Hi, I’m using Jetson Orin develop kit with R35.3.1
From UART log, there is a lot of empty lines in Jetson UEFI firmware.
[0000.062] I> MB1 (version: 0.32.0.0-t234-54845784-57325615)
[0000.067] I> t234-A01-0-Silicon (0x12347) Prod
[0000.071] I> Boot-mode : Coldboot
[0000.075] I> Emulation:
[0000.077] I> Entry timestamp: 0x00000000
[0000.081] I> last_boot_error: 0x0
[0000.084] I> BR-BCT: preprod_dev_sign: 0
[0000.088] I> rst_source: 0xb, rst_level: 0x1
[0000.092] I> Task: Bootchain select WAR set (0x5000ba65)
[0000.097] I> Task: Enable SLCG (0x5000bab1)
[0000.101] I> Task: CRC check (0x5001ea19)
[0000.105] I> Skip FUSE records CRC check as records_integrity fuse is not burned
[0000.112] I> Task: Initialize MB2 params (0x5000cb51)
[0000.117] I> MB2-params @ 0x40060000
[0000.121] I> Task: Crypto init (0x5001d981)
[0000.125] I> Task: Secure debug controls (0x5000c0a9)
[0000.130] I> Task: strap war set (0x5000ba2d)
[0000.134] I> Task: Initialize SOC Therm (0x5001bd35)
[0000.139] I> Task: Program NV master stream id (0x5000c05d)
[0000.144] I> Task: Verify boot mode (0xd4820f1)
[0000.150] I> Task: Alias fuses (0x5001095d)
[0000.155] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.162] I> Task: Print SKU type (0x5000f5f1)
[0000.166] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000000
[0000.171] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[0000.176] I> FUSE_OPT_TPC_DISABLE = 0x00000000
[0000.180] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0000.184] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0000.189] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0000.193] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.197] I> FUSE_OPT_FSI_DISABLE = 0x00000000
[0000.202] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0000.206] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.210] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.214] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.218] I> FUSE_SKU_INFO_0 = 0xd0
[0000.222] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.226] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.229] I> SKU: Prod
[0000.232] I> Task: Boost clocks (0x500148a1)
[0000.236] I> Initializing PLLC2 for AXI_CBB.
[0000.240] I> AXI_CBB : src = 35, divisor = 0
[0000.244] I> Task: Voltage monitor (0x50014b49)
[0000.248] I> VMON: Vmon re-calibration and fine tuning done
[0000.254] I> Task: UPHY init (0x5000d065)
[0000.260] I> HSIO UPHY init done
[0000.263] E> Skipping GBE UPHY config
[0000.266] I> Task: Boot device init (0x50000be9)
[0000.271] I> Boot_device: QSPI_FLASH instance: 0
[0000.275] I> Qspi clock source : pllc_out0
[0000.279] I> QSPI Flash: Macronix 64MB
[0000.283] I> QSPI-0l initialized successfully
[0000.287] I> Task: TSC init (0x50020a4d)
[0000.291] I> Task: Load membct (0x50011fe9)
[0000.295] I> RAM_CODE 0x4000401
[0000.298] I> Loading MEMBCT
[0000.301] I> Slot: 0
[0000.303] I> Binary[0] block-0 (partition size: 0x40000)
[0000.308] I> get_binary_info: Binary name: MEM-BCT-0
[0000.313] I> Size of crypto header is 8192
[0000.317] I> BCH load address is : 0x40050000
[0000.321] I> Size of crypto header is 8192
[0000.325] I> BCH of MEM-BCT-0 read from storage
[0000.330] I> BCH address is : 0x40050000
[0000.334] I> MEM-BCT-0 header integrity check is success
[0000.339] I> Binary magic in BCH component 0 is MEM0
[0000.344] I> component binary type is 0
[0000.348] I> MEM-BCT-0 binary is read from storage
[0000.353] I> MEM-BCT-0 binary integrity check is success
[0000.358] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.365] I> RAM_CODE 0x4000401
[0000.370] I> RAM_CODE 0x4000401
[0000.374] I> Task: Load Page retirement list (0x500115b1)
[0000.379] I> Task: SDRAM params override (0x50011fc5)
[0000.384] I> Task: Save mem-bct info (0x50014fa1)
[0000.388] I> Task: Carveout allocate (0x50015005)
[0000.393] I> RCM blob carveout will not be allocated
[0000.398] I> ECC region[0]: Start:0x0, End:0x0
[0000.402] I> ECC region[1]: Start:0x0, End:0x0
[0000.406] I> ECC region[2]: Start:0x0, End:0x0
[0000.411] I> ECC region[3]: Start:0x0, End:0x0
[0000.415] I> ECC region[4]: Start:0x0, End:0x0
[0000.419] I> Non-ECC region[0]: Start:0x80000000, End:0x880000000
[0000.425] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.430] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.434] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.439] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.449] I> allocated(CO:44) base:0x849800000 size:0x36800000 align: 0x100000
[0000.456] I> allocated(CO:31) base:0x840000000 size:0x8000000 align: 0x8000000
[0000.463] I> allocated(CO:43) base:0x83c000000 size:0x4000000 align: 0x200000
[0000.470] I> allocated(CO:20) base:0x83a000000 size:0x2000000 align: 0x2000000
[0000.477] I> allocated(CO:24) base:0x838000000 size:0x2000000 align: 0x2000000
[0000.484] I> allocated(CO:28) base:0x836000000 size:0x2000000 align: 0x2000000
[0000.491] I> allocated(CO:29) base:0x834000000 size:0x2000000 align: 0x2000000
[0000.498] I> allocated(CO:22) base:0x848000000 size:0x1000000 align: 0x1000000
[0000.505] I> allocated(CO:41) base:0x833000000 size:0x1000000 align: 0x100000
[0000.512] I> allocated(CO:35) base:0x832200000 size:0xe00000 align: 0x10000
[0000.519] I> allocated(CO:02) base:0x849000000 size:0x800000 align: 0x800000
[0000.526] I> allocated(CO:03) base:0x831800000 size:0x800000 align: 0x800000
[0000.533] I> allocated(CO:06) base:0x831000000 size:0x800000 align: 0x800000
[0000.540] I> allocated(CO:10) base:0x830800000 size:0x800000 align: 0x800000
[0000.547] I> allocated(CO:56) base:0x830000000 size:0x800000 align: 0x200000
[0000.554] I> allocated(CO:07) base:0x82fc00000 size:0x400000 align: 0x400000
[0000.561] I> allocated(CO:33) base:0x82f800000 size:0x400000 align: 0x200000
[0000.568] I> allocated(CO:23) base:0x832000000 size:0x200000 align: 0x200000
[0000.575] I> allocated(CO:01) base:0x82f700000 size:0x100000 align: 0x100000
[0000.582] I> allocated(CO:04) base:0x82f600000 size:0x100000 align: 0x100000
[0000.588] I> allocated(CO:05) base:0x82f500000 size:0x100000 align: 0x100000
[0000.595] I> allocated(CO:08) base:0x82f400000 size:0x100000 align: 0x100000
[0000.602] I> allocated(CO:09) base:0x82f300000 size:0x100000 align: 0x100000
[0000.609] I> allocated(CO:15) base:0x82f200000 size:0x100000 align: 0x100000
[0000.616] I> allocated(CO:17) base:0x82f100000 size:0x100000 align: 0x100000
[0000.623] I> allocated(CO:27) base:0x82f000000 size:0x100000 align: 0x100000
[0000.630] I> allocated(CO:42) base:0x82ef00000 size:0x100000 align: 0x100000
[0000.637] I> allocated(CO:54) base:0x82ee80000 size:0x80000 align: 0x80000
[0000.644] I> allocated(CO:34) base:0x82ee70000 size:0x10000 align: 0x10000
[0000.650] I> allocated(CO:47) base:0x82ea00000 size:0x400000 align: 0x200000
[0000.657] I> allocated(CO:72) base:0x82e800000 size:0x200000 align: 0x10000
[0000.664] I> allocated(CO:48) base:0x82ee50000 size:0x20000 align: 0x10000
[0000.671] I> allocated(CO:69) base:0x82ee30000 size:0x20000 align: 0x10000
[0000.678] I> allocated(CO:49) base:0x82ee20000 size:0x10000 align: 0x10000
[0000.684] I> allocated(CO:50) base:0x82ee10000 size:0x10000 align: 0x10000
[0000.691] I> allocated(CO:52) base:0x82ee00000 size:0x10000 align: 0x10000
[0000.698] I> NSDRAM base: 0x80000000, end: 0x82ee70000
[0000.703] I> Task: Thermal check (0x50021d55)
[0000.707] I> max_chip_limit = 105
[0000.710] I> min_chip_limit = -28
[0000.713] I> max temp read = 34
[0000.716] I> min temp read = 33
[0000.719] I> Task: Update FSI SCR with thermal fuse data (0x50021e61)
[0000.726] I> Task: Enable WDT 5th expiry (0x50021a41)
[0000.731] I> Task: I2C register (0x50000b85)
[0000.735] I> Task: Reset FSI (0x500148b1)
[0000.739] I> Task: Pinmux init (0x5001397d)
[0000.743] I> Task: Prod config init (0x50013ddd)
[0000.748] I> Task: Pad voltage init (0x50013a2d)
[0000.752] I> Task: Prod init (0x50013e21)
[0000.756] I> Task: Common rail init (0x50014575)
[0000.760] I> DONE: Thermal config
[0000.764] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.772] I> DONE: SOC rail config
[0000.776] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0000.782] I> DONE: MEMIO rail config
[0000.785] I> DONE: GPU rail info
[0000.789] I> DONE: CV rail info
[0000.792] I> Task: Mem clock src (0x50011de9)
[0000.796] I> Task: Misc. board config (0x5001461d)
[0000.801] W> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0000.807] I> Task: SDRAM init (0x50011ded)
[0000.811] I> SDRAM-params @ 0xd485000
[0000.814] I> MemoryType: 4 MemBctRevision: 9
[0000.821] I> MSS code-drop: NvBootSdramInit
[0000.825] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 9
[0000.832] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 9
[0000.840] I> MSS CAR: Init PLLM
[0000.843] I> MSS CAR: Init PLLHUB
[0000.848] I> Encryption: MTS: en, TX: en, VPR: en, GSC: en
[0000.859] I> mb1_sdram_init Done !
[0000.863] I> SDRAM Size in Total 0x800000000
[0000.867] I> Task: Dram Ecc scrub (0x500116f5)
[0000.871] I> Task: DRAM alias check (0x50011fbd)
[0000.903] I> Task: Program NSDRAM carveout (0x50015961)
[0000.910] I> NSDRAM carveout encryption is enabled
[0000.915] I> Program NSDRAM carveout
[0000.919] I> Task: Register checker (0x50011fc1)
[0000.927] I> Task: Enable clock-mon (0x50020a35)
[0000.944] I> FMON: Fmon re-programming done
[0000.948] I> Task: Mapper init (0x5001ef4d)
[0000.953] I> Task: SC7 Context Init (0x50020d3d)
[0000.959] I> Task: CCPLEX IST init (0x5000c925)
[0000.965] I> Task: CPU WP0 (0x5000bb15)
[0000.970] I> Loading MCE
[0000.973] I> Slot: 0
[0000.975] I> Binary[8] block-0 (partition size: 0x80000)
[0000.981] I> get_binary_info: Binary name: MCE
[0000.986] I> Size of crypto header is 8192
[0000.990] I> BCH load address is : 0x4003e000
[0000.996] I> Size of crypto header is 8192
[0001.001] I> BCH of MCE read from storage
[0001.005] I> BCH address is : 0x4003e000
[0001.010] I> MCE header integrity check is success
[0001.015] I> Binary magic in BCH component 0 is MTSM
[0001.020] I> component binary type is 8
[0001.025] I> Size of crypto header is 8192
[0001.031] I> MCE binary is read from storage
[0001.036] I> MCE binary integrity check is success
[0001.042] I> Binary MCE loaded successfully at 0x40000000 (0x2c880)
[0001.049] I> Size of crypto header is 8192
[0001.063] I> Size of crypto header is 8192
[0001.068] I> Sending WP0 mailbox command to PSC
[0001.079] I> Task: XUSB Powergate (0x50000b91)
[0001.084] I> Skipping powergate XUSB.
[0001.088] I> Task: MB1 fixed firewalls (0x5002006d)
[0001.099] W> Firewall readback mismatch
[0001.103] W> Firewall readback mismatch
[0001.112] W> Firewall readback mismatch
[0001.122] I> Task: Load bpmp-fw (0x500203c9)
[0001.128] I> Slot: 0
[0001.130] I> Binary[15] block-0 (partition size: 0x180000)
[0001.136] I> get_binary_info: Binary name: BPMP_FW
[0001.141] I> Size of crypto header is 8192
[0001.146] I> BCH load address is : 0x807fe000
[0001.151] I> Size of crypto header is 8192
[0001.156] I> BCH of BPMP_FW read from storage
[0001.161] I> BCH address is : 0x807fe000
[0001.166] I> BPMP_FW header integrity check is success
[0001.171] I> Binary magic in BCH component 0 is BPMF
[0001.177] I> component binary type is 15
[0001.181] I> Size of crypto header is 8192
[0001.196] I> BPMP_FW binary is read from storage
[0001.203] I> BPMP_FW binary integrity check is success
[0001.209] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xfddc0)
[0001.217] I> Slot: 0
[0001.219] I> Binary[16] block-10000 (partition size: 0x400000)
[0001.226] I> get_binary_info: Binary name: BPMP_FW_DTB
[0001.231] I> Size of crypto header is 8192
[0001.236] I> BCH load address is : 0x807fc000
[0001.241] I> Size of crypto header is 8192
[0001.246] I> BCH of BPMP_FW_DTB read from storage
[0001.251] I> BCH address is : 0x807fc000
[0001.256] I> BPMP_FW_DTB header integrity check is success
[0001.262] I> Binary magic in BCH component 0 is BPMD
[0001.268] I> component binary type is 16
[0001.272] I> Size of crypto header is 8192
[0001.278] I> BPMP_FW_DTB binary is read from storage
[0001.284] I> BPMP_FW_DTB binary integrity check is success
[0001.290] I> Binary BPMP_FW_DTB loaded successfully at 0x807db9f0 (0x20480)
[0001.298] I> Task: Load psc-fw (0x50020551)
[0001.304] I> Slot: 0
[0001.306] I> Binary[17] block-0 (partition size: 0xc0000)
[0001.312] I> get_binary_info: Binary name: PSC_FW
[0001.318] I> Size of crypto header is 8192
[0001.322] I> BCH load address is : 0x80ffe000
[0001.327] I> Size of crypto header is 8192
[0001.332] I> BCH of PSC_FW read from storage
[0001.337] I> BCH address is : 0x80ffe000
[0001.342] I> PSC_FW header integrity check is success
[0001.347] I> Binary magic in BCH component 0 is PFWP
[0001.353] I> component binary type is 17
[0001.357] I> Size of crypto header is 8192
[0001.365] I> PSC_FW binary is read from storage
[0001.371] I> PSC_FW binary integrity check is success
[0001.377] I> Binary PSC_FW loaded successfully at 0x80000000 (0x59980)
[0001.385] I> Task: Load nvdec-fw (0x500205c5)
[0001.390] I> Slot: 0
[0001.393] I> Binary[7] block-0 (partition size: 0x100000)
[0001.399] I> get_binary_info: Binary name: NVDEC
[0001.404] I> Size of crypto header is 8192
[0001.408] I> BCH load address is : 0x800fe000
[0001.414] I> Size of crypto header is 8192
[0001.419] I> BCH of NVDEC read from storage
[0001.423] I> BCH address is : 0x800fe000
[0001.428] I> NVDEC header integrity check is success
[0001.434] I> Binary magic in BCH component 0 is NDEC
[0001.439] I> component binary type is 7
[0001.443] I> Size of crypto header is 8192
[0001.451] I> NVDEC binary is read from storage
[0001.456] I> NVDEC binary integrity check is success
[0001.462] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0001.469] I> Size of crypto header is 8192
[0001.487] I> Task: Load tsec-fw (0x5002097d)
[0001.493] I> TSEC-FW load support not enabled
[0001.497] I> Task: GPIO interrupt map (0x500147b5)
[0001.503] I> Task: SC7 context save (0x50020d79)
[0001.509] I> Slot: 0
[0001.511] I> Binary[27] block-0 (partition size: 0x100000)
[0001.518] I> get_binary_info: Binary name: BR_BCT
[0001.523] I> Size of crypto header is 8192
[0001.527] I> Size of crypto header is 8192
[0001.532] I> BR_BCT binary is read from storage
[0001.537] I> BR_BCT binary integrity check is success
[0001.543] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[0001.550] I> Slot: 0
[0001.553] I> Binary[13] block-0 (partition size: 0x30000)
[0001.559] I> get_binary_info: Binary name: SC7-FW
[0001.564] I> Size of crypto header is 8192
[0001.568] I> Size of crypto header is 8192
[0001.573] I> BCH load address is : 0xa0002000
[0001.578] I> Size of crypto header is 8192
[0001.583] I> BCH of SC7-FW read from storage
[0001.588] I> BCH address is : 0xa0002000
[0001.593] I> SC7-FW header integrity check is success
[0001.598] I> Binary magic in BCH component 0 is WB0B
[0001.604] I> component binary type is 13
[0001.608] I> Size of crypto header is 8192
[0001.614] I> SC7-FW binary is read from storage
[0001.620] I> SC7-FW binary integrity check is success
[0001.625] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x26db0)
[0001.633] I> Slot: 0
[0001.635] I> Binary[22] block-0 (partition size: 0x30000)
[0001.641] I> get_binary_info: Binary name: PSC_RF
[0001.647] I> Size of crypto header is 8192
[0001.651] I> Size of crypto header is 8192
[0001.656] I> BCH load address is : 0xa002adb0
[0001.661] I> Size of crypto header is 8192
[0001.666] I> BCH of PSC_RF read from storage
[0001.670] I> BCH address is : 0xa002adb0
[0001.676] I> PSC_RF header integrity check is success
[0001.681] I> Binary magic in BCH component 0 is PSCR
[0001.686] I> component binary type is 22
[0001.691] I> Size of crypto header is 8192
[0001.696] I> PSC_RF binary is read from storage
[0001.702] I> PSC_RF binary integrity check is success
[0001.707] I> Binary PSC_RF loaded successfully at 0xa002cdb0 (0x1b140)
[0001.730] I> Task: Save WP0 payload to SC7 ctx (0x50021725)
[0001.737] I> Task: Load MB2rf binary to SC7 ctx (0x500216b9)
[0001.744] I> Slot: 0
[0001.746] I> Binary[14] block-0 (partition size: 0x20000)
[0001.752] I> get_binary_info: Binary name: MB2_RF
[0001.757] I> Size of crypto header is 8192
[0001.762] I> Size of crypto header is 8192
[0001.766] I> BCH load address is : 0xa00d6a48
[0001.771] I> Size of crypto header is 8192
[0001.776] I> BCH of MB2_RF read from storage
[0001.781] I> BCH address is : 0xa00d6a48
[0001.786] I> MB2_RF header integrity check is success
[0001.792] I> Binary magic in BCH component 0 is MB2R
[0001.797] I> component binary type is 14
[0001.801] I> Size of crypto header is 8192
[0001.807] I> MB2_RF binary is read from storage
[0001.812] I> MB2_RF binary integrity check is success
[0001.818] I> Binary MB2_RF loaded successfully at 0xa00d8a48 (0x1bfa0)
[0001.826] I> Task: Save Fuse-Bypass data to SC7 ctx (0x50021621)
[0001.833] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0001.841] I> SC7 context fuse-bypass data is empty
[0001.846] I> Task: Save PMIC data to SC7 ctx (0x5002144d)
[0001.853] I> Task: Save I2C bus freq data to SC7 ctx (0x500213d9)
[0001.860] I> Task: Save SOCTherm data to SC7 ctx (0x50021365)
[0001.866] I> Task: Save FMON data to SC7 ctx (0x500212f1)
[0001.873] I> Task: Save VMON data to SC7 ctx (0x50021279)
[0001.879] I> Task: Save TZDRAM data to SC7 ctx (0x5002178d)
[0001.886] I> Task: Save GPIO int data to SC7 ctx (0x50021561)
[0001.893] I> Task: Save clock data to SC7 ctx (0x50021205)
[0001.899] I> Task: Save debug data to SC7 ctx (0x50021191)
[0001.910] I> SC7 context save done
[0001.914] I> Task: Load MB2/Applet/FSKP (0x5000ca55)
[0001.920] I> Loading MB2
[0001.923] I> Slot: 0
[0001.925] I> Binary[6] block-0 (partition size: 0x80000)
[0001.931] I> get_binary_info: Binary name: MB2
[0001.936] I> Size of crypto header is 8192
[0001.941] I> BCH load address is : 0x8007e000
[0001.946] I> Size of crypto header is 8192
[0001.951] I> BCH of MB2 read from storage
[0001.955] I> BCH address is : 0x8007e000
[0001.960] I> MB2 header integrity check is success
[0001.965] I> Binary magic in BCH component 0 is MB2B
[0001.971] I> component binary type is 6
[0001.975] I> Size of crypto header is 8192
[0001.984] I> MB2 binary is read from storage
[0001.990] I> MB2 binary integrity check is success
[0001.995] I> Binary MB2 loaded successfully at 0x80000000 (0x68ee0)
[0002.003] I> Task: Map CCPLEX SHARED carveout (0x5000cbf9)
[0002.010] I> Task: Prepare MB2 params (0x5000cca9)
[0002.016] I> BR-BCT Boot Chain Fields
[0002.020] I> u32_non_gpio_select_boot_chain : 0
[0002.025] I> u32_num_boot_chains : 2
[0002.030] I> bf_bl_gpio_select_boot_chain_1b : 0
[0002.036] I> Task: Dram ecc test (0x50011791)
[0002.041] I> Task: Misc NV security settings (0x5000c529)
[0002.048] I> NVDEC sticky bits programming done
[0002.053] I> Successfully powergated NVDEC
[0002.057] I> Task: Disable/Reload WDT (0x50021a99)
[0002.063] I> Task: Program misc carveouts (0x50015381)
[0002.069] I> Program IPC carveouts
[0002.076] I> SLCG Global override status := 0x0
[0002.081] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-9c429857)
I> Emulation:
I> Entry timestamp: 0x002064b4
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0x830000000, size:0x800000]
I> Task: ARI update carveout TZDRAM (0x50001e80)
I> Task: Enable hot-plug capability (0x50026c6c)
I> Task: PSC mailbox init (0x50016a7c)
I> Task: Crypto init (0x500065a8)
I> Task: Enable GP-SE clock (0x50001fe4)
I> Task: DICE Identity init (0x50019e50)
I> DICE is not enabled.
I> Task: OEM SC7 context save init (0x50019550)
I> Task: I2C register (0x50001e44)
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout (0x50001e2c)
I> Task: Program CBB PCIE AMAP regions (0x50019b64)
I> Task: Boot device init (0x50001d74)
I> Task: Partition Manager Init (0x50001d70)
I> Found 57 partitions in QSPI_FLASH (instance 0)
W> Cannot find any partition table for 00000003
> PARTITION_MANAGER: Failed to publish partition.
I> Found 14 partitions in SDMMC_USER (instance 3)
I> Task: Load and authenticate registered FWs (0x5001ce48)
I> Task: Load AUXP FWs (0x5002680c)
I> Successfully register SPE FW load task with MB2 loader
I> Skipping SCE FW load
I> Successfully register RCE FW load task with MB2 loader
I> Successfully register DCE FW load task with MB2 loader
I> Unpowergating APE
I> Unpowergate done
I> Successfully register APE FW load task with MB2 loader
I> Skipping FSI FW load
I> Successfully register XUSB FW load task with MB2 loader
I> Partition name: A_spe-fw
I> Size of partition: 589824
I> Binary@ device:3/0 block-55040 (partition size: 0x90000), name: A_spe-fw
I> Partition name: A_rce-fw
I> Size of partition: 1048576
I> Binary@ device:3/0 block-56192 (partition size: 0x100000), name: A_rce-fw
I> spe: Authentication Finalize Done
I> Binary spe loaded successfully at 0x82f400000
I> Partition name: A_dce-fw
I> Size of partition: 5242880
I> Binary@ device:3/0 block-44800 (partition size: 0x500000), name: A_dce-fw
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0x82f100000
I> dce : oem authentication of header done
I> dce : meta-blob integrity check is success.
I> dce : will be decompressed at 0x83a000000
I> version 1 Bin 1 BCheckSum 0 content_size 0 Content ChkSum 1 reserved_00 0
I> Reserved10 0 BlockMaxSize 5 Reserved11 0
I> dce : decompressed to 9509936 bytes
I> dce: plain binary integrity check is success
I> Partition name: A_adsp-fw
I> Size of partition: 2097152
I> Binary@ device:3/0 block-58240 (partition size: 0x200000), name: A_adsp-fw
I> dce: Authentication Finalize Done
I> Binary dce loaded successfully at 0x83a000000
I> Partition name: A_xusb-fw
I> Size of partition: 262144
I> Binary@ device:3/0 block-9472 (partition size: 0x40000), name: A_xusb-fw
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0x82fc00000
I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0x82f500000
I> Task: Carveout setup (0x5001f55c)
I> Program remaining OEM carveouts
I> Task: Enable FSITHERM (0x50016950)
I> Task: Enable FSI VMON (0x500164d8)
E> FSI VMON: FUSE_OPT_ADC_CAL_FSI not programmed
I> Task: Validate FSI Therm readings (0x50016530)
I> FSITHERM max temp = 34
I> FSITHERM min temp = 33
I> Task: Restore XUSB sec (0x50001d44)
I> Task: Enable FSI SE clock (0x50016ed8)
I> Enable FSI-SE clock and 10ms delay...
I> Task: Initialize SBSA UART CAR (0x50001f48)
I> Task: Ratchet update (0x50027d08)
W> OPTIN fuse not set, skip ratchet update
I> Task: Initialize CPUBL Params (0x50017e0c)
I> CPUBL-params @ 0x836000000
I> Task: Prepare eeprom data (0x50017bd8)
I> Task: FSI padctl context save (0x500196e0)
I> Task: Unpowergate APE (0x50017640)
W> mb2_unpowergate_ape: skip! APE is in unpowergated state
I> Task: OEM firewalls (0x5002397c)
I> OEM firewalls configured
I> Task: Powergate APE (0x500177b4)
I> Powergating APE
I> Powergate done
I> Task: OEM firewall restore saved settings (0x50023dd0)
I> Task: Unhalt AUXPs (0x50026a74)
I> Unhalting SPE..
I> Enabling combined UART
?跴pe: early_init
vic initialized
tsc initialized
aon lic initialized
spe: tag is 243b265b351d6bb9cc7b2e3acc5d90f8
spe: SafeRTOS v8.4
spe: init
scheduler initialized
aon hsp initialized
tag initialized
tcu initialized
bpmp ipc initialized
spe: late init
cpu_nic clock initialized
apb clock initialized
pm initialized
bpmp hsp initialized
top1 hsp initialized
ccplex ipc initialized
spe: start scheduler
I> Task: Trigger mailbox for PSC-BL1 exit (0x50016afc)
I> Sending opcode 0x4d420802 to psc
艐NFO: Entering psc_monitor_init!
INFO: GSC22 BOM:0x848002000 SIZE:0x1000000 CLIENT_ACCESS1:00180000
INFO: PSCFW BUILD VERSION: 8a33b23-73b589c-8a15f76-rel-t234
INFO: mstatus:0xa00000808
INFO: Supervisor entry_point:c108c00
嘌> Received ACK from psc
I> Tas艐NFO: MONITOR: user task addr:0x848022000, blob offset:0x00020000
INFO: MONITOR: populated user images:13
INFO: mret to Supervisor!
INFO: psc supervisor init.
INFO: psc_irq_init...
INFO: enter idl?
bpmp: socket 0
bpmp: base binary md5 is 1377b684fe55be78e1d7fc3e0f143b55
bpmp: combined binary md5 is 463f4d5b75234b74bb7蔒 task.
殞05b524d2a015
bpmp: firmware tag is 463f4d5b75234b74bb7f-1377b684fe5
initialized vwdt
initialized mail_early
initialized fuse
initialized vfrel
initialized hwwdt
initialized adc
fmon_populate_monitors: found 199 monitors
initialized fmon
initialized mc
initialized reset
initialized uphy_early
initialized emc_early
471 clocks registered
initialized clk_mach
initialized clk_cal_early
initialized clk_mach_early_config
initialized io_dpd
initialized soctherm
initialized tj_init
initialized regime
initialized i2c
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
initialized vrmon
initialized regulator
嫜: Start secure NOR provision (0x5001997c)
I> Task: Load FSI keyblob (0x50016f20)
I> Skipping FSI key blob copy
I> Task: Unhalt毃nitialized avfs_clk_platform
initialized powergate
?AUXPs (0x50026a7c)
I> SCE unhalt skipped
I> Unhalting RCE
I> RCE unhalt successful
I> DCE un毃nitialized dvs
initialized clk_mach_config
initialized pm
suspend progress: 0x0
initialized suspend
initialized strap
initialized mce_dbell
嬂 2.545214] Camera-FW on t234-rce-safe started
TCU early console enabled.
墏alt successful
I> APE unhalt skipped
I> FSI unhalt skipped
I> Task: Load CPUBL (0x50017f04)
I> Task: Load TOS (0x50018608)
I> Partition name: A_cpu-bootloader
I> Size of partition: 3670016
I> Binary@ device:3/0 block-24832 (partition size: 0x380000), name: A_cpu-bootloader
毃nitialized emc
initialized emc_mrq
initialized clk_cal
initialized uphy_dt
initialized uphy_mrq
HSIO UPHY reset has been de-asserted 0x0
initialized uphy
initialized pg_late
initialized pg_mrq_init
swdtimer_init: 0 reg polling start w period 47 ms
initialized swdtimer
initialized hwwdt_late
initialized bwmgr
initialized thermal_host_trip
initialized thermal_mrq
initialized oc_mrq
initialized reset_mrq
initialized mail_mrq
initialized fmon_mrq
initialized clk_mrq
initialized avfs_mrq
initialized i2c_mrq
initialized tag_mrq
initialized bwmgr_mrq
initialized console_mrq
嘌> Partition name: A_secure-os
I> Size of partition: 4194304
滵issing prod DT calibration data for 199 fmons
initialized clk_sync_fmon_post
嘌> Binary@ device:3/0 block-32000 (partition size: 0x400000), name: A_secure-os
I> cpubl: Authentication Finalize Done
I> Binary cpubl loaded successfully at 0x82ea00000
毃nitialized clk_cal_late
initialized noc_late
initialized cvc
嘌> tos: Authentication Finalize Done
I> Binary tos l毃nitialized avfs_clk_mach_post
initialized avfs_clk_platform_post
initialized cvc_late
initialized rm
initialized console_late
handling unreferenced clks
enable can1_core
enable can1_host
enable can2_core
enable can2_host
enable pwm3
enable mss_encrypt
enable maud
enable pllg_ref
enable dsi_core
enable aza_2xbit
enable pllc4_muxed
enable xusb_ss
enable xusb_fs
enable xusb_falcon
enable xusb_core_mux
enable dsi_lp
enable sdmmc_legacy_tm
initialized clk_mach_post
initialized pg_post
initialized reg嬂 2.717871] Camera-FW on t234-rce-safe ready SHA1=97e50cbf (crt 12.948 ms,漉lator_post
initialized profile
initialized fuse_late
initialized mrq
initialized patrol_scrubber
initialized cactmon
initialized extras_post
bpmp: ini?total boot 186.665 ms)
漮 complete
嫪aded successfully at 0x83fdfe000
I> Relocating OP-TEE dtb from: 0x83feff770 to 0x82ee30000, size: 0x1976
I> [0] START: 0x80000000, SIZE: 0x7aee70000
I> [1] START: 0x836000000, SIZE: 0x2000000
I> Setting NS memory ranges to OP-TEE dtb finished.
I> Partition name: A_eks
I> Binary@ device:3/0 block-44288 (partition size: 0x40000), name: A_eks
I> eks: Authentication Finalize Done
I> Binary eks loaded successfully at 0x830000400
I> EKB detected (length: 0x410) @ VA:0x830000400
I> Task: Prepare TOS params (0x50018580)
I> Setting EKB blob info to OPTEE dtb finished.
I> Setting OPTEE arg3: 0x82ee30000
I> Task: OEM SC7 context save (0x500197dc)
I> OEM sc7 context saved
I> Task: Disable MSS perf stats (0x50026b08)
I> Task: Program display sticky bits (0x50026a84)
I> Task: Storage device deinit (0x50001eec)
I> Task: SMMU external bypass disable (0x50016a60)
I> Task: SMMU init (0x5001697c)
I> Task: Program GICv3 registers (0x50026ba8)
I> Task: Audit firewall settings (0x50023bd0)
I> Task: Bootchain failure check (0x50002434)
I> Current Boot-Chain Slot: 0
I> BR-BCT Boot-Chain is 0, and status is 1. Set UPDATE_BRBCT bit to 0
I> MB2 finished
誏OTICE: BL31: v2.6(release):07eea4970
NOTICE: BL31: Built : 07:55:15, Mar 19 2023
I/TC:
踜CE: FW Boot Done
觨/TC: Non-secure external DT found
I/TC: OP-TEE version: 3.19 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Sun Mar 19 15:02:44 UTC 2023 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: WARNING: Test OEM keys are being used!
I/TC: This is only for TZ-SE testing and should NOT be used for a shipping product!
I/TC: Primary CPU switching to normal world boot
Jetson UEFI firmware (version 3.1-32827747 built on 2023-03-19T14:56:32+00:00)
ESC to enter Setup.
F11 to enter Boot Manager Menu.
Enter to continue boot.
When I enable full UEFI log I see the firmware load lots of driver (about 170) in this phase.
- Can this part be optimized? such us skip or reduce the amount of drivers being loaded.
Another issue is:
I followed the instructions on Build · NVIDIA/edk2-nvidia Wiki · GitHub to build UEFI last week, I use source on main branch.
edkrepo clone nvidia-uefi NVIDIA-Jetson main
It worked normally, but since this Monday (5/8), I clone source from main and build again, I get error messages.
I do same instructions to r35.3.1 branch and it works fine.
