The pipeline will get the warning on Xavier NX.
I’m more concerned about two of these messages, should I solve them? My pipeline still looks fine.
[ 69.006543] nvmap_alloc_handle: PID 11127: yrvideo: WARNING: All NvMap Allocations must have a tag to identify the subsystem allocating memory.Please pass the tag to the API call NvRmMemHanldeAllocAttr() or relevant.
[37330.603328] Unable to handle kernel NULL pointer dereference at virtual address 00000004
The full dmesg here.
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.201-tegra (root@rj-ThinkPad-E475) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #46 SMP PREEMPT Thu May 19 10:54:53 CST 2022
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44800000
[ 0.000000] OF: fdt: - 100000000 , 380000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb3_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[ 0.000000] cma: Reserved 64 MiB at 0x00000000c2000000
[ 0.000000] On node 0 totalpages: 4130304
[ 0.000000] DMA zone: 7192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 460288 pages, LIFO batch:31
[ 0.000000] Normal zone: 57344 pages used for memmap
[ 0.000000] Normal zone: 3670016 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s57560 r8192 d32552 u98304
[ 0.000000] pcpu-alloc: s57560 r8192 d32552 u98304 alloc=24*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 4065768
[ 0.000000] Kernel command line: console=ttyTCU0,115200 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1 quiet root=/dev/nvme0n1p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29088(88%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[ 0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Memory: 15435972K/16521216K available (15294K kernel code, 2942K rwdata, 6708K rodata, 8576K init, 609K bss, 331580K reserved, 753664K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f70000 ( 15296 KB)
[ 0.000000] .rodata : 0xffffff8008f70000 - 0xffffff8009610000 ( 6784 KB)
[ 0.000000] .init : 0xffffff8009610000 - 0xffffff8009e70000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e70000 - 0xffffff800a14f808 ( 2943 KB)
[ 0.000000] .bss : 0xffffff800a14f808 - 0xffffff800a1e7cbc ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf10000000 ( 256 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc400000000 ( 16384 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000004] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000664] Console: colour dummy device 80x25
[ 0.000678] console [tty0] enabled
[ 0.000686] bootconsole [tegra_comb_uart0] disabled
[ 0.000700] kmemleak: Kernel memory leak detector disabled
[ 0.000719] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.000736] pid_max: default: 32768 minimum: 301
[ 0.001829] Security Framework initialized
[ 0.002399] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.002411] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.004164] ftrace: allocating 47209 entries in 185 pages
[ 0.407631] sched-energy: Sched-energy-costs installed from DT
[ 0.407654] ASID allocator initialised with 65536 entries
[ 0.442052] tegra-id: chipid=21917.
[ 0.442068] tegra-id: opt_subrevision=1.
[ 0.442096] Tegra Revision: A02p SKU: 0xde CPU Process: 0 SoC Process: 0
[ 0.442126] DTS File Name: /home/rj/nx_35_5_1_kernel/Linux_for_Tegra/source/public/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[ 0.442137] DTB Build time: Mar 10 2022 17:54:05
[ 0.490212] CPU1: Booted secondary processor [4e0f0040]
[ 0.522391] CPU2: Booted secondary processor [4e0f0040]
[ 0.554497] CPU3: Booted secondary processor [4e0f0040]
[ 0.586749] CPU4: Booted secondary processor [4e0f0040]
[ 0.618850] CPU5: Booted secondary processor [4e0f0040]
[ 0.619095] Brought up 6 CPUs
[ 0.619105] SMP: Total of 6 processors activated.
[ 0.619115] CPU features: detected feature: Privileged Access Never
[ 0.619121] CPU features: detected feature: LSE atomic instructions
[ 0.619128] CPU features: detected feature: User Access Override
[ 0.619134] CPU features: detected feature: 32-bit EL0 Support
[ 0.620603] CPU: All CPU(s) started at EL2
[ 0.620651] alternatives: patching kernel code
[ 0.628075] devtmpfs: initialized
[ 0.667004] Initilizing CustomIPI irq domain
[ 0.667264] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.667279] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.675823] pinctrl core: initialized pinctrl subsystem
[ 0.676049] OS set in device tree is not L4T.
[ 0.676299] regulator-dummy: no parameters
[ 0.676530] Initializing plugin-manager
[ 0.676587] Plugin module not found
[ 0.676621] Plugin-manager status disabled
[ 0.677853] NET: Registered protocol family 16
[ 0.679364] pstore: using zlib compression
[ 0.679385] console [pstore-1] enabled
[ 0.679393] pstore: Registered ramoops as persistent store backend
[ 0.679425] ramoops: attached 0x200000@0xf0800000, ecc: 0/0
[ 0.693421] cpuidle: using governor menu
[ 0.694502] bpmp: waiting for handshake
[ 0.694511] bpmp: handshake completed
[ 0.694525] bpmp: synchronizing channels
[ 0.694534] bpmp: channels synchronized
[ 0.694540] bpmp: mail init ok
[ 0.697211] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[ 0.697452] t19x-arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.697460] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.697467] t19x-arm-smmu 12000000.iommu: stage 1 translation
[ 0.697472] t19x-arm-smmu 12000000.iommu: stage 2 translation
[ 0.697498] t19x-arm-smmu 12000000.iommu: nested translation
[ 0.697508] t19x-arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.697516] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.697523] t19x-arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.697530] t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.697536] t19x-arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.700780] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009e74000)
[ 0.700808] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.703351] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.705421] tegra_aon_clk_init: ok
[ 0.705431] Registering BPMP clocks...
[ 0.705546] tegra_bpmp_clk_init: clock init ok (400 clks)
[ 0.706386] Serial: AMBA PL011 UART driver
[ 0.706535] tegra_powergate_init: DONE
[ 0.706609] DTS File Name: /home/rj/nx_35_5_1_kernel/Linux_for_Tegra/source/public/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[ 0.706619] DTB Build time: Mar 10 2022 17:54:05
[ 0.710256] Tegra reboot handler registered.
[ 0.719186] iommu: Adding device 14160000.pcie to group 0
[ 0.719830] iommu: Adding device 141a0000.pcie to group 1
[ 0.721211] iommu: Adding device 2490000.ether_qos to group 2
[ 0.721742] iommu: Adding device 3100000.serial to group 3
[ 0.722274] iommu: Adding device 3110000.serial to group 4
[ 0.722681] iommu: Adding device 3140000.serial to group 5
[ 0.723336] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.723734] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.723754] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[ 0.723759] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L1
[ 0.723764] tegra-pmc: ### PMC reset status reg: 0x2d
[ 0.723812] tegra-pmc: PMC Prod config success
[ 0.724051] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.724065] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.724397] iommu: Adding device 3460000.sdhci to group 6
[ 0.724887] iommu: Adding device 3400000.sdhci to group 7
[ 0.725714] iommu: Adding device 3440000.sdhci to group 8
[ 0.726229] iommu: Adding device 3210000.spi to group 9
[ 0.726612] iommu: Adding device 3230000.spi to group 10
[ 0.727026] iommu: Adding device 3270000.spi to group 11
[ 0.728219] iommu: Adding device 3160000.i2c to group 12
[ 0.728598] iommu: Adding device c240000.i2c to group 13
[ 0.729014] iommu: Adding device 3180000.i2c to group 14
[ 0.729397] iommu: Adding device 3190000.i2c to group 15
[ 0.729996] iommu: Adding device 31b0000.i2c to group 16
[ 0.730408] iommu: Adding device 31c0000.i2c to group 17
[ 0.730801] iommu: Adding device c250000.i2c to group 18
[ 0.731224] iommu: Adding device 31e0000.i2c to group 19
[ 0.731854] iommu: Adding device sound to group 20
[ 0.732615] iommu: Adding device 3510000.hda to group 21
[ 0.733357] iommu: Adding device bc00000.rtcpu to group 22
[ 0.735355] iommu: Adding device 13e10000.host1x to group 23
[ 0.735810] iommu: Adding device 13e10000.host1x:ctx0 to group 24
[ 0.736197] iommu: Adding device 13e10000.host1x:ctx1 to group 25
[ 0.736628] iommu: Adding device 13e10000.host1x:ctx2 to group 26
[ 0.737013] iommu: Adding device 13e10000.host1x:ctx3 to group 27
[ 0.737411] iommu: Adding device 13e10000.host1x:ctx4 to group 28
[ 0.737855] iommu: Adding device 13e10000.host1x:ctx5 to group 29
[ 0.738217] iommu: Adding device 13e10000.host1x:ctx6 to group 30
[ 0.738618] iommu: Adding device 13e10000.host1x:ctx7 to group 31
[ 0.739115] iommu: Adding device 15340000.vic to group 32
[ 0.739569] iommu: Adding device 15380000.nvjpg to group 33
[ 0.739841] iommu: Adding device 15500000.tsec to group 34
[ 0.740112] iommu: Adding device 15100000.tsecb to group 35
[ 0.740395] iommu: Adding device 15480000.nvdec to group 36
[ 0.740667] iommu: Adding device 15140000.nvdec1 to group 37
[ 0.740976] iommu: Adding device 154c0000.nvenc to group 38
[ 0.741248] iommu: Adding device 15a80000.nvenc1 to group 39
[ 0.741665] iommu: Adding device 15880000.nvdla0 to group 40
[ 0.742195] iommu: Adding device 158c0000.nvdla1 to group 41
[ 0.742749] iommu: Adding device 15200000.nvdisplay to group 42
[ 0.746789] platform 15200000.nvdisplay: IOVA linear map 0x00000000c6000000(2a000000)
[ 0.746861] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[ 0.747583] iommu: Adding device 15210000.nvdisplay to group 43
[ 0.747655] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[ 0.749343] iommu: Adding device 15c10000.vi to group 44
[ 0.749505] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[ 0.749990] iommu: Adding device 14800000.isp to group 45
[ 0.750975] iommu: Adding device 16000000.pva0 to group 46
[ 0.751493] iommu: Adding device 16800000.pva1 to group 47
[ 0.751882] iommu: Adding device 15810000.se to group 48
[ 0.752288] iommu: Adding device 15820000.se to group 49
[ 0.752560] iommu: Adding device 15830000.se to group 50
[ 0.752846] iommu: Adding device 15840000.se to group 51
[ 0.753141] iommu: Adding device c1a0000.aon to group 52
[ 0.754712] iommu: Adding device d000000.bpmp to group 53
[ 0.755042] bpmp: ping status is 0
[ 0.755197] bpmp d000000.bpmp: firmware tag is e73a758761f0c6d24a1e69a2ac6b5035
[ 0.758319] bpmp d000000.bpmp: probe ok
[ 0.760310] tegra-reset 0.bpmp_reset: registered 190 resets.
[ 0.760730] iommu: Adding device smmu_test to group 54
[ 0.761869] mc: mapped MMIO address: 0xffffff800a5c0000 -> 0x2c10000
[ 0.761886] mc: mapped MMIO address: 0xffffff800a5e0000 -> 0x2c20000
[ 0.761903] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2c30000
[ 0.761973] mc: mapped MMIO address: 0xffffff800a7d0000 -> 0x2c40000
[ 0.761992] mc: mapped MMIO address: 0xffffff800b010000 -> 0x2c50000
[ 0.762006] mc: mapped MMIO address: 0xffffff800b030000 -> 0x2b80000
[ 0.762043] mc: mapped MMIO address: 0xffffff800b050000 -> 0x2b90000
[ 0.762058] mc: mapped MMIO address: 0xffffff800b070000 -> 0x2ba0000
[ 0.762072] mc: mapped MMIO address: 0xffffff800b090000 -> 0x2bb0000
[ 0.762087] mc: mapped MMIO address: 0xffffff800b0b0000 -> 0x1700000
[ 0.762121] mc: mapped MMIO address: 0xffffff800b0d0000 -> 0x1710000
[ 0.762136] mc: mapped MMIO address: 0xffffff800b0f0000 -> 0x1720000
[ 0.762151] mc: mapped MMIO address: 0xffffff800b110000 -> 0x1730000
[ 0.762165] mc: mapped MMIO address: 0xffffff800b130000 -> 0x1740000
[ 0.762180] mc: mapped MMIO address: 0xffffff800b150000 -> 0x1750000
[ 0.762195] mc: mapped MMIO address: 0xffffff800b170000 -> 0x1760000
[ 0.762209] mc: mapped MMIO address: 0xffffff800b190000 -> 0x1770000
[ 0.762283] mc-err: mcerr ops are set to t19x
[ 0.767798] iommu: Adding device 2600000.dma to group 55
[ 0.773158] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 224 lines on the chip
[ 0.774304] GPIO line 339 (wifi-enable) hogged as output/high
[ 0.774369] GPIO line 393 (rst-tca1116) hogged as output/low
[ 0.774409] GPIO line 419 (rst-5g) hogged as output/low
[ 0.774449] GPIO line 412 (camera-control-output-low) hogged as output/low
[ 0.774487] GPIO line 413 (camera-control-output-low) hogged as output/low
[ 0.774830] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.782409] gpio gpiochip1: gpio-line-names specifies 21 line names but there are 40 lines on the chip
[ 0.782474] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[ 0.782510] GPIO line 266 (sys-led1) hogged as output/low
[ 0.782543] GPIO line 264 (w-disable2) hogged as output/high
[ 0.782603] GPIO line 265 (suspend-led-gpio) hogged as output/high
[ 0.782927] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[ 0.785299] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_83 = 0x10a
[ 0.785314] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.785330] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.786264] iommu: Adding device 3550000.xudc to group 56
[ 0.786911] iommu: Adding device 3610000.xhci to group 57
[ 0.788917] arm64_ras arm64_ras: probed
[ 0.789285] ras_fhi_enable: FHI 471 enabled on CPU0
[ 0.789355] ras_fhi_enable: FHI 472 enabled on CPU1
[ 0.789460] ras_fhi_enable: FHI 473 enabled on CPU2
[ 0.789529] ras_fhi_enable: FHI 474 enabled on CPU3
[ 0.789602] ras_fhi_enable: FHI 475 enabled on CPU4
[ 0.789689] ras_fhi_enable: FHI 476 enabled on CPU5
[ 0.789907] carmel_ras_enable: RAS enabled on cpu0
[ 0.790083] carmel_ras_enable: RAS enabled on cpu1
[ 0.790319] carmel_ras_enable: RAS enabled on cpu2
[ 0.790518] carmel_ras_enable: RAS enabled on cpu3
[ 0.790725] carmel_ras_enable: RAS enabled on cpu4
[ 0.790957] carmel_ras_enable: RAS enabled on cpu5
[ 0.791039] carmel_ras carmel_ras: probed
[ 0.792165] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 480, noc_nonsecure_irq = 479>
[ 0.792635] tegra-cbb c600000.aon-noc: noc_secure_irq = 482, noc_nonsecure_irq = 481>
[ 0.793477] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 484, noc_nonsecure_irq = 483>
[ 0.794310] tegra-cbb be00000.rce-noc: noc_secure_irq = 486, noc_nonsecure_irq = 485>
[ 0.795127] tegra-cbb b600000.sce-noc: noc_secure_irq = 488, noc_nonsecure_irq = 487>
[ 0.795497] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[ 0.796700] vdd-ac-bat: 5000 mV
[ 0.797115] vdd-sdmmc1-sw: 3300 mV
[ 0.797489] vdd-sdmmc3-sw: 3300 mV
[ 0.797802] vdd-1v8-sd: 1800 mV
[ 0.798108] vdd-3v3-cvb: 3300 mV
[ 0.798447] vdd-1v8-cvb: 1800 mV
[ 0.798790] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 0.798834] vdd-epb-1v0: 1000 mV
[ 0.799240] avdd-cam-2v8: 2800 mV
[ 0.799555] vdd-fan: 5000 mV
[ 0.799861] vdd-hdmi-5v0: 5000 mV
[ 0.800160] vdd_sys_en: 1200 mV
[ 0.835277] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.839655] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.839994] SCSI subsystem initialized
[ 0.840233] libata version 3.00 loaded.
[ 0.840460] usbcore: registered new interface driver usbfs
[ 0.840517] usbcore: registered new interface driver hub
[ 0.840629] usbcore: registered new device driver usb
[ 0.851784] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[ 0.854465] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x2
[ 0.866768] vdd-1v0: at 1000 mV
[ 0.874842] vdd-1v8-hs: at 1800 mV
[ 0.882877] vdd-1v8-ls: at 1800 mV
[ 0.890915] vdd-1v8-ao: at 1800 mV
[ 0.898915] vddio-ddr-1v1: at 1100 mV
[ 0.906702] vdd-rtc: at 800 mV
[ 0.907753] spmic-ldo1: at 2375 mV
[ 0.918766] vdd-ao-3v3: at 3300 mV
[ 0.930798] vddio-emmc-3v3: at 3300 mV
[ 0.931920] spmic-ldo4: at 1587 mV
[ 0.942867] vdd-usb-3v3: at 3300 mV
[ 0.954899] vddio-sdmmc1-3v3: at 3300 mV
[ 0.959013] vdd-csi-1v2: at 1200 mV
[ 0.960101] spmic-ldo8: at 1800 mV
[ 0.964328] GPIO line 246 (gpio_default) hogged as output/high
[ 0.965275] GPIO line 247 (gpio_default) hogged as output/high
[ 0.965651] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[ 0.965926] max77620 4-003c: max77620 probe successful
[ 0.966378] media: Linux media interface: v0.10
[ 0.966425] Linux video capture interface: v2.00
[ 0.967675] pps_core: LinuxPPS API ver. 1 registered
[ 0.967686] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.967707] PTP clock support registered
[ 0.967931] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 0.968187] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.968220] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.970713] trusty trusty: trusty version: Built: 08:40:57 Feb 19 2021
[ 0.970773] trusty trusty: selected api version: 3 (requested 3)
[ 0.971738] Advanced Linux Sound Architecture Driver Initialized.
[ 0.972220] Bluetooth: Core ver 2.22
[ 0.972264] NET: Registered protocol family 31
[ 0.972274] Bluetooth: HCI device and connection manager initialized
[ 0.972288] Bluetooth: HCI socket layer initialized
[ 0.972317] Bluetooth: L2CAP socket layer initialized
[ 0.972349] Bluetooth: SCO socket layer initialized
[ 0.975118] camchar: rtcpu character device driver loaded
[ 0.975877] gpio tegra-gpio wake61 for gpio=201(Z:1)
[ 0.975974] extcon-gpio-states external-connection:extcon@1: Cable state:0, cable id:0
[ 0.977678] clocksource: Switched to clocksource arch_sys_counter
[ 1.022745] VFS: Disk quotas dquot_6.6.0
[ 1.022834] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.023157] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 1.024435] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[ 1.024492] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[ 1.024753] cma: enabled page replacement for spfn=c6000, epfn=f0000
[ 1.024764] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 1.024785] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[ 1.024799] nvmap_page_pool_init: Total RAM pages: 4047409
[ 1.024808] nvmap_page_pool_init: nvmap page pool size: 505926 pages (1976 MB)
[ 1.024967] nvmap_background_zero_thread: PP zeroing thread starting.
[ 1.025437] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[ 1.027591] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 1.040431] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 1.040653] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 1.040877] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[ 1.041069] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[ 1.041254] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 1.042617] la/ptsa driver initialized.
[ 1.042914] NET: Registered protocol family 2
[ 1.043704] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 1.044351] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 1.044975] TCP: Hash tables configured (established 131072 bind 65536)
[ 1.045043] UDP hash table entries: 8192 (order: 6, 262144 bytes)
[ 1.045306] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes)
[ 1.045861] NET: Registered protocol family 1
[ 1.046466] RPC: Registered named UNIX socket transport module.
[ 1.046477] RPC: Registered udp transport module.
[ 1.046505] RPC: Registered tcp transport module.
[ 1.046516] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.046528] PCI: CLS 0 bytes, default 64
[ 1.046724] Trying to unpack rootfs image as initramfs...
[ 1.046999] rootfs image is not initramfs (junk in compressed archive); looks like an initrd
[ 1.055036] Freeing initrd memory: 7064K
[ 1.077922] host1x 13e10000.host1x: initialized
[ 1.080447] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.085324] audit: initializing netlink subsys (disabled)
[ 1.085378] audit: type=2000 audit(0.700:1): initialized
[ 1.086212] workingset: timestamp_bits=46 max_order=22 bucket_order=0
[ 1.097002] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.098347] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.099014] 9p: Installing v9fs 9p2000 file system support
[ 1.104277] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.104450] io scheduler noop registered
[ 1.104742] io scheduler cfq registered (default)
[ 1.108493] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 1.109700] random: fast init done
[ 1.143463] iommu: Adding device 2993000.adsp to group 58
[ 1.253494] iommu: Adding device aconnect@2a41000:adsp_audio to group 59
[ 1.254453] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.267666] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.268126] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.268724] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.269183] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[ 1.269592] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.272929] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.273127] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 1.276047] tsec 15500000.tsec: initialized
[ 1.277584] tsec 15100000.tsecb: initialized
[ 1.281424] nvdec 15480000.nvdec: initialized
[ 1.283918] nvdec 15140000.nvdec1: initialized
[ 1.289457] falcon 15340000.vic: initialized
[ 1.291519] falcon 15380000.nvjpg: initialized
[ 1.293703] falcon 154c0000.nvenc: initialized
[ 1.295780] falcon 15a80000.nvenc1: initialized
[ 1.299048] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.300669] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.302370] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.304010] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.305752] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.307289] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.308862] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.310414] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.314084] t194-nvcsi 15a00000.nvcsi: initialized
[ 1.319690] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 1.320153] scare-pigeon 14b00000.isp-thi: initialized
[ 1.325878] pva 16000000.pva0: initialized
[ 1.331680] pva 16800000.pva1: initialized
[ 1.336562] nvdla 15880000.nvdla0: initialized
[ 1.341199] nvdla 158c0000.nvdla1: initialized
[ 1.342503] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.342515] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.342556] tegradccommon 15200000.dc_common: dma mapping done
[ 1.342823] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=79
[ 1.342832] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[ 1.343081] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 1.343112] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 1.343405] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 1.343413] tegra_cec 3960000.tegra_cec: probed
[ 1.343848] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor1
[ 1.343899] generic_infoframe_type: 0x87
[ 1.343978] tegradc 15200000.nvdisplay: DT parsed successfully
[ 1.344013] tegradc 15200000.nvdisplay: Display dc.ffffff800bce0000 registered with id=0
[ 1.348752] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 1.348767] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 933000000 Hz
[ 1.348779] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[ 1.349024] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[ 1.349033] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[ 1.352245] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.352252] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.354659] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[ 1.355342] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check disabled
[ 1.355350] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.355672] kfuse 3830000.kfuse: initialized
[ 1.356671] tegradc 15200000.nvdisplay: probed
[ 1.357434] Console: switching to colour frame buffer device 80x30
[ 1.357468] tegradc 15200000.nvdisplay: fb registered
[ 1.357910] gpio tegra-gpio wake63 for gpio=97(M:1)
[ 1.358276] tegradc 15210000.nvdisplay: disp1 connected to head1->/host1x/sor
[ 1.358305] tegradc 15210000.nvdisplay: parse_dp_settings: No dp-lt-settings node
[ 1.358375] tegradc 15210000.nvdisplay: DT parsed successfully
[ 1.358406] tegradc 15210000.nvdisplay: Display dc.ffffff800be50000 registered with id=1
[ 1.358557] tegradc 15210000.nvdisplay: vblank syncpt # 11 for dc 1
[ 1.358565] tegradc 15210000.nvdisplay: vpulse3 syncpt # 12 for dc 1
[ 1.363181] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.366903] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 47, base_baud = 0) is a TEGRA_UART
[ 1.368150] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 48, base_baud = 0) is a TEGRA_UART
[ 1.368523] tegradc 15210000.nvdisplay: probed
[ 1.368838] tegradc 15210000.nvdisplay: fb registered
[ 1.368851] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 49, base_baud = 0) is a TEGRA_UART
[ 1.369955] console [ttyTCU0] enabled
[ 1.370264] [drm] Initialized
[ 1.373099] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 2
[ 1.374439] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 1
[ 1.375971] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 0
[ 1.377502] tegradc 15210000.nvdisplay: dp: aux write got error (0x10000100)
[ 1.377710] tegradc 15210000.nvdisplay: dp: Failed for I2C write addr:80, size:1, stat:0x10000100
[ 1.378675] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 1.378811] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 1.378936] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 1.382948] brd: module loaded
[ 1.383986] Parent Clock set for DC pll_d
[ 1.389197] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 2
[ 1.390413] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 1
[ 1.391976] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 0
[ 1.393470] tegradc 15210000.nvdisplay: dp: aux write got error (0x10000100)
[ 1.393628] tegradc 15210000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.394516] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 2
[ 1.395853] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 1
[ 1.397159] loop: module loaded
[ 1.397252] tegra_profiler: version: 1.143, samples/io: 48/28
[ 1.397402] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 0
[ 1.397409] tegra_profiler: auth: init
[ 1.398082] THERMAL EST: found 3 subdevs
[ 1.398096] THERMAL EST num_resources: 0
[ 1.398108] [THERMAL EST subdev 0]
[ 1.398118] [THERMAL EST subdev 1]
[ 1.398130] [THERMAL EST subdev 2]
[ 1.398143] THERMAL EST: Found 2 profiles, default profile is quiet
[ 1.398451] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.398459] THERMAL EST: thz register success.
[ 1.398664] THERMAL EST: end of probe, return err: 0
[ 1.398756] tegradc 15210000.nvdisplay: dp: aux write got error (0x10000100)
[ 1.398920] tegradc 15210000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.399317] sd: No Scsi addr parsed to reserve index
[ 1.399349] hisi_sas: driver version v1.6
[ 1.399802] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 2
[ 1.401314] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 1
[ 1.401889] spi spi0.0: lch:setup 8 bpw, ~cpol, ~cpha, 14000000Hz
[ 1.402835] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 0
[ 1.403261] spi spi2.0: lch:setup 8 bpw, ~cpol, ~cpha, 33000000Hz
[ 1.404366] tegradc 15210000.nvdisplay: dp: aux write got error (0x10000100)
[ 1.404507] tegradc 15210000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.405401] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 2
[ 1.406914] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 1
[ 1.408462] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 0
[ 1.409170] qspi_mtd spi6.0: s25fs256s SSG 8 0 1000 2000000
[ 1.409178] qspi_mtd spi6.0: s25fs256s (32768 Kbytes)
[ 1.409188] qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x2000000 (32MiB) .erasesize = 0x00010000 (64KiB) .numeraseregions = 0
[ 1.409437] 1 ofpart partitions found on MTD device spi6.0
[ 1.409443] Creating 1 MTD partitions on "spi6.0":
[ 1.409461] 0x000000000000-0x000002000000 : "Whole_flash0"
[ 1.410065] tegradc 15210000.nvdisplay: dp: aux write got error (0x10000100)
[ 1.410227] tegradc 15210000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.410406] tegradc 15210000.nvdisplay: dp: failed to exit panel power save mode (0xfffffff2)
[ 1.411066] hpd: state 7 (Takeover from bootloader), hpd 1, pending_hpd_evt 1
[ 1.411073] hpd: switching from state 7 (Takeover from bootloader) to state 1 (Check Plug)
[ 1.412276] libphy: Fixed MDIO Bus: probed
[ 1.412980] tun: Universal TUN/TAP device driver, 1.6
[ 1.412986] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.413746] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.413751] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.413817] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.413822] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.413861] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.413865] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.413915] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.413920] Copyright(c) 1999 - 2017 Intel Corporation.
[ 1.513760] hpd: state 1 (Check Plug), hpd 1, pending_hpd_evt 0
[ 1.513771] hpd: switching from state 1 (Check Plug) to state 2 (Check EDID)
[ 1.521727] hpd: state 2 (Check EDID), hpd 1, pending_hpd_evt 0
[ 1.522456] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 2
[ 1.523978] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 1
[ 1.525500] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 0
[ 1.526999] tegradc 15210000.nvdisplay: dp: aux write got error (0x10000100)
[ 1.527150] tegradc 15210000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.528022] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 2
[ 1.529543] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 1
[ 1.531063] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 0
[ 1.532581] tegradc 15210000.nvdisplay: dp: aux write got error (0x10000100)
[ 1.532718] tegradc 15210000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.533582] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 2
[ 1.535113] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 1
[ 1.536629] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 0
[ 1.538164] tegradc 15210000.nvdisplay: dp: aux write got error (0x10000100)
[ 1.538315] tegradc 15210000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.539181] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 2
[ 1.540681] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 1
[ 1.542179] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 0
[ 1.543673] tegradc 15210000.nvdisplay: dp: aux write got error (0x10000100)
[ 1.543846] tegradc 15210000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.544022] tegradc 15210000.nvdisplay: dp: failed to exit panel power save mode (0xfffffff2)
[ 1.544178] hpd: edid read prepare failed
[ 1.544272] hpd: DC from connected to disconnected
[ 1.660911] eqos 2490000.ether_qos: failed to read eqos_auto_cal_config_0_reg
[ 1.661507] eqos 2490000.ether_qos: Setting local MAC: 48 b0 2d 5f 87 f7
[ 1.661628] libphy: dwc_phy: probed
[ 1.664039] PPP generic driver version 2.4.2
[ 1.664446] PPP BSD Compression module registered
[ 1.664454] PPP Deflate Compression module registered
[ 1.664471] PPP MPPE Compression module registered
[ 1.664477] NET: Registered protocol family 24
[ 1.664526] usbcore: registered new interface driver r8152
[ 1.664562] usbcore: registered new interface driver asix
[ 1.664593] usbcore: registered new interface driver ax88179_178a
[ 1.664620] usbcore: registered new interface driver cdc_ether
[ 1.664646] usbcore: registered new interface driver net1080
[ 1.664673] usbcore: registered new interface driver cdc_subset
[ 1.664702] usbcore: registered new interface driver zaurus
[ 1.664743] usbcore: registered new interface driver cdc_ncm
[ 1.665165] VFIO - User Level meta-driver version: 0.3
[ 1.666559] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.666578] ehci-pci: EHCI PCI platform driver
[ 1.666617] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.666627] ohci-pci: OHCI PCI platform driver
[ 1.666660] ohci-platform: OHCI generic platform driver
[ 1.671043] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 1.673076] tegra-xusb 3610000.xhci: extcon 0: ffffffc3ec2b4000 id
[ 1.673329] tegra-xusb 3610000.xhci: Direct firmware load for tegra19x_xusb_firmware failed with error -2
[ 1.673361] tegra-xusb 3610000.xhci: Falling back to user helper
[ 1.673608] usbcore: registered new interface driver uas
[ 1.673720] usbcore: registered new interface driver usb-storage
[ 1.673821] usbcore: registered new interface driver usbserial
[ 1.676592] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 1.676668] tegra-xudc-new 3550000.xudc: device count: 1
[ 1.677490] tegra-xudc-new 3550000.xudc: vbus state: 0
[ 1.677500] tegra-xudc-new 3550000.xudc: Initialize boost_cpufreq work
[ 1.677527] tegra-xudc-new 3550000.xudc: entering ELPG
[ 1.677871] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 1.678364] mousedev: PS/2 mouse device common for all mice
[ 1.678497] usbcore: registered new interface driver xpad
[ 1.813005] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.814688] Wake73 for irq=42
[ 1.816045] rtc rtc1: alarm rtc device
[ 1.816061] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 1.816086] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 1.816207] i2c /dev entries driver
[ 1.818309] i2c i2c-2: Added multiplexed i2c bus 9
[ 1.818705] i2c i2c-2: Added multiplexed i2c bus 10
[ 1.818735] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[ 1.819201] imx219 9-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.842763] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.843075] imx219 9-0010: board setup failed
[ 1.843241] imx219: probe of 9-0010 failed with error -121
[ 1.843696] imx219 10-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.867017] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.867343] imx219 10-0010: board setup failed
[ 1.867521] imx219: probe of 10-0010 failed with error -121
[ 1.868608] max77620-power max20024-power: Event recorder REG_NVERC : 0x0
[ 1.875420] tegra-thermal-throttle bthrot_cdev: cpufreq policy is not ready defer
[ 1.875795] FAN dev name: pwm-fan
[ 1.875867] FAN:gpio request success.
[ 1.875916] FAN: can't find tach_gpio
[ 1.875927] pwm_fan_driver pwm-fan: Found 2 profiles, default profile is quiet
[ 1.876015] pwm_fan_driver pwm-fan: cap state:4, cap pwm:160
[ 1.876258] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 1.876290] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.876912] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.876921] pwm_fan_driver pwm-fan: index 1: pwm=90, rpm=1000, rru=2, rrd=2, state:2
[ 1.876927] pwm_fan_driver pwm-fan: index 2: pwm=110, rpm=2000, rru=1, rrd=1, state:2
[ 1.876933] pwm_fan_driver pwm-fan: index 3: pwm=130, rpm=3000, rru=1, rrd=1, state:2
[ 1.876939] pwm_fan_driver pwm-fan: index 4: pwm=160, rpm=4000, rru=1, rrd=1, state:3
[ 1.876945] pwm_fan_driver pwm-fan: index 5: pwm=200, rpm=5000, rru=1, rrd=1, state:3
[ 1.876950] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.876956] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.876962] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.876967] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.877895] tegra-oc-event d280000.soctherm-oc-event: OC driver initialized
[ 1.879091] device-mapper: uevent: version 1.0.3
[ 1.879651] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.883367] tegra194_cpufreq_probe: platform driver Initialization: pass
[ 1.884593] cpuidle: Initializing cpuidle driver
[ 1.885425] sdhci: Secure Digital Host Controller Interface driver
[ 1.885429] sdhci: Copyright(c) Pierre Ossman
[ 1.885432] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.886468] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 1.888222] CMDQ: cmdq_platfm_init successful
[ 1.888701] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 1.890791] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 1.892764] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 248
[ 1.894596] sdhci-tegra 3440000.sdhci: Got CD GPIO
[ 1.895617] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 1.897718] sdhci-tegra 3440000.sdhci: wakeup init done, cdirq 441
[ 1.902648] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 1.904208] tegra-se-nvhost 15810000.se: initialized
[ 1.905445] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 1.906198] tegra-se-nvhost 15820000.se: initialized
[ 1.907590] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 1.908606] tegra-se-nvhost 15830000.se: initialized
[ 1.909352] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 1.910384] tegra-se-nvhost 15840000.se: initialized
[ 1.911561] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 1.911825] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.913034] usbcore: registered new interface driver usbhid
[ 1.913038] usbhid: USB HID core driver
[ 1.916863] tegra186-cam-rtcpu bc00000.rtcpu: deferring, 14800000.isp is not probed
[ 1.918045] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 1.918600] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 1.919265] denver_knobs_init:MTS_VERSION:51035886
[ 1.919431] tegra19x_actmon d230000.actmon: in actmon_register()...
[ 1.920237] tegra19x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 1.920596] t19x_cache tegra-cache: probed
[ 1.923322] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[ 1.923332] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[ 1.923993] carmel-pmu-drv carmel-pmu: Registered Carmel PMU
[ 1.924423] PLL_AON clock registered
[ 1.926241] Clocks initialized successfully
[ 1.927820] nvpmodel: initialized successfully
[ 1.928888] trusty-virtio trusty:virtio: initializing
[ 1.929103] trusty_ipc virtio0: vring0: va(pa) ffffffc3e8c60000(0) qsz 32 notifyid 1
[ 1.929113] trusty_ipc virtio0: vring1: va(pa) ffffffc3e8c62000(0) qsz 32 notifyid 2
[ 1.929258] trusty-virtio trusty:virtio: initializing done
[ 1.929390] trusty_ipc virtio0: is online
[ 1.930525] tegra-hda 3510000.hda: Override SDO lines to 4
[ 1.930868] usbcore: registered new interface driver snd-usb-audio
[ 1.933703] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 1.936391] wrm tegra_admaif_probe ---1
[ 1.937817] gpio tegra-gpio wake8 for gpio=55(G:7)
[ 1.937875] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 1.941845] mmc2: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 1.943894] input: tegra-hda-xnx HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 1.944155] input: tegra-hda-xnx HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 1.944340] input: tegra-hda-xnx HDMI/DP,pcm=8 as /devices/3510000.hda/sound/card0/input2
[ 1.944621] input: tegra-hda-xnx HDMI/DP,pcm=9 as /devices/3510000.hda/sound/card0/input3
[ 1.979749] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 1.993860] mmc0: periodic cache flush enabled
[ 1.993876] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 1.994506] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[ 1.994785] mmcblk0boot0: mmc0:0001 DG4016 partition 1 4.00 MiB
[ 1.995093] mmcblk0boot1: mmc0:0001 DG4016 partition 2 4.00 MiB
[ 1.995309] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB
[ 2.000249] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[ 2.005855] OPE platform probe
[ 2.005962] OPE platform probe successful
[ 2.011625] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 2.012191] u32 classifier
[ 2.012194] Actions configured
[ 2.012284] Initializing XFRM netlink socket
[ 2.012875] NET: Registered protocol family 10
[ 2.017789] NET: Registered protocol family 17
[ 2.017804] NET: Registered protocol family 15
[ 2.017861] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 2.017951] Bluetooth: RFCOMM socket layer initialized
[ 2.017966] Bluetooth: RFCOMM ver 1.11
[ 2.017976] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.017983] Bluetooth: HIDP socket layer initialized
[ 2.018001] 9pnet: Installing 9P2000 support
[ 2.018042] Key type dns_resolver registered
[ 2.018334] Registered cp15_barrier emulation handler
[ 2.018353] Registered setend emulation handler
[ 2.019772] registered taskstats version 1
[ 2.020118] tegra-pcie-dw 14160000.pcie: Setting init speed to max speed
[ 2.021547] OF: PCI: host bridge /pcie@14160000 ranges:
[ 2.021564] OF: PCI: IO 0x36100000..0x361fffff -> 0x36100000
[ 2.021587] OF: PCI: MEM 0x1740000000..0x17ffffffff -> 0x40000000
[ 2.021593] OF: PCI: MEM 0x1400000000..0x173fffffff -> 0x1400000000
[ 2.361762] tegra_cec 3960000.tegra_cec: Can't find physical addresse.
[ 2.361769] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 2.522124] FAN rising trip_level:1 cur_temp:46400 trip_temps[2]:60000
[ 2.537868] tegra-pcie-dw 14160000.pcie: link is down
[ 2.538036] tegra-pcie-dw 14160000.pcie: PCI host bridge to bus 0004:00
[ 2.538045] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 2.538053] pci_bus 0004:00: root bus resource [io 0x0000-0xfffff] (bus address [0x36100000-0x361fffff])
[ 2.538060] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[ 2.538064] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[ 2.538091] pci 0004:00:00.0: [10de:1ad1] type 01 class 0x060400
[ 2.538239] pci 0004:00:00.0: PME# supported from D0 D3hot D3cold
[ 2.538432] iommu: Adding device 0004:00:00.0 to group 60
[ 2.538718] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 2.538741] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 2.538951] pcieport 0004:00:00.0: Signaling PME through PCIe PME interrupt
[ 2.538958] pcie_pme 0004:00:00.0:pcie001: service driver pcie_pme loaded
[ 2.539060] aer 0004:00:00.0:pcie002: service driver aer loaded
[ 2.539244] pcie_pme 0004:00:00.0:pcie001: unloading service driver pcie_pme
[ 2.539349] aer 0004:00:00.0:pcie002: unloading service driver aer
[ 2.539464] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[ 2.539593] iommu: Removing device 0004:00:00.0 from group 60
[ 2.539625] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[ 2.541817] tegra-pcie-dw 14160000.pcie: PCIe link is not up...!
[ 2.542576] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[ 2.543676] OF: PCI: host bridge /pcie@141a0000 ranges:
[ 2.543693] OF: PCI: IO 0x3a100000..0x3a1fffff -> 0x3a100000
[ 2.543702] OF: PCI: MEM 0x1f40000000..0x1fffffffff -> 0x40000000
[ 2.543707] OF: PCI: MEM 0x1c00000000..0x1f3fffffff -> 0x1c00000000
[ 2.555368] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 2.555442] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 2.555898] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 2.555967] tegradc 15210000.nvdisplay: blank - powerdown
[ 2.555978] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[ 2.555981] Extcon DP: HPD disabled
[ 2.555984] hpd: hpd_switch 0
[ 2.555988] hpd: switching from state 2 (Check EDID) to state 3 (Disabled)
[ 2.653729] tegra-pcie-dw 141a0000.pcie: link is up
[ 2.654021] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0005:00
[ 2.654031] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 2.654055] pci_bus 0005:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x3a100000-0x3a1fffff])
[ 2.654062] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[ 2.654067] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[ 2.654094] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 2.654238] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[ 2.654417] iommu: Adding device 0005:00:00.0 to group 60
[ 2.654777] pci 0005:01:00.0: [1bc0:1002] type 00 class 0x010802
[ 2.654880] pci 0005:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 2.655551] pci 0005:01:00.0: PME# supported from D0 D3hot
[ 2.655848] iommu: Adding device 0005:01:00.0 to group 61
[ 2.666482] pci 0005:00:00.0: BAR 14: assigned [mem 0x1f40000000-0x1f400fffff]
[ 2.666491] pci 0005:01:00.0: BAR 0: assigned [mem 0x1f40000000-0x1f40003fff 64bit]
[ 2.666549] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 2.666556] pci 0005:00:00.0: bridge window [mem 0x1f40000000-0x1f400fffff]
[ 2.666572] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 2.666613] pci 0005:01:00.0: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
[ 2.666833] pcieport 0005:00:00.0: Signaling PME through PCIe PME interrupt
[ 2.666837] pci 0005:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.666843] pcie_pme 0005:00:00.0:pcie001: service driver pcie_pme loaded
[ 2.666976] aer 0005:00:00.0:pcie002: service driver aer loaded
[ 2.667343] nvme nvme0: pci function 0005:01:00.0
[ 2.667400] nvme 0005:01:00.0: enabling device (0000 -> 0002)
[ 2.678288] tegra-cbb 14040000.cv-noc: noc_secure_irq = 92, noc_nonsecure_irq = 91>
[ 2.683632] tegra194-isp5 14800000.isp: initialized
[ 2.690637] tegra194-vi5 15c10000.vi: using default number of vi channels, 36
[ 2.693326] tegra194-vi5 15c10000.vi: initialized
[ 2.697594] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--2 bound
[ 2.697744] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--1 bound
[ 2.697951] tegra-thermal-throttle bthrot_cdev: clk:cpu max:1907200000, min:115200000 steps:24
[ 2.702090] tegra-thermal-throttle bthrot_cdev: clk:gpu max:1109250000, min:114750000 steps:10
[ 2.702107] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
[ 2.702112] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
[ 2.702189] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:48 cutoff:0
[ 2.702246] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:0:cpu off:0 slope-adj:400
[ 2.702250] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:1:gpu off:0 slope-adj:400
[ 2.706438] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced max_state:40 cutoff:1
[ 2.706501] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:0:cpu off:0 slope-adj:200
[ 2.706506] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:1:gpu off:365500000 slope-adj:300
[ 2.706801] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced max_state:48 cutoff:0
[ 2.706855] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:0:cpu off:38400000 slope-adj:10
[ 2.706860] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:1:gpu off:25500000 slope-adj:10
[ 2.707193] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced max_state:2 cutoff:0
[ 2.707236] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:0:cpu off:0 slope-adj:400
[ 2.707241] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:1:gpu off:0 slope-adj:400
[ 2.707462] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced max_state:40 cutoff:1
[ 2.708235] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 2.779408] nvme0n1: p1
[ 2.787651] tegra-ivc ivc-bc00000.rtcpu: region 0: iova=0xbfee0000-0xbfefffff size=131072
[ 2.788053] tegra-ivc ivc-bc00000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 2.788287] tegra-ivc ivc-bc00000.rtcpu:dbg@1: dbg: ver=0 grp=1 RX[1x384]=0x1900-0x1b00 TX[1x384]=0x1b00-0x1d00
[ 2.788463] tegra-ivc ivc-bc00000.rtcpu:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d00-0x3d80 TX[1x8192]=0x3d80-0x5e00
[ 2.788940] tegra-ivc ivc-bc00000.rtcpu:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e00-0xae80 TX[64x320]=0xae80-0xff00
[ 2.789012] tegra-ivc ivc-bc00000.rtcpu:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff00-0x17f80 TX[512x64]=0x17f80-0x20000
[ 2.789197] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (67)
[ 2.789201] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 2.790275] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=5 sha1=cf2bef3ad10e437272857b76308abef8ffb80bda
[ 2.792288] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 2.792993] Wake83 for irq=211
[ 2.793059] gpio tegra-gpio wake67 for gpio=48(G:0)
[ 2.793146] gpio tegra-gpio-aon wake29 for gpio=36(EE:4)
[ 2.793284] input: gpio-keys as /devices/gpio-keys/input/input4
[ 2.795575] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 2.826800] tegra_rtc c2a0000.rtc: setting system clock to 2022-06-20 08:39:22 UTC (1655714362)
[ 2.827379] mmcblk mmc0:0001: Card claimed for testing.
[ 2.868843] bpmp: mounted debugfs mirror
[ 2.875108] ALSA device list:
[ 2.875114] #0: tegra-hda-xnx at 0x3518000 irq 66
[ 2.875363] RAMDISK: Couldn't find valid RAM disk image starting at 0.
[ 2.882420] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null)
[ 2.882451] VFS: Mounted root (ext4 filesystem) on device 259:1.
[ 2.883581] devtmpfs: mounted
[ 2.885877] Freeing unused kernel memory: 8576K
[ 2.979369] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.982548] cgroup: cgroup2: unknown option "nsdelegate"
[ 2.988406] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 2.989535] systemd[1]: Detected architecture arm64.
[ 2.994871] systemd[1]: Set hostname to <rj-desktop>.
[ 3.072516] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 3.072528] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 3.107836] systemd[1]: Configuration file /etc/systemd/system/zookeeper.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 3.127169] systemd[1]: Configuration file /etc/systemd/system/supervisord.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 3.144284] systemd[1]: Configuration file /etc/systemd/system/nginx.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 3.147798] systemd[1]: Configuration file /etc/systemd/system/kafka.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 3.148972] systemd[1]: Configuration file /etc/systemd/system/h2.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 3.181500] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.184438] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.184882] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.225616] EXT4-fs (nvme0n1p1): re-mounted. Opts: (null)
[ 3.323240] nvgpu: 17000000.gv11b nvgpu_nvhost_syncpt_init:291 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[ 3.335066] cpu-throttle-alert cooling device registered.
[ 3.335143] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 3.335442] gpu-throttle-alert cooling device registered.
[ 3.335777] aux-throttle-alert cooling device registered.
[ 3.342111] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 3.344836] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 3.590150] systemd-journald[2280]: Received request to flush runtime journal from PID 1
[ 4.402602] gpio tegra-gpio wake20 for gpio=52(G:4)
[ 4.412370] random: crng init done
[ 4.412478] random: 7 urandom warning(s) missed due to ratelimiting
[ 4.413496] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 4.531343] using random self ethernet address
[ 4.531475] using random host ethernet address
[ 4.546369] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 4.640733] tegra-xusb 3610000.xhci: cannot find firmware....retry after 1 second
[ 5.087155] Mass Storage Function, version: 2009/09/11
[ 5.087164] LUN: removable file: (no medium)
[ 5.096379] using random self ethernet address
[ 5.096506] using random host ethernet address
[ 5.121166] rndis0: HOST MAC ea:c4:95:67:be:a0
[ 5.121427] rndis0: MAC ea:c4:95:67:be:a1
[ 5.123078] usb0: HOST MAC ea:c4:95:67:be:a2
[ 5.123139] usb0: MAC ea:c4:95:67:be:a3
[ 5.123162] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 5.128553] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 5.128576] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 5.129365] tegra-xudc-new 3550000.xudc: entering ELPG
[ 5.129704] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 5.129722] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 5.130171] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 5.130184] tegra-xudc-new 3550000.xudc: entering ELPG
[ 5.130378] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 5.150238] l4tbr0: port 1(rndis0) entered blocking state
[ 5.150248] l4tbr0: port 1(rndis0) entered disabled state
[ 5.150732] device rndis0 entered promiscuous mode
[ 5.159854] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 5.245244] l4tbr0: port 2(usb0) entered blocking state
[ 5.245253] l4tbr0: port 2(usb0) entered disabled state
[ 5.245832] device usb0 entered promiscuous mode
[ 5.247534] es8311_i2c_probe success
[ 5.262410] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 5.328578] Enter into es8311_probe()
[ 5.332196] ES8311_CLK_MANAGER_REG02: 0x18
[ 5.453714] Enter into es8311_set_bias_level(), level = 1
[ 5.466163] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 5.466334] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 5.466519] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 5.466686] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 5.466848] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 5.467023] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 5.467184] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 5.467332] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 5.467525] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 5.467977] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 5.468170] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 5.468345] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 5.468526] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 5.468789] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 5.468989] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 5.469303] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 5.469486] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 5.469712] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 5.469870] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 5.470028] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 5.474273] Enter into es8311_set_dai_sysclk: freq=12288000
[ 5.474280] Enter into es8311_set_dai_fmt()
[ 5.476023] nvgpu: 17000000.gv11b tpc_pg_mask_store:843 [INFO] no value change, same mask already set
[ 5.478711] ES8311 in Slave mode
[ 5.479132] ES8311 in I2S Format
[ 5.504892] Enter into es8311_set_bias_level(), level = 1
[ 5.508800] Enter into es8311_set_bias_level(), level = 2
[ 5.510602] Enter into es8311_set_bias_level(), level = 3
[ 5.524978] num_ahub_links=135 num_codec_links=12
[ 5.660853] tegra-xusb 3610000.xhci: Firmware timestamp: 2019-07-24 05:47:34 UTC, Version: 60.06 release
[ 5.660914] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 5.660947] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 5.661816] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[ 5.661864] tegra-xusb 3610000.xhci: irq 466, io mem 0x03610000
[ 5.662054] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 5.662079] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.662090] usb usb1: Product: xHCI Host Controller
[ 5.662096] usb usb1: Manufacturer: Linux 4.9.201-tegra xhci-hcd
[ 5.662101] usb usb1: SerialNumber: 3610000.xhci
[ 5.662627] hub 1-0:1.0: USB hub found
[ 5.662674] hub 1-0:1.0: 4 ports detected
[ 5.663124] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 5.663138] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 5.663148] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 5.663356] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 5.663363] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.663369] usb usb2: Product: xHCI Host Controller
[ 5.663375] usb usb2: Manufacturer: Linux 4.9.201-tegra xhci-hcd
[ 5.663380] usb usb2: SerialNumber: 3610000.xhci
[ 5.663926] hub 2-0:1.0: USB hub found
[ 5.663972] hub 2-0:1.0: 4 ports detected
[ 5.673851] Wake76 for irq=199
[ 5.673857] Wake77 for irq=199
[ 5.673862] Wake78 for irq=199
[ 5.673866] Wake79 for irq=199
[ 5.673870] Wake80 for irq=199
[ 5.673874] Wake81 for irq=199
[ 5.673878] Wake82 for irq=199
[ 5.673948] tegra-xusb 3610000.xhci: Upgrade port 0 to USB3.0
[ 5.673963] tegra-xusb 3610000.xhci: Upgrade port 1 to USB3.0
[ 5.766505] usb usb2: usb_suspend_both: status 0
[ 5.830903] zram: Added device: zram0
[ 5.835353] zram: Added device: zram1
[ 5.837936] zram: Added device: zram2
[ 5.843342] zram: Added device: zram3
[ 5.846786] zram: Added device: zram4
[ 5.853993] zram: Added device: zram5
[ 5.916166] zram0: detected capacity change from 0 to 1382850560
[ 5.958911] Adding 1350436k swap on /dev/zram0. Priority:5 extents:1 across:1350436k SS
[ 5.980860] zram1: detected capacity change from 0 to 1382850560
[ 6.000339] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 6.019422] usb 1-2: New USB device found, idVendor=0424, idProduct=2744
[ 6.019433] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.019440] usb 1-2: Product: USB2744
[ 6.019447] usb 1-2: Manufacturer: Microchip Tech
[ 6.020572] hub 1-2:1.0: USB hub found
[ 6.020661] hub 1-2:1.0: 4 ports detected
[ 6.021912] Adding 1350436k swap on /dev/zram1. Priority:5 extents:1 across:1350436k SS
[ 6.027508] zram2: detected capacity change from 0 to 1382850560
[ 6.061391] Adding 1350436k swap on /dev/zram2. Priority:5 extents:1 across:1350436k SS
[ 6.073891] zram3: detected capacity change from 0 to 1382850560
[ 6.114188] Adding 1350436k swap on /dev/zram3. Priority:5 extents:1 across:1350436k SS
[ 6.119455] zram4: detected capacity change from 0 to 1382850560
[ 6.138024] usb 2-3: new SuperSpeed USB device number 2 using tegra-xusb
[ 6.148589] Adding 1350436k swap on /dev/zram4. Priority:5 extents:1 across:1350436k SS
[ 6.156173] zram5: detected capacity change from 0 to 1382850560
[ 6.158685] usb 2-3: New USB device found, idVendor=0424, idProduct=5744
[ 6.158697] usb 2-3: New USB device strings: Mfr=2, Product=3, SerialNumber=0
[ 6.158704] usb 2-3: Product: USB5744
[ 6.158710] usb 2-3: Manufacturer: Microchip Tech
[ 6.171406] hub 2-3:1.0: USB hub found
[ 6.171824] hub 2-3:1.0: 4 ports detected
[ 6.206675] Adding 1350436k swap on /dev/zram5. Priority:5 extents:1 across:1350436k SS
[ 7.002022] FAN rising trip_level:1 cur_temp:47700 trip_temps[2]:60000
[ 7.423262] usb 2-3.1: Device not responding to setup address.
[ 7.548079] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 7.548716] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 7.631304] usb 2-3.1: Device not responding to setup address.
[ 7.837737] usb 2-3.1: device not accepting address 3, error -71
[ 7.917773] usb 1-2.2: new full-speed USB device number 4 using tegra-xusb
[ 7.940400] usb 1-2.2: New USB device found, idVendor=10c4, idProduct=ea60
[ 7.940412] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 7.940419] usb 1-2.2: Product: CP2102N USB to UART Bridge Controller
[ 7.940424] usb 1-2.2: Manufacturer: Silicon Labs
[ 7.940432] usb 1-2.2: SerialNumber: 76e06e8cb735ec11bc475c5db659684c
[ 8.673750] usb 2-3: usb_suspend_both: status 0
[ 8.673992] usb usb2: usb_suspend_both: status 0
[ 9.032992] usbcore: registered new interface driver cp210x
[ 9.033053] usbserial: USB Serial support registered for cp210x
[ 9.033139] cp210x 1-2.2:1.0: cp210x converter detected
[ 9.046070] usb 1-2.2: cp210x converter now attached to ttyUSB0
[ 9.614741] Enter into es8311_set_dai_fmt()
[ 9.616253] ES8311 in Slave mode
[ 9.616638] ES8311 in I2S Format
[ 9.618671] Enter into es8311_set_dai_fmt()
[ 9.620168] ES8311 in Slave mode
[ 9.620556] ES8311 in I2S Format
[ 10.092536] eqos 2490000.ether_qos eth0: Link is Down
[ 13.315542] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 14.363493] usb_wwan: loading out-of-tree module taints kernel.
[ 14.381995] usbcore: registered new interface driver option
[ 14.382060] usbserial: USB Serial support registered for GSM modem (1-port)
[ 14.396100] usbcore: registered new interface driver qcserial
[ 14.396159] usbserial: USB Serial support registered for Qualcomm USB modem
[ 14.430154] [lch][encx24j600_init:1258] --- DEBUG encx24j600 driver
[ 14.430233] [lch][encx24j600_spi_probe:1109] --- start
[ 14.430347] [lch][encx24j600_spi_probe:1139] --- Reset device and check if it is connected
[ 14.430353] [lch][encx24j600_soft_reset:477] --- Write and verify a test value to EUDAST
[ 14.445650] [lch][encx24j600_soft_reset:494] --- Wait for CLKRDY to become set
[ 14.451317] [lch][encx24j600_spi_probe:1161] --- Initialize the device HW to the consistent state
[ 14.478676] [lch][encx24j600_spi_probe:1200] --- read spi success!
[ 14.478696] encx24j600 spi0.0 eth1: Silicon rev ID: 0x01
[ 14.478705] encx24j600 spi0.0 eth1: MAC address 80:1f:12:2a:c4:07
[ 14.478710] [lch][encx24j600_spi_probe:1207] --- over!
[ 14.776193] [lch][encx24j600_open:865] --- start
[ 14.776202] [lch][encx24j600_open:879] --- schedule_work
[ 14.781602] [lch][encx24j600_open:882] --- work queue test
[ 14.785794] [lch][encx24j600_open:884] --- encx24j600_hw_init start!
[ 14.805872] [lch][encx24j600_open:886] --- encx24j600_hw_enable start!
[ 14.805881] encx24j600: CHECK
[ 14.806401] encx24j600 ECON1: 0000
[ 14.810198] encx24j600 ECON2: CB00
[ 14.810208] encx24j600 ERXFCON: 0049
[ 14.810389] encx24j600 ESTAT: 5A00
[ 14.810540] encx24j600 EIR: 0700
[ 14.810550] encx24j600 EIDLED: CB21
[ 14.810556] encx24j600 MACON1: 0009
[ 14.810560] encx24j600 MACON2: 40B2
[ 14.810565] encx24j600 MAIPG: 0C12
[ 14.810804] encx24j600 MACLCON: 370F
[ 14.811105] encx24j600 MABBIPG: 0012
[ 14.811114] encx24j600 PHCON1: 1200
[ 14.814927] encx24j600 PHCON2: 0002
[ 14.814936] encx24j600 PHANA: 05E1
[ 14.819184] encx24j600 PHANLPA: 0001
[ 14.824836] encx24j600 PHANE: 0000
[ 14.827024] encx24j600 PHSTAT1: 7809
[ 14.830865] encx24j600 PHSTAT2: 0000
[ 14.846601] encx24j600 PHSTAT3: 0040
[ 14.856826] [lch][encx24j600_open:891] --- netif_start_queue start!
[ 14.859047] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 16.239318] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[ 17.078405] tegradc 15200000.nvdisplay: blank - powerdown
[ 17.078420] tegradc 15210000.nvdisplay: blank - powerdown
[ 18.062889] fuse init (API version 7.26)
[ 20.650384] pll_a_out0 = 45158400 Hz, aud_mclk = 11289600 Hz, sample rate = 44100 Hz
[ 20.650427] tegra_machine_dai_init===========8311=======es8311-playback=========== 332
[ 20.650438] Enter into es8311_set_dai_sysclk: freq=12288000
[ 20.898292] pll_a_out0 = 45158400 Hz, aud_mclk = 11289600 Hz, sample rate = 44100 Hz
[ 20.898336] tegra_machine_dai_init===========8311=======es8311-playback=========== 332
[ 20.898343] Enter into es8311_set_dai_sysclk: freq=12288000
[ 21.096334] pll_a_out0 = 45158400 Hz, aud_mclk = 11289600 Hz, sample rate = 44100 Hz
[ 21.096378] tegra_machine_dai_init===========8311=======es8311-playback=========== 332
[ 21.096386] Enter into es8311_set_dai_sysclk: freq=12288000
[ 21.097909] rtd == NULL
[ 21.098400] ES8311_CLK_MANAGER_REG02: 0x18
[ 21.103769] substream->stream =0
[ 21.104610] Enter into es8311_mute(), mute = 0
[ 21.317322] pll_a_out0 = 45158400 Hz, aud_mclk = 11289600 Hz, sample rate = 44100 Hz
[ 21.317365] tegra_machine_dai_init===========8311=======es8311-playback=========== 332
[ 21.317372] Enter into es8311_set_dai_sysclk: freq=12288000
[ 21.319454] pll_a_out0 = 45158400 Hz, aud_mclk = 11289600 Hz, sample rate = 44100 Hz
[ 21.319493] tegra_machine_dai_init===========8311=======es8311-playback=========== 332
[ 21.319499] Enter into es8311_set_dai_sysclk: freq=12288000
[ 21.321182] Enter into es8311_mute(), mute = 1
[ 21.327463] pll_a_out0 = 45158400 Hz, aud_mclk = 11289600 Hz, sample rate = 44100 Hz
[ 21.327505] tegra_machine_dai_init===========8311=======es8311-playback=========== 332
[ 21.327512] Enter into es8311_set_dai_sysclk: freq=12288000
[ 21.328864] rtd == NULL
[ 21.329358] ES8311_CLK_MANAGER_REG02: 0x18
[ 21.336271] substream->stream =0
[ 21.337115] Enter into es8311_mute(), mute = 0
[ 21.454090] usb 2-3.1: new SuperSpeed USB device number 5 using tegra-xusb
[ 21.475173] usb 2-3.1: New USB device found, idVendor=2c7c, idProduct=0900
[ 21.475183] usb 2-3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 21.475189] usb 2-3.1: Product: RM500U-CN
[ 21.475194] usb 2-3.1: Manufacturer: Quectel
[ 21.475200] usb 2-3.1: SerialNumber: 0123456789ABCDEF
[ 21.481028] usb 2-3.1: Enable of device-initiated U1 failed.
[ 21.482315] usb 2-3.1: Enable of device-initiated U2 failed.
[ 21.502556] cdc_ncm 2-3.1:1.0: MAC-Address: 86:a5:5e:43:a0:95
[ 21.503144] cdc_ncm 2-3.1:1.0 sim-usb0: register 'cdc_ncm' at usb-3610000.xhci-3.1, CDC NCM, 86:a5:5e:43:a0:95
[ 21.503959] usb 2-3.1: Enable of device-initiated U1 failed.
[ 21.505348] usb 2-3.1: Enable of device-initiated U2 failed.
[ 21.506561] option 2-3.1:1.2: GSM modem (1-port) converter detected
[ 21.506842] usb 2-3.1: GSM modem (1-port) converter now attached to ttyUSB1
[ 21.507057] option 2-3.1:1.3: GSM modem (1-port) converter detected
[ 21.507335] usb 2-3.1: GSM modem (1-port) converter now attached to ttyUSB2
[ 21.507552] option 2-3.1:1.4: GSM modem (1-port) converter detected
[ 21.507788] usb 2-3.1: GSM modem (1-port) converter now attached to ttyUSB3
[ 21.508000] option 2-3.1:1.5: GSM modem (1-port) converter detected
[ 21.508251] usb 2-3.1: GSM modem (1-port) converter now attached to ttyUSB4
[ 21.508454] option 2-3.1:1.6: GSM modem (1-port) converter detected
[ 21.508699] usb 2-3.1: GSM modem (1-port) converter now attached to ttyUSB5
[ 21.551993] pll_a_out0 = 45158400 Hz, aud_mclk = 11289600 Hz, sample rate = 44100 Hz
[ 21.552035] tegra_machine_dai_init===========8311=======es8311-playback=========== 332
[ 21.552042] Enter into es8311_set_dai_sysclk: freq=12288000
[ 21.553931] pll_a_out0 = 45158400 Hz, aud_mclk = 11289600 Hz, sample rate = 44100 Hz
[ 21.553964] tegra_machine_dai_init===========8311=======es8311-playback=========== 332
[ 21.553971] Enter into es8311_set_dai_sysclk: freq=12288000
[ 21.556470] Enter into es8311_mute(), mute = 1
[ 21.584639] pll_a_out0 = 45158400 Hz, aud_mclk = 11289600 Hz, sample rate = 44100 Hz
[ 21.584681] tegra_machine_dai_init===========8311=======es8311-playback=========== 332
[ 21.584689] Enter into es8311_set_dai_sysclk: freq=12288000
[ 21.586290] rtd == NULL
[ 21.586782] ES8311_CLK_MANAGER_REG02: 0x18
[ 21.592216] substream->stream =0
[ 21.593065] Enter into es8311_mute(), mute = 0
[ 21.820083] IPv6: ADDRCONF(NETDEV_UP): sim-usb0: link is not ready
[ 21.821340] IPv6: ADDRCONF(NETDEV_UP): sim-usb0: link is not ready
[ 21.833283] cdc_ncm 2-3.1:1.0 sim-usb0: 851 mbit/s downlink 851 mbit/s uplink
[ 21.865286] cdc_ncm 2-3.1:1.0 sim-usb0: 851 mbit/s downlink 851 mbit/s uplink
[ 21.897301] cdc_ncm 2-3.1:1.0 sim-usb0: network connection: disconnected
[ 21.965380] pll_a_out0 = 45158400 Hz, aud_mclk = 11289600 Hz, sample rate = 44100 Hz
[ 21.965427] tegra_machine_dai_init===========8311=======es8311-playback=========== 332
[ 21.965435] Enter into es8311_set_dai_sysclk: freq=12288000
[ 22.470779] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 22.470798] Bluetooth: BNEP socket layer initialized
[ 27.342235] Enter into es8311_mute(), mute = 1
[ 32.561148] eqos 2490000.ether_qos eth0: Link is Down
[ 34.137884] vdd-sdmmc1-sw: disabling
[ 34.137903] vdd-sdmmc3-sw: disabling
[ 34.137908] vdd-1v8-sd: disabling
[ 34.137913] vdd-1v8-cvb: disabling
[ 34.137918] vdd-epb-1v0: disabling
[ 34.137922] avdd-cam-2v8: disabling
[ 34.137927] vdd-fan: disabling
[ 34.137931] vdd_sys_en: disabling
[ 35.145301] cdc_ncm 2-3.1:1.0 sim-usb0: 851 mbit/s downlink 851 mbit/s uplink
[ 35.177301] cdc_ncm 2-3.1:1.0 sim-usb0: network connection: connected
[ 35.177403] IPv6: ADDRCONF(NETDEV_CHANGE): sim-usb0: link becomes ready
[ 35.574531] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 40.500786] eqos 2490000.ether_qos eth0: Link is Down
[ 43.431728] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 58.111623] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 58.125034] Netfilter messages via NETLINK v0.30.
[ 58.127952] ctnetlink v0.93: registering with nfnetlink.
[ 58.136410] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready
[ 58.137935] IPv6: ADDRCONF(NETDEV_UP): br-fa7bf4bc76b7: link is not ready
[ 58.467130] docker0: port 1(vethde52c22) entered blocking state
[ 58.467140] docker0: port 1(vethde52c22) entered disabled state
[ 58.467276] device vethde52c22 entered promiscuous mode
[ 58.467452] IPv6: ADDRCONF(NETDEV_UP): vethde52c22: link is not ready
[ 58.467458] docker0: port 1(vethde52c22) entered blocking state
[ 58.467463] docker0: port 1(vethde52c22) entered forwarding state
[ 58.467663] docker0: port 1(vethde52c22) entered disabled state
[ 58.471608] br-fa7bf4bc76b7: port 1(veth4d1ba22) entered blocking state
[ 58.471618] br-fa7bf4bc76b7: port 1(veth4d1ba22) entered disabled state
[ 58.471773] device veth4d1ba22 entered promiscuous mode
[ 58.471960] IPv6: ADDRCONF(NETDEV_UP): veth4d1ba22: link is not ready
[ 58.471966] br-fa7bf4bc76b7: port 1(veth4d1ba22) entered blocking state
[ 58.471972] br-fa7bf4bc76b7: port 1(veth4d1ba22) entered forwarding state
[ 58.472083] IPv6: ADDRCONF(NETDEV_CHANGE): br-fa7bf4bc76b7: link becomes ready
[ 58.472337] br-fa7bf4bc76b7: port 1(veth4d1ba22) entered disabled state
[ 59.683315] eth0: renamed from veth80dd522
[ 59.706988] IPv6: ADDRCONF(NETDEV_CHANGE): vethde52c22: link becomes ready
[ 59.707101] docker0: port 1(vethde52c22) entered blocking state
[ 59.707107] docker0: port 1(vethde52c22) entered forwarding state
[ 59.708396] IPv6: ADDRCONF(NETDEV_CHANGE): docker0: link becomes ready
[ 60.115673] eth0: renamed from vethe2c12b6
[ 60.138029] IPv6: ADDRCONF(NETDEV_CHANGE): veth4d1ba22: link becomes ready
[ 60.138220] br-fa7bf4bc76b7: port 1(veth4d1ba22) entered blocking state
[ 60.138226] br-fa7bf4bc76b7: port 1(veth4d1ba22) entered forwarding state
[ 63.042668] NOHZ: local_softirq_pending 08
[ 64.038463] NOHZ: local_softirq_pending 08
[ 65.035993] NOHZ: local_softirq_pending 08
[ 66.038560] NOHZ: local_softirq_pending 08
[ 68.030620] NOHZ: local_softirq_pending 08
[ 69.006543] nvmap_alloc_handle: PID 11127: yrvideo: WARNING: All NvMap Allocations must have a tag to identify the subsystem allocating memory.Please pass the tag to the API call NvRmMemHanldeAllocAttr() or relevant.
[ 70.058687] NOHZ: local_softirq_pending 08
[ 73.262471] NOHZ: local_softirq_pending 08
[ 75.270365] NOHZ: local_softirq_pending 08
[ 76.266711] NOHZ: local_softirq_pending 08
[ 78.262424] NOHZ: local_softirq_pending 08
[ 120.770098] pll_a_out0 = 45158400 Hz, aud_mclk = 11289600 Hz, sample rate = 44100 Hz
[ 120.770143] tegra_machine_dai_init===========8311=======es8311-playback=========== 332
[ 120.770150] Enter into es8311_set_dai_sysclk: freq=12288000
[ 122.053016] pll_a_out0 = 45158400 Hz, aud_mclk = 11289600 Hz, sample rate = 44100 Hz
[ 122.053101] tegra_machine_dai_init===========8311=======es8311-playback=========== 332
[ 122.053109] Enter into es8311_set_dai_sysclk: freq=12288000
[ 122.750208] pll_a_out0 = 45158400 Hz, aud_mclk = 11289600 Hz, sample rate = 44100 Hz
[ 122.750251] tegra_machine_dai_init===========8311=======es8311-playback=========== 332
[ 122.750258] Enter into es8311_set_dai_sysclk: freq=12288000
[ 122.751624] rtd == NULL
[ 122.752134] ES8311_CLK_MANAGER_REG02: 0x18
[ 122.757810] substream->stream =0
[ 122.758664] Enter into es8311_mute(), mute = 0
[ 123.598850] pll_a_out0 = 45158400 Hz, aud_mclk = 11289600 Hz, sample rate = 44100 Hz
[ 123.598894] tegra_machine_dai_init===========8311=======es8311-playback=========== 332
[ 123.598900] Enter into es8311_set_dai_sysclk: freq=12288000
[ 123.615361] pll_a_out0 = 45158400 Hz, aud_mclk = 11289600 Hz, sample rate = 44100 Hz
[ 123.615404] tegra_machine_dai_init===========8311=======es8311-playback=========== 332
[ 123.615411] Enter into es8311_set_dai_sysclk: freq=12288000
[ 123.623664] Enter into es8311_mute(), mute = 1
[ 123.643915] pll_a_out0 = 45158400 Hz, aud_mclk = 11289600 Hz, sample rate = 44100 Hz
[ 123.643958] tegra_machine_dai_init===========8311=======es8311-playback=========== 332
[ 123.643969] Enter into es8311_set_dai_sysclk: freq=12288000
[ 123.647704] rtd == NULL
[ 123.648514] ES8311_CLK_MANAGER_REG02: 0x18
[ 123.659121] substream->stream =0
[ 123.660047] Enter into es8311_mute(), mute = 0
[ 124.567681] pll_a_out0 = 45158400 Hz, aud_mclk = 11289600 Hz, sample rate = 44100 Hz
[ 124.567797] tegra_machine_dai_init===========8311=======es8311-playback=========== 332
[ 124.567806] Enter into es8311_set_dai_sysclk: freq=12288000
[ 124.578663] pll_a_out0 = 45158400 Hz, aud_mclk = 11289600 Hz, sample rate = 44100 Hz
[ 124.578704] tegra_machine_dai_init===========8311=======es8311-playback=========== 332
[ 124.578711] Enter into es8311_set_dai_sysclk: freq=12288000
[ 124.594035] Enter into es8311_mute(), mute = 1
[ 124.747515] pll_a_out0 = 45158400 Hz, aud_mclk = 11289600 Hz, sample rate = 44100 Hz
[ 124.747558] tegra_machine_dai_init===========8311=======es8311-playback=========== 332
[ 124.747565] Enter into es8311_set_dai_sysclk: freq=12288000
[ 124.759698] rtd == NULL
[ 124.760212] ES8311_CLK_MANAGER_REG02: 0x18
[ 124.771885] substream->stream =0
[ 124.772755] Enter into es8311_mute(), mute = 0
[ 125.328455] pll_a_out0 = 45158400 Hz, aud_mclk = 11289600 Hz, sample rate = 44100 Hz
[ 125.328498] tegra_machine_dai_init===========8311=======es8311-playback=========== 332
[ 125.328505] Enter into es8311_set_dai_sysclk: freq=12288000
[ 128.007488] Enter into es8311_mute(), mute = 1
[ 128.042388] pll_a_out0 = 49152000 Hz, aud_mclk = 12288000 Hz, sample rate = 48000 Hz
[ 128.042439] tegra_machine_dai_init===========8311=======es8311-playback=========== 332
[ 128.042446] Enter into es8311_set_dai_sysclk: freq=12288000
[ 128.045483] rtd == NULL
[ 128.048047] ES8311_CLK_MANAGER_REG02: 0x18
[ 128.076174] substream->stream =0
[ 128.078820] Enter into es8311_mute(), mute = 0
[ 135.441499] Enter into es8311_mute(), mute = 1
[ 146.999012] FAN rising trip_level:2 cur_temp:60200 trip_temps[3]:68000
[ 180.597685] FAN cooling trip_level:1 cur_temp:51850 trip_temps[2]:60000
[ 429.239132] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[ 537.878679] FAN rising trip_level:1 cur_temp:46100 trip_temps[2]:60000
[ 742.836274] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[ 852.582936] FAN rising trip_level:1 cur_temp:46250 trip_temps[2]:60000
[ 1050.796029] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[ 1158.309031] FAN rising trip_level:1 cur_temp:46100 trip_temps[2]:60000
[ 1380.092410] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[ 1488.761725] FAN rising trip_level:1 cur_temp:46050 trip_temps[2]:60000
[ 1687.023883] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[ 1796.789599] FAN rising trip_level:1 cur_temp:46250 trip_temps[2]:60000
[ 2059.969547] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[ 2167.485230] FAN rising trip_level:1 cur_temp:46100 trip_temps[2]:60000
[ 2538.201777] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[ 2645.722386] FAN rising trip_level:1 cur_temp:46250 trip_temps[2]:60000
[ 3206.867843] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[ 3314.393186] FAN rising trip_level:1 cur_temp:46100 trip_temps[2]:60000
[ 3924.815402] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[ 4034.578526] FAN rising trip_level:1 cur_temp:46050 trip_temps[2]:60000
[ 4576.676211] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[ 4685.315045] FAN rising trip_level:1 cur_temp:46100 trip_temps[2]:60000
[ 5162.395357] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[ 5271.017301] FAN rising trip_level:1 cur_temp:46250 trip_temps[2]:60000
[ 5835.455341] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[ 5942.971144] FAN rising trip_level:1 cur_temp:46100 trip_temps[2]:60000
[ 6317.040602] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[ 6426.798264] FAN rising trip_level:1 cur_temp:46100 trip_temps[2]:60000
[ 6933.031091] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[ 7042.781018] FAN rising trip_level:1 cur_temp:46100 trip_temps[2]:60000
[ 7550.103635] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[ 7658.738237] FAN rising trip_level:1 cur_temp:46100 trip_temps[2]:60000
[ 8372.151844] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[ 8480.788755] FAN rising trip_level:1 cur_temp:46050 trip_temps[2]:60000
[ 8879.497741] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[ 8988.138938] FAN rising trip_level:1 cur_temp:46050 trip_temps[2]:60000
[ 9286.049094] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[ 9395.806868] FAN rising trip_level:1 cur_temp:46250 trip_temps[2]:60000
[ 9765.399023] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[ 9874.036462] FAN rising trip_level:1 cur_temp:46100 trip_temps[2]:60000
[10381.388856] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[10490.022241] FAN rising trip_level:1 cur_temp:46100 trip_temps[2]:60000
[10889.852999] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[11000.730352] FAN rising trip_level:1 cur_temp:46250 trip_temps[2]:60000
[11630.253186] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[11737.781235] FAN rising trip_level:1 cur_temp:46100 trip_temps[2]:60000
[12240.687111] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[12347.090939] FAN rising trip_level:1 cur_temp:46100 trip_temps[2]:60000
[12736.861947] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[12844.384265] FAN rising trip_level:1 cur_temp:46100 trip_temps[2]:60000
[13346.127505] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[13453.641027] FAN rising trip_level:1 cur_temp:46250 trip_temps[2]:60000
[13823.227057] FAN cooling trip_level:0 cur_temp:37950 trip_temps[1]:46000
[13930.744631] FAN rising trip_level:1 cur_temp:46100 trip_temps[2]:60000
[14316.019009] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[14424.658427] FAN rising trip_level:1 cur_temp:46100 trip_temps[2]:60000
[14846.896708] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[14955.536745] FAN rising trip_level:1 cur_temp:46100 trip_temps[2]:60000
[15459.533504] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[15570.412700] FAN rising trip_level:1 cur_temp:46100 trip_temps[2]:60000
[15879.531729] FAN cooling trip_level:0 cur_temp:37950 trip_temps[1]:46000
[15988.171002] FAN rising trip_level:1 cur_temp:46100 trip_temps[2]:60000
[16386.890407] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[16496.650537] FAN rising trip_level:1 cur_temp:46100 trip_temps[2]:60000
[16959.210224] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[17068.970362] FAN rising trip_level:1 cur_temp:46100 trip_temps[2]:60000
[17468.821453] FAN cooling trip_level:0 cur_temp:37950 trip_temps[1]:46000
[17579.704946] FAN rising trip_level:1 cur_temp:46100 trip_temps[2]:60000
[17940.353848] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[18051.236132] FAN rising trip_level:1 cur_temp:46100 trip_temps[2]:60000
[18401.801473] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[18510.446623] FAN rising trip_level:1 cur_temp:46250 trip_temps[2]:60000
[19127.569676] FAN cooling trip_level:0 cur_temp:37750 trip_temps[1]:46000
[19237.330636] FAN rising trip_level:1 cur_temp:46250 trip_temps[2]:60000
[19823.041684] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[19933.915494] FAN rising trip_level:1 cur_temp:46250 trip_temps[2]:60000
[20273.261056] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[20381.897320] FAN rising trip_level:1 cur_temp:46250 trip_temps[2]:60000
[20699.969025] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[20808.610498] FAN rising trip_level:1 cur_temp:46050 trip_temps[2]:60000
[21483.954444] FAN cooling trip_level:0 cur_temp:37950 trip_temps[1]:46000
[21593.717689] FAN rising trip_level:1 cur_temp:46100 trip_temps[2]:60000
[37330.603328] Unable to handle kernel NULL pointer dereference at virtual address 00000004
[37330.603504] Mem abort info:
[37330.603558] ESR = 0x96000005
[37330.603616] Exception class = DABT (current EL), IL = 32 bits
[37330.603717] SET = 0, FnV = 0
[37330.603773] EA = 0, S1PTW = 0
[37330.603835] Data abort info:
[37330.603888] ISV = 0, ISS = 0x00000005
[37330.605123] CM = 0, WnR = 0
[37330.605190] user pgtable: 4k pages, 39-bit VAs, pgd = ffffffc333cc0000
[37330.605349] [0000000000000004] *pgd=0000000000000000, *pud=0000000000000000
[37330.605491] Internal error: Oops: 96000005 [#1] PREEMPT SMP
[37330.605596] Modules linked in: ipt_MASQUERADE nf_nat_masquerade_ipv4 iptable_mangle xt_nat xt_tcpudp veth iptable_filter iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack_netlink nfnetlink nf_conntrack bnep fuse encx24j600 encx24j600_regmap qcserial(O) option(O) usb_wwan(O) cp210x zram snd_soc_es8311 overlay spidev userspace_alert nvgpu bluedroid_pm ip_tables x_tables
[37330.606484] CPU: 0 PID: 29667 Comm: lscpu Tainted: G O 4.9.201-tegra #46
[37330.612400] Hardware name: NVIDIA Jetson Xavier NX Developer Kit (DT)
[37330.618789] task: ffffffc272002a00 task.stack: ffffffc26c69c000
[37330.624837] PC is at do_last+0x54/0xfd0
[37330.628672] LR is at path_openat+0x90/0x378
[37330.632871] pc : [<ffffff800826ced4>] lr : [<ffffff800826dee0>] pstate: 20400145
[37330.640219] sp : ffffffc26c69fbc0
[37330.642937] x29: ffffffc26c69fbc0 x28: ffffffc272002a00
[37330.648967] x27: ffffffc26c69fd48 x26: ffffffc352ab8f00
[37330.654130] x25: ffffffc26c69fe7c x24: 0000000000000000
[37330.659555] x23: 0000000000000041 x22: 0000000000000004
[37330.664807] x21: ffffffc349291d00 x20: ffffffc26c69fcfc
[37330.669969] x19: 0000000000020000 x18: 0000007f7de4ba70
[37330.675742] x17: 0000007f7dd6f1c8 x16: ffffff800825a4c0
[37330.681517] x15: 0000000000000000 x14: 0000000000000014
[37330.687206] x13: 736563697665642f x12: 6963702f7375622f
[37330.692639] x11: 0000007fe67df030 x10: d0a3b5b3b9a6b5b4
[37330.698329] x9 : 0000000000000000 x8 : ffffffc352ab8f00
[37330.704352] x7 : bd4c9ff19354077b x6 : ff8c9aa03bddea64
[37330.709867] x5 : 0000000000000007 x4 : ff00000000010003
[37330.714954] x3 : ffffffc26c69fcfc x2 : 0000000000000000
[37330.720541] x1 : 0000000000000000 x0 : 0000000000000041
[37330.727293] Process lscpu (pid: 29667, stack limit = 0xffffffc26c69c000)
[37330.733414] Call trace:
[37330.735783] [<ffffff800826ced4>] do_last+0x54/0xfd0
[37330.740327] [<ffffff800826dee0>] path_openat+0x90/0x378
[37330.745401] [<ffffff800826f450>] do_filp_open+0x70/0xe8
[37330.750217] [<ffffff800825a394>] do_sys_open+0x174/0x258
[37330.755550] [<ffffff800825a4fc>] SyS_openat+0x3c/0x50
[37330.760105] [<ffffff8008083900>] el0_svc_naked+0x34/0x38
[37330.765181] ---[ end trace 9a8041004be6edc4 ]---
[51564.775365] FAN cooling trip_level:0 cur_temp:37950 trip_temps[1]:46000
[51675.658270] FAN rising trip_level:1 cur_temp:46100 trip_temps[2]:60000
[52003.823720] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[52114.705215] FAN rising trip_level:1 cur_temp:46250 trip_temps[2]:60000
[52419.347266] FAN cooling trip_level:0 cur_temp:37950 trip_temps[1]:46000
[52530.227656] FAN rising trip_level:1 cur_temp:46250 trip_temps[2]:60000
[52804.628672] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[52915.509054] FAN rising trip_level:1 cur_temp:46250 trip_temps[2]:60000
[59624.180182] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[59735.057938] FAN rising trip_level:1 cur_temp:46100 trip_temps[2]:60000
[60019.543920] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[60129.299753] FAN rising trip_level:1 cur_temp:46100 trip_temps[2]:60000
[60455.218525] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[60566.097522] FAN rising trip_level:1 cur_temp:46250 trip_temps[2]:60000
[60875.214863] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[60983.853620] FAN rising trip_level:1 cur_temp:46100 trip_temps[2]:60000
[61285.130058] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[61394.888772] FAN rising trip_level:1 cur_temp:46100 trip_temps[2]:60000
[61649.135337] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[61757.781718] FAN rising trip_level:1 cur_temp:46250 trip_temps[2]:60000
[62083.715021] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[62194.598117] FAN rising trip_level:1 cur_temp:46250 trip_temps[2]:60000
[62448.842897] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[62557.484465] FAN rising trip_level:1 cur_temp:46050 trip_temps[2]:60000
[62803.887377] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[62913.648103] FAN rising trip_level:1 cur_temp:46100 trip_temps[2]:60000
[63125.329234] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[63233.969922] FAN rising trip_level:1 cur_temp:46250 trip_temps[2]:60000
[63528.535033] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[63638.289947] FAN rising trip_level:1 cur_temp:46100 trip_temps[2]:60000
[63871.245718] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[63978.764371] FAN rising trip_level:1 cur_temp:46100 trip_temps[2]:60000
[64235.241484] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[64345.000622] FAN rising trip_level:1 cur_temp:46100 trip_temps[2]:60000
