Hi, I may have done something really wrong here and messed up one of my Orin NX. I have managed to flash one Orin NX 16GB on a custom board successfully by following the steps in the developer guide and on this forum. However, for my other Orin NX, I tried flashing it but it failed with Error flashing non-qspi storage. Following How to flash Jetson Orin NX 16GB moudule - #12 by alexandru7ac9a, I deleted all partitions in my SSD and formatted it as a single ext4. After this, my ssd is no longer being detected and my Orin NX is unable to boot. In force recovery mode, it can still be detected using lsusb, with the correct code 7323. Moving the SSD on this Orin NX to my working Orin NX, I can boot but immediately go into a shell screen. How can I resolve this? Thanks!
Is it okay to reflash the board again? If it cannot be flashed, please share me the full log and command you are using.
It is not possible to reflash. Command used is
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p “-c bootloader/t186ref/cfg/flash_t234_qspi.xml” --showlogs --network usb0 p3509-a02+p3767-0000 internal.
These are the logs before i formatted the SSD.
* Step 1: Build the flashing environment *
Create flash environment 0
~/Downloads/Linux_for_Tegra/bootloader ~/Downloads/Linux_for_Tegra
Finish creating flash environment 0.
* Step 2: Boot the device with flash initrd image *
~/Downloads/Linux_for_Tegra/temp_initrdflash/bootloader0 ~/Downloads/Linux_for_Tegra
./tegraflash.py --bl uefi_jetson_with_dtb_sigheader.bin.encrypt --bct br_bct_BR.bct --securedev --bldtb tegra234-p3767-0000-p3509-a02.dtb --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --cmd "rcmboot" --cfg secureflash.xml --chip 0x23 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mb1_bin mb1_t234_prod_aligned_sigheader.bin.encrypt --psc_bl1_bin psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt --bins "psc_fw pscfw_t234_prod_sigheader.bin.encrypt; mts_mce mce_flash_o10_cr_prod_sigheader.bin.encrypt; mb2_applet applet_t234_sigheader.bin.encrypt; mb2_bootloader mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt; xusb_fw xusb_t234_prod_sigheader.bin.encrypt; dce_fw display-t234-dce_sigheader.bin.encrypt; nvdec nvdec_t234_prod_sigheader.fw.encrypt; bpmp_fw bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt; bpmp_fw_dtb tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt; sce_fw camera-rtcpu-sce_sigheader.img.encrypt; rce_fw camera-rtcpu-t234-rce_sigheader.img.encrypt; ape_fw adsp-fw_sigheader.bin.encrypt; spe_fw spe_t234_sigheader.bin.encrypt; tos tos-optee_t234_sigheader.img.encrypt; eks eks_t234_sigheader.img.encrypt; kernel boot0.img; kernel_dtb tegra234-p3767-0000-p3509-a02.dtb" --secondary_gpt_backup --bct_backup --boot_chain A --instance 3-4
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
Entering RCM boot
[ 0.0193 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from --mb1_bin
[ 0.0193 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from --psc_bl1_bin
[ 0.0193 ] rcm boot with presigned binaries
[ 0.0200 ] tegrarcm_v2 --instance 3-4 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.0205 ] BR_CID: 0x80012344705DD5D16C0000000A0102C0
[ 0.0259 ] Sending bct_br
[ 0.0301 ] Sending mb1
[ 0.0306 ] Sending psc_bl1
[ 0.0418 ] Sending bct_mb1
[ 0.0479 ] Generating blob for T23x
[ 0.0502 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[ 0.0513 ] The number of images in blob is 18
[ 0.0516 ] blobsize is 73435389
[ 0.0517 ] Added binary blob_uefi_jetson_with_dtb_sigheader.bin.encrypt of size 3182656
[ 0.0723 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 375168
[ 0.0726 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 190592
[ 0.0728 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 277312
[ 0.0730 ] Not supported type: mb2_applet
[ 0.0731 ] Added binary blob_mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt of size 437984
[ 0.0734 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164352
[ 0.0736 ] Added binary blob_display-t234-dce_sigheader.bin.encrypt of size 9097216
[ 0.0764 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[ 0.0772 ] Added binary blob_bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt of size 1048000
[ 0.0776 ] Added binary blob_tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt of size 138880
[ 0.0779 ] Added binary blob_camera-rtcpu-sce_sigheader.img.encrypt of size 166304
[ 0.0781 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 537952
[ 0.0782 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 400960
[ 0.0784 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[ 0.0786 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1064752
[ 0.0787 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[ 0.0789 ] Added binary blob_boot0.img of size 55433216
[ 0.0996 ] Added binary blob_tegra234-p3767-0000-p3509-a02.dtb of size 344461
[ 0.1336 ] tegrarcm_v2 --instance 3-4 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[ 0.1342 ] BL: version 0.32.0.0-t234-54845784-57325615 last_boot_error: 0
[ 0.2764 ] Sending bct_mem
[ 0.2940 ] Sending blob
[ 3.2920 ] RCM-boot started
* Step 3: Start the flashing process *
Waiting for target to boot-up...
Waiting for device to expose ssh ......RTNETLINK answers: File exists
Run command: if [ -f /qspi/l4t_flash_from_kernel.sh ]; then USER=root /qspi/l4t_flash_from_kernel.sh --no-reboot --qspi-only ; fi on root@fe80::1%enp0s20f0u4
blockdev: cannot open /dev/sdb: No medium found
[ 0]: l4t_flash_from_kernel: Starting to create gpt for emmc
Active index file is /home/felix/Downloads/Linux_for_Tegra/tools/kernel_flash/images/internal/flash.idx
Number of lines is 75
max_index=74
SSH ready
blockdev: cannot open /dev/mmcblk0boot0: No such file or directory
Flash index file is /qspi/internal/flash.idx
max_index=74
[ 0]: l4t_flash_from_kernel: Starting to flash to qspi
QSPI storage size: 67108864 bytes.
writing item=59, 6:0:primary_gpt, 512, 19968, gpt_primary_6_0.bin, 16896, fixed-<reserved>-0, ae31cc9a851aa1188743737786fc00d0f73f90e7
Error: Error opening /dev/sda: No medium found
Erased 67108864 bytes from address 0x00000000 in flash
max_index=74
Writing br_bct_BR.bct (parittion: BCT) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/br_bct_BR.bct
Writing /qspi/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:0
Copied 8192 bytes from /qspi/internal/br_bct_BR.bct to address 0x00000000 in flash
[ 176]: l4t_flash_from_kernel: QSPI erase block size is 65536
[ 176]: l4t_flash_from_kernel: Writing 16 copies of /qspi/internal/br_bct_BR.bct
Writing /qspi/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:65536
Copied 8192 bytes from /qspi/internal/br_bct_BR.bct to address 0x00010000 in flash
Writing /qspi/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:131072
Copied 8192 bytes from /qspi/internal/br_bct_BR.bct to address 0x00020000 in flash
Writing /qspi/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:196608
Copied 8192 bytes from /qspi/internal/br_bct_BR.bct to address 0x00030000 in flash
Writing /qspi/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:262144
Copied 8192 bytes from /qspi/internal/br_bct_BR.bct to address 0x00040000 in flash
Writing /qspi/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:327680
Copied 8192 bytes from /qspi/internal/br_bct_BR.bct to address 0x00050000 in flash
Writing /qspi/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:393216
Copied 8192 bytes from /qspi/internal/br_bct_BR.bct to address 0x00060000 in flash
Writing /qspi/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:458752
Copied 8192 bytes from /qspi/internal/br_bct_BR.bct to address 0x00070000 in flash
Writing /qspi/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:524288
Copied 8192 bytes from /qspi/internal/br_bct_BR.bct to address 0x00080000 in flash
Writing /qspi/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:589824
Copied 8192 bytes from /qspi/internal/br_bct_BR.bct to address 0x00090000 in flash
Writing /qspi/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:655360
Copied 8192 bytes from /qspi/internal/br_bct_BR.bct to address 0x000a0000 in flash
Writing /qspi/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:720896
Copied 8192 bytes from /qspi/internal/br_bct_BR.bct to address 0x000b0000 in flash
Writing /qspi/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:786432
Copied 8192 bytes from /qspi/internal/br_bct_BR.bct to address 0x000c0000 in flash
Writing /qspi/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:851968
Copied 8192 bytes from /qspi/internal/br_bct_BR.bct to address 0x000d0000 in flash
Writing /qspi/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:917504
Copied 8192 bytes from /qspi/internal/br_bct_BR.bct to address 0x000e0000 in flash
Writing /qspi/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:983040
Copied 8192 bytes from /qspi/internal/br_bct_BR.bct to address 0x000f0000 in flash
Writing mb1_t234_prod_aligned_sigheader.bin.encrypt (parittion: A_mb1) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/mb1_t234_prod_aligned_sigheader.bin.encrypt
Writing /qspi/internal/mb1_t234_prod_aligned_sigheader.bin.encrypt (268240 bytes) into /dev/mtd0:1048576
Copied 268240 bytes from /qspi/internal/mb1_t234_prod_aligned_sigheader.bin.encrypt to address 0x00100000 in flash
Writing psc_bl1_t234_prod_aligned_sigheader.bin.encrypt (parittion: A_psc_bl1) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/psc_bl1_t234_prod_aligned_sigheader.bin.encrypt
Writing /qspi/internal/psc_bl1_t234_prod_aligned_sigheader.bin.encrypt (119616 bytes) into /dev/mtd0:1572864
Copied 119616 bytes from /qspi/internal/psc_bl1_t234_prod_aligned_sigheader.bin.encrypt to address 0x00180000 in flash
Writing mb1_cold_boot_bct_MB1_sigheader.bct.encrypt (parittion: A_MB1_BCT) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
Writing /qspi/internal/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt (17056 bytes) into /dev/mtd0:1835008
Copied 17056 bytes from /qspi/internal/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt to address 0x001c0000 in flash
Writing mem_coldboot_sigheader.bct.encrypt (parittion: A_MEM_BCT) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/mem_coldboot_sigheader.bct.encrypt
Writing /qspi/internal/mem_coldboot_sigheader.bct.encrypt (243712 bytes) into /dev/mtd0:1966080
Copied 243712 bytes from /qspi/internal/mem_coldboot_sigheader.bct.encrypt to address 0x001e0000 in flash
[ 177]: l4t_flash_from_kernel: Warning: skip writing A_tsec-fw partition as no image is specified
Writing nvdec_t234_prod_sigheader.fw.encrypt (parittion: A_nvdec) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/nvdec_t234_prod_sigheader.fw.encrypt
Writing /qspi/internal/nvdec_t234_prod_sigheader.fw.encrypt (294912 bytes) into /dev/mtd0:3276800
Copied 294912 bytes from /qspi/internal/nvdec_t234_prod_sigheader.fw.encrypt to address 0x00320000 in flash
Writing mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt (parittion: A_mb2) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt
Writing /qspi/internal/mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt (437984 bytes) into /dev/mtd0:4325376
Copied 437984 bytes from /qspi/internal/mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt to address 0x00420000 in flash
Writing xusb_t234_prod_sigheader.bin.encrypt (parittion: A_xusb-fw) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/xusb_t234_prod_sigheader.bin.encrypt
Writing /qspi/internal/xusb_t234_prod_sigheader.bin.encrypt (164352 bytes) into /dev/mtd0:4849664
Copied 164352 bytes from /qspi/internal/xusb_t234_prod_sigheader.bin.encrypt to address 0x004a0000 in flash
Writing bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt (parittion: A_bpmp-fw) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt
Writing /qspi/internal/bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt (1048000 bytes) into /dev/mtd0:5111808
Copied 1048000 bytes from /qspi/internal/bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt to address 0x004e0000 in flash
Writing tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt (parittion: A_bpmp-fw-dtb) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt
Writing /qspi/internal/tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt (138880 bytes) into /dev/mtd0:6684672
Copied 138880 bytes from /qspi/internal/tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt to address 0x00660000 in flash
Writing pscfw_t234_prod_sigheader.bin.encrypt (parittion: A_psc-fw) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/pscfw_t234_prod_sigheader.bin.encrypt
Writing /qspi/internal/pscfw_t234_prod_sigheader.bin.encrypt (375168 bytes) into /dev/mtd0:10878976
Copied 375168 bytes from /qspi/internal/pscfw_t234_prod_sigheader.bin.encrypt to address 0x00a60000 in flash
Writing mce_flash_o10_cr_prod_sigheader.bin.encrypt (parittion: A_mts-mce) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/mce_flash_o10_cr_prod_sigheader.bin.encrypt
Writing /qspi/internal/mce_flash_o10_cr_prod_sigheader.bin.encrypt (190592 bytes) into /dev/mtd0:11665408
Copied 190592 bytes from /qspi/internal/mce_flash_o10_cr_prod_sigheader.bin.encrypt to address 0x00b20000 in flash
Writing sc7_t234_prod_sigheader.bin.encrypt (parittion: A_sc7) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/sc7_t234_prod_sigheader.bin.encrypt
Writing /qspi/internal/sc7_t234_prod_sigheader.bin.encrypt (167344 bytes) into /dev/mtd0:12189696
Copied 167344 bytes from /qspi/internal/sc7_t234_prod_sigheader.bin.encrypt to address 0x00ba0000 in flash
Writing psc_rf_t234_prod_sigheader.bin.encrypt (parittion: A_pscrf) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/psc_rf_t234_prod_sigheader.bin.encrypt
Writing /qspi/internal/psc_rf_t234_prod_sigheader.bin.encrypt (119104 bytes) into /dev/mtd0:12386304
Copied 119104 bytes from /qspi/internal/psc_rf_t234_prod_sigheader.bin.encrypt to address 0x00bd0000 in flash
Writing mb2rf_t234_sigheader.bin.encrypt (parittion: A_mb2rf) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/mb2rf_t234_sigheader.bin.encrypt
Writing /qspi/internal/mb2rf_t234_sigheader.bin.encrypt (122784 bytes) into /dev/mtd0:12582912
Copied 122784 bytes from /qspi/internal/mb2rf_t234_sigheader.bin.encrypt to address 0x00c00000 in flash
Writing uefi_jetson_with_dtb_sigheader.bin.encrypt (parittion: A_cpu-bootloader) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/uefi_jetson_with_dtb_sigheader.bin.encrypt
Writing /qspi/internal/uefi_jetson_with_dtb_sigheader.bin.encrypt (3182656 bytes) into /dev/mtd0:12713984
Copied 3182656 bytes from /qspi/internal/uefi_jetson_with_dtb_sigheader.bin.encrypt to address 0x00c20000 in flash
Writing tos-optee_t234_sigheader.img.encrypt (parittion: A_secure-os) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/tos-optee_t234_sigheader.img.encrypt
Writing /qspi/internal/tos-optee_t234_sigheader.img.encrypt (1064752 bytes) into /dev/mtd0:16384000
Copied 1064752 bytes from /qspi/internal/tos-optee_t234_sigheader.img.encrypt to address 0x00fa0000 in flash
[ 190]: l4t_flash_from_kernel: Warning: skip writing A_smm-fw partition as no image is specified
Writing eks_t234_sigheader.img.encrypt (parittion: A_eks) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/eks_t234_sigheader.img.encrypt
Writing /qspi/internal/eks_t234_sigheader.img.encrypt (9232 bytes) into /dev/mtd0:22675456
Copied 9232 bytes from /qspi/internal/eks_t234_sigheader.img.encrypt to address 0x015a0000 in flash
Writing display-t234-dce_with_kernel_tegra234-p3767-0000-p3509-a02_aligned_blob_w_bin_sigheader.bin.encrypt (parittion: A_dce-fw) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/display-t234-dce_with_kernel_tegra234-p3767-0000-p3509-a02_aligned_blob_w_bin_sigheader.bin.encrypt
Writing /qspi/internal/display-t234-dce_with_kernel_tegra234-p3767-0000-p3509-a02_aligned_blob_w_bin_sigheader.bin.encrypt (736112 bytes) into /dev/mtd0:22937600
Copied 736112 bytes from /qspi/internal/display-t234-dce_with_kernel_tegra234-p3767-0000-p3509-a02_aligned_blob_w_bin_sigheader.bin.encrypt to address 0x015e0000 in flash
Writing spe_t234_sigheader.bin.encrypt (parittion: A_spe-fw) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/spe_t234_sigheader.bin.encrypt
Writing /qspi/internal/spe_t234_sigheader.bin.encrypt (270336 bytes) into /dev/mtd0:28180480
Copied 270336 bytes from /qspi/internal/spe_t234_sigheader.bin.encrypt to address 0x01ae0000 in flash
Writing camera-rtcpu-t234-rce_sigheader.img.encrypt (parittion: A_rce-fw) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/camera-rtcpu-t234-rce_sigheader.img.encrypt
Writing /qspi/internal/camera-rtcpu-t234-rce_sigheader.img.encrypt (537952 bytes) into /dev/mtd0:28770304
Copied 537952 bytes from /qspi/internal/camera-rtcpu-t234-rce_sigheader.img.encrypt to address 0x01b70000 in flash
Writing adsp-fw_sigheader.bin.encrypt (parittion: A_adsp-fw) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/adsp-fw_sigheader.bin.encrypt
Writing /qspi/internal/adsp-fw_sigheader.bin.encrypt (400960 bytes) into /dev/mtd0:29818880
Copied 400960 bytes from /qspi/internal/adsp-fw_sigheader.bin.encrypt to address 0x01c70000 in flash
[ 193]: l4t_flash_from_kernel: Warning: skip writing A_reserved_on_boot partition as no image is specified
Writing mb1_t234_prod_aligned_sigheader.bin.encrypt (parittion: B_mb1) into /dev/mtd0
Writing /qspi/internal/mb1_t234_prod_aligned_sigheader.bin.encrypt (268240 bytes) into /dev/mtd0:33292288
Copied 268240 bytes from /qspi/internal/mb1_t234_prod_aligned_sigheader.bin.encrypt to address 0x01fc0000 in flash
Writing psc_bl1_t234_prod_aligned_sigheader.bin.encrypt (parittion: B_psc_bl1) into /dev/mtd0
Writing /qspi/internal/psc_bl1_t234_prod_aligned_sigheader.bin.encrypt (119616 bytes) into /dev/mtd0:33816576
Copied 119616 bytes from /qspi/internal/psc_bl1_t234_prod_aligned_sigheader.bin.encrypt to address 0x02040000 in flash
Writing mb1_cold_boot_bct_MB1_sigheader.bct.encrypt (parittion: B_MB1_BCT) into /dev/mtd0
Writing /qspi/internal/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt (17056 bytes) into /dev/mtd0:34078720
Copied 17056 bytes from /qspi/internal/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt to address 0x02080000 in flash
Writing mem_coldboot_sigheader.bct.encrypt (parittion: B_MEM_BCT) into /dev/mtd0
Writing /qspi/internal/mem_coldboot_sigheader.bct.encrypt (243712 bytes) into /dev/mtd0:34209792
Copied 243712 bytes from /qspi/internal/mem_coldboot_sigheader.bct.encrypt to address 0x020a0000 in flash
[ 195]: l4t_flash_from_kernel: Warning: skip writing B_tsec-fw partition as no image is specified
Writing nvdec_t234_prod_sigheader.fw.encrypt (parittion: B_nvdec) into /dev/mtd0
Writing /qspi/internal/nvdec_t234_prod_sigheader.fw.encrypt (294912 bytes) into /dev/mtd0:35520512
Copied 294912 bytes from /qspi/internal/nvdec_t234_prod_sigheader.fw.encrypt to address 0x021e0000 in flash
Writing mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt (parittion: B_mb2) into /dev/mtd0
Writing /qspi/internal/mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt (437984 bytes) into /dev/mtd0:36569088
Copied 437984 bytes from /qspi/internal/mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt to address 0x022e0000 in flash
Writing xusb_t234_prod_sigheader.bin.encrypt (parittion: B_xusb-fw) into /dev/mtd0
Writing /qspi/internal/xusb_t234_prod_sigheader.bin.encrypt (164352 bytes) into /dev/mtd0:37093376
Copied 164352 bytes from /qspi/internal/xusb_t234_prod_sigheader.bin.encrypt to address 0x02360000 in flash
Writing bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt (parittion: B_bpmp-fw) into /dev/mtd0
Writing /qspi/internal/bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt (1048000 bytes) into /dev/mtd0:37355520
Copied 1048000 bytes from /qspi/internal/bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt to address 0x023a0000 in flash
Writing tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt (parittion: B_bpmp-fw-dtb) into /dev/mtd0
Writing /qspi/internal/tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt (138880 bytes) into /dev/mtd0:38928384
Copied 138880 bytes from /qspi/internal/tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt to address 0x02520000 in flash
Writing pscfw_t234_prod_sigheader.bin.encrypt (parittion: B_psc-fw) into /dev/mtd0
Writing /qspi/internal/pscfw_t234_prod_sigheader.bin.encrypt (375168 bytes) into /dev/mtd0:43122688
Copied 375168 bytes from /qspi/internal/pscfw_t234_prod_sigheader.bin.encrypt to address 0x02920000 in flash
Writing mce_flash_o10_cr_prod_sigheader.bin.encrypt (parittion: B_mts-mce) into /dev/mtd0
Writing /qspi/internal/mce_flash_o10_cr_prod_sigheader.bin.encrypt (190592 bytes) into /dev/mtd0:43909120
Copied 190592 bytes from /qspi/internal/mce_flash_o10_cr_prod_sigheader.bin.encrypt to address 0x029e0000 in flash
Writing sc7_t234_prod_sigheader.bin.encrypt (parittion: B_sc7) into /dev/mtd0
Writing /qspi/internal/sc7_t234_prod_sigheader.bin.encrypt (167344 bytes) into /dev/mtd0:44433408
Copied 167344 bytes from /qspi/internal/sc7_t234_prod_sigheader.bin.encrypt to address 0x02a60000 in flash
Writing psc_rf_t234_prod_sigheader.bin.encrypt (parittion: B_pscrf) into /dev/mtd0
Writing /qspi/internal/psc_rf_t234_prod_sigheader.bin.encrypt (119104 bytes) into /dev/mtd0:44630016
Copied 119104 bytes from /qspi/internal/psc_rf_t234_prod_sigheader.bin.encrypt to address 0x02a90000 in flash
Writing mb2rf_t234_sigheader.bin.encrypt (parittion: B_mb2rf) into /dev/mtd0
Writing /qspi/internal/mb2rf_t234_sigheader.bin.encrypt (122784 bytes) into /dev/mtd0:44826624
Copied 122784 bytes from /qspi/internal/mb2rf_t234_sigheader.bin.encrypt to address 0x02ac0000 in flash
Writing uefi_jetson_with_dtb_sigheader.bin.encrypt (parittion: B_cpu-bootloader) into /dev/mtd0
Writing /qspi/internal/uefi_jetson_with_dtb_sigheader.bin.encrypt (3182656 bytes) into /dev/mtd0:44957696
Copied 3182656 bytes from /qspi/internal/uefi_jetson_with_dtb_sigheader.bin.encrypt to address 0x02ae0000 in flash
Writing tos-optee_t234_sigheader.img.encrypt (parittion: B_secure-os) into /dev/mtd0
Writing /qspi/internal/tos-optee_t234_sigheader.img.encrypt (1064752 bytes) into /dev/mtd0:48627712
Copied 1064752 bytes from /qspi/internal/tos-optee_t234_sigheader.img.encrypt to address 0x02e60000 in flash
[ 208]: l4t_flash_from_kernel: Warning: skip writing B_smm-fw partition as no image is specified
Writing eks_t234_sigheader.img.encrypt (parittion: B_eks) into /dev/mtd0
Writing /qspi/internal/eks_t234_sigheader.img.encrypt (9232 bytes) into /dev/mtd0:54919168
Copied 9232 bytes from /qspi/internal/eks_t234_sigheader.img.encrypt to address 0x03460000 in flash
Writing display-t234-dce_with_kernel_tegra234-p3767-0000-p3509-a02_aligned_blob_w_bin_sigheader.bin.encrypt (parittion: B_dce-fw) into /dev/mtd0
Writing /qspi/internal/display-t234-dce_with_kernel_tegra234-p3767-0000-p3509-a02_aligned_blob_w_bin_sigheader.bin.encrypt (736112 bytes) into /dev/mtd0:55181312
Copied 736112 bytes from /qspi/internal/display-t234-dce_with_kernel_tegra234-p3767-0000-p3509-a02_aligned_blob_w_bin_sigheader.bin.encrypt to address 0x034a0000 in flash
Writing spe_t234_sigheader.bin.encrypt (parittion: B_spe-fw) into /dev/mtd0
Writing /qspi/internal/spe_t234_sigheader.bin.encrypt (270336 bytes) into /dev/mtd0:60424192
Copied 270336 bytes from /qspi/internal/spe_t234_sigheader.bin.encrypt to address 0x039a0000 in flash
Writing camera-rtcpu-t234-rce_sigheader.img.encrypt (parittion: B_rce-fw) into /dev/mtd0
Writing /qspi/internal/camera-rtcpu-t234-rce_sigheader.img.encrypt (537952 bytes) into /dev/mtd0:61014016
Copied 537952 bytes from /qspi/internal/camera-rtcpu-t234-rce_sigheader.img.encrypt to address 0x03a30000 in flash
Writing adsp-fw_sigheader.bin.encrypt (parittion: B_adsp-fw) into /dev/mtd0
Writing /qspi/internal/adsp-fw_sigheader.bin.encrypt (400960 bytes) into /dev/mtd0:62062592
Copied 400960 bytes from /qspi/internal/adsp-fw_sigheader.bin.encrypt to address 0x03b30000 in flash
[ 211]: l4t_flash_from_kernel: Warning: skip writing B_reserved_on_boot partition as no image is specified
[ 211]: l4t_flash_from_kernel: Warning: skip writing uefi_variables partition as no image is specified
[ 211]: l4t_flash_from_kernel: Warning: skip writing uefi_ftw partition as no image is specified
[ 211]: l4t_flash_from_kernel: Warning: skip writing worm partition as no image is specified
Writing bct_backup.img (parittion: BCT-boot-chain_backup) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/bct_backup.img
Writing /qspi/internal/bct_backup.img (32768 bytes) into /dev/mtd0:66715648
Copied 32768 bytes from /qspi/internal/bct_backup.img to address 0x03fa0000 in flash
[ 211]: l4t_flash_from_kernel: Warning: skip writing reserved_partition partition as no image is specified
Writing gpt_secondary_3_0.bin (parittion: secondary_gpt_backup) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/gpt_secondary_3_0.bin
Writing /qspi/internal/gpt_secondary_3_0.bin (16896 bytes) into /dev/mtd0:66846720
Copied 16896 bytes from /qspi/internal/gpt_secondary_3_0.bin to address 0x03fc0000 in flash
Writing qspi_bootblob_ver.txt (parittion: B_VER) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/qspi_bootblob_ver.txt
Writing /qspi/internal/qspi_bootblob_ver.txt (109 bytes) into /dev/mtd0:66912256
Copied 109 bytes from /qspi/internal/qspi_bootblob_ver.txt to address 0x03fd0000 in flash
Writing qspi_bootblob_ver.txt (parittion: A_VER) into /dev/mtd0
Writing /qspi/internal/qspi_bootblob_ver.txt (109 bytes) into /dev/mtd0:66977792
Copied 109 bytes from /qspi/internal/qspi_bootblob_ver.txt to address 0x03fe0000 in flash
Writing gpt_secondary_3_0.bin (parittion: secondary_gpt) into /dev/mtd0
Writing /qspi/internal/gpt_secondary_3_0.bin (16896 bytes) into /dev/mtd0:67091968
Copied 16896 bytes from /qspi/internal/gpt_secondary_3_0.bin to address 0x03ffbe00 in flash
[ 212]: l4t_flash_from_kernel: Successfully flash the qspi
[ 212]: l4t_flash_from_kernel: Flashing success
Cleaning up...
After formatting the SSD, I get:
* Step 1: Generate flash packages *
Create folder to store images to flash
Generate image for internal storage devices
Generate images to be flashed
ADDITIONAL_DTB_OVERLAY="" /home/felix/Downloads/Linux_for_Tegra/flash.sh --no-flash --sign “-c p3509-a02+p3767-0000 internal
# L4T BSP Information:
# R35 , REVISION: 3.1
# User release: 0.0
copying emc_fuse_dev_params(/home/felix/Downloads/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-diag-boot.dts)... done.
copying device_config(/home/felix/Downloads/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-device-p3767-0000.dts)... done.
copying misc_config(/home/felix/Downloads/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-misc-p3767-0000.dts)... done.
./tegraflash.py --chip 0x23 --applet "/home/felix/Downloads/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3767-0000.dts --misc_config tegra234-mb1-bct-misc-p3767-0000.dts --bins "mb2_applet applet_t234.bin" --cmd "dump eeprom cvm cvm.bin; dump custinfo custinfo_out.bin; reboot recovery"
version 1.0.0
[ 0.0096 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.0101 ] File rcm_state open failed
[ 0.0102 ] ERROR: failed to read rcm_state
[ 0.0102 ]
[ 0.0111 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0112 ] Assuming zero filled SBK key
[ 0.0104 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[ 0.0386 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[ 0.0441 ] Parsing partition layout
[ 0.0452 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0462 ] Kernel DTB used: None
[ 0.0462 ] WARNING: dce base dtb is not provided
[ 0.0462 ] Parsing partition layout
[ 0.0467 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0472 ] Creating list of images to be signed
[ 0.0481 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[ 0.0486 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0495 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0496 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0526 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0527 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0560 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0561 ] adding BCH for mb2_t234_aligned.bin
[ 0.0582 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0661 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0662 ] adding BCH for mb2_t234_aligned.bin
[ 0.0758 ] Filling MB1 storage info
[ 0.0759 ] Parsing dev params for multi chains
[ 0.0794 ] Generating br-bct
[ 0.0803 ] Updating dev and MSS params in BR BCT
[ 0.0803 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.0819 ] Updating bl info
[ 0.0824 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[ 0.0829 ] WARNING: boot chain is not completed. set to 0
[ 0.0832 ] Generating signatures
[ 0.0841 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.0842 ] Assuming zero filled SBK key
[ 0.0937 ] Warning: pub_key.key is not found
[ 0.0930 ] Parsing dev params for multi chains
[ 0.0930 ] Generating br-bct
[ 0.0936 ] Updating dev and MSS params in BR BCT
[ 0.0937 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.0946 ] Updating bl info
[ 0.0954 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.0961 ] WARNING: boot chain is not completed. set to 0
[ 0.0968 ] Get Signed section of bct
[ 0.0975 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 0.0983 ] Signing BCT
[ 0.0992 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.0994 ] Assuming zero filled SBK key
[ 0.1014 ] Sha saved in br_bct_BR.sha
[ 0.1017 ] Warning: pub_key.key is not found
[ 0.1008 ] Updating BCT with signature
[ 0.1013 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 0.1022 ] Offset :4608 Len :3584
[ 0.1026 ] Generating SHA2 Hash
[ 0.1035 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 0.1036 ] Assuming zero filled SBK key
[ 0.1050 ] Sha saved in br_bct_BR.sha
[ 0.1043 ] Updating BCT with SHA2 Hash
[ 0.1048 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 0.1052 ] Offset :4608 Len :3584
[ 0.1053 ] Offset :68 Len :8124
[ 0.1053 ]
[ 0.1054 ] Generating coldboot mb1-bct
[ 0.1059 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.1063 ] MB1-BCT version: 0.10
[ 0.1064 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.1067 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.1069 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.1070 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.1072 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.1074 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.1074 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[ 0.1074 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[ 0.1074 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[ 0.1074 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[ 0.1074 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[ 0.1074 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[ 0.1074 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[ 0.1074 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[ 0.1074 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[ 0.1074 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[ 0.1074 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[ 0.1074 ]
[ 0.1074 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.1074 ] Added Platform Config 9 data with size :- 100
[ 0.1074 ]
[ 0.1074 ] Updating mb1-bct with firmware information
[ 0.1078 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.1088 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 0.1098 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 0.1102 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 0.1115 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1116 ] Assuming zero filled SBK key
[ 0.1124 ] Warning: pub_key.key is not found
[ 0.1121 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.1128 ] Generating recovery mb1-bct
[ 0.1133 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.1137 ] MB1-BCT version: 0.10
[ 0.1138 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.1141 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.1142 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.1144 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.1146 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.1148 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.1148 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[ 0.1148 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[ 0.1148 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[ 0.1148 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[ 0.1148 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[ 0.1148 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[ 0.1148 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[ 0.1148 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[ 0.1148 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[ 0.1148 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[ 0.1148 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[ 0.1148 ]
[ 0.1148 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.1148 ] Added Platform Config 9 data with size :- 100
[ 0.1148 ]
[ 0.1148 ] Updating mb1-bct with firmware information
[ 0.1153 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.1163 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[ 0.1171 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 0.1175 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 0.1189 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1190 ] Assuming zero filled SBK key
[ 0.1199 ] Warning: pub_key.key is not found
[ 0.1195 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.1202 ] Error: Skip generating mem_bct because sdram_config is not defined
[ 0.1202 ] Copying signatures
[ 0.1207 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.1234 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.1235 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.1235 ] Boot Rom communication
[ 0.1240 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.1244 ] BR_CID: 0x80012344705DD5D16C0000000A0102C0
[ 0.1516 ] Sending bct_br
[ 0.1950 ] ERROR: might be timeout in USB write.
Error: Return value 3
Command tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
Reading board information failed.
Error: failed to generate images
Cleaning up...
The error log you just posted reminds me of another issue. But that one has nothing to do with SSD format.
Do you have other spare SSD on your side to try?
You mean a fresh SSD? I do not have one at the moment. However, if i switch the SSD from my working Orin NX to this one, it still does not boot, not even having the Nvidia logo boot screen. Should I get a new SSD and try reflashing?
Is your ubuntu host a 20.04 one? Did you use same ubuntu host to flash this Orin before?
Do you have any ubuntu 18.04 host on your side that can do the flash work?
The issue I am talking about is we notice some ubuntu 20.04 host may have usb connection problem with Orin platform (Orin AGX/NX). The symptom is just as what you shared.
However, this issue seems not stable and I am not able to reproduce on my side.
You can also try different usb port on your host and see if this makes difference.
Or cold reboot the host machine.
My host is Ubuntu18.04. I managed to use this host to flash one Orin NX right before this one. Also tried different USB ports. Still getting Reading board information failed.
Could you dump the serial console log during flash? You can use the boot up case first to validate if you can really dump log.
Also, when doing flash, please remove other jeston devices from host side only leave the one you want to flash.
Will try to find a usb ttl cable so i can get the serial console logs. I made sure that only 1 Jetson device is connected to the host.
Just a reminder about the usb-ttl cable
The boot up process shall give you the log no matter what situation.
The flash process here may not print any log.
Thus, please use the boot up process first to make sure you can really dump the log.
No luck with the booting up process. It seems to be dumping garbage:
����0��X
�1 �
Ĉh��x�� ��`� p����(@�������������������p��������}��0���� � �
������������0��`�������������������������������������������������������������
�������������o����������������������������������������������������������������|
�����������������������������������������������������0�����~�������������������
��p�������������������������������������������������������������������
�������������������������������������������������������������8�����������������������������x��������������������������������������������������������������@�������������������������������������������
You told us you still have one board that can boot up fine right? Could you use that board to validate your setup first?
To clarify, should i be booting in force recovery mode or normally?
As I alraedy told in previous comment, boot it up normally.
For the not working Orin NX, booting up normally shows the same thing as above. For the working Orin NX:
Jetson UEFI firmware (version 3.1-32827747 built on 2023-03-19T14:56:32+00:00)
ESC to enter Setup.
F11 to enter Boot Manager Menu.
Enter to continue boot.
** WARNING: Test Key is used. **
L4TLauncher: Attempting Direct Boot
L4T boot options
0: primary kernel
1: Custom Header Config: <CSI Camera IMX477-A and IMX219-C>
Press 0-1 to boot selection within 3.0 seconds.
Press any other key to boot default (Option: 1)
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map...
��I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
��[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.10.104-tegra (buildbrain@mobile-u64-6289-d7000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Sun Mar 19 07:55:23
[ 0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[ 0.000000] OF: fdt: - 80000000 , c0000000
[ 0.000000] Machine model: NVIDIA Orin NX Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x45f4fae18 SMBIOS=0xffff0000 SMBIOS 3.0=0x4412e0000 MEMATTR=0x440ea4018 ESRT=0x440ed8898 RNG=0x464536c18 MEMRESERVE=0x440eaff18
[ 0.000000] efi: seeding entropy pool
[ 0.000000] esrt: Reserving ESRT space from 0x0000000440ed8898 to 0x0000000440ed88d0.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000454400000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x000000046fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000043bffffff]
[ 0.000000] node 0: [mem 0x000000043c000000-0x000000043e1bffff]
[ 0.000000] node 0: [mem 0x000000043e1c0000-0x000000044078ffff]
[ 0.000000] node 0: [mem 0x0000000440790000-0x00000004407bffff]
[ 0.000000] node 0: [mem 0x00000004407c0000-0x00000004407dffff]
[ 0.000000] node 0: [mem 0x00000004407e0000-0x000000044087ffff]
[ 0.000000] node 0: [mem 0x0000000440880000-0x000000044089ffff]
[ 0.000000] node 0: [mem 0x00000004408a0000-0x00000004408bffff]
[ 0.000000] node 0: [mem 0x00000004408c0000-0x0000000440d41fff]
[ 0.000000] node 0: [mem 0x0000000440d42000-0x0000000440ea0fff]
[ 0.000000] node 0: [mem 0x0000000440ea1000-0x00000004412cffff]
[ 0.000000] node 0: [mem 0x00000004412d0000-0x00000004412effff]
[ 0.000000] node 0: [mem 0x00000004412f0000-0x000000044160ffff]
[ 0.000000] node 0: [mem 0x0000000441610000-0x000000044165ffff]
[ 0.000000] node 0: [mem 0x0000000441660000-0x000000044181ffff]
[ 0.000000] node 0: [mem 0x0000000441820000-0x00000004419fffff]
[ 0.000000] node 0: [mem 0x0000000441a00000-0x0000000441a8ffff]
[ 0.000000] node 0: [mem 0x0000000441a90000-0x0000000441c6ffff]
[ 0.000000] node 0: [mem 0x0000000441c70000-0x0000000441ccffff]
[ 0.000000] node 0: [mem 0x0000000441cd0000-0x0000000441dbffff]
[ 0.000000] node 0: [mem 0x0000000441dc0000-0x0000000441deffff]
[ 0.000000] node 0: [mem 0x0000000441df0000-0x0000000441dfffff]
[ 0.000000] node 0: [mem 0x0000000441e00000-0x0000000441eaffff]
[ 0.000000] node 0: [mem 0x0000000441eb0000-0x0000000441f4ffff]
[ 0.000000] node 0: [mem 0x0000000441f50000-0x000000044204ffff]
[ 0.000000] node 0: [mem 0x0000000442050000-0x00000004420effff]
[ 0.000000] node 0: [mem 0x00000004420f0000-0x00000004421effff]
[ 0.000000] node 0: [mem 0x00000004421f0000-0x000000044228ffff]
[ 0.000000] node 0: [mem 0x0000000442290000-0x0000000442b5ffff]
[ 0.000000] node 0: [mem 0x0000000442b60000-0x0000000442d3ffff]
[ 0.000000] node 0: [mem 0x0000000442d40000-0x00000004644effff]
[ 0.000000] node 0: [mem 0x00000004644f0000-0x000000046453ffff]
[ 0.000000] node 0: [mem 0x0000000464540000-0x0000000467ffffff]
[ 0.000000] node 0: [mem 0x0000000468200000-0x000000046860ffff]
[ 0.000000] node 0: [mem 0x000000046e000000-0x000000046fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000046fffffff]
[ 0.000000] On node 0, zone Normal: 496 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 32 pages/cpu s90200 r8192 d32680 u131072
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 4040720
[ 0.000000] Kernel command line: root=PARTUUID=2665df59-76bb-4f9e-8ab2-334874e75584 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 firmware_class.path=/etc/firmwa
[ 0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000effe0000-0x00000000fffe0000] (256MB)
[ 0.000000] Memory: 15482592K/16420928K available (18496K kernel code, 3168K rwdata, 7172K rodata, 3968K init, 1418K bss, 676192K reserved, 262144K cma-reserved)
[ 0.000000] random: get_random_u64 called from __kmem_cache_create+0x38/0x420 with crng_init=0
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[ 0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000671] Console: colour dummy device 80x25
[ 0.000717] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.000724] pid_max: default: 32768 minimum: 301
[ 0.000790] LSM: Security Framework initializing
[ 0.000813] Yama: becoming mindful.
[ 0.000831] SELinux: Initializing.
[ 0.000899] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.000923] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.002071] rcu: Hierarchical SRCU implementation.
[ 0.002161] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.002652] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t23x/p3768/kernel-dts/tegra234-p3767-0000-p3509-a02.dts
[ 0.002657] DTB Build time: Mar 19 2023 08:08:40
[ 0.003926] Tegra Revision: A01 SKU: 0xd3 CPU Process: 0 SoC Process: 0
[ 0.004093] Remapping and enabling EFI services.
[ 0.005299] smp: Bringing up secondary CPUs ...
[ 0.034008] Detected PIPT I-cache on CPU1
[ 0.034044] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.034081] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.062741] Detected PIPT I-cache on CPU2
[ 0.062753] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.062769] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.091375] Detected PIPT I-cache on CPU3
[ 0.091384] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.091398] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.122066] Detected PIPT I-cache on CPU4
[ 0.122087] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[ 0.122114] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[ 0.150779] Detected PIPT I-cache on CPU5
[ 0.150789] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[ 0.150803] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[ 0.179433] Detected PIPT I-cache on CPU6
[ 0.179443] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[ 0.179458] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.208088] Detected PIPT I-cache on CPU7
[ 0.208098] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[ 0.208113] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.208172] smp: Brought up 1 node, 8 CPUs
[ 0.208186] SMP: Total of 8 processors activated.
[ 0.208189] CPU features: detected: Privileged Access Never
[ 0.208191] CPU features: detected: LSE atomic instructions
[ 0.208192] CPU features: detected: User Access Override
[ 0.208194] CPU features: detected: 32-bit EL0 Support
[ 0.208197] CPU features: detected: Common not Private translations
[ 0.208198] CPU features: detected: RAS Extension Support
[ 0.208200] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.208202] CPU features: detected: CRC32 instructions
[ 0.208203] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.242204] CPU: All CPU(s) started at EL2
[ 0.244183] devtmpfs: initialized
[ 0.258807] Registered cp15_barrier emulation handler
[ 0.258818] Registered setend emulation handler
[ 0.258823] KASLR enabled
[ 0.258952] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.258964] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.260566] pinctrl core: initialized pinctrl subsystem
[ 0.261121] SMBIOS 3.0.0 present.
[ 0.261128] DMI: Unknown NVIDIA Orin NX Developer Kit/NVIDIA Orin NX Developer Kit, BIOS 3.1-32827747 03/19/2023
[ 0.261396] NET: Registered protocol family 16
[ 0.262033] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[ 0.262143] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.262244] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.262271] audit: initializing netlink subsys (disabled)
[ 0.262352] audit: type=2000 audit(0.260:1): state=initialized audit_enabled=0 res=1
[ 0.262526] thermal_sys: Registered thermal governor 'step_wise'
[ 0.262528] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.262530] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[ 0.263379] cpuidle: using governor menu
[ 0.263483] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.263567] ASID allocator initialised with 32768 entries
[ 0.263662] Serial: AMBA PL011 UART driver
[ 0.265452] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[ 0.265476] Tegra reboot handler registered.
[ 0.283695] mc: mapped MMIO address: 0xffff800010b10000 -> 0x2c10000
[ 0.283703] mc: mapped MMIO address: 0xffff800010b30000 -> 0x2c20000
[ 0.283709] mc: mapped MMIO address: 0xffff800010b50000 -> 0x2c30000
[ 0.283715] mc: mapped MMIO address: 0xffff800010b70000 -> 0x2c40000
[ 0.283721] mc: mapped MMIO address: 0xffff800010b90000 -> 0x2c50000
[ 0.283726] mc: mapped MMIO address: 0xffff800010bb0000 -> 0x2b80000
[ 0.283731] mc: mapped MMIO address: 0xffff800010bd0000 -> 0x2b90000
[ 0.283736] mc: mapped MMIO address: 0xffff800010bf0000 -> 0x2ba0000
[ 0.283743] mc: mapped MMIO address: 0xffff800010c10000 -> 0x2bb0000
[ 0.283748] mc: mapped MMIO address: 0xffff800010c30000 -> 0x1700000
[ 0.283754] mc: mapped MMIO address: 0xffff800010c50000 -> 0x1710000
[ 0.283759] mc: mapped MMIO address: 0xffff800010c70000 -> 0x1720000
[ 0.283765] mc: mapped MMIO address: 0xffff800010c90000 -> 0x1730000
[ 0.283771] mc: mapped MMIO address: 0xffff800010cb0000 -> 0x1740000
[ 0.283779] mc: mapped MMIO address: 0xffff800010cd0000 -> 0x1750000
[ 0.283784] mc: mapped MMIO address: 0xffff800010cf0000 -> 0x1760000
[ 0.283789] mc: mapped MMIO address: 0xffff800010d10000 -> 0x1770000
[ 0.283797] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.283820] mc-err: mcerr ops are set to t23x
[ 0.284505] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 63, base_baud = 0) is a SBSA
[ 1.470230] printk: console [ttyAMA0] enabled
[ 1.478425] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 1.485137] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 1.491837] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 1.498535] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 1.507043] ACPI: Interpreter disabled.
[ 1.511258] ddr-vddq: supplied by vdd-5v
[ 1.515383] ddr-vdd2: supplied by vdd-5v
[ 1.519416] vdd-AO-1v2: supplied by vdd-5v
[ 1.523622] vdd-3v3: supplied by vdd-5v
[ 1.527577] vdd-rtc: supplied by vdd-AO-1v2
[ 1.531857] vdd-0v95-uphy: supplied by vdd-AO-1v2
[ 1.536663] vdd-0v95-hdmi: supplied by vdd-AO-1v2
[ 1.541603] vdd-1v8: supplied by vdd-3v3-sys
[ 1.545968] vdd-3v3-AO: supplied by vdd-5v-sys
[ 1.550503] vdd-av10-hub: supplied by vdd-5v-sys
[ 1.555228] vdd-vbus-a: supplied by vdd-5v-sys
[ 1.559766] vdd-vbus-b: supplied by vdd-5v-sys
[ 1.564369] vdd-3v3-dp: supplied by vdd-3v3-sys
[ 1.569138] iommu: Default domain type: Translated
[ 1.574049] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.580315] SCSI subsystem initialized
[ 1.584123] usbcore: registered new interface driver usbfs
[ 1.589624] usbcore: registered new interface driver hub
[ 1.594943] usbcore: registered new device driver usb
[ 1.600166] mc: Linux media interface: v0.10
[ 1.604442] videodev: Linux video capture interface: v2.00
[ 1.610066] pps_core: LinuxPPS API ver. 1 registered
[ 1.615028] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.624163] PTP clock support registered
[ 1.628290] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.635461] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[ 1.643090] Registered efivars operations
[ 1.647227] FPGA manager framework
[ 1.650665] Advanced Linux Sound Architecture Driver Initialized.
[ 1.657019] Bluetooth: Core ver 2.22
[ 1.660600] NET: Registered protocol family 31
[ 1.665041] Bluetooth: HCI device and connection manager initialized
[ 1.671397] Bluetooth: HCI socket layer initialized
[ 1.676273] Bluetooth: L2CAP socket layer initialized
[ 1.681329] Bluetooth: SCO socket layer initialized
[ 1.686679] camchar: rtcpu character device driver loaded
[ 1.692284] clocksource: Switched to clocksource arch_sys_counter
[ 1.851810] VFS: Disk quotas dquot_6.6.0
[ 1.855775] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.862805] pnp: PnP ACPI: disabled
[ 1.868196] la/ptsa driver initialized.
[ 1.872086] NET: Registered protocol family 2
[ 1.876644] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 1.886387] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 1.895027] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 1.903224] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 1.911127] TCP: Hash tables configured (established 131072 bind 65536)
[ 1.917822] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 1.924639] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 1.931954] NET: Registered protocol family 1
[ 1.936613] RPC: Registered named UNIX socket transport module.
[ 1.942541] RPC: Registered udp transport module.
[ 1.947241] RPC: Registered tcp transport module.
[ 1.951943] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.958392] PCI: CLS 0 bytes, default 64
[ 1.962441] Trying to unpack rootfs image as initramfs...
[ 2.091970] Freeing initrd memory: 9120K
[ 2.098009] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 2.105914] kvm [1]: IPA Size Limit: 48 bits
[ 2.110204] kvm [1]: GICv3: no GICV resource entry
[ 2.114993] kvm [1]: disabling GICv2 emulation
[ 2.119451] kvm [1]: GIC system register CPU interface enabled
[ 2.125366] kvm [1]: vgic interrupt IRQ9
[ 2.129423] kvm [1]: VHE mode initialized successfully
[ 2.135336] Initialise system trusted keyrings
[ 2.139878] workingset: timestamp_bits=46 max_order=22 bucket_order=0
[ 2.148527] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.154661] NFS: Registering the id_resolver key type
[ 2.159723] Key type id_resolver registered
[ 2.163902] Key type id_legacy registered
[ 2.167942] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 2.174647] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 2.182050] ntfs: driver 2.1.32 [Flags: R/W].
[ 2.198233] NET: Registered protocol family 38
[ 2.202677] Key type asymmetric registered
[ 2.206771] Asymmetric key parser 'x509' registered
[ 2.211665] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 2.219107] io scheduler mq-deadline registered
[ 2.223637] io scheduler kyber registered
[ 2.231393] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 2.236994] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 2.242580] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 2.250493] tegra_dc_assign_hw_data: no matching compatible node
[ 2.256504] tegradccommon module_init failed
[ 2.260772] tegradc module_init failed
[ 2.264757] EINJ: ACPI disabled.
[ 2.269383] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 2.276291] tegra-pmc: ### PMC reset source: SYS_RESET_N
[ 2.281607] tegra-pmc: ### PMC reset level: L0
[ 2.286045] tegra-pmc: ### PMC reset status reg: 0x0
[ 2.292221] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 2.313997] random: fast init done
[ 2.316894] printk: console [ttyTCU0] enabled
[ 3.919826] arm-smmu 12000000.iommu: probing hardware configuration...
[ 3.926514] arm-smmu 12000000.iommu: SMMUv2 with:
[ 3.931339] arm-smmu 12000000.iommu: stage 1 translation
[ 3.936888] arm-smmu 12000000.iommu: stage 2 translation
[ 3.942415] arm-smmu 12000000.iommu: nested translation
[ 3.947864] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 3.955272] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 3.964169] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 3.970862] arm-smmu 12000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 3.977552] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 3.985050] arm-smmu 10000000.iommu: probing hardware configuration...
[ 3.991740] arm-smmu 10000000.iommu: SMMUv2 with:
[ 3.996564] arm-smmu 10000000.iommu: stage 1 translation
[ 4.002093] arm-smmu 10000000.iommu: stage 2 translation
[ 4.007620] arm-smmu 10000000.iommu: nested translation
[ 4.013070] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 4.020473] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 4.029327] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 4.036016] arm-smmu 10000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.042700] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.049813] arm-smmu 8000000.iommu: probing hardware configuration...
[ 4.056421] arm-smmu 8000000.iommu: SMMUv2 with:
[ 4.061149] arm-smmu 8000000.iommu: stage 1 translation
[ 4.066591] arm-smmu 8000000.iommu: stage 2 translation
[ 4.072039] arm-smmu 8000000.iommu: nested translation
[ 4.077398] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 4.084716] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 4.093470] arm-smmu 8000000.iommu: Supported page sizes: 0x00001000
[ 4.100074] arm-smmu 8000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.106667] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.113929] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 4.123576] tegra_profiler: version: 1.151, samples/io: 51/30
[ 4.129550] tegra_profiler: auth: init
[ 4.133686] nvsciipc: loaded module
[ 4.138809] tun: Universal TUN/TAP device driver, 1.6
[ 4.144430] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 4.151841] hns3: Copyright (c) 2017 Huawei Corporation.
[ 4.157313] e1000e: Intel(R) PRO/1000 Network Driver
[ 4.162395] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.168480] igb: Intel(R) Gigabit Ethernet Network Driver
[ 4.174015] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.179871] PPP generic driver version 2.4.2
[ 4.184296] PPP BSD Compression module registered
[ 4.189119] PPP Deflate Compression module registered
[ 4.194317] PPP MPPE Compression module registered
[ 4.199252] usbcore: registered new interface driver r8152
[ 4.204888] usbcore: registered new interface driver asix
[ 4.210428] usbcore: registered new interface driver ax88179_178a
[ 4.216681] usbcore: registered new interface driver cdc_ether
[ 4.222669] usbcore: registered new interface driver net1080
[ 4.228472] usbcore: registered new interface driver cdc_subset
[ 4.234548] usbcore: registered new interface driver zaurus
[ 4.240276] usbcore: registered new interface driver cdc_ncm
[ 4.246086] usbcore: registered new interface driver aqc111
[ 4.251917] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 4.258263] ohci-pci: OHCI PCI platform driver
[ 4.262829] ohci-platform: OHCI generic platform driver
[ 4.268485] tegra-xusb 3610000.xhci: Adding to iommu group 0
[ 4.274824] usbcore: registered new interface driver uas
[ 4.280290] usbcore: registered new interface driver usb-storage
[ 4.286590] tegra-xudc 3550000.xudc: Adding to iommu group 1
[ 4.292673] mousedev: PS/2 mouse device common for all mice
[ 4.298407] usbcore: registered new interface driver xpad
[ 4.305824] tegra_rtc c2a0000.rtc: registered as rtc1
[ 4.311284] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:28 UTC (28)
[ 4.319520] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.325927] i2c /dev entries driver
[ 4.329609] tegra-i2c 3160000.i2c: Adding to iommu group 2
[ 4.335470] tegra-i2c c240000.i2c: Adding to iommu group 2
[ 4.341166] tegra-i2c 3180000.i2c: Adding to iommu group 2
[ 4.346862] tegra-i2c 3190000.i2c: Adding to iommu group 2
[ 4.352533] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[ 4.358199] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[ 4.363864] tegra-i2c c250000.i2c: Adding to iommu group 2
[ 4.369535] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[ 4.378498] device-mapper: uevent: version 1.0.3
[ 4.383336] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 4.393047] sdhci: Secure Digital Host Controller Interface driver
[ 4.399391] sdhci: Copyright(c) Pierre Ossman
[ 4.403857] Synopsys Designware Multimedia Card Interface Driver
[ 4.410093] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.416390] sdhci-tegra 3400000.sdhci: Adding to iommu group 3
[ 4.416620] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[ 4.429816] tegra-bpmp bpmp: firmware: 463f4d5b75234b74bb7f-1377b684fe5
[ 4.437850] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[ 4.443518] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x82
[ 4.457082] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[ 4.462999] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
��Failed to create /rm/vdd_cpu
debugfs initialized
��[ 6.808433] hid: raw HID events driver (C) Jiri Kosina
[ 6.814306] usbcore: registered new interface driver usbhid
[ 6.820034] usbhid: USB HID core driver
[ 6.824395] tegra-dce d800000.dce: Adding to iommu group 4
[ 6.831620] dce: dce_ipc_channel_init:319 Invalid Channel State [0x0] for ch_type [2]
[ 6.840595] tegra234-aon c000000.aon: Adding to iommu group 5
[ 6.847272] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x5]
[ 6.848817] c000000.aon:hsp: probed
[ 6.856289] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [0]. Ignored...
[ 6.868705] tegra234-aon c000000.aon: init done
[ 6.868963] tegra23x-psc e860000.psc: Adding to iommu group 6
[ 6.873386] dce: dce_admin_send_cmd_ver:424 version : [0x2] err : [0x0]
[ 6.879579] tegra23x-psc e860000.psc: ext_cfg base:(____ptrval____)
[ 6.886686] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x1]
[ 6.892649] tegra23x-psc e860000.psc: init done
[ 6.892792] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 7
[ 6.901648] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [1] ...
[ 6.901651] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [1]. Ignored...
[ 6.901661] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [1]. Ignored...
[ 6.907122] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 6.912932] dce: dce_admin_setup_clients_ipc:529 Get queue info failed for [2]
[ 6.913364] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x2]
[ 6.925201] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 6.930191] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [3] ...
[ 6.930194] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [3]. Ignored...
[ 6.930204] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [3]. Ignored...
[ 6.939004] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 6.947719] dce: dce_start_boot_flow:173 DCE_BOOT_DONE
[ 6.955122] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 7.027254] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 7.039065] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[ 7.051628] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[ 7.064434] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 7.076834] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (111)
[ 7.083631] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 7.095761] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=97e50cbff52bc4b542b2989187109c001c01cf77
[ 7.109688] t19x_cache tegra-cache: probed
[ 7.114161] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[ 7.127770] optee: probing for conduit method.
[ 7.132361] optee: revision 3.19 (3f29c61f)
[ 7.133105] optee: dynamic shared memory is enabled
[ 7.142517] optee: initialized driver
[ 7.157640] nvpmodel: initialized successfully
[ 7.162307] tegra_hv: get_hvd: not initialized yet
[ 7.167248] user_ivc_mempool: hypervisor not present
[ 7.173141] usbcore: registered new interface driver snd-usb-audio
[ 7.180357] u32 classifier
[ 7.183137] input device check on
[ 7.186903] Actions configured
[ 7.190548] Initializing XFRM netlink socket
[ 7.195445] NET: Registered protocol family 10
[ 7.201277] Segment Routing with IPv6
[ 7.205090] NET: Registered protocol family 17
[ 7.209674] NET: Registered protocol family 15
[ 7.214295] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 7.228447] Bluetooth: RFCOMM socket layer initialized
[ 7.233760] Bluetooth: RFCOMM ver 1.11
[ 7.237628] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 7.243727] Bluetooth: HIDP socket layer initialized
[ 7.250007] 9pnet: Installing 9P2000 support
[ 7.254481] Key type dns_resolver registered
[ 7.260070] registered taskstats version 1
[ 7.264325] Loading compiled-in X.509 certificates
[ 7.280033] Loaded X.509 cert 'Build time autogenerated kernel key: e63fb224cdc2a940ac382bb67b420fcb52cc4aee'
[ 7.290796] tegra194-pcie 14100000.pcie: Adding to iommu group 8
[ 7.303743] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 7.311607] tegra194-pcie 14160000.pcie: Adding to iommu group 9
[ 7.323919] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 7.330886] tegra194-pcie 140a0000.pcie: Adding to iommu group 10
[ 7.343030] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[ 7.375013] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 11
[ 7.385653] host1x 13e40000.host1x: Adding to iommu group 12
[ 7.415070] host1x 13e40000.host1x: initialized
[ 7.420196] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 13
[ 7.428332] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[ 7.440383] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 14
[ 7.448493] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[ 7.460526] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 15
[ 7.468589] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[ 7.480644] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 16
[ 7.488670] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[ 7.500673] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 17
[ 7.508697] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[ 7.520698] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 18
[ 7.528725] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[ 7.540732] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 19
[ 7.548802] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[ 7.560825] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 20
[ 7.568875] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[ 7.580892] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 21
[ 7.588912] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[ 7.600905] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 22
[ 7.608930] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[ 7.620937] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 23
[ 7.628976] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[ 7.641003] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 24
[ 7.649067] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[ 7.661072] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 25
[ 7.669114] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[ 7.681136] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 26
[ 7.689182] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[ 7.701176] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 27
[ 7.709219] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[ 7.721226] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 28
[ 7.729259] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[ 7.741282] falcon 15340000.vic: Adding to iommu group 29
[ 7.752214] falcon 15340000.vic: initialized
[ 7.756978] falcon 15380000.nvjpg: Adding to iommu group 30
[ 7.766061] falcon 15380000.nvjpg: initialized
[ 7.770783] falcon 15540000.nvjpg1: Adding to iommu group 31
[ 7.779882] falcon 15540000.nvjpg1: initialized
[ 7.784692] falcon 154c0000.nvenc: Adding to iommu group 32
[ 7.795026] falcon 154c0000.nvenc: initialized
[ 7.799746] falcon 15a50000.ofa: Adding to iommu group 33
[ 7.809365] falcon 15a50000.ofa: initialized
[ 7.813916] nvdec 15480000.nvdec: Adding to iommu group 34
[ 7.826198] nvdec 15480000.nvdec: initialized
[ 7.830827] tsec 15500000.tsec: Adding to iommu group 35
[ 7.841019] tsec 15500000.tsec: initialized
[ 7.848795] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 7.866069] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 7.882547] gpio-397 (camera-control-output-low): hogged as output/low
[ 7.889303] gpio-486 (camera-control-output-low): hogged as output/low
[ 7.897100] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[ 7.904482] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[ 7.911499] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 7.918003] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 7.924475] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 7.932807] tegra194-isp5 14800000.isp: Adding to iommu group 36
[ 7.941805] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 7.951467] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[ 7.957922] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 7.967150] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 7.976531] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 37
[ 7.984636] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 38
[ 7.992649] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
[ 8.002645] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[ 8.009431] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
[ 8.019415] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[ 8.026214] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[ 8.036174] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[ 8.043011] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 39
[ 8.051697] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18, iommu=smmu.0x0000000008000000)
[ 8.063068] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 40
[ 8.071712] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19, iommu=smmu.0x0000000008000000)
[ 8.083064] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 41
[ 8.091715] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20, iommu=smmu.0x0000000008000000)
[ 8.103074] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 42
[ 8.111709] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21, iommu=smmu.0x0000000008000000)
[ 8.123080] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to iommu group 43
[ 8.131730] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized (streamid=22, iommu=smmu.0x0000000008000000)
[ 8.143098] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to iommu group 44
[ 8.151780] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized (streamid=23, iommu=smmu.0x0000000008000000)
[ 8.163128] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to iommu group 45
[ 8.171779] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized (streamid=24, iommu=smmu.0x0000000008000000)
[ 8.183150] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to iommu group 46
[ 8.191814] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized (streamid=25, iommu=smmu.0x0000000008000000)
[ 8.203187] pva 16000000.pva0: Adding to iommu group 47
[ 8.214168] pva 16000000.pva0: initialized
[ 8.228044] nvdla 15880000.nvdla0: Adding to iommu group 48
[ 8.239127] nvdla 15880000.nvdla0: initialized
[ 8.245588] nvdla 158c0000.nvdla1: Adding to iommu group 49
[ 8.256658] nvdla 158c0000.nvdla1: initialized
[ 8.262961] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 2
[ 8.269999] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[ 8.277517] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 8.284152] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 8.290887] serial-tegra 3100000.serial: Adding to iommu group 2
[ 8.297551] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 17, base_baud = 0) is a TEGRA_UART
[ 8.307442] serial-tegra 3130000.serial: Adding to iommu group 2
[ 8.313970] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 61, base_baud = 0) is a TEGRA_UART
[ 8.323644] serial-tegra 3140000.serial: Adding to iommu group 2
[ 8.330138] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 62, base_baud = 0) is a TEGRA_UART
[ 8.356336] tegra-xusb 3610000.xhci: Firmware timestamp: 2021-12-01 05:27:10 UTC, Version: 80.03 release
[ 8.366089] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 8.371655] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 8.380283] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[ 8.389894] tegra-xusb 3610000.xhci: irq 228, io mem 0x03610000
[ 8.396338] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 8.404841] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.412275] usb usb1: Product: xHCI Host Controller
[ 8.417290] usb usb1: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[ 8.423554] usb usb1: SerialNumber: 3610000.xhci
[ 8.429075] hub 1-0:1.0: USB hub found
[ 8.432955] hub 1-0:1.0: 4 ports detected
[ 8.437325] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 8.442881] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 8.450669] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 8.458215] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 8.466728] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.474170] usb usb2: Product: xHCI Host Controller
[ 8.479184] usb usb2: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[ 8.485452] usb usb2: SerialNumber: 3610000.xhci
[ 8.490757] hub 2-0:1.0: USB hub found
[ 8.494630] hub 2-0:1.0: 4 ports detected
[ 8.516617] i2c i2c-2: Added multiplexed i2c bus 9
[ 8.521858] i2c i2c-2: Added multiplexed i2c bus 10
[ 8.526880] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[ 8.533879] tegra23x-oc-event soctherm-oc-event: Finished tegra23x overcurrent event probing
[ 8.557379] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1969000 KHz, changing to: 1984000 KHz
[ 8.570944] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 1981000 KHz, changing to: 1984000 KHz
[ 8.582809] tegra194-cpufreq e000000.ccplex: probed with ICC
[ 8.589826] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 8.597222] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 8.598045] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[ 8.609342] tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff -> 0x0030100000
[ 8.618037] tegra194-pcie 14100000.pcie: MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[ 8.626726] tegra194-pcie 14100000.pcie: MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[ 8.644159] irq: IRQ292: trimming hierarchy from :interrupt-controller@f400000-1
[ 8.651848] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 292
[ 8.708283] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 8.740287] tegra194-pcie 14100000.pcie: Link up
[ 8.746178] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 8.752994] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 8.758638] pci_bus 0001:00: root bus resource [io 0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[ 8.768511] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[ 8.779343] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[ 8.787272] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 8.793596] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 8.803321] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[ 8.809670] pci 0001:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 8.815608] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[ 8.824050] pci 0001:01:00.0: supports D1 D2
[ 8.828447] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 8.839338] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[ 8.846792] pci 0001:00:00.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 8.853180] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff 64bit]
[ 8.861156] pci 0001:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 8.867452] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 8.872821] pci 0001:00:00.0: bridge window [io 0x1000-0x1fff]
[ 8.879154] pci 0001:00:00.0: bridge window [mem 0x20a8000000-0x20a80fffff]
[ 8.886535] pci 0001:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 8.895310] pci 0001:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 8.904263] pcieport 0001:00:00.0: Adding to iommu group 8
[ 8.910156] pcieport 0001:00:00.0: PME: Signaling with IRQ 55
[ 8.916640] pcieport 0001:00:00.0: AER: enabled with IRQ 55
[ 8.922552] usb 1-2: New USB device found, idVendor=2109, idProduct=2817, bcdDevice=90.23
[ 8.923219] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 8.930971] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.930973] usb 1-2: Product: USB2.0 Hub
[ 8.930976] usb 1-2: Manufacturer: VIA Labs, Inc.
[ 8.938688] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[ 8.962820] tegra194-pcie 14160000.pcie: IO 0x0036100000..0x00361fffff -> 0x0036100000
[ 8.971529] tegra194-pcie 14160000.pcie: MEM 0x2428000000..0x242fffffff -> 0x0040000000
[ 8.971558] hub 1-2:1.0: USB hub found
[ 8.980216] tegra194-pcie 14160000.pcie: MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[ 8.992927] hub 1-2:1.0: 4 ports detected
[ 9.029922] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using tegra-xusb
[ 9.100282] tegra194-pcie 14160000.pcie: Link up
[ 9.106095] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 9.112911] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 9.118546] pci_bus 0004:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[ 9.128702] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[ 9.139559] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[ 9.147494] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 9.153835] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 9.160771] usb 2-1: New USB device found, idVendor=2109, idProduct=0817, bcdDevice=90.23
[ 9.163466] pci 0004:01:00.0: [1e4b:1202] type 00 class 0x010802
[ 9.169194] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.169197] usb 2-1: Product: USB3.0 Hub
[ 9.175551] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 9.182710] usb 2-1: Manufacturer: VIA Labs, Inc.
[ 9.201916] pci 0004:01:00.0: PME# supported from D0 D3hot D3cold
[ 9.210383] hub 2-1:1.0: USB hub found
[ 9.212266] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280fffff]
[ 9.221720] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428000000-0x2428003fff 64bit]
[ 9.221874] hub 2-1:1.0: 4 ports detected
[ 9.229684] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 9.239121] pci 0004:00:00.0: bridge window [mem 0x2428000000-0x24280fffff]
[ 9.246494] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 9.255250] pci 0004:01:00.0: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
[ 9.264185] pcieport 0004:00:00.0: Adding to iommu group 9
[ 9.270047] pcieport 0004:00:00.0: PME: Signaling with IRQ 57
[ 9.272485] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[ 9.276464] pcieport 0004:00:00.0: AER: enabled with IRQ 57
[ 9.288949] nvme 0004:01:00.0: Adding to iommu group 9
[ 9.294701] nvme nvme0: pci function 0004:01:00.0
[ 9.299625] nvme 0004:01:00.0: enabling device (0000 -> 0002)
[ 9.300326] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[ 9.312270] vdd-3v3-sd: supplied by vdd-3v3
[ 9.316758] nvme nvme0: missing or invalid SUBNQN field.
[ 9.316941] irq: IRQ294: trimming hierarchy from :pmc@c360000
[ 9.329478] usb-conn-gpio 3520000.xusb_padctl:ports:usb2-0:connector: repeated role: 0
[ 9.330458] tegra194-isp5 14800000.isp: initialized
[ 9.331235] nvme nvme0: allocated 16 MiB host memory buffer.
[ 9.349953] nvme nvme0: 8/0/0 default/read/poll queues
[ 9.352477] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[ 9.361692] (NULL device *): fops function table already registered
[ 9.368959] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[ 9.371362] nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 9.376007] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 9.376113] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[ 9.376462] irq: IRQ303: trimming hierarchy from :interrupt-controller@f400000-1
[ 9.412313] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 292
[ 9.444428] usb 1-3: New USB device found, idVendor=13d3, idProduct=3549, bcdDevice= 0.00
[ 9.452847] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 9.460198] usb 1-3: Product: Bluetooth Radio
[ 9.464683] usb 1-3: Manufacturer: Realtek
[ 9.468891] usb 1-3: SerialNumber: 00e04c000001
[ 9.484761] tegra194-pcie 140a0000.pcie: host bridge /pcie@140a0000 ranges:
[ 9.491942] tegra194-pcie 140a0000.pcie: IO 0x002a100000..0x002a1fffff -> 0x002a100000
[ 9.500647] tegra194-pcie 140a0000.pcie: MEM 0x3528000000..0x352fffffff -> 0x0040000000
[ 9.509349] tegra194-pcie 140a0000.pcie: MEM 0x3240000000..0x3527ffffff -> 0x3240000000
[ 9.624282] tegra194-pcie 140a0000.pcie: Link up
[ 9.631088] tegra194-pcie 140a0000.pcie: PCI host bridge to bus 0008:00
[ 9.637911] pci_bus 0008:00: root bus resource [bus 00-ff]
[ 9.643556] pci_bus 0008:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x2a100000-0x2a1fffff])
[ 9.653672] pci_bus 0008:00: root bus resource [mem 0x3528000000-0x352fffffff] (bus address [0x40000000-0x47ffffff])
[ 9.664540] pci_bus 0008:00: root bus resource [mem 0x3240000000-0x3527ffffff pref]
[ 9.672483] pci 0008:00:00.0: [10de:229c] type 01 class 0x060400
[ 9.678830] pci 0008:00:00.0: PME# supported from D0 D3hot
[ 9.688609] pci 0008:01:00.0: [10ec:8168] type 00 class 0x020000
[ 9.695022] pci 0008:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 9.700967] pci 0008:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 9.708065] pci 0008:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 9.716075] pci 0008:01:00.0: supports D1 D2
[ 9.720470] pci 0008:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 9.731360] pci 0008:00:00.0: BAR 14: assigned [mem 0x3528000000-0x35280fffff]
[ 9.738792] pci 0008:00:00.0: BAR 13: assigned [io 0x200000-0x200fff]
[ 9.745514] pci 0008:01:00.0: BAR 4: assigned [mem 0x3528000000-0x3528003fff 64bit]
[ 9.753493] pci 0008:01:00.0: BAR 2: assigned [mem 0x3528004000-0x3528004fff 64bit]
[ 9.761463] pci 0008:01:00.0: BAR 0: assigned [io 0x200000-0x2000ff]
[ 9.768124] pci 0008:00:00.0: PCI bridge to [bus 01-ff]
[ 9.773499] pci 0008:00:00.0: bridge window [io 0x200000-0x200fff]
[ 9.780135] pci 0008:00:00.0: bridge window [mem 0x3528000000-0x35280fffff]
[ 9.787497] pci 0008:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 9.796240] pci 0008:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 9.805188] pcieport 0008:00:00.0: Adding to iommu group 10
[ 9.811142] pcieport 0008:00:00.0: PME: Signaling with IRQ 59
[ 9.817551] pcieport 0008:00:00.0: AER: enabled with IRQ 59
[ 9.824791] irq: IRQ305: trimming hierarchy from :pmc@c360000
[ 9.830777] irq: IRQ306: trimming hierarchy from :interrupt-controller@f400000-1
[ 9.838458] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 9.846523] tegra-se-nvhost 15810000.se: Adding to iommu group 50
[ 9.853370] tegra-se-nvhost 15810000.se: initialized
[ 9.868326] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 9.874702] tegra-se-nvhost 15820000.se: Adding to iommu group 51
[ 9.881374] tegra-se-nvhost 15820000.se: initialized
[ 9.889895] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 9.896289] tegra-se-nvhost 15840000.se: Adding to iommu group 52
[ 9.902972] tegra-se-nvhost 15840000.se: initialized
[ 9.912361] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 9.919236] tegra_actmon d230000.actmon: in actmon_register()...
[ 9.925795] tegra_actmon d230000.actmon: bwmgr_disable = 1
[ 9.932136] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 9.940513] hvc_sysfs: hypervisor is not present
��WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc1clk
��[ 9.962766] random: crng init done
[ 9.988951] ALSA device list:
[ 9.992008] No soundcards found.
[ 9.996136] Freeing unused kernel memory: 3968K
[ 10.000869] Run /init as init process
[ 10.017262] Root device found: PARTUUID=2665df59-76bb-4f9e-8ab2-334874e75584
[ 10.270649] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null)
[ 10.281437] Rootfs mounted over PARTUUID=2665df59-76bb-4f9e-8ab2-334874e75584
[ 10.300483] Switching from initrd to actual rootfs
[ 10.363551] systemd[1]: System time before build time, advancing clock.
[ 10.415944] systemd[1]: systemd 245.4-4ubuntu3.20 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +K)
[ 10.439656] systemd[1]: Detected architecture arm64.
[ 10.459859] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[ 10.480527] systemd[1]: Set hostname to <orin>.
[ 10.610805] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 10.623827] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 10.633580] systemd[1]: Created slice system-modprobe.slice.
[ 10.652675] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 10.672634] systemd[1]: Created slice User and Session Slice.
[ 10.692374] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 10.720533] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 10.744353] systemd[1]: Reached target User and Group Name Lookups.
[ 10.764311] systemd[1]: Reached target Slices.
[ 10.784303] systemd[1]: Reached target Mounting snaps.
[ 10.808299] systemd[1]: Reached target Mounted snaps.
[ 10.832302] systemd[1]: Reached target Swap.
[ 10.852299] systemd[1]: Reached target System Time Set.
[ 10.872696] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 10.892425] systemd[1]: Listening on Syslog Socket.
[ 10.912407] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 10.936364] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 10.956509] systemd[1]: Listening on Journal Audit Socket.
[ 10.976394] systemd[1]: Listening on Journal Socket (/dev/log).
[ 10.996420] systemd[1]: Listening on Journal Socket.
[ 11.016434] systemd[1]: Listening on udev Control Socket.
[ 11.036369] systemd[1]: Listening on udev Kernel Socket.
[ 11.057539] systemd[1]: Mounting Huge Pages File System...
[ 11.077435] systemd[1]: Mounting POSIX Message Queue File System...
[ 11.097315] systemd[1]: Mounting RPC Pipe File System...
[ 11.117362] systemd[1]: Mounting Kernel Debug File System...
[ 11.137379] systemd[1]: Mounting Kernel Trace File System...
[ 11.157630] systemd[1]: Starting Journal Service...
[ 11.177621] systemd[1]: Starting Set the console keyboard layout...
[ 11.201782] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 11.229422] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[ 11.256355] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 11.265781] systemd[1]: Starting Load Kernel Module efi_pstore...
[ 11.285398] systemd[1]: Starting Load Kernel Module pstore_blk...
[ 11.305270] systemd[1]: Starting Load Kernel Module pstore_zone...
[ 11.329235] systemd[1]: Starting Load Kernel Module ramoops...
[ 11.353387] systemd[1]: Starting NVIDIA specific first-boot udev script...
[ 11.381360] systemd[1]: Started Nameserver information manager.
[ 11.400446] systemd[1]: Reached target Network (Pre).
[ 11.425390] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 11.434754] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 11.445517] systemd[1]: Starting Load Kernel Modules...
[ 11.459074] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 11.466324] nvmap_page_pool_init: Total RAM pages: 3939456
[ 11.471974] nvmap_page_pool_init: nvmap page pool size: 492432 pages (1923 MB)
[ 11.479607] nvmap_background_zero_thread: PP zeroing thread starting.
[ 11.489448] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 11.497446] EXT4-fs (nvme0n1p1): re-mounted. Opts: (null)
[ 11.515277] nvgpu: 17000000.ga10b nvgpu_nvhost_syncpt_init:135 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[ 11.515277]
[ 11.541724] systemd[1]: Starting udev Coldplug all Devices...
[ 11.566125] systemd[1]: Started Journal Service.
[ 11.868789] systemd-journald[271]: Received client request to flush runtime journal.
[ 12.419583] nvidia: loading out-of-tree module taints kernel.
[ 12.496742] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[ 12.512418] imx219 10-0010: board setup failed
[ 12.518597] imx219: probe of 10-0010 failed with error -121
[ 12.855392] imx477 9-001a: imx477_board_setup: error during i2c read probe (-121)
[ 12.865215] imx477 9-001a: board setup failed
[ 12.874043] imx477: probe of 9-001a failed with error -121
[ 13.293475] using random self ethernet address
[ 13.298104] using random host ethernet address
[ 13.754672] using random self ethernet address
[ 13.759273] using random host ethernet address
[ 16.291328] Bridge firewalling registered
Ubuntu 20.04.6 LTS orin ttyTCU0
Ok, so it looks like the setup is correct.
Please check if the flash process prints any log from the console on the NG board.
Not sure why but this is the first time reflashing has worked on the NG board. The only difference this time should be that my usb-ttl cable is connected. Anyways, thanks for your quick replies!
Yes, as my previous comment says, not sure why the usb connection is not stable.
