Please provide the following info:
Hardware Platform: DRIVE AGX Xavier™ NX
Software Version: Unknown
Host Machine Version: native Ubuntu 18.04
SDK Manager Version: Unknown
Hello, we have over 4 x AHD cameras via pCIE bus on jeston platform, we added a patch as below to success to get camera data on TX2.
diff --git a/hardware/nvidia/soc/t18x/kernel-dts/tegra186-soc/tegra186-soc-base.dtsi b/hardware/nvidia/soc/t18x/kernel-dts/tegra186-soc/tegra186-soc-base.dtsi
index 9f0d21b1…a01ddaa2 100644
— a/hardware/nvidia/soc/t18x/kernel-dts/tegra186-soc/tegra186-soc-base.dtsi
+++ b/hardware/nvidia/soc/t18x/kernel-dts/tegra186-soc/tegra186-soc-base.dtsi
@@ -1846,13 +1846,6 @@
interrupt-map-mask = <0 0 0 0>;
interrupt-map = <0 0 0 0 &intc 0 72 0x04>;// check this
iommus = <&smmu TEGRA_SID_AFI>; -
iommu_sodev_map;
-#if LINUX_VERSION >= 414
iommu-map = <0x0 &smmu TEGRA_SID_AFI 0x1000>; -
iommu-map-mask = <0x0>;
-#endif
bus-range = <0x00 0xff>;
#address-cells = <3>;
#size-cells = <2>;
Now we tried on Xavier NX, fail to get camera data, below is dmesg log:
0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (xhz@xhz-omen) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Mon Jun 15 10:25:14 CST 2020
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44600000
[ 0.000000] OF: fdt: - 100000000 , 180000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options ‘’)
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] Found tegra_fbmem: 00800000@a069c000
[ 0.000000] Found lut_mem: 00002008@a0696000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb2_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb3_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[ 0.000000] cma: Reserved 64 MiB at 0x00000000c2000000
[ 0.000000] On node 0 totalpages: 2030589
[ 0.000000] DMA zone: 7152 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 457725 pages, LIFO batch:31
[ 0.000000] Normal zone: 24576 pages used for memmap
[ 0.000000] Normal zone: 1572864 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc1ffd05000 s61656 r8192 d32552 u102400
[ 0.000000] pcpu-alloc: s61656 r8192 d32552 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1998861
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt tegra_fbmem=0x800000@0xa069c000 lut_mem=0x2008@0xa0696000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1 quiet
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29216(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7182192K/8122356K available (15294K kernel code, 2934K rwdata, 6676K rodata, 8576K init, 609K bss, 186500K reserved, 753664K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f70000 ( 15296 KB)
[ 0.000000] .rodata : 0xffffff8008f70000 - 0xffffff8009600000 ( 6720 KB)
[ 0.000000] .init : 0xffffff8009600000 - 0xffffff8009e60000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e60000 - 0xffffff800a13d808 ( 2935 KB)
[ 0.000000] .bss : 0xffffff800a13d808 - 0xffffff800a1d5f3c ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf08000000 ( 128 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc200000000 ( 8192 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000004] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000715] Console: colour dummy device 80x25
[ 0.000726] console [tty0] enabled
[ 0.000734] bootconsole [tegra_comb_uart0] disabled
[ 0.000747] kmemleak: Kernel memory leak detector disabled
[ 0.000764] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.000779] pid_max: default: 32768 minimum: 301
[ 0.001858] Security Framework initialized
[ 0.002434] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.002444] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.004072] ftrace: allocating 47094 entries in 184 pages
[ 0.398487] sched-energy: Sched-energy-costs installed from DT
[ 0.398508] ASID allocator initialised with 65536 entries
[ 0.433486] tegra-id: chipid=21917.
[ 0.433497] tegra-id: opt_subrevision=1.
[ 0.433523] Tegra Revision: A02 SKU: 0xde CPU Process: 0 SoC Process: 0
[ 0.433556] DTS File Name: /home/xhz/nvidia/source/Linux_for_Tegra/source/public/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[ 0.433566] DTB Build time: Jun 16 2020 16:26:52
[ 0.481549] CPU1: Booted secondary processor [4e0f0040]
[ 0.513740] CPU2: Booted secondary processor [4e0f0040]
[ 0.545852] CPU3: Booted secondary processor [4e0f0040]
[ 0.578119] CPU4: Booted secondary processor [4e0f0040]
[ 0.610208] CPU5: Booted secondary processor [4e0f0040]
[ 0.610430] Brought up 6 CPUs
[ 0.610440] SMP: Total of 6 processors activated.
[ 0.610449] CPU features: detected feature: Privileged Access Never
[ 0.610455] CPU features: detected feature: LSE atomic instructions
[ 0.610461] CPU features: detected feature: User Access Override
[ 0.610467] CPU features: detected feature: 32-bit EL0 Support
[ 0.611883] CPU: All CPU(s) started at EL2
[ 0.611952] alternatives: patching kernel code
[ 0.618341] devtmpfs: initialized
[ 0.657755] Initilizing CustomIPI irq domain
[ 0.658048] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.658062] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.670126] pinctrl core: initialized pinctrl subsystem
[ 0.670341] OS set in device tree is not L4T.
[ 0.670669] regulator-dummy: no parameters
[ 0.670888] Initializing plugin-manager
[ 0.670941] Plugin module not found
[ 0.670980] Plugin-manager status disabled
[ 0.672311] NET: Registered protocol family 16
[ 0.673667] pstore: using zlib compression
[ 0.673692] console [pstore-1] enabled
[ 0.673700] pstore: Registered ramoops as persistent store backend
[ 0.673709] ramoops: attached 0x200000@0xf0600000, ecc: 0/0
[ 0.696894] cpuidle: using governor menu
[ 0.698178] bpmp: waiting for handshake
[ 0.698190] bpmp: handshake completed
[ 0.698211] bpmp: synchronizing channels
[ 0.698222] bpmp: channels synchronized
[ 0.698231] bpmp: mail init ok
[ 0.701021] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[ 0.701207] t19x-arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.701213] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.701220] t19x-arm-smmu 12000000.iommu: stage 1 translation
[ 0.701225] t19x-arm-smmu 12000000.iommu: stage 2 translation
[ 0.701253] t19x-arm-smmu 12000000.iommu: nested translation
[ 0.701262] t19x-arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.701269] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.701276] t19x-arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.701282] t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.701288] t19x-arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
[ 0.704390] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009e64000)
[ 0.704420] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.707060] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.708312] Registering BPMP clocks…
[ 0.708418] tegra_bpmp_clk_init: clock init ok (400 clks)
[ 0.709086] Serial: AMBA PL011 UART driver
[ 0.709208] tegra_powergate_init: DONE
[ 0.709298] DTS File Name: /home/xhz/nvidia/source/Linux_for_Tegra/source/public/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[ 0.709314] DTB Build time: Jun 16 2020 16:26:52
[ 0.712117] Tegra reboot handler registered.
[ 0.721017] iommu: Adding device 2490000.ether_qos to group 0
[ 0.721515] iommu: Adding device 3100000.serial to group 1
[ 0.721974] iommu: Adding device 3110000.serial to group 2
[ 0.722331] iommu: Adding device 3140000.serial to group 3
[ 0.722911] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.723293] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.723319] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.723326] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 0.723334] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.723407] tegra-pmc: PMC Prod config success
[ 0.723606] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.723619] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.723912] iommu: Adding device 3460000.sdhci to group 4
[ 0.724402] iommu: Adding device 3210000.spi to group 5
[ 0.724826] iommu: Adding device 3230000.spi to group 6
[ 0.725224] iommu: Adding device 3270000.spi to group 7
[ 0.726296] iommu: Adding device 3160000.i2c to group 8
[ 0.726653] iommu: Adding device c240000.i2c to group 9
[ 0.727007] iommu: Adding device 3180000.i2c to group 10
[ 0.727376] iommu: Adding device 3190000.i2c to group 11
[ 0.727850] iommu: Adding device 31b0000.i2c to group 12
[ 0.728260] iommu: Adding device 31c0000.i2c to group 13
[ 0.728771] iommu: Adding device c250000.i2c to group 14
[ 0.729254] iommu: Adding device 31e0000.i2c to group 15
[ 0.729806] iommu: Adding device sound to group 16
[ 0.730339] iommu: Adding device 3510000.hda to group 17
[ 0.730891] iommu: Adding device bc00000.rtcpu to group 18
[ 0.732817] iommu: Adding device 13e10000.host1x to group 19
[ 0.733252] iommu: Adding device 13e10000.host1x:ctx0 to group 20
[ 0.733600] iommu: Adding device 13e10000.host1x:ctx1 to group 21
[ 0.733999] iommu: Adding device 13e10000.host1x:ctx2 to group 22
[ 0.734367] iommu: Adding device 13e10000.host1x:ctx3 to group 23
[ 0.734695] iommu: Adding device 13e10000.host1x:ctx4 to group 24
[ 0.735068] iommu: Adding device 13e10000.host1x:ctx5 to group 25
[ 0.735408] iommu: Adding device 13e10000.host1x:ctx6 to group 26
[ 0.735843] iommu: Adding device 13e10000.host1x:ctx7 to group 27
[ 0.736312] iommu: Adding device 15340000.vic to group 28
[ 0.736708] iommu: Adding device 15380000.nvjpg to group 29
[ 0.736985] iommu: Adding device 15500000.tsec to group 30
[ 0.737272] iommu: Adding device 15100000.tsecb to group 31
[ 0.737522] iommu: Adding device 15480000.nvdec to group 32
[ 0.737820] iommu: Adding device 15140000.nvdec1 to group 33
[ 0.738071] iommu: Adding device 154c0000.nvenc to group 34
[ 0.738309] iommu: Adding device 15a80000.nvenc1 to group 35
[ 0.738700] iommu: Adding device 15880000.nvdla0 to group 36
[ 0.739301] iommu: Adding device 158c0000.nvdla1 to group 37
[ 0.739850] iommu: Adding device 15200000.nvdisplay to group 38
[ 0.740041] platform 15200000.nvdisplay: IOVA linear map 0x00000000a069c000(800000)
[ 0.740052] platform 15200000.nvdisplay: IOVA linear map 0x00000000a0696000(3000)
[ 0.744045] platform 15200000.nvdisplay: IOVA linear map 0x00000000c6000000(2a000000)
[ 0.744114] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[ 0.744824] iommu: Adding device 15210000.nvdisplay to group 39
[ 0.744894] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[ 0.746584] iommu: Adding device 15c10000.vi to group 40
[ 0.746743] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[ 0.747167] iommu: Adding device 14800000.isp to group 41
[ 0.748009] iommu: Adding device 16000000.pva0 to group 42
[ 0.748552] iommu: Adding device 16800000.pva1 to group 43
[ 0.748940] iommu: Adding device 15810000.se to group 44
[ 0.749359] iommu: Adding device 15820000.se to group 45
[ 0.749645] iommu: Adding device 15830000.se to group 46
[ 0.749915] iommu: Adding device 15840000.se to group 47
[ 0.750148] iommu: Adding device c1a0000.aon to group 48
[ 0.751550] iommu: Adding device d000000.bpmp to group 49
[ 0.751896] bpmp: ping status is 0
[ 0.752020] bpmp d000000.bpmp: firmware tag is 57f8a77779f848bf2ecf21dabee5645f
[ 0.755357] bpmp d000000.bpmp: probe ok
[ 0.756903] tegra-reset 0.bpmp_reset: registered 190 resets.
[ 0.757371] iommu: Adding device smmu_test to group 50
[ 0.758371] mc: mapped MMIO address: 0xffffff800a590000 → 0x2c10000
[ 0.758394] mc: mapped MMIO address: 0xffffff800a5b0000 → 0x2c20000
[ 0.758412] mc: mapped MMIO address: 0xffffff800a5d0000 → 0x2c30000
[ 0.758431] mc: mapped MMIO address: 0xffffff800a7b0000 → 0x2c40000
[ 0.758449] mc: mapped MMIO address: 0xffffff800a7d0000 → 0x2c50000
[ 0.758473] mc: mapped MMIO address: 0xffffff800b010000 → 0x2b80000
[ 0.758491] mc: mapped MMIO address: 0xffffff800b030000 → 0x2b90000
[ 0.758508] mc: mapped MMIO address: 0xffffff800b050000 → 0x2ba0000
[ 0.758525] mc: mapped MMIO address: 0xffffff800b070000 → 0x2bb0000
[ 0.758542] mc: mapped MMIO address: 0xffffff800b090000 → 0x1700000
[ 0.758559] mc: mapped MMIO address: 0xffffff800b0b0000 → 0x1710000
[ 0.758575] mc: mapped MMIO address: 0xffffff800b0d0000 → 0x1720000
[ 0.758592] mc: mapped MMIO address: 0xffffff800b0f0000 → 0x1730000
[ 0.758608] mc: mapped MMIO address: 0xffffff800b110000 → 0x1740000
[ 0.758640] mc: mapped MMIO address: 0xffffff800b130000 → 0x1750000
[ 0.758657] mc: mapped MMIO address: 0xffffff800b150000 → 0x1760000
[ 0.758677] mc: mapped MMIO address: 0xffffff800b170000 → 0x1770000
[ 0.758744] mc-err: mcerr ops are set to t19x
[ 0.765152] iommu: Adding device 2600000.dma to group 51
[ 0.770361] GPIO line 339 (wifi-enable) hogged as output/high
[ 0.770400] GPIO line 412 (camera-control-output-low) hogged as output/low
[ 0.770459] GPIO line 413 (camera-control-output-low) hogged as output/low
[ 0.770754] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.777684] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[ 0.777967] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[ 0.779979] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.779990] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.780626] iommu: Adding device 3550000.xudc to group 52
[ 0.781242] iommu: Adding device 3610000.xhci to group 53
[ 0.783244] arm64_ras arm64_ras: probed
[ 0.783631] ras_fhi_enable: FHI 468 enabled on CPU0
[ 0.783674] ras_fhi_enable: FHI 469 enabled on CPU1
[ 0.783750] ras_fhi_enable: FHI 470 enabled on CPU2
[ 0.783818] ras_fhi_enable: FHI 471 enabled on CPU3
[ 0.783875] ras_fhi_enable: FHI 472 enabled on CPU4
[ 0.783925] ras_fhi_enable: FHI 473 enabled on CPU5
[ 0.784106] carmel_ras_enable: RAS enabled on cpu0
[ 0.784272] carmel_ras_enable: RAS enabled on cpu1
[ 0.784497] carmel_ras_enable: RAS enabled on cpu2
[ 0.784680] carmel_ras_enable: RAS enabled on cpu3
[ 0.784872] carmel_ras_enable: RAS enabled on cpu4
[ 0.785049] carmel_ras_enable: RAS enabled on cpu5
[ 0.785145] carmel_ras carmel_ras: probed
[ 0.786258] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 477, noc_nonsecure_irq = 476>
[ 0.786769] tegra-cbb c600000.aon-noc: noc_secure_irq = 479, noc_nonsecure_irq = 478>
[ 0.787676] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 481, noc_nonsecure_irq = 480>
[ 0.788601] tegra-cbb be00000.rce-noc: noc_secure_irq = 483, noc_nonsecure_irq = 482>
[ 0.789419] tegra-cbb b600000.sce-noc: noc_secure_irq = 485, noc_nonsecure_irq = 484>
[ 0.789765] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[ 0.790889] vdd-ac-bat: 5000 mV
[ 0.791414] vdd-sdmmc1-sw: 3300 mV
[ 0.791737] vdd-1v8-sd: 1800 mV
[ 0.792060] vdd-usb2-5v: 5000 mV
[ 0.792428] vdd-3v3-cvb: 3300 mV
[ 0.792700] vdd-1v8-cvb: 1800 mV
[ 0.793003] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 0.793043] vdd-epb-1v0: 1000 mV
[ 0.793391] avdd-cam-2v8: 2800 mV
[ 0.793731] vdd-fan: 5000 mV
[ 0.794014] vdd-hdmi-5v0: 5000 mV
[ 0.794320] vdd_sys_en: 1200 mV
[ 0.832819] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.837884] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.838189] SCSI subsystem initialized
[ 0.838423] libata version 3.00 loaded.
[ 0.838634] usbcore: registered new interface driver usbfs
[ 0.838674] usbcore: registered new interface driver hub
[ 0.838751] usbcore: registered new device driver usb
[ 0.849026] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[ 0.851778] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 0.860270] vdd-1v0: at 1000 mV
[ 0.866001] vdd-1v8-hs: at 1800 mV
[ 0.870003] vdd-1v8-ls: at 1800 mV
[ 0.874029] vdd-1v8-ao: at 1800 mV
[ 0.882054] vddio-ddr-1v1: at 1100 mV
[ 0.885822] vdd-rtc: at 800 mV
[ 0.887040] spmic-ldo1: at 2375 mV
[ 0.897877] vdd-ao-3v3: at 3300 mV
[ 0.905908] vddio-emmc-3v3: at 3300 mV
[ 0.907235] spmic-ldo4: at 1587 mV
[ 0.917973] vdd-usb-3v3: at 3300 mV
[ 0.925992] vddio-sdmmc1-3v3: at 3300 mV
[ 0.930002] vdd-csi-1v2: at 1200 mV
[ 0.931515] spmic-ldo8: at 1800 mV
[ 0.936366] GPIO line 246 (gpio_default) hogged as output/high
[ 0.937735] GPIO line 247 (gpio_default) hogged as output/high
[ 0.938097] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[ 0.938424] max77620 4-003c: max77620 probe successful
[ 0.939072] media: Linux media interface: v0.10
[ 0.939157] Linux video capture interface: v2.00
[ 0.940776] pps_core: LinuxPPS API ver. 1 registered
[ 0.940783] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.940874] PTP clock support registered
[ 0.941290] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 0.941606] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.941643] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.944227] trusty trusty: trusty version: Built: 18:08:23 Apr 8 2020
[ 0.944288] trusty trusty: selected api version: 3 (requested 3)
[ 0.945312] Advanced Linux Sound Architecture Driver Initialized.
[ 0.945742] Bluetooth: Core ver 2.22
[ 0.945782] NET: Registered protocol family 31
[ 0.945787] Bluetooth: HCI device and connection manager initialized
[ 0.945797] Bluetooth: HCI socket layer initialized
[ 0.945804] Bluetooth: L2CAP socket layer initialized
[ 0.945826] Bluetooth: SCO socket layer initialized
[ 0.948281] camchar: rtcpu character device driver loaded
[ 0.948766] gpio tegra-gpio wake61 for gpio=201(Z:1)
[ 0.948874] extcon-gpio-states external-connection:extcon@1: Cable state:0, cable id:0
[ 0.950424] clocksource: Switched to clocksource arch_sys_counter
[ 0.991485] VFS: Disk quotas dquot_6.6.0
[ 0.991591] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.991906] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.993345] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[ 0.993394] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[ 0.993666] cma: enabled page replacement for spfn=c6000, epfn=f0000
[ 0.993677] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.993715] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[ 0.993724] nvmap_page_pool_init: Total RAM pages: 1983964
[ 0.993731] nvmap_page_pool_init: nvmap page pool size: 247995 pages (968 MB)
[ 0.994020] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.994316] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[ 0.995943] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 1.007638] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 1.007803] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 1.007960] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[ 1.008132] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[ 1.008291] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 1.009455] la/ptsa driver initialized.
[ 1.009811] NET: Registered protocol family 2
[ 1.010706] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 1.011032] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 1.011611] TCP: Hash tables configured (established 65536 bind 65536)
[ 1.011652] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 1.011768] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 1.012230] NET: Registered protocol family 1
[ 1.012893] RPC: Registered named UNIX socket transport module.
[ 1.012900] RPC: Registered udp transport module.
[ 1.012904] RPC: Registered tcp transport module.
[ 1.012909] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.012920] PCI: CLS 0 bytes, default 64
[ 1.013106] Trying to unpack rootfs image as initramfs…
[ 1.198688] Freeing initrd memory: 5432K
[ 1.213528] random: fast init done
[ 1.218203] host1x 13e10000.host1x: initialized
[ 1.220601] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.224912] audit: initializing netlink subsys (disabled)
[ 1.224959] audit: type=2000 audit(0.844:1): initialized
[ 1.225632] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 1.234013] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.235372] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.236067] 9p: Installing v9fs 9p2000 file system support
[ 1.241177] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.241321] io scheduler noop registered
[ 1.241537] io scheduler cfq registered (default)
[ 1.245003] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 1.249173] iommu: Adding device 2993000.adsp to group 54
[ 1.315771] iommu: Adding device aconnect@2a41000:adsp_audio to group 55
[ 1.316829] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.328135] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.328530] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.329098] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.329493] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[ 1.329877] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.332703] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.332932] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 1.335406] tsec 15500000.tsec: initialized
[ 1.337202] tsec 15100000.tsecb: initialized
[ 1.340764] nvdec 15480000.nvdec: initialized
[ 1.343285] nvdec 15140000.nvdec1: initialized
[ 1.348747] falcon 15340000.vic: initialized
[ 1.350536] falcon 15380000.nvjpg: initialized
[ 1.352511] falcon 154c0000.nvenc: initialized
[ 1.354297] falcon 15a80000.nvenc1: initialized
[ 1.357482] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.360176] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.362851] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.364735] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.366172] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.367605] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.368998] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.370464] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.374072] t194-nvcsi 15a00000.nvcsi: initialized
[ 1.379029] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 1.379487] scare-pigeon 14b00000.isp-thi: initialized
[ 1.385321] pva 16000000.pva0: initialized
[ 1.391150] pva 16800000.pva1: initialized
[ 1.396034] nvdla 15880000.nvdla0: initialized
[ 1.400873] nvdla 158c0000.nvdla1: initialized
[ 1.402335] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.402349] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.402380] tegradccommon 15200000.dc_common: dma mapping done
[ 1.403348] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor1
[ 1.403380] generic_infoframe_type: 0x87
[ 1.403439] tegradc 15200000.nvdisplay: DT parsed successfully
[ 1.403468] tegradc 15200000.nvdisplay: Display dc.ffffff800bd10000 registered with id=0
[ 1.407132] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 7088400 KB/s
[ 1.407139] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 800000000 Hz
[ 1.407145] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 179200000 Hz
[ 1.407375] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[ 1.407386] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[ 1.408092] tegradc 15200000.nvdisplay: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[ 1.410252] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.410262] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.413232] tegradc 15200000.nvdisplay: probed
[ 1.448637] Console: switching to colour frame buffer device 240x67
[ 1.448774] tegradc 15200000.nvdisplay: fb registered
[ 1.449100] gpio tegra-gpio wake63 for gpio=97(M:1)
[ 1.449743] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 1.449829] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 1.452206] Parent Clock set for DC plld2
[ 1.518766] tegradc 15200000.nvdisplay: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_111m_223m
[ 1.519507] tegradc 15200000.nvdisplay: hdmi: get RGB quant from REG programmed by BL.
[ 1.519522] tegradc 15200000.nvdisplay: hdmi: BL set VIC 0
[ 1.519529] tegradc 15200000.nvdisplay: hdmi: get YCC quant from REG programmed by BL.
[ 1.545160] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 1.545167] Extcon AUX1(HDMI) enable
[ 1.545788] tegradc 15210000.nvdisplay: disp1 connected to head1->/host1x/sor
[ 1.545823] tegradc 15210000.nvdisplay: parse_dp_settings: No dp-lt-settings node
[ 1.545906] tegradc 15210000.nvdisplay: DT parsed successfully
[ 1.545971] tegradc 15210000.nvdisplay: Display dc.ffffff800be10000 registered with id=1
[ 1.546219] tegradc 15210000.nvdisplay: vblank syncpt # 11 for dc 1
[ 1.546229] tegradc 15210000.nvdisplay: vpulse3 syncpt # 12 for dc 1
[ 1.554946] tegradc 15210000.nvdisplay: probed
[ 1.555373] tegradc 15210000.nvdisplay: fb registered
[ 1.558690] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.558699] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.558711] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.558727] tegradc 15210000.nvdisplay: blank - powerdown
[ 1.558743] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[ 1.558748] Extcon DP: HPD disabled
[ 1.558752] hpd: hpd_switch 0
[ 1.558758] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.558768] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.558777] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.559046] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=77
[ 1.559057] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[ 1.559281] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 1.559388] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 1.559546] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 1.559554] tegra_cec 3960000.tegra_cec: probed
[ 1.569367] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[ 1.570174] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check disabled
[ 1.570183] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.570582] kfuse 3830000.kfuse: initialized
[ 1.576463] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.579411] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 47, base_baud = 0) is a TEGRA_UART
[ 1.580815] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 48, base_baud = 0) is a TEGRA_UART
[ 1.581538] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 49, base_baud = 0) is a TEGRA_UART
[ 1.582682] console [ttyTCU0] enabled
[ 1.582956] [drm] Initialized
[ 1.594795] brd: module loaded
[ 1.600507] loop: module loaded
[ 1.600632] tegra_profiler: version: 1.141, samples/io: 48/28
[ 1.600798] tegra_profiler: auth: init
[ 1.601447] THERMAL EST: found 3 subdevs
[ 1.601454] THERMAL EST num_resources: 0
[ 1.601461] [THERMAL EST subdev 0]
[ 1.601468] [THERMAL EST subdev 1]
[ 1.601475] [THERMAL EST subdev 2]
[ 1.601492] THERMAL EST: Found 2 profiles, default profile is quiet
[ 1.601768] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.601773] THERMAL EST: thz register success.
[ 1.601946] THERMAL EST: end of probe, return err: 0
[ 1.602686] sd: No Scsi addr parsed to reserve index
[ 1.602717] hisi_sas: driver version v1.6
[ 1.612513] qspi_mtd spi6.0: s25fs256s SSG 8 0 1000 2000000
[ 1.612524] qspi_mtd spi6.0: s25fs256s (32768 Kbytes)
[ 1.612534] qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x2000000 (32MiB) .erasesize = 0x00010000 (64KiB) .numeraseregions = 0
[ 1.612748] 1 ofpart partitions found on MTD device spi6.0
[ 1.612754] Creating 1 MTD partitions on “spi6.0”:
[ 1.612764] 0x000000000000-0x000002000000 : “Whole_flash0”
[ 1.615276] libphy: Fixed MDIO Bus: probed
[ 1.615936] tun: Universal TUN/TAP device driver, 1.6
[ 1.615942] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 1.616573] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.616579] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.616629] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.616633] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.616674] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.616679] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.616713] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.616718] Copyright(c) 1999 - 2017 Intel Corporation.
[ 1.677813] tegradc 15200000.nvdisplay: blank - powerdown
[ 1.719143] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 1.719147] Extcon AUX1(HDMI) disable
[ 1.745572] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 1.746700] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 1.766649] tegradc 15200000.nvdisplay: unblank
[ 1.768593] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 1.768879] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 1.777466] Parent Clock set for DC plld2
[ 1.782188] tegradc 15200000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 1.783652] tegradc 15200000.nvdisplay: hdmi: get RGB quant from EDID.
[ 1.783662] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 1.818405] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 1.818411] Extcon AUX1(HDMI) enable
[ 1.862098] eqos 2490000.ether_qos: Setting local MAC: 48 b0 2d 7 58 8e
[ 1.862236] libphy: dwc_phy: probed
[ 1.864536] PPP generic driver version 2.4.2
[ 1.864929] PPP BSD Compression module registered
[ 1.864934] PPP Deflate Compression module registered
[ 1.864952] PPP MPPE Compression module registered
[ 1.864956] NET: Registered protocol family 24
[ 1.864998] usbcore: registered new interface driver r8152
[ 1.865029] usbcore: registered new interface driver asix
[ 1.865060] usbcore: registered new interface driver ax88179_178a
[ 1.865087] usbcore: registered new interface driver cdc_ether
[ 1.865112] usbcore: registered new interface driver net1080
[ 1.865137] usbcore: registered new interface driver cdc_subset
[ 1.865162] usbcore: registered new interface driver zaurus
[ 1.865198] usbcore: registered new interface driver cdc_ncm
[ 1.865658] VFIO - User Level meta-driver version: 0.3
[ 1.866843] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.866860] ehci-pci: EHCI PCI platform driver
[ 1.866889] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.866897] ohci-pci: OHCI PCI platform driver
[ 1.866923] ohci-platform: OHCI generic platform driver
[ 1.871579] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 1.873593] tegra-xusb 3610000.xhci: extcon 0: ffffffc1f569c800 id
[ 1.874238] usbcore: registered new interface driver uas
[ 1.874275] usbcore: registered new interface driver usb-storage
[ 1.874343] usbcore: registered new interface driver usbserial
[ 1.876037] tegra-xusb 3610000.xhci: Firmware timestamp: 2019-07-24 05:47:34 UTC, Version: 60.06 release
[ 1.876072] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 1.876088] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 1.876858] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[ 1.876898] tegra-xusb 3610000.xhci: irq 463, io mem 0x03610000
[ 1.877158] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.877167] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.877174] usb usb1: Product: xHCI Host Controller
[ 1.877181] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.877187] usb usb1: SerialNumber: 3610000.xhci
[ 1.877619] hub 1-0:1.0: USB hub found
[ 1.877670] hub 1-0:1.0: 4 ports detected
[ 1.878091] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 1.878101] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 1.878109] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.878538] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.878546] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.878552] usb usb2: Product: xHCI Host Controller
[ 1.878558] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.878564] usb usb2: SerialNumber: 3610000.xhci
[ 1.878983] hub 2-0:1.0: USB hub found
[ 1.879023] hub 2-0:1.0: 4 ports detected
[ 1.879411] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 1.879486] tegra-xudc-new 3550000.xudc: device count: 1
[ 1.880434] tegra-xudc-new 3550000.xudc: vbus state: 0
[ 1.880443] tegra-xudc-new 3550000.xudc: Initialize boost_cpufreq work
[ 1.880469] tegra-xudc-new 3550000.xudc: entering ELPG
[ 1.880751] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 1.881316] mousedev: PS/2 mouse device common for all mice
[ 1.881422] usbcore: registered new interface driver xpad
[ 2.004920] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 2.006572] Wake73 for irq=42
[ 2.007808] rtc rtc1: alarm rtc device
[ 2.007823] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 2.007859] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.007987] i2c /dev entries driver
[ 2.009978] i2c i2c-2: Added multiplexed i2c bus 9
[ 2.010606] i2c i2c-2: Added multiplexed i2c bus 10
[ 2.010612] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[ 2.011136] imx219 9-0010: tegracam sensor driver:imx219_v2.0.6
[ 2.202461] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 2.231675] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 2.231685] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.231692] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 2.231697] usb 1-2: Manufacturer: Generic
[ 2.232633] hub 1-2:1.0: USB hub found
[ 2.233642] hub 1-2:1.0: 4 ports detected
[ 2.522453] usb 1-2.3: new full-speed USB device number 3 using tegra-xusb
[ 2.545643] usb 1-2.3: New USB device found, idVendor=046d, idProduct=c534
[ 2.545651] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.545677] usb 1-2.3: Product: USB Receiver
[ 2.545685] usb 1-2.3: Manufacturer: Logitech
[ 2.586496] tegra_cec 3960000.tegra_cec: physical address: 10:00.
[ 3.841396] extcon-disp-state external-connection:disp-state: cable 51 state 1
[ 3.841402] Extcon HDMI: HPD enabled
[ 3.841423] tegradc 15200000.nvdisplay: hdmi: plugged
[ 4.698515] tegra_cec 3960000.tegra_cec: timeout in tegra_cec_native_write_l:172.
[ 4.698775] tegra_cec 3960000.tegra_cec: Sent res: -62.
[ 4.698781] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 6.039057] Wake76 for irq=199
[ 6.039064] Wake77 for irq=199
[ 6.039068] Wake78 for irq=199
[ 6.039072] Wake79 for irq=199
[ 6.039076] Wake80 for irq=199
[ 6.039080] Wake81 for irq=199
[ 6.039084] Wake82 for irq=199
[ 6.039130] tegra-xusb 3610000.xhci: Upgrade port 0 to USB3.0
[ 6.039137] tegra-xusb 3610000.xhci: Upgrade port 1 to USB3.0
[ 6.366805] usb 2-3: new SuperSpeed USB device number 2 using tegra-xusb
[ 6.395418] usb 2-3: New USB device found, idVendor=0bda, idProduct=0411
[ 6.395429] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.395436] usb 2-3: Product: 4-Port USB 3.1 Hub
[ 6.395442] usb 2-3: Manufacturer: Generic
[ 6.400971] hub 2-3:1.0: USB hub found
[ 6.402079] hub 2-3:1.0: 4 ports detected
[ 6.566472] usb 2-3: usb_suspend_both: status 0
[ 6.566724] usb usb2: usb_suspend_both: status 0
[ 12.122467] tegra-i2c 3180000.i2c: pio timed out addr: 0x10 tlen:28 rlen:4
[ 12.122707] tegra-i2c 3180000.i2c: — register dump for debugging ----
[ 12.122906] tegra-i2c 3180000.i2c: I2C_CNFG - 0x22c00
[ 12.123048] tegra-i2c 3180000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 12.123251] tegra-i2c 3180000.i2c: I2C_FIFO_CONTROL - 0x0
[ 12.123399] tegra-i2c 3180000.i2c: I2C_FIFO_STATUS - 0x800080
[ 12.123555] tegra-i2c 3180000.i2c: I2C_MST_FIFO_CONTROL - 0x70000
[ 12.123737] tegra-i2c 3180000.i2c: I2C_MST_FIFO_STATUS - 0x7c0000
[ 12.123920] tegra-i2c 3180000.i2c: I2C_MST_PACKET_TRANSFER_CNT - 0x0
[ 12.124091] tegra-i2c 3180000.i2c: I2C_INT_MASK - 0x7d
[ 12.124237] tegra-i2c 3180000.i2c: I2C_INT_STATUS - 0x2
[ 12.124399] tegra-i2c 3180000.i2c: i2c transfer timed out addr: 0x10
[ 12.124626] imx219 9-0010: imx219_board_setup: error during i2c read probe (-110)
[ 12.124872] imx219 9-0010: board setup failed
[ 12.125115] imx219: probe of 9-0010 failed with error -110
[ 12.125590] imx219 10-0010: tegracam sensor driver:imx219_v2.0.6
[ 22.362469] tegra-i2c 3180000.i2c: pio timed out addr: 0x10 tlen:28 rlen:4
[ 22.362688] tegra-i2c 3180000.i2c: — register dump for debugging ----
[ 22.362863] tegra-i2c 3180000.i2c: I2C_CNFG - 0x22c00
[ 22.363004] tegra-i2c 3180000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 22.363180] tegra-i2c 3180000.i2c: I2C_FIFO_CONTROL - 0x0
[ 22.363327] tegra-i2c 3180000.i2c: I2C_FIFO_STATUS - 0x800080
[ 22.363479] tegra-i2c 3180000.i2c: I2C_MST_FIFO_CONTROL - 0x70000
[ 22.363655] tegra-i2c 3180000.i2c: I2C_MST_FIFO_STATUS - 0x7c0000
[ 22.363824] tegra-i2c 3180000.i2c: I2C_MST_PACKET_TRANSFER_CNT - 0x0
[ 22.363996] tegra-i2c 3180000.i2c: I2C_INT_MASK - 0x7d
[ 22.364135] tegra-i2c 3180000.i2c: I2C_INT_STATUS - 0x2
[ 22.364300] tegra-i2c 3180000.i2c: i2c transfer timed out addr: 0x10
[ 22.364549] imx219 10-0010: imx219_board_setup: error during i2c read probe (-110)
[ 22.364804] imx219 10-0010: board setup failed
[ 22.365090] imx219: probe of 10-0010 failed with error -110
[ 22.366786] max77620-power max20024-power: Event recorder REG_NVERC : 0x54
[ 22.373952] tegra-thermal-throttle bthrot_cdev: clk:cpu max:1907200000, min:115200000 steps:24
[ 22.378217] tegra-thermal-throttle bthrot_cdev: clk:gpu max:1109250000, min:114750000 steps:10
[ 22.378263] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
[ 22.378270] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
[ 22.378366] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:48 cutoff:0
[ 22.378480] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:0:cpu off:0 slope-adj:400
[ 22.378487] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:1:gpu off:0 slope-adj:400
[ 22.378728] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced max_state:40 cutoff:1
[ 22.378809] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:0:cpu off:0 slope-adj:200
[ 22.378816] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:1:gpu off:365500000 slope-adj:300
[ 22.379087] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced max_state:48 cutoff:0
[ 22.379160] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:0:cpu off:38400000 slope-adj:10
[ 22.379167] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:1:gpu off:25500000 slope-adj:10
[ 22.379497] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced max_state:2 cutoff:0
[ 22.379543] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:0:cpu off:0 slope-adj:400
[ 22.379549] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:1:gpu off:0 slope-adj:400
[ 22.379790] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced max_state:40 cutoff:1
[ 22.380390] FAN dev name: pwm-fan
[ 22.380439] FAN:gpio request success.
[ 22.380451] FAN: can’t find tach_gpio
[ 22.380461] pwm_fan_driver pwm-fan: Found 2 profiles, default profile is quiet
[ 22.380522] pwm_fan_driver pwm-fan: cap state:4, cap pwm:255
[ 22.380689] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 22.380696] pwm_fan_driver pwm-fan: tach period: 1000
[ 22.381253] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 22.381260] pwm_fan_driver pwm-fan: index 1: pwm=130, rpm=1000, rru=2, rrd=2, state:2
[ 22.381266] pwm_fan_driver pwm-fan: index 2: pwm=160, rpm=2000, rru=1, rrd=1, state:2
[ 22.381272] pwm_fan_driver pwm-fan: index 3: pwm=200, rpm=3000, rru=1, rrd=1, state:2
[ 22.381277] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 22.381283] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 22.381288] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 22.381293] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 22.381299] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 22.381305] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 22.382289] device-mapper: uevent: version 1.0.3
[ 22.382827] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 22.386786] tegra194_cpufreq_probe: platform driver Initialization: pass
[ 22.387978] cpuidle: Initializing cpuidle driver
[ 22.388825] sdhci: Secure Digital Host Controller Interface driver
[ 22.388830] sdhci: Copyright(c) Pierre Ossman
[ 22.388834] sdhci-pltfm: SDHCI platform and OF driver helper
[ 22.390367] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 22.392456] CMDQ: cmdq_platfm_init successful
[ 22.396692] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 22.397684] tegra-se-nvhost 15810000.se: initialized
[ 22.398743] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 22.399400] tegra-se-nvhost 15820000.se: initialized
[ 22.400626] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 22.401207] tegra-se-nvhost 15830000.se: initialized
[ 22.401811] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 22.402487] tegra-se-nvhost 15840000.se: initialized
[ 22.403408] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 22.403622] hidraw: raw HID events driver (C) Jiri Kosina
[ 22.406620] input: Logitech USB Receiver as /devices/3610000.xhci/usb1/1-2/1-2.3/1-2.3:1.0/0003:046D:C534.0001/input/input0
[ 22.434481] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 22.467059] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-3610000.xhci-2.3/input0
[ 22.469861] input: Logitech USB Receiver as /devices/3610000.xhci/usb1/1-2/1-2.3/1-2.3:1.1/0003:046D:C534.0002/input/input1
[ 22.476347] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 22.489221] mmc0: periodic cache flush enabled
[ 22.489235] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 22.489747] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[ 22.489998] mmcblk0boot0: mmc0:0001 DG4016 partition 1 4.00 MiB
[ 22.490201] mmcblk0boot1: mmc0:0001 DG4016 partition 2 4.00 MiB
[ 22.490404] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB
[ 22.493659] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[ 22.526834] hid-generic 0003:046D:C534.0002: input,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-3610000.xhci-2.3/input1
[ 22.526900] usbcore: registered new interface driver usbhid
[ 22.526903] usbhid: USB HID core driver
[ 22.531460] tegra186-cam-rtcpu bc00000.rtcpu: deferring, 14800000.isp is not probed
[ 22.532634] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 22.533094] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 22.533628] denver_knobs_init:MTS_VERSION:48073932
[ 22.533827] tegra19x_actmon d230000.actmon: in actmon_register()…
[ 22.534637] tegra19x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 22.535182] t19x_cache tegra-cache: probed
[ 22.537278] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[ 22.537289] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[ 22.537952] carmel-pmu-drv carmel-pmu: Registered Carmel PMU
[ 22.539949] nvpmodel: initialized successfully
[ 22.541056] trusty-virtio trusty:virtio: initializing
[ 22.541250] trusty_ipc virtio0: vring0: va¶ ffffffc1e1484000(0) qsz 32 notifyid 1
[ 22.541261] trusty_ipc virtio0: vring1: va¶ ffffffc1e1486000(0) qsz 32 notifyid 2
[ 22.541393] trusty-virtio trusty:virtio: initializing done
[ 22.541636] trusty_ipc virtio0: is online
[ 22.542033] tegra-hda 3510000.hda: Override SDO lines to 4
[ 22.542553] usbcore: registered new interface driver snd-usb-audio
[ 22.562374] input: tegra-hda-galen-t194 HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input2
[ 22.562638] input: tegra-hda-galen-t194 HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input3
[ 22.562845] input: tegra-hda-galen-t194 HDMI/DP,pcm=8 as /devices/3510000.hda/sound/card0/input4
[ 22.563017] input: tegra-hda-galen-t194 HDMI/DP,pcm=9 as /devices/3510000.hda/sound/card0/input5
[ 22.631436] OPE platform probe
[ 22.631570] OPE platform probe successful
[ 22.705863] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 22.705973] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 22.706073] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 22.706173] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 22.706272] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 22.706381] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 22.706535] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 22.706675] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 22.706824] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 22.706936] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 22.707043] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 22.707151] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 22.707257] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 22.707354] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 22.707448] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 22.707538] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 22.707614] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 22.707696] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 22.707778] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 22.707858] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 22.734365] u32 classifier
[ 22.734372] Actions configured
[ 22.734477] Initializing XFRM netlink socket
[ 22.735098] NET: Registered protocol family 10
[ 22.735840] NET: Registered protocol family 17
[ 22.735854] NET: Registered protocol family 15
[ 22.735909] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 22.735988] Bluetooth: RFCOMM socket layer initialized
[ 22.736004] Bluetooth: RFCOMM ver 1.11
[ 22.736012] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 22.736018] Bluetooth: HIDP socket layer initialized
[ 22.736035] 9pnet: Installing 9P2000 support
[ 22.736071] Key type dns_resolver registered
[ 22.736341] Registered cp15_barrier emulation handler
[ 22.736369] Registered setend emulation handler
[ 22.738088] registered taskstats version 1
[ 22.738540] tegra-pcie-dw 14160000.pcie: Setting init speed to max speed
[ 22.739670] OF: PCI: host bridge /pcie@14160000 ranges:
[ 22.739688] OF: PCI: IO 0x36100000…0x361fffff → 0x36100000
[ 22.739696] OF: PCI: MEM 0x1740000000…0x17ffffffff → 0x40000000
[ 22.739702] OF: PCI: MEM 0x1400000000…0x173fffffff → 0x1400000000
[ 22.875102] FAN rising trip_level:3 cur_temp:68900 trip_temps[4]:76000
[ 23.254777] tegra-pcie-dw 14160000.pcie: link is down
[ 23.254949] tegra-pcie-dw 14160000.pcie: PCI host bridge to bus 0004:00
[ 23.254958] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 23.254966] pci_bus 0004:00: root bus resource [io 0x0000-0xfffff] (bus address [0x36100000-0x361fffff])
[ 23.254972] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[ 23.254976] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[ 23.255005] pci 0004:00:00.0: [10de:1ad1] type 01 class 0x060400
[ 23.255179] pci 0004:00:00.0: PME# supported from D0 D3hot D3cold
[ 23.255534] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 23.255575] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 23.255852] pcieport 0004:00:00.0: Signaling PME through PCIe PME interrupt
[ 23.255859] pcie_pme 0004:00:00.0:pcie001: service driver pcie_pme loaded
[ 23.255951] aer 0004:00:00.0:pcie002: service driver aer loaded
[ 23.256110] pcie_pme 0004:00:00.0:pcie001: unloading service driver pcie_pme
[ 23.256168] aer 0004:00:00.0:pcie002: unloading service driver aer
[ 23.256251] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[ 23.256351] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[ 23.257904] tegra-pcie-dw 14160000.pcie: PCIe link is not up…!
[ 23.258930] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[ 23.259939] OF: PCI: host bridge /pcie@141a0000 ranges:
[ 23.259957] OF: PCI: IO 0x3a100000…0x3a1fffff → 0x3a100000
[ 23.259965] OF: PCI: MEM 0x1f40000000…0x1fffffffff → 0x40000000
[ 23.259971] OF: PCI: MEM 0x1c00000000…0x1f3fffffff → 0x1c00000000
[ 23.370465] tegra-pcie-dw 141a0000.pcie: link is up
[ 23.370740] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0005:00
[ 23.370747] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 23.370756] pci_bus 0005:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x3a100000-0x3a1fffff])
[ 23.370761] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[ 23.370766] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[ 23.370789] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 23.370928] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[ 23.371323] pci 0005:01:00.0: [8888:8508] type 00 class 0x040000
[ 23.371415] pci 0005:01:00.0: reg 0x10: [mem 0x00000000-0x00007fff]
[ 23.383198] pci 0005:00:00.0: BAR 14: assigned [mem 0x1f40000000-0x1f400fffff]
[ 23.383207] pci 0005:01:00.0: BAR 0: assigned [mem 0x1f40000000-0x1f40007fff]
[ 23.383230] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 23.383238] pci 0005:00:00.0: bridge window [mem 0x1f40000000-0x1f400fffff]
[ 23.383276] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 23.383323] pci 0005:01:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 512
[ 23.383618] pcieport 0005:00:00.0: Signaling PME through PCIe PME interrupt
[ 23.383624] pci 0005:01:00.0: Signaling PME through PCIe PME interrupt
[ 23.383629] pcie_pme 0005:00:00.0:pcie001: service driver pcie_pme loaded
[ 23.383787] aer 0005:00:00.0:pcie002: service driver aer loaded
[ 23.392965] tegra-cbb 14040000.cv-noc: noc_secure_irq = 89, noc_nonsecure_irq = 88>
[ 23.397408] tegra194-isp5 14800000.isp: initialized
[ 23.404115] tegra194-vi5 15c10000.vi: using default number of vi channels, 36
[ 23.406793] tegra194-vi5 15c10000.vi: initialized
[ 23.410978] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi–2 bound
[ 23.411072] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi–1 bound
[ 23.411761] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 23.493441] tegra-ivc ivc-bc00000.rtcpu: region 0: iova=0xbfee0000-0xbfefffff size=131072
[ 23.493728] tegra-ivc ivc-bc00000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 23.493893] tegra-ivc ivc-bc00000.rtcpu:dbg@1: dbg: ver=0 grp=1 RX[1x384]=0x1900-0x1b00 TX[1x384]=0x1b00-0x1d00
[ 23.494085] tegra-ivc ivc-bc00000.rtcpu:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d00-0x3d80 TX[1x8192]=0x3d80-0x5e00
[ 23.494412] tegra-ivc ivc-bc00000.rtcpu:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e00-0xae80 TX[64x320]=0xae80-0xff00
[ 23.494549] tegra-ivc ivc-bc00000.rtcpu:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff00-0x17f80 TX[512x64]=0x17f80-0x20000
[ 23.494736] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (65)
[ 23.494741] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 23.496038] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=5 sha1=cf2bef3ad10e437272857b76308abef8ffb80bda
[ 23.496452] gpio tegra-gpio wake67 for gpio=48(G:0)
[ 23.496521] gpio tegra-gpio-aon wake29 for gpio=36(EE:4)
[ 23.496638] input: gpio-keys as /devices/gpio-keys/input/input6
[ 23.527391] tegra_rtc c2a0000.rtc: setting system clock to 2020-06-16 09:06:27 UTC (1592298387)
[ 23.527808] mmcblk mmc0:0001: Card claimed for testing.
[ 23.563469] bpmp: mounted debugfs mirror
[ 23.569442] vdd-sdmmc1-sw: disabling
[ 23.569449] vdd-1v8-sd: disabling
[ 23.569453] vdd-1v8-cvb: disabling
[ 23.569456] vdd-epb-1v0: disabling
[ 23.569460] avdd-cam-2v8: disabling
[ 23.569463] vdd_sys_en: disabling
[ 23.569470] ALSA device list:
[ 23.569473] #0: tegra-hda-galen-t194 at 0x3518000 irq 64
[ 23.569478] #1: jetson-xaviernx-ape
[ 23.571604] Freeing unused kernel memory: 8576K
[ 23.604232] Root device found: mmcblk0p1
[ 23.605335] Found dev node: /dev/mmcblk0p1
[ 23.714802] EXT4-fs (mmcblk0p1): 10 orphan inodes deleted
[ 23.714812] EXT4-fs (mmcblk0p1): recovery complete
[ 23.719161] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 23.720214] Rootfs mounted over mmcblk0p1
[ 23.740878] Switching from initrd to actual rootfs
[ 23.864167] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 23.867902] cgroup: cgroup2: unknown option “nsdelegate”
[ 23.879448] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 23.880058] systemd[1]: Detected architecture arm64.
[ 23.887397] systemd[1]: Set hostname to .
[ 23.981299] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 23.981313] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 24.119474] random: systemd: uninitialized urandom read (16 bytes read)
[ 24.122285] systemd[1]: Created slice User and Session Slice.
[ 24.122471] random: systemd: uninitialized urandom read (16 bytes read)
[ 24.122623] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 24.122674] random: systemd: uninitialized urandom read (16 bytes read)
[ 24.122701] systemd[1]: Reached target User and Group Name Lookups.
[ 24.122754] systemd[1]: Reached target Swap.
[ 24.123339] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 24.213762] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 24.273356] nvgpu: 17000000.gv11b nvgpu_nvhost_syncpt_init:291 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[ 24.648763] systemd-journald[2295]: Received request to flush runtime journal from PID 1
[ 25.809839] using random self ethernet address
[ 25.810087] using random host ethernet address
[ 25.833281] random: crng init done
[ 25.833460] random: 7 urandom warning(s) missed due to ratelimiting
[ 26.630563] Mass Storage Function, version: 2009/09/11
[ 26.630578] LUN: removable file: (no medium)
[ 26.650910] using random self ethernet address
[ 26.651151] using random host ethernet address
[ 26.710189] rndis0: HOST MAC 82:e7:d6:79:f9:94
[ 26.710377] rndis0: MAC 82:e7:d6:79:f9:95
[ 26.713412] usb0: HOST MAC 82:e7:d6:79:f9:96
[ 26.713459] usb0: MAC 82:e7:d6:79:f9:97
[ 26.713483] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 26.714494] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 26.714521] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 26.716776] tegra-xudc-new 3550000.xudc: entering ELPG
[ 26.717099] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 26.718647] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 26.719549] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 26.719589] tegra-xudc-new 3550000.xudc: entering ELPG
[ 26.719878] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 26.727301] l4tbr0: port 1(rndis0) entered blocking state
[ 26.727312] l4tbr0: port 1(rndis0) entered disabled state
[ 26.727548] device rndis0 entered promiscuous mode
[ 26.753590] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 26.763953] l4tbr0: port 2(usb0) entered blocking state
[ 26.763966] l4tbr0: port 2(usb0) entered disabled state
[ 26.764768] device usb0 entered promiscuous mode
[ 26.775916] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 26.941080] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 27.123081] ras_fhi_disable: FHI 470 disabled
[ 27.124285] CPU2: shutdown
[ 27.124435] psci: CPU2 killed.
[ 27.203078] ras_fhi_disable: FHI 471 disabled
[ 27.204204] CPU3: shutdown
[ 27.204348] psci: CPU3 killed.
[ 27.251048] ras_fhi_disable: FHI 472 disabled
[ 27.252799] CPU4: shutdown
[ 27.252943] psci: CPU4 killed.
[ 27.259226] gpio tegra-gpio wake20 for gpio=52(G:4)
[ 27.263328] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 27.287073] ras_fhi_disable: FHI 473 disabled
[ 27.287985] CPU5: shutdown
[ 27.288124] psci: CPU5 killed.
[ 27.289961] nvgpu: 17000000.gv11b tpc_pg_mask_store:843 [INFO] no value change, same mask already set
[ 27.605527] zram: Added device: zram0
[ 27.606087] zram: Added device: zram1
[ 27.687303] zram0: detected capacity change from 0 to 2035167232
[ 27.732459] Adding 1987464k swap on /dev/zram0. Priority:5 extents:1 across:1987464k SS
[ 27.749203] zram1: detected capacity change from 0 to 2035167232
[ 27.797707] Adding 1987464k swap on /dev/zram1. Priority:5 extents:1 across:1987464k SS
[ 28.853334] eqos 2490000.ether_qos eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 28.853978] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 29.267627] tegradc 15200000.nvdisplay: blank - powerdown
[ 29.333956] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 29.333960] Extcon AUX1(HDMI) disable
[ 29.359590] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 29.360218] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 29.366644] tegradc 15200000.nvdisplay: unblank
[ 29.367439] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 29.367552] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 29.369558] Parent Clock set for DC plld2
[ 29.374488] tegradc 15200000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 29.375951] tegradc 15200000.nvdisplay: hdmi: get RGB quant from EDID.
[ 29.375960] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 29.417631] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 29.417635] Extcon AUX1(HDMI) enable
[ 29.423593] tegradc 15200000.nvdisplay: unblank
[ 29.423615] tegradc 15210000.nvdisplay: blank - powerdown
[ 31.834771] FAN rising trip_level:3 cur_temp:71000 trip_temps[4]:76000
[ 34.026043] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 34.026060] Bluetooth: BNEP socket layer initialized
[ 34.047965] fuse init (API version 7.26)
[ 36.036377] tegradc 15200000.nvdisplay: unblank
[ 36.036391] tegradc 15210000.nvdisplay: blank - powerdown
And we insmod our kernel module, got below message:
[ 123.974623] FAN rising trip_level:4 cur_temp:76000 trip_temps[5]:140000
[ 136.518965] dvrs_hw: loading out-of-tree module taints kernel.
[ 136.520607] Cry Driver init /n
[ 136.524603] dvr_hw_ahd probe
[ 136.524633] dvr_hw_ahd Device =8508 VID =8888
[ 136.524671] dvrs_hw_ahd 0005:01:00.0: enabling device (0000 → 0002)
[ 136.524784] msi_msix_capable in
[ 136.524823] pci_enable_msi()
[ 136.525082] pdev->irq = 554
[ 136.525112] Using IRQ#554 with 0xffffffc1e2832000
[ 136.525119] ************[HW]-[VIDV]=[120]-[1] ************
[ 136.525487] [MV]Mem Video::m_dwVideoBuffer[0] = 800000
[ 136.525493] [MV]Mem Video::m_dwVideoHighBuffer[0] = 2
[ 136.525497] [MV]Mem Video::m_dwVideoBuffer[1] = a00000
[ 136.525502] [MV]Mem Video::m_dwVideoHighBuffer[1] = 2
[ 136.530114] [MV]Mem Video::m_dwVideoBuffer[2] = 400000
[ 136.530133] [MV]Mem Video::m_dwVideoHighBuffer[2] = 2
[ 136.530144] [MV]Mem Video::m_dwVideoBuffer[3] = 600000
[ 136.530150] [MV]Mem Video::m_dwVideoHighBuffer[3] = 2
[ 136.530589] [MV]Mem Video::m_dwVideoBuffer[4] = 0
[ 136.530595] [MV]Mem Video::m_dwVideoHighBuffer[4] = 2
[ 136.530600] [MV]Mem Video::m_dwVideoBuffer[5] = 200000
[ 136.530604] [MV]Mem Video::m_dwVideoHighBuffer[5] = 2
[ 136.530981] [MV]Mem Video::m_dwVideoBuffer[6] = ffc00000
[ 136.530985] [MV]Mem Video::m_dwVideoHighBuffer[6] = 1
[ 136.530990] [MV]Mem Video::m_dwVideoBuffer[7] = ffe00000
[ 136.530993] [MV]Mem Video::m_dwVideoHighBuffer[7] = 1
[ 136.539543] [MV] pdx->m_pbyVideoBuffer[0]=80800000
[ 136.539559] [MV]1-pdx->m_dwVideoBuffer[0]-800000
[ 136.539574] [MV]1-PCI_Addr[0] :PhyAddr_A_Low 0=0 PhyAddr_A_High 2=2
[ 136.539591] [MV]1-Avalone [X64]BUF[0]:BUF1=20800000 BUF2=E100 BUF3=20A00000 BUF4=E100
[ 136.539595] [MV] pdx->m_pbyVideoBuffer[2]=80400000
[ 136.539599] [MV]1-pdx->m_dwVideoBuffer[2]-400000
[ 136.539609] [MV]1-PCI_Addr[2] :PhyAddr_A_Low 0=0 PhyAddr_A_High 2=2
[ 136.539626] [MV]1-Avalone [X64]BUF[2]:BUF1=40400000 BUF2=E100 BUF3=40600000 BUF4=E100
[ 136.539630] [MV] pdx->m_pbyVideoBuffer[4]=80000000
[ 136.539633] [MV]1-pdx->m_dwVideoBuffer[4]-0
[ 136.539643] [MV]1-PCI_Addr[4] :PhyAddr_A_Low 0=0 PhyAddr_A_High 2=2
[ 136.539660] [MV]1-Avalone [X64]BUF[4]:BUF1=60000000 BUF2=E100 BUF3=60200000 BUF4=E100
[ 136.539663] [MV] pdx->m_pbyVideoBuffer[6]=7FC00000
[ 136.539667] [MV]1-pdx->m_dwVideoBuffer[6]-FFC00000
[ 136.539677] [MV]1-PCI_Addr[6] :PhyAddr_A_Low E0000000=E0000000 PhyAddr_A_High 1=1
[ 136.539694] [MV]1-Avalone [X64]BUF[6]:BUF1=9FC00000 BUF2=E100 BUF3=9FE00000 BUF4=E100
[ 136.539698] dvr_hw_ahd probe exit
