Custom底板启动报错
我们基于Jetson开发板的启动日志如下:
[0000.066] I> MB1 (version: 1.4.0.2-t234-54845784-08a4de08)
[0000.071] I> t234-A01-1-Silicon (0x12347) Prod
[0000.076] I> Boot-mode : Coldboot
[0000.079] I> Entry timestamp: 0x00000000
[0000.083] I> last_boot_error: 0x0
[0000.086] I> BR-BCT: preprod_dev_sign: 0
[0000.090] I> rst_source: 0x0, rst_level: 0x0
[0000.094] I> Task: SE error check
[0000.097] I> Task: Bootchain select WAR set
[0000.101] I> Task: Enable SLCG
[0000.104] I> Task: CRC check
[0000.107] I> Task: Initialize MB2 params
[0000.111] I> MB2-params @ 0x40060000
[0000.114] I> Task: Crypto init
[0000.117] I> Task: Perform MB1 KAT tests
[0000.121] I> Task: NVRNG health check
[0000.125] I> NVRNG: Health check success
[0000.128] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.134] I> Task: Enabling and initialization of Bandwidth limiter
[0000.140] I> No request to configure MBWT settings for any PC!
[0000.146] I> Task: Secure debug controls
[0000.150] I> Task: strap war set
[0000.153] I> Task: Initialize SOC Therm
[0000.157] I> Task: Program NV master stream id
[0000.161] I> Task: Verify boot mode
[0000.167] I> Task: Alias fuses
[0000.170] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.177] I> Task: Print SKU type
[0000.180] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c8
[0000.185] I> FUSE_OPT_GPC_DISABLE = 0x00000002
[0000.190] I> FUSE_OPT_TPC_DISABLE = 0x000000f0
[0000.194] I> FUSE_OPT_DLA_DISABLE = 0x00000003
[0000.198] I> FUSE_OPT_PVA_DISABLE = 0x00000001
[0000.202] I> FUSE_OPT_NVENC_DISABLE = 0x00000001
[0000.207] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.211] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0000.216] I> FUSE_OPT_EMC_DISABLE = 0x0000000c
[0000.220] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.224] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.228] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.232] I> FUSE_SKU_INFO_0 = 0xd5
[0000.236] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.240] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.243] I> SKU: Prod
[0000.246] I> Task: Boost clocks
[0000.249] I> Initializing NAFLL for BPMP_CPU_NIC.
[0000.254] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[0000.259] I> BPMP NAFLL lock success.
[0000.263] I> BPMP_CPU_NIC : src = 42, divisor = 0
[0000.267] I> Initializing PLLC2 for AXI_CBB.
[0000.271] I> AXI_CBB : src = 35, divisor = 0
[0000.275] I> Task: Voltage monitor
[0000.279] I> VMON: Vmon re-calibration and fine tuning done
[0000.284] I> Task: UPHY init
[0000.289] I> HSIO UPHY init done
[0000.292] W> Skipping GBE UPHY config
[0000.296] I> Task: Boot device init
[0000.299] I> Boot_device: QSPI_FLASH instance: 0
[0000.304] I> Qspi clock source : pllc_out0
[0000.308] I> QSPI Flash: Macronix 64MB
[0000.311] I> QSPI-0l initialized successfully
[0000.315] I> Task: TSC init
[0000.318] I> Task: Load membct
[0000.321] I> RAM_CODE 0x4000421
[0000.324] I> Loading MEMBCT
[0000.327] I> Slot: 0
[0000.329] I> Binary[0] block-3840 (partition size: 0x40000)
[0000.334] I> Binary name: MEM-BCT-0
[0000.338] I> Size of crypto header is 8192
[0000.342] I> Size of crypto header is 8192
[0000.346] I> strt_pg_num(3840) num_of_pgs(16) read_buf(0x40050000)
[0000.352] I> BCH of MEM-BCT-0 read from storage
[0000.356] I> BCH address is : 0x40050000
[0000.360] I> MEM-BCT-0 header integrity check is success
[0000.365] I> Binary magic in BCH component 0 is MEM0
[0000.370] I> component binary type is 0
[0000.374] I> strt_pg_num(3856) num_of_pgs(115) read_buf(0x40040000)
[0000.381] I> MEM-BCT-0 binary is read from storage
[0000.385] I> MEM-BCT-0 binary integrity check is success
[0000.391] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.397] I> RAM_CODE 0x4000421
[0000.403] I> RAM_CODE 0x4000421
[0000.407] I> Task: Load Page retirement list
[0000.411] I> Task: SDRAM params override
[0000.414] I> Task: Save mem-bct info
[0000.418] I> Task: Carveout allocate
[0000.421] I> RCM blob carveout will not be allocated
[0000.426] I> Update CCPLEX IST carveout from MB1-BCT
[0000.431] I> ECC region[0]: Start:0x0, End:0x0
[0000.435] I> ECC region[1]: Start:0x0, End:0x0
[0000.439] I> ECC region[2]: Start:0x0, End:0x0
[0000.444] I> ECC region[3]: Start:0x0, End:0x0
[0000.448] I> ECC region[4]: Start:0x0, End:0x0
[0000.452] I> Non-ECC region[0]: Start:0x80000000, End:0x280000000
[0000.458] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.463] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.467] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.472] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.483] I> allocated(CO:43) base:0xbe000000 size:0x4000000 align: 0x200000
[0000.490] I> allocated(CO:39) base:0x27de00000 size:0x2200000 align: 0x10000
[0000.497] I> allocated(CO:20) base:0x27a000000 size:0x2000000 align: 0x2000000
[0000.504] I> allocated(CO:24) base:0x278000000 size:0x2000000 align: 0x2000000
[0000.511] I> allocated(CO:28) base:0x276000000 size:0x2000000 align: 0x2000000
[0000.518] I> allocated(CO:22) base:0x27c000000 size:0x1000000 align: 0x1000000
[0000.525] I> allocated(CO:35) base:0x275000000 size:0x1000000 align: 0x100000
[0000.532] I> allocated(CO:02) base:0x27d000000 size:0x800000 align: 0x800000
[0000.539] I> allocated(CO:03) base:0x274800000 size:0x800000 align: 0x800000
[0000.546] I> allocated(CO:06) base:0x274000000 size:0x800000 align: 0x800000
[0000.553] I> allocated(CO:56) base:0x273800000 size:0x800000 align: 0x200000
[0000.560] I> allocated(CO:07) base:0x27d800000 size:0x400000 align: 0x400000
[0000.567] I> allocated(CO:33) base:0x273400000 size:0x400000 align: 0x200000
[0000.574] I> allocated(CO:19) base:0x273180000 size:0x280000 align: 0x10000
[0000.581] I> allocated(CO:23) base:0x27dc00000 size:0x200000 align: 0x200000
[0000.588] I> allocated(CO:01) base:0x273000000 size:0x100000 align: 0x100000
[0000.595] I> allocated(CO:05) base:0x272f00000 size:0x100000 align: 0x100000
[0000.601] I> allocated(CO:08) base:0x272e00000 size:0x100000 align: 0x100000
[0000.608] I> allocated(CO:09) base:0x272d00000 size:0x100000 align: 0x100000
[0000.615] I> allocated(CO:12) base:0x272c00000 size:0x100000 align: 0x100000
[0000.622] I> allocated(CO:15) base:0x272b00000 size:0x100000 align: 0x100000
[0000.629] I> allocated(CO:17) base:0x272a00000 size:0x100000 align: 0x100000
[0000.636] I> allocated(CO:27) base:0x272900000 size:0x100000 align: 0x100000
[0000.643] I> allocated(CO:42) base:0x272800000 size:0x100000 align: 0x100000
[0000.650] I> allocated(CO:54) base:0x273100000 size:0x80000 align: 0x80000
[0000.657] I> allocated(CO:34) base:0x2727f0000 size:0x10000 align: 0x10000
[0000.664] I> allocated(CO:72) base:0x2725f0000 size:0x200000 align: 0x10000
[0000.670] I> allocated(CO:47) base:0x272000000 size:0x400000 align: 0x200000
[0000.677] I> allocated(CO:50) base:0x271e00000 size:0x200000 align: 0x100000
[0000.684] I> allocated(CO:48) base:0x2725d0000 size:0x20000 align: 0x10000
[0000.691] I> allocated(CO:69) base:0x2725b0000 size:0x20000 align: 0x10000
[0000.698] I> allocated(CO:49) base:0x2725a0000 size:0x10000 align: 0x10000
[0000.705] I> NSDRAM base: 0x80000000, end: 0x2725f0000, size: 0x1f25f0000
[0000.711] I> Task: Thermal check
[0000.714] I> Using min_chip_limit as min_tmon_limit
[0000.719] I> Using max_chip_limit as max_tmon_limit
[0000.724] I> BCT max_tmon_limit = 105
[0000.727] I> BCT min_tmon_limit = -28
[0000.731] I> BCT max_tmon_limit = 105
[0000.734] I> BCT min_tmon_limit = -28
[0000.738] I> SKU specific max_chip_limit = 105
[0000.742] I> SKU specific min_chip_limit = -28
[0000.746] I> BCT max_chip_limit = 105
[0000.750] I> BCT min_chip_limit = -28
[0000.753] I> enable_soctherm_polling = 0
[0000.757] I> max temp read = 32
[0000.760] I> min temp read = 32
[0000.763] I> Enabling thermtrip
[0000.766] I> Task: Update FSI SCR with thermal fuse data
[0000.771] I> Task: Enable WDT 5th expiry
[0000.775] I> Task: I2C register
[0000.778] I> Task: Set I2C bus freq
[0000.781] I> Task: Reset FSI
[0000.784] I> Task: Pinmux init
[0000.787] I> skipped mmio_addr = 0x9240008
[0000.791] I> skipped mmio_addr = 0x9240000
[0000.795] I> skipped mmio_addr = 0x9240010
[0000.799] I> skipped mmio_addr = 0x9240018
[0000.803] I> skipped mmio_addr = 0x9240020
[0000.807] I> skipped mmio_addr = 0x9240030
[0000.811] I> skipped mmio_addr = 0x9240028
[0000.815] I> skipped mmio_addr = 0x9240038
[0000.819] I> skipped mmio_addr = 0x9240040
[0000.823] I> skipped mmio_addr = 0x9240048
[0000.827] I> skipped mmio_addr = 0x9241000
[0000.830] I> skipped mmio_addr = 0x9241008
[0000.834] I> skipped mmio_addr = 0x9241010
[0000.838] I> skipped mmio_addr = 0x9241018
[0000.842] I> skipped mmio_addr = 0x9241020
[0000.846] I> skipped mmio_addr = 0x9241028
[0000.850] I> skipped mmio_addr = 0x9241030
[0000.854] I> skipped mmio_addr = 0x9241038
[0000.858] I> skipped mmio_addr = 0x9241040
[0000.862] I> skipped mmio_addr = 0x9242000
[0000.866] I> skipped mmio_addr = 0x9242008
[0000.870] I> Task: Prod config init
[0000.873] I> Task: Pad voltage init
[0000.877] I> Task: Prod init
[0000.879] I> Task: Program rst req config reg
[0000.884] I> Task: Common rail init
[0000.887] I> DONE: Thermal config
[0000.891] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.899] I> DONE: SOC rail config
[0000.903] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0000.909] I> DONE: MEMIO rail config
[0000.913] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.
[0000.920] I> DONE: GPU rail info
[0000.923] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.
[0000.929] I> DONE: CV rail info
[0000.932] I> Task: Mem clock src
[0000.935] I> Task: Misc. board config
[0000.939] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0000.945] I> Task: SDRAM init
[0000.948] I> MemoryType: 4 MemBctRevision: 1
[0000.954] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 1
[0000.962] I> MSS CAR: Init PLLM
[0000.965] I> MSS CAR: Init PLLHUB
[0000.970] I> Encryption: MTS: en, TX: en, VPR: en, GSC: en
[0000.981] I> SDRAM initialized!
[0000.984] I> SDRAM Size in Total 0x200000000
[0000.988] I> Task: Dram Ecc scrub
[0000.991] I> Task: DRAM alias check
[0000.998] I> Task: Program NSDRAM carveout
[0001.002] I> NSDRAM carveout encryption is enabled
[0001.006] I> Program NSDRAM carveout
[0001.010] I> Task: Register checker
[0001.013] I> Task: Enable clock-mon
[0001.017] I> FMON: Fmon re-programming done
[0001.021] I> Task: Mapper init
[0001.024] I> Task: SC7 Context Init
[0001.028] I> Task: CCPLEX IST init
[0001.031] I> Task: CPU WP0
[0001.034] I> Loading MCE
[0001.036] I> Slot: 0
[0001.038] I> Binary[8] block-22784 (partition size: 0x80000)
[0001.044] I> Binary name: MCE
[0001.046] I> Size of crypto header is 8192
[0001.050] I> Size of crypto header is 8192
[0001.054] I> strt_pg_num(22784) num_of_pgs(16) read_buf(0x4003e000)
[0001.061] I> BCH of MCE read from storage
[0001.064] I> BCH address is : 0x4003e000
[0001.068] I> MCE header integrity check is success
[0001.073] I> Binary magic in BCH component 0 is MTSM
[0001.078] I> component binary type is 8
[0001.081] I> Size of crypto header is 8192
[0001.085] I> strt_pg_num(22800) num_of_pgs(350) read_buf(0x40000000)
[0001.094] I> MCE binary is read from storage
[0001.098] I> MCE binary integrity check is success
[0001.103] I> Binary MCE loaded successfully at 0x40000000 (0x2baf0)
[0001.109] I> Size of crypto header is 8192
[0001.120] I> Size of crypto header is 8192
[0001.124] I> Sending WP0 mailbox command to PSC
[0001.133] I> Task: XUSB Powergate
[0001.136] I> Skipping powergate XUSB.
[0001.140] I> Task: MB1 fixed firewalls
[0001.146] W> Firewall readback mismatch
[0001.151] I> Task: Load bpmp-fw
[0001.154] I> Slot: 0
[0001.156] I> Binary[15] block-9984 (partition size: 0x180000)
[0001.162] I> Binary name: BPMP_FW
[0001.165] I> Size of crypto header is 8192
[0001.169] I> Size of crypto header is 8192
[0001.173] I> strt_pg_num(9984) num_of_pgs(16) read_buf(0x807fe000)
[0001.179] I> BCH of BPMP_FW read from storage
[0001.183] I> BCH address is : 0x807fe000
[0001.187] I> BPMP_FW header integrity check is success
[0001.192] I> Binary magic in BCH component 0 is BPMF
[0001.197] I> component binary type is 15
[0001.200] I> Size of crypto header is 8192
[0001.204] I> strt_pg_num(10000) num_of_pgs(1990) read_buf(0x80000000)
[0001.222] I> BPMP_FW binary is read from storage
[0001.228] I> BPMP_FW binary integrity check is success
[0001.233] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xf8bc0)
[0001.240] I> Slot: 0
[0001.242] I> Binary[16] block-13056 (partition size: 0x400000)
[0001.247] I> Binary name: BPMP_FW_DTB
[0001.251] I> Size of crypto header is 8192
[0001.255] I> Size of crypto header is 8192
[0001.259] I> strt_pg_num(13056) num_of_pgs(16) read_buf(0x807fc000)
[0001.265] I> BCH of BPMP_FW_DTB read from storage
[0001.270] I> BCH address is : 0x807fc000
[0001.273] I> BPMP_FW_DTB header integrity check is success
[0001.279] I> Binary magic in BCH component 0 is BPMD
[0001.284] I> component binary type is 16
[0001.287] I> Size of crypto header is 8192
[0001.291] I> strt_pg_num(13072) num_of_pgs(384) read_buf(0x807cbff0)
[0001.300] I> BPMP_FW_DTB binary is read from storage
[0001.305] I> BPMP_FW_DTB binary integrity check is success
[0001.310] I> Binary BPMP_FW_DTB loaded successfully at 0x807cbff0 (0x2ff80)
[0001.317] I> Task: BPMP fw ast config
[0001.321] I> Task: Load psc-fw
[0001.323] I> Slot: 0
[0001.325] I> Binary[17] block-21248 (partition size: 0xc0000)
[0001.331] I> Binary name: PSC_FW
[0001.334] I> Size of crypto header is 8192
[0001.338] I> Size of crypto header is 8192
[0001.342] I> strt_pg_num(21248) num_of_pgs(16) read_buf(0x80ffe000)
[0001.348] I> BCH of PSC_FW read from storage
[0001.352] I> BCH address is : 0x80ffe000
[0001.356] I> PSC_FW header integrity check is success
[0001.361] I> Binary magic in BCH component 0 is PFWP
[0001.366] I> component binary type is 17
[0001.370] I> Size of crypto header is 8192
[0001.374] I> strt_pg_num(21264) num_of_pgs(591) read_buf(0x80fb4200)
[0001.383] I> PSC_FW binary is read from storage
[0001.388] I> PSC_FW binary integrity check is success
[0001.393] I> Binary PSC_FW loaded successfully at 0x80fb4200 (0x49df0)
[0001.399] I> Task: Load nvdec-fw
[0001.403] I> Slot: 0
[0001.405] I> Binary[7] block-6400 (partition size: 0x100000)
[0001.410] I> Binary name: NVDEC
[0001.413] I> Size of crypto header is 8192
[0001.417] I> Size of crypto header is 8192
[0001.421] I> strt_pg_num(6400) num_of_pgs(16) read_buf(0x800fe000)
[0001.427] I> BCH of NVDEC read from storage
[0001.431] I> BCH address is : 0x800fe000
[0001.435] I> NVDEC header integrity check is success
[0001.440] I> Binary magic in BCH component 0 is NDEC
[0001.445] I> component binary type is 7
[0001.448] I> Size of crypto header is 8192
[0001.452] I> strt_pg_num(6416) num_of_pgs(560) read_buf(0x80000000)
[0001.461] I> NVDEC binary is read from storage
[0001.466] I> NVDEC binary integrity check is success
[0001.471] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0001.477] I> Size of crypto header is 8192
[0001.489] I> Task: Load tsec-fw
[0001.492] I> TSEC-FW load support not enabled
[0001.496] I> Task: GPIO interrupt map
[0001.500] I> Task: SC7 context save
[0001.503] I> Slot: 0
[0001.505] I> Binary[27] block-0 (partition size: 0x100000)
[0001.510] I> Binary name: BR_BCT
[0001.513] I> Size of crypto header is 8192
[0001.517] I> Size of crypto header is 8192
[0001.521] I> Size of crypto header is 8192
[0001.525] I> strt_pg_num(0) num_of_pgs(16) read_buf(0xa0000000)
[0001.531] I> BR_BCT binary is read from storage
[0001.536] I> BR_BCT binary integrity check is success
[0001.540] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[0001.547] I> Slot: 0
[0001.549] I> Binary[13] block-23808 (partition size: 0x30000)
[0001.554] I> Binary name: SC7-FW
[0001.557] I> Size of crypto header is 8192
[0001.561] I> Size of crypto header is 8192
[0001.565] I> Size of crypto header is 8192
[0001.569] I> Size of crypto header is 8192
[0001.573] I> strt_pg_num(23808) num_of_pgs(16) read_buf(0xa0002000)
[0001.579] I> BCH of SC7-FW read from storage
[0001.584] I> BCH address is : 0xa0002000
[0001.587] I> SC7-FW header integrity check is success
[0001.592] I> Binary magic in BCH component 0 is WB0B
[0001.597] I> component binary type is 13
[0001.601] I> Size of crypto header is 8192
[0001.605] I> strt_pg_num(23824) num_of_pgs(349) read_buf(0xa0004000)
[0001.613] I> SC7-FW binary is read from storage
[0001.618] I> SC7-FW binary integrity check is success
[0001.623] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x2b920)
[0001.629] I> Slot: 0
[0001.631] I> Binary[22] block-24192 (partition size: 0x30000)
[0001.637] I> Binary name: PSC_RF
[0001.640] I> Size of crypto header is 8192
[0001.644] I> Size of crypto header is 8192
[0001.648] I> Size of crypto header is 8192
[0001.651] I> Size of crypto header is 8192
[0001.655] I> strt_pg_num(24192) num_of_pgs(16) read_buf(0xa002f920)
[0001.662] I> BCH of PSC_RF read from storage
[0001.666] I> BCH address is : 0xa002f920
[0001.670] I> PSC_RF header integrity check is success
[0001.674] I> Binary magic in BCH component 0 is PSCR
[0001.679] I> component binary type is 22
[0001.683] I> Size of crypto header is 8192
[0001.687] I> strt_pg_num(24208) num_of_pgs(224) read_buf(0xa0031920)
[0001.694] I> PSC_RF binary is read from storage
[0001.699] I> PSC_RF binary integrity check is success
[0001.704] I> Binary PSC_RF loaded successfully at 0xa0031920 (0x1be60)
[0001.713] I> Task: Save WP0 payload to SC7 ctx
[0001.718] I> Task: Load MB2rf binary to SC7 ctx
[0001.722] I> Slot: 0
[0001.724] I> Binary[14] block-24576 (partition size: 0x20000)
[0001.730] I> Binary name: MB2_RF
[0001.733] I> Size of crypto header is 8192
[0001.737] I> Size of crypto header is 8192
[0001.741] I> Size of crypto header is 8192
[0001.745] I> Size of crypto header is 8192
[0001.748] I> strt_pg_num(24576) num_of_pgs(16) read_buf(0xa00d5d10)
[0001.755] I> BCH of MB2_RF read from storage
[0001.759] I> BCH address is : 0xa00d5d10
[0001.763] I> MB2_RF header integrity check is success
[0001.768] I> Binary magic in BCH component 0 is MB2R
[0001.772] I> component binary type is 14
[0001.776] I> Size of crypto header is 8192
[0001.780] I> strt_pg_num(24592) num_of_pgs(224) read_buf(0xa00d7d10)
[0001.788] I> MB2_RF binary is read from storage
[0001.792] I> MB2_RF binary integrity check is success
[0001.797] I> Binary MB2_RF loaded successfully at 0xa00d7d10 (0x1bf30)
[0001.803] I> Task: Save fuse alias data to SC7 ctx
[0001.808] I> Task: Save PMIC data to SC7 ctx
[0001.812] I> Task: Save Pinmux data to SC7 ctx
[0001.817] I> Task: Save Pad Voltage data to SC7 ctx
[0001.821] I> Task: Save controller prod data to SC7 ctx
[0001.826] I> Task: Save prod cfg data to SC7 ctx
[0001.831] I> Task: Save I2C bus freq data to SC7 ctx
[0001.836] I> Task: Save SOCTherm data to SC7 ctx
[0001.840] I> Task: Save FMON data to SC7 ctx
[0001.844] I> Task: Save VMON data to SC7 ctx
[0001.848] I> Task: Save TZDRAM data to SC7 ctx
[0001.853] I> Task: Save GPIO int data to SC7 ctx
[0001.857] I> Task: Save clock data to SC7 ctx
[0001.861] I> Task: Save debug data to SC7 ctx
[0001.865] I> Task: Save MBWT data to SC7 ctx
[0001.873] I> SC7 context save done
[0001.877] I> Task: Load MB2/Applet/FSKP
[0001.880] I> Loading MB2
[0001.883] I> Slot: 0
[0001.885] I> Binary[6] block-8448 (partition size: 0x80000)
[0001.890] I> Binary name: MB2
[0001.893] I> Size of crypto header is 8192
[0001.897] I> Size of crypto header is 8192
[0001.901] I> strt_pg_num(8448) num_of_pgs(16) read_buf(0x8007e000)
[0001.907] I> BCH of MB2 read from storage
[0001.911] I> BCH address is : 0x8007e000
[0001.915] I> MB2 header integrity check is success
[0001.919] I> Binary magic in BCH component 0 is MB2B
[0001.924] I> component binary type is 6
[0001.928] I> Size of crypto header is 8192
[0001.932] I> strt_pg_num(8464) num_of_pgs(844) read_buf(0x80000000)
[0001.943] I> MB2 binary is read from storage
[0001.948] I> MB2 binary integrity check is success
[0001.952] I> Binary MB2 loaded successfully at 0x80000000 (0x696a0)
[0001.958] I> Task: Map CCPLEX SHARED carveout
[0001.963] I> Task: Prepare MB2 params
[0001.966] I> Task: Dram ecc test
[0001.970] I> Task: Misc NV security settings
[0001.974] I> NVDEC sticky bits programming done
[0001.978] I> Successfully powergated NVDEC
[0001.982] I> Task: Disable/Reload WDT
[0001.986] I> Task: Program misc carveouts
[0001.989] I> Program IPC carveouts
[0001.993] I> Task: Disable SCPM/POD reset
[0001.997] I> SLCG Global override status := 0x0
[0002.001] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-af79ed0a)
I> Emulation:
I> Entry timestamp: 0x001ef7e0
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0x273800000, size:0x800000]
I> Task: MB2 Params integrity check
I> Task: Enable CCPLEX WDT 5th expiry
I> Task: ARI update carveout TZDRAM
I> Task: Configure OEM set LA/PTSA values
I> Task: Check MC errors
I> Task: Enable hot-plug capability
I> Task: PSC mailbox init
I> Task: Enable clock for external modules
I> Task: Measured Boot init
I> Task: fTPM silicon identity init
I> fTPM is not enabled.
I> Task: OEM SC7 context save init
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout
I> Task: Program CBB PCIE AMAP regions
I> Secondary storage device: QSPI_FLASH instance: 0
I> Task: Partition Manager Init
I> strt_pg_num(1) num_of_pgs(1) read_buf(0x273801000)
I> strt_pg_num(131071) num_of_pgs(1) read_buf(0x273801000)
I> strt_pg_num(131039) num_of_pgs(32) read_buf(0x273801200)
I> Found 60 partitions in QSPI_FLASH (instance 0)
I> Task: Pass DRAM ECC PRL Flag to FSI
I> Task: Load and authenticate registered FWs
I> Task: Load AUXP FWs
I> Successfully register SPE FW load task with MB2 loader
I> Successfully register RCE FW load task with MB2 loader
I> Successfully register DCE FW load task with MB2 loader
I> Unpowergating APE
I> Unpowergate done
I> Successfully register APE FW load task with MB2 loader
I> Skipping FSI FW load
I> Successfully register XUSB FW load task with MB2 loader
I> Successfully register PVA FW load task with MB2 loader
I> Partition name: A_spe-fw
I> Size of partition: 589824
I> Binary@ device:3/0 block-55040 (partition size: 0x90000), name: A_spe-fw
I> strt_pg_num(55040) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(55056) num_of_pgs(512) read_buf(0x272e00000)
I> Partition name: A_rce-fw
I> Size of partition: 1048576
I> Binary@ device:3/0 block-56192 (partition size: 0x100000), name: A_rce-fw
I> strt_pg_num(56192) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(56208) num_of_pgs(880) read_buf(0x272a00000)
I> spe: Authentication Finalize Done
I> Binary spe loaded successfully at 0x272e00000
I> Partition name: A_dce-fw
I> Size of partition: 5242880
I> Binary@ device:3/0 block-44800 (partition size: 0x500000), name: A_dce-fw
I> strt_pg_num(44800) num_of_pgs(16) read_buf(0x40066880)
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0x272a00000
I> Successfully register RCE FW context save task with MB2 loader
I> dce : oem authentication of header done
I> strt_pg_num(44816) num_of_pgs(1) read_buf(0x2739400d8)
I> strt_pg_num(44816) num_of_pgs(8) read_buf(0x2739400d8)
I> dce : meta-blob integrity check is success.
I> strt_pg_num(44824) num_of_pgs(512) read_buf(0x2738000c0)
I> strt_pg_num(45336) num_of_pgs(512) read_buf(0x2738400c0)
I> dce : will be decompressed at 0x27a000000
I> version 1 Bin 1 BCheckSum 0 content_size 0 Content ChkSum 1 reserved_00 0
I> Reserved10 0 BlockMaxSize 5 Reserved11 0
I> strt_pg_num(45848) num_of_pgs(512) read_buf(0x2738800c0)
I> dce : decompressed to 12095616 bytes
I> dce: plain binary integrity check is success
I> Partition name: A_adsp-fw
I> Size of partition: 2097152
I> Binary@ device:3/0 block-58240 (partition size: 0x200000), name: A_adsp-fw
I> strt_pg_num(58240) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(58256) num_of_pgs(800) read_buf(0x27d800000)
I> dce: Authentication Finalize Done
I> Binary dce loaded successfully at 0x27a000000
I> Partition name: A_xusb-fw
I> Size of partition: 262144
I> Binary@ device:3/0 block-9472 (partition size: 0x40000), name: A_xusb-fw
I> strt_pg_num(9472) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(9488) num_of_pgs(312) read_buf(0x272f00000)
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0x27d800000
I> Successfully register APE FW context save task with MB2 loader
I> Partition name: A_pva-fw
I> Binary@ device:3/0 block-62336 (partition size: 0x40000), name: A_pva-fw
I> strt_pg_num(62336) num_of_pgs(16) read_buf(0x40066880)
I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0x272f00000
I> Successfully register XUSB FW context save task with MB2 loader
I> pva-fw : oem authentication of header done
I> strt_pg_num(62352) num_of_pgs(1) read_buf(0x2739400d8)
I> strt_pg_num(62352) num_of_pgs(8) read_buf(0x2739400d8)
I> pva-fw : meta-blob integrity check is success.
I> strt_pg_num(62360) num_of_pgs(512) read_buf(0x2738000c0)
I> pva-fw : will be decompressed at 0x273180000
I> pva-fw : decompressed to 2156512 bytes
I> pva-fw: plain binary integrity check is success
I> pva-fw: Authentication Finalize Done
I> Binary pva-fw loaded successfully at 0x273180000
I> Successfully register PVA FW context save task with MB2 loader
I> Task: Carveout setup
I> Program remaining OEM carveouts
I> Task: Enable FSITHERM
I> Task: Enable FSI VMON
I> Task: Validate FSI Therm readings
I> Task: Restore XUSB sec
I> Task: Enable FSI SE clock
I> Task: Initialize SBSA UART CAR
I> Task: Initialize CPUBL Params
I> CPUBL-params @ 0x276000000
I> Task: Ratchet update
W> Skip ratchet update - OPTIN fuse not set
I> Task: Prepare eeprom data
I> Task: FSI padctl context save
W> Skipping FSI padctl config save: fsi not enabled
I> Task: Unpowergate APE
W> mb2_unpowergate_ape: skip! APE is in unpowergated state
I> Task: Memctrl reconfig pending clients
I> Task: OEM firewalls
I> OEM firewalls configured
I> Task: Powergate APE
I> Powergating APE
I> Powergate done
I> Task: OEM firewall restore saved settings
I> Task: Unhalt AUXPs
I> Unhalting SPE…
I> Enabling combined UART
ÿ󲯥: early_init
ÿ¸ÿ󿵩c initialized
ÿ¸ÿ󿳳c initialized
ÿ¸ÿ󿠯n lic initialized
ÿ¸ÿ󿲰e: tag is 5243985d1b1eb3f06fac6d36bd7e74ac
ÿ¸ÿ󿲰e: SafeRTOS v8.4
ÿ¸ÿ󿲰e: init
ÿ¸ÿ󿲣heduler initialized
ÿ¸ÿ󿠯n hsp initialized
ÿ¸ÿ󿳡g initialized
ÿ¸ÿ󿳣u initialized
ÿ¸ÿ󿡰mp ipc initialized
ÿ¸ÿ󿲰e: late init
ÿ¸ÿ󿢰u_nic clock initialized
ÿ¸ÿ󿠰b clock initialized
ÿ¸ÿ󿯭 initialized
ÿ¸ÿ󿡰mp hsp initialized
ÿ¸ÿ󿳯p1 hsp initialized
ÿ¸ÿ󿢣plex ipc initialized
ÿ¸ÿ󿲰e: start scheduler
ÿ¸ÿ
Ǿ Task: Trigger mailbox for PSC-BL1 exit
I> Sending opcode 0x4d420802 to psc
I> Received ACK from psc
I> Task: Start secure NOR provision
I> Skip Secure NOR provisioning
I> Task: Trigger load FSI keyblob
I> Task: Complete load FSI keyblob
I> Task: MB2-PSC_FW Key Manager Init
I> Sending opcode OP_PSC_KEY_MANAGER to psc-fw
I> Sending opcode 0x4b45594d to psc
ÿ
᧷wdt_init: WDT boot cfg 0x710010 sts 0x10
bpmp: socket 0
bpmp: base binary md5 is 3b0e1a33cf85c7f62a7e8b93c2af97ed
bpmp: combined binary md5 is 4f590cddd4eeb67cd15bf080683d6d83
bpmp: firmware tag is 4f590cddd4eeb67cd15b-3b0e1a33cf8
Write control check for CBB_CENTRAL_CBB_FIREWALL_PWM7_BLF failed, expected value: 00100008 != actual value: 0010000a address: 13a178a8
initialized vwdt
initialized mail_early
initialized fuse
initialized vfrel
initialized adc
fmon_populate_monitors: found 199 monitors
initialized fmon
initialized mc
initialized reset
initialized uphy_early
initialized emc_early
initialized pm
465 clocks registered
initialized clk_mach
initialized clk_cal_early
initialized clk_mach_early_config
initialized io_dpd
initialized soctherm
initialized regime
initialized i2c
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
initialized vrmon
initialized regulator
ÿǾ Received ACK from psc
I> Task: Unhalt FSI
I> FSI unhalt skipped
I> Unhalting RCE
I> RCE unhalt successful
I> Unhalting DCE
I> DCE unhalt successful
I> APE unhalt skipped
I> Task: Load Hÿᨮitialized avfs_clk_platform
ÿ䙠 2.573597] Camerÿ
䀥a-FW on t234-rce-safe started
ÿᨮitialized dvs
initialized clk_mach_confÿ䓃U early console enabled.
ÿᨧ
initialized suspend
initialized strap
initialized mce_dbell
ÿԯCPUBL
I> Task: Load TOS
I> Task: Trigger load TSEC leyblob
I> Sending opcode 0x53535452 to psc
I> Sent opcode to psc
I> Task: Load aÿ
ꀡnd authenticate registered FWs
I> Parÿᨮitialized emc
initialized emc_mrq
ÿ೩tion name: A_cpu-bootloader
ÿ烃E Stÿᨮitialized clk_cal
initialized uphy_dt
initialized uphy_mrq
HSIO UPHY reset has been de-asserted 0x0
initialized uphy
initialized pg_late
initialized pg_mrq_init
swdtimer_init: reg polling start w period 47 ms
initialized swdtimer
initialized hwwdt_late
initialized bwmgr
initialized thermal_host_trip
initialized thermal_mrq
initialized oc_mrq
initialized reset_mrq
initialized mail_mrq
initialized fmon_mrq
initialized clk_mrq
initialized avfs_mrq
initialized i2c_mrq
initialized tag_mrq
initialized bwmgr_mrq
initialized console_mrq
missing prod DT calibration data for 199 fmons
initialized clk_sync_fmon_post
ÿǾ Size oÿ砲ted
ÿᨮitialized clk_cal_late
initialized noc_late
initialized cvc
ÿ
ÿठpartition: 36ÿᨮitialized avfs_clk_mach_post
initialized avfs_clk_platform_post
initialized cvc_late
WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/2 have not matching zones 0/1
WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/3 have not matching zone list sizes 1/3
WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/3 have not matching zones 0/2
WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/0 have not matching zones 1/0
WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/3 have not matching zone list sizes 1/3
WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/3 have not matching zones 1/2
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/0 have not matching zone list sizes 3/1
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/0 have not matching zones 2/0
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/2 have not matching zone list sizes 3/1
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/2 have not matching zones 2/1
initialized rm
initialized console_late
handling unreferenced clks
enable can1_core
enable can1_host
enable can2_core
enable can2_host
enable pwm3
enable sdmmc4_axicif
enable mss_encrypt
enable maud
enable pllg_ref
enable dsi_core
enable aza_2xbit
enable xusb_ss
enable xusb_fs
enable xusb_falcon
enable xusb_core_mux
enable dsi_lp
clk_check_max_rate: pex1_c6_core rate 500000000 > max 250000000
clk_check_max_rate: pex2_c7_core rate 500000000 > max 250000000
clk_check_max_rate: pex2_c8_core rate 500000000 > max 250000000
clk_check_max_rate: pex2_c9_core rate 500000000 > max 250000000
clk_check_max_rate: pex2_c10_core rate 500000000 > max 250000000
clk_check_max_rate: pex0_c0_core rate 500000000 ÿ䙠 2.828361] Camerÿ༠max 250000000
clk_check_max_rate: pex0_c1_core rate 500000000 > max 250000000
clk_check_max_rate:ÿ䟭FW on t234-rce-safe ready SHA1=e2238c99 (crt 12.420 ms, total boot 268.256 mÿ߰ex0_c2_core rate 500000000 > max 250000000
clk_checkÿ䱩
ÿឭax_rate: pex0_c3_core rate 500000000 > max 250000000
clk_check_max_rate: pex0_c4_core rate 500000000 > max 250000000
clk_check_max_rate: pex1_c5_core rate 500000000 > max 250000000
initialized clk_mach_post
initialized pg_post
initialized regulator_post
initialized profile
initialized mrq
initialized patrol_scrubber
initialized cactmon
initialized extras_post
bpmp: init complete
ÿ󿵰016
I> Binary@ device:3/0 block-24832 (partition size: 0x380000), name: A_cpu-bootloader
ÿ
烃E_SW_Init
Admin Task Init
Admin Task Init complete
Print Task Init
RM Task Init
SHA Task Init
Admin Task Started
DCE SC7 SHA Enabled
RM Task Started
RM Task Running
Print Task Started
Print Task Running
SHA Task Started
SHA TaÿǾ strt_pg_num(24832) num_of_pgs(16) read_buf(0x40066880)
ÿ粫 Running
DCE: FW Boot Complete
Admin Task Running
ÿǾ cpubl : oem authentication of header done
I> strt_pg_num(24848) num_of_pgs(1) read_buf(0x273943c98)
I> strt_pg_num(24848) num_of_pgs(8) read_buf(0x273943c98)
I> cpubl : meta-blob integrity check is success.
I> strt_pg_num(24856) num_of_pgs(512) read_buf(0x273803c80)
I> strt_pg_num(25368) num_of_pgs(512) read_buf(0x273843c80)
I> cpubl : will be decompressed at 0x272000000
I> strt_pg_num(25880) num_of_pgs(512) read_buf(0x273883c80)
I> strt_pg_num(26392) num_of_pgs(512) read_buf(0x2738c3c80)
I> strt_pg_num(26904) num_of_pgs(512) read_buf(0x273903c80)
I> strt_pg_num(27416) num_of_pgs(512) read_buf(0x273803c80)
I> strt_pg_num(27928) num_of_pgs(512) read_buf(0x273843c80)
I> strt_pg_num(28440) num_of_pgs(512) read_buf(0x273883c80)
I> strt_pg_num(28952) num_of_pgs(512) read_buf(0x2738c3c80)
I> strt_pg_num(29464) num_of_pgs(512) read_buf(0x273903c80)
I> strt_pg_num(29976) num_of_pgs(512) read_buf(0x273803c80)
I> strt_pg_num(30488) num_of_pgs(512) read_buf(0x273843c80)
I> strt_pg_num(31000) num_of_pgs(512) read_buf(0x273883c80)
I> cpubl : decompressed to 3559552 bytes
I> cpubl: plain binary integrity check is success
I> Partition name: A_secure-os
I> Size of partition: 4194304
I> Binary@ device:3/0 block-32000 (partition size: 0x400000), name: A_secure-os
I> strt_pg_num(32000) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(32016) num_of_pgs(3176) read_buf(0xc1d73000)
I> NSDRAM carveout base: 0x80000000, size: 0x1f25f0000
I> cpubl_params: nsdram: carveout: 1, encryption: 1
I> cpubl: Authentication Finalize Done
I> Binary cpubl loaded successfully at 0x272000000
I> tos: Authentication Finalize Done
I> Binary tos loaded successfully at 0xc1d73000
I> Relocating OP-TEE dtb from: 0xc1eff0f0 to 0xbe040020, size: 0x2889
I> [0] START: 0x80000000, SIZE: 0x1f25f0000
I> [1] START: 0x276000000, SIZE: 0x2000000
I> Setting NS memory ranges to OP-TEE dtb finished.
I> Partition name: A_eks
I> Binary@ device:3/0 block-44288 (partition size: 0x40000), name: A_eks
I> strt_pg_num(44288) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(44304) num_of_pgs(8) read_buf(0xbe020000)
I> eks: Authentication Finalize Done
I> Binary eks loaded successfully at 0xbe020000
I> EKB detected (length: 0x410) @ VA:0xbe020000
I> Task: Add cpubl params integrity check
I> Added cpubl params digest.
I> Task: Prepare TOS params
I> Setting EKB blob info to OPTEE dtb finished.
I> Setting OPTEE arg3: 0xbe040020
I> OEM sc7 context saved
I> Task: Disable MSS perf stats
I> Task: Program display sticky bits
I> Task: Storage device deinit
I> Task: SMMU external bypass disable
I> Task: SMMU init
I> Task: Program GICv3 registers
I> Task: Audit firewall settings
I> Task: Bootchain failure check
I> Current Boot-Chain Slot: 0
I> BR-BCT Boot-Chain is 0, and status is 1. Set UPDATE_BRBCT bit to 0
I> Task: Burn RESERVED_ODM0 fuse
I> Task: Lock fusing
I> Task: Clear dec source key
I> MB2 finished
ÿ㍏TICE: BL31: v2.8(release):e12e3fa93
NOTICE: BL31: Built : 09:56:21, May 6 2024
I/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 3.22 (gcc version 11.3.0 (Buildroot 2022.08)) #2 Mon May 6 17:07:49 UTC 2024 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check Porting guidelines — OP-TEE documentation documentation
I/TC: Primary CPU initializing
I/TC: Test OEM keys are being used. This is insecure for shipping products!
I/TC: Primary CPU switching to normal world boot
ÿ
ɥtson UEFI firmware (version 36.3.0-gcid-36191598 built on 2024-05-06T16:58:59+00:00)
在我们自己的底板上启动报错:
[0000.061] I> MB1 (version: 1.4.0.2-t234-54845784-08a4de08)
[0000.066] I> t234-A01-1-Silicon (0x12347) Prod
[0000.071] I> Boot-mode : Coldboot
[0000.074] I> Entry timestamp: 0x00000000
[0000.078] I> last_boot_error: 0x0
[0000.081] I> BR-BCT: preprod_dev_sign: 0
[0000.084] I> rst_source: 0x0, rst_level: 0x0
[0000.089] I> Task: SE error check
[0000.092] I> Task: Bootchain select WAR set
[0000.096] I> Task: Enable SLCG
[0000.099] I> Task: CRC check
[0000.101] I> Task: Initialize MB2 params
[0000.106] I> MB2-params @ 0x40060000
[0000.109] I> Task: Crypto init
[0000.112] I> Task: Perform MB1 KAT tests
[0000.116] I> Task: NVRNG health check
[0000.119] I> NVRNG: Health check success
[0000.123] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.129] I> Task: Enabling and initialization of Bandwidth limiter
[0000.135] I> No request to configure MBWT settings for any PC!
[0000.141] I> Task: Secure debug controls
[0000.145] I> Task: strap war set
[0000.148] I> Task: Initialize SOC Therm
[0000.152] I> Task: Program NV master stream id
[0000.156] I> Task: Verify boot mode
[0000.162] I> Task: Alias fuses
[0000.165] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.172] I> Task: Print SKU type
[0000.175] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c8
[0000.180] I> FUSE_OPT_GPC_DISABLE = 0x00000002
[0000.184] I> FUSE_OPT_TPC_DISABLE = 0x000000f0
[0000.189] I> FUSE_OPT_DLA_DISABLE = 0x00000003
[0000.193] I> FUSE_OPT_PVA_DISABLE = 0x00000001
[0000.197] I> FUSE_OPT_NVENC_DISABLE = 0x00000001
[0000.202] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.206] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0000.210] I> FUSE_OPT_EMC_DISABLE = 0x0000000c
[0000.215] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.219] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.223] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.227] I> FUSE_SKU_INFO_0 = 0xd5
[0000.230] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.235] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.238] I> SKU: Prod
[0000.240] I> Task: Boost clocks
[0000.243] I> Initializing NAFLL for BPMP_CPU_NIC.
[0000.248] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[0000.254] I> BPMP NAFLL lock success.
[0000.257] I> BPMP_CPU_NIC : src = 42, divisor = 0
[0000.262] I> Initializing PLLC2 for AXI_CBB.
[0000.266] I> AXI_CBB : src = 35, divisor = 0
[0000.270] I> Task: Voltage monitor
[0000.274] I> VMON: Vmon re-calibration and fine tuning done
[0000.279] I> Task: UPHY init
[0000.284] I> HSIO UPHY init done
[0000.287] W> Skipping GBE UPHY config
[0000.290] I> Task: Boot device init
[0000.294] I> Boot_device: QSPI_FLASH instance: 0
[0000.298] I> Qspi clock source : pllc_out0
[0000.302] I> QSPI Flash: Macronix 64MB
[0000.306] I> QSPI-0l initialized successfully
[0000.310] I> Task: TSC init
[0000.313] I> Task: Load membct
[0000.316] I> RAM_CODE 0x4000421
[0000.319] I> Loading MEMBCT
[0000.322] I> Slot: 0
[0000.324] I> Binary[0] block-3840 (partition size: 0x40000)
[0000.329] I> Binary name: MEM-BCT-0
[0000.333] I> Size of crypto header is 8192
[0000.337] I> Size of crypto header is 8192
[0000.340] I> strt_pg_num(3840) num_of_pgs(16) read_buf(0x40050000)
[0000.347] I> BCH of MEM-BCT-0 read from storage
[0000.351] I> BCH address is : 0x40050000
[0000.355] I> MEM-BCT-0 header integrity check is success
[0000.360] I> Binary magic in BCH component 0 is MEM0
[0000.365] I> component binary type is 0
[0000.369] I> strt_pg_num(3856) num_of_pgs(115) read_buf(0x40040000)
[0000.375] I> MEM-BCT-0 binary is read from storage
[0000.380] I> MEM-BCT-0 binary integrity check is success
[0000.385] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.392] I> RAM_CODE 0x4000421
[0000.401] I> Task: Load Page retirement list
[0000.405] I> Task: SDRAM params override
[0000.409] I> Task: Save mem-bct info
[0000.413] I> Task: Carveout allocate
[0000.416] I> RCM blob carveout will not be allocated
[0000.421] I> Update CCPLEX IST carveout from MB1-BCT
[0000.426] I> ECC region[0]: Start:0x0, End:0x0
[0000.430] I> ECC region[1]: Start:0x0, End:0x0
[0000.434] I> ECC region[2]: Start:0x0, End:0x0
[0000.439] I> ECC region[3]: Start:0x0, End:0x0
[0000.443] I> ECC region[4]: Start:0x0, End:0x0
[0000.447] I> Non-ECC region[0]: Start:0x80000000, End:0x280000000
[0000.453] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.458] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.462] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.467] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.478] I> allocated(CO:43) base:0xbe000000 size:0x4000000 align: 0x200000
[0000.485] I> allocated(CO:39) base:0x27de00000 size:0x2200000 align: 0x10000
[0000.492] I> allocated(CO:20) base:0x27a000000 size:0x2000000 align: 0x2000000
[0000.499] I> allocated(CO:24) base:0x278000000 size:0x2000000 align: 0x2000000
[0000.506] I> allocated(CO:28) base:0x276000000 size:0x2000000 align: 0x2000000
[0000.513] I> allocated(CO:22) base:0x27c000000 size:0x1000000 align: 0x1000000
[0000.520] I> allocated(CO:35) base:0x275000000 size:0x1000000 align: 0x100000
[0000.527] I> allocated(CO:02) base:0x27d000000 size:0x800000 align: 0x800000
[0000.534] I> allocated(CO:03) base:0x274800000 size:0x800000 align: 0x800000
[0000.541] I> allocated(CO:06) base:0x274000000 size:0x800000 align: 0x800000
[0000.548] I> allocated(CO:56) base:0x273800000 size:0x800000 align: 0x200000
[0000.555] I> allocated(CO:07) base:0x27d800000 size:0x400000 align: 0x400000
[0000.562] I> allocated(CO:33) base:0x273400000 size:0x400000 align: 0x200000
[0000.569] I> allocated(CO:19) base:0x273180000 size:0x280000 align: 0x10000
[0000.576] I> allocated(CO:23) base:0x27dc00000 size:0x200000 align: 0x200000
[0000.582] I> allocated(CO:01) base:0x273000000 size:0x100000 align: 0x100000
[0000.589] I> allocated(CO:05) base:0x272f00000 size:0x100000 align: 0x100000
[0000.596] I> allocated(CO:08) base:0x272e00000 size:0x100000 align: 0x100000
[0000.603] I> allocated(CO:09) base:0x272d00000 size:0x100000 align: 0x100000
[0000.610] I> allocated(CO:12) base:0x272c00000 size:0x100000 align: 0x100000
[0000.617] I> allocated(CO:15) base:0x272b00000 size:0x100000 align: 0x100000
[0000.624] I> allocated(CO:17) base:0x272a00000 size:0x100000 align: 0x100000
[0000.631] I> allocated(CO:27) base:0x272900000 size:0x100000 align: 0x100000
[0000.638] I> allocated(CO:42) base:0x272800000 size:0x100000 align: 0x100000
[0000.645] I> allocated(CO:54) base:0x273100000 size:0x80000 align: 0x80000
[0000.652] I> allocated(CO:34) base:0x2727f0000 size:0x10000 align: 0x10000
[0000.658] I> allocated(CO:72) base:0x2725f0000 size:0x200000 align: 0x10000
[0000.665] I> allocated(CO:47) base:0x272000000 size:0x400000 align: 0x200000
[0000.672] I> allocated(CO:50) base:0x271e00000 size:0x200000 align: 0x100000
[0000.679] I> allocated(CO:48) base:0x2725d0000 size:0x20000 align: 0x10000
[0000.686] I> allocated(CO:69) base:0x2725b0000 size:0x20000 align: 0x10000
[0000.693] I> allocated(CO:49) base:0x2725a0000 size:0x10000 align: 0x10000
[0000.699] I> NSDRAM base: 0x80000000, end: 0x2725f0000, size: 0x1f25f0000
[0000.706] I> Task: Thermal check
[0000.709] I> Using min_chip_limit as min_tmon_limit
[0000.714] I> Using max_chip_limit as max_tmon_limit
[0000.719] I> BCT max_tmon_limit = 105
[0000.722] I> BCT min_tmon_limit = -28
[0000.726] I> BCT max_tmon_limit = 105
[0000.729] I> BCT min_tmon_limit = -28
[0000.733] I> SKU specific max_chip_limit = 105
[0000.737] I> SKU specific min_chip_limit = -28
[0000.741] I> BCT max_chip_limit = 105
[0000.745] I> BCT min_chip_limit = -28
[0000.748] I> enable_soctherm_polling = 0
[0000.752] I> max temp read = 32
[0000.755] I> min temp read = 32
[0000.758] I> Enabling thermtrip
[0000.761] I> Task: Update FSI SCR with thermal fuse data
[0000.766] I> Task: Enable WDT 5th expiry
[0000.770] I> Task: I2C register
[0000.773] I> Task: Set I2C bus freq
[0000.776] I> Task: Reset FSI
[0000.779] I> Task: Pinmux init
[0000.782] I> skipped mmio_addr = 0x9240008
[0000.786] I> skipped mmio_addr = 0x9240000
[0000.790] I> skipped mmio_addr = 0x9240010
[0000.794] I> skipped mmio_addr = 0x9240018
[0000.798] I> skipped mmio_addr = 0x9240020
[0000.802] I> skipped mmio_addr = 0x9240030
[0000.806] I> skipped mmio_addr = 0x9240028
[0000.810] I> skipped mmio_addr = 0x9240038
[0000.814] I> skipped mmio_addr = 0x9240040
[0000.817] I> skipped mmio_addr = 0x9240048
[0000.821] I> skipped mmio_addr = 0x9241000
[0000.825] I> skipped mmio_addr = 0x9241008
[0000.829] I> skipped mmio_addr = 0x9241010
[0000.833] I> skipped mmio_addr = 0x9241018
[0000.837] I> skipped mmio_addr = 0x9241020
[0000.841] I> skipped mmio_addr = 0x9241028
[0000.845] I> skipped mmio_addr = 0x9241030
[0000.849] I> skipped mmio_addr = 0x9241038
[0000.853] I> skipped mmio_addr = 0x9241040
[0000.857] I> skipped mmio_addr = 0x9242000
[0000.861] I> skipped mmio_addr = 0x9242008
[0000.865] I> Task: Prod config init
[0000.868] I> Task: Pad voltage init
[0000.871] I> Task: Prod init
[0000.874] I> Task: Program rst req config reg
[0000.878] I> Task: Common rail init
[0000.882] I> DONE: Thermal config
[0000.886] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.894] I> DONE: SOC rail config
[0000.898] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0000.905] I> DONE: MEMIO rail config
[0000.908] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.
[0000.914] I> DONE: GPU rail info
[0000.918] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.
[0000.924] I> DONE: CV rail info
[0000.927] I> Task: Mem clock src
[0000.930] I> Task: Misc. board config
[0000.934] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0000.939] I> Task: SDRAM init
[0000.942] I> MemoryType: 4 MemBctRevision: 1
[0000.949] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 1
[0000.956] I> MSS CAR: Init PLLM
[0000.959] I> MSS CAR: Init PLLHUB
[0000.964] I> Encryption: MTS: en, TX: en, VPR: en, GSC: en
[0000.975] I> SDRAM initialized!
[0000.978] I> SDRAM Size in Total 0x200000000
[0000.982] I> Task: Dram Ecc scrub
[0000.986] I> Task: DRAM alias check
[0000.992] I> Task: Program NSDRAM carveout
[0000.996] I> NSDRAM carveout encryption is enabled
[0001.001] I> Program NSDRAM carveout
[0001.004] I> Task: Register checker
[0001.008] I> Task: Enable clock-mon
[0001.012] I> FMON: Fmon re-programming done
[0001.016] I> Task: Mapper init
[0001.019] I> Task: SC7 Context Init
[0001.022] I> Task: CCPLEX IST init
[0001.025] I> Task: CPU WP0
[0001.028] I> Loading MCE
[0001.031] I> Slot: 0
[0001.033] I> Binary[8] block-22784 (partition size: 0x80000)
[0001.038] I> Binary name: MCE
[0001.041] I> Size of crypto header is 8192
[0001.045] I> Size of crypto header is 8192
[0001.049] I> strt_pg_num(22784) num_of_pgs(16) read_buf(0x4003e000)
[0001.055] I> BCH of MCE read from storage
[0001.059] I> BCH address is : 0x4003e000
[0001.063] I> MCE header integrity check is success
[0001.067] I> Binary magic in BCH component 0 is MTSM
[0001.072] I> component binary type is 8
[0001.076] I> Size of crypto header is 8192
[0001.080] I> strt_pg_num(22800) num_of_pgs(350) read_buf(0x40000000)
[0001.088] I> MCE binary is read from storage
[0001.093] I> MCE binary integrity check is success
[0001.097] I> Binary MCE loaded successfully at 0x40000000 (0x2baf0)
[0001.103] I> Size of crypto header is 8192
[0001.114] I> Size of crypto header is 8192
[0001.118] I> Sending WP0 mailbox command to PSC
[0001.127] I> Task: XUSB Powergate
[0001.131] I> Skipping powergate XUSB.
[0001.134] I> Task: MB1 fixed firewalls
[0001.140] W> Firewall readback mismatch
[0001.145] I> Task: Load bpmp-fw
[0001.148] I> Slot: 0
[0001.150] I> Binary[15] block-9984 (partition size: 0x180000)
[0001.156] I> Binary name: BPMP_FW
[0001.159] I> Size of crypto header is 8192
[0001.163] I> Size of crypto header is 8192
[0001.167] I> strt_pg_num(9984) num_of_pgs(16) read_buf(0x807fe000)
[0001.173] I> BCH of BPMP_FW read from storage
[0001.177] I> BCH address is : 0x807fe000
[0001.181] I> BPMP_FW header integrity check is success
[0001.186] I> Binary magic in BCH component 0 is BPMF
[0001.191] I> component binary type is 15
[0001.195] I> Size of crypto header is 8192
[0001.199] I> strt_pg_num(10000) num_of_pgs(1990) read_buf(0x80000000)
[0001.216] I> BPMP_FW binary is read from storage
[0001.223] I> BPMP_FW binary integrity check is success
[0001.228] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xf8bc0)
[0001.234] I> Slot: 0
[0001.236] I> Binary[16] block-13056 (partition size: 0x400000)
[0001.242] I> Binary name: BPMP_FW_DTB
[0001.245] I> Size of crypto header is 8192
[0001.249] I> Size of crypto header is 8192
[0001.253] I> strt_pg_num(13056) num_of_pgs(16) read_buf(0x807fc000)
[0001.259] I> BCH of BPMP_FW_DTB read from storage
[0001.264] I> BCH address is : 0x807fc000
[0001.268] I> BPMP_FW_DTB header integrity check is success
[0001.273] I> Binary magic in BCH component 0 is BPMD
[0001.278] I> component binary type is 16
[0001.282] I> Size of crypto header is 8192
[0001.286] I> strt_pg_num(13072) num_of_pgs(384) read_buf(0x807cbff0)
[0001.294] I> BPMP_FW_DTB binary is read from storage
[0001.299] I> BPMP_FW_DTB binary integrity check is success
[0001.305] I> Binary BPMP_FW_DTB loaded successfully at 0x807cbff0 (0x2ff80)
[0001.311] I> Task: BPMP fw ast config
[0001.315] I> Task: Load psc-fw
[0001.318] I> Slot: 0
[0001.320] I> Binary[17] block-21248 (partition size: 0xc0000)
[0001.325] I> Binary name: PSC_FW
[0001.329] I> Size of crypto header is 8192
[0001.332] I> Size of crypto header is 8192
[0001.336] I> strt_pg_num(21248) num_of_pgs(16) read_buf(0x80ffe000)
[0001.343] I> BCH of PSC_FW read from storage
[0001.347] I> BCH address is : 0x80ffe000
[0001.351] I> PSC_FW header integrity check is success
[0001.356] I> Binary magic in BCH component 0 is PFWP
[0001.360] I> component binary type is 17
[0001.364] I> Size of crypto header is 8192
[0001.368] I> strt_pg_num(21264) num_of_pgs(591) read_buf(0x80fb4200)
[0001.378] I> PSC_FW binary is read from storage
[0001.383] I> PSC_FW binary integrity check is success
[0001.387] I> Binary PSC_FW loaded successfully at 0x80fb4200 (0x49df0)
[0001.394] I> Task: Load nvdec-fw
[0001.397] I> Slot: 0
[0001.399] I> Binary[7] block-6400 (partition size: 0x100000)
[0001.404] I> Binary name: NVDEC
[0001.407] I> Size of crypto header is 8192
[0001.411] I> Size of crypto header is 8192
[0001.415] I> strt_pg_num(6400) num_of_pgs(16) read_buf(0x800fe000)
[0001.421] I> BCH of NVDEC read from storage
[0001.426] I> BCH address is : 0x800fe000
[0001.429] I> NVDEC header integrity check is success
[0001.434] I> Binary magic in BCH component 0 is NDEC
[0001.439] I> component binary type is 7
[0001.443] I> Size of crypto header is 8192
[0001.447] I> strt_pg_num(6416) num_of_pgs(560) read_buf(0x80000000)
[0001.456] I> NVDEC binary is read from storage
[0001.461] I> NVDEC binary integrity check is success
[0001.466] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0001.472] I> Size of crypto header is 8192
[0001.483] I> Task: Load tsec-fw
[0001.486] I> TSEC-FW load support not enabled
[0001.490] I> Task: GPIO interrupt map
[0001.494] I> Task: SC7 context save
[0001.497] I> Slot: 0
[0001.499] I> Binary[27] block-0 (partition size: 0x100000)
[0001.505] I> Binary name: BR_BCT
[0001.508] I> Size of crypto header is 8192
[0001.512] I> Size of crypto header is 8192
[0001.516] I> Size of crypto header is 8192
[0001.520] I> strt_pg_num(0) num_of_pgs(16) read_buf(0xa0000000)
[0001.526] I> BR_BCT binary is read from storage
[0001.530] I> BR_BCT binary integrity check is success
[0001.535] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[0001.541] I> Slot: 0
[0001.543] I> Binary[13] block-23808 (partition size: 0x30000)
[0001.549] I> Binary name: SC7-FW
[0001.552] I> Size of crypto header is 8192
[0001.556] I> Size of crypto header is 8192
[0001.560] I> Size of crypto header is 8192
[0001.564] I> Size of crypto header is 8192
[0001.568] I> strt_pg_num(23808) num_of_pgs(16) read_buf(0xa0002000)
[0001.574] I> BCH of SC7-FW read from storage
[0001.578] I> BCH address is : 0xa0002000
[0001.582] I> SC7-FW header integrity check is success
[0001.587] I> Binary magic in BCH component 0 is WB0B
[0001.591] I> component binary type is 13
[0001.595] I> Size of crypto header is 8192
[0001.599] I> strt_pg_num(23824) num_of_pgs(349) read_buf(0xa0004000)
[0001.607] I> SC7-FW binary is read from storage
[0001.612] I> SC7-FW binary integrity check is success
[0001.617] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x2b920)
[0001.623] I> Slot: 0
[0001.625] I> Binary[22] block-24192 (partition size: 0x30000)
[0001.631] I> Binary name: PSC_RF
[0001.634] I> Size of crypto header is 8192
[0001.638] I> Size of crypto header is 8192
[0001.642] I> Size of crypto header is 8192
[0001.646] I> Size of crypto header is 8192
[0001.650] I> strt_pg_num(24192) num_of_pgs(16) read_buf(0xa002f920)
[0001.656] I> BCH of PSC_RF read from storage
[0001.660] I> BCH address is : 0xa002f920
[0001.664] I> PSC_RF header integrity check is success
[0001.669] I> Binary magic in BCH component 0 is PSCR
[0001.674] I> component binary type is 22
[0001.677] I> Size of crypto header is 8192
[0001.681] I> strt_pg_num(24208) num_of_pgs(224) read_buf(0xa0031920)
[0001.689] I> PSC_RF binary is read from storage
[0001.694] I> PSC_RF binary integrity check is success
[0001.698] I> Binary PSC_RF loaded successfully at 0xa0031920 (0x1be60)
[0001.708] I> Task: Save WP0 payload to SC7 ctx
[0001.712] I> Task: Load MB2rf binary to SC7 ctx
[0001.716] I> Slot: 0
[0001.718] I> Binary[14] block-24576 (partition size: 0x20000)
[0001.724] I> Binary name: MB2_RF
[0001.727] I> Size of crypto header is 8192
[0001.731] I> Size of crypto header is 8192
[0001.735] I> Size of crypto header is 8192
[0001.739] I> Size of crypto header is 8192
[0001.743] I> strt_pg_num(24576) num_of_pgs(16) read_buf(0xa00d5d10)
[0001.749] I> BCH of MB2_RF read from storage
[0001.753] I> BCH address is : 0xa00d5d10
[0001.757] I> MB2_RF header integrity check is success
[0001.762] I> Binary magic in BCH component 0 is MB2R
[0001.767] I> component binary type is 14
[0001.771] I> Size of crypto header is 8192
[0001.774] I> strt_pg_num(24592) num_of_pgs(224) read_buf(0xa00d7d10)
[0001.782] I> MB2_RF binary is read from storage
[0001.787] I> MB2_RF binary integrity check is success
[0001.792] I> Binary MB2_RF loaded successfully at 0xa00d7d10 (0x1bf30)
[0001.798] I> Task: Save fuse alias data to SC7 ctx
[0001.803] I> Task: Save PMIC data to SC7 ctx
[0001.807] I> Task: Save Pinmux data to SC7 ctx
[0001.811] I> Task: Save Pad Voltage data to SC7 ctx
[0001.816] I> Task: Save controller prod data to SC7 ctx
[0001.821] I> Task: Save prod cfg data to SC7 ctx
[0001.825] I> Task: Save I2C bus freq data to SC7 ctx
[0001.830] I> Task: Save SOCTherm data to SC7 ctx
[0001.834] I> Task: Save FMON data to SC7 ctx
[0001.839] I> Task: Save VMON data to SC7 ctx
[0001.843] I> Task: Save TZDRAM data to SC7 ctx
[0001.847] I> Task: Save GPIO int data to SC7 ctx
[0001.851] I> Task: Save clock data to SC7 ctx
[0001.856] I> Task: Save debug data to SC7 ctx
[0001.860] I> Task: Save MBWT data to SC7 ctx
[0001.868] I> SC7 context save done
[0001.871] I> Task: Load MB2/Applet/FSKP
[0001.875] I> Loading MB2
[0001.877] I> Slot: 0
[0001.879] I> Binary[6] block-8448 (partition size: 0x80000)
[0001.885] I> Binary name: MB2
[0001.887] I> Size of crypto header is 8192
[0001.891] I> Size of crypto header is 8192
[0001.895] I> strt_pg_num(8448) num_of_pgs(16) read_buf(0x8007e000)
[0001.901] I> BCH of MB2 read from storage
[0001.905] I> BCH address is : 0x8007e000
[0001.909] I> MB2 header integrity check is success
[0001.914] I> Binary magic in BCH component 0 is MB2B
[0001.919] I> component binary type is 6
[0001.922] I> Size of crypto header is 8192
[0001.926] I> strt_pg_num(8464) num_of_pgs(844) read_buf(0x80000000)
[0001.937] I> MB2 binary is read from storage
[0001.942] I> MB2 binary integrity check is success
[0001.947] I> Binary MB2 loaded successfully at 0x80000000 (0x696a0)
[0001.953] I> Task: Map CCPLEX SHARED carveout
[0001.957] I> Task: Prepare MB2 params
[0001.961] I> Task: Dram ecc test
[0001.964] I> Task: Misc NV security settings
[0001.968] I> NVDEC sticky bits programming done
[0001.973] I> Successfully powergated NVDEC
[0001.976] I> Task: Disable/Reload WDT
[0001.980] I> Task: Program misc carveouts
[0001.984] I> Program IPC carveouts
[0001.987] I> Task: Disable SCPM/POD reset
[0001.991] I> SLCG Global override status := 0x0
[0001.996] I> MB1: MSS reconfig completed
I> Emulation:
I> Entry timestamp: 0x001ee407
I> Unpowergate done
E> I2C: slave not found in slaves.
E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
E> I2C_DEV: Failed to send register address 0x00000000.
E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 0.
E> eeprom: Retry to read I2C slave device.
E> eeprom: Failed to read I2C slave device
C> Task 0x0 failed (err: 0x1f1e050d)
E> Top caller module: I2C_DEV, error module: I2C, reason: 0x0d, aux_info: 0x05
I> Busy Spin
是同一个Jetson核心板,I2C是在核心板上吗,我们如何定位问题?
