DP and PCIe of the Orin NX
Hi NV team, we make a carrier board for the Jetson Orin NX 16GB module feature two PCIe interface for SSD and the DP port. We success to flash it the JP5.1 follow the guide for Orin NX + Xavier NX carrier board. However, one of the PCIe and DP port seems to be disabled. Could you please show me how could I enable them? Should I need to modify the souces codes and rebuild the kernel? If I should, which files should be edited?
Thanks for your help.
Attach the logs of serial booting for checking.
ÿ
[0000.064] I> MB1 (version: 0.28.0.0-t234-54845784-ec016368)
[0000.069] I> t234-A01-0-Silicon (0x12347) Prod
[0000.073] I> Boot-mode : Coldboot
[0000.077] I> Emulation:
[0000.079] I> Entry timestamp: 0x00000000
[0000.083] I> last_boot_error: 0x0
[0000.086] I> BR-BCT: preprod_dev_sign: 0
[0000.090] I> rst_source: 0x0, rst_level: 0x0
[0000.094] I> Task: Bootchain select WAR set (0x5000c741)
[0000.099] I> Active chain: 0
[0000.102] I> Task: CRC check (0x5001dab5)
[0000.106] I> Task: Initialize MB2 params (0x5000d78d)
[0000.111] I> MB2-params @ 0x40060000
[0000.114] I> Task: Crypto init (0x5001cb8d)
[0000.118] I> Task: Secure debug controls (0x5000cd21)
[0000.123] I> Task: strap war set (0x5000c70d)
[0000.128] I> strap value(0x4000401) set to 0x4000401
[0000.132] I> Task: Initialize SOC Therm (0x5001af85)
[0000.137] I> Task: Program NV master stream id (0x5000ccd5)
[0000.143] I> Task: Verify boot mode (0xd482021)
[0000.149] I> Task: Alias fuses (0x500109cd)
[0000.153] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.160] I> Task: Print SKU type (0x5000fee1)
[0000.164] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c0
[0000.169] I> FUSE_OPT_GPC_DISABLE = 0x00000002
[0000.174] I> FUSE_OPT_TPC_DISABLE = 0x000000f0
[0000.178] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0000.182] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0000.186] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.191] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.195] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.199] I> FUSE_SKU_INFO_0 = 0xd3
[0000.202] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.206] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.210] I> SKU: Prod
[0000.212] I> Task: Boost clocks (0x5001462d)
[0000.216] I> Initializing PLLC2 for AXI_CBB.
[0000.220] I> AXI_CBB : src = 35, divisor = 0
[0000.224] I> Task: Voltage monitor (0x50014639)
[0000.229] I> VMON: Vmon re-calibration and fine tuning done
[0000.234] I> Task: UPHY init (0x5000dced)
[0000.239] W> UPHY: UPHY lane info table is empty in MB1 BCT.
[0000.244] I> Task: Boot device init (0x50000b39)
[0000.249] I> Boot_device: QSPI_FLASH instance: 0
[0000.253] I> Qspi clock source : pllc_out0
[0000.257] I> QSPI Flash: Macronix 64MB
[0000.261] I> QSPI-0l initialized successfully
[0000.265] I> Task: TSC init (0x5001fa6d)
[0000.269] I> Task: Load membct (0x50011fb9)
[0000.273] I> RAM_CODE 0x4000401
[0000.276] I> Loading MEMBCT
[0000.279] I> Active chain: 0
[0000.282] I> Slot: 0
[0000.284] I> Binary[0] block-0 (partition size: 0x40000)
[0000.289] I>  get_binary_info: Binary name: MEM-BCT-0
[0000.294] I> Size of crypto header is 8192
[0000.298] I> BCH load address is : 0x40050000
[0000.302] I> Size of crypto header is 8192
[0000.306] I> BCH of MEM-BCT-0 read from storage
[0000.310] I> BCH address is : 0x40050000
[0000.314] I> MEM-BCT-0 header integrity check is success
[0000.320] I> Binary magic in BCH component 0 is MEM0
[0000.324] I> component binary type is 0
[0000.329] I> MEM-BCT-0 binary is read from storage
[0000.334] I> MEM-BCT-0 binary integrity check is success
[0000.339] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.345] I> RAM_CODE 0x4000401
[0000.351] I> RAM_CODE 0x4000401
[0000.354] I> Task: Load Page retirement list (0x50011601)
[0000.360] I> Task: SDRAM params override (0x50011f95)
[0000.365] I> Task: Save mem-bct info (0x500147fd)
[0000.369] I> Task: Carveout allocate (0x50014861)
[0000.374] I> RCM blob carveout will not be allocated
[0000.378] I> ECC region[0]: Start:0x0, End:0x0
[0000.383] I> ECC region[1]: Start:0x0, End:0x0
[0000.387] I> ECC region[2]: Start:0x0, End:0x0
[0000.391] I> ECC region[3]: Start:0x0, End:0x0
[0000.396] I> ECC region[4]: Start:0x0, End:0x0
[0000.400] I> Non-ECC region[0]: Start:0x80000000, End:0x480000000
[0000.406] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.410] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.415] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.420] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.429] I> allocated(CO:44) base:0x449800000 size:0x36800000 align: 0x100000
[0000.436] I> allocated(CO:31) base:0x440000000 size:0x8000000 align: 0x8000000
[0000.444] I> allocated(CO:43) base:0x43c000000 size:0x4000000 align: 0x200000
[0000.451] I> allocated(CO:20) base:0x43a000000 size:0x2000000 align: 0x2000000
[0000.458] I> allocated(CO:24) base:0x438000000 size:0x2000000 align: 0x2000000
[0000.465] I> allocated(CO:28) base:0x436000000 size:0x2000000 align: 0x2000000
[0000.472] I> allocated(CO:29) base:0x434000000 size:0x2000000 align: 0x2000000
[0000.479] I> allocated(CO:22) base:0x448000000 size:0x1000000 align: 0x1000000
[0000.486] I> allocated(CO:41) base:0x433000000 size:0x1000000 align: 0x100000
[0000.493] I> allocated(CO:35) base:0x432200000 size:0xe00000 align: 0x10000
[0000.500] I> allocated(CO:02) base:0x449000000 size:0x800000 align: 0x800000
[0000.507] I> allocated(CO:03) base:0x431800000 size:0x800000 align: 0x800000
[0000.514] I> allocated(CO:06) base:0x431000000 size:0x800000 align: 0x800000
[0000.521] I> allocated(CO:10) base:0x430800000 size:0x800000 align: 0x800000
[0000.528] I> allocated(CO:56) base:0x430000000 size:0x800000 align: 0x200000
[0000.535] I> allocated(CO:07) base:0x42fc00000 size:0x400000 align: 0x400000
[0000.541] I> allocated(CO:33) base:0x42f800000 size:0x400000 align: 0x200000
[0000.548] I> allocated(CO:01) base:0x432100000 size:0x100000 align: 0x100000
[0000.555] I> allocated(CO:04) base:0x432000000 size:0x100000 align: 0x100000
[0000.562] I> allocated(CO:05) base:0x42f700000 size:0x100000 align: 0x100000
[0000.569] I> allocated(CO:08) base:0x42f600000 size:0x100000 align: 0x100000
[0000.576] I> allocated(CO:09) base:0x42f500000 size:0x100000 align: 0x100000
[0000.583] I> allocated(CO:15) base:0x42f400000 size:0x100000 align: 0x100000
[0000.590] I> allocated(CO:17) base:0x42f300000 size:0x100000 align: 0x100000
[0000.597] I> allocated(CO:23) base:0x42f200000 size:0x100000 align: 0x100000
[0000.604] I> allocated(CO:27) base:0x42f100000 size:0x100000 align: 0x100000
[0000.611] I> allocated(CO:42) base:0x42f000000 size:0x100000 align: 0x100000
[0000.618] I> allocated(CO:54) base:0x42ef80000 size:0x80000 align: 0x80000
[0000.624] I> allocated(CO:34) base:0x42ef70000 size:0x10000 align: 0x10000
[0000.631] I> allocated(CO:47) base:0x42ea00000 size:0x400000 align: 0x200000
[0000.638] I> allocated(CO:72) base:0x42e800000 size:0x200000 align: 0x10000
[0000.645] I> allocated(CO:48) base:0x42ef50000 size:0x20000 align: 0x10000
[0000.652] I> allocated(CO:69) base:0x42ef30000 size:0x20000 align: 0x10000
[0000.658] I> allocated(CO:49) base:0x42ef20000 size:0x10000 align: 0x10000
[0000.665] I> allocated(CO:50) base:0x42ef10000 size:0x10000 align: 0x10000
[0000.672] I> allocated(CO:52) base:0x42ef00000 size:0x10000 align: 0x10000
[0000.679] I> NSDRAM base: 0x80000000, end: 0x42ef70000
[0000.684] I> Task: Thermal check (0x500208f9)
[0000.688] I> max_chip_limit = 105
[0000.691] I> min_chip_limit = -28
[0000.694] I> max temp read = 49
[0000.697] I> min temp read = 46
[0000.700] I> Task: Update FSI SCR with thermal fuse data (0x50020a05)
[0000.706] I> Task: Enable WDT 5th expiry (0x50020699)
[0000.711] I> Task: I2C register (0x50000ad9)
[0000.715] I> Task: Reset FSI (0x50014635)
[0000.719] I> Task: Pinmux init (0x500137bd)
[0000.724] I> Task: Prod config init (0x50013c09)
[0000.728] I> Task: Pad voltage init (0x50013859)
[0000.732] I> Task: Prod init (0x50013c4d)
[0000.736] I> Task: Common rail init (0x50014305)
[0000.741] I> DONE: Thermal config
[0000.745] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.752] I> DONE: SOC rail config
[0000.756] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0000.762] I> DONE: MEMIO rail config
[0000.766] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.
[0000.772] I> DONE: GPU rail info
[0000.775] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.
[0000.781] I> DONE: CV rail info
[0000.784] I> Task: Mem clock src (0x50011de5)
[0000.788] I> Task: Misc. board config (0x500143ad)
[0000.793] W> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0000.799] I> Task: SDRAM init (0x50011de9)
[0000.806] I> SDRAM-params @ 0xd485000
[0000.809] I> MSS code-drop: NvBootSdramInit
[0000.813] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 1
[0000.821] I> MSS CAR: Init PLLM
[0000.824] I> MSS CAR: Init PLLHUB
[0000.828] I> Encryption:   MTS: en, TX: en, VPR: en, GSC: en
[0000.840] I> mb1_sdram_init Done !
[0000.843] I> SDRAM Size in Total 0x400000000
[0000.847] I> Task: Dram Ecc scrub (0x50011729)
[0000.851] I> Task: DRAM alias check (0x50011f8d)
[0000.869] I> Task: Program NSDRAM carveout (0x50015171)
[0000.876] I> NSDRAM carveout encryption is enabled
[0000.881] I> Program NSDRAM carveout
[0000.885] I> Task: Register checker (0x50011f91)
[0000.892] I> Task: Enable clock-mon (0x5001fa5d)
[0000.899] I> FMON: Fmon re-programming done
[0000.903] I> Task: Mapper init (0x5001dfed)
[0000.908] I> Task: SC7 Context Init (0x5001fd5d)
[0000.914] I> Task: CCPLEX IST init (0x5000d561)
[0000.921] I> Task: CPU WP0 (0x5000c7a9)
[0000.926] I> Loading MCE
[0000.928] I> Active chain: 0
[0000.932] I> Slot: 0
[0000.934] I> Binary[8] block-0 (partition size: 0x80000)
[0000.940] I>  get_binary_info: Binary name: MCE
[0000.945] I> Size of crypto header is 8192
[0000.949] I> BCH load address is : 0x4003e000
[0000.955] I> Size of crypto header is 8192
[0000.959] I> BCH of MCE read from storage
[0000.964] I> BCH address is : 0x4003e000
[0000.969] I> MCE header integrity check is success
[0000.974] I> Binary magic in BCH component 0 is MTSM
[0000.979] I> component binary type is 8
[0000.984] I> Size of crypto header is 8192
[0000.990] I> MCE binary is read from storage
[0000.995] I> MCE binary integrity check is success
[0001.000] I> Binary MCE loaded successfully at 0x40000000 (0x2c880)
[0001.008] I> Size of crypto header is 8192
[0001.024] I> Size of crypto header is 8192
[0001.029] I> Sending WP0 mailbox command to PSC
[0001.039] I> Task: XUSB Powergate (0x50000ae5)
[0001.044] I> Skipping powergate XUSB.
[0001.048] I> Task: MB1 fixed firewalls (0x5001f0d9)
[0001.069] I> Task: Load bpmp-fw (0x5001f41d)
[0001.075] I> Active chain: 0
[0001.078] I> Slot: 0
[0001.080] I> Binary[15] block-0 (partition size: 0x180000)
[0001.087] I>  get_binary_info: Binary name: BPMP_FW
[0001.092] I> Size of crypto header is 8192
[0001.096] I> BCH load address is : 0x807fe000
[0001.102] I> Size of crypto header is 8192
[0001.107] I> BCH of BPMP_FW read from storage
[0001.111] I> BCH address is : 0x807fe000
[0001.117] I> BPMP_FW header integrity check is success
[0001.122] I> Binary magic in BCH component 0 is BPMF
[0001.128] I> component binary type is 15
[0001.132] I> Size of crypto header is 8192
[0001.147] I> BPMP_FW binary is read from storage
[0001.154] I> BPMP_FW binary integrity check is success
[0001.160] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xfdc40)
[0001.168] I> Active chain: 0
[0001.171] I> Slot: 0
[0001.174] I> Binary[16] block-10000 (partition size: 0x400000)
[0001.180] I>  get_binary_info: Binary name: BPMP_FW_DTB
[0001.186] I> Size of crypto header is 8192
[0001.191] I> BCH load address is : 0x807fc000
[0001.196] I> Size of crypto header is 8192
[0001.201] I> BCH of BPMP_FW_DTB read from storage
[0001.206] I> BCH address is : 0x807fc000
[0001.211] I> BPMP_FW_DTB header integrity check is success
[0001.217] I> Binary magic in BCH component 0 is BPMD
[0001.223] I> component binary type is 16
[0001.227] I> Size of crypto header is 8192
[0001.233] I> BPMP_FW_DTB binary is read from storage
[0001.239] I> BPMP_FW_DTB binary integrity check is success
[0001.245] I> Binary BPMP_FW_DTB loaded successfully at 0x807dbff0 (0x1fe80)
[0001.254] I> Task: Load psc-fw (0x5001f5a5)
[0001.259] I> Active chain: 0
[0001.262] I> Slot: 0
[0001.265] I> Binary[17] block-0 (partition size: 0xc0000)
[0001.271] I>  get_binary_info: Binary name: PSC_FW
[0001.276] I> Size of crypto header is 8192
[0001.280] I> BCH load address is : 0x80ffe000
[0001.286] I> Size of crypto header is 8192
[0001.291] I> BCH of PSC_FW read from storage
[0001.295] I> BCH address is : 0x80ffe000
[0001.301] I> PSC_FW header integrity check is success
[0001.306] I> Binary magic in BCH component 0 is PFWP
[0001.311] I> component binary type is 17
[0001.316] I> Size of crypto header is 8192
[0001.324] I> PSC_FW binary is read from storage
[0001.330] I> PSC_FW binary integrity check is success
[0001.336] I> Binary PSC_FW loaded successfully at 0x80000000 (0x59980)
[0001.344] I> Task: Load nvdec-fw (0x5001f619)
[0001.350] I> Active chain: 0
[0001.353] I> Slot: 0
[0001.355] I> Binary[7] block-0 (partition size: 0x100000)
[0001.361] I>  get_binary_info: Binary name: NVDEC
[0001.366] I> Size of crypto header is 8192
[0001.371] I> BCH load address is : 0x800fe000
[0001.376] I> Size of crypto header is 8192
[0001.381] I> BCH of NVDEC read from storage
[0001.386] I> BCH address is : 0x800fe000
[0001.391] I> NVDEC header integrity check is success
[0001.397] I> Binary magic in BCH component 0 is NDEC
[0001.402] I> component binary type is 7
[0001.406] I> Size of crypto header is 8192
[0001.414] I> NVDEC binary is read from storage
[0001.419] I> NVDEC binary integrity check is success
[0001.425] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0001.435] I> Task: Load tsec-fw (0x5001f9a5)
[0001.441] I> TSEC-FW load support not enabled
[0001.445] I> Task: GPIO interrupt map (0x50014541)
[0001.452] I> Task: SC7 context save (0x5001fe9d)
[0001.457] I> NV_SC7 Context addr: 0xa0000000
[0001.463] I> Active chain: 0
[0001.466] I> Slot: 0
[0001.468] I> Binary[27] block-0 (partition size: 0x100000)
[0001.475] I>  get_binary_info: Binary name: BR_BCT
[0001.480] I> Size of crypto header is 8192
[0001.484] I> Size of crypto header is 8192
[0001.489] I> BR_BCT binary is read from storage
[0001.494] I> BR_BCT binary integrity check is success
[0001.500] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[0001.508] I> Active chain: 0
[0001.511] I> Slot: 0
[0001.513] I> Binary[13] block-0 (partition size: 0x30000)
[0001.519] I>  get_binary_info: Binary name: SC7-FW
[0001.524] I> Size of crypto header is 8192
[0001.529] I> Size of crypto header is 8192
[0001.533] I> BCH load address is : 0xa0002000
[0001.539] I> Size of crypto header is 8192
[0001.544] I> BCH of SC7-FW read from storage
[0001.548] I> BCH address is : 0xa0002000
[0001.554] I> SC7-FW header integrity check is success
[0001.559] I> Binary magic in BCH component 0 is WB0B
[0001.565] I> component binary type is 13
[0001.569] I> Size of crypto header is 8192
[0001.575] I> SC7-FW binary is read from storage
[0001.581] I> SC7-FW binary integrity check is success
[0001.586] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x26220)
[0001.594] I> Active chain: 0
[0001.597] I> Slot: 0
[0001.600] I> Binary[22] block-0 (partition size: 0x30000)
[0001.606] I>  get_binary_info: Binary name: PSC_RF
[0001.611] I> Size of crypto header is 8192
[0001.615] I> Size of crypto header is 8192
[0001.620] I> BCH load address is : 0xa002a220
[0001.625] I> Size of crypto header is 8192
[0001.630] I> BCH of PSC_RF read from storage
[0001.635] I> BCH address is : 0xa002a220
[0001.640] I> PSC_RF header integrity check is success
[0001.646] I> Binary magic in BCH component 0 is PSCR
[0001.651] I> component binary type is 22
[0001.655] I> Size of crypto header is 8192
[0001.661] I> PSC_RF binary is read from storage
[0001.667] I> PSC_RF binary integrity check is success
[0001.672] I> Binary PSC_RF loaded successfully at 0xa002c220 (0x1b000)
[0001.694] I> Active chain: 0
[0001.698] I> Slot: 0
[0001.700] I> Binary[14] block-0 (partition size: 0x20000)
[0001.706] I>  get_binary_info: Binary name: MB2_RF
[0001.711] I> Size of crypto header is 8192
[0001.716] I> Size of crypto header is 8192
[0001.720] I> BCH load address is : 0xa008ea48
[0001.726] I> Size of crypto header is 8192
[0001.731] I> BCH of MB2_RF read from storage
[0001.735] I> BCH address is : 0xa008ea48
[0001.741] I> MB2_RF header integrity check is success
[0001.746] I> Binary magic in BCH component 0 is MB2R
[0001.752] I> component binary type is 14
[0001.756] I> Size of crypto header is 8192
[0001.762] I> MB2_RF binary is read from storage
[0001.767] I> MB2_RF binary integrity check is success
[0001.773] I> Binary MB2_RF loaded successfully at 0xa0090a48 (0x1bfa0)
[0001.781] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0001.789] I> SC7 context fuse-bypass data is empty
[0001.796] I> SC7 context save done
[0001.800] I> Task: Load MB2/Applet/FSKP (0x5000d691)
[0001.807] I> Loading MB2
[0001.810] I> Active chain: 0
[0001.813] I> Slot: 0
[0001.815] I> Binary[6] block-0 (partition size: 0x80000)
[0001.821] I>  get_binary_info: Binary name: MB2
[0001.826] I> Size of crypto header is 8192
[0001.831] I> BCH load address is : 0x8007e000
[0001.836] I> Size of crypto header is 8192
[0001.841] I> BCH of MB2 read from storage
[0001.845] I> BCH address is : 0x8007e000
[0001.851] I> MB2 header integrity check is success
[0001.856] I> Binary magic in BCH component 0 is MB2B
[0001.861] I> component binary type is 6
[0001.865] I> Size of crypto header is 8192
[0001.874] I> MB2 binary is read from storage
[0001.880] I> MB2 binary integrity check is success
[0001.885] I> Binary MB2 loaded successfully at 0x80000000 (0x68e00)
[0001.894] I> Task: Map CCPLEX SHARED carveout (0x5000d835)
[0001.901] I> Task: Prepare MB2 params (0x5000d8f1)
[0001.909] I> BR-BCT Boot Chain Fields
[0001.913] I> 	 u32_non_gpio_select_boot_chain  : 0
[0001.918] I> 	 u32_num_boot_chains             : 2
[0001.923] I> 	 bf_bl_gpio_select_boot_chain_1b : 0
[0001.928] I> Task: Program misc carveouts (0x50014bcd)
[0001.935] I> Program IPC carveouts
[0001.942] I> Task: Dram ecc test (0x500117a5)
[0001.948] I> Task: Misc NV security settings (0x5000d0f9)
[0001.954] I> NVDEC sticky bits programming done
[0001.959] I> Successfully powergated NVDEC
[0001.964] I> Task: Disable/Reload WDT (0x500206e1)
[0001.970] I> Programmed SLCG global override := 0x0
[0001.975] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-a9c0116a)
I> Emulation:
I> Entry timestamp: 0x001ea792
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0x430000000, size:0x800000]
I> Task: ARI update carveout TZDRAM (0x50001e80)
I> Task: Enable hot-plug capability (0x50025b5c)
I> Task: PSC mailbox init (0x50015c10)
I> Task: Crypto init (0x5000573c)
I> Task: Enable GP-SE clock (0x50001fe4)
I> Task: DICE Identity init (0x50018fcc)
I> DICE is not enabled.
I> Task: OEM SC7 context save init (0x500186cc)
I> Task: I2C register (0x50001e44)
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout (0x50001e2c)
I> Task: Boot device init (0x50001d74)
I> Task: Partition Manager Init (0x50001d70)
I> Found 57 partitions in QSPI_FLASH (instance 0)
I> Task: Load and authenticate registered FWs (0x5001bfc0)
I> Task: Load AUXP FWs (0x500256fc)
I> Successfully register SPE FW load task with MB2 loader
I> Skipping SCE FW load
I> Successfully register RCE FW load task with MB2 loader
I> Successfully register DCE FW load task with MB2 loader
I> Unpowergating APE
I> Unpowergate done
I> Successfully register APE FW load task with MB2 loader
I> Skipping FSI FW load
I> Successfully register XUSB FW load task with MB2 loader
I> Scratch RSV109: 0x00000001    active chain: 0
I> Partition name: A_spe-fw
I> Size of partition: 589824
I> Binary@ device:3/0 block-55040 (partition size: 0x90000), name: A_spe-fw
I> Partition name: A_rce-fw
I> Size of partition: 1048576
I> Binary@ device:3/0 block-56192 (partition size: 0x100000), name: A_rce-fw
I> spe: Authentication Finalize Done
I> Binary spe loaded successfully at 0x42f600000
I> Partition name: A_dce-fw
I> Size of partition: 5242880
I> Binary@ device:3/0 block-44800 (partition size: 0x500000), name: A_dce-fw
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0x42f300000
I> dce : oem authentication of header done
I> dce : meta-blob integrity check is success.
I> dce : will be decompressed at 0x43a000000
I> version 1 Bin 1 BCheckSum 0 content_size 0 Content ChkSum 1 reserved_00  0
I> Reserved10 0 BlockMaxSize 5 Reserved11 0
I> dce : decompressed to 9434016 bytes
I> dce: plain binary integrity check is success
I> Partition name: A_adsp-fw
I> Size of partition: 2097152
I> Binary@ device:3/0 block-58240 (partition size: 0x200000), name: A_adsp-fw
I> dce: Authentication Finalize Done
I> Binary dce loaded successfully at 0x43a000000
I> Partition name: A_xusb-fw
I> Size of partition: 262144
I> Binary@ device:3/0 block-9472 (partition size: 0x40000), name: A_xusb-fw
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0x42fc00000
I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0x42f700000
I> Task: Carveout setup (0x5001e6a0)
I> Program remaining OEM carveouts
I> Task: Enable FSITHERM (0x50015ae4)
I> Task: Enable FSI VMON (0x5001566c)
I> Task: Validate FSI Therm readings (0x500156c4)
I> Task: Restore XUSB sec (0x50001d44)
I> Task: Enable FSI SE clock (0x5001606c)
I> Task: Initialize SBSA UART CAR (0x50001f48)
I> Task: Initialize CPUBL Params (0x50016f88)
I> CPUBL-params @ 0x436000000
I> Task: Prepare eeprom data (0x50016d54)
I> Task: FSI padctl context save (0x5001885c)
E> Skipping FSI padctl config save: fsi not enabled
I> Task: Unpowergate APE (0x500167cc)
W> mb2_unpowergate_ape: skip! APE is in unpowergated state
I> Task: OEM firewalls (0x50022920)
I> OEM firewalls configured
I> Task: Powergate APE (0x50016940)
I> Powergating APE
I> Powergate done
I> Task: OEM firewall restore saved settings (0x50022ff0)
I> Task: Unhalt AUXPs (0x50025964)
I> Unhalting SPE..
I> Enabling combined UART
ÿ󲯥: early_init
vic initialized
tsc initialized
aon lic initialized
spe: tag is 243b265b351d6bb9cc7b2e3acc5d90f8
spe: SafeRTOS v8.4
spe: init
scheduler initialized
aon hsp initialized
tag initialized
tcu initialized
bpmp ipc initialized
spe: late init
cpu_nic clock initialized
apb clock initialized
pm initialized
bpmp hsp initialized
top1 hsp initialized
ccplex ipc initialized
spe: start scheduler
ÿ
 Ǿ Task: Trigger mailbox for PSC-BL1 exit (0x50015c90)
I> Sending opcode 0x4d420802 to psc
ÿ戎FO: Entering psc_monitor_init!
INFO: GSC22 BOM:0x448002000 SIZE:0x1000000 CLIENT_ACCESS1:00180000
INFO: PSCFW BUILD VERSION: 8a33b23-73b589c-8a15f76-rel-t234
INFO: mstatus:0xa00000808
INFO: Supervisor entry_point:c108c00
ÿǾ Received ACK from psc
I> Tasÿ戎FO: MONITOR: user task addr:0x448022000, blob offset:0x00020000
INFO: MONITOR: populated user images:13
INFO: mret to Supervisor!
INFO: psc supervisor init.
INFO: psc_irq_init...
INFO: enter idle task.
ÿ
 ᡰmp: socket 0
bpmp: base binary md5 is ccd7dae126b648f6d4de17417b40e939
bpmp: combined binary md5 is 9a7bb16aee9be45a56e6b18b82f5e183
bpmp: firmware tag is 9a7bb16aee9be45a56e6-ccd7dae126b
initialized vwdt
initialized mail_early
initialized fuse
initialized vfrel
initialized hwwdt
initialized adc
fmon_populate_monitors: found 199 monitors
initialized fmon
initialized mc
initialized reset
initialized uphy_early
initialized emc_early
471 clocks registered
initialized clk_mach
initialized clk_cal_early
initialized clk_mach_early_config
initialized io_dpd
initialized soctherm
initialized tj_init
initialized regime
initialized i2c
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
initialized vrmon
initialized regulator
ÿ੺ Start secure NOR provision (0x50018af8)
ÿᨮitialized avfs_clk_platform
initialized powergate
ÿǾ Task: Load FSI keyblob (ÿᨮitialized dvs
ÿ󿯸5ÿᨮitialized clk_mach_config
initialized pm
initialized suspend
initialized strap
initialized mce_dbell
ÿ󿮰160b4)
I> Task: Unhalt AUXPs (0x5002596c)
I> SCE unhalt skipped
I> Unhalting RCE
I> RCE unhalt successful
I> DCE unhalt successful
I> APE unhalt skipped
I> FSI unhalt skipped
I> Task: Load CPUBL (0x50017080)
I> Task: Load TOS (0x50017784)
I> Partition name: A_cpu-bootloader
I> Size of pÿ䙠    2.412918] Camera-FW on t234-rce-safe started
ÿ࠲tÿ䓃U earlyÿᨮitialized emc
initialized emc_mrq
ÿ㟣onsole enabled.
ÿ਴ion:ÿ
       ꀡ 36ÿᨮitialized clk_cal
initialized uphy_dt
initialized uphy_mrq
ÿ󿵰016
I> ÿᨮitialized uphy
ÿinary@ device:3/0 block-24832 (partition sizÿᨮitialized pg_late
initialized pg_mrq_init
swdtimer_init: 0 reg polling start w period 47 ms
initialized swdtimer
initialized hwwdt_late
initialized bwmgr
initialized thermal_host_trip
initialized thermal_mrq
initialized oc_mrq
initialized reset_mrq
initialized mail_mrq
initialized fmon_mrq
initialized clk_mrq
initialized avfs_mrq
initialized i2c_mrq
initialized tag_mrq
initialized bwmgr_mrq
initialized console_mrq
missing prod DT calibration data for 199 fmons
initialized clk_sync_fmon_post
ÿࣺ 0x380000), name: A_cpu-bootloader
ÿᨮitialized clk_cal_late
initialized noc_late
initialized cvc
initialized avfs_clk_mach_post
initialized avfs_clk_platform_post
initialized cvc_late
initialized rm
initialized console_late
handling unreferenced clks
enable can1_core
enable can1_host
enable can2_core
enable can2_host
enable pwm3
enable mss_encrypt
enable maud
enable pllg_ref
enable dsi_core
enable aza_2xbit
enable xusb_ss
enable xusb_fs
enable xusb_falcon
enable xusb_core_mux
enable dsi_lp
initialized clk_mach_post
initialized pg_post
initialized regulator_post
initialized profile
initialized fuse_late
initialized mrq
initialized patrol_scrubber
initialized cactmon
initialized extras_post
bpmp: init complete
ÿ䙠    2.542715] Camera-FW on t234-rce-safe ready SHA1=10150ec0 (crt 21.757 ms, total boot 152.613 ms)
ÿǾ Scratch RSV109: 0x00000001    active chain: 0
I> Partition name: A_secure-os
I> Size of partition: 4194304
I> Binary@ device:3/0 block-32000 (partition size: 0x400000), name: A_secure-os
ÿ烃E: FW Boot Done
ÿǾ MB2-params @ 0x40060000
I> cpubl: Authentication Finalize Done
I> Binary cpubl loaded successfully at 0x42ea00000
I> tos: Authentication Finalize Done
I> Binary tos loaded successfully at 0x43fdfe000
I> Relocating OP-TEE dtb from: 0x43feff770 to 0x42ef30000, size: 0x1976
I> [0] START: 0x80000000, SIZE: 0x3aef70000
I> [1] START: 0x436000000, SIZE: 0x2000000
I> Setting NS memory ranges to OP-TEE dtb finished.
I> Partition name: A_eks
I> Binary@ device:3/0 block-44288 (partition size: 0x40000), name: A_eks
I> eks: Authentication Finalize Done
I> Binary eks loaded successfully at 0x430000200
I> EKB detected (length: 0x410) @ VA:0x430000200
I> Task: Prepare TOS params (0x500176fc)
I> Setting EKB blob info to OPTEE dtb finished.
I> Setting OPTEE arg3: 0x42ef30000
I> Task: OEM SC7 context save (0x50018958)
I> OEM sc7 context saved
I> Task: Disable MSS perf stats (0x500259f8)
I> Task: Program display sticky bits (0x50025974)
I> Task: Storage device deinit (0x50001eec)
I> Task: SMMU external bypass disable (0x50015bf4)
I> Task: SMMU init (0x50015b10)
I> Task: Program CBB PCIE AMAP regions (0x50018ce0)
I> Task: Program GICv3 registers (0x50025a98)
I> Task: Audit firewall settings (0x50022c08)
I> Task: Bootchain failure check (0x5000242c)
I> Current Boot-Chain Slot: 0
I> BR-BCT Boot-Chain is 0, and status is 1. Set UPDATE_BRBCT bit to 0
I> MB2 finished
ÿ㍏TICE:  BL31: v2.6(release):6363e7382
NOTICE:  BL31: Built : 15:09:30, Jan 24 2023
I/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 3.19 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Tue Jan 24 23:20:42 UTC 2023 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: WARNING: Test OEM keys are being used!
I/TC: This is only for TZ-SE testing and should NOT be used for a shipping product!
I/TC: Primary CPU switching to normal world boot
ÿ
 ɥtson UEFI firmware (version 2.1-32413640 built on 2023-01-24T23:12:27+00:00)
Jetson UEFI firmware (version 2.1-32413640 built on 2023-01-24T23:12:27+00:00)
ESC   to enter Setup.
F11   to enter Boot Manager Menu.
Enter to continue boot.
**  WARNING: Test Key is used.  **
      L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map...
ÿ㇯TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
ÿ٠   0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[    0.000000] Linux version 5.10.104-tegra (buildbrain@mobile-u64-6348-d7000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Tue Jan 24 15:09:44 PST 2023
[    0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[    0.000000] OF: fdt:  - 80000000 ,  c0000000
[    0.000000] Machine model: NVIDIA Orin NX Developer Kit
[    0.000000] efi: EFI v2.70 by EDK II
[    0.000000] efi: RTPROP=0x425d19a98 SMBIOS=0xffff0000 SMBIOS 3.0=0x407b70000 MEMATTR=0x4076cd018 ESRT=0x407709398 RNG=0x42ad46c18 MEMRESERVE=0x4076d0f18
[    0.000000] efi: seeding entropy pool
[    0.000000] esrt: Reserving ESRT space from 0x0000000407709398 to 0x00000004077093d0.
[    0.000000] Reserved memory: created CMA memory pool at 0x000000041ac00000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x0000000437ffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000fffdffff]
[    0.000000]   node   0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x0000000403ffffff]
[    0.000000]   node   0: [mem 0x0000000404000000-0x00000004061bffff]
[    0.000000]   node   0: [mem 0x00000004061c0000-0x0000000406fcffff]
[    0.000000]   node   0: [mem 0x0000000406fd0000-0x0000000406ffffff]
[    0.000000]   node   0: [mem 0x0000000407000000-0x000000040703ffff]
[    0.000000]   node   0: [mem 0x0000000407040000-0x00000004070dffff]
[    0.000000]   node   0: [mem 0x00000004070e0000-0x0000000407567fff]
[    0.000000]   node   0: [mem 0x0000000407568000-0x00000004076c5fff]
[    0.000000]   node   0: [mem 0x00000004076c6000-0x00000004076dffff]
[    0.000000]   node   0: [mem 0x00000004076e0000-0x00000004076fffff]
[    0.000000]   node   0: [mem 0x0000000407700000-0x0000000407b0ffff]
[    0.000000]   node   0: [mem 0x0000000407b10000-0x0000000407b1ffff]
[    0.000000]   node   0: [mem 0x0000000407b20000-0x0000000407b6ffff]
[    0.000000]   node   0: [mem 0x0000000407b70000-0x0000000407b7ffff]
[    0.000000]   node   0: [mem 0x0000000407b80000-0x0000000407e5ffff]
[    0.000000]   node   0: [mem 0x0000000407e60000-0x0000000407eaffff]
[    0.000000]   node   0: [mem 0x0000000407eb0000-0x000000040806ffff]
[    0.000000]   node   0: [mem 0x0000000408070000-0x000000040824ffff]
[    0.000000]   node   0: [mem 0x0000000408250000-0x00000004082cffff]
[    0.000000]   node   0: [mem 0x00000004082d0000-0x00000004084affff]
[    0.000000]   node   0: [mem 0x00000004084b0000-0x00000004084bffff]
[    0.000000]   node   0: [mem 0x00000004084c0000-0x00000004085affff]
[    0.000000]   node   0: [mem 0x00000004085b0000-0x000000040861ffff]
[    0.000000]   node   0: [mem 0x0000000408620000-0x000000040862ffff]
[    0.000000]   node   0: [mem 0x0000000408630000-0x000000040870ffff]
[    0.000000]   node   0: [mem 0x0000000408710000-0x00000004087affff]
[    0.000000]   node   0: [mem 0x00000004087b0000-0x00000004088affff]
[    0.000000]   node   0: [mem 0x00000004088b0000-0x000000040894ffff]
[    0.000000]   node   0: [mem 0x0000000408950000-0x0000000408a1ffff]
[    0.000000]   node   0: [mem 0x0000000408a20000-0x0000000408abffff]
[    0.000000]   node   0: [mem 0x0000000408ac0000-0x000000040938ffff]
[    0.000000]   node   0: [mem 0x0000000409390000-0x000000040956ffff]
[    0.000000]   node   0: [mem 0x0000000409570000-0x000000042acfffff]
[    0.000000]   node   0: [mem 0x000000042ad00000-0x000000042ad4ffff]
[    0.000000]   node   0: [mem 0x000000042ad50000-0x000000042e7fffff]
[    0.000000]   node   0: [mem 0x000000042ea00000-0x000000042eefffff]
[    0.000000]   node   0: [mem 0x0000000436000000-0x0000000437ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000437ffffff]
[    0.000000] On node 0, zone Normal: 256 pages in unavailable ranges
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 32 pages/cpu s90200 r8192 d32680 u131072
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] CPU features: detected: Spectre-v4
[    0.000000] alternatives: patching kernel code
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 3809024
[    0.000000] Kernel command line: root=PARTUUID=6d3ddd25-5cd3-45a7-93d4-f2efc34c9ea7 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0
[    0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000effe0000-0x00000000fffe0000] (256MB)
[    0.000000] Memory: 14559100K/15479808K available (18432K kernel code, 3168K rwdata, 7164K rodata, 3968K init, 1110K bss, 658564K reserved, 262144K cma-reserved)
[    0.000000] random: get_random_u64 called from __kmem_cache_create+0x38/0x420 with crng_init=0
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Rude variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[    0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[    0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[    0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.000633] Console: colour dummy device 80x25
[    0.000671] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.000679] pid_max: default: 32768 minimum: 301
[    0.000741] LSM: Security Framework initializing
[    0.000760] Yama: becoming mindful.
[    0.000777] SELinux:  Initializing.
[    0.000843] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.000868] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.001924] rcu: Hierarchical SRCU implementation.
[    0.002012] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[    0.002408] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t23x/p3768/kernel-dts/tegra234-p3767-0000-p3509-a02.dts
[    0.002412] DTB Build time: Jan 24 2023 15:26:10
[    0.003603] Tegra Revision: A01 SKU: 0xd3 CPU Process: 0 SoC Process: 0
[    0.003761] Remapping and enabling EFI services.
[    0.004947] smp: Bringing up secondary CPUs ...
[    0.033632] Detected PIPT I-cache on CPU1
[    0.033666] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[    0.033688] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[    0.062309] Detected PIPT I-cache on CPU2
[    0.062318] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[    0.062333] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[    0.090923] Detected PIPT I-cache on CPU3
[    0.090932] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[    0.090946] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[    0.121595] Detected PIPT I-cache on CPU4
[    0.121616] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[    0.121644] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[    0.150294] Detected PIPT I-cache on CPU5
[    0.150303] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[    0.150319] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[    0.178934] Detected PIPT I-cache on CPU6
[    0.178943] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[    0.178958] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[    0.207573] Detected PIPT I-cache on CPU7
[    0.207583] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[    0.207598] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[    0.207654] smp: Brought up 1 node, 8 CPUs
[    0.207668] SMP: Total of 8 processors activated.
[    0.207672] CPU features: detected: Privileged Access Never
[    0.207673] CPU features: detected: LSE atomic instructions
[    0.207675] CPU features: detected: User Access Override
[    0.207676] CPU features: detected: 32-bit EL0 Support
[    0.207678] CPU features: detected: Common not Private translations
[    0.207680] CPU features: detected: RAS Extension Support
[    0.207682] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.207683] CPU features: detected: CRC32 instructions
[    0.207685] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.240653] CPU: All CPU(s) started at EL2
[    0.242539] devtmpfs: initialized
[    0.257272] Registered cp15_barrier emulation handler
[    0.257281] Registered setend emulation handler
[    0.257287] KASLR enabled
[    0.257404] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.257416] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.258786] pinctrl core: initialized pinctrl subsystem
[    0.259309] SMBIOS 3.0.0 present.
[    0.259317] DMI: Unknown NVIDIA Orin NX Developer Kit/NVIDIA Orin NX Developer Kit, BIOS 2.1-32413640 01/24/2023
[    0.259583] NET: Registered protocol family 16
[    0.260210] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.260317] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.260416] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.260441] audit: initializing netlink subsys (disabled)
[    0.260517] audit: type=2000 audit(0.260:1): state=initialized audit_enabled=0 res=1
[    0.260682] thermal_sys: Registered thermal governor 'step_wise'
[    0.260684] thermal_sys: Registered thermal governor 'power_allocator'
[    0.260686] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[    0.261473] cpuidle: using governor menu
[    0.261575] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.261655] ASID allocator initialised with 32768 entries
[    0.261744] Serial: AMBA PL011 UART driver
[    0.263471] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[    0.263491] Tegra reboot handler registered.
[    0.281327] mc: mapped MMIO address: 0xffff800010b10000 -> 0x2c10000
[    0.281335] mc: mapped MMIO address: 0xffff800010b30000 -> 0x2c20000
[    0.281341] mc: mapped MMIO address: 0xffff800010b50000 -> 0x2c30000
[    0.281346] mc: mapped MMIO address: 0xffff800010b70000 -> 0x2c40000
[    0.281353] mc: mapped MMIO address: 0xffff800010b90000 -> 0x2c50000
[    0.281359] mc: mapped MMIO address: 0xffff800010bb0000 -> 0x2b80000
[    0.281364] mc: mapped MMIO address: 0xffff800010bd0000 -> 0x2b90000
[    0.281369] mc: mapped MMIO address: 0xffff800010bf0000 -> 0x2ba0000
[    0.281376] mc: mapped MMIO address: 0xffff800010c10000 -> 0x2bb0000
[    0.281381] mc: mapped MMIO address: 0xffff800010c30000 -> 0x1700000
[    0.281386] mc: mapped MMIO address: 0xffff800010c50000 -> 0x1710000
[    0.281391] mc: mapped MMIO address: 0xffff800010c70000 -> 0x1720000
[    0.281397] mc: mapped MMIO address: 0xffff800010c90000 -> 0x1730000
[    0.281402] mc: mapped MMIO address: 0xffff800010cb0000 -> 0x1740000
[    0.281410] mc: mapped MMIO address: 0xffff800010cd0000 -> 0x1750000
[    0.281415] mc: mapped MMIO address: 0xffff800010cf0000 -> 0x1760000
[    0.281419] mc: mapped MMIO address: 0xffff800010d10000 -> 0x1770000
[    0.281427] nv-tegra-mc 2c10000.mc: No mssnvlink node
[    0.281445] mc-err: mcerr ops are set to t23x
[    0.282051] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 62, base_baud = 0) is a SBSA
[    1.480290] printk: console [ttyAMA0] enabled
[    1.488370] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    1.495082] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    1.501782] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    1.508479] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    1.516919] ACPI: Interpreter disabled.
[    1.521114] ddr-vddq: supplied by vdd-5v
[    1.525233] ddr-vdd2: supplied by vdd-5v
[    1.529262] vdd-AO-1v2: supplied by vdd-5v
[    1.533464] vdd-3v3: supplied by vdd-5v
[    1.537409] vdd-rtc: supplied by vdd-AO-1v2
[    1.541696] vdd-0v95-uphy: supplied by vdd-AO-1v2
[    1.546505] vdd-0v95-hdmi: supplied by vdd-AO-1v2
[    1.551442] vdd-1v8: supplied by vdd-3v3-sys
[    1.555808] vdd-3v3-AO: supplied by vdd-5v-sys
[    1.560343] vdd-av10-hub: supplied by vdd-5v-sys
[    1.565070] vdd-vbus-a: supplied by vdd-5v-sys
[    1.569610] vdd-vbus-b: supplied by vdd-5v-sys
[    1.574208] vdd-3v3-dp: supplied by vdd-3v3-sys
[    1.578971] iommu: Default domain type: Translated
[    1.583886] eventlib_kernel: keventlib is initialized, test id: 0
[    1.590150] SCSI subsystem initialized
[    1.593961] usbcore: registered new interface driver usbfs
[    1.599462] usbcore: registered new interface driver hub
[    1.604783] usbcore: registered new device driver usb
[    1.610005] mc: Linux media interface: v0.10
[    1.614282] videodev: Linux video capture interface: v2.00
[    1.619898] pps_core: LinuxPPS API ver. 1 registered
[    1.624859] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.633996] PTP clock support registered
[    1.638109] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[    1.645288] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[    1.652916] Registered efivars operations
[    1.657046] FPGA manager framework
[    1.660487] Advanced Linux Sound Architecture Driver Initialized.
[    1.666851] Bluetooth: Core ver 2.22
[    1.670433] NET: Registered protocol family 31
[    1.674874] Bluetooth: HCI device and connection manager initialized
[    1.681231] Bluetooth: HCI socket layer initialized
[    1.686108] Bluetooth: L2CAP socket layer initialized
[    1.691163] Bluetooth: SCO socket layer initialized
[    1.696505] camchar: rtcpu character device driver loaded
[    1.702101] clocksource: Switched to clocksource arch_sys_counter
[    1.862442] VFS: Disk quotas dquot_6.6.0
[    1.866402] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.873425] pnp: PnP ACPI: disabled
[    1.878764] la/ptsa driver initialized.
[    1.882655] NET: Registered protocol family 2
[    1.887213] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    1.896984] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    1.905621] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    1.913815] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    1.921717] TCP: Hash tables configured (established 131072 bind 65536)
[    1.928411] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    1.935226] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    1.942543] NET: Registered protocol family 1
[    1.947188] RPC: Registered named UNIX socket transport module.
[    1.953116] RPC: Registered udp transport module.
[    1.957817] RPC: Registered tcp transport module.
[    1.962522] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.968971] PCI: CLS 0 bytes, default 64
[    1.973022] Trying to unpack rootfs image as initramfs...
[    2.089892] Freeing initrd memory: 8208K
[    2.095933] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    2.103830] kvm [1]: IPA Size Limit: 48 bits
[    2.108240] kvm [1]: VHE mode initialized successfully
[    2.114011] Initialise system trusted keyrings
[    2.118603] workingset: timestamp_bits=46 max_order=22 bucket_order=0
[    2.127164] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    2.133263] NFS: Registering the id_resolver key type
[    2.138327] Key type id_resolver registered
[    2.142508] Key type id_legacy registered
[    2.146546] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    2.153254] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    2.160660] ntfs: driver 2.1.32 [Flags: R/W].
[    2.176733] NET: Registered protocol family 38
[    2.181178] Key type asymmetric registered
[    2.185271] Asymmetric key parser 'x509' registered
[    2.190161] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[    2.197611] io scheduler mq-deadline registered
[    2.202141] io scheduler kyber registered
[    2.209761] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    2.215369] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[    2.220958] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    2.228821] tegra_dc_assign_hw_data: no matching compatible node
[    2.234833] tegradccommon module_init failed
[    2.239101] tegradc module_init failed
[    2.243087] EINJ: ACPI disabled.
[    2.247684] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[    2.254565] tegra-pmc: ### PMC reset source: SYS_RESET_N
[    2.259874] tegra-pmc: ### PMC reset level: L0
[    2.264311] tegra-pmc: ### PMC reset status reg: 0x0
[    2.270498] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    2.283183] random: fast init done
[    2.283340] printk: console [ttyTCU0] enabled
[    3.891684] arm-smmu 12000000.iommu: probing hardware configuration...
[    3.898391] arm-smmu 12000000.iommu: SMMUv2 with:
[    3.903221] arm-smmu 12000000.iommu: 	stage 1 translation
[    3.908775] arm-smmu 12000000.iommu: 	stage 2 translation
[    3.914337] arm-smmu 12000000.iommu: 	nested translation
[    3.919806] arm-smmu 12000000.iommu: 	stream matching with 128 register groups
[    3.927227] arm-smmu 12000000.iommu: 	128 context banks (0 stage-2 only)
[    3.936144] arm-smmu 12000000.iommu: 	Supported page sizes: 0x00001000
[    3.942850] arm-smmu 12000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    3.949551] arm-smmu 12000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    3.957041] arm-smmu 10000000.iommu: probing hardware configuration...
[    3.963739] arm-smmu 10000000.iommu: SMMUv2 with:
[    3.968574] arm-smmu 10000000.iommu: 	stage 1 translation
[    3.974106] arm-smmu 10000000.iommu: 	stage 2 translation
[    3.979641] arm-smmu 10000000.iommu: 	nested translation
[    3.985100] arm-smmu 10000000.iommu: 	stream matching with 128 register groups
[    3.992509] arm-smmu 10000000.iommu: 	128 context banks (0 stage-2 only)
[    4.001405] arm-smmu 10000000.iommu: 	Supported page sizes: 0x00001000
[    4.008102] arm-smmu 10000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    4.014792] arm-smmu 10000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    4.021908] arm-smmu 8000000.iommu: probing hardware configuration...
[    4.028518] arm-smmu 8000000.iommu: SMMUv2 with:
[    4.033252] arm-smmu 8000000.iommu: 	stage 1 translation
[    4.038704] arm-smmu 8000000.iommu: 	stage 2 translation
[    4.044165] arm-smmu 8000000.iommu: 	nested translation
[    4.049520] arm-smmu 8000000.iommu: 	stream matching with 128 register groups
[    4.056839] arm-smmu 8000000.iommu: 	128 context banks (0 stage-2 only)
[    4.065570] arm-smmu 8000000.iommu: 	Supported page sizes: 0x00001000
[    4.072192] arm-smmu 8000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    4.078799] arm-smmu 8000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    4.086053] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[    4.095770] tegra_profiler: version: 1.150, samples/io: 50/29
[    4.101746] tegra_profiler: auth: init
[    4.105856] nvsciipc: loaded module
[    4.110958] tun: Universal TUN/TAP device driver, 1.6
[    4.116547] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    4.123968] hns3: Copyright (c) 2017 Huawei Corporation.
[    4.129440] e1000e: Intel(R) PRO/1000 Network Driver
[    4.134535] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    4.140625] igb: Intel(R) Gigabit Ethernet Network Driver
[    4.146165] igb: Copyright (c) 2007-2014 Intel Corporation.
[    4.152035] PPP generic driver version 2.4.2
[    4.156482] PPP BSD Compression module registered
[    4.161315] PPP Deflate Compression module registered
[    4.166513] PPP MPPE Compression module registered
[    4.171454] usbcore: registered new interface driver r8152
[    4.177091] usbcore: registered new interface driver asix
[    4.182634] usbcore: registered new interface driver ax88179_178a
[    4.188896] usbcore: registered new interface driver cdc_ether
[    4.194893] usbcore: registered new interface driver net1080
[    4.200711] usbcore: registered new interface driver cdc_subset
[    4.206788] usbcore: registered new interface driver zaurus
[    4.212528] usbcore: registered new interface driver cdc_ncm
[    4.218335] usbcore: registered new interface driver aqc111
[    4.224165] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    4.230511] ohci-pci: OHCI PCI platform driver
[    4.235079] ohci-platform: OHCI generic platform driver
[    4.240731] tegra-xusb 3610000.xhci: Adding to iommu group 0
[    4.247032] usbcore: registered new interface driver uas
[    4.252510] usbcore: registered new interface driver usb-storage
[    4.258811] tegra-xudc 3550000.xudc: Adding to iommu group 1
[    4.264869] mousedev: PS/2 mouse device common for all mice
[    4.270613] usbcore: registered new interface driver xpad
[    4.278013] tegra_rtc c2a0000.rtc: registered as rtc1
[    4.283482] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:24 UTC (24)
[    4.291700] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    4.298112] i2c /dev entries driver
[    4.301805] tegra-i2c 3160000.i2c: Adding to iommu group 2
[    4.307595] tegra-i2c c240000.i2c: Adding to iommu group 2
[    4.313327] tegra-i2c 3180000.i2c: Adding to iommu group 2
[    4.319008] tegra-i2c 3190000.i2c: Adding to iommu group 2
[    4.324678] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[    4.330353] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[    4.336023] tegra-i2c c250000.i2c: Adding to iommu group 2
[    4.341704] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[    4.350581] device-mapper: uevent: version 1.0.3
[    4.355415] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[    4.365061] sdhci: Secure Digital Host Controller Interface driver
[    4.371403] sdhci: Copyright(c) Pierre Ossman
[    4.375865] Synopsys Designware Multimedia Card Interface Driver
[    4.382099] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.388415] sdhci-tegra 3400000.sdhci: Adding to iommu group 3
[    4.388835] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[    4.402579] tegra-bpmp bpmp: firmware: 9a7bb16aee9be45a56e6-ccd7dae126b
[    4.411468] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[    4.417347] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x82
[    4.428792] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[    4.434716] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
ÿᅡiled to create /rm/vdd_cpu
Failed to create /rm/vdd_cpu
debugfs initialized
ÿ٠   6.606940] hid: raw HID events driver (C) Jiri Kosina
[    6.612755] usbcore: registered new interface driver usbhid
[    6.618498] usbhid: USB HID core driver
[    6.623000] tegra-dce d800000.dce: Adding to iommu group 4
[    6.630007] dce: dce_ipc_channel_init:314  Invalid Channel State [0x0] for ch_type [2]
[    6.638924] tegra234-aon c000000.aon: Adding to iommu group 5
[    6.645345] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x5]
[    6.647249]  c000000.aon:hsp: probed
[    6.654347] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [0]. Ignored...
[    6.666738] tegra234-aon c000000.aon: init done
[    6.667151] tegra23x-psc e860000.psc: Adding to iommu group 6
[    6.671419] dce: dce_admin_send_cmd_ver:424  version : [0x2] err : [0x0]
[    6.677689] tegra23x-psc e860000.psc: ext_cfg base:(____ptrval____)
[    6.684662] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x1]
[    6.690659] tegra23x-psc e860000.psc: init done
[    6.699590] dce: dce_admin_setup_clients_ipc:553  Channel Reset Complete for Type [1] ...
[    6.699591] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [1]. Ignored...
[    6.699601] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [1]. Ignored...
[    6.704466] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 7
[    6.712649] dce: dce_admin_setup_clients_ipc:529  Get queue info failed for [2]
[    6.722032] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[    6.730670] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x2]
[    6.740378] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[    6.744320] dce: dce_admin_setup_clients_ipc:553  Channel Reset Complete for Type [3] ...
[    6.744321] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [3]. Ignored...
[    6.744331] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [3]. Ignored...
[    6.752680] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[    6.762006] dce: dce_start_boot_flow:173  DCE_BOOT_DONE
[    6.771025] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[    6.824664] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[    6.836498] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[    6.849061] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[    6.861876] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[    6.873861] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (110)
[    6.880656] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[    6.892847] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=10150ec03f8849d1537396903b70d4a48a255aba
[    6.906516] t19x_cache tegra-cache: probed
[    6.910998] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[    6.924165] optee: probing for conduit method.
[    6.928757] optee: revision 3.19 (18d0f61b)
[    6.929536] optee: dynamic shared memory is enabled
[    6.938953] optee: initialized driver
[    6.953946] nvpmodel: initialized successfully
[    6.958609] tegra_hv: get_hvd: not initialized yet
[    6.963543] user_ivc_mempool: hypervisor not present
[    6.969433] usbcore: registered new interface driver snd-usb-audio
[    6.976655] u32 classifier
[    6.979452]     input device check on
[    6.983218]     Actions configured
[    6.986884] Initializing XFRM netlink socket
[    6.991743] NET: Registered protocol family 10
[    6.997578] Segment Routing with IPv6
[    7.001398] NET: Registered protocol family 17
[    7.005990] NET: Registered protocol family 15
[    7.011018] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    7.024770] Bluetooth: RFCOMM socket layer initialized
[    7.030066] Bluetooth: RFCOMM ver 1.11
[    7.033927] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    7.040007] Bluetooth: HIDP socket layer initialized
[    7.045659] 9pnet: Installing 9P2000 support
[    7.050116] Key type dns_resolver registered
[    7.055555] registered taskstats version 1
[    7.059790] Loading compiled-in X.509 certificates
[    7.068524] Loaded X.509 cert 'Build time autogenerated kernel key: d2e6b29ce3ba3f3d31103e414d71889f8474be7b'
[    7.079058] tegra194-pcie 14100000.pcie: Adding to iommu group 8
[    7.091777] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[    7.098899] tegra194-pcie 14160000.pcie: Adding to iommu group 9
[    7.111105] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[    7.117939] tegra194-pcie 140a0000.pcie: Adding to iommu group 10
[    7.130192] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[    7.162133] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 11
[    7.172497] host1x 13e40000.host1x: Adding to iommu group 12
[    8.190488] t23x_init_gating_regs: Timed out waiting for syncpt ram init!
[    8.207813] host1x 13e40000.host1x: initialized
[    8.212831] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 13
[    8.220920] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[    8.232927] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 14
[    8.240959] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[    8.252959] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 15
[    8.260989] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[    8.272987] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 16
[    8.280999] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[    8.292975] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 17
[    8.301023] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[    8.312994] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 18
[    8.321012] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[    8.332998] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 19
[    8.341008] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[    8.352998] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 20
[    8.360988] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[    8.372977] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 21
[    8.380997] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[    8.392991] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 22
[    8.401015] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[    8.413003] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 23
[    8.421008] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[    8.433002] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 24
[    8.441075] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[    8.453054] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 25
[    8.461064] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[    8.473055] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 26
[    8.481073] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[    8.493064] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 27
[    8.501075] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[    8.513073] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 28
[    8.521080] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[    8.533080] falcon 15340000.vic: Adding to iommu group 29
[    8.543911] falcon 15340000.vic: initialized
[    8.548619] falcon 15380000.nvjpg: Adding to iommu group 30
[    8.557646] falcon 15380000.nvjpg: initialized
[    8.562365] falcon 15540000.nvjpg1: Adding to iommu group 31
[    8.571439] falcon 15540000.nvjpg1: initialized
[    8.576243] falcon 154c0000.nvenc: Adding to iommu group 32
[    8.586966] falcon 154c0000.nvenc: initialized
[    8.591681] falcon 15a50000.ofa: Adding to iommu group 33
[    8.600730] falcon 15a50000.ofa: initialized
[    8.605282] nvdec 15480000.nvdec: Adding to iommu group 34
[    8.616746] nvdec 15480000.nvdec: initialized
[    8.621369] tsec 15500000.tsec: Adding to iommu group 35
[    8.631696] tsec 15500000.tsec: initialized
[    8.638596] gic 2a41000.agic-controller: GIC IRQ controller registered
[    8.655261] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[    8.671252] gpio-397 (camera-control-output-low): hogged as output/low
[    8.678003] gpio-486 (camera-control-output-low): hogged as output/low
[    8.685758] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[    8.692689] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[    8.699671] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    8.706205] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[    8.712626] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    8.720860] tegra194-isp5 14800000.isp: Adding to iommu group 36
[    8.730021] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[    8.739284] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[    8.745740] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[    8.754954] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[    8.764313] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 37
[    8.772342] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 38
[    8.780343] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
[    8.790289] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[    8.797096] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
[    8.807034] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[    8.813849] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[    8.823797] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[    8.830619] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 39
[    8.839260] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18, iommu=smmu.0x0000000008000000)
[    8.850627] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 40
[    8.859314] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19, iommu=smmu.0x0000000008000000)
[    8.870681] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 41
[    8.879332] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20, iommu=smmu.0x0000000008000000)
[    8.890692] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 42
[    8.899343] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21, iommu=smmu.0x0000000008000000)
[    8.910709] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to iommu group 43
[    8.919346] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized (streamid=22, iommu=smmu.0x0000000008000000)
[    8.930703] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to iommu group 44
[    8.939376] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized (streamid=23, iommu=smmu.0x0000000008000000)
[    8.950448] random: crng init done
[    8.950756] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to iommu group 45
[    8.962794] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized (streamid=24, iommu=smmu.0x0000000008000000)
[    8.974165] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to iommu group 46
[    8.982796] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized (streamid=25, iommu=smmu.0x0000000008000000)
[    8.994157] pva 16000000.pva0: Adding to iommu group 47
[    9.005053] pva 16000000.pva0: initialized
[    9.018162] nvdla 15880000.nvdla0: Adding to iommu group 48
[    9.029471] nvdla 15880000.nvdla0: initialized
[    9.035781] nvdla 158c0000.nvdla1: Adding to iommu group 49
[    9.046641] nvdla 158c0000.nvdla1: initialized
[    9.052888] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 2
[    9.059909] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[    9.067452] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[    9.074072] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[    9.080811] serial-tegra 3100000.serial: Adding to iommu group 2
[    9.087479] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 16, base_baud = 0) is a TEGRA_UART
[    9.097279] serial-tegra 3130000.serial: Adding to iommu group 2
[    9.103804] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 60, base_baud = 0) is a TEGRA_UART
[    9.113433] serial-tegra 3140000.serial: Adding to iommu group 2
[    9.119926] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 61, base_baud = 0) is a TEGRA_UART
[    9.146024] tegra-xusb 3610000.xhci: Firmware timestamp: 2021-12-01 05:27:10 UTC, Version: 80.03 release
[    9.155777] tegra-xusb 3610000.xhci: xHCI Host Controller
[    9.161343] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[    9.169982] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[    9.179589] tegra-xusb 3610000.xhci: irq 227, io mem 0x03610000
[    9.186015] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    9.194519] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    9.201945] usb usb1: Product: xHCI Host Controller
[    9.206959] usb usb1: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[    9.213220] usb usb1: SerialNumber: 3610000.xhci
[    9.218729] hub 1-0:1.0: USB hub found
[    9.222601] hub 1-0:1.0: 4 ports detected
[    9.226994] tegra-xusb 3610000.xhci: xHCI Host Controller
[    9.232550] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[    9.240334] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[    9.247836] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    9.256347] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    9.263776] usb usb2: Product: xHCI Host Controller
[    9.268783] usb usb2: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[    9.275044] usb usb2: SerialNumber: 3610000.xhci
[    9.280631] hub 2-0:1.0: USB hub found
[    9.284510] hub 2-0:1.0: 4 ports detected
[    9.308786] i2c i2c-2: Added multiplexed i2c bus 9
[    9.314012] i2c i2c-2: Added multiplexed i2c bus 10
[    9.319030] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[    9.326049] tegra23x-oc-event soctherm-oc-event: Finished tegra23x overcurrent event probing
[    9.347724] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1987000 KHz, changing to: 1984000 KHz
[    9.361610] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 1946000 KHz, changing to: 1958400 KHz
[    9.374484] tegra194-cpufreq e000000.ccplex: probed with ICC
[    9.381717] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[    9.382385] sdhci-tegra 3400000.sdhci: Got CD GPIO
[    9.389040] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[    9.400265] tegra194-pcie 14100000.pcie:       IO 0x0030100000..0x00301fffff -> 0x0030100000
[    9.402208] irq: IRQ291: trimming hierarchy from :interrupt-controller@f400000-1
[    9.408945] tegra194-pcie 14100000.pcie:      MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[    9.408950] tegra194-pcie 14100000.pcie:      MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[    9.416631] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 291
[    9.490249] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[    9.658423] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411, bcdDevice= 1.01
[    9.666842] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    9.674189] usb 1-2: Product: USB2.1 Hub
[    9.678212] usb 1-2: Manufacturer: Generic
[    9.684378] hub 1-2:1.0: USB hub found
[    9.689316] hub 1-2:1.0: 4 ports detected
[    9.779051] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using tegra-xusb
[    9.818813] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411, bcdDevice= 1.01
[    9.827229] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    9.834567] usb 2-1: Product: USB3.2 Hub
[    9.838592] usb 2-1: Manufacturer: Generic
[    9.847680] hub 2-1:1.0: USB hub found
[    9.853202] hub 2-1:1.0: 4 ports detected
[    9.986100] usb 1-2.3: new full-speed USB device number 3 using tegra-xusb
[   10.108480] usb 1-2.3: New USB device found, idVendor=0eef, idProduct=0005, bcdDevice= 2.00
[   10.117073] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[   10.124585] usb 1-2.3: Product: WS170120
[   10.128609] usb 1-2.3: Manufacturer: WaveShare
[   10.133171] usb 1-2.3: SerialNumber:±A8250P035
[   10.147873] input: WaveShare WS170120 as /devices/platform/3610000.xhci/usb1/1-2/1-2.3/1-2.3:1.0/0003:0EEF:0005.0001/input/input0
[   10.160700] hid-multitouch 0003:0EEF:0005.0001: input,hidraw0: USB HID v1.10 Device [WaveShare WS170120] on usb-3610000.xhci-2.3/input0
[   10.543477] tegra194-pcie 14100000.pcie: Phy link never came up
[   10.549638] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[   10.556450] pci_bus 0001:00: root bus resource [bus 00-ff]
[   10.562091] pci_bus 0001:00: root bus resource [io  0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[   10.571924] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[   10.582744] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[   10.590658] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[   10.596996] pci 0001:00:00.0: PME# supported from D0 D3hot
[   10.609868] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[   10.615264] pci 0001:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[   10.624194] pcieport 0001:00:00.0: Adding to iommu group 8
[   10.630041] pcieport 0001:00:00.0: PME: Signaling with IRQ 54
[   10.636203] pcieport 0001:00:00.0: AER: enabled with IRQ 54
[   10.642160] pci_bus 0001:01: busn_res: [bus 01-ff] is released
[   10.648242] pci 0001:00:00.0: Removing from iommu group 8
[   10.653797] pci_bus 0001:00: busn_res: [bus 00-ff] is released
[   10.661618] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[   10.668969] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[   10.676137] tegra194-pcie 14160000.pcie:       IO 0x0036100000..0x00361fffff -> 0x0036100000
[   10.684818] tegra194-pcie 14160000.pcie:      MEM 0x2428000000..0x242fffffff -> 0x0040000000
[   10.693492] tegra194-pcie 14160000.pcie:      MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[   10.810323] tegra194-pcie 14160000.pcie: Link up
[   10.818496] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[   10.825311] pci_bus 0004:00: root bus resource [bus 00-ff]
[   10.830939] pci_bus 0004:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[   10.841033] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[   10.851864] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[   10.859776] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[   10.866083] pci 0004:00:00.0: PME# supported from D0 D3hot
[   10.875504] pci 0004:01:00.0: [10ec:5765] type 00 class 0x010802
[   10.881873] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[   10.889097] pci 0004:01:00.0: reg 0x24: [mem 0x00000000-0x00001fff]
[   10.900351] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280fffff]
[   10.907777] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428000000-0x2428003fff 64bit]
[   10.915740] pci 0004:01:00.0: BAR 5: assigned [mem 0x2428004000-0x2428005fff]
[   10.923100] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[   10.928469] pci 0004:00:00.0:   bridge window [mem 0x2428000000-0x24280fffff]
[   10.935829] pci 0004:00:00.0: Max Payload Size set to  128/ 256 (was  256), Max Read Rq  512
[   10.944569] pci 0004:01:00.0: Max Payload Size set to  128/ 128 (was  128), Max Read Rq  512
[   10.953484] pcieport 0004:00:00.0: Adding to iommu group 9
[   10.959316] pcieport 0004:00:00.0: PME: Signaling with IRQ 56
[   10.965491] pcieport 0004:00:00.0: AER: enabled with IRQ 56
[   10.971515] nvme 0004:01:00.0: Adding to iommu group 9
[   10.977212] nvme nvme0: pci function 0004:01:00.0
[   10.982266] nvme 0004:01:00.0: enabling device (0000 -> 0002)
[   10.982821] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[   10.984910] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   10.984918] pcieport 0004:00:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[   10.984920] pcieport 0004:00:00.0:   device [10de:229c] error status/mask=00000001/0000e000
[   10.984922] pcieport 0004:00:00.0:    [ 0] RxErr
[   11.002614] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   11.020502] pcieport 0004:00:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[   11.026896] vdd-3v3-sd: supplied by vdd-3v3
[   11.034177] pcieport 0004:00:00.0:   device [10de:229c] error status/mask=00000001/0000e000
[   11.044336] irq: IRQ293: trimming hierarchy from :pmc@c360000
[   11.048301] pcieport 0004:00:00.0:    [ 0] RxErr
[   11.048308] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   11.076523] pcieport 0004:00:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[   11.086363] pcieport 0004:00:00.0:   device [10de:229c] error status/mask=00000001/0000e000
[   11.094955] pcieport 0004:00:00.0:    [ 0] RxErr
[   11.101230] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   11.108700] pcieport 0004:00:00.0: AER: can't find device of ID0000
[   11.115164] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   11.122619] pcieport 0004:00:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[   11.122906] tegra194-isp5 14800000.isp: initialized
[   11.132464] pcieport 0004:00:00.0:   device [10de:229c] error status/mask=00000001/0000e000
[   11.146081] pcieport 0004:00:00.0:    [ 0] RxErr
[   11.149293] nvme nvme0: allocated 64 MiB host memory buffer.
[   11.152356] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   11.165611] pcieport 0004:00:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[   11.175464] pcieport 0004:00:00.0:   device [10de:229c] error status/mask=00000001/0000e000
[   11.184063] pcieport 0004:00:00.0:    [ 0] RxErr
[   11.184345] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[   11.190325] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   11.196817] (NULL device *): fops function table already registered
[   11.204118] pcieport 0004:00:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[   11.220423] pcieport 0004:00:00.0:   device [10de:229c] error status/mask=00000001/0000e000
[   11.229022] pcieport 0004:00:00.0:    [ 0] RxErr
[   11.235292] pcieport 0004:00:00.0: AER: Multiple Corrected error received: 0004:00:00.0
[   11.243580] pcieport 0004:00:00.0: AER: can't find device of ID0000
[   11.250033] pcieport 0004:00:00.0: AER: Multiple Corrected error received: 0004:00:00.0
[   11.258309] pcieport 0004:00:00.0: AER: can't find device of ID0000
[   11.258521] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[   11.264776] pcieport 0004:00:00.0: AER: Multiple Corrected error received: 0004:00:00.0
[   11.271953] sdhci-tegra 3400000.sdhci: Got CD GPIO
[   11.279419] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[   11.279437] pcieport 0004:00:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[   11.279442] pcieport 0004:00:00.0:   device [10de:229c] error status/mask=00000001/0000e000
[   11.279443] pcieport 0004:00:00.0:    [ 0] RxErr
[   11.279449] pcieport 0004:00:00.0: AER: Multiple Corrected error received: 0004:00:00.0
[   11.279496] pcieport 0004:00:00.0: AER: can't find device of ID0000
[   11.279497] pcieport 0004:00:00.0: AER: Multiple Corrected error received: 0004:00:00.0
[   11.279531] nvme nvme0: 8/0/0 default/read/poll queues
[   11.279541] pcieport 0004:00:00.0: AER: can't find device of ID0000
[   11.279542] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   11.279582] pcieport 0004:00:00.0: AER: can't find device of ID0000
[   11.279583] pcieport 0004:00:00.0: AER: Multiple Corrected error received: 0004:00:00.0
[   11.279623] pcieport 0004:00:00.0: AER: can't find device of ID0000
[   11.279624] pcieport 0004:00:00.0: AER: Multiple Corrected error received: 0004:00:00.0
[   11.279665] pcieport 0004:00:00.0: AER: can't find device of ID0000
[   11.279666] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   11.279706] pcieport 0004:00:00.0: AER: can't find device of ID0000
[   11.279707] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   11.279747] pcieport 0004:00:00.0: AER: can't find device of ID0000
[   11.279748] pcieport 0004:00:00.0: AER: Multiple Corrected error received: 0004:00:00.0
[   11.279788] pcieport 0004:00:00.0: AER: can't find device of ID0000
[   11.279789] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   11.279829] pcieport 0004:00:00.0: AER: can't find device of ID0000
[   11.279830] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   11.279870] pcieport 0004:00:00.0: AER: can't find device of ID0000
[   11.279871] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   11.279923] pcieport 0004:00:00.0: AER: can't find device of ID0000
[   11.279924] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   11.279930] pcieport 0004:00:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[   11.279931] pcieport 0004:00:00.0:   device [10de:229c] error status/mask=00000001/0000e000
[   11.279932] pcieport 0004:00:00.0:    [ 0] RxErr
[   11.279938] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   11.279981] pcieport 0004:00:00.0: AER: can't find device of ID0000
[   11.279982] pcieport 0004:00:00.0: AER: Multiple Corrected error received: 0004:00:00.0
[   11.280022] pcieport 0004:00:00.0: AER: can't find device of ID0000
[   11.280023] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   11.280063] pcieport 0004:00:00.0: AER: can't find device of ID0000
[   11.281878] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   11.281885] pcieport 0004:00:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[   11.281886] pcieport 0004:00:00.0:   device [10de:229c] error status/mask=00000001/0000e000
[   11.281886] pcieport 0004:00:00.0:    [ 0] RxErr
[   11.282013] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   11.282019] pcieport 0004:00:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[   11.282020] pcieport 0004:00:00.0:   device [10de:229c] error status/mask=00000001/0000e000
[   11.282021] pcieport 0004:00:00.0:    [ 0] RxErr
[   11.282777]  nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[   11.284744] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   11.324155] irq: IRQ302: trimming hierarchy from :interrupt-controller@f400000-1
[   11.330165] pcieport 0004:00:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[   11.350538] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 291
[   11.357577] pcieport 0004:00:00.0:   device [10de:229c] error status/mask=00000001/0000e000
[   11.357578] pcieport 0004:00:00.0:    [ 0] RxErr
[   11.357585] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   11.471115] tegra194-pcie 140a0000.pcie: host bridge /pcie@140a0000 ranges:
[   11.477433] pcieport 0004:00:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[   11.484869] tegra194-pcie 140a0000.pcie:       IO 0x002a100000..0x002a1fffff -> 0x002a100000
[   11.494699] pcieport 0004:00:00.0:   device [10de:229c] error status/mask=00000001/0000e000
[   11.503273] tegra194-pcie 140a0000.pcie:      MEM 0x3528000000..0x352fffffff -> 0x0040000000
[   11.503275] tegra194-pcie 140a0000.pcie:      MEM 0x3240000000..0x3527ffffff -> 0x3240000000
[   11.614109] tegra194-pcie 140a0000.pcie: Link up
[   11.616233] pcieport 0004:00:00.0:    [ 0] RxErr
[   11.676526] tegra194-pcie 140a0000.pcie: PCI host bridge to bus 0008:00
[   11.683501] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   11.693330] pci_bus 0008:00: root bus resource [bus 00-ff]
[   11.702048] pcieport 0004:00:00.0: AER: can't find device of ID0000
[   11.710589] pci_bus 0008:00: root bus resource [io  0x200000-0x2fffff] (bus address [0x2a100000-0x2a1fffff])
[   11.710591] pci_bus 0008:00: root bus resource [mem 0x3528000000-0x352fffffff] (bus address [0x40000000-0x47ffffff])
[   11.710592] pci_bus 0008:00: root bus resource [mem 0x3240000000-0x3527ffffff pref]
[   11.710636] pci 0008:00:00.0: [10de:229c] type 01 class 0x060400
[   11.719271] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   11.728095] pci 0008:00:00.0: PME# supported from D0 D3hot
[   11.732697] pcieport 0004:00:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[   11.743063] pci 0008:01:00.0: [10ec:8168] type 00 class 0x020000
[   11.745769] pcieport 0004:00:00.0:   device [10de:229c] error status/mask=00000001/0000e000
[   11.753334] pci 0008:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[   11.758833] pcieport 0004:00:00.0:    [ 0] RxErr
[   11.765451] pci 0008:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[   11.775443] pcieport 0004:00:00.0: AER: Multiple Corrected error received: 0004:00:00.0
[   11.786377] pci 0008:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[   11.794235] pcieport 0004:00:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[   11.801360] pci 0008:01:00.0: supports D1 D2
[   11.807770] pcieport 0004:00:00.0:   device [10de:229c] error status/mask=00000001/0000e000
[   11.813390] pci 0008:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[   11.817469] pci 0008:00:00.0: BAR 14: assigned [mem 0x3528000000-0x35280fffff]
[   11.823227] pcieport 0004:00:00.0:    [ 0] RxErr
[   11.829377] pci 0008:00:00.0: BAR 13: assigned [io  0x200000-0x200fff]
[   11.829380] pci 0008:01:00.0: BAR 4: assigned [mem 0x3528000000-0x3528003fff 64bit]
[   11.829474] pci 0008:01:00.0: BAR 2: assigned [mem 0x3528004000-0x3528004fff 64bit]
[   11.837993] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   11.843787] pci 0008:01:00.0: BAR 0: assigned [io  0x200000-0x2000ff]
[   11.850016] pcieport 0004:00:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[   11.857000] pci 0008:00:00.0: PCI bridge to [bus 01-ff]
[   11.865216] pcieport 0004:00:00.0:   device [10de:229c] error status/mask=00000001/0000e000
[   11.872187] pci 0008:00:00.0:   bridge window [io  0x200000-0x200fff]
[   11.872191] pci 0008:00:00.0:   bridge window [mem 0x3528000000-0x35280fffff]
[   11.882033] pcieport 0004:00:00.0:    [ 0] RxErr
[   11.886435] pci 0008:00:00.0: Max Payload Size set to  128/ 256 (was  256), Max Read Rq  512
[   11.895011] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   11.901873] pci 0008:01:00.0: Max Payload Size set to  128/ 128 (was  128), Max Read Rq  512
[   11.909286] pcieport 0004:00:00.0: AER: can't find device of ID0000
[   11.915751] pcieport 0008:00:00.0: Adding to iommu group 10
[   11.922225] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   11.930306] pcieport 0008:00:00.0: PME: Signaling with IRQ 58
[   11.937997] pcieport 0004:00:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[   11.945800] pcieport 0008:00:00.0: AER: enabled with IRQ 58
[   11.952068] pcieport 0004:00:00.0:   device [10de:229c] error status/mask=00000001/0000e000
[   11.963280] irq: IRQ304: trimming hierarchy from :pmc@c360000
[   11.967280] pcieport 0004:00:00.0:    [ 0] RxErr
[   11.975923] irq: IRQ305: trimming hierarchy from :interrupt-controller@f400000-1
[   11.982501] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   11.989894] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[   11.996106] pcieport 0004:00:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[   12.005419] tegra-se-nvhost 15810000.se: Adding to iommu group 50
[   12.012241] pcieport 0004:00:00.0:   device [10de:229c] error status/mask=00000001/0000e000
[   12.027417] tegra-se-nvhost 15810000.se: initialized
[   12.033102] pcieport 0004:00:00.0:    [ 0] RxErr
[   12.077146] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[   12.082795] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   12.090492] tegra-se-nvhost 15820000.se: Adding to iommu group 51
[   12.097856] pcieport 0004:00:00.0: AER: can't find device of ID0000
[   12.114571] tegra-se-nvhost 15820000.se: initialized
[   12.120809] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   12.130891] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[   12.134490] pcieport 0004:00:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[   12.140830] tegra-se-nvhost 15840000.se: Adding to iommu group 52
[   12.147010] pcieport 0004:00:00.0:   device [10de:229c] error status/mask=00000001/0000e000
[   12.160716] tegra-se-nvhost 15840000.se: initialized
[   12.167128] pcieport 0004:00:00.0:    [ 0] RxErr
[   12.176204] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[   12.179669] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   12.186577] tegra_actmon d230000.actmon: in actmon_register()...
[   12.195773] pcieport 0004:00:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[   12.210615] tegra_actmon d230000.actmon: bwmgr_disable = 1
[   12.215705] pcieport 0004:00:00.0:   device [10de:229c] error status/mask=00000001/0000e000
[   12.235969] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[   12.241857] pcieport 0004:00:00.0:    [ 0] RxErr
[   12.251910] hvc_sysfs: hypervisor is not present
[   12.257350] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   12.292626] pcieport 0004:00:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[   12.302473] pcieport 0004:00:00.0:   device [10de:229c] error status/mask=00000001/0000e000
[   12.311062] pcieport 0004:00:00.0:    [ 0] RxErr
[   12.317340] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   12.324788] pcieport 0004:00:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[   12.334647] pcieport 0004:00:00.0:   device [10de:229c] error status/mask=00000001/0000e000
[   12.343251] pcieport 0004:00:00.0:    [ 0] RxErr
[   12.349522] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   12.356985] pcieport 0004:00:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[   12.366848] pcieport 0004:00:00.0:   device [10de:229c] error status/mask=00000001/0000e000
[   12.375444] pcieport 0004:00:00.0:    [ 0] RxErr
[   12.381724] pcieport 0004:00:00.0: AER: Multiple Corrected error received: 0004:00:00.0
[   12.390018] pcieport 0004:00:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[   12.399869] pcieport 0004:00:00.0:   device [10de:229c] error status/mask=00000001/0000e000
[   12.408464] pcieport 0004:00:00.0:    [ 0] RxErr
[   12.414736] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   12.422190] pcieport 0004:00:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[   12.432046] pcieport 0004:00:00.0:   device [10de:229c] error status/mask=00000001/0000e000
[   12.440654] pcieport 0004:00:00.0:    [ 0] RxErr
[   12.446928] pcieport 0004:00:00.0: AER: Multiple Corrected error received: 0004:00:00.0
[   12.455204] pcieport 0004:00:00.0: AER: can't find device of ID0000
[   12.461659] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   12.469134] pcieport 0004:00:00.0: AER: can't find device of ID0000
[   12.475591] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   12.483047] pcieport 0004:00:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[   12.492910] pcieport 0004:00:00.0:   device [10de:229c] error status/mask=00000001/0000e000
[   12.501511] pcieport 0004:00:00.0:    [ 0] RxErr
[   12.507773] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   12.515219] pcieport 0004:00:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[   12.525074] pcieport 0004:00:00.0:   device [10de:229c] error status/mask=00000001/0000e000
[   12.533673] pcieport 0004:00:00.0:    [ 0] RxErr
[   12.539960] pcieport 0004:00:00.0: AER: Multiple Corrected error received: 0004:00:00.0
[   12.548241] pcieport 0004:00:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[   12.558112] pcieport 0004:00:00.0:   device [10de:229c] error status/mask=00000001/0000e000
[   12.566721] pcieport 0004:00:00.0:    [ 0] RxErr
[   12.572986] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   12.580465] pcieport 0004:00:00.0: AER: can't find device of ID0000
[   12.586917] sched: RT throttling activated
[   12.624380] ALSA device list:
[   12.627434]   No soundcards found.
[   12.631568] Freeing unused kernel memory: 3968K
[   12.636268] Run /init as init process
[   12.636306] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   12.641186] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[   12.647454] pcieport 0004:00:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[   12.665340] pcieport 0004:00:00.0:   device [10de:229c] error status/mask=00000001/0000e000
[   12.665342] pcieport 0004:00:00.0:    [ 0] RxErr
[   12.665348] pcieport 0004:00:00.0: AER: Multiple Corrected error received: 0004:00:00.0
[   12.687068] Root device found: PARTUUID=6d3ddd25-5cd3-45a7-93d4-f2efc34c9ea7
[   12.688496] pcieport 0004:00:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[   12.705563] pcieport 0004:00:00.0:   device [10de:229c] error status/mask=00000001/0000e000
[   12.714162] pcieport 0004:00:00.0:    [ 0] RxErr
[   12.720431] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   12.727900] pcieport 0004:00:00.0: AER: can't find device of ID0000
[   12.734351] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   12.741827] pcieport 0004:00:00.0: AER: can't find device of ID0000
[   12.748269] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   12.755712] pcieport 0004:00:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[   12.765574] pcieport 0004:00:00.0:   device [10de:229c] error status/mask=00000001/0000e000
[   12.774172] pcieport 0004:00:00.0:    [ 0] RxErr
[   12.780455] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   12.787899] pcieport 0004:00:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[   12.797759] pcieport 0004:00:00.0:   device [10de:229c] error status/mask=00000001/0000e000
[   12.806356] pcieport 0004:00:00.0:    [ 0] RxErr
[   12.812627] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   12.820074] pcieport 0004:00:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[   12.829928] pcieport 0004:00:00.0:   device [10de:229c] error status/mask=00000001/0000e000
[   12.838532] pcieport 0004:00:00.0:    [ 0] RxErr
[   12.844806] pcieport 0004:00:00.0: AER: Multiple Corrected error received: 0004:00:00.0
[   12.853086] pcieport 0004:00:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[   12.862930] pcieport 0004:00:00.0:   device [10de:229c] error status/mask=00000001/0000e000
[   12.871521] pcieport 0004:00:00.0:    [ 0] RxErr
[   12.877795] pcieport 0004:00:00.0: AER: Multiple Corrected error received: 0004:00:00.0
[   12.886069] pcieport 0004:00:00.0: AER: can't find device of ID0000
[   12.892529] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[   12.899969] pcieport 0004:00:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[   12.909819] pcieport 0004:00:00.0:   device [10de:229c] error status/mask=00000001/0000e000
For DP, please change the DCB image in device tree to below one.
Also, pinmux setting needs to be SFIO.
I decompile the tegra234-p3767-000-p3509-a00.dtb file to dts and replace the dcb image.
reflash the Orin NX, however, the DP port could not work either. I also check the used pinmux file (tegra234-mb1-bct-pinmux-p3767-hdmi-a03.dtsi), it comments SFIO configuration, do I need to modify any other files for it?
And do you have any suggestions about the PCIe?
Thanks for your help.
@Zera I am trying to do the same: Orin NX with Xavier NX carrier board. I followed the migration guide Nvidia provides to identify which pins are different between the two.
Do you mind sharing how you changed the pinmux for the Orin to allow it to flash to the Xavier NX? I can’t find any info online about the specifics of this step.
Searching on forum this issue (which we had as well) seems like a common issue experienced by many.
Of course it’s ok to do manual kernel mod once and command line flash file system to Orin NX but then can’t do OTA JP updates as kernel gets overwritten each time and mod is lost?
So it seems now without help on this issue from Nvidia that Orin NX is backwards step from Xavier NX for DP functionality?
Question: Can Nividia update in a release of JP to allow DP to work on Orin NX without requiring manual kernel modification?
Yes, we already updated. If you use orin nano devkit config then it by default will use DP instead of HDMI.
