Reflash Jetson Orin NX: QSPI error
I have a qspi error (at the end of the log) qhen I try to flash a board that is already flashed. Do I miss something ?
enterprise@Ubuntu-20:~/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh -r^C-external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" --showlogs --network usb0 client-board+p3767-0000 internal
enterprise@Ubuntu-20:~/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" --showlogs --network usb0 client-board+p3767-0000 internal
/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh --no-flash --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p -c bootloader/t186ref/cfg/flash_t234_qspi.xml --showlogs --network usb0 client-board+p3767-0000 internal
*  Step 1: Generate flash packages *
Create folder to store images to flash
Generate image for internal storage devices
Generate images to be flashed
ADDITIONAL_DTB_OVERLAY=""  /home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/flash.sh --no-flash --sign  -c bootloader/t186ref/cfg/flash_t234_qspi.xml client-board+p3767-0000 internal
# L4T BSP Information:
# R35 , REVISION: 3.1
# User release: 0.0
copying emc_fuse_dev_params(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-diag-boot.dts)... done.
copying device_config(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-device-p3767-0000.dts)... done.
copying misc_config(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-misc-p3767-0000.dts)... done.
./tegraflash.py --chip 0x23 --applet "/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3767-0000.dts --misc_config tegra234-mb1-bct-misc-p3767-0000.dts --bins "mb2_applet applet_t234.bin" --cmd "dump eeprom cvm cvm.bin; dump custinfo custinfo_out.bin; reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[   0.0219 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.0237 ] File rcm_state open failed
[   0.0242 ] ERROR: failed to read rcm_state
[   0.0242 ]
[   0.0269 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0272 ] Assuming zero filled SBK key
[   0.0248 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[   0.0412 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[   0.0581 ] Parsing partition layout
[   0.0602 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.0632 ] Kernel DTB used: None
[   0.0633 ] WARNING: dce base dtb is not provided
[   0.0633 ] Parsing partition layout
[   0.0645 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.0661 ] Creating list of images to be signed
[   0.0673 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[   0.0687 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.0696 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.0703 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.0805 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.0921 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.1022 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.1025 ] adding BCH for mb2_t234_aligned.bin
[   0.1062 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.1211 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.1215 ] adding BCH for mb2_t234_aligned.bin
[   0.1400 ] Filling MB1 storage info
[   0.1400 ] Parsing dev params for multi chains
[   0.1487 ] Generating br-bct
[   0.1504 ] Updating dev and MSS params in BR BCT
[   0.1504 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.1525 ] Updating bl info
[   0.1539 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[   0.1551 ] WARNING: boot chain is not completed. set to 0
[   0.1607 ] Generating signatures
[   0.1633 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.1636 ] Assuming zero filled SBK key
[   0.1864 ] Warning: pub_key.key is not found
[   0.1841 ] Parsing dev params for multi chains
[   0.1841 ] Generating br-bct
[   0.1852 ] Updating dev and MSS params in BR BCT
[   0.1853 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.1866 ] Updating bl info
[   0.1877 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.1889 ] WARNING: boot chain is not completed. set to 0
[   0.2027 ] Get Signed section of bct
[   0.2042 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   0.2058 ] Signing BCT
[   0.2085 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.2087 ] Assuming zero filled SBK key
[   0.2180 ] Sha saved in br_bct_BR.sha
[   0.2185 ] Warning: pub_key.key is not found
[   0.2159 ] Updating BCT with signature
[   0.2173 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   0.2185 ] Offset :4608 Len :3584
[   0.2258 ] Generating SHA2 Hash
[   0.2285 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   0.2287 ] Assuming zero filled SBK key
[   0.2345 ] Sha saved in br_bct_BR.sha
[   0.2323 ] Updating BCT with SHA2 Hash
[   0.2335 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   0.2345 ] Offset :4608 Len :3584
[   0.2348 ] Offset :68 Len :8124
[   0.2459 ] Generating coldboot mb1-bct
[   0.2476 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.2489 ] MB1-BCT version: 0.10
[   0.2492 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   0.2499 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   0.2503 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   0.2507 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   0.2512 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   0.2516 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   0.2522 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[   0.2522 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[   0.2522 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[   0.2522 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[   0.2522 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[   0.2522 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[   0.2522 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[   0.2522 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[   0.2522 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[   0.2522 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[   0.2522 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[   0.2522 ]
[   0.2522 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.2522 ] Added Platform Config 9 data with size :- 100
[   0.2522 ]
[   0.2523 ] Updating mb1-bct with firmware information
[   0.2538 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.2578 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   0.2602 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   0.2612 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   0.2647 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.2649 ] Assuming zero filled SBK key
[   0.2681 ] Warning: pub_key.key is not found
[   0.2667 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.2713 ] Generating recovery mb1-bct
[   0.2724 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.2735 ] MB1-BCT version: 0.10
[   0.2737 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   0.2742 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   0.2745 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   0.2748 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   0.2752 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   0.2755 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   0.2758 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[   0.2758 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[   0.2758 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[   0.2758 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[   0.2758 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[   0.2758 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[   0.2758 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[   0.2758 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[   0.2758 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[   0.2758 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[   0.2758 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[   0.2758 ]
[   0.2758 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.2758 ] Added Platform Config 9 data with size :- 100
[   0.2758 ]
[   0.2759 ] Updating mb1-bct with firmware information
[   0.2804 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.2848 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[   0.2870 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   0.2880 ] adding BCH for mb1_bct_MB1_aligned.bct
[   0.2915 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.2917 ] Assuming zero filled SBK key
[   0.2936 ] Warning: pub_key.key is not found
[   0.2922 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.3035 ] Error: Skip generating mem_bct because sdram_config is not defined
[   0.3035 ] Copying signatures
[   0.3049 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.3550 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   0.3552 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   0.3552 ] Boot Rom communication
[   0.3567 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   0.3580 ] BR_CID: 0x80012344705DD2996C00000009FD8140
[   0.4444 ] Sending bct_br
[   0.5558 ] Sending mb1
[   0.5740 ] Sending psc_bl1
[   0.6587 ] Sending bct_mb1
[   0.6975 ] Boot Rom communication completed
[   0.7010 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[   0.7060 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --appendsigheader applet_t234_aligned.bin zerosbk
[   0.7082 ] adding BCH for applet_t234_aligned.bin
[   0.7396 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.7398 ] Assuming zero filled SBK key
[   0.7430 ] Warning: pub_key.key is not found
[   0.7419 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[   0.7499 ] Sending mb2_applet...
[   0.7513 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[   0.7526 ] BL: version 0.32.0.0-t234-54845784-57325615 last_boot_error: 0
[   0.9056 ] Sending applet
[   1.1029 ] completed
[   1.1058 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   1.1085 ] MB2 Applet version 01.00.0000
[   1.4642 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   1.4669 ] MB2 Applet version 01.00.0000
[   1.7003 ] Retrieving board information
[   1.7026 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails chip chip_info.bin
[   1.7050 ] MB2 Applet version 01.00.0000
[   1.9691 ] Saved platform info in chip_info.bin
[   2.0564 ] Chip minor revision: 1
[   2.0567 ] Bootrom revision: 0x7
[   2.0570 ] Ram code: 0x0
[   2.0572 ] Chip sku: 0xd3
[   2.0574 ] Chip Sample: prod
[   2.0988 ] Retrieving EEPROM data
[   2.0990 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23 0
[   2.1017 ] MB2 Applet version 01.00.0000
[   2.3274 ] Saved platform info in /home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
[   2.5157 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   2.5181 ] MB2 Applet version 01.00.0000
[   2.7454 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   2.7480 ] MB2 Applet version 01.00.0000
[   2.9622 ] Dumping customer Info
[   2.9651 ] tegrarcm_v2 --chip 0x23 0 --oem dump bct tmp.bct
[   2.9677 ] MB2 Applet version 01.00.0000
[   3.2145 ] Saved bct in tmp.bct
[   3.3501 ] tegrabct_v2 --brbct tmp.bct --chip 0x23 0 --custinfo /home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/custinfo_out.bin
[   3.3512 ] C[   3.3516 ] ustomer data saved in /home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/custinfo_out.bin successfully
[   3.3516 ] Rebooting to recovery mode
[   3.3530 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[   3.5806 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   3.5837 ] MB2 Applet version 01.00.0000
[   3.8678 ] Booting to recovery mode
[   3.8699 ] tegrarcm_v2 --chip 0x23 0 --reboot recovery
[   3.8717 ] MB2 Applet version 01.00.0000
Board ID(3767) version(300) sku(0000) revision(G.3)
Chip SKU(00:00:00:D3) ramcode(00:00:00:00) fuselevel(fuselevel_production) board_FAB(300)
emc_opt_disable_fuse:(0)
Copy /home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/kernel/dtb/tegra234-p3767-0000-client-board-a0.dtb to /home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/kernel/dtb/tegra234-p3767-0000-client-board-a0.dtb.rec
Using UUID a0bf6b65-78f9-4933-ae0a-92844a08eea9 for mounting root APP partition.
copying bctfile(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-p3767-0000-sdram-l4t.dts)... done.
copying minratchet_config(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-ratchet-p3767-0000.dts)... done.
copying pinmux_config(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/Orin-client-board-pinmux.dtsi)... done.
copying gpioint_config(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-gpioint-p3767-0000.dts)... done.
copying pmic_config(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-pmic-p3767-0000-a02.dts)... done.
copying pmc_config(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/Orin-client-board-padvoltage-default.dtsi)... done.
copying deviceprod_config(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-cprod-p3767-0000.dts)... done.
copying prod_config(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-prod-p3767-0000.dts)... done.
copying scr_config(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb2-bct-scr-p3767-0000.dts)... done.
copying wb0sdram(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-p3767-0000-wb0sdram-l4t.dts)... done.
copying bootrom_config(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-reset-p3767-0000.dts)... done.
Existing uphylane_config(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/tegra234-mb1-bct-uphylane-si.dtsi) reused.
copying dev_params(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-p3767-0000-l4t.dts)... done.
copying dev_params_b(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct_b-p3767-0000-l4t.dts)... done.
copying mb2bct_cfg(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb2-bct-misc-p3767-0000.dts)... done.
Existing pscfwfile(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/pscfw_t234_prod.bin) reused.
Existing pscbl1file(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/psc_bl1_t234_prod.bin) reused.
Existing mtsmcefile(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/mce_flash_o10_cr_prod.bin) reused.
Existing mb2applet(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/applet_t234.bin) reused.
Existing bootloader(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
copying initrd(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
bl is uefi
Making Boot image... done.
Not signing of boot.img
Making recovery ramdisk for recovery image...
Re-generating recovery ramdisk for recovery image...
/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/ramdisk_tmp /home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader /home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra
39726 blocks
gzip: /home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/kernel/Image: not in gzip format
_BASE_KERNEL_VERSION=5.10.104-tegra
56174 blocks
Making Recovery image...
copying recdtbfile(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/kernel/dtb/tegra234-p3767-0000-client-board-a0.dtb.rec)... done.
20+0 records in
20+0 records out
20 bytes copied, 0,000281484 s, 71,1 kB/s
Existing sosfile(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing tegraboot(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing cpu_bootloader(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing mb2blfile(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing xusbfile(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/xusb_t234_prod.bin) reused.
Existing dcefile(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/display-t234-dce.bin) reused.
Existing nvdecfile(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/nvdec_t234_prod.fw) reused.
Existing psc_rf(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/psc_rf_t234_prod.bin) reused.
Existing mb2_rf(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/mb2rf_t234.bin) reused.
Existing mb1file(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing bpffile(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/bpmp_t234-TE990M-A1_prod.bin) reused.
copying bpfdtbfile(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/tegra234-bpmp-3767-0000-a02-3509-a02.dtb)... done.
Existing scefile(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/camera-rtcpu-t234-rce.img) reused.
Existing apefile(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/adsp-fw.bin) reused.
Existing spefile(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/spe_t234.bin) reused.
Existing wb0boot(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/sc7_t234_prod.bin) reused.
Existing tosfile(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/tos-optee_t234.img) reused.
Existing eksfile(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/eks_t234.img) reused.
copying dtbfile(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/kernel/dtb/tegra234-p3767-0000-client-board-a0.dtb)... done.
Copying nv_boot_control.conf to rootfs
	populating kernel to rootfs... done.
	populating initrd to rootfs... done.
	populating kernel_tegra234-p3767-0000-client-board-a0.dtb to rootfs... done.
Making system.img...
	Setting "FDT /boot/dtb/kernel_tegra234-p3767-0000-client-board-a0.dtb" successfully in the extlinux.conf...done.
	populating rootfs from /home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/rootfs ... 	populating /boot/extlinux/extlinux.conf ... done.
	Sync'ing system.img ... done.
	Converting RAW image to Sparse image... done.
system.img built successfully.
Not signing of kernel-dtb
Existing tbcfile(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/uefi_jetson.bin) reused.
131072+0 records in
131072+0 records out
67108864 bytes (67 MB, 64 MiB) copied, 0,400014 s, 168 MB/s
	Sync'ing esp.img ... done.
copying tbcdtbfile(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/kernel/dtb/tegra234-p3767-0000-client-board-a0.dtb)... done.
copying cfgfile(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/cfg/flash_t234_qspi.xml) to flash.xml... done.
Existing flashapp(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py) reused.
copying overlay_dtb(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/kernel/dtb/L4TConfiguration.dtbo)... done.
copying overlay_dtb(/home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/kernel/dtb/tegra234-p3767-overlay.dtbo)... done.
./tegraflash.py  --bl uefi_jetson_with_dtb.bin  --odmdata gbe-uphy-config-8,hsstp-lane-map-3,hsio-uphy-config-0  --overlay_dtb L4TConfiguration.dtbo,tegra234-p3767-overlay.dtbo,  --bldtb tegra234-p3767-0000-client-board-a0.dtb --applet mb1_t234_prod.bin --cmd "sign"  --cfg flash.xml --chip 0x23 --concat_cpubl_bldtb --cpubl uefi_jetson.bin --minratchet_config tegra234-mb1-bct-ratchet-p3767-0000.dts --device_config tegra234-mb1-bct-device-p3767-0000.dts --misc_config tegra234-mb1-bct-misc-p3767-0000.dts --pinmux_config Orin-client-board-pinmux.dtsi --gpioint_config tegra234-mb1-bct-gpioint-p3767-0000.dts --pmic_config tegra234-mb1-bct-pmic-p3767-0000-a02.dts --pmc_config Orin-client-board-padvoltage-default.dtsi --deviceprod_config tegra234-mb1-bct-cprod-p3767-0000.dts --prod_config tegra234-mb1-bct-prod-p3767-0000.dts --scr_config tegra234-mb2-bct-scr-p3767-0000.dts --wb0sdram_config tegra234-p3767-0000-wb0sdram-l4t.dts --br_cmd_config tegra234-mb1-bct-reset-p3767-0000.dts --uphy tegra234-mb1-bct-uphylane-si.dtsi --dev_params tegra234-br-bct-p3767-0000-l4t.dts,tegra234-br-bct_b-p3767-0000-l4t.dts --mb2bct_cfg tegra234-mb2-bct-misc-p3767-0000.dts  --bins "psc_fw pscfw_t234_prod.bin; mts_mce mce_flash_o10_cr_prod.bin; mb2_applet applet_t234.bin; mb2_bootloader mb2_t234.bin; xusb_fw xusb_t234_prod.bin; dce_fw display-t234-dce.bin; nvdec nvdec_t234_prod.fw; bpmp_fw bpmp_t234-TE990M-A1_prod.bin; bpmp_fw_dtb tegra234-bpmp-3767-0000-a02-3509-a02.dtb; sce_fw camera-rtcpu-sce.img; rce_fw camera-rtcpu-t234-rce.img; ape_fw adsp-fw.bin; spe_fw spe_t234.bin; tos tos-optee_t234.img; eks eks_t234.img"  --sdram_config tegra234-p3767-0000-sdram-l4t.dts  --cust_info custinfo_out.bin  --secondary_gpt_backup  --bct_backup  --boot_chain A
saving flash command in /home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/enterprise/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/flash_win.bat
*** Sign and generate flashing ready partition images... ***
version 1.0.0
[   0.0410 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0411 ] Assuming zero filled SBK key
[   0.0494 ] Parsing partition layout
[   0.0531 ] tegraparser_v2 --pt flash.xml.tmp
[   0.0658 ] Change tegra234-bpmp-3767-0000-a02-3509-a02.dtb to tegra234-bpmp-3767-0000-a02-3509-a02_with_odm.dtb
[   0.0973 ] /usr/bin/python3 dtbcheck.py -c t234 -o tegra234-bpmp-3767-0000-a02-3509-a02_with_odm.dtb tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_tmp.dtb
[   0.3632 ] Concatenating L4TConfiguration.dtbo,tegra234-p3767-overlay.dtbo to tegra234-p3767-0000-client-board-a0_with_odm_overlay.dtb
[   0.3634 ] Concatenating bl dtb to cpubl binary
[   0.3661 ] MB2 binary: mb2_t234.bin
[   0.3662 ] Pre-processing mb2bct config: tegra234-mb2-bct-misc-p3767-0000.dts
[   0.5580 ] Pre-processing mb2bct config: tegra234-mb2-bct-scr-p3767-0000.dts
[   1.2472 ] Generating coldboot mb2-bct
[   1.2472 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct.cfg --mb2bctcfg tegra234-mb2-bct-misc-p3767-0000_cpp.dtb --scr tegra234-mb2-bct-scr-p3767-0000_cpp.dtb
[   1.2493 ] WARNING: unknown property 'tfc_version'
[   1.2553 ] WARNING: unknown property 'addr_header_version'
[   1.2748 ] Updating mb2-bct with storage information
[   1.2773 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct_MB2.bct --updatestorageinfo flash.xml.bin
[   1.2936 ] Concatenating mb2-bct to mb2 binary
[   1.2936 ] mb2_bin_file = mb2_t234.bin
[   1.2936 ] mb2_bct_file = mb2_cold_boot_bct_MB2.bct
[   1.3014 ] DCE binary: display-t234-dce.bin
[   1.3015 ] Kernel DTB used: tegra234-p3767-0000-client-board-a0_with_odm_overlay.dtb
[   1.3015 ] Concatenating kernel-dtb to dce-fw binary
[   1.3015 ] dce_bin = display-t234-dce.bin
[   1.3015 ] kernel_dtb = tegra234-p3767-0000-client-board-a0_with_odm_overlay.dtb
[   1.3015 ] dce_with_dtb = display-t234-dce_with_tegra234-p3767-0000-client-board-a0_with_odm_overlay.bin
[   1.3517 ] Update display-t234-dce_with_tegra234-p3767-0000-client-board-a0_with_odm_overlay.bin to dce_fw partitions
[   1.3544 ] Parsing partition layout
[   1.3566 ] tegraparser_v2 --pt flash.xml.tmp
[   1.3592 ] Creating list of images to be signed
[   1.3619 ] Generating ratchet blob
[   1.3619 ] Pre-processing config: tegra234-mb1-bct-reset-p3767-0000.dts
[   1.3792 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[   1.3973 ] Pre-processing config: tegra234-mb1-bct-cprod-p3767-0000.dts
[   1.4113 ] Pre-processing config: tegra234-mb1-bct-gpioint-p3767-0000.dts
[   1.4208 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[   1.4383 ] Pre-processing config: Orin-client-board-pinmux.dtsi
[   1.4585 ] Pre-processing config: Orin-client-board-padvoltage-default.dtsi
[   1.4701 ] Pre-processing config: tegra234-mb1-bct-pmic-p3767-0000-a02.dts
[   1.4821 ] Pre-processing config: tegra234-mb1-bct-prod-p3767-0000.dts
[   1.5004 ] Pre-processing config: tegra234-p3767-0000-sdram-l4t.dts
[   3.6837 ] Pre-processing config: tegra234-mb1-bct-uphylane-si.dtsi
[   3.6955 ] Pre-processing config: tegra234-p3767-0000-wb0sdram-l4t.dts
[   5.8856 ] Pre-processing config: tegra234-mb1-bct-ratchet-p3767-0000.dts
[   5.9047 ] Generating coldboot mb1-bct
[   5.9076 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --wb0sdram tegra234-p3767-0000-wb0sdram-l4t_cpp.dtb --pinmux Orin-client-board-pinmux_cpp.dtb --pmc Orin-client-board-padvoltage-default_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3767-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3767-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[   5.9106 ] MB1-BCT version: 0.10
[   5.9110 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   5.9124 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   5.9129 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   5.9133 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   5.9138 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   5.9143 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   5.9147 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[   5.9150 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[   5.9155 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[   5.9159 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[   5.9161 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[   5.9164 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[   5.9168 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[   5.9171 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[   5.9174 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[   5.9178 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[   5.9181 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[   5.9185 ] Parsing config file :Orin-client-board-pinmux_cpp.dtb
[   5.9188 ] WARNING: unknown property 'nvidia,schmitt'
[   5.9191 ] Added Platform Config 0 data with size :- 2640
[   5.9219 ] Parsing config file :Orin-client-board-padvoltage-default_cpp.dtb
[   5.9223 ] WARNING: unknown node 'g2'
[   5.9225 ] WARNING: unknown node 'g2'
[   5.9226 ] WARNING: unknown node 'g9'
[   5.9230 ] WARNING: unknown node 'g9'
[   5.9230 ] Added Platform Config 2 data with size :- 24
[   5.9230 ]
[   5.9230 ] Parsing config file :tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb
[   5.9230 ] Added Platform Config 4 data with size :- 288
[   5.9230 ]
[   5.9230 ] Parsing config file :tegra234-mb1-bct-reset-p3767-0000_cpp.dtb
[   5.9230 ] Added Platform Config 3 data with size :- 52
[   5.9231 ]
[   5.9231 ] Parsing config file :tegra234-mb1-bct-prod-p3767-0000_cpp.dtb
[   5.9231 ] WARNING: unknown property 'major'
[   5.9231 ] WARNING: unknown property 'minor'
[   5.9231 ] Added Platform Config 5 data with size :- 500
[   5.9231 ]
[   5.9231 ] Parsing config file :tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb
[   5.9231 ] Added Platform Config 7 data with size :- 380
[   5.9231 ]
[   5.9231 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[   5.9231 ] Added Platform Config 8 data with size :- 24
[   5.9231 ]
[   5.9231 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   5.9231 ] Added Platform Config 9 data with size :- 100
[   5.9231 ]
[   5.9231 ] Parsing config file :tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[   5.9231 ] ModuleCount 0 NumProdNames 0
[   5.9231 ] Added Platform Config 6 data with size :- 16
[   5.9231 ]
[   5.9231 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[   5.9231 ]
[   5.9232 ] Updating mb1-bct with firmware information
[   5.9247 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[   5.9750 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   5.9788 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   5.9800 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   5.9877 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.9880 ] Assuming zero filled SBK key
[   5.9959 ] Warning: pub_key.key is not found
[   5.9920 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   5.9953 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[   5.9972 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   5.9989 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   5.9994 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   6.0121 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   6.0125 ] Header already present for nvdec_t234_prod_aligned.fw
[   6.0138 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[   6.0213 ] adding BCH for xusb_t234_prod_aligned.bin
[   6.0384 ] Header already present for bpmp_t234-TE990M-A1_prod_aligned.bin
[   6.0476 ] adding BCH for tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_aligned.dtb
[   6.0675 ] Header already present for pscfw_t234_prod_aligned.bin
[   6.0731 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[   6.0810 ] Header already present for sc7_t234_prod.bin
[   6.0895 ] Header already present for psc_rf_t234_prod_aligned.bin
[   6.0940 ] adding BCH for mb2rf_t234_aligned.bin
[   6.0972 ] adding BCH for uefi_jetson_with_dtb_aligned.bin
[   6.1089 ] adding BCH for tos-optee_t234_aligned.img
[   6.2236 ] adding BCH for eks_t234_aligned.img
[   6.2684 ] INFO: compressing display-t234-dce_with_tegra234-p3767-0000-client-board-a0_with_odm_overlay_aligned.bin
[   6.4538 ] INFO: complete compression, display-t234-dce_with_tegra234-p3767-0000-client-board-a0_with_odm_overlay_aligned.bin, ratio = 7%
[   6.4753 ] adding BCH for display-t234-dce_with_tegra234-p3767-0000-client-board-a0_with_odm_overlay_aligned_blob_w_bin_aligned.bin
[   6.4952 ] adding BCH for spe_t234_aligned.bin
[   6.5087 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[   6.5207 ] adding BCH for adsp-fw_aligned.bin
[   6.5515 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   6.5667 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   6.5674 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   6.5920 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   6.5929 ] Header already present for nvdec_t234_prod_aligned.fw
[   6.5955 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[   6.6212 ] adding BCH for xusb_t234_prod_aligned.bin
[   6.6389 ] Header already present for bpmp_t234-TE990M-A1_prod_aligned.bin
[   6.6480 ] adding BCH for tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_aligned.dtb
[   6.6675 ] Header already present for pscfw_t234_prod_aligned.bin
[   6.6732 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[   6.6805 ] Header already present for sc7_t234_prod.bin
[   6.6839 ] Header already present for psc_rf_t234_prod_aligned.bin
[   6.6874 ] adding BCH for mb2rf_t234_aligned.bin
[   6.6899 ] adding BCH for uefi_jetson_with_dtb_aligned.bin
[   6.7025 ] adding BCH for tos-optee_t234_aligned.img
[   6.8158 ] adding BCH for eks_t234_aligned.img
[   6.8547 ] INFO: compressing display-t234-dce_with_tegra234-p3767-0000-client-board-a0_with_odm_overlay_aligned.bin
[   7.0606 ] INFO: complete compression, display-t234-dce_with_tegra234-p3767-0000-client-board-a0_with_odm_overlay_aligned.bin, ratio = 7%
[   7.0821 ] adding BCH for display-t234-dce_with_tegra234-p3767-0000-client-board-a0_with_odm_overlay_aligned_blob_w_bin_aligned.bin
[   7.1014 ] adding BCH for spe_t234_aligned.bin
[   7.1167 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[   7.1248 ] adding BCH for adsp-fw_aligned.bin
[   7.1598 ] Filling MB1 storage info
[   7.1598 ] Parsing dev params for multi chains
[   7.1757 ] Generating br-bct
[   7.1770 ] Updating dev and MSS params in BR BCT
[   7.1771 ] tegrabct_v2 --dev_param tegra234-br-bct-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0000-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   7.2972 ] Updating bl info
[   7.2996 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[   7.3556 ] Generating br-bct
[   7.3574 ] Updating dev and MSS params in BR BCT
[   7.3574 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0000-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   7.4726 ] Updating bl info
[   7.4743 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[   7.4763 ] Generating BCT backup image
[   7.4764 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[   7.4776 ] 32768+0 records in
[   7.5288 ] 32768+0 records out
[   7.5288 ] 32768 bytes (33 kB, 32 KiB) copied, 0,0505346 s, 648 kB/s
[   7.5288 ]
[   7.5289 ] Concatenating BCT for chain A to bct_backup.img
[   7.5289 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[   7.5308 ] 8192+0 records in
[   7.5406 ] 8192+0 records out
[   7.5406 ] 8192 bytes (8,2 kB, 8,0 KiB) copied, 0,00926941 s, 884 kB/s
[   7.5406 ]
[   7.5406 ] Concatenating BCT for chain B to bct_backup.img
[   7.5406 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[   7.5423 ] 8192+0 records in
[   7.5546 ] 8192+0 records out
[   7.5546 ] 8192 bytes (8,2 kB, 8,0 KiB) copied, 0,0116205 s, 705 kB/s
[   7.5546 ]
[   7.5546 ] Generating signatures
[   7.5610 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[   7.5613 ] Assuming zero filled SBK key
[   7.7448 ] Warning: pub_key.key is not found
[   7.7427 ] Parsing dev params for multi chains
[   7.7428 ] Generating br-bct
[   7.7455 ] Updating dev and MSS params in BR BCT
[   7.7456 ] tegrabct_v2 --dev_param tegra234-br-bct-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0000-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   7.8790 ] Updating customer data section
[   7.8818 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[   7.8966 ] Updating bl info
[   7.8996 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   7.9061 ] Get Signed section of bct
[   7.9086 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   7.9119 ] Signing BCT
[   7.9184 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   7.9188 ] Assuming zero filled SBK key
[   7.9255 ] Sha saved in br_bct_BR.sha
[   7.9259 ] Warning: pub_key.key is not found
[   7.9196 ] Updating BCT with signature
[   7.9210 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   7.9224 ] Offset :4608 Len :3584
[   7.9242 ] Generating SHA2 Hash
[   7.9306 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   7.9309 ] Assuming zero filled SBK key
[   7.9418 ] Sha saved in br_bct_BR.sha
[   7.9360 ] Updating BCT with SHA2 Hash
[   7.9374 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   7.9388 ] Offset :4608 Len :3584
[   7.9396 ] Offset :68 Len :8124
[   7.9406 ] Generating br-bct
[   7.9419 ] Updating dev and MSS params in BR BCT
[   7.9420 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0000-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   8.0758 ] Updating customer data section
[   8.0779 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[   8.0816 ] Updating bl info
[   8.0837 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   8.0889 ] Get Signed section of bct
[   8.0912 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   8.0945 ] Signing BCT
[   8.1010 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   8.1013 ] Assuming zero filled SBK key
[   8.1123 ] Sha saved in br_bct_BR.sha
[   8.1129 ] Warning: pub_key.key is not found
[   8.1067 ] Updating BCT with signature
[   8.1085 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   8.1098 ] Offset :4608 Len :3584
[   8.1325 ] Generating SHA2 Hash
[   8.1389 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   8.1392 ] Assuming zero filled SBK key
[   8.1439 ] Sha saved in br_bct_BR.sha
[   8.1381 ] Updating BCT with SHA2 Hash
[   8.1395 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   8.1408 ] Offset :4608 Len :3584
[   8.1411 ] Offset :68 Len :8124
[   8.1450 ] Generating BCT backup image
[   8.1450 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[   8.1470 ] 32768+0 records in
[   8.1991 ] 32768+0 records out
[   8.1991 ] 32768 bytes (33 kB, 32 KiB) copied, 0,0514046 s, 637 kB/s
[   8.1991 ]
[   8.1991 ] Concatenating BCT for chain A to bct_backup.img
[   8.1992 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[   8.2009 ] 8192+0 records in
[   8.2112 ] 8192+0 records out
[   8.2112 ] 8192 bytes (8,2 kB, 8,0 KiB) copied, 0,00967107 s, 847 kB/s
[   8.2112 ]
[   8.2112 ] Concatenating BCT for chain B to bct_backup.img
[   8.2112 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[   8.2132 ] 8192+0 records in
[   8.2257 ] 8192+0 records out
[   8.2257 ] 8192 bytes (8,2 kB, 8,0 KiB) copied, 0,0115712 s, 708 kB/s
[   8.2257 ]
[   8.2257 ] Generating coldboot mb1-bct
[   8.2274 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --wb0sdram tegra234-p3767-0000-wb0sdram-l4t_cpp.dtb --pinmux Orin-client-board-pinmux_cpp.dtb --pmc Orin-client-board-padvoltage-default_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3767-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3767-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[   8.2289 ] MB1-BCT version: 0.10
[   8.2291 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   8.2297 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   8.2300 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   8.2303 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   8.2306 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   8.2311 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   8.2314 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[   8.2317 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[   8.2320 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[   8.2325 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[   8.2328 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[   8.2331 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[   8.2335 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[   8.2339 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[   8.2342 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[   8.2344 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[   8.2347 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[   8.2350 ] Parsing config file :Orin-client-board-pinmux_cpp.dtb
[   8.2353 ] WARNING: unknown property 'nvidia,schmitt'
[   8.2355 ] Added Platform Config 0 data with size :- 2640
[   8.2373 ] Parsing config file :Orin-client-board-padvoltage-default_cpp.dtb
[   8.2376 ] WARNING: unknown node 'g2'
[   8.2377 ] WARNING: unknown node 'g2'
[   8.2379 ] WARNING: unknown node 'g9'
[   8.2380 ] WARNING: unknown node 'g9'
[   8.2381 ] Added Platform Config 2 data with size :- 24
[   8.2383 ] Parsing config file :tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb
[   8.2386 ] Added Platform Config 4 data with size :- 288
[   8.2388 ] Parsing config file :tegra234-mb1-bct-reset-p3767-0000_cpp.dtb
[   8.2391 ] Added Platform Config 3 data with size :- 52
[   8.2393 ]
[   8.2393 ] Parsing config file :tegra234-mb1-bct-prod-p3767-0000_cpp.dtb
[   8.2393 ] WARNING: unknown property 'major'
[   8.2393 ] WARNING: unknown property 'minor'
[   8.2393 ] Added Platform Config 5 data with size :- 500
[   8.2393 ]
[   8.2393 ] Parsing config file :tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb
[   8.2393 ] Added Platform Config 7 data with size :- 380
[   8.2394 ]
[   8.2394 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[   8.2394 ] Added Platform Config 8 data with size :- 24
[   8.2394 ]
[   8.2394 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   8.2394 ] Added Platform Config 9 data with size :- 100
[   8.2394 ]
[   8.2394 ] Parsing config file :tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[   8.2394 ] ModuleCount 0 NumProdNames 0
[   8.2394 ] Added Platform Config 6 data with size :- 16
[   8.2394 ]
[   8.2394 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[   8.2394 ]
[   8.2394 ] Updating mb1-bct with firmware information
[   8.2418 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[   8.2491 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   8.2591 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   8.2609 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   8.2689 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   8.2691 ] Assuming zero filled SBK key
[   8.2721 ] Warning: pub_key.key is not found
[   8.2673 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   8.2693 ] Generating recovery mb1-bct
[   8.2711 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --wb0sdram tegra234-p3767-0000-wb0sdram-l4t_cpp.dtb --pinmux Orin-client-board-pinmux_cpp.dtb --pmc Orin-client-board-padvoltage-default_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3767-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3767-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[   8.2732 ] MB1-BCT version: 0.10
[   8.2735 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   8.2742 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   8.2745 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   8.2749 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   8.2753 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   8.2756 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   8.2760 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[   8.2764 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[   8.2767 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[   8.2772 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[   8.2775 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[   8.2778 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[   8.2782 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[   8.2786 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[   8.2790 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[   8.2793 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[   8.2796 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[   8.2802 ] Parsing config file :Orin-client-board-pinmux_cpp.dtb
[   8.2805 ] WARNING: unknown property 'nvidia,schmitt'
[   8.2812 ] Added Platform Config 0 data with size :- 2640
[   8.2812 ]
[   8.2812 ] Parsing config file :Orin-client-board-padvoltage-default_cpp.dtb
[   8.2812 ] WARNING: unknown node 'g2'
[   8.2812 ] WARNING: unknown node 'g9'
[   8.2812 ] Added Platform Config 2 data with size :- 24
[   8.2812 ]
[   8.2812 ] Parsing config file :tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb
[   8.2812 ] Added Platform Config 4 data with size :- 288
[   8.2812 ]
[   8.2812 ] Parsing config file :tegra234-mb1-bct-reset-p3767-0000_cpp.dtb
[   8.2812 ] Added Platform Config 3 data with size :- 52
[   8.2812 ]
[   8.2812 ] Parsing config file :tegra234-mb1-bct-prod-p3767-0000_cpp.dtb
[   8.2812 ] WARNING: unknown property 'major'
[   8.2812 ] WARNING: unknown property 'minor'
[   8.2812 ] Added Platform Config 5 data with size :- 500
[   8.2812 ]
[   8.2812 ] Parsing config file :tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb
[   8.2813 ] WARNING: unknown property 'major'
[   8.2813 ] WARNING: unknown property 'minor'
[   8.2813 ] Added Platform Config 7 data with size :- 380
[   8.2813 ]
[   8.2813 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[   8.2813 ] Added Platform Config 8 data with size :- 24
[   8.2813 ]
[   8.2813 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   8.2813 ] Added Platform Config 9 data with size :- 100
[   8.2813 ]
[   8.2813 ] Parsing config file :tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[   8.2813 ] ModuleCount 0 NumProdNames 0
[   8.2813 ] Added Platform Config 6 data with size :- 16
[   8.2813 ]
[   8.2813 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[   8.2813 ]
[   8.2814 ] Updating mb1-bct with firmware information
[   8.2834 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo flash.xml.bin
[   8.2871 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[   8.2901 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   8.2916 ] adding BCH for mb1_bct_MB1_aligned.bct
[   8.2991 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   8.2993 ] Assuming zero filled SBK key
[   8.3021 ] Warning: pub_key.key is not found
[   8.2976 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   8.3004 ] Generating coldboot mem-bct
[   8.3020 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3767-0000-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3767-0000-wb0sdram-l4t_cpp.dtb --membct tegra234-p3767-0000-sdram-l4t_cpp_1.bct tegra234-p3767-0000-sdram-l4t_cpp_2.bct tegra234-p3767-0000-sdram-l4t_cpp_3.bct tegra234-p3767-0000-sdram-l4t_cpp_4.bct
[   8.3035 ]  packing sdram params with Wb0 file tegra234-p3767-0000-wb0sdram-l4t_cpp.dtb
[   8.4360 ] Packing sdram param for instance[0]
[   8.4363 ] Packing sdram param for instance[1]
[   8.4367 ] Packing sdram param for instance[2]
[   8.4370 ] Packing sdram param for instance[3]
[   8.4374 ] Packing sdram param for instance[4]
[   8.4377 ] Packing sdram param for instance[5]
[   8.4380 ] Packing sdram param for instance[6]
[   8.4383 ] Packing sdram param for instance[7]
[   8.4386 ] Packing sdram param for instance[8]
[   8.4389 ] Packing sdram param for instance[9]
[   8.4393 ] Packing sdram param for instance[10]
[   8.4396 ] Packing sdram param for instance[11]
[   8.4400 ] Packing sdram param for instance[12]
[   8.4403 ] Packing sdram param for instance[13]
[   8.4406 ] Packing sdram param for instance[14]
[   8.4408 ] Packing sdram param for instance[15]
[   8.5478 ] Getting sector size from pt
[   8.5504 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[   8.5531 ] BlockSize read from layout is 0x200
[   8.5555 ] tegrahost_v2 --chip 0x23 0 --blocksize 512 --magicid MEMB --addsigheader_multi tegra234-p3767-0000-sdram-l4t_cpp_1.bct tegra234-p3767-0000-sdram-l4t_cpp_2.bct tegra234-p3767-0000-sdram-l4t_cpp_3.bct tegra234-p3767-0000-sdram-l4t_cpp_4.bct
[   8.5576 ] Binary 0 length is 58752
[   8.5581 ] Binary 0 align length is 58880
[   8.5592 ] Binary 1 length is 58752
[   8.5599 ] Binary 1 align length is 58880
[   8.5604 ] Binary 2 length is 58752
[   8.5607 ] Binary 2 align length is 58880
[   8.5623 ] Binary 3 length is 58752
[   8.5625 ] Binary 3 align length is 58880
[   8.5627 ] Buffer length is 235520
[   8.5629 ] adding BCH for tegra234-p3767-0000-sdram-l4t_cpp_1.bct
[   8.5629 ] new length is 243712
[   8.5629 ]
[   8.5655 ] tegrahost_v2 --chip 0x23 0 --align mem_coldboot_aligned.bct
[   8.5706 ] tegrahost_v2 --chip 0x23 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_coldboot_aligned.bct zerosbk
[   8.5727 ] Header already present for mem_coldboot_aligned.bct
[   8.5802 ] tegrasign_v3.py --key None --list mem_coldboot_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   8.5806 ] Assuming zero filled SBK key
[   8.5872 ] Warning: pub_key.key is not found
[   8.5844 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_coldboot_aligned_sigheader.bct.encrypt mem_coldboot_aligned_sigheader.bct.hash zerosbk
[   8.5909 ] Generating recovery mem-bct
[   8.5932 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3767-0000-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3767-0000-wb0sdram-l4t_cpp.dtb --membct tegra234-p3767-0000-sdram-l4t_cpp_1.bct tegra234-p3767-0000-sdram-l4t_cpp_2.bct tegra234-p3767-0000-sdram-l4t_cpp_3.bct tegra234-p3767-0000-sdram-l4t_cpp_4.bct
[   8.5952 ]  packing sdram params with Wb0 file tegra234-p3767-0000-wb0sdram-l4t_cpp.dtb
[   8.7139 ] Packing sdram param for instance[0]
[   8.7141 ] Packing sdram param for instance[1]
[   8.7143 ] Packing sdram param for instance[2]
[   8.7145 ] Packing sdram param for instance[3]
[   8.7147 ] Packing sdram param for instance[4]
[   8.7149 ] Packing sdram param for instance[5]
[   8.7151 ] Packing sdram param for instance[6]
[   8.7153 ] Packing sdram param for instance[7]
[   8.7155 ] Packing sdram param for instance[8]
[   8.7157 ] Packing sdram param for instance[9]
[   8.7159 ] Packing sdram param for instance[10]
[   8.7162 ] Packing sdram param for instance[11]
[   8.7164 ] Packing sdram param for instance[12]
[   8.7166 ] Packing sdram param for instance[13]
[   8.7168 ] Packing sdram param for instance[14]
[   8.7170 ] Packing sdram param for instance[15]
[   8.8292 ] Reading ramcode from backup chip_info.bin file
[   8.8294 ] RAMCODE Read from Device: 0
---- Cut because too long ----
*  Step 3: Start the flashing process *
Waiting for target to boot-up...
Waiting for device to expose ssh ......RTNETLINK answers: File exists
Waiting for device to expose ssh ...Run command: flash on fc00:1:1:0::2
SSH ready
blockdev: cannot open /dev/mmcblk0boot0: No such file or directory
[ 0]: l4t_flash_from_kernel: Starting to create gpt for emmc
Active index file is /mnt/internal/flash.idx
Number of lines is 58
max_index=57
[ 5]: l4t_flash_from_kernel: Successfully create gpt for emmc
[ 5]: l4t_flash_from_kernel: Starting to create gpt for external device
Active index file is /mnt/external/flash.idx
Number of lines is 17
max_index=16
writing item=1, 9:0:primary_gpt, 512, 19968, gpt_primary_9_0.bin, 16896, fixed-<reserved>-0, 552a8f7e947ac86d15459975888809bfbbdb0589
Writing primary_gpt partition with gpt_primary_9_0.bin
Offset is not aligned to K Bytes, no optimization is applied
dd if=/mnt/external/gpt_primary_9_0.bin of=/dev/nvme0n1 bs=1 skip=0  seek=512 count=16896
16896+0 records in
16896+0 records out
16896 bytes (17 kB, 16 KiB) copied, 0.0189181 s, 893 kB/s
Writing primary_gpt partition done
Error: The backup GPT table is corrupt, but the primary appears OK, so that will be used.
Warning: Not all of the space available to /dev/nvme0n1 appears to be used, you can fix the GPT to use all of the space (an extra 380580527 blocks) or continue with the current setting?
Writing secondary_gpt partition with gpt_secondary_9_0.bin
dd if=/mnt/external/gpt_secondary_9_0.bin of=/dev/nvme0n1 bs=1 skip=0  seek=61203267072 count=16896
16896+0 records in
16896+0 records out
16896 bytes (17 kB, 16 KiB) copied, 0.0198966 s, 849 kB/s
Writing secondary_gpt partition done
Error: The backup GPT table is not at the end of the disk, as it should be.  Fix, by moving the backup to the end (and removing the old backup)?
Fix/Ignore? Fix
Fix/Ignore? Fix
Model: BIWIN SSD (nvme)
Disk /dev/nvme0n1: 256GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number  Start   End     Size    File system  Name                       Flags
 2      20.5kB  67.1MB  67.1MB               kernel                     msftdata
 3      67.1MB  67.6MB  459kB                kernel-dtb                 msftdata
 4      67.6MB  101MB   33.6MB               reserved_for_chain_A_user  msftdata
 5      101MB   168MB   67.1MB               kernel_b                   msftdata
 6      168MB   169MB   459kB                kernel-dtb_b               msftdata
 7      169MB   202MB   33.6MB               reserved_for_chain_B_user  msftdata
 8      202MB   286MB   83.9MB               recovery                   msftdata
 9      286MB   287MB   524kB                recovery-dtb               msftdata
10      287MB   601MB   315MB                RECROOTFS                  msftdata
11      601MB   668MB   67.1MB  fat32        esp                        boot, esp
12      668MB   752MB   83.9MB               recovery_alt               msftdata
13      752MB   753MB   524kB                recovery-dtb_alt           msftdata
14      753MB   820MB   67.1MB               esp_alt                    msftdata
 1      820MB   59.9GB  59.1GB  ext4         APP                        msftdata
[ 8]: l4t_flash_from_kernel: Successfully create gpt for external device
Flash index file is /mnt/internal/flash.idx
max_index=57
[ 8]: l4t_flash_from_kernel: Starting to flash to emmc
max_index=57
[ 8]: l4t_flash_from_kernel: Starting to flash to external device
max_index=16
[ 8]: l4t_flash_from_kernel: Starting to flash to qspi
mtd_debug: error!: open()
writing item=0, 9:0:master_boot_record, 0, 512, mbr_9_0.bin, 512, fixed-<reserved>-0, 694898d1c345bdb31b377790ed7fc0b0db184bf7
QSPI storage size:  bytes.
writing item=2, 9:0:kernel, 20480, 67108864, boot.img, 43902976, fixed-<reserved>-2, 98bcc1ff98d201d29731b1cc2592185af182f825
Writing kernel partition with boot.img
Get size of partition through connection.
43902976 bytes from /mnt/external/boot.img to /dev/nvme0n1: 1KB block=42874 remainder=0
dd if=/mnt/external/boot.img of=/dev/nvme0n1 bs=1K skip=0  seek=20 count=42874
42874+0 records in
42874+0 records out
43902976 bytes (44 MB, 42 MiB) copied, 7.33354 s, 6.0 MB/s
Writing kernel partition done
writing item=3, 9:0:kernel-dtb, 67129344, 458752, kernel_tegra234-p3767-0000-client-board-a0.dtb, 202222, fixed-<reserved>-3, eba2a2781c01840cb7606f8e0ca613b2d5529ab2
Writing kernel-dtb partition with kernel_tegra234-p3767-0000-client-board-a0.dtb
202222 bytes from /mnt/external/kernel_tegra234-p3767-0000-client-board-a0.dtb to /dev/nvme0n1: 1KB block=197 remainder=494
dd if=/mnt/external/kernel_tegra234-p3767-0000-client-board-a0.dtb of=/dev/nvme0n1 bs=1K skip=0  seek=65556 count=197
197+0 records in
197+0 records out
201728 bytes (202 kB, 197 KiB) copied, 0.0336673 s, 6.0 MB/s
dd if=/mnt/external/kernel_tegra234-p3767-0000-client-board-a0.dtb of=/dev/nvme0n1 bs=1 skip=201728  seek=67331072 count=494
494+0 records in
494+0 records out
494 bytes copied, 0.00163299 s, 303 kB/s
Writing kernel-dtb partition done
writing item=4, 9:0:reserved_for_chain_A_user, 67588096, 33554432, , , fixed-<reserved>-4,
[ 16]: l4t_flash_from_kernel: Warning: skip writing reserved_for_chain_A_user partition as no image is specified
writing item=5, 9:0:kernel_b, 101142528, 67108864, boot.img, 43902976, fixed-<reserved>-5, 98bcc1ff98d201d29731b1cc2592185af182f825
Writing kernel_b partition with boot.img
dd if=/mnt/external/boot.img of=/dev/nvme0n1 bs=1K skip=0  seek=98772 count=42874
42874+0 records in
42874+0 records out
43902976 bytes (44 MB, 42 MiB) copied, 1.01495 s, 43.3 MB/s
Writing kernel_b partition done
writing item=6, 9:0:kernel-dtb_b, 168251392, 458752, kernel_tegra234-p3767-0000-client-board-a0.dtb, 202222, fixed-<reserved>-6, eba2a2781c01840cb7606f8e0ca613b2d5529ab2
Writing kernel-dtb_b partition with kernel_tegra234-p3767-0000-client-board-a0.dtb
dd if=/mnt/external/kernel_tegra234-p3767-0000-client-board-a0.dtb of=/dev/nvme0n1 bs=1K skip=0  seek=164308 count=197
197+0 records in
197+0 records out
201728 bytes (202 kB, 197 KiB) copied, 0.0048792 s, 41.3 MB/s
dd if=/mnt/external/kernel_tegra234-p3767-0000-client-board-a0.dtb of=/dev/nvme0n1 bs=1 skip=201728  seek=168453120 count=494
494+0 records in
494+0 records out
494 bytes copied, 0.000621568 s, 795 kB/s
Writing kernel-dtb_b partition done
writing item=7, 9:0:reserved_for_chain_B_user, 168710144, 33554432, , , fixed-<reserved>-7,
[ 17]: l4t_flash_from_kernel: Warning: skip writing reserved_for_chain_B_user partition as no image is specified
writing item=8, 9:0:recovery, 202264576, 83886080, recovery.img, 47552512, fixed-<reserved>-8, d4e48a696d6f5a183c4ff8c1094b084c0322d67e
Writing recovery partition with recovery.img
47552512 bytes from /mnt/external/recovery.img to /dev/nvme0n1: 1KB block=46438 remainder=0
dd if=/mnt/external/recovery.img of=/dev/nvme0n1 bs=1K skip=0  seek=197524 count=46438
[ 18]: l4t_flash_from_kernel: Successfully flash the emmc
46438+0 records in
46438+0 records out
47552512 bytes (48 MB, 45 MiB) copied, 7.5918 s, 6.3 MB/s
Writing recovery partition done
writing item=9, 9:0:recovery-dtb, 286150656, 524288, tegra234-p3767-0000-client-board-a0.dtb.rec, 202222, fixed-<reserved>-9, eba2a2781c01840cb7606f8e0ca613b2d5529ab2
Writing recovery-dtb partition with tegra234-p3767-0000-client-board-a0.dtb.rec
202222 bytes from /mnt/external/tegra234-p3767-0000-client-board-a0.dtb.rec to /dev/nvme0n1: 1KB block=197 remainder=494
dd if=/mnt/external/tegra234-p3767-0000-client-board-a0.dtb.rec of=/dev/nvme0n1 bs=1K skip=0  seek=279444 count=197
197+0 records in
197+0 records out
201728 bytes (202 kB, 197 KiB) copied, 0.0391543 s, 5.2 MB/s
dd if=/mnt/external/tegra234-p3767-0000-client-board-a0.dtb.rec of=/dev/nvme0n1 bs=1 skip=201728  seek=286352384 count=494
494+0 records in
494+0 records out
494 bytes copied, 0.00224704 s, 220 kB/s
Writing recovery-dtb partition done
writing item=10, 9:0:RECROOTFS, 286674944, 314572800, , , fixed-<reserved>-10,
[ 25]: l4t_flash_from_kernel: Warning: skip writing RECROOTFS partition as no image is specified
writing item=11, 9:0:esp, 601247744, 67108864, esp.img, 67108864, fixed-<reserved>-11, a4ab16ba48905af6cd02e5b0b96895e33b11a27e
Writing esp partition with esp.img
67108864 bytes from /mnt/external/esp.img to /dev/nvme0n1: 1KB block=65536 remainder=0
dd if=/mnt/external/esp.img of=/dev/nvme0n1 bs=1K skip=0  seek=587156 count=65536
65536+0 records in
65536+0 records out
67108864 bytes (67 MB, 64 MiB) copied, 9.96541 s, 6.7 MB/s
Writing esp partition done
writing item=12, 9:0:recovery_alt, 668356608, 83886080, , , fixed-<reserved>-12,
[ 35]: l4t_flash_from_kernel: Warning: skip writing recovery_alt partition as no image is specified
writing item=13, 9:0:recovery-dtb_alt, 752242688, 524288, , , fixed-<reserved>-13,
[ 35]: l4t_flash_from_kernel: Warning: skip writing recovery-dtb_alt partition as no image is specified
writing item=14, 9:0:esp_alt, 752766976, 67108864, , , fixed-<reserved>-14,
[ 35]: l4t_flash_from_kernel: Warning: skip writing esp_alt partition as no image is specified
writing item=15, 9:0:APP, 819875840, 59055800320, , , fixed-<reserved>-1,
Formatting APP partition /dev/nvme0n1p1 ...
mke2fs 1.45.5 (07-Jan-2020)
Discarding device blocks: done
Creating filesystem with 14417920 4k blocks and 3604480 inodes
Filesystem UUID: 684bf72a-8844-4fcd-b47a-0efc5daf7061
Superblock backups stored on blocks:
	32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
	4096000, 7962624, 11239424
Allocating group tables: done
Writing inode tables: done
Creating journal (65536 blocks): done
Writing superblocks and filesystem accounting information: done
Formatting APP parition done
tar --xattrs -xpf /mnt/external/system.img  --checkpoint=10000 --warning=no-timestamp --numeric-owner  -C  /tmp/ci-xSgfaIJzRq
tar: Read checkpoint 10000
tar: Read checkpoint 20000
tar: Read checkpoint 30000
tar: Read checkpoint 40000
tar: Read checkpoint 50000
tar: Read checkpoint 60000
tar: Read checkpoint 70000
tar: Read checkpoint 80000
tar: Read checkpoint 90000
tar: Read checkpoint 100000
tar: Read checkpoint 110000
tar: Read checkpoint 120000
tar: Read checkpoint 130000
tar: Read checkpoint 140000
tar: Read checkpoint 150000
tar: Read checkpoint 160000
tar: Read checkpoint 170000
tar: Read checkpoint 180000
tar: Read checkpoint 190000
tar: Read checkpoint 200000
tar: Read checkpoint 210000
tar: Read checkpoint 220000
tar: Read checkpoint 230000
tar: Read checkpoint 240000
tar: Read checkpoint 250000
tar: Read checkpoint 260000
tar: Read checkpoint 270000
tar: Read checkpoint 280000
tar: Read checkpoint 290000
tar: Read checkpoint 300000
tar: Read checkpoint 310000
tar: Read checkpoint 320000
tar: Read checkpoint 330000
tar: Read checkpoint 340000
tar: Read checkpoint 350000
tar: Read checkpoint 360000
tar: Read checkpoint 370000
tar: Read checkpoint 380000
tar: Read checkpoint 390000
tar: Read checkpoint 400000
tar: Read checkpoint 410000
tar: Read checkpoint 420000
tar: Read checkpoint 430000
tar: Read checkpoint 440000
tar: Read checkpoint 450000
tar: Read checkpoint 460000
tar: Read checkpoint 470000
tar: Read checkpoint 480000
tar: Read checkpoint 490000
tar: Read checkpoint 500000
tar: Read checkpoint 510000
tar: Read checkpoint 520000
tar: Read checkpoint 530000
tar: Read checkpoint 540000
tar: Read checkpoint 550000
tar: Read checkpoint 560000
tar: Read checkpoint 570000
writing item=16, 9:0:secondary_gpt, 61203267072, 16896, gpt_secondary_9_0.bin, 16896, fixed-<reserved>-0, f2aae2c0b2e11ca21503c0989951ea6699655037
[ 945]: l4t_flash_from_kernel: Successfully flash the external device
[ 945]: l4t_flash_from_kernel: The device size indicated in the partition layout xml is smaller than the actual size. This utility will try to fix the GPT.
[ 945]: l4t_flash_from_kernel: Error flashing qspi
Flash failure
Cleaning up...
Hi jbzp00y,
What’s your carrier board for Orin NX?
From flash log, it seems the whole process almost finished.
Have you formatted the NVMe SSD as ext4 before flash?
Hi @KevinFFF
It’s a custom carrier board. I already succeed to flash the Jetson once so it’s not board related.
My SSD seen well formatted:
nvidia@ubuntu:~$ sudo blkid /dev/nvme0n1*
/dev/nvme0n1: PTUUID="736fac37-ca79-4058-bbfc-3105b472484c" PTTYPE="gpt"
/dev/nvme0n1p1: UUID="684bf72a-8844-4fcd-b47a-0efc5daf7061" TYPE="ext4" PARTLABEL="APP" PARTUUID="66571245-815e-4425-9a7c-4c33cc11a835"
/dev/nvme0n1p10: PARTLABEL="RECROOTFS" PARTUUID="43809aeb-4c78-4dae-8240-5c6c3e92d71f"
/dev/nvme0n1p11: UUID="5203-7172" TYPE="vfat" PARTLABEL="esp" PARTUUID="27c942b4-ed90-454e-bae7-5f1469b62b44"
/dev/nvme0n1p12: PARTLABEL="recovery_alt" PARTUUID="0bf92773-8394-4665-bc44-8d64779b256f"
/dev/nvme0n1p13: PARTLABEL="recovery-dtb_alt" PARTUUID="01b95ec9-bad3-4eed-8970-775531813b4c"
/dev/nvme0n1p14: PARTLABEL="esp_alt" PARTUUID="36992e64-8b48-4c6a-a52a-98304e078449"
/dev/nvme0n1p2: PARTLABEL="kernel" PARTUUID="6fc35fec-69bd-44da-9630-a06e33ef6871"
/dev/nvme0n1p3: PARTLABEL="kernel-dtb" PARTUUID="5c56f753-f63b-4a1a-8ead-f2587c558874"
/dev/nvme0n1p4: PARTLABEL="reserved_for_chain_A_user" PARTUUID="1c6273b5-39e3-46aa-9a9b-0532938e6120"
/dev/nvme0n1p5: PARTLABEL="kernel_b" PARTUUID="632c7404-db34-4b53-9775-600a91d45166"
/dev/nvme0n1p6: PARTLABEL="kernel-dtb_b" PARTUUID="4a822268-7390-47ab-bf1b-f33673a95c64"
/dev/nvme0n1p7: PARTLABEL="reserved_for_chain_B_user" PARTUUID="12ead8ea-3992-4de3-9bf0-612798e6ec45"
/dev/nvme0n1p8: PARTLABEL="recovery" PARTUUID="4cff796b-0cd0-4e49-b232-333461df2e56"
/dev/nvme0n1p9: PARTLABEL="recovery-dtb" PARTUUID="0b2ff0e2-312d-4ea6-a21c-0e2fce50f37a"
The error is Error flashing qspi. Did I must do something with the qspi flash between two flash ?
I have this error a little above:
Thank you
Is there EEPROM on your carrier board?
Do you mean that you have flashed with the same command on the same board successfully before?
Could you help to flash again and capture full flash log and upload it as file here?
@KevinFFF
I succeed to bypass the problem, but without explanation.
In my device-tree, I remove a gpio-hog for the nReset of a GPIO expander.
tegra_main_gpio: gpio@2200000 {
    exp2_nrst {
        gpio-hog;
        gpios = <TEGRA234_AON_GPIO(CC, 3) GPIO_ACTIVE_HIGH>;
        output-high;
The strange thing is that the nReset is still high because I drive it to 1 in the Excel pinmux.
My gpio expander is recognized by Linux:
[    5.797295] gpiochip3: registered GPIOs 284 to 299 on 0-0075
So, you can flash the board w/o “Error flashing qspi”?
Is the exp2_nrst added by yourself?
It seems your gpio expander be recognized as expected.
What’s the issue currently?
I can’t flash the board but I don’t know why it was not working.
Yes, I added exp2_nrst and the i2c expander is recognized.
If you have any explanation about this, it would be great.
Thank you
I mean “could you flash the board currently?”.
The wrong configuration for the device tree or pinmux may cause “Error flashing qspi ” issue. I can’t explain what’s your case caused from because we don’t have your custom board and can’t reproduce the similar behavior on our devkit.
