Hello, I am having an issue with the USB 3.2 ports on the Orin Nano Dev Kit. I am connecting a device that uses the Cypress/Infineon FX3 USB 3.0 controller. The issue that I am having is that the FX3 device is not found by the Orin nano on power up or reboot. If I plug in the FX3 device after boot up the device is found and everything works well from there. If I have the FX3 device plugged in at boot up I need to unplug and replug the Fx3 device for it to be found by the Orin nano.
When I reboot the Orin with the FX3 device plugged in I do see errors related to the USB in dmesg, however, I don’t know what the error messages mean. I was not expecting these errors as this FX3 device works fine on x86 and on the Jetson Tx2.
dmesg with the FX3 device plugged in at reboot
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.10.120-tegra (buildbrain@mobile-u64-6422-d7000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Tue Aug 1 12:32:50 PDT 2023
[ 0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[ 0.000000] OF: fdt: - 80000000 , c0000000
[ 0.000000] Machine model: NVIDIA Orin Nano Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x20b5bd598 SMBIOS=0xffff0000 SMBIOS 3.0=0x20a520000 MEMATTR=0x20a955018 ESRT=0x20a9b9098 RNG=0x22dd3dd18 MEMRESERVE=0x20a957f18
[ 0.000000] efi: seeding entropy pool
[ 0.000000] esrt: Reserving ESRT space from 0x000000020a9b9098 to 0x000000020a9b90d0.
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000021dc00000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000000237ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x0000000207e7afff]
[ 0.000000] node 0: [mem 0x0000000207e7b000-0x000000020a1bffff]
[ 0.000000] node 0: [mem 0x000000020a1c0000-0x000000020a50ffff]
[ 0.000000] node 0: [mem 0x000000020a510000-0x000000020a52ffff]
[ 0.000000] node 0: [mem 0x000000020a530000-0x000000020a77ffff]
[ 0.000000] node 0: [mem 0x000000020a780000-0x000000020a7cffff]
[ 0.000000] node 0: [mem 0x000000020a7d0000-0x000000020a8bffff]
[ 0.000000] node 0: [mem 0x000000020a8c0000-0x000000020a90ffff]
[ 0.000000] node 0: [mem 0x000000020a910000-0x000000020a95ffff]
[ 0.000000] node 0: [mem 0x000000020a960000-0x000000020a9affff]
[ 0.000000] node 0: [mem 0x000000020a9b0000-0x000000020aaeffff]
[ 0.000000] node 0: [mem 0x000000020aaf0000-0x000000020afeffff]
[ 0.000000] node 0: [mem 0x000000020aff0000-0x000000020b57ffff]
[ 0.000000] node 0: [mem 0x000000020b580000-0x000000020b58ffff]
[ 0.000000] node 0: [mem 0x000000020b590000-0x000000020b6affff]
[ 0.000000] node 0: [mem 0x000000020b6b0000-0x000000020b74ffff]
[ 0.000000] node 0: [mem 0x000000020b750000-0x000000020b84ffff]
[ 0.000000] node 0: [mem 0x000000020b850000-0x000000020b8effff]
[ 0.000000] node 0: [mem 0x000000020b8f0000-0x000000020b9effff]
[ 0.000000] node 0: [mem 0x000000020b9f0000-0x000000020ba8ffff]
[ 0.000000] node 0: [mem 0x000000020ba90000-0x000000020c35ffff]
[ 0.000000] node 0: [mem 0x000000020c360000-0x000000020c53ffff]
[ 0.000000] node 0: [mem 0x000000020c540000-0x000000022dceffff]
[ 0.000000] node 0: [mem 0x000000022dcf0000-0x000000022dd3ffff]
[ 0.000000] node 0: [mem 0x000000022dd40000-0x00000002317fffff]
[ 0.000000] node 0: [mem 0x0000000231a00000-0x0000000231e0ffff]
[ 0.000000] node 0: [mem 0x0000000236000000-0x0000000237ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000237ffffff]
[ 0.000000] On node 0 totalpages: 1784848
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 524288 pages, LIFO batch:63
[ 0.000000] Normal zone: 19968 pages used for memmap
[ 0.000000] Normal zone: 1260560 pages, LIFO batch:63
[ 0.000000] On node 0, zone Normal: 496 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 32 pages/cpu s90328 r8192 d32552 u131072
[ 0.000000] pcpu-alloc: s90328 r8192 d32552 u131072 alloc=32*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1756688
[ 0.000000] Kernel command line: root=/dev/mmcblk1p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000effe0000-0x00000000fffe0000] (256MB)
[ 0.000000] Memory: 6360408K/7139392K available (18560K kernel code, 3166K rwdata, 7196K rodata, 3968K init, 1416K bss, 516840K reserved, 262144K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[ 0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000641] Console: colour dummy device 80x25
[ 0.000684] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.000694] pid_max: default: 32768 minimum: 301
[ 0.000788] LSM: Security Framework initializing
[ 0.000815] Yama: becoming mindful.
[ 0.000836] SELinux: Initializing.
[ 0.000924] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.000938] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.002036] rcu: Hierarchical SRCU implementation.
[ 0.002124] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.002516] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t23x/p3768/kernel-dts/tegra234-p3767-0003-p3768-0000-a0.dts
[ 0.002519] DTB Build time: Aug 1 2023 12:44:16
[ 0.003726] Tegra Revision: A01 SKU: 0xd5 CPU Process: 0 SoC Process: 0
[ 0.003930] Remapping and enabling EFI services.
[ 0.005107] smp: Bringing up secondary CPUs …
[ 0.033794] Detected PIPT I-cache on CPU1
[ 0.033829] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.033857] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.062502] Detected PIPT I-cache on CPU2
[ 0.062512] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.062526] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.091128] Detected PIPT I-cache on CPU3
[ 0.091137] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.091149] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.122412] Detected PIPT I-cache on CPU4
[ 0.122440] GICv3: CPU4: found redistributor 20200 region 0:0x000000000f580000
[ 0.122469] CPU4: Booted secondary processor 0x0000020200 [0x410fd421]
[ 0.151785] Detected PIPT I-cache on CPU5
[ 0.151797] GICv3: CPU5: found redistributor 20300 region 0:0x000000000f5a0000
[ 0.151813] CPU5: Booted secondary processor 0x0000020300 [0x410fd421]
[ 0.151878] smp: Brought up 1 node, 6 CPUs
[ 0.151892] SMP: Total of 6 processors activated.
[ 0.151896] CPU features: detected: Privileged Access Never
[ 0.151897] CPU features: detected: LSE atomic instructions
[ 0.151899] CPU features: detected: User Access Override
[ 0.151901] CPU features: detected: 32-bit EL0 Support
[ 0.151904] CPU features: detected: Common not Private translations
[ 0.151906] CPU features: detected: RAS Extension Support
[ 0.151908] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.151910] CPU features: detected: CRC32 instructions
[ 0.151912] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.171751] spectre-bhb mitigation disabled by command line option
[ 0.171752] spectre-bhb mitigation disabled by command line option
[ 0.190221] CPU: All CPU(s) started at EL2
[ 0.191967] devtmpfs: initialized
[ 0.211500] Registered cp15_barrier emulation handler
[ 0.211508] Registered setend emulation handler
[ 0.211513] KASLR enabled
[ 0.211646] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.211658] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.213586] pinctrl core: initialized pinctrl subsystem
[ 0.214088] SMBIOS 3.0.0 present.
[ 0.214097] DMI: Unknown NVIDIA Orin NX Developer Kit/NVIDIA Orin NX Developer Kit, BIOS 3.0-32616947 02/21/2023
[ 0.214455] NET: Registered protocol family 16
[ 0.215403] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.215468] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.215524] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.215549] audit: initializing netlink subsys (disabled)
[ 0.215642] audit: type=2000 audit(0.212:1): state=initialized audit_enabled=0 res=1
[ 0.215846] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.215849] thermal_sys: Registered thermal governor ‘power_allocator’
[ 0.215853] thermal_sys: Registered thermal governor ‘pid_thermal_gov’
[ 0.216772] cpuidle: using governor menu
[ 0.216899] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.216972] ASID allocator initialised with 32768 entries
[ 0.217078] Serial: AMBA PL011 UART driver
[ 0.219109] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[ 0.219133] Tegra reboot handler registered.
[ 0.242064] mc: mapped MMIO address: 0xffff8000107b0000 → 0x2c10000
[ 0.242078] mc: mapped MMIO address: 0xffff8000107d0000 → 0x2c20000
[ 0.242087] mc: mapped MMIO address: 0xffff8000107f0000 → 0x2c30000
[ 0.242094] mc: mapped MMIO address: 0xffff800010810000 → 0x2c40000
[ 0.242100] mc: mapped MMIO address: 0xffff800010830000 → 0x2c50000
[ 0.242107] mc: mapped MMIO address: 0xffff800010850000 → 0x2b80000
[ 0.242113] mc: mapped MMIO address: 0xffff800010870000 → 0x2b90000
[ 0.242119] mc: mapped MMIO address: 0xffff800010890000 → 0x2ba0000
[ 0.242125] mc: mapped MMIO address: 0xffff8000108b0000 → 0x2bb0000
[ 0.242132] mc: mapped MMIO address: 0xffff8000108d0000 → 0x1700000
[ 0.242138] mc: mapped MMIO address: 0xffff8000108f0000 → 0x1710000
[ 0.242145] mc: mapped MMIO address: 0xffff800010910000 → 0x1720000
[ 0.242151] mc: mapped MMIO address: 0xffff800010930000 → 0x1730000
[ 0.242157] mc: mapped MMIO address: 0xffff800010950000 → 0x1740000
[ 0.242165] mc: mapped MMIO address: 0xffff800010970000 → 0x1750000
[ 0.242171] mc: mapped MMIO address: 0xffff800010990000 → 0x1760000
[ 0.242177] mc: mapped MMIO address: 0xffff8000109b0000 → 0x1770000
[ 0.242185] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.242221] mc-err: mcerr ops are set to t23x
[ 0.242964] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 65, base_baud = 0) is a SBSA
[ 1.350078] printk: console [ttyAMA0] enabled
[ 1.359181] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 1.365890] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 1.372590] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 1.379288] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 1.387986] ACPI: Interpreter disabled.
[ 1.392301] ddr-vddq: supplied by vdd-5v
[ 1.396411] ddr-vdd2: supplied by vdd-5v
[ 1.400456] vdd-AO-1v2: supplied by vdd-5v
[ 1.404685] vdd-3v3: supplied by vdd-5v
[ 1.408670] vdd-rtc: supplied by vdd-AO-1v2
[ 1.412992] vdd-0v95-uphy: supplied by vdd-AO-1v2
[ 1.417812] vdd-0v95-hdmi: supplied by vdd-AO-1v2
[ 1.422802] vdd-1v8: supplied by vdd-3v3-sys
[ 1.427190] vdd-3v3-AO: supplied by vdd-5v-sys
[ 1.431773] vdd-av10-hub: supplied by vdd-5v-sys
[ 1.436503] vdd-vbus-a: supplied by vdd-5v-sys
[ 1.441084] vdd-vbus-b: supplied by vdd-5v-sys
[ 1.445644] vdd-3v3-dp: supplied by vdd-3v3-sys
[ 1.450514] iommu: Default domain type: Translated
[ 1.455429] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.461730] SCSI subsystem initialized
[ 1.465582] usbcore: registered new interface driver usbfs
[ 1.471083] usbcore: registered new interface driver hub
[ 1.476403] usbcore: registered new device driver usb
[ 1.481665] mc: Linux media interface: v0.10
[ 1.485943] videodev: Linux video capture interface: v2.00
[ 1.491589] pps_core: LinuxPPS API ver. 1 registered
[ 1.496552] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 1.505693] PTP clock support registered
[ 1.509866] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.517024] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[ 1.524716] Registered efivars operations
[ 1.529287] FPGA manager framework
[ 1.532724] Advanced Linux Sound Architecture Driver Initialized.
[ 1.539107] Bluetooth: Core ver 2.22
[ 1.542688] NET: Registered protocol family 31
[ 1.547130] Bluetooth: HCI device and connection manager initialized
[ 1.553486] Bluetooth: HCI socket layer initialized
[ 1.558364] Bluetooth: L2CAP socket layer initialized
[ 1.563420] Bluetooth: SCO socket layer initialized
[ 1.568851] camchar: rtcpu character device driver loaded
[ 1.574497] clocksource: Switched to clocksource arch_sys_counter
[ 1.783960] VFS: Disk quotas dquot_6.6.0
[ 1.787934] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.795105] pnp: PnP ACPI: disabled
[ 1.801003] la/ptsa driver initialized.
[ 1.804918] NET: Registered protocol family 2
[ 1.809424] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 1.818474] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 1.827016] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 1.835006] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 1.842996] TCP: Hash tables configured (established 65536 bind 65536)
[ 1.849599] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 1.856414] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 1.863721] NET: Registered protocol family 1
[ 1.868298] RPC: Registered named UNIX socket transport module.
[ 1.874223] RPC: Registered udp transport module.
[ 1.878936] RPC: Registered tcp transport module.
[ 1.883638] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.890082] PCI: CLS 0 bytes, default 64
[ 1.894131] Trying to unpack rootfs image as initramfs…
[ 2.061813] Freeing initrd memory: 9552K
[ 2.067867] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 2.075832] kvm [1]: IPA Size Limit: 48 bits
[ 2.080119] kvm [1]: GICv3: no GICV resource entry
[ 2.084909] kvm [1]: disabling GICv2 emulation
[ 2.089364] kvm [1]: GIC system register CPU interface enabled
[ 2.095262] kvm [1]: vgic interrupt IRQ9
[ 2.099290] kvm [1]: VHE mode initialized successfully
[ 2.105128] Initialise system trusted keyrings
[ 2.109663] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 2.118893] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.125081] NFS: Registering the id_resolver key type
[ 2.130161] Key type id_resolver registered
[ 2.134343] Key type id_legacy registered
[ 2.138393] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 2.145100] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 2.152507] ntfs: driver 2.1.32 [Flags: R/W].
[ 2.172037] NET: Registered protocol family 38
[ 2.176482] Key type asymmetric registered
[ 2.180577] Asymmetric key parser ‘x509’ registered
[ 2.185475] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 239)
[ 2.192933] io scheduler mq-deadline registered
[ 2.197467] io scheduler kyber registered
[ 2.205840] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 2.211444] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 2.217032] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 2.222619] tegra-pwm 32e0000.pwm: PWM clk can sleep in ops
[ 2.229093] efifb: probing for efifb
[ 2.232716] efifb: framebuffer at 0x208000000, using 9600k, total 9600k
[ 2.239331] efifb: mode is 1920x1200x32, linelength=8192, pages=1
[ 2.245422] efifb: scrolling: redraw
[ 2.248996] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 2.258727] Console: switching to colour frame buffer device 240x75
[ 2.268903] fb0: EFI VGA frame buffer device
[ 2.275158] tegra_dc_assign_hw_data: no matching compatible node
[ 2.281165] tegradccommon module_init failed
[ 2.285436] tegradc module_init failed
[ 2.289477] EINJ: ACPI disabled.
[ 2.294485] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 2.301371] tegra-pmc: ### PMC reset source: MAINSWRST
[ 2.306507] tegra-pmc: ### PMC reset level: L1
[ 2.310948] tegra-pmc: ### PMC reset status reg: 0x2d
[ 2.317423] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 3.898820] printk: console [ttyTCU0] enabled
[ 3.903893] arm-smmu 12000000.iommu: probing hardware configuration…
[ 3.910597] arm-smmu 12000000.iommu: SMMUv2 with:
[ 3.915416] arm-smmu 12000000.iommu: stage 1 translation
[ 3.920954] arm-smmu 12000000.iommu: stage 2 translation
[ 3.926493] arm-smmu 12000000.iommu: nested translation
[ 3.931942] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 3.939348] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 3.948741] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 3.955439] arm-smmu 12000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 3.962132] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 3.969683] arm-smmu 10000000.iommu: probing hardware configuration…
[ 3.976382] arm-smmu 10000000.iommu: SMMUv2 with:
[ 3.981206] arm-smmu 10000000.iommu: stage 1 translation
[ 3.986736] arm-smmu 10000000.iommu: stage 2 translation
[ 3.992276] arm-smmu 10000000.iommu: nested translation
[ 3.997725] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 4.005131] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 4.014464] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 4.021160] arm-smmu 10000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 4.027849] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 4.035020] arm-smmu 8000000.iommu: probing hardware configuration…
[ 4.041628] arm-smmu 8000000.iommu: SMMUv2 with:
[ 4.046359] arm-smmu 8000000.iommu: stage 1 translation
[ 4.051805] arm-smmu 8000000.iommu: stage 2 translation
[ 4.057253] arm-smmu 8000000.iommu: nested translation
[ 4.062610] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 4.069929] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 4.079168] arm-smmu 8000000.iommu: Supported page sizes: 0x00001000
[ 4.085775] arm-smmu 8000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 4.092377] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 4.099695] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 4.109494] tegra_profiler: version: 1.151, samples/io: 51/30
[ 4.115483] tegra_profiler: auth: init
[ 4.119651] nvsciipc: loaded module
[ 4.125037] tun: Universal TUN/TAP device driver, 1.6
[ 4.130738] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 4.138146] hns3: Copyright (c) 2017 Huawei Corporation.
[ 4.143617] e1000e: Intel(R) PRO/1000 Network Driver
[ 4.148706] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.154794] igb: Intel(R) Gigabit Ethernet Network Driver
[ 4.160324] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.166228] PPP generic driver version 2.4.2
[ 4.170664] PPP BSD Compression module registered
[ 4.175496] PPP Deflate Compression module registered
[ 4.180694] PPP MPPE Compression module registered
[ 4.185643] usbcore: registered new interface driver r8152
[ 4.191283] usbcore: registered new interface driver asix
[ 4.196826] usbcore: registered new interface driver ax88179_178a
[ 4.203095] usbcore: registered new interface driver cdc_ether
[ 4.209090] usbcore: registered new interface driver net1080
[ 4.214917] usbcore: registered new interface driver cdc_subset
[ 4.220995] usbcore: registered new interface driver zaurus
[ 4.226732] usbcore: registered new interface driver cdc_ncm
[ 4.232546] usbcore: registered new interface driver aqc111
[ 4.238405] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 4.244763] ohci-pci: OHCI PCI platform driver
[ 4.249344] ohci-platform: OHCI generic platform driver
[ 4.255081] tegra-xusb 3610000.xhci: Adding to iommu group 0
[ 4.261471] usbcore: registered new interface driver uas
[ 4.266954] usbcore: registered new interface driver usb-storage
[ 4.273281] tegra-xudc 3550000.xudc: Adding to iommu group 1
[ 4.279377] mousedev: PS/2 mouse device common for all mice
[ 4.285129] usbcore: registered new interface driver xpad
[ 4.292567] tegra_rtc c2a0000.rtc: registered as rtc1
[ 4.298052] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:31 UTC (31)
[ 4.306280] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.312678] i2c /dev entries driver
[ 4.316384] tegra-i2c 3160000.i2c: Adding to iommu group 2
[ 4.322188] tegra-i2c c240000.i2c: Adding to iommu group 2
[ 4.327873] tegra-i2c 3180000.i2c: Adding to iommu group 2
[ 4.333556] tegra-i2c 3190000.i2c: Adding to iommu group 2
[ 4.339266] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[ 4.344955] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[ 4.350637] tegra-i2c c250000.i2c: Adding to iommu group 2
[ 4.356316] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[ 4.366016] device-mapper: uevent: version 1.0.3
[ 4.370856] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 4.380593] sdhci: Secure Digital Host Controller Interface driver
[ 4.386940] sdhci: Copyright(c) Pierre Ossman
[ 4.391406] Synopsys Designware Multimedia Card Interface Driver
[ 4.397657] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.403847] sdhci-tegra 3400000.sdhci: Adding to iommu group 3
[ 4.404109] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[ 4.417216] tegra-bpmp bpmp: firmware: f0fadc45ec6216cb5b0b-1377b684fe5
[ 4.426022] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[ 4.431666] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x82
[ 4.441507] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[ 4.447437] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
[ 5.537634] hid: raw HID events driver (C) Jiri Kosina
[ 5.543535] usbcore: registered new interface driver usbhid
[ 5.549265] usbhid: USB HID core driver
[ 5.553714] tegra-dce d800000.dce: Adding to iommu group 4
[ 5.561408] dce: dce_ipc_channel_init:319 Invalid Channel State [0x0] for ch_type [2]
[ 5.570364] tegra234-aon c000000.aon: Adding to iommu group 5
[ 5.576809] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x5]
[ 5.583322] c000000.aon:hsp: probed
[ 5.585971] dce: dce_admin_send_cmd_ver:424 version : [0x2] err : [0x0]
[ 5.596337] tegra234-aon c000000.aon: init done
[ 5.596729] tegra23x-psc e860000.psc: Adding to iommu group 6
[ 5.601132] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x1]
[ 5.607279] tegra23x-psc e860000.psc: ext_cfg base:(ptrval)
[ 5.615861] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [1] …
[ 5.622276] tegra23x-psc e860000.psc: init done
[ 5.622517] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 7
[ 5.630687] dce: dce_admin_setup_clients_ipc:529 Get queue info failed for [2]
[ 5.636027] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 5.642079] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x2]
[ 5.666782] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [3] …
[ 5.675433] dce: dce_start_boot_flow:173 DCE_BOOT_DONE
[ 5.682096] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 5.691279] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 5.702715] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 5.714280] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 5.726007] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[ 5.738568] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[ 5.751385] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 5.763841] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (113)
[ 5.770641] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 5.779204] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=0b67520f597ddc6db82218e87c6c6eb8979fd4bb
[ 5.792692] t19x_cache tegra-cache: probed
[ 5.797124] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[ 5.807991] optee: probing for conduit method.
[ 5.812591] optee: revision 3.19 (3f29c61f)
[ 5.813361] optee: dynamic shared memory is enabled
[ 5.822797] optee: initialized driver
[ 5.838081] nvpmodel: initialized successfully
[ 5.842752] tegra_hv: get_hvd: not initialized yet
[ 5.847689] user_ivc_mempool: hypervisor not present
[ 5.853600] usbcore: registered new interface driver snd-usb-audio
[ 5.860806] u32 classifier
[ 5.863591] input device check on
[ 5.867352] Actions configured
[ 5.871003] Initializing XFRM netlink socket
[ 5.875891] NET: Registered protocol family 10
[ 5.881949] Segment Routing with IPv6
[ 5.885767] NET: Registered protocol family 17
[ 5.890353] NET: Registered protocol family 15
[ 5.894969] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 5.908885] Bluetooth: RFCOMM socket layer initialized
[ 5.914196] Bluetooth: RFCOMM ver 1.11
[ 5.918057] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 5.924137] Bluetooth: HIDP socket layer initialized
[ 5.929721] 9pnet: Installing 9P2000 support
[ 5.934176] Key type dns_resolver registered
[ 5.939319] registered taskstats version 1
[ 5.943550] Loading compiled-in X.509 certificates
[ 5.958830] Loaded X.509 cert ‘Build time autogenerated kernel key: d94b64a20d69a5a32183bad4f211c4cae67041a9’
[ 5.969411] tegra194-pcie 14100000.pcie: Adding to iommu group 8
[ 5.983799] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 5.991200] tegra194-pcie 14160000.pcie: Adding to iommu group 9
[ 6.004864] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 6.011712] tegra194-pcie 141e0000.pcie: Adding to iommu group 10
[ 6.025132] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[ 6.031890] tegra194-pcie 140a0000.pcie: Adding to iommu group 11
[ 6.045390] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[ 6.052579] tegra194-pcie 140a0000.pcie: Failed to get slot regulators: -517
[ 6.079717] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 12
[ 6.089791] host1x 13e40000.host1x: Adding to iommu group 13
[ 6.121833] host1x 13e40000.host1x: initialized
[ 6.126894] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 14
[ 6.134947] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[ 6.147246] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 15
[ 6.155257] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[ 6.167561] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 16
[ 6.175544] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[ 6.187842] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 17
[ 6.195852] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[ 6.208116] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 18
[ 6.216096] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[ 6.228374] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 19
[ 6.236371] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[ 6.248637] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 20
[ 6.256624] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[ 6.268894] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 21
[ 6.276878] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[ 6.289160] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 22
[ 6.297153] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[ 6.309438] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 23
[ 6.317426] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[ 6.329709] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 24
[ 6.337723] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[ 6.349982] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 25
[ 6.357973] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[ 6.370242] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 26
[ 6.378212] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[ 6.390506] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 27
[ 6.398479] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[ 6.410741] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 28
[ 6.418725] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[ 6.431014] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 29
[ 6.438990] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[ 6.451293] falcon 15340000.vic: Adding to iommu group 30
[ 6.462021] falcon 15340000.vic: initialized
[ 6.466787] falcon 15380000.nvjpg: Adding to iommu group 31
[ 6.475903] falcon 15380000.nvjpg: initialized
[ 6.480607] falcon 15540000.nvjpg1: Adding to iommu group 32
[ 6.490048] falcon 15540000.nvjpg1: initialized
[ 6.494853] falcon 154c0000.nvenc: Adding to iommu group 33
[ 6.504766] falcon 154c0000.nvenc: _opp_is_duplicate: duplicate OPPs detected. Existing: freq: 115200000, volt: 0, enabled: 1. New: freq: 115200000, volt: 0, enabled: 1
[ 6.520776] falcon 154c0000.nvenc: initialized
[ 6.525491] falcon 15a50000.ofa: Adding to iommu group 34
[ 6.534058] falcon 15a50000.ofa: initialized
[ 6.538608] nvdec 15480000.nvdec: Adding to iommu group 35
[ 6.551225] nvdec 15480000.nvdec: initialized
[ 6.555856] tsec 15500000.tsec: Adding to iommu group 36
[ 6.566098] tsec 15500000.tsec: initialized
[ 6.573832] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 6.591589] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 6.608488] gpio-397 (camera-control-output-low): hogged as output/low
[ 6.615239] gpio-486 (camera-control-output-low): hogged as output/low
[ 6.623027] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[ 6.630399] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[ 6.637389] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 6.643893] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 6.650414] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 6.656749] tegra-pwm 32e0000.pwm: PWM clk can sleep in ops
[ 6.665251] tegra194-isp5 14800000.isp: Adding to iommu group 37
[ 6.673497] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 6.683113] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[ 6.689571] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 6.698788] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 6.708185] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 38
[ 6.716270] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 39
[ 6.724230] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
[ 6.734191] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[ 6.740994] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
[ 6.750971] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[ 6.757757] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[ 6.767714] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[ 6.774550] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 40
[ 6.783207] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18, iommu=smmu.0x0000000008000000)
[ 6.794586] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 41
[ 6.803208] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19, iommu=smmu.0x0000000008000000)
[ 6.814570] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 42
[ 6.823179] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20, iommu=smmu.0x0000000008000000)
[ 6.834579] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 43
[ 6.843179] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21, iommu=smmu.0x0000000008000000)
[ 6.854564] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to iommu group 44
[ 6.863209] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized (streamid=22, iommu=smmu.0x0000000008000000)
[ 6.874590] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to iommu group 45
[ 6.883189] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized (streamid=23, iommu=smmu.0x0000000008000000)
[ 6.894552] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to iommu group 46
[ 6.903152] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized (streamid=24, iommu=smmu.0x0000000008000000)
[ 6.914528] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to iommu group 47
[ 6.923140] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized (streamid=25, iommu=smmu.0x0000000008000000)
[ 6.934523] pva 16000000.pva0: Adding to iommu group 48
[ 6.940332] nvdla 15880000.nvdla0: Adding to iommu group 49
[ 6.946501] nvdla 158c0000.nvdla1: Adding to iommu group 50
[ 6.952657] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 2
[ 6.959872] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[ 6.967419] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 6.974037] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 6.980752] serial-tegra 3100000.serial: Adding to iommu group 2
[ 6.987370] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 17, base_baud = 0) is a TEGRA_UART
[ 6.997149] serial-tegra 3130000.serial: Adding to iommu group 2
[ 7.003718] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 63, base_baud = 0) is a TEGRA_UART
[ 7.013382] serial-tegra 3140000.serial: Adding to iommu group 2
[ 7.019894] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 7.046782] tegra-xusb 3610000.xhci: Firmware timestamp: 2021-12-01 05:27:10 UTC, Version: 80.03 release
[ 7.056533] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 7.062103] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 7.070802] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[ 7.080415] tegra-xusb 3610000.xhci: irq 230, io mem 0x03610000
[ 7.086864] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 7.095366] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.102790] usb usb1: Product: xHCI Host Controller
[ 7.107796] usb usb1: Manufacturer: Linux 5.10.120-tegra xhci-hcd
[ 7.114048] usb usb1: SerialNumber: 3610000.xhci
[ 7.119531] hub 1-0:1.0: USB hub found
[ 7.123415] hub 1-0:1.0: 4 ports detected
[ 7.127801] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 7.133356] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 7.141141] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 7.148644] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 7.157147] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.164573] usb usb2: Product: xHCI Host Controller
[ 7.169578] usb usb2: Manufacturer: Linux 5.10.120-tegra xhci-hcd
[ 7.175835] usb usb2: SerialNumber: 3610000.xhci
[ 7.181241] hub 2-0:1.0: USB hub found
[ 7.185117] hub 2-0:1.0: 4 ports detected
[ 7.211637] i2c i2c-2: Added multiplexed i2c bus 9
[ 7.217282] i2c i2c-2: Added multiplexed i2c bus 10
[ 7.222301] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[ 7.229300] tegra23x-oc-event soctherm-oc-event: Finished tegra23x overcurrent event probing
[ 7.251396] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1561000 KHz, changing to: 1510400 KHz
[ 7.264147] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 1554000 KHz, changing to: 1510400 KHz
[ 7.276046] tegra194-cpufreq e000000.ccplex: probed with ICC, cl:3
[ 7.284051] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 7.285191] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 7.292347] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[ 7.302613] tegra194-pcie 14100000.pcie: IO 0x0030100000…0x00301fffff → 0x0030100000
[ 7.304819] irq: IRQ294: trimming hierarchy from :interrupt-controller@f400000-1
[ 7.311298] tegra194-pcie 14100000.pcie: MEM 0x20a8000000…0x20afffffff → 0x0040000000
[ 7.311302] tegra194-pcie 14100000.pcie: MEM 0x2080000000…0x20a7ffffff → 0x2080000000
[ 7.336351] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 294
[ 7.386505] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 7.434501] tegra194-pcie 14100000.pcie: Link up
[ 7.442114] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 7.448916] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 7.454550] pci_bus 0001:00: root bus resource [io 0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[ 7.464381] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[ 7.475206] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[ 7.483151] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 7.489501] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 7.500838] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[ 7.507177] pci 0001:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 7.513107] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[ 7.521576] pci 0001:01:00.0: supports D1 D2
[ 7.525967] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 7.538128] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[ 7.545557] pci 0001:00:00.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 7.551905] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff 64bit]
[ 7.559879] pci 0001:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 7.565295] usb 1-2: New USB device found, idVendor=0bda, idProduct=5489, bcdDevice= 1.40
[ 7.566172] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 7.574584] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7.579938] pci 0001:00:00.0: bridge window [io 0x1000-0x1fff]
[ 7.587274] usb 1-2: Product: 4-Port USB 2.0 Hub
[ 7.587278] usb 1-2: Manufacturer: Generic
[ 7.593540] pci 0001:00:00.0: bridge window [mem 0x20a8000000-0x20a80fffff]
[ 7.601502] hub 1-2:1.0: USB hub found
[ 7.602509] pci 0001:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 7.611594] hub 1-2:1.0: 4 ports detected
[ 7.613739] pci 0001:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 7.635546] pcieport 0001:00:00.0: Adding to iommu group 8
[ 7.641480] pcieport 0001:00:00.0: PME: Signaling with IRQ 55
[ 7.647928] pcieport 0001:00:00.0: AER: enabled with IRQ 55
[ 7.654821] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 7.663104] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[ 7.670277] tegra194-pcie 14160000.pcie: IO 0x0036100000…0x00361fffff → 0x0036100000
[ 7.678963] tegra194-pcie 14160000.pcie: MEM 0x2428000000…0x242fffffff → 0x0040000000
[ 7.683641] usb 2-1: new SuperSpeedPlus Gen 2 USB device number 2 using tegra-xusb
[ 7.687641] tegra194-pcie 14160000.pcie: MEM 0x2140000000…0x2427ffffff → 0x2140000000
[ 7.743606] usb 2-1: New USB device found, idVendor=0bda, idProduct=0489, bcdDevice= 1.40
[ 7.752027] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7.759366] usb 2-1: Product: 4-Port USB 3.0 Hub
[ 7.764106] usb 2-1: Manufacturer: Generic
[ 7.778861] hub 2-1:1.0: USB hub found
[ 7.785039] hub 2-1:1.0: 4 ports detected
[ 7.862697] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[ 8.024339] usb 1-3: New USB device found, idVendor=13d3, idProduct=3549, bcdDevice= 0.00
[ 8.032752] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 8.040091] usb 1-3: Product: Bluetooth Radio
[ 8.044559] usb 1-3: Manufacturer: Realtek
[ 8.048761] usb 1-3: SerialNumber: 00e04c000001
[ 8.334500] usb 1-2.1: new high-speed USB device number 4 using tegra-xusb
[ 8.786936] tegra194-pcie 14160000.pcie: Phy link never came up
[ 8.793112] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 8.799922] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 8.805558] pci_bus 0004:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[ 8.815655] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[ 8.826465] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[ 8.834384] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 8.840729] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 8.856102] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 8.861493] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 8.870548] pcieport 0004:00:00.0: Adding to iommu group 9
[ 8.876478] pcieport 0004:00:00.0: PME: Signaling with IRQ 57
[ 8.883369] pcieport 0004:00:00.0: AER: enabled with IRQ 57
[ 8.889383] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[ 8.895505] pci 0004:00:00.0: Removing from iommu group 9
[ 8.901063] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[ 8.908886] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[ 8.917072] tegra194-pcie 141e0000.pcie: host bridge /pcie@141e0000 ranges:
[ 8.924250] tegra194-pcie 141e0000.pcie: IO 0x003e100000…0x003e1fffff → 0x003e100000
[ 8.932935] tegra194-pcie 141e0000.pcie: MEM 0x3228000000…0x322fffffff → 0x0040000000
[ 8.941616] tegra194-pcie 141e0000.pcie: MEM 0x2e40000000…0x3227ffffff → 0x2e40000000
[ 10.046920] tegra194-pcie 141e0000.pcie: Phy link never came up
[ 10.053070] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00
[ 10.059869] pci_bus 0007:00: root bus resource [bus 00-ff]
[ 10.065504] pci_bus 0007:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x3e100000-0x3e1fffff])
[ 10.075619] pci_bus 0007:00: root bus resource [mem 0x3228000000-0x322fffffff] (bus address [0x40000000-0x47ffffff])
[ 10.086440] pci_bus 0007:00: root bus resource [mem 0x2e40000000-0x3227ffffff pref]
[ 10.094360] pci 0007:00:00.0: [10de:229a] type 01 class 0x060400
[ 10.100683] pci 0007:00:00.0: PME# supported from D0 D3hot
[ 10.115761] pci 0007:00:00.0: PCI bridge to [bus 01-ff]
[ 10.121149] pci 0007:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 10.130175] pcieport 0007:00:00.0: Adding to iommu group 10
[ 10.136172] pcieport 0007:00:00.0: PME: Signaling with IRQ 59
[ 10.143048] pcieport 0007:00:00.0: AER: enabled with IRQ 59
[ 10.149559] pci_bus 0007:01: busn_res: [bus 01-ff] is released
[ 10.155690] pci 0007:00:00.0: Removing from iommu group 10
[ 10.161332] pci_bus 0007:00: busn_res: [bus 00-ff] is released
[ 10.169178] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[ 10.175753] tegra194-pcie 140a0000.pcie: Failed to get slot regulators: -517
[ 10.175985] vdd-3v3-sd: supplied by vdd-3v3
[ 10.182597] tegra194-isp5 14800000.isp: initialized
[ 10.194195] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[ 10.200659] (NULL device *): fops function table already registered
[ 10.207980] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[ 10.215378] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 10.215677] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[ 10.227163] irq: IRQ295: trimming hierarchy from :interrupt-controller@f400000-1
[ 10.238797] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 294
[ 10.343677] tegra194-pcie 140a0000.pcie: host bridge /pcie@140a0000 ranges:
[ 10.350849] tegra194-pcie 140a0000.pcie: IO 0x002a100000…0x002a1fffff → 0x002a100000
[ 10.359529] tegra194-pcie 140a0000.pcie: MEM 0x3528000000…0x352fffffff → 0x0040000000
[ 10.368205] tegra194-pcie 140a0000.pcie: MEM 0x3240000000…0x3527ffffff → 0x3240000000
[ 10.482696] tegra194-pcie 140a0000.pcie: Link up
[ 10.491339] tegra194-pcie 140a0000.pcie: PCI host bridge to bus 0008:00
[ 10.498153] pci_bus 0008:00: root bus resource [bus 00-ff]
[ 10.503789] pci_bus 0008:00: root bus resource [io 0x300000-0x3fffff] (bus address [0x2a100000-0x2a1fffff])
[ 10.513887] pci_bus 0008:00: root bus resource [mem 0x3528000000-0x352fffffff] (bus address [0x40000000-0x47ffffff])
[ 10.524700] pci_bus 0008:00: root bus resource [mem 0x3240000000-0x3527ffffff pref]
[ 10.532631] pci 0008:00:00.0: [10de:229c] type 01 class 0x060400
[ 10.538959] pci 0008:00:00.0: PME# supported from D0 D3hot
[ 10.550173] pci 0008:01:00.0: [10ec:8168] type 00 class 0x020000
[ 10.556488] pci 0008:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 10.562397] pci 0008:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 10.569481] pci 0008:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 10.577504] pci 0008:01:00.0: supports D1 D2
[ 10.581891] pci 0008:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 10.594039] pci 0008:00:00.0: BAR 14: assigned [mem 0x3528000000-0x35280fffff]
[ 10.601467] pci 0008:00:00.0: BAR 13: assigned [io 0x300000-0x300fff]
[ 10.608169] pci 0008:01:00.0: BAR 4: assigned [mem 0x3528000000-0x3528003fff 64bit]
[ 10.616139] pci 0008:01:00.0: BAR 2: assigned [mem 0x3528004000-0x3528004fff 64bit]
[ 10.624102] pci 0008:01:00.0: BAR 0: assigned [io 0x300000-0x3000ff]
[ 10.630745] pci 0008:00:00.0: PCI bridge to [bus 01-ff]
[ 10.636111] pci 0008:00:00.0: bridge window [io 0x300000-0x300fff]
[ 10.642723] pci 0008:00:00.0: bridge window [mem 0x3528000000-0x35280fffff]
[ 10.650073] pci 0008:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 10.658813] pci 0008:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 10.667871] pcieport 0008:00:00.0: Adding to iommu group 11
[ 10.673891] pcieport 0008:00:00.0: PME: Signaling with IRQ 61
[ 10.680469] pcieport 0008:00:00.0: AER: enabled with IRQ 61
[ 10.687200] pva 16000000.pva0: deferred probe timeout, ignoring dependency
[ 10.694290] pva: probe of 16000000.pva0 failed with error -110
[ 10.700387] nvdla 15880000.nvdla0: deferred probe timeout, ignoring dependency
[ 10.707821] nvdla: probe of 15880000.nvdla0 failed with error -110
[ 10.714260] nvdla 158c0000.nvdla1: deferred probe timeout, ignoring dependency
[ 10.721694] nvdla: probe of 158c0000.nvdla1 failed with error -110
[ 10.729369] irq: IRQ297: trimming hierarchy from :pmc@c360000
[ 10.735363] irq: IRQ298: trimming hierarchy from :interrupt-controller@f400000-1
[ 10.743113] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 10.750785] tegra-se-nvhost 15810000.se: Adding to iommu group 51
[ 10.757498] tegra-se-nvhost 15810000.se: initialized
[ 10.772701] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 10.779144] tegra-se-nvhost 15820000.se: Adding to iommu group 52
[ 10.785760] tegra-se-nvhost 15820000.se: initialized
[ 10.794460] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 10.800865] tegra-se-nvhost 15840000.se: Adding to iommu group 53
[ 10.807484] tegra-se-nvhost 15840000.se: initialized
[ 10.815713] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 10.822745] tegra_actmon d230000.actmon: in actmon_register()…
[ 10.829092] tegra_actmon d230000.actmon: bwmgr_disable = 1
[ 10.835163] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 10.843592] hvc_sysfs: hypervisor is not present
[ 10.883604] ALSA device list:
[ 10.886673] No soundcards found.
[ 10.891090] Freeing unused kernel memory: 3968K
[ 10.898532] Run /init as init process
[ 10.902296] with arguments:
[ 10.902298] /init
[ 10.902299] with environment:
[ 10.902300] HOME=/
[ 10.902301] TERM=linux
[ 10.902302] mminit_loglevel=4
[ 10.918791] Root device found: mmcblk1p1
[ 11.287614] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[ 11.686566] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
[ 11.693840] mmcblk1: mmc1:aaaa SK32G 29.7 GiB
[ 11.842433] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 11.940181] Found dev node: /dev/mmcblk1p1
[ 12.119909] EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Opts: (null)
[ 12.135901] Rootfs mounted over mmcblk1p1
[ 12.163741] Switching from initrd to actual rootfs
[ 12.465237] systemd[1]: System time before build time, advancing clock.
[ 12.706692] systemd[1]: systemd 245.4-4ubuntu3.22 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 12.730470] systemd[1]: Detected architecture arm64.
[ 13.047413] systemd[1]: Set hostname to .
[ 13.401189] random: systemd: uninitialized urandom read (16 bytes read)
[ 13.408113] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 13.421126] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 13.431216] systemd[1]: Created slice system-modprobe.slice.
[ 13.450600] random: systemd: uninitialized urandom read (16 bytes read)
[ 13.457935] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 13.478542] random: systemd: uninitialized urandom read (16 bytes read)
[ 13.485818] systemd[1]: Created slice User and Session Slice.
[ 13.506642] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 13.530852] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 13.554616] systemd[1]: Reached target User and Group Name Lookups.
[ 13.574554] systemd[1]: Reached target Slices.
[ 13.590541] systemd[1]: Reached target Mounting snaps.
[ 13.602691] usb 1-2.1: device descriptor read/64, error -110
[ 13.610537] systemd[1]: Reached target Mounted snaps.
[ 13.630540] systemd[1]: Reached target Swap.
[ 13.646857] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 13.666678] systemd[1]: Listening on Syslog Socket.
[ 13.686670] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 13.710608] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 13.730805] systemd[1]: Listening on Journal Audit Socket.
[ 13.750657] systemd[1]: Listening on Journal Socket (/dev/log).
[ 13.770697] systemd[1]: Listening on Journal Socket.
[ 13.790700] systemd[1]: Listening on udev Control Socket.
[ 13.810622] systemd[1]: Listening on udev Kernel Socket.
[ 13.832147] systemd[1]: Mounting Huge Pages File System…
[ 13.852018] systemd[1]: Mounting POSIX Message Queue File System…
[ 13.875985] systemd[1]: Mounting RPC Pipe File System…
[ 13.895972] systemd[1]: Mounting Kernel Debug File System…
[ 13.916143] systemd[1]: Mounting Kernel Trace File System…
[ 13.936610] systemd[1]: Starting Journal Service…
[ 13.956723] systemd[1]: Starting Set the console keyboard layout…
[ 13.981047] systemd[1]: Starting Create list of static device nodes for the current kernel…
[ 14.008662] systemd[1]: Starting Load Kernel Module chromeos_pstore…
[ 14.034646] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 14.044985] systemd[1]: Starting Load Kernel Module efi_pstore…
[ 14.068365] systemd[1]: Starting Load Kernel Module pstore_blk…
[ 14.088128] systemd[1]: Starting Load Kernel Module pstore_zone…
[ 14.112053] systemd[1]: Starting Load Kernel Module ramoops…
[ 14.132269] systemd[1]: Starting NVIDIA specific first-boot udev script…
[ 14.156217] systemd[1]: Started Nameserver information manager.
[ 14.178867] systemd[1]: Reached target Network (Pre).
[ 14.217621] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 14.227043] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 14.242128] systemd[1]: Starting Load Kernel Modules…
[ 14.264300] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 14.273100] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 14.278637] EXT4-fs (mmcblk1p1): re-mounted. Opts: (null)
[ 14.282726] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x0000000249800000,914358272
[ 14.299464] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 14.301717] systemd[1]: Starting udev Coldplug all Devices…
[ 14.307741] nvmap_page_pool_init: Total RAM pages: 1659018
[ 14.307745] nvmap_page_pool_init: nvmap page pool size: 207377 pages (810 MB)
[ 14.326751] nvmap_background_zero_thread: PP zeroing thread starting.
[ 14.327021] misc nvmap: created heap vpr base 0x0000000249800000 size (892928KiB)
[ 14.349295] systemd[1]: Started Journal Service.
[ 14.572898] nvgpu: 17000000.ga10b nvgpu_nvhost_syncpt_init:135 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[ 14.637510] urandom_read_iter: 54 callbacks suppressed
[ 14.637514] random: systemd-journal: uninitialized urandom read (16 bytes read)
[ 14.750799] random: systemd: uninitialized urandom read (16 bytes read)
[ 14.760755] random: systemd-journal: uninitialized urandom read (16 bytes read)
[ 14.779391] systemd-journald[260]: Received client request to flush runtime journal.
[ 15.050514] random: crng init done
[ 15.054040] random: 12 urandom warning(s) missed due to ratelimiting
[ 15.742083] spi-tegra114 3210000.spi: Adding to iommu group 2
[ 15.746559] spi-tegra114 3230000.spi: Adding to iommu group 2
[ 15.804914] imx219 9-0010: tegracam sensor driver:imx219_v2.0.6
[ 15.806206] cpu-throttle-alert cooling device registered.
[ 15.806356] gpu-throttle-alert cooling device registered.
[ 15.806453] cv0-throttle-alert cooling device registered.
[ 15.807412] cv1-throttle-alert cooling device registered.
[ 15.807523] cv2-throttle-alert cooling device registered.
[ 15.807607] soc0-throttle-alert cooling device registered.
[ 15.807696] soc1-throttle-alert cooling device registered.
[ 15.807769] soc2-throttle-alert cooling device registered.
[ 15.807892] hot-surface-alert cooling device registered.
[ 15.815657] nvidia: loading out-of-tree module taints kernel.
[ 15.819946] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[ 15.831910] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
[ 15.833252] irq: IRQ299: trimming hierarchy from :pmc@c360000
[ 15.834547] fusb301 1-0025: device id: 0x12
[ 15.842566] imx219 9-0010: board setup failed
[ 15.848884] nv_platform 13800000.display: Adding to iommu group 54
[ 15.848920] imx219: probe of 9-0010 failed with error -121
[ 15.854250] platform 13800000.display:nvdisplay-niso: Adding to iommu group 55
[ 15.858557] imx219 10-0010: tegracam sensor driver:imx219_v2.0.6
[ 15.865415] NVRM: loading NVIDIA UNIX Open Kernel Module for aarch64 35.4.1 Release Build (buildbrain@mobile-u64-6422-d7000) Tue Aug 1 12:45:41 PDT 2023
[ 15.869335] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[ 15.871998] fusb301 1-0025: toggle_time(0) is not updated
[ 15.884946] fusb301 1-0025: fusb301_set_mode: mode (32)(32)
[ 15.886025] fusb301 1-0025: fusb301_detach: type[0x00] chipstate[0x01]
[ 15.886035] fusb301 1-0025: fusb_update_state: 1
[ 15.886867] fusb301 1-0025: mode[0x20], host_cur[0x02], dttime[0x00]
[ 15.888894] imx219 10-0010: board setup failed
[ 15.894648] imx219: probe of 10-0010 failed with error -121
[ 15.990879] tegra-hda 3510000.hda: Adding to iommu group 56
[ 15.997432] nvadsp 2993000.adsp: Adding to iommu group 57
[ 15.997678] nvadsp 2993000.adsp: in probe()…
[ 15.998628] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 16.162276] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=3 as /devices/platform/3510000.hda/sound/card0/input1
[ 16.162395] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=7 as /devices/platform/3510000.hda/sound/card0/input2
[ 16.162484] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=8 as /devices/platform/3510000.hda/sound/card0/input3
[ 16.162612] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=9 as /devices/platform/3510000.hda/sound/card0/input4
[ 16.168857] tegra-asoc: sound: Adding to iommu group 57
[ 16.239240] r8168 0008:01:00.0: Adding to iommu group 11
[ 16.239739] r8168 Gigabit Ethernet driver 8.051.02-NAPI loaded
[ 16.239856] r8168 0008:01:00.0: enabling device (0000 → 0003)
[ 16.258228] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 16.260316] r8168 Copyright (C) 2022 Realtek NIC software team nicfae@realtek.com
This program comes with ABSOLUTELY NO WARRANTY; for details, please see http://www.gnu.org/licenses/.
This is free software, and you are welcome to redistribute it under certain conditions; see http://www.gnu.org/licenses/.
[ 16.308379] tegra210-adsp aconnect@2a41000:adsp_audio: Adding to iommu group 57
[ 16.308415] tegra210_adsp_audio_probe: platform probe started
[ 16.308875] tegra210-adsp tegra210-adsp: Default param-type to BYTE for mp3-dec1
[ 16.309204] tegra210-adsp tegra210-adsp: Default param-type to BYTE for spkprot
[ 16.309523] tegra210-adsp tegra210-adsp: Default param-type to BYTE for src
[ 16.309843] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aac-dec1
[ 16.310159] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aec
[ 16.310474] tegra210-adsp tegra210-adsp: Default param-type to BYTE for wire
[ 16.310479] tegra210-adsp tegra210-adsp: adma channel page address dt entry not found
[ 16.310480] tegra210-adsp tegra210-adsp: using adma channel page 0
[ 16.310591] nvadsp 2993000.adsp: ADSP OS firmware already loaded
[ 16.457714] cryptd: max_cpu_qlen set to 1000
[ 16.497146] rtl88x2ce 0001:01:00.0: Adding to iommu group 8
[ 16.497733] rtl88x2ce 0001:01:00.0: enabling device (0000 → 0003)
[ 16.758831] tegra210-adsp tegra210-adsp: Loaded app wire
[ 16.758844] tegra210-adsp tegra210-adsp: Loaded app apm
[ 16.758846] tegra210-adsp tegra210-adsp: Loaded app adma
[ 16.758848] tegra210-adsp tegra210-adsp: Loaded app adma_tx
[ 16.758853] nvadsp_set_adma_dump_reg: callback for adma reg dump is sent to 00000000275152c0
[ 16.794546] tegra210-adsp tegra210-adsp: Tegra210 ADSP driver successfully registered
[ 17.110538] using random self ethernet address
[ 17.115134] using random host ethernet address
[ 17.839471] loop: module loaded
[ 18.103806] Mass Storage Function, version: 2009/09/11
[ 18.103822] LUN: removable file: (no medium)
[ 18.107566] using random self ethernet address
[ 18.112177] using random host ethernet address
[ 18.142311] rndis0: HOST MAC 4a:7d:87:06:ad:bc
[ 18.142321] rndis0: MAC 4a:7d:87:06:ad:bd
[ 18.143104] usb0: HOST MAC 4a:7d:87:06:ad:be
[ 18.143111] usb0: MAC 4a:7d:87:06:ad:bf
[ 18.145235] tegra-xudc 3550000.xudc: EP 0 (type: ctrl, dir: out) enabled
[ 18.149537] l4tbr0: port 1(rndis0) entered blocking state
[ 18.149562] l4tbr0: port 1(rndis0) entered disabled state
[ 18.149825] device rndis0 entered promiscuous mode
[ 18.161167] l4tbr0: port 2(usb0) entered blocking state
[ 18.161191] l4tbr0: port 2(usb0) entered disabled state
[ 18.161446] device usb0 entered promiscuous mode
[ 18.436881] eth0: 0xffff80001108d000, 48:b0:2d:ec:0c:b8, IRQ 301
[ 22.589284] r8168: eth0: link up
[ 22.589405] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 24.946073] pstore: Using crash dump compression: deflate
[ 24.946147] printk: console [ramoops-1] enabled
[ 24.946151] pstore: Registered ramoops as persistent store backend
[ 24.946154] ramoops: using 0x200000@0x231800000, ecc: 0
[ 25.308975] nvgpu: 17000000.ga10b gk20a_scale_init:541 [INFO] enabled scaling for GPU
[ 25.664464] zram: Added device: zram0
[ 25.664652] zram: Added device: zram1
[ 25.664863] zram: Added device: zram2
[ 25.665131] zram: Added device: zram3
[ 25.665479] zram: Added device: zram4
[ 25.665723] zram: Added device: zram5
[ 25.752443] zram0: detected capacity change from 0 to 566280192
[ 25.858597] Adding 553004k swap on /dev/zram0. Priority:5 extents:1 across:553004k SS
[ 25.860607] zram1: detected capacity change from 0 to 566280192
[ 25.894547] Adding 553004k swap on /dev/zram1. Priority:5 extents:1 across:553004k SS
[ 25.896409] zram2: detected capacity change from 0 to 566280192
[ 25.926554] Adding 553004k swap on /dev/zram2. Priority:5 extents:1 across:553004k SS
[ 25.928273] zram3: detected capacity change from 0 to 566280192
[ 25.950577] Adding 553004k swap on /dev/zram3. Priority:5 extents:1 across:553004k SS
[ 25.951960] zram4: detected capacity change from 0 to 566280192
[ 25.990590] Adding 553004k swap on /dev/zram4. Priority:5 extents:1 across:553004k SS
[ 25.992387] zram5: detected capacity change from 0 to 566280192
[ 26.042547] Adding 553004k swap on /dev/zram5. Priority:5 extents:1 across:553004k SS
[ 28.056400] Bridge firewalling registered
[ 29.218620] usb 1-2.1: device descriptor read/64, error -110
[ 29.219946] nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for aarch64 35.4.1 Release Build (buildbrain@mobile-u64-6422-d7000) Tue Aug 1 12:45:42 PDT 2023
[ 29.410551] usb 1-2.1: new high-speed USB device number 5 using tegra-xusb
[ 29.435569] fuse: init (API version 7.32)
[ 29.516364] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
[ 34.594576] usb 1-2.1: device descriptor read/64, error -110
[ 50.211457] usb 1-2.1: device descriptor read/64, error -110
[ 50.323765] usb 1-2-port1: attempt power cycle
[ 52.146521] usb 1-2.1: new high-speed USB device number 6 using tegra-xusb
[ 53.159111] usb 1-2.1: Device not responding to setup address.
[ 54.383077] usb 1-2.1: Device not responding to setup address.
[ 54.594514] usb 1-2.1: device not accepting address 6, error -71
[ 54.682515] usb 1-2.1: new high-speed USB device number 7 using tegra-xusb
[ 55.695080] usb 1-2.1: Device not responding to setup address.
[ 56.924218] usb 1-2.1: Device not responding to setup address.
[ 57.138739] usb 1-2.1: device not accepting address 7, error -71
[ 57.146003] usb 1-2-port1: unable to enumerate USB device
[ 57.230748] usb 1-2.3: new low-speed USB device number 8 using tegra-xusb
[ 57.344279] usb 1-2.3: New USB device found, idVendor=413c, idProduct=2112, bcdDevice= 1.07
[ 57.344289] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 57.344294] usb 1-2.3: Product: Dell USB Wired Multimedia Keyboard
[ 57.344298] usb 1-2.3: Manufacturer: DELL
[ 57.354012] input: DELL Dell USB Wired Multimedia Keyboard as /devices/platform/3610000.xhci/usb1/1-2/1-2.3/1-2.3:1.0/0003:413C:2112.0001/input/input5
[ 57.411474] hid-generic 0003:413C:2112.0001: input,hidraw0: USB HID v1.10 Keyboard [DELL Dell USB Wired Multimedia Keyboard] on usb-3610000.xhci-2.3/input0
[ 57.417818] input: DELL Dell USB Wired Multimedia Keyboard System Control as /devices/platform/3610000.xhci/usb1/1-2/1-2.3/1-2.3:1.1/0003:413C:2112.0002/input/input6
[ 57.475621] input: DELL Dell USB Wired Multimedia Keyboard Consumer Control as /devices/platform/3610000.xhci/usb1/1-2/1-2.3/1-2.3:1.1/0003:413C:2112.0002/input/input7
[ 57.475818] hid-generic 0003:413C:2112.0002: input,hidraw1: USB HID v1.10 Device [DELL Dell USB Wired Multimedia Keyboard] on usb-3610000.xhci-2.3/input1
[ 57.554854] usb 1-2.4: new low-speed USB device number 9 using tegra-xusb
[ 57.664783] usb 1-2.4: New USB device found, idVendor=10c4, idProduct=8108, bcdDevice= 0.00
[ 57.664793] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 57.664798] usb 1-2.4: Product: USB OPTICAL MOUSE
[ 57.664802] usb 1-2.4: Manufacturer: YSPRINGTECH
[ 57.671112] input: YSPRINGTECH USB OPTICAL MOUSE as /devices/platform/3610000.xhci/usb1/1-2/1-2.4/1-2.4:1.0/0003:10C4:8108.0003/input/input8
[ 57.672019] hid-generic 0003:10C4:8108.0003: input,hidraw2: USB HID v1.11 Mouse [YSPRINGTECH USB OPTICAL MOUSE] on usb-3610000.xhci-2.4/input0
[ 57.860842] usbcore: registered new interface driver btusb
[ 57.866882] rtk_btusb: Realtek Bluetooth USB driver ver 3.1
[ 57.866894] rtk_btcoex: rtk_btcoex_init: version: 1.2
[ 57.866896] rtk_btcoex: create workqueue
[ 57.867243] rtk_btcoex: alloc buffers 1792, 2432 for ev and l2
[ 57.867346] rtk_btusb: btusb_probe intf->cur_altsetting->desc.bInterfaceNumber 0
[ 57.867350] rtk_btusb: btusb_probe can_wakeup 1, may wakeup 0
[ 57.867352] rtk_btusb: patch_add
[ 57.867354] rtk_btusb: auto suspend is disabled
[ 57.867358] rtk_btusb: pid = 0x3549
[ 57.867361] rtk_btusb: patch_add: Reset gEVersion to 0xff
[ 57.867377] rtk_btusb: set_bit(HCI_QUIRK_RESET_ON_CLOSE, &hdev->quirks);
[ 57.871146] rtk_btusb: btusb_probe: done
[ 57.871325] usbcore: registered new interface driver rtk_btusb
[ 57.872554] rtk_btusb: btusb_open start
[ 57.872559] rtk_btusb: btusb_open hdev->promisc ==0
[ 57.872563] rtk_btusb: download_patch start
[ 57.872567] rtk_btusb: chip type value: 0x73
[ 57.872571] rtk_btusb: HCI reset.
[ 57.883629] rtk_btusb: read_ver_rsp->lmp_subver = 0x8822
[ 57.883640] rtk_btusb: read_ver_rsp->hci_rev = 0xc
[ 57.883643] rtk_btusb: patch_entry->lmp_sub = 0x8822
[ 57.883645] rtk_btusb: load_firmware start
[ 57.883647] rtk_btusb: lmp_version = 0x8822
[ 57.883650] rtk_btusb: config filename rtl8822cu_config
[ 57.889318] rtk_btusb: no bdaddr file /opt/bdaddr
[ 57.889332] rtk_btusb: 55 ab 23 87 00 00
[ 57.889345] rtk_btusb: Config file length 6, new length 6
[ 57.889348] rtk_btusb: fw name is rtl8822cu_fw
[ 57.893543] rtk_btusb: This is not 8723a, use new patch style!
[ 57.893554] rtk_btusb: rtk_get_eversion: gEVersion 255
[ 57.894620] rtk_btusb: eversion->status = 0x0, eversion->version = 0x3
[ 57.894628] rtk_btusb: load_firmware: New gEVersion 3
[ 57.894634] rtk_btusb: rtk_get_fw_project_id: opcode 0, len 1, data 13
[ 57.894638] rtk_btusb: lmp_version is 8822, project_id is 8822, match!
[ 57.894642] rtk_btusb: fw_version = 0x9a8cbc9
[ 57.894643] rtk_btusb: number_of_total_patch = 3
[ 57.894646] rtk_btusb: chipID 4
[ 57.894649] rtk_btusb: patch_length 0x8590
[ 57.894651] rtk_btusb: start_offset 0x00005d00
[ 57.894656] rtk_btusb: Svn version: 1940234490
[ 57.894659] rtk_btusb: Coexistence: BTCOEX_20210106-2020
[ 57.894662] rtk_btusb: buf_len = 0x8596
[ 57.894678] rtk_btusb: fw: exists, config file: exists
[ 57.894681] rtk_btusb: load_firmware done
[ 57.894706] rtk_btusb: download_data start
[ 57.956661] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 57.956689] Bluetooth: BNEP socket layer initialized
[ 58.068673] rtk_btusb: download_data done
[ 58.068684] rtk_btusb: HCI reset.
[ 58.080617] rtk_btusb: read_ver_rsp->lmp_subver = 0xcbc9
[ 58.080627] rtk_btusb: read_ver_rsp->hci_rev = 0x9a8
[ 58.080629] rtk_btusb: patch_entry->lmp_sub = 0x8822
[ 58.080642] rtk_btusb: Rtk patch end 0
[ 58.080647] rtk_btusb: btusb_open set HCI_RUNNING
[ 58.080690] rtk_btcoex: Open BTCOEX
[ 58.080693] rtk_btusb: btusb_open end
[ 58.083627] rtk_btcoex: BTCOEX hci_rev 0x09a8
[ 58.083632] rtk_btcoex: BTCOEX lmp_subver 0xcbc9
[ 58.103634] rtk_btusb: btusb_notify: hci0 evt 3
lsusb after boot up with FX3 device plugged in at boot up. It is not found
Bus 002 Device 002: ID 0bda:0489 Realtek Semiconductor Corp. 4-Port USB 3.0 Hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 13d3:3549 IMC Networks Bluetooth Radio
Bus 001 Device 009: ID 10c4:8108 Silicon Labs
Bus 001 Device 008: ID 413c:2112 Dell Computer Corp. Bluetooth Radio
Bus 001 Device 002: ID 0bda:5489 Realtek Semiconductor Corp. 4-Port USB 2.0 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Dmesg after the FX3 device is unplugged then plugged in. It is found and ready to go
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.10.120-tegra (buildbrain@mobile-u64-6422-d7000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Tue Aug 1 12:32:50 PDT 2023
[ 0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[ 0.000000] OF: fdt: - 80000000 , c0000000
[ 0.000000] Machine model: NVIDIA Orin Nano Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x20b5bd598 SMBIOS=0xffff0000 SMBIOS 3.0=0x20a520000 MEMATTR=0x20a955018 ESRT=0x20a9b9098 RNG=0x22dd3dd18 MEMRESERVE=0x20a957f18
[ 0.000000] efi: seeding entropy pool
[ 0.000000] esrt: Reserving ESRT space from 0x000000020a9b9098 to 0x000000020a9b90d0.
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000021dc00000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000000237ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x0000000207e7afff]
[ 0.000000] node 0: [mem 0x0000000207e7b000-0x000000020a1bffff]
[ 0.000000] node 0: [mem 0x000000020a1c0000-0x000000020a50ffff]
[ 0.000000] node 0: [mem 0x000000020a510000-0x000000020a52ffff]
[ 0.000000] node 0: [mem 0x000000020a530000-0x000000020a77ffff]
[ 0.000000] node 0: [mem 0x000000020a780000-0x000000020a7cffff]
[ 0.000000] node 0: [mem 0x000000020a7d0000-0x000000020a8bffff]
[ 0.000000] node 0: [mem 0x000000020a8c0000-0x000000020a90ffff]
[ 0.000000] node 0: [mem 0x000000020a910000-0x000000020a95ffff]
[ 0.000000] node 0: [mem 0x000000020a960000-0x000000020a9affff]
[ 0.000000] node 0: [mem 0x000000020a9b0000-0x000000020aaeffff]
[ 0.000000] node 0: [mem 0x000000020aaf0000-0x000000020afeffff]
[ 0.000000] node 0: [mem 0x000000020aff0000-0x000000020b57ffff]
[ 0.000000] node 0: [mem 0x000000020b580000-0x000000020b58ffff]
[ 0.000000] node 0: [mem 0x000000020b590000-0x000000020b6affff]
[ 0.000000] node 0: [mem 0x000000020b6b0000-0x000000020b74ffff]
[ 0.000000] node 0: [mem 0x000000020b750000-0x000000020b84ffff]
[ 0.000000] node 0: [mem 0x000000020b850000-0x000000020b8effff]
[ 0.000000] node 0: [mem 0x000000020b8f0000-0x000000020b9effff]
[ 0.000000] node 0: [mem 0x000000020b9f0000-0x000000020ba8ffff]
[ 0.000000] node 0: [mem 0x000000020ba90000-0x000000020c35ffff]
[ 0.000000] node 0: [mem 0x000000020c360000-0x000000020c53ffff]
[ 0.000000] node 0: [mem 0x000000020c540000-0x000000022dceffff]
[ 0.000000] node 0: [mem 0x000000022dcf0000-0x000000022dd3ffff]
[ 0.000000] node 0: [mem 0x000000022dd40000-0x00000002317fffff]
[ 0.000000] node 0: [mem 0x0000000231a00000-0x0000000231e0ffff]
[ 0.000000] node 0: [mem 0x0000000236000000-0x0000000237ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000237ffffff]
[ 0.000000] On node 0 totalpages: 1784848
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 524288 pages, LIFO batch:63
[ 0.000000] Normal zone: 19968 pages used for memmap
[ 0.000000] Normal zone: 1260560 pages, LIFO batch:63
[ 0.000000] On node 0, zone Normal: 496 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 32 pages/cpu s90328 r8192 d32552 u131072
[ 0.000000] pcpu-alloc: s90328 r8192 d32552 u131072 alloc=32*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1756688
[ 0.000000] Kernel command line: root=/dev/mmcblk1p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000effe0000-0x00000000fffe0000] (256MB)
[ 0.000000] Memory: 6360408K/7139392K available (18560K kernel code, 3166K rwdata, 7196K rodata, 3968K init, 1416K bss, 516840K reserved, 262144K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[ 0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000641] Console: colour dummy device 80x25
[ 0.000684] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.000694] pid_max: default: 32768 minimum: 301
[ 0.000788] LSM: Security Framework initializing
[ 0.000815] Yama: becoming mindful.
[ 0.000836] SELinux: Initializing.
[ 0.000924] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.000938] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.002036] rcu: Hierarchical SRCU implementation.
[ 0.002124] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.002516] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t23x/p3768/kernel-dts/tegra234-p3767-0003-p3768-0000-a0.dts
[ 0.002519] DTB Build time: Aug 1 2023 12:44:16
[ 0.003726] Tegra Revision: A01 SKU: 0xd5 CPU Process: 0 SoC Process: 0
[ 0.003930] Remapping and enabling EFI services.
[ 0.005107] smp: Bringing up secondary CPUs …
[ 0.033794] Detected PIPT I-cache on CPU1
[ 0.033829] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.033857] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.062502] Detected PIPT I-cache on CPU2
[ 0.062512] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.062526] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.091128] Detected PIPT I-cache on CPU3
[ 0.091137] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.091149] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.122412] Detected PIPT I-cache on CPU4
[ 0.122440] GICv3: CPU4: found redistributor 20200 region 0:0x000000000f580000
[ 0.122469] CPU4: Booted secondary processor 0x0000020200 [0x410fd421]
[ 0.151785] Detected PIPT I-cache on CPU5
[ 0.151797] GICv3: CPU5: found redistributor 20300 region 0:0x000000000f5a0000
[ 0.151813] CPU5: Booted secondary processor 0x0000020300 [0x410fd421]
[ 0.151878] smp: Brought up 1 node, 6 CPUs
[ 0.151892] SMP: Total of 6 processors activated.
[ 0.151896] CPU features: detected: Privileged Access Never
[ 0.151897] CPU features: detected: LSE atomic instructions
[ 0.151899] CPU features: detected: User Access Override
[ 0.151901] CPU features: detected: 32-bit EL0 Support
[ 0.151904] CPU features: detected: Common not Private translations
[ 0.151906] CPU features: detected: RAS Extension Support
[ 0.151908] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.151910] CPU features: detected: CRC32 instructions
[ 0.151912] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.171751] spectre-bhb mitigation disabled by command line option
[ 0.171752] spectre-bhb mitigation disabled by command line option
[ 0.190221] CPU: All CPU(s) started at EL2
[ 0.191967] devtmpfs: initialized
[ 0.211500] Registered cp15_barrier emulation handler
[ 0.211508] Registered setend emulation handler
[ 0.211513] KASLR enabled
[ 0.211646] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.211658] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.213586] pinctrl core: initialized pinctrl subsystem
[ 0.214088] SMBIOS 3.0.0 present.
[ 0.214097] DMI: Unknown NVIDIA Orin NX Developer Kit/NVIDIA Orin NX Developer Kit, BIOS 3.0-32616947 02/21/2023
[ 0.214455] NET: Registered protocol family 16
[ 0.215403] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.215468] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.215524] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.215549] audit: initializing netlink subsys (disabled)
[ 0.215642] audit: type=2000 audit(0.212:1): state=initialized audit_enabled=0 res=1
[ 0.215846] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.215849] thermal_sys: Registered thermal governor ‘power_allocator’
[ 0.215853] thermal_sys: Registered thermal governor ‘pid_thermal_gov’
[ 0.216772] cpuidle: using governor menu
[ 0.216899] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.216972] ASID allocator initialised with 32768 entries
[ 0.217078] Serial: AMBA PL011 UART driver
[ 0.219109] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[ 0.219133] Tegra reboot handler registered.
[ 0.242064] mc: mapped MMIO address: 0xffff8000107b0000 → 0x2c10000
[ 0.242078] mc: mapped MMIO address: 0xffff8000107d0000 → 0x2c20000
[ 0.242087] mc: mapped MMIO address: 0xffff8000107f0000 → 0x2c30000
[ 0.242094] mc: mapped MMIO address: 0xffff800010810000 → 0x2c40000
[ 0.242100] mc: mapped MMIO address: 0xffff800010830000 → 0x2c50000
[ 0.242107] mc: mapped MMIO address: 0xffff800010850000 → 0x2b80000
[ 0.242113] mc: mapped MMIO address: 0xffff800010870000 → 0x2b90000
[ 0.242119] mc: mapped MMIO address: 0xffff800010890000 → 0x2ba0000
[ 0.242125] mc: mapped MMIO address: 0xffff8000108b0000 → 0x2bb0000
[ 0.242132] mc: mapped MMIO address: 0xffff8000108d0000 → 0x1700000
[ 0.242138] mc: mapped MMIO address: 0xffff8000108f0000 → 0x1710000
[ 0.242145] mc: mapped MMIO address: 0xffff800010910000 → 0x1720000
[ 0.242151] mc: mapped MMIO address: 0xffff800010930000 → 0x1730000
[ 0.242157] mc: mapped MMIO address: 0xffff800010950000 → 0x1740000
[ 0.242165] mc: mapped MMIO address: 0xffff800010970000 → 0x1750000
[ 0.242171] mc: mapped MMIO address: 0xffff800010990000 → 0x1760000
[ 0.242177] mc: mapped MMIO address: 0xffff8000109b0000 → 0x1770000
[ 0.242185] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.242221] mc-err: mcerr ops are set to t23x
[ 0.242964] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 65, base_baud = 0) is a SBSA
[ 1.350078] printk: console [ttyAMA0] enabled
[ 1.359181] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 1.365890] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 1.372590] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 1.379288] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 1.387986] ACPI: Interpreter disabled.
[ 1.392301] ddr-vddq: supplied by vdd-5v
[ 1.396411] ddr-vdd2: supplied by vdd-5v
[ 1.400456] vdd-AO-1v2: supplied by vdd-5v
[ 1.404685] vdd-3v3: supplied by vdd-5v
[ 1.408670] vdd-rtc: supplied by vdd-AO-1v2
[ 1.412992] vdd-0v95-uphy: supplied by vdd-AO-1v2
[ 1.417812] vdd-0v95-hdmi: supplied by vdd-AO-1v2
[ 1.422802] vdd-1v8: supplied by vdd-3v3-sys
[ 1.427190] vdd-3v3-AO: supplied by vdd-5v-sys
[ 1.431773] vdd-av10-hub: supplied by vdd-5v-sys
[ 1.436503] vdd-vbus-a: supplied by vdd-5v-sys
[ 1.441084] vdd-vbus-b: supplied by vdd-5v-sys
[ 1.445644] vdd-3v3-dp: supplied by vdd-3v3-sys
[ 1.450514] iommu: Default domain type: Translated
[ 1.455429] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.461730] SCSI subsystem initialized
[ 1.465582] usbcore: registered new interface driver usbfs
[ 1.471083] usbcore: registered new interface driver hub
[ 1.476403] usbcore: registered new device driver usb
[ 1.481665] mc: Linux media interface: v0.10
[ 1.485943] videodev: Linux video capture interface: v2.00
[ 1.491589] pps_core: LinuxPPS API ver. 1 registered
[ 1.496552] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 1.505693] PTP clock support registered
[ 1.509866] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.517024] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[ 1.524716] Registered efivars operations
[ 1.529287] FPGA manager framework
[ 1.532724] Advanced Linux Sound Architecture Driver Initialized.
[ 1.539107] Bluetooth: Core ver 2.22
[ 1.542688] NET: Registered protocol family 31
[ 1.547130] Bluetooth: HCI device and connection manager initialized
[ 1.553486] Bluetooth: HCI socket layer initialized
[ 1.558364] Bluetooth: L2CAP socket layer initialized
[ 1.563420] Bluetooth: SCO socket layer initialized
[ 1.568851] camchar: rtcpu character device driver loaded
[ 1.574497] clocksource: Switched to clocksource arch_sys_counter
[ 1.783960] VFS: Disk quotas dquot_6.6.0
[ 1.787934] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.795105] pnp: PnP ACPI: disabled
[ 1.801003] la/ptsa driver initialized.
[ 1.804918] NET: Registered protocol family 2
[ 1.809424] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 1.818474] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 1.827016] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 1.835006] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 1.842996] TCP: Hash tables configured (established 65536 bind 65536)
[ 1.849599] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 1.856414] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 1.863721] NET: Registered protocol family 1
[ 1.868298] RPC: Registered named UNIX socket transport module.
[ 1.874223] RPC: Registered udp transport module.
[ 1.878936] RPC: Registered tcp transport module.
[ 1.883638] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.890082] PCI: CLS 0 bytes, default 64
[ 1.894131] Trying to unpack rootfs image as initramfs…
[ 2.061813] Freeing initrd memory: 9552K
[ 2.067867] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 2.075832] kvm [1]: IPA Size Limit: 48 bits
[ 2.080119] kvm [1]: GICv3: no GICV resource entry
[ 2.084909] kvm [1]: disabling GICv2 emulation
[ 2.089364] kvm [1]: GIC system register CPU interface enabled
[ 2.095262] kvm [1]: vgic interrupt IRQ9
[ 2.099290] kvm [1]: VHE mode initialized successfully
[ 2.105128] Initialise system trusted keyrings
[ 2.109663] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 2.118893] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.125081] NFS: Registering the id_resolver key type
[ 2.130161] Key type id_resolver registered
[ 2.134343] Key type id_legacy registered
[ 2.138393] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 2.145100] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 2.152507] ntfs: driver 2.1.32 [Flags: R/W].
[ 2.172037] NET: Registered protocol family 38
[ 2.176482] Key type asymmetric registered
[ 2.180577] Asymmetric key parser ‘x509’ registered
[ 2.185475] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 239)
[ 2.192933] io scheduler mq-deadline registered
[ 2.197467] io scheduler kyber registered
[ 2.205840] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 2.211444] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 2.217032] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 2.222619] tegra-pwm 32e0000.pwm: PWM clk can sleep in ops
[ 2.229093] efifb: probing for efifb
[ 2.232716] efifb: framebuffer at 0x208000000, using 9600k, total 9600k
[ 2.239331] efifb: mode is 1920x1200x32, linelength=8192, pages=1
[ 2.245422] efifb: scrolling: redraw
[ 2.248996] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 2.258727] Console: switching to colour frame buffer device 240x75
[ 2.268903] fb0: EFI VGA frame buffer device
[ 2.275158] tegra_dc_assign_hw_data: no matching compatible node
[ 2.281165] tegradccommon module_init failed
[ 2.285436] tegradc module_init failed
[ 2.289477] EINJ: ACPI disabled.
[ 2.294485] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 2.301371] tegra-pmc: ### PMC reset source: MAINSWRST
[ 2.306507] tegra-pmc: ### PMC reset level: L1
[ 2.310948] tegra-pmc: ### PMC reset status reg: 0x2d
[ 2.317423] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 3.898820] printk: console [ttyTCU0] enabled
[ 3.903893] arm-smmu 12000000.iommu: probing hardware configuration…
[ 3.910597] arm-smmu 12000000.iommu: SMMUv2 with:
[ 3.915416] arm-smmu 12000000.iommu: stage 1 translation
[ 3.920954] arm-smmu 12000000.iommu: stage 2 translation
[ 3.926493] arm-smmu 12000000.iommu: nested translation
[ 3.931942] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 3.939348] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 3.948741] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 3.955439] arm-smmu 12000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 3.962132] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 3.969683] arm-smmu 10000000.iommu: probing hardware configuration…
[ 3.976382] arm-smmu 10000000.iommu: SMMUv2 with:
[ 3.981206] arm-smmu 10000000.iommu: stage 1 translation
[ 3.986736] arm-smmu 10000000.iommu: stage 2 translation
[ 3.992276] arm-smmu 10000000.iommu: nested translation
[ 3.997725] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 4.005131] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 4.014464] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 4.021160] arm-smmu 10000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 4.027849] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 4.035020] arm-smmu 8000000.iommu: probing hardware configuration…
[ 4.041628] arm-smmu 8000000.iommu: SMMUv2 with:
[ 4.046359] arm-smmu 8000000.iommu: stage 1 translation
[ 4.051805] arm-smmu 8000000.iommu: stage 2 translation
[ 4.057253] arm-smmu 8000000.iommu: nested translation
[ 4.062610] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 4.069929] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 4.079168] arm-smmu 8000000.iommu: Supported page sizes: 0x00001000
[ 4.085775] arm-smmu 8000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 4.092377] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 4.099695] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 4.109494] tegra_profiler: version: 1.151, samples/io: 51/30
[ 4.115483] tegra_profiler: auth: init
[ 4.119651] nvsciipc: loaded module
[ 4.125037] tun: Universal TUN/TAP device driver, 1.6
[ 4.130738] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 4.138146] hns3: Copyright (c) 2017 Huawei Corporation.
[ 4.143617] e1000e: Intel(R) PRO/1000 Network Driver
[ 4.148706] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.154794] igb: Intel(R) Gigabit Ethernet Network Driver
[ 4.160324] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.166228] PPP generic driver version 2.4.2
[ 4.170664] PPP BSD Compression module registered
[ 4.175496] PPP Deflate Compression module registered
[ 4.180694] PPP MPPE Compression module registered
[ 4.185643] usbcore: registered new interface driver r8152
[ 4.191283] usbcore: registered new interface driver asix
[ 4.196826] usbcore: registered new interface driver ax88179_178a
[ 4.203095] usbcore: registered new interface driver cdc_ether
[ 4.209090] usbcore: registered new interface driver net1080
[ 4.214917] usbcore: registered new interface driver cdc_subset
[ 4.220995] usbcore: registered new interface driver zaurus
[ 4.226732] usbcore: registered new interface driver cdc_ncm
[ 4.232546] usbcore: registered new interface driver aqc111
[ 4.238405] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 4.244763] ohci-pci: OHCI PCI platform driver
[ 4.249344] ohci-platform: OHCI generic platform driver
[ 4.255081] tegra-xusb 3610000.xhci: Adding to iommu group 0
[ 4.261471] usbcore: registered new interface driver uas
[ 4.266954] usbcore: registered new interface driver usb-storage
[ 4.273281] tegra-xudc 3550000.xudc: Adding to iommu group 1
[ 4.279377] mousedev: PS/2 mouse device common for all mice
[ 4.285129] usbcore: registered new interface driver xpad
[ 4.292567] tegra_rtc c2a0000.rtc: registered as rtc1
[ 4.298052] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:31 UTC (31)
[ 4.306280] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.312678] i2c /dev entries driver
[ 4.316384] tegra-i2c 3160000.i2c: Adding to iommu group 2
[ 4.322188] tegra-i2c c240000.i2c: Adding to iommu group 2
[ 4.327873] tegra-i2c 3180000.i2c: Adding to iommu group 2
[ 4.333556] tegra-i2c 3190000.i2c: Adding to iommu group 2
[ 4.339266] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[ 4.344955] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[ 4.350637] tegra-i2c c250000.i2c: Adding to iommu group 2
[ 4.356316] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[ 4.366016] device-mapper: uevent: version 1.0.3
[ 4.370856] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 4.380593] sdhci: Secure Digital Host Controller Interface driver
[ 4.386940] sdhci: Copyright(c) Pierre Ossman
[ 4.391406] Synopsys Designware Multimedia Card Interface Driver
[ 4.397657] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.403847] sdhci-tegra 3400000.sdhci: Adding to iommu group 3
[ 4.404109] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[ 4.417216] tegra-bpmp bpmp: firmware: f0fadc45ec6216cb5b0b-1377b684fe5
[ 4.426022] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[ 4.431666] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x82
[ 4.441507] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[ 4.447437] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
[ 5.537634] hid: raw HID events driver (C) Jiri Kosina
[ 5.543535] usbcore: registered new interface driver usbhid
[ 5.549265] usbhid: USB HID core driver
[ 5.553714] tegra-dce d800000.dce: Adding to iommu group 4
[ 5.561408] dce: dce_ipc_channel_init:319 Invalid Channel State [0x0] for ch_type [2]
[ 5.570364] tegra234-aon c000000.aon: Adding to iommu group 5
[ 5.576809] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x5]
[ 5.583322] c000000.aon:hsp: probed
[ 5.585971] dce: dce_admin_send_cmd_ver:424 version : [0x2] err : [0x0]
[ 5.596337] tegra234-aon c000000.aon: init done
[ 5.596729] tegra23x-psc e860000.psc: Adding to iommu group 6
[ 5.601132] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x1]
[ 5.607279] tegra23x-psc e860000.psc: ext_cfg base:(ptrval)
[ 5.615861] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [1] …
[ 5.622276] tegra23x-psc e860000.psc: init done
[ 5.622517] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 7
[ 5.630687] dce: dce_admin_setup_clients_ipc:529 Get queue info failed for [2]
[ 5.636027] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 5.642079] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x2]
[ 5.666782] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [3] …
[ 5.675433] dce: dce_start_boot_flow:173 DCE_BOOT_DONE
[ 5.682096] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 5.691279] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 5.702715] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 5.714280] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 5.726007] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[ 5.738568] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[ 5.751385] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 5.763841] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (113)
[ 5.770641] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 5.779204] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=0b67520f597ddc6db82218e87c6c6eb8979fd4bb
[ 5.792692] t19x_cache tegra-cache: probed
[ 5.797124] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[ 5.807991] optee: probing for conduit method.
[ 5.812591] optee: revision 3.19 (3f29c61f)
[ 5.813361] optee: dynamic shared memory is enabled
[ 5.822797] optee: initialized driver
[ 5.838081] nvpmodel: initialized successfully
[ 5.842752] tegra_hv: get_hvd: not initialized yet
[ 5.847689] user_ivc_mempool: hypervisor not present
[ 5.853600] usbcore: registered new interface driver snd-usb-audio
[ 5.860806] u32 classifier
[ 5.863591] input device check on
[ 5.867352] Actions configured
[ 5.871003] Initializing XFRM netlink socket
[ 5.875891] NET: Registered protocol family 10
[ 5.881949] Segment Routing with IPv6
[ 5.885767] NET: Registered protocol family 17
[ 5.890353] NET: Registered protocol family 15
[ 5.894969] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 5.908885] Bluetooth: RFCOMM socket layer initialized
[ 5.914196] Bluetooth: RFCOMM ver 1.11
[ 5.918057] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 5.924137] Bluetooth: HIDP socket layer initialized
[ 5.929721] 9pnet: Installing 9P2000 support
[ 5.934176] Key type dns_resolver registered
[ 5.939319] registered taskstats version 1
[ 5.943550] Loading compiled-in X.509 certificates
[ 5.958830] Loaded X.509 cert ‘Build time autogenerated kernel key: d94b64a20d69a5a32183bad4f211c4cae67041a9’
[ 5.969411] tegra194-pcie 14100000.pcie: Adding to iommu group 8
[ 5.983799] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 5.991200] tegra194-pcie 14160000.pcie: Adding to iommu group 9
[ 6.004864] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 6.011712] tegra194-pcie 141e0000.pcie: Adding to iommu group 10
[ 6.025132] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[ 6.031890] tegra194-pcie 140a0000.pcie: Adding to iommu group 11
[ 6.045390] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[ 6.052579] tegra194-pcie 140a0000.pcie: Failed to get slot regulators: -517
[ 6.079717] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 12
[ 6.089791] host1x 13e40000.host1x: Adding to iommu group 13
[ 6.121833] host1x 13e40000.host1x: initialized
[ 6.126894] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 14
[ 6.134947] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[ 6.147246] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 15
[ 6.155257] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[ 6.167561] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 16
[ 6.175544] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[ 6.187842] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 17
[ 6.195852] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[ 6.208116] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 18
[ 6.216096] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[ 6.228374] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 19
[ 6.236371] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[ 6.248637] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 20
[ 6.256624] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[ 6.268894] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 21
[ 6.276878] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[ 6.289160] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 22
[ 6.297153] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[ 6.309438] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 23
[ 6.317426] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[ 6.329709] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 24
[ 6.337723] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[ 6.349982] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 25
[ 6.357973] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[ 6.370242] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 26
[ 6.378212] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[ 6.390506] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 27
[ 6.398479] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[ 6.410741] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 28
[ 6.418725] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[ 6.431014] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 29
[ 6.438990] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[ 6.451293] falcon 15340000.vic: Adding to iommu group 30
[ 6.462021] falcon 15340000.vic: initialized
[ 6.466787] falcon 15380000.nvjpg: Adding to iommu group 31
[ 6.475903] falcon 15380000.nvjpg: initialized
[ 6.480607] falcon 15540000.nvjpg1: Adding to iommu group 32
[ 6.490048] falcon 15540000.nvjpg1: initialized
[ 6.494853] falcon 154c0000.nvenc: Adding to iommu group 33
[ 6.504766] falcon 154c0000.nvenc: _opp_is_duplicate: duplicate OPPs detected. Existing: freq: 115200000, volt: 0, enabled: 1. New: freq: 115200000, volt: 0, enabled: 1
[ 6.520776] falcon 154c0000.nvenc: initialized
[ 6.525491] falcon 15a50000.ofa: Adding to iommu group 34
[ 6.534058] falcon 15a50000.ofa: initialized
[ 6.538608] nvdec 15480000.nvdec: Adding to iommu group 35
[ 6.551225] nvdec 15480000.nvdec: initialized
[ 6.555856] tsec 15500000.tsec: Adding to iommu group 36
[ 6.566098] tsec 15500000.tsec: initialized
[ 6.573832] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 6.591589] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 6.608488] gpio-397 (camera-control-output-low): hogged as output/low
[ 6.615239] gpio-486 (camera-control-output-low): hogged as output/low
[ 6.623027] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[ 6.630399] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[ 6.637389] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 6.643893] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 6.650414] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 6.656749] tegra-pwm 32e0000.pwm: PWM clk can sleep in ops
[ 6.665251] tegra194-isp5 14800000.isp: Adding to iommu group 37
[ 6.673497] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 6.683113] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[ 6.689571] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 6.698788] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 6.708185] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 38
[ 6.716270] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 39
[ 6.724230] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
[ 6.734191] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[ 6.740994] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
[ 6.750971] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[ 6.757757] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[ 6.767714] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[ 6.774550] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 40
[ 6.783207] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18, iommu=smmu.0x0000000008000000)
[ 6.794586] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 41
[ 6.803208] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19, iommu=smmu.0x0000000008000000)
[ 6.814570] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 42
[ 6.823179] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20, iommu=smmu.0x0000000008000000)
[ 6.834579] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 43
[ 6.843179] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21, iommu=smmu.0x0000000008000000)
[ 6.854564] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to iommu group 44
[ 6.863209] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized (streamid=22, iommu=smmu.0x0000000008000000)
[ 6.874590] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to iommu group 45
[ 6.883189] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized (streamid=23, iommu=smmu.0x0000000008000000)
[ 6.894552] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to iommu group 46
[ 6.903152] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized (streamid=24, iommu=smmu.0x0000000008000000)
[ 6.914528] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to iommu group 47
[ 6.923140] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized (streamid=25, iommu=smmu.0x0000000008000000)
[ 6.934523] pva 16000000.pva0: Adding to iommu group 48
[ 6.940332] nvdla 15880000.nvdla0: Adding to iommu group 49
[ 6.946501] nvdla 158c0000.nvdla1: Adding to iommu group 50
[ 6.952657] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 2
[ 6.959872] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[ 6.967419] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 6.974037] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 6.980752] serial-tegra 3100000.serial: Adding to iommu group 2
[ 6.987370] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 17, base_baud = 0) is a TEGRA_UART
[ 6.997149] serial-tegra 3130000.serial: Adding to iommu group 2
[ 7.003718] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 63, base_baud = 0) is a TEGRA_UART
[ 7.013382] serial-tegra 3140000.serial: Adding to iommu group 2
[ 7.019894] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 7.046782] tegra-xusb 3610000.xhci: Firmware timestamp: 2021-12-01 05:27:10 UTC, Version: 80.03 release
[ 7.056533] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 7.062103] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 7.070802] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[ 7.080415] tegra-xusb 3610000.xhci: irq 230, io mem 0x03610000
[ 7.086864] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 7.095366] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.102790] usb usb1: Product: xHCI Host Controller
[ 7.107796] usb usb1: Manufacturer: Linux 5.10.120-tegra xhci-hcd
[ 7.114048] usb usb1: SerialNumber: 3610000.xhci
[ 7.119531] hub 1-0:1.0: USB hub found
[ 7.123415] hub 1-0:1.0: 4 ports detected
[ 7.127801] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 7.133356] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 7.141141] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 7.148644] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 7.157147] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.164573] usb usb2: Product: xHCI Host Controller
[ 7.169578] usb usb2: Manufacturer: Linux 5.10.120-tegra xhci-hcd
[ 7.175835] usb usb2: SerialNumber: 3610000.xhci
[ 7.181241] hub 2-0:1.0: USB hub found
[ 7.185117] hub 2-0:1.0: 4 ports detected
[ 7.211637] i2c i2c-2: Added multiplexed i2c bus 9
[ 7.217282] i2c i2c-2: Added multiplexed i2c bus 10
[ 7.222301] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[ 7.229300] tegra23x-oc-event soctherm-oc-event: Finished tegra23x overcurrent event probing
[ 7.251396] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1561000 KHz, changing to: 1510400 KHz
[ 7.264147] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 1554000 KHz, changing to: 1510400 KHz
[ 7.276046] tegra194-cpufreq e000000.ccplex: probed with ICC, cl:3
[ 7.284051] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 7.285191] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 7.292347] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[ 7.302613] tegra194-pcie 14100000.pcie: IO 0x0030100000…0x00301fffff → 0x0030100000
[ 7.304819] irq: IRQ294: trimming hierarchy from :interrupt-controller@f400000-1
[ 7.311298] tegra194-pcie 14100000.pcie: MEM 0x20a8000000…0x20afffffff → 0x0040000000
[ 7.311302] tegra194-pcie 14100000.pcie: MEM 0x2080000000…0x20a7ffffff → 0x2080000000
[ 7.336351] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 294
[ 7.386505] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 7.434501] tegra194-pcie 14100000.pcie: Link up
[ 7.442114] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 7.448916] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 7.454550] pci_bus 0001:00: root bus resource [io 0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[ 7.464381] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[ 7.475206] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[ 7.483151] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 7.489501] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 7.500838] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[ 7.507177] pci 0001:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 7.513107] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[ 7.521576] pci 0001:01:00.0: supports D1 D2
[ 7.525967] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 7.538128] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[ 7.545557] pci 0001:00:00.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 7.551905] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff 64bit]
[ 7.559879] pci 0001:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 7.565295] usb 1-2: New USB device found, idVendor=0bda, idProduct=5489, bcdDevice= 1.40
[ 7.566172] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 7.574584] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7.579938] pci 0001:00:00.0: bridge window [io 0x1000-0x1fff]
[ 7.587274] usb 1-2: Product: 4-Port USB 2.0 Hub
[ 7.587278] usb 1-2: Manufacturer: Generic
[ 7.593540] pci 0001:00:00.0: bridge window [mem 0x20a8000000-0x20a80fffff]
[ 7.601502] hub 1-2:1.0: USB hub found
[ 7.602509] pci 0001:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 7.611594] hub 1-2:1.0: 4 ports detected
[ 7.613739] pci 0001:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 7.635546] pcieport 0001:00:00.0: Adding to iommu group 8
[ 7.641480] pcieport 0001:00:00.0: PME: Signaling with IRQ 55
[ 7.647928] pcieport 0001:00:00.0: AER: enabled with IRQ 55
[ 7.654821] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 7.663104] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[ 7.670277] tegra194-pcie 14160000.pcie: IO 0x0036100000…0x00361fffff → 0x0036100000
[ 7.678963] tegra194-pcie 14160000.pcie: MEM 0x2428000000…0x242fffffff → 0x0040000000
[ 7.683641] usb 2-1: new SuperSpeedPlus Gen 2 USB device number 2 using tegra-xusb
[ 7.687641] tegra194-pcie 14160000.pcie: MEM 0x2140000000…0x2427ffffff → 0x2140000000
[ 7.743606] usb 2-1: New USB device found, idVendor=0bda, idProduct=0489, bcdDevice= 1.40
[ 7.752027] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7.759366] usb 2-1: Product: 4-Port USB 3.0 Hub
[ 7.764106] usb 2-1: Manufacturer: Generic
[ 7.778861] hub 2-1:1.0: USB hub found
[ 7.785039] hub 2-1:1.0: 4 ports detected
[ 7.862697] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[ 8.024339] usb 1-3: New USB device found, idVendor=13d3, idProduct=3549, bcdDevice= 0.00
[ 8.032752] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 8.040091] usb 1-3: Product: Bluetooth Radio
[ 8.044559] usb 1-3: Manufacturer: Realtek
[ 8.048761] usb 1-3: SerialNumber: 00e04c000001
[ 8.334500] usb 1-2.1: new high-speed USB device number 4 using tegra-xusb
[ 8.786936] tegra194-pcie 14160000.pcie: Phy link never came up
[ 8.793112] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 8.799922] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 8.805558] pci_bus 0004:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[ 8.815655] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[ 8.826465] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[ 8.834384] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 8.840729] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 8.856102] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 8.861493] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 8.870548] pcieport 0004:00:00.0: Adding to iommu group 9
[ 8.876478] pcieport 0004:00:00.0: PME: Signaling with IRQ 57
[ 8.883369] pcieport 0004:00:00.0: AER: enabled with IRQ 57
[ 8.889383] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[ 8.895505] pci 0004:00:00.0: Removing from iommu group 9
[ 8.901063] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[ 8.908886] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[ 8.917072] tegra194-pcie 141e0000.pcie: host bridge /pcie@141e0000 ranges:
[ 8.924250] tegra194-pcie 141e0000.pcie: IO 0x003e100000…0x003e1fffff → 0x003e100000
[ 8.932935] tegra194-pcie 141e0000.pcie: MEM 0x3228000000…0x322fffffff → 0x0040000000
[ 8.941616] tegra194-pcie 141e0000.pcie: MEM 0x2e40000000…0x3227ffffff → 0x2e40000000
[ 10.046920] tegra194-pcie 141e0000.pcie: Phy link never came up
[ 10.053070] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00
[ 10.059869] pci_bus 0007:00: root bus resource [bus 00-ff]
[ 10.065504] pci_bus 0007:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x3e100000-0x3e1fffff])
[ 10.075619] pci_bus 0007:00: root bus resource [mem 0x3228000000-0x322fffffff] (bus address [0x40000000-0x47ffffff])
[ 10.086440] pci_bus 0007:00: root bus resource [mem 0x2e40000000-0x3227ffffff pref]
[ 10.094360] pci 0007:00:00.0: [10de:229a] type 01 class 0x060400
[ 10.100683] pci 0007:00:00.0: PME# supported from D0 D3hot
[ 10.115761] pci 0007:00:00.0: PCI bridge to [bus 01-ff]
[ 10.121149] pci 0007:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 10.130175] pcieport 0007:00:00.0: Adding to iommu group 10
[ 10.136172] pcieport 0007:00:00.0: PME: Signaling with IRQ 59
[ 10.143048] pcieport 0007:00:00.0: AER: enabled with IRQ 59
[ 10.149559] pci_bus 0007:01: busn_res: [bus 01-ff] is released
[ 10.155690] pci 0007:00:00.0: Removing from iommu group 10
[ 10.161332] pci_bus 0007:00: busn_res: [bus 00-ff] is released
[ 10.169178] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[ 10.175753] tegra194-pcie 140a0000.pcie: Failed to get slot regulators: -517
[ 10.175985] vdd-3v3-sd: supplied by vdd-3v3
[ 10.182597] tegra194-isp5 14800000.isp: initialized
[ 10.194195] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[ 10.200659] (NULL device *): fops function table already registered
[ 10.207980] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[ 10.215378] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 10.215677] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[ 10.227163] irq: IRQ295: trimming hierarchy from :interrupt-controller@f400000-1
[ 10.238797] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 294
[ 10.343677] tegra194-pcie 140a0000.pcie: host bridge /pcie@140a0000 ranges:
[ 10.350849] tegra194-pcie 140a0000.pcie: IO 0x002a100000…0x002a1fffff → 0x002a100000
[ 10.359529] tegra194-pcie 140a0000.pcie: MEM 0x3528000000…0x352fffffff → 0x0040000000
[ 10.368205] tegra194-pcie 140a0000.pcie: MEM 0x3240000000…0x3527ffffff → 0x3240000000
[ 10.482696] tegra194-pcie 140a0000.pcie: Link up
[ 10.491339] tegra194-pcie 140a0000.pcie: PCI host bridge to bus 0008:00
[ 10.498153] pci_bus 0008:00: root bus resource [bus 00-ff]
[ 10.503789] pci_bus 0008:00: root bus resource [io 0x300000-0x3fffff] (bus address [0x2a100000-0x2a1fffff])
[ 10.513887] pci_bus 0008:00: root bus resource [mem 0x3528000000-0x352fffffff] (bus address [0x40000000-0x47ffffff])
[ 10.524700] pci_bus 0008:00: root bus resource [mem 0x3240000000-0x3527ffffff pref]
[ 10.532631] pci 0008:00:00.0: [10de:229c] type 01 class 0x060400
[ 10.538959] pci 0008:00:00.0: PME# supported from D0 D3hot
[ 10.550173] pci 0008:01:00.0: [10ec:8168] type 00 class 0x020000
[ 10.556488] pci 0008:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 10.562397] pci 0008:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 10.569481] pci 0008:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 10.577504] pci 0008:01:00.0: supports D1 D2
[ 10.581891] pci 0008:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 10.594039] pci 0008:00:00.0: BAR 14: assigned [mem 0x3528000000-0x35280fffff]
[ 10.601467] pci 0008:00:00.0: BAR 13: assigned [io 0x300000-0x300fff]
[ 10.608169] pci 0008:01:00.0: BAR 4: assigned [mem 0x3528000000-0x3528003fff 64bit]
[ 10.616139] pci 0008:01:00.0: BAR 2: assigned [mem 0x3528004000-0x3528004fff 64bit]
[ 10.624102] pci 0008:01:00.0: BAR 0: assigned [io 0x300000-0x3000ff]
[ 10.630745] pci 0008:00:00.0: PCI bridge to [bus 01-ff]
[ 10.636111] pci 0008:00:00.0: bridge window [io 0x300000-0x300fff]
[ 10.642723] pci 0008:00:00.0: bridge window [mem 0x3528000000-0x35280fffff]
[ 10.650073] pci 0008:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 10.658813] pci 0008:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 10.667871] pcieport 0008:00:00.0: Adding to iommu group 11
[ 10.673891] pcieport 0008:00:00.0: PME: Signaling with IRQ 61
[ 10.680469] pcieport 0008:00:00.0: AER: enabled with IRQ 61
[ 10.687200] pva 16000000.pva0: deferred probe timeout, ignoring dependency
[ 10.694290] pva: probe of 16000000.pva0 failed with error -110
[ 10.700387] nvdla 15880000.nvdla0: deferred probe timeout, ignoring dependency
[ 10.707821] nvdla: probe of 15880000.nvdla0 failed with error -110
[ 10.714260] nvdla 158c0000.nvdla1: deferred probe timeout, ignoring dependency
[ 10.721694] nvdla: probe of 158c0000.nvdla1 failed with error -110
[ 10.729369] irq: IRQ297: trimming hierarchy from :pmc@c360000
[ 10.735363] irq: IRQ298: trimming hierarchy from :interrupt-controller@f400000-1
[ 10.743113] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 10.750785] tegra-se-nvhost 15810000.se: Adding to iommu group 51
[ 10.757498] tegra-se-nvhost 15810000.se: initialized
[ 10.772701] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 10.779144] tegra-se-nvhost 15820000.se: Adding to iommu group 52
[ 10.785760] tegra-se-nvhost 15820000.se: initialized
[ 10.794460] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 10.800865] tegra-se-nvhost 15840000.se: Adding to iommu group 53
[ 10.807484] tegra-se-nvhost 15840000.se: initialized
[ 10.815713] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 10.822745] tegra_actmon d230000.actmon: in actmon_register()…
[ 10.829092] tegra_actmon d230000.actmon: bwmgr_disable = 1
[ 10.835163] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 10.843592] hvc_sysfs: hypervisor is not present
[ 10.883604] ALSA device list:
[ 10.886673] No soundcards found.
[ 10.891090] Freeing unused kernel memory: 3968K
[ 10.898532] Run /init as init process
[ 10.902296] with arguments:
[ 10.902298] /init
[ 10.902299] with environment:
[ 10.902300] HOME=/
[ 10.902301] TERM=linux
[ 10.902302] mminit_loglevel=4
[ 10.918791] Root device found: mmcblk1p1
[ 11.287614] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[ 11.686566] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
[ 11.693840] mmcblk1: mmc1:aaaa SK32G 29.7 GiB
[ 11.842433] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 11.940181] Found dev node: /dev/mmcblk1p1
[ 12.119909] EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Opts: (null)
[ 12.135901] Rootfs mounted over mmcblk1p1
[ 12.163741] Switching from initrd to actual rootfs
[ 12.465237] systemd[1]: System time before build time, advancing clock.
[ 12.706692] systemd[1]: systemd 245.4-4ubuntu3.22 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 12.730470] systemd[1]: Detected architecture arm64.
[ 13.047413] systemd[1]: Set hostname to .
[ 13.401189] random: systemd: uninitialized urandom read (16 bytes read)
[ 13.408113] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 13.421126] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 13.431216] systemd[1]: Created slice system-modprobe.slice.
[ 13.450600] random: systemd: uninitialized urandom read (16 bytes read)
[ 13.457935] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 13.478542] random: systemd: uninitialized urandom read (16 bytes read)
[ 13.485818] systemd[1]: Created slice User and Session Slice.
[ 13.506642] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 13.530852] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 13.554616] systemd[1]: Reached target User and Group Name Lookups.
[ 13.574554] systemd[1]: Reached target Slices.
[ 13.590541] systemd[1]: Reached target Mounting snaps.
[ 13.602691] usb 1-2.1: device descriptor read/64, error -110
[ 13.610537] systemd[1]: Reached target Mounted snaps.
[ 13.630540] systemd[1]: Reached target Swap.
[ 13.646857] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 13.666678] systemd[1]: Listening on Syslog Socket.
[ 13.686670] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 13.710608] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 13.730805] systemd[1]: Listening on Journal Audit Socket.
[ 13.750657] systemd[1]: Listening on Journal Socket (/dev/log).
[ 13.770697] systemd[1]: Listening on Journal Socket.
[ 13.790700] systemd[1]: Listening on udev Control Socket.
[ 13.810622] systemd[1]: Listening on udev Kernel Socket.
[ 13.832147] systemd[1]: Mounting Huge Pages File System…
[ 13.852018] systemd[1]: Mounting POSIX Message Queue File System…
[ 13.875985] systemd[1]: Mounting RPC Pipe File System…
[ 13.895972] systemd[1]: Mounting Kernel Debug File System…
[ 13.916143] systemd[1]: Mounting Kernel Trace File System…
[ 13.936610] systemd[1]: Starting Journal Service…
[ 13.956723] systemd[1]: Starting Set the console keyboard layout…
[ 13.981047] systemd[1]: Starting Create list of static device nodes for the current kernel…
[ 14.008662] systemd[1]: Starting Load Kernel Module chromeos_pstore…
[ 14.034646] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 14.044985] systemd[1]: Starting Load Kernel Module efi_pstore…
[ 14.068365] systemd[1]: Starting Load Kernel Module pstore_blk…
[ 14.088128] systemd[1]: Starting Load Kernel Module pstore_zone…
[ 14.112053] systemd[1]: Starting Load Kernel Module ramoops…
[ 14.132269] systemd[1]: Starting NVIDIA specific first-boot udev script…
[ 14.156217] systemd[1]: Started Nameserver information manager.
[ 14.178867] systemd[1]: Reached target Network (Pre).
[ 14.217621] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 14.227043] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 14.242128] systemd[1]: Starting Load Kernel Modules…
[ 14.264300] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 14.273100] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 14.278637] EXT4-fs (mmcblk1p1): re-mounted. Opts: (null)
[ 14.282726] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x0000000249800000,914358272
[ 14.299464] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 14.301717] systemd[1]: Starting udev Coldplug all Devices…
[ 14.307741] nvmap_page_pool_init: Total RAM pages: 1659018
[ 14.307745] nvmap_page_pool_init: nvmap page pool size: 207377 pages (810 MB)
[ 14.326751] nvmap_background_zero_thread: PP zeroing thread starting.
[ 14.327021] misc nvmap: created heap vpr base 0x0000000249800000 size (892928KiB)
[ 14.349295] systemd[1]: Started Journal Service.
[ 14.572898] nvgpu: 17000000.ga10b nvgpu_nvhost_syncpt_init:135 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[ 14.637510] urandom_read_iter: 54 callbacks suppressed
[ 14.637514] random: systemd-journal: uninitialized urandom read (16 bytes read)
[ 14.750799] random: systemd: uninitialized urandom read (16 bytes read)
[ 14.760755] random: systemd-journal: uninitialized urandom read (16 bytes read)
[ 14.779391] systemd-journald[260]: Received client request to flush runtime journal.
[ 15.050514] random: crng init done
[ 15.054040] random: 12 urandom warning(s) missed due to ratelimiting
[ 15.742083] spi-tegra114 3210000.spi: Adding to iommu group 2
[ 15.746559] spi-tegra114 3230000.spi: Adding to iommu group 2
[ 15.804914] imx219 9-0010: tegracam sensor driver:imx219_v2.0.6
[ 15.806206] cpu-throttle-alert cooling device registered.
[ 15.806356] gpu-throttle-alert cooling device registered.
[ 15.806453] cv0-throttle-alert cooling device registered.
[ 15.807412] cv1-throttle-alert cooling device registered.
[ 15.807523] cv2-throttle-alert cooling device registered.
[ 15.807607] soc0-throttle-alert cooling device registered.
[ 15.807696] soc1-throttle-alert cooling device registered.
[ 15.807769] soc2-throttle-alert cooling device registered.
[ 15.807892] hot-surface-alert cooling device registered.
[ 15.815657] nvidia: loading out-of-tree module taints kernel.
[ 15.819946] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[ 15.831910] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
[ 15.833252] irq: IRQ299: trimming hierarchy from :pmc@c360000
[ 15.834547] fusb301 1-0025: device id: 0x12
[ 15.842566] imx219 9-0010: board setup failed
[ 15.848884] nv_platform 13800000.display: Adding to iommu group 54
[ 15.848920] imx219: probe of 9-0010 failed with error -121
[ 15.854250] platform 13800000.display:nvdisplay-niso: Adding to iommu group 55
[ 15.858557] imx219 10-0010: tegracam sensor driver:imx219_v2.0.6
[ 15.865415] NVRM: loading NVIDIA UNIX Open Kernel Module for aarch64 35.4.1 Release Build (buildbrain@mobile-u64-6422-d7000) Tue Aug 1 12:45:41 PDT 2023
[ 15.869335] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[ 15.871998] fusb301 1-0025: toggle_time(0) is not updated
[ 15.884946] fusb301 1-0025: fusb301_set_mode: mode (32)(32)
[ 15.886025] fusb301 1-0025: fusb301_detach: type[0x00] chipstate[0x01]
[ 15.886035] fusb301 1-0025: fusb_update_state: 1
[ 15.886867] fusb301 1-0025: mode[0x20], host_cur[0x02], dttime[0x00]
[ 15.888894] imx219 10-0010: board setup failed
[ 15.894648] imx219: probe of 10-0010 failed with error -121
[ 15.990879] tegra-hda 3510000.hda: Adding to iommu group 56
[ 15.997432] nvadsp 2993000.adsp: Adding to iommu group 57
[ 15.997678] nvadsp 2993000.adsp: in probe()…
[ 15.998628] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 16.162276] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=3 as /devices/platform/3510000.hda/sound/card0/input1
[ 16.162395] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=7 as /devices/platform/3510000.hda/sound/card0/input2
[ 16.162484] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=8 as /devices/platform/3510000.hda/sound/card0/input3
[ 16.162612] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=9 as /devices/platform/3510000.hda/sound/card0/input4
[ 16.168857] tegra-asoc: sound: Adding to iommu group 57
[ 16.239240] r8168 0008:01:00.0: Adding to iommu group 11
[ 16.239739] r8168 Gigabit Ethernet driver 8.051.02-NAPI loaded
[ 16.239856] r8168 0008:01:00.0: enabling device (0000 → 0003)
[ 16.258228] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 16.260316] r8168 Copyright (C) 2022 Realtek NIC software team nicfae@realtek.com
This program comes with ABSOLUTELY NO WARRANTY; for details, please see http://www.gnu.org/licenses/.
This is free software, and you are welcome to redistribute it under certain conditions; see http://www.gnu.org/licenses/.
[ 16.308379] tegra210-adsp aconnect@2a41000:adsp_audio: Adding to iommu group 57
[ 16.308415] tegra210_adsp_audio_probe: platform probe started
[ 16.308875] tegra210-adsp tegra210-adsp: Default param-type to BYTE for mp3-dec1
[ 16.309204] tegra210-adsp tegra210-adsp: Default param-type to BYTE for spkprot
[ 16.309523] tegra210-adsp tegra210-adsp: Default param-type to BYTE for src
[ 16.309843] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aac-dec1
[ 16.310159] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aec
[ 16.310474] tegra210-adsp tegra210-adsp: Default param-type to BYTE for wire
[ 16.310479] tegra210-adsp tegra210-adsp: adma channel page address dt entry not found
[ 16.310480] tegra210-adsp tegra210-adsp: using adma channel page 0
[ 16.310591] nvadsp 2993000.adsp: ADSP OS firmware already loaded
[ 16.457714] cryptd: max_cpu_qlen set to 1000
[ 16.497146] rtl88x2ce 0001:01:00.0: Adding to iommu group 8
[ 16.497733] rtl88x2ce 0001:01:00.0: enabling device (0000 → 0003)
[ 16.758831] tegra210-adsp tegra210-adsp: Loaded app wire
[ 16.758844] tegra210-adsp tegra210-adsp: Loaded app apm
[ 16.758846] tegra210-adsp tegra210-adsp: Loaded app adma
[ 16.758848] tegra210-adsp tegra210-adsp: Loaded app adma_tx
[ 16.758853] nvadsp_set_adma_dump_reg: callback for adma reg dump is sent to 00000000275152c0
[ 16.794546] tegra210-adsp tegra210-adsp: Tegra210 ADSP driver successfully registered
[ 17.110538] using random self ethernet address
[ 17.115134] using random host ethernet address
[ 17.839471] loop: module loaded
[ 18.103806] Mass Storage Function, version: 2009/09/11
[ 18.103822] LUN: removable file: (no medium)
[ 18.107566] using random self ethernet address
[ 18.112177] using random host ethernet address
[ 18.142311] rndis0: HOST MAC 4a:7d:87:06:ad:bc
[ 18.142321] rndis0: MAC 4a:7d:87:06:ad:bd
[ 18.143104] usb0: HOST MAC 4a:7d:87:06:ad:be
[ 18.143111] usb0: MAC 4a:7d:87:06:ad:bf
[ 18.145235] tegra-xudc 3550000.xudc: EP 0 (type: ctrl, dir: out) enabled
[ 18.149537] l4tbr0: port 1(rndis0) entered blocking state
[ 18.149562] l4tbr0: port 1(rndis0) entered disabled state
[ 18.149825] device rndis0 entered promiscuous mode
[ 18.161167] l4tbr0: port 2(usb0) entered blocking state
[ 18.161191] l4tbr0: port 2(usb0) entered disabled state
[ 18.161446] device usb0 entered promiscuous mode
[ 18.436881] eth0: 0xffff80001108d000, 48:b0:2d:ec:0c:b8, IRQ 301
[ 22.589284] r8168: eth0: link up
[ 22.589405] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 24.946073] pstore: Using crash dump compression: deflate
[ 24.946147] printk: console [ramoops-1] enabled
[ 24.946151] pstore: Registered ramoops as persistent store backend
[ 24.946154] ramoops: using 0x200000@0x231800000, ecc: 0
[ 25.308975] nvgpu: 17000000.ga10b gk20a_scale_init:541 [INFO] enabled scaling for GPU
[ 25.664464] zram: Added device: zram0
[ 25.664652] zram: Added device: zram1
[ 25.664863] zram: Added device: zram2
[ 25.665131] zram: Added device: zram3
[ 25.665479] zram: Added device: zram4
[ 25.665723] zram: Added device: zram5
[ 25.752443] zram0: detected capacity change from 0 to 566280192
[ 25.858597] Adding 553004k swap on /dev/zram0. Priority:5 extents:1 across:553004k SS
[ 25.860607] zram1: detected capacity change from 0 to 566280192
[ 25.894547] Adding 553004k swap on /dev/zram1. Priority:5 extents:1 across:553004k SS
[ 25.896409] zram2: detected capacity change from 0 to 566280192
[ 25.926554] Adding 553004k swap on /dev/zram2. Priority:5 extents:1 across:553004k SS
[ 25.928273] zram3: detected capacity change from 0 to 566280192
[ 25.950577] Adding 553004k swap on /dev/zram3. Priority:5 extents:1 across:553004k SS
[ 25.951960] zram4: detected capacity change from 0 to 566280192
[ 25.990590] Adding 553004k swap on /dev/zram4. Priority:5 extents:1 across:553004k SS
[ 25.992387] zram5: detected capacity change from 0 to 566280192
[ 26.042547] Adding 553004k swap on /dev/zram5. Priority:5 extents:1 across:553004k SS
[ 28.056400] Bridge firewalling registered
[ 29.218620] usb 1-2.1: device descriptor read/64, error -110
[ 29.219946] nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for aarch64 35.4.1 Release Build (buildbrain@mobile-u64-6422-d7000) Tue Aug 1 12:45:42 PDT 2023
[ 29.410551] usb 1-2.1: new high-speed USB device number 5 using tegra-xusb
[ 29.435569] fuse: init (API version 7.32)
[ 29.516364] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
[ 34.594576] usb 1-2.1: device descriptor read/64, error -110
[ 50.211457] usb 1-2.1: device descriptor read/64, error -110
[ 50.323765] usb 1-2-port1: attempt power cycle
[ 52.146521] usb 1-2.1: new high-speed USB device number 6 using tegra-xusb
[ 53.159111] usb 1-2.1: Device not responding to setup address.
[ 54.383077] usb 1-2.1: Device not responding to setup address.
[ 54.594514] usb 1-2.1: device not accepting address 6, error -71
[ 54.682515] usb 1-2.1: new high-speed USB device number 7 using tegra-xusb
[ 55.695080] usb 1-2.1: Device not responding to setup address.
[ 56.924218] usb 1-2.1: Device not responding to setup address.
[ 57.138739] usb 1-2.1: device not accepting address 7, error -71
[ 57.146003] usb 1-2-port1: unable to enumerate USB device
[ 57.230748] usb 1-2.3: new low-speed USB device number 8 using tegra-xusb
[ 57.344279] usb 1-2.3: New USB device found, idVendor=413c, idProduct=2112, bcdDevice= 1.07
[ 57.344289] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 57.344294] usb 1-2.3: Product: Dell USB Wired Multimedia Keyboard
[ 57.344298] usb 1-2.3: Manufacturer: DELL
[ 57.354012] input: DELL Dell USB Wired Multimedia Keyboard as /devices/platform/3610000.xhci/usb1/1-2/1-2.3/1-2.3:1.0/0003:413C:2112.0001/input/input5
[ 57.411474] hid-generic 0003:413C:2112.0001: input,hidraw0: USB HID v1.10 Keyboard [DELL Dell USB Wired Multimedia Keyboard] on usb-3610000.xhci-2.3/input0
[ 57.417818] input: DELL Dell USB Wired Multimedia Keyboard System Control as /devices/platform/3610000.xhci/usb1/1-2/1-2.3/1-2.3:1.1/0003:413C:2112.0002/input/input6
[ 57.475621] input: DELL Dell USB Wired Multimedia Keyboard Consumer Control as /devices/platform/3610000.xhci/usb1/1-2/1-2.3/1-2.3:1.1/0003:413C:2112.0002/input/input7
[ 57.475818] hid-generic 0003:413C:2112.0002: input,hidraw1: USB HID v1.10 Device [DELL Dell USB Wired Multimedia Keyboard] on usb-3610000.xhci-2.3/input1
[ 57.554854] usb 1-2.4: new low-speed USB device number 9 using tegra-xusb
[ 57.664783] usb 1-2.4: New USB device found, idVendor=10c4, idProduct=8108, bcdDevice= 0.00
[ 57.664793] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 57.664798] usb 1-2.4: Product: USB OPTICAL MOUSE
[ 57.664802] usb 1-2.4: Manufacturer: YSPRINGTECH
[ 57.671112] input: YSPRINGTECH USB OPTICAL MOUSE as /devices/platform/3610000.xhci/usb1/1-2/1-2.4/1-2.4:1.0/0003:10C4:8108.0003/input/input8
[ 57.672019] hid-generic 0003:10C4:8108.0003: input,hidraw2: USB HID v1.11 Mouse [YSPRINGTECH USB OPTICAL MOUSE] on usb-3610000.xhci-2.4/input0
[ 57.860842] usbcore: registered new interface driver btusb
[ 57.866882] rtk_btusb: Realtek Bluetooth USB driver ver 3.1
[ 57.866894] rtk_btcoex: rtk_btcoex_init: version: 1.2
[ 57.866896] rtk_btcoex: create workqueue
[ 57.867243] rtk_btcoex: alloc buffers 1792, 2432 for ev and l2
[ 57.867346] rtk_btusb: btusb_probe intf->cur_altsetting->desc.bInterfaceNumber 0
[ 57.867350] rtk_btusb: btusb_probe can_wakeup 1, may wakeup 0
[ 57.867352] rtk_btusb: patch_add
[ 57.867354] rtk_btusb: auto suspend is disabled
[ 57.867358] rtk_btusb: pid = 0x3549
[ 57.867361] rtk_btusb: patch_add: Reset gEVersion to 0xff
[ 57.867377] rtk_btusb: set_bit(HCI_QUIRK_RESET_ON_CLOSE, &hdev->quirks);
[ 57.871146] rtk_btusb: btusb_probe: done
[ 57.871325] usbcore: registered new interface driver rtk_btusb
[ 57.872554] rtk_btusb: btusb_open start
[ 57.872559] rtk_btusb: btusb_open hdev->promisc ==0
[ 57.872563] rtk_btusb: download_patch start
[ 57.872567] rtk_btusb: chip type value: 0x73
[ 57.872571] rtk_btusb: HCI reset.
[ 57.883629] rtk_btusb: read_ver_rsp->lmp_subver = 0x8822
[ 57.883640] rtk_btusb: read_ver_rsp->hci_rev = 0xc
[ 57.883643] rtk_btusb: patch_entry->lmp_sub = 0x8822
[ 57.883645] rtk_btusb: load_firmware start
[ 57.883647] rtk_btusb: lmp_version = 0x8822
[ 57.883650] rtk_btusb: config filename rtl8822cu_config
[ 57.889318] rtk_btusb: no bdaddr file /opt/bdaddr
[ 57.889332] rtk_btusb: 55 ab 23 87 00 00
[ 57.889345] rtk_btusb: Config file length 6, new length 6
[ 57.889348] rtk_btusb: fw name is rtl8822cu_fw
[ 57.893543] rtk_btusb: This is not 8723a, use new patch style!
[ 57.893554] rtk_btusb: rtk_get_eversion: gEVersion 255
[ 57.894620] rtk_btusb: eversion->status = 0x0, eversion->version = 0x3
[ 57.894628] rtk_btusb: load_firmware: New gEVersion 3
[ 57.894634] rtk_btusb: rtk_get_fw_project_id: opcode 0, len 1, data 13
[ 57.894638] rtk_btusb: lmp_version is 8822, project_id is 8822, match!
[ 57.894642] rtk_btusb: fw_version = 0x9a8cbc9
[ 57.894643] rtk_btusb: number_of_total_patch = 3
[ 57.894646] rtk_btusb: chipID 4
[ 57.894649] rtk_btusb: patch_length 0x8590
[ 57.894651] rtk_btusb: start_offset 0x00005d00
[ 57.894656] rtk_btusb: Svn version: 1940234490
[ 57.894659] rtk_btusb: Coexistence: BTCOEX_20210106-2020
[ 57.894662] rtk_btusb: buf_len = 0x8596
[ 57.894678] rtk_btusb: fw: exists, config file: exists
[ 57.894681] rtk_btusb: load_firmware done
[ 57.894706] rtk_btusb: download_data start
[ 57.956661] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 57.956689] Bluetooth: BNEP socket layer initialized
[ 58.068673] rtk_btusb: download_data done
[ 58.068684] rtk_btusb: HCI reset.
[ 58.080617] rtk_btusb: read_ver_rsp->lmp_subver = 0xcbc9
[ 58.080627] rtk_btusb: read_ver_rsp->hci_rev = 0x9a8
[ 58.080629] rtk_btusb: patch_entry->lmp_sub = 0x8822
[ 58.080642] rtk_btusb: Rtk patch end 0
[ 58.080647] rtk_btusb: btusb_open set HCI_RUNNING
[ 58.080690] rtk_btcoex: Open BTCOEX
[ 58.080693] rtk_btusb: btusb_open end
[ 58.083627] rtk_btcoex: BTCOEX hci_rev 0x09a8
[ 58.083632] rtk_btcoex: BTCOEX lmp_subver 0xcbc9
[ 58.103634] rtk_btusb: btusb_notify: hci0 evt 3
[ 254.413711] usb 1-2.1: new high-speed USB device number 10 using tegra-xusb
[ 254.517620] usb 1-2.1: New USB device found, idVendor=04b4, idProduct=00f3, bcdDevice= 1.00
[ 254.517632] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 254.517639] usb 1-2.1: Product: WestBridge
[ 254.517645] usb 1-2.1: Manufacturer: Cypress
[ 254.517651] usb 1-2.1: SerialNumber: 0000000004BE
lsusb after the FX3 device is unplugged and the replugged in. The device is found and does operate normally.
Bus 002 Device 002: ID 0bda:0489 Realtek Semiconductor Corp. 4-Port USB 3.0 Hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 13d3:3549 IMC Networks Bluetooth Radio
Bus 001 Device 009: ID 10c4:8108 Silicon Labs
Bus 001 Device 008: ID 413c:2112 Dell Computer Corp. Bluetooth Radio
Bus 001 Device 010: ID 04b4:00f3 Cypress Semiconductor Corp.
Bus 001 Device 002: ID 0bda:5489 Realtek Semiconductor Corp. 4-Port USB 2.0 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
I am using the SD card image that I downloaded from the Nvida web site
JP512-orin-nano-sd-card-image
Thanks in advance.
could you attach your log as file instead of copy and paste?
Sorry about that. Didin’t know I could upload files.
dmesg_fx3_plugged_in_at_reboot.txt (71.1 KB)
lsusb_fx3_plugged_in_at_reboot.txt (464 Bytes)
dmesg_unplug_then_replug_fx3.txt (71.5 KB)
lsusb_unplug_then_replug_fx3.txt (526 Bytes)
Hello, I haven’t heard anything on this topic. I posted my log files as requested
It looks like need further check with below error.
Could you test does this issue only on type A or even type C port can reproduce this or not?
I am not sure what you are asking. I am using one of the 4 USB 3.2 ports on the Orin nano. This error happens on all of the type A ports. The Orin nano does not detect the FX3 based device on reboot or power up but if I unplug and plug the device back in everything works fine. I have included the dmesg logs after reboot and then again after I unplug and plug in the FX3 based device.
Are you asking me to try the same test on the USB type C port on the Orin nano?
Yes, that is what I am talking about.
Also, this may need my local reproduce to check. Could you post a link of where can we buy the device?
I performed the same test using the USB type c port. Nothing happened with this connection and I don’t think I would have expect a connection to the USB type C port to work. That port is used by Nvidia as a serial port for configuration of the Orin Nano. Keep in mind I am using the SD card image from the Nvidia web site.
In addition, I used a USB 3.1 powered Hub and plugged it into the USB type A 3.1 port of the Orin. I was thinking that the Orin wasn’t able to supply enough power but I got the same results when using a HUB. I still have to unplug and plug in the FX3 based device before the Orin recognizes it on the USB 3.1 port.
The FX3 device is actually a radio that I don’t think Nvidia will want to buy as it is not inexpensive.
I don’t want to argue too much on this but this port is actually configured as OTG by default. It could be device mode or host mode.
We also debug other kind of usb device on this type C port with jetson as host mode before.
It is kind of method to tell whether this is from that type A hub or even type C controller would hit issue.
Did you use typeC to A adapter? Have you tried other simpler usb device to test type C function as host mode?
Do you have dmesg to share?
OK. I understand. I will give it another try.
Bill
OK. I tried plugging in the FX3 device into the type C usb connector of the Orin Nano. You will see that dmesg reports nothing regarding this connection. In addition, I connected two different USB hubs to the type C port and you will notice that nothing was reported in the dmesg log. I can plug the USB type C connector into a linux computer and an Ethernet connection via USB 0 is created with the machine as is normal. So the USB type C port does seem to work as intended. I have attached the dmesg log.
dmesg.log (70.1 KB)
That sounds weird. Are you sure that is NV devkit?
I just pick one of my mouse and connect to the type C port and it could be detected.
[588432.209115] usb 2-2: new SuperSpeed Gen 1 USB device number 3 using tegra-xusb
[588432.233143] usb 2-2: New USB device found, idVendor=2109, idProduct=0817, bcdDevice= 3.b4
[588432.233151] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[588432.233156] usb 2-2: Product: USB3.0 Hub
[588432.233159] usb 2-2: Manufacturer: VIA Labs, Inc.
[588432.237060] hub 2-2:1.0: USB hub found
[588432.238188] hub 2-2:1.0: 4 ports detected
[588432.356615] usb 1-1: new high-speed USB device number 4 using tegra-xusb
[588432.509702] usb 1-1: New USB device found, idVendor=2109, idProduct=2817, bcdDevice= 3.b4
[588432.509708] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[588432.509712] usb 1-1: Product: USB2.0 Hub
[588432.509715] usb 1-1: Manufacturer: VIA Labs, Inc.
[588432.510727] hub 1-1:1.0: USB hub found
[588432.511181] hub 1-1:1.0: 4 ports detected
[588433.252582] usb 1-1.4: new low-speed USB device number 5 using tegra-xusb
[588433.409232] usb 1-1.4: New USB device found, idVendor=093a, idProduct=2510, bcdDevice= 1.00
[588433.409237] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[588433.409240] usb 1-1.4: Product: USB Optical Mouse
[588433.409242] usb 1-1.4: Manufacturer: PixArt
[588433.414185] input: PixArt USB Optical Mouse as /devices/platform/3610000.xhci/usb1/1-1/1-1.4/1-1.4:1.0/0003:093A:2510.0001/input/input5
[588433.414342] hid-generic 0003:093A:2510.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-3610000.xhci-1.4/input0
TNSPEC 3767-300-0005-K.2-1-1-jetson-orin-nano-devkit- /etc/nv_boot_control.conf
COMPATIBLE_SPEC 3767--0005--1--jetson-orin-nano-devkit-
TEGRA_LEGACY_UPDATE false
TEGRA_BOOT_STORAGE nvme0n1
TEGRA_EMMC_ONLY false
TEGRA_CHIPID 0x23
TEGRA_OTA_BOOT_DEVICE /dev/mtdblock0
TEGRA_OTA_GPT_DEVICE /dev/mtdblock0
