i am getting a segmentation error when I try to open a Camera App like cheese or guvcview.
Jetson Xavier NX
Jetpack 4.5
Logitech C270
Here is what I get:
nvidia@nvidia-desktop:~$ cheese
(cheese:9841): Gtk-WARNING **: 20:11:40.361: Theme parsing error: cheese.css:7:35: The style property GtkScrollbar:min-slider-length is deprecated and shouldn’t be used anymore. It will be removed in a future version
Opening in BLOCKING MODE
nvidia@nvidia-desktop:~$ guvcview
nvidia@nvidia-desktop:~$ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.201-tegra (buildbrain@mobile-u64-4551) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Fri Jan 15 14:54:23 PST 2021
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44800000
[ 0.000000] OF: fdt: - 100000000 , 180000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options ‘’)
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] Found tegra_fbmem: 00800000@a06a0000
[ 0.000000] Found lut_mem: 00002008@a069a000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb2_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb3_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[ 0.000000] cma: Reserved 64 MiB at 0x00000000c2000000
[ 0.000000] On node 0 totalpages: 2031101
[ 0.000000] DMA zone: 7160 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 458237 pages, LIFO batch:31
[ 0.000000] Normal zone: 24576 pages used for memmap
[ 0.000000] Normal zone: 1572864 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s57560 r8192 d32552 u98304
[ 0.000000] pcpu-alloc: s57560 r8192 d32552 u98304 alloc=24*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1999365
[ 0.000000] Kernel command line: console=ttyTCU0,115200 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= tegra_fbmem=0x800000@0xa06a0000 lut_mem=0x2008@0xa069a000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix=_b boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29180(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7182604K/8124404K available (15294K kernel code, 2942K rwdata, 6664K rodata, 8576K init, 609K bss, 188136K reserved, 753664K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f70000 ( 15296 KB)
[ 0.000000] .rodata : 0xffffff8008f70000 - 0xffffff8009600000 ( 6720 KB)
[ 0.000000] .init : 0xffffff8009600000 - 0xffffff8009e60000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e60000 - 0xffffff800a13f808 ( 2943 KB)
[ 0.000000] .bss : 0xffffff800a13f808 - 0xffffff800a1d7cbc ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf08000000 ( 128 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc200000000 ( 8192 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000004] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000780] Console: colour dummy device 80x25
[ 0.000792] console [tty0] enabled
[ 0.000799] bootconsole [tegra_comb_uart0] disabled
[ 0.000813] kmemleak: Kernel memory leak detector disabled
[ 0.000831] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.000846] pid_max: default: 32768 minimum: 301
[ 0.001921] Security Framework initialized
[ 0.002489] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.002499] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.004145] ftrace: allocating 47208 entries in 185 pages
[ 0.405123] sched-energy: Sched-energy-costs installed from DT
[ 0.405143] ASID allocator initialised with 65536 entries
[ 0.440826] tegra-id: chipid=21917.
[ 0.440837] tegra-id: opt_subrevision=1.
[ 0.440864] Tegra Revision: A02p SKU: 0xde CPU Process: 0 SoC Process: 0
[ 0.440893] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[ 0.440903] DTB Build time: Jan 15 2021 15:02:59
[ 0.488573] CPU1: Booted secondary processor [4e0f0040]
[ 0.520641] CPU2: Booted secondary processor [4e0f0040]
[ 0.552774] CPU3: Booted secondary processor [4e0f0040]
[ 0.585010] CPU4: Booted secondary processor [4e0f0040]
[ 0.617137] CPU5: Booted secondary processor [4e0f0040]
[ 0.617326] Brought up 6 CPUs
[ 0.617335] SMP: Total of 6 processors activated.
[ 0.617345] CPU features: detected feature: Privileged Access Never
[ 0.617351] CPU features: detected feature: LSE atomic instructions
[ 0.617357] CPU features: detected feature: User Access Override
[ 0.617363] CPU features: detected feature: 32-bit EL0 Support
[ 0.618844] CPU: All CPU(s) started at EL2
[ 0.618898] alternatives: patching kernel code
[ 0.625305] devtmpfs: initialized
[ 0.665761] Initilizing CustomIPI irq domain
[ 0.666022] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.666041] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.677117] pinctrl core: initialized pinctrl subsystem
[ 0.677317] OS set in device tree is not L4T.
[ 0.677558] regulator-dummy: no parameters
[ 0.677787] Initializing plugin-manager
[ 0.677841] Plugin module not found
[ 0.677872] Plugin-manager status disabled
[ 0.679177] NET: Registered protocol family 16
[ 0.680748] pstore: using zlib compression
[ 0.680768] console [pstore-1] enabled
[ 0.680773] pstore: Registered ramoops as persistent store backend
[ 0.680780] ramoops: attached 0x200000@0xf0800000, ecc: 0/0
[ 0.695739] cpuidle: using governor menu
[ 0.696836] bpmp: waiting for handshake
[ 0.696844] bpmp: handshake completed
[ 0.696859] bpmp: synchronizing channels
[ 0.696871] bpmp: channels synchronized
[ 0.696877] bpmp: mail init ok
[ 0.699745] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[ 0.699907] t19x-arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.699913] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.699920] t19x-arm-smmu 12000000.iommu: stage 1 translation
[ 0.699926] t19x-arm-smmu 12000000.iommu: stage 2 translation
[ 0.699931] t19x-arm-smmu 12000000.iommu: nested translation
[ 0.699943] t19x-arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.699974] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.699980] t19x-arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.699988] t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.699994] t19x-arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
[ 0.703209] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009e64000)
[ 0.703240] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.705798] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.707695] tegra_aon_clk_init: ok
[ 0.707704] Registering BPMP clocks…
[ 0.707813] tegra_bpmp_clk_init: clock init ok (400 clks)
[ 0.708547] Serial: AMBA PL011 UART driver
[ 0.708651] tegra_powergate_init: DONE
[ 0.708715] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[ 0.708728] DTB Build time: Jan 15 2021 15:02:59
[ 0.711687] Tegra reboot handler registered.
[ 0.720321] iommu: Adding device 14160000.pcie to group 0
[ 0.720939] iommu: Adding device 141a0000.pcie to group 1
[ 0.722525] iommu: Adding device 2490000.ether_qos to group 2
[ 0.723016] iommu: Adding device 3100000.serial to group 3
[ 0.723569] iommu: Adding device 3110000.serial to group 4
[ 0.724087] iommu: Adding device 3140000.serial to group 5
[ 0.724694] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.724929] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.724946] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[ 0.724950] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L1
[ 0.724955] tegra-pmc: ### PMC reset status reg: 0x2d
[ 0.725045] tegra-pmc: PMC Prod config success
[ 0.725255] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.725268] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.725619] iommu: Adding device 3400000.sdhci to group 6
[ 0.726152] iommu: Adding device 3210000.spi to group 7
[ 0.726553] iommu: Adding device 3230000.spi to group 8
[ 0.726999] iommu: Adding device 3270000.spi to group 9
[ 0.728350] iommu: Adding device 3160000.i2c to group 10
[ 0.728798] iommu: Adding device c240000.i2c to group 11
[ 0.729210] iommu: Adding device 3180000.i2c to group 12
[ 0.729620] iommu: Adding device 3190000.i2c to group 13
[ 0.730209] iommu: Adding device 31b0000.i2c to group 14
[ 0.730606] iommu: Adding device 31c0000.i2c to group 15
[ 0.731047] iommu: Adding device c250000.i2c to group 16
[ 0.731446] iommu: Adding device 31e0000.i2c to group 17
[ 0.732095] iommu: Adding device sound to group 18
[ 0.732707] iommu: Adding device 3510000.hda to group 19
[ 0.733294] iommu: Adding device bc00000.rtcpu to group 20
[ 0.735344] iommu: Adding device 13e10000.host1x to group 21
[ 0.735748] iommu: Adding device 13e10000.host1x:ctx0 to group 22
[ 0.736156] iommu: Adding device 13e10000.host1x:ctx1 to group 23
[ 0.736547] iommu: Adding device 13e10000.host1x:ctx2 to group 24
[ 0.736904] iommu: Adding device 13e10000.host1x:ctx3 to group 25
[ 0.737300] iommu: Adding device 13e10000.host1x:ctx4 to group 26
[ 0.737663] iommu: Adding device 13e10000.host1x:ctx5 to group 27
[ 0.738021] iommu: Adding device 13e10000.host1x:ctx6 to group 28
[ 0.738406] iommu: Adding device 13e10000.host1x:ctx7 to group 29
[ 0.738917] iommu: Adding device 15340000.vic to group 30
[ 0.739291] iommu: Adding device 15380000.nvjpg to group 31
[ 0.739611] iommu: Adding device 15500000.tsec to group 32
[ 0.739913] iommu: Adding device 15100000.tsecb to group 33
[ 0.740254] iommu: Adding device 15480000.nvdec to group 34
[ 0.740526] iommu: Adding device 15140000.nvdec1 to group 35
[ 0.740819] iommu: Adding device 154c0000.nvenc to group 36
[ 0.741085] iommu: Adding device 15a80000.nvenc1 to group 37
[ 0.741511] iommu: Adding device 15880000.nvdla0 to group 38
[ 0.741914] iommu: Adding device 158c0000.nvdla1 to group 39
[ 0.742591] iommu: Adding device 15200000.nvdisplay to group 40
[ 0.742748] platform 15200000.nvdisplay: IOVA linear map 0x00000000a06a0000(800000)
[ 0.742760] platform 15200000.nvdisplay: IOVA linear map 0x00000000a069a000(3000)
[ 0.746651] platform 15200000.nvdisplay: IOVA linear map 0x00000000c6000000(2a000000)
[ 0.746738] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[ 0.747372] iommu: Adding device 15210000.nvdisplay to group 41
[ 0.747427] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[ 0.749287] iommu: Adding device 15c10000.vi to group 42
[ 0.749487] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[ 0.750020] iommu: Adding device 14800000.isp to group 43
[ 0.751025] iommu: Adding device 16000000.pva0 to group 44
[ 0.751686] iommu: Adding device 16800000.pva1 to group 45
[ 0.752068] iommu: Adding device 15810000.se to group 46
[ 0.752514] iommu: Adding device 15820000.se to group 47
[ 0.752804] iommu: Adding device 15830000.se to group 48
[ 0.753101] iommu: Adding device 15840000.se to group 49
[ 0.753414] iommu: Adding device c1a0000.aon to group 50
[ 0.755118] iommu: Adding device d000000.bpmp to group 51
[ 0.755487] bpmp: ping status is 0
[ 0.755618] bpmp d000000.bpmp: firmware tag is e73a758761f0c6d24a1e69a2ac6b5035
[ 0.758764] bpmp d000000.bpmp: probe ok
[ 0.760995] tegra-reset 0.bpmp_reset: registered 190 resets.
[ 0.761463] iommu: Adding device smmu_test to group 52
[ 0.762578] mc: mapped MMIO address: 0xffffff800a590000 → 0x2c10000
[ 0.762615] mc: mapped MMIO address: 0xffffff800a5b0000 → 0x2c20000
[ 0.762635] mc: mapped MMIO address: 0xffffff800a5d0000 → 0x2c30000
[ 0.762656] mc: mapped MMIO address: 0xffffff800a7b0000 → 0x2c40000
[ 0.762672] mc: mapped MMIO address: 0xffffff800a7d0000 → 0x2c50000
[ 0.762689] mc: mapped MMIO address: 0xffffff800b010000 → 0x2b80000
[ 0.762704] mc: mapped MMIO address: 0xffffff800b030000 → 0x2b90000
[ 0.762721] mc: mapped MMIO address: 0xffffff800b050000 → 0x2ba0000
[ 0.762735] mc: mapped MMIO address: 0xffffff800b070000 → 0x2bb0000
[ 0.762750] mc: mapped MMIO address: 0xffffff800b090000 → 0x1700000
[ 0.762764] mc: mapped MMIO address: 0xffffff800b0b0000 → 0x1710000
[ 0.762779] mc: mapped MMIO address: 0xffffff800b0d0000 → 0x1720000
[ 0.762793] mc: mapped MMIO address: 0xffffff800b0f0000 → 0x1730000
[ 0.762808] mc: mapped MMIO address: 0xffffff800b110000 → 0x1740000
[ 0.762822] mc: mapped MMIO address: 0xffffff800b130000 → 0x1750000
[ 0.762837] mc: mapped MMIO address: 0xffffff800b150000 → 0x1760000
[ 0.762853] mc: mapped MMIO address: 0xffffff800b170000 → 0x1770000
[ 0.762935] mc-err: mcerr ops are set to t19x
[ 0.768872] iommu: Adding device 2600000.dma to group 53
[ 0.774776] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 224 lines on the chip
[ 0.775959] GPIO line 339 (wifi-enable) hogged as output/high
[ 0.776006] GPIO line 412 (camera-control-output-low) hogged as output/low
[ 0.776048] GPIO line 413 (camera-control-output-low) hogged as output/low
[ 0.776362] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.784682] gpio gpiochip1: gpio-line-names specifies 21 line names but there are 40 lines on the chip
[ 0.784753] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[ 0.784793] GPIO line 266 (w-disable1) hogged as output/high
[ 0.784829] GPIO line 264 (w-disable2) hogged as output/high
[ 0.784864] GPIO line 265 (suspend-led-gpio) hogged as output/high
[ 0.785162] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[ 0.787740] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_83 = 0x10a
[ 0.787750] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.787762] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.788609] iommu: Adding device 3550000.xudc to group 54
[ 0.789316] iommu: Adding device 3610000.xhci to group 55
[ 0.791398] arm64_ras arm64_ras: probed
[ 0.791772] ras_fhi_enable: FHI 469 enabled on CPU0
[ 0.791829] ras_fhi_enable: FHI 470 enabled on CPU1
[ 0.791920] ras_fhi_enable: FHI 471 enabled on CPU2
[ 0.792007] ras_fhi_enable: FHI 472 enabled on CPU3
[ 0.792128] ras_fhi_enable: FHI 473 enabled on CPU4
[ 0.792262] ras_fhi_enable: FHI 474 enabled on CPU5
[ 0.792460] carmel_ras_enable: RAS enabled on cpu0
[ 0.792643] carmel_ras_enable: RAS enabled on cpu1
[ 0.792851] carmel_ras_enable: RAS enabled on cpu2
[ 0.793073] carmel_ras_enable: RAS enabled on cpu3
[ 0.793289] carmel_ras_enable: RAS enabled on cpu4
[ 0.793493] carmel_ras_enable: RAS enabled on cpu5
[ 0.793581] carmel_ras carmel_ras: probed
[ 0.794737] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 478, noc_nonsecure_irq = 477>
[ 0.795298] tegra-cbb c600000.aon-noc: noc_secure_irq = 480, noc_nonsecure_irq = 479>
[ 0.796202] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 482, noc_nonsecure_irq = 481>
[ 0.797073] tegra-cbb be00000.rce-noc: noc_secure_irq = 484, noc_nonsecure_irq = 483>
[ 0.797942] tegra-cbb b600000.sce-noc: noc_secure_irq = 486, noc_nonsecure_irq = 485>
[ 0.798332] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[ 0.799646] vdd-ac-bat: 5000 mV
[ 0.800089] vdd-sdmmc1-sw: 3300 mV
[ 0.800522] vdd-1v8-sd: 1800 mV
[ 0.800884] vdd-3v3-cvb: 3300 mV
[ 0.801227] vdd-1v8-cvb: 1800 mV
[ 0.801601] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 0.801640] vdd-epb-1v0: 1000 mV
[ 0.802022] avdd-cam-2v8: 2800 mV
[ 0.802426] vdd-fan: 5000 mV
[ 0.802726] vdd-hdmi-5v0: 5000 mV
[ 0.803015] vdd_sys_en: 1200 mV
[ 0.839125] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.843554] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.843843] SCSI subsystem initialized
[ 0.844144] libata version 3.00 loaded.
[ 0.844400] usbcore: registered new interface driver usbfs
[ 0.844488] usbcore: registered new interface driver hub
[ 0.844560] usbcore: registered new device driver usb
[ 0.854937] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[ 0.857640] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 0.862789] vdd-1v0: at 1000 mV
[ 0.866843] vdd-1v8-hs: at 1800 mV
[ 0.870821] vdd-1v8-ls: at 1800 mV
[ 0.874904] vdd-1v8-ao: at 1800 mV
[ 0.881082] vddio-ddr-1v1: at 1100 mV
[ 0.884813] vdd-rtc: at 800 mV
[ 0.885908] spmic-ldo1: at 2375 mV
[ 0.896848] vdd-ao-3v3: at 3300 mV
[ 0.904905] vddio-emmc-3v3: at 3300 mV
[ 0.905995] spmic-ldo4: at 1587 mV
[ 0.916951] vdd-usb-3v3: at 3300 mV
[ 0.925024] vddio-sdmmc1-3v3: at 3300 mV
[ 0.929015] vdd-csi-1v2: at 1200 mV
[ 0.930100] spmic-ldo8: at 1800 mV
[ 0.934388] GPIO line 246 (gpio_default) hogged as output/high
[ 0.935372] GPIO line 247 (gpio_default) hogged as output/high
[ 0.935758] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[ 0.936104] max77620 4-003c: max77620 probe successful
[ 0.936666] media: Linux media interface: v0.10
[ 0.936722] Linux video capture interface: v2.00
[ 0.938113] pps_core: LinuxPPS API ver. 1 registered
[ 0.938123] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.938147] PTP clock support registered
[ 0.938381] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 0.938659] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.938700] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.941275] trusty trusty: trusty version: Built: 14:49:44 Jan 15 2021
[ 0.941336] trusty trusty: selected api version: 3 (requested 3)
[ 0.942348] Advanced Linux Sound Architecture Driver Initialized.
[ 0.942887] Bluetooth: Core ver 2.22
[ 0.942972] NET: Registered protocol family 31
[ 0.942981] Bluetooth: HCI device and connection manager initialized
[ 0.942995] Bluetooth: HCI socket layer initialized
[ 0.943030] Bluetooth: L2CAP socket layer initialized
[ 0.943062] Bluetooth: SCO socket layer initialized
[ 0.945713] camchar: rtcpu character device driver loaded
[ 0.946239] gpio tegra-gpio wake61 for gpio=201(Z:1)
[ 0.946335] extcon-gpio-states external-connection:extcon@1: Cable state:0, cable id:0
[ 0.947254] clocksource: Switched to clocksource arch_sys_counter
[ 0.990537] VFS: Disk quotas dquot_6.6.0
[ 0.990627] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.991004] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.992295] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[ 0.992357] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[ 0.992586] cma: enabled page replacement for spfn=c6000, epfn=f0000
[ 0.992598] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.992621] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[ 0.992632] nvmap_page_pool_init: Total RAM pages: 1984067
[ 0.992641] nvmap_page_pool_init: nvmap page pool size: 248008 pages (968 MB)
[ 0.992797] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.993167] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[ 0.995288] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 1.007320] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 1.007554] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 1.007768] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[ 1.007940] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[ 1.008112] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 1.009284] la/ptsa driver initialized.
[ 1.009570] NET: Registered protocol family 2
[ 1.010381] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 1.010724] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 1.011373] TCP: Hash tables configured (established 65536 bind 65536)
[ 1.011460] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 1.011589] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 1.011973] NET: Registered protocol family 1
[ 1.012570] RPC: Registered named UNIX socket transport module.
[ 1.012576] RPC: Registered udp transport module.
[ 1.012582] RPC: Registered tcp transport module.
[ 1.012587] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.012597] PCI: CLS 0 bytes, default 64
[ 1.012765] Trying to unpack rootfs image as initramfs…
[ 1.245787] Freeing initrd memory: 7064K
[ 1.267687] host1x 13e10000.host1x: initialized
[ 1.269435] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.274089] audit: initializing netlink subsys (disabled)
[ 1.274136] audit: type=2000 audit(0.892:1): initialized
[ 1.274911] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 1.284060] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.285300] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.285934] 9p: Installing v9fs 9p2000 file system support
[ 1.290999] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.291182] io scheduler noop registered
[ 1.291469] io scheduler cfq registered (default)
[ 1.295400] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 1.296672] random: fast init done
[ 1.331300] iommu: Adding device 2993000.adsp to group 56
[ 1.440533] iommu: Adding device aconnect@2a41000:adsp_audio to group 57
[ 1.441569] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.453936] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.454350] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.454934] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.455377] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[ 1.455747] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.458987] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.459225] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 1.462123] tsec 15500000.tsec: initialized
[ 1.463824] tsec 15100000.tsecb: initialized
[ 1.467488] nvdec 15480000.nvdec: initialized
[ 1.470099] nvdec 15140000.nvdec1: initialized
[ 1.476209] falcon 15340000.vic: initialized
[ 1.477994] falcon 15380000.nvjpg: initialized
[ 1.479937] falcon 154c0000.nvenc: initialized
[ 1.481854] falcon 15a80000.nvenc1: initialized
[ 1.485528] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.487369] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.489061] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.490811] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.492533] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.494259] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.495969] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.497690] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.501287] t194-nvcsi 15a00000.nvcsi: initialized
[ 1.507142] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 1.507585] scare-pigeon 14b00000.isp-thi: initialized
[ 1.513489] pva 16000000.pva0: initialized
[ 1.519197] pva 16800000.pva1: initialized
[ 1.524149] nvdla 15880000.nvdla0: initialized
[ 1.529119] nvdla 158c0000.nvdla1: initialized
[ 1.530917] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.530931] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.530976] tegradccommon 15200000.dc_common: dma mapping done
[ 1.531152] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=77
[ 1.531163] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[ 1.531490] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 1.531527] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 1.531826] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 1.531834] tegra_cec 3960000.tegra_cec: probed
[ 1.532530] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor1
[ 1.532581] generic_infoframe_type: 0x87
[ 1.532695] tegradc 15200000.nvdisplay: DT parsed successfully
[ 1.532737] tegradc 15200000.nvdisplay: Display dc.ffffff800bd10000 registered with id=0
[ 1.536543] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 7088400 KB/s
[ 1.536557] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 800000000 Hz
[ 1.536568] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[ 1.536808] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[ 1.536818] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[ 1.538078] tegradc 15200000.nvdisplay: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[ 1.540849] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.540857] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.544419] tegradc 15200000.nvdisplay: probed
[ 1.544937] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[ 1.545677] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check disabled
[ 1.545687] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.546065] kfuse 3830000.kfuse: initialized
[ 1.552663] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.555613] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 47, base_baud = 0) is a TEGRA_UART
[ 1.556884] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 48, base_baud = 0) is a TEGRA_UART
[ 1.557721] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 49, base_baud = 0) is a TEGRA_UART
[ 1.559371] console [ttyTCU0] enabled
[ 1.559789] [drm] Initialized
[ 1.573875] brd: module loaded
[ 1.583613] loop: module loaded
[ 1.583692] tegra_profiler: version: 1.143, samples/io: 48/28
[ 1.583843] tegra_profiler: auth: init
[ 1.584620] THERMAL EST: found 3 subdevs
[ 1.584627] THERMAL EST num_resources: 0
[ 1.584635] [THERMAL EST subdev 0]
[ 1.584642] [THERMAL EST subdev 1]
[ 1.584648] [THERMAL EST subdev 2]
[ 1.584660] THERMAL EST: Found 2 profiles, default profile is quiet
[ 1.584962] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.584967] THERMAL EST: thz register success.
[ 1.587218] Console: switching to colour frame buffer device 240x67
[ 1.587387] tegradc 15200000.nvdisplay: fb registered
[ 1.587632] gpio tegra-gpio wake63 for gpio=97(M:1)
[ 1.588224] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 1.588320] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 1.589148] THERMAL EST: end of probe, return err: 0
[ 1.589952] sd: No Scsi addr parsed to reserve index
[ 1.589999] hisi_sas: driver version v1.6
[ 1.590602] Parent Clock set for DC plld2
[ 1.600921] qspi_mtd spi6.0: s25fs256s SSG 8 0 1000 2000000
[ 1.600930] qspi_mtd spi6.0: s25fs256s (32768 Kbytes)
[ 1.600940] qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x2000000 (32MiB) .erasesize = 0x00010000 (64KiB) .numeraseregions = 0
[ 1.601220] 1 ofpart partitions found on MTD device spi6.0
[ 1.601226] Creating 1 MTD partitions on “spi6.0”:
[ 1.601244] 0x000000000000-0x000002000000 : “Whole_flash0”
[ 1.603926] libphy: Fixed MDIO Bus: probed
[ 1.604517] tun: Universal TUN/TAP device driver, 1.6
[ 1.604523] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 1.605285] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.605291] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.605327] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.605331] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.605381] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.605386] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.605427] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.605432] Copyright(c) 1999 - 2017 Intel Corporation.
[ 1.653132] tegradc 15200000.nvdisplay: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_111m_223m
[ 1.653830] tegradc 15200000.nvdisplay: hdmi: get RGB quant from REG programmed by BL.
[ 1.653844] tegradc 15200000.nvdisplay: hdmi: get YCC quant from REG programmed by BL.
[ 1.679456] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 1.679462] Extcon AUX1(HDMI) enable
[ 1.679914] tegradc 15210000.nvdisplay: disp1 connected to head1->/host1x/sor
[ 1.679945] tegradc 15210000.nvdisplay: parse_dp_settings: No dp-lt-settings node
[ 1.680044] tegradc 15210000.nvdisplay: DT parsed successfully
[ 1.680089] tegradc 15210000.nvdisplay: Display dc.ffffff800d150000 registered with id=1
[ 1.680330] tegradc 15210000.nvdisplay: vblank syncpt # 11 for dc 1
[ 1.680339] tegradc 15210000.nvdisplay: vpulse3 syncpt # 12 for dc 1
[ 1.688771] tegradc 15210000.nvdisplay: probed
[ 1.689140] tegradc 15210000.nvdisplay: fb registered
[ 1.692440] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.692448] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.692460] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.692472] tegradc 15210000.nvdisplay: blank - powerdown
[ 1.692486] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[ 1.692491] Extcon DP: HPD disabled
[ 1.692496] hpd: hpd_switch 0
[ 1.692501] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.692512] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.692521] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.814564] tegradc 15200000.nvdisplay: blank - powerdown
[ 1.850457] eqos 2490000.ether_qos: failed to read eqos_auto_cal_config_0_reg
[ 1.851051] eqos 2490000.ether_qos: Setting local MAC: 48 b0 2d 2f 7d 50
[ 1.851188] libphy: dwc_phy: probed
[ 1.853529] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 1.853533] Extcon AUX1(HDMI) disable
[ 1.854096] PPP generic driver version 2.4.2
[ 1.854286] PPP BSD Compression module registered
[ 1.854292] PPP Deflate Compression module registered
[ 1.854311] PPP MPPE Compression module registered
[ 1.854315] NET: Registered protocol family 24
[ 1.854367] usbcore: registered new interface driver r8152
[ 1.854399] usbcore: registered new interface driver asix
[ 1.854433] usbcore: registered new interface driver ax88179_178a
[ 1.854459] usbcore: registered new interface driver cdc_ether
[ 1.854483] usbcore: registered new interface driver net1080
[ 1.854508] usbcore: registered new interface driver cdc_subset
[ 1.854532] usbcore: registered new interface driver zaurus
[ 1.854567] usbcore: registered new interface driver cdc_ncm
[ 1.854782] VFIO - User Level meta-driver version: 0.3
[ 1.856091] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.856107] ehci-pci: EHCI PCI platform driver
[ 1.856139] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.856148] ohci-pci: OHCI PCI platform driver
[ 1.856179] ohci-platform: OHCI generic platform driver
[ 1.861291] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 1.863338] tegra-xusb 3610000.xhci: extcon 0: ffffffc1f4c6d400 id
[ 1.863972] usbcore: registered new interface driver uas
[ 1.864018] usbcore: registered new interface driver usb-storage
[ 1.864088] usbcore: registered new interface driver usbserial
[ 1.865698] tegra-xusb 3610000.xhci: Firmware timestamp: 2019-07-24 05:47:34 UTC, Version: 60.06 release
[ 1.865733] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 1.865751] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 1.866463] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[ 1.866502] tegra-xusb 3610000.xhci: irq 464, io mem 0x03610000
[ 1.866718] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.866723] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.866728] usb usb1: Product: xHCI Host Controller
[ 1.866733] usb usb1: Manufacturer: Linux 4.9.201-tegra xhci-hcd
[ 1.866738] usb usb1: SerialNumber: 3610000.xhci
[ 1.867210] hub 1-0:1.0: USB hub found
[ 1.867303] hub 1-0:1.0: 4 ports detected
[ 1.867845] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 1.867859] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 1.867868] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.868148] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.868153] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.868158] usb usb2: Product: xHCI Host Controller
[ 1.868163] usb usb2: Manufacturer: Linux 4.9.201-tegra xhci-hcd
[ 1.868167] usb usb2: SerialNumber: 3610000.xhci
[ 1.868637] hub 2-0:1.0: USB hub found
[ 1.868679] hub 2-0:1.0: 4 ports detected
[ 1.869624] Wake76 for irq=199
[ 1.869627] Wake77 for irq=199
[ 1.869630] Wake78 for irq=199
[ 1.869633] Wake79 for irq=199
[ 1.869635] Wake80 for irq=199
[ 1.869638] Wake81 for irq=199
[ 1.869640] Wake82 for irq=199
[ 1.869714] tegra-xusb 3610000.xhci: Upgrade port 0 to USB3.0
[ 1.869720] tegra-xusb 3610000.xhci: Upgrade port 1 to USB3.0
[ 1.871530] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 1.871605] tegra-xudc-new 3550000.xudc: device count: 1
[ 1.872401] tegra-xudc-new 3550000.xudc: vbus state: 0
[ 1.872410] tegra-xudc-new 3550000.xudc: Initialize boost_cpufreq work
[ 1.872438] tegra-xudc-new 3550000.xudc: entering ELPG
[ 1.872654] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 1.873232] mousedev: PS/2 mouse device common for all mice
[ 1.873357] usbcore: registered new interface driver xpad
[ 1.880378] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 1.881906] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 1.902122] tegradc 15200000.nvdisplay: unblank
[ 1.904145] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 1.904504] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 1.913232] Parent Clock set for DC plld2
[ 1.918328] tegradc 15200000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 1.919729] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 1.954542] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 1.954546] Extcon AUX1(HDMI) enable
[ 1.969944] tegradc 15200000.nvdisplay: sync windows ret = 246
[ 1.971997] usb usb2: usb_suspend_both: status 0
[ 2.001427] extcon-disp-state external-connection:disp-state: cable 51 state 1
[ 2.001433] Extcon HDMI: HPD enabled
[ 2.001478] tegradc 15200000.nvdisplay: hdmi: plugged
[ 2.007895] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 2.009463] Wake73 for irq=42
[ 2.010785] rtc rtc1: alarm rtc device
[ 2.010802] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 2.010846] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.011037] i2c /dev entries driver
[ 2.013387] i2c i2c-2: Added multiplexed i2c bus 9
[ 2.013993] i2c i2c-2: Added multiplexed i2c bus 10
[ 2.014004] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[ 2.014559] imx219 9-0010: tegracam sensor driver:imx219_v2.0.6
[ 2.038136] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[ 2.038191] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[ 2.038548] imx219 9-0010: board setup failed
[ 2.038782] imx219: probe of 9-0010 failed with error -121
[ 2.039199] imx219 10-0010: tegracam sensor driver:imx219_v2.0.6
[ 2.062467] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[ 2.062533] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[ 2.062858] imx219 10-0010: board setup failed
[ 2.063073] imx219: probe of 10-0010 failed with error -121
[ 2.064665] max77620-power max20024-power: Event recorder REG_NVERC : 0x0
[ 2.071643] tegra-thermal-throttle bthrot_cdev: cpufreq policy is not ready defer
[ 2.072049] FAN dev name: pwm-fan
[ 2.072093] FAN:gpio request success.
[ 2.072104] FAN: can’t find tach_gpio
[ 2.072114] pwm_fan_driver pwm-fan: Found 2 profiles, default profile is quiet
[ 2.072157] pwm_fan_driver pwm-fan: cap state:4, cap pwm:255
[ 2.072363] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 2.072370] pwm_fan_driver pwm-fan: tach period: 1000
[ 2.072933] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 2.072941] pwm_fan_driver pwm-fan: index 1: pwm=130, rpm=1000, rru=2, rrd=2, state:2
[ 2.072949] pwm_fan_driver pwm-fan: index 2: pwm=160, rpm=2000, rru=1, rrd=1, state:2
[ 2.072956] pwm_fan_driver pwm-fan: index 3: pwm=200, rpm=3000, rru=1, rrd=1, state:2
[ 2.072962] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 2.072968] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 2.072974] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 2.072981] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 2.072987] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 2.072993] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 2.073834] tegra-oc-event d280000.soctherm-oc-event: OC driver initialized
[ 2.075014] device-mapper: uevent: version 1.0.3
[ 2.075488] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 2.079125] tegra194_cpufreq_probe: platform driver Initialization: pass
[ 2.080465] cpuidle: Initializing cpuidle driver
[ 2.081320] sdhci: Secure Digital Host Controller Interface driver
[ 2.081324] sdhci: Copyright(c) Pierre Ossman
[ 2.081328] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.081619] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 2.082449] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 2.084253] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 246
[ 2.088843] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 2.090905] tegra-se-nvhost 15810000.se: initialized
[ 2.092300] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 2.093010] tegra-se-nvhost 15820000.se: initialized
[ 2.094188] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 2.095325] tegra-se-nvhost 15830000.se: initialized
[ 2.095943] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 2.097340] tegra-se-nvhost 15840000.se: initialized
[ 2.098248] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 2.098650] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.100150] usbcore: registered new interface driver usbhid
[ 2.100155] usbhid: USB HID core driver
[ 2.104158] tegra186-cam-rtcpu bc00000.rtcpu: deferring, 14800000.isp is not probed
[ 2.105404] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 2.105954] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 2.106706] denver_knobs_init:MTS_VERSION:51035886
[ 2.106879] tegra19x_actmon d230000.actmon: in actmon_register()…
[ 2.107689] tegra19x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 2.108116] t19x_cache tegra-cache: probed
[ 2.111469] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[ 2.111477] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[ 2.112208] carmel-pmu-drv carmel-pmu: Registered Carmel PMU
[ 2.112691] PLL_AON clock registered
[ 2.114632] Clocks initialized successfully
[ 2.116480] nvpmodel: initialized successfully
[ 2.117738] trusty-virtio trusty:virtio: initializing
[ 2.117961] trusty_ipc virtio0: vring0: va¶ ffffffc1e275c000(0) qsz 32 notifyid 1
[ 2.117971] trusty_ipc virtio0: vring1: va¶ ffffffc1e275e000(0) qsz 32 notifyid 2
[ 2.118098] trusty-virtio trusty:virtio: initializing done
[ 2.118366] trusty_ipc virtio0: is online
[ 2.118842] tegra-hda 3510000.hda: Override SDO lines to 4
[ 2.119386] usbcore: registered new interface driver snd-usb-audio
[ 2.135423] gpio tegra-gpio wake8 for gpio=55(G:7)
[ 2.135500] mmc0: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.139158] input: tegra-hda-xnx HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 2.139329] input: tegra-hda-xnx HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 2.139553] input: tegra-hda-xnx HDMI/DP,pcm=8 as /devices/3510000.hda/sound/card0/input2
[ 2.139750] input: tegra-hda-xnx HDMI/DP,pcm=9 as /devices/3510000.hda/sound/card0/input3
[ 2.203313] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 2.211117] OPE platform probe
[ 2.211235] OPE platform probe successful
[ 2.243850] usb 1-2: New USB device found, idVendor=0bda, idProduct=5489
[ 2.243859] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.243864] usb 1-2: Product: 4-Port USB 2.0 Hub
[ 2.243869] usb 1-2: Manufacturer: Generic
[ 2.245275] hub 1-2:1.0: USB hub found
[ 2.246302] hub 1-2:1.0: 4 ports detected
[ 2.288998] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 2.289129] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 2.289260] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 2.289391] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 2.289510] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 2.289621] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 2.289751] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 2.289891] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 2.290054] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 2.290151] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 2.290241] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 2.290350] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 2.290446] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 2.290544] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 2.290639] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 2.290751] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 2.290863] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 2.290972] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 2.291070] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 2.291164] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 2.322924] u32 classifier
[ 2.322932] Actions configured
[ 2.323029] Initializing XFRM netlink socket
[ 2.323644] NET: Registered protocol family 10
[ 2.324516] NET: Registered protocol family 17
[ 2.324533] NET: Registered protocol family 15
[ 2.324593] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 2.324703] Bluetooth: RFCOMM socket layer initialized
[ 2.324722] Bluetooth: RFCOMM ver 1.11
[ 2.324730] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.324738] Bluetooth: HIDP socket layer initialized
[ 2.324756] 9pnet: Installing 9P2000 support
[ 2.324833] Key type dns_resolver registered
[ 2.325118] Registered cp15_barrier emulation handler
[ 2.325142] Registered setend emulation handler
[ 2.326963] registered taskstats version 1
[ 2.327483] tegra-pcie-dw 14160000.pcie: Setting init speed to max speed
[ 2.328428] OF: PCI: host bridge /pcie@14160000 ranges:
[ 2.328446] OF: PCI: IO 0x36100000…0x361fffff → 0x36100000
[ 2.328455] OF: PCI: MEM 0x1740000000…0x17ffffffff → 0x40000000
[ 2.328461] OF: PCI: MEM 0x1400000000…0x173fffffff → 0x1400000000
[ 2.352232] usb 2-3: new SuperSpeedPlus USB device number 2 using tegra-xusb
[ 2.388184] usb 2-3: New USB device found, idVendor=0bda, idProduct=0489
[ 2.388209] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.388214] usb 2-3: Product: 4-Port USB 3.0 Hub
[ 2.388218] usb 2-3: Manufacturer: Generic
[ 2.398314] hub 2-3:1.0: USB hub found
[ 2.400082] hub 2-3:1.0: 4 ports detected
[ 2.439318] tegra-pcie-dw 14160000.pcie: link is up
[ 2.439500] tegra-pcie-dw 14160000.pcie: PCI host bridge to bus 0004:00
[ 2.439508] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 2.439516] pci_bus 0004:00: root bus resource [io 0x0000-0xfffff] (bus address [0x36100000-0x361fffff])
[ 2.439524] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[ 2.439529] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[ 2.439559] pci 0004:00:00.0: [10de:1ad1] type 01 class 0x060400
[ 2.439761] pci 0004:00:00.0: PME# supported from D0 D3hot D3cold
[ 2.439985] iommu: Adding device 0004:00:00.0 to group 58
[ 2.440403] pci 0004:01:00.0: [10ec:c822] type 00 class 0x028000
[ 2.440543] pci 0004:01:00.0: reg 0x10: [io 0x1000-0x10ff]
[ 2.440750] pci 0004:01:00.0: reg 0x18: [mem 0x1740000000-0x174000ffff 64bit]
[ 2.441560] pci 0004:01:00.0: supports D1 D2
[ 2.441566] pci 0004:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.441912] iommu: Adding device 0004:01:00.0 to group 59
[ 2.452261] pci 0004:00:00.0: BAR 14: assigned [mem 0x1740000000-0x17400fffff]
[ 2.452268] pci 0004:00:00.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.452277] pci 0004:01:00.0: BAR 2: assigned [mem 0x1740000000-0x174000ffff 64bit]
[ 2.452360] pci 0004:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.452388] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 2.452394] pci 0004:00:00.0: bridge window [io 0x1000-0x1fff]
[ 2.452403] pci 0004:00:00.0: bridge window [mem 0x1740000000-0x17400fffff]
[ 2.452437] pci 0004:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 2.452498] pci 0004:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 2.452722] pcieport 0004:00:00.0: Signaling PME through PCIe PME interrupt
[ 2.452727] pci 0004:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.452734] pcie_pme 0004:00:00.0:pcie001: service driver pcie_pme loaded
[ 2.452817] aer 0004:00:00.0:pcie002: service driver aer loaded
[ 2.453422] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[ 2.454470] OF: PCI: host bridge /pcie@141a0000 ranges:
[ 2.454486] OF: PCI: IO 0x3a100000…0x3a1fffff → 0x3a100000
[ 2.454494] OF: PCI: MEM 0x1f40000000…0x1fffffffff → 0x40000000
[ 2.454500] OF: PCI: MEM 0x1c00000000…0x1f3fffffff → 0x1c00000000
[ 2.499290] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[ 2.520503] usb 1-3: New USB device found, idVendor=13d3, idProduct=3549
[ 2.520511] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.520516] usb 1-3: Product: Bluetooth Radio
[ 2.520520] usb 1-3: Manufacturer: Realtek
[ 2.520525] usb 1-3: SerialNumber: 00e04c000001
[ 2.551290] tegra_cec 3960000.tegra_cec: physical address: 10:00.
[ 2.615812] tegra_cec 3960000.tegra_cec: Sent res: -113.
[ 2.615818] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 2.814970] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.953961] mmc0: hw tuning done …
[ 2.954030] mmc0: new ultra high speed SDR104 SDHC card at address 59b4
[ 2.954452] mmcblk0: mmc0:59b4 USDU1 28.3 GiB
[ 2.958045] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[ 2.963299] usb 1-2.2: new full-speed USB device number 4 using tegra-xusb
[ 2.965304] tegra-pcie-dw 141a0000.pcie: link is down
[ 2.965535] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0005:00
[ 2.965547] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 2.965555] pci_bus 0005:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x3a100000-0x3a1fffff])
[ 2.965562] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[ 2.965567] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[ 2.965594] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 2.965764] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[ 2.966003] iommu: Adding device 0005:00:00.0 to group 60
[ 2.966279] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 2.966322] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 2.966538] pcieport 0005:00:00.0: Signaling PME through PCIe PME interrupt
[ 2.966545] pcie_pme 0005:00:00.0:pcie001: service driver pcie_pme loaded
[ 2.966647] aer 0005:00:00.0:pcie002: service driver aer loaded
[ 2.966834] pcie_pme 0005:00:00.0:pcie001: unloading service driver pcie_pme
[ 2.966950] aer 0005:00:00.0:pcie002: unloading service driver aer
[ 2.967080] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 2.967210] iommu: Removing device 0005:00:00.0 from group 60
[ 2.967324] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[ 2.969575] tegra-pcie-dw 141a0000.pcie: PCIe link is not up…!
[ 2.979547] tegra-cbb 14040000.cv-noc: noc_secure_irq = 90, noc_nonsecure_irq = 89>
[ 2.983703] usb 1-2.2: not running at top speed; connect to a high speed hub
[ 2.984454] usb 1-2.2: New USB device found, idVendor=1e7d, idProduct=2dcd
[ 2.984461] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.984466] usb 1-2.2: Product: ROCCAT Kone Pure Owl-Eye
[ 2.984485] usb 1-2.2: Manufacturer: ROCCAT
[ 2.984843] tegra194-isp5 14800000.isp: initialized
[ 2.987015] input: ROCCAT ROCCAT Kone Pure Owl-Eye as /devices/3610000.xhci/usb1/1-2/1-2.2/1-2.2:1.0/0003:1E7D:2DCD.0001/input/input4
[ 2.992226] tegra194-vi5 15c10000.vi: using default number of vi channels, 36
[ 2.994972] tegra194-vi5 15c10000.vi: initialized
[ 2.999455] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi–2 bound
[ 2.999542] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi–1 bound
[ 2.999794] tegra-thermal-throttle bthrot_cdev: clk:cpu max:1907200000, min:115200000 steps:24
[ 3.003297] usb 2-3: usb_suspend_both: status 0
[ 3.003503] usb usb2: usb_suspend_both: status 0
[ 3.004192] tegra-thermal-throttle bthrot_cdev: clk:gpu max:1109250000, min:114750000 steps:10
[ 3.004211] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
[ 3.004218] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
[ 3.004293] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:48 cutoff:0
[ 3.004327] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:0:cpu off:0 slope-adj:400
[ 3.004332] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:1:gpu off:0 slope-adj:400
[ 3.008452] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced max_state:40 cutoff:1
[ 3.008487] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:0:cpu off:0 slope-adj:200
[ 3.008493] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:1:gpu off:365500000 slope-adj:300
[ 3.009341] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced max_state:48 cutoff:0
[ 3.009396] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:0:cpu off:38400000 slope-adj:10
[ 3.009402] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:1:gpu off:25500000 slope-adj:10
[ 3.009884] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced max_state:2 cutoff:0
[ 3.009916] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:0:cpu off:0 slope-adj:400
[ 3.009922] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:1:gpu off:0 slope-adj:400
[ 3.010245] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced max_state:40 cutoff:1
[ 3.011042] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 3.043643] hid-generic 0003:1E7D:2DCD.0001: input,hidraw0: USB HID v1.11 Mouse [ROCCAT ROCCAT Kone Pure Owl-Eye] on usb-3610000.xhci-2.2/input0
[ 3.044819] input: ROCCAT ROCCAT Kone Pure Owl-Eye as /devices/3610000.xhci/usb1/1-2/1-2.2/1-2.2:1.1/0003:1E7D:2DCD.0002/input/input5
[ 3.095319] tegra-ivc ivc-bc00000.rtcpu: region 0: iova=0xbfee0000-0xbfefffff size=131072
[ 3.095635] tegra-ivc ivc-bc00000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 3.095853] tegra-ivc ivc-bc00000.rtcpu:dbg@1: dbg: ver=0 grp=1 RX[1x384]=0x1900-0x1b00 TX[1x384]=0x1b00-0x1d00
[ 3.096088] tegra-ivc ivc-bc00000.rtcpu:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d00-0x3d80 TX[1x8192]=0x3d80-0x5e00
[ 3.096473] tegra-ivc ivc-bc00000.rtcpu:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e00-0xae80 TX[64x320]=0xae80-0xff00
[ 3.096547] tegra-ivc ivc-bc00000.rtcpu:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff00-0x17f80 TX[512x64]=0x17f80-0x20000
[ 3.096757] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (65)
[ 3.096762] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 3.097794] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=5 sha1=cf2bef3ad10e437272857b76308abef8ffb80bda
[ 3.098424] Wake83 for irq=211
[ 3.098512] gpio tegra-gpio wake67 for gpio=48(G:0)
[ 3.098602] gpio tegra-gpio-aon wake29 for gpio=36(EE:4)
[ 3.098765] input: gpio-keys as /devices/gpio-keys/input/input6
[ 3.107938] hid-generic 0003:1E7D:2DCD.0002: input,hidraw1: USB HID v1.11 Keyboard [ROCCAT ROCCAT Kone Pure Owl-Eye] on usb-3610000.xhci-2.2/input1
[ 3.140240] tegra_rtc c2a0000.rtc: setting system clock to 2021-02-23 18:58:18 UTC (1614106698)
[ 3.140758] mmcblk mmc0:59b4: Card claimed for testing.
[ 3.178776] bpmp: mounted debugfs mirror
[ 3.184765] ALSA device list:
[ 3.184772] #0: tegra-hda-xnx at 0x3518000 irq 64
[ 3.184775] #1: jetson-xaviernx-ape
[ 3.186913] Freeing unused kernel memory: 8576K
[ 3.187323] usb 1-2.3: new high-speed USB device number 5 using tegra-xusb
[ 3.225138] Root device found: mmcblk0p1
[ 3.227033] Found dev node: /dev/mmcblk0p1
[ 3.292473] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 3.295189] Rootfs mounted over mmcblk0p1
[ 3.323352] Switching from initrd to actual rootfs
[ 3.425968] usb 1-2.3: New USB device found, idVendor=046d, idProduct=0825
[ 3.425976] usb 1-2.3: New USB device strings: Mfr=0, Product=0, SerialNumber=2
[ 3.425981] usb 1-2.3: SerialNumber: 201A6270
[ 3.547036] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.551392] cgroup: cgroup2: unknown option “nsdelegate”
[ 3.568282] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 3.568938] systemd[1]: Detected architecture arm64.
[ 3.574587] systemd[1]: Set hostname to .
[ 3.690923] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 3.690936] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 3.831559] FAN rising trip_level:1 cur_temp:46100 trip_temps[2]:60000
[ 3.854202] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.854437] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.854696] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.855097] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.855137] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.857772] systemd[1]: Created slice User and Session Slice.
[ 3.858929] systemd[1]: Created slice System Slice.
[ 3.859343] systemd[1]: Listening on Syslog Socket.
[ 3.960999] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 4.003487] nvgpu: 17000000.gv11b nvgpu_nvhost_syncpt_init:291 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[ 4.017091] cpu-throttle-alert cooling device registered.
[ 4.017396] gpu-throttle-alert cooling device registered.
[ 4.017730] aux-throttle-alert cooling device registered.
[ 4.247470] systemd-journald[2344]: Received request to flush runtime journal from PID 1
[ 4.766105] usb 1-2.3: set resolution quirk: cval->res = 384
[ 4.851345] usb 1-2.4: new low-speed USB device number 6 using tegra-xusb
[ 4.883174] usb 1-2.4: New USB device found, idVendor=04b4, idProduct=0101
[ 4.883184] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.883189] usb 1-2.4: Product: Cypress USB Keyboard / PS2 Mouse
[ 4.883193] usb 1-2.4: Manufacturer: Cypress
[ 4.900968] input: Cypress Cypress USB Keyboard / PS2 Mouse as /devices/3610000.xhci/usb1/1-2/1-2.4/1-2.4:1.0/0003:04B4:0101.0003/input/input7
[ 4.960457] hid-generic 0003:04B4:0101.0003: input,hidraw2: USB HID v1.00 Keyboard [Cypress Cypress USB Keyboard / PS2 Mouse] on usb-3610000.xhci-2.4/input0
[ 4.969673] input: Cypress Cypress USB Keyboard / PS2 Mouse as /devices/3610000.xhci/usb1/1-2/1-2.4/1-2.4:1.1/0003:04B4:0101.0004/input/input8
[ 5.029229] hid-generic 0003:04B4:0101.0004: input,hidraw3: USB HID v1.00 Mouse [Cypress Cypress USB Keyboard / PS2 Mouse] on usb-3610000.xhci-2.4/input1
[ 5.122419] using random self ethernet address
[ 5.122620] using random host ethernet address
[ 5.208436] random: crng init done
[ 5.208583] random: 7 urandom warning(s) missed due to ratelimiting
[ 5.494988] usbcore: registered new interface driver btusb
[ 5.499143] rtk_btusb: Realtek Bluetooth USB driver ver 3.1
[ 5.499151] rtk_btcoex: rtk_btcoex_init: version: 1.2
[ 5.499154] rtk_btcoex: create workqueue
[ 5.501517] rtk_btcoex: alloc buffers 1792, 2432 for ev and l2
[ 5.501602] rtk_btusb: btusb_probe intf->cur_altsetting->desc.bInterfaceNumber 0
[ 5.501606] rtk_btusb: btusb_probe can_wakeup 1, may wakeup 0
[ 5.501610] rtk_btusb: patch_add
[ 5.501613] rtk_btusb: auto suspend is disabled
[ 5.501617] rtk_btusb: pid = 0x3549
[ 5.501621] rtk_btusb: patch_add: Reset gEVersion to 0xff
[ 5.501636] rtk_btusb: set_bit(HCI_QUIRK_RESET_ON_CLOSE, &hdev->quirks);
[ 5.505507] rtk_btusb: btusb_open start
[ 5.505514] rtk_btusb: btusb_open hdev->promisc ==0
[ 5.505518] rtk_btusb: download_patch start
[ 5.505522] rtk_btusb: chip type value: 0x73
[ 5.505529] rtk_btusb: HCI reset.
[ 5.505574] rtk_btusb: btusb_probe: done
[ 5.505757] usbcore: registered new interface driver rtk_btusb
[ 5.516108] rtk_btusb: read_ver_rsp->lmp_subver = 0x8822
[ 5.516114] rtk_btusb: read_ver_rsp->hci_rev = 0xc
[ 5.516118] rtk_btusb: patch_entry->lmp_sub = 0x8822
[ 5.516122] rtk_btusb: load_firmware start
[ 5.516126] rtk_btusb: lmp_version = 0x8822
[ 5.516131] rtk_btusb: config filename rtl8822cu_config
[ 5.542384] rtk_btusb: no bdaddr file /opt/bdaddr
[ 5.542393] rtk_btusb: 55 ab 23 87 00 00
[ 5.542405] rtk_btusb: Config file length 6, new length 6
[ 5.542409] rtk_btusb: fw name is rtl8822cu_fw
[ 5.543536] rtk_btusb: This is not 8723a, use new patch style!
[ 5.543548] rtk_btusb: rtk_get_eversion: gEVersion 255
[ 5.544100] rtk_btusb: eversion->status = 0x0, eversion->version = 0x3
[ 5.544107] rtk_btusb: load_firmware: New gEVersion 3
[ 5.544112] rtk_btusb: rtk_get_fw_project_id: opcode 0, len 1, data 13
[ 5.544116] rtk_btusb: lmp_version is 8822, project_id is 8822, match!
[ 5.544120] rtk_btusb: fw_version = 0x98a42f7
[ 5.544123] rtk_btusb: number_of_total_patch = 3
[ 5.544126] rtk_btusb: chipID 4
[ 5.544129] rtk_btusb: patch_length 0x55f0
[ 5.544132] rtk_btusb: start_offset 0x00005d00
[ 5.544136] rtk_btusb: Svn version: 21761
[ 5.544141] rtk_btusb: Coexistence: BTCOEX_20190509-0d0d
[ 5.544144] rtk_btusb: buf_len = 0x55f6
[ 5.544155] rtk_btusb: fw: exists, config file: exists
[ 5.544159] rtk_btusb: load_firmware done
[ 5.544179] rtk_btusb: download_data start
[ 5.658130] rtk_btusb: download_data done
[ 5.658134] rtk_btusb: HCI reset.
[ 5.669108] rtk_btusb: read_ver_rsp->lmp_subver = 0x42f7
[ 5.669110] rtk_btusb: read_ver_rsp->hci_rev = 0x98a
[ 5.669112] rtk_btusb: patch_entry->lmp_sub = 0x8822
[ 5.669121] rtk_btusb: Rtk patch end 0
[ 5.669125] rtk_btusb: btusb_open set HCI_RUNNING
[ 5.669327] rtk_btcoex: Open BTCOEX
[ 5.669330] rtk_btusb: btusb_open end
[ 5.671746] uvcvideo: Found UVC 1.00 device (046d:0825)
[ 5.673119] rtk_btcoex: BTCOEX hci_rev 0x098a
[ 5.673135] rtk_btcoex: BTCOEX lmp_subver 0x42f7
[ 5.685995] uvcvideo 1-2.3:1.0: Entity type for entity Extension 4 was not initialized!
[ 5.686242] uvcvideo 1-2.3:1.0: Entity type for entity Extension 6 was not initialized!
[ 5.686429] uvcvideo 1-2.3:1.0: Entity type for entity Extension 7 was not initialized!
[ 5.686712] uvcvideo 1-2.3:1.0: Entity type for entity Processing 2 was not initialized!
[ 5.686911] uvcvideo 1-2.3:1.0: Entity type for entity Extension 3 was not initialized!
[ 5.687100] uvcvideo 1-2.3:1.0: Entity type for entity Camera 1 was not initialized!
[ 5.687833] input: UVC Camera (046d:0825) as /devices/3610000.xhci/usb1/1-2/1-2.3/1-2.3:1.0/input/input9
[ 5.688529] usbcore: registered new interface driver uvcvideo
[ 5.688534] USB Video Class driver (1.1.1)
[ 5.693115] rtk_btusb: btusb_notify: hci0 evt 3
[ 6.149114] Mass Storage Function, version: 2009/09/11
[ 6.149125] LUN: removable file: (no medium)
[ 6.154793] using random self ethernet address
[ 6.154990] using random host ethernet address
[ 6.513137] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 6.513154] Bluetooth: BNEP socket layer initialized
[ 6.539434] rndis0: HOST MAC aa:ef:8c:e6:94:b8
[ 6.539773] rndis0: MAC aa:ef:8c:e6:94:b9
[ 6.540633] usb0: HOST MAC aa:ef:8c:e6:94:ba
[ 6.540666] usb0: MAC aa:ef:8c:e6:94:bb
[ 6.540686] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 6.542439] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 6.542460] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 6.542818] tegra-xudc-new 3550000.xudc: entering ELPG
[ 6.543069] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 6.543085] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 6.543612] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 6.543624] tegra-xudc-new 3550000.xudc: entering ELPG
[ 6.543814] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 6.549933] l4tbr0: port 1(rndis0) entered blocking state
[ 6.549944] l4tbr0: port 1(rndis0) entered disabled state
[ 6.550171] device rndis0 entered promiscuous mode
[ 6.556126] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 6.563010] l4tbr0: port 2(usb0) entered blocking state
[ 6.563019] l4tbr0: port 2(usb0) entered disabled state
[ 6.563532] device usb0 entered promiscuous mode
[ 6.569724] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 7.279357] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.495903] ras_fhi_disable: FHI 471 disabled
[ 7.496716] CPU2: shutdown
[ 7.496853] psci: CPU2 killed.
[ 7.561094] ras_fhi_disable: FHI 472 disabled
[ 7.566542] CPU3: shutdown
[ 7.583350] psci: Retrying again to check for CPU kill
[ 7.583373] psci: CPU3 killed.
[ 7.592171] gpio tegra-gpio wake20 for gpio=52(G:4)
[ 7.597876] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.623892] ras_fhi_disable: FHI 473 disabled
[ 7.624503] CPU4: shutdown
[ 7.624644] psci: CPU4 killed.
[ 7.631516] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 7.682560] ras_fhi_disable: FHI 474 disabled
[ 7.692410] CPU5: shutdown
[ 7.711343] psci: Retrying again to check for CPU kill
[ 7.711365] psci: CPU5 killed.
[ 7.720372] nvgpu: 17000000.gv11b tpc_pg_mask_store:843 [INFO] no value change, same mask already set
[ 8.049701] zram: Added device: zram0
[ 8.050559] zram: Added device: zram1
[ 8.070041] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 8.114216] zram0: detected capacity change from 0 to 2035691520
[ 8.323850] Adding 1987976k swap on /dev/zram0. Priority:5 extents:1 across:1987976k SS
[ 8.387220] zram1: detected capacity change from 0 to 2035691520
[ 8.439238] Adding 1987976k swap on /dev/zram1. Priority:5 extents:1 across:1987976k SS
[ 8.558160] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 9.236611] usb 1-2.3: usb_suspend_both: status 0
[ 10.168844] tegradc 15200000.nvdisplay: unblank
[ 10.168858] tegradc 15210000.nvdisplay: blank - powerdown
[ 11.457769] fuse init (API version 7.26)
[ 13.815124] ------------[ cut here ]------------
[ 13.815317] WARNING: CPU: 1 PID: 6018 at /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/net/wireless/nl80211.c:14141 cfg80211_ch_switch_notify+0x150/0x170 [cfg80211]
[ 13.815563] Modules linked in: fuse zram overlay bnep uvcvideo rtk_btusb btusb btrtl btbcm btintel rtl8822ce cfg80211 spidev userspace_alert nvgpu bluedroid_pm ip_tables x_tables
[ 13.815637] CPU: 1 PID: 6018 Comm: RTW_CMD_THREAD Not tainted 4.9.201-tegra #1
[ 13.815640] Hardware name: NVIDIA Jetson Xavier NX Developer Kit (DT)
[ 13.815644] task: ffffffc1f52cd400 task.stack: ffffffc1ceac8000
[ 13.815704] PC is at cfg80211_ch_switch_notify+0x150/0x170 [cfg80211]
[ 13.816147] LR is at rtw_cfg80211_ch_switch_notify+0x94/0x98 [rtl8822ce]
[ 13.816151] pc : [] lr : [] pstate: 60c00045
[ 13.816154] sp : ffffffc1ceacbc20
[ 13.816158] x29: ffffffc1ceacbc20 x28: ffffff8001290760
[ 13.816166] x27: ffffff800bfa21bc x26: ffffff8001455578
[ 13.816174] x25: ffffff80014d913c x24: ffffffc1db0b1000
[ 13.816181] x23: ffffffc1d588b000 x22: ffffffc1d589b000
[ 13.816189] x21: 0000000000000000 x20: ffffffc1ceacbca8
[ 13.816198] x19: ffffffc1de347000 x18: 0000000000000000
[ 13.816206] x17: 0000007f91280258 x16: 0000000000000000
[ 13.816214] x15: 000000000000001d x14: 0000000000000000
[ 13.816222] x13: 000000000000ffff x12: 13192d1a2d000100
[ 13.816229] x11: 0000000000000004 x10: 0000000000000002
[ 13.816237] x9 : 0000000000000004 x8 : ffffffc1ceacbd3a
[ 13.816245] x7 : 0000000000000000 x6 : 0000000000000001
[ 13.816262] x5 : 0000000000000040 x4 : 0000000000000985
[ 13.816272] x3 : 0000098500000001 x2 : ffffffc1d589c188
[ 13.816279] x1 : 0000098500000001 x0 : 0000000000000000
[ 13.816290] —[ end trace 8383b0b6c25168b6 ]—
[ 13.816392] Call trace:
[ 13.816454] [] cfg80211_ch_switch_notify+0x150/0x170 [cfg80211]
[ 13.816924] [] rtw_cfg80211_ch_switch_notify+0x94/0x98 [rtl8822ce]
[ 13.817358] [] rtw_chk_start_clnt_join+0x43c/0x4d8 [rtl8822ce]
[ 13.817792] [] join_cmd_hdl+0x238/0x330 [rtl8822ce]
[ 13.818214] [] rtw_cmd_thread+0x308/0x608 [rtl8822ce]
[ 13.818225] [] kthread+0xec/0xf0
[ 13.818232] [] ret_from_fork+0x10/0x30
[ 14.037590] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 14.607562] usb 1-2.3: reset high-speed USB device number 5 using tegra-xusb
[ 24.307361] usb 1-2.3: usb_suspend_both: status 0
[ 34.135391] vdd-1v8-sd: disabling
[ 34.135403] vdd-1v8-cvb: disabling
[ 34.135411] vdd-epb-1v0: disabling
[ 34.135440] avdd-cam-2v8: disabling
[ 34.135445] vdd-fan: disabling
[ 34.135451] vdd_sys_en: disabling
[ 39.535008] tegradc 15200000.nvdisplay: blank - powerdown
[ 39.587522] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 39.587526] Extcon AUX1(HDMI) disable
[ 39.609458] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 39.611564] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 39.611716] tegradc 15210000.nvdisplay: blank - powerdown
[ 39.873745] tegradc 15200000.nvdisplay: blank - powerdown
[ 39.873763] tegradc 15200000.nvdisplay: unblank
[ 39.874617] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 39.874742] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 39.876988] Parent Clock set for DC plld2
[ 39.882072] tegradc 15200000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 39.883444] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 39.919440] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 39.919444] Extcon AUX1(HDMI) enable
[ 39.919622] tegradc 15200000.nvdisplay: unblank
[ 39.919635] tegradc 15210000.nvdisplay: blank - powerdown
[ 44.674167] usb 1-2.3: reset high-speed USB device number 5 using tegra-xusb
[ 45.188264] tegradc 15200000.nvdisplay: unblank
[ 45.188277] tegradc 15210000.nvdisplay: blank - powerdown
[ 45.551934] usb 1-2.2: ctrl urb status -75 received
[ 46.681083] FAN rising trip_level:1 cur_temp:46100 trip_temps[2]:60000
[ 54.735036] usb 1-2.3: usb_suspend_both: status 0
[ 281.232019] usb 1-2.3: reset high-speed USB device number 5 using tegra-xusb
[ 281.627839] [RCE] WARNING: t194/isp5.c:901 [config_channel] “All error notifications not enabled: correctable=0x00 uncorrectable=0x00”
[ 284.635734] usb 1-2.3: usb_suspend_both: status 0
[ 294.195747] usb 1-2.3: reset high-speed USB device number 5 using tegra-xusb
[ 297.691461] usb 1-2.3: usb_suspend_both: status 0
[ 390.208756] usb 1-2.3: reset high-speed USB device number 5 using tegra-xusb
[ 394.584416] usb 1-2.3: usb_suspend_both: status 0
[ 505.768716] usb 1-2.3: reset high-speed USB device number 5 using tegra-xusb
[ 508.628459] usb 1-2.3: usb_suspend_both: status 0
[ 759.258862] usb 1-2.3: reset high-speed USB device number 5 using tegra-xusb
[ 762.578652] usb 1-2.3: usb_suspend_both: status 0
[ 804.718081] usb 1-2.3: reset high-speed USB device number 5 using tegra-xusb
[ 822.769232] usb 1-2.3: usb_suspend_both: status 0
[ 830.253243] usb 1-2.3: reset high-speed USB device number 5 using tegra-xusb
[ 833.744989] usb 1-2.3: usb_suspend_both: status 0
nvidia@nvidia-desktop:~$ lsusb
Bus 002 Device 002: ID 0bda:0489 Realtek Semiconductor Corp.
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 13d3:3549 IMC Networks
Bus 001 Device 006: ID 04b4:0101 Cypress Semiconductor Corp. Keyboard/Hub
Bus 001 Device 005: ID 046d:0825 Logitech, Inc. Webcam C270
Bus 001 Device 004: ID 1e7d:2dcd ROCCAT
Bus 001 Device 002: ID 0bda:5489 Realtek Semiconductor Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
nvidia@nvidia-desktop:~$ ls /dev/video*
/dev/video0
nvidia@nvidia-desktop:~$ sudo apt-cache show nvidia-jetpack
Package: nvidia-jetpack
Version: 4.5-b129
Architecture: arm64
Maintainer: NVIDIA Corporation
Installed-Size: 194
Depends: nvidia-cuda (= 4.5-b129), nvidia-opencv (= 4.5-b129), nvidia-cudnn8 (= 4.5-b129), nvidia-tensorrt (= 4.5-b129), nvidia-visionworks (= 4.5-b129), nvidia-container (= 4.5-b129), nvidia-vpi (= 4.5-b129), nvidia-l4t-jetson-multimedia-api (>> 32.5-0), nvidia-l4t-jetson-multimedia-api (<< 32.6-0)
Homepage: Autonomous Machines | NVIDIA Developer
Priority: standard
Section: metapackages
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_4.5-b129_arm64.deb
SHA256: 002646e6d81d13526ade23d7c45180014f3cd9e9f5fb0f8896b77dff85d6b9fe
SHA1: cb17547b902b2793e0df86d561809ecdbf7e401f
MD5sum: 06962c42e462f643455d6194d1a2d641
Description: NVIDIA Jetpack Meta Package
Description-md5: ad1462289bdbc54909ae109d1d32c0a8
What could be the problem?
