我使用orin的板子,烧写了,最新的jetpack36.2.通过,如下命令烧写的:./flash.sh jetson-agx-orin-devkit mmcblk1p1
我之前都是这么烧写的。但是现在无法启动,我看了下说是找不到emmcblk0p1,但是 我看到内核中找到的竟然是mmcblk3,好奇怪。
[0000.065] I> MB1 (version: 1.4.0.1-t234-54845784-08e631ca)
[0000.071] I> t234-A01-0-Silicon (0x12347) Prod
[0000.075] I> Boot-mode : Coldboot
[0000.078] I> Entry timestamp: 0x00000000
[0000.082] I> last_boot_error: 0x0
[0000.085] I> BR-BCT: preprod_dev_sign: 0
[0000.089] I> rst_source: 0x0, rst_level: 0x0
[0000.093] I> Task: SE error check
[0000.096] I> Task: Bootchain select WAR set
[0000.100] I> Task: Enable SLCG
[0000.103] I> Task: CRC check
[0000.106] I> Skip FUSE records CRC check as records_integrity fuse is not burned
[0000.113] I> Task: Initialize MB2 params
[0000.117] I> MB2-params @ 0x40060000
[0000.121] I> Task: Crypto init
[0000.123] I> Task: Perform MB1 KAT tests
[0000.127] I> Task: NVRNG health check
[0000.131] I> NVRNG: Health check success
[0000.135] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.141] I> Task: Enabling and initialization of Bandwidth limiter
[0000.147] I> No request to configure MBWT settings for any PC!
[0000.152] I> Task: Secure debug controls
[0000.156] I> Task: strap war set
[0000.159] I> Task: Initialize SOC Therm
[0000.163] I> Task: Program NV master stream id
[0000.167] I> Task: Verify boot mode
[0000.173] I> Task: Alias fuses
[0000.176] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.184] I> Task: Print SKU type
[0000.187] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c0
[0000.192] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[0000.196] I> FUSE_OPT_TPC_DISABLE = 0x00000004
[0000.200] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0000.205] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0000.209] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0000.213] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.218] I> FUSE_OPT_FSI_DISABLE = 0x00000000
[0000.222] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0000.226] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.231] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.235] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.239] I> FUSE_SKU_INFO_0 = 0xd2
[0000.242] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.246] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.250] I> SKU: Prod
[0000.252] I> Task: Boost clocks
[0000.255] I> Initializing NAFLL for BPMP_CPU_NIC.
[0000.260] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[0000.266] I> BPMP NAFLL lock success.
[0000.269] I> BPMP_CPU_NIC : src = 42, divisor = 0
[0000.274] I> Initializing PLLC2 for AXI_CBB.
[0000.278] I> AXI_CBB : src = 35, divisor = 0
[0000.282] I> Task: Voltage monitor
[0000.285] I> VMON: Vmon re-calibration and fine tuning done
[0000.291] I> Task: UPHY init
[0000.296] I> HSIO UPHY init done
[0000.299] W> Skipping GBE UPHY config
[0000.302] I> Task: Boot device init
[0000.306] I> Boot_device: QSPI_FLASH instance: 0
[0000.310] I> Qspi clock source : pllc_out0
[0000.314] I> QSPI Flash: Macronix 64MB
[0000.318] I> QSPI-0l initialized successfully
[0000.322] I> Task: TSC init
[0000.325] I> Task: Load membct
[0000.328] I> RAM_CODE 0x4000401
[0000.331] I> Loading MEMBCT
[0000.334] I> Slot: 0
[0000.336] I> Binary[0] block-3840 (partition size: 0x40000)
[0000.341] I> Binary name: MEM-BCT-0
[0000.344] I> Size of crypto header is 8192
[0000.348] I> Size of crypto header is 8192
[0000.352] I> strt_pg_num(3840) num_of_pgs(16) read_buf(0x40050000)
[0000.358] I> BCH of MEM-BCT-0 read from storage
[0000.363] I> BCH address is : 0x40050000
[0000.367] I> MEM-BCT-0 header integrity check is success
[0000.372] I> Binary magic in BCH component 0 is MEM0
[0000.377] I> component binary type is 0
[0000.380] I> strt_pg_num(3856) num_of_pgs(115) read_buf(0x40040000)
[0000.387] I> MEM-BCT-0 binary is read from storage
[0000.392] I> MEM-BCT-0 binary integrity check is success
[0000.397] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.404] I> RAM_CODE 0x4000401
[0000.409] I> RAM_CODE 0x4000401
[0000.413] I> Task: Load Page retirement list
[0000.417] I> Task: SDRAM params override
[0000.421] I> Task: Save mem-bct info
[0000.424] I> Task: Carveout allocate
[0000.428] I> RCM blob carveout will not be allocated
[0000.433] I> Update CCPLEX IST carveout from MB1-BCT
[0000.437] I> ECC region[0]: Start:0x0, End:0x0
[0000.442] I> ECC region[1]: Start:0x0, End:0x0
[0000.446] I> ECC region[2]: Start:0x0, End:0x0
[0000.450] I> ECC region[3]: Start:0x0, End:0x0
[0000.454] I> ECC region[4]: Start:0x0, End:0x0
[0000.459] I> Non-ECC region[0]: Start:0x80000000, End:0x880000000
[0000.465] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.469] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.474] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.479] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.489] I> allocated(CO:44) base:0x849800000 size:0x36800000 align: 0x100000
[0000.496] I> allocated(CO:31) base:0x840000000 size:0x8000000 align: 0x8000000
[0000.504] I> allocated(CO:43) base:0x83c000000 size:0x4000000 align: 0x200000
[0000.511] I> allocated(CO:39) base:0x839e00000 size:0x2200000 align: 0x10000
[0000.517] I> allocated(CO:20) base:0x836000000 size:0x2000000 align: 0x2000000
[0000.525] I> allocated(CO:24) base:0x834000000 size:0x2000000 align: 0x2000000
[0000.532] I> allocated(CO:28) base:0x832000000 size:0x2000000 align: 0x2000000
[0000.539] I> allocated(CO:29) base:0x830000000 size:0x2000000 align: 0x2000000
[0000.546] I> allocated(CO:22) base:0x848000000 size:0x1000000 align: 0x1000000
[0000.553] I> allocated(CO:35) base:0x838e00000 size:0x1000000 align: 0x100000
[0000.560] I> allocated(CO:41) base:0x82f000000 size:0x1000000 align: 0x100000
[0000.567] I> allocated(CO:02) base:0x849000000 size:0x800000 align: 0x800000
[0000.574] I> allocated(CO:03) base:0x838000000 size:0x800000 align: 0x800000
[0000.581] I> allocated(CO:06) base:0x82e800000 size:0x800000 align: 0x800000
[0000.588] I> allocated(CO:56) base:0x82e000000 size:0x800000 align: 0x200000
[0000.595] I> allocated(CO:07) base:0x838800000 size:0x400000 align: 0x400000
[0000.602] I> allocated(CO:33) base:0x82dc00000 size:0x400000 align: 0x200000
[0000.609] I> allocated(CO:19) base:0x82d980000 size:0x280000 align: 0x10000
[0000.616] I> allocated(CO:23) base:0x838c00000 size:0x200000 align: 0x200000
[0000.623] I> allocated(CO:01) base:0x82d800000 size:0x100000 align: 0x100000
[0000.630] I> allocated(CO:05) base:0x82d700000 size:0x100000 align: 0x100000
[0000.637] I> allocated(CO:08) base:0x82d600000 size:0x100000 align: 0x100000
[0000.643] I> allocated(CO:09) base:0x82d500000 size:0x100000 align: 0x100000
[0000.650] I> allocated(CO:12) base:0x82d400000 size:0x100000 align: 0x100000
[0000.657] I> allocated(CO:15) base:0x82d300000 size:0x100000 align: 0x100000
[0000.664] I> allocated(CO:17) base:0x82d200000 size:0x100000 align: 0x100000
[0000.671] I> allocated(CO:27) base:0x82d100000 size:0x100000 align: 0x100000
[0000.678] I> allocated(CO:42) base:0x82d000000 size:0x100000 align: 0x100000
[0000.685] I> allocated(CO:54) base:0x82d900000 size:0x80000 align: 0x80000
[0000.692] I> allocated(CO:34) base:0x82cff0000 size:0x10000 align: 0x10000
[0000.699] I> allocated(CO:72) base:0x82cdf0000 size:0x200000 align: 0x10000
[0000.706] I> allocated(CO:47) base:0x82c800000 size:0x400000 align: 0x200000
[0000.712] I> allocated(CO:50) base:0x82c600000 size:0x200000 align: 0x100000
[0000.719] I> allocated(CO:52) base:0x82cdc0000 size:0x30000 align: 0x10000
[0000.726] I> allocated(CO:48) base:0x82cda0000 size:0x20000 align: 0x10000
[0000.733] I> allocated(CO:69) base:0x82cd80000 size:0x20000 align: 0x10000
[0000.740] I> allocated(CO:49) base:0x82cd70000 size:0x10000 align: 0x10000
[0000.746] I> NSDRAM base: 0x80000000, end: 0x82cdf0000, size: 0x7acdf0000
[0000.753] I> Task: Thermal check
[0000.756] I> max_chip_limit = 105
[0000.759] I> min_chip_limit = -28
[0000.763] I> max temp read = 36
[0000.766] I> min temp read = 35
[0000.768] I> Task: Update FSI SCR with thermal fuse data
[0000.774] I> Task: Enable WDT 5th expiry
[0000.777] I> Task: I2C register
[0000.780] I> Task: Set I2C bus freq
[0000.784] I> Task: Reset FSI
[0000.787] I> Task: Pinmux init
[0000.790] I> Task: Prod config init
[0000.793] I> Task: Pad voltage init
[0000.797] I> Task: Prod init
[0000.799] I> Task: Program rst req config reg
[0000.804] I> Task: Common rail init
[0000.807] I> DONE: Thermal config
[0000.811] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.819] I> DONE: SOC rail config
[0000.823] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0000.829] I> DONE: MEMIO rail config
[0000.833] I> DONE: GPU rail info
[0000.836] I> DONE: CV rail info
[0000.839] I> Task: Mem clock src
[0000.842] I> Task: Misc. board config
[0000.846] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0000.851] I> Task: SDRAM init
[0000.854] I> MemoryType: 4 MemBctRevision: 9
[0000.861] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 9
[0000.868] I> MSS CAR: Init PLLM
[0000.871] I> MSS CAR: Init PLLHUB
[0000.876] I> Encryption: MTS: en, TX: en, VPR: en, GSC: en
[0000.888] I> SDRAM initialized!
[0000.891] I> SDRAM Size in Total 0x800000000
[0000.895] I> Task: Dram Ecc scrub
[0000.898] I> Task: DRAM alias check
[0000.914] I> Task: Program NSDRAM carveout
[0000.918] I> NSDRAM carveout encryption is enabled
[0000.923] I> Program NSDRAM carveout
[0000.927] I> Task: Register checker
[0000.930] I> Task: Enable clock-mon
[0000.944] I> FMON: Fmon re-programming done
[0000.948] I> Task: Mapper init
[0000.951] I> Task: SC7 Context Init
[0000.955] I> Task: CCPLEX IST init
[0000.958] I> Task: CPU WP0
[0000.961] I> Loading MCE
[0000.963] I> Slot: 0
[0000.965] I> Binary[8] block-22784 (partition size: 0x80000)
[0000.971] I> Binary name: MCE
[0000.974] I> Size of crypto header is 8192
[0000.978] I> Size of crypto header is 8192
[0000.982] I> strt_pg_num(22784) num_of_pgs(16) read_buf(0x4003e000)
[0000.988] I> BCH of MCE read from storage
[0000.992] I> BCH address is : 0x4003e000
[0000.996] I> MCE header integrity check is success
[0001.000] I> Binary magic in BCH component 0 is MTSM
[0001.005] I> component binary type is 8
[0001.009] I> Size of crypto header is 8192
[0001.013] I> strt_pg_num(22800) num_of_pgs(350) read_buf(0x40000000)
[0001.021] I> MCE binary is read from storage
[0001.025] I> MCE binary integrity check is success
[0001.030] I> Binary MCE loaded successfully at 0x40000000 (0x2baf0)
[0001.036] I> Size of crypto header is 8192
[0001.047] I> Size of crypto header is 8192
[0001.051] I> Sending WP0 mailbox command to PSC
[0001.060] I> Task: XUSB Powergate
[0001.063] I> Skipping powergate XUSB.
[0001.067] I> Task: MB1 fixed firewalls
[0001.073] W> Firewall readback mismatch
[0001.078] I> Task: Load bpmp-fw
[0001.081] I> Slot: 0
[0001.083] I> Binary[15] block-9984 (partition size: 0x180000)
[0001.089] I> Binary name: BPMP_FW
[0001.092] I> Size of crypto header is 8192
[0001.096] I> Size of crypto header is 8192
[0001.100] I> strt_pg_num(9984) num_of_pgs(16) read_buf(0x807fe000)
[0001.106] I> BCH of BPMP_FW read from storage
[0001.110] I> BCH address is : 0x807fe000
[0001.114] I> BPMP_FW header integrity check is success
[0001.119] I> Binary magic in BCH component 0 is BPMF
[0001.124] I> component binary type is 15
[0001.128] I> Size of crypto header is 8192
[0001.132] I> strt_pg_num(10000) num_of_pgs(2017) read_buf(0x80000000)
[0001.149] I> BPMP_FW binary is read from storage
[0001.156] I> BPMP_FW binary integrity check is success
[0001.161] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xfc080)
[0001.167] I> Slot: 0
[0001.169] I> Binary[16] block-13056 (partition size: 0x400000)
[0001.175] I> Binary name: BPMP_FW_DTB
[0001.178] I> Size of crypto header is 8192
[0001.182] I> Size of crypto header is 8192
[0001.186] I> strt_pg_num(13056) num_of_pgs(16) read_buf(0x807fc000)
[0001.193] I> BCH of BPMP_FW_DTB read from storage
[0001.197] I> BCH address is : 0x807fc000
[0001.201] I> BPMP_FW_DTB header integrity check is success
[0001.206] I> Binary magic in BCH component 0 is BPMD
[0001.211] I> component binary type is 16
[0001.215] I> Size of crypto header is 8192
[0001.219] I> strt_pg_num(13072) num_of_pgs(502) read_buf(0x807bd3f0)
[0001.228] I> BPMP_FW_DTB binary is read from storage
[0001.233] I> BPMP_FW_DTB binary integrity check is success
[0001.238] I> Binary BPMP_FW_DTB loaded successfully at 0x807bd3f0 (0x3ebc0)
[0001.245] I> Task: BPMP fw ast config
[0001.249] I> Task: Load psc-fw
[0001.252] I> Slot: 0
[0001.254] I> Binary[17] block-21248 (partition size: 0xc0000)
[0001.259] I> Binary name: PSC_FW
[0001.262] I> Size of crypto header is 8192
[0001.266] I> Size of crypto header is 8192
[0001.270] I> strt_pg_num(21248) num_of_pgs(16) read_buf(0x80ffe000)
[0001.277] I> BCH of PSC_FW read from storage
[0001.281] I> BCH address is : 0x80ffe000
[0001.284] I> PSC_FW header integrity check is success
[0001.289] I> Binary magic in BCH component 0 is PFWP
[0001.294] I> component binary type is 17
[0001.298] I> Size of crypto header is 8192
[0001.302] I> strt_pg_num(21264) num_of_pgs(591) read_buf(0x80fb4200)
[0001.311] I> PSC_FW binary is read from storage
[0001.316] I> PSC_FW binary integrity check is success
[0001.321] I> Binary PSC_FW loaded successfully at 0x80fb4200 (0x49df0)
[0001.328] I> Task: Load nvdec-fw
[0001.331] I> Slot: 0
[0001.333] I> Binary[7] block-6400 (partition size: 0x100000)
[0001.338] I> Binary name: NVDEC
[0001.341] I> Size of crypto header is 8192
[0001.345] I> Size of crypto header is 8192
[0001.349] I> strt_pg_num(6400) num_of_pgs(16) read_buf(0x800fe000)
[0001.355] I> BCH of NVDEC read from storage
[0001.359] I> BCH address is : 0x800fe000
[0001.363] I> NVDEC header integrity check is success
[0001.368] I> Binary magic in BCH component 0 is NDEC
[0001.373] I> component binary type is 7
[0001.376] I> Size of crypto header is 8192
[0001.380] I> strt_pg_num(6416) num_of_pgs(560) read_buf(0x80000000)
[0001.390] I> NVDEC binary is read from storage
[0001.395] I> NVDEC binary integrity check is success
[0001.399] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0001.406] I> Size of crypto header is 8192
[0001.417] I> Task: Load tsec-fw
[0001.420] I> TSEC-FW load support not enabled
[0001.424] I> Task: GPIO interrupt map
[0001.428] I> Task: SC7 context save
[0001.431] I> Slot: 0
[0001.433] I> Binary[27] block-0 (partition size: 0x100000)
[0001.439] I> Binary name: BR_BCT
[0001.442] I> Size of crypto header is 8192
[0001.446] I> Size of crypto header is 8192
[0001.450] I> Size of crypto header is 8192
[0001.453] I> strt_pg_num(0) num_of_pgs(16) read_buf(0xa0000000)
[0001.459] I> BR_BCT binary is read from storage
[0001.464] I> BR_BCT binary integrity check is success
[0001.469] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[0001.475] I> Slot: 0
[0001.477] I> Binary[13] block-23808 (partition size: 0x30000)
[0001.483] I> Binary name: SC7-FW
[0001.486] I> Size of crypto header is 8192
[0001.490] I> Size of crypto header is 8192
[0001.494] I> Size of crypto header is 8192
[0001.497] I> Size of crypto header is 8192
[0001.501] I> strt_pg_num(23808) num_of_pgs(16) read_buf(0xa0002000)
[0001.508] I> BCH of SC7-FW read from storage
[0001.512] I> BCH address is : 0xa0002000
[0001.516] I> SC7-FW header integrity check is success
[0001.521] I> Binary magic in BCH component 0 is WB0B
[0001.525] I> component binary type is 13
[0001.529] I> Size of crypto header is 8192
[0001.533] I> strt_pg_num(23824) num_of_pgs(347) read_buf(0xa0004000)
[0001.541] I> SC7-FW binary is read from storage
[0001.546] I> SC7-FW binary integrity check is success
[0001.551] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x2b440)
[0001.557] I> Slot: 0
[0001.559] I> Binary[22] block-24192 (partition size: 0x30000)
[0001.565] I> Binary name: PSC_RF
[0001.568] I> Size of crypto header is 8192
[0001.572] I> Size of crypto header is 8192
[0001.576] I> Size of crypto header is 8192
[0001.580] I> Size of crypto header is 8192
[0001.584] I> strt_pg_num(24192) num_of_pgs(16) read_buf(0xa002f440)
[0001.590] I> BCH of PSC_RF read from storage
[0001.594] I> BCH address is : 0xa002f440
[0001.598] I> PSC_RF header integrity check is success
[0001.603] I> Binary magic in BCH component 0 is PSCR
[0001.608] I> component binary type is 22
[0001.611] I> Size of crypto header is 8192
[0001.615] I> strt_pg_num(24208) num_of_pgs(224) read_buf(0xa0031440)
[0001.623] I> PSC_RF binary is read from storage
[0001.627] I> PSC_RF binary integrity check is success
[0001.632] I> Binary PSC_RF loaded successfully at 0xa0031440 (0x1be60)
[0001.642] I> Task: Save WP0 payload to SC7 ctx
[0001.646] I> Task: Load MB2rf binary to SC7 ctx
[0001.650] I> Slot: 0
[0001.652] I> Binary[14] block-24576 (partition size: 0x20000)
[0001.658] I> Binary name: MB2_RF
[0001.661] I> Size of crypto header is 8192
[0001.665] I> Size of crypto header is 8192
[0001.669] I> Size of crypto header is 8192
[0001.673] I> Size of crypto header is 8192
[0001.677] I> strt_pg_num(24576) num_of_pgs(16) read_buf(0xa00d5d10)
[0001.683] I> BCH of MB2_RF read from storage
[0001.687] I> BCH address is : 0xa00d5d10
[0001.691] I> MB2_RF header integrity check is success
[0001.696] I> Binary magic in BCH component 0 is MB2R
[0001.701] I> component binary type is 14
[0001.704] I> Size of crypto header is 8192
[0001.708] I> strt_pg_num(24592) num_of_pgs(223) read_buf(0xa00d7d10)
[0001.716] I> MB2_RF binary is read from storage
[0001.720] I> MB2_RF binary integrity check is success
[0001.725] I> Binary MB2_RF loaded successfully at 0xa00d7d10 (0x1bd90)
[0001.732] I> Task: Save fuse alias data to SC7 ctx
[0001.736] I> Task: Save PMIC data to SC7 ctx
[0001.740] I> Task: Save Pinmux data to SC7 ctx
[0001.745] I> Task: Save Pad Voltage data to SC7 ctx
[0001.749] I> Task: Save controller prod data to SC7 ctx
[0001.755] I> Task: Save prod cfg data to SC7 ctx
[0001.759] I> Task: Save I2C bus freq data to SC7 ctx
[0001.764] I> Task: Save SOCTherm data to SC7 ctx
[0001.768] I> Task: Save FMON data to SC7 ctx
[0001.772] I> Task: Save VMON data to SC7 ctx
[0001.776] I> Task: Save TZDRAM data to SC7 ctx
[0001.781] I> Task: Save GPIO int data to SC7 ctx
[0001.785] I> Task: Save clock data to SC7 ctx
[0001.789] I> Task: Save debug data to SC7 ctx
[0001.794] I> Task: Save MBWT data to SC7 ctx
[0001.802] I> SC7 context save done
[0001.805] I> Task: Load MB2/Applet/FSKP
[0001.809] I> Loading MB2
[0001.811] I> Slot: 0
[0001.813] I> Binary[6] block-8448 (partition size: 0x80000)
[0001.818] I> Binary name: MB2
[0001.821] I> Size of crypto header is 8192
[0001.825] I> Size of crypto header is 8192
[0001.829] I> strt_pg_num(8448) num_of_pgs(16) read_buf(0x8007e000)
[0001.835] I> BCH of MB2 read from storage
[0001.839] I> BCH address is : 0x8007e000
[0001.843] I> MB2 header integrity check is success
[0001.848] I> Binary magic in BCH component 0 is MB2B
[0001.852] I> component binary type is 6
[0001.856] I> Size of crypto header is 8192
[0001.860] I> strt_pg_num(8464) num_of_pgs(845) read_buf(0x80000000)
[0001.871] I> MB2 binary is read from storage
[0001.876] I> MB2 binary integrity check is success
[0001.880] I> Binary MB2 loaded successfully at 0x80000000 (0x69900)
[0001.887] I> Task: Map CCPLEX SHARED carveout
[0001.891] I> Task: Prepare MB2 params
[0001.895] I> Task: Dram ecc test
[0001.898] I> Task: Misc NV security settings
[0001.902] I> NVDEC sticky bits programming done
[0001.906] I> Successfully powergated NVDEC
[0001.910] I> Task: Disable/Reload WDT
[0001.914] I> Task: Program misc carveouts
[0001.918] I> Program IPC carveouts
[0001.921] I> Task: Disable SCPM/POD reset
[0001.925] I> SLCG Global override status := 0x0
[0001.929] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-c6a05a9f)
I> Emulation:
I> Entry timestamp: 0x001de28d
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0x82e000000, size:0x800000]
I> Task: MB2 Params integrity check
I> Task: ARI update carveout TZDRAM
I> Task: Configure OEM set LA/PTSA values
I> Task: Check MC errors
I> Task: Enable hot-plug capability
I> Task: PSC mailbox init
I> Task: Enable clock for external modules
I> Task: OEM SC7 context save init
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout
I> Task: Program CBB PCIE AMAP regions
I> Secondary storage device: QSPI_FLASH instance: 0
I> Secondary storage device: SDMMC_USER instance: 3
I> sdmmc HS400 mode enabled
I> Task: Partition Manager Init
I> strt_pg_num(1) num_of_pgs(1) read_buf(0x82e001000)
I> strt_pg_num(131071) num_of_pgs(1) read_buf(0x82e001000)
I> strt_pg_num(131039) num_of_pgs(32) read_buf(0x82e001200)
I> Found 60 partitions in QSPI_FLASH (instance 0)
W> Cannot find any partition table for 00000003
W> PARTITION_MANAGER: Failed to publish partition.
I> Found 15 partitions in SDMMC_USER (instance 3)
I> Task: Pass DRAM ECC PRL Flag to FSI
I> Task: Load and authenticate registered FWs
I> Task: Load AUXP FWs
I> Successfully register SPE FW load task with MB2 loader
I> Skipping SCE FW load
I> Successfully register RCE FW load task with MB2 loader
I> Successfully register DCE FW load task with MB2 loader
I> Unpowergating APE
I> Unpowergate done
I> Successfully register APE FW load task with MB2 loader
I> Skipping FSI FW load
I> Successfully register XUSB FW load task with MB2 loader
I> Successfully register PVA FW load task with MB2 loader
I> Partition name: A_spe-fw
I> Size of partition: 589824
I> Binary@ device:3/0 block-55040 (partition size: 0x90000), name: A_spe-fw
I> strt_pg_num(55040) num_of_pgs(16) read_buf(0x40066650)
I> strt_pg_num(55056) num_of_pgs(512) read_buf(0x82d600000)
I> Partition name: A_rce-fw
I> Size of partition: 1048576
I> Binary@ device:3/0 block-56192 (partition size: 0x100000), name: A_rce-fw
I> strt_pg_num(56192) num_of_pgs(16) read_buf(0x40066650)
I> strt_pg_num(56208) num_of_pgs(880) read_buf(0x82d200000)
I> spe: Authentication Finalize Done
I> Binary spe loaded successfully at 0x82d600000
I> Partition name: A_dce-fw
I> Size of partition: 5242880
I> Binary@ device:3/0 block-44800 (partition size: 0x500000), name: A_dce-fw
I> strt_pg_num(44800) num_of_pgs(16) read_buf(0x40066650)
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0x82d200000
I> Successfully register RCE FW context save task with MB2 loader
I> dce : oem authentication of header done
I> strt_pg_num(44816) num_of_pgs(1) read_buf(0x82e1403d8)
I> strt_pg_num(44816) num_of_pgs(8) read_buf(0x82e1403d8)
I> dce : meta-blob integrity check is success.
I> strt_pg_num(44824) num_of_pgs(512) read_buf(0x82e0003c0)
I> strt_pg_num(45336) num_of_pgs(512) read_buf(0x82e0403c0)
I> dce : will be decompressed at 0x836000000
I> version 1 Bin 1 BCheckSum 0 content_size 0 Content ChkSum 1 reserved_00 0
I> Reserved10 0 BlockMaxSize 5 Reserved11 0
I> strt_pg_num(45848) num_of_pgs(512) read_buf(0x82e0803c0)
I> dce : decompressed to 12060128 bytes
I> dce: plain binary integrity check is success
I> Partition name: A_adsp-fw
I> Size of partition: 2097152
I> Binary@ device:3/0 block-58240 (partition size: 0x200000), name: A_adsp-fw
I> strt_pg_num(58240) num_of_pgs(16) read_buf(0x40066650)
I> strt_pg_num(58256) num_of_pgs(800) read_buf(0x838800000)
I> dce: Authentication Finalize Done
I> Binary dce loaded successfully at 0x836000000
I> Partition name: A_xusb-fw
I> Size of partition: 262144
I> Binary@ device:3/0 block-9472 (partition size: 0x40000), name: A_xusb-fw
I> strt_pg_num(9472) num_of_pgs(16) read_buf(0x40066650)
I> strt_pg_num(9488) num_of_pgs(312) read_buf(0x82d700000)
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0x838800000
I> Successfully register APE FW context save task with MB2 loader
I> Partition name: A_pva-fw
I> Binary@ device:3/0 block-62336 (partition size: 0x40000), name: A_pva-fw
I> strt_pg_num(62336) num_of_pgs(16) read_buf(0x40066650)
I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0x82d700000
I> Successfully register XUSB FW context save task with MB2 loader
I> pva-fw : oem authentication of header done
I> strt_pg_num(62352) num_of_pgs(1) read_buf(0x82e1403d8)
I> strt_pg_num(62352) num_of_pgs(8) read_buf(0x82e1403d8)
I> pva-fw : meta-blob integrity check is success.
I> strt_pg_num(62360) num_of_pgs(512) read_buf(0x82e0003c0)
I> pva-fw : will be decompressed at 0x82d980000
I> pva-fw : decompressed to 2156512 bytes
I> pva-fw: plain binary integrity check is success
I> pva-fw: Authentication Finalize Done
I> Binary pva-fw loaded successfully at 0x82d980000
I> Successfully register PVA FW context save task with MB2 loader
I> Task: Carveout setup
I> Program remaining OEM carveouts
I> Task: Enable FSITHERM
I> Task: Enable FSI VMON
I> FSI VMON: FSI Vmon re-calibration and fine tuning done
I> Task: Validate FSI Therm readings
I> Task: Restore XUSB sec
I> Task: Enable FSI SE clock
I> Enable FSI-SE clock…
I> Task: Initialize SBSA UART CAR
I> Task: Initialize CPUBL Params
I> CPUBL-params @ 0x832000000
I> Task: Ratchet update
W> Skip ratchet update - OPTIN fuse not set
I> Task: Prepare eeprom data
I> Task: FSI padctl context save
I> Task: Unpowergate APE
W> mb2_unpowergate_ape: skip! APE is in unpowergated state
I> Task: Memctrl reconfig pending clients
I> Task: OEM firewalls
I> OEM firewalls configured
I> Task: Powergate APE
I> Powergating APE
I> Powergate done
I> Task: OEM firewall restore saved settings
I> Task: Unhalt AUXPs
I> Unhalting SPE…
I> Enabling combined UART
����spe: early_init
����vic initialized
����tsc initialized
����aon lic initialized
����spe: tag is 5243985d1b1eb3f06fac6d36bd7e74ac
����spe: SafeRTOS v8.4
����spe: init
����scheduler initialized
����aon hsp initialized
����tag initialized
����tcu initialized
����bpmp ipc initialized
����spe: late init
����cpu_nic clock initialized
����apb clock initialized
����pm initialized
����bpmp hsp initialized
����top1 hsp initialized
����ccplex ipc initialized
����spe: start scheduler
I> Task: Trigger mailbox for PSC-BL1 exit
I> Sending opcode 0x4d420802 to psc
I> Received ACK from psc
I> Task: Start secure NOR provision
I> Skip Secure NOR provisioning
I> Task: Trigger load FSI keyblob
I> Skipping FSI key blob copy
I> Task: Complete load FSI keyblob
I> Task: MB2-PSC_FW Key Manager Init
I> Sending opcode OP_PSC_KEY_MANAGER to psc-fw
I> Sending opcode 0x4b45594d t��
hwwdt_init: WDT boot cfg 0x710010 sts 0x10
bpmp: socket 0
bpmp: base binary md5 is ac83764aab09e08198fdb2c012af5bb1
bpmp: combined binary md5 is a381fb560faa591136e784a2cb58c159
bpmp: firmware tag is a381fb560faa591136e7-ac83764aab0
initialized vwdt
initialized mail_early
initialized fuse
initialized vfrel
initialized adc
fmon_populate_monitors: found 199 monitors
initialized fmon
initialized mc
initialized reset
initialized uphy_early
initialized emc_early
initialized pm
465 clocks registered
initialized clk_mach
initialized clk_cal_early
initialized clk_mach_early_config
initialized io_dpd
initialized soctherm
initialized regime
initialized i2c
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
initialized vrmon
initialized regulator
��o psc
I> Task: Unhalt FSI
I> FSI unhalt skipped
I> SCE unhalt skipped
I> Unhalting RCE
I> RCE unhalt successful
I> Unhalting DCE
I> DCE unhalt successful
I> APE unhalt skipped
I> Task: Load HV/CPUBL
I> Task: Load TOS
I> Tas��initialized avfs_clk_platform
initialized powe��[ 2.529261] Camer��rgate
��a-FW on t234-rce-safe started
TCU early console enabled.
��k: Trigge��initialized dvs
initialized clk_mach_config
initialized suspend
initialized strap
initialized mce_dbell
��r load TSEC leyblob
I> Sending opcode 0x53535452 to psc
��I> Sent opcode to psc
I> Partition name: A_cpu-bootloader
I> Size of partition: 3670016
I> Binary@ device:3/0 block-24832 (partition size: 0x380000), name: A_cpu-bootloader
��DCE Started
��I> strt_pg_num(24832) num_of_pgs(16) read_buf(0x40066650)
I> strt_pg_num(24848) num_of_pgs(7008) read_buf(0x82c800000)
��DCE_R5_Init
��initialized emc
initialized emc_mrq
��MPU enabled
��initialized clk_cal
��DCE_SW_Init
��initialized uphy_dt
initialized uphy_mrq
HSIO UPHY reset has been de-asserted 0x0
initialized uphy
initialized pg_late
initialized pg_mrq_init
swdtimer_init: reg polling start w period 47 ms
initialized swdtimer
initialized hwwdt_late
initialized bwmgr
initialized thermal_host_trip
initialized thermal_mrq
initialized oc_mrq
initialized reset_mrq
initialized mail_mrq
initialized fmon_mrq
initialized clk_mrq
initialized avfs_mrq
initialized i2c_mrq
initialized tag_mrq
initialized bwmgr_mrq
initialized console_mrq
��I> Partition name: A_secure-os
I> Size of partition: 4194304
��missing prod DT calibration data for 199 fmons
initialized clk_sync_fmon_post
��I> Binary@ device:3/0 block-32000 (partition size: 0x400000), name: A_secure-os
I> strt_pg_num(32000) num_of_pgs(16) read_buf(0x40066650)
I> strt_pg_num(32016) num_of_pgs(2560) read_buf(0x83fdc0000)
I> MB2-pa��initialized clk_cal_late
initialized noc_late
initialized cvc
��rams @ 0x40060000
I> NSDRAM carve��initialized avfs_clk_mach_post
initialized avfs_clk_platform_post
initialized cvc_late
initialized rm
initialized console_late
handling unreferenced clks
enable can1_core
enable can1_host
enable can2_core
enable can2_host
enable pwm3
enable mss_encrypt
enable maud
enable pllg_ref
enable dsi_core
enable aza_2xbit
enable pllc4_muxed
enable sdmmc4_axicif
enable xusb_ss
enable xusb_fs
enable xusb_falcon
enable xusb_core_mux
enable dsi_lp
enable sdmmc_legacy_tm
initialized clk_mach_p��[ 2.727338] Camera-FW on t234-rce-safe ready SHA1=e2238c99 (crt 12.422 ms,��ost
initialized pg_post
initialized regulator_post
initialized profile
ini�� total boot 211.571 ms)
��tialized mrq
initialized patrol_scrubber
initialized cactmon
initialized extras_post
bpmp: init complete
��out base: 0x80000000, size: 0x7acdf0000
I> cpubl_params: nsdram: carveout: 1, encryption: 1
I> cpubl: Authentication Finalize Done
I> Binary cpubl loaded successfully at 0x82c800000
I> tos: Authentication Finalize Done
I> Binary tos loaded successfully at 0x83fdc0000
I> Relocating OP-TEE dtb from: 0x83feff0f0 to 0x83c040020, size: 0x2837
I> [0] START: 0x80000000, SIZE: 0x7acdf0000
I> [1] START: 0x832000000, SIZE: 0x2000000
I> Setting NS memory ranges to OP-TEE dtb finished.
I> Partition name: A_eks
I> Binary@ device:3/0 block-44288 (partition size: 0x40000), name: A_eks
I> strt_pg_num(44288) num_of_pgs(16) read_buf(0x40066650)
��Admin Task Init
Admin Task Init complete
Print Task Init
RM Task Init
SHA Task Init
Admin Task Started
DCE SC7 SHA Enabled
RM Task S��I> strt_pg_num(44304) num_of_pgs(8) read_buf(0x83c020000)
��tarted
RM Task R��I> eks: Authentication Finalize Done
I> Binary eks loaded successfully at 0x83c020000
I> EKB detected (length: 0x410) @ VA:0x83c020000
I> Task: Add cpubl params integrity check
��unning
Print Task Started
Print Task Running
SHA Task Started
DCE: FW Boot Complete
Admin Task Running
SHA Task Running
��I> Added cpubl params digest.
I> Task: Prepare TOS params
I> Setting EKB blob info to OPTEE dtb finished.
I> Setting OPTEE arg3: 0x83c040020
I> OEM sc7 context saved
I> Task: Disable MSS perf stats
I> Task: Program display sticky bits
I> Task: Storage device deinit
I> Task: SMMU external bypass disable
I> Task: SMMU init
I> Task: Program GICv3 registers
I> Task: Audit firewall settings
I> Task: Bootchain failure check
I> Current Boot-Chain Slot: 0
I> BR-BCT Boot-Chain is 0, and status is 1. Set UPDATE_BRBCT bit to 0
I> Task: Burn RESERVED_ODM0 fuse
I> Task: Lock fusing
I> Task: Clear dec source key
I> MB2 finished
��NOTICE: BL31: v2.8(release):8a7f432be
NOTICE: BL31: Built : 10:30:22, Nov 30 2023
I/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 3.22 (gcc version 11.3.0 (Buildroot 2022.08)) #2 Thu Nov 30 18:39:35 UTC 2023 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check Porting guidelines — OP-TEE documentation documentation
I/TC: Primary CPU initializing
I/TC: Test OEM keys are being used. This is insecure for shipping products!
I/TC: Primary CPU switching to normal world boot
Jetson UEFI firmware (version 36.2.0-gcid-34956989 built on 2023-11-30T18:35:35+00:00)
��I/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
��[ 5.187121] Camera-FW on t234-rce-safe started
��[ 5.234607] Camera-FW on t234-rce-safe ready SHA1=e2238c99 (crt 0.907 ms, total boot 48.445 ms)
��E/TC:?? 00 get_rpc_alloc_res:645 RPC allocation failed. Non-secure world result: ret=0xffff0000 ret_origin=0
E/LD: init_elf:486 sys_open_ta_bin(bc50d971-d4c9-42c4-82cb-343fb7f37896)
E/TC:?? 00 ldelf_init_with_ldelf:131 ldelf failed with res: 0xffff000c
Jetson System firmware version 36.2.0-gcid-34956989 date 2023-11-30T18:35:35+00:
00
ESC to enter Setup.
F11 to enter Boot Manager Menu.
Enter to continue boot.
** WARNING: Test Key is used. **
L4TLauncher: Attempting Direct Boot
L4T boot options
0: primary kernel
1: backup kernel
Press 0-1 to boot selection within 3.0 seconds.
Press any other key to boot default (Option: 0)
EFI stub: Booting Linux Kernel…
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services…
��debugfs initialized
��[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.15.122-tegra (buildbrain@mobile-u64-6517-d7000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2022.08) 11.3.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT Thu Nov 30 10:30:37 PST 2023 ()
[ 0.000000] Machine model: NVIDIA Jetson AGX Orin Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x8281ef318 SMBIOS=0xffff0000 SMBIOS 3.0=0x827c10000 MEMATTR=0x82194e018 ESRT=0x8218d7f98 RNG=0x815860018 MEMRESERVE=0x816330f98
[ 0.000000] random: crng init done
[ 0.000000] secureboot: Secure boot disabled
[ 0.000000] esrt: Reserving ESRT space from 0x00000008218d7f98 to 0x00000008218d7fd0.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000805000000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x0000000833ffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0x828c80800-0x828c82fff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000000833ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x0000000818c70fff]
[ 0.000000] node 0: [mem 0x0000000818c71000-0x0000000818dcbfff]
[ 0.000000] node 0: [mem 0x0000000818dcc000-0x00000008262affff]
[ 0.000000] node 0: [mem 0x00000008262b0000-0x00000008281effff]
[ 0.000000] node 0: [mem 0x00000008281f0000-0x000000082c5fffff]
[ 0.000000] node 0: [mem 0x000000082c600000-0x000000082c7fffff]
[ 0.000000] node 0: [mem 0x000000082c800000-0x000000082cd6ffff]
[ 0.000000] node 0: [mem 0x0000000832000000-0x0000000833ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000833ffffff]
��WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpusysclk
��[ 0.000000] On node 0, zone Normal: 21136 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 16384 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
��WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc1clk
��[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 29 pages/cpu s80344 r8192 d30248 u118784
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Address authentication (architected algorithm)
[ 0.000000] CPU features: detected: GIC system register CPU interface
��WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc0clk
��[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: detected: Hardware dirty bit management
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 7929968
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 console=tty0 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb��WARNING: clock_disable: clk_power_ungate on gated domain 34 for dla1_core
�� root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb video=efifb:off console=tty0 bl_prof_dataptr=2031616@0x82C610000 bl_prof_ro_ptr=65536@0x82C600000 ��WARNING: clock_disable: clk_power_ungate on gated domain 34 for nafll_dla1_core
[ 0.000000] Unknown kernel command line parameters “bl_prof_dataptr=2031616@0x82C610000 bl_prof_ro_ptr=65536@0x82C600000”, will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
��WARNING: clock_disable: clk_power_ungate on gated domain 34 for dla1_falcon
��[ 0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000fbfe0000-0x00000000fffe0000] (64MB)
[ 0.000000] Memory: 31153996K/32224704K available (197��WARNING: clock_disable: clk_power_ungate on gated domain 34 for nafll_dla1_falcon
��12K kernel code, 4056K rwdata, 9960K rodata, 7680K init, 528K bss, 808564K reserved, 262144K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Preemptible hierarchical ��WARNING: clock_disable: clk_power_ungate on gated domain 34 for dla0_core
��RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing var��WARNING: clock_disable: clk_power_ungate on gated domain 34 for nafll_dla0_core
��iant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GI��WARNING: clock_disable: clk_power_ungate on gated domain 34 for dla0_falcon
��C: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: 16 PPIs implement��WARNING: clock_disable: clk_power_ungate on gated domain 34 for nafll_dla0_falcon
��ed
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000552] Console: colour dummy device 80x25
[ 0.000570] printk: console [tty0] enabled
[ 0.000707] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.000722] pid_max: default: 32768 minimum: 301
[ 0.000791] LSM: Security Framework initializing
[ 0.000836] Yama: becoming mindful.
[ 0.000872] SELinux: Initializing.
[ 0.001095] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.001214] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.003741] rcu: Hierarchical SRCU implementation.
[ 0.007957] Tegra Revision: A01 SKU: 210 CPU Process: 0 SoC Process: 0
[ 0.008343] Remapping and enabling EFI services.
[ 0.009451] smp: Bringing up secondary CPUs …
[ 0.010250] Detected PIPT I-cache on CPU1
[ 0.010370] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.010425] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.011167] Detected PIPT I-cache on CPU2
[ 0.011180] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.011200] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.011864] Detected PIPT I-cache on CPU3
[ 0.011878] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.011894] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.014607] Detected PIPT I-cache on CPU4
[ 0.014636] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[ 0.014668] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[ 0.015391] Detected PIPT I-cache on CPU5
[ 0.015404] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[ 0.015422] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[ 0.016080] Detected PIPT I-cache on CPU6
[ 0.016093] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[ 0.016112] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.016802] Detected PIPT I-cache on CPU7
[ 0.016815] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[ 0.016834] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.016906] smp: Brought up 1 node, 8 CPUs
[ 0.016913] SMP: Total of 8 processors activated.
[ 0.016919] CPU features: detected: 32-bit EL0 Support
[ 0.016922] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.016925] CPU features: detected: Common not Private translations
[ 0.016928] CPU features: detected: CRC32 instructions
[ 0.016929] CPU features: detected: Data cache clean to Point of Persistence
[ 0.016931] CPU features: detected: Generic authentication (architected algorithm)
[ 0.016933] CPU features: detected: RCpc load-acquire (LDAPR)
[ 0.016935] CPU features: detected: LSE atomic instructions
[ 0.016937] CPU features: detected: Privileged Access Never
[ 0.016939] CPU features: detected: RAS Extension Support
[ 0.016945] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.043268] spectre-bhb mitigation disabled by command line option
[ 0.069119] CPU: All CPU(s) started at EL2
[ 0.074229] devtmpfs: initialized
[ 0.097540] KASLR enabled
[ 0.097750] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.097779] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.102663] pinctrl core: initialized pinctrl subsystem
[ 0.103714] SMBIOS 3.6.0 present.
[ 0.103731] DMI: Unknown NVIDIA Jetson AGX Orin Developer Kit/NVIDIA Jetson AGX Orin Developer Kit, BIOS 36.2.0-gcid-34956989 11/30/2023
[ 0.104334] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.106352] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.106718] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.107054] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.107109] audit: initializing netlink subsys (disabled)
[ 0.107249] audit: type=2000 audit(0.104:1): state=initialized audit_enabled=0 res=1
[ 0.109131] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.109136] thermal_sys: Registered thermal governor ‘user_space’
[ 0.109139] thermal_sys: Registered thermal governor ‘power_allocator’
[ 0.113646] cpuidle: using governor menu
[ 0.113899] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.113994] ASID allocator initialised with 32768 entries
[ 0.115907] Serial: AMBA PL011 UART driver
[ 0.117469] printk: console [ramoops-1] enabled
[ 0.117474] pstore: Registered ramoops as persistent store backend
[ 0.117479] ramoops: using 0x200000@0x82cdf0000, ecc: 0
[ 0.127528] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 118, base_baud = 0) is a SBSA
[ 0.127561] printk: console [ttyAMA0] enabled
[ 0.139224] platform bpmp: Fixing up cyclic dependency with 2c60000.external-memory-controller
[ 0.148278] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.148285] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.148286] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.148288] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.149252] cryptd: max_cpu_qlen set to 1000
[ 0.150931] ACPI: Interpreter disabled.
[ 0.152808] iommu: Default domain type: Translated
[ 0.152814] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.153143] SCSI subsystem initialized
[ 0.153309] vgaarb: loaded
[ 0.153465] usbcore: registered new interface driver usbfs
[ 0.153487] usbcore: registered new interface driver hub
[ 0.153503] usbcore: registered new device driver usb
[ 0.153932] pps_core: LinuxPPS API ver. 1 registered
[ 0.153938] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.153956] PTP clock support registered
[ 0.154027] EDAC MC: Ver: 3.0.0
[ 0.155199] Registered efivars operations
[ 0.155836] FPGA manager framework
[ 0.155915] Advanced Linux Sound Architecture Driver Initialized.
[ 0.156787] clocksource: Switched to clocksource arch_sys_counter
[ 0.192881] VFS: Disk quotas dquot_6.6.0
[ 0.192945] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.193185] pnp: PnP ACPI: disabled
[ 0.196626] NET: Registered PF_INET protocol family
[ 0.197226] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.199596] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 0.199634] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.199668] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.199879] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.201208] TCP: Hash tables configured (established 262144 bind 65536)
[ 0.201394] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.201466] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.201715] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.202199] RPC: Registered named UNIX socket transport module.
[ 0.202204] RPC: Registered udp transport module.
[ 0.202205] RPC: Registered tcp transport module.
[ 0.202207] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.202225] PCI: CLS 0 bytes, default 64
[ 0.202438] Unpacking initramfs…
[ 0.214048] hw perfevents: enabled with armv8_cortex_a78 PMU driver, 7 counters available
[ 0.214406] kvm [1]: IPA Size Limit: 48 bits
[ 0.214446] kvm [1]: GICv3: no GICV resource entry
[ 0.214454] kvm [1]: disabling GICv2 emulation
[ 0.214482] kvm [1]: GIC system register CPU interface enabled
[ 0.214572] kvm [1]: vgic interrupt IRQ9
[ 0.214754] kvm [1]: VHE mode initialized successfully
[ 0.218184] Initialise system trusted keyrings
[ 0.218324] workingset: timestamp_bits=42 max_order=23 bucket_order=0
[ 0.222408] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.222766] NFS: Registering the id_resolver key type
[ 0.222788] Key type id_resolver registered
[ 0.222789] Key type id_legacy registered
[ 0.222840] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.222857] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 0.222878] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.223105] 9p: Installing v9fs 9p2000 file system support
[ 0.234865] NET: Registered PF_ALG protocol family
[ 0.234877] Key type asymmetric registered
[ 0.234883] Asymmetric key parser ‘x509’ registered
[ 0.234965] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.234974] io scheduler mq-deadline registered
[ 0.234982] io scheduler kyber registered
[ 0.245986] EINJ: ACPI disabled.
[ 0.258484] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.260278] SuperH (H)SCI(F) driver initialized
[ 0.260627] msm_serial: driver initialized
[ 0.261277] printk: console [ttyTCU0] enabled
[ 0.262153] arm-smmu 8000000.iommu: probing hardware configuration…
[ 0.262158] arm-smmu 8000000.iommu: SMMUv2 with:
[ 0.262164] arm-smmu 8000000.iommu: stage 1 translation
[ 0.262166] arm-smmu 8000000.iommu: stage 2 translation
[ 0.262170] arm-smmu 8000000.iommu: nested translation
[ 0.262181] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 0.262185] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 0.262207] arm-smmu 8000000.iommu: Supported page sizes: 0x61311000
[ 0.262209] arm-smmu 8000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 0.262211] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 0.263214] arm-smmu 10000000.iommu: probing hardware configuration…
[ 0.263217] arm-smmu 10000000.iommu: SMMUv2 with:
[ 0.263219] arm-smmu 10000000.iommu: stage 1 translation
[ 0.263221] arm-smmu 10000000.iommu: stage 2 translation
[ 0.263223] arm-smmu 10000000.iommu: nested translation
[ 0.263225] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 0.263229] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 0.263235] arm-smmu 10000000.iommu: Supported page sizes: 0x61311000
[ 0.263237] arm-smmu 10000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 0.263238] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 0.263583] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.263585] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.263586] arm-smmu 12000000.iommu: stage 1 translation
[ 0.263587] arm-smmu 12000000.iommu: stage 2 translation
[ 0.263588] arm-smmu 12000000.iommu: nested translation
[ 0.263591] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 0.263593] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 0.263598] arm-smmu 12000000.iommu: Supported page sizes: 0x61311000
[ 0.263599] arm-smmu 12000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 0.263600] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 0.272073] loop: module loaded
[ 0.272910] megasas: 07.717.02.00-rc1
[ 0.277083] tun: Universal TUN/TAP device driver, 1.6
[ 0.277647] thunder_xcv, ver 1.0
[ 0.277675] thunder_bgx, ver 1.0
[ 0.277700] nicpf, ver 1.0
[ 0.278563] hclge is initializing
[ 0.278595] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 0.278603] hns3: Copyright (c) 2017 Huawei Corporation.
[ 0.278638] e1000: Intel(R) PRO/1000 Network Driver
[ 0.278646] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 0.278690] e1000e: Intel(R) PRO/1000 Network Driver
[ 0.278696] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 0.278721] igb: Intel(R) Gigabit Ethernet Network Driver
[ 0.278726] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 0.278739] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.278744] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.278972] sky2: driver version 1.30
[ 0.279662] VFIO - User Level meta-driver version: 0.3
[ 0.281267] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.281280] ehci-pci: EHCI PCI platform driver
[ 0.281315] ehci-platform: EHCI generic platform driver
[ 0.281389] ehci-orion: EHCI orion driver
[ 0.281467] ehci-exynos: EHCI Exynos driver
[ 0.281534] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.281586] ohci-pci: OHCI PCI platform driver
[ 0.281616] ohci-platform: OHCI generic platform driver
[ 0.281693] ohci-exynos: OHCI Exynos driver
[ 0.282148] usbcore: registered new interface driver usb-storage
[ 0.284021] i2c_dev: i2c /dev entries driver
[ 0.287383] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[ 0.289365] sdhci: Secure Digital Host Controller Interface driver
[ 0.289370] sdhci: Copyright(c) Pierre Ossman
[ 0.289831] Synopsys Designware Multimedia Card Interface Driver
[ 0.290469] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.291644] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.292571] SMCCC: SOC_ID: ID = jep106:036b:0234 Revision = 0x00000401
[ 0.293138] tegra-bpmp bpmp: Adding to iommu group 0
[ 0.294479] tegra-bpmp bpmp: firmware: a381fb560faa591136e7-ac83764aab0
[ 0.379972] Freeing initrd memory: 10976K
[ 1.861961] clocksource: tsc: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 1.861984] clocksource: osc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 49772407460 ns
[ 1.861986] clocksource: usec: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 1.862671] usbcore: registered new interface driver usbhid
[ 1.862676] usbhid: USB HID core driver
[ 1.866654] optee: probing for conduit method.
[ 1.866711] optee: revision 3.22 (1b7f2993)
[ 1.926137] optee: dynamic shared memory is enabled
[ 1.926375] optee: initialized driver
[ 1.928728] usbcore: registered new interface driver snd-usb-audio
[ 1.930261] NET: Registered PF_PACKET protocol family
[ 1.930533] 9pnet: Installing 9P2000 support
[ 1.930646] Key type dns_resolver registered
[ 1.931772] printk: console [tty0]: printing thread started
[ 1.932351] printk: console [ttyTCU0]: printing thread started
[ 1.932937] printk: console [ttyAMA0]: printing thread started
[ 1.932996] printk: console [ramoops-1]: printing thread started
[ 1.933068] Loading compiled-in X.509 certificates
[ 1.944324] Loaded X.509 cert ‘Build time autogenerated kernel key: 6df01ab60d1edfd9b484fde1a886c193293a8ad8’
[ 1.971346] pstore: Using crash dump compression: deflate
[ 1.998590] gpio-394 (camera-control-output-low): hogged as output/low
[ 1.998616] gpio-397 (camera-control-output-low): hogged as output/low
[ 1.998639] gpio-487 (camera-control-output-low): hogged as output/low
[ 1.998657] gpio-486 (camera-control-output-low): hogged as output/low
[ 2.004741] tegra-gpcdma 2600000.dma-controller: Adding to iommu group 1
[ 2.007127] tegra-gpcdma 2600000.dma-controller: GPC DMA driver register 31 channels
[ 2.009307] serial-tegra 3100000.serial: RX in PIO mode
[ 2.009314] serial-tegra 3100000.serial: TX in PIO mode
[ 2.009441] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 112, base_baud = 0) is a TEGRA_UART
[ 2.011480] serial-tegra 3110000.serial: RX in PIO mode
[ 2.011488] serial-tegra 3110000.serial: TX in PIO mode
[ 2.011579] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 206, base_baud = 0) is a TEGRA_UART
[ 2.017136] tegra_rtc c2a0000.rtc: registered as rtc1
[ 2.017157] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.017748] tegra-i2c 3160000.i2c: Adding to iommu group 1
[ 2.026775] tegra-i2c 3180000.i2c: Adding to iommu group 1
[ 2.033648] tegra-i2c 3190000.i2c: Adding to iommu group 1
[ 2.040701] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[ 2.047779] tegra-i2c 31c0000.i2c: Adding to iommu group 1
[ 2.054878] tegra-i2c 31e0000.i2c: Adding to iommu group 1
[ 2.062301] tegra-i2c c240000.i2c: Adding to iommu group 1
[ 2.069675] tegra-i2c c250000.i2c: Adding to iommu group 1
[ 2.104501] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2009000 KHz, changing to: 2035200 KHz
[ 2.107868] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2008000 KHz, changing to: 2035200 KHz
[ 2.116696] sdhci-tegra 3460000.mmc: Adding to iommu group 2
[ 2.117366] sdhci-tegra 3400000.mmc: Adding to iommu group 3
[ 2.119090] irq: IRQ233: trimming hierarchy from :bus@0:pmc@c360000
[ 2.119153] irq: IRQ234: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[ 2.119193] irq: IRQ235: trimming hierarchy from :bus@0:pmc@c360000
[ 2.119253] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 2.581539] ALSA device list:
[ 2.581545] No soundcards found.
[ 2.581944] mmc3: CQHCI version 5.10
[ 2.584299] sdhci-tegra 3400000.mmc: Got CD GPIO
[ 2.616588] mmc3: SDHCI controller on 3460000.mmc [3460000.mmc] using ADMA 64-bit
[ 2.630456] irq: IRQ236: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[ 2.631329] mmc4: SDHCI controller on 3400000.mmc [3400000.mmc] using ADMA 64-bit
[ 2.632160] Freeing unused kernel memory: 7680K
[ 2.632342] Run /init as init process
[ 2.643631] Checking overlayfs setting…
[ 2.652646] Overlayfs is disabled…
[ 2.658754] Root device found: mmcblk0p1
[ 2.723173] mmc3: Command Queue Engine enabled
[ 2.723187] mmc3: new HS400 Enhanced strobe MMC card at address 0001
[ 2.723439] mmcblk3: mmc3:0001 G1M15M 59.3 GiB
[ 2.726543] mmcblk3: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 2.726950] mmcblk3boot0: mmc3:0001 G1M15M 31.5 MiB
[ 2.727315] mmcblk3boot1: mmc3:0001 G1M15M 31.5 MiB
[ 2.727641] mmcblk3rpmb: mmc3:0001 G1M15M 4.00 MiB, chardev (511:0)
[ 15.788249] ERROR: mmcblk0p1 not found
[ 33.760973] VDD_3V3_PCIE: disabling
[ 33.760987] VDD_12V_PCIE: disabling
