Device mode stopped working
I have a Orin NX 16GB running in a devkit carrier board.
Until now, the device mode was working fine and I could connect via SSH to 192.168.55.1.
But after one or two weeks in the box, I started to work on the Jetson again, and now the network interface is not working on the Jetson.
If I plug the Nano on the same carrier board, it’s working fine, but on that Orin NX it stopped working.
I tried to flash the NVMe from scratch, but no luck. I tried to connect to another PC, but same result.
The USB-C cable is OK since I can flash it, and device mode is working with this cable with the Nano module.
When I plug the USB cable, I see nothing in dmesg (on the Jetson and on my PC).
Service nv-l4t-usb-device-mode is successful and usb0 and usb1 interfaces are created, but no IP is assigned when plugging the USB-C cable to the PC.
What else can I check?
What does that mean no luck? Flash failed or flash succeeded but USB port is still not working?
And what Nano are you talking about? Orin Nano?
Sorry for bad explainations.
I mean that device mode is not working, flashing is working fine.
Let me try to explain the situation better:
  • I have a Orin Nano devkit (carrier board+module).
  • I have a Orin NX 16GB module.
  • I can flash successfully Orin NX installed in the devkit carrier board.
  • Device mode is not working on this Orin NX anymore, it worked before with the same NVMe (what happened? I don’t know yet).
  • If I install the Orin Nano in the carrier instead of the Orin NX 16GB, the device mode is working fine, so the carrier board itself is OK, I did this test without changing the NVMe neither flashing it.
Please share the dmesg of your board with Orin NX.
Also, is the host mode of usb port still working or not?
And this comment does not make sense at all. It sounds like the software on this board was for Jetson Orin Nano all the time. Orin NX and Orin Nano still have difference. They are not going to work perfectly if just using another module without flashing.
Yes I know, it was just for testing…
The NVMe was flashed for NX, not for Nano.
I just tested host mode, and it’s working fine.
Here is the dmesg:
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[    0.000000] Linux version 5.15.136-tegra (root@laptop) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2022.08) 11.3.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT Wed Jun 5 07:42:16 UTC 2024 ()
[    0.000000] Machine model: NVIDIA Jetson Orin NX Engineering Reference Developer Kit
[    0.000000] efi: EFI v2.70 by EDK II
[    0.000000] efi: RTPROP=0x437a2f198 SMBIOS=0xffff0000 SMBIOS 3.0=0x437400000 MEMATTR=0x4314ed018 ESRT=0x431409318 RNG=0x425060018 MEMRESERVE=0x425bbcc18
[    0.000000] random: crng init done
[    0.000000] secureboot: Secure boot disabled
[    0.000000] esrt: Reserving ESRT space from 0x0000000431409318 to 0x0000000431409350.
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000461000000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x0000000477ffffff]
[    0.000000] NUMA: NODE_DATA [mem 0x4602f1800-0x4602f3fff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x0000000477ffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000fffdffff]
[    0.000000]   node   0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x000000042843cfff]
[    0.000000]   node   0: [mem 0x000000042843d000-0x000000042860bfff]
[    0.000000]   node   0: [mem 0x000000042860c000-0x0000000435aeffff]
[    0.000000]   node   0: [mem 0x0000000435af0000-0x0000000437a2ffff]
[    0.000000]   node   0: [mem 0x0000000437a30000-0x000000043bffffff]
[    0.000000]   node   0: [mem 0x0000000440000000-0x0000000471dfffff]
[    0.000000]   node   0: [mem 0x0000000471e00000-0x0000000471ffffff]
[    0.000000]   node   0: [mem 0x0000000472000000-0x000000047259ffff]
[    0.000000]   node   0: [mem 0x0000000472f00000-0x0000000472ffffff]
[    0.000000]   node   0: [mem 0x0000000476000000-0x0000000477ffffff]
[    0.000000] mminit::pageflags_layout_widths Section 0 Node 4 Zone 2 Lastcpupid 16 Kasantag 0 Flags 24
[    0.000000] mminit::pageflags_layout_shifts Section 21 Node 4 Zone 2 Lastcpupid 16 Kasantag 0
[    0.000000] mminit::pageflags_layout_pgshifts Section 0 Node 60 Zone 58 Lastcpupid 42 Kasantag 0
[    0.000000] mminit::pageflags_layout_nodezoneid Node/Zone ID: 64 -> 58
[    0.000000] mminit::pageflags_layout_usage location: 64 -> 42 layout 42 -> 24 unused 24 -> 0 page-flags
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000477ffffff]
[    0.000000] mminit::memmap_init Initialising map node 0 zone 0 pfns 524288 -> 1048576
[    0.000000] mminit::memmap_init Initialising map node 0 zone 2 pfns 1048576 -> 4685824
[    0.000000] On node 0, zone Normal: 16384 pages in unavailable ranges
[    0.000000] On node 0, zone Normal: 2400 pages in unavailable ranges
[    0.000000] On node 0, zone Normal: 12288 pages in unavailable ranges
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 29 pages/cpu s80408 r8192 d30184 u118784
[    0.000000] pcpu-alloc: s80408 r8192 d30184 u118784 alloc=29*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: Address authentication (architected algorithm)
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: detected: Hardware dirty bit management
[    0.000000] CPU features: detected: Spectre-v4
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] alternatives: patching kernel code
[    0.000000] mminit::zonelist general 0:DMA = 0:DMA
[    0.000000] mminit::zonelist general 0:Normal = 0:Normal 0:DMA
[    0.000000] mminit::zonelist thisnode 0:DMA = 0:DMA
[    0.000000] mminit::zonelist thisnode 0:Normal = 0:Normal 0:DMA
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 4065440
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: root=PARTUUID=1cef3ff5-30d6-4eae-bee8-fb23e0d227de rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb video=efifb:off console=tty0 bl_prof_dataptr=2031616@0x471E10000 bl_prof_ro_ptr=65536@0x471E00000
[    0.000000] Unknown kernel command line parameters "bl_prof_dataptr=2031616@0x471E10000 bl_prof_ro_ptr=65536@0x471E00000", will be passed to user space.
[    0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000fbfe0000-0x00000000fffe0000] (64MB)
[    0.000000] Memory: 15751288K/16521856K available (19008K kernel code, 4056K rwdata, 9972K rodata, 7616K init, 529K bss, 508424K reserved, 262144K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Rude variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[    0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000000] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.000322] Console: colour dummy device 80x25
[    0.000328] printk: console [tty0] enabled
[    0.000371] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.000376] pid_max: default: 32768 minimum: 301
[    0.000402] LSM: Security Framework initializing
[    0.000418] Yama: becoming mindful.
[    0.000429] SELinux:  Initializing.
[    0.000493] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.000512] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.001341] rcu: Hierarchical SRCU implementation.
[    0.003461] Tegra Revision: A01 SKU: 211 CPU Process: 0 SoC Process: 0
[    0.003714] Remapping and enabling EFI services.
[    0.004471] smp: Bringing up secondary CPUs ...
[    0.004823] Detected PIPT I-cache on CPU1
[    0.004848] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[    0.004870] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[    0.005207] Detected PIPT I-cache on CPU2
[    0.005219] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[    0.005232] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[    0.005536] Detected PIPT I-cache on CPU3
[    0.005545] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[    0.005556] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[    0.007836] Detected PIPT I-cache on CPU4
[    0.007857] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[    0.007878] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[    0.008232] Detected PIPT I-cache on CPU5
[    0.008242] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[    0.008253] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[    0.008570] Detected PIPT I-cache on CPU6
[    0.008580] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[    0.008591] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[    0.008914] Detected PIPT I-cache on CPU7
[    0.008924] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[    0.008935] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[    0.008978] smp: Brought up 1 node, 8 CPUs
[    0.008981] SMP: Total of 8 processors activated.
[    0.008983] CPU features: detected: 32-bit EL0 Support
[    0.008984] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.008986] CPU features: detected: Common not Private translations
[    0.008987] CPU features: detected: CRC32 instructions
[    0.008987] CPU features: detected: Data cache clean to Point of Persistence
[    0.008988] CPU features: detected: Generic authentication (architected algorithm)
[    0.008989] CPU features: detected: RCpc load-acquire (LDAPR)
[    0.008989] CPU features: detected: LSE atomic instructions
[    0.008990] CPU features: detected: Privileged Access Never
[    0.008991] CPU features: detected: RAS Extension Support
[    0.008993] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.022840] spectre-bhb mitigation disabled by command line option
[    0.035956] CPU: All CPU(s) started at EL2
[    0.037656] devtmpfs: initialized
[    0.048643] KASLR enabled
[    0.048747] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.048762] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.050845] pinctrl core: initialized pinctrl subsystem
[    0.051359] SMBIOS 3.6.0 present.
[    0.051366] DMI: NVIDIA NVIDIA Jetson Orin NX Engineering Reference Developer Kit/Jetson, BIOS 36.3.0-gcid-36191598 05/06/2024
[    0.051640] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.052778] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.052886] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.052980] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.053011] audit: initializing netlink subsys (disabled)
[    0.053093] audit: type=2000 audit(0.052:1): state=initialized audit_enabled=0 res=1
[    0.053946] thermal_sys: Registered thermal governor 'step_wise'
[    0.053949] thermal_sys: Registered thermal governor 'user_space'
[    0.053949] thermal_sys: Registered thermal governor 'power_allocator'
[    0.055936] cpuidle: using governor menu
[    0.056069] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.056150] ASID allocator initialised with 32768 entries
[    0.057191] Serial: AMBA PL011 UART driver
[    0.065441] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 117, base_baud = 0) is a SBSA
[    0.073173] platform bpmp: Fixing up cyclic dependency with 2c60000.external-memory-controller
[    0.079499] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.079503] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.079504] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.079505] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.080040] cryptd: max_cpu_qlen set to 1000
[    0.081256] ACPI: Interpreter disabled.
[    0.082096] VDD_1V8_AO: supplied by VDD_5V0_SYS
[    0.082173] VDD_3V3_AO: supplied by VDD_5V0_SYS
[    0.082363] VDD_AV10_HUB: supplied by VDD_5V0_SYS
[    0.082621] iommu: Default domain type: Translated
[    0.082624] iommu: DMA domain TLB invalidation policy: strict mode
[    0.082808] SCSI subsystem initialized
[    0.082863] libata version 3.00 loaded.
[    0.082912] vgaarb: loaded
[    0.083013] usbcore: registered new interface driver usbfs
[    0.083029] usbcore: registered new interface driver hub
[    0.083042] usbcore: registered new device driver usb
[    0.083349] pps_core: LinuxPPS API ver. 1 registered
[    0.083351] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.083358] PTP clock support registered
[    0.083403] EDAC MC: Ver: 3.0.0
[    0.084008] Registered efivars operations
[    0.084429] FPGA manager framework
[    0.084464] Advanced Linux Sound Architecture Driver Initialized.
[    0.084914] clocksource: Switched to clocksource arch_sys_counter
[    0.113332] VFS: Disk quotas dquot_6.6.0
[    0.113412] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.113640] pnp: PnP ACPI: disabled
[    0.116779] NET: Registered PF_INET protocol family
[    0.117355] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.119859] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    0.119901] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.119921] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.120095] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.121460] TCP: Hash tables configured (established 131072 bind 65536)
[    0.121663] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.121706] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.121933] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.122380] RPC: Registered named UNIX socket transport module.
[    0.122386] RPC: Registered udp transport module.
[    0.122388] RPC: Registered tcp transport module.
[    0.122389] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.122405] PCI: CLS 0 bytes, default 64
[    0.122665] Unpacking initramfs...
[    0.130064] hw perfevents: enabled with armv8_cortex_a78 PMU driver, 7 counters available
[    0.130370] kvm [1]: IPA Size Limit: 48 bits
[    0.130409] kvm [1]: GICv3: no GICV resource entry
[    0.130418] kvm [1]: disabling GICv2 emulation
[    0.130438] kvm [1]: GIC system register CPU interface enabled
[    0.130531] kvm [1]: vgic interrupt IRQ9
[    0.130704] kvm [1]: VHE mode initialized successfully
[    0.133971] Initialise system trusted keyrings
[    0.134098] workingset: timestamp_bits=42 max_order=22 bucket_order=0
[    0.137878] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.138281] NFS: Registering the id_resolver key type
[    0.138316] Key type id_resolver registered
[    0.138320] Key type id_legacy registered
[    0.138359] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.138377] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.138406] ntfs: driver 2.1.32 [Flags: R/O].
[    0.138641] 9p: Installing v9fs 9p2000 file system support
[    0.150943] Key type asymmetric registered
[    0.150950] Asymmetric key parser 'x509' registered
[    0.151024] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.151031] io scheduler mq-deadline registered
[    0.151038] io scheduler kyber registered
[    0.161188] EINJ: ACPI disabled.
[    0.173522] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.175353] SuperH (H)SCI(F) driver initialized
[    0.175712] msm_serial: driver initialized
[    0.176370] printk: console [ttyTCU0] enabled
[    0.177273] arm-smmu 8000000.iommu: probing hardware configuration...
[    0.177279] arm-smmu 8000000.iommu: SMMUv2 with:
[    0.177285] arm-smmu 8000000.iommu: 	stage 1 translation
[    0.177287] arm-smmu 8000000.iommu: 	stage 2 translation
[    0.177292] arm-smmu 8000000.iommu: 	nested translation
[    0.177298] arm-smmu 8000000.iommu: 	stream matching with 128 register groups
[    0.177301] arm-smmu 8000000.iommu: 	128 context banks (0 stage-2 only)
[    0.177314] arm-smmu 8000000.iommu: 	Supported page sizes: 0x61311000
[    0.177317] arm-smmu 8000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    0.177318] arm-smmu 8000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    0.178332] arm-smmu 10000000.iommu: probing hardware configuration...
[    0.178336] arm-smmu 10000000.iommu: SMMUv2 with:
[    0.178340] arm-smmu 10000000.iommu: 	stage 1 translation
[    0.178344] arm-smmu 10000000.iommu: 	stage 2 translation
[    0.178345] arm-smmu 10000000.iommu: 	nested translation
[    0.178349] arm-smmu 10000000.iommu: 	stream matching with 128 register groups
[    0.178352] arm-smmu 10000000.iommu: 	128 context banks (0 stage-2 only)
[    0.178361] arm-smmu 10000000.iommu: 	Supported page sizes: 0x61311000
[    0.178363] arm-smmu 10000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    0.178364] arm-smmu 10000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    0.178730] arm-smmu 12000000.iommu: probing hardware configuration...
[    0.178734] arm-smmu 12000000.iommu: SMMUv2 with:
[    0.178735] arm-smmu 12000000.iommu: 	stage 1 translation
[    0.178736] arm-smmu 12000000.iommu: 	stage 2 translation
[    0.178736] arm-smmu 12000000.iommu: 	nested translation
[    0.178739] arm-smmu 12000000.iommu: 	stream matching with 128 register groups
[    0.178741] arm-smmu 12000000.iommu: 	128 context banks (0 stage-2 only)
[    0.178750] arm-smmu 12000000.iommu: 	Supported page sizes: 0x61311000
[    0.178752] arm-smmu 12000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    0.178753] arm-smmu 12000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    0.187065] loop: module loaded
[    0.188057] megasas: 07.717.02.00-rc1
[    0.192229] tun: Universal TUN/TAP device driver, 1.6
[    0.192845] thunder_xcv, ver 1.0
[    0.192875] thunder_bgx, ver 1.0
[    0.192896] nicpf, ver 1.0
[    0.193727] hclge is initializing
[    0.193756] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    0.193762] hns3: Copyright (c) 2017 Huawei Corporation.
[    0.193800] e1000: Intel(R) PRO/1000 Network Driver
[    0.193805] e1000: Copyright (c) 1999-2006 Intel Corporation.
[    0.193832] e1000e: Intel(R) PRO/1000 Network Driver
[    0.193837] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    0.193863] igb: Intel(R) Gigabit Ethernet Network Driver
[    0.193869] igb: Copyright (c) 2007-2014 Intel Corporation.
[    0.193883] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    0.193889] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.194106] sky2: driver version 1.30
[    0.194765] VFIO - User Level meta-driver version: 0.3
[    0.196274] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.196284] ehci-pci: EHCI PCI platform driver
[    0.196309] ehci-platform: EHCI generic platform driver
[    0.196394] ehci-orion: EHCI orion driver
[    0.196459] ehci-exynos: EHCI Exynos driver
[    0.196516] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.196535] ohci-pci: OHCI PCI platform driver
[    0.196563] ohci-platform: OHCI generic platform driver
[    0.196635] ohci-exynos: OHCI Exynos driver
[    0.197077] usbcore: registered new interface driver usb-storage
[    0.198885] i2c_dev: i2c /dev entries driver
[    0.200163] pps pps0: new PPS source ktimer
[    0.200172] pps pps0: ktimer PPS source registered
[    0.200184] pps_ldisc: PPS line discipline registered
[    0.202294] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[    0.204260] sdhci: Secure Digital Host Controller Interface driver
[    0.204266] sdhci: Copyright(c) Pierre Ossman
[    0.204723] Synopsys Designware Multimedia Card Interface Driver
[    0.205327] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.206393] ledtrig-cpu: registered to indicate activity on CPUs
[    0.207315] SMCCC: SOC_ID: ID = jep106:036b:0234 Revision = 0x00000401
[    0.207875] tegra-bpmp bpmp: Adding to iommu group 0
[    0.209187] tegra-bpmp bpmp: firmware: 6432e47ee22b94f945d6-3b0e1a33cf8
[    0.310566] Freeing initrd memory: 11480K
[    3.770885] clocksource: tsc: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    3.770916] clocksource: osc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 49772407460 ns
[    3.770919] clocksource: usec: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[    3.771089] hid: raw HID events driver (C) Jiri Kosina
[    3.771444] usbcore: registered new interface driver usbhid
[    3.771450] usbhid: USB HID core driver
[    3.775929] optee: probing for conduit method.
[    3.775982] optee: revision 3.22 (e7b5ff3f)
[    3.835360] optee: dynamic shared memory is enabled
[    3.835595] optee: initialized driver
[    3.838235] usbcore: registered new interface driver snd-usb-audio
[    3.839721] NET: Registered PF_PACKET protocol family
[    3.839956] 9pnet: Installing 9P2000 support
[    3.840078] Key type dns_resolver registered
[    3.841188] printk: console [tty0]: printing thread started
[    3.841936] printk: console [ttyTCU0]: printing thread started
[    3.842036] Loading compiled-in X.509 certificates
[    3.855190] Loaded X.509 cert 'Build time autogenerated kernel key: dbb286d1aefe630fbef42e509f7ecd7dd6264e39'
[    3.883373] gpio-394 (camera-control-output-low): hogged as output/low
[    3.889637] tegra-gpcdma 2600000.dma-controller: Adding to iommu group 1
[    3.891697] tegra-gpcdma 2600000.dma-controller: GPC DMA driver register 31 channels
[    3.894358] serial-tegra 3100000.serial: RX in PIO mode
[    3.894367] serial-tegra 3100000.serial: TX in PIO mode
[    3.894509] 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 112, base_baud = 0) is a TEGRA_UART
[    3.896601] serial-tegra 3140000.serial: RX in PIO mode
[    3.896608] serial-tegra 3140000.serial: TX in PIO mode
[    3.896745] 3140000.serial: ttyTHS2 at MMIO 0x3140000 (irq = 113, base_baud = 0) is a TEGRA_UART
[    3.902080] tegra_rtc c2a0000.rtc: registered as rtc1
[    3.902101] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    3.902914] tegra-i2c 3160000.i2c: Adding to iommu group 1
[    3.910402] tegra-i2c 3180000.i2c: Adding to iommu group 1
[    3.915308] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[    3.920898] tegra-i2c c240000.i2c: Adding to iommu group 1
[    3.924917] i2c 1-0025: Fixing up cyclic dependency with 3520000.padctl
[    3.925667] tegra-i2c c250000.i2c: Adding to iommu group 1
[    3.932290] i2c i2c-2: Added multiplexed i2c bus 9
[    3.934005] i2c i2c-2: Added multiplexed i2c bus 10
[    3.934022] i2c-mux-gpio bus@0:cam_i2cmux: 2 port mux on 3180000.i2c adapter
[    3.954581] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1993000 KHz, changing to: 1984000 KHz
[    3.957151] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 1996000 KHz, changing to: 1984000 KHz
[    3.961786] tegra-xusb 3610000.usb: Adding to iommu group 2
[    3.977876] tegra-xusb 3610000.usb: Firmware timestamp: 2023-02-10 03:48:10 UTC
[    3.977885] tegra-xusb 3610000.usb: xHCI Host Controller
[    3.977899] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 1
[    3.978625] tegra-xusb 3610000.usb: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000010810
[    3.978647] tegra-xusb 3610000.usb: irq 123, io mem 0x03610000
[    3.978760] tegra-xusb 3610000.usb: xHCI Host Controller
[    3.978765] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 2
[    3.978769] tegra-xusb 3610000.usb: Host supports USB 3.1 Enhanced SuperSpeed
[    3.979385] hub 1-0:1.0: USB hub found
[    3.979402] hub 1-0:1.0: 4 ports detected
[    3.979693] hub 2-0:1.0: USB hub found
[    3.979703] hub 2-0:1.0: 4 ports detected
[    3.981271] irq: IRQ221: trimming hierarchy from :bus@0:pmc@c360000
[    3.981325] irq: IRQ222: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[    3.981371] irq: IRQ223: trimming hierarchy from :bus@0:pmc@c360000
[    3.981427] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    4.020549] ALSA device list:
[    4.020553]   No soundcards found.
[    4.033680] Freeing unused kernel memory: 7616K
[    4.033750] Run /init as init process
[    4.033751]   with arguments:
[    4.033752]     /init
[    4.033752]   with environment:
[    4.033753]     HOME=/
[    4.033753]     TERM=linux
[    4.033754]     bl_prof_dataptr=2031616@0x471E10000
[    4.033755]     bl_prof_ro_ptr=65536@0x471E00000
[    4.046832] Checking overlayfs setting...
[    4.055211] Overlayfs is disabled...
[    4.061015] Root device found: PARTUUID=1cef3ff5-30d6-4eae-bee8-fb23e0d227de
[    4.320913] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[    4.495663] hub 1-2:1.0: USB hub found
[    4.496763] hub 1-2:1.0: 4 ports detected
[    4.609755] usb 2-1: new SuperSpeed Plus Gen 2x1 USB device number 2 using tegra-xusb
[    4.660625] hub 2-1:1.0: USB hub found
[    4.662861] hub 2-1:1.0: 4 ports detected
[    4.765086] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[    7.412965] tegra194-pcie 14100000.pcie: Adding to iommu group 3
[    7.415508] tegra194-pcie 14100000.pcie: host bridge /bus@0/pcie@14100000 ranges:
[    7.415529] tegra194-pcie 14100000.pcie:      MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[    7.415535] tegra194-pcie 14100000.pcie:      MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[    7.415539] tegra194-pcie 14100000.pcie:       IO 0x0030100000..0x00301fffff -> 0x0030100000
[    7.415860] tegra194-pcie 14100000.pcie: iATU unroll: enabled
[    7.415863] tegra194-pcie 14100000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    7.435962] tegra-xudc 3550000.usb: Adding to iommu group 4
[    7.521099] tegra194-pcie 14100000.pcie: Link up
[    7.523677] tegra194-pcie 14100000.pcie: Link up
[    7.523739] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[    7.523744] pci_bus 0001:00: root bus resource [io  0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[    7.523747] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[    7.523750] pci_bus 0001:00: root bus resource [bus 00-ff]
[    7.523752] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[    7.523803] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[    7.523972] pci 0001:00:00.0: PME# supported from D0 D3hot
[    7.527093] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[    7.527265] pci 0001:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[    7.527465] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[    7.528490] pci 0001:01:00.0: supports D1 D2
[    7.528491] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    7.543540] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[    7.543543] pci 0001:00:00.0: BAR 13: assigned [io  0x1000-0x1fff]
[    7.543546] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff 64bit]
[    7.543648] pci 0001:01:00.0: BAR 0: assigned [io  0x1000-0x10ff]
[    7.543679] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[    7.543682] pci 0001:00:00.0:   bridge window [io  0x1000-0x1fff]
[    7.543686] pci 0001:00:00.0:   bridge window [mem 0x20a8000000-0x20a80fffff]
[    7.543789] pcieport 0001:00:00.0: Adding to iommu group 3
[    7.543885] pcieport 0001:00:00.0: PME: Signaling with IRQ 191
[    7.544158] pcieport 0001:00:00.0: AER: enabled with IRQ 191
[    7.545004] tegra194-pcie 14160000.pcie: Adding to iommu group 5
[    7.547306] tegra194-pcie 14160000.pcie: host bridge /bus@0/pcie@14160000 ranges:
[    7.547319] tegra194-pcie 14160000.pcie:      MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[    7.547325] tegra194-pcie 14160000.pcie:      MEM 0x2428000000..0x242fffffff -> 0x0040000000
[    7.547329] tegra194-pcie 14160000.pcie:       IO 0x0036100000..0x00361fffff -> 0x0036100000
[    7.547677] tegra194-pcie 14160000.pcie: iATU unroll: enabled
[    7.547679] tegra194-pcie 14160000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    7.653089] tegra194-pcie 14160000.pcie: Link up
[    7.660828] tegra194-pcie 14160000.pcie: Link up
[    7.660892] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[    7.660895] pci_bus 0004:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[    7.660898] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[    7.660900] pci_bus 0004:00: root bus resource [bus 00-ff]
[    7.660901] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[    7.660954] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[    7.661094] pci 0004:00:00.0: PME# supported from D0 D3hot
[    7.664029] pci 0004:01:00.0: [2646:5019] type 00 class 0x010802
[    7.664209] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[    7.668687] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280fffff]
[    7.668690] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428000000-0x2428003fff 64bit]
[    7.668770] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[    7.668774] pci 0004:00:00.0:   bridge window [mem 0x2428000000-0x24280fffff]
[    7.668854] pcieport 0004:00:00.0: Adding to iommu group 5
[    7.668937] pcieport 0004:00:00.0: PME: Signaling with IRQ 193
[    7.669358] pcieport 0004:00:00.0: AER: enabled with IRQ 193
[    7.669515] nvme 0004:01:00.0: Adding to iommu group 5
[    7.669805] nvme nvme0: pci function 0004:01:00.0
[    7.669855] nvme 0004:01:00.0: enabling device (0000 -> 0002)
[    7.670302] tegra194-pcie 141e0000.pcie: Adding to iommu group 6
[    7.671747] tegra194-pcie 141e0000.pcie: host bridge /bus@0/pcie@141e0000 ranges:
[    7.671758] tegra194-pcie 141e0000.pcie:      MEM 0x3000000000..0x3227ffffff -> 0x3000000000
[    7.671763] tegra194-pcie 141e0000.pcie:      MEM 0x3228000000..0x322fffffff -> 0x0040000000
[    7.671766] tegra194-pcie 141e0000.pcie:       IO 0x003e100000..0x003e1fffff -> 0x003e100000
[    7.672056] tegra194-pcie 141e0000.pcie: iATU unroll: enabled
[    7.672058] tegra194-pcie 141e0000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    7.696790] nvme nvme0: allocated 64 MiB host memory buffer.
[    7.718641] nvme nvme0: 8/0/0 default/read/poll queues
[    7.721138]  nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[    8.044102] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[    8.047593] Rootfs mounted over PARTUUID=1cef3ff5-30d6-4eae-bee8-fb23e0d227de
[    8.056205] Switching from initrd to actual rootfs
[    8.285240] systemd[1]: System time before build time, advancing clock.
[    8.306838] NET: Registered PF_INET6 protocol family
[    8.307807] Segment Routing with IPv6
[    8.307813] In-situ OAM (IOAM) with IPv6
[    8.344605] systemd[1]: systemd 249.11-0ubuntu3.12 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    8.344931] systemd[1]: Detected architecture arm64.
[    8.347368] systemd[1]: Hostname set to <jetson>.
[    8.375225] systemd[1]: Using hardware watchdog 'NVIDIA Tegra186 WDT', version 0, device /dev/watchdog
[    8.375242] systemd[1]: Set hardware watchdog to 2min.
[    8.582560] systemd[1]: Configuration file /run/systemd/system/netplan-ovs-cleanup.service is marked world-inaccessible. This has no effect as configuration data is accessible via APIs without restrictions. Proceeding anyway.
[    8.655278] systemd[1]: /etc/systemd/system/nvs-service.service:41: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    8.661649] systemd[1]: /etc/systemd/system/nvargus-daemon.service:42: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    8.758589] systemd[1]: Queued start job for default target Graphical Interface.
[    8.760211] systemd[1]: Created slice Slice /system/modprobe.
[    8.760830] systemd[1]: Created slice Slice /system/serial-getty.
[    8.761484] systemd[1]: Created slice User and Session Slice.
[    8.761961] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    8.762288] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    8.762438] systemd[1]: Reached target Slice Units.
[    8.762492] systemd[1]: Reached target Mounting snaps.
[    8.762534] systemd[1]: Reached target Mounted snaps.
[    8.762582] systemd[1]: Reached target Swaps.
[    8.762631] systemd[1]: Reached target Local Verity Protected Volumes.
[    8.762759] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[    8.763076] systemd[1]: Listening on LVM2 poll daemon socket.
[    8.767977] systemd[1]: Listening on RPCbind Server Activation Socket.
[    8.768293] systemd[1]: Listening on Syslog Socket.
[    8.768476] systemd[1]: Listening on fsck to fsckd communication Socket.
[    8.768590] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    8.768874] systemd[1]: Listening on Journal Audit Socket.
[    8.769303] systemd[1]: Listening on Journal Socket (/dev/log).
[    8.776919] tegra194-pcie 141e0000.pcie: Phy link never came up
[    8.792358] systemd[1]: Listening on Journal Socket.
[    8.792609] systemd[1]: Listening on udev Control Socket.
[    8.792754] systemd[1]: Listening on udev Kernel Socket.
[    8.793857] systemd[1]: Mounting Huge Pages File System...
[    8.814448] systemd[1]: Mounting POSIX Message Queue File System...
[    8.815674] systemd[1]: Mounting Kernel Debug File System...
[    8.816750] systemd[1]: Mounting Kernel Trace File System...
[    8.819502] systemd[1]: Starting Journal Service...
[    8.836287] systemd[1]: Finished Availability of block devices.
[    8.838151] systemd[1]: Starting Set the console keyboard layout...
[    8.849632] systemd[1]: Starting Create List of Static Device Nodes...
[    8.850937] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[    8.852108] systemd[1]: Starting Load Kernel Module configfs...
[    8.853239] systemd[1]: Starting Load Kernel Module drm...
[    8.878082] systemd[1]: Starting Load Kernel Module efi_pstore...
[    8.879190] systemd[1]: Starting Load Kernel Module fuse...
[    8.880553] systemd[1]: Starting NVIDIA specific first-boot udev script...
[    8.881931] systemd[1]: Started Nameserver information manager.
[    8.885417] fuse: init (API version 7.34)
[    8.906037] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    8.907816] systemd[1]: Starting Load Kernel Modules...
[    8.908974] systemd[1]: Starting Remount Root and Kernel File Systems...
[    8.910353] systemd[1]: Starting Coldplug All udev Devices...
[    8.914803] EXT4-fs (nvme0n1p1): re-mounted. Opts: (null). Quota mode: none.
[    8.917698] nvsciipc: loading out-of-tree module taints kernel.
[    8.918479] nvsciipc: loaded module
[    8.923694] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    8.924094] nvmap_page_pool_init: Total RAM pages: 4008132
[    8.924096] nvmap_page_pool_init: nvmap page pool size: 501016 pages (1957 MB)
[    8.924172] nvmap_background_zero_thread: PP zeroing thread starting.
[    8.930781] tegra-host1x 13e00000.host1x: Adding to iommu group 7
[    8.931885] host1x-context host1x-ctx.0: Adding to iommu group 8
[    8.932028] host1x-context host1x-ctx.1: Adding to iommu group 9
[    8.932136] host1x-context host1x-ctx.2: Adding to iommu group 10
[    8.932253] host1x-context host1x-ctx.3: Adding to iommu group 11
[    8.932359] host1x-context host1x-ctx.4: Adding to iommu group 12
[    8.932466] host1x-context host1x-ctx.5: Adding to iommu group 13
[    8.932577] host1x-context host1x-ctx.6: Adding to iommu group 14
[    8.932681] host1x-context host1x-ctx.7: Adding to iommu group 15
[    8.932786] host1x-context host1x-ctx.8: Adding to iommu group 16
[    8.932891] host1x-context host1x-ctx.9: Adding to iommu group 17
[    8.933014] host1x-context host1x-ctx.10: Adding to iommu group 18
[    8.933137] host1x-context host1x-ctx.11: Adding to iommu group 19
[    8.933272] host1x-context host1x-ctx.12: Adding to iommu group 20
[    8.933406] host1x-context host1x-ctx.13: Adding to iommu group 21
[    8.933517] host1x-context host1x-ctx.14: Adding to iommu group 22
[    8.933629] host1x-context host1x-ctx.15: Adding to iommu group 23
[    8.941028] platform 13e00000.host1x:nvcsi@15a00000: Fixing up cyclic dependency with 10-0010
[    8.941044] platform 13e00000.host1x:nvcsi@15a00000: Fixing up cyclic dependency with 9-0010
[    8.941058] platform 13e00000.host1x:nvcsi@15a00000: Fixing up cyclic dependency with tegra-capture-vi
[    8.947724] systemd[1]: Started Journal Service.
[    8.978622] nvgpu: 17000000.gpu          nvgpu_nvhost_syncpt_init:122  [INFO]  syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[    9.141198] systemd-journald[256]: Received client request to flush runtime journal.
[    9.342218] tegra-soc-hwpm f100000.hwpm: Adding to iommu group 24
[    9.343435] mc: Linux media interface: v0.10
[    9.343677] scare-pigeon 13e00000.host1x:vi0-thi@15f00000: syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[    9.344031] scare-pigeon 13e00000.host1x:vi1-thi@14f00000: syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[    9.344314] scare-pigeon 13e00000.host1x:isp-thi@14b00000: syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[    9.351931] videodev: Linux video capture interface: v2.00
[    9.352253] nvdla 15880000.nvdla0: Adding to iommu group 25
[    9.355496] pva 16000000.pva0: Adding to iommu group 26
[    9.356604] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 27
[    9.356689] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18, iommu=smmu.0x0000000008000000)
[    9.357240] tegra-vic 15340000.vic: Adding to iommu group 28
[    9.357394] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 29
[    9.357437] nvdla 15880000.nvdla0: syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[    9.357494] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19, iommu=smmu.0x0000000008000000)
[    9.357663] nvdla 158c0000.nvdla1: Adding to iommu group 30
[    9.357885] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 31
[    9.357960] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20, iommu=smmu.0x0000000008000000)
[    9.358381] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 32
[    9.358457] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21, iommu=smmu.0x0000000008000000)
[    9.363796] nvdla 158c0000.nvdla1: syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[    9.363898] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to iommu group 33
[    9.365368] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized (streamid=22, iommu=smmu.0x0000000008000000)
[    9.366772] Inserting ivc_ext.ko module
[    9.370087] tegra-nvdec 15480000.nvdec: Adding to iommu group 34
[    9.373605] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to iommu group 35
[    9.375409] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized (streamid=23, iommu=smmu.0x0000000008000000)
[    9.390831] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to iommu group 36
[    9.391329] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized (streamid=24, iommu=smmu.0x0000000008000000)
[    9.392801] tegra-nvenc 154c0000.nvenc: Adding to iommu group 37
[    9.397876] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 38
[    9.399207] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[    9.403372] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to iommu group 39
[    9.404056] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized (streamid=25, iommu=smmu.0x0000000008000000)
[    9.404752] tegra-nvjpg 15380000.nvjpg: Adding to iommu group 40
[    9.404761] pva 16000000.pva0: pdata->version is HW_GEN2
[    9.410445] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee027f size=131712
[    9.410496] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[    9.410526] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x512]=0x1900-0x1b80 TX[1x512]=0x1b80-0x1e00
[    9.410548] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1e00-0x3e80 TX[1x8192]=0x3e80-0x5f00
[    9.410572] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5f00-0xaf80 TX[64x320]=0xaf80-0x10000
[    9.410592] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0x10000-0x18080 TX[512x64]=0x18080-0x20100
[    9.410610] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20100-0x201c0 TX[1x64]=0x201c0-0x20280
[    9.411359] pva 16000000.pva0: Completed nvhost_client_device_init
[    9.411397] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (219)
[    9.411402] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[    9.411678] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=e2238c99959d2df9350d393f04e1f44e5bef98cb
[    9.411799] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: ivc channel driver missing
[    9.411801] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: ivc channel driver missing
[    9.411803] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: ivc channel driver missing
[    9.411806] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivc channel driver missing
[    9.411805] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[    9.411808] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivc channel driver missing
[    9.411810] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: ivc channel driver missing
[    9.411819] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[    9.411820] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[    9.411823] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[    9.411825] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[    9.411826] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[    9.411828] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[    9.411830] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[    9.411832] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[    9.411841] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[    9.411842] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[    9.411844] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[    9.412160] pva 16000000.pva0: syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[    9.418084] tegra-nvjpg 15540000.nvjpg: Adding to iommu group 41
[    9.434011] tegra-ofa 15a50000.ofa: Adding to iommu group 42
[    9.435393] drm drm: [drm] Cannot find any crtc or sizes
[    9.435614] [drm] Initialized tegra 1.0.99 20120330 for drm on minor 0
[    9.452943] [RCE] TCU debug prints will be routed to traces.
[    9.482152] tegra194-vi5 13e00000.host1x:vi0@15c00000: Adding to iommu group 43
[    9.484385] tegra194-isp5 14800000.isp: Adding to iommu group 44
[    9.491584] tegra194-vi5 13e00000.host1x:vi1@14c00000: Adding to iommu group 45
[    9.491773] (NULL device *): fops function table already registered
[    9.492638] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e00000.host1x:nvcsi@15a00000- bound
[    9.492646] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e00000.host1x:nvcsi@15a00000- bound
[    9.768930] tegra194-pcie 141e0000.pcie: Phy link never came up
[    9.778406] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00
[    9.778415] pci_bus 0007:00: root bus resource [io  0x200000-0x2fffff] (bus address [0x3e100000-0x3e1fffff])
[    9.778419] pci_bus 0007:00: root bus resource [mem 0x3228000000-0x322fffffff] (bus address [0x40000000-0x47ffffff])
[    9.778422] pci_bus 0007:00: root bus resource [bus 00-ff]
[    9.778423] pci_bus 0007:00: root bus resource [mem 0x3000000000-0x3227ffffff pref]
[    9.778471] pci 0007:00:00.0: [10de:229a] type 01 class 0x060400
[    9.778626] pci 0007:00:00.0: PME# supported from D0 D3hot
[    9.785272] pci 0007:00:00.0: PCI bridge to [bus 01-ff]
[    9.785442] imx219 9-0010: tegracam sensor driver:imx219_v2.0.6
[    9.785642] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[    9.785931] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x82
[    9.786315] pcieport 0007:00:00.0: Adding to iommu group 6
[    9.786516] spi-tegra114 3210000.spi: Adding to iommu group 1
[    9.786572] tegra-dce d800000.dce: Adding to iommu group 46
[    9.787705] dce: dce_ipc_channel_init:311  Invalid Channel State [0x0] for ch_type [2]
[    9.787897] dce: tegra_dce_probe:245  Found display consumer device
[    9.788440] dce: dce_mailbox_set_full_interrupt:157  Intr bit set multiple times for MB : [0x5]
[    9.788447] dce: dce_mailbox_set_full_interrupt:157  Intr bit set multiple times for MB : [0x5]
[    9.788669] dce: dce_admin_send_cmd_ver:456  version : [0x3] err : [0x0]
[    9.788840] dce: dce_mailbox_set_full_interrupt:157  Intr bit set multiple times for MB : [0x1]
[    9.788847] dce: dce_mailbox_set_full_interrupt:157  Intr bit set multiple times for MB : [0x1]
[    9.788851] dce: dce_admin_setup_clients_ipc:585  Channel Reset Complete for Type [1] ...
[    9.788854] dce: dce_admin_setup_clients_ipc:561  Get queue info failed for [2]
[    9.789022] dce: dce_mailbox_set_full_interrupt:157  Intr bit set multiple times for MB : [0x2]
[    9.789028] dce: dce_admin_setup_clients_ipc:585  Channel Reset Complete for Type [3] ...
[    9.789939] dce: dce_start_boot_flow:166  DCE_BOOT_DONE
[    9.794177] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
[    9.794305] pcieport 0007:00:00.0: PME: Signaling with IRQ 195
[    9.795967] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[    9.796401] pcieport 0007:00:00.0: AER: enabled with IRQ 195
[    9.800768] at24 0-0050: 256 byte 24c02 EEPROM, read-only
[    9.801042] imx219 9-0010: board setup failed
[    9.801080] imx219: probe of 9-0010 failed with error -121
[    9.802776] imx219 10-0010: tegracam sensor driver:imx219_v2.0.6
[    9.804864] at24 0-0057: 256 byte 24c02 EEPROM, read-only
[    9.808001] spi-tegra114 3230000.spi: Adding to iommu group 1
[    9.810862] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[    9.811087] pci_bus 0007:01: busn_res: [bus 01-ff] is released
[    9.814081] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[    9.819171] imx219 10-0010: board setup failed
[    9.819212] imx219: probe of 10-0010 failed with error -121
[    9.819775] nv_platform 13800000.display: Adding to iommu group 47
[    9.825193] pci 0007:00:00.0: Removing from iommu group 6
[    9.825225] pci_bus 0007:00: busn_res: [bus 00-ff] is released
[    9.834489] tegra194-pcie 140a0000.pcie: Adding to iommu group 49
[    9.835108] platform 13800000.display:nvdisplay-niso: Adding to iommu group 48
[    9.843472] tegra-hda 3510000.hda: Adding to iommu group 50
[    9.844281] tegra234-aon c000000.aon: Adding to iommu group 51
[    9.846182]  c000000.aon:hsp: probed
[    9.847860] tegra234-aon c000000.aon: init done
[    9.874566] thermal-trip-event cpu-throttle-alert: cooling device registered.
[    9.878322] CAN device driver interface
[    9.883075] gic 2a41000.interrupt-controller: GIC IRQ controller registered
[    9.883340] thermal-trip-event gpu-throttle-alert: cooling device registered.
[    9.883768] tegra-aconnect bus@0:aconnect@2900000: Tegra ACONNECT bus registered
[    9.885051] thermal-trip-event cv0-throttle-alert: cooling device registered.
[    9.900999] thermal-trip-event cv1-throttle-alert: cooling device registered.
[    9.903934] TT CAN feature is not supported
[    9.905592] 	 Message RAM Configuration
               	| base addr   |0x0c312000|
               	| sidfc_flssa |0x00000000|
               	| xidfc_flesa |0x00000040|
               	| rxf0c_f0sa  |0x000000c0|
               	| rxf1c_f1sa  |0x000009c0|
               	| rxbc_rbsa   |0x000009c0|
               	| txefc_efsa  |0x000009c0|
               	| txbc_tbsa   |0x00000a40|
               	| tmc_tmsa    |0x00000ec0|
               	| mram size   |0x00001000|
[    9.906895] Release 3.2.3 from 09.06.2018
[    9.910257] thermal-trip-event cv2-throttle-alert: cooling device registered.
[    9.914659] thermal-trip-event soc0-throttle-alert: cooling device registered.
[    9.918200] net can0: mttcan device registered (regs=00000000e04c0ef3, irq=201)
[    9.919312] thermal-trip-event soc1-throttle-alert: cooling device registered.
[    9.933424] thermal-trip-event soc2-throttle-alert: cooling device registered.
[    9.942397] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=3 as /devices/platform/bus@0/3510000.hda/sound/card0/input1
[    9.949433] tegra194-pcie 140a0000.pcie: host bridge /bus@0/pcie@140a0000 ranges:
[    9.949460] tegra194-pcie 140a0000.pcie:      MEM 0x3240000000..0x3527ffffff -> 0x3240000000
[    9.949467] tegra194-pcie 140a0000.pcie:      MEM 0x3528000000..0x352fffffff -> 0x0040000000
[    9.949470] tegra194-pcie 140a0000.pcie:       IO 0x002a100000..0x002a1fffff -> 0x002a100000
[    9.949768] tegra194-pcie 140a0000.pcie: iATU unroll: enabled
[    9.949770] tegra194-pcie 140a0000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    9.954962] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=7 as /devices/platform/bus@0/3510000.hda/sound/card0/input2
[    9.956154] thermal-trip-event hot-surface-alert: cooling device registered.
[    9.956401] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=8 as /devices/platform/bus@0/3510000.hda/sound/card0/input3
[    9.981914] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=9 as /devices/platform/bus@0/3510000.hda/sound/card0/input4
[    9.986434] irq: IRQ248: trimming hierarchy from :bus@0:pmc@c360000
[    9.986933] fusb301 1-0025: device id: 0x12
[   10.018477] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   10.026876] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   10.028460] fusb301 1-0025: toggle_time(0) is not updated
[   10.028800] fusb301 1-0025: fusb301_set_mode: mode (32)(32)
[   10.030500] fusb301 1-0025: fusb301_detach: type[0x00] chipstate[0x01]
[   10.030507] fusb301 1-0025: fusb_update_state: 1
[   10.032430] fusb301 1-0025: mode[0x20], host_cur[0x02], dttime[0x00]
[   10.056931] tegra194-pcie 140a0000.pcie: Link up
[   10.058226] tegra194-pcie 140a0000.pcie: Link up
[   10.058369] tegra194-pcie 140a0000.pcie: PCI host bridge to bus 0008:00
[   10.058374] pci_bus 0008:00: root bus resource [io  0x300000-0x3fffff] (bus address [0x2a100000-0x2a1fffff])
[   10.058378] pci_bus 0008:00: root bus resource [mem 0x3528000000-0x352fffffff] (bus address [0x40000000-0x47ffffff])
[   10.058381] pci_bus 0008:00: root bus resource [bus 00-ff]
[   10.058383] pci_bus 0008:00: root bus resource [mem 0x3240000000-0x3527ffffff pref]
[   10.058430] pci 0008:00:00.0: [10de:229c] type 01 class 0x060400
[   10.058586] pci 0008:00:00.0: PME# supported from D0 D3hot
[   10.068731] pci 0008:01:00.0: [10ec:8168] type 00 class 0x020000
[   10.068892] pci 0008:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[   10.069090] pci 0008:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[   10.069206] pci 0008:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[   10.070172] pci 0008:01:00.0: supports D1 D2
[   10.070174] pci 0008:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[   10.088984] pci 0008:00:00.0: BAR 14: assigned [mem 0x3528000000-0x35280fffff]
[   10.088995] pci 0008:00:00.0: BAR 13: assigned [io  0x300000-0x300fff]
[   10.089001] pci 0008:01:00.0: BAR 4: assigned [mem 0x3528000000-0x3528003fff 64bit]
[   10.089094] pci 0008:01:00.0: BAR 2: assigned [mem 0x3528004000-0x3528004fff 64bit]
[   10.089184] pci 0008:01:00.0: BAR 0: assigned [io  0x300000-0x3000ff]
[   10.089212] pci 0008:00:00.0: PCI bridge to [bus 01-ff]
[   10.089215] pci 0008:00:00.0:   bridge window [io  0x300000-0x300fff]
[   10.089219] pci 0008:00:00.0:   bridge window [mem 0x3528000000-0x35280fffff]
[   10.091368] pcieport 0008:00:00.0: Adding to iommu group 49
[   10.092952] Bluetooth: Core ver 2.22
[   10.092992] NET: Registered PF_BLUETOOTH protocol family
[   10.092994] Bluetooth: HCI device and connection manager initialized
[   10.093003] Bluetooth: HCI socket layer initialized
[   10.093007] Bluetooth: L2CAP socket layer initialized
[   10.093015] Bluetooth: SCO socket layer initialized
[   10.095625] pcieport 0008:00:00.0: PME: Signaling with IRQ 189
[   10.098612] pcieport 0008:00:00.0: AER: enabled with IRQ 189
[   10.130801] rtl88x2ce 0001:01:00.0: Adding to iommu group 3
[   10.131989] rtl88x2ce 0001:01:00.0: enabling device (0000 -> 0003)
[   10.143473] usbcore: registered new interface driver btusb
[   10.176776] rtk_btusb: Realtek Bluetooth USB driver ver 3.1.6fd4e69.20220818-105856
[   10.176783] rtk_btcoex: rtk_btcoex_init: version: 1.2
[   10.176784] rtk_btcoex: create workqueue
[   10.176926] rtk_btcoex: alloc buffers 1792, 2432 for ev and l2
[   10.176977] rtk_btusb: btusb_probe intf->cur_altsetting->desc.bInterfaceNumber 0
[   10.176979] rtk_btusb: btusb_probe can_wakeup 1, may wakeup 0
[   10.176980] rtk_btusb: patch_add
[   10.176981] rtk_btusb: auto suspend is disabled
[   10.176982] rtk_btusb: pid = 0x3549
[   10.176983] rtk_btusb: patch_add: Reset gEVersion to 0xff
[   10.176990] rtk_btusb: set_bit(HCI_QUIRK_RESET_ON_CLOSE, &hdev->quirks);
[   10.177132] rtk_btusb: btusb_probe: done
[   10.177155] usbcore: registered new interface driver rtk_btusb
[   10.178747] rtk_btusb: btusb_open start
[   10.178752] rtk_btusb: btusb_open hdev->promisc ==0
[   10.178753] rtk_btusb: download_patch start
[   10.178754] rtk_btusb: chip type value: 0x73
[   10.180297] rtk_btusb: chip_type->status = 0x0, chip_type->chip = 0xbeef
[   10.180303] rtk_btusb: HCI reset.
[   10.191294] rtk_btusb: read_ver_rsp->lmp_subver = 0x8822
[   10.191301] rtk_btusb: read_ver_rsp->hci_rev = 0xc
[   10.191302] rtk_btusb: patch_entry->lmp_sub = 0x8822
[   10.191304] rtk_btusb: load_firmware start
[   10.191305] rtk_btusb: lmp_version = 0x8822
[   10.191306] rtk_btusb: config filename rtl8822cu_config
[   10.196882] rtk_btusb: no bdaddr file /opt/bdaddr
[   10.196888] rtk_btusb: Origin cfg len 6
[   10.196890] rtk_btusb: 55 ab 23 87 00 00
[   10.196892] rtk_btusb: New cfg len 6
[   10.196893] rtk_btusb: 55 ab 23 87 00 00
[   10.196899] rtk_btusb: fw name is  rtl8822cu_fw
[   10.201051] rtk_btusb: This is not 8723a, use new patch style!
[   10.201058] rtk_btusb: rtk_get_eversion: gEVersion 255
[   10.202290] rtk_btusb: eversion->status = 0x0, eversion->version = 0x3
[   10.202295] rtk_btusb: load_firmware: New gEVersion 3
[   10.202297] rtk_btusb: rtk_get_fw_project_id: opcode 0, len 1, data 13
[   10.202298] rtk_btusb: lmp_version is 8822, project_id is 8822, match!
[   10.202299] rtk_btusb: fw_version = 0x9a8cbc9
[   10.202300] rtk_btusb: number_of_total_patch = 3
[   10.202301] rtk_btusb: chipID 4
[   10.202301] rtk_btusb: patch_length 0x8590
[   10.202302] rtk_btusb: start_offset 0x00005d00
[   10.202302] rtk_btusb: Svn version: 1940234490
[   10.202303] rtk_btusb: Coexistence: BTCOEX_20210106-2020
[   10.202304] rtk_btusb: buf_len = 0x8596
[   10.202314] rtk_btusb: fw: exists, config file: exists
[   10.202315] rtk_btusb: load_firmware done
[   10.202328] rtk_btusb: download_data start
[   10.249604] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[   10.250795] nvvrs-pseq-rtc nvvrs-pseq-rtc: setting system clock to 2024-08-02T12:15:19 UTC (1722600919)
[   10.322959] tegra-adma 2930000.dma-controller: Tegra210 ADMA driver registered 32 channels
[   10.327870] r8168 0008:01:00.0: Adding to iommu group 49
[   10.327970] r8168 Gigabit Ethernet driver 8.051.02.10m_pll-NAPI loaded
[   10.328030] r8168 0008:01:00.0: enabling device (0000 -> 0003)
[   10.349349] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[   10.351406] r8168  Copyright (C) 2022 Realtek NIC software team <nicfae@realtek.com>
                This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
                This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[   10.375309] rtk_btusb: download_data done
[   10.375316] rtk_btusb: HCI reset.
[   10.386287] rtk_btusb: read_ver_rsp->lmp_subver = 0xcbc9
[   10.386293] rtk_btusb: read_ver_rsp->hci_rev = 0x9a8
[   10.386295] rtk_btusb: patch_entry->lmp_sub = 0x8822
[   10.386300] rtk_btusb: Rtk patch end 0
[   10.386302] rtk_btusb: btusb_open set HCI UP RUNNING
[   10.386324] rtk_btcoex: Open BTCOEX
[   10.386328] rtk_btcoex: rtk_vendor_cmd_to_fw: opcode 0xfc1b
[   10.386334] rtk_btusb: btusb_open end
[   10.387299] rtk_btcoex: unknown hci command
[   10.389300] rtk_btcoex: BTCOEX hci_rev 0x09a8
[   10.389303] rtk_btcoex: BTCOEX lmp_subver 0xcbc9
[   10.409294] rtk_btusb: btusb_notify: hci0 evt 3
[   10.440310] tegra210-admaif 290f000.admaif: Adding to iommu group 52
[   10.766109] using random self ethernet address
[   10.766114] using random host ethernet address
[   10.858381] loop0: detected capacity change from 0 to 32768
[   10.924544] nv_nvsciipc_init.sh[637]: found /dev/nvsciipc
[   10.959172] nvsciipc: set_db start
[   10.959198] nvsciipc: set_db done
[   10.984300] NET: Registered PF_ALG protocol family
[   11.117167] Mass Storage Function, version: 2009/09/11
[   11.117174] LUN: removable file: (no medium)
[   11.133615] using random self ethernet address
[   11.133622] using random host ethernet address
[   11.157808] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[   11.161194] usb0: HOST MAC 06:bf:1e:f4:7f:b4
[   11.161199] usb0: MAC 06:bf:1e:f4:7f:b5
[   11.161544] usb1: HOST MAC 06:bf:1e:f4:7f:b6
[   11.161548] usb1: MAC 06:bf:1e:f4:7f:b7
[   11.168150] tegra-xudc 3550000.usb: EP 0 (type: ctrl, dir: out) enabled
[   11.174409] l4tbr0: port 1(usb0) entered blocking state
[   11.174426] l4tbr0: port 1(usb0) entered disabled state
[   11.174603] device usb0 entered promiscuous mode
[   11.180403] l4tbr0: port 2(usb1) entered blocking state
[   11.180418] l4tbr0: port 2(usb1) entered disabled state
[   11.180567] device usb1 entered promiscuous mode
[   11.198543] eth0: 0xffff800008f25000, 48:b0:2d:eb:3b:d9, IRQ 282
[   11.218201] loop0: detected capacity change from 0 to 32768
[   11.921157] loop1: detected capacity change from 0 to 8
[   13.065239] pstore: Using crash dump compression: deflate
[   13.065321] printk: console [ramoops-1]: printing thread started
[   13.065337] printk: console [ramoops-1] enabled
[   13.065339] pstore: Registered ramoops as persistent store backend
[   13.065340] ramoops: using 0x200000@0x4725f0000, ecc: 0
[   13.258510] nvgpu: 17000000.gpu                  gk20a_scale_init:541  [INFO]  enabled scaling for GPU
[   13.313285] zram: Added device: zram0
[   13.313458] zram: Added device: zram1
[   13.318540] zram: Added device: zram2
[   13.322769] zram: Added device: zram3
[   13.323339] zram: Added device: zram4
[   13.323512] zram: Added device: zram5
[   13.323945] zram: Added device: zram6
[   13.324092] zram: Added device: zram7
[   13.367013] zram0: detected capacity change from 0 to 2004072
[   13.373552] nvgpu: 17000000.gpu             railgate_enable_store:365  [INFO]  railgate is disabled.
[   13.373814] Adding 1002032k swap on /dev/zram0.  Priority:5 extents:1 across:1002032k SS
[   13.376011] zram1: detected capacity change from 0 to 2004072
[   13.381419] Adding 1002032k swap on /dev/zram1.  Priority:5 extents:1 across:1002032k SS
[   13.385106] zram2: detected capacity change from 0 to 2004072
[   13.390144] Adding 1002032k swap on /dev/zram2.  Priority:5 extents:1 across:1002032k SS
[   13.391599] zram3: detected capacity change from 0 to 2004072
[   13.396657] Adding 1002032k swap on /dev/zram3.  Priority:5 extents:1 across:1002032k SS
[   13.398454] zram4: detected capacity change from 0 to 2004072
[   13.403706] Adding 1002032k swap on /dev/zram4.  Priority:5 extents:1 across:1002032k SS
[   13.405381] zram5: detected capacity change from 0 to 2004072
[   13.414575] Adding 1002032k swap on /dev/zram5.  Priority:5 extents:1 across:1002032k SS
[   13.416187] zram6: detected capacity change from 0 to 2004072
[   13.424686] Adding 1002032k swap on /dev/zram6.  Priority:5 extents:1 across:1002032k SS
[   13.429787] zram7: detected capacity change from 0 to 2004072
[   13.436790] Adding 1002032k swap on /dev/zram7.  Priority:5 extents:1 across:1002032k SS
[   14.291104] Bridge firewalling registered
[   15.320619] nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for aarch64  540.3.0  Release Build  (root@buildmachine)  Wed Jun  5 07:52:01 UTC 2024
[   16.038584] ACK 04 d4
[   16.040496] ACK 04 d4
[   16.067018] ACK 04 d4
[   16.281525] ACK 04 d4
[   16.525524] ACK 04 d4
[   16.769538] ACK 04 d4
[   17.013603] ACK 04 d4
[   21.306194] ACK 04 d4
[   21.320148] ACK 04 d4
[   21.354476] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   27.140768] rfkill: input handler disabled
[   28.669672] loop1: detected capacity change from 0 to 8
[   37.453052] loop1: detected capacity change from 0 to 8
[   46.173894] ACK 04 d4
[   46.175961] ACK 04 d4
This case is with a custom kernel, give me 1 minute and I send you the dmesg with the original rootfs flashed.
Please attach them as files. Do not just copy and paste if you want to upload multiple logs.
OK.
Here it is.
dmesg.txt (59.3 KB)
This is clean system (original sample rootfs), flashed on Orin NX 16GB.
Will your Jetson dmesg get anything printed when you hotplug the type C cable?
nop, neither on the jetson dmesg neither on the PC dmesg.
But when I plug a USB drive with a USB-C adapter, the USB drive is recognized correctly, even without stopping nv-l4t-usb-device-mode service.
It’s as if it was in host mode all the time.
I know the cable is OK, since I use it to flash the Orin NX, and device mode is working with another jetson.
Could you flash your whole board with jetpack5.1.3 and do the test again?
OK I can, it will take a while. I’ll let you know the result.
I’ll have to do it manually since SDK Manager requires Ubuntu 18 or 20 for JP 5.1.3.
Thanks for your patience…
USB device mode works succesfully with 5.1.3…
wget https://developer.nvidia.com/downloads/embedded/l4t/r35_release_v5.0/release/Jetson_Linux_R35.5.0_aarch64.tbz2
wget https://developer.nvidia.com/downloads/embedded/l4t/r35_release_v5.0/release/Tegra_Linux_Sample-Root-Filesystem_R35.5.0_aarch64.tbz2
mkdir Linux_for_Tegra.513
tar xvf Jetson_Linux_R35.5.0_aarch64.tbz2 --strip-components=1 -C Linux_for_Tegra.513
sudo tar xvpf Tegra_Linux_Sample-Root-Filesystem_R35.5.0_aarch64.tbz2 -C Linux_for_Tegra.513/rootfs/
cd Linux_for_Tegra.513/
sudo ./apply_binaries.sh
sudo ./tools/l4t_create_default_user.sh -u jetson -p jetson -n jetson -a --accept-license
sudo ./tools/kernel_flash/l4t_initrd_flash.sh \
    --external-device nvme0n1p1 \
    -p "-c ./bootloader/t186ref/cfg/flash_t234_qspi.xml" \
    -c ./tools/kernel_flash/flash_l4t_t234_nvme.xml \
    --showlogs \
    --network usb0 \
    jetson-orin-nano-devkit \
    nvme0n1p1
Let me try the same commands for 6.0, just to confirm it works or not…
This makes me crazy… I flashed with JP 6.0 and USB device mode is working back!
Then I switched the NVMe with the one where it didn’t work (where I have all my development environment). And it’s working back too with that untouched NVMe.
I have no idea what could have happened, I even didn’t touch the USB cable, as if the flashing of 5.1.3 did something…
