[0000.064] I> MB1 (version: 1.4.0.1-t234-54845784-08e631ca)
[0000.069] I> t234-A01-1-Silicon (0x12347) Prod
[0000.073] I> Boot-mode : Coldboot
[0000.076] I> Entry timestamp: 0x00000000
[0000.080] I> last_boot_error: 0x0
[0000.083] I> BR-BCT: preprod_dev_sign: 0
[0000.087] I> rst_source: 0x0, rst_level: 0x0
[0000.091] I> Task: SE error check
[0000.094] I> Task: Bootchain select WAR set
[0000.098] I> Task: Enable SLCG
[0000.101] I> Task: CRC check
[0000.104] I> Task: Initialize MB2 params
[0000.108] I> MB2-params @ 0x40060000
[0000.112] I> Task: Crypto init
[0000.115] I> Task: Perform MB1 KAT tests
[0000.119] I> Task: NVRNG health check
[0000.122] I> NVRNG: Health check success
[0000.126] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.132] I> Task: Enabling and initialization of Bandwidth limiter
[0000.138] I> No request to configure MBWT settings for any PC!
[0000.144] I> Task: Secure debug controls
[0000.147] I> Task: strap war set
[0000.151] I> Task: Initialize SOC Therm
[0000.154] I> Task: Program NV master stream id
[0000.159] I> Task: Verify boot mode
[0000.164] I> Task: Alias fuses
[0000.168] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.175] I> Task: Print SKU type
[0000.178] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c8
[0000.183] I> FUSE_OPT_GPC_DISABLE = 0x00000002
[0000.188] I> FUSE_OPT_TPC_DISABLE = 0x000000f0
[0000.192] I> FUSE_OPT_DLA_DISABLE = 0x00000003
[0000.196] I> FUSE_OPT_PVA_DISABLE = 0x00000001
[0000.200] I> FUSE_OPT_NVENC_DISABLE = 0x00000001
[0000.205] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.209] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0000.214] I> FUSE_OPT_EMC_DISABLE = 0x0000000c
[0000.218] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.222] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.226] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.230] I> FUSE_SKU_INFO_0 = 0xd5
[0000.234] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.238] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.241] I> SKU: Prod
[0000.243] I> Task: Boost clocks
[0000.246] I> Initializing PLLC2 for AXI_CBB.
[0000.251] I> AXI_CBB : src = 35, divisor = 0
[0000.255] I> Task: Voltage monitor
[0000.258] I> VMON: Vmon re-calibration and fine tuning done
[0000.264] I> Task: UPHY init
[0000.268] I> HSIO UPHY init done
[0000.271] W> Skipping GBE UPHY config
[0000.275] I> Task: Boot device init
[0000.278] I> Boot_device: QSPI_FLASH instance: 0
[0000.283] I> Qspi clock source : pllc_out0
[0000.287] I> QSPI Flash: Macronix 64MB
[0000.291] I> QSPI-0l initialized successfully
[0000.295] I> Task: TSC init
[0000.298] I> Task: Load membct
[0000.301] I> RAM_CODE 0x4000421
[0000.304] I> Loading MEMBCT
[0000.306] I> Slot: 0
[0000.308] I> Binary[0] block-3840 (partition size: 0x40000)
[0000.314] I> Binary name: MEM-BCT-0
[0000.317] I> Size of crypto header is 8192
[0000.321] I> Size of crypto header is 8192
[0000.325] I> strt_pg_num(3840) num_of_pgs(16) read_buf(0x40050000)
[0000.331] I> BCH of MEM-BCT-0 read from storage
[0000.336] I> BCH address is : 0x40050000
[0000.340] I> MEM-BCT-0 header integrity check is success
[0000.345] I> Binary magic in BCH component 0 is MEM0
[0000.349] I> component binary type is 0
[0000.353] I> strt_pg_num(3856) num_of_pgs(115) read_buf(0x40040000)
[0000.360] I> MEM-BCT-0 binary is read from storage
[0000.365] I> MEM-BCT-0 binary integrity check is success
[0000.370] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.377] I> RAM_CODE 0x4000421
[0000.382] I> RAM_CODE 0x4000421
[0000.386] I> Task: Load Page retirement list
[0000.390] I> Task: SDRAM params override
[0000.394] I> Task: Save mem-bct info
[0000.397] I> Task: Carveout allocate
[0000.401] I> RCM blob carveout will not be allocated
[0000.405] I> Update CCPLEX IST carveout from MB1-BCT
[0000.410] I> ECC region[0]: Start:0x0, End:0x0
[0000.415] I> ECC region[1]: Start:0x0, End:0x0
[0000.419] I> ECC region[2]: Start:0x0, End:0x0
[0000.423] I> ECC region[3]: Start:0x0, End:0x0
[0000.427] I> ECC region[4]: Start:0x0, End:0x0
[0000.432] I> Non-ECC region[0]: Start:0x80000000, End:0x280000000
[0000.438] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.442] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.447] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.451] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.462] I> allocated(CO:43) base:0x27c000000 size:0x4000000 align: 0x200000
[0000.469] I> allocated(CO:39) base:0x279e00000 size:0x2200000 align: 0x10000
[0000.476] I> allocated(CO:20) base:0x276000000 size:0x2000000 align: 0x2000000
[0000.483] I> allocated(CO:24) base:0x274000000 size:0x2000000 align: 0x2000000
[0000.490] I> allocated(CO:28) base:0x272000000 size:0x2000000 align: 0x2000000
[0000.498] I> allocated(CO:22) base:0x278000000 size:0x1000000 align: 0x1000000
[0000.505] I> allocated(CO:35) base:0x279000000 size:0xe00000 align: 0x10000
[0000.511] I> allocated(CO:02) base:0x271800000 size:0x800000 align: 0x800000
[0000.518] I> allocated(CO:03) base:0x271000000 size:0x800000 align: 0x800000
[0000.525] I> allocated(CO:06) base:0x270800000 size:0x800000 align: 0x800000
[0000.532] I> allocated(CO:56) base:0x270000000 size:0x800000 align: 0x200000
[0000.539] I> allocated(CO:07) base:0x26fc00000 size:0x400000 align: 0x400000
[0000.546] I> allocated(CO:33) base:0x26f800000 size:0x400000 align: 0x200000
[0000.553] I> allocated(CO:23) base:0x26f600000 size:0x200000 align: 0x200000
[0000.560] I> allocated(CO:01) base:0x26f500000 size:0x100000 align: 0x100000
[0000.567] I> allocated(CO:05) base:0x26f400000 size:0x100000 align: 0x100000
[0000.574] I> allocated(CO:08) base:0x26f300000 size:0x100000 align: 0x100000
[0000.581] I> allocated(CO:09) base:0x26f200000 size:0x100000 align: 0x100000
[0000.588] I> allocated(CO:15) base:0x26f100000 size:0x100000 align: 0x100000
[0000.595] I> allocated(CO:17) base:0x26f000000 size:0x100000 align: 0x100000
[0000.602] I> allocated(CO:27) base:0x26ef00000 size:0x100000 align: 0x100000
[0000.609] I> allocated(CO:42) base:0x26ee00000 size:0x100000 align: 0x100000
[0000.616] I> allocated(CO:54) base:0x26ed80000 size:0x80000 align: 0x80000
[0000.622] I> allocated(CO:34) base:0x26ed70000 size:0x10000 align: 0x10000
[0000.629] I> allocated(CO:72) base:0x26eb70000 size:0x200000 align: 0x10000
[0000.636] I> allocated(CO:47) base:0x26e600000 size:0x400000 align: 0x200000
[0000.643] I> allocated(CO:48) base:0x26eb50000 size:0x20000 align: 0x10000
[0000.650] I> allocated(CO:69) base:0x26eb30000 size:0x20000 align: 0x10000
[0000.656] I> allocated(CO:49) base:0x26eb20000 size:0x10000 align: 0x10000
[0000.663] I> allocated(CO:50) base:0x26eb10000 size:0x10000 align: 0x10000
[0000.670] I> NSDRAM base: 0x80000000, end: 0x26eb70000, size: 0x1eeb70000
[0000.677] I> Task: Thermal check
[0000.680] I> max_chip_limit = 105
[0000.683] I> min_chip_limit = -28
[0000.686] I> max temp read = 30
[0000.689] I> min temp read = 29
[0000.692] I> Task: Update FSI SCR with thermal fuse data
[0000.697] I> Task: Enable WDT 5th expiry
[0000.701] I> Task: I2C register
[0000.704] I> Task: Set I2C bus freq
[0000.707] I> Task: Reset FSI
[0000.710] I> Task: Pinmux init
[0000.713] I> skipped mmio_addr = 0x9240008
[0000.717] I> skipped mmio_addr = 0x9240000
[0000.721] I> skipped mmio_addr = 0x9240010
[0000.725] I> skipped mmio_addr = 0x9240018
[0000.729] I> skipped mmio_addr = 0x9240020
[0000.733] I> skipped mmio_addr = 0x9240030
[0000.737] I> skipped mmio_addr = 0x9240028
[0000.741] I> skipped mmio_addr = 0x9240038
[0000.745] I> skipped mmio_addr = 0x9240040
[0000.749] I> skipped mmio_addr = 0x9240048
[0000.753] I> skipped mmio_addr = 0x9241000
[0000.756] I> skipped mmio_addr = 0x9241008
[0000.760] I> skipped mmio_addr = 0x9241010
[0000.764] I> skipped mmio_addr = 0x9241018
[0000.768] I> skipped mmio_addr = 0x9241020
[0000.772] I> skipped mmio_addr = 0x9241028
[0000.776] I> skipped mmio_addr = 0x9241030
[0000.780] I> skipped mmio_addr = 0x9241038
[0000.784] I> skipped mmio_addr = 0x9241040
[0000.788] I> skipped mmio_addr = 0x9242000
[0000.792] I> skipped mmio_addr = 0x9242008
[0000.796] I> Task: Prod config init
[0000.799] I> Task: Pad voltage init
[0000.803] I> Task: Prod init
[0000.805] I> Task: Program rst req config reg
[0000.809] I> Task: Common rail init
[0000.813] I> DONE: Thermal config
[0000.817] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.825] I> DONE: SOC rail config
[0000.829] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0000.836] I> DONE: MEMIO rail config
[0000.840] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.
[0000.846] I> DONE: GPU rail info
[0000.850] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.
[0000.856] I> DONE: CV rail info
[0000.859] I> Task: Mem clock src
[0000.862] I> Task: Misc. board config
[0000.866] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0000.872] I> Task: SDRAM init
[0000.875] I> MemoryType: 4 MemBctRevision: 1
[0000.882] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 1
[0000.889] I> MSS CAR: Init PLLM
[0000.892] I> MSS CAR: Init PLLHUB
[0000.897] I> Encryption: MTS: en, TX: en, VPR: en, GSC: en
[0000.908] I> SDRAM initialized!
[0000.911] I> SDRAM Size in Total 0x200000000
[0000.915] I> Task: Dram Ecc scrub
[0000.918] I> Task: DRAM alias check
[0000.925] I> Task: Program NSDRAM carveout
[0000.929] I> NSDRAM carveout encryption is enabled
[0000.934] I> Program NSDRAM carveout
[0000.937] I> Task: Register checker
[0000.941] I> Task: Enable clock-mon
[0000.945] I> FMON: Fmon re-programming done
[0000.949] I> Task: Mapper init
[0000.952] I> Task: SC7 Context Init
[0000.955] I> Task: CCPLEX IST init
[0000.958] I> Task: CPU WP0
[0000.961] I> Loading MCE
[0000.963] I> Slot: 0
[0000.965] I> Binary[8] block-22784 (partition size: 0x80000)
[0000.971] I> Binary name: MCE
[0000.974] I> Size of crypto header is 8192
[0000.978] I> Size of crypto header is 8192
[0000.981] I> strt_pg_num(22784) num_of_pgs(16) read_buf(0x4003e000)
[0000.988] I> BCH of MCE read from storage
[0000.992] I> BCH address is : 0x4003e000
[0000.996] I> MCE header integrity check is success
[0001.000] I> Binary magic in BCH component 0 is MTSM
[0001.005] I> component binary type is 8
[0001.009] I> Size of crypto header is 8192
[0001.013] I> strt_pg_num(22800) num_of_pgs(357) read_buf(0x40000000)
[0001.021] I> MCE binary is read from storage
[0001.025] I> MCE binary integrity check is success
[0001.030] I> Binary MCE loaded successfully at 0x40000000 (0x2c880)
[0001.036] I> Size of crypto header is 8192
[0001.047] I> Size of crypto header is 8192
[0001.051] I> Sending WP0 mailbox command to PSC
[0001.060] I> Task: XUSB Powergate
[0001.063] I> Skipping powergate XUSB.
[0001.067] I> Task: MB1 fixed firewalls
[0001.073] W> Firewall readback mismatch
[0001.078] I> Task: Load bpmp-fw
[0001.081] I> Slot: 0
[0001.083] I> Binary[15] block-9984 (partition size: 0x180000)
[0001.089] I> Binary name: BPMP_FW
[0001.092] I> Size of crypto header is 8192
[0001.096] I> Size of crypto header is 8192
[0001.100] I> strt_pg_num(9984) num_of_pgs(16) read_buf(0x807fe000)
[0001.106] I> BCH of BPMP_FW read from storage
[0001.110] I> BCH address is : 0x807fe000
[0001.114] I> BPMP_FW header integrity check is success
[0001.119] I> Binary magic in BCH component 0 is BPMF
[0001.124] I> component binary type is 15
[0001.128] I> Size of crypto header is 8192
[0001.132] I> strt_pg_num(10000) num_of_pgs(1990) read_buf(0x80000000)
[0001.149] I> BPMP_FW binary is read from storage
[0001.156] I> BPMP_FW binary integrity check is success
[0001.161] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xf8bc0)
[0001.167] I> Slot: 0
[0001.169] I> Binary[16] block-13056 (partition size: 0x400000)
[0001.175] I> Binary name: BPMP_FW_DTB
[0001.178] I> Size of crypto header is 8192
[0001.182] I> Size of crypto header is 8192
[0001.186] I> strt_pg_num(13056) num_of_pgs(16) read_buf(0x807fc000)
[0001.192] I> BCH of BPMP_FW_DTB read from storage
[0001.197] I> BCH address is : 0x807fc000
[0001.201] I> BPMP_FW_DTB header integrity check is success
[0001.206] I> Binary magic in BCH component 0 is BPMD
[0001.211] I> component binary type is 16
[0001.215] I> Size of crypto header is 8192
[0001.219] I> strt_pg_num(13072) num_of_pgs(375) read_buf(0x807cd1f0)
[0001.227] I> BPMP_FW_DTB binary is read from storage
[0001.232] I> BPMP_FW_DTB binary integrity check is success
[0001.237] I> Binary BPMP_FW_DTB loaded successfully at 0x807cd1f0 (0x2ed00)
[0001.244] I> Task: BPMP fw ast config
[0001.248] I> Task: Load psc-fw
[0001.251] I> Slot: 0
[0001.253] I> Binary[17] block-21248 (partition size: 0xc0000)
[0001.258] I> Binary name: PSC_FW
[0001.261] I> Size of crypto header is 8192
[0001.265] I> Size of crypto header is 8192
[0001.269] I> strt_pg_num(21248) num_of_pgs(16) read_buf(0x80ffe000)
[0001.276] I> BCH of PSC_FW read from storage
[0001.280] I> BCH address is : 0x80ffe000
[0001.283] I> PSC_FW header integrity check is success
[0001.288] I> Binary magic in BCH component 0 is PFWP
[0001.293] I> component binary type is 17
[0001.297] I> Size of crypto header is 8192
[0001.301] I> strt_pg_num(21264) num_of_pgs(717) read_buf(0x80fa4600)
[0001.311] I> PSC_FW binary is read from storage
[0001.316] I> PSC_FW binary integrity check is success
[0001.321] I> Binary PSC_FW loaded successfully at 0x80fa4600 (0x59980)
[0001.328] I> Task: Load nvdec-fw
[0001.331] I> Slot: 0
[0001.333] I> Binary[7] block-6400 (partition size: 0x100000)
[0001.338] I> Binary name: NVDEC
[0001.341] I> Size of crypto header is 8192
[0001.345] I> Size of crypto header is 8192
[0001.349] I> strt_pg_num(6400) num_of_pgs(16) read_buf(0x800fe000)
[0001.355] I> BCH of NVDEC read from storage
[0001.359] I> BCH address is : 0x800fe000
[0001.363] I> NVDEC header integrity check is success
[0001.368] I> Binary magic in BCH component 0 is NDEC
[0001.373] I> component binary type is 7
[0001.376] I> Size of crypto header is 8192
[0001.380] I> strt_pg_num(6416) num_of_pgs(560) read_buf(0x80000000)
[0001.390] I> NVDEC binary is read from storage
[0001.394] I> NVDEC binary integrity check is success
[0001.399] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0001.405] I> Size of crypto header is 8192
[0001.417] I> Task: Load tsec-fw
[0001.420] I> TSEC-FW load support not enabled
[0001.424] I> Task: GPIO interrupt map
[0001.428] I> Task: SC7 context save
[0001.431] I> Slot: 0
[0001.433] I> Binary[27] block-0 (partition size: 0x100000)
[0001.438] I> Binary name: BR_BCT
[0001.441] I> Size of crypto header is 8192
[0001.445] I> Size of crypto header is 8192
[0001.449] I> Size of crypto header is 8192
[0001.453] I> strt_pg_num(0) num_of_pgs(16) read_buf(0xa0000000)
[0001.459] I> BR_BCT binary is read from storage
[0001.464] I> BR_BCT binary integrity check is success
[0001.468] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[0001.475] I> Slot: 0
[0001.477] I> Binary[13] block-23808 (partition size: 0x30000)
[0001.482] I> Binary name: SC7-FW
[0001.485] I> Size of crypto header is 8192
[0001.489] I> Size of crypto header is 8192
[0001.493] I> Size of crypto header is 8192
[0001.497] I> Size of crypto header is 8192
[0001.501] I> strt_pg_num(23808) num_of_pgs(16) read_buf(0xa0002000)
[0001.507] I> BCH of SC7-FW read from storage
[0001.512] I> BCH address is : 0xa0002000
[0001.515] I> SC7-FW header integrity check is success
[0001.520] I> Binary magic in BCH component 0 is WB0B
[0001.525] I> component binary type is 13
[0001.529] I> Size of crypto header is 8192
[0001.533] I> strt_pg_num(23824) num_of_pgs(347) read_buf(0xa0004000)
[0001.541] I> SC7-FW binary is read from storage
[0001.546] I> SC7-FW binary integrity check is success
[0001.551] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x2b440)
[0001.557] I> Slot: 0
[0001.559] I> Binary[22] block-24192 (partition size: 0x30000)
[0001.565] I> Binary name: PSC_RF
[0001.568] I> Size of crypto header is 8192
[0001.572] I> Size of crypto header is 8192
[0001.576] I> Size of crypto header is 8192
[0001.579] I> Size of crypto header is 8192
[0001.583] I> strt_pg_num(24192) num_of_pgs(16) read_buf(0xa002f440)
[0001.590] I> BCH of PSC_RF read from storage
[0001.594] I> BCH address is : 0xa002f440
[0001.598] I> PSC_RF header integrity check is success
[0001.602] I> Binary magic in BCH component 0 is PSCR
[0001.607] I> component binary type is 22
[0001.611] I> Size of crypto header is 8192
[0001.615] I> strt_pg_num(24208) num_of_pgs(224) read_buf(0xa0031440)
[0001.623] I> PSC_RF binary is read from storage
[0001.627] I> PSC_RF binary integrity check is success
[0001.632] I> Binary PSC_RF loaded successfully at 0xa0031440 (0x1be60)
[0001.641] I> Task: Save WP0 payload to SC7 ctx
[0001.646] I> Task: Load MB2rf binary to SC7 ctx
[0001.650] I> Slot: 0
[0001.652] I> Binary[14] block-24576 (partition size: 0x20000)
[0001.658] I> Binary name: MB2_RF
[0001.661] I> Size of crypto header is 8192
[0001.665] I> Size of crypto header is 8192
[0001.669] I> Size of crypto header is 8192
[0001.673] I> Size of crypto header is 8192
[0001.676] I> strt_pg_num(24576) num_of_pgs(16) read_buf(0xa00d6aa0)
[0001.683] I> BCH of MB2_RF read from storage
[0001.687] I> BCH address is : 0xa00d6aa0
[0001.691] I> MB2_RF header integrity check is success
[0001.696] I> Binary magic in BCH component 0 is MB2R
[0001.700] I> component binary type is 14
[0001.704] I> Size of crypto header is 8192
[0001.708] I> strt_pg_num(24592) num_of_pgs(224) read_buf(0xa00d8aa0)
[0001.716] I> MB2_RF binary is read from storage
[0001.720] I> MB2_RF binary integrity check is success
[0001.725] I> Binary MB2_RF loaded successfully at 0xa00d8aa0 (0x1bfc0)
[0001.732] I> Task: Save fuse alias data to SC7 ctx
[0001.736] I> Task: Save PMIC data to SC7 ctx
[0001.740] I> Task: Save Pinmux data to SC7 ctx
[0001.745] I> Task: Save Pad Voltage data to SC7 ctx
[0001.749] I> Task: Save controller prod data to SC7 ctx
[0001.754] I> Task: Save prod cfg data to SC7 ctx
[0001.759] I> Task: Save I2C bus freq data to SC7 ctx
[0001.764] I> Task: Save SOCTherm data to SC7 ctx
[0001.768] I> Task: Save FMON data to SC7 ctx
[0001.772] I> Task: Save VMON data to SC7 ctx
[0001.776] I> Task: Save TZDRAM data to SC7 ctx
[0001.781] I> Task: Save GPIO int data to SC7 ctx
[0001.785] I> Task: Save clock data to SC7 ctx
[0001.789] I> Task: Save debug data to SC7 ctx
[0001.793] I> Task: Save MBWT data to SC7 ctx
[0001.801] I> SC7 context save done
[0001.805] I> Task: Load MB2/Applet/FSKP
[0001.808] I> Loading MB2
[0001.811] I> Slot: 0
[0001.813] I> Binary[6] block-8448 (partition size: 0x80000)
[0001.818] I> Binary name: MB2
[0001.821] I> Size of crypto header is 8192
[0001.825] I> Size of crypto header is 8192
[0001.829] I> strt_pg_num(8448) num_of_pgs(16) read_buf(0x8007e000)
[0001.835] I> BCH of MB2 read from storage
[0001.839] I> BCH address is : 0x8007e000
[0001.843] I> MB2 header integrity check is success
[0001.847] I> Binary magic in BCH component 0 is MB2B
[0001.852] I> component binary type is 6
[0001.856] I> Size of crypto header is 8192
[0001.860] I> strt_pg_num(8464) num_of_pgs(838) read_buf(0x80000000)
[0001.871] I> MB2 binary is read from storage
[0001.876] I> MB2 binary integrity check is success
[0001.880] I> Binary MB2 loaded successfully at 0x80000000 (0x68b10)
[0001.886] I> Task: Map CCPLEX SHARED carveout
[0001.891] I> Task: Prepare MB2 params
[0001.894] I> Task: Dram ecc test
[0001.897] I> Task: Misc NV security settings
[0001.902] I> NVDEC sticky bits programming done
[0001.906] I> Successfully powergated NVDEC
[0001.910] I> Task: Disable/Reload WDT
[0001.914] I> Task: Program misc carveouts
[0001.917] I> Program IPC carveouts
[0001.921] I> Task: Disable SCPM/POD reset
[0001.925] I> SLCG Global override status := 0x0
[0001.929] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-934581f8)
I> Emulation:
I> Entry timestamp: 0x001dd7f2
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0x270000000, size:0x800000]
I> Task: ARI update carveout TZDRAM (0x50002050)
I> Task: Check MC errors (0x5000204c)
I> Task: Enable hot-plug capability (0x500290f8)
I> Task: TZDRAM heap init (0x5001a0fc)
I> Task: PSC mailbox init (0x50018864)
I> Task: Crypto init (0x50006874)
I> Task: Enable GP-SE clock (0x500021b4)
I> Task: Measured Boot init (0x5001c04c)
I> Task: fTPM silicon identity init (0x5001c1f8)
I> fTPM is not enabled.
I> Task: OEM SC7 context save init (0x5001b598)
I> Task: I2C register (0x50002010)
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout (0x50001ff8)
I> Task: Program CBB PCIE AMAP regions (0x5001bcf8)
I> Task: Boot device init (0x50001f40)
I> Task: Partition Manager Init (0x50001f20)
I> Active chain: 0
I> Found 57 partitions in QSPI_FLASH (instance 0)
I> Task: Load and authenticate registered FWs (0x5001f064)
I> Task: Load AUXP FWs (0x50028c7c)
I> Successfully register SPE FW load task with MB2 loader
I> Skipping SCE FW load
I> Successfully register RCE FW load task with MB2 loader
I> Successfully register DCE FW load task with MB2 loader
I> Unpowergating APE
I> Unpowergate done
I> Successfully register APE FW load task with MB2 loader
I> Skipping FSI FW load
I> Successfully register XUSB FW load task with MB2 loader
I> Active chain: 0
I> Partition name: A_spe-fw
I> Size of partition: 589824
I> Binary@ device:3/0 block-55040 (partition size: 0x90000), name: A_spe-fw
I> Active chain: 0
I> Partition name: A_rce-fw
I> Size of partition: 1048576
I> Binary@ device:3/0 block-56192 (partition size: 0x100000), name: A_rce-fw
I> spe: Authentication Finalize Done
I> Binary spe loaded successfully at 0x26f300000
I> Active chain: 0
I> Partition name: A_dce-fw
I> Size of partition: 5242880
I> Binary@ device:3/0 block-44800 (partition size: 0x500000), name: A_dce-fw
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0x26f000000
I> Successfully register RCE FW context save task with MB2 loader
I> dce : oem authentication of header done
I> dce : meta-blob integrity check is success.
I> dce : will be decompressed at 0x276000000
I> version 1 Bin 1 BCheckSum 0 content_size 0 Content ChkSum 1 reserved_00 0
I> Reserved10 0 BlockMaxSize 5 Reserved11 0
I> dce : decompressed to 9449600 bytes
I> dce: plain binary integrity check is success
I> Active chain: 0
I> Partition name: A_adsp-fw
I> Size of partition: 2097152
I> Binary@ device:3/0 block-58240 (partition size: 0x200000), name: A_adsp-fw
I> dce: Authentication Finalize Done
I> Binary dce loaded successfully at 0x276000000
I> Active chain: 0
I> Partition name: A_xusb-fw
I> Size of partition: 262144
I> Binary@ device:3/0 block-9472 (partition size: 0x40000), name: A_xusb-fw
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0x26fc00000
I> Successfully register APE FW context save task with MB2 loader
I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0x26f400000
I> Successfully register XUSB FW context save task with MB2 loader
I> Task: Carveout setup (0x500217e4)
I> Program remaining OEM carveouts
I> Task: Enable FSITHERM (0x50018738)
I> Task: Enable FSI VMON (0x50018234)
I> Task: Validate FSI Therm readings (0x50018318)
I> Task: Restore XUSB sec (0x50001ef4)
I> Task: Enable FSI SE clock (0x50018cc0)
I> Task: Initialize SBSA UART CAR (0x50002118)
I> Task: Initialize CPUBL Params (0x50019cac)
I> CPUBL-params @ 0x272000000
I> Task: Ratchet update (0x5002a194)
W> Skip ratchet update - OPTIN fuse not set
I> Task: Prepare eeprom data (0x50019a78)
I> Task: Revoke PKC fuse (0x50001d40)
I> PKC revoke fuse burn not requested
I> Task: FSI padctl context save (0x5001b874)
W> Skipping FSI padctl config save: fsi not enabled
I> Task: Unpowergate APE (0x50019428)
W> mb2_unpowergate_ape: skip! APE is in unpowergated state
I> Task: OEM firewalls (0x50025cf0)
I> OEM firewalls configured
I> Task: Powergate APE (0x5001959c)
I> Powergating APE
I> Powergate done
I> Task: OEM firewall restore saved settings (0x50026144)
I> Task: Unhalt AUXPs (0x50028f00)
I> Unhalting SPE…
I> Enabling combined UART
����spe: early_init
����vic initialized
����tsc initialized
����aon lic initialized
����spe: tag is 5243985d1b1eb3f06fac6d36bd7e74ac
����spe: SafeRTOS v8.4
����spe: init
����scheduler initialized
����aon hsp initialized
����tag initialized
����tcu initialized
����bpmp ipc initialized
����spe: late init
����cpu_nic clock initialized
����apb clock initialized
����pm initialized
����bpmp hsp initialized
����top1 hsp initialized
����ccplex ipc initialized
����spe: start scheduler
I> Task: Trigger mailbox for PSC-BL1 exit (0x500188e4)
I> Sending opcode 0x4d420802 to psc
��INFO: Entering psc_monitor_init!
INFO: GSC22 BOM:0x278002000 SIZE:0x1000000 CLIENT_ACCESS1:00180000
INFO: PSCFW BUILD VERSION: 8a33b23-73b589c-8a15f76-rel-t234
INFO: mstatus:0xa00000808
INFO: Supervisor entry_point:c108c00
��I> Received ACK from psc
I> Tas��INFO: MONITOR: user task addr:0x278022000, blob offset:0x00020000
INFO: MONITOR: populated user images:13
INFO: mret to Supervisor!
INFO: psc supervisor init.
INFO: psc_irq_init…
INFO: enter idle task.
hwwdt_init: WDT boot cfg 0x710010 sts 0x10
bpmp: socket 0
bpmp: base binary md5 is fcc6f4f897ab64a32c3de470c48f0036
bpmp: combined binary md5 is 3c848c2f90df80c584289bcb9a674eb3
bpmp: firmware tag is 3c848c2f90df80c58428-fcc6f4f897a
Control register check for CBB_CENTRAL_CBB_FIREWALL_MCB_BLF failed, expected value: 80030000 != actual value: 00000000 address: 13a159d0
Write control check for CBB_CENTRAL_CBB_FIREWALL_MCB_BLF failed, expected value: 0f18000b != actual value: 00000000 address: 13a159c8
Write control check for CBB_CENTRAL_CBB_FIREWALL_PWM7_BLF failed, expected value: 00100008 != actual value: 0010000a address: 13a178a8
initialized vwdt
initialized mail_early
initialized fuse
initialized vfrel
initialized adc
fmon_populate_monitors: found 199 monitors
initialized fmon
initialized mc
initialized reset
initialized uphy_early
initialized emc_early
initialized pm
465 clocks registered
initialized clk_mach
initialized clk_cal_early
initialized clk_mach_early_config
initialized io_dpd
initialized soctherm
initialized regime
initialized i2c
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
initialized vrmon
initialized regulator
initialized avfs_clk_platform
initialized powergate
initialized dvs
initialized clk_mach_config
initialized suspend
initialized strap
initialized mce_dbell
��k: Start secure NOR provision (0x5001bb10)
I> Task: Load FSI keyblob (��initialized emc
initialized emc_mrq
��0x50018d08)
I> Task: Unhalt AUXPs (0��initialized clk_cal
initialized uphy_dt
initialized uphy_mrq
HSIO UPHY reset has been de-asserted 0x0
initialized uphy
initialized pg_late
initialized pg_mrq_init
swdtimer_init: reg polling start w period 47 ms
initialized swdtimer
initialized hwwdt_late
initialized bwmgr
initialized thermal_host_trip
initialized thermal_mrq
initialized oc_mrq
initialized reset_mrq
initialized mail_mrq
initialized fmon_mrq
initialized clk_mrq
initialized avfs_mrq
initialized i2c_mrq
initialized tag_mrq
initialized bwmgr_mrq
initialized console_mrq
missing prod DT calibration data for 199 fmons
initialized clk_sync_fmon_post
��x50028f08)
I> SCE unhalt skipped��initialized clk_cal_late
initialized noc_late
initialized cvc
I> Unhalting RCE
I> RCE unhal��initialized avfs_clk_mach_post
initialized avfs_clk_platform_post
��[ 2.453194] Camer��initialized cvc_late
WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/2 have not matching zones ��a-FW on t234-rce-safe started
TCU early console enable��0/1
WARNING @ [platf��d.
��orm/drivers/rm/rm.c]: shared rails 0/3 have not matching zone list sizes 1/3
WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/3 have not matching zones 0/2
WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/0 have not matching zones 1/0
WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/3 have not matching zone list sizes 1/3
WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/3 have not matching zones 1/2
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/0 have not matching zone list sizes 3/1
WARNING @ [platform/drivers/rm/r]: shared rails 3/0 have not matching zones 2/0
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/2 have not matching zone list sizes 3/1
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/2 have not matching zones 2/1
initialized rm
initialized console_late
handling unreferenced clks
enable can1_core
enable can1_host
enable can2_core
enable can2_host
enable pwm3
enable sdmmc4_axicif
enable mss_encrypt
enable maud
enable pllg_ref
enable dsi_core
enable aza_2xbit
enable xusb_ss
enable xusb_fs
enable xusb_falcon
enable xusb_core_mux
enable dsi_lp
clk_check_max_rate: pex1_c6_core rate 500000000 > max 250000000
clk_check_max_rate: pex2_c7_core rate 500000000 > max 250000000
clk_check_max_rate: pex2_c8_core rate 500000000 > max 250000000
clk_check_max_rate: pex2_c9_core rate 500000000 > max 250000000
clk_check_max_rate: pex2_c10_core rate 500000000 > max 250000000
clk_check_ma��[ 2.605140] Camer��x_rate: pex0_c0_core rate 500000000 > max 250000000
clk_check_max_rate: pex0_��a-FW on t234-rce-safe��c1_core rate 500000000 > max 250000000
clk_check_max_r�� ready SHA1=55ecd57d ��ate: pex0_c2_core rate 500000000 > max 250000000
clk_check_max_rate: pex0_c3_��(crt 1.490 ms, total boot 153.540 ms)
��core rate 500000000 > max 250000000
clk_check_max_rate: pex0_c4_core rate 500000000 > max 250000000
clk_check_max_rate: pex1_c5_core rate 500000000 > max 250000000
initialized clk_mach_post
initialized pg_post
initialized regulator_post
initialized profile
initialized mrq
initialized patrol_scrubber
initialized cactmon
initialized extras_post
bpmp: init complete
��t successful
I> DCE unhalt successful
I> APE unhalt skip��
��ped
I> FSI unhalt skipped
I> Task: Load CPUBL (0x50019dd0)
I> Task: Load TOS (0x5001a560)
I> Active chain: 0
I> Partition name: A_cpu-bootloader
I> Size of partition: 3670016
I> Binary@ device:3/0 block-24832 (partition size: 0x380000), name: A_cpu-bootloader
I> cpubl : oem authentication of header done
I> cpubl : meta-blob integrity check is success.
I> cpubl : will be decompressed at 0x26e600000
I> cpubl : decompressed to 3178624 bytes
I> cpubl: plain binary integrity check is success
I> Active chain: 0
I> Partition name: A_secure-os
I> Size of partition: 4194304
I> Binary@ device:3/0 block-32000 (partition size: 0x400000), name: A_secure-os
��DCE: FW Boot Done
��I> MB2-params @ 0x40060000
I> cpubl_params: nsdram: carveout: 1, encryption: 1
I> NSDRAM carveout base: 0x80000000, size: 0x1eeb70000
I> cpubl: Authentication Finalize Done
I> Binary cpubl loaded successfully at 0x26e600000
I> tos: Authentication Finalize Done
I> Binary tos loaded successfully at 0x27fdc7000
I> Relocating OP-TEE dtb from: 0x27fefec50 to 0x27c000860, size: 0x2886
I> [0] START: 0x80000000, SIZE: 0x1eeb70000
I> [1] START: 0x272000000, SIZE: 0x2000000
I> Setting NS memory ranges to OP-TEE dtb finished.
I> Active chain: 0
I> Partition name: A_eks
I> Binary@ device:3/0 block-44288 (partition size: 0x40000), name: A_eks
I> eks: Authentication Finalize Done
I> Binary eks loaded successfully at 0x270000200
I> EKB detected (length: 0x410) @ VA:0x270000200
I> Task: Prepare TOS params (0x5001a4d8)
I> Setting EKB blob info to OPTEE dtb finished.
I> Setting OPTEE arg3: 0x27c000860
I> Task: OEM SC7 context save (0x5001b970)
I> OEM sc7 context saved
I> Task: Disable MSS perf stats (0x50028f94)
I> Task: Program display sticky bits (0x50028f10)
I> Task: Storage device deinit (0x500020bc)
I> Task: SMMU external bypass disable (0x50018848)
I> Task: SMMU init (0x50018764)
I> Task: Program GICv3 registers (0x50029034)
I> Task: Audit firewall settings (0x50025f44)
I> Task: Bootchain failure check (0x500025c8)
I> Current Boot-Chain Slot: 0
I> BR-BCT Boot-Chain is 0, and status is 1. Set UPDATE_BRBCT bit to 0
I> MB2 finished
��NOTICE: BL31: v2.6(release):cec9a2bc3
NOTICE: BL31: Built : 20:19:41, Feb 19 2024
I/TC: Physical secure memory base 0x27c040000 size 0x3fc0000
I/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 3.22 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Tue Feb 20 04:28:56 UTC 2024 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check Porting guidelines — OP-TEE documentation documentation
I/TC: Primary CPU initializing
I/TC: Test OEM keys are being used. This is insecure for shipping products!
I/TC: Primary CPU switching to normal world boot
Jetson UEFI firmware (version 5.0-35550185 built on 2024-02-20T04:21:22+00:00)
��I/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
E/TC:?? 00
E/TC:?? 00 User mode data-abort at address 0x40 (translation fault)
E/TC:?? 00 esr 0x92000005 ttbr0 0x200027c1ba000 ttbr1 0x00000000 cidr 0x0
E/TC:?? 00 cpu #0 cpsr 0x60000000
E/TC:?? 00 x0 00000000405e0000 x1 0000000000000000
E/TC:?? 00 x2 0000000000000020 x3 00000000405f5c58
E/TC:?? 00 x4 00000000405f5c57 x5 00000000405d9410
E/TC:?? 00 x6 00000000000000fc x7 00000000000000fc
E/TC:?? 00 x8 00000000000000fc x9 0000000000000000
E/TC:?? 00 x10 0000a00000001000 x11 0000000000000040
E/TC:?? 00 x12 0000000000000000 x13 4200004000000000
E/TC:?? 00 x14 0000000000000000 x15 0000000000000000
E/TC:?? 00 x16 00000000400491f8 x17 00000000000000f8
E/TC:?? 00 x18 0000000000000000 x19 00000000405ef160
E/TC:?? 00 x20 00000000405f5c58 x21 00000000405e0000
E/TC:?? 00 x22 0000000000000020 x23 000000000000003f
E/TC:?? 00 x24 00000000405f5c57 x25 0000000000000000
E/TC:?? 00 x26 0000000000001000 x27 0000000000040000
E/TC:?? 00 x28 0000000040508000 x29 00000000405f5bb0
E/TC:?? 00 x30 0000000040500370 elr 00000000405d9494
E/TC:?? 00 sp_el0 00000000405f5bb0
E/TC:?? 00 region 0: va 0x0000000040000000 pa 0x000000027c042000 size 0x002000 flags —R-X
E/TC:?? 00 region 1: va 0x0000000040002000 pa 0x000000027c190000 size 0x001000 flags —RW-
E/TC:?? 00 region 2: va 0x0000000040004000 pa 0x000000027c240000 size 0x03f000 flags r-xR–
E/TC:?? 00 region 3: va 0x0000000040043000 pa 0x000000027c27f000 size 0x001000 flags rw----
E/TC:?? 00 region 4: va 0x0000000040044000 pa 0x000000027c280000 size 0x00b000 flags r-x—
E/TC:?? 00 region 5: va 0x000000004004f000 pa 0x000000027c28b000 size 0x001000 flags rw----
E/TC:?? 00 region 6: va 0x0000000040050000 pa 0x000000027c28c000 size 0x001000 flags r-x—
E/TC:?? 00 region 7: va 0x0000000040051000 pa 0x000000027c28d000 size 0x2b3000 flags r-xR–
E/TC:?? 00 region 8: va 0x0000000040304000 pa 0x000000027c540000 size 0x1fc000 flags rw-RW-
E/TC:?? 00 region 9: va 0x0000000040500000 pa 0x000000027c73c000 size 0x008000 flags r-x—
E/TC:?? 00 region 10: va 0x0000000040508000 pa 0x000000027c744000 size 0x001000 flags rw-RW-
E/TC:?? 00 region 11: va 0x0000000040509000 pa 0x000000027c745000 size 0x001000 flags r-x—
E/TC:?? 00 region 12: va 0x000000004050a000 pa 0x000000027c746000 size 0x002000 flags rw-RW-
E/TC:?? 00 region 13: va 0x000000004050c000 pa 0x000000027c748000 size 0x005000 flags r-x—
E/TC:?? 00 region 14: va 0x0000000040511000 pa 0x000000027c74d000 size 0x001000 flags rw-RW-
E/TC:?? 00 region 15: va 0x0000000040512000 pa 0x000000027c74e000 size 0x001000 flags r-x—
E/TC:?? 00 region 16: va 0x0000000040513000 pa 0x000000027c74f000 size 0x0c3000 flags rw-RW-
E/TC:?? 00 region 17: va 0x00000000405d6000 pa 0x000000027c812000 size 0x00a000 flags r-x—
E/TC:?? 00 region 18: va 0x00000000405e0000 pa 0x000000027c81c000 size 0x001000 flags rw-RW-
E/TC:?? 00 region 19: va 0x00000000405e1000 pa 0x000000027c81d000 size 0x001000 flags r-x—
E/TC:?? 00 region 20: va 0x00000000405e2000 pa 0x000000027c81e000 size 0x002000 flags rw-RW-
E/TC:?? 00 region 21: va 0x00000000405e4000 pa 0x000000027c820000 size 0x006000 flags r-x—
E/TC:?? 00 region 22: va 0x00000000405ea000 pa 0x000000027c826000 size 0x001000 flags rw-RW-
E/TC:?? 00 region 23: va 0x00000000405eb000 pa 0x000000027c827000 size 0x001000 flags r-x—
E/TC:?? 00 region 24: va 0x00000000405ec000 pa 0x000000027c828000 size 0x01f000 flags rw-RW-
E/TC:?? 00 region 25: va 0x000000004060b000 pa 0x000000027c847000 size 0x015000 flags rw-RW-
E/TC:?? 00 region 26: va 0x0000000040620000 pa 0x000000000c198000 size 0x001000 flags rw----
E/TC:?? 00 region 27: va 0x0000000040621000 pa 0x0000000003270000 size 0x010000 flags rw----
E/TC:?? 00 region 28: va 0x0000000040631000 pa 0x000000000c390000 size 0x002000 flags rw----
��ERROR: Exception reason=0 syndrome=0xbe000011
ERROR: **************************************
ERROR: RAS Uncorrectable Error in IOB, base=0xe010000:
ERROR: Status = 0xec000612
ERROR: SERR = Error response from slave: 0x12
ERROR: IERR = CBB Interface Error: 0x6
ERROR: Overflow (there may be more errors) - Uncorrectable
ERROR: MISC0 = 0xc44e0040
ERROR: MISC1 = 0xd4c860000000000
ERROR: MISC2 = 0x0
ERROR: MISC3 = 0x0
ERROR: ADDR = 0x8000000003270000
ERROR: sdei_dispatch_event returned -1
Unhandled Exception in EL3.
x30 = 0x0000000050011384
x0 = 0x0000000000000000
x1 = 0x0000000000000000
x2 = 0x000000005000d1b8
x3 = 0x0000000000000047
x4 = 0x0000000000000000
x5 = 0x0000000000000043
x6 = 0x0000000000000001
x7 = 0x0000000000000000
x8 = 0x000000005000b7ec
x9 = 0x0000000000000000
x10 = 0x0000000264a6c000
x11 = 0x0000000264a9dfff
x12 = 0x0000000000000000
x13 = 0x000000000002700f
x14 = 0x00000002694f00a8
x15 = 0x000000026e555000
x16 = 0x0000000268654cd4
x17 = 0x0000000001e80008
x18 = 0x0000000000000000
x19 = 0x0000000003270000
x20 = 0x000000000000001c
x21 = 0x00000002694f0000
x22 = 0x000000000000001d
x23 = 0x00000002694f00a8
x24 = 0x0000000003270000
x25 = 0x0000000000000001
x26 = 0x0000000000000001
x27 = 0x0000000000000000
x28 = 0x0000000000000001
x29 = 0x000000026e9fe520
scr_el3 = 0x000000000003073d
sctlr_el3 = 0x00000000b0cd183f
cptr_el3 = 0x0000000000000000
tcr_el3 = 0x0000000080823518
daif = 0x00000000000003c0
mair_el3 = 0x00000000004404ff
spsr_el3 = 0x00000000600003cd
elr_el3 = 0x0000000050011384
ttbr0_el3 = 0x0000000050026ac1
esr_el3 = 0x0000000002000000
far_el3 = 0x0000000000000000
spsr_el1 = 0x0000000000000000
elr_el1 = 0x0000000000000000
spsr_abt = 0x0000000000000000
spsr_und = 0x0000000000000000
spsr_irq = 0x0000000000000000
spsr_fiq = 0x0000000000000000
sctlr_el1 = 0x0000000030d00800
actlr_el1 = 0x0000000000000000
cpacr_el1 = 0x0000000000300000
csselr_el1 = 0x0000000000000000
sp_el1 = 0x0000000000000000
esr_el1 = 0x0000000000000000
ttbr0_el1 = 0x0000000000000000
ttbr1_el1 = 0x0000000000000000
mair_el1 = 0x0000000000000000
amair_el1 = 0x0000000000000000
tcr_el1 = 0x0000000000000000
tpidr_el1 = 0x0000000000000000
tpidr_el0 = 0x0000000080000000
tpidrro_el0 = 0x0000000000000000
par_el1 = 0x0000000000000800
mpidr_el1 = 0x0000000081000000
afsr0_el1 = 0x0000000000000000
afsr1_el1 = 0x0000000000000000
contextidr_el1 = 0x0000000000000000
vbar_el1 = 0x0000000000000000
cntp_ctl_el0 = 0x0000000000000005
cntp_cval_el0 = 0x000000000c2fdf7c
cntv_ctl_el0 = 0x0000000000000000
cntv_cval_el0 = 0x0000000000000000
cntkctl_el1 = 0x0000000000000000
sp_el0 = 0x00000002687db2f0
isr_el1 = 0x0000000000000040
cpuectlr_el1 = 0xa000000b40543000
gicd_ispendr regs (Offsets 0x200 - 0x278)
Offset: value
0000000000000200: 0x0000000000000000
0000000000000204: 0x0000000000000000
0000000000000208: 0x0000000000000000
000000000000020c: 0x0000000000000000
0000000000000210: 0x0000000000000000
0000000000000214: 0x0000000000000000
0000000000000218: 0x0000000000010000
000000000000021c: 0x0000000000000000
0000000000000220: 0x0000000000000000
0000000000000224: 0x0000000000000000
0000000000000228: 0x0000000000000000
000000000000022c: 0x0000000000000000
0000000000000230: 0x0000000000000000
0000000000000234: 0x0000000000000000
0000000000000238: 0x0000000000000000
000000000000023c: 0x0000000000000000
0000000000000240: 0x0000000000000000
0000000000000244: 0x0000000000000000
0000000000000248: 0x0000000000000000
000000000000024c: 0x0000000000000000
0000000000000250: 0x0000000000000000
0000000000000254: 0x0000000000000000
0000000000000258: 0x0000000000000000
000000000000025c: 0x0000000000000000
0000000000000260: 0x0000000000000000
0000000000000264: 0x0000000000000000
0000000000000268: 0x0000000000000000
000000000000026c: 0x0000000000000000
0000000000000270: 0x0000000000000000
0000000000000274: 0x0000000000000000
0000000000000278: 0x0000000000000000
000000000000027c: 0x0000000000000000
