Failed to initialize partition table from GPT
Hi.
Because of production reasons, I need to flash the jetson-orin-nx module using below command:
sudo ./flash.sh jetson-orin-nano-devkit-nvme nvme0n1p1
And this is the result I get from the module’s console
[0040.147] I> MB1 (version: 1.4.0.2-t234-54845784-08a4de08)
[0040.153] I> t234-A01-1-Silicon (0x12347) Prod
[0040.157] I> Boot-mode : Coldboot
[0040.160] I> Entry timestamp: 0x00000000
[0040.164] I> last_boot_error: 0x0
[0040.167] I> BR-BCT: preprod_dev_sign: 0
[0040.171] I> rst_source: 0xb, rst_level: 0x1
[0040.175] I> Task: SE error check
[0040.178] I> Task: Bootchain select WAR set
[0040.182] I> Task: Enable SLCG
[0040.185] I> Task: CRC check
[0040.188] I> Task: Initialize MB2 params
[0040.192] I> MB2-params @ 0x40060000
[0040.196] I> Task: Crypto init
[0040.198] I> Task: Perform MB1 KAT tests
[0040.202] I> Task: NVRNG health check
[0040.206] I> NVRNG: Health check success
[0040.210] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0040.216] I> Task: Enabling and initialization of Bandwidth limiter
[0040.222] I> No request to configure MBWT settings for any PC!
[0040.227] I> Task: Secure debug controls
[0040.231] I> Task: strap war set
[0040.234] I> Task: Initialize SOC Therm
[0040.238] I> Task: Program NV master stream id
[0040.242] I> Task: Verify boot mode
[0040.248] I> Task: Alias fuses
[0040.252] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0040.259] I> Task: Print SKU type
[0040.262] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c8
[0040.267] I> FUSE_OPT_GPC_DISABLE = 0x00000002
[0040.271] I> FUSE_OPT_TPC_DISABLE = 0x000000f0
[0040.276] I> FUSE_OPT_DLA_DISABLE = 0x00000002
[0040.280] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0040.284] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0040.289] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0040.293] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0040.297] I> FUSE_OPT_EMC_DISABLE = 0x0000000c
[0040.302] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0040.306] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0040.310] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0040.314] I> FUSE_SKU_INFO_0 = 0xd4
[0040.317] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0040.322] I> FUSE_PACKAGE_INFO_0 = 0x2
[0040.325] I> SKU: Prod
[0040.327] I> Task: Boost clocks
[0040.330] I> Initializing NAFLL for BPMP_CPU_NIC.
[0040.335] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[0040.341] I> BPMP NAFLL lock success.
[0040.344] I> BPMP_CPU_NIC : src = 42, divisor = 0
[0040.349] I> Initializing PLLC2 for AXI_CBB.
[0040.353] I> AXI_CBB : src = 35, divisor = 0
[0040.357] I> Task: Voltage monitor
[0040.361] I> VMON: Vmon re-calibration and fine tuning done
[0040.366] I> Task: UPHY init
[0040.371] I> HSIO UPHY init done
[0040.374] W> Skipping GBE UPHY config
[0040.377] I> Task: Boot device init
[0040.381] I> Boot_device: RCM
[0040.384] I> USB configuration success
[0042.535] I> Task: TSC init
[0042.538] I> Task: Load membct
[0042.541] I> RAM_CODE 0x4000021
[0042.544] I> Loading MEMBCT
[0042.546] I> Slot: 0
[0042.548] I> Binary[0] block-0 (partition size: 0x40000)
[0042.554] I> Binary name: MEM-BCT-0
[0042.557] I> Size of crypto header is 8192
[0042.561] I> Size of crypto header is 8192
[0044.535] I> BCH of MEM-BCT-0 read from storage
[0044.539] I> BCH address is : 0x40050000
[0044.543] I> MEM-BCT-0 header integrity check is success
[0044.549] I> Binary magic in BCH component 0 is MEM0
[0044.553] I> component binary type is 0
[0044.559] I> MEM-BCT-0 binary is read from storage
[0044.564] I> MEM-BCT-0 binary integrity check is success
[0044.569] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0044.575] I> RAM_CODE 0x4000021
[0044.581] I> RAM_CODE 0x4000021
[0044.585] I> Task: Load Page retirement list
[0044.589] I> Task: SDRAM params override
[0044.593] I> Task: Save mem-bct info
[0044.596] I> Task: Carveout allocate
[0044.600] I> Update CCPLEX IST carveout from MB1-BCT
[0044.604] I> ECC region[0]: Start:0x0, End:0x0
[0044.609] I> ECC region[1]: Start:0x0, End:0x0
[0044.613] I> ECC region[2]: Start:0x0, End:0x0
[0044.617] I> ECC region[3]: Start:0x0, End:0x0
[0044.621] I> ECC region[4]: Start:0x0, End:0x0
[0044.626] I> Non-ECC region[0]: Start:0x80000000, End:0x280000000
[0044.632] I> Non-ECC region[1]: Start:0x0, End:0x0
[0044.636] I> Non-ECC region[2]: Start:0x0, End:0x0
[0044.641] I> Non-ECC region[3]: Start:0x0, End:0x0
[0044.646] I> Non-ECC region[4]: Start:0x0, End:0x0
[0044.656] I> allocated(CO:43) base:0xbe000000 size:0x4000000 align: 0x200000
[0044.663] I> allocated(CO:39) base:0x27de00000 size:0x2200000 align: 0x10000
[0044.670] I> allocated(CO:20) base:0x27a000000 size:0x2000000 align: 0x2000000
[0044.677] I> allocated(CO:24) base:0x278000000 size:0x2000000 align: 0x2000000
[0044.684] I> allocated(CO:28) base:0x276000000 size:0x2000000 align: 0x2000000
[0044.692] I> allocated(CO:22) base:0x27c000000 size:0x1000000 align: 0x1000000
[0044.699] I> allocated(CO:35) base:0x275000000 size:0x1000000 align: 0x100000
[0044.706] I> allocated(CO:02) base:0x27d000000 size:0x800000 align: 0x800000
[0044.713] I> allocated(CO:03) base:0x274800000 size:0x800000 align: 0x800000
[0044.720] I> allocated(CO:06) base:0x274000000 size:0x800000 align: 0x800000
[0044.727] I> allocated(CO:56) base:0x273800000 size:0x800000 align: 0x200000
[0044.733] I> allocated(CO:07) base:0x27d800000 size:0x400000 align: 0x400000
[0044.740] I> allocated(CO:33) base:0x273400000 size:0x400000 align: 0x200000
[0044.747] I> allocated(CO:19) base:0x273180000 size:0x280000 align: 0x10000
[0044.754] I> allocated(CO:23) base:0x27dc00000 size:0x200000 align: 0x200000
[0044.761] I> allocated(CO:01) base:0x273000000 size:0x100000 align: 0x100000
[0044.768] I> allocated(CO:05) base:0x272f00000 size:0x100000 align: 0x100000
[0044.775] I> allocated(CO:08) base:0x272e00000 size:0x100000 align: 0x100000
[0044.782] I> allocated(CO:09) base:0x272d00000 size:0x100000 align: 0x100000
[0044.789] I> allocated(CO:12) base:0x272c00000 size:0x100000 align: 0x100000
[0044.796] I> allocated(CO:15) base:0x272b00000 size:0x100000 align: 0x100000
[0044.803] I> allocated(CO:17) base:0x272a00000 size:0x100000 align: 0x100000
[0044.810] I> allocated(CO:27) base:0x272900000 size:0x100000 align: 0x100000
[0044.817] I> allocated(CO:42) base:0x272800000 size:0x100000 align: 0x100000
[0044.824] I> allocated(CO:54) base:0x273100000 size:0x80000 align: 0x80000
[0044.830] I> allocated(CO:34) base:0x2727f0000 size:0x10000 align: 0x10000
[0044.837] I> allocated(CO:72) base:0x2725f0000 size:0x200000 align: 0x10000
[0044.844] I> allocated(CO:46) base:0x240000000 size:0x20000000 align: 0x20000000
[0044.851] I> allocated(CO:47) base:0x272000000 size:0x400000 align: 0x200000
[0044.858] I> allocated(CO:50) base:0x271e00000 size:0x200000 align: 0x100000
[0044.865] I> allocated(CO:48) base:0x2725d0000 size:0x20000 align: 0x10000
[0044.872] I> allocated(CO:69) base:0x2725b0000 size:0x20000 align: 0x10000
[0044.879] I> allocated(CO:49) base:0x2725a0000 size:0x10000 align: 0x10000
[0044.886] I> NSDRAM base: 0x80000000, end: 0x2725f0000, size: 0x1f25f0000
[0044.892] I> Task: Thermal check
[0044.895] I> Using min_chip_limit as min_tmon_limit
[0044.900] I> Using max_chip_limit as max_tmon_limit
[0044.905] I> BCT max_tmon_limit = 105
[0044.908] I> BCT min_tmon_limit = -28
[0044.912] I> BCT max_tmon_limit = 105
[0044.915] I> BCT min_tmon_limit = -28
[0044.919] I> SKU specific max_chip_limit = 105
[0044.923] I> SKU specific min_chip_limit = -28
[0044.927] I> BCT max_chip_limit = 105
[0044.931] I> BCT min_chip_limit = -28
[0044.934] I> enable_soctherm_polling = 0
[0044.938] I> max temp read = 31
[0044.941] I> min temp read = 30
[0044.944] I> Enabling thermtrip
[0044.947] I> Task: Update FSI SCR with thermal fuse data
[0044.952] I> Task: Enable WDT 5th expiry
[0044.956] I> Task: I2C register
[0044.959] I> Task: Set I2C bus freq
[0044.962] I> Task: Reset FSI
[0044.965] I> Task: Pinmux init
[0044.968] I> skipped mmio_addr = 0x9240008
[0044.972] I> skipped mmio_addr = 0x9240000
[0044.976] I> skipped mmio_addr = 0x9240010
[0044.980] I> skipped mmio_addr = 0x9240018
[0044.984] I> skipped mmio_addr = 0x9240020
[0044.988] I> skipped mmio_addr = 0x9240030
[0044.992] I> skipped mmio_addr = 0x9240028
[0044.996] I> skipped mmio_addr = 0x9240038
[0045.000] I> skipped mmio_addr = 0x9240040
[0045.004] I> skipped mmio_addr = 0x9240048
[0045.008] I> skipped mmio_addr = 0x9241000
[0045.012] I> skipped mmio_addr = 0x9241008
[0045.015] I> skipped mmio_addr = 0x9241010
[0045.019] I> skipped mmio_addr = 0x9241018
[0045.023] I> skipped mmio_addr = 0x9241020
[0045.027] I> skipped mmio_addr = 0x9241028
[0045.031] I> skipped mmio_addr = 0x9241030
[0045.035] I> skipped mmio_addr = 0x9241038
[0045.039] I> skipped mmio_addr = 0x9241040
[0045.043] I> skipped mmio_addr = 0x9242000
[0045.047] I> skipped mmio_addr = 0x9242008
[0045.051] I> Task: Prod config init
[0045.054] I> Task: Pad voltage init
[0045.058] I> Task: Prod init
[0045.060] I> Task: Program rst req config reg
[0045.065] I> Task: Common rail init
[0045.068] I> DONE: Thermal config
[0045.072] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0045.081] I> DONE: SOC rail config
[0045.084] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0045.090] I> DONE: MEMIO rail config
[0045.094] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.
[0045.100] I> DONE: GPU rail info
[0045.104] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.
[0045.110] I> DONE: CV rail info
[0045.113] I> Task: Mem clock src
[0045.116] I> Task: Misc. board config
[0045.120] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0045.126] I> Task: SDRAM init
[0045.129] I> MemoryType: 4 MemBctRevision: 1
[0045.136] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 1
[0045.143] I> MSS CAR: Init PLLM
[0045.146] I> MSS CAR: Init PLLHUB
[0045.151] I> Encryption:   MTS: en, TX: en, VPR: en, GSC: en
[0045.162] I> SDRAM initialized!
[0045.165] I> SDRAM Size in Total 0x200000000
[0045.169] I> Task: Dram Ecc scrub
[0045.172] I> Task: DRAM alias check
[0045.179] I> Task: Program NSDRAM carveout
[0045.183] I> NSDRAM carveout encryption is enabled
[0045.188] I> Program NSDRAM carveout
[0045.191] I> Task: Register checker
[0045.195] I> Task: Enable clock-mon
[0045.199] I> FMON: Fmon re-programming done
[0045.203] I> Task: Mapper init
[0045.206] I> Task: SC7 Context Init
[0045.209] W> SC7_CONTEXT_SAVE: SC7 ctx save is not supported.
[0045.215] I> Task: CCPLEX IST init
[0045.218] I> Task: CPU WP0
[0045.221] I> Loading MCE
[0045.223] I> Slot: 0
[0045.225] I> Binary[8] block-134217728 (partition size: 0x80000)
[0045.231] I> Binary name: MCE
[0045.234] I> Size of crypto header is 8192
[0045.238] I> Size of crypto header is 8192
[0045.870] I> BCH of MCE read from storage
[0045.874] I> BCH address is : 0x4003e000
[0045.878] I> MCE header integrity check is success
[0045.883] I> Binary magic in BCH component 0 is MTSM
[0045.888] I> component binary type is 8
[0045.891] I> Size of crypto header is 8192
[0045.898] I> MCE binary is read from storage
[0045.903] I> MCE binary integrity check is success
[0045.907] I> Binary MCE loaded successfully at 0x40000000 (0x2baf0)
[0045.914] I> Size of crypto header is 8192
[0045.918] I> Sending WP0 mailbox command to PSC
[0045.927] I> Task: XUSB Powergate
[0045.930] I> Skipping powergate XUSB.
[0045.933] I> Task: MB1 fixed firewalls
[0045.940] W> Firewall readback mismatch
[0045.945] I> Task: Load bpmp-fw
[0045.948] I> Slot: 0
[0045.950] I> Binary[15] block-251658240 (partition size: 0x180000)
[0045.956] I> Binary name: BPMP_FW
[0045.959] I> Size of crypto header is 8192
[0045.963] I> Size of crypto header is 8192
[0045.967] I> BCH of BPMP_FW read from storage
[0045.971] I> BCH address is : 0x807fe000
[0045.975] I> BPMP_FW header integrity check is success
[0045.980] I> Binary magic in BCH component 0 is BPMF
[0045.985] I> component binary type is 15
[0045.989] I> Size of crypto header is 8192
[0046.010] I> BPMP_FW binary is read from storage
[0046.016] I> BPMP_FW binary integrity check is success
[0046.021] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xf8bc0)
[0046.028] I> Slot: 0
[0046.030] I> Binary[16] block-268435456 (partition size: 0x400000)
[0046.036] I> Binary name: BPMP_FW_DTB
[0046.039] I> Size of crypto header is 8192
[0046.043] I> Size of crypto header is 8192
[0046.047] I> BCH of BPMP_FW_DTB read from storage
[0046.052] I> BCH address is : 0x807fc000
[0046.056] I> BPMP_FW_DTB header integrity check is success
[0046.061] I> Binary magic in BCH component 0 is BPMD
[0046.066] I> component binary type is 16
[0046.069] I> Size of crypto header is 8192
[0046.078] I> BPMP_FW_DTB binary is read from storage
[0046.083] I> BPMP_FW_DTB binary integrity check is success
[0046.088] I> Binary BPMP_FW_DTB loaded successfully at 0x807bdaf0 (0x3e500)
[0046.095] I> Task: BPMP fw ast config
[0046.099] I> Task: Load psc-fw
[0046.102] I> Slot: 0
[0046.104] I> Binary[17] block-285212672 (partition size: 0xc0000)
[0046.110] I> Binary name: PSC_FW
[0046.113] I> Size of crypto header is 8192
[0046.117] I> Size of crypto header is 8192
[0046.121] I> BCH of PSC_FW read from storage
[0046.125] I> BCH address is : 0x80ffe000
[0046.129] I> PSC_FW header integrity check is success
[0046.134] I> Binary magic in BCH component 0 is PFWP
[0046.138] I> component binary type is 17
[0046.142] I> Size of crypto header is 8192
[0046.151] I> PSC_FW binary is read from storage
[0046.156] I> PSC_FW binary integrity check is success
[0046.161] I> Binary PSC_FW loaded successfully at 0x80fb4210 (0x49df0)
[0046.168] I> Task: Load nvdec-fw
[0046.171] I> Slot: 0
[0046.173] I> Binary[7] block-117440512 (partition size: 0x100000)
[0046.179] I> Binary name: NVDEC
[0046.182] I> Size of crypto header is 8192
[0046.186] I> Size of crypto header is 8192
[0046.190] I> BCH of NVDEC read from storage
[0046.194] I> BCH address is : 0x800fe000
[0046.198] I> NVDEC header integrity check is success
[0046.202] I> Binary magic in BCH component 0 is NDEC
[0046.207] I> component binary type is 7
[0046.211] I> Size of crypto header is 8192
[0046.220] I> NVDEC binary is read from storage
[0046.224] I> NVDEC binary integrity check is success
[0046.229] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0046.238] I> Task: Load tsec-fw
[0046.241] I> TSEC-FW load support not enabled
[0046.245] I> Task: GPIO interrupt map
[0046.249] I> Task: SC7 context save
[0046.253] W> SC7_CONTEXT_SAVE: SC7 ctx save is not supported.
[0046.259] I> Task: Load MB2/Applet/FSKP
[0046.262] I> Loading MB2
[0046.265] I> Slot: 0
[0046.267] I> Binary[6] block-100663296 (partition size: 0x80000)
[0046.272] I> Binary name: MB2
[0046.275] I> Size of crypto header is 8192
[0046.279] I> Size of crypto header is 8192
[0046.283] I> BCH of MB2 read from storage
[0046.287] I> BCH address is : 0x8007e000
[0046.291] I> MB2 header integrity check is success
[0046.296] I> Binary magic in BCH component 0 is MB2B
[0046.300] I> component binary type is 6
[0046.304] I> Size of crypto header is 8192
[0046.315] I> MB2 binary is read from storage
[0046.320] I> MB2 binary integrity check is success
[0046.325] I> Binary MB2 loaded successfully at 0x80000000 (0x696a0)
[0046.331] I> Task: Map CCPLEX SHARED carveout
[0046.335] I> Task: Prepare MB2 params
[0046.339] I> Task: Dram ecc test
[0046.342] I> Task: Misc NV security settings
[0046.346] I> NVDEC sticky bits programming done
[0046.351] I> Successfully powergated NVDEC
[0046.355] I> Task: Disable/Reload WDT
[0046.358] I> Task: Program misc carveouts
[0046.362] I> Program IPC carveouts
[0046.366] I> Task: Disable SCPM/POD reset
[0046.369] I> SLCG Global override status := 0x0
[0046.374] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-af79ed0a)
I> Boot-mode : RCM Flash
I> Emulation:
I> Entry timestamp: 0x02c403e2
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0x273800000, size:0x800000]
I> Task: MB2 Params integrity check
I> Task: Enable CCPLEX WDT 5th expiry
I> Task: ARI update carveout TZDRAM
I> Task: Configure OEM set LA/PTSA values
I> Task: Check MC errors
I> Task: PSC mailbox init
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout
I> Task: Program CBB PCIE AMAP regions
I> Boot_device: QSPI_FLASH instance: 0
I> Qspi clock source : pllc_out0
I> QSPI Flash: Macronix 64MB
I> QSPI-0l initialized successfully
I> Secondary storage device: QSPI_FLASH instance: 0
I> Secondary storage device: NVME instance: 4
I> Initializing nvme device instance 4
I> Initializing nvme controller
I> tegrabl_pcie_soc_preinit: (4):
I> Unpowergate
I> PCIE unpowergating successful (PCIEX1A)
I> PCIE unpowergating successful (PCIEX4BB)
I> tegrabl_pcie_soc_init: (4):
I> APPL initialization ...
I> PCIe controller-4 link is up
I> tegra_pcie_info[4].cfg0_base = 0x36000000
I> tegra_pcie_info[4].cfg1_base = 36020000
I> tegra_pcie_info[4].atu_dma_base = 0x36040000
I> tegra_pcie_bus[4].mem = 0x36200000
I> Scanning busnr: 0 devfn: 0
I> PCIe IDs: 0x229c10de
I> PCIe RID_CC: 0x60400a1
I> Scanning busnr: 1 devfn: 0
I> PCIe IDs: 0x50192646
I> PCIe RID_CC: 0x1080200
I> PCI Config: I/O=0x36100000, Memory=0x36200000
I> MEM64 bar_num=0 bar=0x36200000
I> Number of PCIe devices detected: 2
I> NVME page size: 4096
I> NVMe serial number: 50026B7784D269DA
I> NVMe model number: KINGSTON SNV2S1000G
I> NVMe firmware revision: ELFK0S.4
I> block_count: 1953525168
I> supported_lba: 0
I> block_size_log2: 0x9
I> tegrabl_create_io_queue_cmd: queue size: 2
I> nvme device id 000c0004
I> Task: Partition Manager Init
I> strt_pg_num(1) num_of_pgs(1) read_buf(0x273808000)
I> strt_pg_num(131071) num_of_pgs(1) read_buf(0x273808000)
W> Cannot find any partition table for 00030000
W> PARTITION_MANAGER: Failed to publish partition.
I> Found 15 partitions in NVME (instance 4)
I> Task: Trigger mailbox for PSC-BL1 exit
I> Sending opcode 0x4d420802 to psc
I> Received ACK from psc
I> Task: Enter 3p server
I> Populate storage info
I> Erasing device 3: 0
I> QSPI: Erasing entire device
I> Writing device 3: 0.
I> strt_pg_num(1) num_of_pgs(1) read_buf(0x273908000)
I> strt_pg_num(131071) num_of_pgs(1) read_buf(0x273908000)
E> NV3P_SERVER: Failed to initialize partition table from GPT.
Then I thought maybe it’s the wrong device tree. So, I did this:
sudo ./flash.sh -d bootloader/tegra234-p3768-0000+p3767-0000-nv.dtb jetson-orin-nano-devkit-nvme nvme0n1p1
This result is the same as above.
Then I found out that it’s better to use below command:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh -p "--no-systemimg -c bootloader/t186ref/cfg/flash_t234_qspi.xml" --network usb0 jetson-orin-nano-devkit nvme0n1p1
and this is the output
# L4T BSP Information:
# R36 , REVISION: 3.0
# User release: 0.0
ECID is 0x80012344705DE5C07400000009FE8280
Existing emcfuse(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/fuse_t234.xml) reused.
copying emc_fuse_dev_params(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct-diag-boot.dts)... done.
copying device_config(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-device-p3767-0000.dts)... done.
copying misc_config(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-misc-p3767-0000.dts)... done.
./tegraflash.py --chip "0x23" --applet "/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3767-0000.dts --misc_config tegra234-mb1-bct-misc-p3767-0000.dts --bins "mb2_applet applet_t234.bin" --cmd "readfuses fuse_t234.bin fuse_t234.xml; dump eeprom cvm cvm.bin; dump try_custinfo custinfo_out.bin; reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[   0.0077 ] Reading fuses
[   0.0080 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.0082 ] File rcm_state open failed
[   0.0082 ] ERROR: failed to read rcm_state
[   0.0082 ]
[   0.0086 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0086 ] Assuming zero filled SBK key
[   0.0083 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[   0.0112 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[   0.0151 ] Parsing partition layout
[   0.0153 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.0157 ] Kernel DTB used: None
[   0.0157 ] WARNING: dce base dtb is not provided
[   0.0157 ] Parsing partition layout
[   0.0158 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.0161 ] Creating list of images to be signed
[   0.0162 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[   0.0164 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.0171 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.0172 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.0189 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.0191 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.0207 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.0208 ] adding BCH for mb2_t234_aligned.bin
[   0.0219 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.0266 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.0267 ] adding BCH for mb2_t234_aligned.bin
[   0.0322 ] Filling MB1 storage info
[   0.0322 ] Parsing dev params for multi chains
[   0.0357 ] Generating br-bct
[   0.0358 ] Updating dev and MSS params in BR BCT
[   0.0358 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.0362 ] Updating bl info
[   0.0363 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[   0.0364 ] WARNING: boot chain is not completed. set to 0
[   0.0369 ] Generating signatures
[   0.0372 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.0373 ] Assuming zero filled SBK key
[   0.0412 ] Warning: pub_key.key is not found
[   0.0409 ] Parsing dev params for multi chains
[   0.0409 ] Generating br-bct
[   0.0411 ] Updating dev and MSS params in BR BCT
[   0.0411 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.0412 ] Updating bl info
[   0.0413 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.0414 ] WARNING: boot chain is not completed. set to 0
[   0.0417 ] Generating SHA2 Hash
[   0.0422 ] Sha saved in br_bct_BR.sha
[   0.0419 ] Get Signed section of bct
[   0.0420 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   0.0421 ] Signing BCT
[   0.0425 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.0425 ] Assuming zero filled SBK key
[   0.0430 ] Sha saved in br_bct_BR.sha
[   0.0431 ] Warning: pub_key.key is not found
[   0.0428 ] Updating BCT with signature
[   0.0428 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   0.0429 ] Offset :4608 Len :3584
[   0.0430 ] Generating SHA2 Hash
[   0.0434 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   0.0434 ] Assuming zero filled SBK key
[   0.0440 ] Sha saved in br_bct_BR.sha
[   0.0437 ] Updating BCT with SHA2 Hash
[   0.0438 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   0.0439 ] Offset :4608 Len :3584
[   0.0440 ] Offset :68 Len :8124
[   0.0440 ] Generating coldboot mb1-bct
[   0.0441 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.0442 ] MB1-BCT version: 0.13
[   0.0455 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.0456 ] Added Platform Config 9 data with size :- 100
[   0.0456 ] Updating mb1-bct with firmware information
[   0.0457 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.0459 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   0.0460 ] Generating SHA2 Hash for mb1bct
[   0.0466 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[   0.0469 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[   0.0466 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   0.0467 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   0.0473 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.0473 ] Assuming zero filled SBK key
[   0.0476 ] Warning: pub_key.key is not found
[   0.0474 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.0476 ] Generating recovery mb1-bct
[   0.0478 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.0478 ] MB1-BCT version: 0.13
[   0.0492 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.0493 ] Added Platform Config 9 data with size :- 100
[   0.0493 ]
[   0.0493 ] Updating mb1-bct with firmware information
[   0.0493 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.0496 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[   0.0497 ] Generating SHA2 Hash for mb1bct
[   0.0502 ] Sha saved in mb1_bct_MB1_aligned.sha
[   0.0505 ] Sha saved in mb1_bct_MB1.sha
[   0.0502 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   0.0503 ] adding BCH for mb1_bct_MB1_aligned.bct
[   0.0509 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.0509 ] Assuming zero filled SBK key
[   0.0512 ] Warning: pub_key.key is not found
[   0.0510 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.0513 ] Info: Skip generating mem_bct because sdram_config is not defined
[   0.0513 ] Copying signatures
[   0.0514 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.0533 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   0.0534 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   0.0534 ] Boot Rom communication
[   0.0535 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   0.0536 ] BR_CID: 0x80012344705DE5C07400000009FE8280
[   2.0550 ] Sending bct_br
[   4.0663 ] Sending mb1
[   4.0671 ] Sending psc_bl1
[   4.0763 ] Sending bct_mb1
[   4.0831 ] Boot Rom communication completed
[   4.0839 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[   4.0845 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --appendsigheader applet_t234_aligned.bin zerosbk
[   4.0846 ] adding BCH for applet_t234_aligned.bin
[   4.0885 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   4.0886 ] Assuming zero filled SBK key
[   4.0895 ] Warning: pub_key.key is not found
[   4.0894 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[   4.0900 ] Sending mb2_applet...
[   4.0902 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[   4.0903 ] BL: version 1.4.0.2-t234-54845784-08a4de08 last_boot_error: 0
[   6.1066 ] Sending applet
[   8.1212 ] completed
[   8.1217 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   8.1220 ] MB2 Applet version 01.00.0000
[  10.1498 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[  10.1501 ] MB2 Applet version 01.00.0000
[  12.1770 ] Parsing fuse info as per xml file
[  12.1774 ] tegraparser_v2 --chip 0x23 0 --get_fuse_names fuse_t234.xml read_fuse_names.txt
[  12.1775 ] MagicId=0x45535546 version=0x2
[  12.1776 ] trying to read fuse with MB2 Applet
[  12.1778 ] tegraparser_v2 --chip 0x23 0 --read_fusetype PublicKeyHash read_fuse.bin
[  12.1781 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  12.1782 ] MB2 Applet version 01.00.0000
[  16.2290 ] Saved read fuses in file __fuse_read_scatter.bin
[  16.2348 ] Fuse read successful
[  16.2362 ] tegraparser_v2 --chip 0x23 0 --read_fusetype PkcPubkeyHash1 read_fuse.bin
[  16.2367 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  16.2368 ] MB2 Applet version 01.00.0000
[  20.2611 ] Saved read fuses in file __fuse_read_scatter.bin
[  20.2669 ] Fuse read successful
[  20.2683 ] tegraparser_v2 --chip 0x23 0 --read_fusetype PkcPubkeyHash2 read_fuse.bin
[  20.2693 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  20.2695 ] MB2 Applet version 01.00.0000
[  24.2927 ] Saved read fuses in file __fuse_read_scatter.bin
[  24.2986 ] Fuse read successful
[  24.2999 ] tegraparser_v2 --chip 0x23 0 --read_fusetype BootSecurityInfo read_fuse.bin
[  24.3004 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  24.3005 ] MB2 Applet version 01.00.0000
[  29.5170 ] Saved read fuses in file __fuse_read_scatter.bin
[  29.5229 ] Fuse read successful
[  29.5242 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ArmJtagDisable read_fuse.bin
[  29.5249 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  29.5251 ] MB2 Applet version 01.00.0000
[  33.5291 ] Saved read fuses in file __fuse_read_scatter.bin
[  33.5351 ] Fuse read successful
[  33.5365 ] tegraparser_v2 --chip 0x23 0 --read_fusetype SecurityMode read_fuse.bin
[  33.5371 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  33.5372 ] MB2 Applet version 01.00.0000
[  37.5528 ] Saved read fuses in file __fuse_read_scatter.bin
[  37.5586 ] Fuse read successful
[  37.5599 ] tegraparser_v2 --chip 0x23 0 --read_fusetype SwReserved read_fuse.bin
[  37.5603 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  37.5604 ] MB2 Applet version 01.00.0000
[  41.5890 ] Saved read fuses in file __fuse_read_scatter.bin
[  41.5948 ] Fuse read successful
[  41.5962 ] tegraparser_v2 --chip 0x23 0 --read_fusetype DebugAuthentication read_fuse.bin
[  41.5968 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  41.5969 ] MB2 Applet version 01.00.0000
[  45.6169 ] Saved read fuses in file __fuse_read_scatter.bin
[  45.6227 ] Fuse read successful
[  45.6240 ] tegraparser_v2 --chip 0x23 0 --read_fusetype OdmInfo read_fuse.bin
[  45.6247 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  45.6249 ] MB2 Applet version 01.00.0000
[  50.9607 ] Saved read fuses in file __fuse_read_scatter.bin
[  50.9666 ] Fuse read successful
[  50.9679 ] tegraparser_v2 --chip 0x23 0 --read_fusetype OdmId read_fuse.bin
[  50.9684 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  50.9685 ] MB2 Applet version 01.00.0000
[  54.9893 ] Saved read fuses in file __fuse_read_scatter.bin
[  54.9951 ] Fuse read successful
[  54.9965 ] tegraparser_v2 --chip 0x23 0 --read_fusetype OdmLock read_fuse.bin
[  54.9973 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  54.9975 ] MB2 Applet version 01.00.0000
[  58.9931 ] Saved read fuses in file __fuse_read_scatter.bin
[  58.9992 ] Fuse read successful
[  59.0005 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm0 read_fuse.bin
[  59.0010 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  59.0012 ] MB2 Applet version 01.00.0000
[  63.0412 ] Saved read fuses in file __fuse_read_scatter.bin
[  63.0471 ] Fuse read successful
[  63.0487 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm1 read_fuse.bin
[  63.0498 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  63.0501 ] MB2 Applet version 01.00.0000
[  67.0846 ] Saved read fuses in file __fuse_read_scatter.bin
[  67.0905 ] Fuse read successful
[  67.0918 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm2 read_fuse.bin
[  67.0924 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  67.0926 ] MB2 Applet version 01.00.0000
[  72.3930 ] Saved read fuses in file __fuse_read_scatter.bin
[  72.3992 ] Fuse read successful
[  72.4007 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm3 read_fuse.bin
[  72.4012 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  72.4014 ] MB2 Applet version 01.00.0000
[  76.4050 ] Saved read fuses in file __fuse_read_scatter.bin
[  76.4108 ] Fuse read successful
[  76.4121 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm4 read_fuse.bin
[  76.4129 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  76.4130 ] MB2 Applet version 01.00.0000
[  80.4565 ] Saved read fuses in file __fuse_read_scatter.bin
[  80.4624 ] Fuse read successful
[  80.4637 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm5 read_fuse.bin
[  80.4641 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  80.4642 ] MB2 Applet version 01.00.0000
[  84.4687 ] Saved read fuses in file __fuse_read_scatter.bin
[  84.4745 ] Fuse read successful
[  84.4759 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm6 read_fuse.bin
[  84.4765 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  84.4767 ] MB2 Applet version 01.00.0000
[  88.4930 ] Saved read fuses in file __fuse_read_scatter.bin
[  88.4988 ] Fuse read successful
[  88.5002 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm7 read_fuse.bin
[  88.5008 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  88.5010 ] MB2 Applet version 01.00.0000
[  93.0450 ] Saved read fuses in file __fuse_read_scatter.bin
[  93.0508 ] Fuse read successful
[  93.0522 ] tegraparser_v2 --chip 0x23 0 --read_fusetype Sku read_fuse.bin
[  93.0528 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  93.0530 ] MB2 Applet version 01.00.0000
[  97.0526 ] Saved read fuses in file __fuse_read_scatter.bin
[  97.0585 ] Fuse read successful
[  97.0599 ] tegraparser_v2 --chip 0x23 0 --read_fusetype Uid read_fuse.bin
[  97.0608 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  97.0609 ] MB2 Applet version 01.00.0000
[ 101.0769 ] Saved read fuses in file __fuse_read_scatter.bin
[ 101.0828 ] Fuse read successful
[ 101.0842 ] tegraparser_v2 --chip 0x23 0 --read_fusetype OptEmcDisable read_fuse.bin
[ 101.0850 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 101.0852 ] MB2 Applet version 01.00.0000
[ 105.0971 ] Saved read fuses in file __fuse_read_scatter.bin
[ 105.1030 ] Fuse read successful
[ 105.1044 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 105.1047 ] MB2 Applet version 01.00.0000
[ 107.1134 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 107.1136 ] MB2 Applet version 01.00.0000
[ 109.1132 ] Retrieving board information
[ 109.1134 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails chip chip_info.bin
[ 109.1136 ] MB2 Applet version 01.00.0000
[ 111.1126 ] Saved platform info in chip_info.bin
[ 111.1180 ] Chip minor revision: 1
[ 111.1180 ] Bootrom revision: 0x7
[ 111.1180 ] Ram code: 0x2
[ 111.1180 ] Chip sku: 0xd4
[ 111.1180 ] Chip Sample: prod
[ 111.1191 ] Retrieving EEPROM data
[ 111.1191 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23 0
[ 111.1193 ] MB2 Applet version 01.00.0000
[ 113.8611 ] Saved platform info in /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/cvm.bin
[ 113.8945 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 113.8947 ] MB2 Applet version 01.00.0000
[ 115.8894 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 115.8895 ] MB2 Applet version 01.00.0000
[ 117.8887 ] Dumping customer Info
[ 117.8890 ] tegrarcm_v2 --chip 0x23 0 --oem dump bct tmp.bct
[ 117.8892 ] MB2 Applet version 01.00.0000
[ 119.8852 ] Saved bct in tmp.bct
[ 119.9239 ] tegrabct_v2 --brbct tmp.bct --chip 0x23 0 --custinfo /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/custinfo_out.bin
[ 119.9242 ] Customer data[ 119.9245 ]  saved in /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/custinfo_out.bin successfully
[ 119.9245 ] Rebooting to recovery mode
[ 119.9247 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[ 121.9334 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 121.9336 ] MB2 Applet version 01.00.0000
[ 123.9332 ] Booting to recovery mode
[ 123.9336 ] tegrarcm_v2 --chip 0x23 0 --reboot recovery
[ 123.9337 ] MB2 Applet version 01.00.0000
Board ID(3767) version(300) sku(0001) revision(R.1)
Chip SKU(00:00:00:D4) ramcode(00:00:00:02) fuselevel(fuselevel_production) board_FAB(300)
emc_opt_disable_fuse:(0)
Error: missing cfgfile ().
P.S: I’m using jetson-orin-nx 8GB, with NVMe
what am I missing ?
Hi benyamin,
Are you using the devkit or custom board for Orin NX?
What’s your Jetpack version in use? (JP6.0GA - R36.3.0?)
If you want to flash NVMe SSD, please use l4t_initrd_flash.sh.
You can find more details in <Linux_for_Tegra>/tools/kernel_flash/README_initrd_flash.txt
Have you confirmed that the jetson-orin-nano-devkit.conf exists?
Hi @KevinFFF
Thanks for the reply.
Yes, I’m using JP6 - R36.3
and I only have the jetson SoM with my own custom carrier board.
I run below command:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-only -c bootloader/generic/cfg/flash_t234_qspi.xml -S 10240000000 --external-device nvme0n1 jetson-orin-nano-devkit external
sudo ADDITIONAL_DTB_OVERLAY_OPT="BootOrderNvme.dtbo" ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c ./tools/kernel_flash/flash_l4t_external.xml --showlogs jetson-orin-nano-devkit external
Both of the above commands have similar output as below:
*  Step 1: Generate flash packages *
Create folder to store images to flash
Generate image for external storage devices
Generate images to be flashed
BOOTDEV=external ADDITIONAL_DTB_OVERLAY=""  /home/ai-blox/Desktop/test/Linux_for_Tegra/flash.sh --no-flash --sign --external-device -c "bootloader/generic/cfg/flash_t234_qspi.xml" -S "10240000000"  jetson-orin-nano-devkit external
# User release: 0.0
version 1.0.0
[   0.0080 ] Reading fuses
[   0.0081 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.0083 ] File rcm_state open failed
[   0.0084 ] ERROR: failed to read rcm_state
[   0.0084 ]
[   0.0087 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0088 ] Assuming zero filled SBK key
[   0.0085 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[   0.0157 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.0160 ] Creating list of images to be signed
[   0.0161 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[   0.0163 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.0174 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.0175 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.0194 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.0195 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.0212 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.0212 ] adding BCH for mb2_t234_aligned.bin
[   0.0223 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.0268 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.0268 ] adding BCH for mb2_t234_aligned.bin
[   0.0325 ] Filling MB1 storage info
[   0.0325 ] Parsing dev params for multi chains
[   0.0359 ] Updating dev and MSS params in BR BCT
[   0.0359 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.0370 ] Generating signatures
[   0.0373 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.0374 ] Assuming zero filled SBK key
[   0.0415 ] Warning: pub_key.key is not found
[   0.0413 ] Parsing dev params for multi chains
[   0.0413 ] Generating br-bct
[   0.0414 ] Updating dev and MSS params in BR BCT
[   0.0414 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.0416 ] Updating bl info
[   0.0417 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.0418 ] WARNING: boot chain is not completed. set to 0
[   0.0421 ] Generating SHA2 Hash
[   0.0427 ] Sha saved in br_bct_BR.sha
[   0.0424 ] Get Signed section of bct
[   0.0425 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   0.0427 ] Signing BCT
[   0.0430 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.0431 ] Assuming zero filled SBK key
[   0.0438 ] Sha saved in br_bct_BR.sha
[   0.0439 ] Warning: pub_key.key is not found
[   0.0435 ] Updating BCT with signature
[   0.0436 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   0.0437 ] Offset :4608 Len :3584
[   0.0439 ] Generating SHA2 Hash
[   0.0442 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   0.0443 ] Assuming zero filled SBK key
[   0.0449 ] Sha saved in br_bct_BR.sha
[   0.0447 ] Updating BCT with SHA2 Hash
[   0.0448 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   0.0449 ] Offset :4608 Len :3584
[   0.0451 ] Offset :68 Len :8124
[   0.0452 ] Generating coldboot mb1-bct
[   0.0453 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.0454 ] MB1-BCT version: 0.13
[   0.0468 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.0469 ] Added Platform Config 9 data with size :- 100
[   0.0470 ] Updating mb1-bct with firmware information
[   0.0471 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.0477 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   0.0478 ] Generating SHA2 Hash for mb1bct
[   0.0485 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[   0.0488 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[   0.0487 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   0.0489 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   0.0497 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.0498 ] Assuming zero filled SBK key
[   0.0504 ] Warning: pub_key.key is not found
[   0.0502 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.0508 ] Generating recovery mb1-bct
[   0.0510 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.0511 ] MB1-BCT version: 0.13
[   0.0525 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.0526 ] Added Platform Config 9 data with size :- 100
[   0.0526 ] Updating mb1-bct with firmware information
[   0.0528 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.0532 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[   0.0533 ] Generating SHA2 Hash for mb1bct
[   0.0541 ] Sha saved in mb1_bct_MB1_aligned.sha
[   0.0545 ] Sha saved in mb1_bct_MB1.sha
[   0.0542 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   0.0543 ] adding BCH for mb1_bct_MB1_aligned.bct
[   0.0549 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.0550 ] Assuming zero filled SBK key
[   0.0554 ] Warning: pub_key.key is not found
[   0.0552 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.0555 ] Info: Skip generating mem_bct because sdram_config is not defined
[   0.0555 ] Copying signatures
[   0.0556 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.0573 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   0.0573 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   0.0573 ] Boot Rom communication
[   0.0574 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   0.0575 ] BR_CID: 0x80012344705DE5C07400000009FE8280
[   2.0904 ] Sending bct_br
[   4.1135 ] Sending mb1
[   4.1145 ] Sending psc_bl1
[   4.1257 ] Sending bct_mb1
[   4.1319 ] Boot Rom communication completed
[   4.1336 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[   4.1354 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --appendsigheader applet_t234_aligned.bin zerosbk
[   4.1360 ] adding BCH for applet_t234_aligned.bin
[   4.1475 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   4.1476 ] Assuming zero filled SBK key
[   4.1506 ] Warning: pub_key.key is not found
[   4.1509 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[   4.1544 ] Sending mb2_applet...
[   4.1552 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[   4.1555 ] BL: version 1.4.0.2-t234-54845784-08a4de08 last_boot_error: 0
[   6.1700 ] Sending applet
[   8.2175 ] completed
[   8.2186 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   8.2194 ] MB2 Applet version 01.00.0000
[  10.2335 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[  10.2343 ] MB2 Applet version 01.00.0000
[  12.2609 ] Parsing fuse info as per xml file
[  12.2622 ] tegraparser_v2 --chip 0x23 0 --get_fuse_names fuse_t234.xml read_fuse_names.txt
[  12.2633 ] MagicId=0x45535546 version=0x2
[  12.2636 ] trying to read fuse with MB2 Applet
[  12.2652 ] tegraparser_v2 --chip 0x23 0 --read_fusetype PublicKeyHash read_fuse.bin
[  12.2671 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  12.2679 ] MB2 Applet version 01.00.0000
[  16.3048 ] Saved read fuses in file __fuse_read_scatter.bin
[  16.3107 ] Fuse read successful
[  16.3125 ] tegraparser_v2 --chip 0x23 0 --read_fusetype PkcPubkeyHash1 read_fuse.bin
[  16.3144 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  16.3151 ] MB2 Applet version 01.00.0000
[  20.1643 ] Saved read fuses in file __fuse_read_scatter.bin
[  20.1701 ] Fuse read successful
[  20.1720 ] tegraparser_v2 --chip 0x23 0 --read_fusetype PkcPubkeyHash2 read_fuse.bin
[  20.1739 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  20.1747 ] MB2 Applet version 01.00.0000
[  24.2130 ] Saved read fuses in file __fuse_read_scatter.bin
[  24.2193 ] Fuse read successful
[  24.2213 ] tegraparser_v2 --chip 0x23 0 --read_fusetype BootSecurityInfo read_fuse.bin
[  24.2232 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  24.2239 ] MB2 Applet version 01.00.0000
[  28.2607 ] Saved read fuses in file __fuse_read_scatter.bin
[  28.2666 ] Fuse read successful
[  28.2684 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ArmJtagDisable read_fuse.bin
[  28.2703 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  28.2710 ] MB2 Applet version 01.00.0000
[  32.3002 ] Saved read fuses in file __fuse_read_scatter.bin
[  32.3063 ] Fuse read successful
[  32.3081 ] tegraparser_v2 --chip 0x23 0 --read_fusetype SecurityMode read_fuse.bin
[  32.3101 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  32.3111 ] MB2 Applet version 01.00.0000
[  36.3366 ] Saved read fuses in file __fuse_read_scatter.bin
[  36.3426 ] Fuse read successful
[  36.3445 ] tegraparser_v2 --chip 0x23 0 --read_fusetype SwReserved read_fuse.bin
[  36.3464 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  36.3471 ] MB2 Applet version 01.00.0000
[  41.8645 ] Saved read fuses in file __fuse_read_scatter.bin
[  41.8704 ] Fuse read successful
[  41.8724 ] tegraparser_v2 --chip 0x23 0 --read_fusetype DebugAuthentication read_fuse.bin
[  41.8747 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  41.8755 ] MB2 Applet version 01.00.0000
[  45.9046 ] Saved read fuses in file __fuse_read_scatter.bin
[  45.9106 ] Fuse read successful
[  45.9126 ] tegraparser_v2 --chip 0x23 0 --read_fusetype OdmInfo read_fuse.bin
[  45.9145 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  45.9153 ] MB2 Applet version 01.00.0000
[  49.9605 ] Saved read fuses in file __fuse_read_scatter.bin
[  49.9667 ] Fuse read successful
[  49.9686 ] tegraparser_v2 --chip 0x23 0 --read_fusetype OdmId read_fuse.bin
[  49.9704 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  49.9712 ] MB2 Applet version 01.00.0000
[  54.0003 ] Saved read fuses in file __fuse_read_scatter.bin
[  54.0063 ] Fuse read successful
[  54.0082 ] tegraparser_v2 --chip 0x23 0 --read_fusetype OdmLock read_fuse.bin
[  54.0102 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  54.0109 ] MB2 Applet version 01.00.0000
[  58.6446 ] Saved read fuses in file __fuse_read_scatter.bin
[  58.6506 ] Fuse read successful
[  58.6523 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm0 read_fuse.bin
[  58.6541 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  58.6548 ] MB2 Applet version 01.00.0000
[  62.6842 ] Saved read fuses in file __fuse_read_scatter.bin
[  62.6901 ] Fuse read successful
[  62.6921 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm1 read_fuse.bin
[  62.6943 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  62.6951 ] MB2 Applet version 01.00.0000
[  66.7324 ] Saved read fuses in file __fuse_read_scatter.bin
[  66.7386 ] Fuse read successful
[  66.7403 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm2 read_fuse.bin
[  66.7423 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  66.7430 ] MB2 Applet version 01.00.0000
[  70.7769 ] Saved read fuses in file __fuse_read_scatter.bin
[  70.7832 ] Fuse read successful
[  70.7853 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm3 read_fuse.bin
[  70.7875 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  70.7883 ] MB2 Applet version 01.00.0000
[  74.8122 ] Saved read fuses in file __fuse_read_scatter.bin
[  74.8183 ] Fuse read successful
[  74.8202 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm4 read_fuse.bin
[  74.8223 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  74.8231 ] MB2 Applet version 01.00.0000
[  79.2527 ] Saved read fuses in file __fuse_read_scatter.bin
[  79.2586 ] Fuse read successful
[  79.2605 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm5 read_fuse.bin
[  79.2622 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  79.2630 ] MB2 Applet version 01.00.0000
[  83.2924 ] Saved read fuses in file __fuse_read_scatter.bin
[  83.2985 ] Fuse read successful
[  83.3004 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm6 read_fuse.bin
[  83.3024 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  83.3032 ] MB2 Applet version 01.00.0000
[  87.3400 ] Saved read fuses in file __fuse_read_scatter.bin
[  87.3461 ] Fuse read successful
[  87.3480 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm7 read_fuse.bin
[  87.3501 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  87.3509 ] MB2 Applet version 01.00.0000
[  91.3800 ] Saved read fuses in file __fuse_read_scatter.bin
[  91.3860 ] Fuse read successful
[  91.3879 ] tegraparser_v2 --chip 0x23 0 --read_fusetype Sku read_fuse.bin
[  91.3901 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  91.3909 ] MB2 Applet version 01.00.0000
[  95.4244 ] Saved read fuses in file __fuse_read_scatter.bin
[  95.4304 ] Fuse read successful
[  95.4321 ] tegraparser_v2 --chip 0x23 0 --read_fusetype Uid read_fuse.bin
[  95.4340 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  95.4347 ] MB2 Applet version 01.00.0000
[ 100.5124 ] Saved read fuses in file __fuse_read_scatter.bin
[ 100.5185 ] Fuse read successful
[ 100.5203 ] tegraparser_v2 --chip 0x23 0 --read_fusetype OptEmcDisable read_fuse.bin
[ 100.5220 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 100.5227 ] MB2 Applet version 01.00.0000
[ 104.5644 ] Saved read fuses in file __fuse_read_scatter.bin
[ 104.5705 ] Fuse read successful
[ 104.5724 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 104.5731 ] MB2 Applet version 01.00.0000
[ 106.6027 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 106.6034 ] MB2 Applet version 01.00.0000
[ 108.6254 ] Retrieving board information
[ 108.6260 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails chip chip_info.bin
[ 108.6266 ] MB2 Applet version 01.00.0000
[ 110.6483 ] Saved platform info in chip_info.bin
[ 110.6541 ] Chip minor revision: 1
[ 110.6543 ] Bootrom revision: 0x7
[ 110.6543 ] Ram code: 0x2
[ 110.6544 ] Chip sku: 0xd4
[ 110.6545 ] Chip Sample: prod
[ 110.6556 ] Retrieving EEPROM data
[ 110.6557 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23 0
[ 110.6565 ] MB2 Applet version 01.00.0000
[ 112.6764 ] Saved platform info in /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/cvm.bin
[ 112.7110 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 112.7118 ] MB2 Applet version 01.00.0000
[ 114.7216 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 114.7224 ] MB2 Applet version 01.00.0000
[ 116.7363 ] Dumping customer Info
[ 116.7373 ] tegrarcm_v2 --chip 0x23 0 --oem dump bct tmp.bct
[ 116.7381 ] MB2 Applet version 01.00.0000
[ 118.7644 ] Saved bct in tmp.bct
[ 118.8035 ] tegrabct_v2 --brbct tmp.bct --chip 0x23 0 --custinfo /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/custinfo_out.bin
[ 118.8063 ] Customer data saved in /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/custinfo_out.bin successfully
[ 118.8064 ] Rebooting to recovery mode
[ 118.8072 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[ 121.3137 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 121.3145 ] MB2 Applet version 01.00.0000
[ 123.3287 ] Booting to recovery mode
[ 123.3297 ] tegrarcm_v2 --chip 0x23 0 --reboot recovery
[ 123.3305 ] MB2 Applet version 01.00.0000
Copy /home/ai-blox/Desktop/test/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0001-nv.dtb to /home/ai-blox/Desktop/test/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0001-nv.dtb.rec
Generated UUID 837b85c4-4260-42e1-9fde-db4d413eace1 for mounting root APP_ext partition.
copying bctfile(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/generic/BCT/tegra234-p3767-0001-sdram-l4t.dts)... done.
copying minratchet_config(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-ratchet-p3767-0000.dts)... done.
copying pinmux_config(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi)... done.
copying gpioint_config(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-gpioint-p3767-0000.dts)... done.
copying pmic_config(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-pmic-p3767-0000-a02.dts)... done.
copying pmc_config(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi)... done.
copying deviceprod_config(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-cprod-p3767-0000.dts)... done.
copying prod_config(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-prod-p3767-0000.dts)... done.
copying scr_config(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb2-bct-scr-p3767-0000.dts)... done.
copying wb0sdram(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/generic/BCT/tegra234-p3767-0001-wb0sdram-l4t.dts)... done.
copying bootrom_config(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-reset-p3767-0000.dts)... done.
Existing uphylane_config(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/tegra234-mb1-bct-uphylane-si.dtsi) reused.
copying dev_params(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct-p3767-0000-l4t.dts)... done.
copying dev_params_b(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct_b-p3767-0000-l4t.dts)... done.
copying mb2bct_cfg(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb2-bct-misc-p3767-0000.dts)... done.
Existing pscfwfile(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/pscfw_t234_prod.bin) reused.
Existing pscbl1file(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/psc_bl1_t234_prod.bin) reused.
Existing mtsmcefile(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/mce_flash_o10_cr_prod.bin) reused.
Existing tscfwfile(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/tsec_t234.bin) reused.
Existing mb2applet(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/applet_t234.bin) reused.
Existing bootloader(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
copying initrd(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
bl is uefi
Making Boot image... done.
Not signing of boot.img
Making recovery ramdisk for recovery image...
Re-generating recovery ramdisk for recovery image...
/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/ramdisk_tmp /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader /home/ai-blox/Desktop/test/Linux_for_Tegra
53899 blocks
gzip: /home/ai-blox/Desktop/test/Linux_for_Tegra/kernel/Image: not in gzip format
_BASE_KERNEL_VERSION=5.15.136-tegra
77459 blocks
Making Recovery image...
copying recdtbfile(/home/ai-blox/Desktop/test/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0001-nv.dtb.rec)... done.
20+0 records in
20+0 records out
20 bytes copied, 9.9561e-05 s, 201 kB/s
Existing sosfile(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing tegraboot(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing cpu_bootloader(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing mb2blfile(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing xusbfile(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/xusb_t234_prod.bin) reused.
Existing pvafile(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/nvpva_020.fw) reused.
Existing dcefile(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/display-t234-dce.bin) reused.
Existing nvdecfile(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/nvdec_t234_prod.fw) reused.
Existing psc_rf(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/psc_rf_t234_prod.bin) reused.
Existing mb2_rf(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/mb2rf_t234.bin) reused.
Existing mb1file(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing bpffile(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/bpmp_t234-TE980M-A1_prod.bin) reused.
copying bpfdtbfile(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/generic/tegra234-bpmp-3767-0001-3509-a02.dtb)... done.
Existing camerafw(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/camera-rtcpu-t234-rce.img) reused.
Existing apefile(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/adsp-fw.bin) reused.
Existing spefile(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/spe_t234.bin) reused.
Existing wb0boot(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/sc7_t234_prod.bin) reused.
Existing tosfile(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/tos-optee_t234.img) reused.
Existing eksfile(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/eks_t234.img) reused.
copying dtbfile(/home/ai-blox/Desktop/test/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0001-nv.dtb)... done.
Copying nv_boot_control.conf to rootfs
Skip generating system.img
Not signing of kernel-dtb
Existing tbcfile(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/uefi_jetson.bin) reused.
131072+0 records in
131072+0 records out
67108864 bytes (67 MB, 64 MiB) copied, 0.152054 s, 441 MB/s
	Sync'ing esp.img ... done.
copying tbcdtbfile(/home/ai-blox/Desktop/test/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0001-nv.dtb)... done.
copying cfgfile(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/generic/cfg/flash_t234_qspi.xml) to flash.xml... done.
Existing flashapp(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/tegraflash.py) reused.
copying overlay_dtb(/home/ai-blox/Desktop/test/Linux_for_Tegra/kernel/dtb/L4TConfiguration.dtbo)... done.
copying overlay_dtb(/home/ai-blox/Desktop/test/Linux_for_Tegra/kernel/dtb/tegra234-carveouts.dtbo)... done.
copying overlay_dtb(/home/ai-blox/Desktop/test/Linux_for_Tegra/kernel/dtb/tegra-optee.dtbo)... done.
copying overlay_dtb(/home/ai-blox/Desktop/test/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0000-dynamic.dtbo)... done.
/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/L4TConfiguration_updated.dts: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/L4TConfiguration.dtbo: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
./tegraflash.py --bl uefi_jetson_with_dtb.bin --odmdata gbe-uphy-config-8,hsstp-lane-map-3,hsio-uphy-config-0 --overlay_dtb L4TConfiguration.dtbo,tegra234-carveouts.dtbo,tegra-optee.dtbo,tegra234-p3768-0000+p3767-0000-dynamic.dtbo, --bldtb tegra234-p3768-0000+p3767-0001-nv.dtb --applet mb1_t234_prod.bin --cmd "sign" --cfg flash.xml --chip "0x23" --concat_cpubl_bldtb --cpubl uefi_jetson.bin --minratchet_config tegra234-mb1-bct-ratchet-p3767-0000.dts --device_config tegra234-mb1-bct-device-p3767-0000.dts --misc_config tegra234-mb1-bct-misc-p3767-0000.dts --pinmux_config tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi --gpioint_config tegra234-mb1-bct-gpioint-p3767-0000.dts --pmic_config tegra234-mb1-bct-pmic-p3767-0000-a02.dts --pmc_config tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi --deviceprod_config tegra234-mb1-bct-cprod-p3767-0000.dts --prod_config tegra234-mb1-bct-prod-p3767-0000.dts --scr_config tegra234-mb2-bct-scr-p3767-0000.dts --wb0sdram_config tegra234-p3767-0001-wb0sdram-l4t.dts --br_cmd_config tegra234-mb1-bct-reset-p3767-0000.dts --uphy tegra234-mb1-bct-uphylane-si.dtsi --dev_params tegra234-br-bct-p3767-0000-l4t.dts,tegra234-br-bct_b-p3767-0000-l4t.dts --mb2bct_cfg tegra234-mb2-bct-misc-p3767-0000.dts --bins "psc_fw pscfw_t234_prod.bin; mts_mce mce_flash_o10_cr_prod.bin; tsec_fw tsec_t234.bin; mb2_applet applet_t234.bin; mb2_bootloader mb2_t234.bin; xusb_fw xusb_t234_prod.bin; pva_fw nvpva_020.fw; dce_fw display-t234-dce.bin; nvdec nvdec_t234_prod.fw; bpmp_fw bpmp_t234-TE980M-A1_prod.bin; bpmp_fw_dtb tegra234-bpmp-3767-0001-3509-a02.dtb; rce_fw camera-rtcpu-t234-rce.img; ape_fw adsp-fw.bin; spe_fw spe_t234.bin; tos tos-optee_t234.img; eks eks_t234.img" --sdram_config tegra234-p3767-0001-sdram-l4t.dts --cust_info custinfo_out.bin --external_device --bct_backup --boot_chain A
version 1.0.0
[   0.0101 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0101 ] Assuming zero filled SBK key
[   0.0098 ] Parsing partition layout
[   0.0101 ] tegraparser_v2 --pt flash.xml.tmp
[   0.0126 ] Change tegra234-bpmp-3767-0001-3509-a02.dtb to tegra234-bpmp-3767-0001-3509-a02_with_odm.dtb
[   0.0314 ] /usr/bin/python3 dtbcheck.py -c t234 -o tegra234-bpmp-3767-0001-3509-a02_with_odm.dtb tegra234-bpmp-3767-0001-3509-a02_with_odm_tmp.dtb
[   0.1368 ] Concatenating L4TConfiguration.dtbo,tegra234-carveouts.dtbo,tegra-optee.dtbo,tegra234-p3768-0000+p3767-0000-dynamic.dtbo to tegra234-p3768-0000+p3767-0001-nv_with_odm_overlay.dtb.updated
[   0.1368 ] Concatenating bl dtb to cpubl binary
[   0.1390 ] MB2 binary: mb2_t234.bin
[   0.1390 ] Pre-processing mb2bct config: tegra234-mb2-bct-misc-p3767-0000.dts
[   0.1455 ] Pre-processing mb2bct config: tegra234-mb2-bct-scr-p3767-0000.dts
[   0.2655 ] Generating coldboot mb2-bct
[   0.2656 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct.cfg --mb2bctcfg tegra234-mb2-bct-misc-p3767-0000_cpp.dtb --scr tegra234-mb2-bct-scr-p3767-0000_cpp.dtb
[   0.2657 ] ERROR: value 0x31 is out of range
[   0.2664 ] ERROR: value 0x31 is out of range
[   0.2665 ] ERROR: value 0x31 is out of range
[   0.2666 ] WARNING: unknown property 'tfc_version'
[   0.2668 ] WARNING: unknown property 'addr_header_version'
[   0.2749 ] Updating mb2-bct with storage information
[   0.2752 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct_MB2.bct --updatestorageinfo flash.xml.bin
[   0.2755 ] Concatenating mb2-bct to mb2 binary
[   0.2755 ] mb2_bin_file = mb2_t234.bin
[   0.2755 ] mb2_bct_file = mb2_cold_boot_bct_MB2.bct
[   0.2770 ] DCE binary: display-t234-dce.bin
[   0.2770 ] Kernel DTB used: tegra234-p3768-0000+p3767-0001-nv_with_odm_overlay.dtb.updated
[   0.2770 ] Concatenating kernel-dtb to dce-fw binary
[   0.2770 ] dce_bin = display-t234-dce.bin
[   0.2770 ] kernel_dtb = tegra234-p3768-0000+p3767-0001-nv_with_odm_overlay.dtb.updated
[   0.2770 ] dce_with_dtb = display-t234-dce_with_tegra234-p3768-0000+p3767-0001-nv_with_odm_overlay.dtb.bin
[   0.2809 ] Update display-t234-dce_with_tegra234-p3768-0000+p3767-0001-nv_with_odm_overlay.dtb.bin to dce_fw partitions
[   0.2816 ] Parsing partition layout
[   0.2819 ] tegraparser_v2 --pt flash.xml.tmp
[   0.2823 ] Creating list of images to be signed
[   0.2825 ] Generating ratchet blob
[   0.2825 ] Pre-processing config: tegra234-mb1-bct-reset-p3767-0000.dts
[   0.2851 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[   0.2880 ] Pre-processing config: tegra234-mb1-bct-cprod-p3767-0000.dts
[   0.2908 ] Pre-processing config: tegra234-mb1-bct-gpioint-p3767-0000.dts
[   0.2936 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[   0.2974 ] Pre-processing config: tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi
[   0.3025 ] Pre-processing config: tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi
[   0.3063 ] Pre-processing config: tegra234-mb1-bct-pmic-p3767-0000-a02.dts
[   0.3091 ] Pre-processing config: tegra234-mb1-bct-prod-p3767-0000.dts
[   0.3118 ] Pre-processing config: tegra234-p3767-0001-sdram-l4t.dts
[   0.7239 ] Pre-processing config: tegra234-mb1-bct-uphylane-si.dtsi
[   0.7271 ] Pre-processing config: tegra234-p3767-0001-wb0sdram-l4t.dts
[   1.1309 ] Pre-processing config: tegra234-mb1-bct-ratchet-p3767-0000.dts
[   1.1340 ] Generating coldboot mb1-bct
[   1.1342 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3767-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3767-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[   1.1344 ] MB1-BCT version: 0.13
[   1.1358 ] Parsing config file :tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb
[   1.1359 ] Added Platform Config 0 data with size :- 2416
[   1.1378 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb
[   1.1378 ] WARNING: unknown node 'g2'
[   1.1379 ] WARNING: unknown node 'g2'
[   1.1379 ] WARNING: unknown node 'g9'
[   1.1379 ] Added Platform Config 2 data with size :- 24
[   1.1380 ] Parsing config file :tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb
[   1.1380 ] Added Platform Config 4 data with size :- 288
[   1.1381 ] Parsing config file :tegra234-mb1-bct-reset-p3767-0000_cpp.dtb
[   1.1381 ] Added Platform Config 3 data with size :- 52
[   1.1382 ]
[   1.1382 ] Parsing config file :tegra234-mb1-bct-prod-p3767-0000_cpp.dtb
[   1.1382 ] WARNING: unknown property 'major'
[   1.1382 ] WARNING: unknown property 'minor'
[   1.1382 ] Added Platform Config 5 data with size :- 512
[   1.1382 ]
[   1.1382 ] Parsing config file :tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb
[   1.1382 ] Added Platform Config 7 data with size :- 380
[   1.1382 ]
[   1.1382 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[   1.1382 ] Added Platform Config 8 data with size :- 24
[   1.1382 ]
[   1.1382 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   1.1382 ] Added Platform Config 9 data with size :- 100
[   1.1382 ]
[   1.1382 ] Parsing config file :tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[   1.1382 ] ModuleCount 0 NumProdNames 0
[   1.1382 ] Added Platform Config 6 data with size :- 16
[   1.1382 ]
[   1.1382 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[   1.1382 ]
[   1.1383 ] Updating mb1-bct with firmware information
[   1.1384 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[   1.1438 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   1.1440 ] Generating SHA2 Hash for mb1bct
[   1.1449 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[   1.1452 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[   1.1449 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   1.1450 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   1.1458 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   1.1459 ] Assuming zero filled SBK key
[   1.1464 ] Warning: pub_key.key is not found
[   1.1462 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   1.1465 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[   1.1467 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   1.1474 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   1.1475 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   1.1492 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   1.1492 ] Header already present for tsec_t234_aligned.bin
[   1.1502 ] Header already present for nvdec_t234_prod_aligned.fw
[   1.1513 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[   1.1536 ] adding BCH for xusb_t234_prod_aligned.bin
[   1.1586 ] Header already present for bpmp_t234-TE980M-A1_prod_aligned.bin
[   1.1619 ] adding BCH for tegra234-bpmp-3767-0001-3509-a02_with_odm_aligned.dtb
[   1.1685 ] Header already present for pscfw_t234_prod_aligned.bin
[   1.1715 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[   1.1734 ] Header already present for sc7_t234_prod.bin
[   1.1745 ] Header already present for psc_rf_t234_prod_aligned.bin
[   1.1756 ] adding BCH for mb2rf_t234_aligned.bin
[   1.1763 ] INFO: compressing uefi_jetson_with_dtb_aligned.bin
[   1.2014 ] INFO: complete compression, uefi_jetson_with_dtb_aligned.bin, ratio = 91%
[   1.2043 ] adding BCH for uefi_jetson_with_dtb_aligned_blob_w_bin_aligned.bin
[   1.2275 ] adding BCH for tos-optee_t234_aligned.img
[   1.2497 ] adding BCH for eks_t234_aligned.img
[   1.2693 ] INFO: compressing display-t234-dce_with_tegra234-p3768-0000+p3767-0001-nv_with_odm_overlay.dtb_aligned.bin
[   1.3491 ] INFO: complete compression, display-t234-dce_with_tegra234-p3768-0000+p3767-0001-nv_with_odm_overlay.dtb_aligned.bin, ratio = 6%
[   1.3582 ] adding BCH for display-t234-dce_with_tegra234-p3768-0000+p3767-0001-nv_with_odm_overlay.dtb_aligned_blob_w_bin_aligned.bin
[   1.3663 ] adding BCH for spe_t234_aligned.bin
[   1.3711 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[   1.3745 ] adding BCH for adsp-fw_aligned.bin
[   1.3800 ] INFO: compressing nvpva_020_aligned.fw
[   1.4004 ] INFO: complete compression, nvpva_020_aligned.fw, ratio = 2%
[   1.4014 ] adding BCH for nvpva_020_aligned_blob_w_bin_aligned.fw
[   1.4023 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   1.4030 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   1.4031 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   1.4049 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   1.4050 ] Header already present for tsec_t234_aligned.bin
[   1.4058 ] Header already present for nvdec_t234_prod_aligned.fw
[   1.4069 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[   1.4092 ] adding BCH for xusb_t234_prod_aligned.bin
[   1.4150 ] Header already present for bpmp_t234-TE980M-A1_prod_aligned.bin
[   1.4179 ] adding BCH for tegra234-bpmp-3767-0001-3509-a02_with_odm_aligned.dtb
[   1.4241 ] Header already present for pscfw_t234_prod_aligned.bin
[   1.4271 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[   1.4289 ] Header already present for sc7_t234_prod.bin
[   1.4299 ] Header already present for psc_rf_t234_prod_aligned.bin
[   1.4312 ] adding BCH for mb2rf_t234_aligned.bin
[   1.4320 ] INFO: compressing uefi_jetson_with_dtb_aligned.bin
[   1.4573 ] INFO: complete compression, uefi_jetson_with_dtb_aligned.bin, ratio = 91%
[   1.4602 ] adding BCH for uefi_jetson_with_dtb_aligned_blob_w_bin_aligned.bin
[   1.4838 ] adding BCH for tos-optee_t234_aligned.img
[   1.5058 ] adding BCH for eks_t234_aligned.img
[   1.5251 ] INFO: compressing display-t234-dce_with_tegra234-p3768-0000+p3767-0001-nv_with_odm_overlay.dtb_aligned.bin
[   1.6085 ] INFO: complete compression, display-t234-dce_with_tegra234-p3768-0000+p3767-0001-nv_with_odm_overlay.dtb_aligned.bin, ratio = 6%
[   1.6162 ] adding BCH for display-t234-dce_with_tegra234-p3768-0000+p3767-0001-nv_with_odm_overlay.dtb_aligned_blob_w_bin_aligned.bin
[   1.6245 ] adding BCH for spe_t234_aligned.bin
[   1.6292 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[   1.6327 ] adding BCH for adsp-fw_aligned.bin
[   1.6383 ] INFO: compressing nvpva_020_aligned.fw
[   1.6581 ] INFO: complete compression, nvpva_020_aligned.fw, ratio = 2%
[   1.6591 ] adding BCH for nvpva_020_aligned_blob_w_bin_aligned.fw
[   1.6606 ] Filling MB1 storage info
[   1.6606 ] Parsing dev params for multi chains
[   1.6637 ] Generating br-bct
[   1.6639 ] Updating dev and MSS params in BR BCT
[   1.6639 ] tegrabct_v2 --dev_param tegra234-br-bct-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   1.7081 ] Updating bl info
[   1.7084 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[   1.7124 ] Generating br-bct
[   1.7125 ] Updating dev and MSS params in BR BCT
[   1.7125 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   1.7579 ] Updating bl info
[   1.7582 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[   1.7589 ] Generating BCT backup image
[   1.7589 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[   1.7592 ] 32768+0 records in
[   1.7796 ] 32768+0 records out
[   1.7796 ] 32768 bytes (33 kB, 32 KiB) copied, 0.0200753 s, 1.6 MB/s
[   1.7796 ]
[   1.7796 ] Concatenating BCT for chain A to bct_backup.img
[   1.7796 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[   1.7800 ] 8192+0 records in
[   1.7838 ] 8192+0 records out
[   1.7838 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.00369585 s, 2.2 MB/s
[   1.7838 ]
[   1.7839 ] Concatenating BCT for chain B to bct_backup.img
[   1.7839 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[   1.7842 ] 8192+0 records in
[   1.7880 ] 8192+0 records out
[   1.7880 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.00368592 s, 2.2 MB/s
[   1.7880 ]
[   1.7880 ] Generating signatures
[   1.7884 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[   1.7885 ] Assuming zero filled SBK key
[   1.8226 ] Warning: pub_key.key is not found
[   1.8232 ] Parsing dev params for multi chains
[   1.8232 ] Generating br-bct
[   1.8234 ] Updating dev and MSS params in BR BCT
[   1.8234 ] tegrabct_v2 --dev_param tegra234-br-bct-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   1.8673 ] Updating customer data section
[   1.8676 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[   1.8679 ] Updating bl info
[   1.8681 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   1.8688 ] Generating SHA2 Hash
[   1.8696 ] Sha saved in br_bct_BR.sha
[   1.8692 ] Get Signed section of bct
[   1.8694 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   1.8696 ] Signing BCT
[   1.8700 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   1.8701 ] Assuming zero filled SBK key
[   1.8708 ] Sha saved in br_bct_BR.sha
[   1.8709 ] Warning: pub_key.key is not found
[   1.8705 ] Updating BCT with signature
[   1.8706 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   1.8708 ] Offset :4608 Len :3584
[   1.8709 ] Generating SHA2 Hash
[   1.8713 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   1.8713 ] Assuming zero filled SBK key
[   1.8720 ] Sha saved in br_bct_BR.sha
[   1.8717 ] Updating BCT with SHA2 Hash
[   1.8718 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   1.8719 ] Offset :4608 Len :3584
[   1.8720 ] Offset :68 Len :8124
[   1.8721 ] Generating br-bct
[   1.8722 ] Updating dev and MSS params in BR BCT
[   1.8722 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   1.9159 ] Updating customer data section
[   1.9163 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[   1.9167 ] Updating bl info
[   1.9169 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   1.9178 ] Generating SHA2 Hash
[   1.9186 ] Sha saved in br_bct_BR.sha
[   1.9183 ] Get Signed section of bct
[   1.9184 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   1.9186 ] Signing BCT
[   1.9190 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   1.9191 ] Assuming zero filled SBK key
[   1.9199 ] Sha saved in br_bct_BR.sha
[   1.9200 ] Warning: pub_key.key is not found
[   1.9196 ] Updating BCT with signature
[   1.9197 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   1.9198 ] Offset :4608 Len :3584
[   1.9199 ] Generating SHA2 Hash
[   1.9203 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   1.9204 ] Assuming zero filled SBK key
[   1.9210 ] Sha saved in br_bct_BR.sha
[   1.9207 ] Updating BCT with SHA2 Hash
[   1.9208 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   1.9208 ] Offset :4608 Len :3584
[   1.9209 ] Offset :68 Len :8124
[   1.9210 ] Generating BCT backup image
[   1.9210 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[   1.9211 ] 32768+0 records in
[   1.9430 ] 32768+0 records out
[   1.9430 ] 32768 bytes (33 kB, 32 KiB) copied, 0.0216356 s, 1.5 MB/s
[   1.9431 ] Concatenating BCT for chain A to bct_backup.img
[   1.9431 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[   1.9434 ] 8192+0 records in
[   1.9472 ] 8192+0 records out
[   1.9472 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.00364549 s, 2.2 MB/s
[   1.9472 ]
[   1.9472 ] Concatenating BCT for chain B to bct_backup.img
[   1.9472 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[   1.9474 ] 8192+0 records in
[   1.9513 ] 8192+0 records out
[   1.9513 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.0037449 s, 2.2 MB/s
[   1.9513 ]
[   1.9513 ] Generating coldboot mb1-bct
[   1.9514 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3767-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3767-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[   1.9516 ] MB1-BCT version: 0.13
[   1.9530 ] Parsing config file :tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb
[   1.9530 ] Added Platform Config 0 data with size :- 2416
[   1.9549 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb
[   1.9550 ] WARNING: unknown node 'g2'
[   1.9550 ] WARNING: unknown node 'g9'
[   1.9550 ] Added Platform Config 2 data with size :- 24
[   1.9551 ] Parsing config file :tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb
[   1.9551 ] Added Platform Config 4 data with size :- 288
[   1.9552 ] Parsing config file :tegra234-mb1-bct-reset-p3767-0000_cpp.dtb
[   1.9552 ] Added Platform Config 3 data with size :- 52
[   1.9552 ]
[   1.9552 ] Parsing config file :tegra234-mb1-bct-prod-p3767-0000_cpp.dtb
[   1.9553 ] WARNING: unknown property 'major'
[   1.9553 ] WARNING: unknown property 'minor'
[   1.9553 ] Added Platform Config 5 data with size :- 512
[   1.9553 ]
[   1.9553 ] Parsing config file :tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb
[   1.9553 ] Added Platform Config 7 data with size :- 380
[   1.9553 ]
[   1.9553 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[   1.9553 ] Added Platform Config 8 data with size :- 24
[   1.9553 ]
[   1.9553 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   1.9553 ] Added Platform Config 9 data with size :- 100
[   1.9553 ]
[   1.9553 ] Parsing config file :tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[   1.9553 ] ModuleCount 0 NumProdNames 0
[   1.9553 ] Added Platform Config 6 data with size :- 16
[   1.9553 ]
[   1.9553 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[   1.9553 ]
[   1.9553 ] Updating mb1-bct with firmware information
[   1.9554 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[   1.9559 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   1.9560 ] Generating SHA2 Hash for mb1bct
[   1.9568 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[   1.9571 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[   1.9568 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   1.9569 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   1.9577 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   1.9578 ] Assuming zero filled SBK key
[   1.9582 ] Warning: pub_key.key is not found
[   1.9580 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   1.9583 ] Generating recovery mb1-bct
[   1.9585 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3767-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3767-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[   1.9586 ] MB1-BCT version: 0.13
[   1.9600 ] Parsing config file :tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb
[   1.9600 ] Added Platform Config 0 data with size :- 2416
[   1.9619 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb
[   1.9620 ] WARNING: unknown node 'g2'
[   1.9620 ] WARNING: unknown node 'g9'
[   1.9621 ] Added Platform Config 2 data with size :- 24
[   1.9621 ] Parsing config file :tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb
[   1.9622 ] Added Platform Config 4 data with size :- 288
[   1.9622 ] Parsing config file :tegra234-mb1-bct-reset-p3767-0000_cpp.dtb
[   1.9622 ] Added Platform Config 3 data with size :- 52
[   1.9623 ] Parsing config file :tegra234-mb1-bct-prod-p3767-0000_cpp.dtb
[   1.9623 ] WARNING: unknown property 'major'
[   1.9623 ] WARNING: unknown property 'minor'
[   1.9623 ] Added Platform Config 5 data with size :- 512
[   1.9623 ]
[   1.9623 ] Parsing config file :tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb
[   1.9623 ] Added Platform Config 7 data with size :- 380
[   1.9623 ]
[   1.9623 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[   1.9623 ] Added Platform Config 8 data with size :- 24
[   1.9623 ]
[   1.9623 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   1.9623 ] Added Platform Config 9 data with size :- 100
[   1.9623 ]
[   1.9623 ] Parsing config file :tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[   1.9623 ] ModuleCount 0 NumProdNames 0
[   1.9623 ] Added Platform Config 6 data with size :- 16
[   1.9623 ]
[   1.9623 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[   1.9623 ]
[   1.9624 ] Updating mb1-bct with firmware information
[   1.9625 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo flash.xml.bin
[   1.9631 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[   1.9633 ] Generating SHA2 Hash for mb1bct
[   1.9644 ] Sha saved in mb1_bct_MB1_aligned.sha
[   1.9654 ] Sha saved in mb1_bct_MB1.sha
[   1.9653 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   1.9655 ] adding BCH for mb1_bct_MB1_aligned.bct
[   1.9662 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   1.9663 ] Assuming zero filled SBK key
[   1.9667 ] Warning: pub_key.key is not found
[   1.9664 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   1.9667 ] Generating coldboot mem-bct
[   1.9669 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --membct tegra234-p3767-0001-sdram-l4t_cpp_1.bct tegra234-p3767-0001-sdram-l4t_cpp_2.bct tegra234-p3767-0001-sdram-l4t_cpp_3.bct tegra234-p3767-0001-sdram-l4t_cpp_4.bct
[   1.9670 ]  packing sdram params with Wb0 file tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb
[   2.0103 ] Packing sdram param for instance[0]
[   2.0103 ] Packing sdram param for instance[1]
[   2.0104 ] Packing sdram param for instance[2]
[   2.0104 ] Packing sdram param for instance[3]
[   2.0104 ] Packing sdram param for instance[4]
[   2.0104 ] Packing sdram param for instance[5]
[   2.0105 ] Packing sdram param for instance[6]
[   2.0105 ] Packing sdram param for instance[7]
[   2.0105 ] Packing sdram param for instance[8]
[   2.0106 ] Packing sdram param for instance[9]
[   2.0106 ] Packing sdram param for instance[10]
[   2.0106 ] Packing sdram param for instance[11]
[   2.0107 ] Packing sdram param for instance[12]
[   2.0107 ] Packing sdram param for instance[13]
[   2.0107 ] Packing sdram param for instance[14]
[   2.0107 ] Packing sdram param for instance[15]
[   2.0555 ] Getting sector size from pt
[   2.0557 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[   2.0561 ] BlockSize read from layout is 0x200
[   2.0563 ] tegrahost_v2 --chip 0x23 0 --blocksize 512 --magicid MEMB --addsigheader_multi tegra234-p3767-0001-sdram-l4t_cpp_1.bct tegra234-p3767-0001-sdram-l4t_cpp_2.bct tegra234-p3767-0001-sdram-l4t_cpp_3.bct tegra234-p3767-0001-sdram-l4t_cpp_4.bct
[   2.0565 ] Binary 0 length is 58752
[   2.0565 ] Binary 0 align length is 58880
[   2.0568 ] Binary 1 length is 58752
[   2.0568 ] Binary 1 align length is 58880
[   2.0573 ] Binary 2 length is 58752
[   2.0573 ] Binary 2 align length is 58880
[   2.0576 ] Binary 3 length is 58752
[   2.0576 ] Binary 3 align length is 58880
[   2.0579 ] Buffer length is 235520
[   2.0579 ] adding BCH for tegra234-p3767-0001-sdram-l4t_cpp_1.bct
[   2.0579 ] new length is 243712
[   2.0585 ] tegrahost_v2 --chip 0x23 0 --align mem_coldboot_aligned.bct
[   2.0588 ] tegrahost_v2 --chip 0x23 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_coldboot_aligned.bct zerosbk
[   2.0588 ] Header already present for mem_coldboot_aligned.bct
[   2.0596 ] tegrasign_v3.py --key None --list mem_coldboot_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.0597 ] Assuming zero filled SBK key
[   2.0603 ] Warning: pub_key.key is not found
[   2.0601 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_coldboot_aligned_sigheader.bct.encrypt mem_coldboot_aligned_sigheader.bct.hash zerosbk
[   2.0607 ] Generating recovery mem-bct
[   2.0609 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --membct tegra234-p3767-0001-sdram-l4t_cpp_1.bct tegra234-p3767-0001-sdram-l4t_cpp_2.bct tegra234-p3767-0001-sdram-l4t_cpp_3.bct tegra234-p3767-0001-sdram-l4t_cpp_4.bct
[   2.0610 ]  packing sdram params with Wb0 file tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb
[   2.1043 ] Packing sdram param for instance[0]
[   2.1043 ] Packing sdram param for instance[1]
[   2.1044 ] Packing sdram param for instance[2]
[   2.1044 ] Packing sdram param for instance[3]
[   2.1044 ] Packing sdram param for instance[4]
[   2.1045 ] Packing sdram param for instance[5]
[   2.1045 ] Packing sdram param for instance[6]
[   2.1045 ] Packing sdram param for instance[7]
[   2.1045 ] Packing sdram param for instance[8]
[   2.1046 ] Packing sdram param for instance[9]
[   2.1046 ] Packing sdram param for instance[10]
[   2.1046 ] Packing sdram param for instance[11]
[   2.1047 ] Packing sdram param for instance[12]
[   2.1047 ] Packing sdram param for instance[13]
[   2.1047 ] Packing sdram param for instance[14]
[   2.1048 ] Packing sdram param for instance[15]
[   2.1477 ] Reading ramcode from backup chip_info.bin file
[   2.1478 ] RAMCODE Read from Device: 2
[   2.1478 ] Using ramcode 0
[   2.1478 ] Disabled BPMP dtb trim, using default dtb
[   2.1478 ]
[   2.1484 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_aligned.bct
[   2.1489 ] tegrahost_v2 --chip 0x23 0 --magicid MEM0 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_aligned.bct zerosbk
[   2.1491 ] adding BCH for mem_rcm_aligned.bct
[   2.1504 ] tegrasign_v3.py --key None --list mem_rcm_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.1505 ] Assuming zero filled SBK key
[   2.1512 ] Warning: pub_key.key is not found
[   2.1510 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_aligned_sigheader.bct.encrypt mem_rcm_aligned_sigheader.bct.hash zerosbk
[   2.1515 ] Copying signatures
[   2.1516 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[   2.1763 ] tegraparser_v2 --generategpt --pt flash.xml.bin
[   2.1764 ] gpt_secondary_3_0.bin:
[   2.1767 ] partition_id	partition_name			      StartingLba	EndingLba
[   2.1767 ]            1	BCT                                 	       0	    2047
[   2.1768 ]            2	A_mb1                               	    2048	    3071
[   2.1768 ]            3	A_psc_bl1                           	    3072	    3583
[   2.1769 ]            4	A_MB1_BCT                           	    3584	    3839
[   2.1769 ]            5	A_MEM_BCT                           	    3840	    4351
[   2.1770 ]            6	A_tsec-fw                           	    4352	    6399
[   2.1771 ]            7	A_nvdec                             	    6400	    8447
[   2.1771 ]            8	A_mb2                               	    8448	    9471
[   2.1772 ]            9	A_xusb-fw                           	    9472	    9983
[   2.1772 ]           10	A_bpmp-fw                           	    9984	   13055
[   2.1773 ]           11	A_bpmp-fw-dtb                       	   13056	   21247
[   2.1774 ]           12	A_psc-fw                            	   21248	   22783
[   2.1774 ]           13	A_mts-mce                           	   22784	   23807
[   2.1774 ]           14	A_sc7                               	   23808	   24191
[   2.1774 ]           15	A_pscrf                             	   24192	   24575
[   2.1774 ]           16	A_mb2rf                             	   24576	   24831
[   2.1774 ]           17	A_cpu-bootloader                    	   24832	   31999
[   2.1774 ]           18	A_secure-os                         	   32000	   40191
[   2.1774 ]           19	A_smm-fw                            	   40192	   44287
[   2.1774 ]           20	A_eks                               	   44288	   44799
[   2.1774 ]           21	A_dce-fw                            	   44800	   55039
[   2.1774 ]           22	A_spe-fw                            	   55040	   56191
[   2.1774 ]           23	A_rce-fw                            	   56192	   58239
[   2.1774 ]           24	A_adsp-fw                           	   58240	   62335
[   2.1774 ]           25	A_pva-fw                            	   62336	   62847
[   2.1774 ]           26	A_reserved_on_boot                  	   62848	   65023
[   2.1774 ]           27	B_mb1                               	   65024	   66047
[   2.1774 ]           28	B_psc_bl1                           	   66048	   66559
[   2.1774 ]           29	B_MB1_BCT                           	   66560	   66815
[   2.1774 ]           30	B_MEM_BCT                           	   66816	   67327
[   2.1774 ]           31	B_tsec-fw                           	   67328	   69375
[   2.1774 ]           32	B_nvdec                             	   69376	   71423
[   2.1774 ]           33	B_mb2                               	   71424	   72447
[   2.1774 ]           34	B_xusb-fw                           	   72448	   72959
[   2.1774 ]           35	B_bpmp-fw                           	   72960	   76031
[   2.1774 ]           36	B_bpmp-fw-dtb                       	   76032	   84223
[   2.1774 ]           37	B_psc-fw                            	   84224	   85759
[   2.1774 ]           38	B_mts-mce                           	   85760	   86783
[   2.1774 ]           39	B_sc7                               	   86784	   87167
[   2.1774 ]           40	B_pscrf                             	   87168	   87551
[   2.1774 ]           41	B_mb2rf                             	   87552	   87807
[   2.1774 ]           42	B_cpu-bootloader                    	   87808	   94975
[   2.1774 ]           43	B_secure-os                         	   94976	  103167
[   2.1774 ]           44	B_smm-fw                            	  103168	  107263
[   2.1774 ]           45	B_eks                               	  107264	  107775
[   2.1774 ]           46	B_dce-fw                            	  107776	  118015
[   2.1774 ]           47	B_spe-fw                            	  118016	  119167
[   2.1774 ]           48	B_rce-fw                            	  119168	  121215
[   2.1774 ]           49	B_adsp-fw                           	  121216	  125311
[   2.1774 ]           50	B_pva-fw                            	  125312	  125823
[   2.1774 ]           51	B_reserved_on_boot                  	  125824	  127999
[   2.1774 ]           52	uefi_variables                      	  128000	  128511
[   2.1774 ]           53	uefi_ftw                            	  128512	  129535
[   2.1774 ]           54	reserved                            	  129536	  129919
[   2.1774 ]           55	worm                                	  129920	  130303
[   2.1774 ]           56	BCT-boot-chain_backup               	  130304	  130431
[   2.1774 ]           57	reserved_partition                  	  130432	  130559
[   2.1774 ]           58	secondary_gpt_backup                	  130560	  130687
[   2.1774 ]           59	B_VER                               	  130688	  130815
[   2.1774 ]           60	A_VER                               	  130816	  130943
[   2.1774 ]
[   2.1811 ] tegrahost_v2 --chip 0x23 0 --align uefi_jetson_with_dtb_aligned.bin
[   2.1815 ] tegrahost_v2 --chip 0x23 0 --magicid CPBL --ratchet_blob ratchet_blob.bin --appendsigheader uefi_jetson_with_dtb_aligned.bin zerosbk
[   2.1816 ] adding BCH for uefi_jetson_with_dtb_aligned.bin
[   2.2256 ] tegrasign_v3.py --key None --list uefi_jetson_with_dtb_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.2257 ] Assuming zero filled SBK key
[   2.2300 ] Warning: pub_key.key is not found
[   2.2299 ] tegrahost_v2 --chip 0x23 0 --updatesigheader uefi_jetson_with_dtb_aligned_sigheader.bin.encrypt uefi_jetson_with_dtb_aligned_sigheader.bin.hash zerosbk
[   2.2343 ] Copying enc\/signed file in /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed
[   2.2452 ] Copying br bct for multi chains
[   2.2452 ] Signed BCT for boot chain A is copied to /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/br_bct_BR.bct
[   2.2453 ] Signed BCT for boot chain B is copied to /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/br_bct_b_BR.bct
[   2.2453 ] Copying BCT backup image bct_backup.img to /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/bct_backup.img
[   2.2465 ] Copying uefi_jetson_with_dtb_sigheader.bin.encrypt to /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed
[   2.2477 ] Signed file: /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/uefi_jetson_with_dtb_sigheader.bin.encrypt
[   2.2491 ] tegraparser_v2 --pt flash.xml.bin --generateflashindex /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/flash.xml.tmp flash.idx
Using bpmp-dtb concatenated with odmdata in blob for t23x
./tegraflash.py --bl uefi_jetson_with_dtb_sigheader.bin.encrypt --bct br_bct_BR.bct --bldtb tegra234-p3768-0000+p3767-0001-nv.dtb --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --cmd "secureflash;reboot"  --cfg secureflash.xml --chip 0x23 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mb1_bin mb1_t234_prod_aligned_sigheader.bin.encrypt --psc_bl1_bin psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt  --bins "psc_fw pscfw_t234_prod_sigheader.bin.encrypt; mts_mce mce_flash_o10_cr_prod_sigheader.bin.encrypt; tsec_fw tsec_t234_sigheader.bin.encrypt; mb2_applet applet_t234_sigheader.bin.encrypt; mb2_bootloader mb2_t234_with_mb2_bct_MB2_sigheader.bin.encrypt; xusb_fw xusb_t234_prod_sigheader.bin.encrypt; pva_fw nvpva_020_sigheader.fw.encrypt; dce_fw display-t234-dce_sigheader.bin.encrypt; nvdec nvdec_t234_prod_sigheader.fw.encrypt; bpmp_fw bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt; bpmp_fw_dtb tegra234-bpmp-3767-0001-3509-a02_with_odm_sigheader.dtb.encrypt; rce_fw camera-rtcpu-t234-rce_sigheader.img.encrypt; ape_fw adsp-fw_sigheader.bin.encrypt; spe_fw spe_t234_sigheader.bin.encrypt; tos tos-optee_t234_sigheader.img.encrypt; eks eks_t234_sigheader.img.encrypt"    --bct_backup
saving flash command in flashcmd.txt
*** no-flash flag enabled. Exiting now... ***
User can run above saved command in factory environment without
providing pkc and sbk keys to flash a device
Example:
    $ cd bootloader
    $ sudo bash ./flashcmd.txt
'/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/flash.idx' -> '/home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/flash.idx'
Flash index file is /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/flash.idx
Number of lines is 61
max_index=60
Copying /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/br_bct_BR.bct  /home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/br_bct_BR.bct
'/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/br_bct_BR.bct' -> '/home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/br_bct_BR.bct'
Copying /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/mb1_t234_prod_aligned_sigheader.bin.encrypt  /home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/mb1_t234_prod_aligned_sigheader.bin.encrypt
'/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/mb1_t234_prod_aligned_sigheader.bin.encrypt' -> '/home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/mb1_t234_prod_aligned_sigheader.bin.encrypt'
Copying /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/psc_bl1_t234_prod_aligned_sigheader.bin.encrypt  /home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/psc_bl1_t234_prod_aligned_sigheader.bin.encrypt
'/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/psc_bl1_t234_prod_aligned_sigheader.bin.encrypt' -> '/home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/psc_bl1_t234_prod_aligned_sigheader.bin.encrypt'
Copying /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt  /home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
'/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt' -> '/home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt'
Copying /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/mem_coldboot_sigheader.bct.encrypt  /home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/mem_coldboot_sigheader.bct.encrypt
'/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/mem_coldboot_sigheader.bct.encrypt' -> '/home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/mem_coldboot_sigheader.bct.encrypt'
Copying /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/tsec_t234_sigheader.bin.encrypt  /home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/tsec_t234_sigheader.bin.encrypt
'/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/tsec_t234_sigheader.bin.encrypt' -> '/home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/tsec_t234_sigheader.bin.encrypt'
Copying /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/nvdec_t234_prod_sigheader.fw.encrypt  /home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/nvdec_t234_prod_sigheader.fw.encrypt
'/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/nvdec_t234_prod_sigheader.fw.encrypt' -> '/home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/nvdec_t234_prod_sigheader.fw.encrypt'
Copying /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt  /home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt
'/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt' -> '/home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt'
Copying /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/xusb_t234_prod_sigheader.bin.encrypt  /home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/xusb_t234_prod_sigheader.bin.encrypt
'/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/xusb_t234_prod_sigheader.bin.encrypt' -> '/home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/xusb_t234_prod_sigheader.bin.encrypt'
Copying /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt  /home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt
'/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt' -> '/home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt'
Copying /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/tegra234-bpmp-3767-0001-3509-a02_with_odm_sigheader.dtb.encrypt  /home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/tegra234-bpmp-3767-0001-3509-a02_with_odm_sigheader.dtb.encrypt
'/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/tegra234-bpmp-3767-0001-3509-a02_with_odm_sigheader.dtb.encrypt' -> '/home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/tegra234-bpmp-3767-0001-3509-a02_with_odm_sigheader.dtb.encrypt'
Copying /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/pscfw_t234_prod_sigheader.bin.encrypt  /home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/pscfw_t234_prod_sigheader.bin.encrypt
'/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/pscfw_t234_prod_sigheader.bin.encrypt' -> '/home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/pscfw_t234_prod_sigheader.bin.encrypt'
Copying /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/mce_flash_o10_cr_prod_sigheader.bin.encrypt  /home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/mce_flash_o10_cr_prod_sigheader.bin.encrypt
'/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/mce_flash_o10_cr_prod_sigheader.bin.encrypt' -> '/home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/mce_flash_o10_cr_prod_sigheader.bin.encrypt'
Copying /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/sc7_t234_prod_sigheader.bin.encrypt  /home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/sc7_t234_prod_sigheader.bin.encrypt
'/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/sc7_t234_prod_sigheader.bin.encrypt' -> '/home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/sc7_t234_prod_sigheader.bin.encrypt'
Copying /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/psc_rf_t234_prod_sigheader.bin.encrypt  /home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/psc_rf_t234_prod_sigheader.bin.encrypt
'/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/psc_rf_t234_prod_sigheader.bin.encrypt' -> '/home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/psc_rf_t234_prod_sigheader.bin.encrypt'
Copying /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/mb2rf_t234_sigheader.bin.encrypt  /home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/mb2rf_t234_sigheader.bin.encrypt
'/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/mb2rf_t234_sigheader.bin.encrypt' -> '/home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/mb2rf_t234_sigheader.bin.encrypt'
Copying /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/uefi_jetson_with_dtb_aligned_blob_w_bin_sigheader.bin.encrypt  /home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/uefi_jetson_with_dtb_aligned_blob_w_bin_sigheader.bin.encrypt
'/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/uefi_jetson_with_dtb_aligned_blob_w_bin_sigheader.bin.encrypt' -> '/home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/uefi_jetson_with_dtb_aligned_blob_w_bin_sigheader.bin.encrypt'
Copying /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/tos-optee_t234_sigheader.img.encrypt  /home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/tos-optee_t234_sigheader.img.encrypt
'/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/tos-optee_t234_sigheader.img.encrypt' -> '/home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/tos-optee_t234_sigheader.img.encrypt'
Warning: skip writing A_smm-fw partition as no image is specified
Copying /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/eks_t234_sigheader.img.encrypt  /home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/eks_t234_sigheader.img.encrypt
'/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/eks_t234_sigheader.img.encrypt' -> '/home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/eks_t234_sigheader.img.encrypt'
Copying /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/display-t234-dce_with_tegra234-p3768-0000+p3767-0001-nv_with_odm_overlay.dtb_aligned_blob_w_bin_sigheader.bin.encrypt  /home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/display-t234-dce_with_tegra234-p3768-0000+p3767-0001-nv_with_odm_overlay.dtb_aligned_blob_w_bin_sigheader.bin.encrypt
'/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/display-t234-dce_with_tegra234-p3768-0000+p3767-0001-nv_with_odm_overlay.dtb_aligned_blob_w_bin_sigheader.bin.encrypt' -> '/home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/display-t234-dce_with_tegra234-p3768-0000+p3767-0001-nv_with_odm_overlay.dtb_aligned_blob_w_bin_sigheader.bin.encrypt'
Copying /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/spe_t234_sigheader.bin.encrypt  /home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/spe_t234_sigheader.bin.encrypt
'/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/spe_t234_sigheader.bin.encrypt' -> '/home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/spe_t234_sigheader.bin.encrypt'
Copying /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/camera-rtcpu-t234-rce_sigheader.img.encrypt  /home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/camera-rtcpu-t234-rce_sigheader.img.encrypt
'/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/camera-rtcpu-t234-rce_sigheader.img.encrypt' -> '/home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/camera-rtcpu-t234-rce_sigheader.img.encrypt'
Copying /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/adsp-fw_sigheader.bin.encrypt  /home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/adsp-fw_sigheader.bin.encrypt
'/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/adsp-fw_sigheader.bin.encrypt' -> '/home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/adsp-fw_sigheader.bin.encrypt'
Copying /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/nvpva_020_aligned_blob_w_bin_sigheader.fw.encrypt  /home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/nvpva_020_aligned_blob_w_bin_sigheader.fw.encrypt
'/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/nvpva_020_aligned_blob_w_bin_sigheader.fw.encrypt' -> '/home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/nvpva_020_aligned_blob_w_bin_sigheader.fw.encrypt'
Warning: skip writing A_reserved_on_boot partition as no image is specified
Warning: skip writing B_smm-fw partition as no image is specified
Warning: skip writing B_reserved_on_boot partition as no image is specified
Warning: skip writing uefi_variables partition as no image is specified
Warning: skip writing uefi_ftw partition as no image is specified
Warning: skip writing reserved partition as no image is specified
Warning: skip writing worm partition as no image is specified
Copying /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/bct_backup.img  /home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/bct_backup.img
'/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/bct_backup.img' -> '/home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/bct_backup.img'
Warning: skip writing reserved_partition partition as no image is specified
Copying /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/gpt_backup_secondary_3_0.bin  /home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/gpt_backup_secondary_3_0.bin
'/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/gpt_backup_secondary_3_0.bin' -> '/home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/gpt_backup_secondary_3_0.bin'
Copying /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/qspi_bootblob_ver.txt  /home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/qspi_bootblob_ver.txt
'/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/qspi_bootblob_ver.txt' -> '/home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/qspi_bootblob_ver.txt'
Copying /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/gpt_secondary_3_0.bin  /home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/gpt_secondary_3_0.bin
'/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/gpt_secondary_3_0.bin' -> '/home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/external/gpt_secondary_3_0.bin'
Copy flash script to /home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images
'/home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/l4t_flash_from_kernel.sh' -> '/home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/l4t_flash_from_kernel.sh'
Success
I add the rest of the output in the next reply.
*  Step 2: Generate rcm boot commandline *
ROOTFS_AB= ROOTFS_ENC= /home/ai-blox/Desktop/test/Linux_for_Tegra/flash.sh  --no-flash --rcm-boot jetson-orin-nano-devkit mmcblk0p1
# L4T BSP Information:
# R36 , REVISION: 3.0
# User release: 0.0
ECID is 0x80012344705DE5C07400000009FE8280
Existing emcfuse(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/fuse_t234.xml) reused.
copying emc_fuse_dev_params(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct-diag-boot.dts)... done.
copying device_config(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-device-p3767-0000.dts)... done.
copying misc_config(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-misc-p3767-0000.dts)... done.
./tegraflash.py --chip "0x23" --applet "/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3767-0000.dts --misc_config tegra234-mb1-bct-misc-p3767-0000.dts --bins "mb2_applet applet_t234.bin" --cmd "readfuses fuse_t234.bin fuse_t234.xml; dump eeprom cvm cvm.bin; dump try_custinfo custinfo_out.bin; reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[   0.0080 ] Reading fuses
[   0.0082 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.0084 ] File rcm_state open failed
[   0.0084 ] ERROR: failed to read rcm_state
[   0.0084 ]
[   0.0088 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0088 ] Assuming zero filled SBK key
[   0.0085 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[   0.0118 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[   0.0157 ] Parsing partition layout
[   0.0158 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.0163 ] Kernel DTB used: None
[   0.0163 ] WARNING: dce base dtb is not provided
[   0.0163 ] Parsing partition layout
[   0.0164 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.0167 ] Creating list of images to be signed
[   0.0168 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[   0.0169 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.0174 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.0175 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.0198 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.0200 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.0225 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.0226 ] adding BCH for mb2_t234_aligned.bin
[   0.0238 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.0286 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.0289 ] adding BCH for mb2_t234_aligned.bin
[   0.0345 ] Filling MB1 storage info
[   0.0346 ] Parsing dev params for multi chains
[   0.0382 ] Generating br-bct
[   0.0383 ] Updating dev and MSS params in BR BCT
[   0.0383 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.0386 ] Updating bl info
[   0.0387 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[   0.0389 ] WARNING: boot chain is not completed. set to 0
[   0.0395 ] Generating signatures
[   0.0398 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.0399 ] Assuming zero filled SBK key
[   0.0454 ] Warning: pub_key.key is not found
[   0.0452 ] Parsing dev params for multi chains
[   0.0452 ] Generating br-bct
[   0.0454 ] Updating dev and MSS params in BR BCT
[   0.0454 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.0456 ] Updating bl info
[   0.0457 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.0458 ] WARNING: boot chain is not completed. set to 0
[   0.0461 ] Generating SHA2 Hash
[   0.0467 ] Sha saved in br_bct_BR.sha
[   0.0464 ] Get Signed section of bct
[   0.0465 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   0.0467 ] Signing BCT
[   0.0471 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.0472 ] Assuming zero filled SBK key
[   0.0478 ] Sha saved in br_bct_BR.sha
[   0.0478 ] Warning: pub_key.key is not found
[   0.0475 ] Updating BCT with signature
[   0.0476 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   0.0477 ] Offset :4608 Len :3584
[   0.0478 ] Generating SHA2 Hash
[   0.0482 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   0.0482 ] Assuming zero filled SBK key
[   0.0488 ] Sha saved in br_bct_BR.sha
[   0.0485 ] Updating BCT with SHA2 Hash
[   0.0486 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   0.0487 ] Offset :4608 Len :3584
[   0.0488 ] Offset :68 Len :8124
[   0.0489 ] Generating coldboot mb1-bct
[   0.0490 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.0490 ] MB1-BCT version: 0.13
[   0.0504 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.0505 ] Added Platform Config 9 data with size :- 100
[   0.0505 ]
[   0.0506 ] Updating mb1-bct with firmware information
[   0.0507 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.0511 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   0.0512 ] Generating SHA2 Hash for mb1bct
[   0.0518 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[   0.0521 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[   0.0519 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   0.0521 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   0.0529 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.0530 ] Assuming zero filled SBK key
[   0.0537 ] Warning: pub_key.key is not found
[   0.0535 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.0540 ] Generating recovery mb1-bct
[   0.0541 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.0542 ] MB1-BCT version: 0.13
[   0.0557 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.0557 ] Added Platform Config 9 data with size :- 100
[   0.0558 ] Updating mb1-bct with firmware information
[   0.0559 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.0562 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[   0.0563 ] Generating SHA2 Hash for mb1bct
[   0.0569 ] Sha saved in mb1_bct_MB1_aligned.sha
[   0.0572 ] Sha saved in mb1_bct_MB1.sha
[   0.0570 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   0.0571 ] adding BCH for mb1_bct_MB1_aligned.bct
[   0.0579 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.0580 ] Assuming zero filled SBK key
[   0.0583 ] Warning: pub_key.key is not found
[   0.0581 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.0584 ] Info: Skip generating mem_bct because sdram_config is not defined
[   0.0584 ] Copying signatures
[   0.0585 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.0604 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   0.0605 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   0.0605 ] Boot Rom communication
[   0.0606 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   0.0607 ] BR_CID: 0x80012344705DE5C07400000009FE8280
[   2.0850 ] Sending bct_br
[   4.1041 ] Sending mb1
[   4.1051 ] Sending psc_bl1
[   4.1164 ] Sending bct_mb1
[   4.1225 ] Boot Rom communication completed
[   4.1241 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[   4.1256 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --appendsigheader applet_t234_aligned.bin zerosbk
[   4.1263 ] adding BCH for applet_t234_aligned.bin
[   4.1354 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   4.1355 ] Assuming zero filled SBK key
[   4.1367 ] Warning: pub_key.key is not found
[   4.1366 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[   4.1378 ] Sending mb2_applet...
[   4.1381 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[   4.1382 ] BL: version 1.4.0.2-t234-54845784-08a4de08 last_boot_error: 0
[   6.1525 ] Sending applet
[   8.2002 ] completed
[   8.2012 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   8.2020 ] MB2 Applet version 01.00.0000
[  10.2122 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[  10.2130 ] MB2 Applet version 01.00.0000
[  12.2272 ] Parsing fuse info as per xml file
[  12.2282 ] tegraparser_v2 --chip 0x23 0 --get_fuse_names fuse_t234.xml read_fuse_names.txt
[  12.2292 ] MagicId=0x45535546 version=0x2
[  12.2296 ] trying to read fuse with MB2 Applet
[  12.2310 ] tegraparser_v2 --chip 0x23 0 --read_fusetype PublicKeyHash read_fuse.bin
[  12.2332 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  12.2339 ] MB2 Applet version 01.00.0000
[  16.2552 ] Saved read fuses in file __fuse_read_scatter.bin
[  16.2615 ] Fuse read successful
[  16.2633 ] tegraparser_v2 --chip 0x23 0 --read_fusetype PkcPubkeyHash1 read_fuse.bin
[  16.2653 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  16.2662 ] MB2 Applet version 01.00.0000
[  20.6389 ] Saved read fuses in file __fuse_read_scatter.bin
[  20.6448 ] Fuse read successful
[  20.6466 ] tegraparser_v2 --chip 0x23 0 --read_fusetype PkcPubkeyHash2 read_fuse.bin
[  20.6487 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  20.6495 ] MB2 Applet version 01.00.0000
[  24.6791 ] Saved read fuses in file __fuse_read_scatter.bin
[  24.6852 ] Fuse read successful
[  24.6871 ] tegraparser_v2 --chip 0x23 0 --read_fusetype BootSecurityInfo read_fuse.bin
[  24.6892 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  24.6899 ] MB2 Applet version 01.00.0000
[  28.7231 ] Saved read fuses in file __fuse_read_scatter.bin
[  28.7293 ] Fuse read successful
[  28.7312 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ArmJtagDisable read_fuse.bin
[  28.7334 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  28.7341 ] MB2 Applet version 01.00.0000
[  32.7670 ] Saved read fuses in file __fuse_read_scatter.bin
[  32.7732 ] Fuse read successful
[  32.7749 ] tegraparser_v2 --chip 0x23 0 --read_fusetype SecurityMode read_fuse.bin
[  32.7769 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  32.7776 ] MB2 Applet version 01.00.0000
[  36.8111 ] Saved read fuses in file __fuse_read_scatter.bin
[  36.8171 ] Fuse read successful
[  36.8190 ] tegraparser_v2 --chip 0x23 0 --read_fusetype SwReserved read_fuse.bin
[  36.8204 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  36.8209 ] MB2 Applet version 01.00.0000
[  42.0674 ] Saved read fuses in file __fuse_read_scatter.bin
[  42.0736 ] Fuse read successful
[  42.0756 ] tegraparser_v2 --chip 0x23 0 --read_fusetype DebugAuthentication read_fuse.bin
[  42.0773 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  42.0777 ] MB2 Applet version 01.00.0000
[  46.1075 ] Saved read fuses in file __fuse_read_scatter.bin
[  46.1136 ] Fuse read successful
[  46.1156 ] tegraparser_v2 --chip 0x23 0 --read_fusetype OdmInfo read_fuse.bin
[  46.1176 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  46.1184 ] MB2 Applet version 01.00.0000
[  50.1467 ] Saved read fuses in file __fuse_read_scatter.bin
[  50.1528 ] Fuse read successful
[  50.1546 ] tegraparser_v2 --chip 0x23 0 --read_fusetype OdmId read_fuse.bin
[  50.1567 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  50.1575 ] MB2 Applet version 01.00.0000
[  54.1995 ] Saved read fuses in file __fuse_read_scatter.bin
[  54.2056 ] Fuse read successful
[  54.2077 ] tegraparser_v2 --chip 0x23 0 --read_fusetype OdmLock read_fuse.bin
[  54.2097 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  54.2105 ] MB2 Applet version 01.00.0000
[  59.7153 ] Saved read fuses in file __fuse_read_scatter.bin
[  59.7217 ] Fuse read successful
[  59.7236 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm0 read_fuse.bin
[  59.7256 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  59.7263 ] MB2 Applet version 01.00.0000
[  63.7671 ] Saved read fuses in file __fuse_read_scatter.bin
[  63.7731 ] Fuse read successful
[  63.7747 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm1 read_fuse.bin
[  63.7763 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  63.7771 ] MB2 Applet version 01.00.0000
[  67.8033 ] Saved read fuses in file __fuse_read_scatter.bin
[  67.8092 ] Fuse read successful
[  67.8109 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm2 read_fuse.bin
[  67.8128 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  67.8136 ] MB2 Applet version 01.00.0000
[  71.8437 ] Saved read fuses in file __fuse_read_scatter.bin
[  71.8500 ] Fuse read successful
[  71.8518 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm3 read_fuse.bin
[  71.8538 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  71.8546 ] MB2 Applet version 01.00.0000
[  75.8913 ] Saved read fuses in file __fuse_read_scatter.bin
[  75.8974 ] Fuse read successful
[  75.8991 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm4 read_fuse.bin
[  75.9009 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  75.9017 ] MB2 Applet version 01.00.0000
[  79.7553 ] Saved read fuses in file __fuse_read_scatter.bin
[  79.7619 ] Fuse read successful
[  79.7637 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm5 read_fuse.bin
[  79.7656 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  79.7663 ] MB2 Applet version 01.00.0000
[  83.7992 ] Saved read fuses in file __fuse_read_scatter.bin
[  83.8051 ] Fuse read successful
[  83.8073 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm6 read_fuse.bin
[  83.8092 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  83.8100 ] MB2 Applet version 01.00.0000
[  87.8471 ] Saved read fuses in file __fuse_read_scatter.bin
[  87.8530 ] Fuse read successful
[  87.8548 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm7 read_fuse.bin
[  87.8569 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  87.8576 ] MB2 Applet version 01.00.0000
[  91.8954 ] Saved read fuses in file __fuse_read_scatter.bin
[  91.9013 ] Fuse read successful
[  91.9030 ] tegraparser_v2 --chip 0x23 0 --read_fusetype Sku read_fuse.bin
[  91.9050 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  91.9057 ] MB2 Applet version 01.00.0000
[  95.9273 ] Saved read fuses in file __fuse_read_scatter.bin
[  95.9331 ] Fuse read successful
[  95.9350 ] tegraparser_v2 --chip 0x23 0 --read_fusetype Uid read_fuse.bin
[  95.9371 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  95.9380 ] MB2 Applet version 01.00.0000
[ 100.8832 ] Saved read fuses in file __fuse_read_scatter.bin
[ 100.8892 ] Fuse read successful
[ 100.8911 ] tegraparser_v2 --chip 0x23 0 --read_fusetype OptEmcDisable read_fuse.bin
[ 100.8927 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 100.8932 ] MB2 Applet version 01.00.0000
[ 104.9351 ] Saved read fuses in file __fuse_read_scatter.bin
[ 104.9410 ] Fuse read successful
[ 104.9430 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 104.9437 ] MB2 Applet version 01.00.0000
[ 106.9686 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 106.9693 ] MB2 Applet version 01.00.0000
[ 108.9883 ] Retrieving board information
[ 108.9892 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails chip chip_info.bin
[ 108.9900 ] MB2 Applet version 01.00.0000
[ 111.0110 ] Saved platform info in chip_info.bin
[ 111.0166 ] Chip minor revision: 1
[ 111.0167 ] Bootrom revision: 0x7
[ 111.0169 ] Ram code: 0x2
[ 111.0170 ] Chip sku: 0xd4
[ 111.0171 ] Chip Sample: prod
[ 111.0179 ] Retrieving EEPROM data
[ 111.0180 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23 0
[ 111.0189 ] MB2 Applet version 01.00.0000
[ 113.0316 ] Saved platform info in /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/cvm.bin
[ 113.0668 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 113.0675 ] MB2 Applet version 01.00.0000
[ 115.0961 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 115.0969 ] MB2 Applet version 01.00.0000
[ 117.1152 ] Dumping customer Info
[ 117.1162 ] tegrarcm_v2 --chip 0x23 0 --oem dump bct tmp.bct
[ 117.1170 ] MB2 Applet version 01.00.0000
[ 119.1309 ] Saved bct in tmp.bct
[ 119.1701 ] tegrabct_v2 --brbct tmp.bct --chip 0x23 0 --custinfo /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/custinfo_out.bin
[ 119.1710 ] Customer data saved in /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/custinfo_out.bin successfully[ 119.1728 ] Rebooting to recovery mode
[ 119.1738 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[ 122.3245 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 122.3253 ] MB2 Applet version 01.00.0000
[ 124.3393 ] Booting to recovery mode
[ 124.3402 ] tegrarcm_v2 --chip 0x23 0 --reboot recovery
[ 124.3410 ] MB2 Applet version 01.00.0000
Board ID(3767) version(300) sku(0001) revision(R.1)
Chip SKU(00:00:00:D4) ramcode(00:00:00:02) fuselevel(fuselevel_production) board_FAB(300)
emc_opt_disable_fuse:(0)
Copy /home/ai-blox/Desktop/test/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0001-nv.dtb to /home/ai-blox/Desktop/test/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0001-nv.dtb.rec
copying bctfile(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/generic/BCT/tegra234-p3767-0001-sdram-l4t.dts)... done.
copying minratchet_config(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-ratchet-p3767-0000.dts)... done.
copying pinmux_config(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi)... done.
copying gpioint_config(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-gpioint-p3767-0000.dts)... done.
copying pmic_config(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-pmic-p3767-0000-a02.dts)... done.
copying pmc_config(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi)... done.
copying deviceprod_config(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-cprod-p3767-0000.dts)... done.
copying prod_config(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-prod-p3767-0000.dts)... done.
copying scr_config(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb2-bct-scr-p3767-0000.dts)... done.
copying wb0sdram(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/generic/BCT/tegra234-p3767-0001-wb0sdram-l4t.dts)... done.
copying bootrom_config(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-reset-p3767-0000.dts)... done.
Existing uphylane_config(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/tegra234-mb1-bct-uphylane-si.dtsi) reused.
copying dev_params(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct-p3767-0000-l4t.dts)... done.
copying dev_params_b(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct_b-p3767-0000-l4t.dts)... done.
copying mb2bct_cfg(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb2-bct-misc-p3767-0000.dts)... done.
Existing pscfwfile(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/pscfw_t234_prod.bin) reused.
Existing pscbl1file(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/psc_bl1_t234_prod.bin) reused.
Existing mtsmcefile(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/mce_flash_o10_cr_prod.bin) reused.
Existing tscfwfile(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/tsec_t234.bin) reused.
Existing mb2applet(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/applet_t234.bin) reused.
Existing bootloader(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
copying initrd(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
bl is uefi
Making Boot image... done.
Not signing of boot.img
Making recovery ramdisk for recovery image...
Re-generating recovery ramdisk for recovery image...
/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/ramdisk_tmp /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader /home/ai-blox/Desktop/test/Linux_for_Tegra
53899 blocks
gzip: /home/ai-blox/Desktop/test/Linux_for_Tegra/kernel/Image: not in gzip format
_BASE_KERNEL_VERSION=5.15.136-tegra
77459 blocks
Making Recovery image...
copying recdtbfile(/home/ai-blox/Desktop/test/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0001-nv.dtb.rec)... done.
20+0 records in
20+0 records out
20 bytes copied, 0.000123352 s, 162 kB/s
Existing sosfile(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing tegraboot(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing cpu_bootloader(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing mb2blfile(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing xusbfile(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/xusb_t234_prod.bin) reused.
Existing pvafile(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/nvpva_020.fw) reused.
Existing dcefile(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/display-t234-dce.bin) reused.
Existing nvdecfile(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/nvdec_t234_prod.fw) reused.
Existing psc_rf(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/psc_rf_t234_prod.bin) reused.
Existing mb2_rf(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/mb2rf_t234.bin) reused.
Existing mb1file(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing bpffile(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/bpmp_t234-TE980M-A1_prod.bin) reused.
copying bpfdtbfile(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/generic/tegra234-bpmp-3767-0001-3509-a02.dtb)... done.
Existing camerafw(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/camera-rtcpu-t234-rce.img) reused.
Existing apefile(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/adsp-fw.bin) reused.
Existing spefile(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/spe_t234.bin) reused.
Existing wb0boot(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/sc7_t234_prod.bin) reused.
Existing tosfile(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/tos-optee_t234.img) reused.
Existing eksfile(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/eks_t234.img) reused.
copying dtbfile(/home/ai-blox/Desktop/test/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0001-nv.dtb)... done.
Copying nv_boot_control.conf to rootfs
Skip generating system.img
Not signing of kernel-dtb
Existing tbcfile(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/uefi_jetson.bin) reused.
131072+0 records in
131072+0 records out
67108864 bytes (67 MB, 64 MiB) copied, 0.140758 s, 477 MB/s
	Sync'ing esp.img ... done.
copying tbcdtbfile(/home/ai-blox/Desktop/test/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0001-nv.dtb)... done.
copying cfgfile(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/generic/cfg/flash_t234_qspi_sd.xml) to flash.xml... done.
Existing flashapp(/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/tegraflash.py) reused.
copying overlay_dtb(/home/ai-blox/Desktop/test/Linux_for_Tegra/kernel/dtb/L4TConfiguration.dtbo)... done.
copying overlay_dtb(/home/ai-blox/Desktop/test/Linux_for_Tegra/kernel/dtb/tegra234-carveouts.dtbo)... done.
copying overlay_dtb(/home/ai-blox/Desktop/test/Linux_for_Tegra/kernel/dtb/tegra-optee.dtbo)... done.
copying overlay_dtb(/home/ai-blox/Desktop/test/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0000-dynamic.dtbo)... done.
/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/L4TConfiguration_updated.dts: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/L4TConfiguration.dtbo: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
./tegraflash.py --bl uefi_jetson_with_dtb.bin --odmdata gbe-uphy-config-8,hsstp-lane-map-3,hsio-uphy-config-0 --overlay_dtb L4TConfiguration.dtbo,tegra234-carveouts.dtbo,tegra-optee.dtbo,tegra234-p3768-0000+p3767-0000-dynamic.dtbo, --bldtb tegra234-p3768-0000+p3767-0001-nv.dtb --applet mb1_t234_prod.bin --cmd "sign" --cfg flash.xml --chip "0x23" --concat_cpubl_bldtb --cpubl uefi_jetson.bin --minratchet_config tegra234-mb1-bct-ratchet-p3767-0000.dts --device_config tegra234-mb1-bct-device-p3767-0000.dts --misc_config tegra234-mb1-bct-misc-p3767-0000.dts --pinmux_config tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi --gpioint_config tegra234-mb1-bct-gpioint-p3767-0000.dts --pmic_config tegra234-mb1-bct-pmic-p3767-0000-a02.dts --pmc_config tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi --deviceprod_config tegra234-mb1-bct-cprod-p3767-0000.dts --prod_config tegra234-mb1-bct-prod-p3767-0000.dts --scr_config tegra234-mb2-bct-scr-p3767-0000.dts --wb0sdram_config tegra234-p3767-0001-wb0sdram-l4t.dts --br_cmd_config tegra234-mb1-bct-reset-p3767-0000.dts --uphy tegra234-mb1-bct-uphylane-si.dtsi --dev_params tegra234-br-bct-p3767-0000-l4t.dts,tegra234-br-bct_b-p3767-0000-l4t.dts --mb2bct_cfg tegra234-mb2-bct-misc-p3767-0000.dts --bins "psc_fw pscfw_t234_prod.bin; mts_mce mce_flash_o10_cr_prod.bin; tsec_fw tsec_t234.bin; mb2_applet applet_t234.bin; mb2_bootloader mb2_t234.bin; xusb_fw xusb_t234_prod.bin; pva_fw nvpva_020.fw; dce_fw display-t234-dce.bin; nvdec nvdec_t234_prod.fw; bpmp_fw bpmp_t234-TE980M-A1_prod.bin; bpmp_fw_dtb tegra234-bpmp-3767-0001-3509-a02.dtb; rce_fw camera-rtcpu-t234-rce.img; ape_fw adsp-fw.bin; spe_fw spe_t234.bin; tos tos-optee_t234.img; eks eks_t234.img; kernel boot.img; kernel_dtb tegra234-p3768-0000+p3767-0001-nv.dtb" --sdram_config tegra234-p3767-0001-sdram-l4t.dts --cust_info custinfo_out.bin --bct_backup --boot_chain A
version 1.0.0
[   0.0094 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0095 ] Assuming zero filled SBK key
[   0.0092 ] Parsing partition layout
[   0.0096 ] tegraparser_v2 --pt flash.xml.tmp
[   0.0123 ] Change tegra234-bpmp-3767-0001-3509-a02.dtb to tegra234-bpmp-3767-0001-3509-a02_with_odm.dtb
[   0.0323 ] /usr/bin/python3 dtbcheck.py -c t234 -o tegra234-bpmp-3767-0001-3509-a02_with_odm.dtb tegra234-bpmp-3767-0001-3509-a02_with_odm_tmp.dtb
[   0.1399 ] Concatenating L4TConfiguration.dtbo,tegra234-carveouts.dtbo,tegra-optee.dtbo,tegra234-p3768-0000+p3767-0000-dynamic.dtbo to tegra234-p3768-0000+p3767-0001-nv_with_odm_overlay.dtb.updated
[   0.1400 ] Concatenating bl dtb to cpubl binary
[   0.1417 ] MB2 binary: mb2_t234.bin
[   0.1418 ] Pre-processing mb2bct config: tegra234-mb2-bct-misc-p3767-0000.dts
[   0.1466 ] Pre-processing mb2bct config: tegra234-mb2-bct-scr-p3767-0000.dts
[   0.2617 ] Generating coldboot mb2-bct
[   0.2617 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct.cfg --mb2bctcfg tegra234-mb2-bct-misc-p3767-0000_cpp.dtb --scr tegra234-mb2-bct-scr-p3767-0000_cpp.dtb
[   0.2620 ] ERROR: value 0x31 is out of range
[   0.2627 ] ERROR: value 0x31 is out of range
[   0.2628 ] ERROR: value 0x31 is out of range
[   0.2629 ] WARNING: unknown property 'tfc_version'
[   0.2631 ] WARNING: unknown property 'addr_header_version'
[   0.2714 ] Updating mb2-bct with storage information
[   0.2717 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct_MB2.bct --updatestorageinfo flash.xml.bin
[   0.2720 ] Concatenating mb2-bct to mb2 binary
[   0.2720 ] mb2_bin_file = mb2_t234.bin
[   0.2720 ] mb2_bct_file = mb2_cold_boot_bct_MB2.bct
[   0.2738 ] DCE binary: display-t234-dce.bin
[   0.2738 ] Kernel DTB used: kernel_tegra234-p3768-0000+p3767-0001-nv.dtb
[   0.2738 ] Concatenating kernel-dtb to dce-fw binary
[   0.2738 ] dce_bin = display-t234-dce.bin
[   0.2738 ] kernel_dtb = kernel_tegra234-p3768-0000+p3767-0001-nv.dtb
[   0.2738 ] dce_with_dtb = display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0001-nv.bin
[   0.2777 ] Update display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0001-nv.bin to dce_fw partitions
[   0.2789 ] Parsing partition layout
[   0.2791 ] tegraparser_v2 --pt flash.xml.tmp
[   0.2796 ] Creating list of images to be signed
[   0.2797 ] Generating ratchet blob
[   0.2797 ] Pre-processing config: tegra234-mb1-bct-reset-p3767-0000.dts
[   0.2823 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[   0.2849 ] Pre-processing config: tegra234-mb1-bct-cprod-p3767-0000.dts
[   0.2879 ] Pre-processing config: tegra234-mb1-bct-gpioint-p3767-0000.dts
[   0.2911 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[   0.2949 ] Pre-processing config: tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi
[   0.3010 ] Pre-processing config: tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi
[   0.3036 ] Pre-processing config: tegra234-mb1-bct-pmic-p3767-0000-a02.dts
[   0.3060 ] Pre-processing config: tegra234-mb1-bct-prod-p3767-0000.dts
[   0.3083 ] Pre-processing config: tegra234-p3767-0001-sdram-l4t.dts
[   0.7214 ] Pre-processing config: tegra234-mb1-bct-uphylane-si.dtsi
[   0.7247 ] Pre-processing config: tegra234-p3767-0001-wb0sdram-l4t.dts
[   1.1361 ] Pre-processing config: tegra234-mb1-bct-ratchet-p3767-0000.dts
[   1.1396 ] Generating coldboot mb1-bct
[   1.1401 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3767-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3767-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[   1.1405 ] MB1-BCT version: 0.13
[   1.1418 ] Parsing config file :tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb
[   1.1420 ] Added Platform Config 0 data with size :- 2416
[   1.1439 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb
[   1.1440 ] WARNING: unknown node 'g2'
[   1.1442 ] WARNING: unknown node 'g2'
[   1.1442 ] WARNING: unknown node 'g9'
[   1.1442 ] Added Platform Config 2 data with size :- 24
[   1.1442 ]
[   1.1442 ] Parsing config file :tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb
[   1.1442 ] Added Platform Config 4 data with size :- 288
[   1.1442 ]
[   1.1442 ] Parsing config file :tegra234-mb1-bct-reset-p3767-0000_cpp.dtb
[   1.1442 ] Added Platform Config 3 data with size :- 52
[   1.1442 ]
[   1.1442 ] Parsing config file :tegra234-mb1-bct-prod-p3767-0000_cpp.dtb
[   1.1442 ] WARNING: unknown property 'major'
[   1.1443 ] WARNING: unknown property 'minor'
[   1.1443 ] Added Platform Config 5 data with size :- 512
[   1.1443 ]
[   1.1443 ] Parsing config file :tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb
[   1.1443 ] WARNING: unknown property 'major'
[   1.1443 ] Added Platform Config 7 data with size :- 380
[   1.1443 ]
[   1.1443 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[   1.1443 ] Added Platform Config 8 data with size :- 24
[   1.1443 ]
[   1.1443 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   1.1443 ] Added Platform Config 9 data with size :- 100
[   1.1443 ]
[   1.1443 ] Parsing config file :tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[   1.1443 ] ModuleCount 0 NumProdNames 0
[   1.1443 ] Added Platform Config 6 data with size :- 16
[   1.1443 ]
[   1.1443 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[   1.1443 ]
[   1.1443 ] Updating mb1-bct with firmware information
[   1.1447 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[   1.1490 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   1.1493 ] Generating SHA2 Hash for mb1bct
[   1.1503 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[   1.1508 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[   1.1507 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   1.1508 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   1.1516 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   1.1517 ] Assuming zero filled SBK key
[   1.1523 ] Warning: pub_key.key is not found
[   1.1522 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   1.1526 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[   1.1527 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   1.1532 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   1.1533 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   1.1550 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   1.1550 ] Header already present for tsec_t234_aligned.bin
[   1.1558 ] Header already present for nvdec_t234_prod_aligned.fw
[   1.1571 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[   1.1594 ] adding BCH for xusb_t234_prod_aligned.bin
[   1.1644 ] Header already present for bpmp_t234-TE980M-A1_prod_aligned.bin
[   1.1676 ] adding BCH for tegra234-bpmp-3767-0001-3509-a02_with_odm_aligned.dtb
[   1.1737 ] Header already present for pscfw_t234_prod_aligned.bin
[   1.1765 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[   1.1783 ] Header already present for sc7_t234_prod.bin
[   1.1794 ] Header already present for psc_rf_t234_prod_aligned.bin
[   1.1804 ] adding BCH for mb2rf_t234_aligned.bin
[   1.1811 ] INFO: compressing uefi_jetson_with_dtb_aligned.bin
[   1.2057 ] INFO: complete compression, uefi_jetson_with_dtb_aligned.bin, ratio = 91%
[   1.2086 ] adding BCH for uefi_jetson_with_dtb_aligned_blob_w_bin_aligned.bin
[   1.2320 ] adding BCH for tos-optee_t234_aligned.img
[   1.2540 ] adding BCH for eks_t234_aligned.img
[   1.2730 ] INFO: compressing display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0001-nv_aligned.bin
[   1.3554 ] INFO: complete compression, display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0001-nv_aligned.bin, ratio = 6%
[   1.3635 ] adding BCH for display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0001-nv_aligned_blob_w_bin_aligned.bin
[   1.3716 ] adding BCH for spe_t234_aligned.bin
[   1.3762 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[   1.3796 ] adding BCH for adsp-fw_aligned.bin
[   1.3853 ] INFO: compressing nvpva_020_aligned.fw
[   1.4049 ] INFO: complete compression, nvpva_020_aligned.fw, ratio = 2%
[   1.4059 ] adding BCH for nvpva_020_aligned_blob_w_bin_aligned.fw
[   1.4069 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   1.4075 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   1.4076 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   1.4094 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   1.4095 ] Header already present for tsec_t234_aligned.bin
[   1.4102 ] Header already present for nvdec_t234_prod_aligned.fw
[   1.4113 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[   1.4136 ] adding BCH for xusb_t234_prod_aligned.bin
[   1.4194 ] Header already present for bpmp_t234-TE980M-A1_prod_aligned.bin
[   1.4223 ] adding BCH for tegra234-bpmp-3767-0001-3509-a02_with_odm_aligned.dtb
[   1.4283 ] Header already present for pscfw_t234_prod_aligned.bin
[   1.4314 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[   1.4332 ] Header already present for sc7_t234_prod.bin
[   1.4342 ] Header already present for psc_rf_t234_prod_aligned.bin
[   1.4354 ] adding BCH for mb2rf_t234_aligned.bin
[   1.4362 ] INFO: compressing uefi_jetson_with_dtb_aligned.bin
[   1.4606 ] INFO: complete compression, uefi_jetson_with_dtb_aligned.bin, ratio = 91%
[   1.4635 ] adding BCH for uefi_jetson_with_dtb_aligned_blob_w_bin_aligned.bin
[   1.4868 ] adding BCH for tos-optee_t234_aligned.img
[   1.5071 ] adding BCH for eks_t234_aligned.img
[   1.5262 ] INFO: compressing display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0001-nv_aligned.bin
[   1.6077 ] INFO: complete compression, display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0001-nv_aligned.bin, ratio = 6%
[   1.6158 ] adding BCH for display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0001-nv_aligned_blob_w_bin_aligned.bin
[   1.6242 ] adding BCH for spe_t234_aligned.bin
[   1.6289 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[   1.6323 ] adding BCH for adsp-fw_aligned.bin
[   1.6381 ] INFO: compressing nvpva_020_aligned.fw
[   1.6569 ] INFO: complete compression, nvpva_020_aligned.fw, ratio = 2%
[   1.6579 ] adding BCH for nvpva_020_aligned_blob_w_bin_aligned.fw
[   1.6592 ] Filling MB1 storage info
[   1.6592 ] Parsing dev params for multi chains
[   1.6624 ] Generating br-bct
[   1.6626 ] Updating dev and MSS params in BR BCT
[   1.6626 ] tegrabct_v2 --dev_param tegra234-br-bct-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   1.7059 ] Updating bl info
[   1.7062 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[   1.7152 ] Generating br-bct
[   1.7153 ] Updating dev and MSS params in BR BCT
[   1.7153 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   1.7592 ] Updating bl info
[   1.7596 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[   1.7601 ] Generating BCT backup image
[   1.7601 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[   1.7603 ] 32768+0 records in
[   1.7818 ] 32768+0 records out
[   1.7818 ] 32768 bytes (33 kB, 32 KiB) copied, 0.0211364 s, 1.6 MB/s
[   1.7818 ]
[   1.7818 ] Concatenating BCT for chain A to bct_backup.img
[   1.7818 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[   1.7821 ] 8192+0 records in
[   1.7860 ] 8192+0 records out
[   1.7860 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.0037097 s, 2.2 MB/s
[   1.7860 ]
[   1.7860 ] Concatenating BCT for chain B to bct_backup.img
[   1.7860 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[   1.7862 ] 8192+0 records in
[   1.7901 ] 8192+0 records out
[   1.7901 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.00368571 s, 2.2 MB/s
[   1.7901 ] Generating signatures
[   1.7905 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[   1.7906 ] Assuming zero filled SBK key
[   1.8241 ] Warning: pub_key.key is not found
[   1.8249 ] Parsing dev params for multi chains
[   1.8249 ] Generating br-bct
[   1.8251 ] Updating dev and MSS params in BR BCT
[   1.8251 ] tegrabct_v2 --dev_param tegra234-br-bct-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   1.8693 ] Updating customer data section
[   1.8697 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[   1.8700 ] Updating bl info
[   1.8701 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   1.8708 ] Generating SHA2 Hash
[   1.8716 ] Sha saved in br_bct_BR.sha
[   1.8713 ] Get Signed section of bct
[   1.8715 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   1.8716 ] Signing BCT
[   1.8720 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   1.8721 ] Assuming zero filled SBK key
[   1.8727 ] Sha saved in br_bct_BR.sha
[   1.8728 ] Warning: pub_key.key is not found
[   1.8725 ] Updating BCT with signature
[   1.8726 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   1.8727 ] Offset :4608 Len :3584
[   1.8729 ] Generating SHA2 Hash
[   1.8733 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   1.8733 ] Assuming zero filled SBK key
[   1.8740 ] Sha saved in br_bct_BR.sha
[   1.8737 ] Updating BCT with SHA2 Hash
[   1.8738 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   1.8739 ] Offset :4608 Len :3584
[   1.8740 ] Offset :68 Len :8124
[   1.8742 ] Generating br-bct
[   1.8743 ] Updating dev and MSS params in BR BCT
[   1.8743 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   1.9188 ] Updating customer data section
[   1.9191 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[   1.9195 ] Updating bl info
[   1.9197 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   1.9203 ] Generating SHA2 Hash
[   1.9211 ] Sha saved in br_bct_BR.sha
[   1.9208 ] Get Signed section of bct
[   1.9208 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   1.9211 ] Signing BCT
[   1.9215 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   1.9215 ] Assuming zero filled SBK key
[   1.9223 ] Sha saved in br_bct_BR.sha
[   1.9224 ] Warning: pub_key.key is not found
[   1.9220 ] Updating BCT with signature
[   1.9221 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   1.9222 ] Offset :4608 Len :3584
[   1.9224 ] Generating SHA2 Hash
[   1.9228 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   1.9228 ] Assuming zero filled SBK key
[   1.9236 ] Sha saved in br_bct_BR.sha
[   1.9233 ] Updating BCT with SHA2 Hash
[   1.9234 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   1.9236 ] Offset :4608 Len :3584
[   1.9237 ] Offset :68 Len :8124
[   1.9238 ] Generating BCT backup image
[   1.9238 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[   1.9240 ] 32768+0 records in
[   1.9446 ] 32768+0 records out
[   1.9446 ] 32768 bytes (33 kB, 32 KiB) copied, 0.0202747 s, 1.6 MB/s
[   1.9446 ]
[   1.9446 ] Concatenating BCT for chain A to bct_backup.img
[   1.9446 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[   1.9449 ] 8192+0 records in
[   1.9488 ] 8192+0 records out
[   1.9488 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.0037036 s, 2.2 MB/s
[   1.9488 ]
[   1.9488 ] Concatenating BCT for chain B to bct_backup.img
[   1.9488 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[   1.9491 ] 8192+0 records in
[   1.9536 ] 8192+0 records out
[   1.9536 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.00425672 s, 1.9 MB/s
[   1.9536 ]
[   1.9536 ] Generating coldboot mb1-bct
[   1.9539 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3767-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3767-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[   1.9541 ] MB1-BCT version: 0.13
[   1.9555 ] Parsing config file :tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb
[   1.9556 ] Added Platform Config 0 data with size :- 2416
[   1.9574 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb
[   1.9575 ] WARNING: unknown node 'g2'
[   1.9576 ] WARNING: unknown node 'g9'
[   1.9576 ] Added Platform Config 2 data with size :- 24
[   1.9577 ] Parsing config file :tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb
[   1.9578 ] Added Platform Config 4 data with size :- 288
[   1.9578 ]
[   1.9578 ] Parsing config file :tegra234-mb1-bct-reset-p3767-0000_cpp.dtb
[   1.9578 ] Added Platform Config 3 data with size :- 52
[   1.9578 ]
[   1.9578 ] Parsing config file :tegra234-mb1-bct-prod-p3767-0000_cpp.dtb
[   1.9578 ] WARNING: unknown property 'major'
[   1.9578 ] WARNING: unknown property 'minor'
[   1.9578 ] Added Platform Config 5 data with size :- 512
[   1.9578 ]
[   1.9578 ] Parsing config file :tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb
[   1.9578 ] Added Platform Config 7 data with size :- 380
[   1.9578 ]
[   1.9578 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[   1.9578 ] Added Platform Config 8 data with size :- 24
[   1.9578 ]
[   1.9578 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   1.9578 ] Added Platform Config 9 data with size :- 100
[   1.9578 ]
[   1.9578 ] Parsing config file :tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[   1.9578 ] ModuleCount 0 NumProdNames 0
[   1.9578 ] Added Platform Config 6 data with size :- 16
[   1.9578 ]
[   1.9578 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[   1.9578 ]
[   1.9578 ] Updating mb1-bct with firmware information
[   1.9580 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[   1.9586 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   1.9587 ] Generating SHA2 Hash for mb1bct
[   1.9595 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[   1.9599 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[   1.9597 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   1.9598 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   1.9605 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   1.9606 ] Assuming zero filled SBK key
[   1.9611 ] Warning: pub_key.key is not found
[   1.9610 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   1.9613 ] Generating recovery mb1-bct
[   1.9614 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3767-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3767-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[   1.9615 ] MB1-BCT version: 0.13
[   1.9629 ] Parsing config file :tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb
[   1.9630 ] Added Platform Config 0 data with size :- 2416
[   1.9649 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb
[   1.9650 ] WARNING: unknown node 'g2'
[   1.9650 ] WARNING: unknown node 'g9'
[   1.9651 ] WARNING: unknown node 'g9'
[   1.9651 ] Added Platform Config 2 data with size :- 24
[   1.9651 ] Parsing config file :tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb
[   1.9652 ] Added Platform Config 4 data with size :- 288
[   1.9652 ]
[   1.9652 ] Parsing config file :tegra234-mb1-bct-reset-p3767-0000_cpp.dtb
[   1.9652 ] Added Platform Config 3 data with size :- 52
[   1.9652 ]
[   1.9652 ] Parsing config file :tegra234-mb1-bct-prod-p3767-0000_cpp.dtb
[   1.9652 ] WARNING: unknown property 'major'
[   1.9652 ] WARNING: unknown property 'minor'
[   1.9652 ] Added Platform Config 5 data with size :- 512
[   1.9652 ]
[   1.9652 ] Parsing config file :tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb
[   1.9652 ] Added Platform Config 7 data with size :- 380
[   1.9652 ]
[   1.9652 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[   1.9652 ] Added Platform Config 8 data with size :- 24
[   1.9652 ]
[   1.9652 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   1.9652 ] Added Platform Config 9 data with size :- 100
[   1.9652 ]
[   1.9652 ] Parsing config file :tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[   1.9652 ] ModuleCount 0 NumProdNames 0
[   1.9652 ] Added Platform Config 6 data with size :- 16
[   1.9652 ]
[   1.9652 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[   1.9652 ]
[   1.9652 ] Updating mb1-bct with firmware information
[   1.9653 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo flash.xml.bin
[   1.9657 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[   1.9658 ] Generating SHA2 Hash for mb1bct
[   1.9664 ] Sha saved in mb1_bct_MB1_aligned.sha
[   1.9667 ] Sha saved in mb1_bct_MB1.sha
[   1.9664 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   1.9666 ] adding BCH for mb1_bct_MB1_aligned.bct
[   1.9672 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   1.9673 ] Assuming zero filled SBK key
[   1.9676 ] Warning: pub_key.key is not found
[   1.9674 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   1.9677 ] Generating coldboot mem-bct
[   1.9678 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --membct tegra234-p3767-0001-sdram-l4t_cpp_1.bct tegra234-p3767-0001-sdram-l4t_cpp_2.bct tegra234-p3767-0001-sdram-l4t_cpp_3.bct tegra234-p3767-0001-sdram-l4t_cpp_4.bct
[   1.9679 ]  packing sdram params with Wb0 file tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb
[   2.0115 ] Packing sdram param for instance[0]
[   2.0116 ] Packing sdram param for instance[1]
[   2.0116 ] Packing sdram param for instance[2]
[   2.0117 ] Packing sdram param for instance[3]
[   2.0117 ] Packing sdram param for instance[4]
[   2.0117 ] Packing sdram param for instance[5]
[   2.0118 ] Packing sdram param for instance[6]
[   2.0118 ] Packing sdram param for instance[7]
[   2.0119 ] Packing sdram param for instance[8]
[   2.0119 ] Packing sdram param for instance[9]
[   2.0120 ] Packing sdram param for instance[10]
[   2.0120 ] Packing sdram param for instance[11]
[   2.0121 ] Packing sdram param for instance[12]
[   2.0121 ] Packing sdram param for instance[13]
[   2.0121 ] Packing sdram param for instance[14]
[   2.0122 ] Packing sdram param for instance[15]
[   2.0557 ] Getting sector size from pt
[   2.0560 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[   2.0563 ] BlockSize read from layout is 0x200
[   2.0564 ] tegrahost_v2 --chip 0x23 0 --blocksize 512 --magicid MEMB --addsigheader_multi tegra234-p3767-0001-sdram-l4t_cpp_1.bct tegra234-p3767-0001-sdram-l4t_cpp_2.bct tegra234-p3767-0001-sdram-l4t_cpp_3.bct tegra234-p3767-0001-sdram-l4t_cpp_4.bct
[   2.0565 ] Binary 0 length is 58752
[   2.0566 ] Binary 0 align length is 58880
[   2.0569 ] Binary 1 length is 58752
[   2.0569 ] Binary 1 align length is 58880
[   2.0572 ] Binary 2 length is 58752
[   2.0572 ] Binary 2 align length is 58880
[   2.0575 ] Binary 3 length is 58752
[   2.0575 ] Binary 3 align length is 58880
[   2.0578 ] Buffer length is 235520
[   2.0578 ] adding BCH for tegra234-p3767-0001-sdram-l4t_cpp_1.bct
[   2.0579 ] new length is 243712
[   2.0584 ] tegrahost_v2 --chip 0x23 0 --align mem_coldboot_aligned.bct
[   2.0586 ] tegrahost_v2 --chip 0x23 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_coldboot_aligned.bct zerosbk
[   2.0587 ] Header already present for mem_coldboot_aligned.bct
[   2.0595 ] tegrasign_v3.py --key None --list mem_coldboot_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.0595 ] Assuming zero filled SBK key
[   2.0602 ] Warning: pub_key.key is not found
[   2.0600 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_coldboot_aligned_sigheader.bct.encrypt mem_coldboot_aligned_sigheader.bct.hash zerosbk
[   2.0606 ] Generating recovery mem-bct
[   2.0607 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --membct tegra234-p3767-0001-sdram-l4t_cpp_1.bct tegra234-p3767-0001-sdram-l4t_cpp_2.bct tegra234-p3767-0001-sdram-l4t_cpp_3.bct tegra234-p3767-0001-sdram-l4t_cpp_4.bct
[   2.0609 ]  packing sdram params with Wb0 file tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb
[   2.1055 ] Packing sdram param for instance[0]
[   2.1055 ] Packing sdram param for instance[1]
[   2.1056 ] Packing sdram param for instance[2]
[   2.1056 ] Packing sdram param for instance[3]
[   2.1057 ] Packing sdram param for instance[4]
[   2.1057 ] Packing sdram param for instance[5]
[   2.1058 ] Packing sdram param for instance[6]
[   2.1058 ] Packing sdram param for instance[7]
[   2.1059 ] Packing sdram param for instance[8]
[   2.1059 ] Packing sdram param for instance[9]
[   2.1060 ] Packing sdram param for instance[10]
[   2.1060 ] Packing sdram param for instance[11]
[   2.1061 ] Packing sdram param for instance[12]
[   2.1061 ] Packing sdram param for instance[13]
[   2.1061 ] Packing sdram param for instance[14]
[   2.1062 ] Packing sdram param for instance[15]
[   2.1493 ] Reading ramcode from backup chip_info.bin file
[   2.1494 ] RAMCODE Read from Device: 2
[   2.1494 ] Using ramcode 0
[   2.1494 ] Disabled BPMP dtb trim, using default dtb
[   2.1494 ]
[   2.1498 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_aligned.bct
[   2.1501 ] tegrahost_v2 --chip 0x23 0 --magicid MEM0 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_aligned.bct zerosbk
[   2.1502 ] adding BCH for mem_rcm_aligned.bct
[   2.1515 ] tegrasign_v3.py --key None --list mem_rcm_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.1516 ] Assuming zero filled SBK key
[   2.1521 ] Warning: pub_key.key is not found
[   2.1520 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_aligned_sigheader.bct.encrypt mem_rcm_aligned_sigheader.bct.hash zerosbk
[   2.1526 ] Copying signatures
[   2.1528 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[   2.1789 ] tegraparser_v2 --generategpt --pt flash.xml.bin
[   2.1790 ] gpt_secondary_3_0.bin:
[   2.1792 ] partition_id	partition_name			      StartingLba	EndingLba
[   2.1793 ]            1	BCT                                 	       0	    2047
[   2.1794 ]            2	A_mb1                               	    2048	    3071
[   2.1795 ]            3	A_psc_bl1                           	    3072	    3583
[   2.1796 ]            4	A_MB1_BCT                           	    3584	    3839
[   2.1797 ]            5	A_MEM_BCT                           	    3840	    4351
[   2.1798 ]            6	A_tsec-fw                           	    4352	    6399
[   2.1799 ]            7	A_nvdec                             	    6400	    8447
[   2.1800 ]            8	A_mb2                               	    8448	    9471
[   2.1801 ]            9	A_xusb-fw                           	    9472	    9983
[   2.1802 ]           10	A_bpmp-fw                           	    9984	   13055
[   2.1803 ]           11	A_bpmp-fw-dtb                       	   13056	   21247
[   2.1803 ]           12	A_psc-fw                            	   21248	   22783
[   2.1804 ]           13	A_mts-mce                           	   22784	   23807
[   2.1804 ]           14	A_sc7                               	   23808	   24191
[   2.1805 ]           15	A_pscrf                             	   24192	   24575
[   2.1805 ]           16	A_mb2rf                             	   24576	   24831
[   2.1805 ]           17	A_cpu-bootloader                    	   24832	   31999
[   2.1805 ]           18	A_secure-os                         	   32000	   40191
[   2.1805 ]           19	A_smm-fw                            	   40192	   44287
[   2.1805 ]           20	A_eks                               	   44288	   44799
[   2.1805 ]           21	A_dce-fw                            	   44800	   55039
[   2.1805 ]           22	A_spe-fw                            	   55040	   56191
[   2.1805 ]           23	A_rce-fw                            	   56192	   58239
[   2.1805 ]           24	A_adsp-fw                           	   58240	   62335
[   2.1805 ]           25	A_pva-fw                            	   62336	   62847
[   2.1805 ]           26	A_reserved_on_boot                  	   62848	   65023
[   2.1805 ]           27	B_mb1                               	   65024	   66047
[   2.1805 ]           28	B_psc_bl1                           	   66048	   66559
[   2.1805 ]           29	B_MB1_BCT                           	   66560	   66815
[   2.1805 ]           30	B_MEM_BCT                           	   66816	   67327
[   2.1805 ]           31	B_tsec-fw                           	   67328	   69375
[   2.1805 ]           32	B_nvdec                             	   69376	   71423
[   2.1805 ]           33	B_mb2                               	   71424	   72447
[   2.1805 ]           34	B_xusb-fw                           	   72448	   72959
[   2.1805 ]           35	B_bpmp-fw                           	   72960	   76031
[   2.1805 ]           36	B_bpmp-fw-dtb                       	   76032	   84223
[   2.1805 ]           37	B_psc-fw                            	   84224	   85759
[   2.1805 ]           38	B_mts-mce                           	   85760	   86783
[   2.1805 ]           39	B_sc7                               	   86784	   87167
[   2.1805 ]           40	B_pscrf                             	   87168	   87551
[   2.1805 ]           41	B_mb2rf                             	   87552	   87807
[   2.1805 ]           42	B_cpu-bootloader                    	   87808	   94975
[   2.1805 ]           43	B_secure-os                         	   94976	  103167
[   2.1805 ]           44	B_smm-fw                            	  103168	  107263
[   2.1805 ]           45	B_eks                               	  107264	  107775
[   2.1805 ]           46	B_dce-fw                            	  107776	  118015
[   2.1805 ]           47	B_spe-fw                            	  118016	  119167
[   2.1805 ]           48	B_rce-fw                            	  119168	  121215
[   2.1805 ]           49	B_adsp-fw                           	  121216	  125311
[   2.1805 ]           50	B_pva-fw                            	  125312	  125823
[   2.1805 ]           51	B_reserved_on_boot                  	  125824	  127999
[   2.1805 ]           52	uefi_variables                      	  128000	  128511
[   2.1805 ]           53	uefi_ftw                            	  128512	  129535
[   2.1805 ]           54	reserved                            	  129536	  129919
[   2.1805 ]           55	worm                                	  129920	  130303
[   2.1805 ]           56	BCT-boot-chain_backup               	  130304	  130431
[   2.1805 ]           57	reserved_partition                  	  130432	  130559
[   2.1805 ]           58	secondary_gpt_backup                	  130560	  130687
[   2.1805 ]           59	B_VER                               	  130688	  130815
[   2.1805 ]           60	A_VER                               	  130816	  130943
[   2.1805 ] gpt_primary_6_0.bin:
[   2.1806 ] partition_id	partition_name			      StartingLba	EndingLba
[   2.1806 ]            1	APP                                 	 3050048	119537623
[   2.1806 ]            2	A_kernel                            	      40	  262183
[   2.1806 ]            3	A_kernel-dtb                        	  262184	  263719
[   2.1806 ]            4	A_reserved_on_user                  	  263720	  328487
[   2.1806 ]            5	B_kernel                            	  328488	  590631
[   2.1806 ]            6	B_kernel-dtb                        	  590632	  592167
[   2.1806 ]            7	B_reserved_on_user                  	  592168	  656935
[   2.1806 ]            8	recovery                            	  656936	  820775
[   2.1806 ]            9	recovery-dtb                        	  820776	  821799
[   2.1806 ]           10	esp                                 	  821800	  952871
[   2.1806 ]           11	recovery_alt                        	  952872	 1116711
[   2.1806 ]           12	recovery-dtb_alt                    	 1116712	 1117735
[   2.1806 ]           13	esp_alt                             	 1117736	 1248807
[   2.1806 ]           14	UDA                                 	 1248832	 2068031
[   2.1806 ]           15	reserved                            	 2068032	 3050047
[   2.1806 ] gpt_secondary_6_0.bin:
[   2.1806 ]
[   2.1814 ] Get magic id
[   2.1815 ] tegraparser_v2 --get_magic psc_fw
[   2.1816 ] PFWP
[   2.1817 ] partition type psc_fw, magic id = PFWP
[   2.1820 ] tegrahost_v2 --chip 0x23 0 --align pscfw_t234_prod_aligned.bin
[   2.1823 ] tegrahost_v2 --chip 0x23 0 --magicid PFWP --ratchet_blob ratchet_blob.bin --appendsigheader pscfw_t234_prod_aligned.bin zerosbk
[   2.1823 ] Header already present for pscfw_t234_prod_aligned.bin
[   2.1848 ] tegrasign_v3.py --key None --list pscfw_t234_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.1848 ] Assuming zero filled SBK key
[   2.1855 ] Warning: pub_key.key is not found
[   2.1853 ] tegrahost_v2 --chip 0x23 0 --updatesigheader pscfw_t234_prod_aligned_sigheader.bin.encrypt pscfw_t234_prod_aligned_sigheader.bin.hash zerosbk
[   2.1860 ] Get magic id
[   2.1861 ] tegraparser_v2 --get_magic mts_mce
[   2.1862 ] MTSM
[   2.1862 ] partition type mts_mce, magic id = MTSM
[   2.1865 ] tegrahost_v2 --chip 0x23 0 --align mce_flash_o10_cr_prod_aligned.bin
[   2.1867 ] tegrahost_v2 --chip 0x23 0 --magicid MTSM --ratchet_blob ratchet_blob.bin --appendsigheader mce_flash_o10_cr_prod_aligned.bin zerosbk
[   2.1868 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[   2.1884 ] tegrasign_v3.py --key None --list mce_flash_o10_cr_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.1884 ] Assuming zero filled SBK key
[   2.1889 ] Warning: pub_key.key is not found
[   2.1887 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mce_flash_o10_cr_prod_aligned_sigheader.bin.encrypt mce_flash_o10_cr_prod_aligned_sigheader.bin.hash zerosbk
[   2.1892 ] Get magic id
[   2.1893 ] tegraparser_v2 --get_magic tsec_fw
[   2.1894 ] TSEC
[   2.1894 ] partition type tsec_fw, magic id = TSEC
[   2.1896 ] tegrahost_v2 --chip 0x23 0 --align tsec_t234_aligned.bin
[   2.1898 ] tegrahost_v2 --chip 0x23 0 --magicid TSEC --ratchet_blob ratchet_blob.bin --appendsigheader tsec_t234_aligned.bin zerosbk
[   2.1899 ] Header already present for tsec_t234_aligned.bin
[   2.1915 ] tegrasign_v3.py --key None --list tsec_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.1915 ] Assuming zero filled SBK key
[   2.1921 ] Warning: pub_key.key is not found
[   2.1919 ] tegrahost_v2 --chip 0x23 0 --updatesigheader tsec_t234_aligned_sigheader.bin.encrypt tsec_t234_aligned_sigheader.bin.hash zerosbk
[   2.1925 ] Get magic id
[   2.1926 ] tegraparser_v2 --get_magic mb2_applet
[   2.1927 ] MB2A
[   2.1927 ] partition type mb2_applet, magic id = MB2A
[   2.1929 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[   2.1931 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --ratchet_blob ratchet_blob.bin --appendsigheader applet_t234_aligned.bin zerosbk
[   2.1932 ] adding BCH for applet_t234_aligned.bin
[   2.1972 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.1973 ] Assuming zero filled SBK key
[   2.1983 ] Warning: pub_key.key is not found
[   2.1981 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[   2.1992 ] Generating recovery mb2-bct
[   2.1992 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_bct.cfg --recov --mb2bctcfg tegra234-mb2-bct-misc-p3767-0000_cpp.dtb --scr tegra234-mb2-bct-scr-p3767-0000_cpp.dtb
[   2.1993 ] ERROR: value 0x31 is out of range
[   2.2001 ] ERROR: value 0x31 is out of range
[   2.2002 ] WARNING: unknown property 'tfc_version'
[   2.2004 ] WARNING: unknown property 'addr_header_version'
[   2.2090 ] Updating mb2-bct with storage information for RCM
[   2.2093 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_bct_MB2.bct --updatestorageinfo flash.xml.bin
[   2.2096 ] Concatenating mb2-bct to mb2 binary
[   2.2096 ] mb2_bin_file = mb2_t234.bin
[   2.2096 ] mb2_bct_file = mb2_bct_MB2.bct
[   2.2098 ] Get magic id
[   2.2100 ] tegraparser_v2 --get_magic mb2_bootloader
[   2.2100 ] MB2B
[   2.2101 ] partition type mb2_bootloader, magic id = MB2B
[   2.2104 ] tegrahost_v2 --chip 0x23 0 --align mb2_t234_with_mb2_bct_MB2_aligned.bin
[   2.2107 ] tegrahost_v2 --chip 0x23 0 --magicid MB2B --ratchet_blob ratchet_blob.bin --appendsigheader mb2_t234_with_mb2_bct_MB2_aligned.bin zerosbk
[   2.2108 ] adding BCH for mb2_t234_with_mb2_bct_MB2_aligned.bin
[   2.2164 ] tegrasign_v3.py --key None --list mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.2164 ] Assuming zero filled SBK key
[   2.2172 ] Warning: pub_key.key is not found
[   2.2171 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin.encrypt mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin.hash zerosbk
[   2.2178 ] Get magic id
[   2.2180 ] tegraparser_v2 --get_magic xusb_fw
[   2.2181 ] XUSB
[   2.2181 ] partition type xusb_fw, magic id = XUSB
[   2.2184 ] tegrahost_v2 --chip 0x23 0 --align xusb_t234_prod_aligned.bin
[   2.2187 ] tegrahost_v2 --chip 0x23 0 --magicid XUSB --ratchet_blob ratchet_blob.bin --appendsigheader xusb_t234_prod_aligned.bin zerosbk
[   2.2187 ] adding BCH for xusb_t234_prod_aligned.bin
[   2.2212 ] tegrasign_v3.py --key None --list xusb_t234_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.2212 ] Assuming zero filled SBK key
[   2.2218 ] Warning: pub_key.key is not found
[   2.2216 ] tegrahost_v2 --chip 0x23 0 --updatesigheader xusb_t234_prod_aligned_sigheader.bin.encrypt xusb_t234_prod_aligned_sigheader.bin.hash zerosbk
[   2.2221 ] Get magic id
[   2.2222 ] tegraparser_v2 --get_magic pva_fw
[   2.2223 ] PVAF
[   2.2223 ] partition type pva_fw, magic id = PVAF
[   2.2234 ] tegrahost_v2 --chip 0x23 0 --align nvpva_020_aligned.fw
[   2.2237 ] tegrahost_v2 --chip 0x23 0 --magicid PVAF --ratchet_blob ratchet_blob.bin --appendsigheader nvpva_020_aligned.fw zerosbk
[   2.2237 ] adding BCH for nvpva_020_aligned.fw
[   2.2503 ] tegrasign_v3.py --key None --list nvpva_020_aligned_sigheader.fw_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.2504 ] Assuming zero filled SBK key
[   2.2530 ] Warning: pub_key.key is not found
[   2.2529 ] tegrahost_v2 --chip 0x23 0 --updatesigheader nvpva_020_aligned_sigheader.fw.encrypt nvpva_020_aligned_sigheader.fw.hash zerosbk
[   2.2561 ] Kernel DTB used: kernel_tegra234-p3768-0000+p3767-0001-nv.dtb
[   2.2561 ] Concatenating kernel-dtb to dce-fw binary
[   2.2562 ] dce_bin = display-t234-dce.bin
[   2.2562 ] kernel_dtb = kernel_tegra234-p3768-0000+p3767-0001-nv.dtb
[   2.2562 ] dce_with_dtb = display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0001-nv.bin
[   2.2632 ] Get magic id
[   2.2638 ] tegraparser_v2 --get_magic dce_fw
[   2.2642 ] DCEF
[   2.2642 ]
[   2.2642 ] partition type dce_fw, magic id = DCEF
[   2.2700 ] tegrahost_v2 --chip 0x23 0 --align display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0001-nv_aligned.bin
[   2.2704 ] tegrahost_v2 --chip 0x23 0 --magicid DCEF --ratchet_blob ratchet_blob.bin --appendsigheader display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0001-nv_aligned.bin zerosbk
[   2.2706 ] adding BCH for display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0001-nv_aligned.bin
[   2.4161 ] tegrasign_v3.py --key None --list display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0001-nv_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.4162 ] Assuming zero filled SBK key
[   2.4324 ] Warning: pub_key.key is not found
[   2.4323 ] tegrahost_v2 --chip 0x23 0 --updatesigheader display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0001-nv_aligned_sigheader.bin.encrypt display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0001-nv_aligned_sigheader.bin.hash zerosbk
[   2.4526 ] Get magic id
[   2.4530 ] tegraparser_v2 --get_magic nvdec
[   2.4532 ] NDEC
[   2.4532 ] partition type nvdec, magic id = NDEC
[   2.4536 ] tegrahost_v2 --chip 0x23 0 --align nvdec_t234_prod_aligned.fw
[   2.4538 ] tegrahost_v2 --chip 0x23 0 --magicid NDEC --ratchet_blob ratchet_blob.bin --appendsigheader nvdec_t234_prod_aligned.fw zerosbk
[   2.4539 ] Header already present for nvdec_t234_prod_aligned.fw
[   2.4562 ] tegrasign_v3.py --key None --list nvdec_t234_prod_aligned_sigheader.fw_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.4563 ] Assuming zero filled SBK key
[   2.4571 ] Warning: pub_key.key is not found
[   2.4569 ] tegrahost_v2 --chip 0x23 0 --updatesigheader nvdec_t234_prod_aligned_sigheader.fw.encrypt nvdec_t234_prod_aligned_sigheader.fw.hash zerosbk
[   2.4575 ] Get magic id
[   2.4576 ] tegraparser_v2 --get_magic bpmp_fw
[   2.4577 ] BPMF
[   2.4578 ] partition type bpmp_fw, magic id = BPMF
[   2.4583 ] tegrahost_v2 --chip 0x23 0 --align bpmp_t234-TE980M-A1_prod_aligned.bin
[   2.4585 ] tegrahost_v2 --chip 0x23 0 --magicid BPMF --ratchet_blob ratchet_blob.bin --appendsigheader bpmp_t234-TE980M-A1_prod_aligned.bin zerosbk
[   2.4586 ] Header already present for bpmp_t234-TE980M-A1_prod_aligned.bin
[   2.4653 ] tegrasign_v3.py --key None --list bpmp_t234-TE980M-A1_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.4654 ] Assuming zero filled SBK key
[   2.4672 ] Warning: pub_key.key is not found
[   2.4670 ] tegrahost_v2 --chip 0x23 0 --updatesigheader bpmp_t234-TE980M-A1_prod_aligned_sigheader.bin.encrypt bpmp_t234-TE980M-A1_prod_aligned_sigheader.bin.hash zerosbk
[   2.4683 ] Using bpmp-dtb concatenated with odmdata
[   2.4683 ] Get magic id
[   2.4684 ] tegraparser_v2 --get_magic bpmp_fw_dtb
[   2.4685 ] BPMD
[   2.4685 ] partition type bpmp_fw_dtb, magic id = BPMD
[   2.4688 ] tegrahost_v2 --chip 0x23 0 --align tegra234-bpmp-3767-0001-3509-a02_with_odm_aligned.dtb
[   2.4690 ] tegrahost_v2 --chip 0x23 0 --magicid BPMD --ratchet_blob ratchet_blob.bin --appendsigheader tegra234-bpmp-3767-0001-3509-a02_with_odm_aligned.dtb zerosbk
[   2.4691 ] adding BCH for tegra234-bpmp-3767-0001-3509-a02_with_odm_aligned.dtb
[   2.4733 ] tegrasign_v3.py --key None --list tegra234-bpmp-3767-0001-3509-a02_with_odm_aligned_sigheader.dtb_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.4734 ] Assuming zero filled SBK key
[   2.4740 ] Warning: pub_key.key is not found
[   2.4738 ] tegrahost_v2 --chip 0x23 0 --updatesigheader tegra234-bpmp-3767-0001-3509-a02_with_odm_aligned_sigheader.dtb.encrypt tegra234-bpmp-3767-0001-3509-a02_with_odm_aligned_sigheader.dtb.hash zerosbk
[   2.4744 ] Get magic id
[   2.4746 ] tegraparser_v2 --get_magic rce_fw
[   2.4747 ] RCEF
[   2.4747 ] partition type rce_fw, magic id = RCEF
[   2.4750 ] tegrahost_v2 --chip 0x23 0 --align camera-rtcpu-t234-rce_aligned.img
[   2.4752 ] tegrahost_v2 --chip 0x23 0 --magicid RCEF --ratchet_blob ratchet_blob.bin --appendsigheader camera-rtcpu-t234-rce_aligned.img zerosbk
[   2.4753 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[   2.4814 ] tegrasign_v3.py --key None --list camera-rtcpu-t234-rce_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.4815 ] Assuming zero filled SBK key
[   2.4824 ] Warning: pub_key.key is not found
[   2.4823 ] tegrahost_v2 --chip 0x23 0 --updatesigheader camera-rtcpu-t234-rce_aligned_sigheader.img.encrypt camera-rtcpu-t234-rce_aligned_sigheader.img.hash zerosbk
[   2.4831 ] Get magic id
[   2.4832 ] tegraparser_v2 --get_magic ape_fw
[   2.4833 ] APEF
[   2.4833 ] partition type ape_fw, magic id = APEF
[   2.4839 ] tegrahost_v2 --chip 0x23 0 --align adsp-fw_aligned.bin
[   2.4844 ] tegrahost_v2 --chip 0x23 0 --magicid APEF --ratchet_blob ratchet_blob.bin --appendsigheader adsp-fw_aligned.bin zerosbk
[   2.4845 ] adding BCH for adsp-fw_aligned.bin
[   2.4915 ] tegrasign_v3.py --key None --list adsp-fw_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.4916 ] Assuming zero filled SBK key
[   2.4927 ] Warning: pub_key.key is not found
[   2.4926 ] tegrahost_v2 --chip 0x23 0 --updatesigheader adsp-fw_aligned_sigheader.bin.encrypt adsp-fw_aligned_sigheader.bin.hash zerosbk
[   2.4935 ] Get magic id
[   2.4937 ] tegraparser_v2 --get_magic spe_fw
[   2.4938 ] SPEF
[   2.4939 ] partition type spe_fw, magic id = SPEF
[   2.4942 ] tegrahost_v2 --chip 0x23 0 --align spe_t234_aligned.bin
[   2.4944 ] tegrahost_v2 --chip 0x23 0 --magicid SPEF --ratchet_blob ratchet_blob.bin --appendsigheader spe_t234_aligned.bin zerosbk
[   2.4945 ] adding BCH for spe_t234_aligned.bin
[   2.4991 ] tegrasign_v3.py --key None --list spe_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.4992 ] Assuming zero filled SBK key
[   2.5000 ] Warning: pub_key.key is not found
[   2.4999 ] tegrahost_v2 --chip 0x23 0 --updatesigheader spe_t234_aligned_sigheader.bin.encrypt spe_t234_aligned_sigheader.bin.hash zerosbk
[   2.5007 ] Get magic id
[   2.5009 ] tegraparser_v2 --get_magic tos
[   2.5010 ] TOSB
[   2.5011 ] partition type tos, magic id = TOSB
[   2.5024 ] tegrahost_v2 --chip 0x23 0 --align tos-optee_t234_aligned.img
[   2.5028 ] tegrahost_v2 --chip 0x23 0 --magicid TOSB --ratchet_blob ratchet_blob.bin --appendsigheader tos-optee_t234_aligned.img zerosbk
[   2.5030 ] adding BCH for tos-optee_t234_aligned.img
[   2.5292 ] tegrasign_v3.py --key None --list tos-optee_t234_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.5293 ] Assuming zero filled SBK key
[   2.5314 ] Warning: pub_key.key is not found
[   2.5313 ] tegrahost_v2 --chip 0x23 0 --updatesigheader tos-optee_t234_aligned_sigheader.img.encrypt tos-optee_t234_aligned_sigheader.img.hash zerosbk
[   2.5334 ] Get magic id
[   2.5336 ] tegraparser_v2 --get_magic eks
[   2.5337 ] EKSB
[   2.5338 ] partition type eks, magic id = EKSB
[   2.5340 ] tegrahost_v2 --chip 0x23 0 --align eks_t234_aligned.img
[   2.5343 ] tegrahost_v2 --chip 0x23 0 --magicid EKSB --ratchet_blob ratchet_blob.bin --appendsigheader eks_t234_aligned.img zerosbk
[   2.5345 ] adding BCH for eks_t234_aligned.img
[   2.5352 ] tegrasign_v3.py --key None --list eks_t234_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.5352 ] Assuming zero filled SBK key
[   2.5358 ] Warning: pub_key.key is not found
[   2.5356 ] tegrahost_v2 --chip 0x23 0 --updatesigheader eks_t234_aligned_sigheader.img.encrypt eks_t234_aligned_sigheader.img.hash zerosbk
[   2.5377 ] tegrahost_v2 --chip 0x23 0 --align uefi_jetson_with_dtb_aligned.bin
[   2.5380 ] tegrahost_v2 --chip 0x23 0 --magicid CPBL --ratchet_blob ratchet_blob.bin --appendsigheader uefi_jetson_with_dtb_aligned.bin zerosbk
[   2.5380 ] adding BCH for uefi_jetson_with_dtb_aligned.bin
[   2.5833 ] tegrasign_v3.py --key None --list uefi_jetson_with_dtb_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.5834 ] Assuming zero filled SBK key
[   2.5879 ] Warning: pub_key.key is not found
[   2.5879 ] tegrahost_v2 --chip 0x23 0 --updatesigheader uefi_jetson_with_dtb_aligned_sigheader.bin.encrypt uefi_jetson_with_dtb_aligned_sigheader.bin.hash zerosbk
[   2.5923 ] Copying enc\/signed file in /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed
[   2.6033 ] Copying br bct for multi chains
[   2.6033 ] Signed BCT for boot chain A is copied to /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/br_bct_BR.bct
[   2.6034 ] Signed BCT for boot chain B is copied to /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/br_bct_b_BR.bct
[   2.6034 ] Copying BCT backup image bct_backup.img to /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/bct_backup.img
[   2.6048 ] Copying pscfw_t234_prod_sigheader.bin.encrypt to /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed
[   2.6050 ] Signed file: /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/pscfw_t234_prod_sigheader.bin.encrypt
[   2.6050 ] Copying mce_flash_o10_cr_prod_sigheader.bin.encrypt to /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed
[   2.6051 ] Signed file: /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/mce_flash_o10_cr_prod_sigheader.bin.encrypt
[   2.6051 ] Copying tsec_t234_sigheader.bin.encrypt to /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed
[   2.6052 ] Signed file: /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/tsec_t234_sigheader.bin.encrypt
[   2.6052 ] Copying applet_t234_sigheader.bin.encrypt to /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed
[   2.6053 ] Signed file: /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/applet_t234_sigheader.bin.encrypt
[   2.6053 ] Copying mb2_t234_with_mb2_bct_MB2_sigheader.bin.encrypt to /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed
[   2.6054 ] Signed file: /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/mb2_t234_with_mb2_bct_MB2_sigheader.bin.encrypt
[   2.6054 ] Copying xusb_t234_prod_sigheader.bin.encrypt to /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed
[   2.6056 ] Signed file: /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/xusb_t234_prod_sigheader.bin.encrypt
[   2.6056 ] Copying nvpva_020_sigheader.fw.encrypt to /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed
[   2.6062 ] Signed file: /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/nvpva_020_sigheader.fw.encrypt
[   2.6062 ] Copying display-t234-dce_sigheader.bin.encrypt to /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed
[   2.6108 ] Signed file: /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/display-t234-dce_sigheader.bin.encrypt
[   2.6108 ] Copying display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0001-nv_sigheader.bin.encrypt to /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed
[   2.6165 ] Signed file: /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0001-nv_sigheader.bin.encrypt
[   2.6165 ] Copying nvdec_t234_prod_sigheader.fw.encrypt to /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed
[   2.6167 ] Signed file: /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/nvdec_t234_prod_sigheader.fw.encrypt
[   2.6167 ] Copying bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt to /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed
[   2.6171 ] Signed file: /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt
[   2.6171 ] Copying tegra234-bpmp-3767-0001-3509-a02_with_odm_sigheader.dtb.encrypt to /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed
[   2.6173 ] Signed file: /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/tegra234-bpmp-3767-0001-3509-a02_with_odm_sigheader.dtb.encrypt
[   2.6173 ] Copying camera-rtcpu-t234-rce_sigheader.img.encrypt to /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed
[   2.6175 ] Signed file: /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/camera-rtcpu-t234-rce_sigheader.img.encrypt
[   2.6175 ] Copying adsp-fw_sigheader.bin.encrypt to /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed
[   2.6177 ] Signed file: /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/adsp-fw_sigheader.bin.encrypt
[   2.6177 ] Copying spe_t234_sigheader.bin.encrypt to /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed
[   2.6178 ] Signed file: /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/spe_t234_sigheader.bin.encrypt
[   2.6178 ] Copying tos-optee_t234_sigheader.img.encrypt to /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed
[   2.6184 ] Signed file: /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/tos-optee_t234_sigheader.img.encrypt
[   2.6184 ] Copying eks_t234_sigheader.img.encrypt to /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed
[   2.6185 ] Signed file: /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/eks_t234_sigheader.img.encrypt
[   2.6185 ] Copying uefi_jetson_with_dtb_sigheader.bin.encrypt to /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed
[   2.6200 ] Signed file: /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/uefi_jetson_with_dtb_sigheader.bin.encrypt
[   2.6216 ] tegraparser_v2 --pt flash.xml.bin --generateflashindex /home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader/signed/flash.xml.tmp flash.idx
Using bpmp-dtb concatenated with odmdata in blob for t23x
./tegraflash.py --bl uefi_jetson_with_dtb_sigheader.bin.encrypt --bct br_bct_BR.bct --securedev  --bldtb tegra234-p3768-0000+p3767-0001-nv.dtb --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --cmd "rcmboot"  --cfg secureflash.xml --chip 0x23 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mb1_bin mb1_t234_prod_aligned_sigheader.bin.encrypt --psc_bl1_bin psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt  --bins "psc_fw pscfw_t234_prod_sigheader.bin.encrypt; mts_mce mce_flash_o10_cr_prod_sigheader.bin.encrypt; tsec_fw tsec_t234_sigheader.bin.encrypt; mb2_applet applet_t234_sigheader.bin.encrypt; mb2_bootloader mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt; xusb_fw xusb_t234_prod_sigheader.bin.encrypt; pva_fw nvpva_020_sigheader.fw.encrypt; dce_fw display-t234-dce_sigheader.bin.encrypt; nvdec nvdec_t234_prod_sigheader.fw.encrypt; bpmp_fw bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt; bpmp_fw_dtb tegra234-bpmp-3767-0001-3509-a02_with_odm_sigheader.dtb.encrypt; rce_fw camera-rtcpu-t234-rce_sigheader.img.encrypt; ape_fw adsp-fw_sigheader.bin.encrypt; spe_fw spe_t234_sigheader.bin.encrypt; tos tos-optee_t234_sigheader.img.encrypt; eks eks_t234_sigheader.img.encrypt; kernel boot.img; kernel_dtb tegra234-p3768-0000+p3767-0001-nv.dtb"    --bct_backup
saving flash command in flashcmd.txt
no_flash ...; prepare rcm blob
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
 Entering RCM boot
[   0.0092 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from --mb1_bin
[   0.0092 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from --psc_bl1_bin
[   0.0092 ] rcm boot with presigned binaries
[   0.0095 ] Generating blob for T23x
[   0.0100 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[   0.0102 ] The number of images in blob is 19
[   0.0103 ] blobsize is 78254676
[   0.0104 ] Added binary blob_uefi_jetson_with_dtb_sigheader.bin.encrypt of size 3563584
[   0.0302 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 310768
[   0.0305 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 187120
[   0.0306 ] Added binary blob_tsec_t234_sigheader.bin.encrypt of size 176128
[   0.0307 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 279616
[   0.0308 ] Not supported type: mb2_applet
[   0.0308 ] Added binary blob_mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt of size 439968
[   0.0309 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164864
[   0.0310 ] Added binary blob_nvpva_020_sigheader.fw.encrypt of size 2164640
[   0.0314 ] Added binary blob_display-t234-dce_sigheader.bin.encrypt of size 12065152
[   0.0365 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[   0.0381 ] Added binary blob_bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt of size 1027008
[   0.0385 ] Added binary blob_tegra234-bpmp-3767-0001-3509-a02_with_odm_sigheader.dtb.encrypt of size 263424
[   0.0386 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 458096
[   0.0387 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 414960
[   0.0388 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[   0.0389 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1633344
[   0.0394 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[   0.0396 ] Added binary blob_boot.img of size 54286336
[   0.0642 ] Added binary blob_tegra234-p3768-0000+p3767-0001-nv.dtb of size 244084
[   0.1270 ] All RCM required files are saved in rcm_blob folder
done.
*** no-flash flag enabled. Exiting now... ***
User can run above saved command in factory environment without
providing pkc and sbk keys to flash a device
Example:
    $ cd bootloader
    $ sudo bash ./flashcmd.txt
Save initrd flashing command parameters to /home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/initrdflashparam.txt
/tmp/tmp.RysiNXSxXN /home/ai-blox/Desktop/test/Linux_for_Tegra
writing boot image config in bootimg.cfg
extracting kernel in zImage
extracting ramdisk in initrd.img
/tmp/tmp.RysiNXSxXN/initrd /tmp/tmp.RysiNXSxXN /home/ai-blox/Desktop/test/Linux_for_Tegra
77459 blocks
grep: /home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/images/internal/flash.idx: No such file or directory
108535 blocks
flashimg0=boot0.img
Success
Cleaning up...
Finish generating flash package.
/home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh --external-only --usb-instance 1-8.3.2 --device-instance 0 --flash-only --external-device nvme0n1 -c "bootloader/generic/cfg/flash_t234_qspi.xml" -S 10240000000 --network usb0 jetson-orin-nano-devkit external
# Entry added by NVIDIA initrd flash tool
/home/ai-blox/Desktop/test/Linux_for_Tegra/tools/kernel_flash/tmp 127.0.0.1(rw,nohide,insecure,no_subtree_check,async,no_root_squash)
Export list for localhost:
*  Step 1: Build the flashing environment    *
Create flash environment 0
/home/ai-blox/Desktop/test/Linux_for_Tegra/bootloader /home/ai-blox/Desktop/test/Linux_for_Tegra
Finish creating flash environment 0.
*  Step 2: Boot the device with flash initrd image *
/home/ai-blox/Desktop/test/Linux_for_Tegra/temp_initrdflash/bootloader0 /home/ai-blox/Desktop/test/Linux_for_Tegra
./tegraflash.py --bl uefi_jetson_with_dtb_sigheader.bin.encrypt --bct br_bct_BR.bct --securedev  --bldtb tegra234-p3768-0000+p3767-0001-nv.dtb --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --cmd "rcmboot"  --cfg secureflash.xml --chip 0x23 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mb1_bin mb1_t234_prod_aligned_sigheader.bin.encrypt --psc_bl1_bin psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt  --bins "psc_fw pscfw_t234_prod_sigheader.bin.encrypt; mts_mce mce_flash_o10_cr_prod_sigheader.bin.encrypt; tsec_fw tsec_t234_sigheader.bin.encrypt; mb2_applet applet_t234_sigheader.bin.encrypt; mb2_bootloader mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt; xusb_fw xusb_t234_prod_sigheader.bin.encrypt; pva_fw nvpva_020_sigheader.fw.encrypt; dce_fw display-t234-dce_sigheader.bin.encrypt; nvdec nvdec_t234_prod_sigheader.fw.encrypt; bpmp_fw bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt; bpmp_fw_dtb tegra234-bpmp-3767-0001-3509-a02_with_odm_sigheader.dtb.encrypt; rce_fw camera-rtcpu-t234-rce_sigheader.img.encrypt; ape_fw adsp-fw_sigheader.bin.encrypt; spe_fw spe_t234_sigheader.bin.encrypt; tos tos-optee_t234_sigheader.img.encrypt; eks eks_t234_sigheader.img.encrypt; kernel boot0.img; kernel_dtb tegra234-p3768-0000+p3767-0001-nv.dtb"    --bct_backup  --instance 1-8.3.2
version 1.0.0
 Entering RCM boot
[   0.0174 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from --mb1_bin
[   0.0174 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from --psc_bl1_bin
[   0.0174 ] rcm boot with presigned binaries
[   0.0177 ] tegrarcm_v2 --instance 1-8.3.2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   0.0179 ] BR_CID: 0x80012344705DE5C07400000009FE8280
[   0.0244 ] Sending bct_br
[   0.0293 ] Sending mb1
[   0.0297 ] Sending psc_bl1
[   0.0393 ] Sending bct_mb1
[   0.0452 ] Generating blob for T23x
[   0.0459 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[   0.0462 ] The number of images in blob is 19
[   0.0464 ] blobsize is 87583316
[   0.0465 ] Added binary blob_uefi_jetson_with_dtb_sigheader.bin.encrypt of size 3563584
[   0.0707 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 310768
[   0.0710 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 187120
[   0.0711 ] Added binary blob_tsec_t234_sigheader.bin.encrypt of size 176128
[   0.0712 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 279616
[   0.0713 ] Not supported type: mb2_applet
[   0.0713 ] Added binary blob_mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt of size 439968
[   0.0714 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164864
[   0.0715 ] Added binary blob_nvpva_020_sigheader.fw.encrypt of size 2164640
[   0.0719 ] Added binary blob_display-t234-dce_sigheader.bin.encrypt of size 12065152
[   0.0757 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[   0.0769 ] Added binary blob_bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt of size 1027008
[   0.0773 ] Added binary blob_tegra234-bpmp-3767-0001-3509-a02_with_odm_sigheader.dtb.encrypt of size 263424
[   0.0776 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 458096
[   0.0777 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 414960
[   0.0778 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[   0.0780 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1633344
[   0.0785 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[   0.0787 ] Added binary blob_boot0.img of size 63614976
[   0.1062 ] Added binary blob_tegra234-p3768-0000+p3767-0001-nv.dtb of size 244084
[   0.1514 ] tegrarcm_v2 --instance 1-8.3.2 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[   0.1515 ] BL: version 1.4.0.2-t234-54845784-08a4de08 last_boot_error: 0
[   0.3059 ] Sending bct_mem
[   0.3179 ] Sending blob
[   3.5737 ] RCM-boot started
*  Step 3: Start the flashing process *
Waiting for target to boot-up...
Timeout
Device failed to boot to the initrd flash kernel. Please retrive the serial log during flashing to debug further.
Cleaning up...
And this is the output of the console:
I> Task: Prepare eeprom data
E> I2C: slave not found in slaves.
E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
E> I2C_DEV: Failed to send register address 0x00000000.
E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 0.
E> eeprom: Retry to read I2C slave device.
E> eeprom: Failed to read I2C slave device
C> Task 0x0 failed (err: 0x1f1e050d)
E> Top caller module: I2C_DEV, error module: I2C, reason: 0x0d, aux_info: 0x05
I> Busy Spin
Am I missing something here ?
OK. Somehow it worked with the following changes (although I’m still not able to successfully flash the module):
1- set the eeprom_read size to 0x0 in dts files
2- manually change the num_sectors in bootloader/generic/cfg
3- Used the following command for flashing
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" --showlogs --network usb0 jetson-orin-nano-devkit external
