HDMI does not display interface after Orin installs nvidia-jetpack
Hi, nvidia, this is my first article about the problem that HDMI cannot display interface after Orin manually installs Nvidia-Jetpack, please help to solve it.
At present, the Orin on-board system is Ubuntu20.04.
After the initial burning of the image, the system runs normally and the HDMI display interface is normal.
After sudo apt install nvidia-jetpack, restart the system. HDMI cannot be displayed, but you can enter the system through ssh.
Run the command cat /etc/nv_tegra_release to check the version: # R34 (release), REVISION: 1.1, GCID: 30414990, BOARD: t186ref, EABI: aarch64, DATE: Tue May 17 04:20:55 UTC 2022
Run sudo apt show nvidia-jetpack
Display:
Package: nvidia-jetpack
Version: 5.0.1-b118
Priority: standard
Section: metapackages
Maintainer: NVIDIA Corporation
Installed-Size: 199 kB
Depends: nvidia-jetpack-runtime (= 5.0.1-b118), nvidia-jetpack-dev (= 5.0.1-b118)
Homepage: Jetson - Embedded AI Computing Platform | NVIDIA Developer
Download-Size: 29.3 kB
APT-Manual-Installed: yes
APT-Sources: https://repo.download.nvidia.com/jetson/t234 r34.1/main arm64 Packages
Description: NVIDIA Jetpack Meta Package
Please help to deal with the following, looking forward to your reply。
dmesg log
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.10.65-tegra (tgzx-wl@tgzxwl-virtual-machine) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #2 SMP PREEMPT Wed Jul 13 10:53:34 CST 2022
[ 0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[ 0.000000] OF: fdt: - 80000000 , c0000000
[ 0.000000] Machine model: NVIDIA Orin Jetson-Small Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x8549b2018 SMBIOS=0xbabc0000 SMBIOS 3.0=0x853300000 MEMATTR=0x85314f018 ESRT=0x8531cbe98 RNG=0x85456ff18 MEMRESERVE=0x853150f18
[ 0.000000] efi: seeding entropy pool
[ 0.000000] esrt: Reserving ESRT space from 0x00000008531cbe98 to 0x00000008531cbed0.
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000086b800000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node fsi-carveout, compatible id nvidia,fsi-carveout
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x000000087fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x0000000087ffffff]
[ 0.000000] node 0: [mem 0x0000000088000000-0x00000000b9ccffff]
[ 0.000000] node 0: [mem 0x00000000ba800000-0x00000000ba9affff]
[ 0.000000] node 0: [mem 0x00000000babb0000-0x00000000babcffff]
[ 0.000000] node 0: [mem 0x00000000babd0000-0x00000000babfffff]
[ 0.000000] node 0: [mem 0x00000000c2000000-0x00000000c3ffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000084fffffff]
[ 0.000000] node 0: [mem 0x0000000850000000-0x0000000851faffff]
[ 0.000000] node 0: [mem 0x0000000851fb0000-0x0000000852dd1fff]
[ 0.000000] node 0: [mem 0x0000000852dd2000-0x0000000852f37fff]
[ 0.000000] node 0: [mem 0x0000000852f38000-0x0000000852f4ffff]
[ 0.000000] node 0: [mem 0x0000000852f50000-0x0000000852f6ffff]
[ 0.000000] node 0: [mem 0x0000000852f70000-0x000000085319ffff]
[ 0.000000] node 0: [mem 0x00000008531a0000-0x00000008531bffff]
[ 0.000000] node 0: [mem 0x00000008531c0000-0x00000008532effff]
[ 0.000000] node 0: [mem 0x00000008532f0000-0x000000085330ffff]
[ 0.000000] node 0: [mem 0x0000000853310000-0x0000000853d6ffff]
[ 0.000000] node 0: [mem 0x0000000853d70000-0x0000000853efffff]
[ 0.000000] node 0: [mem 0x0000000853f00000-0x0000000853fbffff]
[ 0.000000] node 0: [mem 0x0000000853fc0000-0x00000008540fffff]
[ 0.000000] node 0: [mem 0x0000000854100000-0x000000085410ffff]
[ 0.000000] node 0: [mem 0x0000000854110000-0x000000085430ffff]
[ 0.000000] node 0: [mem 0x0000000854310000-0x000000085432ffff]
[ 0.000000] node 0: [mem 0x0000000854330000-0x000000085452ffff]
[ 0.000000] node 0: [mem 0x0000000854530000-0x000000085455ffff]
[ 0.000000] node 0: [mem 0x0000000854560000-0x000000085456ffff]
[ 0.000000] node 0: [mem 0x0000000854570000-0x00000008545cffff]
[ 0.000000] node 0: [mem 0x00000008545d0000-0x000000085466ffff]
[ 0.000000] node 0: [mem 0x0000000854670000-0x00000008546bffff]
[ 0.000000] node 0: [mem 0x00000008546c0000-0x000000085475ffff]
[ 0.000000] node 0: [mem 0x0000000854760000-0x000000085487ffff]
[ 0.000000] node 0: [mem 0x0000000854880000-0x00000008548cffff]
[ 0.000000] node 0: [mem 0x00000008548d0000-0x000000085495ffff]
[ 0.000000] node 0: [mem 0x0000000854960000-0x00000008549affff]
[ 0.000000] node 0: [mem 0x00000008549b0000-0x00000008549cffff]
[ 0.000000] node 0: [mem 0x00000008549d0000-0x0000000854a6ffff]
[ 0.000000] node 0: [mem 0x0000000854a70000-0x0000000854acffff]
[ 0.000000] node 0: [mem 0x0000000854ad0000-0x0000000854bbffff]
[ 0.000000] node 0: [mem 0x0000000854bc0000-0x000000085539ffff]
[ 0.000000] node 0: [mem 0x00000008553a0000-0x000000085557ffff]
[ 0.000000] node 0: [mem 0x0000000855580000-0x000000087b8dffff]
[ 0.000000] node 0: [mem 0x000000087b8e0000-0x000000087b92ffff]
[ 0.000000] node 0: [mem 0x000000087b930000-0x000000087fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000087fffffff]
[ 0.000000] On node 0 totalpages: 8109776
[ 0.000000] DMA zone: 3836 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 245456 pages, LIFO batch:63
[ 0.000000] Normal zone: 122880 pages used for memmap
[ 0.000000] Normal zone: 7864320 pages, LIFO batch:63
[ 0.000000] On node 0, zone DMA: 304 pages in unavailable ranges
[ 0.000000] On node 0, zone DMA: 80 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 31 pages/cpu s90008 r8192 d28776 u126976
[ 0.000000] pcpu-alloc: s90008 r8192 d28776 u126976 alloc=31*4096
[ 0.000000] pcpu-alloc: [0] 00 [0] 01 [0] 02 [0] 03 [0] 04 [0] 05 [0] 06 [0] 07
[ 0.000000] pcpu-alloc: [0] 08 [0] 09 [0] 10 [0] 11
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation disabled by kernel configuration
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 7983060
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=tty0 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0
[ 0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000a9cd0000-0x00000000b9cd0000] (256MB)
[ 0.000000] Memory: 31083600K/32439104K available (18432K kernel code, 3212K rwdata, 7068K rodata, 3968K init, 1072K bss, 1093360K reserved, 262144K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=12.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[ 0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[ 0.000000] random: get_random_bytes called from start_kernel+0x378/0x4f4 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000544] Console: colour dummy device 80x25
[ 0.000741] printk: console [tty0] enabled
[ 0.000778] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.000787] pid_max: default: 32768 minimum: 301
[ 0.000837] LSM: Security Framework initializing
[ 0.000903] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.000947] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.002551] rcu: Hierarchical SRCU implementation.
[ 0.002633] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.002949] DTS File Name: /home/tgzx-wl/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/source/public/kernel/kernel-5.10/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t23x/concord/kernel-dts/tegra234-p3701-0000-p3737-0000.dts
[ 0.002958] DTB Build time: Jul 13 2022 10:55:20
[ 0.003934] Tegra Revision: A01 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.004045] Remapping and enabling EFI services.
[ 0.005199] smp: Bringing up secondary CPUs …
[ 0.005589] Detected PIPT I-cache on CPU1
[ 0.005617] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.005644] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.005993] Detected PIPT I-cache on CPU2
[ 0.006003] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.006017] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.006328] Detected PIPT I-cache on CPU3
[ 0.006337] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.006349] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.008677] Detected PIPT I-cache on CPU4
[ 0.008698] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[ 0.008726] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[ 0.009095] Detected PIPT I-cache on CPU5
[ 0.009104] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[ 0.009118] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[ 0.009458] Detected PIPT I-cache on CPU6
[ 0.009468] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[ 0.009482] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.009827] Detected PIPT I-cache on CPU7
[ 0.009836] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[ 0.009851] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.012186] Detected PIPT I-cache on CPU8
[ 0.012208] GICv3: CPU8: found redistributor 20000 region 0:0x000000000f540000
[ 0.012236] CPU8: Booted secondary processor 0x0000020000 [0x410fd421]
[ 0.012603] Detected PIPT I-cache on CPU9
[ 0.012613] GICv3: CPU9: found redistributor 20100 region 0:0x000000000f560000
[ 0.012627] CPU9: Booted secondary processor 0x0000020100 [0x410fd421]
[ 0.012970] Detected PIPT I-cache on CPU10
[ 0.012980] GICv3: CPU10: found redistributor 20200 region 0:0x000000000f580000
[ 0.012995] CPU10: Booted secondary processor 0x0000020200 [0x410fd421]
[ 0.013334] Detected PIPT I-cache on CPU11
[ 0.013345] GICv3: CPU11: found redistributor 20300 region 0:0x000000000f5a0000
[ 0.013358] CPU11: Booted secondary processor 0x0000020300 [0x410fd421]
[ 0.013413] smp: Brought up 1 node, 12 CPUs
[ 0.013475] SMP: Total of 12 processors activated.
[ 0.013479] CPU features: detected: Privileged Access Never
[ 0.013482] CPU features: detected: LSE atomic instructions
[ 0.013484] CPU features: detected: User Access Override
[ 0.013487] CPU features: detected: 32-bit EL0 Support
[ 0.013490] CPU features: detected: Common not Private translations
[ 0.013493] CPU features: detected: RAS Extension Support
[ 0.013495] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.013498] CPU features: detected: CRC32 instructions
[ 0.013501] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.047303] CPU: All CPU(s) started at EL2
[ 0.049549] devtmpfs: initialized
[ 0.057612] Registered cp15_barrier emulation handler
[ 0.057625] Registered setend emulation handler
[ 0.057630] KASLR enabled
[ 0.057708] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.057721] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[ 0.059329] pinctrl core: initialized pinctrl subsystem
[ 0.059740] SMBIOS 3.0.0 present.
[ 0.059746] DMI: /, BIOS r34.1-975eef6 04/06/2022
[ 0.059986] NET: Registered protocol family 16
[ 0.060866] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.061071] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.061267] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.061327] audit: initializing netlink subsys (disabled)
[ 0.061418] audit: type=2000 audit(0.060:1): state=initialized audit_enabled=0 res=1
[ 0.062023] printk: console [ramoops-1] enabled
[ 0.062030] pstore: Registered ramoops as persistent store backend
[ 0.062036] ramoops: using 0x200000@0xba9b0000, ecc: 0
[ 0.062189] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.062190] thermal_sys: Registered thermal governor ‘power_allocator’
[ 0.062196] thermal_sys: Registered thermal governor ‘pid_thermal_gov’
[ 0.063586] cpuidle: using governor menu
[ 0.063700] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.063805] ASID allocator initialised with 65536 entries
[ 0.063946] Serial: AMBA PL011 UART driver
[ 0.065260] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[ 0.065282] Tegra reboot handler registered.
[ 0.065354] DTS File Name: /home/tgzx-wl/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/source/public/kernel/kernel-5.10/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t23x/concord/kernel-dts/tegra234-p3701-0000-p3737-0000.dts
[ 0.065365] DTB Build time: Jul 13 2022 10:55:20
[ 0.079712] mc: mapped MMIO address: 0x(ptrval) → 0x2c10000
[ 0.079731] mc: mapped MMIO address: 0x(ptrval) → 0x2c20000
[ 0.079741] mc: mapped MMIO address: 0x(ptrval) → 0x2c30000
[ 0.079754] mc: mapped MMIO address: 0x(ptrval) → 0x2c40000
[ 0.079763] mc: mapped MMIO address: 0x(ptrval) → 0x2c50000
[ 0.079771] mc: mapped MMIO address: 0x(ptrval) → 0x2b80000
[ 0.079779] mc: mapped MMIO address: 0x(ptrval) → 0x2b90000
[ 0.079787] mc: mapped MMIO address: 0x(ptrval) → 0x2ba0000
[ 0.079795] mc: mapped MMIO address: 0x(ptrval) → 0x2bb0000
[ 0.079803] mc: mapped MMIO address: 0x(ptrval) → 0x1700000
[ 0.079811] mc: mapped MMIO address: 0x(ptrval) → 0x1710000
[ 0.079821] mc: mapped MMIO address: 0x(ptrval) → 0x1720000
[ 0.079829] mc: mapped MMIO address: 0x(ptrval) → 0x1730000
[ 0.079837] mc: mapped MMIO address: 0x(ptrval) → 0x1740000
[ 0.079845] mc: mapped MMIO address: 0x(ptrval) → 0x1750000
[ 0.079853] mc: mapped MMIO address: 0x(ptrval) → 0x1760000
[ 0.079860] mc: mapped MMIO address: 0x(ptrval) → 0x1770000
[ 0.079871] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.079890] mc-err: mcerr ops are set to t23x
[ 0.080149] tegra23x-cbb 13a00000.cbb-en: secure_irq = 21
[ 0.080197] tegra23x-cbb c600000.aon-en: secure_irq = 22
[ 0.080233] tegra23x-cbb de00000.dce-en: secure_irq = 23
[ 0.080268] tegra23x-cbb be00000.rce-en: secure_irq = 24
[ 0.080300] tegra23x-cbb b600000.sce-en: secure_irq = 25
[ 0.083764] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.083772] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.083778] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.083782] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.085074] ACPI: Interpreter disabled.
[ 0.086100] vdd-av1v1-hub: supplied by vdd-5v-sys
[ 0.086247] vbusA-cvb: supplied by vdd-5v-sys
[ 0.086353] vbusB-cvb: supplied by vdd-5v-sys
[ 0.086502] vdd-usbc1-vbus: supplied by vdd-5v-sys
[ 0.086589] vdd-usbc2-vbus: supplied by vdd-5v-sys
[ 0.086845] iommu: Default domain type: Translated
[ 0.086882] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.087030] SCSI subsystem initialized
[ 0.087087] usbcore: registered new interface driver usbfs
[ 0.087103] usbcore: registered new interface driver hub
[ 0.087120] usbcore: registered new device driver usb
[ 0.087283] mc: Linux media interface: v0.10
[ 0.087294] videodev: Linux video capture interface: v2.00
[ 0.087424] pps_core: LinuxPPS API ver. 1 registered
[ 0.087430] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.087438] PTP clock support registered
[ 0.087626] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.087644] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[ 0.088929] Registered efivars operations
[ 0.089273] FPGA manager framework
[ 0.089367] Advanced Linux Sound Architecture Driver Initialized.
[ 0.089614] Bluetooth: Core ver 2.22
[ 0.089630] NET: Registered protocol family 31
[ 0.089635] Bluetooth: HCI device and connection manager initialized
[ 0.089644] Bluetooth: HCI socket layer initialized
[ 0.089651] Bluetooth: L2CAP socket layer initialized
[ 0.089661] Bluetooth: SCO socket layer initialized
[ 0.090275] camchar: rtcpu character device driver loaded
[ 0.090503] clocksource: Switched to clocksource arch_sys_counter
[ 0.239493] VFS: Disk quotas dquot_6.6.0
[ 0.239537] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.239651] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.239810] pnp: PnP ACPI: disabled
[ 0.239861] tegra-carveouts tegra-carveouts: fsi :dma coherent mem declare 0x00000000bf000000,16777216
[ 0.239875] tegra-carveouts tegra-carveouts: assigned reserved memory node fsi-carveout
[ 0.239888] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x00000000d6000000,704643072
[ 0.239896] nvmap_page_pool_init: Total RAM pages: 7836436
[ 0.239901] nvmap_page_pool_init: nvmap page pool size: 979554 pages (3826 MB)
[ 0.239994] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.240088] misc nvmap: created heap vpr base 0x00000000d6000000 size (688128KiB)
[ 0.241533] la/ptsa driver initialized.
[ 0.241580] NET: Registered protocol family 2
[ 0.241775] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.243573] misc nvmap: created heap fsi base 0x00000000bf000000 size (16384KiB)
[ 0.243892] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 0.243961] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.244175] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.244602] TCP: Hash tables configured (established 262144 bind 65536)
[ 0.244678] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.244735] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.244861] NET: Registered protocol family 1
[ 0.245087] RPC: Registered named UNIX socket transport module.
[ 0.245099] RPC: Registered udp transport module.
[ 0.245104] RPC: Registered tcp transport module.
[ 0.245109] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.245121] PCI: CLS 0 bytes, default 64
[ 0.245220] Trying to unpack rootfs image as initramfs…
[ 0.353966] Freeing initrd memory: 8196K
[ 0.355851] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.356000] kvm [1]: IPA Size Limit: 48 bits
[ 0.356159] kvm [1]: VHE mode initialized successfully
[ 0.356759] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[ 0.358135] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.358333] NFS: Registering the id_resolver key type
[ 0.358354] Key type id_resolver registered
[ 0.358359] Key type id_legacy registered
[ 0.358386] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.358397] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 0.358412] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.369693] NET: Registered protocol family 38
[ 0.369719] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 239)
[ 0.369777] io scheduler mq-deadline registered
[ 0.369783] io scheduler kyber registered
[ 0.373115] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.373141] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.373158] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 0.373173] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 0.375163] tegra_dc_assign_hw_data: no matching compatible node
[ 0.375171] tegradccommon module_init failed
[ 0.375177] tegradc module_init failed
[ 0.375378] EINJ: ACPI disabled.
[ 0.376445] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.376455] tegra-pmc: ### PMC reset source: SYS_RESET_N
[ 0.376461] tegra-pmc: ### PMC reset level: L0
[ 0.376466] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.377471] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.381947] random: fast init done
[ 0.382544] printk: console [ttyTCU0] enabled
[ 2.197175] arm-smmu 12000000.iommu: probing hardware configuration…
[ 2.203097] arm-smmu 12000000.iommu: SMMUv2 with:
[ 2.207663] arm-smmu 12000000.iommu: stage 1 translation
[ 2.212974] arm-smmu 12000000.iommu: stage 2 translation
[ 2.218483] arm-smmu 12000000.iommu: nested translation
[ 2.223647] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 2.230823] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 2.239042] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 2.243859] arm-smmu 12000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 2.250422] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 2.257539] arm-smmu 10000000.iommu: probing hardware configuration…
[ 2.263459] arm-smmu 10000000.iommu: SMMUv2 with:
[ 2.268184] arm-smmu 10000000.iommu: stage 1 translation
[ 2.273694] arm-smmu 10000000.iommu: stage 2 translation
[ 2.279120] arm-smmu 10000000.iommu: nested translation
[ 2.284548] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 2.291721] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 2.300011] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 2.304935] arm-smmu 10000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 2.311496] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 2.318422] arm-smmu 8000000.iommu: probing hardware configuration…
[ 2.324624] arm-smmu 8000000.iommu: SMMUv2 with:
[ 2.329346] arm-smmu 8000000.iommu: stage 1 translation
[ 2.334857] arm-smmu 8000000.iommu: stage 2 translation
[ 2.340283] arm-smmu 8000000.iommu: nested translation
[ 2.345446] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 2.352621] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 2.360876] arm-smmu 8000000.iommu: Supported page sizes: 0x00001000
[ 2.365834] arm-smmu 8000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 2.372394] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 2.379440] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 2.388221] tegra_profiler: version: 1.146, samples/io: 49/28
[ 2.392588] tegra_profiler: auth: init
[ 2.397309] tegra23x-qspi 3270000.spi: Adding to iommu group 0
[ 2.402931] libphy: Fixed MDIO Bus: probed
[ 2.406340] tun: Universal TUN/TAP device driver, 1.6
[ 2.411871] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 2.418688] hns3: Copyright (c) 2017 Huawei Corporation.
[ 2.424219] e1000e: Intel(R) PRO/1000 Network Driver
[ 2.429009] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.434968] igb: Intel(R) Gigabit Ethernet Network Driver
[ 2.440384] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.446216] PPP generic driver version 2.4.2
[ 2.450581] PPP BSD Compression module registered
[ 2.455263] PPP Deflate Compression module registered
[ 2.460520] PPP MPPE Compression module registered
[ 2.465338] usbcore: registered new interface driver r8152
[ 2.470669] usbcore: registered new interface driver asix
[ 2.476091] usbcore: registered new interface driver ax88179_178a
[ 2.482216] usbcore: registered new interface driver cdc_ether
[ 2.488166] usbcore: registered new interface driver net1080
[ 2.493765] usbcore: registered new interface driver cdc_subset
[ 2.499802] usbcore: registered new interface driver zaurus
[ 2.505492] usbcore: registered new interface driver cdc_ncm
[ 2.511178] usbcore: registered new interface driver aqc111
[ 2.516688] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 2.522902] ohci-pci: OHCI PCI platform driver
[ 2.527195] ohci-platform: OHCI generic platform driver
[ 2.532507] tegra-xusb 3610000.xhci: Adding to iommu group 1
[ 2.538339] usbcore: registered new interface driver uas
[ 2.543476] usbcore: registered new interface driver usb-storage
[ 2.549431] tegra-xudc 3550000.xudc: Adding to iommu group 2
[ 2.555267] mousedev: PS/2 mouse device common for all mice
[ 2.560626] usbcore: registered new interface driver xpad
[ 2.567833] tegra_rtc c2a0000.rtc: registered as rtc1
[ 2.571386] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:18 UTC (18)
[ 2.579168] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.585374] i2c /dev entries driver
[ 2.588966] tegra-i2c 3160000.i2c: Adding to iommu group 3
[ 2.594549] tegra-i2c c240000.i2c: Adding to iommu group 3
[ 2.599937] tegra-i2c 3180000.i2c: Adding to iommu group 3
[ 2.605358] tegra-i2c 3190000.i2c: Adding to iommu group 3
[ 2.610696] tegra-i2c 31b0000.i2c: Adding to iommu group 3
[ 2.616205] tegra-i2c 31c0000.i2c: Adding to iommu group 3
[ 2.621629] tegra-i2c c250000.i2c: Adding to iommu group 3
[ 2.626984] tegra-i2c 31e0000.i2c: Adding to iommu group 3
[ 2.635157] device-mapper: uevent: version 1.0.3
[ 2.636973] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 2.646277] sdhci: Secure Digital Host Controller Interface driver
[ 2.651613] sdhci: Copyright(c) Pierre Ossman
[ 2.655896] Synopsys Designware Multimedia Card Interface Driver
[ 2.662000] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.667872] sdhci-tegra 3460000.sdhci: Adding to iommu group 4
[ 2.667999] sdhci-tegra 3400000.sdhci: Adding to iommu group 5
[ 2.668666] pstore: ignoring unexpected backend ‘efi’
[ 2.668723] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[ 2.679966] tegra-bpmp bpmp: firmware: 43f75b5aad2b8e1992e4-f0425a554b3
[ 3.787882] hid: raw HID events driver (C) Jiri Kosina
[ 3.788486] usbcore: registered new interface driver usbhid
[ 3.788672] usbhid: USB HID core driver
[ 3.789056] tegra-dce d800000.dce: Adding to iommu group 6
[ 3.790408] dce: dce_ipc_channel_init:314 Invalid Channel State [0x0] for ch_type [2]
[ 3.791621] dce: dce_wait_boot_complete:100 dce is ready to receive bootstrap commands
[ 3.791771] tegra234-aon c000000.aon: Adding to iommu group 7
[ 3.792304] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x5]
[ 3.792602] dce: dce_admin_ipc_handle_signal:119 Spurious signal on channel: [0]. Ignored…
[ 3.792860] dce: dce_admin_send_cmd_ver:424 version : [0x2] err : [0x0]
[ 3.793156] c000000.aon:hsp: probed
[ 3.793191] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x1]
[ 3.793426] tegra234-aon c000000.aon: init done
[ 3.793610] dce: dce_admin_setup_clients_ipc:480 Channel Reset Complete for Type [1] …
[ 3.793613] dce: dce_admin_ipc_handle_signal:119 Spurious signal on channel: [1]. Ignored…
[ 3.793625] dce: dce_admin_ipc_handle_signal:119 Spurious signal on channel: [1]. Ignored…
[ 3.794011] tegra23x-psc e860000.psc: Adding to iommu group 8
[ 3.794031] dce: dce_admin_setup_clients_ipc:456 Get queue info failed for [2]
[ 3.796871] tegra23x-psc e860000.psc: ext_cfg base:(ptrval)
[ 3.805228] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x2]
[ 3.810906] tegra23x-psc e860000.psc: init done
[ 3.818078] dce: dce_admin_setup_clients_ipc:480 Channel Reset Complete for Type [3] …
[ 3.818085] dce: dce_admin_ipc_handle_signal:119 Spurious signal on channel: [3]. Ignored…
[ 3.818093] dce: dce_admin_ipc_handle_signal:119 Spurious signal on channel: [3]. Ignored…
[ 3.824415] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 9
[ 3.833619] dce: dce_worker:209 DCE_BOOT_DONE
[ 3.838250] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 3.888036] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 3.891451] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 3.901749] random: crng init done
[ 3.902560] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 3.917023] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 3.927606] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[ 3.939475] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[ 3.951970] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 3.963907] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (113)
[ 3.970067] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 3.978385] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=e4da4cf5a29dccddc6d8f65bbd5202381ca3db13
[ 3.990906] t19x_cache tegra-cache: probed
[ 3.993423] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[ 4.011116] nvpmodel: initialized successfully
[ 4.011552] tegra_hv: get_hvd: not initialized yet
[ 4.011691] user_ivc_mempool: hypervisor not present
[ 4.013891] usbcore: registered new interface driver snd-usb-audio
[ 4.020530] u32 classifier
[ 4.022742] input device check on
[ 4.026409] Actions configured
[ 4.029851] Initializing XFRM netlink socket
[ 4.034517] NET: Registered protocol family 10
[ 4.039746] Segment Routing with IPv6
[ 4.042189] NET: Registered protocol family 17
[ 4.046467] NET: Registered protocol family 15
[ 4.050956] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 4.064684] Bluetooth: RFCOMM socket layer initialized
[ 4.068959] Bluetooth: RFCOMM ver 1.11
[ 4.072882] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.078741] Bluetooth: HIDP socket layer initialized
[ 4.084632] 9pnet: Installing 9P2000 support
[ 4.088147] Key type dns_resolver registered
[ 4.093462] registered taskstats version 1
[ 4.096932] pstore: Using crash dump compression: deflate
[ 4.102157] tegra194-pcie 14180000.pcie: Adding to iommu group 10
[ 4.113857] tegra194-pcie 14180000.pcie: Using GICv2m MSI allocator
[ 4.115276] tegra194-pcie 141a0000.pcie: Adding to iommu group 11
[ 4.125673] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 4.127249] tegra194-pcie 141a0000.pcie: Failed to get slot regulators: -517
[ 4.146579] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 3
[ 4.148071] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[ 4.148429] host1x 13e40000.host1x: Adding to iommu group 12
[ 5.162116] t23x_init_gating_regs: Timed out waiting for syncpt ram init!
[ 5.172817] host1x 13e40000.host1x: initialized
[ 5.173248] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 13
[ 5.173739] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[ 5.175312] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 14
[ 5.175724] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[ 5.177276] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 15
[ 5.177693] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[ 5.179247] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 16
[ 5.179637] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[ 5.181179] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 17
[ 5.181617] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[ 5.183170] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 18
[ 5.183588] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[ 5.194900] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 19
[ 5.201441] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[ 5.212913] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 20
[ 5.219446] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[ 5.230926] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 21
[ 5.237500] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[ 5.248954] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 22
[ 5.255483] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[ 5.266972] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 23
[ 5.273535] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[ 5.284989] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 24
[ 5.291580] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[ 5.303016] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 25
[ 5.309596] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[ 5.321027] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 26
[ 5.327590] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[ 5.339089] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 27
[ 5.345628] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[ 5.357093] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 28
[ 5.363620] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[ 5.375162] falcon 15340000.vic: Adding to iommu group 29
[ 5.386722] falcon 15340000.vic: initialized
[ 5.387049] falcon 15380000.nvjpg: Adding to iommu group 30
[ 5.394014] falcon 15380000.nvjpg: initialized
[ 5.394234] falcon 15540000.nvjpg1: Adding to iommu group 31
[ 5.404085] falcon 15540000.nvjpg1: initialized
[ 5.404484] falcon 154c0000.nvenc: Adding to iommu group 32
[ 5.417249] falcon 154c0000.nvenc: initialized
[ 5.417477] falcon 15a50000.ofa: Adding to iommu group 33
[ 5.424756] falcon 15a50000.ofa: initialized
[ 5.424983] nvdec 15480000.nvdec: Adding to iommu group 34
[ 5.441914] nvdec 15480000.nvdec: initialized
[ 5.442127] tsec 15500000.tsec: Adding to iommu group 35
[ 5.450161] tsec 15500000.tsec: initialized
[ 5.452344] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 5.458642] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 5.465516] gpio-394 (camera-control-output-high): hogged as output/high
[ 5.466682] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[ 5.471525] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[ 5.476986] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 5.483791] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 5.489817] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 5.494344] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 5.501641] misc tegra_camera_ctrl: tegra_camera_isomgr_register: some fields not in DT.
[ 5.507661] tegra194-isp5 14800000.isp: Adding to iommu group 36
[ 5.516126] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 5.522965] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[ 5.528775] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 5.537746] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 5.546756] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 5.555593] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 5.564604] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 5.573624] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 5.582912] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 37
[ 5.590640] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 38
[ 5.597756] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
[ 5.607086] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[ 5.613089] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: grid-of-semaphores not supported
[ 5.621544] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
[ 5.630956] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[ 5.637141] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: grid-of-semaphores not supported
[ 5.645430] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[ 5.655478] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[ 5.661212] scare-pigeon 13e40000.host1x:isp-thi@14b00000: grid-of-semaphores not supported
[ 5.669760] pva 16000000.pva0: Adding to iommu group 39
[ 5.695012] pva 16000000.pva0: initialized
[ 5.702828] nvdla 15880000.nvdla0: Adding to iommu group 40
[ 5.712249] nvdla 15880000.nvdla0: initialized
[ 5.713987] nvdla 158c0000.nvdla1: Adding to iommu group 41
[ 5.723460] nvdla 158c0000.nvdla1: initialized
[ 5.725153] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 5.725369] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 5.725767] serial-tegra 3100000.serial: Adding to iommu group 3
[ 5.726299] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 13, base_baud = 0) is a TEGRA_UART
[ 5.727741] serial-tegra 3130000.serial: Adding to iommu group 3
[ 5.733438] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 61, base_baud = 0) is a TEGRA_UART
[ 5.742621] serial-tegra 3140000.serial: Adding to iommu group 3
[ 5.748267] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 62, base_baud = 0) is a TEGRA_UART
[ 5.780671] tegra-xusb 3610000.xhci: Firmware timestamp: 2021-12-01 05:27:10 UTC, Version: 80.03 release
[ 5.781002] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 5.781196] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 5.782252] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[ 5.788624] tegra-xusb 3610000.xhci: irq 230, io mem 0x03610000
[ 5.794769] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 5.802864] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.810037] usb usb1: Product: xHCI Host Controller
[ 5.815025] usb usb1: Manufacturer: Linux 5.10.65-tegra xhci-hcd
[ 5.821062] usb usb1: SerialNumber: 3610000.xhci
[ 5.826194] hub 1-0:1.0: USB hub found
[ 5.829574] hub 1-0:1.0: 4 ports detected
[ 5.833763] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 5.839007] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 5.846618] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 5.854022] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 5.862194] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.869450] usb usb2: Product: xHCI Host Controller
[ 5.874437] usb usb2: Manufacturer: Linux 5.10.65-tegra xhci-hcd
[ 5.880387] usb usb2: SerialNumber: 3610000.xhci
[ 5.885453] hub 2-0:1.0: USB hub found
[ 5.888980] hub 2-0:1.0: 4 ports detected
[ 5.894308] bwmgr API not supported
[ 5.894312] tegra-xusb 3610000.xhci: can’t register EMC bwmgr (-22)
[ 5.908436] pca954x 1-0070: pca954x_probe: forcing device bus number, start 30.
[ 5.909967] pca954x 1-0070: device detect skipped.
[ 5.915856] i2c i2c-1: Added multiplexed i2c bus 30
[ 5.920686] i2c i2c-1: Added multiplexed i2c bus 31
[ 5.925270] i2c i2c-1: Added multiplexed i2c bus 32
[ 5.930159] i2c i2c-1: Added multiplexed i2c bus 33
[ 5.934731] pca954x 1-0070: registered 4 multiplexed busses for I2C switch pca9546
[ 5.962917] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2009000 KHz, changing to: 2035200 KHz
[ 5.966104] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2009000 KHz, changing to: 2035200 KHz
[ 5.969265] cpufreq: cpufreq_online: CPU8: Running at unlisted initial frequency: 2010000 KHz, changing to: 2035200 KHz
[ 5.978862] tegra194-pcie 14180000.pcie: Using GICv2m MSI allocator
[ 5.979049] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 5.987067] tegra194-pcie 14180000.pcie: host bridge /pcie@14180000 ranges:
[ 5.992658] tegra194-pcie 14180000.pcie: IO 0x0038100000…0x00381fffff → 0x0038100000
[ 5.995048] irq: IRQ288: trimming hierarchy from :pmc@c360000
[ 5.995604] mmc0: CQHCI version 5.10
[ 6.001139] tegra194-pcie 14180000.pcie: MEM 0x2728000000…0x272fffffff → 0x0040000000
[ 6.001142] tegra194-pcie 14180000.pcie: MEM 0x2440000000…0x2727ffffff → 0x2440000000
[ 6.006954] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 288
[ 6.048417] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[ 6.137048] mmc0: Command Queue Engine enabled
[ 6.137181] mmc0: periodic cache flush enabled
[ 6.137313] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 6.137940] mmcblk0: mmc0:0001 G1M15M 59.3 GiB
[ 6.138250] mmcblk0rpmb: mmc0:0001 G1M15M partition 3 4.00 MiB, chardev (510:0)
[ 6.141776] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[ 6.142498] tegra194-pcie 14180000.pcie: Link up
[ 6.145060] tegra194-pcie 14180000.pcie: PCI host bridge to bus 0000:00
[ 6.145257] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 6.145427] pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0x38100000-0x381fffff])
[ 6.145711] pci_bus 0000:00: root bus resource [mem 0x2728000000-0x272fffffff] (bus address [0x40000000-0x47ffffff])
[ 6.146036] pci_bus 0000:00: root bus resource [mem 0x2440000000-0x2727ffffff pref]
[ 6.146306] pci 0000:00:00.0: [10de:229c] type 01 class 0x060400
[ 6.146577] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 6.149488] pci 0000:01:00.0: [1b4b:9170] type 00 class 0x010601
[ 6.149772] pci 0000:01:00.0: reg 0x10: initial BAR value 0x00008000 invalid
[ 6.149981] pci 0000:01:00.0: reg 0x10: [io size 0x0008]
[ 6.152885] pci 0000:01:00.0: reg 0x14: initial BAR value 0x00008040 invalid
[ 6.159739] pci 0000:01:00.0: reg 0x14: [io size 0x0004]
[ 6.165305] pci 0000:01:00.0: reg 0x18: initial BAR value 0x00008100 invalid
[ 6.172250] pci 0000:01:00.0: reg 0x18: [io size 0x0008]
[ 6.177816] pci 0000:01:00.0: reg 0x1c: initial BAR value 0x00008140 invalid
[ 6.184675] pci 0000:01:00.0: reg 0x1c: [io size 0x0004]
[ 6.190066] pci 0000:01:00.0: reg 0x20: [io 0x800000-0x80000f]
[ 6.196103] pci 0000:01:00.0: reg 0x24: [mem 0x00900000-0x009001ff]
[ 6.202403] pci 0000:01:00.0: reg 0x30: [mem 0xd0000000-0xd000ffff pref]
[ 6.209236] pci 0000:01:00.0: Enabling fixed DMA alias to 00.1
[ 6.215479] pci 0000:01:00.0: PME# supported from D3hot
[ 6.222994] pci 0000:00:00.0: BAR 14: assigned [mem 0x2728000000-0x27280fffff]
[ 6.227727] pci 0000:00:00.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 6.233940] pci 0000:01:00.0: BAR 6: assigned [mem 0x2728000000-0x272800ffff pref]
[ 6.241551] pci 0000:01:00.0: BAR 5: assigned [mem 0x2728010000-0x27280101ff]
[ 6.248829] pci 0000:01:00.0: BAR 4: assigned [io 0x1000-0x100f]
[ 6.255130] pci 0000:01:00.0: BAR 0: assigned [io 0x1010-0x1017]
[ 6.261344] pci 0000:01:00.0: BAR 2: assigned [io 0x1018-0x101f]
[ 6.267557] pci 0000:01:00.0: BAR 1: assigned [io 0x1020-0x1023]
[ 6.273853] pci 0000:01:00.0: BAR 3: assigned [io 0x1024-0x1027]
[ 6.280068] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 6.285127] pci 0000:00:00.0: bridge window [io 0x1000-0x1fff]
[ 6.291428] pci 0000:00:00.0: bridge window [mem 0x2728000000-0x27280fffff]
[ 6.298696] pci 0000:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 6.307302] pci 0000:01:00.0: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
[ 6.315935] pcieport 0000:00:00.0: Adding to iommu group 10
[ 6.321493] pcieport 0000:00:00.0: PME: Signaling with IRQ 50
[ 6.327460] pcieport 0000:00:00.0: AER: enabled with IRQ 50
[ 6.333412] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 6.338863] tegra194-pcie 141a0000.pcie: Failed to get slot regulators: -517
[ 6.338928] vdd-3v3-pcie: supplied by vdd-3v3-sys
[ 6.343555] avdd-cam-2v8: supplied by vdd-3v3-sys
[ 6.348014] vdd-dp: supplied by vdd-3v3-sys
[ 6.352245] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 6.357113] dsi-vdd-1v8-bl-en: supplied by vdd-1v8-sys
[ 6.363543] tegra194-isp5 14800000.isp: initialized
[ 6.371940] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[ 6.372945] (NULL device *): fops function table already registered
[ 6.380904] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[ 6.385814] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 6.385891] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 6.399089] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 288
[ 6.503802] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[ 6.504018] tegra194-pcie 141a0000.pcie: IO 0x003a100000…0x003a1fffff → 0x003a100000
[ 6.504260] tegra194-pcie 141a0000.pcie: MEM 0x2b28000000…0x2b2fffffff → 0x0040000000
[ 6.504492] tegra194-pcie 141a0000.pcie: MEM 0x2740000000…0x2b27ffffff → 0x2740000000
[ 6.610628] tegra194-pcie 141a0000.pcie: Link up
[ 6.613144] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[ 6.613335] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 6.613485] pci_bus 0005:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x3a100000-0x3a1fffff])
[ 6.613752] pci_bus 0005:00: root bus resource [mem 0x2b28000000-0x2b2fffffff] (bus address [0x40000000-0x47ffffff])
[ 6.614025] pci_bus 0005:00: root bus resource [mem 0x2740000000-0x2b27ffffff pref]
[ 6.614260] pci 0005:00:00.0: [10de:229a] type 01 class 0x060400
[ 6.614524] pci 0005:00:00.0: PME# supported from D0 D3hot
[ 6.617360] pci 0005:01:00.0: [8086:1533] type 00 class 0x020000
[ 6.617623] pci 0005:01:00.0: reg 0x10: [mem 0x00000000-0x000fffff]
[ 6.617929] pci 0005:01:00.0: reg 0x1c: [mem 0x00000000-0x00003fff]
[ 6.618235] pci 0005:01:00.0: reg 0x30: [mem 0x00000000-0x000fffff pref]
[ 6.618973] pci 0005:01:00.0: PME# supported from D0 D3hot D3cold
[ 6.621797] pci 0005:00:00.0: BAR 14: assigned [mem 0x2b28000000-0x2b282fffff]
[ 6.621983] pci 0005:01:00.0: BAR 0: assigned [mem 0x2b28000000-0x2b280fffff]
[ 6.622185] pci 0005:01:00.0: BAR 6: assigned [mem 0x2b28100000-0x2b281fffff pref]
[ 6.629126] pci 0005:01:00.0: BAR 3: assigned [mem 0x2b28200000-0x2b28203fff]
[ 6.636318] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 6.641550] pci 0005:00:00.0: bridge window [mem 0x2b28000000-0x2b282fffff]
[ 6.648908] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 6.657608] pci 0005:01:00.0: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
[ 6.666410] pcieport 0005:00:00.0: Adding to iommu group 11
[ 6.672054] pcieport 0005:00:00.0: PME: Signaling with IRQ 52
[ 6.677887] pcieport 0005:00:00.0: AER: enabled with IRQ 52
[ 6.683430] igb 0005:01:00.0: Adding to iommu group 11
[ 6.688417] igb 0005:01:00.0: enabling device (0000 → 0002)
[ 6.727976] pps_core: source ptp0 got cdev (246:0)
[ 6.727981] pps pps0: new PPS source ptp0
[ 6.728506] igb 0005:01:00.0: added PHC on eth0
[ 6.728628] igb 0005:01:00.0: Intel(R) Gigabit Ethernet Network Connection
[ 6.728806] igb 0005:01:00.0: eth0: (PCIe:2.5Gb/s:Width x1) 6c:b3:11:5d:00:12
[ 6.729288] igb 0005:01:00.0: eth0: PBA No: G65055-009
[ 6.729426] igb 0005:01:00.0: Using MSI-X interrupts. 4 rx queue(s), 4 tx queue(s)
[ 6.730416] nvethernet 2310000.ethernet: Adding to iommu group 42
[ 6.735989] nvethernet 2310000.ethernet: failed to read skip mac reset flag, default 0
[ 6.743859] nvethernet 2310000.ethernet: failed to read MDIO address
[ 6.750229] nvethernet 2310000.ethernet: Failed to read nvida,pause_frames, so setting to default support as disable
[ 6.760816] nvethernet 2310000.ethernet: setting to default DMA bit mask
[ 6.780377] nvethernet 2310000.ethernet: Ethernet MAC index missing
[ 6.780593] nvethernet 2310000.ethernet: Ethernet MAC address: 48:b0:2d:69:48:06
[ 6.781054] -->macsec_probe()
[ 6.781062] -->macsec_get_platform_res()
[ 6.781078] <–macsec_get_platform_res()
[ 6.781079] -->macsec_enable_car()
[ 6.781896] <–macsec_enable_car()
[ 6.781911] <–macsec_probe()
[ 6.781913] nvethernet 2310000.ethernet: Macsec not enabled
[ 6.786635] nvethernet 2310000.ethernet: Macsec: Reduced MTU: 1466 Max: 16383
[ 6.796067] nvethernet 2310000.ethernet: eth1 (HW ver: 53) created with 8 DMA channels
[ 6.802185] irq: IRQ295: trimming hierarchy from :pmc@c360000
[ 6.807688] irq: IRQ296: trimming hierarchy from :interrupt-controller@f400000-1
[ 6.815109] irq: IRQ297: trimming hierarchy from :pmc@c360000
[ 6.820726] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 6.828068] tegra-se-nvhost 15810000.se: Adding to iommu group 43
[ 6.834194] tegra-se-nvhost 15810000.se: initialized
[ 6.846283] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 6.846532] tegra-se-nvhost 15820000.se: Adding to iommu group 44
[ 6.851476] tegra-se-nvhost 15820000.se: initialized
[ 6.858376] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 6.861975] tegra-se-nvhost 15840000.se: Adding to iommu group 45
[ 6.868538] tegra-se-nvhost 15840000.se: initialized
[ 6.875344] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 6.879724] tegra_actmon d230000.actmon: in actmon_register()…
[ 6.885440] tegra_actmon d230000.actmon: bwmgr_disable = 1
[ 6.891418] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 6.898856] hvc_sysfs: hypervisor is not present
[ 6.934602] ALSA device list:
[ 6.934695] No soundcards found.
[ 6.935344] Freeing unused kernel memory: 3968K
[ 6.938518] Run /init as init process
[ 6.938625] with arguments:
[ 6.938626] /init
[ 6.938627] with environment:
[ 6.938628] HOME=/
[ 6.938629] TERM=linux
[ 6.938629] mminit_loglevel=4
[ 6.949379] Root device found: mmcblk0p1
[ 6.949953] Found dev node: /dev/mmcblk0p1
[ 7.169311] EXT4-fs (mmcblk0p1): recovery complete
[ 7.170082] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 7.171251] Rootfs mounted over mmcblk0p1
[ 7.178473] Switching from initrd to actual rootfs
[ 7.271811] systemd[1]: System time before build time, advancing clock.
[ 7.304692] systemd[1]: systemd 245.4-4ubuntu3.15 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 7.305760] systemd[1]: Detected architecture arm64.
[ 7.329773] systemd[1]: Set hostname to .
[ 7.460910] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[ 7.508042] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 7.508438] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 7.509481] systemd[1]: Created slice system-modprobe.slice.
[ 7.510059] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 7.510565] systemd[1]: Created slice User and Session Slice.
[ 7.510843] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 7.511300] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 7.511646] systemd[1]: Reached target User and Group Name Lookups.
[ 7.511876] systemd[1]: Reached target Slices.
[ 7.512048] systemd[1]: Reached target Swap.
[ 7.512381] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 7.512703] systemd[1]: Listening on Syslog Socket.
[ 7.512957] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 7.513234] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 7.513617] systemd[1]: Listening on Journal Audit Socket.
[ 7.517665] systemd[1]: Listening on Journal Socket (/dev/log).
[ 7.523773] systemd[1]: Listening on Journal Socket.
[ 7.528708] systemd[1]: Listening on udev Control Socket.
[ 7.534167] systemd[1]: Listening on udev Kernel Socket.
[ 7.540518] systemd[1]: Mounting Huge Pages File System…
[ 7.546236] systemd[1]: Mounting POSIX Message Queue File System…
[ 7.552228] systemd[1]: Mounting RPC Pipe File System…
[ 7.557575] systemd[1]: Mounting Kernel Debug File System…
[ 7.563376] systemd[1]: Mounting Kernel Trace File System…
[ 7.569272] systemd[1]: Starting Journal Service…
[ 7.574165] systemd[1]: Starting Set the console keyboard layout…
[ 7.580355] systemd[1]: Starting Create list of static device nodes for the current kernel…
[ 7.588127] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 7.597300] systemd[1]: Started Nameserver information manager.
[ 7.602563] systemd[1]: Reached target Network (Pre).
[ 7.610238] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 7.616645] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 7.627382] systemd[1]: Starting Load Kernel Modules…
[ 7.631816] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 7.637382] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 7.643990] systemd[1]: Starting udev Coldplug all Devices…
[ 7.650028] systemd[1]: Mounted Huge Pages File System.
[ 7.654245] systemd[1]: Started Journal Service.
[ 7.688502] systemd-journald[305]: Received client request to flush runtime journal.
[ 8.014232] tegra-xusb 3610000.xhci: entering ELPG done
[ 9.532241] nvidia: loading out-of-tree module taints kernel.
[ 9.538592] nv_platform 13800000.display: Adding to iommu group 46
[ 9.543925] platform 13800000.display:nvdisplay-niso: Adding to iommu group 47
[ 9.547169] NVRM: loading NVIDIA UNIX Kernel Module for aarch64 34.1.0 Release Build (buildbrain@mobile-u64-5280-d6000) Wed Apr 6 12:07:34 PDT 2022
[ 9.559870] spi-tegra114 3210000.spi: Adding to iommu group 3
[ 9.571004] spi-tegra114 3230000.spi: Adding to iommu group 3
[ 9.603733] cpu-throttle-alert cooling device registered.
[ 9.604261] gpu-throttle-alert cooling device registered.
[ 9.604741] cv0-throttle-alert cooling device registered.
[ 9.605184] cv1-throttle-alert cooling device registered.
[ 9.605618] cv2-throttle-alert cooling device registered.
[ 9.606376] soc0-throttle-alert cooling device registered.
[ 9.607135] soc1-throttle-alert cooling device registered.
[ 9.607366] soc2-throttle-alert cooling device registered.
[ 9.607934] hot-surface-alert cooling device registered.
[ 9.618225] libata version 3.00 loaded.
[ 9.621748] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
[ 9.621877] irq: IRQ298: trimming hierarchy from :pmc@c360000
[ 9.622158] nct1008_nct72 4-004c: starting parse dt
[ 9.622329] nct1008_nct72 4-004c: !!!Found deprecated property!!!
[ 9.622561] nct1008_nct72 4-004c: success parsing dt
[ 9.622779] nct1008_nct72 4-004c: success in enabling tmp451 VDD rail
[ 9.658795] nct1008_nct72 4-004c: LOC shutdown limit 107
[ 9.659582] nct1008_nct72 4-004c: EXT shutdown limit 107
[ 9.669256] nvadsp 2993000.adsp: Adding to iommu group 48
[ 9.669617] nvadsp 2993000.adsp: in probe()…
[ 9.672368] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 9.682971] qspi_mtd spi6.0: MX25U51279G (65536 Kbytes)
[ 9.683145] qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x4000000 (64MiB) .erasesize = 0x00010000 (64KiB) .numeraseregions = 0
[ 9.683809] tegra-hda 3510000.hda: Adding to iommu group 49
[ 9.696265] nct1008_nct72 4-004c: initial LOC temp: 30000
[ 9.696902] nct1008_nct72 4-004c: initial EXT temp: 36500
[ 9.697997] nct1008_nct72 4-004c: hi_b:-4, lo_b:0
[ 9.698910] nct1008_nct72 4-004c: nct1008_probe: initialized
[ 9.699987] ahci 0000:01:00.0: Adding to iommu group 10
[ 9.700553] ahci 0000:01:00.0: version 3.0
[ 9.701443] ahci 0000:01:00.0: AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
[ 9.701703] ahci 0000:01:00.0: flags: 64bit ncq sntf led only pmp fbs pio slum part sxs
[ 9.708640] scsi host0: ahci
[ 9.710317] scsi host1: ahci
[ 9.714884] ata1: SATA max UDMA/133 abar m512@0x2728010000 port 0x2728010100 irq 300
[ 9.715128] ata2: SATA max UDMA/133 abar m512@0x2728010000 port 0x2728010180 irq 300
[ 9.739222] irq: IRQ301: trimming hierarchy from :pmc@c360000
[ 9.739793] ucsi_ccg 1-0008: i2c_transfer failed -121
[ 9.739956] ucsi_ccg 1-0008: ucsi_ccg_init failed - -121
[ 9.742848] ucsi_ccg: probe of 1-0008 failed with error -121
[ 9.748540] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=3 as /devices/platform/3510000.hda/sound/card0/input1
[ 9.749380] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=7 as /devices/platform/3510000.hda/sound/card0/input2
[ 9.751990] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=8 as /devices/platform/3510000.hda/sound/card0/input3
[ 9.766834] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=9 as /devices/platform/3510000.hda/sound/card0/input4
[ 9.772873] 1 fixed-partitions partitions found on MTD device spi6.0
[ 9.778872] Creating 1 MTD partitions on “spi6.0”:
[ 9.783610] 0x000000000000-0x000004000000 : “Whole_flash0”
[ 9.796202] tegra-asoc: sound: Adding to iommu group 48
[ 9.814980] tegra210-adsp aconnect@2a41000:adsp_audio: Adding to iommu group 48
[ 9.815248] tegra210_adsp_audio_probe: platform probe started
[ 9.815762] tegra210-adsp tegra210-adsp: Default param-type to BYTE for mp3-dec1
[ 9.816220] tegra210-adsp tegra210-adsp: Default param-type to BYTE for spkprot
[ 9.822335] tegra210-adsp tegra210-adsp: Default param-type to BYTE for src
[ 9.829259] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aac-dec1
[ 9.836683] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aec
[ 9.843822] tegra210-adsp tegra210-adsp: Default param-type to BYTE for wire
[ 9.850204] tegra210-adsp tegra210-adsp: adma channel page address dt entry not found
[ 9.858829] tegra210-adsp tegra210-adsp: using adma channel page 0
[ 9.865108] nvadsp 2993000.adsp: ADSP OS firmware already loaded
[ 9.877664] cryptd: max_cpu_qlen set to 1000
[ 9.878515] nvgpu: 17000000.ga10b nvgpu_nvhost_syncpt_init:135 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[ 10.028781] ata1: SATA link down (SStatus 0 SControl 300)
[ 10.029029] ata2: SATA link down (SStatus 0 SControl 300)
[ 10.206063] tegra210-adsp tegra210-adsp: Loaded app wire
[ 10.206069] tegra210-adsp tegra210-adsp: Loaded app apm
[ 10.206071] tegra210-adsp tegra210-adsp: Loaded app adma
[ 10.206072] tegra210-adsp tegra210-adsp: Loaded app adma_tx
[ 10.206074] nvadsp_set_adma_dump_reg: callback for adma reg dump is sent to 000000009863600a
[ 10.212191] using random self ethernet address
[ 10.212339] using random host ethernet address
[ 10.231177] tegra210-adsp tegra210-adsp: Tegra210 ADSP driver successfully registered
[ 10.607035] loop: module loaded
[ 10.743712] libphy: nvethernet_mdio_bus: probed
[ 10.805340] Mass Storage Function, version: 2009/09/11
[ 10.805347] LUN: removable file: (no medium)
[ 10.807715] using random self ethernet address
[ 10.807869] using random host ethernet address
[ 10.830699] nvgpu: 17000000.ga10b tpc_pg_mask_store:1042 [INFO] no value change, same mask already set
[ 10.863346] rndis0: HOST MAC e6:53:53:0f:79:20
[ 10.863409] rndis0: MAC e6:53:53:0f:79:21
[ 10.863733] usb0: HOST MAC e6:53:53:0f:79:22
[ 10.863769] usb0: MAC e6:53:53:0f:79:23
[ 10.865723] tegra-xudc 3550000.xudc: EP 0 (type: ctrl, dir: out) enabled
[ 10.868265] l4tbr0: port 1(rndis0) entered blocking state
[ 10.868277] l4tbr0: port 1(rndis0) entered disabled state
[ 10.868408] device rndis0 entered promiscuous mode
[ 10.873478] l4tbr0: port 2(usb0) entered blocking state
[ 10.873490] l4tbr0: port 2(usb0) entered disabled state
[ 10.873665] device usb0 entered promiscuous mode
[ 12.483212] zram: Added device: zram0
[ 12.484353] zram: Added device: zram1
[ 12.484901] zram: Added device: zram2
[ 12.485548] zram: Added device: zram3
[ 12.486121] zram: Added device: zram4
[ 12.486675] zram: Added device: zram5
[ 12.487328] zram: Added device: zram6
[ 12.488330] zram: Added device: zram7
[ 12.488484] zram: Added device: zram8
[ 12.488677] zram: Added device: zram9
[ 12.489047] zram: Added device: zram10
[ 12.489911] zram: Added device: zram11
[ 12.543494] zram0: detected capacity change from 0 to 1337937920
[ 12.694586] Adding 1306576k swap on /dev/zram0. Priority:5 extents:1 across:1306576k SS
[ 12.697441] zram1: detected capacity change from 0 to 1337937920
[ 12.746599] Adding 1306576k swap on /dev/zram1. Priority:5 extents:1 across:1306576k SS
[ 12.748053] zram2: detected capacity change from 0 to 1337937920
[ 12.802570] Adding 1306576k swap on /dev/zram2. Priority:5 extents:1 across:1306576k SS
[ 12.803994] zram3: detected capacity change from 0 to 1337937920
[ 12.838640] Adding 1306576k swap on /dev/zram3. Priority:5 extents:1 across:1306576k SS
[ 12.840243] zram4: detected capacity change from 0 to 1337937920
[ 12.894580] Adding 1306576k swap on /dev/zram4. Priority:5 extents:1 across:1306576k SS
[ 12.897078] zram5: detected capacity change from 0 to 1337937920
[ 12.946551] Adding 1306576k swap on /dev/zram5. Priority:5 extents:1 across:1306576k SS
[ 12.948499] zram6: detected capacity change from 0 to 1337937920
[ 12.982921] Adding 1306576k swap on /dev/zram6. Priority:5 extents:1 across:1306576k SS
[ 12.985501] zram7: detected capacity change from 0 to 1337937920
[ 13.030571] Adding 1306576k swap on /dev/zram7. Priority:5 extents:1 across:1306576k SS
[ 13.032709] zram8: detected capacity change from 0 to 1337937920
[ 13.086590] Adding 1306576k swap on /dev/zram8. Priority:5 extents:1 across:1306576k SS
[ 13.088744] zram9: detected capacity change from 0 to 1337937920
[ 13.138535] Adding 1306576k swap on /dev/zram9. Priority:5 extents:1 across:1306576k SS
[ 13.139821] zram10: detected capacity change from 0 to 1337937920
[ 13.198604] Adding 1306576k swap on /dev/zram10. Priority:5 extents:1 across:1306576k SS
[ 13.201174] zram11: detected capacity change from 0 to 1337937920
[ 13.234539] Adding 1306576k swap on /dev/zram11. Priority:5 extents:1 across:1306576k SS
[ 13.454961] Bridge firewalling registered
[ 13.911214] igb 0005:01:00.0 eth0: igb: eth0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[ 14.018999] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 14.946929] nvethernet 2310000.ethernet eth1: Link is Up - 1Gbps/Full - flow control off
[ 14.947027] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[ 23.626591] nvidia-modeset: Loading NVIDIA UNIX Kernel Mode Setting Driver for aarch64 34.1.0 Release Build (buildbrain@mobile-u64-5280-d6000) Wed Apr 6 12:07:36 PDT 2022
[ 23.626644] NVRM gpumgrGetSomeGpu: Failed to retrieve pGpu - Too early call!.
[ 23.626648] NVRM nvAssertFailedNoLog: Assertion failed: NV_FALSE @ gpu_mgr.c:295
[ 23.626654] CPU: 1 PID: 1805 Comm: modprobe Tainted: G O 5.10.65-tegra #2
[ 23.626655] Hardware name: /, BIOS r34.1-975eef6 04/06/2022
[ 23.626657] Call trace:
[ 23.626667] dump_backtrace+0x0/0x1a0
[ 23.626670] show_stack+0x2c/0x40
[ 23.626676] dump_stack+0xd8/0x138
[ 23.626706] os_dump_stack+0x14/0x1c [nvidia]
[ 23.626725] tlsEntryUnreference+0x198/0x1a0 [nvidia]
[ 23.626741] gpumgrGetSomeGpu+0x80/0x98 [nvidia]
[ 23.626756] threadPriorityRestore+0xa8/0x2f0 [nvidia]
[ 23.626771] rmclientConstruct_IMPL+0x160/0x258 [nvidia]
[ 23.626786] __nvoc_ctor_RmClient+0x5c/0x88 [nvidia]
[ 23.626801] __nvoc_objCreate_RmClient+0x7c/0x118 [nvidia]
[ 23.626815] resservClientFactory+0x28/0x90 [nvidia]
[ 23.626830] serverAllocClient+0x19c/0x318 [nvidia]
[ 23.626845] serverAllocResource+0x140/0x2e8 [nvidia]
[ 23.626860] rmapiAllocWithSecInfo+0x17c/0x2e8 [nvidia]
[ 23.626875] rmapiAllocWithSecInfoTls+0x74/0xa8 [nvidia]
[ 23.626889] rmapiInitDeprecatedContext+0x520/0x598 [nvidia]
[ 23.626931] nvkms_call_rm+0x5c/0x90 [nvidia_modeset]
[ 23.626962] nvRmApiAlloc+0x30/0x40 [nvidia_modeset]
[ 23.626965] do_one_initcall+0x4c/0x2d0
[ 23.626968] do_init_module+0x5c/0x210
[ 23.626970] load_module+0x2068/0x2680
[ 23.626971] __do_sys_finit_module+0xb4/0xf0
[ 23.626973] __arm64_sys_finit_module+0x28/0x40
[ 23.626976] el0_svc_common.constprop.0+0x7c/0x1c0
[ 23.626977] do_el0_svc+0x34/0xa0
[ 23.626980] el0_svc+0x1c/0x30
[ 23.626982] el0_sync_handler+0xa8/0xb0
[ 23.626983] el0_sync+0x16c/0x180
[ 23.626988] NVRM gpumgrGetSomeGpu: Failed to retrieve pGpu - Too early call!.
[ 23.626990] NVRM nvAssertFailedNoLog: Assertion failed: NV_FALSE @ gpu_mgr.c:295
[ 23.663880] fuse: init (API version 7.32)
[ 37.858900] vdd-12v-sys: disabling
[ 37.858933] vdd-3v3-ftdi: disabling
[ 37.858957] avdd-cam-2v8: disabling
[ 37.858972] dsi-vdd-1v8-bl-en: disabling
Jetpack 5.1 is released. Please try the latest release and see if the issue still exists.
