb/L4TConfiguration.dtbo)... done.
copying overlay_dtb(/home/daniel/Jetson/Linux_for_Tegra/kernel/dtb/tegra234-p3767-overlay.dtbo)... done.
copying overlay_dtb(/home/daniel/Jetson/Linux_for_Tegra/kernel/dtb/tegra234-p3768-overlay.dtbo)... done.
/home/daniel/Jetson/Linux_for_Tegra/bootloader/L4TConfiguration_updated.dts: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
/home/daniel/Jetson/Linux_for_Tegra/bootloader/L4TConfiguration.dtbo: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
./tegraflash.py  --bl uefi_jetson_with_dtb.bin  --odmdata gbe-uphy-config-8,hsstp-lane-map-3,hsio-uphy-config-0  --overlay_dtb L4TConfiguration.dtbo,tegra234-p3767-overlay.dtbo,tegra234-p3768-overlay.dtbo,  --bldtb tegra234-p3767-0003-p3768-0000-a0.dtb --applet mb1_t234_prod.bin --cmd "flash; reboot"  --cfg flash.xml --chip 0x23 --concat_cpubl_bldtb --cpubl uefi_jetson.bin --minratchet_config tegra234-mb1-bct-ratchet-p3767-0000.dts --device_config tegra234-mb1-bct-device-p3767-0000.dts --misc_config tegra234-mb1-bct-misc-p3767-0000.dts --pinmux_config tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi --gpioint_config tegra234-mb1-bct-gpioint-p3767-0000.dts --pmic_config tegra234-mb1-bct-pmic-p3767-0000-a02.dts --pmc_config tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi --deviceprod_config tegra234-mb1-bct-cprod-p3767-0000.dts --prod_config tegra234-mb1-bct-prod-p3767-0000.dts --scr_config tegra234-mb2-bct-scr-p3767-0000.dts --wb0sdram_config tegra234-p3767-0001-wb0sdram-l4t.dts --br_cmd_config tegra234-mb1-bct-reset-p3767-0000.dts --uphy tegra234-mb1-bct-uphylane-si.dtsi --dev_params tegra234-br-bct-p3767-0000-l4t.dts,tegra234-br-bct_b-p3767-0000-l4t.dts --mb2bct_cfg tegra234-mb2-bct-misc-p3767-0000.dts  --bins "psc_fw pscfw_t234_prod.bin; mts_mce mce_flash_o10_cr_prod.bin; mb2_applet applet_t234.bin; mb2_bootloader mb2_t234.bin; xusb_fw xusb_t234_prod.bin; dce_fw display-t234-dce.bin; nvdec nvdec_t234_prod.fw; bpmp_fw bpmp_t234-TE950M-A1_prod.bin; bpmp_fw_dtb tegra234-bpmp-3767-0003-3509-a02.dtb; sce_fw camera-rtcpu-sce.img; rce_fw camera-rtcpu-t234-rce.img; ape_fw adsp-fw.bin; spe_fw spe_t234.bin; tos tos-optee_t234.img; eks eks_t234.img" --sdram_config tegra234-p3767-0001-sdram-l4t.dts  --cust_info custinfo_out.bin   --ramcode 2  --bct_backup  --boot_chain A
saving flash command in /home/daniel/Jetson/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/daniel/Jetson/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[   0.1298 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.1302 ] Assuming zero filled SBK key
[   0.1144 ] tegraparser_v2 --pt flash.xml.tmp
[   0.1472 ] Change tegra234-bpmp-3767-0003-3509-a02.dtb to tegra234-bpmp-3767-0003-3509-a02_with_odm.dtb
[   0.1473 ] Change tegra234-bpmp-3767-0003-3509-a02.dtb to tegra234-bpmp-3767-0003-3509-a02_with_odm.dtb
[   0.2482 ] /usr/bin/python3 dtbcheck.py -c t234 -o tegra234-bpmp-3767-0003-3509-a02_with_odm.dtb tegra234-bpmp-3767-0003-3509-a02_with_odm_tmp.dtb
[   1.4739 ] Concatenating L4TConfiguration.dtbo,tegra234-p3767-overlay.dtbo,tegra234-p3768-overlay.dtbo to tegra234-p3767-0003-p3768-0000-a0_with_odm_overlay.dtb
[   1.4744 ] Concatenating bl dtb to cpubl binary
[   1.4818 ] MB2 binary: mb2_t234.bin
[   1.4820 ] Pre-processing mb2bct config: tegra234-mb2-bct-misc-p3767-0000.dts
[   1.5894 ] Pre-processing mb2bct config: tegra234-mb2-bct-scr-p3767-0000.dts
[   3.6079 ] Generating coldboot mb2-bct
[   3.6080 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct.cfg --mb2bctcfg tegra234-mb2-bct-misc-p3767-0000_cpp.dtb --scr tegra234-mb2-bct-scr-p3767-0000_cpp.dtb
[   3.6096 ] ERROR: value 0x31 is out of range
[   3.6159 ] ERROR: value 0x31 is out of range
[   3.6189 ] ERROR: value 0x31 is out of range
[   3.6194 ] ERROR: value 0x31 is out of range
[   3.6198 ] WARNING: unknown property 'tfc_version'
[   3.6204 ] WARNING: unknown property 'addr_header_version'
[   3.6465 ] Updating mb2-bct with storage information
[   3.6475 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct_MB2.bct --updatestorageinfo flash.xml.bin
[   3.6496 ] Concatenating mb2-bct to mb2 binary
[   3.6497 ] mb2_bin_file = mb2_t234.bin
[   3.6497 ] mb2_bct_file = mb2_cold_boot_bct_MB2.bct
[   3.6789 ] DCE binary: display-t234-dce.bin
[   3.6792 ] Kernel DTB used: kernel_tegra234-p3767-0003-p3768-0000-a0.dtb
[   3.6793 ] Concatenating kernel-dtb to dce-fw binary
[   3.6795 ] dce_bin = display-t234-dce.bin
[   3.6795 ] kernel_dtb = kernel_tegra234-p3767-0003-p3768-0000-a0.dtb
[   3.6795 ] dce_with_dtb = display-t234-dce_with_kernel_tegra234-p3767-0003-p3768-0000-a0.bin
[   3.8296 ] Update display-t234-dce_with_kernel_tegra234-p3767-0003-p3768-0000-a0.bin to dce_fw partitions
[   3.8390 ] Parsing partition layout
[   3.8405 ] tegraparser_v2 --pt flash.xml.tmp
[   3.8446 ] Creating list of images to be signed
[   3.8539 ] Generating ratchet blob
[   3.8540 ] Pre-processing config: tegra234-mb1-bct-reset-p3767-0000.dts
[   3.8822 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[   3.9225 ] Pre-processing config: tegra234-mb1-bct-cprod-p3767-0000.dts
[   3.9378 ] Pre-processing config: tegra234-mb1-bct-gpioint-p3767-0000.dts
[   3.9551 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[   4.0252 ] Pre-processing config: tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi
[   4.1123 ] Pre-processing config: tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi
[   4.1276 ] Pre-processing config: tegra234-mb1-bct-pmic-p3767-0000-a02.dts
[   4.1436 ] Pre-processing config: tegra234-mb1-bct-prod-p3767-0000.dts
[   4.1591 ] Pre-processing config: tegra234-p3767-0001-sdram-l4t.dts
[   8.2300 ] Pre-processing config: tegra234-mb1-bct-uphylane-si.dtsi
[   8.2452 ] Pre-processing config: tegra234-p3767-0001-wb0sdram-l4t.dts
[  12.2911 ] Pre-processing config: tegra234-mb1-bct-ratchet-p3767-0000.dts
[  12.3071 ] Generating coldboot mb1-bct
[  12.3081 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3767-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3767-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[  12.3094 ] MB1-BCT version: 0.13
[  12.3151 ] Parsing config file :tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb
[  12.3164 ] Added Platform Config 0 data with size :- 2416
[  12.3249 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb
[  12.3271 ] WARNING: unknown node 'g2'
[  12.3271 ] WARNING: unknown node 'g9'
[  12.3272 ] WARNING: unknown node 'g9'
[  12.3272 ] Added Platform Config 2 data with size :- 24
[  12.3272 ]
[  12.3272 ] Parsing config file :tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb
[  12.3273 ] Added Platform Config 4 data with size :- 288
[  12.3273 ]
[  12.3273 ] Parsing config file :tegra234-mb1-bct-reset-p3767-0000_cpp.dtb
[  12.3273 ] Added Platform Config 3 data with size :- 52
[  12.3274 ]
[  12.3274 ] Parsing config file :tegra234-mb1-bct-prod-p3767-0000_cpp.dtb
[  12.3274 ] WARNING: unknown property 'major'
[  12.3274 ] WARNING: unknown property 'minor'
[  12.3275 ] Added Platform Config 5 data with size :- 512
[  12.3275 ]
[  12.3275 ] Parsing config file :tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb
[  12.3275 ] WARNING: unknown property 'major'
[  12.3276 ] WARNING: unknown property 'minor'
[  12.3276 ] Added Platform Config 7 data with size :- 380
[  12.3276 ]
[  12.3276 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[  12.3277 ] Added Platform Config 8 data with size :- 24
[  12.3277 ]
[  12.3277 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[  12.3278 ] Added Platform Config 9 data with size :- 100
[  12.3278 ]
[  12.3278 ] Parsing config file :tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[  12.3279 ] ModuleCount 0 NumProdNames 0
[  12.3279 ] Added Platform Config 6 data with size :- 16
[  12.3279 ]
[  12.3279 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[  12.3280 ]
[  12.3280 ] Updating mb1-bct with firmware information
[  12.3293 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[  12.3331 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[  12.3343 ] Generating SHA2 Hash for mb1bct
[  12.3846 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[  12.3868 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[  12.3598 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[  12.3606 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[  12.3907 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[  12.3911 ] Assuming zero filled SBK key
[  12.3940 ] Warning: pub_key.key is not found
[  12.3671 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[  12.3693 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[  12.3701 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[  12.3837 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[  12.3876 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[  12.4058 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[  12.4067 ] Header already present for nvdec_t234_prod_aligned.fw
[  12.4333 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[  12.4479 ] adding BCH for xusb_t234_prod_aligned.bin
[  12.4828 ] Header already present for bpmp_t234-TE950M-A1_prod_aligned.bin
[  12.5288 ] adding BCH for tegra234-bpmp-3767-0003-3509-a02_with_odm_aligned.dtb
[  12.5696 ] Header already present for pscfw_t234_prod_aligned.bin
[  12.6045 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[  12.6255 ] Header already present for sc7_t234_prod.bin
[  12.6384 ] Header already present for psc_rf_t234_prod_aligned.bin
[  12.6495 ] adding BCH for mb2rf_t234_aligned.bin
[  12.6576 ] INFO: compressing uefi_jetson_with_dtb_aligned.bin
[  12.8065 ] INFO: complete compression, uefi_jetson_with_dtb_aligned.bin, ratio = 91%
[  12.8246 ] adding BCH for uefi_jetson_with_dtb_aligned_blob_w_bin_aligned.bin
[  12.9538 ] adding BCH for tos-optee_t234_aligned.img
[  13.1120 ] adding BCH for eks_t234_aligned.img
[  13.2169 ] INFO: compressing display-t234-dce_with_kernel_tegra234-p3767-0003-p3768-0000-a0_aligned.bin
[  13.6334 ] INFO: complete compression, display-t234-dce_with_kernel_tegra234-p3767-0003-p3768-0000-a0_aligned.bin, ratio = 7%
[  13.6782 ] adding BCH for display-t234-dce_with_kernel_tegra234-p3767-0003-p3768-0000-a0_aligned_blob_w_bin_aligned.bin
[  13.7220 ] adding BCH for spe_t234_aligned.bin
[  13.7774 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[  13.8214 ] adding BCH for adsp-fw_aligned.bin
[  13.8783 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[  13.9111 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[  13.9153 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[  13.9252 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[  13.9276 ] Header already present for nvdec_t234_prod_aligned.fw
[  13.9340 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[  13.9459 ] adding BCH for xusb_t234_prod_aligned.bin
[  13.9805 ] Header already present for bpmp_t234-TE950M-A1_prod_aligned.bin
[  14.0007 ] adding BCH for tegra234-bpmp-3767-0003-3509-a02_with_odm_aligned.dtb
[  14.0425 ] Header already present for pscfw_t234_prod_aligned.bin
[  14.0598 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[  14.0757 ] Header already present for sc7_t234_prod.bin
[  14.0833 ] Header already present for psc_rf_t234_prod_aligned.bin
[  14.0916 ] adding BCH for mb2rf_t234_aligned.bin
[  14.0971 ] INFO: compressing uefi_jetson_with_dtb_aligned.bin
[  14.2480 ] INFO: complete compression, uefi_jetson_with_dtb_aligned.bin, ratio = 91%
[  14.2627 ] adding BCH for uefi_jetson_with_dtb_aligned_blob_w_bin_aligned.bin
[  14.4003 ] adding BCH for tos-optee_t234_aligned.img
[  14.5295 ] adding BCH for eks_t234_aligned.img
[  14.6307 ] INFO: compressing display-t234-dce_with_kernel_tegra234-p3767-0003-p3768-0000-a0_aligned.bin
[  15.1315 ] INFO: complete compression, display-t234-dce_with_kernel_tegra234-p3767-0003-p3768-0000-a0_aligned.bin, ratio = 7%
[  15.1761 ] adding BCH for display-t234-dce_with_kernel_tegra234-p3767-0003-p3768-0000-a0_aligned_blob_w_bin_aligned.bin
[  15.2219 ] adding BCH for spe_t234_aligned.bin
[  15.2524 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[  15.2772 ] adding BCH for adsp-fw_aligned.bin
[  15.3525 ] Filling MB1 storage info
[  15.3525 ] Parsing dev params for multi chains
[  15.3797 ] Generating br-bct
[  15.3806 ] Updating dev and MSS params in BR BCT
[  15.3807 ] tegrabct_v2 --dev_param tegra234-br-bct-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[  15.6754 ] Updating bl info
[  15.6764 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[  15.6951 ] Generating br-bct
[  15.6959 ] Updating dev and MSS params in BR BCT
[  15.6960 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[  15.9903 ] Updating bl info
[  15.9913 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[  15.9941 ] Generating BCT backup image
[  15.9942 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[  15.9951 ] 32768+0 records in
[  16.0805 ] 32768+0 records out
[  16.0806 ] 32768 bytes (33 kB, 32 KiB) copied, 0.0840719 s, 390 kB/s
[  16.0806 ]
[  16.0806 ] Concatenating BCT for chain A to bct_backup.img
[  16.0806 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[  16.0815 ] 8192+0 records in
[  16.1035 ] 8192+0 records out
[  16.1035 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.020743 s, 395 kB/s
[  16.1035 ]
[  16.1035 ] Concatenating BCT for chain B to bct_backup.img
[  16.1035 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[  16.1044 ] 8192+0 records in
[  16.1291 ] 8192+0 records out
[  16.1291 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.0235095 s, 348 kB/s
[  16.1291 ]
[  16.1292 ] Generating signatures
[  16.1572 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[  16.1575 ] Assuming zero filled SBK key
[  16.3550 ] Warning: pub_key.key is not found
[  16.3343 ] Parsing dev params for multi chains
[  16.3344 ] Generating br-bct
[  16.3353 ] Updating dev and MSS params in BR BCT
[  16.3354 ] tegrabct_v2 --dev_param tegra234-br-bct-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[  16.6305 ] Updating customer data section
[  16.6315 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[  16.6469 ] Updating bl info
[  16.6478 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[  16.6522 ] Get Signed section of bct
[  16.6531 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[  16.6552 ] Signing BCT
[  16.6833 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[  16.6835 ] Assuming zero filled SBK key
[  16.6878 ] Sha saved in br_bct_BR.sha
[  16.6883 ] Warning: pub_key.key is not found
[  16.6604 ] Updating BCT with signature
[  16.6612 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[  16.6622 ] Offset :4608 Len :3584
[  16.6633 ] Generating SHA2 Hash
[  16.6913 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[  16.6916 ] Assuming zero filled SBK key
[  16.6962 ] Sha saved in br_bct_BR.sha
[  16.6689 ] Updating BCT with SHA2 Hash
[  16.6698 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[  16.6708 ] Offset :4608 Len :3584
[  16.6720 ] Offset :68 Len :8124
[  16.6720 ]
[  16.6721 ] Generating br-bct
[  16.6730 ] Updating dev and MSS params in BR BCT
[  16.6732 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[  16.9667 ] Updating customer data section
[  16.9676 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[  16.9696 ] Updating bl info
[  16.9705 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[  16.9748 ] Get Signed section of bct
[  16.9758 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[  16.9775 ] Signing BCT
[  17.0056 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[  17.0059 ] Assuming zero filled SBK key
[  17.0104 ] Sha saved in br_bct_BR.sha
[  17.0111 ] Warning: pub_key.key is not found
[  16.9832 ] Updating BCT with signature
[  16.9841 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[  16.9855 ] Offset :4608 Len :3584
[  16.9859 ] Generating SHA2 Hash
[  17.0140 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[  17.0142 ] Assuming zero filled SBK key
[  17.0189 ] Sha saved in br_bct_BR.sha
[  16.9916 ] Updating BCT with SHA2 Hash
[  16.9925 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[  16.9940 ] Offset :4608 Len :3584
[  16.9945 ] Offset :68 Len :8124
[  16.9945 ]
[  16.9947 ] Generating BCT backup image
[  16.9947 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[  16.9957 ] 32768+0 records in
[  17.0734 ] 32768+0 records out
[  17.0734 ] 32768 bytes (33 kB, 32 KiB) copied, 0.0763329 s, 429 kB/s
[  17.0734 ]
[  17.0734 ] Concatenating BCT for chain A to bct_backup.img
[  17.0735 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[  17.0743 ] 8192+0 records in
[  17.1035 ] 8192+0 records out
[  17.1035 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.027974 s, 293 kB/s
[  17.1035 ]
[  17.1036 ] Concatenating BCT for chain B to bct_backup.img
[  17.1036 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[  17.1044 ] 8192+0 records in
[  17.1269 ] 8192+0 records out
[  17.1270 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.0211901 s, 387 kB/s
[  17.1270 ]
[  17.1270 ] Generating coldboot mb1-bct
[  17.1279 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3767-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3767-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[  17.1291 ] MB1-BCT version: 0.13
[  17.1328 ] Parsing config file :tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb
[  17.1352 ] Added Platform Config 0 data with size :- 2416
[  17.1401 ]
[  17.1402 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb
[  17.1402 ] WARNING: unknown node 'g2'
[  17.1402 ] WARNING: unknown node 'g9'
[  17.1403 ] WARNING: unknown node 'g9'
[  17.1403 ] Added Platform Config 2 data with size :- 24
[  17.1403 ]
[  17.1403 ] Parsing config file :tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb
[  17.1403 ] Added Platform Config 4 data with size :- 288
[  17.1404 ]
[  17.1404 ] Parsing config file :tegra234-mb1-bct-reset-p3767-0000_cpp.dtb
[  17.1404 ] Added Platform Config 3 data with size :- 52
[  17.1404 ]
[  17.1404 ] Parsing config file :tegra234-mb1-bct-prod-p3767-0000_cpp.dtb
[  17.1405 ] WARNING: unknown property 'major'
[  17.1405 ] WARNING: unknown property 'minor'
[  17.1405 ] Added Platform Config 5 data with size :- 512
[  17.1405 ]
[  17.1405 ] Parsing config file :tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb
[  17.1406 ] WARNING: unknown property 'major'
[  17.1406 ] WARNING: unknown property 'minor'
[  17.1406 ] Added Platform Config 7 data with size :- 380
[  17.1406 ]
[  17.1407 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[  17.1407 ] Added Platform Config 8 data with size :- 24
[  17.1407 ]
[  17.1407 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[  17.1407 ] Added Platform Config 9 data with size :- 100
[  17.1408 ]
[  17.1408 ] Parsing config file :tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[  17.1408 ] ModuleCount 0 NumProdNames 0
[  17.1408 ] Added Platform Config 6 data with size :- 16
[  17.1409 ]
[  17.1409 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[  17.1409 ]
[  17.1410 ] Updating mb1-bct with firmware information
[  17.1421 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[  17.1451 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[  17.1462 ] Generating SHA2 Hash for mb1bct
[  17.1764 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[  17.1786 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[  17.1517 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[  17.1525 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[  17.1832 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[  17.1836 ] Assuming zero filled SBK key
[  17.1866 ] Warning: pub_key.key is not found
[  17.1599 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[  17.1621 ] Generating recovery mb1-bct
[  17.1631 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3767-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3767-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[  17.1649 ] MB1-BCT version: 0.13
[  17.1683 ] Parsing config file :tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb
[  17.1719 ] Added Platform Config 0 data with size :- 2416
[  17.1738 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb
[  17.1746 ] WARNING: unknown node 'g2'
[  17.1749 ] WARNING: unknown node 'g2'
[  17.1752 ] WARNING: unknown node 'g9'
[  17.1753 ] WARNING: unknown node 'g9'
[  17.1753 ] Added Platform Config 2 data with size :- 24
[  17.1753 ]
[  17.1754 ] Parsing config file :tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb
[  17.1754 ] Added Platform Config 4 data with size :- 288
[  17.1754 ]
[  17.1755 ] Parsing config file :tegra234-mb1-bct-reset-p3767-0000_cpp.dtb
[  17.1755 ] Added Platform Config 3 data with size :- 52
[  17.1755 ]
[  17.1756 ] Parsing config file :tegra234-mb1-bct-prod-p3767-0000_cpp.dtb
[  17.1756 ] WARNING: unknown property 'major'
[  17.1756 ] WARNING: unknown property 'minor'
[  17.1757 ] Added Platform Config 5 data with size :- 512
[  17.1757 ]
[  17.1757 ] Parsing config file :tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb
[  17.1758 ] WARNING: unknown property 'major'
[  17.1758 ] WARNING: unknown property 'minor'
[  17.1758 ] Added Platform Config 7 data with size :- 380
[  17.1759 ]
[  17.1759 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[  17.1759 ] Added Platform Config 8 data with size :- 24
[  17.1760 ]
[  17.1760 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[  17.1761 ] Added Platform Config 9 data with size :- 100
[  17.1761 ]
[  17.1761 ] Parsing config file :tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[  17.1761 ] ModuleCount 0 NumProdNames 0
[  17.1761 ] Added Platform Config 6 data with size :- 16
[  17.1762 ]
[  17.1762 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[  17.1762 ]
[  17.1762 ] Updating mb1-bct with firmware information
[  17.1772 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo flash.xml.bin
[  17.1800 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[  17.1810 ] Generating SHA2 Hash for mb1bct
[  17.2112 ] Sha saved in mb1_bct_MB1_aligned.sha
[  17.2134 ] Sha saved in mb1_bct_MB1.sha
[  17.1865 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[  17.1873 ] adding BCH for mb1_bct_MB1_aligned.bct
[  17.2175 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[  17.2178 ] Assuming zero filled SBK key
[  17.2205 ] Warning: pub_key.key is not found
[  17.1937 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[  17.1959 ] Generating coldboot mem-bct
[  17.1968 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --membct tegra234-p3767-0001-sdram-l4t_cpp_1.bct tegra234-p3767-0001-sdram-l4t_cpp_2.bct tegra234-p3767-0001-sdram-l4t_cpp_3.bct tegra234-p3767-0001-sdram-l4t_cpp_4.bct
[  17.1980 ]  packing sdram params with Wb0 file tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb
[  17.4898 ] Packing sdram param for instance[0]
[  17.4902 ] Packing sdram param for instance[1]
[  17.4906 ] Packing sdram param for instance[2]
[  17.4920 ] Packing sdram param for instance[3]
[  17.4940 ] Packing sdram param for instance[4]
[  17.4961 ] Packing sdram param for instance[5]
[  17.4979 ] Packing sdram param for instance[6]
[  17.4998 ] Packing sdram param for instance[7]
[  17.5016 ] Packing sdram param for instance[8]
[  17.5023 ] Packing sdram param for instance[9]
[  17.5027 ] Packing sdram param for instance[10]
[  17.5052 ] Packing sdram param for instance[11]
[  17.5072 ] Packing sdram param for instance[12]
[  17.5089 ] Packing sdram param for instance[13]
[  17.5093 ] Packing sdram param for instance[14]
[  17.5097 ] Packing sdram param for instance[15]
[  17.7833 ] Getting sector size from pt
[  17.7843 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[  17.7856 ] BlockSize read from layout is 0x200
[  17.7865 ] tegrahost_v2 --chip 0x23 0 --blocksize 512 --magicid MEMB --addsigheader_multi tegra234-p3767-0001-sdram-l4t_cpp_1.bct tegra234-p3767-0001-sdram-l4t_cpp_2.bct tegra234-p3767-0001-sdram-l4t_cpp_3.bct tegra234-p3767-0001-sdram-l4t_cpp_4.bct
[  17.7873 ] Binary 0 length is 58752
[  17.7887 ] Binary 0 align length is 58880
[  17.7907 ] Binary 1 length is 58752
[  17.7925 ] Binary 1 align length is 58880
[  17.7933 ] Binary 2 length is 58752
[  17.7937 ] Binary 2 align length is 58880
[  17.7965 ] Binary 3 length is 58752
[  17.7979 ] Binary 3 align length is 58880
[  17.7988 ] Buffer length is 235520
[  17.7988 ] adding BCH for tegra234-p3767-0001-sdram-l4t_cpp_1.bct
[  17.7989 ] new length is 243712
[  17.7989 ]
[  17.8008 ] tegrahost_v2 --chip 0x23 0 --align mem_coldboot_aligned.bct
[  17.8027 ] tegrahost_v2 --chip 0x23 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_coldboot_aligned.bct zerosbk
[  17.8036 ] Header already present for mem_coldboot_aligned.bct
[  17.8351 ] tegrasign_v3.py --key None --list mem_coldboot_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[  17.8354 ] Assuming zero filled SBK key
[  17.8389 ] Warning: pub_key.key is not found
[  17.8121 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_coldboot_aligned_sigheader.bct.encrypt mem_coldboot_aligned_sigheader.bct.hash zerosbk
[  17.8155 ] Generating recovery mem-bct
[  17.8166 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --membct tegra234-p3767-0001-sdram-l4t_cpp_1.bct tegra234-p3767-0001-sdram-l4t_cpp_2.bct tegra234-p3767-0001-sdram-l4t_cpp_3.bct tegra234-p3767-0001-sdram-l4t_cpp_4.bct
[  17.8177 ]  packing sdram params with Wb0 file tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb
[  18.1102 ] Packing sdram param for instance[0]
[  18.1106 ] Packing sdram param for instance[1]
[  18.1110 ] Packing sdram param for instance[2]
[  18.1114 ] Packing sdram param for instance[3]
[  18.1119 ] Packing sdram param for instance[4]
[  18.1141 ] Packing sdram param for instance[5]
[  18.1161 ] Packing sdram param for instance[6]
[  18.1180 ] Packing sdram param for instance[7]
[  18.1200 ] Packing sdram param for instance[8]
[  18.1218 ] Packing sdram param for instance[9]
[  18.1238 ] Packing sdram param for instance[10]
[  18.1255 ] Packing sdram param for instance[11]
[  18.1268 ] Packing sdram param for instance[12]
[  18.1289 ] Packing sdram param for instance[13]
[  18.1295 ] Packing sdram param for instance[14]
[  18.1312 ] Packing sdram param for instance[15]
[  18.4053 ] Got ramcode 2 from the command line
[  18.4054 ] Using ramcode 0
[  18.4055 ] Disabled BPMP dtb trim, using default dtb
[  18.4055 ]
[  18.4071 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_aligned.bct
[  18.4090 ] tegrahost_v2 --chip 0x23 0 --magicid MEM0 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_aligned.bct zerosbk
[  18.4098 ] adding BCH for mem_rcm_aligned.bct
[  18.4439 ] tegrasign_v3.py --key None --list mem_rcm_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[  18.4442 ] Assuming zero filled SBK key
[  18.4472 ] Warning: pub_key.key is not found
[  18.4203 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_aligned_sigheader.bct.encrypt mem_rcm_aligned_sigheader.bct.hash zerosbk
[  18.4228 ] Copying signatures
[  18.4239 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[  18.5546 ] Boot Rom communication
[  18.6752 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[  18.6765 ] BR_CID: 0x80012344705DF1047C00000006FD8200
[  18.9841 ] Sending bct_br
[  19.0734 ] Sending mb1
[  19.0746 ] Sending psc_bl1
[  19.0925 ] Sending bct_mb1
[  19.1033 ] Boot Rom communication completed
[  19.1034 ] Generating blob for T23x
[  19.1112 ] tegrahost_v2 --chip 0x23 0 --align blob_uefi_jetson_with_dtb_aligned.bin
[  19.1139 ] tegrahost_v2 --chip 0x23 0 --magicid CPBL --ratchet_blob ratchet_blob.bin --appendsigheader blob_uefi_jetson_with_dtb_aligned.bin zerosbk
[  19.1150 ] adding BCH for blob_uefi_jetson_with_dtb_aligned.bin
[  19.3942 ] tegrasign_v3.py --key None --list blob_uefi_jetson_with_dtb_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[  19.3945 ] Assuming zero filled SBK key
[  19.4154 ] Warning: pub_key.key is not found
[  19.3886 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_uefi_jetson_with_dtb_aligned_sigheader.bin.encrypt blob_uefi_jetson_with_dtb_aligned_sigheader.bin.hash zerosbk
[  19.4095 ] Get magic id
[  19.4111 ] tegraparser_v2 --get_magic psc_fw
[  19.4127 ] PFWP
[  19.4127 ]
[  19.4127 ] partition type psc_fw, magic id = PFWP
[  19.4150 ] tegrahost_v2 --chip 0x23 0 --align blob_pscfw_t234_prod_aligned.bin
[  19.4175 ] tegrahost_v2 --chip 0x23 0 --magicid PFWP --ratchet_blob ratchet_blob.bin --appendsigheader blob_pscfw_t234_prod_aligned.bin zerosbk
[  19.4185 ] Header already present for blob_pscfw_t234_prod_aligned.bin
[  19.4655 ] tegrasign_v3.py --key None --list blob_pscfw_t234_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[  19.4659 ] Assuming zero filled SBK key
[  19.4699 ] Warning: pub_key.key is not found
[  19.4432 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_pscfw_t234_prod_aligned_sigheader.bin.encrypt blob_pscfw_t234_prod_aligned_sigheader.bin.hash zerosbk
[  19.4476 ] Get magic id
[  19.4487 ] tegraparser_v2 --get_magic mts_mce
[  19.4499 ] MTSM
[  19.4499 ]
[  19.4499 ] partition type mts_mce, magic id = MTSM
[  19.4515 ] tegrahost_v2 --chip 0x23 0 --align blob_mce_flash_o10_cr_prod_aligned.bin
[  19.4535 ] tegrahost_v2 --chip 0x23 0 --magicid MTSM --ratchet_blob ratchet_blob.bin --appendsigheader blob_mce_flash_o10_cr_prod_aligned.bin zerosbk
[  19.4543 ] Header already present for blob_mce_flash_o10_cr_prod_aligned.bin
[  19.4913 ] tegrasign_v3.py --key None --list blob_mce_flash_o10_cr_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[  19.4917 ] Assuming zero filled SBK key
[  19.4950 ] Warning: pub_key.key is not found
[  19.4682 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_mce_flash_o10_cr_prod_aligned_sigheader.bin.encrypt blob_mce_flash_o10_cr_prod_aligned_sigheader.bin.hash zerosbk
[  19.4716 ] Get magic id
[  19.4725 ] tegraparser_v2 --get_magic mb2_applet
[  19.4734 ] MB2A
[  19.4737 ] partition type mb2_applet, magic id = MB2A
[  19.4909 ] tegrahost_v2 --chip 0x23 0 --align blob_applet_t234_aligned.bin
[  19.4930 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --ratchet_blob ratchet_blob.bin --appendsigheader blob_applet_t234_aligned.bin zerosbk
[  19.4937 ] adding BCH for blob_applet_t234_aligned.bin
[  19.5476 ] tegrasign_v3.py --key None --list blob_applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[  19.5479 ] Assuming zero filled SBK key
[  19.5516 ] Warning: pub_key.key is not found
[  19.5248 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_applet_t234_aligned_sigheader.bin.encrypt blob_applet_t234_aligned_sigheader.bin.hash zerosbk
[  19.5298 ] Generating recovery mb2-bct
[  19.5299 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_bct.cfg --recov --mb2bctcfg tegra234-mb2-bct-misc-p3767-0000_cpp.dtb --scr tegra234-mb2-bct-scr-p3767-0000_cpp.dtb
[  19.5310 ] ERROR: value 0x31 is out of range
[  19.5345 ] ERROR: value 0x31 is out of range
[  19.5365 ] ERROR: value 0x31 is out of range
[  19.5376 ] ERROR: value 0x31 is out of range
[  19.5379 ] WARNING: unknown property 'tfc_version'
[  19.5383 ] WARNING: unknown property 'addr_header_version'
[  19.5609 ] Updating mb2-bct with storage information
[  19.5619 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_bct_MB2.bct --updatestorageinfo flash.xml.bin
[  19.5639 ] Concatenating mb2-bct to mb2 binary
[  19.5639 ] mb2_bin_file = mb2_t234.bin
[  19.5640 ] mb2_bct_file = mb2_bct_MB2.bct
[  19.5652 ] Get magic id
[  19.5663 ] tegraparser_v2 --get_magic mb2_bootloader
[  19.5674 ] MB2B
[  19.5674 ]
[  19.5675 ] partition type mb2_bootloader, magic id = MB2B
[  19.5694 ] tegrahost_v2 --chip 0x23 0 --align blob_mb2_t234_with_mb2_bct_MB2_aligned.bin
[  19.5713 ] tegrahost_v2 --chip 0x23 0 --magicid MB2B --ratchet_blob ratchet_blob.bin --appendsigheader blob_mb2_t234_with_mb2_bct_MB2_aligned.bin zerosbk
[  19.5724 ] adding BCH for blob_mb2_t234_with_mb2_bct_MB2_aligned.bin
[  19.6359 ] tegrasign_v3.py --key None --list blob_mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[  19.6364 ] Assuming zero filled SBK key
[  19.6407 ] Warning: pub_key.key is not found
[  19.6141 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin.encrypt blob_mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin.hash zerosbk
[  19.6187 ] Get magic id
[  19.6199 ] tegraparser_v2 --get_magic xusb_fw
[  19.6210 ] XUSB
[  19.6211 ]
[  19.6211 ] partition type xusb_fw, magic id = XUSB
[  19.6227 ] tegrahost_v2 --chip 0x23 0 --align blob_xusb_t234_prod_aligned.bin
[  19.6246 ] tegrahost_v2 --chip 0x23 0 --magicid XUSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_xusb_t234_prod_aligned.bin zerosbk
[  19.6256 ] adding BCH for blob_xusb_t234_prod_aligned.bin
[  19.6677 ] tegrasign_v3.py --key None --list blob_xusb_t234_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[  19.6681 ] Assuming zero filled SBK key
[  19.6714 ] Warning: pub_key.key is not found
[  19.6447 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_xusb_t234_prod_aligned_sigheader.bin.encrypt blob_xusb_t234_prod_aligned_sigheader.bin.hash zerosbk
[  19.6480 ] Kernel DTB used: kernel_tegra234-p3767-0003-p3768-0000-a0.dtb
[  19.6480 ] Concatenating kernel-dtb to dce-fw binary
[  19.6481 ] dce_bin = display-t234-dce.bin
[  19.6481 ] kernel_dtb = kernel_tegra234-p3767-0003-p3768-0000-a0.dtb
[  19.6481 ] dce_with_dtb = display-t234-dce_with_kernel_tegra234-p3767-0003-p3768-0000-a0.bin
[  19.6690 ] Get magic id
[  19.6701 ] tegraparser_v2 --get_magic dce_fw
[  19.6713 ] DCEF
[  19.6713 ]
[  19.6713 ] partition type dce_fw, magic id = DCEF
[  19.6875 ] tegrahost_v2 --chip 0x23 0 --align blob_display-t234-dce_with_kernel_tegra234-p3767-0003-p3768-0000-a0_aligned.bin
[  19.6895 ] tegrahost_v2 --chip 0x23 0 --magicid DCEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_display-t234-dce_with_kernel_tegra234-p3767-0003-p3768-0000-a0_aligned.bin zerosbk
[  19.6906 ] adding BCH for blob_display-t234-dce_with_kernel_tegra234-p3767-0003-p3768-0000-a0_aligned.bin
[  20.4618 ] tegrasign_v3.py --key None --list blob_display-t234-dce_with_kernel_tegra234-p3767-0003-p3768-0000-a0_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[  20.4622 ] Assuming zero filled SBK key
[  20.5227 ] Warning: pub_key.key is not found
[  20.4959 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_display-t234-dce_with_kernel_tegra234-p3767-0003-p3768-0000-a0_aligned_sigheader.bin.encrypt blob_display-t234-dce_with_kernel_tegra234-p3767-0003-p3768-0000-a0_aligned_sigheader.bin.hash zerosbk
[  20.6531 ] Get magic id
[  20.6544 ] tegraparser_v2 --get_magic nvdec
[  20.6552 ] NDEC
[  20.6554 ] partition type nvdec, magic id = NDEC
[  20.6572 ] tegrahost_v2 --chip 0x23 0 --align blob_nvdec_t234_prod_aligned.fw
[  20.6592 ] tegrahost_v2 --chip 0x23 0 --magicid NDEC --ratchet_blob ratchet_blob.bin --appendsigheader blob_nvdec_t234_prod_aligned.fw zerosbk
[  20.6601 ] Header already present for blob_nvdec_t234_prod_aligned.fw
[  20.7020 ] tegrasign_v3.py --key None --list blob_nvdec_t234_prod_aligned_sigheader.fw_list.xml --pubkeyhash pub_key.key --sha sha512
[  20.7023 ] Assuming zero filled SBK key
[  20.7512 ] Warning: pub_key.key is not found
[  20.7246 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_nvdec_t234_prod_aligned_sigheader.fw.encrypt blob_nvdec_t234_prod_aligned_sigheader.fw.hash zerosbk
[  20.7294 ] Get magic id
[  20.7305 ] tegraparser_v2 --get_magic bpmp_fw
[  20.7320 ] BPMF
[  20.7320 ]
[  20.7320 ] partition type bpmp_fw, magic id = BPMF
[  20.7349 ] tegrahost_v2 --chip 0x23 0 --align blob_bpmp_t234-TE950M-A1_prod_aligned.bin
[  20.7369 ] tegrahost_v2 --chip 0x23 0 --magicid BPMF --ratchet_blob ratchet_blob.bin --appendsigheader blob_bpmp_t234-TE950M-A1_prod_aligned.bin zerosbk
[  20.7376 ] Header already present for blob_bpmp_t234-TE950M-A1_prod_aligned.bin
[  20.8083 ] tegrasign_v3.py --key None --list blob_bpmp_t234-TE950M-A1_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[  20.8087 ] Assuming zero filled SBK key
[  20.8150 ] Warning: pub_key.key is not found
[  20.7883 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_bpmp_t234-TE950M-A1_prod_aligned_sigheader.bin.encrypt blob_bpmp_t234-TE950M-A1_prod_aligned_sigheader.bin.hash zerosbk
[  20.7972 ] Using bpmp-dtb concatenated with odmdata in blob
[  20.7975 ] Get magic id
[  20.7985 ] tegraparser_v2 --get_magic bpmp_fw_dtb
[  20.7993 ] BPMD
[  20.7997 ] partition type bpmp_fw_dtb, magic id = BPMD
[  20.8013 ] tegrahost_v2 --chip 0x23 0 --align blob_tegra234-bpmp-3767-0003-3509-a02_with_odm_aligned.dtb
[  20.8034 ] tegrahost_v2 --chip 0x23 0 --magicid BPMD --ratchet_blob ratchet_blob.bin --appendsigheader blob_tegra234-bpmp-3767-0003-3509-a02_with_odm_aligned.dtb zerosbk
[  20.8042 ] adding BCH for blob_tegra234-bpmp-3767-0003-3509-a02_with_odm_aligned.dtb
[  20.8492 ] tegrasign_v3.py --key None --list blob_tegra234-bpmp-3767-0003-3509-a02_with_odm_aligned_sigheader.dtb_list.xml --pubkeyhash pub_key.key --sha sha512
[  20.8497 ] Assuming zero filled SBK key
[  20.8531 ] Warning: pub_key.key is not found
[  20.8265 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_tegra234-bpmp-3767-0003-3509-a02_with_odm_aligned_sigheader.dtb.encrypt blob_tegra234-bpmp-3767-0003-3509-a02_with_odm_aligned_sigheader.dtb.hash zerosbk
[  20.8300 ] Get magic id
[  20.8311 ] tegraparser_v2 --get_magic sce_fw
[  20.8320 ] SCEF
[  20.8324 ] partition type sce_fw, magic id = SCEF
[  20.8494 ] tegrahost_v2 --chip 0x23 0 --align blob_camera-rtcpu-sce_aligned.img
[  20.8514 ] tegrahost_v2 --chip 0x23 0 --magicid SCEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_camera-rtcpu-sce_aligned.img zerosbk
[  20.8522 ] adding BCH for blob_camera-rtcpu-sce_aligned.img
[  20.8946 ] tegrasign_v3.py --key None --list blob_camera-rtcpu-sce_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[  20.8949 ] Assuming zero filled SBK key
[  20.8983 ] Warning: pub_key.key is not found
[  20.8715 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_camera-rtcpu-sce_aligned_sigheader.img.encrypt blob_camera-rtcpu-sce_aligned_sigheader.img.hash zerosbk
[  20.8749 ] Get magic id
[  20.8759 ] tegraparser_v2 --get_magic rce_fw
[  20.8771 ] RCEF
[  20.8771 ]
[  20.8772 ] partition type rce_fw, magic id = RCEF
[  20.8793 ] tegrahost_v2 --chip 0x23 0 --align blob_camera-rtcpu-t234-rce_aligned.img
[  20.8813 ] tegrahost_v2 --chip 0x23 0 --magicid RCEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_camera-rtcpu-t234-rce_aligned.img zerosbk
[  20.8824 ] adding BCH for blob_camera-rtcpu-t234-rce_aligned.img
[  20.9544 ] tegrasign_v3.py --key None --list blob_camera-rtcpu-t234-rce_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[  20.9548 ] Assuming zero filled SBK key
[  20.9595 ] Warning: pub_key.key is not found
[  20.9329 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_camera-rtcpu-t234-rce_aligned_sigheader.img.encrypt blob_camera-rtcpu-t234-rce_aligned_sigheader.img.hash zerosbk
[  20.9381 ] Get magic id
[  20.9393 ] tegraparser_v2 --get_magic ape_fw
[  20.9401 ] APEF
[  20.9405 ] partition type ape_fw, magic id = APEF
[  20.9425 ] tegrahost_v2 --chip 0x23 0 --align blob_adsp-fw_aligned.bin
[  20.9445 ] tegrahost_v2 --chip 0x23 0 --magicid APEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_adsp-fw_aligned.bin zerosbk
[  20.9453 ] adding BCH for blob_adsp-fw_aligned.bin
[  21.0058 ] tegrasign_v3.py --key None --list blob_adsp-fw_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[  21.0062 ] Assuming zero filled SBK key
[  21.0105 ] Warning: pub_key.key is not found
[  20.9838 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_adsp-fw_aligned_sigheader.bin.encrypt blob_adsp-fw_aligned_sigheader.bin.hash zerosbk
[  20.9882 ] Get magic id
[  20.9893 ] tegraparser_v2 --get_magic spe_fw
[  20.9902 ] SPEF
[  20.9906 ] partition type spe_fw, magic id = SPEF
[  20.9923 ] tegrahost_v2 --chip 0x23 0 --align blob_spe_t234_aligned.bin
[  20.9943 ] tegrahost_v2 --chip 0x23 0 --magicid SPEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_spe_t234_aligned.bin zerosbk
[  20.9952 ] adding BCH for blob_spe_t234_aligned.bin
[  21.0456 ] tegrasign_v3.py --key None --list blob_spe_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[  21.0460 ] Assuming zero filled SBK key
[  21.0498 ] Warning: pub_key.key is not found
[  21.0231 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_spe_t234_aligned_sigheader.bin.encrypt blob_spe_t234_aligned_sigheader.bin.hash zerosbk
[  21.0268 ] Get magic id
[  21.0279 ] tegraparser_v2 --get_magic tos
[  21.0291 ] TOSB
[  21.0291 ]
[  21.0291 ] partition type tos, magic id = TOSB
[  21.0325 ] tegrahost_v2 --chip 0x23 0 --align blob_tos-optee_t234_aligned.img
[  21.0344 ] tegrahost_v2 --chip 0x23 0 --magicid TOSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_tos-optee_t234_aligned.img zerosbk
[  21.0355 ] adding BCH for blob_tos-optee_t234_aligned.img
[  21.1656 ] tegrasign_v3.py --key None --list blob_tos-optee_t234_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[  21.1660 ] Assuming zero filled SBK key
[  21.1734 ] Warning: pub_key.key is not found
[  21.1467 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_tos-optee_t234_aligned_sigheader.img.encrypt blob_tos-optee_t234_aligned_sigheader.img.hash zerosbk
[  21.1562 ] Get magic id
[  21.1574 ] tegraparser_v2 --get_magic eks
[  21.1587 ] EKSB
[  21.1587 ]
[  21.1587 ] partition type eks, magic id = EKSB
[  21.1601 ] tegrahost_v2 --chip 0x23 0 --align blob_eks_t234_aligned.img
[  21.1622 ] tegrahost_v2 --chip 0x23 0 --magicid EKSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_eks_t234_aligned.img zerosbk
[  21.1631 ] adding BCH for blob_eks_t234_aligned.img
[  21.1926 ] tegrasign_v3.py --key None --list blob_eks_t234_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[  21.1929 ] Assuming zero filled SBK key
[  21.1957 ] Warning: pub_key.key is not found
[  21.1689 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_eks_t234_aligned_sigheader.img.encrypt blob_eks_t234_aligned_sigheader.img.hash zerosbk
[  21.1724 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[  21.1732 ] The number of images in blob is 16
[  21.1743 ] blobsize is 18274240
[  21.1745 ] Added binary blob_uefi_jetson_with_dtb_sigheader.bin.encrypt of size 3186752
[  21.2067 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 375168
[  21.2107 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 190592
[  21.2133 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 277312
[  21.2157 ] Not supported type: mb2_applet
[  21.2166 ] Added binary blob_mb2_t234_with_mb2_bct_MB2_sigheader.bin.encrypt of size 437264
[  21.2175 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164864
[  21.2204 ] Added binary blob_display-t234-dce_with_kernel_tegra234-p3767-0003-p3768-0000-a0_sigheader.bin.encrypt of size 9444352
[  21.2402 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[  21.2447 ] Added binary blob_bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt of size 1027008
[  21.2506 ] Added binary blob_tegra234-bpmp-3767-0003-3509-a02_with_odm_sigheader.dtb.encrypt of size 199936
[  21.2536 ] Added binary blob_camera-rtcpu-sce_sigheader.img.encrypt of size 166304
[  21.2582 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 540000
[  21.2613 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 401008
[  21.2650 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[  21.2670 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1288096
[  21.2685 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[  21.2830 ] Sending membct and RCM blob
[  21.2841 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[  21.2852 ] BL: version 1.4.0.4-t234-54845784-e89ea9bc last_boot_error: 0
[  21.5611 ] Sending bct_mem
[  21.6530 ] Sending blob
[  23.4731 ] completed
[  23.4732 ] Retrieving storage infomation
[  23.4747 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails storage storage_info.bin
[  23.4765 ] Applet/MB2 is not running on device.
[ 2041.5775 ] Error: failed to get storage info
[ 2042.5798 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 3057.3869 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[ 4074.1956 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 5089.0015 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[ 6105.8112 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 7120.6186 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[ 8137.4281 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 9152.2351 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[ 10169.0433 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
devkit orin 8GB
[18684.750620] loop17: detected capacity change from 0 to 131072
[20854.869955] usb 7-2: USB disconnect, device number 14
[20867.326086] usb 7-2: new high-speed USB device number 15 using ehci-pci
[20867.455583] usb 7-2: New USB device found, idVendor=0955, idProduct=7523, bcdDevice= 4.01
[20867.455596] usb 7-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[20867.455601] usb 7-2: Product: APX
[20867.455606] usb 7-2: Manufacturer: NVIDIA Corp.
For the devkit, have you tried using SDK Manager on standalone Ubuntu host to flash?
I would like to use command console, which need less resources.
Does this auto flash feature is NOT avaliable or has bug right now?
Using the SDK manager is helping to clarify if there’s the issue on the board itself.
(It is a method with less manual operation)
Are you trying to flash into SD or NVMe SSD?
It seems the smart flash tool/command for flashing the firmware.
But it didn’t work the way it should.
I didn’t plug SD card. The system only has NVMe SSD.
EDIT: @KevinFFF Forgot to tell you, I don’t have a specialized PC(8GB/1440x900 resolution ubuntu) for flashing the firmware. So I would like to use command tool.
And it works, just this nvautoflash.sh doesn’t work the way it implies.
Could you run the following command to flash the devkit?
$ sudo ADDITIONAL_DTB_OVERLAY_OPT="BootOrderNvme.dtbo" ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_t234_nvme.xml -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" --showlogs --network usb0 jetson-orin-nano-devkit internal
I did flash with a much more specific commands as follows.
Right now, I hope the nvautoflash.shwill do the work for me as you know, it’s easy and kind of smart.
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 \
  -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" \
It is a high-level script which includes some configurations and it would call initrd flash script to flash the board.
We would suggest just using l4t_initrd_flash.sh or you can compare the flash log to find where it gets failed.
From the log you shared, it seems something missing on your host.
Please try running nvautoflash.sh in the BSP package downloaded from SDK manager (nvidia/nvidia_sdk/JetPack_5.1.4_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra)
Solved " extlinux.conf is not found issue. And it’s OK with specific commands.
The quesiton is it can’t be nvautoflash.sh, it will fail with error “Error: failed to get storage info”
I’ve tried running this script on the devkit and it is working.
Do you run that script from the BSP package downloaded from SDK Manager?
Please share the result of cat /etc/nv_boot_control.conf on your board.
$ cat /etc/nv_boot_control.conf
TNSPEC 3767-300-0005-M.1-1-1-jetson-orin-nano-devkit-
COMPATIBLE_SPEC 3767--0005--1--jetson-orin-nano-devkit-
TEGRA_LEGACY_UPDATE false
TEGRA_BOOT_STORAGE nvme0n1
TEGRA_EMMC_ONLY false
TEGRA_CHIPID 0x23
TEGRA_OTA_BOOT_DEVICE /dev/mtdblock0
TEGRA_OTA_GPT_DEVICE /dev/mtdblock0
It should be as following sequence:
$ sudo tar xvf jetson_linux_r35.6.0_aarch64.tbz2
$ sudo tar xvpf tegra_linux_sample-root-filesystem_r35.6.0_aarch64.tbz2 -C Linux_for_Tegra/rootfs/
$ sudo ./nvautoflash.sh  // failed first time, no  “boot/extlinux/extlinux.conf”
$ sudo ./apply_binaries.sh  // applied
$ sudo ./nvautoflash.sh  // failed second time , " Error: failed to get storage info"
Could you just try to run this script in the BSP package downloaded from SDK Manager?
I wouldn’t use SDK Manager. As I said I don’t have a specific computer to run SDK manager. And I’m quite sure it would not take that much resource to install only a system.
I perfer to use following command line sequence:
Do you mean the above sequence has trouble to use nvautoflash.sh ?
How did you run nvautoflash.sh?
Are you not using the host to run this script?
Is your daniel-ThinkPad-SL410 not able to install SDK Manager?
No, I just want to clarify if it is caused from something missing in your package.
I’ve verified it working on my host and flash on the Orin Nano devkit successful.
Please refer to the following log and find the difference with yours.
nvautoflash-r35.6.log (108.0 KB)
Yes, the same way as you do, from my point of view.
  • in Linux_for_Tegra
  • run nvautoflash.sh
I have posted log above in the previous post.
Yes, run the script on daniel-ThinkPad-SL410, which is x86 old laptop not ok with SDK manager.
OK, I’ll try it if re-install needed. Right now, it’s under development, I don’t have time to test. As you know it’s NOT sdcard image, I don’t have spare NVM module.
We strongly recommend you flashing the board through l4t_initrd_flash.sh with all required options specified if you can not use SDK manager.
You can also check or debug this script and you would find it just add some logic to detect the kind of the board.
