[16:51:34.299]收←◆\0
[16:51:35.960]收←◆\07\0
[16:51:36.086]收←◆\0?
[16:51:36.126]收←◆[0000.064] I> MB1 (version: 1.4.0.1-t234-54845784-08e631ca)
[0000.070] I> t234-A01-1-Silicon (0x12347) Prod
[0000.074] I> Boot-mode : Coldboot
[0000.077] I> Entry timestamp: 0x00000000
[0000.081] I> last_boot_error: 0x0
[0000.084] I> BR-BCT: preprod_dev_sign: 0
[0000.088] I> rst_source: 0x0, rst_level: 0x0
[0000.092] I> Task: SE error check
[0000.095] I> Task: Bootchain select WAR set
[0000.099] I> Task: Enable SLCG
[0000.102] I> Task: CRC check
[0000.105] I> Task: Initialize MB2 params
[0000.109] I> MB2-params @ 0x40060000
[0000.112] I> Task: Crypto init
[0000.115] I> Task: Perform MB1 KAT tests
[16:51:36.169]收←◆[0000.119] I> Task: NVRNG health check
[0000.123] I> NVRNG: Health check success
[0000.126] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.132] I> Task: Enabling and initialization of Bandwidth limiter
[0000.139] I> No request to configure MBWT settings for any PC!
[0000.144] I> Task: Secure debug controls
[0000.148] I> Task: strap war set
[0000.151] I> Task: Initialize SOC Therm
[0000.155] I> Task: Program NV master stream id
[0000.159] I> Task: Verify boot mode
[0000.165] I> Task: Alias fuses
[16:51:36.234]收←◆[0000.168] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.175] I> Task: Print SKU type
[0000.178] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c0
[0000.183] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[0000.188] I> FUSE_OPT_TPC_DISABLE = 0x00000080
[0000.192] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0000.196] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0000.201] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0000.205] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.209] I> FUSE_OPT_FSI_DISABLE =
[16:51:36.272]收←◆0x00000000
[0000.214] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0000.218] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.222] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.226] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.230] I> FUSE_SKU_INFO_0 = 0xd2
[0000.234] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.238] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.242] I> SKU: Prod
[0000.244] I> Task: Boost clocks
[0000.247] I> Initializing PLLC2 for AXI_CBB.
[0000.251] I> AXI_CBB : src = 35, divisor = 0
[0000.255] I> Task: Voltage monitor
[0000.258] I> VMON: Vmon re-calibration and fine tuning done
[0000.264] I> Task: UPHY init
[0000.269] I> HSIO UPHY init done
[0000.272] W> Skipping GBE UPHY config
[0000.275] I> Task: Boot device init
[0000.279] I> Boot_device: QSPI_FLASH instance: 0
[0000.283] I> Qspi clock source : pllc_out0
[0000.287] I> QSPI Flash: Macronix 64MB
[0000.291] I> QSPI-0l initialized successfully
[0000.295] I> Task: TSC init
[16:51:36.352]收←◆[0000.298] I> Task: Load membct
[0000.301] I> RAM_CODE 0x4000411
[0000.304] I> Loading MEMBCT
[0000.307] I> Slot: 0
[0000.309] I> Binary[0] block-3840 (partition size: 0x40000)
[0000.314] I> Binary name: MEM-BCT-0
[0000.317] I> Size of crypto header is 8192
[0000.321] I> Size of crypto header is 8192
[0000.325] I> strt_pg_num(3840) num_of_pgs(16) read_buf(0x40050000)
[0000.332] I> BCH of MEM-BCT-0 read from storage
[0000.336] I> BCH address is : 0x40050000
[0000.340] I> MEM-BCT-0 header integrity check is success
[0000.345] I> Binary magic in BCH component 0 is MEM0
[0000.350] I> component binary type is 0
[0000.353] I> strt_pg_num(3856) num_of_pgs(115) read_buf(0x40040000)
[0000.360] I> MEM-BCT-0 binary is read from storage
[0000.365] I> MEM-BCT-0 binary integrity check is success
[0000.370] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.377] I> RAM_CODE 0x4000411
[0000.382] I> RAM_CODE 0x4000411
[16:51:36.452]收←◆[0000.386] I> Task: Load Page retirement list
[0000.390] I> Task: SDRAM params override
[0000.394] I> Task: Save mem-bct info
[0000.398] I> Task: Carveout allocate
[0000.401] I> RCM blob carveout will not be allocated
[0000.406] I> Update CCPLEX IST carveout from MB1-BCT
[0000.411] I> ECC region[0]: Start:0x0, End:0x0
[0000.415] I> ECC region[1]: Start:0x0, End:0x0
[0000.419] I> ECC region[2]: Start:0x0, End:0x0
[0000.423] I> ECC region[3]: Start:0x0, End:0x0
[0000.428] I> ECC region[4]: Start:0x0, End:0x0
[0000.432] I> Non-ECC region[0]: Start:0x80000000, End:0x880000000
[0000.438] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.443] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.447] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.452] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.462] I> allocated(CO:44) base:0x849800000 size:0x36800000 align: 0x100000
[0000.470] I> allocated(CO:31) base:0x840000000 size:0x8000000 align: 0x8000000
[0000.477] I> allocated(CO:43) base:0x83c000000 size:0x4000000 align: 0x200000
[0000.484] I> allocated(CO:39) base:0x839e00000 size:0x2200000 align: 0x10000
[0000.491] I> allocated(CO:20) base:0x836000000 size:0x2000000 align: 0x2000000
[0000.498] I> allocated(CO:24) base:0x834000000 size:0x2000000 align: 0x2000000
[0000.505] I> allocated(CO:28) base:0x832000000 size:0x2000000 align: 0x2000000
[0000.512] I> allocated(CO:29) base:0x830000000 size:0x2000000 align: 0x2000000
[0000.519] I> allocated(CO:22) base:0x848000000 size:0x1000000 align: 0x1000000
[0000.526] I> allocated(CO:41) base:0x838e00000 size:0x1000000 align: 0x100000
[0000.533] I> allocated(CO:35) base:0x838000000 size:0xe00000 align: 0x10000
[0000.540] I> allocated(CO:02) base:0x849000000 size:0x800000 align: 0x800000
[0000.547] I> allocated(CO:03) base:0x82f800000 size:0x800000 align: 0x800000
[0000.554] I> allocated(CO:06) base:0x82f000000 size:0x800000 align: 0x800000
[0000.561] I> allocated(CO:56) base:0x82e800000 size:0x800000 align: 0x200000
[0000.568] I> allocated(CO:07) base:0x82e400000 size:0x400000 align: 0x400000
[0000.575] I> allocated(CO:33) base:0x82e000000 size:0x400000 align: 0x200000
[16:51:36.645]收←◆[0000.582] I> allocated(CO:23) base:0x82de00000 size:0x200000 align: 0x200000
[0000.589] I> allocated(CO:01) base:0x82dd00000 size:0x100000 align: 0x100000
[0000.596] I> allocated(CO:05) base:0x82dc00000 size:0x100000 align: 0x100000
[0000.603] I> allocated(CO:08) base:0x82db00000 size:0x100000 align: 0x100000
[0000.610] I> allocated(CO:09) base:0x82da00000 size:0x100000 align: 0x100000
[0000.617] I> allocated(CO:15) base:0x82d900000 size:0x100000 align: 0x100000
[0000.624] I> allocated(CO:17) base:0x82d800000 size:0x100000 align: 0x100000
[0000.630] I> allocated(CO:27) base:0x82d700000 size:0x100000 align: 0x100000
[0000.637] I> allocated(CO:42) base:0x82d600000 size:0x100000 align: 0x100000
[0000.644] I> allocated(CO:54) base:0x82d580000 size:0x80000 align: 0x80000
[0000.651] I> allocated(CO:34) base:0x82d570000 size:0x10000 align: 0x10000
[16:51:36.720]收←◆[0000.658] I> allocated(CO:72) base:0x82d370000 size:0x200000 align: 0x10000
[0000.665] I> allocated(CO:47) base:0x82ce00000 size:0x400000 align: 0x200000
[0000.672] I> allocated(CO:48) base:0x82d350000 size:0x20000 align: 0x10000
[0000.678] I> allocated(CO:69) base:0x82d330000 size:0x20000 align: 0x10000
[0000.685] I> allocated(CO:49) base:0x82d320000 size:0x10000 align: 0x10000
[0000.692] I> allocated(CO:50) base:0x82d310000 size:0x10000 align: 0x10000
[0000.699] I> allocated(CO:52) base:0x82d300000 size:0x10000 align: 0x10000
[16:51:36.754]收←◆[0000.705] I> NSDRAM base: 0x80000000, end: 0x82d370000, size: 0x7ad370000
[0000.712] I> Task: Thermal check
[0000.715] I> max_chip_limit = 105
[0000.718] I> min_chip_limit = -28
[0000.722] I> max temp read = 32
[0000.724] I> min temp read = 31
[0000.727] I> Task: Update FSI SCR with thermal fuse data
[0000.733] I> Task: Enable WDT 5th expiry
[0000.736] I> Task: I2C register
[0000.739] I> Task: Set I2C bus freq
[0000.743] I> Task: Reset FSI
[0000.746] I> Task: Pinmux init
[0000.749] I> Task: Prod config init
[0000.752] I> Task: Pad voltage init
[0000.756] I> Task: Prod init
[0000.758] I> Task: Program rst req config reg
[0000.763] I> Task: Common rail init
[0000.766] I> DONE: Thermal config
[0000.770] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.778] I> DONE: SOC rail config
[0000.782] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0000.788] I> DONE: MEMIO rail config
[0000.791] I> DONE: GPU rail info
[0000.795] I> DONE: CV rail info
[0000.798] I> Task: Mem clock src
[0000.801] I> Task: Misc. board config
[0000.806] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0000.811] I> Task: SDRAM init
[0000.814] I> MemoryType: 4 MemBctRevision: 9
[0000.821] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 9
[0000.828] I> MSS CAR: Init PLLM
[0000.831] I> MSS CAR: Init PLLHUB
[0000.836] I> Encryption: MTS: en, TX: en, VPR: en, GSC: en
[0000.847] I> SDRAM initialized!
[0000.850] I> SDRAM Size in Total 0x800000000
[0000.855] I> Task: Dram Ecc scrub
[0000.858] I> Task: DRAM alias check
[0000.868] I> Task: Program NSDRAM carveout
[0000.872] I> NSDRAM carveout encryption is enabled
[0000.876] I> Program NSDRAM carveout
[0000.880] I> Task: Register checker
[0000.883] I> Task: Enable clock-mon
[0000.898] I> FMON: Fmon re-programming done
[0000.902] I> Task: Mapper init
[0000.905] I> Task: SC7 Context Init
[0000.908] I> Task: CCPLEX IST init
[0000.911] I> Task: CPU WP0
[0000.914] I> Loading MCE
[0000.917] I> Slot: 0
[0000.919] I> Binary[8] block-22784 (partition size: 0x80000)
[0000.924] I> Binary name: MCE
[0000.927] I> Size of crypto header is 8192
[0000.931] I> Size of crypto header is 8192
[0000.935] I> strt_pg_num(22784) num_of_pgs(16) read_buf(0x4003e000)
[0000.941] I> BCH of MCE read from storage
[0000.945] I> BCH address is : 0x4003e000
[0000.949] I> MCE header integrity check is success
[0000.954] I> Binary magic in BCH component 0 is MTSM
[0000.958] I> component binary type is 8
[0000.962] I> Size of crypto header is 8192
[0000.966] I> strt_pg_num(22800) num_of_pgs(357) read_buf(0x40000000)
[0000.974] I> MCE binary is read from storage
[0000.979] I> MCE binary integrity check is success
[0000.983] I> Binary MCE loaded successfully at 0x40000000 (0x2c880)
[0000.989] I> Size of crypto header is 8192
[0001.001] I> Size of crypto header is 8192
[0001.005] I> Sending WP0 mailbox command to PSC
[0001.014] I> Task: XUSB Powergate
[0001.017] I> Skipping powergate XUSB.
[0001.020] I> Task: MB1 fixed firewalls
[0001.027] W> Firewall readback mismatch
[16:51:37.081]收←◆[0001.032] I> Task: Load bpmp-fw
[0001.035] I> Slot: 0
[0001.037] I> Binary[15] block-9984 (partition size: 0x180000)
[0001.042] I> Binary name: BPMP_FW
[0001.045] I> Size of crypto header is 8192
[0001.049] I> Size of crypto header is 8192
[0001.053] I> strt_pg_num(9984) num_of_pgs(16) read_buf(0x807fe000)
[0001.060] I> BCH of BPMP_FW read from storage
[0001.064] I> BCH address is : 0x807fe000
[16:51:37.113]收←◆[0001.068] I> BPMP_FW header integrity check is success
[0001.073] I> Binary magic in BCH component 0 is BPMF
[0001.077] I> component binary type is 15
[0001.081] I> Size of crypto header is 8192
[0001.085] I> strt_pg_num(10000) num_of_pgs(1990) read_buf(0x80000000)
[0001.103] I> BPMP_FW binary is read from storage
[16:51:37.167]收←◆[0001.109] I> BPMP_FW binary integrity check is success
[0001.114] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xf8bc0)
[0001.120] I> Slot: 0
[0001.122] I> Binary[16] block-13056 (partition size: 0x400000)
[0001.128] I> Binary name: BPMP_FW_DTB
[0001.132] I> Size of crypto header is 8192
[0001.136] I> Size of crypto header is 8192
[0001.139] I> strt_pg_num(13056) num_of_pgs(16) read_buf(0x807fc000)
[0001.146] I> BCH of BPMP_FW_DTB read from storage
[0001.150] I> BCH address is : 0x807fc000
[16:51:37.199]收←◆[0001.154] I> BPMP_FW_DTB header integrity check is success
[0001.159] I> Binary magic in BCH component 0 is BPMD
[0001.164] I> component binary type is 16
[0001.168] I> Size of crypto header is 8192
[0001.172] I> strt_pg_num(13072) num_of_pgs(493) read_buf(0x807be5f0)
[0001.181] I> BPMP_FW_DTB binary is read from storage
[0001.186] I> BPMP_FW_DTB binary integrity check is success
[0001.192] I> Binary BPMP_FW_DTB loaded successfully at 0x807be5f0 (0x3d840)
[16:51:37.251]收←◆[0001.198] I> Task: BPMP fw ast config
[0001.202] I> Task: Load psc-fw
[0001.205] I> Slot: 0
[0001.207] I> Binary[17] block-21248 (partition size: 0xc0000)
[0001.213] I> Binary name: PSC_FW
[0001.216] I> Size of crypto header is 8192
[0001.220] I> Size of crypto header is 8192
[0001.223] I> strt_pg_num(21248) num_of_pgs(16) read_buf(0x80ffe000)
[0001.230] I> BCH of PSC_FW read from storage
[0001.234] I> BCH address is : 0x80ffe000
[16:51:37.283]收←◆[0001.238] I> PSC_FW header integrity check is success
[0001.243] I> Binary magic in BCH component 0 is PFWP
[0001.247] I> component binary type is 17
[0001.251] I> Size of crypto header is 8192
[0001.255] I> strt_pg_num(21264) num_of_pgs(717) read_buf(0x80fa4600)
[0001.265] I> PSC_FW binary is read from storage
[16:51:37.331]收←◆[0001.270] I> PSC_FW binary integrity check is success
[0001.275] I> Binary PSC_FW loaded successfully at 0x80fa4600 (0x59980)
[0001.282] I> Task: Load nvdec-fw
[0001.285] I> Slot: 0
[0001.287] I> Binary[7] block-6400 (partition size: 0x100000)
[0001.292] I> Binary name: NVDEC
[0001.295] I> Size of crypto header is 8192
[0001.299] I> Size of crypto header is 8192
[0001.303] I> strt_pg_num(6400) num_of_pgs(16) read_buf(0x800fe000)
[0001.309] I> BCH of NVDEC read from storage
[0001.313] I> BCH address is : 0x800fe000
[16:51:37.362]收←◆[0001.317] I> NVDEC header integrity check is success
[0001.322] I> Binary magic in BCH component 0 is NDEC
[0001.327] I> component binary type is 7
[0001.330] I> Size of crypto header is 8192
[0001.334] I> strt_pg_num(6416) num_of_pgs(560) read_buf(0x80000000)
[0001.344] I> NVDEC binary is read from storage
[0001.349] I> NVDEC binary integrity check is success
[0001.353] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0001.360] I> Size of crypto header is 8192
[16:51:37.403]收←◆[0001.371] I> Task: Load tsec-fw
[0001.374] I> TSEC-FW load support not enabled
[0001.378] I> Task: GPIO interrupt map
[16:51:37.435]收←◆[0001.382] I> Task: SC7 context save
[0001.385] I> Slot: 0
[0001.387] I> Binary[27] block-0 (partition size: 0x100000)
[0001.393] I> Binary name: BR_BCT
[0001.396] I> Size of crypto header is 8192
[0001.400] I> Size of crypto header is 8192
[0001.404] I> Size of crypto header is 8192
[0001.408] I> strt_pg_num(0) num_of_pgs(16) read_buf(0xa0000000)
[0001.413] I> BR_BCT binary is read from storage
[16:51:37.483]收←◆[0001.418] I> BR_BCT binary integrity check is success
[0001.423] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[0001.429] I> Slot: 0
[0001.431] I> Binary[13] block-23808 (partition size: 0x30000)
[0001.437] I> Binary name: SC7-FW
[0001.440] I> Size of crypto header is 8192
[0001.444] I> Size of crypto header is 8192
[0001.448] I> Size of crypto header is 8192
[0001.452] I> Size of crypto header is 8192
[0001.456] I> strt_pg_num(23808) num_of_pgs(16) read_buf(0xa0002000)
[0001.462] I> BCH of SC7-FW read from storage
[0001.466] I> BCH address is : 0xa0002000
[16:51:37.514]收←◆[0001.470] I> SC7-FW header integrity check is success
[0001.475] I> Binary magic in BCH component 0 is WB0B
[0001.479] I> component binary type is 13
[0001.483] I> Size of crypto header is 8192
[0001.487] I> strt_pg_num(23824) num_of_pgs(347) read_buf(0xa0004000)
[0001.495] I> SC7-FW binary is read from storage
[16:51:37.565]收←◆[0001.500] I> SC7-FW binary integrity check is success
[0001.505] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x2b440)
[0001.511] I> Slot: 0
[0001.513] I> Binary[22] block-24192 (partition size: 0x30000)
[0001.519] I> Binary name: PSC_RF
[0001.522] I> Size of crypto header is 8192
[0001.526] I> Size of crypto header is 8192
[0001.530] I> Size of crypto header is 8192
[0001.534] I> Size of crypto header is 8192
[0001.538] I> strt_pg_num(24192) num_of_pgs(16) read_buf(0xa002f440)
[0001.544] I> BCH of PSC_RF read from storage
[0001.548] I> BCH address is : 0xa002f440
[16:51:37.597]收←◆[0001.552] I> PSC_RF header integrity check is success
[0001.557] I> Binary magic in BCH component 0 is PSCR
[0001.562] I> component binary type is 22
[0001.565] I> Size of crypto header is 8192
[0001.569] I> strt_pg_num(24208) num_of_pgs(224) read_buf(0xa0031440)
[0001.577] I> PSC_RF binary is read from storage
[0001.581] I> PSC_RF binary integrity check is success
[0001.586] I> Binary PSC_RF loaded successfully at 0xa0031440 (0x1be60)
[16:51:37.658]收←◆[0001.596] I> Task: Save WP0 payload to SC7 ctx
[0001.600] I> Task: Load MB2rf binary to SC7 ctx
[0001.604] I> Slot: 0
[0001.606] I> Binary[14] block-24576 (partition size: 0x20000)
[0001.612] I> Binary name: MB2_RF
[0001.615] I> Size of crypto header is 8192
[0001.619] I> Size of crypto header is 8192
[0001.623] I> Size of crypto header is 8192
[0001.627] I> Size of crypto header is 8192
[0001.631] I> strt_pg_num(24576) num_of_pgs(16) read_buf(0xa00d6aa0)
[0001.637] I> BCH of MB2_RF read from storage
[0001.641] I> BCH address is : 0xa00d6aa0
[16:51:37.690]收←◆[0001.645] I> MB2_RF header integrity check is success
[0001.650] I> Binary magic in BCH component 0 is MB2R
[0001.655] I> component binary type is 14
[0001.658] I> Size of crypto header is 8192
[0001.662] I> strt_pg_num(24592) num_of_pgs(224) read_buf(0xa00d8aa0)
[0001.670] I> MB2_RF binary is read from storage
[16:51:37.741]收←◆[0001.675] I> MB2_RF binary integrity check is success
[0001.679] I> Binary MB2_RF loaded successfully at 0xa00d8aa0 (0x1bfc0)
[0001.686] I> Task: Save fuse alias data to SC7 ctx
[0001.690] I> Task: Save PMIC data to SC7 ctx
[0001.695] I> Task: Save Pinmux data to SC7 ctx
[0001.699] I> Task: Save Pad Voltage data to SC7 ctx
[0001.704] I> Task: Save controller prod data to SC7 ctx
[0001.709] I> Task: Save prod cfg data to SC7 ctx
[0001.713] I> Task: Save I2C bus freq data to SC7 ctx
[0001.718] I> Ta
[16:51:37.773]收←◆sk: Save SOCTherm data to SC7 ctx
[0001.722] I> Task: Save FMON data to SC7 ctx
[0001.726] I> Task: Save VMON data to SC7 ctx
[0001.731] I> Task: Save TZDRAM data to SC7 ctx
[0001.735] I> Task: Save GPIO int data to SC7 ctx
[0001.739] I> Task: Save clock data to SC7 ctx
[0001.744] I> Task: Save debug data to SC7 ctx
[0001.748] I> Task: Save MBWT data to SC7 ctx
[0001.756] I> SC7 context save done
[16:51:37.810]收←◆[0001.759] I> Task: Load MB2/Applet/FSKP
[0001.763] I> Loading MB2
[0001.765] I> Slot: 0
[0001.767] I> Binary[6] block-8448 (partition size: 0x80000)
[0001.773] I> Binary name: MB2
[0001.775] I> Size of crypto header is 8192
[0001.779] I> Size of crypto header is 8192
[0001.783] I> strt_pg_num(8448) num_of_pgs(16) read_buf(0x8007e000)
[0001.789] I> BCH of MB2 read from storage
[0001.793] I> BCH address is : 0x8007e000
[16:51:37.841]收←◆[0001.797] I> MB2 header integrity check is success
[0001.802] I> Binary magic in BCH component 0 is MB2B
[0001.806] I> component binary type is 6
[0001.810] I> Size of crypto header is 8192
[0001.814] I> strt_pg_num(8464) num_of_pgs(838) read_buf(0x80000000)
[0001.825] I> MB2 binary is read from storage
[0001.830] I> MB2 binary integrity check is success
[0001.835] I> Binary MB2 loaded successfully at 0x80000000 (0x68b10)
[0001.841] I> Task: Map CCPLEX SHARED carveout
[0001.845] I> Task: Prepare MB2 params
[0001.849] I> Task: Dram ecc test
[0001.852] I> Task: Misc NV security settings
[0001.856] I> NVDEC sticky bits programming done
[0001.860] I> Successfully powergated NVDEC
[0001.864] I> Task: Disable/Reload WDT
[0001.868] I> Task: Program misc carveouts
[0001.872] I> Program IPC carveouts
[0001.875] I> Task: Disable SCPM/POD reset
[0001.879] I> SLCG Global override status := 0x0
[0001.884] I> MB1: MSS reconfig completed
[16:51:37.980]收←◆I> MB2 (version: 0.0.0.0-t234-54845784-934581f8)
I> Emulation:
I> Entry timestamp: 0x001d37f4
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0x82e800000, size:0x800000]
I> Task: ARI update carveout TZDRAM (0x50002050)
I> Task: Check MC errors (0x5000204c)
I> Task: Enable hot-plug capability (0x500290f8)
I> Task: TZDRAM heap init (0x5001a0fc)
I> Task: PSC mailbox init (0x50018864)
I> Task: Crypto init (0x50006874)
I> Task: Enable GP-SE clock (0x500021b4)
I> Task: Measured Boot init (0x5001c04c)
I> Task: fTPM silicon identity init (0x5001c1f8)
I> fTPM is not enabled.
I> Task: OEM SC7 context save init (0x5001b598)
I> Task: I2C register (0x50002010)
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout (0x50001ff8)
I> Task: Program CBB PCIE AMAP regions (0x5001bcf8)
I> Task: Boot device init (0x50001f40)
I> Task: Partition Manager Init (0x50001f20)
I> Active chain: 0
I> Found 57 partitions in QSPI_FLASH (instance 0)
I> Active chain: 0
W> Cannot find any partition table for 00000003
> PARTITION_MANAGER: Failed to publish partition.
I> Active chain: 0
[16:51:38.120]收←◆I> Found 15 partitions in SDMMC_USER (instance 3)
I> Task: Load and authenticate registered FWs (0x5001f064)
I> Task: Load AUXP FWs (0x50028c7c)
I> Successfully register SPE FW load task with MB2 loader
I> Skipping SCE FW load
I> Successfully register RCE FW load task with MB2 loader
I> Successfully register DCE FW load task with MB2 loader
I> Unpowergating APE
I> Unpowergate done
I> Successfully register APE FW load task with MB2 loader
I> Skipping FSI FW load
I> Successfully register XUSB FW load task with MB2 loader
I> Active chain: 0
I> Partition name: A_spe-fw
I> Size of partition: 589824
I> Binary@ device:3/0 block-55040 (partition size: 0x90000), name: A_spe-fw
[16:51:38.153]收←◆I> Active chain: 0
I> Partition name: A_rce-fw
I> Size of partition: 1048576
I> Binary@ device:3/0 block-56192 (partition size: 0x100000), name: A_rce-fw
I> spe: Authentication Finalize Done
I> Binary spe loaded successfully at 0x82db00000
I> Active chain: 0
I> Partition name: A_dce-fw
I> Size of partition: 5242880
I> Binary@ device:3/0 block-44800 (partition size: 0x500000), name: A_dce-fw
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0x82d800000
I> Successfully register RCE FW context save task with MB2 loader
I> dce : oem authentication of header done
I> dce : meta-blob integrity check is success.
I> dce : will be decompressed at 0x836000000
I> version 1 Bin 1 BCheckSum 0 content_size 0 Content ChkSum 1 reserved_00 0
I> Reserved10 0 BlockMaxSize 5 Reserved11 0
[16:51:38.249]收←◆I> dce : decompressed to 9528576 bytes
[16:51:38.285]收←◆I> dce: plain binary integrity check is success
I> Active chain: 0
I> Partition name: A_adsp-fw
I> Size of partition: 2097152
I> Binary@ device:3/0 block-58240 (partition size: 0x200000), name: A_adsp-fw
I> dce: Authentication Finalize Done
I> Binary dce loaded successfully at 0x836000000
I> Active chain: 0
I> Partition name: A_xusb-fw
I> Size of partition: 262144
I> Binary@ device:3/0 block-9472 (partition size: 0x40000), name: A_xusb-fw
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0x82e400000
I> Successfully register APE FW context save task with MB2 loader
[16:51:38.368]收←◆I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0x82dc00000
I> Successfully register XUSB FW context save task with MB2 loader
I> Task: Carveout setup (0x500217e4)
I> Program remaining OEM carveouts
I> Task: Enable FSITHERM (0x50018738)
I> Task: Enable FSI VMON (0x50018234)
I> FSI VMON: FSI Vmon re-calibration and fine tuning done
I> Task: Validate FSI Therm readings (0x50018318)
I> FSITHERM max temp = 33
I> FSITHERM min temp = 33
I> Task: Restore XUSB sec (0x50001ef4)
I> Task: Enable FSI SE clock (0x50018cc0)
I> Enable FSI-SE clock and 10ms delay...
I> Task: Initialize SBSA UART CAR (0x50002118)
I> Task: Initialize CPUBL Params (0x50019cac)
I> CPUBL-params @ 0x832000000
I> Task: Ratchet update (0x5002a194)
W> Skip ratchet update - OPTIN fuse not set
I> Task: Prepare eeprom data (0x50019a78)
[16:51:38.469]收←◆I> Task: Revoke PKC fuse (0x50001d40)
I> PKC revoke fuse burn not requested
I> Task: FSI padctl context save (0x5001b874)
I> Task: Unpowergate APE (0x50019428)
W> mb2_unpowergate_ape: skip! APE is in unpowergated state
I> Task: OEM firewalls (0x50025cf0)
[16:51:38.529]收←◆I> OEM firewalls configured
I> Task: Powergate APE (0x5001959c)
I> Powergating APE
I> Powergate done
I> Task: OEM firewall restore saved settings (0x50026144)
I> Task: Unhalt AUXPs (0x50028f00)
I> Unhalting SPE..
I> Enabling combined UART
[16:51:38.578]收←◆\0?鄐pe: early_init
?鄓ic initialized
?鄑sc initialized
?郺on lic initialized
?鄐pe: tag is 5243985d1b1eb3f06fac6d36bd7e74ac
?鄐pe: SafeRTOS v8.4
?鄐pe: init
?鄐cheduler initialized
?郺on hsp initialized
?鄑ag initialized
?鄑cu initialized
?郻pmp ipc initialized
?鄐pe: late init
?郼pu_nic clock initialized
?郺pb clock initialized
?鄍m initialized
?郻pmp hsp initialized
?鄑op1 hsp initialized
?郼cplex ipc initialized
?鄐pe: start scheduler
[16:51:38.624]收←◆?
I> Task: Trigger mailbox for PSC-BL1 exit (0x500188e4)
I> Sending opcode 0x4d420802 to psc
鏘NFO: Entering psc_monitor_init!
INFO: GSC22 BOM:0x848002000 SIZE:0x1000000 CLIENT_ACCESS1:00180000
INFO: PSCFW BUILD VERSION: 8a33b23-73b589c-8a15f76-rel-t234
INFO: mstatus:0xa00000808
INFO: Supervisor entry_point:c108c00
酙> Received ACK from psc
I> Task: 鏘NFO: MONITOR: user task addr:0x848022000, blob offset:0x00020000
INFO: MONITOR: populated user images:13
INFO: mret to Supervisor!
INFO: psc su
[16:51:38.668]收←◆pervisor init.
INFO: psc_irq_init...
INFO: enter idle task.
hwwdt_init: WDT boot cfg 0x710010 sts 0x10
bpmp: socket 0
bpmp: base binary md5 is fcc6f4f897ab64a32c3de470c48f0036
bpmp: combined binary md5 is a414c625926dbe27334a57bddff625ec
bpmp: firmware tag is a414c625926dbe27334a-fcc6f4f897a
Control register check for CBB_CENTRAL_CBB_FIREWALL_MCB_BLF failed, expected value: 80030000 != actual value: 00000000 address: 13a159d0
Write control check for CBB_CENTRAL_CBB_FIREWALL_MCB_BLF failed, expec
[16:51:38.713]收←◆ted value: 0f18000b != actual value: 00000000 address: 13a159c8
initialized vwdt
initialized mail_early
initialized fuse
initialized vfrel
initialized adc
fmon_populate_monitors: found 199 monitors
initialized fmon
initialized mc
initialized reset
initialized uphy_early
initialized emc_early
initialized pm
465 clocks registered
initialized clk_mach
initiali
[16:51:38.759]收←◆zed clk_cal_early
initialized clk_mach_early_config
initialized io_dpd
initialized soctherm
initialized regime
initialized i2c
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
initialized vrmon
initialized regulator
酳tart secure NOR provision (0x5001bb10)
I> Task: Load FSI keyblob (0x50018d08)
I> Skipping FSI key blob copy
鈏nitialized avfs_clk_platform
initialized powergate
酙> Task: Unhalt AUXPs (0x50028f08)
I> SCE unhalt skipped
I> Unhalting RCE
I> RCE
[16:51:38.802]收←◆ unhal鈏nitialized dvs
initialized clk_mach_config
initialized suspend
initialized strap
initialized mce_dbell
醫 successful
I> DCE unhalt successful
錥 2.426515] Camera-FW on t234-rce-safe started
酙> APE unhalt skipped
I> FSI unhalt skipped錞CU early console enabled.
I> Task: Load CPUBL (0x50019dd0)
I> Task: Load TOS (0x5001a560)
I> Active chain: 0
I> Partition name: A_cpu-bootloader
I> Size of partition: 3670016
I> Bi
[16:51:38.847]收←◆nary@ device:3/0 block-24832 (partition size: 鈏nitialized emc
initialized emc_mrq
?x380000), name: A_cpu-bootloader
酙> cpubl : o鈏nitialized clk_cal
initialized uphy_dt
initialized uphy_mrq
HSIO UPHY reset has been de-asserted 0x0
start PLL 8 calibration timeout
FATAL ERROR [FILE=platform/drivers/uphy/uphy-tegra234.c, ERR_UID=2251]: start PLL 8 calibration failed
r0_usr 0x5009a469
r1_usr 0x000008cb
r2_usr 0x50038598
r3_usr 0x50181edc
r4_usr 0x50001ff4
r5_usr 0x50038598
r6_usr 0x00
[16:51:38.892]收←◆0008cb
r7_usr 0x5009a469
r8_usr 0x50181edc r8_fiq 0x00000000
r9_usr 0x5020456c r9_fiq 0x00000000
r10_usr 0x00000009 r10_fiq 0x00000000
r11_usr 0x50080006 r11_fiq 0x00000000
r12_usr 0x50181b90 r12_fiq 0x00000000
sp_usr 0x50181ec0 sp_fiq 0x50010820 sp_irq 0x50010c00
sp_svc 0x50011400 sp_abt 0x50010800 sp_und 0x50010770
lr_usr 0x50003179 lr_fiq 0x00000000 lr_irq 0x50000fce
lr_svc 0x5000a580 lr_abt 0x00000000 lr_und 0x50001ff8
pc 0x50001ff4
spsr 0x20000010
fpscr 0x20000010
00: base: 50000000 size:
[16:51:38.938]收←◆ 00800000 XN P_RW U_RW Non-shareable outer: WB, no WA inner: WB, no WA
01: base: 00000000 size: 40000000 XN P_RW U_RW Shareable strongly-ordered
02: base: 00000000 size: 00000040 X P_RO U_NA Non-shareable outer: WB, no WA inner: WB, no WA
03: base: 50000000 size: 00010000 X P_RO U_RO Non-shareable outer: WB, no WA inner: WB, no WA
04.1: base: 50020000 size: 00020000 X P_RO U_RO Non-shareable outer: WB, no WA inner: WB, no WA
04.2: base: 50040000 size: 00020000 X P_RO U_RO Non-shareable outer: WB, n
[16:51:38.982]收←◆o WA inner: WB, no WA
04.3: base: 50060000 size: 00020000 X P_RO U_RO Non-shareable outer: WB, no WA inner: WB, no WA
04.4: base: 50080000 size: 00020000 X P_RO U_RO Non-shareable outer: WB, no WA inner: WB, no WA
04.5: base: 500a0000 size: 00020000 X P_RO U_RO Non-shareable outer: WB, no WA inner: WB, no WA
04.6: base: 500c0000 size: 00020000 X P_RO U_RO Non-shareable outer: WB, no WA inner: WB, no WA
05.1: base: 500c4000 size: 00004000 XN P_RW U_RW Non-shareable outer: WB, no WA inner: WB, no WA
[16:51:39.026]收←◆
05.2: base: 500c8000 size: 00004000 XN P_RW U_RW Non-shareable outer: WB, no WA inner: WB, no WA
05.3: base: 500cc000 size: 00004000 XN P_RW U_RW Non-shareable outer: WB, no WA inner: WB, no WA
05.4: base: 500d0000 size: 00004000 XN P_RW U_RW Non-shareable outer: WB, no WA inner: WB, no WA
05.5: base: 500d4000 size: 00004000 XN P_RW U_RW Non-shareable outer: WB, no WA inner: WB, no WA
05.6: base: 500d8000 size: 00004000 XN P_RW U_RW Non-shareable outer: WB, no WA inner: WB, no WA
05.7: base: 500dc000
[16:51:39.071]收←◆size: 00004000 XN P_RW U_RW Non-shareable outer: WB, no WA inner: WB, no WA
06: base: 50180000 size: 00080000 XN P_RO U_NA Non-shareable outer: WB, no WA inner: WB, no WA
07.2: base: 507a0000 size: 00010000 XN P_RO U_RO Non-shareable outer: WB, no WA inner: WB, no WA
07.3: base: 507b0000 size: 00010000 XN P_RO U_RO Non-shareable outer: WB, no WA inner: WB, no WA
07.4: base: 507c0000 size: 00010000 XN P_RO U_RO Non-shareable outer: WB, no WA inner: WB, no WA
07.5: base: 507d0000 size: 00010000 XN P_RO U
[16:51:39.117]收←◆_RO Non-shareable outer: WB, no WA inner: WB, no WA
07.6: base: 507e0000 size: 00010000 XN P_RO U_RO Non-shareable outer: WB, no WA inner: WB, no WA
07.7: base: 507f0000 size: 00010000 XN P_RO U_RO Non-shareable outer: WB, no WA inner: WB, no WA
08: base: 50202000 size: 00002000 XN P_RW U_RW Non-shareable outer: WT, no WA inner: WT, no WA
10: base: 40070000 size: 00010000 XN P_RW U_RW Non-shareable outer: WB, no WA inner: WB, no WA
15: base: 50180000 size: 00002000 XN P_RW U_RW Non-shareable outer: WB,
[16:51:39.162]收←◆ no WA inner: WB, no WA
Bootstrap@0x50218f40 sp 0x50181ec0 stack: 50180000 - 50181ffc
Per task regions for Bootstrap
04: base: 50180000 size: 00002000 XN P_RW U_RW Non-shareable outer: WB, no WA inner: WB, no WA
Enable MMIO: 1, Enable data R/W: 1
call stack:
sp 0x50181ec0 pc 0x50001ff4
sp 0x50181ec0 pc 0x50003178
sp 0x50181ed8 pc 0x5003858c
sp 0x50181f20 pc 0x500393ce
sp 0x50181f78 pc 0x5002f21c
sp 0x50181fb8 pc 0x5002dc40
sp 0x50181fe0 pc 0x5006933e
sp 0x50181ff8 pc 0xaaaaaaaa
eht_idx_find: 0
[16:51:39.189]收←◆xaaaaaaaa not a valid code address
no eidx for 0xaaaaaaaa
醗m authentication of header done
I> cpubl : meta-blob integrity check is success.
I> cpubl : will be decompressed at 0x82ce00000
I> cpubl : decompressed to 3346560 bytes
[16:51:39.250]收←◆I> cpubl: plain binary integrity check is success
I> Active chain: 0
I> Partition name: A_secure-os
I> Size of partition: 4194304
I> Binary@ device:3/0 block-32000 (partition size: 0x400000), name: A_secure-os
I> cpubl_params: nsdram: carveout: 1, encryption: 1
I> NSDRAM carveout base: 0x80000000, size: 0x7ad370000
I> cpubl: Authentication Finalize Done
I> Binary cpubl loaded successfully at 0x82ce00000
I> tos: Authentication Finalize Done
I> Binary tos loaded successfu
[16:51:39.295]收←◆lly at 0x83fdc7000
I> Relocating OP-TEE dtb from: 0x83fefec50 to 0x83c000860, size: 0x2886
I> [0] START: 0x80000000, SIZE: 0x7ad370000
I> [1] START: 0x832000000, SIZE: 0x2000000
I> Setting NS memory ranges to OP-TEE dtb finished.
I> Active chain: 0
I> Partition name: A_eks
I> Binary@ device:3/0 block-44288 (partition size: 0x40000), name: A_eks
I> eks: Authentication Finalize Done
I> Binary eks loaded successfully at 0x82e800400
I> EKB detected (length: 0x410) @ VA:0x
[16:51:39.341]收←◆82e800400
I> Task: Prepare TOS params (0x5001a4d8)
I> Setting EKB blob info to OPTEE dtb finished.
I> Setting OPTEE arg3: 0x83c000860
I> Task: OEM SC7 context save (0x5001b970)
I> OEM sc7 context saved
I> Task: Disable MSS perf stats (0x50028f94)
I> Task: Program display sticky bits (0x50028f10)
I> Task: Storage device deinit (0x500020bc)
I> Task: SMMU external bypass disable (0x50018848)
I> Task: SMMU init (0x50018764)
I> Task: Program GICv3 registers (0x50029034)
I> Task: Audit firewall settings (0x50025f44)
I> Task: Bootchain failure check (0x500025c8)
I> Current Boot-Chain Slot: 0
I> BR-BCT Boot-Chain is 0, and status is 1. Set UPDATE_BRBCT bit to 0
I> MB2 finished
銷OTICE: BL31: v2.6(release):cec9a2bc3
NOTICE: BL31: Built : 20:19:41, Feb 19 2024
I/TC: Physical secure memory base 0x83c040000 size 0x3fc0000
[16:51:39.491]收←◆I/TC:
[16:51:39.557]收←◆I/TC: Non-secure external DT found
[16:51:39.718]收←◆I/TC: OP-TEE version: 3.22 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Tue Feb 20 04:28:56 UTC 2024 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
[16:51:40.081]收←◆I/TC: Test OEM keys are being used. This is insecure for shipping products!
[16:51:40.154]收←◆I/TC: Primary CPU switching to normal world boot
[16:51:40.222]收←◆?
Jetson UEFI firmware (version 5.0-35550185 built on 2024-02-20T04:21:22+00:00)
[16:51:40.412]收←◆
[16:51:40.856]收←◆
[16:51:40.912]收←◆
錏RROR: camera-ip/isp5/isp5.c:1980 [isp5_pm_init] "ERROR: Failed to turn isp power on"
BUG: core/init/init.c:85 [init_all] "*** FIRMWARE INIT FAILED AT LEVEL 95 ***"
[16:51:41.384]收←◆
[16:51:41.418]收←◆
[16:51:41.590]收←◆
[16:51:41.762]收←◆
[16:51:41.921]收←◆
[16:51:42.042]收←◆
The system failed to start up normally after being flashed, and the error message is as follows: “ERROR: Failed to turn isp power on”.
Hi 210076320,
Please share the log as file here instead pasting whole contents for better reading.
What’s the Jetpack version in use?(r35.5.0?)
How did you flash the board? (please share the full flash command and log)
The real error is
You probably use a custom board with UPHY setting different from Orin AGX devkit?
