购买的一批orin nano 4g核心板,其中有几块在刷机后,无法正常启动.
日志如下:
[0000.065] I> MB1 (version: 1.4.0.4-t234-54845784-e89ea9bc)
[0000.071] I> t234-A01-1-Silicon (0x12347) Prod
[0000.075] I> Boot-mode : Coldboot |
[0000.078] I> Entry timestamp: 0x00000000 |
[0000.082] I> last_boot_error: 0x0 |
[0000.085] I> BR-BCT: preprod_dev_sign: 0
[0000.089] I> rst_source: 0x0, rst_level: 0x0
[0000.093] I> Task: SE error check |
[0000.096] I> Task: Bootchain select WAR set
[0000.100] I> Task: Enable SLCG
[0000.103] I> Task: CRC check
[0000.106] I> Task: Initialize MB2 params
[0000.110] I> MB2-params @ 0x40060000
[0000.113] I> Task: Crypto init
[0000.116] I> Task: Perform MB1 KAT tests
[0000.120] I> Task: NVRNG health check
[0000.124] I> NVRNG: Health check success
[0000.128] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.134] I> Task: Enabling and initialization of Bandwidth limiter
[0000.140] I> No request to configure MBWT settings for any PC!
[0000.145] I> Task: Secure debug controls
[0000.149] I> Task: strap war set
[0000.152] I> Task: Initialize SOC Therm
[0000.156] I> Task: Program NV master stream id
[0000.160] I> Task: Verify boot mode
[0000.166] I> Task: Alias fuses
[0000.169] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.176] I> Task: Print SKU typeOR | Minicom 2.8 | VT102 | 脱机 | ttyUSB0
[0000.180] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c8
[0000.185] I> FUSE_OPT_GPC_DISABLE = 0x00000002
[0000.189] I> FUSE_OPT_TPC_DISABLE = 0x000000fc
[0000.193] I> FUSE_OPT_DLA_DISABLE = 0x00000003
[0000.198] I> FUSE_OPT_PVA_DISABLE = 0x00000001
[0000.202] I> FUSE_OPT_NVENC_DISABLE = 0x00000001
[0000.206] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.211] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0000.215] I> FUSE_OPT_EMC_DISABLE = 0x0000000c
[0000.219] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.224] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.228] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.232] I> FUSE_SKU_INFO_0 = 0xd6
[0000.235] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.239] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.243] I> SKU: Prod
[0000.245] I> Task: Boost clocks
[0000.248] I> Initializing PLLC2 for AXI_CBB.
[0000.252] I> AXI_CBB : src = 35, divisor = 0
[0000.256] I> Task: Voltage monitor
[0000.260] I> VMON: Vmon re-calibration and fine tuning done
[0000.265] I> Task: UPHY init
[0000.270] I> HSIO UPHY init done
[0000.273] W> Skipping GBE UPHY config
[0000.276] I> Task: Boot device init
[0000.280] I> Boot_device: QSPI_FLASH instance: 0
[0000.284] I> Qspi clock source : pllc_out0
[0000.289] I> QSPI Flash: Macronix 64MB
[0000.292] I> QSPI-0l initialized successfully
[0000.296] I> Task: TSC init
[0000.299] I> Task: Load membct
[0000.302] I> RAM_CODE 0x4000451
[0000.305] I> Loading MEMBCT
[0000.308] I> Slot: 0
[0000.310] I> Binary[1] block-3840 (partition size: 0x40000)
[0000.315] I> Binary name: MEM-BCT-1
[0000.319] I> Size of crypto header is 8192
[0000.323] I> Size of crypto header is 8192
[0000.327] I> strt_pg_num(3840) num_of_pgs(16) read_buf(0x40050000)
[0000.333] I> BCH of MEM-BCT-1 read from storage
[0000.337] I> BCH address is : 0x40050000
[0000.341] I> MEM-BCT-1 header integrity check is success
[0000.346] I> Binary magic in BCH component 1 is MEM1
[0000.351] I> component binary type is 1
[0000.355] I> strt_pg_num(3971) num_of_pgs(115) read_buf(0x40040000)
[0000.362] I> MEM-BCT-1 binary is read from storage
[0000.366] I> MEM-BCT-1 binary integrity check is success
[0000.372] I> Binary MEM-BCT-1 loaded successfully at 0x40040000 (0xe580)
[0000.378] I> RAM_CODE 0x4000451
[0000.384] I> RAM_CODE 0x4000451
[0000.387] I> Task: Load Page retirement list
[0000.392] I> Task: SDRAM params override
[0000.395] I> Task: Save mem-bct info
[0000.399] I> Task: Carveout allocate
[0000.402] I> RCM blob carveout will not be allocated
[0000.407] I> Update CCPLEX IST carveout from MB1-BCT
[0000.412] I> ECC region[0]: Start:0x0, End:0x0
[0000.416] I> ECC region[1]: Start:0x0, End:0x0
[0000.420] I> ECC region[2]: Start:0x0, End:0x0
[0000.425] I> ECC region[3]: Start:0x0, End:0x0
[0000.429] I> ECC region[4]: Start:0x0, End:0x0
[0000.433] I> Non-ECC region[0]: Start:0x80000000, End:0x180000000
[0000.439] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.444] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.448] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.453] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.464] I> allocated(CO:43) base:0x17c000000 size:0x4000000 align: 0x200000
[0000.471] I> allocated(CO:39) base:0x179e00000 size:0x2200000 align: 0x10000
[0000.478] I> allocated(CO:20) base:0x176000000 size:0x2000000 align: 0x2000000
[0000.485] I> allocated(CO:24) base:0x174000000 size:0x2000000 align: 0x2000000
[0000.492] I> allocated(CO:28) base:0x172000000 size:0x2000000 align: 0x2000000
[0000.499] I> allocated(CO:22) base:0x178000000 size:0x1000000 align: 0x1000000
[0000.506] I> allocated(CO:35) base:0x179000000 size:0xe00000 align: 0x10000
[0000.513] I> allocated(CO:02) base:0x171800000 size:0x800000 align: 0x800000
[0000.520] I> allocated(CO:03) base:0x171000000 size:0x800000 align: 0x800000
[0000.527] I> allocated(CO:06) base:0x170800000 size:0x800000 align: 0x800000
[0000.534] I> allocated(CO:56) base:0x170000000 size:0x800000 align: 0x200000
[0000.541] I> allocated(CO:07) base:0x16fc00000 size:0x400000 align: 0x400000
[0000.548] I> allocated(CO:33) base:0x16f800000 size:0x400000 align: 0x200000
[0000.555] I> allocated(CO:23) base:0x16f600000 size:0x200000 align: 0x200000
[0000.562] I> allocated(CO:01) base:0x16f500000 size:0x100000 align: 0x100000
[0000.569] I> allocated(CO:05) base:0x16f400000 size:0x100000 align: 0x100000
[0000.576] I> allocated(CO:08) base:0x16f300000 size:0x100000 align: 0x100000
[0000.582] I> allocated(CO:09) base:0x16f200000 size:0x100000 align: 0x100000
[0000.589] I> allocated(CO:15) base:0x16f100000 size:0x100000 align: 0x100000
[0000.596] I> allocated(CO:17) base:0x16f000000 size:0x100000 align: 0x100000
[0000.603] I> allocated(CO:27) base:0x16ef00000 size:0x100000 align: 0x100000
[0000.610] I> allocated(CO:42) base:0x16ee00000 size:0x100000 align: 0x100000
[0000.617] I> allocated(CO:54) base:0x16ed80000 size:0x80000 align: 0x80000
[0000.624] I> allocated(CO:34) base:0x16ed70000 size:0x10000 align: 0x10000
[0000.631] I> allocated(CO:72) base:0x16eb70000 size:0x200000 align: 0x10000
[0000.638] I> allocated(CO:47) base:0x16e600000 size:0x400000 align: 0x200000
[0000.644] I> allocated(CO:48) base:0x16eb50000 size:0x20000 align: 0x10000
[0000.651] I> allocated(CO:69) base:0x16eb30000 size:0x20000 align: 0x10000
[0000.658] I> allocated(CO:49) base:0x16eb20000 size:0x10000 align: 0x10000
[0000.665] I> allocated(CO:50) base:0x16eb10000 size:0x10000 align: 0x10000
[0000.672] I> NSDRAM base: 0x80000000, end: 0x16eb70000, size: 0xeeb70000
[0000.678] I> Task: Thermal check
[0000.681] I> Using min_chip_limit as min_tmon_limit
[0000.686] I> Using max_chip_limit as max_tmon_limit
[0000.691] I> BCT max_tmon_limit = 105
[0000.694] I> BCT min_tmon_limit = -28
[0000.698] I> BCT max_tmon_limit = 105
[0000.701] I> BCT min_tmon_limit = -28
[0000.705] I> SKU specific max_chip_limit = 105
[0000.709] I> SKU specific min_chip_limit = -28
[0000.713] I> BCT max_chip_limit = 105
[0000.717] I> BCT min_chip_limit = -28
[0000.720] I> enable_soctherm_polling = 0
[0000.724] I> max temp read = 29
[0000.727] I> min temp read = 28
[0000.730] I> Enabling thermtrip
[0000.733] I> Task: Update FSI SCR with thermal fuse data
[0000.738] I> Task: Enable WDT 5th expiry
[0000.742] I> Task: I2C register
[0000.745] I> Task: Set I2C bus freq
[0000.748] I> Task: Reset FSI
[0000.751] I> Task: Pinmux init
[0000.754] I> skipped mmio_addr = 0x9240008
[0000.758] I> skipped mmio_addr = 0x9240000
[0000.762] I> skipped mmio_addr = 0x9240010
[0000.766] I> skipped mmio_addr = 0x9240018
[0000.770] I> skipped mmio_addr = 0x9240020
[0000.774] I> skipped mmio_addr = 0x9240030
[0000.778] I> skipped mmio_addr = 0x9240028
[0000.782] I> skipped mmio_addr = 0x9240038
[0000.786] I> skipped mmio_addr = 0x9240040
[0000.789] I> skipped mmio_addr = 0x9240048
[0000.793] I> skipped mmio_addr = 0x9241000
[0000.797] I> skipped mmio_addr = 0x9241008
[0000.801] I> skipped mmio_addr = 0x9241010
[0000.805] I> skipped mmio_addr = 0x9241018
[0000.809] I> skipped mmio_addr = 0x9241020
[0000.813] I> skipped mmio_addr = 0x9241028
[0000.817] I> skipped mmio_addr = 0x9241030
[0000.821] I> skipped mmio_addr = 0x9241038
[0000.825] I> skipped mmio_addr = 0x9241040
[0000.829] I> skipped mmio_addr = 0x9242000
[0000.833] I> skipped mmio_addr = 0x9242008
[0000.837] I> Task: Prod config init
[0000.840] I> Task: Pad voltage init
[0000.843] I> Task: Prod init
[0000.846] I> Task: Program rst req config reg
[0000.850] I> Task: Common rail init
[0000.854] I> DONE: Thermal config
[0000.858] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.866] I> DONE: SOC rail config
[0000.870] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0000.877] I> DONE: MEMIO rail config
[0000.880] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.
[0000.887] I> DONE: GPU rail info
[0000.890] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.
[0000.896] I> DONE: CV rail info
[0000.899] I> Task: Mem clock src
[0000.902] I> Task: Misc. board config
[0000.906] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0000.912] I> Task: SDRAM init
[0000.915] I> MemoryType: 4 MemBctRevision: 1
[0000.921] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 1
[0000.929] I> MSS CAR: Init PLLM
[0000.932] I> MSS CAR: Init PLLHUB
[0000.937] I> Encryption: MTS: en, TX: en, VPR: en, GSC: en
[0000.948] I> SDRAM initialized!
[0000.951] I> SDRAM Size in Total 0x100000000
[0000.955] I> Task: Dram Ecc scrub
[0000.958] I> Task: DRAM alias check
[0000.963] I> Task: Program NSDRAM carveout
[0000.967] I> NSDRAM carveout encryption is enabled
[0000.971] I> Program NSDRAM carveout
[0000.975] I> Task: Register checker
[0000.978] I> Task: Enable clock-mon
[0000.982] I> FMON: Fmon re-programming done
[0000.986] I> Task: Mapper init
[0000.989] I> Task: SC7 Context Init
[0000.993] I> Task: CCPLEX IST init
[0000.996] I> Task: CPU WP0
[0000.998] I> Loading MCE
[0001.001] I> Slot: 0
[0001.003] I> Binary[8] block-22784 (partition size: 0x80000)
[0001.008] I> Binary name: MCE
[0001.011] I> Size of crypto header is 8192
[0001.015] I> Size of crypto header is 8192
[0001.019] I> strt_pg_num(22784) num_of_pgs(16) read_buf(0x4003e000)
[0001.025] I> BCH of MCE read from storage
[0001.029] I> BCH address is : 0x4003e000
[0001.033] I> MCE header integrity check is success
[0001.038] I> Binary magic in BCH component 0 is MTSM
[0001.043] I> component binary type is 8
[0001.046] I> Size of crypto header is 8192
[0001.050] I> strt_pg_num(22800) num_of_pgs(357) read_buf(0x40000000)
[0001.058] I> MCE binary is read from storage
[0001.063] I> MCE binary integrity check is success
[0001.068] I> Binary MCE loaded successfully at 0x40000000 (0x2c880)
[0001.074] I> Size of crypto header is 8192
[0001.085] I> Size of crypto header is 8192
[0001.089] I> Sending WP0 mailbox command to PSC
[0001.098] I> Task: XUSB Powergate
[0001.101] I> Skipping powergate XUSB.
[0001.105] I> Task: MB1 fixed firewalls
[0001.111] W> Firewall readback mismatch
[0001.116] I> Task: Load bpmp-fw
[0001.119] I> Slot: 0
[0001.121] I> Binary[15] block-9984 (partition size: 0x180000)
[0001.126] I> Binary name: BPMP_FW
[0001.130] I> Size of crypto header is 8192
[0001.134] I> Size of crypto header is 8192
[0001.138] I> strt_pg_num(9984) num_of_pgs(16) read_buf(0x807fe000)
[0001.144] I> BCH of BPMP_FW read from storage
[0001.148] I> BCH address is : 0x807fe000
[0001.152] I> BPMP_FW header integrity check is success
[0001.157] I> Binary magic in BCH component 0 is BPMF
[0001.162] I> component binary type is 15
[0001.165] I> Size of crypto header is 8192
[0001.169] I> strt_pg_num(10000) num_of_pgs(1990) read_buf(0x80000000)
[0001.187] I> BPMP_FW binary is read from storage
[0001.193] I> BPMP_FW binary integrity check is success
[0001.198] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xf8bc0)
[0001.205] I> Slot: 0
[0001.207] I> Binary[16] block-13056 (partition size: 0x400000)
[0001.212] I> Binary name: BPMP_FW_DTB
[0001.216] I> Size of crypto header is 8192
[0001.220] I> Size of crypto header is 8192
[0001.224] I> strt_pg_num(13056) num_of_pgs(16) read_buf(0x807fc000)
[0001.230] I> BCH of BPMP_FW_DTB read from storage
[0001.234] I> BCH address is : 0x807fc000
[0001.238] I> BPMP_FW_DTB header integrity check is success
[0001.244] I> Binary magic in BCH component 0 is BPMD
[0001.248] I> component binary type is 16
[0001.252] I> Size of crypto header is 8192
[0001.256] I> strt_pg_num(13072) num_of_pgs(375) read_buf(0x807cd1f0)
[0001.264] I> BPMP_FW_DTB binary is read from storage
[0001.270] I> BPMP_FW_DTB binary integrity check is success
[0001.275] I> Binary BPMP_FW_DTB loaded successfully at 0x807cd1f0 (0x2ed00)
[0001.282] I> Task: BPMP fw ast config
[0001.285] I> Task: Load psc-fw
[0001.288] I> Slot: 0
[0001.290] I> Binary[17] block-21248 (partition size: 0xc0000)
[0001.296] I> Binary name: PSC_FW
[0001.299] I> Size of crypto header is 8192
[0001.303] I> Size of crypto header is 8192
[0001.307] I> strt_pg_num(21248) num_of_pgs(16) read_buf(0x80ffe000)
[0001.313] I> BCH of PSC_FW read from storage
[0001.317] I> BCH address is : 0x80ffe000
[0001.321] I> PSC_FW header integrity check is success
[0001.326] I> Binary magic in BCH component 0 is PFWP
[0001.331] I> component binary type is 17
[0001.335] I> Size of crypto header is 8192
[0001.338] I> strt_pg_num(21264) num_of_pgs(717) read_buf(0x80fa4600)
[0001.349] I> PSC_FW binary is read from storage
[0001.354] I> PSC_FW binary integrity check is success
[0001.359] I> Binary PSC_FW loaded successfully at 0x80fa4600 (0x59980)
[0001.365] I> Task: Load nvdec-fw
[0001.368] I> Slot: 0
[0001.370] I> Binary[7] block-6400 (partition size: 0x100000)
[0001.376] I> Binary name: NVDEC
[0001.379] I> Size of crypto header is 8192
[0001.383] I> Size of crypto header is 8192
[0001.387] I> strt_pg_num(6400) num_of_pgs(16) read_buf(0x800fe000)
[0001.393] I> BCH of NVDEC read from storage
[0001.397] I> BCH address is : 0x800fe000
[0001.401] I> NVDEC header integrity check is success
[0001.405] I> Binary magic in BCH component 0 is NDEC
[0001.410] I> component binary type is 7
[0001.414] I> Size of crypto header is 8192
[0001.418] I> strt_pg_num(6416) num_of_pgs(560) read_buf(0x80000000)
[0001.427] I> NVDEC binary is read from storage
[0001.432] I> NVDEC binary integrity check is success
[0001.437] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0001.443] I> Size of crypto header is 8192
[0001.454] I> Task: Load tsec-fw
[0001.457] I> TSEC-FW load support not enabled
[0001.462] I> Task: GPIO interrupt map
[0001.465] I> Task: SC7 context save
[0001.469] I> Slot: 0
[0001.471] I> Binary[27] block-0 (partition size: 0x100000)
[0001.476] I> Binary name: BR_BCT
[0001.479] I> Size of crypto header is 8192
[0001.483] I> Size of crypto header is 8192
[0001.487] I> Size of crypto header is 8192
[0001.491] I> strt_pg_num(0) num_of_pgs(16) read_buf(0xa0000000)
[0001.497] I> BR_BCT binary is read from storage
[0001.501] I> BR_BCT binary integrity check is success
[0001.506] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[0001.512] I> Slot: 0
[0001.514] I> Binary[13] block-23808 (partition size: 0x30000)
[0001.520] I> Binary name: SC7-FW
[0001.523] I> Size of crypto header is 8192
[0001.527] I> Size of crypto header is 8192
[0001.531] I> Size of crypto header is 8192
[0001.535] I> Size of crypto header is 8192
[0001.539] I> strt_pg_num(23808) num_of_pgs(16) read_buf(0xa0002000)
[0001.545] I> BCH of SC7-FW read from storage
[0001.549] I> BCH address is : 0xa0002000
[0001.553] I> SC7-FW header integrity check is success
[0001.558] I> Binary magic in BCH component 0 is WB0B
[0001.563] I> component binary type is 13
[0001.566] I> Size of crypto header is 8192
[0001.570] I> strt_pg_num(23824) num_of_pgs(349) read_buf(0xa0004000)
[0001.579] I> SC7-FW binary is read from storage
[0001.583] I> SC7-FW binary integrity check is success
[0001.588] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x2ba00)
[0001.595] I> Slot: 0
[0001.597] I> Binary[22] block-24192 (partition size: 0x30000)
[0001.602] I> Binary name: PSC_RF
[0001.605] I> Size of crypto header is 8192
[0001.609] I> Size of crypto header is 8192
[0001.613] I> Size of crypto header is 8192
[0001.617] I> Size of crypto header is 8192
[0001.621] I> strt_pg_num(24192) num_of_pgs(16) read_buf(0xa002fa00)
[0001.627] I> BCH of PSC_RF read from storage
[0001.631] I> BCH address is : 0xa002fa00
[0001.635] I> PSC_RF header integrity check is success
[0001.640] I> Binary magic in BCH component 0 is PSCR
[0001.645] I> component binary type is 22
[0001.649] I> Size of crypto header is 8192
[0001.653] I> strt_pg_num(24208) num_of_pgs(224) read_buf(0xa0031a00)
[0001.660] I> PSC_RF binary is read from storage
[0001.665] I> PSC_RF binary integrity check is success
[0001.670] I> Binary PSC_RF loaded successfully at 0xa0031a00 (0x1be60)
[0001.679] I> Task: Save WP0 payload to SC7 ctx
[0001.683] I> Task: Load MB2rf binary to SC7 ctx
[0001.688] I> Slot: 0
[0001.690] I> Binary[14] block-24576 (partition size: 0x20000)
[0001.695] I> Binary name: MB2_RF
[0001.698] I> Size of crypto header is 8192
[0001.702] I> Size of crypto header is 8192
[0001.706] I> Size of crypto header is 8192
[0001.710] I> Size of crypto header is 8192
[0001.714] I> strt_pg_num(24576) num_of_pgs(16) read_buf(0xa00d6aa0)
[0001.720] I> BCH of MB2_RF read from storage
[0001.725] I> BCH address is : 0xa00d6aa0
[0001.728] I> MB2_RF header integrity check is success
[0001.733] I> Binary magic in BCH component 0 is MB2R
[0001.738] I> component binary type is 14
[0001.742] I> Size of crypto header is 8192
[0001.746] I> strt_pg_num(24592) num_of_pgs(223) read_buf(0xa00d8aa0)
[0001.753] I> MB2_RF binary is read from storage
[0001.758] I> MB2_RF binary integrity check is success
[0001.763] I> Binary MB2_RF loaded successfully at 0xa00d8aa0 (0x1bcc0)
[0001.769] I> Task: Save fuse alias data to SC7 ctx
[0001.774] I> Task: Save PMIC data to SC7 ctx
[0001.778] I> Task: Save Pinmux data to SC7 ctx
[0001.782] I> Task: Save Pad Voltage data to SC7 ctx
[0001.787] I> Task: Save controller prod data to SC7 ctx
[0001.792] I> Task: Save prod cfg data to SC7 ctx
[0001.796] I> Task: Save I2C bus freq data to SC7 ctx
[0001.801] I> Task: Save SOCTherm data to SC7 ctx
[0001.806] I> Task: Save FMON data to SC7 ctx
[0001.810] I> Task: Save VMON data to SC7 ctx
[0001.814] I> Task: Save TZDRAM data to SC7 ctx
[0001.818] I> Task: Save GPIO int data to SC7 ctx
[0001.823] I> Task: Save clock data to SC7 ctx
[0001.827] I> Task: Save debug data to SC7 ctx
[0001.831] I> Task: Save MBWT data to SC7 ctx
[0001.839] I> SC7 context save done
[0001.842] I> Task: Load MB2/Applet/FSKP
[0001.846] I> Loading MB2
[0001.848] I> Slot: 0
[0001.850] I> Binary[6] block-8448 (partition size: 0x80000)
[0001.856] I> Binary name: MB2
[0001.859] I> Size of crypto header is 8192
[0001.863] I> Size of crypto header is 8192
[0001.867] I> strt_pg_num(8448) num_of_pgs(16) read_buf(0x8007e000)
[0001.873] I> BCH of MB2 read from storage
[0001.877] I> BCH address is : 0x8007e000
[0001.880] I> MB2 header integrity check is success
[0001.885] I> Binary magic in BCH component 0 is MB2B
[0001.890] I> component binary type is 6
[0001.894] I> Size of crypto header is 8192
[0001.897] I> strt_pg_num(8464) num_of_pgs(839) read_buf(0x80000000)
[0001.908] I> MB2 binary is read from storage
[0001.913] I> MB2 binary integrity check is success
[0001.918] I> Binary MB2 loaded successfully at 0x80000000 (0x68c10)
[0001.924] I> Task: Map CCPLEX SHARED carveout
[0001.928] I> Task: Prepare MB2 params
[0001.932] I> Task: Dram ecc test
[0001.935] I> Task: Misc NV security settings
[0001.939] I> NVDEC sticky bits programming done
[0001.944] I> Successfully powergated NVDEC
[0001.948] I> Task: Disable/Reload WDT
[0001.951] I> Task: Program misc carveouts
[0001.955] I> Program IPC carveouts
[0001.959] I> Task: Disable SCPM/POD reset
[0001.962] I> SLCG Global override status := 0x0
[0001.967] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-7f6f63a6)
I> Emulation:
I> Entry timestamp: 0x001e6f77
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0x170000000, size:0x800000]
I> Task: ARI update carveout TZDRAM (0x50002050)
I> Task: Check MC errors (0x5000204c)
I> Task: SMMU external bypass disable (0x500184fc)
I> Task: Enable hot-plug capability (0x50028dec)
I> Task: TZDRAM heap init (0x50019de0)
I> Task: PSC mailbox init (0x50018548)
I> Task: Crypto init (0x50006888)
I> Task: Enable GP-SE clock (0x500021b4)
I> Task: Measured Boot init (0x5001bd30)
I> Task: fTPM silicon identity init (0x5001bedc)
I> fTPM is not enabled.
I> Task: OEM SC7 context save init (0x5001b27c)
I> Task: I2C register (0x50002010)
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout (0x50001ff8)
I> Task: Program CBB PCIE AMAP regions (0x5001b9dc)
I> Task: Boot device init (0x50001f40)
I> Task: Partition Manager Init (0x50001f20)
I> Active chain: 0
I> Found 57 partitions in QSPI_FLASH (instance 0)
I> Task: Load and authenticate registered FWs (0x5001ed44)
I> Task: Load AUXP FWs (0x50028970)
I> Successfully register SPE FW load task with MB2 loader
I> Skipping SCE FW load
I> Successfully register RCE FW load task with MB2 loader
I> Successfully register DCE FW load task with MB2 loader
I> Unpowergating APE
I> Unpowergate done
I> Successfully register APE FW load task with MB2 loader
I> Skipping FSI FW load
I> Successfully register XUSB FW load task with MB2 loader
I> Active chain: 0
I> Partition name: A_spe-fw
I> Size of partition: 589824
I> Binary@ device:3/0 block-55040 (partition size: 0x90000), name: A_spe-fw
I> Active chain: 0
I> Partition name: A_rce-fw
I> Size of partition: 1048576
I> Binary@ device:3/0 block-56192 (partition size: 0x100000), name: A_rce-fw
I> spe: Authentication Finalize Done
I> Binary spe loaded successfully at 0x16f300000
I> Active chain: 0
I> Partition name: A_dce-fw
I> Size of partition: 5242880
I> Binary@ device:3/0 block-44800 (partition size: 0x500000), name: A_dce-fw
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0x16f000000
I> Successfully register RCE FW context save task with MB2 loader
I> dce : oem authentication of header done
I> dce : meta-blob integrity check is success.
I> dce : will be decompressed at 0x176000000
I> version 1 Bin 1 BCheckSum 0 content_size 0 Content ChkSum 1 reserved_00 0
I> Reserved10 0 BlockMaxSize 5 Reserved11 0
I> dce : decompressed to 9441408 bytes
I> dce: plain binary integrity check is success
I> Active chain: 0
I> Partition name: A_adsp-fw
I> Size of partition: 2097152
I> Binary@ device:3/0 block-58240 (partition size: 0x200000), name: A_adsp-fw
I> dce: Authentication Finalize Done
I> Binary dce loaded successfully at 0x176000000
I> Active chain: 0
I> Partition name: A_xusb-fw
I> Size of partition: 262144
I> Binary@ device:3/0 block-9472 (partition size: 0x40000), name: A_xusb-fw
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0x16fc00000
I> Successfully register APE FW context save task with MB2 loader
I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0x16f400000
I> Successfully register XUSB FW context save task with MB2 loader
I> Task: Carveout setup (0x500214d0)
I> Program remaining OEM carveouts
I> Task: Enable FSITHERM (0x500183cc)
I> Task: Enable FSI VMON (0x50017ec8)
I> Task: Validate FSI Therm readings (0x50017fac)
I> Task: Restore XUSB sec (0x50001ef4)
I> Task: Enable FSI SE clock (0x500189a4)
I> Task: Initialize SBSA UART CAR (0x50002118)
I> Task: Initialize CPUBL Params (0x50019990)
I> CPUBL-params @ 0x172000000
I> Task: Ratchet update (0x50029e88)
W> Skip ratchet update - OPTIN fuse not set
I> Task: Prepare eeprom data (0x5001975c)
I> Task: Revoke PKC fuse (0x50001d40)
I> PKC revoke fuse burn not requested
I> Task: FSI padctl context save (0x5001b558)
W> Skipping FSI padctl config save: fsi not enabled
I> Task: Unpowergate APE (0x5001910c)
W> mb2_unpowergate_ape: skip! APE is in unpowergated state
I> Task: OEM firewalls (0x500259e4)
I> OEM firewalls configured
I> Task: Powergate APE (0x50019280)
I> Powergating APE
I> Powergate done
I> Task: OEM firewall restore saved settings (0x50025e38)
I> Task: Unhalt AUXPs (0x50028bf4)
I> Unhalting SPE..
I> Enabling combined UART
spe: early_init
vic initialized
tsc initialized
aon lic initialized
spe: tag is 5243985d1b1eb3f06fac6d36bd7e74ac
spe: SafeRTOS v8.4
spe: init
scheduler initialized
aon hsp initialized
tag initialized
tcu initialized
bpmp ipc initialized
spe: late init
cpu_nic clock initialized
apb clock initialized
pm initialized
bpmp hsp initialized
top1 hsp initialized
ccplex ipc initialized
spe: start scheduler
I> Task: Trigger mailbox for PSC-BL1 exit (0x500185c8)
I> Sending opcode 0x4d420802 to psc
INFO: Entering psc_monitor_init!
INFO: GSC22 BOM:0x178002000 SIZE:0x1000000 CLIENT_ACCESS1:00180000
INFO: PSCFW BUILD VERSION: 8a33b23-73b589c-8a15f76-rel-t234
INFO: mstatus:0xa00000808
INFO: Supervisor entry_point:c108c00
I> Received ACK from psc
I> Tas INFO: MONITOR: user task addr:0x178022000, blob offset:0x00020000
INFO: MONITOR: populated user images:13
INFO: mret to Supervisor!
INFO: psc supervisor init.
INFO: psc_irq_init...
INFO: enter idle task.
hwwdt_init: WDT boot cfg 0x710010 sts 0x10
bpmp: socket 0
bpmp: base binary md5 is da583751bbfe2b7f6e204562d97ff39e
bpmp: combined binary md5 is e941463f35523d12ee540d9bc33bc02f
bpmp: firmware tag is e941463f35523d12ee54-da583751bbf
Control register check for CBB_CENTRAL_CBB_FIREWALL_MCB_BLF failed, expected value: 80030000 != actual value: 00000000 address: 13a159d0
Write control check for CBB_CENTRAL_CBB_FIREWALL_MCB_BLF failed, expected value: 0f18000b != actual value: 00000000 address: 13a159c8
initialized vwdt
initialized mail_early
initialized fuse
initialized vfrel
initialized adc
fmon_populate_monitors: found 199 monitors
initialized fmon
initialized mc
initialized reset
initialized uphy_early
initialized emc_early
initialized pm
465 clocks registered
initialized clk_mach
initialized clk_cal_early
initialized clk_mach_early_config
initialized io_dpd
initialized soctherm
initialized regime
initialized i2c
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
initialized vrmon
initialized regulator
initialized avfs_clk_platform
initialized powergate
initialized dvs
initialized clk_mach_config
initialized suspend
initialized strap
initialized mce_dbell
k: Start secure NOR provision (0x5001b7 initialized emc
initialized emc_mrq
f4)
I> Task: Load FSI keyblob ( initialized clk_cal
initialized uphy_dt
initialized uphy_mrq
HSIO UPHY reset has been de-asserted 0x0
initialized uphy
initialized pg_late
initialized pg_mrq_init
swdtimer_init: reg polling start w period 47 ms
initialized swdtimer
initialized hwwdt_late
initialized bwmgr
initialized thermal_host_trip
initialized thermal_mrq
initialized oc_mrq
initialized reset_mrq
initialized mail_mrq
initialized fmon_mrq
initialized clk_mrq
initialized avfs_mrq
initialized i2c_mrq
initialized tag_mrq
initialized bwmgr_mrq
initialized console_mrq
missing prod DT calibration data for 199 fmons
initialized clk_sync_fmon_post
0x500189ec)
I> Task: Unh initialized clk_cal_late
initialized noc_late
initialized cvc
alt AUXPs (0x50028bfc)
I> SCE initialized avfs_clk_mach_post
initialized avfs_clk_platform_post
initialized cvc_late
WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/2 have not matching zones 0/1
WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/3 have not matching zone list sizes 1/3
WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/3 have not matching zones 0/2
WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/0 have not matching zones 1/0
WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/3 have not matching zone list sizes 1/3
WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/3 have not matching zones 1/2
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/0 have not matching zone list sizes 3/1
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/0 have not matching zones 2/0
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/2 have not matching zone list sizes 3/1
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/2 have not matching zones 2/1
initialized rm
initialized console_late
handling unreferenced clks
enable can1_core
enable can1_host
enable can2_core
enable can2_host
enable pwm3
enable sdmmc4_axicif
enable mss_encrypt
enable maud
enable pllg_ref
enable dsi_core
enable aza_2xbit
enable xusb_ss
enable xusb_fs
enable xusb_falcon
enable xusb_core_mux
enable dsi_lp
clk_check_max_rate: pex1_c6_core rate 500000000 > max 250000000
clk_check_max_rate: pex2_c7_core rate 500000000 > max 250000000
clk_check_max_rate: pex2_c8_core rate 500000000 > max 250000000
clk_check_max_rate: pex2_c9_core rate 500000000 > max 250000000
clk_check_max_rate: pex2_c10_core rate 500000000 > max 250000000
clk_check_max_rate: pex0_c0_core rate 500000000 > max 250000000
clk_check_max_rate: pex0_c1_core rate 500000000 > max 250000000
clk_check_max_rate: pex0_c2_core rate 500000000 > max 250000000
clk_check_max_rate: pex0_c3_core rate 500000000 > max 250000000
clk_check_max_rate: pex0_c4_core rate 500000000 > max 250000000
clk_check_max_rate: pex1_c5_core rate 500000000 > max 250000000
initialized clk_mach_post
initialized pg_post
initialized regulator_post
initialized profile
initialized mrq
initialized patrol_scrubber
initialized cactmon
initialized extras_post
bpmp: init complete
unhalt skipped
I> Unhalting RCE
I> RCE unhalt success [ 2.706443] Camera-FW on t234-rce-safe started
TCU early console enabled.
ful
I> DCE unhalt successful
I> APE unhalt skipped
I> FSI unhalt skipped
I> Task: Load CPUBL (0x50019ab4)
I> Task: Load TOS (0x5001a244)
I> Active chain: 0
I> Partition name: A_cpu-bootloader
I> Size of partition: 3670016
I> Binary@ device:3/0 block-24832 (partition size: 0x380000), name: A_cpu-bootloader
E> HeaderMagi
[0000.070] I> t234-A01-1-Silicon (0x12347) Prod
[0000.074] I> Boot-mode : Coldboot
[0000.081] I> last_boot_error: 0x0
[0000.084] I> BR-BCT: preprod_dev_sign: 0
[0000.088] I> rst_source: 0xb, rst_level: 0x1
[0000.092] I> Task: SE error check
[0000.095] I> Task: Bootchain select WAR set
[0000.099] I> Task: Enable SLCG
[0000.102] I> Task: CRC check
[0000.105] I> Task: Initialize MB2 params
[0000.123] I> NVRNG: Health check success
[0000.127] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.133] I> Task: Enabling and initialization of Bandwidth limiter
[0000.139] I> No request to configure MBWT settings for any PC!
[0000.177] I> Task: Print SKU type
[0000.277] I> Task: Boot device init
[0000.285] I> Qspi clock source : pllc_out0
[0000.297] I> Task: TSC init
[0000.308] I> Slot: 1
[0000.310] I> Binary[1] block-66816 (partition size: 0x40000)
[0000.316] I> Binary name: MEM-BCT-1
[0000.327] I> strt_pg_num(66816) num_of_pgs(16) read_buf(0x40050000)
[0000.347] I> Binary magic in BCH component 1 is MEM1
[0000.355] I> strt_pg_num(66947) num_of_pgs(115) read_buf(0x40040000)
[0000.367] I> MEM-BCT-1 binary integrity check is success
[0000.379] I> RAM_CODE 0x4000451
[0000.388] I> Task: Load Page retirement list
[0000.396] I> Task: Save mem-bct info
[0000.403] I> RCM blob carveout will not be allocated
[0000.417] I> ECC region[1]: Start:0x0, End:0x0
[0000.421] I> ECC region[2]: Start:0x0, End:0x0
[0000.434] I> Non-ECC region[0]: Start:0x80000000, End:0x180000000
[0000.440] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.449] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.507] I> allocated(CO:35) base:0x179000000 size:0xe00000 align: 0x10000
[0000.583] I> allocated(CO:09) base:0x16f200000 size:0x100000 align: 0x100000
[0000.590] I> allocated(CO:15) base:0x16f100000 size:0x100000 align: 0x100000
[0000.597] I> allocated(CO:17) base:0x16f000000 size:0x100000 align: 0x100000
[0000.604] I> allocated(CO:27) base:0x16ef00000 size:0x100000 align: 0x100000
[0000.611] I> allocated(CO:42) base:0x16ee00000 size:0x100000 align: 0x100000
[0000.618] I> allocated(CO:54) base:0x16ed80000 size:0x80000 align: 0x80000
[0000.645] I> allocated(CO:48) base:0x16eb50000 size:0x20000 align: 0x10000
[0000.652] I> allocated(CO:69) base:0x16eb30000 size:0x20000 align: 0x10000
[0000.679] I> Task: Thermal check
[0000.682] I> Using min_chip_limit as min_tmon_limit
[0000.695] I> BCT min_tmon_limit = -28
[0000.714] I> BCT max_chip_limit = 105
[0000.721] I> enable_soctherm_polling = 0
[0000.727] I> min temp read = 29
[0000.790] I> skipped mmio_addr = 0x9240048
[0000.794] I> skipped mmio_addr = 0x9241000
[0000.798] I> skipped mmio_addr = 0x9241008
[0000.802] I> skipped mmio_addr = 0x9241010
[0000.806] I> skipped mmio_addr = 0x9241018
[0000.810] I> skipped mmio_addr = 0x9241020
[0000.814] I> skipped mmio_addr = 0x9241028
[0000.844] I> Task: Prod init
[0000.847] I> Task: Program rst req config reg
[0000.851] I> Task: Common rail init
[0000.876] I> DONE: MEMIO rail config
[0000.886] I> DONE: GPU rail info
[0000.889] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.
[0000.895] I> DONE: CV rail info
[0000.898] I> Task: Mem clock src
[0000.901] I> Task: Misc. board config
[0000.905] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0000.910] I> Task: SDRAM init
[0000.913] I> MemoryType: 4 MemBctRevision: 1
[0000.920] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 1
[0000.927] I> MSS CAR: Init PLLM
[0000.930] I> MSS CAR: Init PLLHUB
[0000.935] I> Encryption: MTS: en, TX: en, VPR: en, GSC: en
[0000.946] I> SDRAM initialized!
[0000.949] I> SDRAM Size in Total 0x100000000
[0000.953] I> Task: Dram Ecc scrub
[0000.956] I> Task: DRAM alias check
[0000.961] I> Task: Program NSDRAM carveout
[0000.965] I> NSDRAM carveout encryption is enabled
[0000.970] I> Program NSDRAM carveout
[0000.973] I> Task: Register checker
[0000.977] I> Task: Enable clock-mon
[0000.981] I> FMON: Fmon re-programming done
[0000.985] I> Task: Mapper init
[0000.988] I> Task: SC7 Context Init
[0000.991] I> Task: CCPLEX IST init
[0000.994] I> Task: CPU WP0
[0000.997] I> Loading MCE
[0000.999] I> Slot: 1
[0001.001] I> Binary[8] block-85760 (partition size: 0x80000)
[0001.007] I> Binary name: MCE
[0001.010] I> Size of crypto header is 8192
[0001.013] I> Size of crypto header is 8192
[0001.017] I> strt_pg_num(85760) num_of_pgs(16) read_buf(0x4003e000)
[0001.024] I> BCH of MCE read from storage
[0001.028] I> BCH address is : 0x4003e000
[0001.031] I> MCE header integrity check is success
[0001.036] I> Binary magic in BCH component 0 is MTSM
[0001.041] I> component binary type is 8
[0001.045] I> Size of crypto header is 8192
[0001.049] I> strt_pg_num(85776) num_of_pgs(357) read_buf(0x40000000)
[0001.057] I> MCE binary is read from storage
[0001.061] I> MCE binary integrity check is success
[0001.066] I> Binary MCE loaded successfully at 0x40000000 (0x2c880)
[0001.072] I> Size of crypto header is 8192
[0001.083] I> Size of crypto header is 8192
[0001.087] I> Sending WP0 mailbox command to PSC
[0001.096] I> Task: XUSB Powergate
[0001.099] I> Skipping powergate XUSB.
[0001.103] I> Task: MB1 fixed firewalls
[0001.109] W> Firewall readback mismatch
[0001.114] I> Task: Load bpmp-fw
[0001.117] I> Slot: 1
[0001.119] I> Binary[15] block-72960 (partition size: 0x180000)
[0001.125] I> Binary name: BPMP_FW
[0001.128] I> Size of crypto header is 8192
[0001.132] I> Size of crypto header is 8192
[0001.136] I> strt_pg_num(72960) num_of_pgs(16) read_buf(0x807fe000)
[0001.142] I> BCH of BPMP_FW read from storage
[0001.146] I> BCH address is : 0x807fe000
[0001.150] I> BPMP_FW header integrity check is success
[0001.155] I> Binary magic in BCH component 0 is BPMF
[0001.160] I> component binary type is 15
[0001.164] I> Size of crypto header is 8192
[0001.168] I> strt_pg_num(72976) num_of_pgs(1990) read_buf(0x80000000)
[0001.185] I> BPMP_FW binary is read from storage
[0001.192] I> BPMP_FW binary integrity check is success
[0001.197] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xf8bc0)
[0001.203] I> Slot: 1
[0001.205] I> Binary[16] block-76032 (partition size: 0x400000)
[0001.211] I> Binary name: BPMP_FW_DTB
[0001.214] I> Size of crypto header is 8192
[0001.218] I> Size of crypto header is 8192
[0001.222] I> strt_pg_num(76032) num_of_pgs(16) read_buf(0x807fc000)
[0001.229] I> BCH of BPMP_FW_DTB read from storage
[0001.233] I> BCH address is : 0x807fc000
[0001.237] I> BPMP_FW_DTB header integrity check is success
[0001.242] I> Binary magic in BCH component 0 is BPMD
[0001.247] I> component binary type is 16
[0001.251] I> Size of crypto header is 8192
[0001.255] I> strt_pg_num(76048) num_of_pgs(375) read_buf(0x807cd1f0)
[0001.263] I> BPMP_FW_DTB binary is read from storage
[0001.268] I> BPMP_FW_DTB binary integrity check is success
[0001.274] I> Binary BPMP_FW_DTB loaded successfully at 0x807cd1f0 (0x2ed00)
[0001.280] I> Task: BPMP fw ast config
[0001.284] I> Task: Load psc-fw
[0001.287] I> Slot: 1
[0001.289] I> Binary[17] block-84224 (partition size: 0xc0000)
[0001.295] I> Binary name: PSC_FW
[0001.298] I> Size of crypto header is 8192
[0001.302] I> Size of crypto header is 8192
[0001.305] I> strt_pg_num(84224) num_of_pgs(16) read_buf(0x80ffe000)
[0001.312] I> BCH of PSC_FW read from storage
[0001.316] I> BCH address is : 0x80ffe000
[0001.320] I> PSC_FW header integrity check is success
[0001.325] I> Binary magic in BCH component 0 is PFWP
[0001.329] I> component binary type is 17
[0001.333] I> Size of crypto header is 8192
[0001.337] I> strt_pg_num(84240) num_of_pgs(717) read_buf(0x80fa4600)
[0001.347] I> PSC_FW binary is read from storage
[0001.352] I> PSC_FW binary integrity check is success
[0001.357] I> Binary PSC_FW loaded successfully at 0x80fa4600 (0x59980)
[0001.364] I> Task: Load nvdec-fw
[0001.367] I> Slot: 1
[0001.369] I> Binary[7] block-69376 (partition size: 0x100000)
[0001.374] I> Binary name: NVDEC
[0001.377] I> Size of crypto header is 8192
[0001.381] I> Size of crypto header is 8192
[0001.385] I> strt_pg_num(69376) num_of_pgs(16) read_buf(0x800fe000)
[0001.392] I> BCH of NVDEC read from storage
[0001.396] I> BCH address is : 0x800fe000
[0001.399] I> NVDEC header integrity check is success
[0001.404] I> Binary magic in BCH component 0 is NDEC
[0001.409] I> component binary type is 7
[0001.413] I> Size of crypto header is 8192
[0001.417] I> strt_pg_num(69392) num_of_pgs(560) read_buf(0x80000000)
[0001.426] I> NVDEC binary is read from storage
[0001.431] I> NVDEC binary integrity check is success
[0001.436] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0001.442] I> Size of crypto header is 8192
[0001.453] I> Task: Load tsec-fw
[0001.456] I> TSEC-FW load support not enabled
[0001.460] I> Task: GPIO interrupt map
[0001.464] I> Task: SC7 context save
[0001.468] I> Slot: 1
[0001.470] I> Binary[27] block-0 (partition size: 0x100000)
[0001.475] I> Binary name: BR_BCT
[0001.478] I> Size of crypto header is 8192
[0001.482] I> Size of crypto header is 8192
[0001.486] I> Size of crypto header is 8192
[0001.490] I> strt_pg_num(0) num_of_pgs(16) read_buf(0xa0000000)
[0001.496] I> BR_BCT binary is read from storage
[0001.500] I> BR_BCT binary integrity check is success
[0001.505] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[0001.511] I> Slot: 1
[0001.513] I> Binary[13] block-86784 (partition size: 0x30000)
[0001.519] I> Binary name: SC7-FW
[0001.522] I> Size of crypto header is 8192
[0001.526] I> Size of crypto header is 8192
[0001.530] I> Size of crypto header is 8192
[0001.534] I> Size of crypto header is 8192
[0001.538] I> strt_pg_num(86784) num_of_pgs(16) read_buf(0xa0002000)
[0001.544] I> BCH of SC7-FW read from storage
[0001.548] I> BCH address is : 0xa0002000
[0001.552] I> SC7-FW header integrity check is success
[0001.557] I> Binary magic in BCH component 0 is WB0B
[0001.562] I> component binary type is 13
[0001.565] I> Size of crypto header is 8192
[0001.569] I> strt_pg_num(86800) num_of_pgs(349) read_buf(0xa0004000)
[0001.578] I> SC7-FW binary is read from storage
[0001.582] I> SC7-FW binary integrity check is success
[0001.587] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x2ba00)
[0001.594] I> Slot: 1
[0001.596] I> Binary[22] block-87168 (partition size: 0x30000)
[0001.601] I> Binary name: PSC_RF
[0001.604] I> Size of crypto header is 8192
[0001.608] I> Size of crypto header is 8192
[0001.612] I> Size of crypto header is 8192
[0001.616] I> Size of crypto header is 8192
[0001.620] I> strt_pg_num(87168) num_of_pgs(16) read_buf(0xa002fa00)
[0001.626] I> BCH of PSC_RF read from storage
[0001.630] I> BCH address is : 0xa002fa00
[0001.634] I> PSC_RF header integrity check is success
[0001.639] I> Binary magic in BCH component 0 is PSCR
[0001.644] I> component binary type is 22
[0001.648] I> Size of crypto header is 8192
[0001.652] I> strt_pg_num(87184) num_of_pgs(224) read_buf(0xa0031a00)
[0001.659] I> PSC_RF binary is read from storage
[0001.664] I> PSC_RF binary integrity check is success
[0001.669] I> Binary PSC_RF loaded successfully at 0xa0031a00 (0x1be60)
[0001.678] I> Task: Save WP0 payload to SC7 ctx
[0001.682] I> Task: Load MB2rf binary to SC7 ctx
[0001.687] I> Slot: 1
[0001.689] I> Binary[14] block-87552 (partition size: 0x20000)
[0001.694] I> Binary name: MB2_RF
[0001.697] I> Size of crypto header is 8192
[0001.701] I> Size of crypto header is 8192
[0001.705] I> Size of crypto header is 8192
[0001.709] I> Size of crypto header is 8192
[0001.713] I> strt_pg_num(87552) num_of_pgs(16) read_buf(0xa00d6aa0)
[0001.719] I> BCH of MB2_RF read from storage
[0001.723] I> BCH address is : 0xa00d6aa0
[0001.727] I> MB2_RF header integrity check is success
[0001.732] I> Binary magic in BCH component 0 is MB2R
[0001.737] I> component binary type is 14
[0001.741] I> Size of crypto header is 8192
[0001.745] I> strt_pg_num(87568) num_of_pgs(223) read_buf(0xa00d8aa0)
[0001.752] I> MB2_RF binary is read from storage
[0001.757] I> MB2_RF binary integrity check is success
[0001.762] I> Binary MB2_RF loaded successfully at 0xa00d8aa0 (0x1bcc0)
[0001.768] I> Task: Save fuse alias data to SC7 ctx
[0001.773] I> Task: Save PMIC data to SC7 ctx
[0001.777] I> Task: Save Pinmux data to SC7 ctx
[0001.781] I> Task: Save Pad Voltage data to SC7 ctx
[0001.786] I> Task: Save controller prod data to SC7 ctx
[0001.791] I> Task: Save prod cfg data to SC7 ctx
[0001.795] I> Task: Save I2C bus freq data to SC7 ctx
[0001.800] I> Task: Save SOCTherm data to SC7 ctx
[0001.805] I> Task: Save FMON data to SC7 ctx
[0001.809] I> Task: Save VMON data to SC7 ctx
[0001.813] I> Task: Save TZDRAM data to SC7 ctx
[0001.817] I> Task: Save GPIO int data to SC7 ctx
[0001.822] I> Task: Save clock data to SC7 ctx
[0001.826] I> Task: Save debug data to SC7 ctx
[0001.830] I> Task: Save MBWT data to SC7 ctx
[0001.838] I> SC7 context save done
[0001.841] I> Task: Load MB2/Applet/FSKP
[0001.845] I> Loading MB2
[0001.847] I> Slot: 1
[0001.849] I> Binary[6] block-71424 (partition size: 0x80000)
[0001.855] I> Binary name: MB2
[0001.858] I> Size of crypto header is 8192
[0001.862] I> Size of crypto header is 8192
[0001.866] I> strt_pg_num(71424) num_of_pgs(16) read_buf(0x8007e000)
[0001.872] I> BCH of MB2 read from storage
[0001.876] I> BCH address is : 0x8007e000
[0001.879] I> MB2 header integrity check is success
[0001.884] I> Binary magic in BCH component 0 is MB2B
[0001.889] I> component binary type is 6
[0001.893] I> Size of crypto header is 8192
[0001.897] I> strt_pg_num(71440) num_of_pgs(839) read_buf(0x80000000)
[0001.912] I> MB2 binary integrity check is success
[0001.917] I> Binary MB2 loaded successfully at 0x80000000 (0x68c10)
[0001.923] I> Task: Map CCPLEX SHARED carveout
[0001.927] I> Task: Prepare MB2 params
[0001.931] I> Task: Dram ecc test
[0001.934] I> Task: Misc NV security settings
[0001.943] I> Successfully powergated NVDEC
[0001.947] I> Task: Disable/Reload WDT
[0001.950] I> Task: Program misc carveouts
[0001.954] I> Program IPC carveouts
[0001.958] I> Task: Disable SCPM/POD reset
[0001.966] I> MB1: MSS reconfig completed
I> Emulation:
I> Entry timestamp: 0x001e6708
I> Active chain: 1
I> Unpowergate done
I> Active chain: 1
I> Partition name: B_spe-fw
I> Binary@ device:3/0 block-118016 (partition size: 0x90000), name: B_spe-fw
I> Active chain: 1
I> Partition name: B_rce-fw
I> Binary@ device:3/0 block-119168 (partition size: 0x100000), name: B_rce-fw
I> Active chain: 1
I> Partition name: B_dce-fw
I> Binary@ device:3/0 block-107776 (partition size: 0x500000), name: B_dce-fw
I> Active chain: 1
I> Partition name: B_adsp-fw
I> Binary@ device:3/0 block-121216 (partition size: 0x200000), name: B_adsp-fw
I> Active chain: 1
I> Partition name: B_xusb-fw
I> Binary@ device:3/0 block-72448 (partition size: 0x40000), name: B_xusb-fw
I> Powergating APE
I> Powergate done
I> Unhalting SPE..
spe: early_init
vic initialized
tsc initialized
aon lic initialized
spe: SafeRTOS v8.4
spe: init
aon hsp initialized
tag initialized
tcu initialized
spe: late init
pm initialized
bpmp: socket 0
initialized vwdt
initialized fuse
initialized vfrel
initialized adc
initialized fmon
initialized mc
initialized reset
initialized pm
initialized io_dpd
initialized regime
initialized i2c
initialized vrmon
initialized dvs
suspend progress: 0x80000000
initialized suspend
initialized strap
k: Start sec initialized emc
initialized emc_mrq
ure NOR provision (0x5001b7f4)
initialized clk_cal
initialized uphy_dt
initialized uphy
initialized pg_late
initialized bwmgr
initialized oc_mrq
initialized clk_mrq
initialized i2c_mrq
initialized tag_mrq
I> Task: Load FSI keyblob ( initialized clk_cal_late
initialized cvc
0x500189ec)
I> Task: Unhalt AU initialized avfs_clk_mach_post
initialized rm
enable can1_core
enable can1_host
enable can2_core
enable can2_host
enable pwm3
enable mss_encrypt
enable maud
enable pllg_ref
enable dsi_core
enable aza_2xbit
enable xusb_ss
enable xusb_fs
enable xusb_falcon
enable dsi_lp
initialized pg_post
initialized profile
initialized mrq
initialized cactmon
bpmp: init complete
XPs (0x50028bfc)
I> SCE unhalt skipped
I> Unhalting RCE
I> RCE unhalt success [ 2.704379] Camera-FW on t234-rce-safe started
ful
I> Task: Load CPUB
L (0x50019ab4)
I> Active chain: 1
I> Partition name: B_cpu-bootloader
I> Binary@ device:3/0 block-87808 (partition size: 0x380000), name: B_cpu-bootloader
E> HeaderMagi
