My Jetson does not boot after few days working again and again
I flash a 256GB SD card with Jetpack 5.1.1 as described in the documentation. It does boot and I install all needed software and start working.
After a few days it does not startup anymore. I have to flash the SD again and install all software again. This happens again and again each time after a few days working. What is going on here?
When it does not boot anymore, it gives this window and after that it stays black:
IMG_6362
When pressing F11 for the boot menu I get:
IMG_6371
And selecting the SD card and pressing enter:
IMG_6396
I really would like to know how to solve this, because this is not a workable situation.
Will an other SD card help?
I would suggest you can dump the serial console log and attach the log for us.
This log is more helpful than some photos.
It will help us identify what happened and lead to crash.
We may need the log in your current status and also the log before this situation happened.
I made the serial output.
I could not paste it into one reply (to big). So I show the first part here and
the second part in the next reply.
<\0><\0>ÿâ<\r><\n>
[0000.062] I> MB1 (version: 0.32.0.0-t234-54845784-57325615)<\r><\n>
[0000.067] I> t234-A01-1-Silicon (0x12347) Prod<\r><\n>
[0000.072] I> Boot-mode : Coldboot<\r><\n>
[0000.075] I> Emulation: <\r><\n>
[0000.077] I> Entry timestamp: 0x00000000<\r><\n>
[0000.081] I> last_boot_error: 0x0<\r><\n>
[0000.084] I> BR-BCT: preprod_dev_sign: 0<\r><\n>
[0000.088] I> rst_source: 0x0, rst_level: 0x0<\r><\n>
[0000.092] I> Task: Bootchain select WAR set (0x5000ba65)<\r><\n>
[0000.097] I> Task: Enable SLCG (0x5000bab1)<\r><\n>
[0000.101] I> Task: CRC check (0x5001ea19)<\r><\n>
[0000.105] I> Task: Initialize MB2 params (0x5000cb51)<\r><\n>
[0000.110] I> MB2-params @ 0x40060000<\r><\n>
[0000.114] I> Task: Crypto init (0x5001d981)<\r><\n>
[0000.118] I> Task: Secure debug controls (0x5000c0a9)<\r><\n>
[0000.123] I> Task: strap war set (0x5000ba2d)<\r><\n>
[0000.127] I> Task: Initialize SOC Therm (0x5001bd35)<\r><\n>
[0000.132] I> Task: Program NV master stream id (0x5000c05d)<\r><\n>
[0000.137] I> Task: Verify boot mode (0xd4820f1)<\r><\n>
[0000.143] I> Task: Alias fuses (0x5001095d)<\r><\n>
[0000.148] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.<\r><\n>
[0000.155] I> Task: Print SKU type (0x5000f5f1)<\r><\n>
[0000.159] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c8<\r><\n>
[0000.164] I> FUSE_OPT_GPC_DISABLE = 0x00000002<\r><\n>
[0000.169] I> FUSE_OPT_TPC_DISABLE = 0x000000f0<\r><\n>
[0000.173] I> FUSE_OPT_DLA_DISABLE = 0x00000003<\r><\n>
[0000.177] I> FUSE_OPT_PVA_DISABLE = 0x00000001<\r><\n>
[0000.182] I> FUSE_OPT_NVENC_DISABLE = 0x00000001<\r><\n>
[0000.186] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000<\r><\n>
[0000.190] I> FUSE_OPT_FSI_DISABLE = 0x00000001<\r><\n>
[0000.195] I> FUSE_OPT_EMC_DISABLE = 0x0000000c<\r><\n>
[0000.199] I> FUSE_BOOTROM_PATCH_VERSION = 0x7<\r><\n>
[0000.203] I> FUSE_PSCROM_PATCH_VERSION = 0x7<\r><\n>
[0000.207] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2<\r><\n>
[0000.211] I> FUSE_SKU_INFO_0 = 0xd5<\r><\n>
[0000.215] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS <\r><\n>
[0000.219] I> FUSE_PACKAGE_INFO_0 = 0x2<\r><\n>
[0000.222] I> SKU: Prod<\r><\n>
[0000.225] I> Task: Boost clocks (0x500148a1)<\r><\n>
[0000.229] I> Initializing PLLC2 for AXI_CBB.<\r><\n>
[0000.233] I> AXI_CBB : src = 35, divisor = 0<\r><\n>
[0000.237] I> Task: Voltage monitor (0x50014b49)<\r><\n>
[0000.241] I> VMON: Vmon re-calibration and fine tuning done<\r><\n>
[0000.247] I> Task: UPHY init (0x5000d065)<\r><\n>
[0000.253] I> HSIO UPHY init done<\r><\n>
[0000.256] E> Skipping GBE UPHY config<\r><\n>
[0000.259] I> Task: Boot device init (0x50000be9)<\r><\n>
[0000.264] I> Boot_device: QSPI_FLASH instance: 0<\r><\n>
[0000.268] I> Qspi clock source : pllc_out0<\r><\n>
[0000.273] I> QSPI Flash: Macronix 64MB<\r><\n>
[0000.276] I> QSPI-0l initialized successfully<\r><\n>
[0000.280] I> Task: TSC init (0x50020a4d)<\r><\n>
[0000.284] I> Task: Load membct (0x50011fe9)<\r><\n>
[0000.288] I> RAM_CODE 0x4000421<\r><\n>
[0000.291] I> Loading MEMBCT <\r><\n>
[0000.294] I> Slot: 0<\r><\n>
[0000.296] I> Binary[0] block-0 (partition size: 0x40000)<\r><\n>
[0000.301] I>  get_binary_info: Binary name: MEM-BCT-0<\r><\n>
[0000.306] I> Size of crypto header is 8192<\r><\n>
[0000.310] I> BCH load address is : 0x40050000<\r><\n>
[0000.314] I> Size of crypto header is 8192<\r><\n>
[0000.318] I> BCH of MEM-BCT-0 read from storage<\r><\n>
[0000.323] I> BCH address is : 0x40050000<\r><\n>
[0000.327] I> MEM-BCT-0 header integrity check is success<\r><\n>
[0000.332] I> Binary magic in BCH component 0 is MEM0<\r><\n>
[0000.337] I> component binary type is 0<\r><\n>
[0000.341] I> MEM-BCT-0 binary is read from storage<\r><\n>
[0000.346] I> MEM-BCT-0 binary integrity check is success<\r><\n>
[0000.351] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)<\r><\n>
[0000.358] I> RAM_CODE 0x4000421<\r><\n>
[0000.363] I> RAM_CODE 0x4000421<\r><\n>
[0000.367] I> Task: Load Page retirement list (0x500115b1)<\r><\n>
[0000.372] I> Task: SDRAM params override (0x50011fc5)<\r><\n>
[0000.377] I> Task: Save mem-bct info (0x50014fa1)<\r><\n>
[0000.382] I> Task: Carveout allocate (0x50015005)<\r><\n>
[0000.386] I> RCM blob carveout will not be allocated<\r><\n>
[0000.391] I> ECC region[0]: Start:0x0, End:0x0<\r><\n>
[0000.395] I> ECC region[1]: Start:0x0, End:0x0<\r><\n>
[0000.400] I> ECC region[2]: Start:0x0, End:0x0<\r><\n>
[0000.404] I> ECC region[3]: Start:0x0, End:0x0<\r><\n>
[0000.408] I> ECC region[4]: Start:0x0, End:0x0<\r><\n>
[0000.412] I> Non-ECC region[0]: Start:0x80000000, End:0x280000000<\r><\n>
[0000.418] I> Non-ECC region[1]: Start:0x0, End:0x0<\r><\n>
[0000.423] I> Non-ECC region[2]: Start:0x0, End:0x0<\r><\n>
[0000.428] I> Non-ECC region[3]: Start:0x0, End:0x0<\r><\n>
[0000.432] I> Non-ECC region[4]: Start:0x0, End:0x0<\r><\n>
[0000.442] I> allocated(CO:44) base:0x249800000 size:0x36800000 align: 0x100000<\r><\n>
[0000.449] I> allocated(CO:31) base:0x240000000 size:0x8000000 align: 0x8000000<\r><\n>
[0000.456] I> allocated(CO:43) base:0x23c000000 size:0x4000000 align: 0x200000<\r><\n>
[0000.463] I> allocated(CO:20) base:0x23a000000 size:0x2000000 align: 0x2000000<\r><\n>
[0000.470] I> allocated(CO:24) base:0x238000000 size:0x2000000 align: 0x2000000<\r><\n>
[0000.477] I> allocated(CO:28) base:0x236000000 size:0x2000000 align: 0x2000000<\r><\n>
[0000.484] I> allocated(CO:22) base:0x248000000 size:0x1000000 align: 0x1000000<\r><\n>
[0000.492] I> allocated(CO:35) base:0x235200000 size:0xe00000 align: 0x10000<\r><\n>
[0000.498] I> allocated(CO:02) base:0x249000000 size:0x800000 align: 0x800000<\r><\n>
[0000.505] I> allocated(CO:03) base:0x234800000 size:0x800000 align: 0x800000<\r><\n>
[0000.512] I> allocated(CO:06) base:0x234000000 size:0x800000 align: 0x800000<\r><\n>
[0000.519] I> allocated(CO:10) base:0x233800000 size:0x800000 align: 0x800000<\r><\n>
[0000.526] I> allocated(CO:56) base:0x233000000 size:0x800000 align: 0x200000<\r><\n>
[0000.533] I> allocated(CO:07) base:0x232c00000 size:0x400000 align: 0x400000<\r><\n>
[0000.540] I> allocated(CO:33) base:0x232800000 size:0x400000 align: 0x200000<\r><\n>
[0000.547] I> allocated(CO:23) base:0x235000000 size:0x200000 align: 0x200000<\r><\n>
[0000.554] I> allocated(CO:01) base:0x232700000 size:0x100000 align: 0x100000<\r><\n>
[0000.561] I> allocated(CO:04) base:0x232600000 size:0x100000 align: 0x100000<\r><\n>
[0000.568] I> allocated(CO:05) base:0x232500000 size:0x100000 align: 0x100000<\r><\n>
[0000.574] I> allocated(CO:08) base:0x232400000 size:0x100000 align: 0x100000<\r><\n>
[0000.581] I> allocated(CO:09) base:0x232300000 size:0x100000 align: 0x100000<\r><\n>
[0000.588] I> allocated(CO:15) base:0x232200000 size:0x100000 align: 0x100000<\r><\n>
[0000.595] I> allocated(CO:17) base:0x232100000 size:0x100000 align: 0x100000<\r><\n>
[0000.602] I> allocated(CO:27) base:0x232000000 size:0x100000 align: 0x100000<\r><\n>
[0000.609] I> allocated(CO:42) base:0x231f00000 size:0x100000 align: 0x100000<\r><\n>
[0000.616] I> allocated(CO:54) base:0x231e80000 size:0x80000 align: 0x80000<\r><\n>
[0000.623] I> allocated(CO:34) base:0x231e70000 size:0x10000 align: 0x10000<\r><\n>
[0000.629] I> allocated(CO:47) base:0x231a00000 size:0x400000 align: 0x200000<\r><\n>
[0000.636] I> allocated(CO:72) base:0x231800000 size:0x200000 align: 0x10000<\r><\n>
[0000.643] I> allocated(CO:48) base:0x231e50000 size:0x20000 align: 0x10000<\r><\n>
[0000.650] I> allocated(CO:69) base:0x231e30000 size:0x20000 align: 0x10000<\r><\n>
[0000.657] I> allocated(CO:49) base:0x231e20000 size:0x10000 align: 0x10000<\r><\n>
[0000.663] I> allocated(CO:50) base:0x231e10000 size:0x10000 align: 0x10000<\r><\n>
[0000.670] I> NSDRAM base: 0x80000000, end: 0x231e70000<\r><\n>
[0000.675] I> Task: Thermal check (0x50021d55)<\r><\n>
[0000.679] I> max_chip_limit = 105<\r><\n>
[0000.683] I> min_chip_limit = -28<\r><\n>
[0000.686] I> max temp read = 36<\r><\n>
[0000.689] I> min temp read = 35<\r><\n>
[0000.692] I> Task: Update FSI SCR with thermal fuse data (0x50021e61)<\r><\n>
[0000.698] I> Task: Enable WDT 5th expiry (0x50021a41)<\r><\n>
[0000.703] I> Task: I2C register (0x50000b85)<\r><\n>
[0000.707] I> Task: Reset FSI (0x500148b1)<\r><\n>
[0000.711] I> Task: Pinmux init (0x5001397d)<\r><\n>
[0000.715] I> skipped mmio_addr = 0x9240008<\r><\n>
[0000.719] I> skipped mmio_addr = 0x9240000<\r><\n>
[0000.723] I> skipped mmio_addr = 0x9240010<\r><\n>
[0000.727] I> skipped mmio_addr = 0x9240018<\r><\n>
[0000.731] I> skipped mmio_addr = 0x9240020<\r><\n>
[0000.735] I> skipped mmio_addr = 0x9240030<\r><\n>
[0000.739] I> skipped mmio_addr = 0x9240028<\r><\n>
[0000.743] I> skipped mmio_addr = 0x9240038<\r><\n>
[0000.747] I> skipped mmio_addr = 0x9240040<\r><\n>
[0000.751] I> skipped mmio_addr = 0x9240048<\r><\n>
[0000.754] I> skipped mmio_addr = 0x9241000<\r><\n>
[0000.758] I> skipped mmio_addr = 0x9241008<\r><\n>
[0000.762] I> skipped mmio_addr = 0x9241010<\r><\n>
[0000.766] I> skipped mmio_addr = 0x9241018<\r><\n>
[0000.770] I> skipped mmio_addr = 0x9241020<\r><\n>
[0000.774] I> skipped mmio_addr = 0x9241028<\r><\n>
[0000.778] I> skipped mmio_addr = 0x9241030<\r><\n>
[0000.782] I> skipped mmio_addr = 0x9241038<\r><\n>
[0000.786] I> skipped mmio_addr = 0x9241040<\r><\n>
[0000.790] I> skipped mmio_addr = 0x9242000<\r><\n>
[0000.794] I> skipped mmio_addr = 0x9242008<\r><\n>
[0000.798] I> Task: Prod config init (0x50013ddd)<\r><\n>
[0000.802] I> Task: Pad voltage init (0x50013a2d)<\r><\n>
[0000.807] I> Task: Prod init (0x50013e21)<\r><\n>
[0000.811] I> Task: Common rail init (0x50014575)<\r><\n>
[0000.815] I> DONE: Thermal config<\r><\n>
[0000.819] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.<\r><\n>
[0000.828] I> DONE: SOC rail config<\r><\n>
[0000.831] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.<\r><\n>
[0000.838] I> DONE: MEMIO rail config<\r><\n>
[0000.842] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.<\r><\n>
[0000.848] I> DONE: GPU rail info<\r><\n>
[0000.851] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.<\r><\n>
[0000.857] I> DONE: CV rail info<\r><\n>
[0000.860] I> Task: Mem clock src (0x50011de9)<\r><\n>
[0000.865] I> Task: Misc. board config (0x5001461d)<\r><\n>
[0000.870] W> PMIC_CONFIG: Platform config not found in MB1 BCT.<\r><\n>
[0000.876] I> Task: SDRAM init (0x50011ded)<\r><\n>
[0000.880] I> SDRAM-params @ 0xd485000<\r><\n>
[0000.883] I> MemoryType: 4 MemBctRevision: 1<\r><\n>
[0000.890] I> MSS code-drop: NvBootSdramInit<\r><\n>
[0000.894] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 1<\r><\n>
[0000.901] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 1<\r><\n>
[0000.908] I> MSS CAR: Init PLLM<\r><\n>
[0000.912] I> MSS CAR: Init PLLHUB<\r><\n>
[0000.916] I> Encryption:   MTS: en, TX: en, VPR: en, GSC: en<\r><\n>
[0000.928] I> mb1_sdram_init Done !<\r><\n>
[0000.931] I> SDRAM Size in Total 0x200000000<\r><\n>
[0000.935] I> Task: Dram Ecc scrub (0x500116f5)<\r><\n>
[0000.939] I> Task: DRAM alias check (0x50011fbd)<\r><\n>
[0000.951] I> Task: Program NSDRAM carveout (0x50015961)<\r><\n>
[0000.957] I> NSDRAM carveout encryption is enabled<\r><\n>
[0000.962] I> Program NSDRAM carveout<\r><\n>
[0000.966] I> Task: Register checker (0x50011fc1)<\r><\n>
[0000.973] I> Task: Enable clock-mon (0x50020a35)<\r><\n>
[0000.979] I> FMON: Fmon re-programming done<\r><\n>
[0000.984] I> Task: Mapper init (0x5001ef4d)<\r><\n>
[0000.989] I> Task: SC7 Context Init (0x50020d3d)<\r><\n>
[0000.995] I> Task: CCPLEX IST init (0x5000c925)<\r><\n>
[0001.001] I> Task: CPU WP0 (0x5000bb15)<\r><\n>
[0001.006] I> Loading MCE<\r><\n>
[0001.009] I> Slot: 0<\r><\n>
[0001.011] I> Binary[8] block-0 (partition size: 0x80000)<\r><\n>
[0001.017] I>  get_binary_info: Binary name: MCE<\r><\n>
[0001.022] I> Size of crypto header is 8192<\r><\n>
[0001.026] I> BCH load address is : 0x4003e000<\r><\n>
[0001.031] I> Size of crypto header is 8192<\r><\n>
[0001.036] I> BCH of MCE read from storage<\r><\n>
[0001.041] I> BCH address is : 0x4003e000<\r><\n>
[0001.046] I> MCE header integrity check is success<\r><\n>
[0001.051] I> Binary magic in BCH component 0 is MTSM<\r><\n>
[0001.056] I> component binary type is 8<\r><\n>
[0001.060] I> Size of crypto header is 8192<\r><\n>
[0001.067] I> MCE binary is read from storage<\r><\n>
[0001.072] I> MCE binary integrity check is success<\r><\n>
[0001.077] I> Binary MCE loaded successfully at 0x40000000 (0x2c880)<\r><\n>
[0001.085] I> Size of crypto header is 8192<\r><\n>
[0001.099] I> Size of crypto header is 8192<\r><\n>
[0001.104] I> Sending WP0 mailbox command to PSC<\r><\n>
[0001.114] I> Task: XUSB Powergate (0x50000b91)<\r><\n>
[0001.120] I> Skipping powergate XUSB.<\r><\n>
[0001.124] I> Task: MB1 fixed firewalls (0x5002006d)<\r><\n>
[0001.135] W> Firewall readback mismatch<\r><\n>
[0001.139] W> Firewall readback mismatch<\r><\n>
[0001.148] W> Firewall readback mismatch<\r><\n>
[0001.158] I> Task: Load bpmp-fw (0x500203c9)<\r><\n>
[0001.163] I> Slot: 0<\r><\n>
[0001.165] I> Binary[15] block-0 (partition size: 0x180000)<\r><\n>
[0001.172] I>  get_binary_info: Binary name: BPMP_FW<\r><\n>
[0001.177] I> Size of crypto header is 8192<\r><\n>
[0001.181] I> BCH load address is : 0x807fe000<\r><\n>
[0001.187] I> Size of crypto header is 8192<\r><\n>
[0001.191] I> BCH of BPMP_FW read from storage<\r><\n>
[0001.196] I> BCH address is : 0x807fe000<\r><\n>
[0001.201] I> BPMP_FW header integrity check is success<\r><\n>
[0001.207] I> Binary magic in BCH component 0 is BPMF<\r><\n>
[0001.212] I> component binary type is 15<\r><\n>
[0001.216] I> Size of crypto header is 8192<\r><\n>
[0001.232] I> BPMP_FW binary is read from storage<\r><\n>
[0001.239] I> BPMP_FW binary integrity check is success<\r><\n>
[0001.244] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xfdd80)<\r><\n>
[0001.252] I> Slot: 0<\r><\n>
[0001.255] I> Binary[16] block-10000 (partition size: 0x400000)<\r><\n>
[0001.261] I>  get_binary_info: Binary name: BPMP_FW_DTB<\r><\n>
[0001.267] I> Size of crypto header is 8192<\r><\n>
[0001.272] I> BCH load address is : 0x807fc000<\r><\n>
[0001.277] I> Size of crypto header is 8192<\r><\n>
[0001.282] I> BCH of BPMP_FW_DTB read from storage<\r><\n>
[0001.287] I> BCH address is : 0x807fc000<\r><\n>
[0001.292] I> BPMP_FW_DTB header integrity check is success<\r><\n>
[0001.298] I> Binary magic in BCH component 0 is BPMD<\r><\n>
[0001.303] I> component binary type is 16<\r><\n>
[0001.307] I> Size of crypto header is 8192<\r><\n>
[0001.313] I> BPMP_FW_DTB binary is read from storage<\r><\n>
[0001.319] I> BPMP_FW_DTB binary integrity check is success<\r><\n>
[0001.325] I> Binary BPMP_FW_DTB loaded successfully at 0x807e31f0 (0x18e00)<\r><\n>
[0001.334] I> Task: Load psc-fw (0x50020551)<\r><\n>
[0001.339] I> Slot: 0<\r><\n>
[0001.342] I> Binary[17] block-0 (partition size: 0xc0000)<\r><\n>
[0001.348] I>  get_binary_info: Binary name: PSC_FW<\r><\n>
[0001.353] I> Size of crypto header is 8192<\r><\n>
[0001.357] I> BCH load address is : 0x80ffe000<\r><\n>
[0001.362] I> Size of crypto header is 8192<\r><\n>
[0001.367] I> BCH of PSC_FW read from storage<\r><\n>
[0001.372] I> BCH address is : 0x80ffe000<\r><\n>
[0001.377] I> PSC_FW header integrity check is success<\r><\n>
[0001.383] I> Binary magic in BCH component 0 is PFWP<\r><\n>
[0001.388] I> component binary type is 17<\r><\n>
[0001.392] I> Size of crypto header is 8192<\r><\n>
[0001.401] I> PSC_FW binary is read from storage<\r><\n>
[0001.407] I> PSC_FW binary integrity check is success<\r><\n>
[0001.412] I> Binary PSC_FW loaded successfully at 0x80000000 (0x59980)<\r><\n>
[0001.420] I> Task: Load nvdec-fw (0x500205c5)<\r><\n>
[0001.426] I> Slot: 0<\r><\n>
[0001.428] I> Binary[7] block-0 (partition size: 0x100000)<\r><\n>
[0001.434] I>  get_binary_info: Binary name: NVDEC<\r><\n>
[0001.439] I> Size of crypto header is 8192<\r><\n>
[0001.444] I> BCH load address is : 0x800fe000<\r><\n>
[0001.449] I> Size of crypto header is 8192<\r><\n>
[0001.454] I> BCH of NVDEC read from storage<\r><\n>
[0001.458] I> BCH address is : 0x800fe000<\r><\n>
[0001.463] I> NVDEC header integrity check is success<\r><\n>
[0001.469] I> Binary magic in BCH component 0 is NDEC<\r><\n>
[0001.474] I> component binary type is 7<\r><\n>
[0001.478] I> Size of crypto header is 8192<\r><\n>
[0001.486] I> NVDEC binary is read from storage<\r><\n>
[0001.491] I> NVDEC binary integrity check is success<\r><\n>
[0001.497] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)<\r><\n>
[0001.505] I> Size of crypto header is 8192<\r><\n>
[0001.523] I> Task: Load tsec-fw (0x5002097d)<\r><\n>
[0001.528] I> TSEC-FW load support not enabled<\r><\n>
[0001.532] I> Task: GPIO interrupt map (0x500147b5)<\r><\n>
[0001.538] I> Task: SC7 context save (0x50020d79)<\r><\n>
[0001.544] I> Slot: 0<\r><\n>
[0001.546] I> Binary[27] block-0 (partition size: 0x100000)<\r><\n>
[0001.553] I>  get_binary_info: Binary name: BR_BCT<\r><\n>
[0001.558] I> Size of crypto header is 8192<\r><\n>
[0001.562] I> Size of crypto header is 8192<\r><\n>
[0001.567] I> BR_BCT binary is read from storage<\r><\n>
[0001.572] I> BR_BCT binary integrity check is success<\r><\n>
[0001.578] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)<\r><\n>
[0001.585] I> Slot: 0<\r><\n>
[0001.588] I> Binary[13] block-0 (partition size: 0x30000)<\r><\n>
[0001.594] I>  get_binary_info: Binary name: SC7-FW<\r><\n>
[0001.599] I> Size of crypto header is 8192<\r><\n>
[0001.603] I> Size of crypto header is 8192<\r><\n>
[0001.608] I> BCH load address is : 0xa0002000<\r><\n>
[0001.613] I> Size of crypto header is 8192<\r><\n>
[0001.618] I> BCH of SC7-FW read from storage<\r><\n>
[0001.623] I> BCH address is : 0xa0002000<\r><\n>
[0001.628] I> SC7-FW header integrity check is success<\r><\n>
[0001.633] I> Binary magic in BCH component 0 is WB0B<\r><\n>
[0001.639] I> component binary type is 13<\r><\n>
[0001.643] I> Size of crypto header is 8192<\r><\n>
[0001.649] I> SC7-FW binary is read from storage<\r><\n>
[0001.655] I> SC7-FW binary integrity check is success<\r><\n>
[0001.660] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x26db0)<\r><\n>
[0001.668] I> Slot: 0<\r><\n>
[0001.670] I> Binary[22] block-0 (partition size: 0x30000)<\r><\n>
[0001.676] I>  get_binary_info: Binary name: PSC_RF<\r><\n>
[0001.682] I> Size of crypto header is 8192<\r><\n>
[0001.686] I> Size of crypto header is 8192<\r><\n>
[0001.691] I> BCH load address is : 0xa002adb0<\r><\n>
[0001.696] I> Size of crypto header is 8192<\r><\n>
[0001.701] I> BCH of PSC_RF read from storage<\r><\n>
[0001.705] I> BCH address is : 0xa002adb0<\r><\n>
[0001.711] I> PSC_RF header integrity check is success<\r><\n>
[0001.716] I> Binary magic in BCH component 0 is PSCR<\r><\n>
[0001.721] I> component binary type is 22<\r><\n>
[0001.726] I> Size of crypto header is 8192<\r><\n>
[0001.732] I> PSC_RF binary is read from storage<\r><\n>
[0001.737] I> PSC_RF binary integrity check is success<\r><\n>
[0001.742] I> Binary PSC_RF loaded successfully at 0xa002cdb0 (0x1b140)<\r><\n>
[0001.765] I> Task: Save WP0 payload to SC7 ctx (0x50021725)<\r><\n>
[0001.772] I> Task: Load MB2rf binary to SC7 ctx (0x500216b9)<\r><\n>
[0001.779] I> Slot: 0<\r><\n>
[0001.781] I> Binary[14] block-0 (partition size: 0x20000)<\r><\n>
[0001.787] I>  get_binary_info: Binary name: MB2_RF<\r><\n>
[0001.792] I> Size of crypto header is 8192<\r><\n>
[0001.797] I> Size of crypto header is 8192<\r><\n>
[0001.801] I> BCH load address is : 0xa00d6a48<\r><\n>
[0001.806] I> Size of crypto header is 8192<\r><\n>
[0001.811] I> BCH of MB2_RF read from storage<\r><\n>
[0001.816] I> BCH address is : 0xa00d6a48<\r><\n>
[0001.821] I> MB2_RF header integrity check is success<\r><\n>
[0001.827] I> Binary magic in BCH component 0 is MB2R<\r><\n>
[0001.832] I> component binary type is 14<\r><\n>
[0001.836] I> Size of crypto header is 8192<\r><\n>
[0001.842] I> MB2_RF binary is read from storage<\r><\n>
[0001.847] I> MB2_RF binary integrity check is success<\r><\n>
[0001.853] I> Binary MB2_RF loaded successfully at 0xa00d8a48 (0x1bfa0)<\r><\n>
[0001.861] I> Task: Save Fuse-Bypass data to SC7 ctx (0x50021621)<\r><\n>
[0001.868] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.<\r><\n>
[0001.876] I> SC7 context fuse-bypass data is empty<\r><\n>
[0001.881] I> Task: Save PMIC data to SC7 ctx (0x5002144d)<\r><\n>
[0001.888] I> Task: Save I2C bus freq data to SC7 ctx (0x500213d9)<\r><\n>
[0001.895] I> Task: Save SOCTherm data to SC7 ctx (0x50021365)<\r><\n>
[0001.901] I> Task: Save FMON data to SC7 ctx (0x500212f1)<\r><\n>
[0001.908] I> Task: Save VMON data to SC7 ctx (0x50021279)<\r><\n>
[0001.914] I> Task: Save TZDRAM data to SC7 ctx (0x5002178d)<\r><\n>
[0001.921] I> Task: Save GPIO int data to SC7 ctx (0x50021561)<\r><\n>
[0001.928] I> Task: Save clock data to SC7 ctx (0x50021205)<\r><\n>
[0001.934] I> Task: Save debug data to SC7 ctx (0x50021191)<\r><\n>
[0001.945] I> SC7 context save done<\r><\n>
[0001.949] I> Task: Load MB2/Applet/FSKP (0x5000ca55)<\r><\n>
[0001.955] I> Loading MB2<\r><\n>
[0001.958] I> Slot: 0<\r><\n>
[0001.960] I> Binary[6] block-0 (partition size: 0x80000)<\r><\n>
[0001.966] I>  get_binary_info: Binary name: MB2<\r><\n>
[0001.971] I> Size of crypto header is 8192<\r><\n>
[0001.976] I> BCH load address is : 0x8007e000<\r><\n>
[0001.981] I> Size of crypto header is 8192<\r><\n>
[0001.986] I> BCH of MB2 read from storage<\r><\n>
[0001.990] I> BCH address is : 0x8007e000<\r><\n>
[0001.995] I> MB2 header integrity check is success<\r><\n>
[0002.001] I> Binary magic in BCH component 0 is MB2B<\r><\n>
[0002.006] I> component binary type is 6<\r><\n>
[0002.010] I> Size of crypto header is 8192<\r><\n>
[0002.019] I> MB2 binary is read from storage<\r><\n>
[0002.025] I> MB2 binary integrity check is success<\r><\n>
[0002.030] I> Binary MB2 loaded successfully at 0x80000000 (0x68ee0)<\r><\n>
[0002.038] I> Task: Map CCPLEX SHARED carveout (0x5000cbf9)<\r><\n>
[0002.045] I> Task: Prepare MB2 params (0x5000cca9)<\r><\n>
[0002.052] I> BR-BCT Boot Chain Fields<\r><\n>
[0002.055] I> <9> u32_non_gpio_select_boot_chain  : 0<\r><\n>
[0002.061] I> <9> u32_num_boot_chains             : 2<\r><\n>
[0002.066] I> <9> bf_bl_gpio_select_boot_chain_1b : 0<\r><\n>
[0002.071] I> Task: Dram ecc test (0x50011791)<\r><\n>
[0002.076] I> Task: Misc NV security settings (0x5000c529)<\r><\n>
[0002.083] I> NVDEC sticky bits programming done<\r><\n>
[0002.088] I> Successfully powergated NVDEC<\r><\n>
[0002.092] I> Task: Disable/Reload WDT (0x50021a99)<\r><\n>
[0002.098] I> Task: Program misc carveouts (0x50015381)<\r><\n>
[0002.104] I> Program IPC carveouts<\r><\n>
[0002.111] I> SLCG Global override status := 0x0<\r><\n>
[0002.116] I> MB1: MSS reconfig completed<\r><\n>
I> MB2 (version: 0.0.0.0-t234-54845784-02a8384c)<\r><\n>
I> t234-A01-1-Silicon (0x12347)<\r><\n>
I> Entry timestamp: 0x0020dd5a<\r><\n>
I> Regular heap: [base:0x40040000, size:0x10000]<\r><\n>
I> DMA heap: [base:0x233000000, size:0x800000]<\r><\n>
I> Task: ARI update carveout TZDRAM (0x50001e80)<\r><\n>
I> Task: Enable hot-plug capability (0x50026bec)<\r><\n>
I> Task: PSC mailbox init (0x50016a7c)<\r><\n>
I> Task: Crypto init (0x500065a8)<\r><\n>
I> Task: Enable GP-SE clock (0x50001fe4)<\r><\n>
I> Task: DICE Identity init (0x50019e50)<\r><\n>
I> DICE is not enabled.<\r><\n>
I> Task: OEM SC7 context save init (0x50019550)<\r><\n>
I> Task: I2C register (0x50001e44)<\r><\n>
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout (0x50001e2c)<\r><\n>
I> Task: Program CBB PCIE AMAP regions (0x50019b64)<\r><\n>
I> Task: Boot device init (0x50001d74)<\r><\n>
I> Task: Partition Manager Init (0x50001d70)<\r><\n>
I> Found 57 partitions in QSPI_FLASH (instance 0)<\r><\n>
I> Task: Load and authenticate registered FWs (0x5001ce48)<\r><\n>
I> Task: Load AUXP FWs (0x5002678c)<\r><\n>
I> Successfully register SPE FW load task with MB2 loader<\r><\n>
I> Skipping SCE FW load<\r><\n>
I> Successfully register RCE FW load task with MB2 loader<\r><\n>
I> Successfully register DCE FW load task with MB2 loader<\r><\n>
I> Unpowergating APE<\r><\n>
I> Unpowergate done<\r><\n>
I> Successfully register APE FW load task with MB2 loader<\r><\n>
I> Skipping FSI FW load<\r><\n>
I> Successfully register XUSB FW load task with MB2 loader<\r><\n>
I> Partition name: A_spe-fw<\r><\n>
I> Size of partition: 589824<\r><\n>
I> Binary@ device:3/0 block-55040 (partition size: 0x90000), name: A_spe-fw<\r><\n>
I> Partition name: A_rce-fw<\r><\n>
I> Size of partition: 1048576<\r><\n>
I> Binary@ device:3/0 block-56192 (partition size: 0x100000), name: A_rce-fw<\r><\n>
I> spe: Authentication Finalize Done<\r><\n>
I> Binary spe loaded successfully at 0x232400000<\r><\n>
I> Partition name: A_dce-fw<\r><\n>
I> Size of partition: 5242880<\r><\n>
I> Binary@ device:3/0 block-44800 (partition size: 0x500000), name: A_dce-fw<\r><\n>
I> rce: Authentication Finalize Done<\r><\n>
I> Binary rce loaded successfully at 0x232100000<\r><\n>
I> dce : oem authentication of header done<\r><\n>
I> dce : meta-blob integrity check is success.<\r><\n>
I> dce : will be decompressed at 0x23a000000<\r><\n>
I> version 1 Bin 1 BCheckSum 0 content_size 0 Content ChkSum 1 reserved_00  0<\r><\n>
I> Reserved10 0 BlockMaxSize 5 Reserved11 0<\r><\n>
I> dce : decompressed to 9441408 bytes<\r><\n>
I> dce: plain binary integrity check is success<\r><\n>
I> Partition name: A_adsp-fw<\r><\n>
I> Size of partition: 2097152<\r><\n>
I> Binary@ device:3/0 block-58240 (partition size: 0x200000), name: A_adsp-fw<\r><\n>
I> dce: Authentication Finalize Done<\r><\n>
I> Binary dce loaded successfully at 0x23a000000<\r><\n>
I> Partition name: A_xusb-fw<\r><\n>
I> Size of partition: 262144<\r><\n>
I> Binary@ device:3/0 block-9472 (partition size: 0x40000), name: A_xusb-fw<\r><\n>
I> ape: Authentication Finalize Done<\r><\n>
I> Binary ape loaded successfully at 0x232c00000<\r><\n>
I> xusb: Authentication Finalize Done<\r><\n>
I> Binary xusb loaded successfully at 0x232500000<\r><\n>
I> Task: Carveout setup (0x5001f55c)<\r><\n>
I> Program remaining OEM carveouts<\r><\n>
I> Task: Enable FSITHERM (0x50016950)<\r><\n>
I> Task: Enable FSI VMON (0x500164d8)<\r><\n>
I> Task: Validate FSI Therm readings (0x50016530)<\r><\n>
I> Task: Restore XUSB sec (0x50001d44)<\r><\n>
I> Task: Enable FSI SE clock (0x50016ed8)<\r><\n>
I> Task: Initialize SBSA UART CAR (0x50001f48)<\r><\n>
I> Task: Ratchet update (0x50027c88)<\r><\n>
W> OPTIN fuse not set, skip ratchet update<\r><\n>
I> Task: Initialize CPUBL Params (0x50017e0c)<\r><\n>
I> CPUBL-params @ 0x236000000<\r><\n>
I> Task: Prepare eeprom data (0x50017bd8)<\r><\n>
I> Task: FSI padctl context save (0x500196e0)<\r><\n>
E> Skipping FSI padctl config save: fsi not enabled<\r><\n>
I> Task: Unpowergate APE (0x50017640)<\r><\n>
W> mb2_unpowergate_ape: skip! APE is in unpowergated state<\r><\n>
I> Task: OEM firewalls (0x500238fc)<\r><\n>
I> OEM firewalls configured<\r><\n>
I> Task: Powergate APE (0x500177b4)<\r><\n>
I> Powergating APE<\r><\n>
I> Powergate done<\r><\n>
I> Task: OEM firewall restore saved settings (0x50023d50)<\r><\n>
I> Task: Unhalt AUXPs (0x500269f4)<\r><\n>
I> Unhalting SPE..<\r><\n>
I> Enabling combined UART <\r><\n>
<\0>ÿýÿàspe: early_init<\r><\n>
vic initialized<\r><\n>
tsc initialized<\r><\n>
aon lic initialized<\r><\n>
spe: tag is 243b265b351d6bb9cc7b2e3acc5d90f8<\r><\n>
spe: SafeRTOS v8.4<\r><\n>
spe: init<\r><\n>
scheduler initialized<\r><\n>
aon hsp initialized<\r><\n>
tag initialized<\r><\n>
tcu initialized<\r><\n>
bpmp ipc initialized<\r><\n>
spe: late init<\r><\n>
cpu_nic clock initialized<\r><\n>
apb clock initialized<\r><\n>
pm initialized<\r><\n>
bpmp hsp initialized<\r><\n>
top1 hsp initialized<\r><\n>
ccplex ipc initialized<\r><\n>
spe: start scheduler<\r><\n>
ÿá<\n>
I> Task: Trigger mailbox for PSC-BL1 exit (0x50016afc)<\r><\n>
I> Sending opcode 0x4d420802 to psc<\r><\n>
ÿçINFO: Entering psc_monitor_init!<\r><\n>
INFO: GSC22 BOM:0x248002000 SIZE:0x1000000 CLIENT_ACCESS1:00180000<\r><\n>
INFO: PSCFW BUILD VERSION: 8a33b23-73b589c-8a15f76-rel-t234<\r><\n>
INFO: mstatus:0xa00000808<\r><\n>
INFO: Supervisor entry_point:c108c00<\r><\n>
ÿáI> Received ACK from psc<\r><\n>
I> TasÿçINFO: MONITOR: user task addr:0x248022000, blob offset:0x00020000<\r><\n>
INFO: MONITOR: populated user images:13<\r><\n>
INFO: mret to Supervisor!<\r><\n>
INFO: psc supervisor init.<\r><\n>
INFO: psc_irq_init...<\r><\n>
INFO: enter idlÿâ<\n>
bpmp: socÿçe task.<\r><\n>
ÿâket 0<\r><\n>
bpmp: base binary md5 is 1377b684fe55be78e1d7fc3e0f143b55<\r><\n>
bpmp: combined binary md5 is f0fadc45ec6216cb5b0bcb3771407fc2<\r><\n>
bpmp: firmware tag is f0fadc45ec6216cb5b0b-1377b684fe5<\r><\n>
initialized vwdt<\r><\n>
initialized mail_early<\r><\n>
initialized fuse<\r><\n>
initialized vfrel<\r><\n>
initialized hwwdt<\r><\n>
initialized adc<\r><\n>
fmon_populate_monitors: found 199 monitors<\r><\n>
initialized fmon<\r><\n>
initialized mc<\r><\n>
initialized reset<\r><\n>
initialized uphy_early<\r><\n>
initialized emc_early<\r><\n>
471 clocks registered<\r><\n>
initialized clk_mach<\r><\n>
initialized clk_cal_early<\r><\n>
initialized clk_mach_early_config<\r><\n>
initialized io_dpd<\r><\n>
initialized soctherm<\r><\n>
initialized tj_init<\r><\n>
initialized regime<\r><\n>
initialized i2c<\r><\n>
vrmon_dt_init: vrmon node not found<\r><\n>
vrmon_chk_boot_state: found 0 rail monitors<\r><\n>
initialized vrmon<\r><\n>
initialized regulator<\r><\n>
initialized avfs_clk_platform<\r><\n>
initialized powergate<\r><\n>
initialized dvs<\r><\n>
initialized clk_mach_config<\r><\n>
initialized pm<\r><\n>
initialized suspend<\r><\n>
initialized strap<\r><\n>
initialized mce_dbell<\r><\n>
ÿák: Start secure NOR provision (0x5001997c)<\r><\n>
I> Task: Load FSI keyblob (0x50016f20)<\r><\n>
I> Task: Unhalt AUXPsÿâinitialized emc<\r><\n>
initialized emc_mrq<\r><\n>
ÿá (0x500269fc)<\r><\n>
I> SCE unhalt skippedÿâinitialized clk_cal<\r><\n>
initialized uphy_dt<\r><\n>
initialized uphy_mrq<\r><\n>
HSIO UPHY reset has been de-asserted 0x0<\r><\n>
initialized uphy<\r><\n>
initialized pg_late<\r><\n>
initialized pg_mrq_init<\r><\n>
swdtimer_init: 0 reg polling start w period 47 ms<\r><\n>
initialized swdtimer<\r><\n>
initialized hwwdt_late<\r><\n>
initialized bwmgr<\r><\n>
initialized thermal_host_trip<\r><\n>
initialized thermal_mrq<\r><\n>
initialized oc_mrq<\r><\n>
initialized reset_mrq<\r><\n>
initialized mail_mrq<\r><\n>
initialized fmon_mrq<\r><\n>
initialized clk_mrq<\r><\n>
initialized avfs_mrq<\r><\n>
initialized i2c_mrq<\r><\n>
initialized tag_mrq<\r><\n>
initialized bwmgr_mrq<\r><\n>
initialized console_mrq<\r><\n>
missing prod DT calibration data for 199 fmons<\r><\n>
initialized clk_sync_fmon_post<\r><\n>
ÿá<\r><\n>
I> Unhalting RCE<\r><\n>
I> RCE unhalÿâinitialized clk_cal_late<\r><\n>
initialized noc_ÿå[     2.577261] Camera-FW on t234-rce-safe started<\r><\n>
TCU early console enabled.<\r><\n>
ÿâlate<\r><\n>
initialized cvc<\r><\n>
initialized avfs_clk_mach_post<\r><\n>
initialized avfs_clk_platform_post<\r><\n>
initialized cvc_late<\r><\n>
initialized rm<\r><\n>
initialized console_late<\r><\n>
handling unreferenced clks<\r><\n>
enable can1_core<\r><\n>
enable can1_host<\r><\n>
enable can2_core<\r><\n>
enable can2_host<\r><\n>
enable pwm3<\r><\n>
enable mss_encrypt<\r><\n>
enable maud<\r><\n>
enable pllg_ref<\r><\n>
enable dsi_core<\r><\n>
enable aza_2xbit<\r><\n>
enable xusb_ss<\r><\n>
enable xusb_fs<\r><\n>
enable xusb_falcon<\r><\n>
enable xusb_core_mux<\r><\n>
enable dsi_lp<\r><\n>
clk_check_max_rates: pex1_c6_core rate 500000000 > max 250000000<\r><\n>
clk_check_max_rates: pex2_c7_core rate 500000000 > max 250000000<\r><\n>
clk_check_max_rates: pex2_c8_core rate 500000000 > max 250000000<\r><\n>
clk_check_max_rates: pex2_c9_core rate 500000000 > max 250000000<\r><\n>
clk_check_max_rates: pex2_c10_core rate 500000000 > max 250000000<\r><\n>
clk_check_max_rates: pex0_c0_core rate 500000000 > max 250000000<\r><\n>
clk_check_max_rates: pex0_c1_core rate 500000000 > max 250000000<\r><\n>
clk_check_max_rates: pex0_c2_core rate 500000000 > max 250000000<\r><\n>
clk_check_max_rates: pex0_c3_core rate 500000000 > max 250000000<\r><\n>
clk_check_max_rates: pex0_c4_core rate 500000000 > max 250000000<\r><\n>
clk_check_max_rates: pex1_c5_core rate 500000000 > max 250000000<\r><\n>
initialized clk_mach_post<\r><\n>
initialized pg_post<\r><\n>
initialized regulator_post<\r><\n>
initialized profile<\r><\n>
initialized fuse_late<\r><\n>
initialized mrq<\r><\n>
initialized patrol_scrubber<\r><\n>
initialized cactmon<\r><\n>
ÿå[     2.703873] Camera-FW on t234-rce-safe ready SHA1=0b67520f (crt 1.489 ms, total boot 128.205 ms)<\r><\n>
ÿâinitialized extras_post<\r><\n>
bpmp: init complete<\r><\n>
ÿát successful<\r><\n>
I> DCE unhalt successful<\r><\n>
I> APE unhalÿè<\n>
ÿát skipped<\r><\n>
I> FSI unhalt skipped<\r><\n>
I> Task: Load CPUBL (0x50017f04)<\r><\n>
I> Task: Load TOS (0x50018608)<\r><\n>
I> Partition name: A_cpu-bootloader<\r><\n>
I> Size of partition: 3670016<\r><\n>
I> Binary@ device:3/0 block-24832 (partition size: 0x380000), name: A_cpu-bootloader<\r><\n>
I> Partition name: A_secure-os<\r><\n>
I> Size of partition: 4194304<\r><\n>
I> Binary@ device:3/0 block-32000 (partition size: 0x400000), name: A_secure-os<\r><\n>
I> cpubl: Authentication Finalize Done<\r><\n>
I> Binary cpubl loaded successfully at 0x231a00000<\r><\n>
I> tos: Authentication Finalize Done<\r><\n>
I> Binary tos loaded successfully at 0x23fdfe000<\r><\n>
I> Relocating OP-TEE dtb from: 0x23feff770 to 0x231e30000, size: 0x1976<\r><\n>
I> [0] START: 0x80000000, SIZE: 0x1b1e70000<\r><\n>
I> [1] START: 0x236000000, SIZE: 0x2000000<\r><\n>
I> Setting NS memory ranges to OP-TEE dtb finished.<\r><\n>
I> Partition name: A_eks<\r><\n>
I> Binary@ device:3/0 block-44288 (partition size: 0x40000), name: A_eks<\r><\n>
I> eks: Authentication Finalize Done<\r><\n>
I> Binary eks loaded successfully at 0x233000200<\r><\n>
ÿèDCE: FW Boot Done<\r><\n>
ÿáI> EKB detected (length: 0x410) @ VA:0x233000200<\r><\n>
I> Task: Prepare TOS params (0x50018580)<\r><\n>
I> Setting EKB blob info to OPTEE dtb finished.<\r><\n>
I> Setting OPTEE arg3: 0x231e30000<\r><\n>
I> Task: OEM SC7 context save (0x500197dc)<\r><\n>
I> OEM sc7 context saved<\r><\n>
I> Task: Disable MSS perf stats (0x50026a88)<\r><\n>
I> Task: Program display sticky bits (0x50026a04)<\r><\n>
I> Task: Storage device deinit (0x50001eec)<\r><\n>
I> Task: SMMU external bypass disable (0x50016a60)<\r><\n>
I> Task: SMMU init (0x5001697c)<\r><\n>
I> Task: Program GICv3 registers (0x50026b28)<\r><\n>
I> Task: Audit firewall settings (0x50023b50)<\r><\n>
I> Task: Bootchain failure check (0x50002434)<\r><\n>
I> Current Boot-Chain Slot: 0<\r><\n>
I> BR-BCT Boot-Chain is 0, and status is 1. Set UPDATE_BRBCT bit to 0<\r><\n>
I> MB2 finished<\n>
<\r><\n>
ÿäNOTICE:  BL31: v2.6(release):6363e7382<\r><\n>
NOTICE:  BL31: Built : 10:08:23, Feb 21 2023<\r><\n>
I/TC: <\r><\n>
I/TC: Non-secure external DT found<\r><\n>
I/TC: OP-TEE version: 3.19 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Tue Feb 21 18:24:01 UTC 2023 aarch64<\r><\n>
I/TC: WARNING: This OP-TEE configuration might be insecure!<\r><\n>
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html<\r><\n>
I/TC: Primary CPU initializing<\r><\n>
I/TC: WARNING: Test OEM keys are being used!<\r><\n>
I/TC: This is only for TZ-SE testing and should NOT be used for a shipping product!<\r><\n>
I/TC: Primary CPU switching to normal world boot<\r><\n>
ÿá<\n>
Jetson UEFI firmware (version 3.0-32616947 built on 2023-02-21T18:13:46+00:00)<\r><\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
Blockquote
Next part:
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<27>[2J<27>[04D<27>[=3h<27>[2J<27>[09D<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
<\n>
**  WARNING: Test Key is used.  **<\r><\n>
<\n>
L4TLauncher: Attempting Direct Boot<\r><\n>
EFI stub: Booting Linux Kernel...<\r><\n>
EFI stub: Using DTB from configuration table<\r><\n>
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path<\r><\n>
EFI stub: Exiting boot services and installing virtual address map...<\r><\n>
ÿäI/TC: Secondary CPU 1 initializing<\r><\n>
I/TC: Secondary CPU 1 switching to normal world boot<\r><\n>
I/TC: Secondary CPU 2 initializing<\r><\n>
I/TC: Secondary CPU 2 switching to normal world boot<\r><\n>
I/TC: Secondary CPU 3 initializing<\r><\n>
I/TC: Secondary CPU 3 switching to normal world boot<\r><\n>
I/TC: Secondary CPU 6 initializing<\r><\n>
I/TC: Secondary CPU 6 switching to normal world boot<\r><\n>
I/TC: Secondary CPU 7 initializing<\r><\n>
I/TC: Secondary CPU 7 switching to normal world boot<\r><\n>
ÿá[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]<\r><\n>
[    0.000000] Linux version 5.10.104-tegra (buildbrain@mobile-u64-6289-d7000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Sun Mar 19 07:55:28 PDT 2023<\r><\n>
[    0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,<\r><\n>
[    0.000000] OF: fdt:  - 80000000 ,  c0000000<\r><\n>
[    0.000000] Machine model: NVIDIA Orin Nano Developer Kit<\r><\n>
[    0.000000] efi: EFI v2.70 by EDK II<\r><\n>
[    0.000000] efi: RTPROP=0x20b5bdf18 SMBIOS=0xffff0000 SMBIOS 3.0=0x20a560000 MEMATTR=0x20ac5d018 ESRT=0x20ac6f498 RNG=0x22dd3dd18 MEMRESERVE=0x20ac5ef18 <\r><\n>
[    0.000000] efi: seeding entropy pool<\r><\n>
[    0.000000] esrt: Reserving ESRT space from 0x000000020ac6f498 to 0x000000020ac6f4d0.<\r><\n>
[    0.000000] Reserved memory: created CMA memory pool at 0x000000021dc00000, size 256 MiB<\r><\n>
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool<\r><\n>
[    0.000000] Zone ranges:<\r><\n>
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]<\r><\n>
[    0.000000]   DMA32    empty<\r><\n>
[    0.000000]   Normal   [mem 0x0000000100000000-0x0000000237ffffff]<\r><\n>
[    0.000000] Movable zone start for each node<\r><\n>
[    0.000000] Early memory node ranges<\r><\n>
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000fffdffff]<\r><\n>
[    0.000000]   node   0: [mem 0x00000000fffe0000-0x00000000ffffffff]<\r><\n>
[    0.000000]   node   0: [mem 0x0000000100000000-0x0000000206faffff]<\r><\n>
[    0.000000]   node   0: [mem 0x0000000206fb0000-0x0000000206fdffff]<\r><\n>
[    0.000000]   node   0: [mem 0x0000000206fe0000-0x0000000207e7cfff]<\r><\n>
[    0.000000]   node   0: [mem 0x0000000207e7d000-0x000000020a1bffff]<\r><\n>
[    0.000000]   node   0: [mem 0x000000020a1c0000-0x000000020a4fffff]<\r><\n>
[    0.000000]   node   0: [mem 0x000000020a500000-0x000000020a50ffff]<\r><\n>
[    0.000000]   node   0: [mem 0x000000020a510000-0x000000020a55ffff]<\r><\n>
[    0.000000]   node   0: [mem 0x000000020a560000-0x000000020a56ffff]<\r><\n>
[    0.000000]   node   0: [mem 0x000000020a570000-0x000000020a76ffff]<\r><\n>
[    0.000000]   node   0: [mem 0x000000020a770000-0x000000020a7bffff]<\r><\n>
[    0.000000]   node   0: [mem 0x000000020a7c0000-0x000000020a8affff]<\r><\n>
[    0.000000]   node   0: [mem 0x000000020a8b0000-0x000000020a8fffff]<\r><\n>
[    0.000000]   node   0: [mem 0x000000020a900000-0x000000020aa7ffff]<\r><\n>
[    0.000000]   node   0: [mem 0x000000020aa80000-0x000000020abbffff]<\r><\n>
[    0.000000]   node   0: [mem 0x000000020abc0000-0x000000020ac6ffff]<\r><\n>
[    0.000000]   node   0: [mem 0x000000020ac70000-0x000000020af0ffff]<\r><\n>
[    0.000000]   node   0: [mem 0x000000020af10000-0x000000020af3ffff]<\r><\n>
[    0.000000]   node   0: [mem 0x000000020af40000-0x000000020b02ffff]<\r><\n>
[    0.000000]   node   0: [mem 0x000000020b030000-0x000000020b03ffff]<\r><\n>
[    0.000000]   node   0: [mem 0x000000020b040000-0x000000020b08ffff]<\r><\n>
[    0.000000]   node   0: [mem 0x000000020b090000-0x000000020b58ffff]<\r><\n>
[    0.000000]   node   0: [mem 0x000000020b590000-0x000000020b59ffff]<\r><\n>
[    0.000000]   node   0: [mem 0x000000020b5a0000-0x000000020b6affff]<\r><\n>
[    0.000000]   node   0: [mem 0x000000020b6b0000-0x000000020b74ffff]<\r><\n>
[    0.000000]   node   0: [mem 0x000000020b750000-0x000000020b84ffff]<\r><\n>
[    0.000000]   node   0: [mem 0x000000020b850000-0x000000020b8effff]<\r><\n>
[    0.000000]   node   0: [mem 0x000000020b8f0000-0x000000020b9effff]<\r><\n>
[    0.000000]   node   0: [mem 0x000000020b9f0000-0x000000020ba8ffff]<\r><\n>
[    0.000000]   node   0: [mem 0x000000020ba90000-0x000000020c35ffff]<\r><\n>
[    0.000000]   node   0: [mem 0x000000020c360000-0x000000020c53ffff]<\r><\n>
[    0.000000]   node   0: [mem 0x000000020c540000-0x000000022dceffff]<\r><\n>
[    0.000000]   node   0: [mem 0x000000022dcf0000-0x000000022dd3ffff]<\r><\n>
[    0.000000]   node   0: [mem 0x000000022dd40000-0x00000002317fffff]<\r><\n>
[    0.000000]   node   0: [mem 0x0000000231a00000-0x0000000231e0ffff]<\r><\n>
[    0.000000]   node   0: [mem 0x0000000236000000-0x0000000237ffffff]<\r><\n>
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000237ffffff]<\r><\n>
[    0.000000] On node 0, zone Normal: 496 pages in unavailable ranges<\r><\n>
[    0.000000] psci: probing for conduit method from DT.<\r><\n>
[    0.000000] psci: PSCIv1.1 detected in firmware.<\r><\n>
[    0.000000] psci: Using standard PSCI v0.2 function IDs<\r><\n>
[    0.000000] psci: Trusted OS migration not required<\r><\n>
[    0.000000] psci: SMC Calling Convention v1.2<\r><\n>
[    0.000000] percpu: Embedded 32 pages/cpu s90200 r8192 d32680 u131072<\r><\n>
[    0.000000] Detected PIPT I-cache on CPU0<\r><\n>
[    0.000000] CPU features: detected: GIC system register CPU interface<\r><\n>
[    0.000000] CPU features: detected: Virtualization Host Extensions<\r><\n>
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR<\r><\n>
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)<\r><\n>
[    0.000000] CPU features: detected: Spectre-v4<\r><\n>
[    0.000000] alternatives: patching kernel code<\r><\n>
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1756688<\r><\n>
[    0.000000] Kernel command line: root=/dev/mmcblk1p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 <\r><\n>
[    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)<\r><\n>
[    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)<\r><\n>
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off<\r><\n>
[    0.000000] software IO TLB: mapped [mem 0x00000000effe0000-0x00000000fffe0000] (256MB)<\r><\n>
[    0.000000] Memory: 6360904K/7139392K available (18496K kernel code, 3168K rwdata, 7172K rodata, 3968K init, 1418K bss, 516344K reserved, 262144K cma-reserved)<\r><\n>
[    0.000000] random: get_random_u64 called from __kmem_cache_create+0x38/0x420 with crng_init=0<\r><\n>
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1<\r><\n>
[    0.000000] rcu: Preemptible hierarchical RCU implementation.<\r><\n>
[    0.000000] rcu: <9>RCU event tracing is enabled.<\r><\n>
[    0.000000] rcu: <9>RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.<\r><\n>
[    0.000000] <9>Trampoline variant of Tasks RCU enabled.<\r><\n>
[    0.000000] <9>Rude variant of Tasks RCU enabled.<\r><\n>
[    0.000000] <9>Tracing variant of Tasks RCU enabled.<\r><\n>
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.<\r><\n>
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6<\r><\n>
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0<\r><\n>
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode<\r><\n>
[    0.000000] GICv3: 960 SPIs implemented<\r><\n>
[    0.000000] GICv3: 0 Extended SPIs implemented<\r><\n>
[    0.000000] GICv3: Distributor has no Range Selector support<\r><\n>
[    0.000000] GICv3: 16 PPIs implemented<\r><\n>
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000<\r><\n>
[    0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)<\r><\n>
[    0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]<\r><\n>
[    0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).<\r><\n>
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns<\r><\n>
[    0.000004] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns<\r><\n>
[    0.000663] Console: colour dummy device 80x25<\r><\n>
[    0.000705] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)<\r><\n>
[    0.000713] pid_max: default: 32768 minimum: 301<\r><\n>
[    0.000775] LSM: Security Framework initializing<\r><\n>
[    0.000799] Yama: becoming mindful.<\r><\n>
[    0.000816] SELinux:  Initializing.<\r><\n>
[    0.000875] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)<\r><\n>
[    0.000889] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)<\r><\n>
[    0.001627] /cpus/cpu-map/cluster1: empty cluster<\r><\n>
[    0.001938] rcu: Hierarchical SRCU implementation.<\r><\n>
[    0.002037] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build<\r><\n>
[    0.002511] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t23x/p3768/kernel-dts/tegra234-p3767-0003-p3768-0000-a0.dts<\r><\n>
[    0.002516] DTB Build time: Mar 19 2023 08:08:40<\r><\n>
[    0.003780] Tegra Revision: A01 SKU: 0xd5 CPU Process: 0 SoC Process: 0<\r><\n>
[    0.004008] Remapping and enabling EFI services.<\r><\n>
[    0.005239] smp: Bringing up secondary CPUs ...<\r><\n>
[    0.033936] Detected PIPT I-cache on CPU1<\r><\n>
[    0.033972] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000<\r><\n>
[    0.034011] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]<\r><\n>
[    0.062656] Detected PIPT I-cache on CPU2<\r><\n>
[    0.062666] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000<\r><\n>
[    0.062682] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]<\r><\n>
[    0.091282] Detected PIPT I-cache on CPU3<\r><\n>
[    0.091292] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000<\r><\n>
[    0.091306] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]<\r><\n>
[    0.121952] Detected PIPT I-cache on CPU4<\r><\n>
[    0.121976] GICv3: CPU4: found redistributor 10200 region 0:0x000000000f500000<\r><\n>
[    0.122006] CPU4: Booted secondary processor 0x0000010200 [0x410fd421]<\r><\n>
[    0.150693] Detected PIPT I-cache on CPU5<\r><\n>
[    0.150705] GICv3: CPU5: found redistributor 10300 region 0:0x000000000f520000<\r><\n>
[    0.150722] CPU5: Booted secondary processor 0x0000010300 [0x410fd421]<\r><\n>
[    0.150787] smp: Brought up 1 node, 6 CPUs<\r><\n>
[    0.150801] SMP: Total of 6 processors activated.<\r><\n>
[    0.150805] CPU features: detected: Privileged Access Never<\r><\n>
[    0.150807] CPU features: detected: LSE atomic instructions<\r><\n>
[    0.150808] CPU features: detected: User Access Override<\r><\n>
[    0.150810] CPU features: detected: 32-bit EL0 Support<\r><\n>
[    0.150813] CPU features: detected: Common not Private translations<\r><\n>
[    0.150815] CPU features: detected: RAS Extension Support<\r><\n>
[    0.150817] CPU features: detected: Data cache clean to the PoU not required for I/D coherence<\r><\n>
[    0.150820] CPU features: detected: CRC32 instructions<\r><\n>
[    0.150821] CPU features: detected: Speculative Store Bypassing Safe (SSBS)<\r><\n>
[    0.189241] CPU: All CPU(s) started at EL2<\r><\n>
[    0.191011] devtmpfs: initialized<\r><\n>
[    0.207795] Registered cp15_barrier emulation handler<\r><\n>
[    0.207805] Registered setend emulation handler<\r><\n>
[    0.207810] KASLR enabled<\r><\n>
[    0.207966] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns<\r><\n>
[    0.207978] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)<\r><\n>
[    0.209927] pinctrl core: initialized pinctrl subsystem<\r><\n>
[    0.210486] SMBIOS 3.0.0 present.<\r><\n>
[    0.210496] DMI: Unknown NVIDIA Orin NX Developer Kit/NVIDIA Orin NX Developer Kit, BIOS 3.0-32616947 02/21/2023<\r><\n>
[    0.210784] NET: Registered protocol family 16<\r><\n>
[    0.211681] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations<\r><\n>
[    0.211746] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations<\r><\n>
[    0.211801] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations<\r><\n>
[    0.211831] audit: initializing netlink subsys (disabled)<\r><\n>
[    0.211926] audit: type=2000 audit(0.208:1): state=initialized audit_enabled=0 res=1<\r><\n>
[    0.212137] thermal_sys: Registered thermal governor 'step_wise'<\r><\n>
[    0.212140] thermal_sys: Registered thermal governor 'power_allocator'<\r><\n>
[    0.212143] thermal_sys: Registered thermal governor 'pid_thermal_gov'<\r><\n>
[    0.212997] cpuidle: using governor menu<\r><\n>
[    0.213116] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.<\r><\n>
[    0.213190] ASID allocator initialised with 32768 entries<\r><\n>
[    0.213294] Serial: AMBA PL011 UART driver<\r><\n>
[    0.215275] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful<\r><\n>
[    0.215302] Tegra reboot handler registered.<\r><\n>
[    0.237404] mc: mapped MMIO address: 0xffff8000107b0000 -> 0x2c10000<\r><\n>
[    0.237417] mc: mapped MMIO address: 0xffff8000107d0000 -> 0x2c20000<\r><\n>
[    0.237427] mc: mapped MMIO address: 0xffff8000107f0000 -> 0x2c30000<\r><\n>
[    0.237437] mc: mapped MMIO address: 0xffff800010810000 -> 0x2c40000<\r><\n>
[    0.237445] mc: mapped MMIO address: 0xffff800010830000 -> 0x2c50000<\r><\n>
[    0.237452] mc: mapped MMIO address: 0xffff800010850000 -> 0x2b80000<\r><\n>
[    0.237459] mc: mapped MMIO address: 0xffff800010870000 -> 0x2b90000<\r><\n>
[    0.237467] mc: mapped MMIO address: 0xffff800010890000 -> 0x2ba0000<\r><\n>
[    0.237474] mc: mapped MMIO address: 0xffff8000108b0000 -> 0x2bb0000<\r><\n>
[    0.237483] mc: mapped MMIO address: 0xffff8000108d0000 -> 0x1700000<\r><\n>
[    0.237490] mc: mapped MMIO address: 0xffff8000108f0000 -> 0x1710000<\r><\n>
[    0.237498] mc: mapped MMIO address: 0xffff800010910000 -> 0x1720000<\r><\n>
[    0.237507] mc: mapped MMIO address: 0xffff800010930000 -> 0x1730000<\r><\n>
[    0.237514] mc: mapped MMIO address: 0xffff800010950000 -> 0x1740000<\r><\n>
[    0.237521] mc: mapped MMIO address: 0xffff800010970000 -> 0x1750000<\r><\n>
[    0.237529] mc: mapped MMIO address: 0xffff800010990000 -> 0x1760000<\r><\n>
[    0.237536] mc: mapped MMIO address: 0xffff8000109b0000 -> 0x1770000<\r><\n>
[    0.237545] nv-tegra-mc 2c10000.mc: No mssnvlink node<\r><\n>
[    0.237570] mc-err: mcerr ops are set to t23x<\r><\n>
[    0.238345] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 65, base_baud = 0) is a SBSA<\r><\n>
[    1.390854] printk: console [ttyAMA0] enabled<\r><\n>
[    1.399793] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages<\r><\n>
[    1.406501] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages<\r><\n>
[    1.413201] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages<\r><\n>
[    1.419900] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages<\r><\n>
[    1.428534] ACPI: Interpreter disabled.<\r><\n>
[    1.432834] ddr-vddq: supplied by vdd-5v<\r><\n>
[    1.436987] ddr-vdd2: supplied by vdd-5v<\r><\n>
[    1.441040] vdd-AO-1v2: supplied by vdd-5v<\r><\n>
[    1.445273] vdd-3v3: supplied by vdd-5v<\r><\n>
[    1.449338] vdd-rtc: supplied by vdd-AO-1v2<\r><\n>
[    1.453644] vdd-0v95-uphy: supplied by vdd-AO-1v2<\r><\n>
[    1.458486] vdd-0v95-hdmi: supplied by vdd-AO-1v2<\r><\n>
[    1.463473] vdd-1v8: supplied by vdd-3v3-sys<\r><\n>
[    1.467863] vdd-3v3-AO: supplied by vdd-5v-sys<\r><\n>
[    1.472424] vdd-av10-hub: supplied by vdd-5v-sys<\r><\n>
[    1.477179] vdd-vbus-a: supplied by vdd-5v-sys<\r><\n>
[    1.481745] vdd-vbus-b: supplied by vdd-5v-sys<\r><\n>
[    1.486315] vdd-3v3-dp: supplied by vdd-3v3-sys<\r><\n>
[    1.491133] iommu: Default domain type: Translated <\r><\n>
[    1.496044] eventlib_kernel: keventlib is initialized, test id: 0<\r><\n>
[    1.502337] SCSI subsystem initialized<\r><\n>
[    1.506165] usbcore: registered new interface driver usbfs<\r><\n>
[    1.511665] usbcore: registered new interface driver hub<\r><\n>
[    1.516991] usbcore: registered new device driver usb<\r><\n>
[    1.522260] mc: Linux media interface: v0.10<\r><\n>
[    1.526538] videodev: Linux video capture interface: v2.00<\r><\n>
[    1.532189] pps_core: LinuxPPS API ver. 1 registered<\r><\n>
[    1.537152] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it><\r><\n>
[    1.546291] PTP clock support registered<\r><\n>
[    1.550477] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec<\r><\n>
[    1.557635] tegra_wdt_t18x 2190000.watchdog: Registered successfully<\r><\n>
[    1.565337] Registered efivars operations<\r><\n>
[    1.569914] FPGA manager framework<\r><\n>
[    1.573359] Advanced Linux Sound Architecture Driver Initialized.<\r><\n>
[    1.579735] Bluetooth: Core ver 2.22<\r><\n>
[    1.583322] NET: Registered protocol family 31<\r><\n>
[    1.587764] Bluetooth: HCI device and connection manager initialized<\r><\n>
[    1.594121] Bluetooth: HCI socket layer initialized<\r><\n>
[    1.598998] Bluetooth: L2CAP socket layer initialized<\r><\n>
[    1.604053] Bluetooth: SCO socket layer initialized<\r><\n>
[    1.609477] camchar: rtcpu character device driver loaded<\r><\n>
[    1.615115] clocksource: Switched to clocksource arch_sys_counter<\r><\n>
[    1.816033] VFS: Disk quotas dquot_6.6.0<\r><\n>
[    1.820001] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)<\r><\n>
[    1.827037] pnp: PnP ACPI: disabled<\r><\n>
[    1.832665] la/ptsa driver initialized.<\r><\n>
[    1.836567] NET: Registered protocol family 2<\r><\n>
[    1.841056] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)<\r><\n>
[    1.850123] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)<\r><\n>
[    1.858671] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)<\r><\n>
[    1.866659] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)<\r><\n>
[    1.874569] TCP: Hash tables configured (established 65536 bind 65536)<\r><\n>
[    1.881182] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)<\r><\n>
[    1.887992] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)<\r><\n>
[    1.895303] NET: Registered protocol family 1<\r><\n>
[    1.899873] RPC: Registered named UNIX socket transport module.<\r><\n>
[    1.905799] RPC: Registered udp transport module.<\r><\n>
[    1.910512] RPC: Registered tcp transport module.<\r><\n>
[    1.915216] RPC: Registered tcp NFSv4.1 backchannel transport module.<\r><\n>
[    1.921660] PCI: CLS 0 bytes, default 64<\r><\n>
[    1.925687] Trying to unpack rootfs image as initramfs...<\r><\n>
[    2.085505] Freeing initrd memory: 9120K<\r><\n>
[    2.091523] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available<\r><\n>
[    2.099446] kvm [1]: IPA Size Limit: 48 bits<\r><\n>
[    2.103766] kvm [1]: GICv3: no GICV resource entry<\r><\n>
[    2.108558] kvm [1]: disabling GICv2 emulation<\r><\n>
[    2.113014] kvm [1]: GIC system register CPU interface enabled<\r><\n>
[    2.118913] kvm [1]: vgic interrupt IRQ9<\r><\n>
[    2.122945] kvm [1]: VHE mode initialized successfully<\r><\n>
[    2.128771] Initialise system trusted keyrings<\r><\n>
[    2.133301] workingset: timestamp_bits=46 max_order=21 bucket_order=0<\r><\n>
[    2.142227] squashfs: version 4.0 (2009/01/31) Phillip Lougher<\r><\n>
[    2.148387] NFS: Registering the id_resolver key type<\r><\n>
[    2.153456] Key type id_resolver registered<\r><\n>
[    2.157638] Key type id_legacy registered<\r><\n>
[    2.161689] nfs4filelayout_init: NFSv4 File Layout Driver Registering...<\r><\n>
[    2.168399] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...<\r><\n>
[    2.175802] ntfs: driver 2.1.32 [Flags: R/W].<\r><\n>
[    2.194771] NET: Registered protocol family 38<\r><\n>
[    2.199217] Key type asymmetric registered<\r><\n>
[    2.203310] Asymmetric key parser 'x509' registered<\r><\n>
[    2.208206] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)<\r><\n>
[    2.215664] io scheduler mq-deadline registered<\r><\n>
[    2.220194] io scheduler kyber registered<\r><\n>
[    2.228535] tegra-pwm 3280000.pwm: PWM clk can sleep in ops<\r><\n>
[    2.234138] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops<\r><\n>
[    2.239726] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops<\r><\n>
[    2.246181] efifb: probing for efifb<\r><\n>
[    2.249796] efifb: framebuffer at 0x208000000, using 23040k, total 23040k<\r><\n>
[    2.256585] efifb: mode is 2560x1440x32, linelength=16384, pages=1<\r><\n>
[    2.262765] efifb: scrolling: redraw<\r><\n>
[    2.266341] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0<\r><\n>
[    2.278423] Console: switching to colour frame buffer device 320x90<\r><\n>
[    2.290907] fb0: EFI VGA frame buffer device<\r><\n>
[    2.297141] tegra_dc_assign_hw_data: no matching compatible node<\r><\n>
[    2.303149] tegradccommon module_init failed<\r><\n>
[    2.307415] tegradc module_init failed<\r><\n>
[    2.311457] EINJ: ACPI disabled.<\r><\n>
[    2.316371] tegra-pmc c360000.pmc: scratch reg offset dts data not present<\r><\n>
[    2.323253] tegra-pmc: ### PMC reset source: SYS_RESET_N<\r><\n>
[    2.328565] tegra-pmc: ### PMC reset level: L0<\r><\n>
[    2.333005] tegra-pmc: ### PMC reset status reg: 0x0<\r><\n>
[    2.339382] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled<\r><\n>
[    3.783892] random: fast init done<\r><\n>
[    3.964481] printk: console [ttyTCU0] enabled<\r><\n>
[    3.969561] arm-smmu 12000000.iommu: probing hardware configuration...<\r><\n>
[    3.976265] arm-smmu 12000000.iommu: SMMUv2 with:<\r><\n>
[    3.981086] arm-smmu 12000000.iommu: <9>stage 1 translation<\r><\n>
[    3.986623] arm-smmu 12000000.iommu: <9>stage 2 translation<\r><\n>
[    3.992164] arm-smmu 12000000.iommu: <9>nested translation<\r><\n>
[    3.997613] arm-smmu 12000000.iommu: <9>stream matching with 128 register groups<\r><\n>
[    4.005025] arm-smmu 12000000.iommu: <9>128 context banks (0 stage-2 only)<\r><\n>
[    4.014162] arm-smmu 12000000.iommu: <9>Supported page sizes: 0x00001000<\r><\n>
[    4.020862] arm-smmu 12000000.iommu: <9>Stage-1: 48-bit VA -> 48-bit IPA<\r><\n>
[    4.027550] arm-smmu 12000000.iommu: <9>Stage-2: 48-bit IPA -> 48-bit PA<\r><\n>
[    4.035105] arm-smmu 10000000.iommu: probing hardware configuration...<\r><\n>
[    4.041807] arm-smmu 10000000.iommu: SMMUv2 with:<\r><\n>
[    4.046626] arm-smmu 10000000.iommu: <9>stage 1 translation<\r><\n>
[    4.052164] arm-smmu 10000000.iommu: <9>stage 2 translation<\r><\n>
[    4.057702] arm-smmu 10000000.iommu: <9>nested translation<\r><\n>
[    4.063156] arm-smmu 10000000.iommu: <9>stream matching with 128 register groups<\r><\n>
[    4.070562] arm-smmu 10000000.iommu: <9>128 context banks (0 stage-2 only)<\r><\n>
[    4.079716] arm-smmu 10000000.iommu: <9>Supported page sizes: 0x00001000<\r><\n>
[    4.086413] arm-smmu 10000000.iommu: <9>Stage-1: 48-bit VA -> 48-bit IPA<\r><\n>
[    4.093098] arm-smmu 10000000.iommu: <9>Stage-2: 48-bit IPA -> 48-bit PA<\r><\n>
[    4.100284] arm-smmu 8000000.iommu: probing hardware configuration...<\r><\n>
[    4.106895] arm-smmu 8000000.iommu: SMMUv2 with:<\r><\n>
[    4.111629] arm-smmu 8000000.iommu: <9>stage 1 translation<\r><\n>
[    4.117076] arm-smmu 8000000.iommu: <9>stage 2 translation<\r><\n>
[    4.122529] arm-smmu 8000000.iommu: <9>nested translation<\r><\n>
[    4.127884] arm-smmu 8000000.iommu: <9>stream matching with 128 register groups<\r><\n>
[    4.135203] arm-smmu 8000000.iommu: <9>128 context banks (0 stage-2 only)<\r><\n>
[    4.144241] arm-smmu 8000000.iommu: <9>Supported page sizes: 0x00001000<\r><\n>
[    4.150846] arm-smmu 8000000.iommu: <9>Stage-1: 48-bit VA -> 48-bit IPA<\r><\n>
[    4.157454] arm-smmu 8000000.iommu: <9>Stage-2: 48-bit IPA -> 48-bit PA<\r><\n>
[    4.164734] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful<\r><\n>
[    4.174531] tegra_profiler: version: 1.151, samples/io: 51/30<\r><\n>
[    4.180501] tegra_profiler: auth: init<\r><\n>
[    4.184655] nvsciipc: loaded module<\r><\n>
[    4.189997] tun: Universal TUN/TAP device driver, 1.6<\r><\n>
[    4.195681] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version<\r><\n>
[    4.203104] hns3: Copyright (c) 2017 Huawei Corporation.<\r><\n>
[    4.208586] e1000e: Intel(R) PRO/1000 Network Driver<\r><\n>
[    4.213677] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.<\r><\n>
[    4.219765] igb: Intel(R) Gigabit Ethernet Network Driver<\r><\n>
[    4.225297] igb: Copyright (c) 2007-2014 Intel Corporation.<\r><\n>
[    4.231205] PPP generic driver version 2.4.2<\r><\n>
[    4.235644] PPP BSD Compression module registered<\r><\n>
[    4.240476] PPP Deflate Compression module registered<\r><\n>
[    4.245672] PPP MPPE Compression module registered<\r><\n>
[    4.250609] usbcore: registered new interface driver r8152<\r><\n>
[    4.256253] usbcore: registered new interface driver asix<\r><\n>
[    4.261798] usbcore: registered new interface driver ax88179_178a<\r><\n>
[    4.268066] usbcore: registered new interface driver cdc_ether<\r><\n>
[    4.274057] usbcore: registered new interface driver net1080<\r><\n>
[    4.279876] usbcore: registered new interface driver cdc_subset<\r><\n>
[    4.285950] usbcore: registered new interface driver zaurus<\r><\n>
[    4.291688] usbcore: registered new interface driver cdc_ncm<\r><\n>
[    4.297498] usbcore: registered new interface driver aqc111<\r><\n>
[    4.303350] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver<\r><\n>
[    4.309703] ohci-pci: OHCI PCI platform driver<\r><\n>
[    4.314280] ohci-platform: OHCI generic platform driver<\r><\n>
[    4.320002] tegra-xusb 3610000.xhci: Adding to iommu group 0<\r><\n>
[    4.326358] usbcore: registered new interface driver uas<\r><\n>
[    4.331837] usbcore: registered new interface driver usb-storage<\r><\n>
[    4.338165] tegra-xudc 3550000.xudc: Adding to iommu group 1<\r><\n>
[    4.344269] mousedev: PS/2 mouse device common for all mice<\r><\n>
[    4.350010] usbcore: registered new interface driver xpad<\r><\n>
[    4.357448] tegra_rtc c2a0000.rtc: registered as rtc1<\r><\n>
[    4.362924] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:33 UTC (33)<\r><\n>
[    4.371146] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock<\r><\n>
[    4.377544] i2c /dev entries driver<\r><\n>
[    4.381257] tegra-i2c 3160000.i2c: Adding to iommu group 2<\r><\n>
[    4.387072] tegra-i2c c240000.i2c: Adding to iommu group 2<\r><\n>
[    4.392770] tegra-i2c 3180000.i2c: Adding to iommu group 2<\r><\n>
[    4.398450] tegra-i2c 3190000.i2c: Adding to iommu group 2<\r><\n>
[    4.404125] tegra-i2c 31b0000.i2c: Adding to iommu group 2<\r><\n>
[    4.409801] tegra-i2c 31c0000.i2c: Adding to iommu group 2<\r><\n>
[    4.415478] tegra-i2c c250000.i2c: Adding to iommu group 2<\r><\n>
[    4.421157] tegra-i2c 31e0000.i2c: Adding to iommu group 2<\r><\n>
[    4.430653] device-mapper: uevent: version 1.0.3<\r><\n>
[    4.435489] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com<\r><\n>
[    4.445210] sdhci: Secure Digital Host Controller Interface driver<\r><\n>
[    4.451564] sdhci: Copyright(c) Pierre Ossman<\r><\n>
[    4.456037] Synopsys Designware Multimedia Card Interface Driver<\r><\n>
[    4.462287] sdhci-pltfm: SDHCI platform and OF driver helper<\r><\n>
[    4.468635] sdhci-tegra 3400000.sdhci: Adding to iommu group 3<\r><\n>
[    4.468884] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401<\r><\n>
[    4.482116] tegra-bpmp bpmp: firmware: f0fadc45ec6216cb5b0b-1377b684fe5<\r><\n>
[    4.490255] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9 <\r><\n>
[    4.495651] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x82<\r><\n>
[    4.504321] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0<\r><\n>
[    4.510234] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful<\r><\n>
ÿâFailed to create /rm/vdd_cpu<\r><\n>
debugfs initialized<\r><\n>
ÿá[    5.598882] hid: raw HID events driver (C) Jiri Kosina<\r><\n>
[    5.604725] usbcore: registered new interface driver usbhid<\r><\n>
[    5.610459] usbhid: USB HID core driver<\r><\n>
[    5.614905] tegra-dce d800000.dce: Adding to iommu group 4<\r><\n>
[    5.622219] dce: dce_ipc_channel_init:319  Invalid Channel State [0x0] for ch_type [2]<\r><\n>
[    5.631446] tegra234-aon c000000.aon: Adding to iommu group 5<\r><\n>
[    5.638084] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x5]<\r><\n>
[    5.640274]  c000000.aon:hsp: probed<\r><\n>
[    5.647068] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [0]. Ignored...<\r><\n>
[    5.659487] tegra234-aon c000000.aon: init done<\r><\n>
[    5.659965] tegra23x-psc e860000.psc: Adding to iommu group 6<\r><\n>
[    5.664172] dce: dce_admin_send_cmd_ver:424  version : [0x2] err : [0x0]<\r><\n>
[    5.670364] tegra23x-psc e860000.psc: ext_cfg base:(____ptrval____)<\r><\n>
[    5.677412] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x1]<\r><\n>
[    5.683372] tegra23x-psc e860000.psc: init done<\r><\n>
[    5.683579] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 7<\r><\n>
[    5.692341] dce: dce_admin_setup_clients_ipc:553  Channel Reset Complete for Type [1] ...<\r><\n>
[    5.692342] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [1]. Ignored...<\r><\n>
[    5.692353] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [1]. Ignored...<\r><\n>
[    5.697676] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000<\r><\n>
[    5.703599] dce: dce_admin_setup_clients_ipc:529  Get queue info failed for [2]<\r><\n>
[    5.714466] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584<\r><\n>
[    5.721165] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x2]<\r><\n>
[    5.729596] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900<\r><\n>
[    5.737876] dce: dce_admin_setup_clients_ipc:553  Channel Reset Complete for Type [3] ...<\r><\n>
[    5.737877] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [3]. Ignored...<\r><\n>
[    5.737888] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [3]. Ignored...<\r><\n>
[    5.745777] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80<\r><\n>
[    5.755078] dce: dce_start_boot_flow:173  DCE_BOOT_DONE<\r><\n>
[    5.763756] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80<\r><\n>
[    5.829173] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80<\r><\n>
[    5.841807] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080<\r><\n>
[    5.854651] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200<\r><\n>
[    5.866789] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (113)<\r><\n>
[    5.873598] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful<\r><\n>
[    5.886997] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=0b67520f597ddc6db82218e87c6c6eb8979fd4bb<\r><\n>
[    5.900686] t19x_cache tegra-cache: probed<\r><\n>
[    5.905153] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU<\r><\n>
[    5.917362] optee: probing for conduit method.<\r><\n>
[    5.921978] optee: revision 3.19 (3f29c61f)<\r><\n>
[    5.922721] optee: dynamic shared memory is enabled<\r><\n>
[    5.932157] optee: initialized driver<\r><\n>
[    5.947564] nvpmodel: initialized successfully<\r><\n>
[    5.952251] tegra_hv: get_hvd: not initialized yet<\r><\n>
[    5.957192] user_ivc_mempool: hypervisor not present<\r><\n>
[    5.963123] usbcore: registered new interface driver snd-usb-audio<\r><\n>
[    5.970274] u32 classifier<\r><\n>
[    5.973061]     input device check on<\r><\n>
[    5.976831]     Actions configured<\r><\n>
[    5.980471] Initializing XFRM netlink socket<\r><\n>
[    5.985338] NET: Registered protocol family 10<\r><\n>
[    5.991329] Segment Routing with IPv6<\r><\n>
[    5.995180] NET: Registered protocol family 17<\r><\n>
[    5.999771] NET: Registered protocol family 15<\r><\n>
[    6.004400] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.<\r><\n>
[    6.018144] Bluetooth: RFCOMM socket layer initialized<\r><\n>
[    6.023445] Bluetooth: RFCOMM ver 1.11<\r><\n>
[    6.027312] Bluetooth: HIDP (Human Interface Emulation) ver 1.2<\r><\n>
[    6.033396] Bluetooth: HIDP socket layer initialized<\r><\n>
[    6.039340] 9pnet: Installing 9P2000 support<\r><\n>
[    6.043799] Key type dns_resolver registered<\r><\n>
[    6.048876] registered taskstats version 1<\r><\n>
[    6.053108] Loading compiled-in X.509 certificates<\r><\n>
[    6.068891] Loaded X.509 cert 'Build time autogenerated kernel key: e63fb224cdc2a940ac382bb67b420fcb52cc4aee'<\r><\n>
[    6.079698] tegra194-pcie 14100000.pcie: Adding to iommu group 8<\r><\n>
[    6.092773] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator<\r><\n>
[    6.100091] tegra194-pcie 14160000.pcie: Adding to iommu group 9<\r><\n>
[    6.112584] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator<\r><\n>
[    6.119688] tegra194-pcie 141e0000.pcie: Adding to iommu group 10<\r><\n>
[    6.131956] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator<\r><\n>
[    6.138923] tegra194-pcie 140a0000.pcie: Adding to iommu group 11<\r><\n>
[    6.151045] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator<\r><\n>
[    6.184411] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 12<\r><\n>
[    6.195412] host1x 13e40000.host1x: Adding to iommu group 13<\r><\n>
[    6.221814] host1x 13e40000.host1x: initialized<\r><\n>
[    6.226924] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 14<\r><\n>
[    6.234962] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)<\r><\n>
[    6.247281] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 15<\r><\n>
[    6.255302] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)<\r><\n>
[    6.267591] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 16<\r><\n>
[    6.275588] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)<\r><\n>
[    6.287875] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 17<\r><\n>
[    6.295859] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)<\r><\n>
[    6.308140] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 18<\r><\n>
[    6.316124] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)<\r><\n>
[    6.328415] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 19<\r><\n>
[    6.336401] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)<\r><\n>
[    6.348672] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 20<\r><\n>
[    6.356685] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)<\r><\n>
[    6.368988] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 21<\r><\n>
[    6.376954] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)<\r><\n>
[    6.389235] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 22<\r><\n>
[    6.397228] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)<\r><\n>
[    6.409493] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 23<\r><\n>
[    6.417488] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)<\r><\n>
[    6.429750] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 24<\r><\n>
[    6.437734] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)<\r><\n>
[    6.450008] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 25<\r><\n>
[    6.457978] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)<\r><\n>
[    6.470268] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 26<\r><\n>
[    6.478241] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)<\r><\n>
[    6.490507] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 27<\r><\n>
[    6.498509] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)<\r><\n>
[    6.510789] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 28<\r><\n>
[    6.518757] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)<\r><\n>
[    6.531017] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 29<\r><\n>
[    6.538987] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)<\r><\n>
[    6.551311] falcon 15340000.vic: Adding to iommu group 30<\r><\n>
[    6.561937] falcon 15340000.vic: initialized<\r><\n>
[    6.566687] falcon 15380000.nvjpg: Adding to iommu group 31<\r><\n>
[    6.576205] falcon 15380000.nvjpg: initialized<\r><\n>
[    6.580921] falcon 15540000.nvjpg1: Adding to iommu group 32<\r><\n>
[    6.590714] falcon 15540000.nvjpg1: initialized<\r><\n>
[    6.595515] falcon 154c0000.nvenc: Adding to iommu group 33<\r><\n>
[    6.605663] falcon 154c0000.nvenc: _opp_is_duplicate: duplicate OPPs detected. Existing: freq: 115200000, volt: 0, enabled: 1. New: freq: 115200000, volt: 0, enabled: 1<\r><\n>
[    6.621636] falcon 154c0000.nvenc: initialized<\r><\n>
[    6.626350] falcon 15a50000.ofa: Adding to iommu group 34<\r><\n>
[    6.635676] falcon 15a50000.ofa: initialized<\r><\n>
[    6.640218] nvdec 15480000.nvdec: Adding to iommu group 35<\r><\n>
[    6.652557] nvdec 15480000.nvdec: initialized<\r><\n>
[    6.657176] tsec 15500000.tsec: Adding to iommu group 36<\r><\n>
[    6.667338] tsec 15500000.tsec: initialized<\r><\n>
[    6.674901] gic 2a41000.agic-controller: GIC IRQ controller registered<\r><\n>
[    6.692403] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered<\r><\n>
[    6.708625] gpio-397 (camera-control-output-low): hogged as output/low<\r><\n>
[    6.715384] gpio-486 (camera-control-output-low): hogged as output/low<\r><\n>
[    6.723184] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio<\r><\n>
[    6.730514] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon<\r><\n>
[    6.737506] tegra-pwm 3280000.pwm: PWM clk can sleep in ops<\r><\n>
[    6.744011] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops<\r><\n>
[    6.750478] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops<\r><\n>
[    6.758850] tegra194-isp5 14800000.isp: Adding to iommu group 37<\r><\n>
[    6.767150] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU<\r><\n>
[    6.776835] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized<\r><\n>
[    6.783287] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound<\r><\n>
[    6.792514] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound<\r><\n>
[    6.801909] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 38<\r><\n>
[    6.810018] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 39<\r><\n>
[    6.818074] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU<\r><\n>
[    6.828057] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized<\r><\n>
[    6.834876] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU<\r><\n>
[    6.844859] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized<\r><\n>
[    6.851664] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU<\r><\n>
[    6.861603] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized<\r><\n>
[    6.868436] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 40<\r><\n>
[    6.877128] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18, iommu=smmu.0x0000000008000000)<\r><\n>
[    6.888492] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 41<\r><\n>
[    6.897120] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19, iommu=smmu.0x0000000008000000)<\r><\n>
[    6.908489] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 42<\r><\n>
[    6.917095] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20, iommu=smmu.0x0000000008000000)<\r><\n>
[    6.928460] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 43<\r><\n>
[    6.937076] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21, iommu=smmu.0x0000000008000000)<\r><\n>
[    6.948449] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to iommu group 44<\r><\n>
[    6.957050] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized (streamid=22, iommu=smmu.0x0000000008000000)<\r><\n>
[    6.968402] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to iommu group 45<\r><\n>
[    6.977005] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized (streamid=23, iommu=smmu.0x0000000008000000)<\r><\n>
[    6.988392] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to iommu group 46<\r><\n>
[    6.997009] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized (streamid=24, iommu=smmu.0x0000000008000000)<\r><\n>
[    7.008368] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to iommu group 47<\r><\n>
[    7.017009] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized (streamid=25, iommu=smmu.0x0000000008000000)<\r><\n>
[    7.028373] pva 16000000.pva0: Adding to iommu group 48<\r><\n>
[    7.034142] nvdla 15880000.nvdla0: Adding to iommu group 49<\r><\n>
[    7.040227] nvdla 158c0000.nvdla1: Adding to iommu group 50<\r><\n>
[    7.046398] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 2<\r><\n>
[    7.053571] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels<\r><\n>
[    7.061078] tegra-fuse-burn efuse-burn: shutdown limit check disabled<\r><\n>
[    7.067705] tegra-fuse-burn efuse-burn: Fuse burn driver initialized<\r><\n>
[    7.074448] serial-tegra 3100000.serial: Adding to iommu group 2<\r><\n>
[    7.081122] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 17, base_baud = 0) is a TEGRA_UART<\r><\n>
[    7.090933] serial-tegra 3130000.serial: Adding to iommu group 2<\r><\n>
[    7.097490] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 63, base_baud = 0) is a TEGRA_UART<\r><\n>
[    7.107152] serial-tegra 3140000.serial: Adding to iommu group 2<\r><\n>
[    7.113708] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 64, base_baud = 0) is a TEGRA_UART<\r><\n>
[    7.140887] tegra-xusb 3610000.xhci: Firmware timestamp: 2021-12-01 05:27:10 UTC, Version: 80.03 release<\r><\n>
[    7.150640] tegra-xusb 3610000.xhci: xHCI Host Controller<\r><\n>
[    7.156219] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1<\r><\n>
[    7.164884] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810<\r><\n>
[    7.174519] tegra-xusb 3610000.xhci: irq 230, io mem 0x03610000<\r><\n>
[    7.180990] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10<\r><\n>
[    7.189493] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1<\r><\n>
[    7.196944] usb usb1: Product: xHCI Host Controller<\r><\n>
[    7.201958] usb usb1: Manufacturer: Linux 5.10.104-tegra xhci-hcd<\r><\n>
[    7.208224] usb usb1: SerialNumber: 3610000.xhci<\r><\n>
[    7.213694] hub 1-0:1.0: USB hub found<\r><\n>
[    7.217586] hub 1-0:1.0: 4 ports detected<\r><\n>
[    7.222025] tegra-xusb 3610000.xhci: xHCI Host Controller<\r><\n>
[    7.227590] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2<\r><\n>
[    7.235381] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed<\r><\n>
[    7.242954] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10<\r><\n>
[    7.251474] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1<\r><\n>
[    7.258909] usb usb2: Product: xHCI Host Controller<\r><\n>
[    7.263924] usb usb2: Manufacturer: Linux 5.10.104-tegra xhci-hcd<\r><\n>
[    7.270186] usb usb2: SerialNumber: 3610000.xhci<\r><\n>
[    7.275467] hub 2-0:1.0: USB hub found<\r><\n>
[    7.279352] hub 2-0:1.0: 4 ports detected<\r><\n>
[    7.304405] i2c i2c-2: Added multiplexed i2c bus 9<\r><\n>
[    7.310023] i2c i2c-2: Added multiplexed i2c bus 10<\r><\n>
[    7.315052] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter<\r><\n>
[    7.322057] tegra23x-oc-event soctherm-oc-event: Finished tegra23x overcurrent event probing<\r><\n>
[    7.343803] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1556000 KHz, changing to: 1510400 KHz<\r><\n>
[    7.356786] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 1459000 KHz, changing to: 1497600 KHz<\r><\n>
[    7.369543] tegra194-cpufreq e000000.ccplex: probed with ICC<\r><\n>
[    7.377251] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator<\r><\n>
[    7.384702] sdhci-tegra 3400000.sdhci: Got CD GPIO<\r><\n>
[    7.385656] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:<\r><\n>
[    7.396829] tegra194-pcie 14100000.pcie:       IO 0x0030100000..0x00301fffff -> 0x0030100000<\r><\n>
[    7.405525] tegra194-pcie 14100000.pcie:      MEM 0x20a8000000..0x20afffffff -> 0x0040000000<\r><\n>
[    7.414240] tegra194-pcie 14100000.pcie:      MEM 0x2080000000..0x20a7ffffff -> 0x2080000000<\r><\n>
[    7.431569] irq: IRQ294: trimming hierarchy from :interrupt-controller@f400000-1<\r><\n>
[    7.439252] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 294<\r><\n>
[    7.487130] usb 1-2: new high-speed USB device number 2 using tegra-xusb<\r><\n>
[    7.531123] tegra194-pcie 14100000.pcie: Link up<\r><\n>
[    7.537561] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00<\r><\n>
[    7.544375] pci_bus 0001:00: root bus resource [bus 00-ff]<\r><\n>
[    7.550041] pci_bus 0001:00: root bus resource [io  0x0000-0xfffff] (bus address [0x30100000-0x301fffff])<\r><\n>
[    7.559876] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])<\r><\n>
[    7.570703] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]<\r><\n>
[    7.578643] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400<\r><\n>
[    7.584990] pci 0001:00:00.0: PME# supported from D0 D3hot<\r><\n>
[    7.596494] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000<\r><\n>
[    7.602841] pci 0001:01:00.0: reg 0x10: [io  0x0000-0x00ff]<\r><\n>
[    7.608785] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]<\r><\n>
[    7.617276] pci 0001:01:00.0: supports D1 D2<\r><\n>
[    7.621673] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold<\r><\n>
[    7.633878] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]<\r><\n>
[    7.641311] pci 0001:00:00.0: BAR 13: assigned [io  0x1000-0x1fff]<\r><\n>
[    7.647670] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff 64bit]<\r><\n>
[    7.655711] pci 0001:01:00.0: BAR 0: assigned [io  0x1000-0x10ff]<\r><\n>
[    7.662039] pci 0001:00:00.0: PCI bridge to [bus 01-ff]<\r><\n>
[    7.667412] pci 0001:00:00.0:   bridge window [io  0x1000-0x1fff]<\r><\n>
[    7.673708] pci 0001:00:00.0:   bridge window [mem 0x20a8000000-0x20a80fffff]<\r><\n>
[    7.681113] pci 0001:00:00.0: Max Payload Size set to  128/ 256 (was  256), Max Read Rq  512<\r><\n>
[    7.689901] pci 0001:01:00.0: Max Payload Size set to  128/ 128 (was  128), Max Read Rq  512<\r><\n>
[    7.699010] pcieport 0001:00:00.0: Adding to iommu group 8<\r><\n>
[    7.705029] pcieport 0001:00:00.0: PME: Signaling with IRQ 55<\r><\n>
[    7.710987] usb 1-2: New USB device found, idVendor=0bda, idProduct=5489, bcdDevice= 1.40<\r><\n>
[    7.711630] pcieport 0001:00:00.0: AER: enabled with IRQ 55<\r><\n>
[    7.719413] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0<\r><\n>
[    7.726338] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator<\r><\n>
[    7.732470] usb 1-2: Product: 4-Port USB 2.0 Hub<\r><\n>
[    7.732472] usb 1-2: Manufacturer: Generic<\r><\n>
[    7.748600] hub 1-2:1.0: USB hub found<\r><\n>
[    7.749591] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:<\r><\n>
[    7.759668] hub 1-2:1.0: 4 ports detected<\r><\n>
[    7.759673] tegra194-pcie 14160000.pcie:       IO 0x0036100000..0x00361fffff -> 0x0036100000<\r><\n>
[    7.759683] tegra194-pcie 14160000.pcie:      MEM 0x2428000000..0x242fffffff -> 0x0040000000<\r><\n>
[    7.781201] tegra194-pcie 14160000.pcie:      MEM 0x2140000000..0x2427ffffff -> 0x2140000000<\r><\n>
[    7.812020] usb 2-1: new SuperSpeedPlus Gen 2 USB device number 2 using tegra-xusb<\r><\n>
[    7.858771] usb 2-1: New USB device found, idVendor=0bda, idProduct=0489, bcdDevice= 1.40<\r><\n>
[    7.867189] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0<\r><\n>
[    7.874542] usb 2-1: Product: 4-Port USB 3.0 Hub<\r><\n>
[    7.879288] usb 2-1: Manufacturer: Generic<\r><\n>
[    7.892720] hub 2-1:1.0: USB hub found<\r><\n>
[    7.898256] hub 2-1:1.0: 4 ports detected<\r><\n>
[    7.975124] usb 1-3: new full-speed USB device number 3 using tegra-xusb<\r><\n>
[    8.132967] usb 1-3: New USB device found, idVendor=13d3, idProduct=3549, bcdDevice= 0.00<\r><\n>
[    8.141384] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3<\r><\n>
[    8.148724] usb 1-3: Product: Bluetooth Radio<\r><\n>
[    8.153200] usb 1-3: Manufacturer: Realtek<\r><\n>
[    8.157406] usb 1-3: SerialNumber: 00e04c000001<\r><\n>
[    8.515128] usb 1-2.2: new high-speed USB device number 4 using tegra-xusb<\r><\n>
[    8.629445] usb 1-2.2: New USB device found, idVendor=2109, idProduct=2817, bcdDevice=90.23<\r><\n>
[    8.638033] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0<\r><\n>
[    8.645578] usb 1-2.2: Product: USB2.0 Hub             <\r><\n>
[    8.650959] usb 1-2.2: Manufacturer: VIA Labs, Inc.         <\r><\n>
[    8.659221] hub 1-2.2:1.0: USB hub found<\r><\n>
[    8.663818] hub 1-2.2:1.0: 4 ports detected<\r><\n>
[    8.731439] usb 2-1.2: new SuperSpeed Gen 1 USB device number 3 using tegra-xusb<\r><\n>
[    8.803934] usb 2-1.2: New USB device found, idVendor=2109, idProduct=0817, bcdDevice=90.23<\r><\n>
[    8.812552] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0<\r><\n>
[    8.820084] usb 2-1.2: Product: USB3.0 Hub             <\r><\n>
[    8.825472] usb 2-1.2: Manufacturer: VIA Labs, Inc.         <\r><\n>
[    8.835044] hub 2-1.2:1.0: USB hub found<\r><\n>
[    8.839481] hub 2-1.2:1.0: 4 ports detected<\r><\n>
[    8.895613] tegra194-pcie 14160000.pcie: Phy link never came up<\r><\n>
[    8.901788] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00<\r><\n>
[    8.908593] pci_bus 0004:00: root bus resource [bus 00-ff]<\r><\n>
[    8.914231] pci_bus 0004:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])<\r><\n>
[    8.924332] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])<\r><\n>
[    8.935159] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]<\r><\n>
[    8.943076] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400<\r><\n>
[    8.949422] pci 0004:00:00.0: PME# supported from D0 D3hot<\r><\n>
[    8.964891] pci 0004:00:00.0: PCI bridge to [bus 01-ff]<\r><\n>
[    8.970287] pci 0004:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512<\r><\n>
[    8.979374] pcieport 0004:00:00.0: Adding to iommu group 9<\r><\n>
[    8.985317] pcieport 0004:00:00.0: PME: Signaling with IRQ 57<\r><\n>
[    8.991888] pcieport 0004:00:00.0: AER: enabled with IRQ 57<\r><\n>
[    8.997952] pci_bus 0004:01: busn_res: [bus 01-ff] is released<\r><\n>
[    9.004074] pci 0004:00:00.0: Removing from iommu group 9<\r><\n>
[    9.009638] pci_bus 0004:00: busn_res: [bus 00-ff] is released<\r><\n>
[    9.017516] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator<\r><\n>
[    9.025462] tegra194-pcie 141e0000.pcie: host bridge /pcie@141e0000 ranges:<\r><\n>
[    9.032642] tegra194-pcie 141e0000.pcie:       IO 0x003e100000..0x003e1fffff -> 0x003e100000<\r><\n>
[    9.041341] tegra194-pcie 141e0000.pcie:      MEM 0x3228000000..0x322fffffff -> 0x0040000000<\r><\n>
[    9.050024] tegra194-pcie 141e0000.pcie:      MEM 0x2e40000000..0x3227ffffff -> 0x2e40000000<\r><\n>
[    9.391117] usb 1-2.2.1: new high-speed USB device number 5 using tegra-xusb<\r><\n>
[    9.552732] usb 1-2.2.1: New USB device found, idVendor=2109, idProduct=2817, bcdDevice=90.23<\r><\n>
[    9.561508] usb 1-2.2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0<\r><\n>
[    9.569210] usb 1-2.2.1: Product: USB2.0 Hub             <\r><\n>
[    9.574767] usb 1-2.2.1: Manufacturer: VIA Labs, Inc.         <\r><\n>
[    9.581897] hub 1-2.2.1:1.0: USB hub found<\r><\n>
[    9.586478] hub 1-2.2.1:1.0: 4 ports detected<\r><\n>
[    9.654260] usb 2-1.2.1: new SuperSpeed Gen 1 USB device number 4 using tegra-xusb<\r><\n>
[    9.720431] usb 2-1.2.1: New USB device found, idVendor=2109, idProduct=0817, bcdDevice=90.23<\r><\n>
[    9.729193] usb 2-1.2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0<\r><\n>
[    9.736883] usb 2-1.2.1: Product: USB3.0 Hub             <\r><\n>
[    9.742426] usb 2-1.2.1: Manufacturer: VIA Labs, Inc.         <\r><\n>
[    9.783112] hub 2-1.2.1:1.0: USB hub found<\r><\n>
[    9.788732] hub 2-1.2.1:1.0: 4 ports detected<\r><\n>
[    9.847116] usb 1-2.2.4: new full-speed USB device number 6 using tegra-xusb<\r><\n>
[   10.013413] usb 1-2.2.4: New USB device found, idVendor=0b95, idProduct=6802, bcdDevice= 0.12<\r><\n>
[   10.022179] usb 1-2.2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3<\r><\n>
[   10.029871] usb 1-2.2.4: Product: AX68002<\r><\n>
[   10.033985] usb 1-2.2.4: Manufacturer:  MTK Electronics<\r><\n>
[   10.039351] usb 1-2.2.4: SerialNumber: 00000001<\r><\n>
[   10.045518] hub 1-2.2.4:1.0: USB hub found<\r><\n>
[   10.051114] hub 1-2.2.4:1.0: 7 ports detected<\r><\n>
[   10.159145] tegra194-pcie 141e0000.pcie: Phy link never came up<\r><\n>
[   10.165309] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00<\r><\n>
[   10.172150] pci_bus 0007:00: root bus resource [bus 00-ff]<\r><\n>
[   10.177810] pci_bus 0007:00: root bus resource [io  0x200000-0x2fffff] (bus address [0x3e100000-0x3e1fffff])<\r><\n>
[   10.187929] pci_bus 0007:00: root bus resource [mem 0x3228000000-0x322fffffff] (bus address [0x40000000-0x47ffffff])<\r><\n>
[   10.198796] pci_bus 0007:00: root bus resource [mem 0x2e40000000-0x3227ffffff pref]<\r><\n>
[   10.206771] pci 0007:00:00.0: [10de:229a] type 01 class 0x060400<\r><\n>
[   10.213118] pci 0007:00:00.0: PME# supported from D0 D3hot<\r><\n>
[   10.228937] pci 0007:00:00.0: PCI bridge to [bus 01-ff]<\r><\n>
[   10.234334] pci 0007:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512<\r><\n>
[   10.243403] pcieport 0007:00:00.0: Adding to iommu group 10<\r><\n>
[   10.249406] pcieport 0007:00:00.0: PME: Signaling with IRQ 59<\r><\n>
[   10.255875] pcieport 0007:00:00.0: AER: enabled with IRQ 59<\r><\n>
[   10.261954] pci_bus 0007:01: busn_res: [bus 01-ff] is released<\r><\n>
[   10.268117] pci 0007:00:00.0: Removing from iommu group 10<\r><\n>
[   10.273797] pci_bus 0007:00: busn_res: [bus 00-ff] is released<\r><\n>
[   10.281729] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator<\r><\n>
[   10.288732] vdd-3v3-sd: supplied by vdd-3v3<\r><\n>
[   10.295187] tegra194-isp5 14800000.isp: initialized<\r><\n>
[   10.303610] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized<\r><\n>
[   10.310086] (NULL device *): fops function table already registered<\r><\n>
[   10.317844] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized<\r><\n>
[   10.325528] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator<\r><\n>
[   10.325532] sdhci-tegra 3400000.sdhci: Got CD GPIO<\r><\n>
[   10.337958] irq: IRQ295: trimming hierarchy from :interrupt-controller@f400000-1<\r><\n>
[   10.339125] usb 1-2.2.1.1: new low-speed USB device number 7 using tegra-xusb<\r><\n>
[   10.350146] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 294<\r><\n>
[   10.451691] tegra194-pcie 140a0000.pcie: host bridge /pcie@140a0000 ranges:<\r><\n>
[   10.458869] tegra194-pcie 140a0000.pcie:       IO 0x002a100000..0x002a1fffff -> 0x002a100000<\r><\n>
[   10.467553] tegra194-pcie 140a0000.pcie:      MEM 0x3528000000..0x352fffffff -> 0x0040000000<\r><\n>
[   10.476240] tegra194-pcie 140a0000.pcie:      MEM 0x3240000000..0x3527ffffff -> 0x3240000000<\r><\n>
[   10.512275] usb 1-2.2.1.1: New USB device found, idVendor=0c45, idProduct=7663, bcdDevice= 0.01<\r><\n>
[   10.521225] usb 1-2.2.1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0<\r><\n>
[   10.529105] usb 1-2.2.1.1: Product: USB Keyboard<\r><\n>
[   10.533847] usb 1-2.2.1.1: Manufacturer: SONiX<\r><\n>
[   10.544292] input: SONiX USB Keyboard as /devices/platform/3610000.xhci/usb1/1-2/1-2.2/1-2.2.1/1-2.2.1.1/1-2.2.1.1:1.0/0003:0C45:7663.0001/input/input0<\r><\n>
[   10.583315] usb 1-2.2.4.6: new full-speed USB device number 8 using tegra-xusb<\r><\n>
[   10.591120] tegra194-pcie 140a0000.pcie: Link up<\r><\n>
[   10.597160] tegra194-pcie 140a0000.pcie: PCI host bridge to bus 0008:00<\r><\n>
[   10.603980] pci_bus 0008:00: root bus resource [bus 00-ff]<\r><\n>
[   10.609617] pci_bus 0008:00: root bus resource [io  0x300000-0x3fffff] (bus address [0x2a100000-0x2a1fffff])<\r><\n>
[   10.619747] pci_bus 0008:00: root bus resource [mem 0x3528000000-0x352fffffff] (bus address [0x40000000-0x47ffffff])<\r><\n>
[   10.619928] hid-generic 0003:0C45:7663.0001: input,hidraw0: USB HID v1.11 Keyboard [SONiX USB Keyboard] on usb-3610000.xhci-2.2.1.1/input0<\r><\n>
[   10.630593] pci_bus 0008:00: root bus resource [mem 0x3240000000-0x3527ffffff pref]<\r><\n>
[   10.651311] pci 0008:00:00.0: [10de:229c] type 01 class 0x060400<\r><\n>
[   10.657657] pci 0008:00:00.0: PME# supported from D0 D3hot<\r><\n>
[   10.657739] input: SONiX USB Keyboard Consumer Control as /devices/platform/3610000.xhci/usb1/1-2/1-2.2/1-2.2.1/1-2.2.1.1/1-2.2.1.1:1.1/0003:0C45:7663.0002/input/input1<\r><\n>
[   10.669030] pci 0008:01:00.0: [10ec:8168] type 00 class 0x020000<\r><\n>
[   10.685088] pci 0008:01:00.0: reg 0x10: [io  0x0000-0x00ff]<\r><\n>
[   10.691003] pci 0008:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]<\r><\n>
[   10.698115] pci 0008:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]<\r><\n>
[   10.706167] pci 0008:01:00.0: supports D1 D2<\r><\n>
[   10.710558] pci 0008:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold<\r><\n>
[   10.722745] pci 0008:00:00.0: BAR 14: assigned [mem 0x3528000000-0x35280fffff]<\r><\n>
[   10.730198] pci 0008:00:00.0: BAR 13: assigned [io  0x300000-0x300fff]<\r><\n>
[   10.736963] pci 0008:01:00.0: BAR 4: assigned [mem 0x3528000000-0x3528003fff 64bit]<\r><\n>
[   10.739736] input: SONiX USB Keyboard System Control as /devices/platform/3610000.xhci/usb1/1-2/1-2.2/1-2.2.1/1-2.2.1.1/1-2.2.1.1:1.1/0003:0C45:7663.0002/input/input2<\r><\n>
[   10.744970] pci 0008:01:00.0: BAR 2: assigned [mem 0x3528004000-0x3528004fff 64bit]<\r><\n>
[   10.760906] hid-generic 0003:0C45:7663.0002: input,hidraw1: USB HID v1.11 Device [SONiX USB Keyboard] on usb-3610000.xhci-2.2.1.1/input1<\r><\n>
[   10.768161] pci 0008:01:00.0: BAR 0: assigned [io  0x300000-0x3000ff]<\r><\n>
[   10.787337] pci 0008:00:00.0: PCI bridge to [bus 01-ff]<\r><\n>
[   10.792734] pci 0008:00:00.0:   bridge window [io  0x300000-0x300fff]<\r><\n>
[   10.792744] usb 1-2.2.4.6: New USB device found, idVendor=0b95, idProduct=6801, bcdDevice= 0.02<\r><\n>
[   10.799370] pci 0008:00:00.0:   bridge window [mem 0x3528000000-0x35280fffff]<\r><\n>
[   10.808283] usb 1-2.2.4.6: New USB device strings: Mfr=1, Product=2, SerialNumber=3<\r><\n>
[   10.808287] usb 1-2.2.4.6: Product: AX68002<\r><\n>
[   10.815626] pci 0008:00:00.0: Max Payload Size set to  128/ 256 (was  256), Max Read Rq  512<\r><\n>
[   10.823467] usb 1-2.2.4.6: Manufacturer: ASIX Electronics<\r><\n>
[   10.823469] usb 1-2.2.4.6: SerialNumber: 00000001<\r><\n>
[   10.846939] pci 0008:01:00.0: Max Payload Size set to  128/ 128 (was  128), Max Read Rq  512<\r><\n>
[   10.856043] pcieport 0008:00:00.0: Adding to iommu group 11<\r><\n>
[   10.862132] pcieport 0008:00:00.0: PME: Signaling with IRQ 61<\r><\n>
[   10.868423] pcieport 0008:00:00.0: AER: enabled with IRQ 61<\r><\n>
[   10.875404] pva 16000000.pva0: deferred probe timeout, ignoring dependency<\r><\n>
[   10.876640] input: ASIX Electronics AX68002 as /devices/platform/3610000.xhci/usb1/1-2/1-2.2/1-2.2.4/1-2.2.4.6/1-2.2.4.6:1.0/0003:0B95:6801.0003/input/input3<\r><\n>
[   10.882496] pva: probe of 16000000.pva0 failed with error -110<\r><\n>
[   10.903088] nvdla 15880000.nvdla0: deferred probe timeout, ignoring dependency<\r><\n>
[   10.910511] nvdla: probe of 15880000.nvdla0 failed with error -110<\r><\n>
[   10.916942] nvdla 158c0000.nvdla1: deferred probe timeout, ignoring dependency<\r><\n>
[   10.924360] nvdla: probe of 158c0000.nvdla1 failed with error -110<\r><\n>
[   10.932401] irq: IRQ297: trimming hierarchy from :pmc@c360000<\r><\n>
[   10.935122] usb 1-2.2.1.4: new low-speed USB device number 9 using tegra-xusb<\r><\n>
[   10.938376] irq: IRQ298: trimming hierarchy from :interrupt-controller@f400000-1<\r><\n>
[   10.953612] input: gpio-keys as /devices/platform/gpio-keys/input/input4<\r><\n>
[   10.956043] hid-generic 0003:0B95:6801.0003: input,hidraw2: USB HID v1.10 Keyboard [ASIX Electronics AX68002] on usb-3610000.xhci-2.2.4.6/input0<\r><\n>
[   10.961853] tegra-se-nvhost 15810000.se: Adding to iommu group 51<\r><\n>
[   10.979607] input: ASIX Electronics AX68002 as /devices/platform/3610000.xhci/usb1/1-2/1-2.2/1-2.2.4/1-2.2.4.6/1-2.2.4.6:1.1/0003:0B95:6801.0004/input/input5<\r><\n>
[   10.980618] tegra-se-nvhost 15810000.se: initialized<\r><\n>
[   10.994769] input: ASIX Electronics AX68002 System Control as /devices/platform/3610000.xhci/usb1/1-2/1-2.2/1-2.2.4/1-2.2.4.6/1-2.2.4.6:1.1/0003:0B95:6801.0004/input/input6<\r><\n>
[   11.009692] tegra-se-nvhost 15810000.se: tegra_se_probe: complete<\r><\n>
[   11.022031] tegra-se-nvhost 15820000.se: Adding to iommu group 52<\r><\n>
[   11.028647] tegra-se-nvhost 15820000.se: initialized<\r><\n>
[   11.034984] tegra-se-nvhost 15820000.se: tegra_se_probe: complete<\r><\n>
[   11.041401] tegra-se-nvhost 15840000.se: Adding to iommu group 53<\r><\n>
[   11.047954] tegra-se-nvhost 15840000.se: initialized<\r><\n>
[   11.054621] tegra-se-nvhost 15840000.se: tegra_se_probe: complete<\r><\n>
[   11.061641] tegra_actmon d230000.actmon: in actmon_register()...<\r><\n>
[   11.067988] tegra_actmon d230000.actmon: bwmgr_disable = 1<\r><\n>
[   11.074043] tegra_actmon d230000.actmon: initialization Completed for the device mc_all<\r><\n>
[   11.075411] input: ASIX Electronics AX68002 Consumer Control as /devices/platform/3610000.xhci/usb1/1-2/1-2.2/1-2.2.4/1-2.2.4.6/1-2.2.4.6:1.1/0003:0B95:6801.0004/input/input7<\r><\n>
[   11.082498] hvc_sysfs: hypervisor is not present<\r><\n>
[   11.098395] hid-generic 0003:0B95:6801.0004: input,hidraw3: USB HID v1.10 Mouse [ASIX Electronics AX68002] on usb-3610000.xhci-2.2.4.6/input1<\r><\n>
[   11.121273] input: ASIX Electronics AX68002 as /devices/platform/3610000.xhci/usb1/1-2/1-2.2/1-2.2.4/1-2.2.4.6/1-2.2.4.6:1.2/0003:0B95:6801.0005/input/input8<\r><\n>
[   11.131977] usb 1-2.2.1.4: New USB device found, idVendor=046d, idProduct=c077, bcdDevice=72.00<\r><\n>
[   11.135921] hid-generic 0003:0B95:6801.0005: input,hidraw4: USB HID v1.10 Mouse [ASIX Electronics AX68002] on usb-3610000.xhci-2.2.4.6/input2<\r><\n>
[   11.138079] ALSA device list:<\r><\n>
[   11.138083]   No soundcards found.<\r><\n>
[   11.144700] usb 1-2.2.1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0<\r><\n>
[   11.144704] usb 1-2.2.1.4: Product: USB Optical Mouse<\r><\n>
[   11.177353] usb 1-2.2.1.4: Manufacturer: Logitech<\r><\n>
[   11.183126] Freeing unused kernel memory: 3968K<\r><\n>
[   11.187860] Run /init as init process<\r><\n>
[   11.193692] input: Logitech USB Optical Mouse as /devices/platform/3610000.xhci/usb1/1-2/1-2.2/1-2.2.1/1-2.2.1.4/1-2.2.1.4:1.0/0003:046D:C077.0006/input/input9<\r><\n>
[   11.208558] hid-generic 0003:046D:C077.0006: input,hidraw5: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-3610000.xhci-2.2.1.4/input0<\r><\n>
[   11.209629] Root device found: mmcblk1p1<\r><\n>
[   11.400378] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit<\r><\n>
[   11.807314] mmc1: new ultra high speed SDR104 SDXC card at address 59b4<\r><\n>
[   11.814588] mmcblk1: mmc1:59b4 EE4S5 239 GiB <\r><\n>
[   11.960193]  mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14<\r><\n>
[   12.040109] Found dev node: /dev/mmcblk1p1<\r><\n>
[   12.220534] EXT4-fs (mmcblk1p1): warning: mounting fs with errors, running e2fsck is recommended<\r><\n>
[   12.235019] EXT4-fs (mmcblk1p1): recovery complete<\r><\n>
[   12.241738] EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Opts: (null)<\r><\n>
[   12.251596] Rootfs mounted over mmcblk1p1<\r><\n>
[   12.414564] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #391682: comm cp: iget: checksum invalid<\r><\n>
[   12.427463] Switching from initrd to actual rootfs<\r><\n>
[   12.682268] systemd[1]: System time before build time, advancing clock.<\r><\n>
[   12.846461] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #391682: comm systemd: iget: checksum invalid<\r><\n>
[   12.892379] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #926177: comm systemd: iget: checksum invalid<\r><\n>
[   12.907961] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #926177: comm systemd: iget: checksum invalid<\r><\n>
[   13.063105] ip_tables: Unknown symbol xt_compat_unlock (err -2)<\r><\n>
[   13.069222] ip_tables: Unknown symbol xt_free_table_info (err -2)<\r><\n>
[   13.075517] ip_tables: Unknown symbol xt_match_to_user (err -2)<\r><\n>
[   13.081606] ip_tables: Unknown symbol xt_alloc_table_info (err -2)<\r><\n>
[   13.087978] ip_tables: Unknown symbol xt_percpu_counter_free (err -2)<\r><\n>
[   13.094607] ip_tables: Unknown symbol xt_check_table_hooks (err -2)<\r><\n>
[   13.101065] ip_tables: Unknown symbol xt_find_jump_offset (err -2)<\r><\n>
[   13.107433] ip_tables: Unknown symbol xt_check_match (err -2)<\r><\n>
[   13.113345] ip_tables: Unknown symbol xt_compat_match_from_user (err -2)<\r><\n>
[   13.120243] ip_tables: Unknown symbol xt_request_find_target (err -2)<\r><\n>
[   13.126897] ip_tables: Unknown symbol xt_unregister_matches (err -2)<\r><\n>
[   13.133453] ip_tables: Unknown symbol xt_request_find_table_lock (err -2)<\r><\n>
[   13.140450] ip_tables: Unknown symbol xt_request_find_match (err -2)<\r><\n>
[   13.146993] ip_tables: Unknown symbol xt_tee_enabled (err -2)<\r><\n>
[   13.152911] ip_tables: Unknown symbol xt_compat_add_offset (err -2)<\r><\n>
[   13.159346] ip_tables: Unknown symbol xt_compat_init_offsets (err -2)<\r><\n>
[   13.165987] ip_tables: Unknown symbol xt_unregister_targets (err -2)<\r><\n>
[   13.172542] ip_tables: Unknown symbol xt_recseq (err -2)<\r><\n>
[   13.178008] ip_tables: Unknown symbol xt_compat_calc_jump (err -2)<\r><\n>
[   13.184360] ip_tables: Unknown symbol xt_compat_flush_offsets (err -2)<\r><\n>
[   13.191083] ip_tables: Unknown symbol xt_compat_target_from_user (err -2)<\r><\n>
[   13.198062] ip_tables: Unknown symbol xt_register_targets (err -2)<\r><\n>
[   13.204432] ip_tables: Unknown symbol xt_compat_check_entry_offsets (err -2)<\r><\n>
[   13.211720] ip_tables: Unknown symbol xt_compat_match_to_user (err -2)<\r><\n>
[   13.218446] ip_tables: Unknown symbol xt_alloc_entry_offsets (err -2)<\r><\n>
[   13.225077] ip_tables: Unknown symbol xt_target_to_user (err -2)<\r><\n>
[   13.231252] ip_tables: Unknown symbol xt_copy_counters (err -2)<\r><\n>
[   13.237338] ip_tables: Unknown symbol xt_register_table (err -2)<\r><\n>
[   13.243530] ip_tables: Unknown symbol xt_proto_init (err -2)<\r><\n>
[   13.249350] ip_tables: Unknown symbol xt_replace_table (err -2)<\r><\n>
[   13.255437] ip_tables: Unknown symbol xt_find_table_lock (err -2)<\r><\n>
[   13.261714] ip_tables: Unknown symbol xt_counters_alloc (err -2)<\r><\n>
[   13.267887] ip_tables: Unknown symbol xt_compat_target_offset (err -2)<\r><\n>
[   13.274612] ip_tables: Unknown symbol xt_table_unlock (err -2)<\r><\n>
[   13.280609] ip_tables: Unknown symbol xt_proto_fini (err -2)<\r><\n>
[   13.286442] ip_tables: Unknown symbol xt_check_entry_offsets (err -2)<\r><\n>
[   13.293076] ip_tables: Unknown symbol xt_compat_target_to_user (err -2)<\r><\n>
[   13.299884] ip_tables: Unknown symbol xt_percpu_counter_alloc (err -2)<\r><\n>
[   13.306586] ip_tables: Unknown symbol xt_compat_match_offset (err -2)<\r><\n>
[   13.313236] ip_tables: Unknown symbol xt_register_matches (err -2)<\r><\n>
[   13.319600] ip_tables: Unknown symbol xt_check_target (err -2)<\r><\n>
[   13.325600] ip_tables: Unknown symbol xt_find_revision (err -2)<\r><\n>
[   13.331684] ip_tables: Unknown symbol xt_compat_lock (err -2)<\r><\n>
[   13.337588] ip_tables: Unknown symbol xt_unregister_table (err -2)<\r><\n>
[   13.359492] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #391682: comm systemd: iget: checksum invalid<\r><\n>
[   13.508909] systemd[1]: Failed to determine whether /run is a mount point: Bad message<\r><\n>
[   13.517109] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #391682: comm systemd: iget: checksum invalid<\r><\n>
[   13.672481] systemd[1]: Failed to determine whether /run/lock is a mount point: Bad message<\r><\n>
[   13.848711] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #391682: comm modprobe: iget: checksum invalid<\r><\n>
[   13.883170] systemd[1]: Freezing execution.<\r><\n>
<\0><\0>
Looks like the file system has some corruption. What “work” did you do there?
I may need to reproduce this issue on our side. Also, have you tried other sdcard?
Well, I did nothing special. Some programming. Thus file edits and compilations.
I work with two USB cameras that are pluged in and out so now and then.
I will try a new SD card. But it can take a few days before it happens again (if it happends again)
Did you have some reboot test on your side? For example, rebooting the device many times.
Or will the usb camera frequently write data to sdcard?
Yes I reboot so now and then.
Normally no camera data is written to sdcard. But some camera tools may have done this while I was not aware of it. Because I discovered a (small) video file of one of the cameras at some time.
Sorry, I just want to clarify this. I mean did you reboot many frequently when the board is still alive?
I did boot so now and then after installing software. So board was ok at that time. Is that what you mean?
And I remember now that I also had a system hang. Probably the boot problem occured after that.
But I did nothing special at that time.
I have a switch between the monitor, mouse and keyboard to switch monitor, mouse and keyboard between the Jetson or a Windows PC. And I switch many times. Could that result in such problems?
No, I don’t think that would hit such issue.
Actually we have some other vendors that will test boot stress test, which means they will keep doing rebooting for maybe 2000 times. I was trying to ask did you do similar things or not. But it sounds not.
I noticed some missing kernel symbols. This could be because of the filesystem corruption (part of the kernel or a kernel module could now be missing). So some questions:
  • Are you shutting the Jetson down normally?
  • The symbols are probably from netfilter x_tables.c; have you built your own custom kernel and added netfilter?
  • What is the output of “uname -r”?
Yes, I always shut down using the Power Off menu.
No we did not build our own cursom kernel. I do not know what netfilter is.
The output of ‘uname -r’ of the current situation (completely new flashed SD and reinstalled all software) is:
5.10.104-tegra
The implication is that at least one kernel module has been corrupted from the filesystem issues. netfilter is a network firewall application and related kernel driver. It is quite possible that the failures are from filesystem issues and not hardware.
I’m going to suggest flash the system again, although you could first clone if you have something valuable. The clone itself would be corrupt, but so far as we know, only the system content is “bad”. Anything which was writing at the time of filesystem corruption would also be truncated, but chances are much of your filesystem is still useful. This might not fix anything, but considering you have at least one kernel module failing to load (one which you did not modify), the implication is that you cannot reliably test until that is fixed.
Somewhere along the course of your testing or operation either (A) the system locked up and power was used to restart, or (B) something caused improper shutdown at least once.
I flashed a new card, installed all software again and continued working.
But I got the same problem again after a few days. This is the (first part of) serial dump:
<\0><\0>ÿâ<\r>
<\n>[0000.062] I> MB1 (version: 0.32.0.0-t234-54845784-57325615)<\r>
<\n>[0000.067] I> t234-A01-1-Silicon (0x12347) Prod<\r>
<\n>[0000.071] I> Boot-mode : Coldboot<\r>
<\n>[0000.074] I> Emulation: <\r>
<\n>[0000.077] I> Entry timestamp: 0x00000000<\r>
<\n>[0000.081] I> last_boot_error: 0x0<\r>
<\n>[0000.084] I> BR-BCT: preprod_dev_sign: 0<\r>
<\n>[0000.087] I> rst_source: 0x0, rst_level: 0x0<\r>
<\n>[0000.092] I> Task: Bootchain select WAR set (0x5000ba65)<\r>
<\n>[0000.097] I> Task: Enable SLCG (0x5000bab1)<\r>
<\n>[0000.101] I> Task: CRC check (0x5001ea19)<\r>
<\n>[0000.105] I> Task: Initialize MB2 params (0x5000cb51)<\r>
<\n>[0000.110] I> MB2-params @ 0x40060000<\r>
<\n>[0000.114] I> Task: Crypto init (0x5001d981)<\r>
<\n>[0000.118] I> Task: Secure debug controls (0x5000c0a9)<\r>
<\n>[0000.123] I> Task: strap war set (0x5000ba2d)<\r>
<\n>[0000.127] I> Task: Initialize SOC Therm (0x5001bd35)<\r>
<\n>[0000.132] I> Task: Program NV master stream id (0x5000c05d)<\r>
<\n>[0000.137] I> Task: Verify boot mode (0xd4820f1)<\r>
<\n>[0000.143] I> Task: Alias fuses (0x5001095d)<\r>
<\n>[0000.147] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.<\r>
<\n>[0000.155] I> Task: Print SKU type (0x5000f5f1)<\r>
<\n>[0000.159] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c8<\r>
<\n>[0000.164] I> FUSE_OPT_GPC_DISABLE = 0x00000002<\r>
<\n>[0000.168] I> FUSE_OPT_TPC_DISABLE = 0x000000f0<\r>
<\n>[0000.173] I> FUSE_OPT_DLA_DISABLE = 0x00000003<\r>
<\n>[0000.177] I> FUSE_OPT_PVA_DISABLE = 0x00000001<\r>
<\n>[0000.181] I> FUSE_OPT_NVENC_DISABLE = 0x00000001<\r>
<\n>[0000.186] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000<\r>
<\n>[0000.190] I> FUSE_OPT_FSI_DISABLE = 0x00000001<\r>
<\n>[0000.194] I> FUSE_OPT_EMC_DISABLE = 0x0000000c<\r>
<\n>[0000.199] I> FUSE_BOOTROM_PATCH_VERSION = 0x7<\r>
<\n>[0000.203] I> FUSE_PSCROM_PATCH_VERSION = 0x7<\r>
<\n>[0000.207] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2<\r>
<\n>[0000.211] I> FUSE_SKU_INFO_0 = 0xd5<\r>
<\n>[0000.214] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS <\r>
<\n>[0000.218] I> FUSE_PACKAGE_INFO_0 = 0x2<\r>
<\n>[0000.222] I> SKU: Prod<\r>
<\n>[0000.224] I> Task: Boost clocks (0x500148a1)<\r>
<\n>[0000.228] I> Initializing PLLC2 for AXI_CBB.<\r>
<\n>[0000.232] I> AXI_CBB : src = 35, divisor = 0<\r>
<\n>[0000.237] I> Task: Voltage monitor (0x50014b49)<\r>
<\n>[0000.241] I> VMON: Vmon re-calibration and fine tuning done<\r>
<\n>[0000.246] I> Task: UPHY init (0x5000d065)<\r>
<\n>[0000.252] I> HSIO UPHY init done<\r>
<\n>[0000.255] E> Skipping GBE UPHY config<\r>
<\n>[0000.259] I> Task: Boot device init (0x50000be9)<\r>
<\n>[0000.263] I> Boot_device: QSPI_FLASH instance: 0<\r>
<\n>[0000.268] I> Qspi clock source : pllc_out0<\r>
<\n>[0000.272] I> QSPI Flash: Macronix 64MB<\r>
<\n>[0000.276] I> QSPI-0l initialized successfully<\r>
<\n>[0000.280] I> Task: TSC init (0x50020a4d)<\r>
<\n>[0000.284] I> Task: Load membct (0x50011fe9)<\r>
<\n>[0000.288] I> RAM_CODE 0x4000421<\r>
<\n>[0000.291] I> Loading MEMBCT <\r>
<\n>[0000.294] I> Slot: 0<\r>
<\n>[0000.296] I> Binary[0] block-0 (partition size: 0x40000)<\r>
<\n>[0000.301] I>  get_binary_info: Binary name: MEM-BCT-0<\r>
<\n>[0000.306] I> Size of crypto header is 8192<\r>
<\n>[0000.310] I> BCH load address is : 0x40050000<\r>
<\n>[0000.314] I> Size of crypto header is 8192<\r>
<\n>[0000.318] I> BCH of MEM-BCT-0 read from storage<\r>
<\n>[0000.322] I> BCH address is : 0x40050000<\r>
<\n>[0000.326] I> MEM-BCT-0 header integrity check is success<\r>
<\n>[0000.331] I> Binary magic in BCH component 0 is MEM0<\r>
<\n>[0000.336] I> component binary type is 0<\r>
<\n>[0000.341] I> MEM-BCT-0 binary is read from storage<\r>
<\n>[0000.345] I> MEM-BCT-0 binary integrity check is success<\r>
<\n>[0000.351] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)<\r>
<\n>[0000.357] I> RAM_CODE 0x4000421<\r>
<\n>[0000.363] I> RAM_CODE 0x4000421<\r>
<\n>[0000.367] I> Task: Load Page retirement list (0x500115b1)<\r>
<\n>[0000.372] I> Task: SDRAM params override (0x50011fc5)<\r>
<\n>[0000.377] I> Task: Save mem-bct info (0x50014fa1)<\r>
<\n>[0000.381] I> Task: Carveout allocate (0x50015005)<\r>
<\n>[0000.386] I> RCM blob carveout will not be allocated<\r>
<\n>[0000.391] I> ECC region[0]: Start:0x0, End:0x0<\r>
<\n>[0000.395] I> ECC region[1]: Start:0x0, End:0x0<\r>
<\n>[0000.399] I> ECC region[2]: Start:0x0, End:0x0<\r>
<\n>[0000.403] I> ECC region[3]: Start:0x0, End:0x0<\r>
<\n>[0000.408] I> ECC region[4]: Start:0x0, End:0x0<\r>
<\n>[0000.412] I> Non-ECC region[0]: Start:0x80000000, End:0x280000000<\r>
<\n>[0000.418] I> Non-ECC region[1]: Start:0x0, End:0x0<\r>
<\n>[0000.423] I> Non-ECC region[2]: Start:0x0, End:0x0<\r>
<\n>[0000.427] I> Non-ECC region[3]: Start:0x0, End:0x0<\r>
<\n>[0000.432] I> Non-ECC region[4]: Start:0x0, End:0x0<\r>
<\n>[0000.441] I> allocated(CO:44) base:0x249800000 size:0x36800000 align: 0x100000<\r>
<\n>[0000.449] I> allocated(CO:31) base:0x240000000 size:0x8000000 align: 0x8000000<\r>
<\n>[0000.456] I> allocated(CO:43) base:0x23c000000 size:0x4000000 align: 0x200000<\r>
<\n>[0000.463] I> allocated(CO:20) base:0x23a000000 size:0x2000000 align: 0x2000000<\r>
<\n>[0000.470] I> allocated(CO:24) base:0x238000000 size:0x2000000 align: 0x2000000<\r>
<\n>[0000.477] I> allocated(CO:28) base:0x236000000 size:0x2000000 align: 0x2000000<\r>
<\n>[0000.484] I> allocated(CO:22) base:0x248000000 size:0x1000000 align: 0x1000000<\r>
<\n>[0000.491] I> allocated(CO:35) base:0x235200000 size:0xe00000 align: 0x10000<\r>
<\n>[0000.498] I> allocated(CO:02) base:0x249000000 size:0x800000 align: 0x800000<\r>
<\n>[0000.505] I> allocated(CO:03) base:0x234800000 size:0x800000 align: 0x800000<\r>
<\n>[0000.512] I> allocated(CO:06) base:0x234000000 size:0x800000 align: 0x800000<\r>
<\n>[0000.519] I> allocated(CO:10) base:0x233800000 size:0x800000 align: 0x800000<\r>
<\n>[0000.526] I> allocated(CO:56) base:0x233000000 size:0x800000 align: 0x200000<\r>
<\n>[0000.533] I> allocated(CO:07) base:0x232c00000 size:0x400000 align: 0x400000<\r>
<\n>[0000.539] I> allocated(CO:33) base:0x232800000 size:0x400000 align: 0x200000<\r>
<\n>[0000.546] I> allocated(CO:23) base:0x235000000 size:0x200000 align: 0x200000<\r>
<\n>[0000.553] I> allocated(CO:01) base:0x232700000 size:0x100000 align: 0x100000<\r>
<\n>[0000.560] I> allocated(CO:04) base:0x232600000 size:0x100000 align: 0x100000<\r>
<\n>[0000.567] I> allocated(CO:05) base:0x232500000 size:0x100000 align: 0x100000<\r>
<\n>[0000.574] I> allocated(CO:08) base:0x232400000 size:0x100000 align: 0x100000<\r>
<\n>[0000.581] I> allocated(CO:09) base:0x232300000 size:0x100000 align: 0x100000<\r>
<\n>[0000.588] I> allocated(CO:15) base:0x232200000 size:0x100000 align: 0x100000<\r>
<\n>[0000.595] I> allocated(CO:17) base:0x232100000 size:0x100000 align: 0x100000<\r>
<\n>[0000.602] I> allocated(CO:27) base:0x232000000 size:0x100000 align: 0x100000<\r>
<\n>[0000.609] I> allocated(CO:42) base:0x231f00000 size:0x100000 align: 0x100000<\r>
<\n>[0000.616] I> allocated(CO:54) base:0x231e80000 size:0x80000 align: 0x80000<\r>
<\n>[0000.622] I> allocated(CO:34) base:0x231e70000 size:0x10000 align: 0x10000<\r>
<\n>[0000.629] I> allocated(CO:47) base:0x231a00000 size:0x400000 align: 0x200000<\r>
<\n>[0000.636] I> allocated(CO:72) base:0x231800000 size:0x200000 align: 0x10000<\r>
<\n>[0000.643] I> allocated(CO:48) base:0x231e50000 size:0x20000 align: 0x10000<\r>
<\n>[0000.650] I> allocated(CO:69) base:0x231e30000 size:0x20000 align: 0x10000<\r>
<\n>[0000.656] I> allocated(CO:49) base:0x231e20000 size:0x10000 align: 0x10000<\r>
<\n>[0000.663] I> allocated(CO:50) base:0x231e10000 size:0x10000 align: 0x10000<\r>
<\n>[0000.670] I> NSDRAM base: 0x80000000, end: 0x231e70000<\r>
<\n>[0000.675] I> Task: Thermal check (0x50021d55)<\r>
<\n>[0000.679] I> max_chip_limit = 105<\r>
<\n>[0000.682] I> min_chip_limit = -28<\r>
<\n>[0000.685] I> max temp read = 21<\r>
<\n>[0000.688] I> min temp read = 19<\r>
<\n>[0000.691] I> Task: Update FSI SCR with thermal fuse data (0x50021e61)<\r>
<\n>[0000.698] I> Task: Enable WDT 5th expiry (0x50021a41)<\r>
<\n>[0000.702] I> Task: I2C register (0x50000b85)<\r>
<\n>[0000.707] I> Task: Reset FSI (0x500148b1)<\r>
<\n>[0000.710] I> Task: Pinmux init (0x5001397d)<\r>
<\n>[0000.715] I> skipped mmio_addr = 0x9240008<\r>
<\n>[0000.719] I> skipped mmio_addr = 0x9240000<\r>
<\n>[0000.723] I> skipped mmio_addr = 0x9240010<\r>
<\n>[0000.727] I> skipped mmio_addr = 0x9240018<\r>
<\n>[0000.730] I> skipped mmio_addr = 0x9240020<\r>
<\n>[0000.734] I> skipped mmio_addr = 0x9240030<\r>
<\n>[0000.738] I> skipped mmio_addr = 0x9240028<\r>
<\n>[0000.742] I> skipped mmio_addr = 0x9240038<\r>
<\n>[0000.746] I> skipped mmio_addr = 0x9240040<\r>
<\n>[0000.750] I> skipped mmio_addr = 0x9240048<\r>
<\n>[0000.754] I> skipped mmio_addr = 0x9241000<\r>
<\n>[0000.758] I> skipped mmio_addr = 0x9241008<\r>
<\n>[0000.762] I> skipped mmio_addr = 0x9241010<\r>
<\n>[0000.766] I> skipped mmio_addr = 0x9241018<\r>
<\n>[0000.770] I> skipped mmio_addr = 0x9241020<\r>
<\n>[0000.774] I> skipped mmio_addr = 0x9241028<\r>
<\n>[0000.778] I> skipped mmio_addr = 0x9241030<\r>
<\n>[0000.782] I> skipped mmio_addr = 0x9241038<\r>
<\n>[0000.785] I> skipped mmio_addr = 0x9241040<\r>
<\n>[0000.789] I> skipped mmio_addr = 0x9242000<\r>
<\n>[0000.793] I> skipped mmio_addr = 0x9242008<\r>
<\n>[0000.797] I> Task: Prod config init (0x50013ddd)<\r>
<\n>[0000.802] I> Task: Pad voltage init (0x50013a2d)<\r>
<\n>[0000.806] I> Task: Prod init (0x50013e21)<\r>
<\n>[0000.810] I> Task: Common rail init (0x50014575)<\r>
<\n>[0000.815] I> DONE: Thermal config<\r>
<\n>[0000.819] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.<\r>
<\n>[0000.827] I> DONE: SOC rail config<\r>
<\n>[0000.831] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.<\r>
<\n>[0000.837] I> DONE: MEMIO rail config<\r>
<\n>[0000.841] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.<\r>
<\n>[0000.847] I> DONE: GPU rail info<\r>
<\n>[0000.851] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.<\r>
<\n>[0000.857] I> DONE: CV rail info<\r>
<\n>[0000.860] I> Task: Mem clock src (0x50011de9)<\r>
<\n>[0000.864] I> Task: Misc. board config (0x5001461d)<\r>
<\n>[0000.869] W> PMIC_CONFIG: Platform config not found in MB1 BCT.<\r>
<\n>[0000.875] I> Task: SDRAM init (0x50011ded)<\r>
<\n>[0000.879] I> SDRAM-params @ 0xd485000<\r>
<\n>[0000.882] I> MemoryType: 4 MemBctRevision: 1<\r>
<\n>[0000.889] I> MSS code-drop: NvBootSdramInit<\r>
<\n>[0000.893] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 1<\r>
<\n>[0000.900] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 1<\r>
<\n>[0000.908] I> MSS CAR: Init PLLM<\r>
<\n>[0000.911] I> MSS CAR: Init PLLHUB<\r>
<\n>[0000.916] I> Encryption:   MTS: en, TX: en, VPR: en, GSC: en<\r>
<\n>[0000.927] I> mb1_sdram_init Done !<\r>
<\n>[0000.930] I> SDRAM Size in Total 0x200000000<\r>
<\n>[0000.934] I> Task: Dram Ecc scrub (0x500116f5)<\r>
<\n>[0000.938] I> Task: DRAM alias check (0x50011fbd)<\r>
<\n>[0000.950] I> Task: Program NSDRAM carveout (0x50015961)<\r>
<\n>[0000.956] I> NSDRAM carveout encryption is enabled<\r>
<\n>[0000.961] I> Program NSDRAM carveout<\r>
<\n>[0000.965] I> Task: Register checker (0x50011fc1)<\r>
<\n>[0000.972] I> Task: Enable clock-mon (0x50020a35)<\r>
<\n>[0000.979] I> FMON: Fmon re-programming done<\r>
<\n>[0000.983] I> Task: Mapper init (0x5001ef4d)<\r>
<\n>[0000.988] I> Task: SC7 Context Init (0x50020d3d)<\r>
<\n>[0000.994] I> Task: CCPLEX IST init (0x5000c925)<\r>
<\n>[0001.000] I> Task: CPU WP0 (0x5000bb15)<\r>
<\n>[0001.005] I> Loading MCE<\r>
<\n>[0001.008] I> Slot: 0<\r>
<\n>[0001.010] I> Binary[8] block-0 (partition size: 0x80000)<\r>
<\n>[0001.016] I>  get_binary_info: Binary name: MCE<\r>
<\n>[0001.021] I> Size of crypto header is 8192<\r>
<\n>[0001.026] I> BCH load address is : 0x4003e000<\r>
<\n>[0001.031] I> Size of crypto header is 8192<\r>
<\n>[0001.036] I> BCH of MCE read from storage<\r>
<\n>[0001.040] I> BCH address is : 0x4003e000<\r>
<\n>[0001.045] I> MCE header integrity check is success<\r>
<\n>[0001.050] I> Binary magic in BCH component 0 is MTSM<\r>
<\n>[0001.056] I> component binary type is 8<\r>
<\n>[0001.060] I> Size of crypto header is 8192<\r>
<\n>[0001.066] I> MCE binary is read from storage<\r>
<\n>[0001.072] I> MCE binary integrity check is success<\r>
<\n>[0001.077] I> Binary MCE loaded successfully at 0x40000000 (0x2c880)<\r>
<\n>[0001.084] I> Size of crypto header is 8192<\r>
<\n>[0001.099] I> Size of crypto header is 8192<\r>
<\n>[0001.103] I> Sending WP0 mailbox command to PSC<\r>
<\n>[0001.115] I> Task: XUSB Powergate (0x50000b91)<\r>
<\n>[0001.120] I> Skipping powergate XUSB.<\r>
<\n>[0001.124] I> Task: MB1 fixed firewalls (0x5002006d)<\r>
<\n>[0001.135] W> Firewall readback mismatch<\r>
<\n>[0001.139] W> Firewall readback mismatch<\r>
<\n>[0001.148] W> Firewall readback mismatch<\r>
<\n>[0001.158] I> Task: Load bpmp-fw (0x500203c9)<\r>
<\n>[0001.163] I> Slot: 0<\r>
<\n>[0001.165] I> Binary[15] block-0 (partition size: 0x180000)<\r>
<\n>[0001.172] I>  get_binary_info: Binary name: BPMP_FW<\r>
<\n>[0001.177] I> Size of crypto header is 8192<\r>
<\n>[0001.181] I> BCH load address is : 0x807fe000<\r>
<\n>[0001.187] I> Size of crypto header is 8192<\r>
<\n>[0001.192] I> BCH of BPMP_FW read from storage<\r>
<\n>[0001.196] I> BCH address is : 0x807fe000<\r>
<\n>[0001.201] I> BPMP_FW header integrity check is success<\r>
<\n>[0001.207] I> Binary magic in BCH component 0 is BPMF<\r>
<\n>[0001.212] I> component binary type is 15<\r>
<\n>[0001.216] I> Size of crypto header is 8192<\r>
<\n>[0001.232] I> BPMP_FW binary is read from storage<\r>
<\n>[0001.239] I> BPMP_FW binary integrity check is success<\r>
<\n>[0001.244] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xfdd80)<\r>
<\n>[0001.252] I> Slot: 0<\r>
<\n>[0001.255] I> Binary[16] block-10000 (partition size: 0x400000)<\r>
<\n>[0001.262] I>  get_binary_info: Binary name: BPMP_FW_DTB<\r>
<\n>[0001.267] I> Size of crypto header is 8192<\r>
<\n>[0001.272] I> BCH load address is : 0x807fc000<\r>
<\n>[0001.277] I> Size of crypto header is 8192<\r>
<\n>[0001.282] I> BCH of BPMP_FW_DTB read from storage<\r>
<\n>[0001.287] I> BCH address is : 0x807fc000<\r>
<\n>[0001.292] I> BPMP_FW_DTB header integrity check is success<\r>
<\n>[0001.298] I> Binary magic in BCH component 0 is BPMD<\r>
<\n>[0001.303] I> component binary type is 16<\r>
<\n>[0001.307] I> Size of crypto header is 8192<\r>
<\n>[0001.313] I> BPMP_FW_DTB binary is read from storage<\r>
<\n>[0001.319] I> BPMP_FW_DTB binary integrity check is success<\r>
<\n>[0001.325] I> Binary BPMP_FW_DTB loaded successfully at 0x807e31f0 (0x18e00)<\r>
<\n>[0001.334] I> Task: Load psc-fw (0x50020551)<\r>
<\n>[0001.339] I> Slot: 0<\r>
<\n>[0001.342] I> Binary[17] block-0 (partition size: 0xc0000)<\r>
<\n>[0001.348] I>  get_binary_info: Binary name: PSC_FW<\r>
<\n>[0001.353] I> Size of crypto header is 8192<\r>
<\n>[0001.357] I> BCH load address is : 0x80ffe000<\r>
<\n>[0001.363] I> Size of crypto header is 8192<\r>
<\n>[0001.367] I> BCH of PSC_FW read from storage<\r>
<\n>[0001.372] I> BCH address is : 0x80ffe000<\r>
<\n>[0001.377] I> PSC_FW header integrity check is success<\r>
<\n>[0001.383] I> Binary magic in BCH component 0 is PFWP<\r>
<\n>[0001.388] I> component binary type is 17<\r>
<\n>[0001.392] I> Size of crypto header is 8192<\r>
<\n>[0001.401] I> PSC_FW binary is read from storage<\r>
<\n>[0001.407] I> PSC_FW binary integrity check is success<\r>
<\n>[0001.412] I> Binary PSC_FW loaded successfully at 0x80000000 (0x59980)<\r>
<\n>[0001.420] I> Task: Load nvdec-fw (0x500205c5)<\r>
<\n>[0001.426] I> Slot: 0<\r>
<\n>[0001.428] I> Binary[7] block-0 (partition size: 0x100000)<\r>
<\n>[0001.434] I>  get_binary_info: Binary name: NVDEC<\r>
<\n>[0001.439] I> Size of crypto header is 8192<\r>
<\n>[0001.444] I> BCH load address is : 0x800fe000<\r>
<\n>[0001.449] I> Size of crypto header is 8192<\r>
<\n>[0001.454] I> BCH of NVDEC read from storage<\r>
<\n>[0001.458] I> BCH address is : 0x800fe000<\r>
<\n>[0001.464] I> NVDEC header integrity check is success<\r>
<\n>[0001.469] I> Binary magic in BCH component 0 is NDEC<\r>
<\n>[0001.474] I> component binary type is 7<\r>
<\n>[0001.478] I> Size of crypto header is 8192<\r>
<\n>[0001.486] I> NVDEC binary is read from storage<\r>
<\n>[0001.492] I> NVDEC binary integrity check is success<\r>
<\n>[0001.497] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)<\r>
<\n>[0001.505] I> Size of crypto header is 8192<\r>
<\n>[0001.523] I> Task: Load tsec-fw (0x5002097d)<\r>
<\n>[0001.528] I> TSEC-FW load support not enabled<\r>
<\n>[0001.532] I> Task: GPIO interrupt map (0x500147b5)<\r>
<\n>[0001.539] I> Task: SC7 context save (0x50020d79)<\r>
<\n>[0001.544] I> Slot: 0<\r>
<\n>[0001.547] I> Binary[27] block-0 (partition size: 0x100000)<\r>
<\n>[0001.553] I>  get_binary_info: Binary name: BR_BCT<\r>
<\n>[0001.558] I> Size of crypto header is 8192<\r>
<\n>[0001.562] I> Size of crypto header is 8192<\r>
<\n>[0001.567] I> BR_BCT binary is read from storage<\r>
<\n>[0001.573] I> BR_BCT binary integrity check is success<\r>
<\n>[0001.578] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)<\r>
<\n>[0001.586] I> Slot: 0<\r>
<\n>[0001.588] I> Binary[13] block-0 (partition size: 0x30000)<\r>
<\n>[0001.594] I>  get_binary_info: Binary name: SC7-FW<\r>
<\n>[0001.599] I> Size of crypto header is 8192<\r>
<\n>[0001.604] I> Size of crypto header is 8192<\r>
<\n>[0001.608] I> BCH load address is : 0xa0002000<\r>
<\n>[0001.613] I> Size of crypto header is 8192<\r>
<\n>[0001.618] I> BCH of SC7-FW read from storage<\r>
<\n>[0001.623] I> BCH address is : 0xa0002000<\r>
<\n>[0001.628] I> SC7-FW header integrity check is success<\r>
<\n>[0001.633] I> Binary magic in BCH component 0 is WB0B<\r>
<\n>[0001.639] I> component binary type is 13<\r>
<\n>[0001.643] I> Size of crypto header is 8192<\r>
<\n>[0001.649] I> SC7-FW binary is read from storage<\r>
<\n>[0001.655] I> SC7-FW binary integrity check is success<\r>
<\n>[0001.660] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x26db0)<\r>
<\n>[0001.668] I> Slot: 0<\r>
<\n>[0001.671] I> Binary[22] block-0 (partition size: 0x30000)<\r>
<\n>[0001.677] I>  get_binary_info: Binary name: PSC_RF<\r>
<\n>[0001.682] I> Size of crypto header is 8192<\r>
<\n>[0001.686] I> Size of crypto header is 8192<\r>
<\n>[0001.691] I> BCH load address is : 0xa002adb0<\r>
<\n>[0001.696] I> Size of crypto header is 8192<\r>
<\n>[0001.701] I> BCH of PSC_RF read from storage<\r>
<\n>[0001.706] I> BCH address is : 0xa002adb0<\r>
<\n>[0001.711] I> PSC_RF header integrity check is success<\r>
<\n>[0001.716] I> Binary magic in BCH component 0 is PSCR<\r>
<\n>[0001.722] I> component binary type is 22<\r>
<\n>[0001.726] I> Size of crypto header is 8192<\r>
<\n>[0001.732] I> PSC_RF binary is read from storage<\r>
<\n>[0001.737] I> PSC_RF binary integrity check is success<\r>
<\n>[0001.742] I> Binary PSC_RF loaded successfully at 0xa002cdb0 (0x1b140)<\r>
<\n>[0001.765] I> Task: Save WP0 payload to SC7 ctx (0x50021725)<\r>
<\n>[0001.772] I> Task: Load MB2rf binary to SC7 ctx (0x500216b9)<\r>
<\n>[0001.779] I> Slot: 0<\r>
<\n>[0001.781] I> Binary[14] block-0 (partition size: 0x20000)<\r>
<\n>[0001.787] I>  get_binary_info: Binary name: MB2_RF<\r>
<\n>[0001.792] I> Size of crypto header is 8192<\r>
<\n>[0001.797] I> Size of crypto header is 8192<\r>
<\n>[0001.801] I> BCH load address is : 0xa00d6a48<\r>
<\n>[0001.807] I> Size of crypto header is 8192<\r>
<\n>[0001.811] I> BCH of MB2_RF read from storage<\r>
<\n>[0001.816] I> BCH address is : 0xa00d6a48<\r>
<\n>[0001.821] I> MB2_RF header integrity check is success<\r>
<\n>[0001.827] I> Binary magic in BCH component 0 is MB2R<\r>
<\n>[0001.832] I> component binary type is 14<\r>
<\n>[0001.836] I> Size of crypto header is 8192<\r>
<\n>[0001.842] I> MB2_RF binary is read from storage<\r>
<\n>[0001.848] I> MB2_RF binary integrity check is success<\r>
<\n>[0001.853] I> Binary MB2_RF loaded successfully at 0xa00d8a48 (0x1bfa0)<\r>
<\n>[0001.861] I> Task: Save Fuse-Bypass data to SC7 ctx (0x50021621)<\r>
<\n>[0001.869] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.<\r>
<\n>[0001.876] I> SC7 context fuse-bypass data is empty<\r>
<\n>[0001.881] I> Task: Save PMIC data to SC7 ctx (0x5002144d)<\r>
<\n>[0001.888] I> Task: Save I2C bus freq data to SC7 ctx (0x500213d9)<\r>
<\n>[0001.895] I> Task: Save SOCTherm data to SC7 ctx (0x50021365)<\r>
<\n>[0001.902] I> Task: Save FMON data to SC7 ctx (0x500212f1)<\r>
<\n>[0001.908] I> Task: Save VMON data to SC7 ctx (0x50021279)<\r>
<\n>[0001.914] I> Task: Save TZDRAM data to SC7 ctx (0x5002178d)<\r>
<\n>[0001.921] I> Task: Save GPIO int data to SC7 ctx (0x50021561)<\r>
<\n>[0001.928] I> Task: Save clock data to SC7 ctx (0x50021205)<\r>
<\n>[0001.934] I> Task: Save debug data to SC7 ctx (0x50021191)<\r>
<\n>[0001.945] I> SC7 context save done<\r>
<\n>[0001.949] I> Task: Load MB2/Applet/FSKP (0x5000ca55)<\r>
<\n>[0001.955] I> Loading MB2<\r>
<\n>[0001.958] I> Slot: 0<\r>
<\n>[0001.961] I> Binary[6] block-0 (partition size: 0x80000)<\r>
<\n>[0001.966] I>  get_binary_info: Binary name: MB2<\r>
<\n>[0001.971] I> Size of crypto header is 8192<\r>
<\n>[0001.976] I> BCH load address is : 0x8007e000<\r>
<\n>[0001.981] I> Size of crypto header is 8192<\r>
<\n>[0001.986] I> BCH of MB2 read from storage<\r>
<\n>[0001.990] I> BCH address is : 0x8007e000<\r>
<\n>[0001.996] I> MB2 header integrity check is success<\r>
<\n>[0002.001] I> Binary magic in BCH component 0 is MB2B<\r>
<\n>[0002.006] I> component binary type is 6<\r>
<\n>[0002.010] I> Size of crypto header is 8192<\r>
<\n>[0002.019] I> MB2 binary is read from storage<\r>
<\n>[0002.025] I> MB2 binary integrity check is success<\r>
<\n>[0002.030] I> Binary MB2 loaded successfully at 0x80000000 (0x68ee0)<\r>
<\n>[0002.038] I> Task: Map CCPLEX SHARED carveout (0x5000cbf9)<\r>
<\n>[0002.045] I> Task: Prepare MB2 params (0x5000cca9)<\r>
<\n>[0002.052] I> BR-BCT Boot Chain Fields<\r>
<\n>[0002.056] I> <9> u32_non_gpio_select_boot_chain  : 0<\r>
<\n>[0002.061] I> <9> u32_num_boot_chains             : 2<\r>
<\n>[0002.066] I> <9> bf_bl_gpio_select_boot_chain_1b : 0<\r>
<\n>[0002.071] I> Task: Dram ecc test (0x50011791)<\r>
<\n>[0002.077] I> Task: Misc NV security settings (0x5000c529)<\r>
<\n>[0002.083] I> NVDEC sticky bits programming done<\r>
<\n>[0002.088] I> Successfully powergated NVDEC<\r>
<\n>[0002.092] I> Task: Disable/Reload WDT (0x50021a99)<\r>
<\n>[0002.098] I> Task: Program misc carveouts (0x50015381)<\r>
<\n>[0002.105] I> Program IPC carveouts<\r>
<\n>[0002.111] I> SLCG Global override status := 0x0<\r>
<\n>[0002.116] I> MB1: MSS reconfig completed<\r>
<\n>I> MB2 (version: 0.0.0.0-t234-54845784-02a8384c)<\r>
<\n>I> t234-A01-1-Silicon (0x12347)<\r>
<\n>I> Boot-mode : Coldboot<\r>
<\n>I> Emulation: <\r>
<\n>I> Entry timestamp: 0x0020e89f<\r>
<\n>I> Regular heap: [base:0x40040000, size:0x10000]<\r>
<\n>I> DMA heap: [base:0x233000000, size:0x800000]<\r>
<\n>I> Task: ARI update carveout TZDRAM (0x50001e80)<\r>
<\n>I> Task: Enable hot-plug capability (0x50026bec)<\r>
<\n>I> Task: PSC mailbox init (0x50016a7c)<\r>
<\n>I> Task: Crypto init (0x500065a8)<\r>
<\n>I> Task: Enable GP-SE clock (0x50001fe4)<\r>
<\n>I> Task: DICE Identity init (0x50019e50)<\r>
<\n>I> DICE is not enabled.<\r>
<\n>I> Task: OEM SC7 context save init (0x50019550)<\r>
<\n>I> Task: I2C register (0x50001e44)<\r>
<\n>I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout (0x50001e2c)<\r>
<\n>I> Task: Program CBB PCIE AMAP regions (0x50019b64)<\r>
<\n>I> Task: Boot device init (0x50001d74)<\r>
<\n>I> Boot_device: QSPI_FLASH instance: 0<\r>
<\n>I> Qspi clock source : pllc_out0<\r>
<\n>I> QSPI-0l initialized successfully<\r>
<\n>I> Task: Partition Manager Init (0x50001d70)<\r>
<\n>I> Found 57 partitions in QSPI_FLASH (instance 0)<\r>
<\n>I> Task: Load and authenticate registered FWs (0x5001ce48)<\r>
<\n>I> Task: Load AUXP FWs (0x5002678c)<\r>
<\n>I> Successfully register SPE FW load task with MB2 loader<\r>
<\n>I> Skipping SCE FW load<\r>
<\n>I> Successfully register RCE FW load task with MB2 loader<\r>
<\n>I> Successfully register DCE FW load task with MB2 loader<\r>
<\n>I> Unpowergating APE<\r>
<\n>I> Unpowergate done<\r>
<\n>I> Successfully register APE FW load task with MB2 loader<\r>
<\n>I> Skipping FSI FW load<\r>
<\n>I> Successfully register XUSB FW load task with MB2 loader<\r>
<\n>I> Partition name: A_spe-fw<\r>
<\n>I> Size of partition: 589824<\r>
<\n>I> Binary@ device:3/0 block-55040 (partition size: 0x90000), name: A_spe-fw<\r>
<\n>I> Partition name: A_rce-fw<\r>
<\n>I> Size of partition: 1048576<\r>
<\n>I> Binary@ device:3/0 block-56192 (partition size: 0x100000), name: A_rce-fw<\r>
<\n>I> spe: Authentication Finalize Done<\r>
<\n>I> Binary spe loaded successfully at 0x232400000<\r>
<\n>I> Partition name: A_dce-fw<\r>
<\n>I> Size of partition: 5242880<\r>
<\n>I> Binary@ device:3/0 block-44800 (partition size: 0x500000), name: A_dce-fw<\r>
<\n>I> rce: Authentication Finalize Done<\r>
<\n>I> Binary rce loaded successfully at 0x232100000<\r>
<\n>I> dce : oem authentication of header done<\r>
<\n>I> dce : meta-blob integrity check is success.<\r>
<\n>I> dce : will be decompressed at 0x23a000000<\r>
<\n>I> version 1 Bin 1 BCheckSum 0 content_size 0 Content ChkSum 1 reserved_00  0<\r>
<\n>I> Reserved10 0 BlockMaxSize 5 Reserved11 0<\r>
<\n>I> dce : decompressed to 9441408 bytes<\r>
<\n>I> dce: plain binary integrity check is success<\r>
<\n>I> Partition name: A_adsp-fw<\r>
<\n>I> Size of partition: 2097152<\r>
<\n>I> Binary@ device:3/0 block-58240 (partition size: 0x200000), name: A_adsp-fw<\r>
<\n>I> dce: Authentication Finalize Done<\r>
<\n>I> Binary dce loaded successfully at 0x23a000000<\r>
<\n>I> Partition name: A_xusb-fw<\r>
<\n>I> Size of partition: 262144<\r>
<\n>I> Binary@ device:3/0 block-9472 (partition size: 0x40000), name: A_xusb-fw<\r>
<\n>I> ape: Authentication Finalize Done<\r>
<\n>I> Binary ape loaded successfully at 0x232c00000<\r>
<\n>I> xusb: Authentication Finalize Done<\r>
<\n>I> Binary xusb loaded successfully at 0x232500000<\r>
<\n>I> Task: Carveout setup (0x5001f55c)<\r>
<\n>I> Program remaining OEM carveouts<\r>
<\n>I> Task: Enable FSITHERM (0x50016950)<\r>
<\n>I> Task: Enable FSI VMON (0x500164d8)<\r>
<\n>I> Task: Validate FSI Therm readings (0x50016530)<\r>
<\n>I> Task: Restore XUSB sec (0x50001d44)<\r>
<\n>I> Task: Enable FSI SE clock (0x50016ed8)<\r>
<\n>I> Task: Initialize SBSA UART CAR (0x50001f48)<\r>
<\n>I> Task: Ratchet update (0x50027c88)<\r>
<\n>W> OPTIN fuse not set, skip ratchet update<\r>
<\n>I> Task: Initialize CPUBL Params (0x50017e0c)<\r>
<\n>I> CPUBL-params @ 0x236000000<\r>
<\n>I> Task: Prepare eeprom data (0x50017bd8)<\r>
<\n>I> Task: FSI padctl context save (0x500196e0)<\r>
<\n>E> Skipping FSI padctl config save: fsi not enabled<\r>
<\n>I> Task: Unpowergate APE (0x50017640)<\r>
<\n>W> mb2_unpowergate_ape: skip! APE is in unpowergated state<\r>
<\n>I> Task: OEM firewalls (0x500238fc)<\r>
<\n>I> OEM firewalls configured<\r>
<\n>I> Task: Powergate APE (0x500177b4)<\r>
<\n>I> Powergating APE<\r>
<\n>I> Powergate done<\r>
<\n>I> Task: OEM firewall restore saved settings (0x50023d50)<\r>
<\n>I> Task: Unhalt AUXPs (0x500269f4)<\r>
<\n>I> Unhalting SPE..<\r>
<\n>I> Enabling combined UART <\r>
<\n><\0>ÿýÿàspe: early_init<\r>
<\n>vic initialized<\r>
<\n>tsc initialized<\r>
<\n>aon lic initialized<\r>
<\n>spe: tag is 243b265b351d6bb9cc7b2e3acc5d90f8<\r>
<\n>spe: SafeRTOS v8.4<\r>
<\n>spe: init<\r>
<\n>scheduler initialized<\r>
<\n>aon hsp initialized<\r>
<\n>tag initialized<\r>
<\n>tcu initialized<\r>
<\n>bpmp ipc initialized<\r>
<\n>spe: late init<\r>
<\n>cpu_nic clock initialized<\r>
<\n>apb clock initialized<\r>
<\n>pm initialized<\r>
<\n>bpmp hsp initialized<\r>
<\n>top1 hsp initialized<\r>
<\n>ccplex ipc initialized<\r>
<\n>spe: start scheduler<\r>
<\n>ÿá<\n>I> Task: Trigger mailbox for PSC-BL1 exit (0x50016afc)<\r>
<\n>I> Sending opcode 0x4d420802 to psc<\r>
<\n>ÿçINFO: Entering psc_monitor_init!<\r>
<\n>INFO: GSC22 BOM:0x248002000 SIZE:0x1000000 CLIENT_ACCESS1:00180000<\r>
<\n>INFO: PSCFW BUILD VERSION: 8a33b23-73b589c-8a15f76-rel-t234<\r>
<\n>INFO: mstatus:0xa00000808<\r>
<\n>INFO: Supervisor entry_point:c108c00<\r>
<\n>ÿáI> Received ACK from psc<\r>
<\n>I> Task: ÿçINFO: MONITOR: user task addr:0x248022000, blob offset:0x00020000<\r>
<\n>INFO: MONITOR: populated user images:13<\r>
<\n>INFO: mret to Supervisor!<\r>
<\n>INFO: psc supervisor init.<\r>
<\n>INFO: psc_irq_init...<\r>
<\n>INFO: enter idle task.<\r>
<\n>ÿâ<\n>bpmp: socket 0<\r>
<\n>bpmp: base binary md5 is 1377b684fe55be78e1d7fc3e0f143b55<\r>
<\n>bpmp: combined binary md5 is f0fadc45ec6216cb5b0bcb3771407fc2<\r>
<\n>bpmp: firmware tag is f0fadc45ec6216cb5b0b-1377b684fe5<\r>
<\n>initialized vwdt<\r>
<\n>initialized mail_early<\r>
<\n>initialized fuse<\r>
<\n>initialized vfrel<\r>
<\n>initialized hwwdt<\r>
<\n>initialized adc<\r>
<\n>fmon_populate_monitors: found 199 monitors<\r>
<\n>initialized fmon<\r>
<\n>initialized mc<\r>
<\n>initialized reset<\r>
<\n>initialized uphy_early<\r>
<\n>initialized emc_early<\r>
<\n>471 clocks registered<\r>
<\n>initialized clk_mach<\r>
<\n>initialized clk_cal_early<\r>
<\n>initialized clk_mach_early_config<\r>
<\n>initialized io_dpd<\r>
<\n>initialized soctherm<\r>
<\n>initialized tj_init<\r>
<\n>initialized regime<\r>
<\n>initialized i2c<\r>
<\n>vrmon_dt_init: vrmon node not found<\r>
<\n>vrmon_chk_boot_state: found 0 rail monitors<\r>
<\n>initialized vrmon<\r>
<\n>initialized regulator<\r>
<\n>initialized avfs_clk_platform<\r>
<\n>initialized powergate<\r>
<\n>initialized dvs<\r>
<\n>initialized clk_mach_config<\r>
<\n>initialized pm<\r>
<\n>initialized suspend<\r>
<\n>initialized strap<\r>
<\n>initialized mce_dbell<\r>
<\n>ÿáStart secure NOR provision (0x5001997c)<\r>
<\n>I> Task: Load FSI keyblob (0x50016f20)<\r>
<\n>I> Task: Unhalt AUXPs (0ÿâinitialized emc<\r>
<\n>initialized emc_mrq<\r>
<\n>ÿáx500269fc)<\r>
<\n>I> SCE unhalt skipped<\r>
<\n>ÿâinitialized clk_cal<\r>
<\n>initialized uphy_dt<\r>
<\n>initialized uphy_mrq<\r>
<\n>HSIO UPHY reset has been de-asserted 0x0<\r>
<\n>initialized uphy<\r>
<\n>initialized pg_late<\r>
<\n>initialized pg_mrq_init<\r>
<\n>swdtimer_init: 0 reg polling start w period 47 ms<\r>
<\n>initialized swdtimer<\r>
<\n>initialized hwwdt_late<\r>
<\n>initialized bwmgr<\r>
<\n>initialized thermal_host_trip<\r>
<\n>initialized thermal_mrq<\r>
<\n>initialized oc_mrq<\r>
<\n>initialized reset_mrq<\r>
<\n>initialized mail_mrq<\r>
<\n>initialized fmon_mrq<\r>
<\n>initialized clk_mrq<\r>
<\n>initialized avfs_mrq<\r>
<\n>initialized i2c_mrq<\r>
<\n>initialized tag_mrq<\r>
<\n>initialized bwmgr_mrq<\r>
<\n>initialized console_mrq<\r>
<\n>missing prod DT calibration data for 199 fmons<\r>
<\n>initialized clk_sync_fmon_post<\r>
<\n>ÿáI> Unhalting RCE<\r>
<\n>I> RCE unhalt sÿâinitializÿå[     2.580207] Camera-FW on t234-rce-safe started<\r>
<\n>TCU early console enabled.ÿâed clk_cal_late<\r>
<\n>initialized noc_late<\r>
<\n>initialized cvc<\r>
<\n>initialized avfs_clk_mÿå<\r>
<\n>ÿâach_post<\r>
<\n>initialized avfs_clk_platform_post<\r>
<\n>initialized cvc_late<\r>
<\n>initialized rm<\r>
<\n>initialized console_late<\r>
<\n>handling unreferenced clks<\r>
<\n>enable can1_core<\r>
<\n>enable can1_host<\r>
<\n>enable can2_core<\r>
<\n>enable can2_host<\r>
<\n>enable pwm3<\r>
<\n>enable mss_encrypt<\r>
<\n>enable maud<\r>
<\n>enable pllg_ref<\r>
<\n>enable dsi_core<\r>
<\n>enable aza_2xbit<\r>
<\n>enable xusb_ss<\r>
<\n>enable xusb_fs<\r>
<\n>enable xusb_falcon<\r>
<\n>enable xusb_core_mux<\r>
<\n>enable dsi_lp<\r>
<\n>clk_check_max_rates: pex1_c6_core rate 500000000 > max 250000000<\r>
<\n>clk_check_max_rates: pex2_c7_core rate 500000000 > max 250000000<\r>
<\n>clk_check_max_rates: pex2_c8_core rate 500000000 > max 250000000<\r>
<\n>clk_check_max_rates: pex2_c9_core rate 500000000 > max 250000000<\r>
<\n>clk_check_max_rates: pex2_c10_core rate 500000000 > max 250000000<\r>
<\n>clk_check_max_rates: pex0_c0_core rate 500000000 > max 250000000<\r>
<\n>clk_check_max_rates: pex0_c1_core rate 500000000 > max 250000000<\r>
<\n>clk_check_max_rates: pex0_c2_core rate 500000000 > max 250000000<\r>
<\n>clk_check_max_rates: pex0_c3_core rate 500000000 > max 250000000<\r>
<\n>clk_check_max_rates: pex0_c4_core rate 500000000 > max 250000000<\r>
<\n>clk_check_max_rates: pex1_c5_core rate 500000000 > max 250000000<\r>
<\n>initialized clk_mach_post<\r>
<\n>initialized pg_post<\r>
<\n>initialized regulator_post<\r>
<\n>initialized profile<\r>
<\n>initialized fuse_late<\r>
<\n>initialized mrq<\r>
<\n>initialized patrol_scrubber<\r>
<\n>initialized cactmon<\r>
<\n>initialized extras_post<\r>
<\n>bpmp: init complete<\r>
<\n>ÿå[     2.704169] Camera-FW on t234-rce-safe ready SHA1=0b67520f (crt 1.488 ms, total boot 125.555 ms)<\r>
<\n>ÿáuccessful<\r>
<\n>I> DCE unhalt successful<\r>
<\n>I> APE unhalt skipped<\r>
<\n>I> FSI unhalt skipped<\r>
<\n>I> Task: Load CPUBL (0x50017f04)<\r>
<\n>I> Task: Load TOS (0x50018608)<\r>
<\n>ÿè<\n>ÿáI> Task: Load and authenticate registered FWs (0x5001ce48)<\r>
<\n>I> Partition name: A_cpu-bootloader<\r>
<\n>I> Size of partition: 3670016<\r>
<\n>I> Binary@ device:3/0 block-24832 (partition size: 0x380000), name: A_cpu-bootloader<\r>
<\n>I> Partition name: A_secure-os<\r>
<\n>I> Size of partition: 4194304<\r>
<\n>I> Binary@ device:3/0 block-32000 (partition size: 0x400000), name: A_secure-os<\r>
<\n>I> MB2-params @ 0x40060000<\r>
<\n>I> cpubl: Authentication Finalize Done<\r>
<\n>I> Binary cpubl loaded successfully at 0x231a00000<\r>
<\n>I> tos: Authentication Finalize Done<\r>
<\n>I> Binary tos loaded successfully at 0x23fdfe000<\r>
<\n>I> Relocating OP-TEE dtb from: 0x23feff770 to 0x231e30000, size: 0x1976<\r>
<\n>I> [0] START: 0x80000000, SIZE: 0x1b1e70000<\r>
<\n>I> [1] START: 0x236000000, SIZE: 0x2000000<\r>
<\n>I> Setting NS memory ranges to OP-TEE dtb finished.<\r>
<\n>I> Partition name: A_eks<\r>
<\n>I> Binary@ device:3/0 block-44288 (partition size: 0x40000), name: A_eks<\r>
<\n>I> eks: Authentication Finalize Done<\r>
<\n>I> Binary eks loaded successfully at 0x233000200<\r>
<\n>I> ÿèDCE: FW Boot Done<\r>
<\n>ÿáEKB detected (length: 0x410) @ VA:0x233000200<\r>
<\n>I> Task: Prepare TOS params (0x50018580)<\r>
<\n>I> Setting EKB blob info to OPTEE dtb finished.<\r>
<\n>I> Setting OPTEE arg3: 0x231e30000<\r>
<\n>I> Task: OEM SC7 context save (0x500197dc)<\r>
<\n>I> OEM sc7 context saved<\r>
<\n>I> Task: Disable MSS perf stats (0x50026a88)<\r>
<\n>I> Task: Program display sticky bits (0x50026a04)<\r>
<\n>I> Task: Storage device deinit (0x50001eec)<\r>
<\n>I> Task: SMMU external bypass disable (0x50016a60)<\r>
<\n>I> Task: SMMU init (0x5001697c)<\r>
<\n>I> Task: Program GICv3 registers (0x50026b28)<\r>
<\n>I> Task: Audit firewall settings (0x50023b50)<\r>
<\n>I> Task: Bootchain failure check (0x50002434)<\r>
<\n>I> Current Boot-Chain Slot: 0<\r>
<\n>I> BR-BCT Boot-Chain is 0, and status is 1. Set UPDATE_BRBCT bit to 0<\r>
<\n>I> MB2 finished<\n><\r>
<\n>ÿäNOTICE:  BL31: v2.6(release):6363e7382<\r>
<\n>NOTICE:  BL31: Built : 10:08:23, Feb 21 2023<\r>
<\n>I/TC: <\r>
<\n>I/TC: Non-secure external DT found<\r>
<\n>I/TC: OP-TEE version: 3.19 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Tue Feb 21 18:24:01 UTC 2023 aarch64<\r>
<\n>I/TC: WARNING: This OP-TEE configuration might be insecure!<\r>
<\n>I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html<\r>
<\n>I/TC: Primary CPU initializing<\r>
<\n>I/TC: WARNING: Test OEM keys are being used!<\r>
<\n>I/TC: This is only for TZ-SE testing and should NOT be used for a shipping product!<\r>
<\n>I/TC: Primary CPU switching to normal world boot<\r>
<\n>ÿá<\n>Jetson UEFI firmware (version 3.0-32616947 built on 2023-02-21T18:13:46+00:00)<\r>
<\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><27>[2J<27>[04D<27>[=3h<27>[2J<27>[09D<\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n><\n>**  WARNING: Test Key is used.  **<\r>
<\n><\n>L4TLauncher: Attempting Direct Boot<\r>
<\n>EFI stub: Booting Linux Kernel...<\r>
<\n>EFI stub: Using DTB from configuration table<\r>
<\n>EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path<\r>
<\n>EFI stub: Exiting boot services and installing virtual address map...<\r>
<\n>ÿäI/TC: Secondary CPU 1 initializing<\r>
<\n>I/TC: Secondary CPU 1 switching to normal world boot<\r>
<\n>I/TC: Secondary CPU 2 initializing<\r>
<\n>I/TC: Secondary CPU 2 switching to normal world boot<\r>
<\n>I/TC: Secondary CPU 3 initializing<\r>
<\n>I/TC: Secondary CPU 3 switching to normal world boot<\r>
<\n>I/TC: Secondary CPU 6 initializing<\r>
<\n>I/TC: Secondary CPU 6 switching to normal world boot<\r>
<\n>I/TC: Secondary CPU 7 initializing<\r>
<\n>I/TC: Secondary CPU 7 switching to normal world boot<\r>
<\n>ÿá[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]<\r>
<\n>[    0.000000] Linux version 5.10.104-tegra (buildbrain@mobile-u64-6289-d7000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Sun Mar 19 07:55:28 PDT 2023<\r>
<\n>[    0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,<\r>
<\n>[    0.000000] OF: fdt:  - 80000000 ,  c0000000<\r>
<\n>[    0.000000] Machine model: NVIDIA Orin Nano Developer Kit<\r>
<\n>[    0.000000] efi: EFI v2.70 by EDK II<\r>
<\n>[    0.000000] efi: RTPROP=0x20b5bdf18 SMBIOS=0xffff0000 SMBIOS 3.0=0x20a560000 MEMATTR=0x20ac5a018 ESRT=0x20700ed18 RNG=0x22dd3dd18 MEMRESERVE=0x20ac5bf18 <\r>
<\n>[    0.000000] efi: seeding entropy pool<\r>
<\n>[    0.000000] esrt: Reserving ESRT space from 0x000000020700ed18 to 0x000000020700ed50.<\r>
<\n>[    0.000000] Reserved memory: created CMA memory pool at 0x000000021dc00000, size 256 MiB<\r>
<\n>[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool<\r>
<\n>[    0.000000] Zone ranges:<\r>
<\n>[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]<\r>
<\n>[    0.000000]   DMA32    empty<\r>
<\n>[    0.000000]   Normal   [mem 0x0000000100000000-0x0000000237ffffff]<\r>
<\n>[    0.000000] Movable zone start for each node<\r>
<\n>[    0.000000] Early memory node ranges<\r>
<\n>[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000fffdffff]<\r>
<\n>[    0.000000]   node   0: [mem 0x00000000fffe0000-0x00000000ffffffff]<\r>
<\n>[    0.000000]   node   0: [mem 0x0000000100000000-0x0000000206fcffff]<\r>
<\n>[    0.000000]   node   0: [mem 0x0000000206fd0000-0x0000000206ffffff]<\r>
<\n>[    0.000000]   node   0: [mem 0x0000000207000000-0x0000000207e7cfff]<\r>
<\n>[    0.000000]   node   0: [mem 0x0000000207e7d000-0x000000020a1bffff]<\r>
<\n>[    0.000000]   node   0: [mem 0x000000020a1c0000-0x000000020a4fffff]<\r>
<\n>[    0.000000]   node   0: [mem 0x000000020a500000-0x000000020a50ffff]<\r>
<\n>[    0.000000]   node   0: [mem 0x000000020a510000-0x000000020a55ffff]<\r>
<\n>[    0.000000]   node   0: [mem 0x000000020a560000-0x000000020a56ffff]<\r>
<\n>[    0.000000]   node   0: [mem 0x000000020a570000-0x000000020a76ffff]<\r>
<\n>[    0.000000]   node   0: [mem 0x000000020a770000-0x000000020a7bffff]<\r>
<\n>[    0.000000]   node   0: [mem 0x000000020a7c0000-0x000000020a8affff]<\r>
<\n>[    0.000000]   node   0: [mem 0x000000020a8b0000-0x000000020a8fffff]<\r>
<\n>[    0.000000]   node   0: [mem 0x000000020a900000-0x000000020aa7ffff]<\r>
<\n>[    0.000000]   node   0: [mem 0x000000020aa80000-0x000000020abbffff]<\r>
<\n>[    0.000000]   node   0: [mem 0x000000020abc0000-0x000000020ac6ffff]<\r>
<\n>[    0.000000]   node   0: [mem 0x000000020ac70000-0x000000020af0ffff]<\r>
<\n>[    0.000000]   node   0: [mem 0x000000020af10000-0x000000020af3ffff]<\r>
<\n>[    0.000000]   node   0: [mem 0x000000020af40000-0x000000020b02ffff]<\r>
<\n>[    0.000000]   node   0: [mem 0x000000020b030000-0x000000020b03ffff]<\r>
<\n>[    0.000000]   node   0: [mem 0x000000020b040000-0x000000020b08ffff]<\r>
<\n>[    0.000000]   node   0: [mem 0x000000020b090000-0x000000020b58ffff]<\r>
<\n>[    0.000000]   node   0: [mem 0x000000020b590000-0x000000020b59ffff]<\r>
<\n>[    0.000000]   node   0: [mem 0x000000020b5a0000-0x000000020b6affff]<\r>
<\n>[    0.000000]   node   0: [mem 0x000000020b6b0000-0x000000020b74ffff]<\r>
<\n>[    0.000000]   node   0: [mem 0x000000020b750000-0x000000020b84ffff]<\r>
<\n>[    0.000000]   node   0: [mem 0x000000020b850000-0x000000020b8effff]<\r>
<\n>[    0.000000]   node   0: [mem 0x000000020b8f0000-0x000000020b9effff]<\r>
<\n>[    0.000000]   node   0: [mem 0x000000020b9f0000-0x000000020ba8ffff]<\r>
<\n>[    0.000000]   node   0: [mem 0x000000020ba90000-0x000000020c35ffff]<\r>
<\n>[    0.000000]   node   0: [mem 0x000000020c360000-0x000000020c53ffff]<\r>
<\n>[    0.000000]   node   0: [mem 0x000000020c540000-0x000000022dceffff]<\r>
<\n>[    0.000000]   node   0: [mem 0x000000022dcf0000-0x000000022dd3ffff]<\r>
<\n>[    0.000000]   node   0: [mem 0x000000022dd40000-0x00000002317fffff]<\r>
<\n>[    0.000000]   node   0: [mem 0x0000000231a00000-0x0000000231e0ffff]<\r>
<\n>[    0.000000]   node   0: [mem 0x0000000236000000-0x0000000237ffffff]<\r>
<\n>[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000237ffffff]<\r>
<\n>[    0.000000] On node 0, zone Normal: 496 pages in unavailable ranges<\r>
<\n>[    0.000000] psci: probing for conduit method from DT.<\r>
<\n>[    0.000000] psci: PSCIv1.1 detected in firmware.<\r>
<\n>[    0.000000] psci: Using standard PSCI v0.2 function IDs<\r>
<\n>[    0.000000] psci: Trusted OS migration not required<\r>
<\n>[    0.000000] psci: SMC Calling Convention v1.2<\r>
<\n>[    0.000000] percpu: Embedded 32 pages/cpu s90200 r8192 d32680 u131072<\r>
<\n>[    0.000000] Detected PIPT I-cache on CPU0<\r>
<\n>[    0.000000] CPU features: detected: GIC system register CPU interface<\r>
<\n>[    0.000000] CPU features: detected: Virtualization Host Extensions<\r>
<\n>[    0.000000] CPU features: kernel page table isolation forced ON by KASLR<\r>
<\n>[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)<\r>
<\n>[    0.000000] CPU features: detected: Spectre-v4<\r>
<\n>[    0.000000] alternatives: patching kernel code<\r>
<\n>[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1756688<\r>
<\n>[    0.000000] Kernel command line: root=/dev/mmcblk1p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 <\r>
<\n>[    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)<\r>
<\n>[    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)<\r>
<\n>[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off<\r>
<\n>[    0.000000] software IO TLB: mapped [mem 0x00000000effe0000-0x00000000fffe0000] (256MB)<\r>
<\n>[    0.000000] Memory: 6360904K/7139392K available (18496K kernel code, 3168K rwdata, 7172K rodata, 3968K init, 1418K bss, 516344K reserved, 262144K cma-reserved)<\r>
<\n>[    0.000000] random: get_random_u64 called from __kmem_cache_create+0x38/0x420 with crng_init=0<\r>
<\n>[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1<\r>
<\n>[    0.000000] rcu: Preemptible hierarchical RCU implementation.<\r>
<\n>[    0.000000] rcu: <9>RCU event tracing is enabled.<\r>
<\n>[    0.000000] rcu: <9>RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.<\r>
<\n>[    0.000000] <9>Trampoline variant of Tasks RCU enabled.<\r>
<\n>[    0.000000] <9>Rude variant of Tasks RCU enabled.<\r>
<\n>[    0.000000] <9>Tracing variant of Tasks RCU enabled.<\r>
<\n>[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.<\r>
<\n>[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6<\r>
<\n>[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0<\r>
<\n>[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode<\r>
<\n>[    0.000000] GICv3: 960 SPIs implemented<\r>
<\n>[    0.000000] GICv3: 0 Extended SPIs implemented<\r>
<\n>[    0.000000] GICv3: Distributor has no Range Selector support<\r>
<\n>[    0.000000] GICv3: 16 PPIs implemented<\r>
<\n>[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000<\r>
<\n>[    0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)<\r>
<\n>[    0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]<\r>
<\n>[    0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).<\r>
<\n>[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns<\r>
<\n>[    0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns<\r>
<\n>[    0.000662] Console: colour dummy device 80x25<\r>
<\n>[    0.000703] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)<\r>
<\n>[    0.000712] pid_max: default: 32768 minimum: 301<\r>
<\n>[    0.000775] LSM: Security Framework initializing<\r>
<\n>[    0.000797] Yama: becoming mindful.<\r>
<\n>[    0.000814] SELinux:  Initializing.<\r>
<\n>[    0.000874] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)<\r>
<\n>[    0.000889] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)<\r>
<\n>[    0.001653] /cpus/cpu-map/cluster1: empty cluster<\r>
<\n>[    0.001968] rcu: Hierarchical SRCU implementation.<\r>
<\n>[    0.002064] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build<\r>
<\n>[    0.002554] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t23x/p3768/kernel-dts/tegra234-p3767-0003-p3768-0000-a0.dts<\r>
<\n>[    0.002560] DTB Build time: Mar 19 2023 08:08:40<\r>
<\n>[    0.003885] Tegra Revision: A01 SKU: 0xd5 CPU Process: 0 SoC Process: 0<\r>
<\n>[    0.004054] Remapping and enabling EFI services.<\r>
<\n>[    0.005287] smp: Bringing up secondary CPUs ...<\r>
<\n>[    0.033985] Detected PIPT I-cache on CPU1<\r>
<\n>[    0.034021] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000<\r>
<\n>[    0.034059] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]<\r>
<\n>[    0.062709] Detected PIPT I-cache on CPU2<\r>
<\n>[    0.062720] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000<\r>
<\n>[    0.062735] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]<\r>
<\n>[    0.091333] Detected PIPT I-cache on CPU3<\r>
<\n>[    0.091342] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000<\r>
<\n>[    0.091356] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]<\r>
<\n>[    0.122001] Detected PIPT I-cache on CPU4<\r>
<\n>[    0.122024] GICv3: CPU4: found redistributor 10200 region 0:0x000000000f500000<\r>
<\n>[    0.122053] CPU4: Booted secondary processor 0x0000010200 [0x410fd421]<\r>
<\n>[    0.150736] Detected PIPT I-cache on CPU5<\r>
<\n>[    0.150747] GICv3: CPU5: found redistributor 10300 region 0:0x000000000f520000<\r>
<\n>[    0.150763] CPU5: Booted secondary processor 0x0000010300 [0x410fd421]<\r>
<\n>[    0.150826] smp: Brought up 1 node, 6 CPUs<\r>
<\n>[    0.150839] SMP: Total of 6 processors activated.<\r>
<\n>[    0.150843] CPU features: detected: Privileged Access Never<\r>
<\n>[    0.150845] CPU features: detected: LSE atomic instructions<\r>
<\n>[    0.150847] CPU features: detected: User Access Override<\r>
<\n>[    0.150849] CPU features: detected: 32-bit EL0 Support<\r>
<\n>[    0.150852] CPU features: detected: Common not Private translations<\r>
<\n>[    0.150854] CPU features: detected: RAS Extension Support<\r>
<\n>[    0.150855] CPU features: detected: Data cache clean to the PoU not required for I/D coherence<\r>
<\n>[    0.150858] CPU features: detected: CRC32 instructions<\r>
<\n>[    0.150860] CPU features: detected: Speculative Store Bypassing Safe (SSBS)<\r>
<\n>[    0.189280] CPU: All CPU(s) started at EL2<\r>
<\n>[    0.191067] devtmpfs: initialized<\r>
<\n>[    0.207739] Registered cp15_barrier emulation handler<\r>
<\n>[    0.207748] Registered setend emulation handler<\r>
<\n>[    0.207753] KASLR enabled<\r>
<\n>[    0.207898] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns<\r>
<\n>[    0.207909] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)<\r>
<\n>[    0.209861] pinctrl core: initialized pinctrl subsystem<\r>
<\n>[    0.210445] SMBIOS 3.0.0 present.<\r>
<\n>[    0.210454] DMI: Unknown NVIDIA Orin NX Developer Kit/NVIDIA Orin NX Developer Kit, BIOS 3.0-32616947 02/21/2023<\r>
<\n>[    0.210750] NET: Registered protocol family 16<\r>
<\n>[    0.211642] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations<\r>
<\n>[    0.211709] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations<\r>
<\n>[    0.211764] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations<\r>
<\n>[    0.211796] audit: initializing netlink subsys (disabled)<\r>
<\n>[    0.211896] audit: type=2000 audit(0.208:1): state=initialized audit_enabled=0 res=1<\r>
<\n>[    0.212106] thermal_sys: Registered thermal governor 'step_wise'<\r>
<\n>[    0.212108] thermal_sys: Registered thermal governor 'power_allocator'<\r>
<\n>[    0.212112] thermal_sys: Registered thermal governor 'pid_thermal_gov'<\r>
<\n>[    0.212964] cpuidle: using governor menu<\r>
<\n>[    0.213083] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.<\r>
<\n>[    0.213161] ASID allocator initialised with 32768 entries<\r>
<\n>[    0.213264] Serial: AMBA PL011 UART driver<\r>
<\n>[    0.215219] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful<\r>
<\n>[    0.215247] Tegra reboot handler registered.<\r>
<\n>[    0.237301] mc: mapped MMIO address: 0xffff8000107b0000 -> 0x2c10000<\r>
<\n>[    0.237313] mc: mapped MMIO address: 0xffff8000107d0000 -> 0x2c20000<\r>
<\n>[    0.237322] mc: mapped MMIO address: 0xffff8000107f0000 -> 0x2c30000<\r>
<\n>[    0.237332] mc: mapped MMIO address: 0xffff800010810000 -> 0x2c40000<\r>
<\n>[    0.237339] mc: mapped MMIO address: 0xffff800010830000 -> 0x2c50000<\r>
<\n>[    0.237345] mc: mapped MMIO address: 0xffff800010850000 -> 0x2b80000<\r>
<\n>[    0.237353] mc: mapped MMIO address: 0xffff800010870000 -> 0x2b90000<\r>
<\n>[    0.237360] mc: mapped MMIO address: 0xffff800010890000 -> 0x2ba0000<\r>
<\n>[    0.237366] mc: mapped MMIO address: 0xffff8000108b0000 -> 0x2bb0000<\r>
<\n>[    0.237373] mc: mapped MMIO address: 0xffff8000108d0000 -> 0x1700000<\r>
<\n>[    0.237380] mc: mapped MMIO address: 0xffff8000108f0000 -> 0x1710000<\r>
<\n>[    0.237386] mc: mapped MMIO address: 0xffff800010910000 -> 0x1720000<\r>
<\n>[    0.237393] mc: mapped MMIO address: 0xffff800010930000 -> 0x1730000<\r>
<\n>[    0.237399] mc: mapped MMIO address: 0xffff800010950000 -> 0x1740000<\r>
<\n>[    0.237406] mc: mapped MMIO address: 0xffff800010970000 -> 0x1750000<\r>
<\n>[    0.237412] mc: mapped MMIO address: 0xffff800010990000 -> 0x1760000<\r>
<\n>[    0.237417] mc: mapped MMIO address: 0xffff8000109b0000 -> 0x1770000<\r>
Second part of log in next reply
Second part:
<\n>[     0.237426] nv-tegra-mc 2c10000.mc: No mssnvlink node<\r>
<\n>[    0.237452] mc-err: mcerr ops are set to t23x<\r>
<\n>[    0.238279] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 65, base_baud = 0) is a SBSA<\r>
<\n>[    1.390796] printk: console [ttyAMA0] enabled<\r>
<\n>[    1.399749] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages<\r>
<\n>[    1.406457] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages<\r>
<\n>[    1.413157] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages<\r>
<\n>[    1.419855] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages<\r>
<\n>[    1.428489] ACPI: Interpreter disabled.<\r>
<\n>[    1.432773] ddr-vddq: supplied by vdd-5v<\r>
<\n>[    1.436936] ddr-vdd2: supplied by vdd-5v<\r>
<\n>[    1.440982] vdd-AO-1v2: supplied by vdd-5v<\r>
<\n>[    1.445218] vdd-3v3: supplied by vdd-5v<\r>
<\n>[    1.449276] vdd-rtc: supplied by vdd-AO-1v2<\r>
<\n>[    1.453585] vdd-0v95-uphy: supplied by vdd-AO-1v2<\r>
<\n>[    1.458426] vdd-0v95-hdmi: supplied by vdd-AO-1v2<\r>
<\n>[    1.463420] vdd-1v8: supplied by vdd-3v3-sys<\r>
<\n>[    1.467815] vdd-3v3-AO: supplied by vdd-5v-sys<\r>
<\n>[    1.472376] vdd-av10-hub: supplied by vdd-5v-sys<\r>
<\n>[    1.477131] vdd-vbus-a: supplied by vdd-5v-sys<\r>
<\n>[    1.481698] vdd-vbus-b: supplied by vdd-5v-sys<\r>
<\n>[    1.486274] vdd-3v3-dp: supplied by vdd-3v3-sys<\r>
<\n>[    1.491095] iommu: Default domain type: Translated <\r>
<\n>[    1.496011] eventlib_kernel: keventlib is initialized, test id: 0<\r>
<\n>[    1.502307] SCSI subsystem initialized<\r>
<\n>[    1.506143] usbcore: registered new interface driver usbfs<\r>
<\n>[    1.511643] usbcore: registered new interface driver hub<\r>
<\n>[    1.516967] usbcore: registered new device driver usb<\r>
<\n>[    1.522236] mc: Linux media interface: v0.10<\r>
<\n>[    1.526514] videodev: Linux video capture interface: v2.00<\r>
<\n>[    1.532165] pps_core: LinuxPPS API ver. 1 registered<\r>
<\n>[    1.537128] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it><\r>
<\n>[    1.546268] PTP clock support registered<\r>
<\n>[    1.550443] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec<\r>
<\n>[    1.557600] tegra_wdt_t18x 2190000.watchdog: Registered successfully<\r>
<\n>[    1.565308] Registered efivars operations<\r>
<\n>[    1.569842] FPGA manager framework<\r>
<\n>[    1.573280] Advanced Linux Sound Architecture Driver Initialized.<\r>
<\n>[    1.579657] Bluetooth: Core ver 2.22<\r>
<\n>[    1.583241] NET: Registered protocol family 31<\r>
<\n>[    1.587683] Bluetooth: HCI device and connection manager initialized<\r>
<\n>[    1.594041] Bluetooth: HCI socket layer initialized<\r>
<\n>[    1.598920] Bluetooth: L2CAP socket layer initialized<\r>
<\n>[    1.603975] Bluetooth: SCO socket layer initialized<\r>
<\n>[    1.609416] camchar: rtcpu character device driver loaded<\r>
<\n>[    1.615054] clocksource: Switched to clocksource arch_sys_counter<\r>
<\n>[    1.814097] VFS: Disk quotas dquot_6.6.0<\r>
<\n>[    1.818063] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)<\r>
<\n>[    1.825105] pnp: PnP ACPI: disabled<\r>
<\n>[    1.830841] la/ptsa driver initialized.<\r>
<\n>[    1.834742] NET: Registered protocol family 2<\r>
<\n>[    1.839236] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)<\r>
<\n>[    1.848300] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)<\r>
<\n>[    1.856848] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)<\r>
<\n>[    1.864842] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)<\r>
<\n>[    1.872763] TCP: Hash tables configured (established 65536 bind 65536)<\r>
<\n>[    1.879377] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)<\r>
<\n>[    1.886186] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)<\r>
<\n>[    1.893500] NET: Registered protocol family 1<\r>
<\n>[    1.898079] RPC: Registered named UNIX socket transport module.<\r>
<\n>[    1.904012] RPC: Registered udp transport module.<\r>
<\n>[    1.908713] RPC: Registered tcp transport module.<\r>
<\n>[    1.913413] RPC: Registered tcp NFSv4.1 backchannel transport module.<\r>
<\n>[    1.919859] PCI: CLS 0 bytes, default 64<\r>
<\n>[    1.923880] Trying to unpack rootfs image as initramfs...<\r>
<\n>[    2.083508] Freeing initrd memory: 9120K<\r>
<\n>[    2.089440] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available<\r>
<\n>[    2.097394] kvm [1]: IPA Size Limit: 48 bits<\r>
<\n>[    2.101683] kvm [1]: GICv3: no GICV resource entry<\r>
<\n>[    2.106474] kvm [1]: disabling GICv2 emulation<\r>
<\n>[    2.110935] kvm [1]: GIC system register CPU interface enabled<\r>
<\n>[    2.116832] kvm [1]: vgic interrupt IRQ9<\r>
<\n>[    2.120861] kvm [1]: VHE mode initialized successfully<\r>
<\n>[    2.126672] Initialise system trusted keyrings<\r>
<\n>[    2.131199] workingset: timestamp_bits=46 max_order=21 bucket_order=0<\r>
<\n>[    2.140119] squashfs: version 4.0 (2009/01/31) Phillip Lougher<\r>
<\n>[    2.146268] NFS: Registering the id_resolver key type<\r>
<\n>[    2.151335] Key type id_resolver registered<\r>
<\n>[    2.155517] Key type id_legacy registered<\r>
<\n>[    2.159568] nfs4filelayout_init: NFSv4 File Layout Driver Registering...<\r>
<\n>[    2.166276] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...<\r>
<\n>[    2.173680] ntfs: driver 2.1.32 [Flags: R/W].<\r>
<\n>[    2.193295] NET: Registered protocol family 38<\r>
<\n>[    2.197742] Key type asymmetric registered<\r>
<\n>[    2.201836] Asymmetric key parser 'x509' registered<\r>
<\n>[    2.206729] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)<\r>
<\n>[    2.214185] io scheduler mq-deadline registered<\r>
<\n>[    2.218717] io scheduler kyber registered<\r>
<\n>[    2.226944] tegra-pwm 3280000.pwm: PWM clk can sleep in ops<\r>
<\n>[    2.232552] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops<\r>
<\n>[    2.238139] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops<\r>
<\n>[    2.244589] efifb: probing for efifb<\r>
<\n>[    2.248195] efifb: framebuffer at 0x208000000, using 23040k, total 23040k<\r>
<\n>[    2.254982] efifb: mode is 2560x1440x32, linelength=16384, pages=1<\r>
<\n>[    2.261161] efifb: scrolling: redraw<\r>
<\n>[    2.264738] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0<\r>
<\n>[    2.276842] Console: switching to colour frame buffer device 320x90<\r>
<\n>[    2.289320] fb0: EFI VGA frame buffer device<\r>
<\n>[    2.295527] tegra_dc_assign_hw_data: no matching compatible node<\r>
<\n>[    2.301532] tegradccommon module_init failed<\r>
<\n>[    2.305803] tegradc module_init failed<\r>
<\n>[    2.309844] EINJ: ACPI disabled.<\r>
<\n>[    2.314744] tegra-pmc c360000.pmc: scratch reg offset dts data not present<\r>
<\n>[    2.321625] tegra-pmc: ### PMC reset source: SYS_RESET_N<\r>
<\n>[    2.326938] tegra-pmc: ### PMC reset level: L0<\r>
<\n>[    2.331378] tegra-pmc: ### PMC reset status reg: 0x0<\r>
<\n>[    2.337731] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled<\r>
<\n>[    3.782232] random: fast init done<\r>
<\n>[    3.962819] printk: console [ttyTCU0] enabled<\r>
<\n>[    3.967911] arm-smmu 12000000.iommu: probing hardware configuration...<\r>
<\n>[    3.974611] arm-smmu 12000000.iommu: SMMUv2 with:<\r>
<\n>[    3.979433] arm-smmu 12000000.iommu: <9>stage 1 translation<\r>
<\n>[    3.984972] arm-smmu 12000000.iommu: <9>stage 2 translation<\r>
<\n>[    3.990511] arm-smmu 12000000.iommu: <9>nested translation<\r>
<\n>[    3.995955] arm-smmu 12000000.iommu: <9>stream matching with 128 register groups<\r>
<\n>[    4.003366] arm-smmu 12000000.iommu: <9>128 context banks (0 stage-2 only)<\r>
<\n>[    4.012574] arm-smmu 12000000.iommu: <9>Supported page sizes: 0x00001000<\r>
<\n>[    4.019274] arm-smmu 12000000.iommu: <9>Stage-1: 48-bit VA -> 48-bit IPA<\r>
<\n>[    4.025971] arm-smmu 12000000.iommu: <9>Stage-2: 48-bit IPA -> 48-bit PA<\r>
<\n>[    4.033536] arm-smmu 10000000.iommu: probing hardware configuration...<\r>
<\n>[    4.040235] arm-smmu 10000000.iommu: SMMUv2 with:<\r>
<\n>[    4.045059] arm-smmu 10000000.iommu: <9>stage 1 translation<\r>
<\n>[    4.050603] arm-smmu 10000000.iommu: <9>stage 2 translation<\r>
<\n>[    4.056146] arm-smmu 10000000.iommu: <9>nested translation<\r>
<\n>[    4.061597] arm-smmu 10000000.iommu: <9>stream matching with 128 register groups<\r>
<\n>[    4.069009] arm-smmu 10000000.iommu: <9>128 context banks (0 stage-2 only)<\r>
<\n>[    4.078161] arm-smmu 10000000.iommu: <9>Supported page sizes: 0x00001000<\r>
<\n>[    4.084859] arm-smmu 10000000.iommu: <9>Stage-1: 48-bit VA -> 48-bit IPA<\r>
<\n>[    4.091547] arm-smmu 10000000.iommu: <9>Stage-2: 48-bit IPA -> 48-bit PA<\r>
<\n>[    4.098732] arm-smmu 8000000.iommu: probing hardware configuration...<\r>
<\n>[    4.105342] arm-smmu 8000000.iommu: SMMUv2 with:<\r>
<\n>[    4.110075] arm-smmu 8000000.iommu: <9>stage 1 translation<\r>
<\n>[    4.115532] arm-smmu 8000000.iommu: <9>stage 2 translation<\r>
<\n>[    4.115533] arm-smmu 8000000.iommu: <9>nested translation<\r>
<\n>[    4.115536] arm-smmu 8000000.iommu: <9>stream matching with 128 register groups<\r>
<\n>[    4.115540] arm-smmu 8000000.iommu: <9>128 context banks (0 stage-2 only)<\r>
<\n>[    4.117799] arm-smmu 8000000.iommu: <9>Supported page sizes: 0x00001000<\r>
<\n>[    4.147066] arm-smmu 8000000.iommu: <9>Stage-1: 48-bit VA -> 48-bit IPA<\r>
<\n>[    4.153673] arm-smmu 8000000.iommu: <9>Stage-2: 48-bit IPA -> 48-bit PA<\r>
<\n>[    4.160963] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful<\r>
<\n>[    4.170739] tegra_profiler: version: 1.151, samples/io: 51/30<\r>
<\n>[    4.176721] tegra_profiler: auth: init<\r>
<\n>[    4.180890] nvsciipc: loaded module<\r>
<\n>[    4.186213] tun: Universal TUN/TAP device driver, 1.6<\r>
<\n>[    4.191905] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version<\r>
<\n>[    4.199323] hns3: Copyright (c) 2017 Huawei Corporation.<\r>
<\n>[    4.204809] e1000e: Intel(R) PRO/1000 Network Driver<\r>
<\n>[    4.209901] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.<\r>
<\n>[    4.215989] igb: Intel(R) Gigabit Ethernet Network Driver<\r>
<\n>[    4.221520] igb: Copyright (c) 2007-2014 Intel Corporation.<\r>
<\n>[    4.227409] PPP generic driver version 2.4.2<\r>
<\n>[    4.231838] PPP BSD Compression module registered<\r>
<\n>[    4.236662] PPP Deflate Compression module registered<\r>
<\n>[    4.241866] PPP MPPE Compression module registered<\r>
<\n>[    4.246810] usbcore: registered new interface driver r8152<\r>
<\n>[    4.252444] usbcore: registered new interface driver asix<\r>
<\n>[    4.258005] usbcore: registered new interface driver ax88179_178a<\r>
<\n>[    4.264262] usbcore: registered new interface driver cdc_ether<\r>
<\n>[    4.270259] usbcore: registered new interface driver net1080<\r>
<\n>[    4.276064] usbcore: registered new interface driver cdc_subset<\r>
<\n>[    4.282146] usbcore: registered new interface driver zaurus<\r>
<\n>[    4.287870] usbcore: registered new interface driver cdc_ncm<\r>
<\n>[    4.293686] usbcore: registered new interface driver aqc111<\r>
<\n>[    4.299531] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver<\r>
<\n>[    4.305884] ohci-pci: OHCI PCI platform driver<\r>
<\n>[    4.310461] ohci-platform: OHCI generic platform driver<\r>
<\n>[    4.316181] tegra-xusb 3610000.xhci: Adding to iommu group 0<\r>
<\n>[    4.322544] usbcore: registered new interface driver uas<\r>
<\n>[    4.328026] usbcore: registered new interface driver usb-storage<\r>
<\n>[    4.334366] tegra-xudc 3550000.xudc: Adding to iommu group 1<\r>
<\n>[    4.340480] mousedev: PS/2 mouse device common for all mice<\r>
<\n>[    4.346236] usbcore: registered new interface driver xpad<\r>
<\n>[    4.353667] tegra_rtc c2a0000.rtc: registered as rtc1<\r>
<\n>[    4.359138] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:29 UTC (29)<\r>
<\n>[    4.367373] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock<\r>
<\n>[    4.373772] i2c /dev entries driver<\r>
<\n>[    4.377484] tegra-i2c 3160000.i2c: Adding to iommu group 2<\r>
<\n>[    4.383296] tegra-i2c c240000.i2c: Adding to iommu group 2<\r>
<\n>[    4.388996] tegra-i2c 3180000.i2c: Adding to iommu group 2<\r>
<\n>[    4.394671] tegra-i2c 3190000.i2c: Adding to iommu group 2<\r>
<\n>[    4.400346] tegra-i2c 31b0000.i2c: Adding to iommu group 2<\r>
<\n>[    4.406021] tegra-i2c 31c0000.i2c: Adding to iommu group 2<\r>
<\n>[    4.411705] tegra-i2c c250000.i2c: Adding to iommu group 2<\r>
<\n>[    4.417380] tegra-i2c 31e0000.i2c: Adding to iommu group 2<\r>
<\n>[    4.426839] device-mapper: uevent: version 1.0.3<\r>
<\n>[    4.431692] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com<\r>
<\n>[    4.441416] sdhci: Secure Digital Host Controller Interface driver<\r>
<\n>[    4.447764] sdhci: Copyright(c) Pierre Ossman<\r>
<\n>[    4.452233] Synopsys Designware Multimedia Card Interface Driver<\r>
<\n>[    4.458477] sdhci-pltfm: SDHCI platform and OF driver helper<\r>
<\n>[    4.464668] sdhci-tegra 3400000.sdhci: Adding to iommu group 3<\r>
<\n>[    4.464921] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401<\r>
<\n>[    4.478091] tegra-bpmp bpmp: firmware: f0fadc45ec6216cb5b0b-1377b684fe5<\r>
<\n>[    4.486271] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9 <\r>
<\n>[    4.491670] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x82<\r>
<\n>[    4.500392] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0<\r>
<\n>[    4.506307] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful<\r>
<\n>ÿâFailed to create /rm/vdd_cpu<\r>
<\n>Failed to create /rm/vdd_cpu<\r>
<\n>debugfs initialized<\r>
<\n>ÿá[    5.597657] hid: raw HID events driver (C) Jiri Kosina<\r>
<\n>[    5.603495] usbcore: registered new interface driver usbhid<\r>
<\n>[    5.609231] usbhid: USB HID core driver<\r>
<\n>[    5.613675] tegra-dce d800000.dce: Adding to iommu group 4<\r>
<\n>[    5.620690] dce: dce_ipc_channel_init:319  Invalid Channel State [0x0] for ch_type [2]<\r>
<\n>[    5.629335] tegra234-aon c000000.aon: Adding to iommu group 5<\r>
<\n>[    5.635737] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x5]<\r>
<\n>[    5.643923]  c000000.aon:hsp: probed<\r>
<\n>[    5.644912] dce: dce_admin_send_cmd_ver:424  version : [0x2] err : [0x0]<\r>
<\n>[    5.655273] tegra234-aon c000000.aon: init done<\r>
<\n>[    5.655738] tegra23x-psc e860000.psc: Adding to iommu group 6<\r>
<\n>[    5.660074] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x1]<\r>
<\n>[    5.666168] tegra23x-psc e860000.psc: ext_cfg base:(____ptrval____)<\r>
<\n>[    5.674811] dce: dce_admin_setup_clients_ipc:553  Channel Reset Complete for Type [1] ...<\r>
<\n>[    5.681220] tegra23x-psc e860000.psc: init done<\r>
<\n>[    5.681457] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 7<\r>
<\n>[    5.689627] dce: dce_admin_setup_clients_ipc:529  Get queue info failed for [2]<\r>
<\n>[    5.694996] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000<\r>
<\n>[    5.701024] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x2]<\r>
<\n>[    5.725721] dce: dce_admin_setup_clients_ipc:553  Channel Reset Complete for Type [3] ...<\r>
<\n>[    5.734374] dce: dce_start_boot_flow:173  DCE_BOOT_DONE<\r>
<\n>[    5.741111] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584<\r>
<\n>[    5.750295] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900<\r>
<\n>[    5.761741] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80<\r>
<\n>[    5.773450] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80<\r>
<\n>[    5.785197] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80<\r>
<\n>[    5.797755] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080<\r>
<\n>[    5.810570] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200<\r>
<\n>[    5.822651] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (113)<\r>
<\n>[    5.829459] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful<\r>
<\n>[    5.838024] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=0b67520f597ddc6db82218e87c6c6eb8979fd4bb<\r>
<\n>[    5.851532] t19x_cache tegra-cache: probed<\r>
<\n>[    5.855947] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU<\r>
<\n>[    5.866730] optee: probing for conduit method.<\r>
<\n>[    5.871318] optee: revision 3.19 (3f29c61f)<\r>
<\n>[    5.872096] optee: dynamic shared memory is enabled<\r>
<\n>[    5.881521] optee: initialized driver<\r>
<\n>[    5.896981] nvpmodel: initialized successfully<\r>
<\n>[    5.901673] tegra_hv: get_hvd: not initialized yet<\r>
<\n>[    5.906610] user_ivc_mempool: hypervisor not present<\r>
<\n>[    5.912476] usbcore: registered new interface driver snd-usb-audio<\r>
<\n>[    5.919629] u32 classifier<\r>
<\n>[    5.922406]     input device check on<\r>
<\n>[    5.926171]     Actions configured<\r>
<\n>[    5.929809] Initializing XFRM netlink socket<\r>
<\n>[    5.934617] NET: Registered protocol family 10<\r>
<\n>[    5.940683] Segment Routing with IPv6<\r>
<\n>[    5.944498] NET: Registered protocol family 17<\r>
<\n>[    5.949083] NET: Registered protocol family 15<\r>
<\n>[    5.953698] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.<\r>
<\n>[    5.967641] Bluetooth: RFCOMM socket layer initialized<\r>
<\n>[    5.972960] Bluetooth: RFCOMM ver 1.11<\r>
<\n>[    5.976825] Bluetooth: HIDP (Human Interface Emulation) ver 1.2<\r>
<\n>[    5.982912] Bluetooth: HIDP socket layer initialized<\r>
<\n>[    5.988752] 9pnet: Installing 9P2000 support<\r>
<\n>[    5.993208] Key type dns_resolver registered<\r>
<\n>[    5.998325] registered taskstats version 1<\r>
<\n>[    6.002550] Loading compiled-in X.509 certificates<\r>
<\n>[    6.018171] Loaded X.509 cert 'Build time autogenerated kernel key: e63fb224cdc2a940ac382bb67b420fcb52cc4aee'<\r>
<\n>[    6.028715] tegra194-pcie 14100000.pcie: Adding to iommu group 8<\r>
<\n>[    6.041817] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator<\r>
<\n>[    6.049081] tegra194-pcie 14160000.pcie: Adding to iommu group 9<\r>
<\n>[    6.061698] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator<\r>
<\n>[    6.068780] tegra194-pcie 141e0000.pcie: Adding to iommu group 10<\r>
<\n>[    6.081044] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator<\r>
<\n>[    6.087984] tegra194-pcie 140a0000.pcie: Adding to iommu group 11<\r>
<\n>[    6.100369] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator<\r>
<\n>[    6.133843] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 12<\r>
<\n>[    6.144556] host1x 13e40000.host1x: Adding to iommu group 13<\r>
<\n>[    6.178150] host1x 13e40000.host1x: initialized<\r>
<\n>[    6.183280] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 14<\r>
<\n>[    6.191329] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)<\r>
<\n>[    6.203623] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 15<\r>
<\n>[    6.211592] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)<\r>
<\n>[    6.223861] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 16<\r>
<\n>[    6.231848] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)<\r>
<\n>[    6.244129] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 17<\r>
<\n>[    6.252096] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)<\r>
<\n>[    6.264372] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 18<\r>
<\n>[    6.272375] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)<\r>
<\n>[    6.284659] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 19<\r>
<\n>[    6.292641] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)<\r>
<\n>[    6.304930] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 20<\r>
<\n>[    6.312917] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)<\r>
<\n>[    6.325187] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 21<\r>
<\n>[    6.333169] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)<\r>
<\n>[    6.345456] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 22<\r>
<\n>[    6.353441] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)<\r>
<\n>[    6.365710] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 23<\r>
<\n>[    6.373685] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)<\r>
<\n>[    6.385967] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 24<\r>
<\n>[    6.393979] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)<\r>
<\n>[    6.406243] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 25<\r>
<\n>[    6.414241] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)<\r>
<\n>[    6.426492] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 26<\r>
<\n>[    6.434456] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)<\r>
<\n>[    6.446732] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 27<\r>
<\n>[    6.454687] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)<\r>
<\n>[    6.466946] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 28<\r>
<\n>[    6.474930] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)<\r>
<\n>[    6.487216] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 29<\r>
<\n>[    6.495212] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)<\r>
<\n>[    6.507587] falcon 15340000.vic: Adding to iommu group 30<\r>
<\n>[    6.518419] falcon 15340000.vic: initialized<\r>
<\n>[    6.523168] falcon 15380000.nvjpg: Adding to iommu group 31<\r>
<\n>[    6.532551] falcon 15380000.nvjpg: initialized<\r>
<\n>[    6.537263] falcon 15540000.nvjpg1: Adding to iommu group 32<\r>
<\n>[    6.546151] falcon 15540000.nvjpg1: initialized<\r>
<\n>[    6.550961] falcon 154c0000.nvenc: Adding to iommu group 33<\r>
<\n>[    6.560594] falcon 154c0000.nvenc: _opp_is_duplicate: duplicate OPPs detected. Existing: freq: 115200000, volt: 0, enabled: 1. New: freq: 115200000, volt: 0, enabled: 1<\r>
<\n>[    6.576810] falcon 154c0000.nvenc: initialized<\r>
<\n>[    6.581519] falcon 15a50000.ofa: Adding to iommu group 34<\r>
<\n>[    6.590597] falcon 15a50000.ofa: initialized<\r>
<\n>[    6.595135] nvdec 15480000.nvdec: Adding to iommu group 35<\r>
<\n>[    6.606771] nvdec 15480000.nvdec: initialized<\r>
<\n>[    6.611401] tsec 15500000.tsec: Adding to iommu group 36<\r>
<\n>[    6.621337] tsec 15500000.tsec: initialized<\r>
<\n>[    6.628875] gic 2a41000.agic-controller: GIC IRQ controller registered<\r>
<\n>[    6.646530] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered<\r>
<\n>[    6.662050] gpio-397 (camera-control-output-low): hogged as output/low<\r>
<\n>[    6.668820] gpio-486 (camera-control-output-low): hogged as output/low<\r>
<\n>[    6.676640] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio<\r>
<\n>[    6.683983] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon<\r>
<\n>[    6.690969] tegra-pwm 3280000.pwm: PWM clk can sleep in ops<\r>
<\n>[    6.697554] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops<\r>
<\n>[    6.704044] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops<\r>
<\n>[    6.712404] tegra194-isp5 14800000.isp: Adding to iommu group 37<\r>
<\n>[    6.721056] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU<\r>
<\n>[    6.730472] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized<\r>
<\n>[    6.736923] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound<\r>
<\n>[    6.746145] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound<\r>
<\n>[    6.755525] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 38<\r>
<\n>[    6.763656] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 39<\r>
<\n>[    6.771613] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU<\r>
<\n>[    6.781358] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized<\r>
<\n>[    6.788172] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU<\r>
<\n>[    6.797755] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized<\r>
<\n>[    6.804562] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU<\r>
<\n>[    6.814538] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized<\r>
<\n>[    6.821382] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 40<\r>
<\n>[    6.830025] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18, iommu=smmu.0x0000000008000000)<\r>
<\n>[    6.841402] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 41<\r>
<\n>[    6.850025] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19, iommu=smmu.0x0000000008000000)<\r>
<\n>[    6.861382] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 42<\r>
<\n>[    6.869994] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20, iommu=smmu.0x0000000008000000)<\r>
<\n>[    6.881362] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 43<\r>
<\n>[    6.889982] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21, iommu=smmu.0x0000000008000000)<\r>
<\n>[    6.901350] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to iommu group 44<\r>
<\n>[    6.909988] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized (streamid=22, iommu=smmu.0x0000000008000000)<\r>
<\n>[    6.921342] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to iommu group 45<\r>
<\n>[    6.929944] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized (streamid=23, iommu=smmu.0x0000000008000000)<\r>
<\n>[    6.941304] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to iommu group 46<\r>
<\n>[    6.949918] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized (streamid=24, iommu=smmu.0x0000000008000000)<\r>
<\n>[    6.961279] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to iommu group 47<\r>
<\n>[    6.969891] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized (streamid=25, iommu=smmu.0x0000000008000000)<\r>
<\n>[    6.981248] pva 16000000.pva0: Adding to iommu group 48<\r>
<\n>[    6.987092] nvdla 15880000.nvdla0: Adding to iommu group 49<\r>
<\n>[    6.993183] nvdla 158c0000.nvdla1: Adding to iommu group 50<\r>
<\n>[    6.999376] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 2<\r>
<\n>[    7.006912] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels<\r>
<\n>[    7.014415] tegra-fuse-burn efuse-burn: shutdown limit check disabled<\r>
<\n>[    7.021041] tegra-fuse-burn efuse-burn: Fuse burn driver initialized<\r>
<\n>[    7.027771] serial-tegra 3100000.serial: Adding to iommu group 2<\r>
<\n>[    7.035021] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 17, base_baud = 0) is a TEGRA_UART<\r>
<\n>[    7.045020] serial-tegra 3130000.serial: Adding to iommu group 2<\r>
<\n>[    7.052232] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 63, base_baud = 0) is a TEGRA_UART<\r>
<\n>[    7.061893] serial-tegra 3140000.serial: Adding to iommu group 2<\r>
<\n>[    7.069109] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 64, base_baud = 0) is a TEGRA_UART<\r>
<\n>[    7.097267] tegra-xusb 3610000.xhci: Firmware timestamp: 2021-12-01 05:27:10 UTC, Version: 80.03 release<\r>
<\n>[    7.107022] tegra-xusb 3610000.xhci: xHCI Host Controller<\r>
<\n>[    7.112597] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1<\r>
<\n>[    7.121276] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810<\r>
<\n>[    7.130910] tegra-xusb 3610000.xhci: irq 230, io mem 0x03610000<\r>
<\n>[    7.137360] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10<\r>
<\n>[    7.145863] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1<\r>
<\n>[    7.153294] usb usb1: Product: xHCI Host Controller<\r>
<\n>[    7.158299] usb usb1: Manufacturer: Linux 5.10.104-tegra xhci-hcd<\r>
<\n>[    7.164561] usb usb1: SerialNumber: 3610000.xhci<\r>
<\n>[    7.170042] hub 1-0:1.0: USB hub found<\r>
<\n>[    7.173923] hub 1-0:1.0: 4 ports detected<\r>
<\n>[    7.178312] tegra-xusb 3610000.xhci: xHCI Host Controller<\r>
<\n>[    7.183875] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2<\r>
<\n>[    7.191665] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed<\r>
<\n>[    7.199187] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10<\r>
<\n>[    7.207698] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1<\r>
<\n>[    7.215128] usb usb2: Product: xHCI Host Controller<\r>
<\n>[    7.220135] usb usb2: Manufacturer: Linux 5.10.104-tegra xhci-hcd<\r>
<\n>[    7.226401] usb usb2: SerialNumber: 3610000.xhci<\r>
<\n>[    7.231709] hub 2-0:1.0: USB hub found<\r>
<\n>[    7.235593] hub 2-0:1.0: 4 ports detected<\r>
<\n>[    7.260873] i2c i2c-2: Added multiplexed i2c bus 9<\r>
<\n>[    7.266555] i2c i2c-2: Added multiplexed i2c bus 10<\r>
<\n>[    7.271583] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter<\r>
<\n>[    7.278559] tegra23x-oc-event soctherm-oc-event: Finished tegra23x overcurrent event probing<\r>
<\n>[    7.300108] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1554000 KHz, changing to: 1510400 KHz<\r>
<\n>[    7.314323] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 1479000 KHz, changing to: 1497600 KHz<\r>
<\n>[    7.327110] tegra194-cpufreq e000000.ccplex: probed with ICC<\r>
<\n>[    7.334892] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator<\r>
<\n>[    7.335983] sdhci-tegra 3400000.sdhci: Got CD GPIO<\r>
<\n>[    7.342711] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:<\r>
<\n>[    7.353463] tegra194-pcie 14100000.pcie:       IO 0x0030100000..0x00301fffff -> 0x0030100000<\r>
<\n>[    7.355897] irq: IRQ294: trimming hierarchy from :interrupt-controller@f400000-1<\r>
<\n>[    7.362150] tegra194-pcie 14100000.pcie:      MEM 0x20a8000000..0x20afffffff -> 0x0040000000<\r>
<\n>[    7.369839] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 294<\r>
<\n>[    7.378470] tegra194-pcie 14100000.pcie:      MEM 0x2080000000..0x20a7ffffff -> 0x2080000000<\r>
<\n>[    7.443070] usb 1-2: new high-speed USB device number 2 using tegra-xusb<\r>
<\n>[    7.499254] tegra194-pcie 14100000.pcie: Link up<\r>
<\n>[    7.505654] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00<\r>
<\n>[    7.512462] pci_bus 0001:00: root bus resource [bus 00-ff]<\r>
<\n>[    7.518099] pci_bus 0001:00: root bus resource [io  0x0000-0xfffff] (bus address [0x30100000-0x301fffff])<\r>
<\n>[    7.527929] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])<\r>
<\n>[    7.538758] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]<\r>
<\n>[    7.546693] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400<\r>
<\n>[    7.553042] pci 0001:00:00.0: PME# supported from D0 D3hot<\r>
<\n>[    7.564241] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000<\r>
<\n>[    7.570577] pci 0001:01:00.0: reg 0x10: [io  0x0000-0x00ff]<\r>
<\n>[    7.576509] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]<\r>
<\n>[    7.584990] pci 0001:01:00.0: supports D1 D2<\r>
<\n>[    7.589384] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold<\r>
<\n>[    7.601548] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]<\r>
<\n>[    7.608979] pci 0001:00:00.0: BAR 13: assigned [io  0x1000-0x1fff]<\r>
<\n>[    7.615329] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff 64bit]<\r>
<\n>[    7.622769] usb 1-2: New USB device found, idVendor=0bda, idProduct=5489, bcdDevice= 1.40<\r>
<\n>[    7.623326] pci 0001:01:00.0: BAR 0: assigned [io  0x1000-0x10ff]<\r>
<\n>[    7.631673] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0<\r>
<\n>[    7.637983] pci 0001:00:00.0: PCI bridge to [bus 01-ff]<\r>
<\n>[    7.645299] usb 1-2: Product: 4-Port USB 2.0 Hub<\r>
<\n>[    7.650668] pci 0001:00:00.0:   bridge window [io  0x1000-0x1fff]<\r>
<\n>[    7.655413] usb 1-2: Manufacturer: Generic<\r>
<\n>[    7.661678] pci 0001:00:00.0:   bridge window [mem 0x20a8000000-0x20a80fffff]<\r>
<\n>[    7.668726] hub 1-2:1.0: USB hub found<\r>
<\n>[    7.673240] pci 0001:00:00.0: Max Payload Size set to  128/ 256 (was  256), Max Read Rq  512<\r>
<\n>[    7.678475] hub 1-2:1.0: 4 ports detected<\r>
<\n>[    7.685851] pci 0001:01:00.0: Max Payload Size set to  128/ 128 (was  128), Max Read Rq  512<\r>
<\n>[    7.698978] pcieport 0001:00:00.0: Adding to iommu group 8<\r>
<\n>[    7.704933] pcieport 0001:00:00.0: PME: Signaling with IRQ 55<\r>
<\n>[    7.711162] pcieport 0001:00:00.0: AER: enabled with IRQ 55<\r>
<\n>[    7.718107] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator<\r>
<\n>[    7.725854] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:<\r>
<\n>[    7.733030] tegra194-pcie 14160000.pcie:       IO 0x0036100000..0x00361fffff -> 0x0036100000<\r>
<\n>[    7.739869] usb 2-1: new SuperSpeedPlus Gen 2 USB device number 2 using tegra-xusb<\r>
<\n>[    7.741712] tegra194-pcie 14160000.pcie:      MEM 0x2428000000..0x242fffffff -> 0x0040000000<\r>
<\n>[    7.758153] tegra194-pcie 14160000.pcie:      MEM 0x2140000000..0x2427ffffff -> 0x2140000000<\r>
<\n>[    7.786326] usb 2-1: New USB device found, idVendor=0bda, idProduct=0489, bcdDevice= 1.40<\r>
<\n>[    7.794754] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0<\r>
<\n>[    7.802096] usb 2-1: Product: 4-Port USB 3.0 Hub<\r>
<\n>[    7.806838] usb 2-1: Manufacturer: Generic<\r>
<\n>[    7.820353] hub 2-1:1.0: USB hub found<\r>
<\n>[    7.825690] hub 2-1:1.0: 4 ports detected<\r>
<\n>[    7.903256] usb 1-3: new full-speed USB device number 3 using tegra-xusb<\r>
<\n>[    8.064884] usb 1-3: New USB device found, idVendor=13d3, idProduct=3549, bcdDevice= 0.00<\r>
<\n>[    8.073300] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3<\r>
<\n>[    8.080639] usb 1-3: Product: Bluetooth Radio<\r>
<\n>[    8.085114] usb 1-3: Manufacturer: Realtek<\r>
<\n>[    8.089330] usb 1-3: SerialNumber: 00e04c000001<\r>
<\n>[    8.387069] usb 1-2.1: new high-speed USB device number 4 using tegra-xusb<\r>
<\n>[    8.501402] usb 1-2.1: New USB device found, idVendor=2109, idProduct=2817, bcdDevice=90.23<\r>
<\n>[    8.510004] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0<\r>
<\n>[    8.517529] usb 1-2.1: Product: USB2.0 Hub             <\r>
<\n>[    8.522910] usb 1-2.1: Manufacturer: VIA Labs, Inc.         <\r>
<\n>[    8.529933] hub 1-2.1:1.0: USB hub found<\r>
<\n>[    8.534399] hub 1-2.1:1.0: 4 ports detected<\r>
<\n>[    8.601973] usb 2-1.1: new SuperSpeed Gen 1 USB device number 3 using tegra-xusb<\r>
<\n>[    8.675114] usb 2-1.1: New USB device found, idVendor=2109, idProduct=0817, bcdDevice=90.23<\r>
<\n>[    8.683699] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0<\r>
<\n>[    8.691212] usb 2-1.1: Product: USB3.0 Hub             <\r>
<\n>[    8.696582] usb 2-1.1: Manufacturer: VIA Labs, Inc.         <\r>
<\n>[    8.710456] hub 2-1.1:1.0: USB hub found<\r>
<\n>[    8.715858] hub 2-1.1:1.0: 4 ports detected<\r>
<\n>[    8.859491] tegra194-pcie 14160000.pcie: Phy link never came up<\r>
<\n>[    8.865680] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00<\r>
<\n>[    8.872491] pci_bus 0004:00: root bus resource [bus 00-ff]<\r>
<\n>[    8.878127] pci_bus 0004:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])<\r>
<\n>[    8.888225] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])<\r>
<\n>[    8.899045] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]<\r>
<\n>[    8.906980] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400<\r>
<\n>[    8.913321] pci 0004:00:00.0: PME# supported from D0 D3hot<\r>
<\n>[    8.928642] pci 0004:00:00.0: PCI bridge to [bus 01-ff]<\r>
<\n>[    8.934032] pci 0004:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512<\r>
<\n>[    8.943104] pcieport 0004:00:00.0: Adding to iommu group 9<\r>
<\n>[    8.949047] pcieport 0004:00:00.0: PME: Signaling with IRQ 57<\r>
<\n>[    8.955570] pcieport 0004:00:00.0: AER: enabled with IRQ 57<\r>
<\n>[    8.961586] pci_bus 0004:01: busn_res: [bus 01-ff] is released<\r>
<\n>[    8.967705] pci 0004:00:00.0: Removing from iommu group 9<\r>
<\n>[    8.973262] pci_bus 0004:00: busn_res: [bus 00-ff] is released<\r>
<\n>[    8.981254] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator<\r>
<\n>[    8.988854] tegra194-pcie 141e0000.pcie: host bridge /pcie@141e0000 ranges:<\r>
<\n>[    8.996029] tegra194-pcie 141e0000.pcie:       IO 0x003e100000..0x003e1fffff -> 0x003e100000<\r>
<\n>[    9.004716] tegra194-pcie 141e0000.pcie:      MEM 0x3228000000..0x322fffffff -> 0x0040000000<\r>
<\n>[    9.013394] tegra194-pcie 141e0000.pcie:      MEM 0x2e40000000..0x3227ffffff -> 0x2e40000000<\r>
<\n>[    9.267057] usb 1-2.1.4: new full-speed USB device number 5 using tegra-xusb<\r>
<\n>[    9.433019] usb 1-2.1.4: New USB device found, idVendor=0b95, idProduct=6802, bcdDevice= 0.12<\r>
<\n>[    9.441791] usb 1-2.1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3<\r>
<\n>[    9.449484] usb 1-2.1.4: Product: AX68002<\r>
<\n>[    9.453600] usb 1-2.1.4: Manufacturer:  MTK Electronics<\r>
<\n>[    9.458968] usb 1-2.1.4: SerialNumber: 00000001<\r>
<\n>[    9.465174] hub 1-2.1.4:1.0: USB hub found<\r>
<\n>[    9.470767] hub 1-2.1.4:1.0: 7 ports detected<\r>
<\n>[    9.779055] usb 1-2.1.4.6: new full-speed USB device number 6 using tegra-xusb<\r>
<\n>[    9.898844] usb 1-2.1.4.6: New USB device found, idVendor=0b95, idProduct=6801, bcdDevice= 0.02<\r>
<\n>[    9.907787] usb 1-2.1.4.6: New USB device strings: Mfr=1, Product=2, SerialNumber=3<\r>
<\n>[    9.915665] usb 1-2.1.4.6: Product: AX68002<\r>
<\n>[    9.919962] usb 1-2.1.4.6: Manufacturer: ASIX Electronics<\r>
<\n>[    9.925504] usb 1-2.1.4.6: SerialNumber: 00000001<\r>
<\n>[    9.939654] input: ASIX Electronics AX68002 as /devices/platform/3610000.xhci/usb1/1-2/1-2.1/1-2.1.4/1-2.1.4.6/1-2.1.4.6:1.0/0003:0B95:6801.0001/input/input0<\r>
<\n>[   10.011779] hid-generic 0003:0B95:6801.0001: input,hidraw0: USB HID v1.10 Keyboard [ASIX Electronics AX68002] on usb-3610000.xhci-2.1.4.6/input0<\r>
<\n>[   10.030509] input: ASIX Electronics AX68002 as /devices/platform/3610000.xhci/usb1/1-2/1-2.1/1-2.1.4/1-2.1.4.6/1-2.1.4.6:1.1/0003:0B95:6801.0002/input/input1<\r>
<\n>[   10.045729] input: ASIX Electronics AX68002 System Control as /devices/platform/3610000.xhci/usb1/1-2/1-2.1/1-2.1.4/1-2.1.4.6/1-2.1.4.6:1.1/0003:0B95:6801.0002/input/input2<\r>
<\n>[   10.111059] tegra194-pcie 141e0000.pcie: Phy link never came up<\r>
<\n>[   10.117209] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00<\r>
<\n>[   10.124031] pci_bus 0007:00: root bus resource [bus 00-ff]<\r>
<\n>[   10.129715] input: ASIX Electronics AX68002 Consumer Control as /devices/platform/3610000.xhci/usb1/1-2/1-2.1/1-2.1.4/1-2.1.4.6/1-2.1.4.6:1.1/0003:0B95:6801.0002/input/input3<\r>
<\n>[   10.145714] pci_bus 0007:00: root bus resource [io  0x200000-0x2fffff] (bus address [0x3e100000-0x3e1fffff])<\r>
<\n>[   10.155828] pci_bus 0007:00: root bus resource [mem 0x3228000000-0x322fffffff] (bus address [0x40000000-0x47ffffff])<\r>
<\n>[   10.166656] pci_bus 0007:00: root bus resource [mem 0x2e40000000-0x3227ffffff pref]<\r>
<\n>[   10.174525] hid-generic 0003:0B95:6801.0002: input,hidraw1: USB HID v1.10 Mouse [ASIX Electronics AX68002] on usb-3610000.xhci-2.1.4.6/input1<\r>
<\n>[   10.187685] pci 0007:00:00.0: [10de:229a] type 01 class 0x060400<\r>
<\n>[   10.194031] pci 0007:00:00.0: PME# supported from D0 D3hot<\r>
<\n>[   10.203135] input: ASIX Electronics AX68002 as /devices/platform/3610000.xhci/usb1/1-2/1-2.1/1-2.1.4/1-2.1.4.6/1-2.1.4.6:1.2/0003:0B95:6801.0003/input/input4<\r>
<\n>[   10.224299] pci 0007:00:00.0: PCI bridge to [bus 01-ff]<\r>
<\n>[   10.229725] pci 0007:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512<\r>
<\n>[   10.238842] pcieport 0007:00:00.0: Adding to iommu group 10<\r>
<\n>[   10.244906] hid-generic 0003:0B95:6801.0003: input,hidraw2: USB HID v1.10 Mouse [ASIX Electronics AX68002] on usb-3610000.xhci-2.1.4.6/input2<\r>
<\n>[   10.258006] pcieport 0007:00:00.0: PME: Signaling with IRQ 59<\r>
<\n>[   10.264561] pcieport 0007:00:00.0: AER: enabled with IRQ 59<\r>
<\n>[   10.270548] pci_bus 0007:01: busn_res: [bus 01-ff] is released<\r>
<\n>[   10.276664] pci 0007:00:00.0: Removing from iommu group 10<\r>
<\n>[   10.282312] pci_bus 0007:00: busn_res: [bus 00-ff] is released<\r>
<\n>[   10.290323] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator<\r>
<\n>[   10.297237] vdd-3v3-sd: supplied by vdd-3v3<\r>
<\n>[   10.303918] tegra194-isp5 14800000.isp: initialized<\r>
<\n>[   10.315511] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized<\r>
<\n>[   10.321981] (NULL device *): fops function table already registered<\r>
<\n>[   10.329419] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized<\r>
<\n>[   10.337012] sdhci-tegra 3400000.sdhci: Got CD GPIO<\r>
<\n>[   10.337014] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator<\r>
<\n>[   10.337470] irq: IRQ295: trimming hierarchy from :interrupt-controller@f400000-1<\r>
<\n>[   10.357016] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 294<\r>
<\n>[   10.464255] tegra194-pcie 140a0000.pcie: host bridge /pcie@140a0000 ranges:<\r>
<\n>[   10.471427] tegra194-pcie 140a0000.pcie:       IO 0x002a100000..0x002a1fffff -> 0x002a100000<\r>
<\n>[   10.480109] tegra194-pcie 140a0000.pcie:      MEM 0x3528000000..0x352fffffff -> 0x0040000000<\r>
<\n>[   10.488787] tegra194-pcie 140a0000.pcie:      MEM 0x3240000000..0x3527ffffff -> 0x3240000000<\r>
<\n>[   10.603256] tegra194-pcie 140a0000.pcie: Link up<\r>
<\n>[   10.611906] tegra194-pcie 140a0000.pcie: PCI host bridge to bus 0008:00<\r>
<\n>[   10.618714] pci_bus 0008:00: root bus resource [bus 00-ff]<\r>
<\n>[   10.624352] pci_bus 0008:00: root bus resource [io  0x300000-0x3fffff] (bus address [0x2a100000-0x2a1fffff])<\r>
<\n>[   10.634468] pci_bus 0008:00: root bus resource [mem 0x3528000000-0x352fffffff] (bus address [0x40000000-0x47ffffff])<\r>
<\n>[   10.645298] pci_bus 0008:00: root bus resource [mem 0x3240000000-0x3527ffffff pref]<\r>
<\n>[   10.653220] pci 0008:00:00.0: [10de:229c] type 01 class 0x060400<\r>
<\n>[   10.659538] pci 0008:00:00.0: PME# supported from D0 D3hot<\r>
<\n>[   10.670552] pci 0008:01:00.0: [10ec:8168] type 00 class 0x020000<\r>
<\n>[   10.676874] pci 0008:01:00.0: reg 0x10: [io  0x0000-0x00ff]<\r>
<\n>[   10.682798] pci 0008:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]<\r>
<\n>[   10.689900] pci 0008:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]<\r>
<\n>[   10.697948] pci 0008:01:00.0: supports D1 D2<\r>
<\n>[   10.702343] pci 0008:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold<\r>
<\n>[   10.714471] pci 0008:00:00.0: BAR 14: assigned [mem 0x3528000000-0x35280fffff]<\r>
<\n>[   10.721900] pci 0008:00:00.0: BAR 13: assigned [io  0x300000-0x300fff]<\r>
<\n>[   10.728601] pci 0008:01:00.0: BAR 4: assigned [mem 0x3528000000-0x3528003fff 64bit]<\r>
<\n>[   10.736568] pci 0008:01:00.0: BAR 2: assigned [mem 0x3528004000-0x3528004fff 64bit]<\r>
<\n>[   10.744533] pci 0008:01:00.0: BAR 0: assigned [io  0x300000-0x3000ff]<\r>
<\n>[   10.751177] pci 0008:00:00.0: PCI bridge to [bus 01-ff]<\r>
<\n>[   10.756543] pci 0008:00:00.0:   bridge window [io  0x300000-0x300fff]<\r>
<\n>[   10.763162] pci 0008:00:00.0:   bridge window [mem 0x3528000000-0x35280fffff]<\r>
<\n>[   10.770512] pci 0008:00:00.0: Max Payload Size set to  128/ 256 (was  256), Max Read Rq  512<\r>
<\n>[   10.779252] pci 0008:01:00.0: Max Payload Size set to  128/ 128 (was  128), Max Read Rq  512<\r>
<\n>[   10.788311] pcieport 0008:00:00.0: Adding to iommu group 11<\r>
<\n>[   10.794370] pcieport 0008:00:00.0: PME: Signaling with IRQ 61<\r>
<\n>[   10.800907] pcieport 0008:00:00.0: AER: enabled with IRQ 61<\r>
<\n>[   10.807661] pva 16000000.pva0: deferred probe timeout, ignoring dependency<\r>
<\n>[   10.814762] pva: probe of 16000000.pva0 failed with error -110<\r>
<\n>[   10.820858] nvdla 15880000.nvdla0: deferred probe timeout, ignoring dependency<\r>
<\n>[   10.828288] nvdla: probe of 15880000.nvdla0 failed with error -110<\r>
<\n>[   10.834728] nvdla 158c0000.nvdla1: deferred probe timeout, ignoring dependency<\r>
<\n>[   10.842159] nvdla: probe of 158c0000.nvdla1 failed with error -110<\r>
<\n>[   10.850018] irq: IRQ297: trimming hierarchy from :pmc@c360000<\r>
<\n>[   10.856000] irq: IRQ298: trimming hierarchy from :interrupt-controller@f400000-1<\r>
<\n>[   10.863733] input: gpio-keys as /devices/platform/gpio-keys/input/input5<\r>
<\n>[   10.871449] tegra-se-nvhost 15810000.se: Adding to iommu group 51<\r>
<\n>[   10.878215] tegra-se-nvhost 15810000.se: initialized<\r>
<\n>[   10.893085] tegra-se-nvhost 15810000.se: tegra_se_probe: complete<\r>
<\n>[   10.899498] tegra-se-nvhost 15820000.se: Adding to iommu group 52<\r>
<\n>[   10.906104] tegra-se-nvhost 15820000.se: initialized<\r>
<\n>[   10.914615] tegra-se-nvhost 15820000.se: tegra_se_probe: complete<\r>
<\n>[   10.921019] tegra-se-nvhost 15840000.se: Adding to iommu group 53<\r>
<\n>[   10.927630] tegra-se-nvhost 15840000.se: initialized<\r>
<\n>[   10.936948] tegra-se-nvhost 15840000.se: tegra_se_probe: complete<\r>
<\n>[   10.943932] tegra_actmon d230000.actmon: in actmon_register()...<\r>
<\n>[   10.950284] tegra_actmon d230000.actmon: bwmgr_disable = 1<\r>
<\n>[   10.956666] tegra_actmon d230000.actmon: initialization Completed for the device mc_all<\r>
<\n>[   10.965078] hvc_sysfs: hypervisor is not present<\r>
<\n>[   11.005917] ALSA device list:<\r>
<\n>[   11.008969]   No soundcards found.<\r>
<\n>[   11.013324] Freeing unused kernel memory: 3968K<\r>
<\n>[   11.018047] Run /init as init process<\r>
<\n>[   11.037918] Root device found: mmcblk1p1<\r>
<\n>[   11.403415] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit<\r>
<\n>[   11.822039] mmc1: new ultra high speed SDR104 SDXC card at address 59b4<\r>
<\n>[   11.829338] mmcblk1: mmc1:59b4 FD4Q5 119 GiB <\r>
<\n>[   11.976370]  mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14<\r>
<\n>[   12.057040] Found dev node: /dev/mmcblk1p1<\r>
<\n>[   12.547563] EXT4-fs (mmcblk1p1): warning: mounting fs with errors, running e2fsck is recommended<\r>
<\n>[   12.560176] EXT4-fs (mmcblk1p1): Errors on filesystem, clearing orphan list.<\r>
<\n>[   12.560176] <\r>
<\n>[   12.568968] EXT4-fs (mmcblk1p1): recovery complete<\r>
<\n>[   12.712970] EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Opts: (null)<\r>
<\n>[   12.722841] Rootfs mounted over mmcblk1p1<\r>
<\n>[   12.879599] Switching from initrd to actual rootfs<\r>
<\n>[   13.127108] systemd[1]: System time before build time, advancing clock.<\r>
<\n>[   13.351490] systemd[1]: systemd 245.4-4ubuntu3.21 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)<\r>
<\n>[   13.375350] systemd[1]: Detected architecture arm64.<\r>
<\n>[   13.473680] random: crng init done<\r>
<\n>[   13.709626] systemd[1]: Set hostname to <CabinControl>.<\r>
<\n>[   13.804487] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #1049937: comm systemd-sysv-ge: iget: checksum invalid<\r>
<\n>[   13.851256] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #1049937: comm systemd: iget: checksum invalid<\r>
<\n>[   13.864146] systemd[1]: Failed to resolve symlink /etc/systemd/system/sshd.service pointing to /lib/systemd/system/ssh.service, ignoring: Bad message<\r>
<\n>[   14.030816] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #1049937: comm systemd: iget: checksum invalid<\r>
<\n>[   14.088546] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #1049937: comm systemd: iget: checksum invalid<\r>
<\n>[   14.125040] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #1049937: comm systemd: iget: checksum invalid<\r>
<\n>[   14.138207] systemd[1]: ssh.service: Failed to open /lib/systemd/system/ssh.service: Bad message<\r>
<\n>[   14.241075] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.<\r>
<\n>[   14.254107] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)<\r>
<\n>[   14.264513] systemd[1]: Created slice system-modprobe.slice.<\r>
<\n>[   14.283604] systemd[1]: Created slice system-serial\x2dgetty.slice.<\r>
<\n>[   14.303570] systemd[1]: Created slice User and Session Slice.<\r>
<\n>[   14.323202] systemd[1]: Started Forward Password Requests to Wall Directory Watch.<\r>
<\n>[   14.347501] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.<\r>
<\n>[   14.371166] systemd[1]: Reached target User and Group Name Lookups.<\r>
<\n>[   14.391099] systemd[1]: Reached target Slices.<\r>
<\n>[   14.407091] systemd[1]: Reached target Mounting snaps.<\r>
<\n>[   14.427093] systemd[1]: Reached target Swap.<\r>
<\n>[   14.443491] systemd[1]: Listening on RPCbind Server Activation Socket.<\r>
<\n>[   14.463240] systemd[1]: Listening on Syslog Socket.<\r>
<\n>[   14.483224] systemd[1]: Listening on fsck to fsckd communication Socket.<\r>
<\n>[   14.507171] systemd[1]: Listening on initctl Compatibility Named Pipe.<\r>
<\n>[   14.527400] systemd[1]: Listening on Journal Audit Socket.<\r>
<\n>[   14.547212] systemd[1]: Listening on Journal Socket (/dev/log).<\r>
<\n>[   14.567254] systemd[1]: Listening on Journal Socket.<\r>
<\n>[   14.587259] systemd[1]: Listening on udev Control Socket.<\r>
<\n>[   14.607179] systemd[1]: Listening on udev Kernel Socket.<\r>
<\n>[   14.629032] systemd[1]: Mounting Huge Pages File System...<\r>
<\n>[   14.649354] systemd[1]: Mounting POSIX Message Queue File System...<\r>
<\n>[   14.672897] systemd[1]: Mounting RPC Pipe File System...<\r>
<\n>[   14.692955] systemd[1]: Mounting Kernel Debug File System...<\r>
<\n>[   14.712968] systemd[1]: Mounting Kernel Trace File System...<\r>
<\n>[   14.733334] systemd[1]: Starting Journal Service...<\r>
<\n>[   14.753679] systemd[1]: Starting Set the console keyboard layout...<\r>
<\n>[   14.777751] systemd[1]: Starting Create list of static device nodes for the current kernel...<\r>
<\n>[   14.805417] systemd[1]: Starting Load Kernel Module chromeos_pstore...<\r>
<\n>[   14.831178] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.<\r>
<\n>[   14.841616] systemd[1]: Starting Load Kernel Module efi_pstore...<\r>
<\n>[   14.864850] systemd[1]: Starting Load Kernel Module pstore_blk...<\r>
<\n>[   14.888730] systemd[1]: Starting Load Kernel Module pstore_zone...<\r>
<\n>[   14.912666] systemd[1]: Starting Load Kernel Module ramoops...<\r>
<\n>[   14.936929] systemd[1]: Starting NVIDIA specific first-boot udev script...<\r>
<\n>[   14.960811] systemd[1]: Started Nameserver information manager.<\r>
<\n>[   14.987417] systemd[1]: Reached target Network (Pre).<\r>
<\n>[   15.014459] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.<\r>
<\n>[   15.023911] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.<\r>
<\n>[   15.038264] systemd[1]: Starting Load Kernel Modules...<\r>
<\n>[   15.057137] systemd[1]: Starting Remount Root and Kernel File Systems...<\r>
<\n>[   15.065993] nvmap_heap_init: nvmap_heap_init: created heap block cache<\r>
<\n>[   15.070251] EXT4-fs (mmcblk1p1): re-mounted. Opts: (null)<\r>
<\n>[   15.075462] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x0000000249800000,914358272<\r>
<\n>[   15.092378] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout<\r>
<\n>[   15.100624] nvmap_page_pool_init: Total RAM pages: 1659034<\r>
<\n>[   15.106260] nvmap_page_pool_init: nvmap page pool size: 207379 pages (810 MB)<\r>
<\n>[   15.113681] nvmap_background_zero_thread: PP zeroing thread starting.<\r>
<\n>[   15.113865] misc nvmap: created heap vpr base 0x0000000249800000 size (892928KiB)<\r>
<\n>[   15.121484] systemd[1]: Starting udev Coldplug all Devices...<\r>
<\n>[   15.150396] systemd[1]: Started Journal Service.<\r>
<\n>[   15.373247] nvgpu: 17000000.ga10b          nvgpu_nvhost_syncpt_init:135  [INFO]  syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000<\r>
<\n>[   15.373247] <\r>
<\n>[   15.552785] systemd-journald[254]: Received client request to flush runtime journal.<\r>
<\n>[   17.235925] EXT4-fs warning (device mmcblk1p1): ext4_dirblock_csum_verify:377: inode #1959402: comm systemd-tmpfile: No space for directory leaf checksum. Please run e2fsck -D.<\r>
<\n>[   17.256242] EXT4-fs error (device mmcblk1p1): htree_dirblock_to_tree:1003: inode #1959402: comm systemd-tmpfile: Directory block failed checksum<\r>
<\n>[   17.470118] EXT4-fs warning (device mmcblk1p1): ext4_dirblock_csum_verify:377: inode #1959402: comm systemd-tmpfile: No space for directory leaf checksum. Please run e2fsck -D.<\r>
<\n>[   17.477415] nvidia: loading out-of-tree module taints kernel.<\r>
<\n>[   17.489873] EXT4-fs error (device mmcblk1p1): htree_dirblock_to_tree:1003: inode #1959402: comm systemd-tmpfile: Directory block failed checksum<\r>
<\n>[   17.508292] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)<\r>
<\n>[   17.522648] imx219 9-0010: board setup failed<\r>
<\n>[   17.527639] imx219: probe of 9-0010 failed with error -121<\r>
<\n>[   17.547910] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)<\r>
<\n>[   17.578654] imx219 10-0010: board setup failed<\r>
<\n>[   17.589440] imx219: probe of 10-0010 failed with error -121<\r>
<\n>[   17.684928] fusb301 1-0025: toggle_time(0) is not updated<\r>
<\n>[   18.916526] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #927228: comm dbus-daemon: iget: checksum invalid<\r>
<\n>[   18.937434] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #927225: comm dbus-daemon: iget: checksum invalid<\r>
<\n>[   18.968264] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #927226: comm dbus-daemon: iget: checksum invalid<\r>
<\n>[   18.985570] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #927227: comm dbus-daemon: iget: checksum invalid<\r>
<\n>[   19.004829] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #927224: comm dbus-daemon: iget: checksum invalid<\r>
<\n>[   19.032156] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #927222: comm dbus-daemon: iget: checksum invalid<\r>
<\n>[   19.047662] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #927223: comm dbus-daemon: iget: checksum invalid<\r>
<\n>[   19.111915] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #927217: comm nv-l4t-usb-devi: iget: checksum invalid<\r>
<\n>[   19.153504] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #927217: comm nv-l4t-usb-devi: iget: checksum invalid<\r>
<\n>[   19.211470] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #927217: comm nv-l4t-usb-devi: iget: checksum invalid<\r>
<\n>[   24.398993] EXT4-fs error: 55 callbacks suppressed<\r>
<\n>[   24.399000] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #927221: comm dbus-daemon: iget: checksum invalid<\r>
<\n>[   24.685316] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #1049937: comm systemd: iget: checksum invalid<\r>
<\n>[   25.176709] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #1049937: comm systemd: iget: checksum invalid<\r>
<\n><\r>
<\r>
<\r>
<\n>Ubuntu 20.04.6 LTS CabinControl ttyTCU0<\r>
<\r>
<\n><\r>
<\r>
<\n>CabinControl login: [   28.974145] Bridge firewalling registered<\r>
<\n>[   29.016073] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #927221: comm dbus-daemon: iget: checksum invalid<\r>
<\n>[   70.226914] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #927221: comm dbus-daemon: iget: checksum invalid<\r>
<\n>[   78.778790] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #1052174: comm fwupdmgr: iget: checksum invalid<\r>
<\n>[   78.792097] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #1052174: comm fwupdmgr: iget: checksum invalid<\r>
<\n>
This time it happend after a crash during OpenCV. But I use OpenCV only to open cameras and grab frames. No writing to disk.
Just a suggestion. Could you just attach the whole file a a txt file here? This forum can upload file.
I will do next time. I do not have the original anymore.
Incidentally, if you set serial console to log, then the entire log can easily be attached (it beats making multiple logs).
I want to point out these errors (there are a lot):
I don’t know if vdd_cpu is needed or not, but if there is a failing power rail (this might just be reporting vdd_cpu and might not matter), then I can’t see any possibility of success without fixing that (I want to emphasize that I don’t know if vdd_cpu matters).
The following errors are just more suggestions that the filesystem is too corrupt to work:
How did you create the SD card? I’m wondering if you can create another one just like you did, but do not use it on the Jetson. It’s purpose is to check if the filesystem is or is not corrupt after creation. There is a possibility that the content used to create the SD card is bad before you ever start. If not, then we know that the corruption is coming from the failed boot.
Or, if the image is a raw binary image, then you can just cover it with loopback and fsck.ext4 directly to your image.
If your SD card (not the corrupt one, but a new one freshly created) is on your host PC, what do you see from “lsblk -f”? I’m only interested in the part which is from the SD card.
Do you have sdcards from other vendors and also different sizes to try?
