Jetson is not booting after reboot
I have a few Jetson Orins. I am using a docker image to run my custom scripts, DWS to remote access, and crontab jobs to connect to the internet via Simcom Wvan Sim 7600x automatically.
Usually, the device works fine. However, after some time, I am always losing connection to the device. When I change a thing on the device and reboot it via the reboot command, it does not boot up.
I am always using an sd card to boot the device. I tried to install the OS via SDKManager or burn an image that I downloaded from nvidia’s website directly. The result is always the same.
How can I debug this issue? Are there any known issues with Jetson Orin Nano that can cause this problem?
Btw, I have two cameras connected to my system. I have 2 motors, and the device is powered through an AC/DC converter. When I replace the SD card, the device works fine until the next failure.
Thank you for your help in advance.
Please follow this page to dump log.
There is a known issue that some sdcards seem to easily get corrupted filesystem.
Okay, yesterday I lost another device. This time I noticed that the Jetson Board was overheated and even after replacing the SD card it didn’t boot. So I think I completely lost the device this time.
So I will set Serial Debug connection to one of the devices with faulty(?) SD card.
I will boot another Jetson Orin by following this page:
https://jetsonhacks.com/2023/05/26/jetson-orin-nano-flashing-qspi-firmware-for-more-memory/
For another Jetson Orin I will use an SSD instead of an SD card.
Finally, I will use the same SD card with a Jetson Xaiver NX. I hope we can figure out the cause of this issue, but it seems Jetson Orin Nano is not as stable as the previous models.
Just to confirm, is it okay to keep the Jetson Orin Nano running for days without a reboot? Usually, I use 85-90% of the CPU and RAM. Also, I am running a human detection model at each 0.2 seconds on GPU.
I need the serial console log to confirm if you really hit the sdcard issue I mentioned first.
debug_logs.txt (120.5 KB)
Here are the last lines of the serial console log, I am also sharing the full context.
[    8.105380] Freeing unused kernel memory: 3968K
[    8.105594] Run /init as init process
[    8.122602] Root device found: initrd
modprobe: FATAL: Module r8168 not found in directory /lib/modules/5.10.120-tegra
[    8.125283] Mount initrd as rootfs and enter recovery mode
Finding OTA work dir on external storage devices
Checking whether device /dev/mmcblk?p1 exist
Device /dev/mmcblk?p1 does not exist
Checking whether device /dev/sd?1 exist
Device /dev/sd?1 does not exist
Checking whether device /dev/nvme?n1p1 exist
Device /dev/nvme?n1p1 does not exist
Finding OTA work dir on internal storage device
mount /dev/mmcblk0p1 /mnt
mount: /mnt: special device /dev/mmcblk0p1 does not exist.
Failed to mount /dev/mmcblk0p1 on the /mnt
Failed to run "mount_ota_work_partition /dev/mmcblk0p1 /mnt"
OTA work directory is not found on internal and external storage devices
bash: cannot set terminal process group (-1): Inappropriate ioctl for device
bash: no job control in this shell
bash-5.0# [    8.739287] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[    8.965025] mmc1: new ultra high speed SDR104 SDXC card at address 59b4
[    8.965719] mmcblk1: mmc1:59b4 SD128 119 GiB
[    8.968979] GPT:Primary header thinks Alt. header is not at the end of the disk.
[    8.969185] GPT:124735487 != 249670655
[    8.969290] GPT:Alternate GPT header not at the end of the disk.
[    8.969456] GPT:124735487 != 249670655
[    8.969559] GPT: Use GNU Parted to correct GPT errors.
[    8.969724]  mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[   17.760340] random: crng init done
This log is too late.
Please refer to this post to recover your system. Your system is in “recovery image” now.
This image will not show the error log and the reason you are in this situation is previously there are consecutive times of boot failure.
You need to dump the log after you recover from recovery image.
Thanks a lot. All of our devices are active now. It seems they were all in ‘recovery image’. Here are the new logs, I think I have a corrupted file system.
[0000.064] I> MB1 (version: 1.2.0.0-t234-54845784-562369e5)
[0000.069] I> t234-A01-1-Silicon (0x12347) Prod
[0000.073] I> Boot-mode : Coldboot
[0000.076] I> Entry timestamp: 0x00000000
[0000.080] I> last_boot_error: 0x0
[0000.083] I> BR-BCT: preprod_dev_sign: 0
[0000.087] I> rst_source: 0xb, rst_level: 0x1
[0000.091] I> Task: SE error check
[0000.094] I> Task: Bootchain select WAR set
[0000.098] I> Task: Enable SLCG
[0000.101] I> Task: CRC check
[0000.104] I> Task: Initialize MB2 params
[0000.108] I> MB2-params @ 0x40060000
[0000.112] I> Task: Crypto init
[0000.115] I> Task: Perform MB1 KAT tests
[0000.119] I> Task: NVRNG health check
[0000.122] I> NVRNG: Health check success
[0000.126] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.132] I> Task: Enabling and initialization of Bandwidth limiter
[0000.138] I> No request to configure MBWT settings for any PC!
[0000.144] I> Task: Secure debug controls
[0000.148] I> Task: strap war set
[0000.151] I> Task: Initialize SOC Therm
[0000.154] I> Task: Program NV master stream id
[0000.159] I> Task: Verify boot mode
[0000.164] I> Task: Alias fuses
[0000.168] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.175] I> Task: Print SKU type
[0000.178] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c8
[0000.184] I> FUSE_OPT_GPC_DISABLE = 0x00000002
[0000.188] I> FUSE_OPT_TPC_DISABLE = 0x000000f0
[0000.192] I> FUSE_OPT_DLA_DISABLE = 0x00000003
[0000.196] I> FUSE_OPT_PVA_DISABLE = 0x00000001
[0000.201] I> FUSE_OPT_NVENC_DISABLE = 0x00000001
[0000.205] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.210] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0000.214] I> FUSE_OPT_EMC_DISABLE = 0x0000000c
[0000.218] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.222] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.226] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.230] I> FUSE_SKU_INFO_0 = 0xd5
[0000.234] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.238] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.242] I> SKU: Prod
[0000.244] I> Task: Boost clocks
[0000.247] I> Initializing PLLC2 for AXI_CBB.
[0000.251] I> AXI_CBB : src = 35, divisor = 0
[0000.255] I> Task: Voltage monitor
[0000.258] I> VMON: Vmon re-calibration and fine tuning done
[0000.264] I> Task: UPHY init
[0000.269] I> HSIO UPHY init done
[0000.272] W> Skipping GBE UPHY config
[0000.275] I> Task: Boot device init
[0000.279] I> Boot_device: QSPI_FLASH instance: 0
[0000.283] I> Qspi clock source : pllc_out0
[0000.287] I> QSPI Flash: Macronix 64MB
[0000.291] I> QSPI-0l initialized successfully
[0000.295] I> Task: TSC init
[0000.298] I> Task: Load membct
[0000.301] I> RAM_CODE 0x4000421
[0000.304] I> Loading MEMBCT
[0000.307] I> Slot: 0
[0000.309] I> Binary[0] block-3840 (partition size: 0x40000)
[0000.314] I> Binary name: MEM-BCT-0
[0000.317] I> Size of crypto header is 8192
[0000.321] I> Size of crypto header is 8192
[0000.325] I> strt_pg_num(3840) num_of_pgs(16) read_buf(0x40050000)
[0000.332] I> BCH of MEM-BCT-0 read from storage
[0000.336] I> BCH address is : 0x40050000
[0000.340] I> MEM-BCT-0 header integrity check is success
[0000.345] I> Binary magic in BCH component 0 is MEM0
[0000.350] I> component binary type is 0
[0000.353] I> strt_pg_num(3856) num_of_pgs(115) read_buf(0x40040000)
[0000.360] I> MEM-BCT-0 binary is read from storage
[0000.365] I> MEM-BCT-0 binary integrity check is success
[0000.370] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.377] I> RAM_CODE 0x4000421
[0000.382] I> RAM_CODE 0x4000421
[0000.386] I> Task: Load Page retirement list
[0000.390] I> Task: SDRAM params override
[0000.394] I> Task: Save mem-bct info
[0000.398] I> Task: Carveout allocate
[0000.401] I> RCM blob carveout will not be allocated
[0000.406] I> Update CCPLEX IST carveout from MB1-BCT
[0000.411] I> ECC region[0]: Start:0x0, End:0x0
[0000.415] I> ECC region[1]: Start:0x0, End:0x0
[0000.419] I> ECC region[2]: Start:0x0, End:0x0
[0000.423] I> ECC region[3]: Start:0x0, End:0x0
[0000.428] I> ECC region[4]: Start:0x0, End:0x0
[0000.432] I> Non-ECC region[0]: Start:0x80000000, End:0x280000000
[0000.438] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.443] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.447] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.452] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.463] I> allocated(CO:43) base:0x27c000000 size:0x4000000 align: 0x200000
[0000.470] I> allocated(CO:39) base:0x279e00000 size:0x2200000 align: 0x10000
[0000.477] I> allocated(CO:20) base:0x276000000 size:0x2000000 align: 0x2000000
[0000.484] I> allocated(CO:24) base:0x274000000 size:0x2000000 align: 0x2000000
[0000.491] I> allocated(CO:28) base:0x272000000 size:0x2000000 align: 0x2000000
[0000.498] I> allocated(CO:22) base:0x278000000 size:0x1000000 align: 0x1000000
[0000.505] I> allocated(CO:35) base:0x279000000 size:0xe00000 align: 0x10000
[0000.512] I> allocated(CO:02) base:0x271800000 size:0x800000 align: 0x800000
[0000.519] I> allocated(CO:03) base:0x271000000 size:0x800000 align: 0x800000
[0000.526] I> allocated(CO:06) base:0x270800000 size:0x800000 align: 0x800000
[0000.533] I> allocated(CO:56) base:0x270000000 size:0x800000 align: 0x200000
[0000.540] I> allocated(CO:07) base:0x26fc00000 size:0x400000 align: 0x400000
[0000.547] I> allocated(CO:33) base:0x26f800000 size:0x400000 align: 0x200000
[0000.553] I> allocated(CO:23) base:0x26f600000 size:0x200000 align: 0x200000
[0000.560] I> allocated(CO:01) base:0x26f500000 size:0x100000 align: 0x100000
[0000.567] I> allocated(CO:04) base:0x26f400000 size:0x100000 align: 0x100000
[0000.574] I> allocated(CO:05) base:0x26f300000 size:0x100000 align: 0x100000
[0000.581] I> allocated(CO:08) base:0x26f200000 size:0x100000 align: 0x100000
[0000.588] I> allocated(CO:09) base:0x26f100000 size:0x100000 align: 0x100000
[0000.595] I> allocated(CO:15) base:0x26f000000 size:0x100000 align: 0x100000
[0000.602] I> allocated(CO:17) base:0x26ef00000 size:0x100000 align: 0x100000
[0000.609] I> allocated(CO:27) base:0x26ee00000 size:0x100000 align: 0x100000
[0000.616] I> allocated(CO:42) base:0x26ed00000 size:0x100000 align: 0x100000
[0000.623] I> allocated(CO:54) base:0x26ec80000 size:0x80000 align: 0x80000
[0000.630] I> allocated(CO:34) base:0x26ec70000 size:0x10000 align: 0x10000
[0000.636] I> allocated(CO:72) base:0x26ea70000 size:0x200000 align: 0x10000
[0000.643] I> allocated(CO:47) base:0x26e600000 size:0x400000 align: 0x200000
[0000.650] I> allocated(CO:48) base:0x26ea50000 size:0x20000 align: 0x10000
[0000.657] I> allocated(CO:69) base:0x26ea30000 size:0x20000 align: 0x10000
[0000.664] I> allocated(CO:49) base:0x26ea20000 size:0x10000 align: 0x10000
[0000.670] I> allocated(CO:50) base:0x26ea10000 size:0x10000 align: 0x10000
[0000.677] I> NSDRAM base: 0x80000000, end: 0x26ea70000, size: 0x1eea70000
[0000.684] I> Task: Thermal check
[0000.687] I> max_chip_limit = 105
[0000.690] I> min_chip_limit = -28
[0000.693] I> max temp read = 41
[0000.696] I> min temp read = 40
[0000.699] I> Task: Update FSI SCR with thermal fuse data
[0000.704] I> Task: Enable WDT 5th expiry
[0000.708] I> Task: I2C register
[0000.711] I> Task: Set I2C bus freq
[0000.714] I> Task: Reset FSI
[0000.717] I> Task: Pinmux init
[0000.720] I> skipped mmio_addr = 0x9240008
[0000.724] I> skipped mmio_addr = 0x9240000
[0000.728] I> skipped mmio_addr = 0x9240010
[0000.732] I> skipped mmio_addr = 0x9240018
[0000.736] I> skipped mmio_addr = 0x9240020
[0000.740] I> skipped mmio_addr = 0x9240030
[0000.744] I> skipped mmio_addr = 0x9240028
[0000.748] I> skipped mmio_addr = 0x9240038
[0000.752] I> skipped mmio_addr = 0x9240040
[0000.756] I> skipped mmio_addr = 0x9240048
[0000.760] I> skipped mmio_addr = 0x9241000
[0000.764] I> skipped mmio_addr = 0x9241008
[0000.768] I> skipped mmio_addr = 0x9241010
[0000.772] I> skipped mmio_addr = 0x9241018
[0000.776] I> skipped mmio_addr = 0x9241020
[0000.779] I> skipped mmio_addr = 0x9241028
[0000.783] I> skipped mmio_addr = 0x9241030
[0000.787] I> skipped mmio_addr = 0x9241038
[0000.791] I> skipped mmio_addr = 0x9241040
[0000.795] I> skipped mmio_addr = 0x9242000
[0000.799] I> skipped mmio_addr = 0x9242008
[0000.803] I> Task: Prod config init
[0000.806] I> Task: Pad voltage init
[0000.810] I> Task: Prod init
[0000.813] I> Task: Program rst req config reg
[0000.817] I> Task: Common rail init
[0000.820] I> DONE: Thermal config
[0000.824] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.832] I> DONE: SOC rail config
[0000.836] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0000.842] I> DONE: MEMIO rail config
[0000.846] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.
[0000.852] I> DONE: GPU rail info
[0000.856] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.
[0000.862] I> DONE: CV rail info
[0000.865] I> Task: Mem clock src
[0000.868] I> Task: Misc. board config
[0000.872] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0000.878] I> Task: SDRAM init
[0000.880] I> MemoryType: 4 MemBctRevision: 1
[0000.887] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 1
[0000.894] I> MSS CAR: Init PLLM
[0000.898] I> MSS CAR: Init PLLHUB
[0000.902] I> Encryption:   MTS: en, TX: en, VPR: en, GSC: en
[0000.914] I> SDRAM initialized!
[0000.917] I> SDRAM Size in Total 0x200000000
[0000.921] I> Task: Dram Ecc scrub
[0000.924] I> Task: DRAM alias check
[0000.934] I> Task: Program NSDRAM carveout
[0000.938] I> NSDRAM carveout encryption is enabled
[0000.943] I> Program NSDRAM carveout
[0000.947] I> Task: Register checker
[0000.952] I> Task: Enable clock-mon
[0000.957] I> FMON: Fmon re-programming done
[0000.961] I> Task: Mapper init
[0000.964] I> Task: SC7 Context Init
[0000.969] I> Task: CCPLEX IST init
[0000.973] I> Task: CPU WP0
[0000.976] I> Loading MCE
[0000.979] I> Slot: 0
[0000.981] I> Binary[8] block-22784 (partition size: 0x80000)
[0000.987] I> Binary name: MCE
[0000.991] I> Size of crypto header is 8192
[0000.995] I> Size of crypto header is 8192
[0001.000] I> strt_pg_num(22784) num_of_pgs(16) read_buf(0x4003e000)
[0001.007] I> BCH of MCE read from storage
[0001.012] I> BCH address is : 0x4003e000
[0001.017] I> MCE header integrity check is success
[0001.022] I> Binary magic in BCH component 0 is MTSM
[0001.027] I> component binary type is 8
[0001.031] I> Size of crypto header is 8192
[0001.036] I> strt_pg_num(22800) num_of_pgs(357) read_buf(0x40000000)
[0001.046] I> MCE binary is read from storage
[0001.051] I> MCE binary integrity check is success
[0001.056] I> Binary MCE loaded successfully at 0x40000000 (0x2c880)
[0001.063] I> Size of crypto header is 8192
[0001.079] I> Size of crypto header is 8192
[0001.084] I> Sending WP0 mailbox command to PSC
[0001.093] I> Task: XUSB Powergate
[0001.097] I> Skipping powergate XUSB.
[0001.100] I> Task: MB1 fixed firewalls
[0001.116] W> Firewall readback mismatch
[0001.127] I> Task: Load bpmp-fw
[0001.130] I> Slot: 0
[0001.133] I> Binary[15] block-9984 (partition size: 0x180000)
[0001.139] I> Binary name: BPMP_FW
[0001.143] I> Size of crypto header is 8192
[0001.147] I> Size of crypto header is 8192
[0001.152] I> strt_pg_num(9984) num_of_pgs(16) read_buf(0x807fe000)
[0001.160] I> BCH of BPMP_FW read from storage
[0001.164] I> BCH address is : 0x807fe000
[0001.170] I> BPMP_FW header integrity check is success
[0001.175] I> Binary magic in BCH component 0 is BPMF
[0001.180] I> component binary type is 15
[0001.184] I> Size of crypto header is 8192
[0001.189] I> strt_pg_num(10000) num_of_pgs(2037) read_buf(0x80000000)
[0001.208] I> BPMP_FW binary is read from storage
[0001.215] I> BPMP_FW binary integrity check is success
[0001.220] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xfea00)
[0001.228] I> Slot: 0
[0001.231] I> Binary[16] block-13056 (partition size: 0x400000)
[0001.237] I> Binary name: BPMP_FW_DTB
[0001.241] I> Size of crypto header is 8192
[0001.246] I> Size of crypto header is 8192
[0001.250] I> strt_pg_num(13056) num_of_pgs(16) read_buf(0x807fc000)
[0001.258] I> BCH of BPMP_FW_DTB read from storage
[0001.263] I> BCH address is : 0x807fc000
[0001.269] I> BPMP_FW_DTB header integrity check is success
[0001.274] I> Binary magic in BCH component 0 is BPMD
[0001.280] I> component binary type is 16
[0001.284] I> Size of crypto header is 8192
[0001.288] I> strt_pg_num(13072) num_of_pgs(199) read_buf(0x807e31f0)
[0001.297] I> BPMP_FW_DTB binary is read from storage
[0001.303] I> BPMP_FW_DTB binary integrity check is success
[0001.309] I> Binary BPMP_FW_DTB loaded successfully at 0x807e31f0 (0x18e00)
[0001.318] I> Task: Load psc-fw
[0001.322] I> Slot: 0
[0001.324] I> Binary[17] block-21248 (partition size: 0xc0000)
[0001.331] I> Binary name: PSC_FW
[0001.334] I> Size of crypto header is 8192
[0001.339] I> Size of crypto header is 8192
[0001.343] I> strt_pg_num(21248) num_of_pgs(16) read_buf(0x80ffe000)
[0001.351] I> BCH of PSC_FW read from storage
[0001.356] I> BCH address is : 0x80ffe000
[0001.361] I> PSC_FW header integrity check is success
[0001.366] I> Binary magic in BCH component 0 is PFWP
[0001.372] I> component binary type is 17
[0001.376] I> Size of crypto header is 8192
[0001.380] I> strt_pg_num(21264) num_of_pgs(717) read_buf(0x80fa4600)
[0001.392] I> PSC_FW binary is read from storage
[0001.398] I> PSC_FW binary integrity check is success
[0001.403] I> Binary PSC_FW loaded successfully at 0x80fa4600 (0x59980)
[0001.412] I> Task: Load nvdec-fw
[0001.415] I> Slot: 0
[0001.418] I> Binary[7] block-6400 (partition size: 0x100000)
[0001.424] I> Binary name: NVDEC
[0001.427] I> Size of crypto header is 8192
[0001.432] I> Size of crypto header is 8192
[0001.437] I> strt_pg_num(6400) num_of_pgs(16) read_buf(0x800fe000)
[0001.444] I> BCH of NVDEC read from storage
[0001.449] I> BCH address is : 0x800fe000
[0001.454] I> NVDEC header integrity check is success
[0001.459] I> Binary magic in BCH component 0 is NDEC
[0001.465] I> component binary type is 7
[0001.469] I> Size of crypto header is 8192
[0001.473] I> strt_pg_num(6416) num_of_pgs(560) read_buf(0x80000000)
[0001.484] I> NVDEC binary is read from storage
[0001.490] I> NVDEC binary integrity check is success
[0001.495] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0001.503] I> Size of crypto header is 8192
[0001.524] I> Task: Load tsec-fw
[0001.527] I> TSEC-FW load support not enabled
[0001.531] I> Task: GPIO interrupt map
[0001.536] I> Task: SC7 context save
[0001.539] I> Slot: 0
[0001.542] I> Binary[27] block-0 (partition size: 0x100000)
[0001.548] I> Binary name: BR_BCT
[0001.551] I> Size of crypto header is 8192
[0001.556] I> Size of crypto header is 8192
[0001.561] I> strt_pg_num(0) num_of_pgs(16) read_buf(0xa0000000)
[0001.568] I> BR_BCT binary is read from storage
[0001.573] I> BR_BCT binary integrity check is success
[0001.578] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[0001.586] I> Slot: 0
[0001.588] I> Binary[13] block-23808 (partition size: 0x30000)
[0001.595] I> Binary name: SC7-FW
[0001.599] I> Size of crypto header is 8192
[0001.603] I> Size of crypto header is 8192
[0001.608] I> Size of crypto header is 8192
[0001.612] I> strt_pg_num(23808) num_of_pgs(16) read_buf(0xa0002000)
[0001.620] I> BCH of SC7-FW read from storage
[0001.625] I> BCH address is : 0xa0002000
[0001.630] I> SC7-FW header integrity check is success
[0001.635] I> Binary magic in BCH component 0 is WB0B
[0001.640] I> component binary type is 13
[0001.645] I> Size of crypto header is 8192
[0001.649] I> strt_pg_num(23824) num_of_pgs(345) read_buf(0xa0004000)
[0001.659] I> SC7-FW binary is read from storage
[0001.665] I> SC7-FW binary integrity check is success
[0001.670] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x2b0e0)
[0001.678] I> Slot: 0
[0001.680] I> Binary[22] block-24192 (partition size: 0x30000)
[0001.687] I> Binary name: PSC_RF
[0001.690] I> Size of crypto header is 8192
[0001.695] I> Size of crypto header is 8192
[0001.699] I> Size of crypto header is 8192
[0001.704] I> strt_pg_num(24192) num_of_pgs(16) read_buf(0xa002f0e0)
[0001.712] I> BCH of PSC_RF read from storage
[0001.716] I> BCH address is : 0xa002f0e0
[0001.722] I> PSC_RF header integrity check is success
[0001.727] I> Binary magic in BCH component 0 is PSCR
[0001.732] I> component binary type is 22
[0001.737] I> Size of crypto header is 8192
[0001.741] I> strt_pg_num(24208) num_of_pgs(223) read_buf(0xa00310e0)
[0001.750] I> PSC_RF binary is read from storage
[0001.756] I> PSC_RF binary integrity check is success
[0001.761] I> Binary PSC_RF loaded successfully at 0xa00310e0 (0x1bdd0)
[0001.784] I> Task: Save WP0 payload to SC7 ctx
[0001.789] I> Task: Load MB2rf binary to SC7 ctx
[0001.794] I> Slot: 0
[0001.796] I> Binary[14] block-24576 (partition size: 0x20000)
[0001.803] I> Binary name: MB2_RF
[0001.806] I> Size of crypto header is 8192
[0001.811] I> Size of crypto header is 8192
[0001.815] I> Size of crypto header is 8192
[0001.820] I> strt_pg_num(24576) num_of_pgs(16) read_buf(0xa00d6a88)
[0001.828] I> BCH of MB2_RF read from storage
[0001.832] I> BCH address is : 0xa00d6a88
[0001.838] I> MB2_RF header integrity check is success
[0001.843] I> Binary magic in BCH component 0 is MB2R
[0001.848] I> component binary type is 14
[0001.853] I> Size of crypto header is 8192
[0001.857] I> strt_pg_num(24592) num_of_pgs(224) read_buf(0xa00d8a88)
[0001.866] I> MB2_RF binary is read from storage
[0001.872] I> MB2_RF binary integrity check is success
[0001.877] I> Binary MB2_RF loaded successfully at 0xa00d8a88 (0x1bf80)
[0001.885] I> Task: Save fuse alias data to SC7 ctx
[0001.890] I> Task: Save PMIC data to SC7 ctx
[0001.895] I> Task: Save Pinmux data to SC7 ctx
[0001.900] I> Task: Save Pad Voltage data to SC7 ctx
[0001.905] I> Task: Save controller prod data to SC7 ctx
[0001.910] I> Task: Save prod cfg data to SC7 ctx
[0001.915] I> Task: Save I2C bus freq data to SC7 ctx
[0001.921] I> Task: Save SOCTherm data to SC7 ctx
[0001.925] I> Task: Save FMON data to SC7 ctx
[0001.930] I> Task: Save VMON data to SC7 ctx
[0001.935] I> Task: Save TZDRAM data to SC7 ctx
[0001.939] I> Task: Save GPIO int data to SC7 ctx
[0001.944] I> Task: Save clock data to SC7 ctx
[0001.949] I> Task: Save debug data to SC7 ctx
[0001.953] I> Task: Save MBWT data to SC7 ctx
[0001.962] I> SC7 context save done
[0001.966] I> Task: Load MB2/Applet/FSKP
[0001.970] I> Loading MB2
[0001.973] I> Slot: 0
[0001.976] I> Binary[6] block-8448 (partition size: 0x80000)
[0001.982] I> Binary name: MB2
[0001.985] I> Size of crypto header is 8192
[0001.990] I> Size of crypto header is 8192
[0001.994] I> strt_pg_num(8448) num_of_pgs(16) read_buf(0x8007e000)
[0002.002] I> BCH of MB2 read from storage
[0002.007] I> BCH address is : 0x8007e000
[0002.012] I> MB2 header integrity check is success
[0002.017] I> Binary magic in BCH component 0 is MB2B
[0002.022] I> component binary type is 6
[0002.026] I> Size of crypto header is 8192
[0002.031] I> strt_pg_num(8464) num_of_pgs(841) read_buf(0x80000000)
[0002.043] I> MB2 binary is read from storage
[0002.049] I> MB2 binary integrity check is success
[0002.054] I> Binary MB2 loaded successfully at 0x80000000 (0x691f0)
[0002.062] I> Task: Map CCPLEX SHARED carveout
[0002.067] I> Task: Prepare MB2 params
[0002.072] I> BR-BCT Boot Chain Fields
[0002.076] I>    u32_non_gpio_select_boot_chain  : 0
[0002.081] I>    u32_num_boot_chains             : 2
[0002.086] I>    bf_bl_gpio_select_boot_chain_1b : 0
[0002.091] I> Task: Dram ecc test
[0002.095] I> Task: Misc NV security settings
[0002.100] I> NVDEC sticky bits programming done
[0002.104] I> Successfully powergated NVDEC
[0002.109] I> Task: Disable/Reload WDT
[0002.113] I> Task: Program misc carveouts
[0002.117] I> Program IPC carveouts
[0002.125] I> SLCG Global override status := 0x0
[0002.130] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-4d0906e6)
I> Emulation:
I> Entry timestamp: 0x0020f691
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0x270000000, size:0x800000]
I> Task: ARI update carveout TZDRAM (0x50002034)
I> Task: Enable hot-plug capability (0x50028064)
I> Task: PSC mailbox init (0x500178b0)
I> Task: Crypto init (0x5000675c)
I> Task: Enable GP-SE clock (0x50002198)
I> Task: DICE Identity init (0x5001af00)
I> DICE is not enabled.
I> Task: Measured Boot init (0x5001b674)
I> Task: OEM SC7 context save init (0x5001a600)
I> Task: I2C register (0x50001ff8)
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout (0x50001fe0)
I> Task: Program CBB PCIE AMAP regions (0x5001ac14)
I> Task: Boot device init (0x50001f28)
I> Task: Partition Manager Init (0x50001f24)
I> Found 57 partitions in QSPI_FLASH (instance 0)
I> Task: Load and authenticate registered FWs (0x5001e198)
I> Task: Load AUXP FWs (0x50027c04)
I> Successfully register SPE FW load task with MB2 loader
I> Skipping SCE FW load
I> Successfully register RCE FW load task with MB2 loader
I> Successfully register DCE FW load task with MB2 loader
I> Unpowergating APE
I> Unpowergate done
I> Successfully register APE FW load task with MB2 loader
I> Skipping FSI FW load
I> Successfully register XUSB FW load task with MB2 loader
I> Partition name: A_spe-fw
I> Size of partition: 589824
I> Binary@ device:3/0 block-55040 (partition size: 0x90000), name: A_spe-fw
I> Partition name: A_rce-fw
I> Size of partition: 1048576
I> Binary@ device:3/0 block-56192 (partition size: 0x100000), name: A_rce-fw
I> spe: Authentication Finalize Done
I> Binary spe loaded successfully at 0x26f200000
I> Partition name: A_dce-fw
I> Size of partition: 5242880
I> Binary@ device:3/0 block-44800 (partition size: 0x500000), name: A_dce-fw
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0x26ef00000
I> dce : oem authentication of header done
I> dce : meta-blob integrity check is success.
I> dce : will be decompressed at 0x276000000
I> version 1 Bin 1 BCheckSum 0 content_size 0 Content ChkSum 1 reserved_00  0
I> Reserved10 0 BlockMaxSize 5 Reserved11 0
I> dce : decompressed to 9453696 bytes
I> dce: plain binary integrity check is success
I> Partition name: A_adsp-fw
I> Size of partition: 2097152
I> Binary@ device:3/0 block-58240 (partition size: 0x200000), name: A_adsp-fw
I> dce: Authentication Finalize Done
I> Binary dce loaded successfully at 0x276000000
I> Partition name: A_xusb-fw
I> Size of partition: 262144
I> Binary@ device:3/0 block-9472 (partition size: 0x40000), name: A_xusb-fw
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0x26fc00000
I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0x26f300000
I> Task: Carveout setup (0x500208f8)
I> Program remaining OEM carveouts
I> Task: Enable FSITHERM (0x50017784)
I> Task: Enable FSI VMON (0x50017280)
I> Task: Validate FSI Therm readings (0x50017364)
I> Task: Restore XUSB sec (0x50001ef8)
I> Task: Enable FSI SE clock (0x50017d0c)
I> Task: Initialize SBSA UART CAR (0x500020fc)
I> Task: Initialize CPUBL Params (0x50018cf8)
I> CPUBL-params @ 0x272000000
I> Task: Ratchet update (0x50029100)
W> Skip ratchet update - OPTIN fuse not set
I> Task: Prepare eeprom data (0x50018ac4)
I> Task: Revoke PKC fuse (0x50001d44)
I> PKC revoke fuse burn not requested
I> Task: FSI padctl context save (0x5001a790)
W> Skipping FSI padctl config save: fsi not enabled
I> Task: Unpowergate APE (0x50018474)
W> mb2_unpowergate_ape: skip! APE is in unpowergated state
I> Task: OEM firewalls (0x50024d68)
I> OEM firewalls configured
I> Task: Powergate APE (0x500185e8)
I> Powergating APE
I> Powergate done
I> Task: OEM firewall restore saved settings (0x500251bc)
I> Task: Unhalt AUXPs (0x50027e6c)
I> Unhalting SPE..
I> Enabling combined UART
����spe: early_init
����vic initialized
�Ḹ��tsc initialized
����aon lic initialized
�ุ��spe: tag is 5243985d1b1eb3f06fac6d36bd7e74ac
����spe: SafeRTOS v8.4
�ุ��spe: init
����scheduler initialized
�ุ��aon hsp initialized
����tag initialized
�ุ��tcu initialized
����bpmp ipc initialized
�ุ��spe: late init
����cpu_nic clock initialized
�ุ��apb clock initialized
����pm initialized
�ุ��bpmp hsp initialized
����top1 hsp initialized
�ุ��ccplex ipc initialized
����spe: start scheduler
    I> Task: Trigger mailbox for PSC-BL1 exit (0x50017930)
I> Sending opcode 0x4d420802 to psc
��INFO: Entering psc_monitor_init!
INFO: GSC22 BOM:0x278002000 SIZE:0x1000000 CLIENT_ACCESS1:00180000
INFO: PSCFW BUILD VERSION: 8a33b23-73b589c-8a15f76-rel-t234
INFO: mstatus:0xa00000808
INFO: Supervisor entry_point:c108c00
��I> Received ACK from psc
I> Tas��INFO: MONITOR: user task addr:0x278022000, blob offset:0x00020000
INFO: MONITOR: populated user images:13
INFO: mret to Supervisor!
INFO: psc supervisor init.
INFO: psc_irq_init...
INFO: enter idle task.
  bpmp: socket 0
bpmp: base binary md5 is 925eece486b7c46d91aa449178b5d322
bpmp: combined binary md5 is cedb24d07defeef07ea9c6fb63a683a6
bpmp: firmware tag is cedb24d07defeef07ea9-925eece486b
initialized vwdt
initialized mail_early
initialized fuse
initialized vfrel
initialized hwwdt
initialized adc
fmon_populate_monitors: found 199 monitors
initialized fmon
initialized mc
initialized reset
initialized uphy_early
initialized emc_early
471 clocks registered
initialized clk_mach
initialized clk_cal_early
initialized clk_mach_early_config
initialized io_dpd
initialized soctherm
initialized regime
initialized i2c
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
initialized vrmon
initialized regulator
initialized avfs_clk_platform
initialized powergate
initialized dvs
initialized clk_mach_config
initialized pm
suspend progress: 0x0
initialized suspend
initialized strap
initialized mce_dbell
��k: Start secure NOR provision (0x5001aa2c)
I> Task: Load FSI keyblob (0x50017d54)
��initialized emc
initialized emc_mrq
��I> Task: Unhalt AUXPs (0x50027e74)
��initialized clk_cal
initialized uphy_dt
initialized uphy_mrq
HSIO UPHY reset has been de-asserted 0x0
initialized uphy
initialized pg_late
initialized pg_mrq_init
swdtimer_init: reg polling start w period 47 ms
initialized swdtimer
initialized hwwdt_late
initialized bwmgr
initialized thermal_host_trip
initialized thermal_mrq
initialized oc_mrq
initialized reset_mrq
initialized mail_mrq
initialized fmon_mrq
initialized clk_mrq
initialized avfs_mrq
initialized i2c_mrq
initialized tag_mrq
initialized bwmgr_mrq
initialized console_mrq
missing prod DT calibration data for 199 fmons
initialized clk_sync_fmon_post
��I> SCE unhalt skipped
I> Unhalting RCE
I> ��initialized clk_cal_late
initialized noc_late
initialized cvc
��[     2.587972] Camera-FW on t234-rce-safe started
TCU early console enabled.
��initialized avfs_clk_mach_post
initialized avfs_clk_platform_post
initialized cvc_late
WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/2 have not matching zones 0/1
WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/3 have not matching zone list sizes 1/3
WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/3 have not matching zones 0/2
WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/0 have not matching zones 1/0
WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/3 have not matching zone list sizes 1/3
WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/3 have not matching zones 1/2
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/0 have not matching zone list sizes 3/1
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/0 have not matching zones 2/0
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/2 have not matching zone list sizes 3/1
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/2 have not matching zones 2/1
initialized rm
initialized console_late
handling unreferenced clks
enable can1_core
enable can1_host
enable can2_core
enable can2_host
enable pwm3
enable mss_encrypt
enable maud
enable pllg_ref
enable dsi_core
enable aza_2xbit
enable xusb_ss
enable xusb_fs
enable xusb_falcon
enable xusb_core_mux
enable dsi_lp
clk_check_max_rates: pex1_c6_core rate 500000000 > max 250000000
clk_check_max_rates: pex2_c7_core rate 500000000 > max 250000000
clk_check_max_rates: pex2_c8_core rate 500000000 > max 250000000
clk_check_max_rates: pex2_c9_core rate 500000000 > max 250000000
clk_check_max_rates: pex2_c10_core rate 500000000 > max 2��[     2.741527] Camera-FW on t234-rce-safe ready SHA1=8676d22a (crt 1.490 ms, tota0
clk_check_max_rates: pex0_c0_core rate 500000000 > max 250000000
clk_check_max_rates: pex0_c1_core rate 500000000 > max 250000000
clk_check_max_rates: pex0_c2_core rate 500000000 > max 250000000
clk_check_max_rates: pex0_c3_core rate 500000000 > max 250000000��55.150 ms)
clk_check_max_rates: pex0_c4_core rate 500000000 > max 250000000
clk_check_max_rates: pex1_c5_core rate 500000000 > max 250000000
initialized clk_mach_post
initialized pg_post
initialized regulator_post
initialized profile
initialized mrq
initialized patrol_scrubber
initialized cacmon
initialized extras_post
bpmp: init complete
��RCE unhalt successful
I> DCE unhalt successful
I> APE unhalt skipped
I> FSI unhalt skipped
I> Task: Load CPUBL (0x50018e1c)
I> Task: Load TOS (0x50019580)
I> Partition name: A_cpu-bootloader
I> Size of partition: 3670016
I> Binary@ device:3/0 block-24832 (partition size: 0x380000), name: A_cpu-bootloader
  ��I> Partition name: A_secure-os
I> Size of partition: 4194304
I> Binary@ device:3/0 block-32000 (partition size: 0x400000), name: A_secure-os
I> cpubl_params: nsdram: carveout: 1, encryption: 1
I> NSDRAM carveout base: 0x80000000, size: 0x1eea70000
I> cpubl: Authentication Finalize Done
I> Binary cpubl loaded successfully at 0x26e600000
I> tos: Authentication Finalize Done
I> Binary tos loaded successfully at 0x27fdee000
I> Relocating OP-TEE dtb from: 0x27fefec50 to 0x27c000020, size: 0x2106
I> [0] START: 0x80000000, SIZE: 0x1eea70000
I> [1] START: 0x272000000, SIZE: 0x2000000
I> Setting NS memory ranges to OP-TEE dtb finished.
I> Partition name: A_eks
I> Binary@ device:3/0 block-44288 (partition size: 0x40000), name: A_eks
��DCE: FW Boot Done
��I> eks: Authentication Finalize Done
I> Binary eks loaded successfully at 0x270000200
I> EKB detected (length: 0x410) @ VA:0x270000200
I> Task: Prepare TOS params (0x500194f8)
I> Setting EKB blob info to OPTEE dtb finished.
I> Setting OPTEE arg3: 0x27c000020
I> Task: OEM SC7 context save (0x5001a88c)
I> OEM sc7 context saved
I> Task: Disable MSS perf stats (0x50027f00)
I> Task: Program display sticky bits (0x50027e7c)
I> Task: Storage device deinit (0x500020a0)
I> Task: SMMU external bypass disable (0x50017894)
I> Task: SMMU init (0x500177b0)
I> Task: Program GICv3 registers (0x50027fa0)
I> Task: Audit firewall settings (0x50024fbc)
I> Task: Bootchain failure check (0x500025e8)
I> Current Boot-Chain Slot: 0
I> BR-BCT Boot-Chain is 0, and status is 1. Set UPDATE_BRBCT bit to 0
I> MB2 finished
��NOTICE:  BL31: v2.6(release):346877e39
NOTICE:  BL31: Built : 12:32:40, Aug  1 2023
I/TC: Physical secure memory base 0x27c040000 size 0x3fc0000
I/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 3.21 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Tue Aug  1 19:39:55 UTC 2023 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: Test OEM keys are being used. This is insecure for shipping products!
I/TC: Primary CPU switching to normal world boot
  Jetson UEFI firmware (version 4.1-33958178 built on 2023-08-01T19:34:02+00:00)
��I/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
  ��E/TC:?? 00 get_rpc_alloc_res:645 RPC allocation failed. Non-secure world result: ret=0xffff0000 ret_origin=0
E/LD:   init_elf:486 sys_open_ta_bin(bc50d971-d4c9-42c4-82cb-343fb7f37896)
E/TC:?? 00 ldelf_init_with_ldelf:131 ldelf failed with res: 0xffff000c
ESC   to enter Setup.
F11   to enter Boot Manager Menu.
Enter to continue boot.
**  WARNING: Test Key is used.  **
  Error: Could not detect network connection.
L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map...
��I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
��[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[    0.000000] Linux version 5.10.120-tegra (buildbrain@mobile-u64-6422-d7000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 93
[    0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[    0.000000] OF: fdt:  - 80000000 ,  c0000000
[    0.000000] Machine model: NVIDIA Orin Nano Developer Kit
[    0.000000] efi: EFI v2.70 by EDK II
[    0.000000] efi: RTPROP=0x266eb1f18 SMBIOS=0xffff0000 SMBIOS 3.0=0x247640000 MEMATTR=0x24844f018 ESRT=0x24848ba98 RNG=0x24883f318 MEMRESER
[    0.000000] efi: seeding entropy pool
[    0.000000] esrt: Reserving ESRT space from 0x000000024848ba98 to 0x000000024848bad0.
[    0.000000] Reserved memory: created CMA memory pool at 0x000000025a800000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x0000000273ffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000fffdffff]
[    0.000000]   node   0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x00000002472edfff]
[    0.000000]   node   0: [mem 0x00000002472ee000-0x0000000247566fff]
[    0.000000]   node   0: [mem 0x0000000247567000-0x000000024756ffff]
[    0.000000]   node   0: [mem 0x0000000247570000-0x000000024757ffff]
[    0.000000]   node   0: [mem 0x0000000247580000-0x000000024758ffff]
[    0.000000]   node   0: [mem 0x0000000247590000-0x000000024762ffff]
[    0.000000]   node   0: [mem 0x0000000247630000-0x000000024763ffff]
[    0.000000]   node   0: [mem 0x0000000247640000-0x000000024764ffff]
[    0.000000]   node   0: [mem 0x0000000247650000-0x00000002482fffff]
[    0.000000]   node   0: [mem 0x0000000248300000-0x000000024839ffff]
[    0.000000]   node   0: [mem 0x00000002483a0000-0x00000002483bffff]
[    0.000000]   node   0: [mem 0x00000002483c0000-0x00000002483dffff]
[    0.000000]   node   0: [mem 0x00000002483e0000-0x00000002483effff]
[    0.000000]   node   0: [mem 0x00000002483f0000-0x000000024841ffff]
[    0.000000]   node   0: [mem 0x0000000248420000-0x000000024845ffff]
[    0.000000]   node   0: [mem 0x0000000248460000-0x000000024847ffff]
[    0.000000]   node   0: [mem 0x0000000248480000-0x000000024858ffff]
[    0.000000]   node   0: [mem 0x0000000248590000-0x000000024876ffff]
[    0.000000]   node   0: [mem 0x0000000248770000-0x000000024882ffff]
[    0.000000]   node   0: [mem 0x0000000248830000-0x00000002488dffff]
[    0.000000]   node   0: [mem 0x00000002488e0000-0x000000024892ffff]
[    0.000000]   node   0: [mem 0x0000000248930000-0x0000000248b5ffff]
[    0.000000]   node   0: [mem 0x0000000248b60000-0x0000000248beffff]
[    0.000000]   node   0: [mem 0x0000000248bf0000-0x0000000248c3ffff]
[    0.000000]   node   0: [mem 0x0000000248c40000-0x0000000248c6ffff]
[    0.000000]   node   0: [mem 0x0000000248c70000-0x0000000248d0ffff]
[    0.000000]   node   0: [mem 0x0000000248d10000-0x0000000248d5ffff]
[    0.000000]   node   0: [mem 0x0000000248d60000-0x0000000248dfffff]
[    0.000000]   node   0: [mem 0x0000000248e00000-0x00000002492dffff]
[    0.000000]   node   0: [mem 0x00000002492e0000-0x00000002494bffff]
[    0.000000]   node   0: [mem 0x00000002494c0000-0x000000026ab2ffff]
[    0.000000]   node   0: [mem 0x000000026ab30000-0x000000026ab7ffff]
[    0.000000]   node   0: [mem 0x000000026ab80000-0x000000026ea0ffff]
[    0.000000]   node   0: [mem 0x000000026ea10000-0x000000026ea1ffff]
[    0.000000]   node   0: [mem 0x0000000272000000-0x0000000273ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000273ffffff]
[    0.000000] On node 0, zone Normal: 480 pages in unavailable ranges
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 32 pages/cpu s90328 r8192 d32552 u131072
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] CPU features: detected: Spectre-v4
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] alternatives: patching kernel code
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 2002208
[    0.000000] Kernel command line: root=PARTUUID=87d4b4ac-25e6-479d-bfc9-2c2220834052 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=
[    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000effe0000-0x00000000fffe0000] (256MB)
[    0.000000] Memory: 7374860K/8136832K available (18560K kernel code, 3166K rwdata, 7196K rodata, 3968K init, 1416K bss, 499828K reserved, )
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[    0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[    0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[    0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.000644] Console: colour dummy device 80x25
[    0.000688] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.000698] pid_max: default: 32768 minimum: 301
[    0.000797] LSM: Security Framework initializing
[    0.000826] Yama: becoming mindful.
[    0.000848] SELinux:  Initializing.
[    0.000937] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.000950] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.001781] /cpus/cpu-map/cluster1: empty cluster
[    0.002104] rcu: Hierarchical SRCU implementation.
[    0.002197] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[    0.002660] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platfos
[    0.002664] DTB Build time: Aug  1 2023 12:44:16
[    0.003920] Tegra Revision: A01 SKU: 0xd5 CPU Process: 0 SoC Process: 0
[    0.004085] Remapping and enabling EFI services.
[    0.004569] smp: Bringing up secondary CPUs ...
[    0.033288] Detected PIPT I-cache on CPU1
[    0.033330] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[    0.033363] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[    0.062023] Detected PIPT I-cache on CPU2
[    0.062034] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[    0.062049] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[    0.090669] Detected PIPT I-cache on CPU3
[    0.090678] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[    0.090692] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[    0.121361] Detected PIPT I-cache on CPU4
[    0.121385] GICv3: CPU4: found redistributor 10200 region 0:0x000000000f500000
[    0.121414] CPU4: Booted secondary processor 0x0000010200 [0x410fd421]
[    0.150132] Detected PIPT I-cache on CPU5
[    0.150144] GICv3: CPU5: found redistributor 10300 region 0:0x000000000f520000
[    0.150160] CPU5: Booted secondary processor 0x0000010300 [0x410fd421]
[    0.150226] smp: Brought up 1 node, 6 CPUs
[    0.150240] SMP: Total of 6 processors activated.
[    0.150244] CPU features: detected: Privileged Access Never
[    0.150246] CPU features: detected: LSE atomic instructions
[    0.150248] CPU features: detected: User Access Override
[    0.150250] CPU features: detected: 32-bit EL0 Support
[    0.150253] CPU features: detected: Common not Private translations
[    0.150255] CPU features: detected: RAS Extension Support
[    0.150257] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.150259] CPU features: detected: CRC32 instructions
[    0.150260] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.169909] spectre-bhb mitigation disabled by command line option
[    0.169911] spectre-bhb mitigation disabled by command line option
[    0.169913] spectre-bhb mitigation disabled by command line option
[    0.188076] CPU: All CPU(s) started at EL2
[    0.189915] devtmpfs: initialized
[    0.209480] Registered cp15_barrier emulation handler
[    0.209489] Registered setend emulation handler
[    0.209495] KASLR enabled
[    0.209631] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.209643] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.211694] pinctrl core: initialized pinctrl subsystem
[    0.212190] SMBIOS 3.0.0 present.
[    0.212199] DMI: Unknown NVIDIA Orin Nano Developer Kit/NVIDIA Orin Nano Developer Kit, BIOS 4.1-33958178 08/01/2023
[    0.212555] NET: Registered protocol family 16
[    0.213498] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.213560] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.213616] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.213647] audit: initializing netlink subsys (disabled)
[    0.213742] audit: type=2000 audit(0.212:1): state=initialized audit_enabled=0 res=1
[    0.213952] thermal_sys: Registered thermal governor 'step_wise'
[    0.213955] thermal_sys: Registered thermal governor 'power_allocator'
[    0.213958] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[    0.214861] cpuidle: using governor menu
[    0.214991] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.215064] ASID allocator initialised with 32768 entries
[    0.215172] Serial: AMBA PL011 UART driver
[    0.217239] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[    0.217266] Tegra reboot handler registered.
[    0.239532] mc: mapped MMIO address: 0xffff8000107b0000 -> 0x2c10000
[    0.239543] mc: mapped MMIO address: 0xffff8000107d0000 -> 0x2c20000
[    0.239552] mc: mapped MMIO address: 0xffff8000107f0000 -> 0x2c30000
[    0.239560] mc: mapped MMIO address: 0xffff800010810000 -> 0x2c40000
[    0.239567] mc: mapped MMIO address: 0xffff800010830000 -> 0x2c50000
[    0.239574] mc: mapped MMIO address: 0xffff800010850000 -> 0x2b80000
[    0.239580] mc: mapped MMIO address: 0xffff800010870000 -> 0x2b90000
[    0.239587] mc: mapped MMIO address: 0xffff800010890000 -> 0x2ba0000
[    0.239593] mc: mapped MMIO address: 0xffff8000108b0000 -> 0x2bb0000
[    0.239600] mc: mapped MMIO address: 0xffff8000108d0000 -> 0x1700000
[    0.239607] mc: mapped MMIO address: 0xffff8000108f0000 -> 0x1710000
[    0.239613] mc: mapped MMIO address: 0xffff800010910000 -> 0x1720000
[    0.239619] mc: mapped MMIO address: 0xffff800010930000 -> 0x1730000
[    0.239625] mc: mapped MMIO address: 0xffff800010950000 -> 0x1740000
[    0.239631] mc: mapped MMIO address: 0xffff800010970000 -> 0x1750000
[    0.239637] mc: mapped MMIO address: 0xffff800010990000 -> 0x1760000
[    0.239643] mc: mapped MMIO address: 0xffff8000109b0000 -> 0x1770000
[    0.239650] nv-tegra-mc 2c10000.mc: No mssnvlink node
[    0.239690] mc-err: mcerr ops are set to t23x
[    0.240474] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 65, base_baud = 0) is a SBSA
[    1.412887] printk: console [ttyAMA0] enabled
[    1.421990] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    1.428698] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    1.435399] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    1.442096] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    1.450870] ACPI: Interpreter disabled.
[    1.455200] ddr-vddq: supplied by vdd-5v
[    1.459307] ddr-vdd2: supplied by vdd-5v
[    1.463375] vdd-AO-1v2: supplied by vdd-5v
[    1.467611] vdd-3v3: supplied by vdd-5v
[    1.471593] vdd-rtc: supplied by vdd-AO-1v2
[    1.475916] vdd-0v95-uphy: supplied by vdd-AO-1v2
[    1.480742] vdd-0v95-hdmi: supplied by vdd-AO-1v2
[    1.485739] vdd-1v8: supplied by vdd-3v3-sys
[    1.490139] vdd-3v3-AO: supplied by vdd-5v-sys
[    1.494722] vdd-av10-hub: supplied by vdd-5v-sys
[    1.499448] vdd-vbus-a: supplied by vdd-5v-sys
[    1.504032] vdd-vbus-b: supplied by vdd-5v-sys
[    1.508590] vdd-3v3-dp: supplied by vdd-3v3-sys
[    1.513456] iommu: Default domain type: Translated
[    1.518372] eventlib_kernel: keventlib is initialized, test id: 0
[    1.524690] SCSI subsystem initialized
[    1.528541] usbcore: registered new interface driver usbfs
[    1.534041] usbcore: registered new interface driver hub
[    1.539362] usbcore: registered new device driver usb
[    1.544622] mc: Linux media interface: v0.10
[    1.548898] videodev: Linux video capture interface: v2.00
[    1.554549] pps_core: LinuxPPS API ver. 1 registered
[    1.559512] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.568648] PTP clock support registered
[    1.572832] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[    1.579991] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[    1.587675] Registered efivars operations
[    1.591829] FPGA manager framework
[    1.595272] Advanced Linux Sound Architecture Driver Initialized.
[    1.601649] Bluetooth: Core ver 2.22
[    1.605232] NET: Registered protocol family 31
[    1.609676] Bluetooth: HCI device and connection manager initialized
[    1.616034] Bluetooth: HCI socket layer initialized
[    1.620912] Bluetooth: L2CAP socket layer initialized
[    1.625967] Bluetooth: SCO socket layer initialized
[    1.631382] camchar: rtcpu character device driver loaded
[    1.637040] clocksource: Switched to clocksource arch_sys_counter
[    1.841779] VFS: Disk quotas dquot_6.6.0
[    1.845747] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.852993] pnp: PnP ACPI: disabled
[    1.858972] la/ptsa driver initialized.
[    1.862893] NET: Registered protocol family 2
[    1.867392] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    1.876434] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    1.884978] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    1.892966] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    1.900876] TCP: Hash tables configured (established 65536 bind 65536)
[    1.907483] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    1.914292] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    1.921604] NET: Registered protocol family 1
[    1.926193] RPC: Registered named UNIX socket transport module.
[    1.932119] RPC: Registered udp transport module.
[    1.936833] RPC: Registered tcp transport module.
[    1.941537] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.947983] PCI: CLS 0 bytes, default 64
[    1.952040] Trying to unpack rootfs image as initramfs...
[    2.120507] Freeing initrd memory: 9552K
[    2.126537] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    2.134494] kvm [1]: IPA Size Limit: 48 bits
[    2.138781] kvm [1]: GICv3: no GICV resource entry
[    2.143571] kvm [1]: disabling GICv2 emulation
[    2.148027] kvm [1]: GIC system register CPU interface enabled
[    2.153920] kvm [1]: vgic interrupt IRQ9
[    2.157947] kvm [1]: VHE mode initialized successfully
[    2.163790] Initialise system trusted keyrings
[    2.168325] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[    2.177515] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    2.183753] NFS: Registering the id_resolver key type
[    2.188828] Key type id_resolver registered
[    2.193008] Key type id_legacy registered
[    2.197055] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    2.203761] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    2.211166] ntfs: driver 2.1.32 [Flags: R/W].
[    2.230409] NET: Registered protocol family 38
[    2.234855] Key type asymmetric registered
[    2.238949] Asymmetric key parser 'x509' registered
[    2.243850] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 239)
[    2.251309] io scheduler mq-deadline registered
[    2.255842] io scheduler kyber registered
[    2.264114] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    2.269719] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[    2.275305] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    2.280890] tegra-pwm 32e0000.pwm: PWM clk can sleep in ops
[    2.289116] tegra_dc_assign_hw_data: no matching compatible node
[    2.295122] tegradccommon module_init failed
[    2.299390] tegradc module_init failed
[    2.303428] EINJ: ACPI disabled.
[    2.308425] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[    2.315310] tegra-pmc: ### PMC reset source: MAINSWRST
[    2.320447] tegra-pmc: ### PMC reset level: L1
[    2.324886] tegra-pmc: ### PMC reset status reg: 0x2d
[    2.331385] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    3.942428] printk: console [ttyTCU0] enabled
[    3.947515] arm-smmu 12000000.iommu: probing hardware configuration...
[    3.954217] arm-smmu 12000000.iommu: SMMUv2 with:
[    3.959047] arm-smmu 12000000.iommu:         stage 1 translation
[    3.964594] arm-smmu 12000000.iommu:         stage 2 translation
[    3.970127] arm-smmu 12000000.iommu:         nested translation
[    3.975577] arm-smmu 12000000.iommu:         stream matching with 128 register groups
[    3.982990] arm-smmu 12000000.iommu:         128 context banks (0 stage-2 only)
[    3.992404] arm-smmu 12000000.iommu:         Supported page sizes: 0x00001000
[    3.999095] arm-smmu 12000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    4.005785] arm-smmu 12000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    4.013345] arm-smmu 10000000.iommu: probing hardware configuration...
[    4.020040] arm-smmu 10000000.iommu: SMMUv2 with:
[    4.024867] arm-smmu 10000000.iommu:         stage 1 translation
[    4.030404] arm-smmu 10000000.iommu:         stage 2 translation
[    4.035936] arm-smmu 10000000.iommu:         nested translation
[    4.041389] arm-smmu 10000000.iommu:         stream matching with 128 register groups
[    4.048795] arm-smmu 10000000.iommu:         128 context banks (0 stage-2 only)
[    4.058130] arm-smmu 10000000.iommu:         Supported page sizes: 0x00001000
[    4.064819] arm-smmu 10000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    4.071511] arm-smmu 10000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    4.078683] arm-smmu 8000000.iommu: probing hardware configuration...
[    4.085287] arm-smmu 8000000.iommu: SMMUv2 with:
[    4.090028] arm-smmu 8000000.iommu:  stage 1 translation
[    4.095481] arm-smmu 8000000.iommu:  stage 2 translation
[    4.100924] arm-smmu 8000000.iommu:  nested translation
[    4.106279] arm-smmu 8000000.iommu:  stream matching with 128 register groups
[    4.113595] arm-smmu 8000000.iommu:  128 context banks (0 stage-2 only)
[    4.122876] arm-smmu 8000000.iommu:  Supported page sizes: 0x00001000
[    4.129479] arm-smmu 8000000.iommu:  Stage-1: 48-bit VA -> 48-bit IPA
[    4.136081] arm-smmu 8000000.iommu:  Stage-2: 48-bit IPA -> 48-bit PA
[    4.143397] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[    4.153362] tegra_profiler: version: 1.151, samples/io: 51/30
[    4.159343] tegra_profiler: auth: init
[    4.163537] nvsciipc: loaded module
[    4.168926] tun: Universal TUN/TAP device driver, 1.6
[    4.174595] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    4.182009] hns3: Copyright (c) 2017 Huawei Corporation.
[    4.187485] e1000e: Intel(R) PRO/1000 Network Driver
[    4.192571] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    4.198658] igb: Intel(R) Gigabit Ethernet Network Driver
[    4.204192] igb: Copyright (c) 2007-2014 Intel Corporation.
[    4.210084] PPP generic driver version 2.4.2
[    4.214528] PPP BSD Compression module registered
[    4.219366] PPP Deflate Compression module registered
[    4.224565] PPP MPPE Compression module registered
[    4.229502] usbcore: registered new interface driver r8152
[    4.235143] usbcore: registered new interface driver asix
[    4.240690] usbcore: registered new interface driver ax88179_178a
[    4.246958] usbcore: registered new interface driver cdc_ether
[    4.252952] usbcore: registered new interface driver net1080
[    4.258768] usbcore: registered new interface driver cdc_subset
[    4.264845] usbcore: registered new interface driver zaurus
[    4.270584] usbcore: registered new interface driver cdc_ncm
[    4.276396] usbcore: registered new interface driver aqc111
[    4.282243] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    4.288595] ohci-pci: OHCI PCI platform driver
[    4.293174] ohci-platform: OHCI generic platform driver
[    4.298867] tegra-xusb 3610000.xhci: Adding to iommu group 0
[    4.305323] usbcore: registered new interface driver uas
[    4.310790] usbcore: registered new interface driver usb-storage
[    4.317133] tegra-xudc 3550000.xudc: Adding to iommu group 1
[    4.323227] mousedev: PS/2 mouse device common for all mice
[    4.328975] usbcore: registered new interface driver xpad
[    4.336402] tegra_rtc c2a0000.rtc: registered as rtc1
[    4.341889] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:31 UTC (31)
[    4.350118] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    4.356533] i2c /dev entries driver
[    4.360245] tegra-i2c 3160000.i2c: Adding to iommu group 2
[    4.366064] tegra-i2c c240000.i2c: Adding to iommu group 2
[    4.371764] tegra-i2c 3180000.i2c: Adding to iommu group 2
[    4.377456] tegra-i2c 3190000.i2c: Adding to iommu group 2
[    4.383155] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[    4.388833] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[    4.394516] tegra-i2c c250000.i2c: Adding to iommu group 2
[    4.400204] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[    4.409852] device-mapper: uevent: version 1.0.3
[    4.414705] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[    4.424460] sdhci: Secure Digital Host Controller Interface driver
[    4.430811] sdhci: Copyright(c) Pierre Ossman
[    4.435279] Synopsys Designware Multimedia Card Interface Driver
[    4.441527] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.447711] sdhci-tegra 3400000.sdhci: Adding to iommu group 3
[    4.447904] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[    4.461111] tegra-bpmp bpmp: firmware: cedb24d07defeef07ea9-925eece486b
[    4.469920] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[    4.475539] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x82
[    4.484933] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[    4.490854] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
��debugfs initialized
��[    5.574220] hid: raw HID events driver (C) Jiri Kosina
[    5.579811] usbcore: registered new interface driver usbhid
[    5.585547] usbhid: USB HID core driver
[    5.589974] tegra-dce d800000.dce: Adding to iommu group 4
[    5.597648] dce: dce_ipc_channel_init:319  Invalid Channel State [0x0] for ch_type [2]
[    5.606585] tegra234-aon c000000.aon: Adding to iommu group 5
[    5.613052] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x5]
[    5.621886]  c000000.aon:hsp: probed
[    5.622187] dce: dce_admin_send_cmd_ver:424  version : [0x2] err : [0x0]
[    5.632592] tegra234-aon c000000.aon: init done
[    5.633130] tegra23x-psc e860000.psc: Adding to iommu group 6
[    5.637390] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x1]
[    5.643538] tegra23x-psc e860000.psc: ext_cfg base:(____ptrval____)
[    5.652123] dce: dce_admin_setup_clients_ipc:553  Channel Reset Complete for Type [1] ...
[    5.658544] tegra23x-psc e860000.psc: init done
[    5.658746] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 7
[    5.666955] dce: dce_admin_setup_clients_ipc:529  Get queue info failed for [2]
[    5.672432] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[    5.678387] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x2]
[    5.703078] dce: dce_admin_setup_clients_ipc:553  Channel Reset Complete for Type [3] ...
[    5.711739] dce: dce_start_boot_flow:173  DCE_BOOT_DONE
[    5.718527] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[    5.727720] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[    5.739377] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[    5.750855] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[    5.762638] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[    5.775193] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[    5.788018] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[    5.800483] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (113)
[    5.807285] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[    5.815845] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=8676d22a01443bdbc66581b7dde3b6d6828cc925
[    5.829348] t19x_cache tegra-cache: probed
[    5.833778] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[    5����.844949] optee: pr��I��obing for conduit met��/��hod.
��TC: Reserved shared memory is disabled
��[    5.849537] optee: revision 3.21 (d8269f24)
[    5.908368] optee: dynamic shared memory is enabled
[    5.917791] optee: initialized driver
[    5.935192] nvpmodel: initialized successfully
[    5.939869] tegra_hv: get_hvd: not initialized yet
[    5.944816] user_ivc_mempool: hypervisor not present
[    5.950770] usbcore: registered new interface driver snd-usb-audio
[    5.957973] u32 classifier
[    5.960765]     input device check on
[    5.964546]     Actions configured
[    5.968222] Initializing XFRM netlink socket
[    5.973083] NET: Registered protocol family 10
[    5.979167] Segment Routing with IPv6
[    5.982981] NET: Registered protocol family 17
[    5.987563] NET: Registered protocol family 15
[    5.992177] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need.
[    6.006314] Bluetooth: RFCOMM socket layer initialized
[    6.011630] Bluetooth: RFCOMM ver 1.11
[    6.015494] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    6.021591] Bluetooth: HIDP socket layer initialized
[    6.027649] 9pnet: Installing 9P2000 support
[    6.032117] Key type dns_resolver registered
[    6.037293] registered taskstats version 1
[    6.041509] Loading compiled-in X.509 certificates
[    6.057443] Loaded X.509 cert 'Build time autogenerated kernel key: d94b64a20d69a5a32183bad4f211c4cae67041a9'
[    6.068017] tegra194-pcie 14100000.pcie: Adding to iommu group 8
[    6.082103] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[    6.089509] tegra194-pcie 14160000.pcie: Adding to iommu group 9
[    6.102893] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[    6.109817] tegra194-pcie 141e0000.pcie: Adding to iommu group 10
[    6.122736] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[    6.129587] tegra194-pcie 140a0000.pcie: Adding to iommu group 11
[    6.142758] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[    6.177287] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 12
[    6.187691] host1x 13e40000.host1x: Adding to iommu group 13
[    6.219912] host1x 13e40000.host1x: initialized
[    6.224985] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 14
[    6.233047] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[    6.245360] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 15
[    6.253362] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[    6.265682] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 16
[    6.273693] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[    6.285978] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 17
[    6.293962] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[    6.306237] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 18
[    6.314265] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[    6.326561] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 19
[    6.334559] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[    6.346822] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 20
[    6.354810] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[    6.367104] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 21
[    6.375082] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[    6.387337] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 22
[    6.395347] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[    6.407601] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 23
[    6.415602] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[    6.427882] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 24
[    6.435862] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[    6.448147] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 25
[    6.456165] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[    6.468445] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 26
[    6.476416] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[    6.488692] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 27
[    6.496694] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[    6.508976] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 28
[    6.516956] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[    6.529271] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 29
[    6.537266] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[    6.549578] falcon 15340000.vic: Adding to iommu group 30
[    6.560224] falcon 15340000.vic: initialized
[    6.564989] falcon 15380000.nvjpg: Adding to iommu group 31
[    6.573448] falcon 15380000.nvjpg: initialized
[    6.578151] falcon 15540000.nvjpg1: Adding to iommu group 32
[    6.586650] falcon 15540000.nvjpg1: initialized
[    6.591463] falcon 15a50000.ofa: Adding to iommu group 33
[    6.600876] falcon 15a50000.ofa: initialized
[    6.605449] nvdec 15480000.nvdec: Adding to iommu group 34
[    6.617970] nvdec 15480000.nvdec: initialized
[    6.622603] tsec 15500000.tsec: Adding to iommu group 35
[    6.632551] tsec 15500000.tsec: initialized
[    6.640238] gic 2a41000.agic-controller: GIC IRQ controller registered
[    6.658140] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[    6.674200] gpio-397 (camera-control-output-low): hogged as output/low
[    6.680958] gpio-486 (camera-control-output-low): hogged as output/low
[    6.688759] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[    6.696228] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[    6.703232] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    6.709735] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[    6.716181] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    6.722424] tegra-pwm 32e0000.pwm: PWM clk can sleep in ops
[    6.730778] tegra194-isp5 14800000.isp: Adding to iommu group 36
[    6.739125] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[    6.748758] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[    6.755223] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[    6.764441] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[    6.773827] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 37
[    6.781985] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 38
[    6.790085] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
[    6.800065] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[    6.806868] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
[    6.816867] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[    6.823659] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[    6.833614] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[    6.840514] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 2
[    6.847705] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[    6.855224] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[    6.861838] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[    6.868561] serial-tegra 3100000.serial: Adding to iommu group 2
[    6.875192] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 17, base_baud = 0) is a TEGRA_UART
[    6.884980] serial-tegra 3130000.serial: Adding to iommu group 2
[    6.891480] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 63, base_baud = 0) is a TEGRA_UART
[    6.901196] serial-tegra 3140000.serial: Adding to iommu group 2
[    6.907734] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 64, base_baud = 0) is a TEGRA_UART
[    6.934204] tegra-xusb 3610000.xhci: Firmware timestamp: 2023-02-10 03:48:10 UTC, Version: 80.05 release
[    6.943953] tegra-xusb 3610000.xhci: xHCI Host Controller
[    6.949530] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[    6.958238] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[    6.967861] tegra-xusb 3610000.xhci: irq 219, io mem 0x03610000
[    6.974343] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    6.982842] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.990260] usb usb1: Product: xHCI Host Controller
[    6.995263] usb usb1: Manufacturer: Linux 5.10.120-tegra xhci-hcd
[    7.001516] usb usb1: SerialNumber: 3610000.xhci
[    7.007047] hub 1-0:1.0: USB hub found
[    7.010928] hub 1-0:1.0: 4 ports detected
[    7.015315] tegra-xusb 3610000.xhci: xHCI Host Controller
[    7.020874] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[    7.028655] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[    7.036181] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    7.044693] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.052120] usb usb2: Product: xHCI Host Controller
[    7.057126] usb usb2: Manufacturer: Linux 5.10.120-tegra xhci-hcd
[    7.063388] usb usb2: SerialNumber: 3610000.xhci
[    7.068727] hub 2-0:1.0: USB hub found
[    7.072603] hub 2-0:1.0: 4 ports detected
[    7.096516] i2c i2c-2: Added multiplexed i2c bus 9
[    7.101801] i2c i2c-2: Added multiplexed i2c bus 10
[    7.106822] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[    7.113824] tegra23x-oc-event soctherm-oc-event: Finished tegra23x overcurrent event probing
[    7.135963] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1557000 KHz, changing to: 1510400 KHz
[    7.149159] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 1563000 KHz, changing to: 1510400 KHz
[    7.161076] tegra194-cpufreq e000000.ccplex: probed with ICC, cl:3
[    7.169098] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[    7.170509] sdhci-tegra 3400000.sdhci: Got CD GPIO
[    7.177324] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[    7.187636] tegra194-pcie 14100000.pcie:       IO 0x0030100000..0x00301fffff -> 0x0030100000
[    7.189767] irq: IRQ283: trimming hierarchy from :interrupt-controller@f400000-1
[    7.196321] tegra194-pcie 14100000.pcie:      MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[    7.203994] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 283
[    7.212615] tegra194-pcie 14100000.pcie:      MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[    7.277051] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[    7.333041] tegra194-pcie 14100000.pcie: Link up
[    7.340747] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[    7.347562] pci_bus 0001:00: root bus resource [bus 00-ff]
[    7.353199] pci_bus 0001:00: root bus resource [io  0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[    7.363033] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[    7.373854] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[    7.381790] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[    7.388133] pci 0001:00:00.0: PME# supported from D0 D3hot
[    7.399927] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[    7.406272] pci 0001:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[    7.412205] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[    7.420656] pci 0001:01:00.0: supports D1 D2
[    7.425051] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    7.437207] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[    7.444638] pci 0001:00:00.0: BAR 13: assigned [io  0x1000-0x1fff]
[    7.450983] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff 64bit]
[    7.457117] usb 1-2: New USB device found, idVendor=0bda, idProduct=5489, bcdDevice= 1.40
[    7.458957] pci 0001:01:00.0: BAR 0: assigned [io  0x1000-0x10ff]
[    7.467321] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    7.473601] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[    7.480913] usb 1-2: Product: 4-Port USB 2.0 Hub
[    7.486276] pci 0001:00:00.0:   bridge window [io  0x1000-0x1fff]
[    7.491028] usb 1-2: Manufacturer: Generic
[    7.497294] pci 0001:00:00.0:   bridge window [mem 0x20a8000000-0x20a80fffff]
[    7.504561] hub 1-2:1.0: USB hub found
[    7.508855] pci 0001:00:00.0: Max Payload Size set to  128/ 256 (was  256), Max Read Rq  512
[    7.514117] hub 1-2:1.0: 4 ports detected
[    7.521457] pci 0001:01:00.0: Max Payload Size set to  128/ 128 (was  128), Max Read Rq  512
[    7.534577] pcieport 0001:00:00.0: Adding to iommu group 8
[    7.540503] pcieport 0001:00:00.0: PME: Signaling with IRQ 55
[    7.547433] pcieport 0001:00:00.0: AER: enabled with IRQ 55
[    7.554355] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[    7.562690] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[    7.569853] tegra194-pcie 14160000.pcie:       IO 0x0036100000..0x00361fffff -> 0x0036100000
[    7.573857] usb 2-1: new SuperSpeedPlus Gen 2 USB device number 2 using tegra-xusb
[    7.578537] tegra194-pcie 14160000.pcie:      MEM 0x2428000000..0x242fffffff -> 0x0040000000
[    7.594991] tegra194-pcie 14160000.pcie:      MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[    7.624188] usb 2-1: New USB device found, idVendor=0bda, idProduct=0489, bcdDevice= 1.40
[    7.632603] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    7.639943] usb 2-1: Product: 4-Port USB 3.0 Hub
[    7.644684] usb 2-1: Manufacturer: Generic
[    7.659579] hub 2-1:1.0: USB hub found
[    7.665631] hub 2-1:1.0: 4 ports detected
[    7.741253] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[    7.902873] usb 1-3: New USB device found, idVendor=13d3, idProduct=3549, bcdDevice= 0.00
[    7.911291] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    7.918632] usb 1-3: Product: Bluetooth Radio
[    7.923103] usb 1-3: Manufacturer: Realtek
[    7.927306] usb 1-3: SerialNumber: 00e04c000001
[    8.697498] tegra194-pcie 14160000.pcie: Phy link never came up
[    8.703673] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[    8.710485] pci_bus 0004:00: root bus resource [bus 00-ff]
[    8.716119] pci_bus 0004:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[    8.726220] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[    8.737039] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[    8.744967] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[    8.751303] pci 0004:00:00.0: PME# supported from D0 D3hot
[    8.766585] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[    8.771979] pci 0004:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    8.781013] pcieport 0004:00:00.0: Adding to iommu group 9
[    8.786940] pcieport 0004:00:00.0: PME: Signaling with IRQ 57
[    8.793846] pcieport 0004:00:00.0: AER: enabled with IRQ 57
[    8.800399] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[    8.806534] pci 0004:00:00.0: Removing from iommu group 9
[    8.812090] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[    8.819886] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[    8.828076] tegra194-pcie 141e0000.pcie: host bridge /pcie@141e0000 ranges:
[    8.835240] tegra194-pcie 141e0000.pcie:       IO 0x003e100000..0x003e1fffff -> 0x003e100000
[    8.843924] tegra194-pcie 141e0000.pcie:      MEM 0x3228000000..0x322fffffff -> 0x0040000000
[    8.852603] tegra194-pcie 141e0000.pcie:      MEM 0x2e40000000..0x3227ffffff -> 0x2e40000000
[    9.957501] tegra194-pcie 141e0000.pcie: Phy link never came up
[    9.963662] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00
[    9.970477] pci_bus 0007:00: root bus resource [bus 00-ff]
[    9.976113] pci_bus 0007:00: root bus resource [io  0x200000-0x2fffff] (bus address [0x3e100000-0x3e1fffff])
[    9.986205] pci_bus 0007:00: root bus resource [mem 0x3228000000-0x322fffffff] (bus address [0x40000000-0x47ffffff])
[    9.997024] pci_bus 0007:00: root bus resource [mem 0x2e40000000-0x3227ffffff pref]
[   10.004943] pci 0007:00:00.0: [10de:229a] type 01 class 0x060400
[   10.011270] pci 0007:00:00.0: PME# supported from D0 D3hot
[   10.026271] pci 0007:00:00.0: PCI bridge to [bus 01-ff]
[   10.031662] pci 0007:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[   10.040680] pcieport 0007:00:00.0: Adding to iommu group 10
[   10.046680] pcieport 0007:00:00.0: PME: Signaling with IRQ 59
[   10.053578] pcieport 0007:00:00.0: AER: enabled with IRQ 59
[   10.060119] pci_bus 0007:01: busn_res: [bus 01-ff] is released
[   10.066240] pci 0007:00:00.0: Removing from iommu group 10
[   10.071881] pci_bus 0007:00: busn_res: [bus 00-ff] is released
[   10.079623] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[   10.086422] vdd-3v3-sd: supplied by vdd-3v3
[   10.093351] tegra194-isp5 14800000.isp: initialized
[   10.103569] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[   10.110037] (NULL device *): fops function table already registered
[   10.119751] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[   10.126941] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[   10.127059] sdhci-tegra 3400000.sdhci: Got CD GPIO
[   10.133791] irq: IRQ284: trimming hierarchy from :interrupt-controller@f400000-1
[   10.149086] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 283
[   10.254317] tegra194-pcie 140a0000.pcie: host bridge /pcie@140a0000 ranges:
[   10.261489] tegra194-pcie 140a0000.pcie:       IO 0x002a100000..0x002a1fffff -> 0x002a100000
[   10.270171] tegra194-pcie 140a0000.pcie:      MEM 0x3528000000..0x352fffffff -> 0x0040000000
[   10.278847] tegra194-pcie 140a0000.pcie:      MEM 0x3240000000..0x3527ffffff -> 0x3240000000
[   10.393253] tegra194-pcie 140a0000.pcie: Link up
[   10.401908] tegra194-pcie 140a0000.pcie: PCI host bridge to bus 0008:00
[   10.408720] pci_bus 0008:00: root bus resource [bus 00-ff]
[   10.414355] pci_bus 0008:00: root bus resource [io  0x300000-0x3fffff] (bus address [0x2a100000-0x2a1fffff])
[   10.424456] pci_bus 0008:00: root bus resource [mem 0x3528000000-0x352fffffff] (bus address [0x40000000-0x47ffffff])
[   10.435279] pci_bus 0008:00: root bus resource [mem 0x3240000000-0x3527ffffff pref]
[   10.443199] pci 0008:00:00.0: [10de:229c] type 01 class 0x060400
[   10.449522] pci 0008:00:00.0: PME# supported from D0 D3hot
[   10.460676] pci 0008:01:00.0: [10ec:8168] type 00 class 0x020000
[   10.466996] pci 0008:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[   10.472909] pci 0008:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[   10.480008] pci 0008:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[   10.488039] pci 0008:01:00.0: supports D1 D2
[   10.492431] pci 0008:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[   10.504576] pci 0008:00:00.0: BAR 14: assigned [mem 0x3528000000-0x35280fffff]
[   10.512005] pci 0008:00:00.0: BAR 13: assigned [io  0x300000-0x300fff]
[   10.518722] pci 0008:01:00.0: BAR 4: assigned [mem 0x3528000000-0x3528003fff 64bit]
[   10.526686] pci 0008:01:00.0: BAR 2: assigned [mem 0x3528004000-0x3528004fff 64bit]
[   10.534653] pci 0008:01:00.0: BAR 0: assigned [io  0x300000-0x3000ff]
[   10.541298] pci 0008:00:00.0: PCI bridge to [bus 01-ff]
[   10.546669] pci 0008:00:00.0:   bridge window [io  0x300000-0x300fff]
[   10.553290] pci 0008:00:00.0:   bridge window [mem 0x3528000000-0x35280fffff]
[   10.560642] pci 0008:00:00.0: Max Payload Size set to  128/ 256 (was  256), Max Read Rq  512
[   10.569388] pci 0008:01:00.0: Max Payload Size set to  128/ 128 (was  128), Max Read Rq  512
[   10.578456] pcieport 0008:00:00.0: Adding to iommu group 11
[   10.584471] pcieport 0008:00:00.0: PME: Signaling with IRQ 61
[   10.591378] pcieport 0008:00:00.0: AER: enabled with IRQ 61
[   10.598781] irq: IRQ286: trimming hierarchy from :pmc@c360000
[   10.604769] irq: IRQ287: trimming hierarchy from :interrupt-controller@f400000-1
[   10.612504] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[   10.620393] tegra-se-nvhost 15810000.se: Adding to iommu group 39
[   10.627121] tegra-se-nvhost 15810000.se: initialized
[   10.641870] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[   10.648303] tegra-se-nvhost 15820000.se: Adding to iommu group 40
[   10.654951] tegra-se-nvhost 15820000.se: initialized
[   10.661490] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[   10.667905] tegra-se-nvhost 15840000.se: Adding to iommu group 41
[   10.674492] tegra-se-nvhost 15840000.se: initialized
[   10.681105] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[   10.688111] tegra_actmon d230000.actmon: in actmon_register()...
[   10.694459] tegra_actmon d230000.actmon: bwmgr_disable = 1
[   10.700709] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[   10.709141] hvc_sysfs: hypervisor is not present
[   10.748064] ALSA device list:
[   10.751131]   No soundcards found.
[   10.755509] Freeing unused kernel memory: 3968K
[   10.760223] Run /init as init process
[   10.780460] Root device found: PARTUUID=87d4b4ac-25e6-479d-bfc9-2c2220834052
[   11.218106] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[   11.651272] mmc1: new ultra high speed SDR104 SDXC card at address 59b4
[   11.658381] mmcblk1: mmc1:59b4 SD128 119 GiB
[   11.801959] GPT:Primary header thinks Alt. header is not at the end of the disk.
[   11.809571] GPT:124735487 != 249670655
[   11.813418] GPT:Alternate GPT header not at the end of the disk.
[   11.819626] GPT:124735487 != 249670655
[   11.823491] GPT: Use GNU Parted to correct GPT errors.
[   11.828826]  mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[   12.243834] EXT4-fs (mmcblk1p1): warning: mounting fs with errors, running e2fsck is recommended
[   12.288168] EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Opts: (null)
[   12.304080] Rootfs mounted over PARTUUID=87d4b4ac-25e6-479d-bfc9-2c2220834052
[   12.333395] Switching from initrd to actual rootfs
[   12.581874] systemd[1]: System time before build time, advancing clock.
[   12.799665] systemd[1]: systemd 245.4-4ubuntu3.21 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIB)
[   12.823414] systemd[1]: Detected architecture arm64.
[   13.145706] systemd[1]: Set hostname to <ubuntu>.
[   13.438500] random: systemd: uninitialized urandom read (16 bytes read)
[   13.445441] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewallin.
[   13.458467] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[   13.468476] systemd[1]: Created slice system-modprobe.slice.
[   13.489086] random: systemd: uninitialized urandom read (16 bytes read)
[   13.496386] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   13.517084] random: systemd: uninitialized urandom read (16 bytes read)
[   13.524371] systemd[1]: Created slice system-simcom_wwan.slice.
[   13.545650] systemd[1]: Created slice User and Session Slice.
[   13.565174] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   13.589391] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   13.613149] systemd[1]: Reached target User and Group Name Lookups.
[   13.633095] systemd[1]: Reached target Slices.
[   13.649086] systemd[1]: Reached target Mounting snaps.
[   13.669078] systemd[1]: Reached target Mounted snaps.
[   13.689086] systemd[1]: Reached target Swap.
[   13.705412] systemd[1]: Listening on RPCbind Server Activation Socket.
[   13.725222] systemd[1]: Listening on Syslog Socket.
[   13.745207] systemd[1]: Listening on fsck to fsckd communication Socket.
[   13.769152] systemd[1]: Listening on initctl Compatibility Named Pipe.
[   13.789344] systemd[1]: Listening on Journal Audit Socket.
[   13.809203] systemd[1]: Listening on Journal Socket (/dev/log).
[   13.829269] systemd[1]: Listening on Journal Socket.
[   13.853245] systemd[1]: Listening on udev Control Socket.
[   13.873171] systemd[1]: Listening on udev Kernel Socket.
[   13.894909] systemd[1]: Mounting Huge Pages File System...
[   13.918768] systemd[1]: Mounting POSIX Message Queue File System...
[   13.942694] systemd[1]: Mounting RPC Pipe File System...
[   13.962876] systemd[1]: Mounting Kernel Debug File System...
[   13.982820] systemd[1]: Mounting Kernel Trace File System...
[   14.003525] systemd[1]: Starting Journal Service...
[   14.027190] systemd[1]: Starting Set the console keyboard layout...
[   14.051658] systemd[1]: Starting Create list of static device nodes for the current kernel...
[   14.083502] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[   14.109147] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[   14.119348] systemd[1]: Starting Load Kernel Module efi_pstore...
[   14.142709] systemd[1]: Starting Load Kernel Module pstore_blk...
[   14.166529] systemd[1]: Starting Load Kernel Module pstore_zone...
[   14.190546] systemd[1]: Starting Load Kernel Module ramoops...
[   14.214854] systemd[1]: Starting NVIDIA specific first-boot udev script...
[   14.242999] systemd[1]: Started Nameserver information manager.
[   14.265420] systemd[1]: Reached target Network (Pre).
[   14.309560] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   14.319074] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[   14.336027] systemd[1]: Starting Load Kernel Modules...
[   14.358777] systemd[1]: Starting Remount Root and Kernel File Systems...
[   14.367617] nvmap_heap_init: nvmap_heap_init: created heap block cache
[   14.371470] EXT4-fs (mmcblk1p1): re-mounted. Opts: (null)
[   14.378160] nvmap_page_pool_init: Total RAM pages: 1912631
[   14.389836] nvmap_page_pool_init: nvmap page pool size: 239078 pages (933 MB)
[   14.397303] nvmap_background_zero_thread: PP zeroing thread starting.
[   14.399719] systemd[1]: Starting udev Coldplug all Devices...
[   14.428055] systemd[1]: Started Journal Service.
[   14.592629] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #786435: comm udevadm: iget: checksum invalid
[   14.648250] nvgpu: 17000000.ga10b          nvgpu_nvhost_syncpt_init:135  [INFO]  syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10
[   14.648250]
[   14.699617] urandom_read_iter: 55 callbacks suppressed
[   14.699621] random: systemd-journal: uninitialized urandom read (16 bytes read)
[   14.699674] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #786435: comm systemd: iget: checksum invalid
[   14.818229] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #786435: comm systemd: iget: checksum invalid
[   14.831194] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #786435: comm udevadm: iget: checksum invalid
[   14.831915] random: systemd: uninitialized urandom read (16 bytes read)
[   14.851888] random: systemd-journal: uninitialized urandom read (16 bytes read)
[   14.865460] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #786435: comm systemd-hwdb: iget: checksum invalid
[   15.028627] systemd-journald[262]: Received client request to flush runtime journal.
[   15.141062] random: crng init done
[   15.144581] random: 14 urandom warning(s) missed due to ratelimiting
[   15.587665] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #786435: comm systemd-hwdb: iget: checksum invalid
[   15.723805] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #786435: comm systemd-hwdb: iget: checksum invalid
[   15.751530] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #786435: comm systemd-hwdb: iget: checksum invalid
[   16.045335] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #786435: comm systemd-udevd: iget: checksum invalid
[   16.062794] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #786435: comm systemd-udevd: iget: checksum invalid
[   16.554699] nvidia: loading out-of-tree module taints kernel.
[   16.615598] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[   16.631784] imx219 9-0010: board setup failed
[   16.636484] imx219: probe of 9-0010 failed with error -121
[   16.653854] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[   16.670744] imx219 10-0010: board setup failed
[   16.675461] imx219: probe of 10-0010 failed with error -121
[   16.786464] fusb301 1-0025: toggle_time(0) is not updated
[   17.325725] using random self ethernet address
[   17.333026] using random host ethernet address
[   18.567519] using random self ethernet address
[   18.572121] using random host ethernet address
[   19.909284] EXT4-fs error: 6 callbacks suppressed
[   19.909293] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #786448: comm systemd: iget: checksum invalid
[   19.978951] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #786448: comm sshd: iget: checksum invalid
[   20.369323] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #786448: comm systemd: iget: checksum invalid
[   20.455559] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #786448: comm sshd: iget: checksum invalid
[   20.757448] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #786448: comm systemd: iget: checksum invalid
[   20.809094] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #786448: comm sshd: iget: checksum invalid
[   21.053463] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #786448: comm systemd: iget: checksum invalid
[   21.112674] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #786448: comm sshd: iget: checksum invalid
[   21.341525] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #786448: comm systemd: iget: checksum invalid
[   21.396728] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #786448: comm sshd: iget: checksum invalid
Ubuntu 20.04.6 LTS ubuntu ttyTCU0
ubuntu login: [   25.173268] Bridge firewalling registered
[   37.607612] simcom_wwan: module verification failed: signature and/or required key missing - tainting kernel
[   37.621626] EXT4-fs error: 2 callbacks suppressed
[   37.621635] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #786435: comm systemd-udevd: iget: checksum invalid
[  316.907925] EXT4-fs (mmcblk1p1): error count since last fsck: 1757
[  316.914411] EXT4-fs (mmcblk1p1): initial error at time 1696175548: ext4_lookup:1706: inode 786433
[  316.923640] EXT4-fs (mmcblk1p1): last error at time 1698272060: ext4_lookup:1706: inode 786435
Yes, this is the known sdcard issue. Please move to SSD first.
