Thanks for your great help, it works! But the patch has a little problem, it should be:
- 0x82000000 0 0x40100000 0x0 0x40100000 0 0x07F00000 /* non-prefetchable memory (127 MiB) */
- 0xc2000000 0 0x48000000 0x0 0x48000000 0 0x38000000>; /* prefetchable memory (896 MiB) */
+ 0x82000000 0 0x40100000 0x0 0x40100000 0 0x18000000 /* non-prefetchable memory (384 MiB) */
+ 0xc2000000 0 0x58100000 0x0 <b>0x58100000 </b>0 0x27f00000>; /* prefetchable memory (639 MiB) */
and the lspci -vvv:
nvidia@nvidia-desktop:~$ sudo lspci -vvv
[sudo] password for nvidia:
00:01.0 PCI bridge: NVIDIA Corporation Device 10e5 (rev a1) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 381
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000f000-00000fff
Memory behind bridge: 44000000-4fffffff
Prefetchable memory behind bridge: 00000000fff00000-00000000000fffff
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Capabilities: [40] Subsystem: NVIDIA Corporation Device 0000
Capabilities: [48] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [50] MSI: Enable- Count=1/2 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [60] HyperTransport: MSI Mapping Enable- Fixed-
Mapping Address Base: 00000000fee00000
Capabilities: [80] Express (v2) Root Port (Slot+), MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0
ExtTag+ RBE+
DevCtl: Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+
RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr+ UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
LnkCap: Port #0, Speed 5GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <512ns, L1 <4us
ClockPM- Surprise- LLActRep+ BwNot+ ASPMOptComp-
LnkCtl: ASPM L0s L1 Enabled; RCB 64 bytes Disabled- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 5GT/s, Width x2, TrErr- Train- SlotClk+ DLActive+ BWMgmt+ ABWMgmt-
SltCap: AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise-
Slot #0, PowerLimit 0.000W; Interlock- NoCompl-
SltCtl: Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
Control: AttnInd Off, PwrInd On, Power- Interlock-
SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet+ Interlock-
Changed: MRL- PresDet+ LinkState+
RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible-
RootCap: CRSVisible-
RootSta: PME ReqID 0000, PMEStatus- PMEPending-
DevCap2: Completion Timeout: Range AB, TimeoutDis+, LTR+, OBFF Not Supported ARIFwd-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR+, OBFF Disabled ARIFwd-
LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [100 v1] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
Kernel driver in use: pcieport
01:00.0 VGA compatible controller: Silicon Motion, Inc. Device 0768 (rev 03) (prog-if 00 [VGA controller])
Subsystem: Silicon Motion, Inc. Device 0768
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Region 0: Memory at 48000000 (32-bit, prefetchable) [disabled]
Region 1: Memory at 44000000 (32-bit, non-prefetchable) [disabled]
[virtual] Expansion ROM at 44200000 [disabled]
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI- D1+ D2- AuxCurrent=375mA PME(D0+,D1+,D2-,D3hot+,D3cold+)
Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [70] Express (v2) Legacy Endpoint, MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop-
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
LnkCap: Port #0, Speed 5GT/s, Width x2, ASPM L0s L1, Exit Latency L0s <512ns, L1 <64us
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
LnkSta: Speed 5GT/s, Width x2, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Not Supported, TimeoutDis+, LTR-, OBFF Not Supported
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
Capabilities: [100 v2] Advanced Error Reporting
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
Capabilities: [148 v1] #19
dmesg:
[code]
nvidia@nvidia-desktop:~$ dmesg
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-2988) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Wed Mar 13 00:30:11 PDT 2019
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 16416,
[ 0.000000] OF: fdt: - 80000000 , 70000000
[ 0.000000] OF: fdt: - f0200000 , 185600000
[ 0.000000] OF: fdt: - 275e00000 , 200000
[ 0.000000] OF: fdt: - 276600000 , 200000
[ 0.000000] OF: fdt: - 277000000 , 200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000003100000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] Found tegra_fbmem2: 00800000@9607b000
[ 0.000000] Found lut_mem2: 00002008@96078000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb2_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] On node 0 totalpages: 2053117
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 521725 pages, LIFO batch:31
[ 0.000000] Normal zone: 24008 pages used for memmap
[ 0.000000] Normal zone: 1531392 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 23 pages/cpu @ffffffc1f6776000 s53400 r8192 d32616 u94208
[ 0.000000] pcpu-alloc: s53400 r8192 d32616 u94208 alloc=23*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2020917
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt tegra_fbmem2=0x800000@0x9607b000 lut_mem2=0x2008@0x96078000 usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.983055.1 bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29492(90%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7966544K/8212468K available (15166K kernel code, 2914K rwdata, 6616K rodata, 8512K init, 605K bss, 180388K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f50000 ( 15168 KB)
[ 0.000000] .rodata : 0xffffff8008f50000 - 0xffffff80095d0000 ( 6656 KB)
[ 0.000000] .init : 0xffffff80095d0000 - 0xffffff8009e20000 ( 8512 KB)
[ 0.000000] .data : 0xffffff8009e20000 - 0xffffff800a0f8808 ( 2915 KB)
[ 0.000000] .bss : 0xffffff800a0f8808 - 0xffffff800a18fe3c ( 606 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf07dc8000 ( 125 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc1f7200000 ( 8050 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009973] Console: colour dummy device 80x25
[ 0.014634] console [tty0] enabled
[ 0.018190] bootconsole [uart8250] disabled
[ 0.022564] kmemleak: Kernel memory leak detector disabled
[ 0.022580] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.022594] pid_max: default: 32768 minimum: 301
[ 0.022908] Security Framework initialized
[ 0.023067] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.023077] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.023692] ftrace: allocating 46802 entries in 183 pages
[ 0.147086] sched-energy: Sched-energy-costs installed from DT
[ 0.147106] ASID allocator initialised with 65536 entries
[ 0.184103] tegra-id: chipid=21817.
[ 0.184118] tegra-id: opt_subrevision=1.
[ 0.184140] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[ 0.184153] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.184170] DTB Build time: Jun 4 2019 00:34:41
[ 0.229902] CPU1: Booted secondary processor [4e0f0030]
[ 0.261560] CPU2: Booted secondary processor [4e0f0030]
[ 0.293441] CPU3: Booted secondary processor [411fd073]
[ 0.325420] CPU4: Booted secondary processor [411fd073]
[ 0.357413] CPU5: Booted secondary processor [411fd073]
[ 0.357467] Brought up 6 CPUs
[ 0.357510] SMP: Total of 6 processors activated.
[ 0.357521] CPU features: detected feature: 32-bit EL0 Support
[ 0.358272] CPU: All CPU(s) started at EL2
[ 0.358325] alternatives: patching kernel code
[ 0.367573] devtmpfs: initialized
[ 0.406159] Initilizing CustomIPI irq domain
[ 0.406402] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.406428] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.407228] pinctrl core: initialized pinctrl subsystem
[ 0.407437] OS set in device tree is not L4T.
[ 0.407594] regulator-dummy: no parameters
[ 0.407745] Initializing plugin-manager
[ 0.407811] Plugin module not found
[ 0.407855] Plugin-manager status disabled
[ 0.409695] NET: Registered protocol family 16
[ 0.410395] pstore: using zlib compression
[ 0.410776] console [pstore-1] enabled
[ 0.410788] pstore: Registered ramoops as persistent store backend
[ 0.410800] ramoops: attached 0x200000@0x275880000, ecc: 0/0
[ 0.429039] cpuidle: using governor menu
[ 0.430428] bpmp: waiting for handshake
[ 0.430445] bpmp: handshake completed
[ 0.430467] bpmp: synchronizing channels
[ 0.430482] bpmp: channels synchronized
[ 0.430493] bpmp: mail init ok
[ 0.432521] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.432540] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.432554] arm-smmu 12000000.iommu: stage 1 translation
[ 0.432566] arm-smmu 12000000.iommu: stage 2 translation
[ 0.432578] arm-smmu 12000000.iommu: nested translation
[ 0.432592] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.432611] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.432629] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.432643] arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.432656] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.434827] vdso: 2 pages (1 code @ ffffff8008f57000, 1 data @ ffffff8009e24000)
[ 0.434857] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.437222] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.439039] Registering BPMP clocks…
[ 0.439141] tegra_bpmp_clk_init: clock init ok (636 clks)
[ 0.439865] tegra_bpmp_of_clk_init: EMC proxy not found.
[ 0.441370] tegra_powergate_init: DONE
[ 0.441391] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.441418] DTB Build time: Jun 4 2019 00:34:41
[ 0.443401] Tegra reboot handler registered.
[ 0.444918] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.444995] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.445046] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[ 0.445060] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L1
[ 0.445071] tegra-pmc: ### PMC reset status reg: 0x2d
[ 0.445238] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.445264] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.445604] iommu: Adding device 3460000.sdhci to group 0
[ 0.446291] iommu: Adding device 3400000.sdhci to group 1
[ 0.447362] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.447388] arm-smmu: forcing sodev map for 3507000.ahci-sata
[ 0.447835] iommu: Adding device 3160000.i2c to group 3
[ 0.448280] iommu: Adding device c240000.i2c to group 4
[ 0.448636] iommu: Adding device 3180000.i2c to group 5
[ 0.448980] iommu: Adding device 3190000.i2c to group 6
[ 0.449452] iommu: Adding device 31b0000.i2c to group 7
[ 0.449797] iommu: Adding device 31c0000.i2c to group 8
[ 0.450138] iommu: Adding device c250000.i2c to group 9
[ 0.450485] iommu: Adding device 31e0000.i2c to group 10
[ 0.451995] iommu: Adding device 3210000.spi to group 11
[ 0.452349] iommu: Adding device c260000.spi to group 12
[ 0.452691] iommu: Adding device 3240000.spi to group 13
[ 0.453430] iommu: Adding device 3100000.serial to group 14
[ 0.453791] iommu: Adding device 3110000.serial to group 15
[ 0.454132] iommu: Adding device c280000.serial to group 16
[ 0.454474] iommu: Adding device 3130000.serial to group 17
[ 0.455821] iommu: Adding device 2490000.ether_qos to group 18
[ 0.455844] arm-smmu: forcing sodev map for 2490000.ether_qos
[ 0.456448] iommu: Adding device b000000.rtcpu to group 19
[ 0.458697] iommu: Adding device 13e10000.host1x to group 20
[ 0.459018] iommu: Adding device 13e10000.host1x:ctx0 to group 21
[ 0.459328] iommu: Adding device 13e10000.host1x:ctx1 to group 22
[ 0.459653] iommu: Adding device 13e10000.host1x:ctx2 to group 23
[ 0.459960] iommu: Adding device 13e10000.host1x:ctx3 to group 24
[ 0.460269] iommu: Adding device 13e10000.host1x:ctx4 to group 25
[ 0.460584] iommu: Adding device 13e10000.host1x:ctx5 to group 26
[ 0.460905] iommu: Adding device 13e10000.host1x:ctx6 to group 27
[ 0.461258] iommu: Adding device 13e10000.host1x:ctx7 to group 28
[ 0.461732] iommu: Adding device 150c0000.nvcsi to group 29
[ 0.462392] iommu: Adding device 15700000.vi to group 30
[ 0.462754] iommu: Adding device 15600000.isp to group 31
[ 0.463226] iommu: Adding device 15210000.nvdisplay to group 32
[ 0.463346] platform 15210000.nvdisplay: OF IOVA linear map 0x9607b000 size (0x800000)
[ 0.463394] platform 15210000.nvdisplay: OF IOVA linear map 0x96078000 size (0x2008)
[ 0.463914] iommu: Adding device 15340000.vic to group 33
[ 0.464141] iommu: Adding device 154c0000.nvenc to group 34
[ 0.464368] iommu: Adding device 15480000.nvdec to group 35
[ 0.464721] iommu: Adding device 15380000.nvjpg to group 36
[ 0.464960] iommu: Adding device 15500000.tsec to group 37
[ 0.465210] iommu: Adding device 15100000.tsecb to group 38
[ 0.465891] iommu: Adding device 15810000.se to group 39
[ 0.466121] iommu: Adding device 15820000.se to group 40
[ 0.466346] iommu: Adding device 15830000.se to group 41
[ 0.466574] iommu: Adding device 15840000.se to group 42
[ 0.467455] iommu: Adding device smmu_test to group 43
[ 0.468067] mc: mapped MMIO address: 0xffffff800a680000 -> 0x2c10000
[ 0.468092] mc: mapped MMIO address: 0xffffff800a6a0000 -> 0x2c20000
[ 0.468113] mc: mapped MMIO address: 0xffffff800a6c0000 -> 0x2c30000
[ 0.468134] mc: mapped MMIO address: 0xffffff800a6e0000 -> 0x2c40000
[ 0.468154] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2c50000
[ 0.468171] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.468193] mc-err: mcerr ops are set to t18x
[ 0.468348] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[ 0.469471] iommu: Adding device 3530000.xhci to group 44
[ 0.469494] arm-smmu: forcing sodev map for 3530000.xhci
[ 0.469937] iommu: Adding device 3550000.xudc to group 45
[ 0.469960] arm-smmu: forcing sodev map for 3550000.xudc
[ 0.470670] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.470690] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.471263] iommu: Adding device 17000000.gp10b to group 46
[ 0.472306] tegra-reset 5000000.clock: registered 193 resets.
[ 0.474536] iommu: Adding device d000000.bpmp to group 47
[ 0.474756] bpmp: ping status is 0
[ 0.474859] bpmp d000000.bpmp: firmware tag is 69fa4e41a01fc02a4db1adf71922a54c
[ 0.477311] bpmp d000000.bpmp: probe ok
[ 0.480446] iommu: Adding device 2600000.dma to group 48
[ 0.481730] GPIO line 461 (camera-control-output-low) hogged as output/low
[ 0.481769] GPIO line 456 (camera-control-output-low) hogged as output/low
[ 0.481801] GPIO line 457 (camera-control-output-low) hogged as output/low
[ 0.481832] GPIO line 426 (camera-control-output-low) hogged as output/low
[ 0.481866] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.481896] GPIO line 445 (sdmmc-wake-support-input) hogged as input
[ 0.481928] GPIO line 446 (sdmmc-wake-support-output) hogged as output/low
[ 0.482132] gpiochip_setup_dev: registered GPIOs 320 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.485835] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.486027] gpiochip_setup_dev: registered GPIOs 256 to 319 on device: gpiochip1 (tegra-gpio-aon)
[ 0.487618] iommu: Adding device 10003000.pcie-controller to group 49
[ 0.487645] arm-smmu: forcing sodev map for 10003000.pcie-controller
[ 0.487970] iommu: Adding device sound to group 50
[ 0.488343] iommu: Adding device 3510000.hda to group 51
[ 0.495917] iommu: Adding device c1a0000.aon to group 52
[ 0.496365] vdd-ac-bat: 5000 mV
[ 0.498088] vdd-1v8-ap: 1800 mV
[ 0.517567] random: fast init done
[ 0.525554] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.528358] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.528556] SCSI subsystem initialized
[ 0.528685] libata version 3.00 loaded.
[ 0.528842] usbcore: registered new interface driver usbfs
[ 0.528897] usbcore: registered new interface driver hub
[ 0.528964] usbcore: registered new device driver usb
[ 0.531538] GPIO line 241 (touch-rails) hogged as output/high
[ 0.531765] GPIO line 242 (touch-rails) hogged as output/high
[ 0.531964] gpiochip_setup_dev: registered GPIOs 240 to 255 on device: gpiochip2 (tca9539)
[ 0.532796] GPIO line 228 (lcd-bias-rails) hogged as output/high
[ 0.532966] gpiochip_setup_dev: registered GPIOs 224 to 239 on device: gpiochip3 (tca9539)
[ 0.542010] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.545579] vddio-ddr: at 1125 mV
[ 0.549432] avdd_dsi_csi: 1200 mV
[ 0.553434] vdd-1v8: 1800 mV
[ 0.557432] vdd-3v3-sys: 3300 mV
[ 0.558566] spmic-ldo0: at 1800 mV
[ 0.559275] spmic-ldo1: at 800 mV
[ 0.561432] vddio-3v3: 3300 mV
[ 0.562036] vddio-sdmmc1: 1800 <–> 3300 mV at 3300 mV
[ 0.565433] vdd-rtc: at 800 mV
[ 0.566167] avdd-ts-hv: 1800 <–> 3300 mV at 1800 mV
[ 0.569432] spmic-ldo6: at 1500 mV
[ 0.573431] vdd-pex-1v00: 1000 mV
[ 0.574077] dvdd-pex: 1000 mV
[ 0.574543] GPIO line 221 (spmic_gpio_input) hogged as input
[ 0.574707] GPIO line 222 (spmic_gpio_input) hogged as input
[ 0.574890] gpiochip_setup_dev: registered GPIOs 216 to 223 on device: gpiochip4 (max77620-gpio)
[ 0.576803] max77620 4-003c: max77620 probe successful
[ 0.577184] media: Linux media interface: v0.10
[ 0.577222] Linux video capture interface: v2.00
[ 0.579713] pps_core: LinuxPPS API ver. 1 registered
[ 0.579728] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.579757] PTP clock support registered
[ 0.580132] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.580161] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.582646] tegra_fiq_debugger_init: found FIQ source (IRQ 386)
[ 0.586821] Advanced Linux Sound Architecture Driver Initialized.
[ 0.587144] Bluetooth: Core ver 2.22
[ 0.587179] NET: Registered protocol family 31
[ 0.587191] Bluetooth: HCI device and connection manager initialized
[ 0.587207] Bluetooth: HCI socket layer initialized
[ 0.587221] Bluetooth: L2CAP socket layer initialized
[ 0.587253] Bluetooth: SCO socket layer initialized
[ 0.587973] en-vdd-sd: 3300 mV
[ 0.588458] en-vdd-cam: 1800 mV
[ 0.593431] vdd-hdmi: 5000 mV
[ 0.593730] vdd-usb0-5v: 5000 mV
[ 0.594004] vdd-usb1-5v: 5000 mV
[ 0.597432] en-vdd-ts-1v8: 1800 mV
[ 0.601432] en-vdd-ts-hv-3v3: 3300 mV
[ 0.601898] en-vdd-disp-3v3: 3300 mV
[ 0.602356] en-mdm-pwr-3v7: 3700 mV
[ 0.602826] en-vdd-disp-1v8: 1800 mV
[ 0.603297] en-vdd-cam-hv-2v8: 2800 mV
[ 0.603781] en-vdd-cam-1v2: 1200 mV
[ 0.604259] vdd-fan: 5000 mV
[ 0.604501] vdd-3v3: 3300 mV
[ 0.605097] dis-vdd-1v2: 1200 mV
[ 0.605349] en-vdd-vcm-2v8: 2800 mV
[ 0.605852] vdd-usb2-5v: 5000 mV
[ 0.606117] vdd-sys-bl: 3300 mV
[ 0.606612] en-vdd-sys: 1200 mV
[ 0.608581] camchar: rtcpu character device driver loaded
[ 0.609100] gpio tegra-gpio wake53 for gpio=159(X:7)
[ 0.610763] extcon-gpio-states external-connection:extcon@1: Cable state:1, cable id:1
[ 0.611484] clocksource: Switched to clocksource arch_sys_counter
[ 0.633143] VFS: Disk quotas dquot_6.6.0
[ 0.633230] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.633474] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.634006] nvmap: nvmap_select_cache_ops() nvmap cache ops set to roc
[ 0.634027] nvmap_page_pool_init: Total RAM pages: 2008020
[ 0.634040] nvmap_page_pool_init: nvmap page pool size: 251002 pages (980 MB)
[ 0.634174] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.636570] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 0.642510] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.642704] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.643089] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.643179] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.643347] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 0.643730] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 0.644273] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
[ 0.644599] la/ptsa driver initialized.
[ 0.644636] pre_t19x_iso_plat_init(): iso emc max clk=1866000KHz
[ 0.644669] pre_t19x_iso_plat_init(): max_iso_bw=26870400KB
[ 0.645833] NET: Registered protocol family 2
[ 0.648074] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.648814] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.649594] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.649703] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.649948] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.650837] NET: Registered protocol family 1
[ 0.651958] RPC: Registered named UNIX socket transport module.
[ 0.651996] RPC: Registered udp transport module.
[ 0.652025] RPC: Registered tcp transport module.
[ 0.652053] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.652090] PCI: CLS 0 bytes, default 64
[ 0.652349] Trying to unpack rootfs image as initramfs…
[ 0.677615] host1x 13e10000.host1x: initialized
[ 0.679958] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.684121] audit: initializing netlink subsys (disabled)
[ 0.684195] audit: type=2000 audit(0.568:1): initialized
[ 0.684947] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 0.698178] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.701007] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.702723] 9p: Installing v9fs 9p2000 file system support
[ 0.708837] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.709027] io scheduler noop registered
[ 0.709689] io scheduler cfq registered (default)
[ 0.714841] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 0.778511] iommu: Adding device aconnect@2a41000:adsp_audio to group 53
[ 0.818628] iommu: Adding device 2993000.adsp to group 54
[ 0.819835] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 0.822776] tegra-xusb-padctl 3520000.xusb_padctl: VBUS over-current detection enabled
[ 0.826931] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.828415] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.829751] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.831152] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.834577] tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuration
[ 0.835808] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 0.836267] tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lanes
[ 0.836693] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.836962] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 0.837022] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=1500000, max_bw=4687500
[ 0.840079] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[ 0.841317] tsec 15500000.tsec: initialized
[ 0.842470] tsec 15100000.tsecb: initialized
[ 0.845842] nvdec 15480000.nvdec: initialized
[ 0.852096] falcon 15340000.vic: initialized
[ 0.853890] falcon 154c0000.nvenc: initialized
[ 0.855417] falcon 15380000.nvjpg: initialized
[ 0.859331] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 0.861073] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 0.862798] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 0.864448] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 0.866303] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 0.868107] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 0.869809] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 0.871375] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 0.875263] tegradccommon 15200000.dc_common: host1x channel mapped
[ 0.875315] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 0.875383] tegradccommon 15200000.dc_common: dma mapping done
[ 0.877723] tegradc 15210000.nvdisplay: disp0 connected to head1->/host1x/sor1
[ 0.877904] generic_infoframe_type: 0x87
[ 0.878157] tegradc 15210000.nvdisplay: DT parsed successfully
[ 0.878234] tegradc 15210000.nvdisplay: Display dc.ffffff800b610000 registered with id=0
[ 0.887953] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 0.888029] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 0.888075] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 0.888406] tegradc 15210000.nvdisplay: vblank syncpt # 8 for dc 1
[ 0.888466] tegradc 15210000.nvdisplay: vpulse3 syncpt # 9 for dc 1
[ 0.889894] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 10 channels
[ 0.890882] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 0.891182] tegradc 15210000.nvdisplay: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[ 0.891580] kfuse 3830000.kfuse: initialized
[ 0.894802] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.895255] tegradc 15210000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 0.895309] tegradc 15210000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 0.900372] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.902256] tegradc 15210000.nvdisplay: probed
[ 0.903689] console [ttyS0] disabled
[ 0.903758] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 36, base_baud = 25500000) is a Tegra
[ 1.278549] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 1.686506] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 2.094219] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 2.096278] tegra-pcie 10003000.pcie-controller: link 2 down, ignoring
[ 2.096720] tegra-pcie 10003000.pcie-controller: PCI host bridge to bus 0000:00
[ 2.096730] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.096737] pci_bus 0000:00: root bus resource [mem 0x40100000-0x580fffff]
[ 2.096744] pci_bus 0000:00: root bus resource [mem 0x58100000-0x7fffffff pref]
[ 2.096752] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.096792] pci 0000:00:01.0: [10de:10e5] type 01 class 0x060400
[ 2.096915] pci 0000:00:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.097143] iommu: Adding device 0000:00:01.0 to group 55
[ 2.097153] arm-smmu: forcing sodev map for 0000:00:01.0
[ 2.097275] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.097599] pci 0000:01:00.0: [126f:0768] type 00 class 0x030000
[ 2.097653] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x07ffffff pref]
[ 2.097681] pci 0000:01:00.0: reg 0x14: [mem 0x00000000-0x001fffff]
[ 2.097794] pci 0000:01:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[ 2.097993] pci 0000:01:00.0: supports D1
[ 2.097999] pci 0000:01:00.0: PME# supported from D0 D1 D3hot D3cold
[ 2.098253] iommu: Adding device 0000:01:00.0 to group 56
[ 2.098259] arm-smmu: forcing sodev map for 0000:01:00.0
[ 2.107640] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.107691] pci 0000:00:01.0: BAR 14: assigned [mem 0x44000000-0x4fffffff]
[ 2.107704] pci 0000:01:00.0: BAR 0: assigned [mem 0x48000000-0x4fffffff pref]
[ 2.107720] pci 0000:01:00.0: BAR 1: assigned [mem 0x44000000-0x441fffff]
[ 2.107736] pci 0000:01:00.0: BAR 6: assigned [mem 0x44200000-0x4420ffff pref]
[ 2.107744] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 2.107756] pci 0000:00:01.0: bridge window [mem 0x44000000-0x4fffffff]
[ 2.107828] tegra-pcie 10003000.pcie-controller: speed change : Gen-1 -> Gen-2
[ 2.111924] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[ 2.111930] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.111941] pcie_pme 0000:00:01.0:pcie001: service driver pcie_pme loaded
[ 2.112125] aer 0000:00:01.0:pcie002: service driver aer loaded
[ 3.339426] console [ttyS0] enabled
[ 3.340357] Console: switching to colour frame buffer device 240x67
[ 3.341760] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 37, base_baud = 0) is a TEGRA_UART
[ 3.342815] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 3.343009] serial-tegra 3130000.serial: RX in PIO mode
[ 3.344201] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 3.351907] [drm] Initialized
[ 3.379990] brd: module loaded
[ 3.389388] tegradc 15210000.nvdisplay: fb registered
[ 3.392015] loop: module loaded
[ 3.392105] tegra_profiler: version: 1.132, samples/io: 46/26
[ 3.392258] tegra_profiler: auth: init
[ 3.393103] THERMAL EST: found 3 subdevs
[ 3.393109] THERMAL EST num_resources: 0
[ 3.393113] [THERMAL EST subdev 0]
[ 3.393118] [THERMAL EST subdev 1]
[ 3.393122] [THERMAL EST subdev 2]
[ 3.393500] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 3.393502] THERMAL EST: thz register success.
[ 3.394303] THERMAL EST: end of probe, return err: 0
[ 3.394397] nct1008_nct72 7-004c: starting parse dt
[ 3.394495] nct1008_nct72 7-004c: !!!Found deprecated property!!!
[ 3.394499] nct1008_nct72 7-004c: success parsing dt
[ 3.394612] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 3.395700] hisi_sas: driver version v1.6
[ 3.401175] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 3.401189] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 3.402425] scsi host0: tegra_ahci
[ 3.407431] scsi host1: tegra_ahci
[ 3.407762] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 24
[ 3.407767] ata2: DUMMY
[ 3.414845] libphy: Fixed MDIO Bus: probed
[ 3.415553] tun: Universal TUN/TAP device driver, 1.6
[ 3.415556] tun: © 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 3.419805] e1000e: Intel® PRO/1000 Network Driver - 3.2.6-k
[ 3.419808] e1000e: Copyright© 1999 - 2015 Intel Corporation.
[ 3.419849] igb: Intel® Gigabit Ethernet Network Driver - version 5.4.0-k
[ 3.419852] igb: Copyright © 2007-2014 Intel Corporation.
[ 3.419895] igbvf: Intel® Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 3.419897] igbvf: Copyright © 2009 - 2012 Intel Corporation.
[ 3.419935] Intel® 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 3.419938] Copyright© 1999 - 2017 Intel Corporation.
[ 3.421609] eqos 2490000.ether_qos: no PHY interrupt found
[ 3.421914] eqos 2490000.ether_qos: can’t get pllrefe_vcoout clk (-2)
[ 3.426554] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b 8c d1 d4
[ 3.426721] libphy: dwc_phy: probed
[ 3.426893] nct1008_nct72 7-004c: LOC shutdown limit 107
[ 3.427221] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 3.427390] nct1008_nct72 7-004c: EXT shutdown limit 107
[ 3.430076] PPP generic driver version 2.4.2
[ 3.430465] PPP BSD Compression module registered
[ 3.430470] PPP Deflate Compression module registered
[ 3.430493] PPP MPPE Compression module registered
[ 3.430498] NET: Registered protocol family 24
[ 3.430567] usbcore: registered new interface driver r8152
[ 3.430608] usbcore: registered new interface driver asix
[ 3.430646] usbcore: registered new interface driver ax88179_178a
[ 3.430684] usbcore: registered new interface driver cdc_ether
[ 3.430721] usbcore: registered new interface driver net1080
[ 3.430763] usbcore: registered new interface driver cdc_subset
[ 3.430799] usbcore: registered new interface driver zaurus
[ 3.430845] usbcore: registered new interface driver cdc_ncm
[ 3.431075] VFIO - User Level meta-driver version: 0.3
[ 3.432790] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 3.432806] ehci-pci: EHCI PCI platform driver
[ 3.432846] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 3.432855] ohci-pci: OHCI PCI platform driver
[ 3.432912] ohci-platform: OHCI generic platform driver
[ 3.440433] tegra-xusb 3530000.xhci: USB2 port 0 has OTG_CAP
[ 3.442522] tegra-xusb 3530000.xhci: extcon 0: ffffffc1eae08000 id
[ 3.442674] tegra-xusb 3530000.xhci: Direct firmware load for tegra18x_xusb_firmware failed with error -2
[ 3.442680] tegra-xusb 3530000.xhci: Falling back to user helper
[ 3.443213] usbcore: registered new interface driver uas
[ 3.443265] usbcore: registered new interface driver usb-storage
[ 3.443358] usbcore: registered new interface driver usbserial
[ 3.448169] tegra-xudc-new 3550000.xudc: device count: 1
[ 3.449504] tegra-xudc-new 3550000.xudc: vbus state: 1
[ 3.459665] nct1008_nct72 7-004c: initial LOC temp: 38000
[ 3.459975] nct1008_nct72 7-004c: initial EXT temp: 52000
[ 3.460587] nct1008_nct72 7-004c: hi_b:-11, lo_b:0
[ 3.460887] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ 3.461080] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 3.615877] tegra-usb-cd usb_cd: notification status (0x0, 0x1)
[ 3.615885] tegra-usb-cd usb_cd: connected to SDP
[ 3.615900] tegra-xudc-new 3550000.xudc: device mode on: 0
[ 3.616143] tegra-xudc-new 3550000.xudc: active: 0 => 1
[ 3.617124] mousedev: PS/2 mouse device common for all mice
[ 3.617209] usbcore: registered new interface driver xpad
[ 3.712764] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 3.714300] Wake73 for irq=42
[ 3.715616] rtc rtc1: alarm rtc device
[ 3.715632] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 3.715662] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 3.715869] i2c /dev entries driver
[ 3.718973] ov5693 2-0036: probing v4l2 sensor.
[ 3.720159] ov5693 2-0036: tegracam sensor driver:ov5693_v2.0.6
[ 3.723038] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.874045] gpio tegra-gpio wake21 for gpio=121(P:1)
[ 3.879838] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 3.885972] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 3.892094] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 3.904156] Parent Clock set for DC plld2
[ 3.970753] tegradc 15210000.nvdisplay: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_111m_223m
[ 3.980345] tegradc 15210000.nvdisplay: hdmi: get RGB quant from REG programmed by BL.
[ 3.988296] tegradc 15210000.nvdisplay: hdmi: get YCC quant from REG programmed by BL.
[ 3.996887] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 4.004137] Extcon AUX1(HDMI) enable
[ 4.143649] tegradc 15210000.nvdisplay: blank - powerdown
[ 4.187784] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 4.187813] Extcon AUX1(HDMI) disable
[ 4.212255] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 4.212370] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 4.213511] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 4.244888] tegradc 15210000.nvdisplay: unblank
[ 4.246437] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 4.246552] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 4.246660] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 4.252455] Parent Clock set for DC plld2
[ 4.256607] tegradc 15210000.nvdisplay: hdmi: tmds rate:241500K prod-setting:prod_c_hdmi_223m_300m
[ 4.258037] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[ 4.258049] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 4.261933] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 4.261936] Extcon AUX1(HDMI) enable
[ 4.500375] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 4.504780] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ 4.505381] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 3 not supported
[ 4.506950] parse_throttle_dt_data: Num cap clks = 4
[ 4.506955] parse_throttle_dt_data: clk=mcpu type=1
[ 4.506958] parse_throttle_dt_data: clk=bcpu type=2
[ 4.506966] parse_throttle_dt_data: clk=gpu type=4
[ 4.506969] parse_throttle_dt_data: clk=emc type=3
[ 4.508063] tegra_throttle_probe: probe successful. #cdevs=4
[ 4.508633] FAN dev name: pwm-fan
[ 4.508695] FAN:gpio request success.
[ 4.508704] FAN: can’t find tach_gpio
[ 4.508744] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 4.508959] pwm_fan_driver pwm-fan: got pwm for fan. polarity is inversed
[ 4.508964] pwm_fan_driver pwm-fan: tach period: 1000
[ 4.509321] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 4.509327] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 4.509332] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 4.509337] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 4.509341] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 4.509346] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 4.509350] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 4.509355] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 4.509359] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 4.509364] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 4.511020] device-mapper: uevent: version 1.0.3
[ 4.512060] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 4.516707] cpufreq: platform driver Initialization: pass
[ 4.517412] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 4.517533] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 4.518478] sdhci: Secure Digital Host Controller Interface driver
[ 4.518479] sdhci: Copyright© Pierre Ossman
[ 4.518481] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.520147] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 4.522069] CMDQ: cmdq_platfm_init successful
[ 4.523208] CQE: CMD_TIMING bit set for R1B DCMD
[ 4.525438] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 4.531797] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 4.531847] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 4.532590] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 4.534450] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 257
[ 4.539689] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 4.540758] tegra-se-nvhost 15810000.se: initialized
[ 4.541989] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 4.542751] tegra-se-nvhost 15820000.se: initialized
[ 4.543756] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 4.544599] tegra-se-nvhost 15830000.se: initialized
[ 4.545261] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 4.546152] tegra-se-nvhost 15840000.se: initialized
[ 4.546948] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 4.547376] hidraw: raw HID events driver © Jiri Kosina
[ 4.550902] usbcore: registered new interface driver usbhid
[ 4.550904] usbhid: USB HID core driver
[ 4.557054] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 4.559272] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xbfef0000-0xbfefdb7f size=56192
[ 4.559526] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 4.559646] tegra-ivc ivc-b000000.rtcpu:i2c@480: i2c: ver=0 grp=1 RX[8x128]=0x1900-0x1d80 TX[8x128]=0x1d80-0x2200
[ 4.559846] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x2200-0x4280 TX[64x128]=0x4280-0x6300
[ 4.560557] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x6300-0x63c0 TX[1x64]=0x63c0-0x6480
[ 4.560626] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x6480-0x7900 TX[16x320]=0x7900-0x8d80
[ 4.560681] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8d80-0x9200 TX[16x64]=0x9200-0x9680
[ 4.560728] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x9680-0x9880 TX[1x384]=0x9880-0x9a80
[ 4.560827] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x8192]=0x9a80-0xbb00 TX[1x8192]=0xbb00-0xdb80
[ 4.561157] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (51)
[ 4.561159] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 4.561654] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=5 sha1=3ecb1dca25fa98771f988f238c025334776c9a96
[ 4.563298] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 4.563544] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 4.563838] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 4.564004] register_ari_mca_banks: Registered MCA ROC:IOB
[ 4.564068] register_ari_mca_banks: Registered MCA ROC:CCE
[ 4.564407] tegra18-bridge 2390000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.564409] tegra18-bridge 2390000.axi2apb: enabled timeout = 11155000
[ 4.564411] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 4.564462] tegra18-bridge 23a0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.564463] tegra18-bridge 23a0000.axi2apb: enabled timeout = 11155000
[ 4.564465] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 4.564514] tegra18-bridge 23b0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.564516] tegra18-bridge 23b0000.axi2apb: enabled timeout = 11155000
[ 4.564517] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 4.564564] tegra18-bridge 23c0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.564566] tegra18-bridge 23c0000.axi2apb: enabled timeout = 11155000
[ 4.564567] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 4.564612] tegra18-bridge 23d0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.564613] tegra18-bridge 23d0000.axi2apb: enabled timeout = 11155000
[ 4.564615] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 4.564663] tegra18-bridge 2100000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.564667] tegra18-bridge 2100000.axip2p: enabled timeout = 11155000
[ 4.564668] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 4.564715] tegra18-bridge 2110000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.564719] tegra18-bridge 2110000.axip2p: enabled timeout = 11155000
[ 4.564720] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 4.564765] tegra18-bridge 2120000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.564769] tegra18-bridge 2120000.axip2p: enabled timeout = 11155000
[ 4.564771] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 4.564817] tegra18-bridge 2130000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.564821] tegra18-bridge 2130000.axip2p: enabled timeout = 11155000
[ 4.564822] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 4.564867] tegra18-bridge 2140000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.564869] tegra18-bridge 2140000.axip2p: enabled timeout = 11155000
[ 4.564870] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 4.564925] tegra18-bridge 2150000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.564929] tegra18-bridge 2150000.axip2p: enabled timeout = 11155000
[ 4.564930] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 4.564977] tegra18-bridge 2160000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.564981] tegra18-bridge 2160000.axip2p: enabled timeout = 11155000
[ 4.564982] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 4.565027] tegra18-bridge 2170000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.565031] tegra18-bridge 2170000.axip2p: enabled timeout = 11155000
[ 4.565033] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 4.565084] tegra18-bridge 2180000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.565089] tegra18-bridge 2180000.axip2p: enabled timeout = 11155000
[ 4.565090] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 4.565135] tegra18-bridge 2190000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.565139] tegra18-bridge 2190000.axip2p: enabled timeout = 11155000
[ 4.565140] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 4.565192] **** A57 ECC: Enabled
[ 4.565193] tegra18_a57_serr_init: on CPU 4 a A57 Core
[ 4.565249] tegra18x_actmon d230000.actmon: in actmon_register()…
[ 4.565700] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 4.566782] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 4.567108] denver_knobs_init:MTS_VERSION:43068234
[ 4.569531] nvpmodel: initialized successfully
[ 4.571507] usbcore: registered new interface driver snd-usb-audio
[ 4.571564] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 4.583639] gpio tegra-gpio wake71 for gpio=125(P:5)
[ 4.583694] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 4.590386] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 4.590558] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 4.597554] OPE platform probe
[ 4.597621] OPE platform probe successful
[ 4.602557] tegra-asoc: sound: This is a dummy codec
[ 4.653031] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 4.653849] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 4.653923] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 4.654001] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 4.654065] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 4.654151] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 4.654218] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 4.654282] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 4.654347] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 4.654409] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 4.654476] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 4.654539] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 4.654605] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 4.654670] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 4.654740] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 4.654804] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 4.654870] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 4.654934] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 4.654996] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 4.655062] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 4.655127] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 4.667219] mmc0: periodic cache flush enabled
[ 4.667232] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 4.668019] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 4.672326] mmcblk0boot0: mmc0:0001 032G34 partition 1 4.00 MiB
[ 4.672543] mmcblk0boot1: mmc0:0001 032G34 partition 2 4.00 MiB
[ 4.672789] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 4.675971] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31
[ 4.702868] u32 classifier
[ 4.702870] Actions configured
[ 4.702976] Initializing XFRM netlink socket
[ 4.704688] NET: Registered protocol family 10
[ 4.705921] NET: Registered protocol family 17
[ 4.705932] NET: Registered protocol family 15
[ 4.706138] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 4.706207] Bluetooth: RFCOMM socket layer initialized
[ 4.706234] Bluetooth: RFCOMM ver 1.11
[ 4.706240] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.706246] Bluetooth: HIDP socket layer initialized
[ 4.706284] 9pnet: Installing 9P2000 support
[ 4.706331] Key type dns_resolver registered
[ 4.707881] Registered cp15_barrier emulation handler
[ 4.707895] Registered setend emulation handler
[ 4.714471] registered taskstats version 1
[ 4.718885] isp 15600000.isp: initialized
[ 4.724983] nvcsi 150c0000.nvcsi: initialized
[ 4.732033] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[ 4.732131] gpio tegra-gpio-aon wake67 for gpio=57(FF:1)
[ 4.732201] gpio tegra-gpio-aon wake68 for gpio=58(FF:2)
[ 4.732351] input: gpio-keys as /devices/gpio-keys/input/input2
[ 4.733505] tegra-vi4 15700000.vi: initialized
[ 4.734345] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi–1 bound
[ 4.734355] tegra-vi4 15700000.vi: subdev ov5693 2-0036 bound
[ 4.765215] tegra_rtc c2a0000.rtc: setting system clock to 2019-06-04 11:02:34 UTC (1559646154)
[ 4.766714] mmcblk mmc0:0001: Card claimed for testing.
[ 4.808228] bpmp: mounted debugfs mirror
[ 4.810052] bwmgr: missing cdev-type property
[ 4.816355] spmic-ldo0: disabling
[ 4.816535] spmic-ldo1: disabling
[ 4.816694] en-vdd-sd: disabling
[ 4.816696] en-vdd-cam: disabling
[ 4.816698] vdd-usb0-5v: disabling
[ 4.816700] vdd-usb1-5v: disabling
[ 4.816703] en-vdd-disp-3v3: disabling
[ 4.816725] en-mdm-pwr-3v7: disabling
[ 4.816727] en-vdd-disp-1v8: disabling
[ 4.816729] en-vdd-cam-hv-2v8: disabling
[ 4.816730] en-vdd-cam-1v2: disabling
[ 4.816732] vdd-fan: disabling
[ 4.816734] vdd-3v3: disabling
[ 4.816736] en-vdd-vcm-2v8: disabling
[ 4.816737] vdd-usb2-5v: disabling
[ 4.816739] vdd-sys-bl: disabling
[ 4.816741] en-vdd-sys: disabling
[ 4.816744] ALSA device list:
[ 4.816747] #0: tegra-hda at 0x3518000 irq 383
[ 4.816749] #1: tegra-snd-t186ref-mobile-rt565x
[ 4.829102] mmc1: hw tuning done …
[ 4.836248] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 7.760126] random: crng init done
[ 7.985592] extcon-disp-state external-connection:disp-state: cable 40 state 1
[ 7.993357] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 7.993377] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 7.995311] devtmpfs: mounted
[ 7.997273] Freeing unused kernel memory: 8512K
[ 8.020830] Extcon HDMI: HPD enabled
[ 8.025682] tegradc 15210000.nvdisplay: hdmi: plugged
[ 8.194919] ip_tables: © 2000-2006 Netfilter Core Team
[ 8.246671] cgroup: cgroup2: unknown option “nsdelegate”
[ 8.278029] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 8.305352] systemd[1]: Detected architecture arm64.
[ 8.403528] systemd[1]: Set hostname to .
[ 8.499182] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 8.517843] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 8.737019] systemd[1]: Created slice System Slice.
[ 8.746421] systemd[1]: Listening on Syslog Socket.
[ 8.754892] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 8.765605] systemd[1]: Listening on udev Kernel Socket.
[ 8.776475] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 8.868790] gpio tegra-gpio-aon wake30 for gpio=60(FF:4)
[ 8.926123] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 9.341629] systemd-journald[2236]: Received request to flush runtime journal from PID 1
[ 9.960268] using random self ethernet address
[ 9.969870] using random host ethernet address
[ 9.975968] tegra-xusb 3530000.xhci: cannot find firmware…retry after 1 second
[ 10.011319] Mass Storage Function, version: 2009/09/11
[ 10.011326] LUN: removable file: (no medium)
[ 10.028772] using random self ethernet address
[ 10.035987] using random host ethernet address
[ 10.054430] rndis0: HOST MAC 2e:fb:cb:70:cb:04
[ 10.054555] rndis0: MAC 2e:fb:cb:70:cb:05
[ 10.057268] usb0: HOST MAC 2e:fb:cb:70:cb:06
[ 10.057291] usb0: MAC 2e:fb:cb:70:cb:07
[ 10.057316] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 10.101077] l4tbr0: port 1(rndis0) entered blocking state
[ 10.101083] l4tbr0: port 1(rndis0) entered disabled state
[ 10.101696] device rndis0 entered promiscuous mode
[ 10.118555] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 10.126031] l4tbr0: port 2(usb0) entered blocking state
[ 10.126035] l4tbr0: port 2(usb0) entered disabled state
[ 10.126161] device usb0 entered promiscuous mode
[ 10.133566] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 10.133573] l4tbr0: port 2(usb0) entered blocking state
[ 10.133575] l4tbr0: port 2(usb0) entered forwarding state
[ 10.200957] dhd_module_init in
[ 10.201101] found wifi platform device bcmdhd_wlan
[ 10.217047] wifi_platform_get_country_code_map: could not get country_code_map
[ 10.217052] wifi_plat_dev_drv_probe:platform country code map is not available
[ 10.217067] Power-up adapter ‘DHD generic adapter’
[ 10.217074] wifi_platform_set_power = 1
[ 10.255524] android_work: did not send uevent (0 0 (null))
[ 10.273057] tegra-i2c c240000.i2c: no acknowledge from address 0x69
[ 10.281754] bmi160 1-0069: bmi_i2c_rd ERR: 0x00
[ 10.291545] bmi160 1-0069: bmi_init _id_i2c ERR
[ 10.291611] bmi160 1-0069: bmi_remove
[ 10.291613] bmi160 1-0069: bmi_probe done
[ 10.328718] android_work: sent uevent USB_STATE=CONNECTED
[ 10.383601] android_work: sent uevent USB_STATE=DISCONNECTED
[ 10.423524] wifi_platform_bus_enumerate device present 1
[ 10.460452] wifi_platform_bus_enumerate device present 0
[ 10.461053] F1 signature read @0x18000000=0x17214354
[ 10.477729] android_work: sent uevent USB_STATE=CONNECTED
[ 10.482235] configfs-gadget gadget: high-speed config #1: c
[ 10.482265] tegra-xudc-new 3550000.xudc: ep 5 (type: 3, dir: in) enabled
[ 10.482280] tegra-xudc-new 3550000.xudc: ep 3 (type: 2, dir: in) enabled
[ 10.482295] tegra-xudc-new 3550000.xudc: ep 2 (type: 2, dir: out) enabled
[ 10.482369] tegra-xudc-new 3550000.xudc: ep 9 (type: 3, dir: in) enabled
[ 10.482384] tegra-xudc-new 3550000.xudc: ep 7 (type: 2, dir: in) enabled
[ 10.482399] tegra-xudc-new 3550000.xudc: ep 4 (type: 2, dir: out) enabled
[ 10.482429] tegra-xudc-new 3550000.xudc: ep 15 (type: 3, dir: in) enabled
[ 10.482447] tegra-xudc-new 3550000.xudc: ep 11 (type: 2, dir: in) enabled
[ 10.482466] tegra-xudc-new 3550000.xudc: ep 6 (type: 2, dir: out) enabled
[ 10.482569] IPv6: ADDRCONF(NETDEV_CHANGE): rndis0: link becomes ready
[ 10.482676] l4tbr0: port 1(rndis0) entered blocking state
[ 10.482691] l4tbr0: port 1(rndis0) entered forwarding state
[ 10.482848] android_work: sent uevent USB_STATE=CONFIGURED
[ 10.485491] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 10.486240] tegra-xudc-new 3550000.xudc: ep 13 (type: 2, dir: in) enabled
[ 10.486257] tegra-xudc-new 3550000.xudc: ep 8 (type: 2, dir: out) enabled
[ 10.486371] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[ 10.488631] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 10.489128] wifi_platform_get_mac_addr
[ 10.551832] ids dhd_log_netlink_init
[ 10.555878] wl_event_handler :
[ 10.555884] tsk Enter, tsk = 0xffffffc1d42c1a90
[ 10.555893] wl_create_event_handler(): thread:wl_event_handler:1317 started
[ 10.559583] dhd_attach(): thread:dhd_watchdog_thread:131a started
[ 10.559651] dhd_attach(): thread:dhd_dpc:131b started
[ 10.560928] dhd_attach(): thread:dhd_rxf:131c started
