Orin NX 8GB nvme link up to pcie x1 or x2 not x4 on R35.4.1
We have both Orin NX(8G) and Orin NX(16G) with the same custom carrier board, and we use a a nvme ssd flashed with p3509-a02+p3767-0000, Orin NX 8GB nvme can not link up to pciex4 , but Orin NX 16GB can. please help me.
Orin NX 8GB:
root@w:~# lspci -vvv -s 0004:01:00.0 | grep Sta
	Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
		DevSta:	CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr- TransPend-
		LnkSta:	Speed 8GT/s (ok), Width x1 (downgraded)
		LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete+, EqualizationPhase1+
		Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
		UESta:	DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
		CESta:	RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr-
		LaneErrStat: 0
Orin NX 16GB:
		LnkSta:	Speed 8GT/s (ok), Width x4 (ok)
		LaneErrStat: 0
here is Orin NX 8GB dmesg info
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[    0.000000] Linux version 5.10.120-tegra (wangyf@ubuntu) (aarch64-linux-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Mon Aug 14 10:10:18 CST 2023
[    0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[    0.000000] OF: fdt:  - 80000000 ,  c0000000
[    0.000000] Machine model: NVIDIA Orin NX Developer Kit
[    0.000000] efi: EFI v2.70 by EDK II
[    0.000000] efi: RTPROP=0x26a936518 MEMATTR=0x248448018 ESRT=0x24848ba18 RNG=0x24883f198 MEMRESERVE=0x248451f18
[    0.000000] efi: seeding entropy pool
[    0.000000] esrt: Reserving ESRT space from 0x000000024848ba18 to 0x000000024848ba50.
[    0.000000] Reserved memory: created CMA memory pool at 0x000000025a800000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x0000000273ffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000024739afff]
[    0.000000]   node   0: [mem 0x000000024739b000-0x000000024765ffff]
[    0.000000]   node   0: [mem 0x0000000247660000-0x00000002482fffff]
[    0.000000]   node   0: [mem 0x0000000248300000-0x000000024839ffff]
[    0.000000]   node   0: [mem 0x00000002483a0000-0x00000002483effff]
[    0.000000]   node   0: [mem 0x00000002483f0000-0x000000024841ffff]
[    0.000000]   node   0: [mem 0x0000000248420000-0x000000024845ffff]
[    0.000000]   node   0: [mem 0x0000000248460000-0x000000024847ffff]
[    0.000000]   node   0: [mem 0x0000000248480000-0x000000024851ffff]
[    0.000000]   node   0: [mem 0x0000000248520000-0x000000024853ffff]
[    0.000000]   node   0: [mem 0x0000000248540000-0x000000024858ffff]
[    0.000000]   node   0: [mem 0x0000000248590000-0x000000024876ffff]
[    0.000000]   node   0: [mem 0x0000000248770000-0x000000024882ffff]
[    0.000000]   node   0: [mem 0x0000000248830000-0x00000002488dffff]
[    0.000000]   node   0: [mem 0x00000002488e0000-0x000000024892ffff]
[    0.000000]   node   0: [mem 0x0000000248930000-0x0000000248b5ffff]
[    0.000000]   node   0: [mem 0x0000000248b60000-0x0000000248beffff]
[    0.000000]   node   0: [mem 0x0000000248bf0000-0x0000000248c3ffff]
[    0.000000]   node   0: [mem 0x0000000248c40000-0x0000000248c6ffff]
[    0.000000]   node   0: [mem 0x0000000248c70000-0x0000000248d0ffff]
[    0.000000]   node   0: [mem 0x0000000248d10000-0x0000000248d5ffff]
[    0.000000]   node   0: [mem 0x0000000248d60000-0x0000000248dfffff]
[    0.000000]   node   0: [mem 0x0000000248e00000-0x00000002492dffff]
[    0.000000]   node   0: [mem 0x00000002492e0000-0x00000002494bffff]
[    0.000000]   node   0: [mem 0x00000002494c0000-0x000000026ab2ffff]
[    0.000000]   node   0: [mem 0x000000026ab30000-0x000000026ab7ffff]
[    0.000000]   node   0: [mem 0x000000026ab80000-0x000000026ea0ffff]
[    0.000000]   node   0: [mem 0x000000026ea10000-0x000000026ea1ffff]
[    0.000000]   node   0: [mem 0x0000000272000000-0x0000000273ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000273ffffff]
[    0.000000] On node 0 totalpages: 2034208
[    0.000000]   DMA zone: 8192 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 524288 pages, LIFO batch:63
[    0.000000]   Normal zone: 23808 pages used for memmap
[    0.000000]   Normal zone: 1509920 pages, LIFO batch:63
[    0.000000] On node 0, zone Normal: 480 pages in unavailable ranges
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 32 pages/cpu s90328 r8192 d32552 u131072
[    0.000000] pcpu-alloc: s90328 r8192 d32552 u131072 alloc=32*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] CPU features: detected: Spectre-v4
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] alternatives: patching kernel code
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 2002208
[    0.000000] Kernel command line: root=/dev/nvme0n1p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb
[    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000effff000-0x00000000fffff000] (256MB)
[    0.000000] Memory: 7375528K/8136832K available (18496K kernel code, 3166K rwdata, 7164K rodata, 3968K init, 1416K bss, 499160K reserved, 262144K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Rude variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[    0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[    0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[    0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.000669] Console: colour dummy device 80x25
[    0.000713] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.000721] pid_max: default: 32768 minimum: 301
[    0.000816] LSM: Security Framework initializing
[    0.000843] Yama: becoming mindful.
[    0.000863] SELinux:  Initializing.
[    0.000946] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.000960] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.001753] /cpus/cpu-map/cluster1: empty cluster
[    0.002070] rcu: Hierarchical SRCU implementation.
[    0.002157] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[    0.002516] DTS File Name: arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t23x/p3768/kernel-dts/tegra234-p3767-0001-p3509-a02.dts
[    0.002520] DTB Build time: Aug 14 2023 09:45:39
[    0.003766] Tegra Revision: A01 SKU: 0xd4 CPU Process: 0 SoC Process: 0
[    0.003979] Remapping and enabling EFI services.
[    0.004429] smp: Bringing up secondary CPUs ...
[    0.033137] Detected PIPT I-cache on CPU1
[    0.033178] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[    0.033205] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[    0.061859] Detected PIPT I-cache on CPU2
[    0.061870] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[    0.061885] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[    0.090505] Detected PIPT I-cache on CPU3
[    0.090514] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[    0.090527] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[    0.121186] Detected PIPT I-cache on CPU4
[    0.121209] GICv3: CPU4: found redistributor 10200 region 0:0x000000000f500000
[    0.121237] CPU4: Booted secondary processor 0x0000010200 [0x410fd421]
[    0.149912] Detected PIPT I-cache on CPU5
[    0.149921] GICv3: CPU5: found redistributor 10300 region 0:0x000000000f520000
[    0.149936] CPU5: Booted secondary processor 0x0000010300 [0x410fd421]
[    0.149996] smp: Brought up 1 node, 6 CPUs
[    0.150007] SMP: Total of 6 processors activated.
[    0.150011] CPU features: detected: Privileged Access Never
[    0.150012] CPU features: detected: LSE atomic instructions
[    0.150014] CPU features: detected: User Access Override
[    0.150015] CPU features: detected: 32-bit EL0 Support
[    0.150018] CPU features: detected: Common not Private translations
[    0.150020] CPU features: detected: RAS Extension Support
[    0.150021] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.150023] CPU features: detected: CRC32 instructions
[    0.150024] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.167197] spectre-bhb mitigation disabled by command line option
[    0.167198] spectre-bhb mitigation disabled by command line option
[    0.167200] spectre-bhb mitigation disabled by command line option
[    0.183083] CPU: All CPU(s) started at EL2
[    0.184770] devtmpfs: initialized
[    0.201668] Registered cp15_barrier emulation handler
[    0.201676] Registered setend emulation handler
[    0.201681] KASLR enabled
[    0.201825] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.201837] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.203366] pinctrl core: initialized pinctrl subsystem
[    0.203787] DMI not present or invalid.
[    0.204110] NET: Registered protocol family 16
[    0.204927] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.204987] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.205040] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.205063] audit: initializing netlink subsys (disabled)
[    0.205150] audit: type=2000 audit(0.204:1): state=initialized audit_enabled=0 res=1
[    0.205339] thermal_sys: Registered thermal governor 'step_wise'
[    0.205342] thermal_sys: Registered thermal governor 'power_allocator'
[    0.205345] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[    0.206212] cpuidle: using governor menu
[    0.206308] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.206368] ASID allocator initialised with 32768 entries
[    0.206465] Serial: AMBA PL011 UART driver
[    0.208174] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[    0.208194] Tegra reboot handler registered.
[    0.226142] mc: mapped MMIO address: 0xffff8000107b0000 -> 0x2c10000
[    0.226153] mc: mapped MMIO address: 0xffff8000107d0000 -> 0x2c20000
[    0.226160] mc: mapped MMIO address: 0xffff8000107f0000 -> 0x2c30000
[    0.226167] mc: mapped MMIO address: 0xffff800010810000 -> 0x2c40000
[    0.226172] mc: mapped MMIO address: 0xffff800010830000 -> 0x2c50000
[    0.226177] mc: mapped MMIO address: 0xffff800010850000 -> 0x2b80000
[    0.226182] mc: mapped MMIO address: 0xffff800010870000 -> 0x2b90000
[    0.226187] mc: mapped MMIO address: 0xffff800010890000 -> 0x2ba0000
[    0.226192] mc: mapped MMIO address: 0xffff8000108b0000 -> 0x2bb0000
[    0.226199] mc: mapped MMIO address: 0xffff8000108d0000 -> 0x1700000
[    0.226203] mc: mapped MMIO address: 0xffff8000108f0000 -> 0x1710000
[    0.226208] mc: mapped MMIO address: 0xffff800010910000 -> 0x1720000
[    0.226214] mc: mapped MMIO address: 0xffff800010930000 -> 0x1730000
[    0.226219] mc: mapped MMIO address: 0xffff800010950000 -> 0x1740000
[    0.226224] mc: mapped MMIO address: 0xffff800010970000 -> 0x1750000
[    0.226229] mc: mapped MMIO address: 0xffff800010990000 -> 0x1760000
[    0.226234] mc: mapped MMIO address: 0xffff8000109b0000 -> 0x1770000
[    0.226240] nv-tegra-mc 2c10000.mc: No mssnvlink node
[    0.226275] mc-err: mcerr ops are set to t23x
[    0.226895] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 63, base_baud = 0) is a SBSA
[    1.323822] printk: console [ttyAMA0] enabled
[    1.332112] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    1.338824] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    1.345524] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    1.352221] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    1.360697] ACPI: Interpreter disabled.
[    1.364936] ddr-vddq: supplied by vdd-5v
[    1.369038] ddr-vdd2: supplied by vdd-5v
[    1.373063] vdd-AO-1v2: supplied by vdd-5v
[    1.377264] vdd-3v3: supplied by vdd-5v
[    1.381276] vdd-rtc: supplied by vdd-AO-1v2
[    1.385573] vdd-0v95-uphy: supplied by vdd-AO-1v2
[    1.390367] vdd-0v95-hdmi: supplied by vdd-AO-1v2
[    1.395308] vdd-1v8: supplied by vdd-3v3-sys
[    1.399738] vdd-3v3-AO: supplied by vdd-5v-sys
[    1.404298] vdd-av10-hub: supplied by vdd-5v-sys
[    1.409003] vdd-vbus-a: supplied by vdd-5v-sys
[    1.413558] vdd-vbus-b: supplied by vdd-5v-sys
[    1.418147] vdd-3v3-dp: supplied by vdd-3v3-sys
[    1.422986] iommu: Default domain type: Translated
[    1.427899] eventlib_kernel: keventlib is initialized, test id: 0
[    1.434172] SCSI subsystem initialized
[    1.437981] usbcore: registered new interface driver usbfs
[    1.443482] usbcore: registered new interface driver hub
[    1.448803] usbcore: registered new device driver usb
[    1.454033] mc: Linux media interface: v0.10
[    1.458317] videodev: Linux video capture interface: v2.00
[    1.463946] pps_core: LinuxPPS API ver. 1 registered
[    1.468911] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.478046] PTP clock support registered
[    1.482185] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[    1.489343] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[    1.496978] Registered efivars operations
[    1.501110] FPGA manager framework
[    1.504537] Advanced Linux Sound Architecture Driver Initialized.
[    1.510891] Bluetooth: Core ver 2.22
[    1.514470] NET: Registered protocol family 31
[    1.518915] Bluetooth: HCI device and connection manager initialized
[    1.525271] Bluetooth: HCI socket layer initialized
[    1.530148] Bluetooth: L2CAP socket layer initialized
[    1.535202] Bluetooth: SCO socket layer initialized
[    1.540545] camchar: rtcpu character device driver loaded
[    1.546146] clocksource: Switched to clocksource arch_sys_counter
[    1.717822] VFS: Disk quotas dquot_6.6.0
[    1.721785] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.728990] pnp: PnP ACPI: disabled
[    1.734577] la/ptsa driver initialized.
[    1.738480] NET: Registered protocol family 2
[    1.742965] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    1.751745] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    1.760283] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    1.768257] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    1.776154] TCP: Hash tables configured (established 65536 bind 65536)
[    1.782747] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    1.789551] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    1.796857] NET: Registered protocol family 1
[    1.801415] RPC: Registered named UNIX socket transport module.
[    1.807342] RPC: Registered udp transport module.
[    1.812043] RPC: Registered tcp transport module.
[    1.816741] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.823186] PCI: CLS 0 bytes, default 64
[    1.827219] Trying to unpack rootfs image as initramfs...
[    1.962223] Freeing initrd memory: 9552K
[    1.968135] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    1.976080] kvm [1]: IPA Size Limit: 48 bits
[    1.980367] kvm [1]: GICv3: no GICV resource entry
[    1.985158] kvm [1]: disabling GICv2 emulation
[    1.989619] kvm [1]: GIC system register CPU interface enabled
[    1.995504] kvm [1]: vgic interrupt IRQ9
[    1.999521] kvm [1]: VHE mode initialized successfully
[    2.005338] Initialise system trusted keyrings
[    2.009863] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[    2.018737] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    2.024888] NFS: Registering the id_resolver key type
[    2.029950] Key type id_resolver registered
[    2.034130] Key type id_legacy registered
[    2.038172] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    2.044877] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    2.052284] ntfs: driver 2.1.32 [Flags: R/W].
[    2.068446] NET: Registered protocol family 38
[    2.072893] Key type asymmetric registered
[    2.076987] Asymmetric key parser 'x509' registered
[    2.081885] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 239)
[    2.089338] io scheduler mq-deadline registered
[    2.093870] io scheduler kyber registered
[    2.101546] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    2.107146] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[    2.112731] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    2.118314] tegra-pwm 32e0000.pwm: PWM clk can sleep in ops
[    2.126349] tegra_dc_assign_hw_data: no matching compatible node
[    2.132356] tegradccommon module_init failed
[    2.136622] tegradc module_init failed
[    2.140607] EINJ: ACPI disabled.
[    2.145340] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[    2.152219] tegra-pmc: ### PMC reset source: SYS_RESET_N
[    2.157528] tegra-pmc: ### PMC reset level: L0
[    2.161967] tegra-pmc: ### PMC reset status reg: 0x0
[    2.168184] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    3.703209] printk: console [ttyTCU0] enabled
[    3.708196] arm-smmu 12000000.iommu: probing hardware configuration...
[    3.714892] arm-smmu 12000000.iommu: SMMUv2 with:
[    3.719712] arm-smmu 12000000.iommu: 	stage 1 translation
[    3.725248] arm-smmu 12000000.iommu: 	stage 2 translation
[    3.730782] arm-smmu 12000000.iommu: 	nested translation
[    3.736229] arm-smmu 12000000.iommu: 	stream matching with 128 register groups
[    3.743634] arm-smmu 12000000.iommu: 	128 context banks (0 stage-2 only)
[    3.752715] arm-smmu 12000000.iommu: 	Supported page sizes: 0x00001000
[    3.759407] arm-smmu 12000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    3.766091] arm-smmu 12000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    3.773540] arm-smmu 10000000.iommu: probing hardware configuration...
[    3.780231] arm-smmu 10000000.iommu: SMMUv2 with:
[    3.785044] arm-smmu 10000000.iommu: 	stage 1 translation
[    3.790577] arm-smmu 10000000.iommu: 	stage 2 translation
[    3.796103] arm-smmu 10000000.iommu: 	nested translation
[    3.801552] arm-smmu 10000000.iommu: 	stream matching with 128 register groups
[    3.808954] arm-smmu 10000000.iommu: 	128 context banks (0 stage-2 only)
[    3.817986] arm-smmu 10000000.iommu: 	Supported page sizes: 0x00001000
[    3.824676] arm-smmu 10000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    3.831359] arm-smmu 10000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    3.838468] arm-smmu 8000000.iommu: probing hardware configuration...
[    3.845072] arm-smmu 8000000.iommu: SMMUv2 with:
[    3.849799] arm-smmu 8000000.iommu: 	stage 1 translation
[    3.855238] arm-smmu 8000000.iommu: 	stage 2 translation
[    3.860678] arm-smmu 8000000.iommu: 	nested translation
[    3.866028] arm-smmu 8000000.iommu: 	stream matching with 128 register groups
[    3.873346] arm-smmu 8000000.iommu: 	128 context banks (0 stage-2 only)
[    3.882306] arm-smmu 8000000.iommu: 	Supported page sizes: 0x00001000
[    3.888918] arm-smmu 8000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    3.895511] arm-smmu 8000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    3.902773] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[    3.912397] tegra_profiler: version: 1.151, samples/io: 51/30
[    3.918367] tegra_profiler: auth: init
[    3.922480] nvsciipc: loaded module
[    3.927653] tun: Universal TUN/TAP device driver, 1.6
[    3.933277] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    3.940687] hns3: Copyright (c) 2017 Huawei Corporation.
[    3.946174] e1000e: Intel(R) PRO/1000 Network Driver
[    3.951267] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    3.957358] igb: Intel(R) Gigabit Ethernet Network Driver
[    3.962886] igb: Copyright (c) 2007-2014 Intel Corporation.
[    3.968758] PPP generic driver version 2.4.2
[    3.973185] PPP BSD Compression module registered
[    3.978009] PPP Deflate Compression module registered
[    3.983206] PPP MPPE Compression module registered
[    3.988151] usbcore: registered new interface driver r8152
[    3.993780] usbcore: registered new interface driver asix
[    3.999328] usbcore: registered new interface driver ax88179_178a
[    4.005581] usbcore: registered new interface driver cdc_ether
[    4.011570] usbcore: registered new interface driver net1080
[    4.017377] usbcore: registered new interface driver cdc_subset
[    4.023447] usbcore: registered new interface driver zaurus
[    4.029184] usbcore: registered new interface driver cdc_ncm
[    4.034990] usbcore: registered new interface driver aqc111
[    4.040817] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    4.047159] ohci-pci: OHCI PCI platform driver
[    4.051732] ohci-platform: OHCI generic platform driver
[    4.057392] tegra-xusb 3610000.xhci: Adding to iommu group 0
[    4.063716] usbcore: registered new interface driver uas
[    4.069187] usbcore: registered new interface driver usb-storage
[    4.075546] mousedev: PS/2 mouse device common for all mice
[    4.081284] usbcore: registered new interface driver xpad
[    4.088677] tegra_rtc c2a0000.rtc: registered as rtc1
[    4.094133] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:22 UTC (22)
[    4.102350] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    4.108727] i2c /dev entries driver
[    4.112414] tegra-i2c 3160000.i2c: Adding to iommu group 1
[    4.118206] tegra-i2c c240000.i2c: Adding to iommu group 1
[    4.123879] tegra-i2c 3180000.i2c: Adding to iommu group 1
[    4.129548] tegra-i2c 3190000.i2c: Adding to iommu group 1
[    4.135226] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[    4.140890] tegra-i2c 31c0000.i2c: Adding to iommu group 1
[    4.146559] tegra-i2c c250000.i2c: Adding to iommu group 1
[    4.152239] tegra-i2c 31e0000.i2c: Adding to iommu group 1
[    4.161308] device-mapper: uevent: version 1.0.3
[    4.166147] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[    4.175760] sdhci: Secure Digital Host Controller Interface driver
[    4.182105] sdhci: Copyright(c) Pierre Ossman
[    4.186574] Synopsys Designware Multimedia Card Interface Driver
[    4.192809] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.198952] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[    4.206423] tegra-bpmp bpmp: firmware: 029a50a8fb4897d35f94-925eece486b
[    4.214712] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[    4.220351] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x82
[    4.225992] nvvrs_pseq 4-003c: CAUTION: interrupt status reg:0x10 set to 0x3
[    4.233235] nvvrs_pseq 4-003c: Clearing interrupts
[    4.244091] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[    4.250042] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
[    5.405238] hid: raw HID events driver (C) Jiri Kosina
[    5.411080] usbcore: registered new interface driver usbhid
[    5.416807] usbhid: USB HID core driver
[    5.421179] tegra-dce d800000.dce: Adding to iommu group 2
[    5.427771] dce: dce_ipc_channel_init:319  Invalid Channel State [0x0] for ch_type [2]
[    5.436345] tegra234-aon c000000.aon: Adding to iommu group 3
[    5.442964] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x5]
[    5.451931] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [0]. Ignored...
[    5.452433]  c000000.aon:hsp: probed
[    5.464387] dce: dce_admin_send_cmd_ver:424  version : [0x2] err : [0x0]
[    5.466335] tegra234-aon c000000.aon: init done
[    5.475988] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x1]
[    5.476537] tegra23x-psc e860000.psc: Adding to iommu group 4
[    5.484938] dce: dce_admin_setup_clients_ipc:553  Channel Reset Complete for Type [1] ...
[    5.484939] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [1]. Ignored...
[    5.484940] dce: dce_admin_setup_clients_ipc:529  Get queue info failed for [2]
[    5.484950] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [1]. Ignored...
[    5.491200] tegra23x-psc e860000.psc: ext_cfg base:(____ptrval____)
[    5.499293] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x2]
[    5.508076] tegra23x-psc e860000.psc: init done
[    5.515590] dce: dce_admin_setup_clients_ipc:553  Channel Reset Complete for Type [3] ...
[    5.515591] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [3]. Ignored...
[    5.515601] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [3]. Ignored...
[    5.524543] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 5
[    5.531040] dce: dce_start_boot_flow:173  DCE_BOOT_DONE
[    5.540482] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[    5.594553] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[    5.603748] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[    5.615397] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[    5.626812] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[    5.638658] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[    5.651240] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[    5.664053] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[    5.676078] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (110)
[    5.682885] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[    5.691981] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=8676d22a01443bdbc66581b7dde3b6d6828cc925
[    5.705955] t19x_cache tegra-cache: probed
[    5.710459] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[    5.721644] optee: probing for conduit method.
[    5.726243] optee: revision 3.21 (d8269f24)
[    5.784986] optee: dynamic shared memory is enabled
[    5.794413] optee: initialized driver
[    5.812469] nvpmodel: initialized successfully
[    5.817149] tegra_hv: get_hvd: not initialized yet
[    5.822089] user_ivc_mempool: hypervisor not present
[    5.827874] usbcore: registered new interface driver snd-usb-audio
[    5.835345] u32 classifier
[    5.838124]     input device check on
[    5.841892]     Actions configured
[    5.845525] Initializing XFRM netlink socket
[    5.850378] NET: Registered protocol family 10
[    5.856247] Segment Routing with IPv6
[    5.860066] NET: Registered protocol family 17
[    5.864659] NET: Registered protocol family 15
[    5.869274] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    5.883387] Bluetooth: RFCOMM socket layer initialized
[    5.888697] Bluetooth: RFCOMM ver 1.11
[    5.892556] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    5.898634] Bluetooth: HIDP socket layer initialized
[    5.904292] 9pnet: Installing 9P2000 support
[    5.908746] Key type dns_resolver registered
[    5.913912] registered taskstats version 1
[    5.918144] Loading compiled-in X.509 certificates
[    5.933378] Loaded X.509 cert 'Build time autogenerated kernel key: 90a3572dd6d0bf99aa9dae0f301fd71270d61209'
[    5.944148] tegra194-pcie 14100000.pcie: Adding to iommu group 6
[    5.957781] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[    5.964966] tegra194-pcie 14160000.pcie: Adding to iommu group 7
[    5.978058] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[    5.984991] tegra194-pcie 140a0000.pcie: Adding to iommu group 8
[    5.997684] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[    6.004859] tegra194-pcie 140a0000.pcie: Failed to get slot regulators: -517
[    6.031449] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 9
[    6.041296] host1x 13e40000.host1x: Adding to iommu group 10
[    6.078562] host1x 13e40000.host1x: initialized
[    6.083594] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 11
[    6.091660] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[    6.103662] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 12
[    6.111677] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[    6.123672] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 13
[    6.131691] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[    6.143658] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 14
[    6.151623] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[    6.163617] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 15
[    6.171599] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[    6.183592] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 16
[    6.191584] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[    6.203559] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 17
[    6.211561] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[    6.223520] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 18
[    6.231523] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[    6.243506] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 19
[    6.251489] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[    6.263451] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 20
[    6.271488] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[    6.283472] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 21
[    6.291455] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[    6.303434] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 22
[    6.311400] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[    6.323393] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 23
[    6.331422] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[    6.343411] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 24
[    6.351385] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[    6.363371] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 25
[    6.371346] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[    6.383333] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 26
[    6.391346] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[    6.403395] falcon 15340000.vic: Adding to iommu group 27
[    6.413704] falcon 15340000.vic: initialized
[    6.418474] falcon 15380000.nvjpg: Adding to iommu group 28
[    6.427001] falcon 15380000.nvjpg: initialized
[    6.431704] falcon 15540000.nvjpg1: Adding to iommu group 29
[    6.440375] falcon 15540000.nvjpg1: initialized
[    6.445175] falcon 154c0000.nvenc: Adding to iommu group 30
[    6.454814] falcon 154c0000.nvenc: initialized
[    6.459538] falcon 15a50000.ofa: Adding to iommu group 31
[    6.468148] falcon 15a50000.ofa: initialized
[    6.472689] nvdec 15480000.nvdec: Adding to iommu group 32
[    6.483655] nvdec 15480000.nvdec: initialized
[    6.488265] tsec 15500000.tsec: Adding to iommu group 33
[    6.497707] tsec 15500000.tsec: initialized
[    6.504938] gic 2a41000.agic-controller: GIC IRQ controller registered
[    6.521642] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[    6.538705] gpio-397 (camera-control-output-low): hogged as output/low
[    6.545456] gpio-486 (camera-control-output-low): hogged as output/low
[    6.553263] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[    6.560528] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[    6.567501] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    6.574015] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[    6.580482] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    6.586676] tegra-pwm 32e0000.pwm: PWM clk can sleep in ops
[    6.594967] tegra194-isp5 14800000.isp: Adding to iommu group 34
[    6.603983] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[    6.613400] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[    6.619851] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[    6.629066] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[    6.638449] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 35
[    6.646552] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 36
[    6.654492] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
[    6.664179] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[    6.670989] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
[    6.680923] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[    6.687708] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[    6.697687] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[    6.704509] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 37
[    6.713145] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18, iommu=smmu.0x0000000008000000)
[    6.724517] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 38
[    6.733133] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19, iommu=smmu.0x0000000008000000)
[    6.744493] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 39
[    6.753084] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20, iommu=smmu.0x0000000008000000)
[    6.764447] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 40
[    6.773057] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21, iommu=smmu.0x0000000008000000)
[    6.784431] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to iommu group 41
[    6.793037] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized (streamid=22, iommu=smmu.0x0000000008000000)
[    6.804402] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to iommu group 42
[    6.813008] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized (streamid=23, iommu=smmu.0x0000000008000000)
[    6.824359] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to iommu group 43
[    6.833007] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized (streamid=24, iommu=smmu.0x0000000008000000)
[    6.844371] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to iommu group 44
[    6.852966] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized (streamid=25, iommu=smmu.0x0000000008000000)
[    6.864330] pva 16000000.pva0: Adding to iommu group 45
[    6.874157] pva 16000000.pva0: initialized
[    6.886738] nvdla 15880000.nvdla0: Adding to iommu group 46
[    6.896671] nvdla 15880000.nvdla0: initialized
[    6.903046] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 1
[    6.910208] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[    6.917754] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[    6.924384] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[    6.931126] serial-tegra 3100000.serial: Adding to iommu group 1
[    6.937687] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 17, base_baud = 0) is a TEGRA_UART
[    6.947476] serial-tegra 3130000.serial: Adding to iommu group 1
[    6.953953] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 61, base_baud = 0) is a TEGRA_UART
[    6.963548] serial-tegra 3140000.serial: Adding to iommu group 1
[    6.970123] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 62, base_baud = 0) is a TEGRA_UART
[    6.995677] tegra-xusb 3610000.xhci: Firmware timestamp: 2023-02-10 03:48:10 UTC, Version: 80.05 release
[    7.005434] tegra-xusb 3610000.xhci: xHCI Host Controller
[    7.011003] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[    7.019656] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[    7.029261] tegra-xusb 3610000.xhci: irq 225, io mem 0x03610000
[    7.035692] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    7.044192] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.051620] usb usb1: Product: xHCI Host Controller
[    7.056630] usb usb1: Manufacturer: Linux 5.10.120-tegra xhci-hcd
[    7.062891] usb usb1: SerialNumber: 3610000.xhci
[    7.068366] hub 1-0:1.0: USB hub found
[    7.072248] hub 1-0:1.0: 4 ports detected
[    7.076607] tegra-xusb 3610000.xhci: xHCI Host Controller
[    7.082161] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[    7.089951] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[    7.097450] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    7.105959] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.113388] usb usb2: Product: xHCI Host Controller
[    7.118394] usb usb2: Manufacturer: Linux 5.10.120-tegra xhci-hcd
[    7.124652] usb usb2: SerialNumber: 3610000.xhci
[    7.129876] hub 2-0:1.0: USB hub found
[    7.133746] hub 2-0:1.0: 4 ports detected
[    7.156511] i2c i2c-2: Added multiplexed i2c bus 9
[    7.162077] i2c i2c-2: Added multiplexed i2c bus 10
[    7.167103] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[    7.174067] tegra23x-oc-event soctherm-oc-event: Finished tegra23x overcurrent event probing
[    7.196256] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1981000 KHz, changing to: 1984000 KHz
[    7.209193] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 1985000 KHz, changing to: 1984000 KHz
[    7.221015] tegra194-cpufreq e000000.ccplex: probed with ICC, cl:3
[    7.228034] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[    7.235843] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[    7.243022] tegra194-pcie 14100000.pcie:       IO 0x0030100000..0x00301fffff -> 0x0030100000
[    7.251716] tegra194-pcie 14100000.pcie:      MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[    7.260398] tegra194-pcie 14100000.pcie:      MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[    8.375750] tegra194-pcie 14100000.pcie: Phy link never came up
[    8.381914] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[    8.388727] pci_bus 0001:00: root bus resource [bus 00-ff]
[    8.394370] pci_bus 0001:00: root bus resource [io  0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[    8.404218] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[    8.415049] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[    8.422977] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[    8.429307] pci 0001:00:00.0: PME# supported from D0 D3hot
[    8.442378] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[    8.447771] pci 0001:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    8.456697] pcieport 0001:00:00.0: Adding to iommu group 6
[    8.462536] pcieport 0001:00:00.0: PME: Signaling with IRQ 55
[    8.468846] pcieport 0001:00:00.0: AER: enabled with IRQ 55
[    8.474801] pci_bus 0001:01: busn_res: [bus 01-ff] is released
[    8.480889] pci 0001:00:00.0: Removing from iommu group 6
[    8.486449] pci_bus 0001:00: busn_res: [bus 00-ff] is released
[    8.494125] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[    8.501351] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[    8.508528] tegra194-pcie 14160000.pcie:       IO 0x0036100000..0x00361fffff -> 0x0036100000
[    8.517215] tegra194-pcie 14160000.pcie:      MEM 0x2428000000..0x242fffffff -> 0x0040000000
[    8.525908] tegra194-pcie 14160000.pcie:      MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[    8.642304] tegra194-pcie 14160000.pcie: Link up
[    8.650651] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[    8.657472] pci_bus 0004:00: root bus resource [bus 00-ff]
[    8.663112] pci_bus 0004:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[    8.673229] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[    8.684057] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[    8.691974] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[    8.698281] pci 0004:00:00.0: PME# supported from D0 D3hot
[    8.707756] pci 0004:01:00.0: [0000:8111] type 00 class 0x010802
[    8.714108] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[    8.722555] pci 0004:01:00.0: 7.876 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x1 link at 0004:00:00.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
[    8.741440] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280fffff]
[    8.748850] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428000000-0x2428003fff 64bit]
[    8.756793] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[    8.762158] pci 0004:00:00.0:   bridge window [mem 0x2428000000-0x24280fffff]
[    8.769495] pci 0004:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    8.778230] pci 0004:01:00.0: Max Payload Size set to  256/ 256 (was  128), Max Read Rq  512
[    8.787133] pcieport 0004:00:00.0: Adding to iommu group 7
[    8.792956] pcieport 0004:00:00.0: PME: Signaling with IRQ 57
[    8.799123] pcieport 0004:00:00.0: AER: enabled with IRQ 57
[    8.805125] nvme 0004:01:00.0: Adding to iommu group 7
[    8.810669] nvme nvme0: pci function 0004:01:00.0
[    8.815562] nvme 0004:01:00.0: enabling device (0000 -> 0002)
[    8.816234] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[    8.828012] tegra194-pcie 140a0000.pcie: Failed to get slot regulators: -517
[    8.828176] vdd-3v3-sd: supplied by vdd-3v3
[    8.834641] tegra194-isp5 14800000.isp: initialized
[    8.845715] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[    8.852175] (NULL device *): fops function table already registered
[    8.859497] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[    8.866405] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[    8.867002] nvme nvme0: allocated 128 MiB host memory buffer.
[    8.873196] irq: IRQ290: trimming hierarchy from :interrupt-controller@f400000-1
[    8.895323] nvme nvme0: 6/0/0 default/read/poll queues
[    8.908409]  nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[    8.995904] tegra194-pcie 140a0000.pcie: host bridge /pcie@140a0000 ranges:
[    9.003088] tegra194-pcie 140a0000.pcie:       IO 0x002a100000..0x002a1fffff -> 0x002a100000
[    9.011781] tegra194-pcie 140a0000.pcie:      MEM 0x3528000000..0x352fffffff -> 0x0040000000
[    9.020462] tegra194-pcie 140a0000.pcie:      MEM 0x3240000000..0x3527ffffff -> 0x3240000000
[    9.134303] tegra194-pcie 140a0000.pcie: Link up
[    9.142592] tegra194-pcie 140a0000.pcie: PCI host bridge to bus 0008:00
[    9.149413] pci_bus 0008:00: root bus resource [bus 00-ff]
[    9.155044] pci_bus 0008:00: root bus resource [io  0x200000-0x2fffff] (bus address [0x2a100000-0x2a1fffff])
[    9.165146] pci_bus 0008:00: root bus resource [mem 0x3528000000-0x352fffffff] (bus address [0x40000000-0x47ffffff])
[    9.175980] pci_bus 0008:00: root bus resource [mem 0x3240000000-0x3527ffffff pref]
[    9.183902] pci 0008:00:00.0: [10de:229c] type 01 class 0x060400
[    9.184574] tegra-xusb 3610000.xhci: entering ELPG done
[    9.190226] pci 0008:00:00.0: PME# supported from D0 D3hot
[    9.205097] pci 0008:01:00.0: [10ec:8168] type 00 class 0x020000
[    9.211412] pci 0008:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[    9.217320] pci 0008:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[    9.224397] pci 0008:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[    9.232403] pci 0008:01:00.0: supports D1 D2
[    9.236802] pci 0008:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    9.247778] pci 0008:00:00.0: BAR 14: assigned [mem 0x3528000000-0x35280fffff]
[    9.255206] pci 0008:00:00.0: BAR 13: assigned [io  0x200000-0x200fff]
[    9.261925] pci 0008:01:00.0: BAR 4: assigned [mem 0x3528000000-0x3528003fff 64bit]
[    9.269894] pci 0008:01:00.0: BAR 2: assigned [mem 0x3528004000-0x3528004fff 64bit]
[    9.277866] pci 0008:01:00.0: BAR 0: assigned [io  0x200000-0x2000ff]
[    9.284510] pci 0008:00:00.0: PCI bridge to [bus 01-ff]
[    9.289878] pci 0008:00:00.0:   bridge window [io  0x200000-0x200fff]
[    9.296511] pci 0008:00:00.0:   bridge window [mem 0x3528000000-0x35280fffff]
[    9.303864] pci 0008:00:00.0: Max Payload Size set to  128/ 256 (was  256), Max Read Rq  512
[    9.312604] pci 0008:01:00.0: Max Payload Size set to  128/ 128 (was  128), Max Read Rq  512
[    9.321547] pcieport 0008:00:00.0: Adding to iommu group 8
[    9.327414] pcieport 0008:00:00.0: PME: Signaling with IRQ 59
[    9.333924] pcieport 0008:00:00.0: AER: enabled with IRQ 59
[    9.340894] irq: IRQ298: trimming hierarchy from :pmc@c360000
[    9.346871] irq: IRQ299: trimming hierarchy from :interrupt-controller@f400000-1
[    9.354574] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    9.362069] tegra-se-nvhost 15810000.se: Adding to iommu group 47
[    9.368659] tegra-se-nvhost 15810000.se: initialized
[    9.382748] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[    9.389118] tegra-se-nvhost 15820000.se: Adding to iommu group 48
[    9.395663] tegra-se-nvhost 15820000.se: initialized
[    9.403191] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[    9.409545] tegra-se-nvhost 15840000.se: Adding to iommu group 49
[    9.416097] tegra-se-nvhost 15840000.se: initialized
[    9.424382] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[    9.431206] tegra_actmon d230000.actmon: in actmon_register()...
[    9.437535] tegra_actmon d230000.actmon: bwmgr_disable = 1
[    9.443556] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[    9.451950] hvc_sysfs: hypervisor is not present
[    9.495762] ALSA device list:
[    9.498820]   No soundcards found.
[    9.502969] Freeing unused kernel memory: 3968K
[    9.507709] Run /init as init process
[    9.511472]   with arguments:
[    9.511473]     /init
[    9.511474]   with environment:
[    9.511475]     HOME=/
[    9.511476]     TERM=linux
[    9.511477]     mminit_loglevel=4
[    9.523775] Root device found: nvme0n1p1
[    9.532674] Found dev node: /dev/nvme0n1p1
[    9.657125] EXT4-fs (nvme0n1p1): 3 orphan inodes deleted
[    9.662609] EXT4-fs (nvme0n1p1): recovery complete
[    9.674905] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null)
[    9.685483] Rootfs mounted over nvme0n1p1
[    9.696365] Switching from initrd to actual rootfs
[    9.763183] systemd[1]: System time before build time, advancing clock.
[    9.794165] x_tables: module verification failed: signature and/or required key missing - tainting kernel
[    9.820312] systemd[1]: systemd 245.4-4ubuntu3.21 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[    9.843893] systemd[1]: Detected architecture arm64.
[    9.882307] systemd[1]: Set hostname to <w>.
[    9.897991] random: crng init done
[   10.012838] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[   10.025881] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[   10.035433] systemd[1]: Created slice system-modprobe.slice.
[   10.054411] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   10.074391] systemd[1]: Created slice User and Session Slice.
[   10.094240] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   10.118400] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   10.142214] systemd[1]: Reached target User and Group Name Lookups.
[   10.162178] systemd[1]: Reached target Slices.
[   10.178169] systemd[1]: Reached target Mounting snaps.
[   10.198166] systemd[1]: Reached target Mounted snaps.
[   10.218167] systemd[1]: Reached target Swap.
[   10.234398] systemd[1]: Listening on RPCbind Server Activation Socket.
[   10.254271] systemd[1]: Listening on Syslog Socket.
[   10.270270] systemd[1]: Listening on fsck to fsckd communication Socket.
[   10.294221] systemd[1]: Listening on initctl Compatibility Named Pipe.
[   10.318374] systemd[1]: Listening on Journal Audit Socket.
[   10.338260] systemd[1]: Listening on Journal Socket (/dev/log).
[   10.362282] systemd[1]: Listening on Journal Socket.
[   10.382288] systemd[1]: Listening on udev Control Socket.
[   10.402236] systemd[1]: Listening on udev Kernel Socket.
[   10.423175] systemd[1]: Mounting Huge Pages File System...
[   10.443090] systemd[1]: Mounting POSIX Message Queue File System...
[   10.463023] systemd[1]: Mounting RPC Pipe File System...
[   10.483121] systemd[1]: Mounting Kernel Debug File System...
[   10.503148] systemd[1]: Mounting Kernel Trace File System...
[   10.523371] systemd[1]: Starting Journal Service...
[   10.543663] systemd[1]: Starting Set the console keyboard layout...
[   10.571503] systemd[1]: Starting Create list of static device nodes for the current kernel...
[   10.599438] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[   10.626267] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[   10.635984] systemd[1]: Starting Load Kernel Module efi_pstore...
[   10.659336] systemd[1]: Starting Load Kernel Module pstore_blk...
[   10.679109] systemd[1]: Starting Load Kernel Module pstore_zone...
[   10.699084] systemd[1]: Starting Load Kernel Module ramoops...
[   10.719212] systemd[1]: Starting NVIDIA specific first-boot udev script...
[   10.743290] systemd[1]: Started Nameserver information manager.
[   10.762360] systemd[1]: Reached target Network (Pre).
[   10.782638] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   10.792030] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[   10.802861] systemd[1]: Starting Load Kernel Modules...
[   10.815145] nvmap_heap_init: nvmap_heap_init: created heap block cache
[   10.822391] nvmap_page_pool_init: Total RAM pages: 1912798
[   10.823282] systemd[1]: Starting Remount Root and Kernel File Systems...
[   10.828044] nvmap_page_pool_init: nvmap page pool size: 239099 pages (933 MB)
[   10.828088] nvmap_background_zero_thread: PP zeroing thread starting.
[   10.831547] EXT4-fs (nvme0n1p1): re-mounted. Opts: (null)
[   10.864927] nvgpu: 17000000.ga10b          nvgpu_nvhost_syncpt_init:135  [INFO]  syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[   10.881116] systemd[1]: Starting udev Coldplug all Devices...
[   10.904053] systemd[1]: Started Journal Service.
[   11.225214] systemd-journald[240]: Received client request to flush runtime journal.
[   11.803421] nvidia: loading out-of-tree module taints kernel.
[   11.823720] nv_platform 13800000.display: Adding to iommu group 50
[   11.827617] platform 13800000.display:nvdisplay-niso: Adding to iommu group 51
[   11.830082] NVRM: loading NVIDIA UNIX Open Kernel Module for aarch64  35.4.1  Release Build  (buildbrain@mobile-u64-6422-d7000)  Tue Aug  1 12:45:41 PDT 2023
[   11.852577] spi-tegra114 3210000.spi: Adding to iommu group 1
[   11.859822] imx219 9-0010: tegracam sensor driver:imx219_v2.0.6
[   11.864399] r8168 0008:01:00.0: Adding to iommu group 8
[   11.864827] r8168 Gigabit Ethernet driver 8.051.02-NAPI loaded
[   11.864919] r8168 0008:01:00.0: enabling device (0000 -> 0003)
[   11.867724] tegra-hda 3510000.hda: Adding to iommu group 52
[   11.872266] spi-tegra114 3230000.spi: Adding to iommu group 1
[   11.885442] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[   11.894385] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[   11.896913] r8168  Copyright (C) 2022 Realtek NIC software team <nicfae@realtek.com>
                This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
                This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[   11.898624] cpu-throttle-alert cooling device registered.
[   11.898983] gpu-throttle-alert cooling device registered.
[   11.899482] cv0-throttle-alert cooling device registered.
[   11.899959] nvadsp 2993000.adsp: Adding to iommu group 53
[   11.900107] nvadsp 2993000.adsp: in probe()...
[   11.900522] cv1-throttle-alert cooling device registered.
[   11.900637] cv2-throttle-alert cooling device registered.
[   11.900694] soc0-throttle-alert cooling device registered.
[   11.900735] soc1-throttle-alert cooling device registered.
[   11.900773] soc2-throttle-alert cooling device registered.
[   11.901712] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
[   11.904915] hot-surface-alert cooling device registered.
[   11.905848] imx219 9-0010: board setup failed
[   11.917473] imx219: probe of 9-0010 failed with error -121
[   11.930990] imx219 10-0010: tegracam sensor driver:imx219_v2.0.6
[   11.934808] nvadsp 2993000.adsp: nvadsp_app_module_probe
[   11.949921] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[   11.971950] tegra-asoc: sound: Adding to iommu group 53
[   11.972417] imx219 10-0010: board setup failed
[   11.987861] tegra210-adsp aconnect@2a41000:adsp_audio: Adding to iommu group 53
[   11.987893] tegra210_adsp_audio_probe: platform probe started
[   11.988958] tegra210-adsp tegra210-adsp: Default param-type to BYTE for mp3-dec1
[   11.989215] tegra210-adsp tegra210-adsp: Default param-type to BYTE for spkprot
[   11.989462] tegra210-adsp tegra210-adsp: Default param-type to BYTE for src
[   11.989703] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aac-dec1
[   11.989944] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aec
[   11.990921] tegra210-adsp tegra210-adsp: Default param-type to BYTE for wire
[   11.990928] tegra210-adsp tegra210-adsp: adma channel page address dt entry not found
[   11.990930] tegra210-adsp tegra210-adsp: using adma channel page 0
[   11.991009] nvadsp 2993000.adsp: ADSP OS firmware already loaded
[   11.998978] imx219: probe of 10-0010 failed with error -121
[   12.013345] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=3 as /devices/platform/3510000.hda/sound/card0/input1
[   12.013425] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=7 as /devices/platform/3510000.hda/sound/card0/input2
[   12.013519] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=8 as /devices/platform/3510000.hda/sound/card0/input3
[   12.013568] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=9 as /devices/platform/3510000.hda/sound/card0/input4
[   12.031944] cryptd: max_cpu_qlen set to 1000
[   12.336784] tegra210-adsp tegra210-adsp: Loaded app wire
[   12.336788] tegra210-adsp tegra210-adsp: Loaded app apm
[   12.336789] tegra210-adsp tegra210-adsp: Loaded app adma
[   12.336791] tegra210-adsp tegra210-adsp: Loaded app adma_tx
[   12.336793] nvadsp_set_adma_dump_reg: callback for adma reg dump is sent to 000000009ce55769
[   12.363359] tegra210-adsp tegra210-adsp: Tegra210 ADSP driver successfully registered
[   13.207383] loop: module loaded
[   13.578420] pstore: Using crash dump compression: deflate
[   13.578454] printk: console [ramoops-1] enabled
[   13.578456] pstore: Registered ramoops as persistent store backend
[   13.578458] ramoops: using 0x200000@0x26ea70000, ecc: 0
[   14.085077] nvgpu: 17000000.ga10b                  gk20a_scale_init:541  [INFO]  enabled scaling for GPU
[   14.275001] zram: Added device: zram0
[   14.275129] zram: Added device: zram1
[   14.276005] zram: Added device: zram2
[   14.276375] zram: Added device: zram3
[   14.277135] zram: Added device: zram4
[   14.277487] zram: Added device: zram5
[   14.306434] tegra-xusb 3610000.xhci: Firmware timestamp: 2023-02-10 03:48:10 UTC, Version: 80.05 release
[   14.314279] zram0: detected capacity change from 0 to 652902400
[   14.350387] Adding 637596k swap on /dev/zram0.  Priority:5 extents:1 across:637596k SS
[   14.352340] zram1: detected capacity change from 0 to 652902400
[   14.378230] Adding 637596k swap on /dev/zram1.  Priority:5 extents:1 across:637596k SS
[   14.379702] zram2: detected capacity change from 0 to 652902400
[   14.430222] Adding 637596k swap on /dev/zram2.  Priority:5 extents:1 across:637596k SS
[   14.431371] zram3: detected capacity change from 0 to 652902400
[   14.444492] nvgpu: 17000000.ga10b                 fbp_pg_mask_store:981  [INFO]  no value change, same mask already set
[   14.444505] nvgpu: 17000000.ga10b                 tpc_pg_mask_store:1070 [INFO]  no value change, same mask already set
[   14.449899] nvgpu: 17000000.ga10b                 fbp_pg_mask_store:981  [INFO]  no value change, same mask already set
[   14.449915] nvgpu: 17000000.ga10b                 tpc_pg_mask_store:1070 [INFO]  no value change, same mask already set
[   14.457341] ccm3310s: no symbol version for module_layout
[   14.458530] spi_ccm3310 spi0.0: ccm3310 device driverload. v1.0
[   14.469524] yytek,board spi0.1: Yytek Generic Operation Device Driver load
[   14.474450] Adding 637596k swap on /dev/zram3.  Priority:5 extents:1 across:637596k SS
[   14.475568] zram4: detected capacity change from 0 to 652902400
[   14.512526] nvvrs_pseq 4-003c: CAUTION: interrupt status reg:0x10 set to 0x8
[   14.512532] nvvrs_pseq 4-003c: Clearing interrupts
[   14.522258] Adding 637596k swap on /dev/zram4.  Priority:5 extents:1 across:637596k SS
[   14.523518] zram5: detected capacity change from 0 to 652902400
[   14.538392] eth0: 0xffff800010908000, 48:b0:2d:d9:37:cb, IRQ 300
[   14.602207] Adding 637596k swap on /dev/zram5.  Priority:5 extents:1 across:637596k SS
[   15.369858] fuse: init (API version 7.32)
[   15.481566] nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for aarch64  35.4.1  Release Build  (buildbrain@mobile-u64-6422-d7000)  Tue Aug  1 12:45:42 PDT 2023
Here is the dts dump from /proc/device-tree, nvme use PCIe C4 RP pcie@14160000.
orin_nx_8gb.dts (427.7 KB)
Configured it by referring to the pcie setting in p3768 dtb.
