RMA Assistance for Multiple Jetson Orin NX units
Hello, I work for a small electronics company where we design devices with OTS components such as the Nvidia Jetson for use on our own carrier board. I have been tasked with starting the RMA process for the Jetson boards we have purchased.
Through our extensive troubleshooting process we have narrowed it down to the Jetson Orin NX hardware, as the rest of our devices function normally. During hardware assembly and testing, a handful of Jetsons began to fail in various ways. While troubleshooting them, they do not boot properly and some output specific error messages over UART, despite attempts to re-flash them with known good software.
All devices were tested and re-flashed on the same Jetson dev board.
Jetson #1: Does not appear to boot when given power, no UART output to diagnose with, and the fan does not initialize.
Jetson #2: During boot UART terminal displays “RAS Uncorrectable Error in CMU_CLOCKS, base=0xe003000:” and continually reboots.
Jetson #3: During boot UART terminal displays “Unhandled Exception in EL3.” then outputs a large list of register values. Does not proceed beyond that point.
Thanks in advance!
The points that really matter and need to clarify first are what is the environment you are using to do these test here?
The most promising way to tell if the module requires RMA is put them on NV developer kit and full flash with latest Jetpack.
We don’t care much about the test result on a custom board for RMA situation. NV devkit test is needed.
Hi Wayne, thanks for the feedback.
As I mentioned, all of the troubleshooting tests were done using the NV devkit. We also use the devkit to re-flash all of our jetsons, but these 3 in particular will not do so anymore. The attempts to re-flash used the same OS build that compiles successfully on all of the rest, whereas these 3 now error out of the flashing process. The UART errors were obtained using the NV devkit as well while attempting a normal boot. Unfortunately our OS build does not work with the latest version of jetpack, but considering these jetsons were previously flashed, worked for a while, then suddenly stopped working, my team reached the conclusion that software is not a likely cause.
For reference however, we are using build r35.4.1
Thanks again.
Which module cannot get flashed on NV devkit? All of them?
Have you tried rel-35.6 or 36.3?
Because I am asking you to test on NV devkit, there should not be any thing like “I can only use r35.4.1 because I need it for my board”. Your board does not matter in this topic and should not get mentioned. Please focus on flashing then with NV devkit first.
Providing the full flash log from host and UART.
Partial log does not provide much help. For example, the last time I saw “RAS Uncorrectable Error in CMU_CLOCKS” is because of voltage issue. I don’t really see much Devkit case has such log.
Correct, all 3 of the boards mentioned will not flash anymore like they used to when we first obtained them. The dev team told me they could not obtain drivers for peripherals that were compatible with the newer jetpack releases at the time we started development, which is why we stuck with 35.4.1 We also have ~20 other jetsons that have been flashed with the same exact build and run as expected with NV devkit, so it is difficult for them to believe that it is software related. I will try to obtain the full UART and flash logs for the devices if they allow me to.
Here are the UART logs for each device at boot time. These were obtained after attempting to flash jetpack 6 onto them, and they appear to be the same as before.
Jetson #1
Still does not boot, and the SDK manager does not recognize it when installed into the nvidia dev kit while in flash mode. Unable to flash at all.
Jetson #2
Summary
[0000.062] I> MB1 (version: 1.4.0.4-t234-54845784-e89ea9bc)
[0000.067] I> t234-A01-0-Silicon (0x12347) Prod
[0000.071] I> Boot-mode : Coldboot
[0000.075] I> Entry timestamp: 0x00000000
[0000.078] I> last_boot_error: 0x0
[0000.081] I> BR-BCT: preprod_dev_sign: 0
[0000.085] I> rst_source: 0x0, rst_level: 0x0
[0000.089] I> Task: SE error check
[0000.092] I> Task: Bootchain select WAR set
[0000.097] I> Task: Enable SLCG
[0000.099] I> Task: CRC check
[0000.102] I> Task: Initialize MB2 params
[0000.107] I> MB2-params @ 0x40060000
[0000.110] I> Task: Crypto init
[0000.113] I> Task: Perform MB1 KAT tests
[0000.117] I> Task: NVRNG health check
[0000.120] I> NVRNG: Health check success
[0000.124] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.130] I> Task: Enabling and initialization of Bandwidth limiter
[0000.136] I> No request to configure MBWT settings for any PC!
[0000.142] I> Task: Secure debug controls
[0000.146] I> Task: strap war set
[0000.149] I> Task: Initialize SOC Therm
[0000.153] I> Task: Program NV master stream id
[0000.157] I> Task: Verify boot mode
[0000.163] I> Task: Alias fuses
[0000.166] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.174] I> Task: Print SKU type
[0000.177] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000038
[0000.182] I> FUSE_OPT_GPC_DISABLE = 0x00000001
[0000.186] I> FUSE_OPT_TPC_DISABLE = 0x0000000f
[0000.190] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0000.195] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0000.199] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0000.203] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.208] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0000.212] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0000.216] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.221] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.225] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.229] I> FUSE_SKU_INFO_0 = 0xd3
[0000.232] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.236] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.240] I> SKU: Prod
[0000.242] I> Task: Boost clocks
[0000.245] I> Initializing NAFLL for BPMP_CPU_NIC.
[0000.250] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[0000.256] I> BPMP NAFLL lock success.
[0000.259] I> BPMP_CPU_NIC : src = 42, divisor = 0
[0000.264] I> Initializing PLLC2 for AXI_CBB.
[0000.268] I> AXI_CBB : src = 35, divisor = 0
[0000.272] I> Task: Voltage monitor
[0000.275] I> VMON: Vmon re-calibration and fine tuning done
[0000.281] I> Task: UPHY init
[0000.286] I> HSIO UPHY init done
[0000.289] W> Skipping GBE UPHY config
[0000.292] I> Task: Boot device init
[0000.295] I> Boot_device: QSPI_FLASH instance: 0
[0000.300] I> Qspi clock source : pllc_out0
[0000.304] I> QSPI Flash: Macronix 64MB
[0000.308] I> QSPI-0l initialized successfully
[0000.312] I> Task: TSC init
[0000.315] I> Task: Load membct
[0000.318] I> RAM_CODE 0x4000401
[0000.321] I> Loading MEMBCT
[0000.324] I> Slot: 1
[0000.326] I> Binary[0] block-66816 (partition size: 0x40000)
[0000.331] I> Binary name: MEM-BCT-0
[0000.334] I> Size of crypto header is 8192
[0000.338] I> Size of crypto header is 8192
[0000.342] I> strt_pg_num(66816) num_of_pgs(16) read_buf(0x40050000)
[0000.349] I> BCH of MEM-BCT-0 read from storage
[0000.353] I> BCH address is : 0x40050000
[0000.357] I> MEM-BCT-0 header integrity check is success
[0000.362] I> Binary magic in BCH component 0 is MEM0
[0000.367] I> component binary type is 0
[0000.371] I> strt_pg_num(66832) num_of_pgs(115) read_buf(0x40040000)
[0000.377] I> MEM-BCT-0 binary is read from storage
[0000.382] I> MEM-BCT-0 binary integrity check is success
[0000.387] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.394] I> RAM_CODE 0x4000401
[0000.399] I> RAM_CODE 0x4000401
[0000.403] I> Task: Load Page retirement list
[0000.407] I> Task: SDRAM params override
[0000.411] I> Task: Save mem-bct info
[0000.415] I> Task: Carveout allocate
[0000.418] I> RCM blob carveout will not be allocated
[0000.423] I> Update CCPLEX IST carveout from MB1-BCT
[0000.428] I> ECC region[0]: Start:0x0, End:0x0
[0000.432] I> ECC region[1]: Start:0x0, End:0x0
[0000.436] I> ECC region[2]: Start:0x0, End:0x0
[0000.440] I> ECC region[3]: Start:0x0, End:0x0
[0000.445] I> ECC region[4]: Start:0x0, End:0x0
[0000.449] I> Non-ECC region[0]: Start:0x80000000, End:0x480000000
[0000.455] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.460] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.464] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.469] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.479] I> allocated(CO:43) base:0xbe000000 size:0x4000000 align: 0x200000
[0000.486] I> allocated(CO:39) base:0x47de00000 size:0x2200000 align: 0x10000
[0000.493] I> allocated(CO:20) base:0x47a000000 size:0x2000000 align: 0x2000000
[0000.500] I> allocated(CO:24) base:0x478000000 size:0x2000000 align: 0x2000000
[0000.508] I> allocated(CO:28) base:0x476000000 size:0x2000000 align: 0x2000000
[0000.515] I> allocated(CO:22) base:0x47c000000 size:0x1000000 align: 0x1000000
[0000.522] I> allocated(CO:35) base:0x475000000 size:0x1000000 align: 0x100000
[0000.529] I> allocated(CO:02) base:0x47d000000 size:0x800000 align: 0x800000
[0000.536] I> allocated(CO:03) base:0x474800000 size:0x800000 align: 0x800000
[0000.543] I> allocated(CO:06) base:0x474000000 size:0x800000 align: 0x800000
[0000.550] I> allocated(CO:56) base:0x473800000 size:0x800000 align: 0x200000
[0000.557] I> allocated(CO:07) base:0x47d800000 size:0x400000 align: 0x400000
[0000.564] I> allocated(CO:33) base:0x473400000 size:0x400000 align: 0x200000
[0000.571] I> allocated(CO:19) base:0x473180000 size:0x280000 align: 0x10000
[0000.577] I> allocated(CO:23) base:0x47dc00000 size:0x200000 align: 0x200000
[0000.584] I> allocated(CO:01) base:0x473000000 size:0x100000 align: 0x100000
[0000.591] I> allocated(CO:05) base:0x472f00000 size:0x100000 align: 0x100000
[0000.598] I> allocated(CO:08) base:0x472e00000 size:0x100000 align: 0x100000
[0000.605] I> allocated(CO:09) base:0x472d00000 size:0x100000 align: 0x100000
[0000.612] I> allocated(CO:12) base:0x472c00000 size:0x100000 align: 0x100000
[0000.619] I> allocated(CO:15) base:0x472b00000 size:0x100000 align: 0x100000
[0000.626] I> allocated(CO:17) base:0x472a00000 size:0x100000 align: 0x100000
[0000.633] I> allocated(CO:27) base:0x472900000 size:0x100000 align: 0x100000
[0000.640] I> allocated(CO:42) base:0x472800000 size:0x100000 align: 0x100000
[0000.647] I> allocated(CO:54) base:0x473100000 size:0x80000 align: 0x80000
[0000.654] I> allocated(CO:34) base:0x4727f0000 size:0x10000 align: 0x10000
[0000.660] I> allocated(CO:72) base:0x4725f0000 size:0x200000 align: 0x10000
[0000.667] I> allocated(CO:47) base:0x472000000 size:0x400000 align: 0x200000
[0000.674] I> allocated(CO:50) base:0x471e00000 size:0x200000 align: 0x100000
[0000.681] I> allocated(CO:48) base:0x4725d0000 size:0x20000 align: 0x10000
[0000.688] I> allocated(CO:69) base:0x4725b0000 size:0x20000 align: 0x10000
[0000.695] I> allocated(CO:49) base:0x4725a0000 size:0x10000 align: 0x10000
[0000.701] I> NSDRAM base: 0x80000000, end: 0x4725f0000, size: 0x3f25f0000
[0000.708] I> Task: Thermal check
[0000.711] I> Using min_chip_limit as min_tmon_limit
[0000.716] I> Using max_chip_limit as max_tmon_limit
[0000.721] I> BCT max_tmon_limit = 105
[0000.724] I> BCT min_tmon_limit = -28
[0000.728] I> BCT max_tmon_limit = 105
[0000.731] I> BCT min_tmon_limit = -28
[0000.735] I> SKU specific max_chip_limit = 105
[0000.739] I> SKU specific min_chip_limit = -28
[0000.743] I> BCT max_chip_limit = 105
[0000.747] I> BCT min_chip_limit = -28
[0000.750] I> enable_soctherm_polling = 0
[0000.754] I> max temp read = 41
[0000.757] I> min temp read = 40
[0000.760] I> Enabling thermtrip
[0000.763] I> Task: Update FSI SCR with thermal fuse data
[0000.768] I> Task: Enable WDT 5th expiry
[0000.772] I> Task: I2C register
[0000.775] I> Task: Set I2C bus freq
[0000.778] I> Task: Reset FSI
[0000.781] I> Task: Pinmux init
[0000.784] I> skipped mmio_addr = 0x9240008
[0000.788] I> skipped mmio_addr = 0x9240000
[0000.792] I> skipped mmio_addr = 0x9240010
[0000.796] I> skipped mmio_addr = 0x9240018
[0000.800] I> skipped mmio_addr = 0x9240020
[0000.804] I> skipped mmio_addr = 0x9240030
[0000.808] I> skipped mmio_addr = 0x9240028
[0000.812] I> skipped mmio_addr = 0x9240038
[0000.815] I> skipped mmio_addr = 0x9240040
[0000.819] I> skipped mmio_addr = 0x9240048
[0000.823] I> skipped mmio_addr = 0x9241000
[0000.827] I> skipped mmio_addr = 0x9241008
[0000.831] I> skipped mmio_addr = 0x9241010
[0000.835] I> skipped mmio_addr = 0x9241018
[0000.839] I> skipped mmio_addr = 0x9241020
[0000.843] I> skipped mmio_addr = 0x9241028
[0000.847] I> skipped mmio_addr = 0x9241030
[0000.851] I> skipped mmio_addr = 0x9241038
[0000.855] I> skipped mmio_addr = 0x9241040
[0000.859] I> skipped mmio_addr = 0x9242000
[0000.863] I> skipped mmio_addr = 0x9242008
[0000.867] I> Task: Prod config init
[0000.870] I> Task: Pad voltage init
[0000.873] I> Task: Prod init
[0000.876] I> Task: Program rst req config reg
[0000.880] I> Task: Common rail init
[0000.884] I> DONE: Thermal config
[0000.888] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.896] I> DONE: SOC rail config
[0000.900] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0000.906] I> DONE: MEMIO rail config
[0000.910] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.
[0000.916] I> DONE: GPU rail info
[0000.920] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.
[0000.926] I> DONE: CV rail info
[0000.929] I> Task: Mem clock src
[0000.932] I> Task: Misc. board config
[0000.936] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0000.942] I> Task: SDRAM init
[0000.945] I> MemoryType: 4 MemBctRevision: 1
[0000.951] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 1
[0000.959] I> MSS CAR: Init PLLM
[0000.962] I> MSS CAR: Init PLLHUB
[0000.967] I> Encryption: MTS: en, TX: en, VPR: en, GSC: en
[0000.978] I> SDRAM initialized!
[0000.981] I> SDRAM Size in Total 0x400000000
[0000.985] I> Task: Dram Ecc scrub
[0000.988] I> Task: DRAM alias check
[0000.998] I> Task: Program NSDRAM carveout
[0001.002] I> NSDRAM carveout encryption is enabled
[0001.007] I> Program NSDRAM carveout
[0001.010] I> Task: Register checker
[0001.014] I> Task: Enable clock-mon
[0001.018] I> FMON: Fmon re-programming done
[0001.022] I> Task: Mapper init
[0001.025] I> Task: SC7 Context Init
[0001.028] I> Task: CCPLEX IST init
[0001.031] I> Task: CPU WP0
[0001.034] I> Loading MCE
[0001.036] I> Slot: 1
[0001.038] I> Binary[8] block-85760 (partition size: 0x80000)
[0001.044] I> Binary name: MCE
[0001.047] I> Size of crypto header is 8192
[0001.051] I> Size of crypto header is 8192
[0001.055] I> strt_pg_num(85760) num_of_pgs(16) read_buf(0x4003e000)
[0001.061] I> BCH of MCE read from storage
[0001.065] I> BCH address is : 0x4003e000
[0001.069] I> MCE header integrity check is success
[0001.073] I> Binary magic in BCH component 0 is MTSM
[0001.078] I> component binary type is 8
[0001.082] I> Size of crypto header is 8192
[0001.086] I> strt_pg_num(85776) num_of_pgs(350) read_buf(0x40000000)
[0001.094] I> MCE binary is read from storage
[0001.098] I> MCE binary integrity check is success
[0001.103] I> Binary MCE loaded successfully at 0x40000000 (0x2baf0)
[0001.109] I> Size of crypto header is 8192
[0001.120] I> Size of crypto header is 8192
[0001.124] I> Sending WP0 mailbox command to PSC
[0001.133] I> Task: XUSB Powergate
[0001.136] I> Skipping powergate XUSB.
[0001.140] I> Task: MB1 fixed firewalls
[0001.146] W> Firewall readback mismatch
[0001.151] I> Task: Load bpmp-fw
[0001.154] I> Slot: 1
[0001.156] I> Binary[15] block-72960 (partition size: 0x180000)
[0001.162] I> Binary name: BPMP_FW
[0001.165] I> Size of crypto header is 8192
[0001.169] I> Size of crypto header is 8192
[0001.173] I> strt_pg_num(72960) num_of_pgs(16) read_buf(0x807fe000)
[0001.179] I> BCH of BPMP_FW read from storage
[0001.184] I> BCH address is : 0x807fe000
[0001.187] I> BPMP_FW header integrity check is success
[0001.192] I> Binary magic in BCH component 0 is BPMF
[0001.197] I> component binary type is 15
[0001.201] I> Size of crypto header is 8192
[0001.205] I> strt_pg_num(72976) num_of_pgs(1990) read_buf(0x80000000)
[0001.222] I> BPMP_FW binary is read from storage
[0001.229] I> BPMP_FW binary integrity check is success
[0001.234] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xf8bc0)
[0001.240] I> Slot: 1
[0001.242] I> Binary[16] block-76032 (partition size: 0x400000)
[0001.248] I> Binary name: BPMP_FW_DTB
[0001.251] I> Size of crypto header is 8192
[0001.255] I> Size of crypto header is 8192
[0001.259] I> strt_pg_num(76032) num_of_pgs(16) read_buf(0x807fc000)
[0001.266] I> BCH of BPMP_FW_DTB read from storage
[0001.270] I> BCH address is : 0x807fc000
[0001.274] I> BPMP_FW_DTB header integrity check is success
[0001.279] I> Binary magic in BCH component 0 is BPMD
[0001.284] I> component binary type is 16
[0001.288] I> Size of crypto header is 8192
[0001.292] I> strt_pg_num(76048) num_of_pgs(733) read_buf(0x807a05f0)
[0001.302] I> BPMP_FW_DTB binary is read from storage
[0001.308] I> BPMP_FW_DTB binary integrity check is success
[0001.313] I> Binary BPMP_FW_DTB loaded successfully at 0x807a05f0 (0x5b940)
[0001.320] I> Task: BPMP fw ast config
[0001.323] I> Task: Load psc-fw
[0001.326] I> Slot: 1
[0001.328] I> Binary[17] block-84224 (partition size: 0xc0000)
[0001.334] I> Binary name: PSC_FW
[0001.337] I> Size of crypto header is 8192
[0001.341] I> Size of crypto header is 8192
[0001.345] I> strt_pg_num(84224) num_of_pgs(16) read_buf(0x80ffe000)
[0001.351] I> BCH of PSC_FW read from storage
[0001.355] I> BCH address is : 0x80ffe000
[0001.359] I> PSC_FW header integrity check is success
[0001.364] I> Binary magic in BCH component 0 is PFWP
[0001.369] I> component binary type is 17
[0001.373] I> Size of crypto header is 8192
[0001.376] I> strt_pg_num(84240) num_of_pgs(591) read_buf(0x80fb4200)
[0001.386] I> PSC_FW binary is read from storage
[0001.391] I> PSC_FW binary integrity check is success
[0001.396] I> Binary PSC_FW loaded successfully at 0x80fb4200 (0x49df0)
[0001.402] I> Task: Load nvdec-fw
[0001.405] I> Slot: 1
[0001.407] I> Binary[7] block-69376 (partition size: 0x100000)
[0001.413] I> Binary name: NVDEC
[0001.416] I> Size of crypto header is 8192
[0001.420] I> Size of crypto header is 8192
[0001.424] I> strt_pg_num(69376) num_of_pgs(16) read_buf(0x800fe000)
[0001.430] I> BCH of NVDEC read from storage
[0001.434] I> BCH address is : 0x800fe000
[0001.438] I> NVDEC header integrity check is success
[0001.443] I> Binary magic in BCH component 0 is NDEC
[0001.448] I> component binary type is 7
[0001.451] I> Size of crypto header is 8192
[0001.455] I> strt_pg_num(69392) num_of_pgs(560) read_buf(0x80000000)
[0001.465] I> NVDEC binary is read from storage
[0001.470] I> NVDEC binary integrity check is success
[0001.474] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0001.481] I> Size of crypto header is 8192
[0001.492] I> Task: Load tsec-fw
[0001.495] I> TSEC-FW load support not enabled
[0001.499] I> Task: GPIO interrupt map
[0001.503] I> Task: SC7 context save
[0001.506] I> Slot: 1
[0001.508] I> Binary[27] block-0 (partition size: 0x100000)
[0001.514] I> Binary name: BR_BCT
[0001.517] I> Size of crypto header is 8192
[0001.521] I> Size of crypto header is 8192
[0001.524] I> Size of crypto header is 8192
[0001.528] I> strt_pg_num(0) num_of_pgs(16) read_buf(0xa0000000)
[0001.534] I> BR_BCT binary is read from storage
[0001.539] I> BR_BCT binary integrity check is success
[0001.544] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[0001.550] I> Slot: 1
[0001.552] I> Binary[13] block-86784 (partition size: 0x30000)
[0001.558] I> Binary name: SC7-FW
[0001.561] I> Size of crypto header is 8192
[0001.565] I> Size of crypto header is 8192
[0001.569] I> Size of crypto header is 8192
[0001.572] I> Size of crypto header is 8192
[0001.576] I> strt_pg_num(86784) num_of_pgs(16) read_buf(0xa0002000)
[0001.583] I> BCH of SC7-FW read from storage
[0001.587] I> BCH address is : 0xa0002000
[0001.591] I> SC7-FW header integrity check is success
[0001.595] I> Binary magic in BCH component 0 is WB0B
[0001.600] I> component binary type is 13
[0001.604] I> Size of crypto header is 8192
[0001.608] I> strt_pg_num(86800) num_of_pgs(349) read_buf(0xa0004000)
[0001.616] I> SC7-FW binary is read from storage
[0001.621] I> SC7-FW binary integrity check is success
[0001.626] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x2ba00)
[0001.632] I> Slot: 1
[0001.634] I> Binary[22] block-87168 (partition size: 0x30000)
[0001.640] I> Binary name: PSC_RF
[0001.643] I> Size of crypto header is 8192
[0001.647] I> Size of crypto header is 8192
[0001.651] I> Size of crypto header is 8192
[0001.655] I> Size of crypto header is 8192
[0001.659] I> strt_pg_num(87168) num_of_pgs(16) read_buf(0xa002fa00)
[0001.665] I> BCH of PSC_RF read from storage
[0001.669] I> BCH address is : 0xa002fa00
[0001.673] I> PSC_RF header integrity check is success
[0001.678] I> Binary magic in BCH component 0 is PSCR
[0001.683] I> component binary type is 22
[0001.686] I> Size of crypto header is 8192
[0001.690] I> strt_pg_num(87184) num_of_pgs(224) read_buf(0xa0031a00)
[0001.698] I> PSC_RF binary is read from storage
[0001.702] I> PSC_RF binary integrity check is success
[0001.707] I> Binary PSC_RF loaded successfully at 0xa0031a00 (0x1be60)
[0001.717] I> Task: Save WP0 payload to SC7 ctx
[0001.721] I> Task: Load MB2rf binary to SC7 ctx
[0001.725] I> Slot: 1
[0001.727] I> Binary[14] block-87552 (partition size: 0x20000)
[0001.733] I> Binary name: MB2_RF
[0001.736] I> Size of crypto header is 8192
[0001.740] I> Size of crypto header is 8192
[0001.744] I> Size of crypto header is 8192
[0001.748] I> Size of crypto header is 8192
[0001.752] I> strt_pg_num(87552) num_of_pgs(16) read_buf(0xa00d5d10)
[0001.758] I> BCH of MB2_RF read from storage
[0001.762] I> BCH address is : 0xa00d5d10
[0001.766] I> MB2_RF header integrity check is success
[0001.771] I> Binary magic in BCH component 0 is MB2R
[0001.776] I> component binary type is 14
[0001.779] I> Size of crypto header is 8192
[0001.783] I> strt_pg_num(87568) num_of_pgs(224) read_buf(0xa00d7d10)
[0001.791] I> MB2_RF binary is read from storage
[0001.796] I> MB2_RF binary integrity check is success
[0001.800] I> Binary MB2_RF loaded successfully at 0xa00d7d10 (0x1bf60)
[0001.807] I> Task: Save fuse alias data to SC7 ctx
[0001.811] I> Task: Save PMIC data to SC7 ctx
[0001.816] I> Task: Save Pinmux data to SC7 ctx
[0001.820] I> Task: Save Pad Voltage data to SC7 ctx
[0001.825] I> Task: Save controller prod data to SC7 ctx
[0001.830] I> Task: Save prod cfg data to SC7 ctx
[0001.834] I> Task: Save I2C bus freq data to SC7 ctx
[0001.839] I> Task: Save SOCTherm data to SC7 ctx
[0001.843] I> Task: Save FMON data to SC7 ctx
[0001.847] I> Task: Save VMON data to SC7 ctx
[0001.852] I> Task: Save TZDRAM data to SC7 ctx
[0001.856] I> Task: Save GPIO int data to SC7 ctx
[0001.860] I> Task: Save clock data to SC7 ctx
[0001.864] I> Task: Save debug data to SC7 ctx
[0001.869] I> Task: Save MBWT data to SC7 ctx
[0001.877] I> SC7 context save done
[0001.880] I> Task: Load MB2/Applet/FSKP
[0001.884] I> Loading MB2
[0001.886] I> Slot: 1
[0001.888] I> Binary[6] block-71424 (partition size: 0x80000)
[0001.894] I> Binary name: MB2
[0001.896] I> Size of crypto header is 8192
[0001.900] I> Size of crypto header is 8192
[0001.904] I> strt_pg_num(71424) num_of_pgs(16) read_buf(0x8007e000)
[0001.911] I> BCH of MB2 read from storage
[0001.914] I> BCH address is : 0x8007e000
[0001.918] I> MB2 header integrity check is success
[0001.923] I> Binary magic in BCH component 0 is MB2B
[0001.928] I> component binary type is 6
[0001.931] I> Size of crypto header is 8192
[0001.935] I> strt_pg_num(71440) num_of_pgs(846) read_buf(0x80000000)
[0001.946] I> MB2 binary is read from storage
[0001.951] I> MB2 binary integrity check is success
[0001.956] I> Binary MB2 loaded successfully at 0x80000000 (0x69a70)
[0001.962] I> Task: Map CCPLEX SHARED carveout
[0001.966] I> Task: Prepare MB2 params
[0001.970] I> Task: Dram ecc test
[0001.973] I> Task: Misc NV security settings
[0001.977] I> NVDEC sticky bits programming done
[0001.982] I> Successfully powergated NVDEC
[0001.986] I> Task: Disable/Reload WDT
[0001.989] I> Task: Program misc carveouts
[0001.993] I> Program IPC carveouts
[0001.997] I> Task: Disable SCPM/POD reset
[0002.000] I> SLCG Global override status := 0x0
[0002.005] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-22833a33)
I> Emulation:
I> Entry timestamp: 0x001f0d1d
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0x473800000, size:0x800000]
I> Task: MB2 Params integrity check
I> Task: Enable CCPLEX WDT 5th expiry
I> Task: ARI update carveout TZDRAM
I> Task: Configure OEM set LA/PTSA values
I> Task: Check MC errors
I> Task: SMMU external bypass disable
I> Task: Enable hot-plug capability
I> Task: TZDRAM heap init
I> Task: PSC mailbox init
I> Task: Enable clock for external modules
I> Task: Measured Boot init
I> Task: fTPM silicon identity init
I> fTPM is not enabled.
I> Task: OEM SC7 context save init
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout
I> Task: Program CBB PCIE AMAP regions
I> Secondary storage device: QSPI_FLASH instance: 0
I> Task: Partition Manager Init
I> strt_pg_num(130592) num_of_pgs(1) read_buf(0x473801000)
I> strt_pg_num(130560) num_of_pgs(32) read_buf(0x473801200)
I> Found 60 partitions in QSPI_FLASH (instance 0)
I> Task: Pass DRAM ECC PRL Flag to FSI
I> Task: Load and authenticate registered FWs
I> Task: Load AUXP FWs
I> Successfully register SPE FW load task with MB2 loader
I> Successfully register RCE FW load task with MB2 loader
I> Successfully register DCE FW load task with MB2 loader
I> Unpowergating APE
I> Unpowergate done
I> Successfully register APE FW load task with MB2 loader
I> Skipping FSI FW load
I> Successfully register XUSB FW load task with MB2 loader
I> Successfully register PVA FW load task with MB2 loader
I> Partition name: B_spe-fw
I> Size of partition: 589824
I> Binary@ device:3/0 block-118016 (partition size: 0x90000), name: B_spe-fw
I> strt_pg_num(118016) num_of_pgs(16) read_buf(0x40067a30)
I> strt_pg_num(118032) num_of_pgs(512) read_buf(0x472e00000)
I> Partition name: B_rce-fw
I> Size of partition: 1048576
I> Binary@ device:3/0 block-119168 (partition size: 0x100000), name: B_rce-fw
I> strt_pg_num(119168) num_of_pgs(16) read_buf(0x40067a30)
I> strt_pg_num(119184) num_of_pgs(880) read_buf(0x472a00000)
I> spe: Authentication Finalize Done
I> Binary spe loaded successfully at 0x472e00000
I> Partition name: B_dce-fw
I> Size of partition: 5242880
I> Binary@ device:3/0 block-107776 (partition size: 0x500000), name: B_dce-fw
I> strt_pg_num(107776) num_of_pgs(16) read_buf(0x40067a30)
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0x472a00000
I> Successfully register RCE FW context save task with MB2 loader
I> dce : oem authentication of header done
I> strt_pg_num(107792) num_of_pgs(1) read_buf(0x4739400d8)
I> strt_pg_num(107792) num_of_pgs(8) read_buf(0x4739400d8)
I> dce : meta-blob integrity check is success.
I> strt_pg_num(107800) num_of_pgs(512) read_buf(0x4738000c0)
I> strt_pg_num(108312) num_of_pgs(512) read_buf(0x4738400c0)
I> dce : will be decompressed at 0x47a000000
I> version 1 Bin 1 BCheckSum 0 content_size 0 Content ChkSum 1 reserved_00 0
I> Reserved10 0 BlockMaxSize 5 Reserved11 0
I> strt_pg_num(108824) num_of_pgs(512) read_buf(0x4738800c0)
I> dce : decompressed to 12099712 bytes
I> dce: plain binary integrity check is success
I> Partition name: B_adsp-fw
I> Size of partition: 2097152
I> Binary@ device:3/0 block-121216 (partition size: 0x200000), name: B_adsp-fw
I> strt_pg_num(121216) num_of_pgs(16) read_buf(0x40067a30)
I> strt_pg_num(121232) num_of_pgs(800) read_buf(0x47d800000)
I> dce: Authentication Finalize Done
I> Binary dce loaded successfully at 0x47a000000
I> Partition name: B_xusb-fw
I> Size of partition: 262144
I> Binary@ device:3/0 block-72448 (partition size: 0x40000), name: B_xusb-fw
I> strt_pg_num(72448) num_of_pgs(16) read_buf(0x40067a30)
I> strt_pg_num(72464) num_of_pgs(312) read_buf(0x472f00000)
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0x47d800000
I> Successfully register APE FW context save task with MB2 loader
I> Partition name: B_pva-fw
I> Binary@ device:3/0 block-125312 (partition size: 0x40000), name: B_pva-fw
I> strt_pg_num(125312) num_of_pgs(16) read_buf(0x40067a30)
I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0x472f00000
I> Successfully register XUSB FW context save task with MB2 loader
I> pva-fw : oem authentication of header done
I> strt_pg_num(125328) num_of_pgs(1) read_buf(0x4739400d8)
I> strt_pg_num(125328) num_of_pgs(8) read_buf(0x4739400d8)
I> pva-fw : meta-blob integrity check is success.
I> strt_pg_num(125336) num_of_pgs(512) read_buf(0x4738000c0)
I> pva-fw : will be decompressed at 0x473180000
I> pva-fw : decompressed to 2156512 bytes
I> pva-fw: plain binary integrity check is success
I> pva-fw: Authentication Finalize Done
I> Binary pva-fw loaded successfully at 0x473180000
I> Successfully register PVA FW context save task with MB2 loader
I> Task: Carveout setup
I> Program remaining OEM carveouts
I> Task: Enable FSITHERM
I> Task: Enable FSI VMON
I> Task: Validate FSI Therm readings
I> Task: Restore XUSB sec
I> Task: Enable FSI SE clock
I> Task: Initialize SBSA UART CAR
I> Task: Initialize CPUBL Params
I> CPUBL-params @ 0x476000000
I> Task: Ratchet update
W> Skip ratchet update - OPTIN fuse not set
I> Task: Prepare eeprom data
I> Task: Revoke PKC fuse
I> PKC revoke fuse burn not requested
I> Task: FSI padctl context save
W> Skipping FSI padctl config save: fsi not enabled
I> Task: Unpowergate APE
W> mb2_unpowergate_ape: skip! APE is in unpowergated state
I> Task: Memctrl reconfig pending clients
I> Task: OEM firewalls
I> OEM firewalls configured
I> Task: Powergate APE
I> Powergating APE
I> Powergate done
I> Task: OEM firewall restore saved settings
I> Task: Unhalt AUXPs
I> Unhalting SPE…
I> Enabling combined UART
▒▒▒▒spe: early_init
▒▒▒▒vic initialized
▒▒▒▒tsc initialized
▒▒▒▒aon lic initialized
▒▒▒▒spe: tag is 5243985d1b1eb3f06fac6d36bd7e74ac
▒▒▒▒spe: SafeRTOS v8.4
▒▒▒▒spe: init
▒▒▒▒scheduler initialized
▒▒▒▒aon hsp initialized
▒▒▒▒tag initialized
▒▒▒▒tcu initialized
▒▒▒▒bpmp ipc initialized
▒▒▒▒spe: late init
▒▒▒▒cpu_nic clock initialized
▒▒▒▒apb clock initialized
▒▒▒▒pm initialized
▒▒▒▒bpmp hsp initialized
▒▒▒▒top1 hsp initialized
▒▒▒▒ccplex ipc initialized
▒▒▒▒spe: start scheduler
I> Task: Trigger mailbox for PSC-BL1 exit
I> Sending opcode 0x4d420802 to psc
I> Received ACK from psc
I> Task: Start secure NOR provision
I> Skip Secure NOR provisioning
I> Task: Trigger load FSI keyblob
I> Task: Complete load FSI keyblob
I> Task: MB2-PSC_FW Key Manager Init
I> Sending opcode OP_PSC_KEY_MANAGER to psc-fw
I> Sending opcode 0x4b45594d to psc
hwwdt_init: WDT boot cfg 0x710010 sts 0x10
bpmp: socket 0
bpmp: base binary md5 is da583751bbfe2b7f6e204562d97ff39e
bpmp: combined binary md5 is dc3fd3cac60f9b918e11d435834d12a3
bpmp: firmware tag is dc3fd3cac60f9b918e11-da583751bbf
initialized vwdt
initialized mail_early
initialized fuse
initialized vfrel
initialized adc
fmon_populate_monitors: found 199 monitors
initialized fmon
initialized mc
initialized reset
initialized uphy_early
initialized emc_early
initialized pm
465 clocks registered
initialized clk_mach
initialized clk_cal_early
initialized clk_mach_early_config
initialized io_dpd
initialized soctherm
initialized regime
initialized i2c
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
initialized vrmon
initialized regulator
▒▒I> Received ACK from psc
I> Task: Unhalt FSI
I> FSI unhalt skipped
I> Unhalting RCE
I> RCE unhalt successful
I> Unhalting DCE
I> DCE unhalt successful
I> APE unhalt skipped
I> Tas▒▒initialized avfs_clk_platform
initialized powergate
▒▒k: ▒▒[ 2.580440] Camera-FW on t234-rce-safe started
▒▒ini▒▒TCU early console enabled.
▒▒tialized dvs
initialized clk_mach_config
initialized suspend
initialized strap
initialized mce_dbell
▒▒Load HV/CPUBL
I> Task: Load TOS
I> Task: Trigger load TSEC leyblob
I> Sending opcode 0x53535452 to psc
I> Sent opcode to psc
I> Partition name: B_cpu-bootloader
▒▒I> Size of partition: 3670016
I> Binary@ device:3/0 block-87808 (partition size: 0x380000), name: B_cpu-bootloader
I> strt_pg_num(87808) num_of_pgs(16) read_buf(0x40067a30)
I> cpubl : oem authentication ▒▒initialized emc
initialized emc_mrq
▒▒of header done
I> strt_pg_num(878▒▒initialized clk_cal
initialized uphy_dt
initialized uphy_mrq
HSIO UPHY reset has been de-asserted 0x0
initialized uphy
▒▒DCE Started
DCE_R5_In▒▒initialized pg_late
initialized pg_mrq_init
swdtimer_init: reg polling start w period 47 ms
initialized swdtimer
initialized hwwdt_late
initialized bwmgr
initialized thermal_host_trip
initialized thermal_mrq
initialized oc_mrq
initialized reset_mrq
initialized mail_mrq
initialized fmon_mrq
initialized clk_mrq
initialized avfs_mrq
initialized i2c_mrq
initialized tag_mrq
initialized bwmgr_mrq
initialized console_mrq
missing prod DT calibration data for 199 fmons
initialized clk_sync_fmon_post
▒▒24) num_of_pgs(1) read_buf(0x473943c98)
▒▒it
MPU enabled
DCE_SW_Init
▒▒I> strt_pg_num(87824)▒▒initialized clk_cal_late
initialized noc_late
initialized cvc
▒▒ num_of_pgs(8) read_buf(0x4739▒▒initialized avfs_clk_mach_post
initialized avfs_clk_platform_post
initialized cvc_late
WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/2 have not matching zones 0/1
WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/3 have not matching zone list sizes 1/3
WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/3 have not matching zones 0/2
WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/0 have not matching zones 1/0
WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/3 have not matching zone list sizes 1/3
WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/3 have not matching zones 1/2
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/0 have not matching zone list sizes 3/1
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/0 have not matching zones 2/0
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/2 have not matching zone list sizes 3/1
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/2 have not matching zones 2/1
initialized rm
initialized console_late
handling unreferenced clks
enable can1_core
enable can1_host
enable can2_core
enable can2_host
enable pwm3
enable sdmmc4_axicif
enable mss_encrypt
enable maud
enable pllg_ref
enable dsi_core▒▒[ 2.812154] Camera-FW on t234-rce-safe ready SHA1=e2238c99 (crt 12.418 ms,▒▒
enable aza_2xbit
enable xusb_ss
enable xusb_fs
enable xusb_falcon
enable▒▒ total boot 245.205 ms)
▒▒ xusb_core_mux
enable dsi_lp
initialized clk_mach_post
initialized pg_post
initialized regulator_post
initialized profile
initialized mrq
initialized patrol_scrubber
initialized cactmon
initialized extras_post
bpmp: init complete
▒▒43c98)
▒▒Admin Task Init
Admin Task Init compl▒▒I> cpubl : meta-blob integrity check is success.
I> strt_pg_num(87832) num_of_pgs(512) read_buf(0x473803c80)
▒▒ete
Print Task Init
RM Task Init
SHA Task ▒▒I> strt_pg_num(88344) num_of_pgs(512) read_buf(0x473843c80)
▒▒Init
Admin Tas▒▒I> cpubl : will be decompressed at 0x472000000
I> version 1 Bin 1 BCheckSum 0▒▒k Started
DCE SC7 SHA Enabled
RM Task Started
RM Task Running
Print Task S▒▒ content_size 0 Content ChkSum 1 reserved_00 0
▒▒tarted
Print Task Running
SHA Task Started
DCE: FW Boot Complete
Admin Task Running
SHA Task Running
▒▒I> strt_pg_num(88856) num_of_pgs(512) read_buf(0x473883c80)
I> strt_pg_num(89368) num_of_pgs(512) read_buf(0x4738c3c80)
I> strt_pg_num(89880) num_of_pgs(512) read_buf(0x473903c80)
I> strt_pg_num(90392) num_of_pgs(512) read_buf(0x473803c80)
I> strt_pg_num(90904) num_of_pgs(512) read_buf(0x473843c80)
I> strt_pg_num(91416) num_of_pgs(512) read_buf(0x473883c80)
I> strt_pg_num(91928) num_of_pgs(512) read_buf(0x4738c3c80)
I> strt_pg_num(92440) num_of_pgs(512) read_buf(0x473903c80)
I> strt_pg_num(92952) num_of_pgs(512) read_buf(0x473803c80)
I> strt_pg_num(93464) num_of_pgs(512) read_buf(0x473843c80)
I> strt_pg_num(93976) num_of_pgs(512) read_buf(0x473883c80)
I> cpubl : decompressed to 3563648 bytes
I> cpubl: plain binary integrity check is success
I> Partition name: B_secure-os
I> Size of partition: 4194304
I> Binary@ device:3/0 block-94976 (partition size: 0x400000), name: B_secure-os
I> strt_pg_num(94976) num_of_pgs(16) read_buf(0x40067a30)
I> strt_pg_num(94992) num_of_pgs(3672) read_buf(0xc1d35000)
I> NSDRAM carveout base: 0x80000000, size: 0x3f25f0000
I> cpubl_params: nsdram: carveout: 1, encryption: 1
I> cpubl: Authentication Finalize Done
I> Binary cpubl loaded successfully at 0x472000000
I> tos: Authentication Finalize Done
I> Binary tos loaded successfully at 0xc1d35000
I> Relocating OP-TEE dtb from: 0xc1eff180 to 0xbe040020, size: 0x2754
I> [0] START: 0x80000000, SIZE: 0x3f25f0000
I> [1] START: 0x476000000, SIZE: 0x2000000
I> Setting NS memory ranges to OP-TEE dtb finished.
I> Partition name: B_eks
I> Binary@ device:3/0 block-107264 (partition size: 0x40000), name: B_eks
I> strt_pg_num(107264) num_of_pgs(16) read_buf(0x40067a30)
I> strt_pg_num(107280) num_of_pgs(8) read_buf(0xbe020000)
I> eks: Authentication Finalize Done
I> Binary eks loaded successfully at 0xbe020000
I> EKB detected (length: 0x410) @ VA:0xbe020000
I> Task: Add cpubl params integrity check
I> Added cpubl params digest.
I> Task: Prepare TOS params
I> Setting EKB blob info to OPTEE dtb finished.
I> Setting OPTEE arg3: 0xbe040020
I> OEM sc7 context saved
I> Task: Disable MSS perf stats
I> Task: Program display sticky bits
I> Task: Storage device deinit
I> Task: SMMU init
I> Task: Program GICv3 registers
I> Task: Audit firewall settings
I> Task: Bootchain failure check
I> Current Boot-Chain Slot: 1
I> BR-BCT Boot-Chain is 1, and status is 1. Set UPDATE_BRBCT bit to 0
I> Task: Burn RESERVED_ODM0 fuse
I> Task: Lock fusing
I> Task: Clear dec source key
I> MB2 finished
▒▒NOTICE: BL31: v2.8(release):e12e3fa93
NOTICE: BL31: Built : 21:01:44, Sep 12 2024
I/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 4.2 (gcc version 11.3.0 (Buildroot 2022.08)) #2 Fri Sep 13 04:10:17 UTC 2024 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check Porting guidelines — OP-TEE documentation documentation
I/TC: Primary CPU initializing
I/TC: Test OEM keys are being used. This is insecure for shipping products!
I/TC: fTPM ID is not enabled.
I/TC: ftpm-helper PTA: fTPM DT or EKB is not available. fTPM provisioning is not supported.
I/TC: Primary CPU switching to normal world boot
Jetson UEFI firmware (version 36.4.0-gcid-37537400 built on 2024-09-13T04:02:39+00:00)
▒▒I/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
I/TC: WARNING: Test UEFI variable auth key is being used !
I/TC: WARNING: UEFI variable protection is not fully enabled !
▒▒[ 5.975952] Camera-FW on t234-rce-safe started
▒▒[ 6.037745] Camera-FW on t234-rce-safe ready SHA1=e2238c99 (crt 1.355 ms, total boot 63.211 ms)
Jetson System firmware version 36.4.0-gcid-37537400 date 2024-09-13T04:02:39+00:
00
ESC to enter Setup.
F11 to enter Boot Manager Menu.
Enter to continue boot.
L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel…
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services…
▒▒ERROR: **************************************
ERROR: RAS Uncorrectable Error in CMU_CLOCKS, base=0xe003000:
ERROR: Status = 0x64000101
ERROR: SERR = IMPLEMENTATION DEFINED error: 0x1
ERROR: IERR = ADC0 VMON Error: 0x1
ERROR: MISC0 = 0x1285c0000
ERROR: MISC1 = 0x0
ERROR: MISC2 = 0x0
ERROR: MISC3 = 0x0
EERROR: sde__dipptcch_eenn rretunned–1
                                     ERROR:   Powering off Ror:
ERROR: MISC0 = 0x128580000
ERROR: MISC1 = 0x0
ERROR: MISC2 = 0x0
ERROR: MISC3 = 0x0
ERROR: sdei_dispatch_event returned -1
ERRRR: Powinfore********************
ERROR: MISC1 = 0x0
ERROR: MISC2 = 0x0
ERROR: MISC3 = 0x0
***********************o*e
ERROR: MISC1 = 0x0
ERROR: MISC2 = 0x0
ERROR: MISC3 = 0x0
ERROR: Powering off core
ERROR: MISC1 = 0x0
ERROR: MISC2 = 0x0
ERROR: MISC3 = 0x0
ERROR: MISC1 = 0x0
ERROR: MISC2 = 0x0
ERROR: MISC3 = 0x0
Jetson #3
Summary
[0000.063] I> MB1 (version: 1.2.0.0-t234-54845784-562369e5)
[0000.069] I> t234-A01-0-Silicon (0x12347) Prod
[0000.073] I> Boot-mode : Coldboot
[0000.076] I> Entry timestamp: 0x00000000
[0000.080] I> last_boot_error: 0x0
[0000.083] I> BR-BCT: preprod_dev_sign: 0
[0000.087] I> rst_source: 0x0, rst_level: 0x0
[0000.091] I> Task: SE error check
[0000.094] I> Task: Bootchain select WAR set
[0000.098] I> Task: Enable SLCG
[0000.101] I> Task: CRC check
[0000.104] I> Task: Initialize MB2 params
[0000.108] I> MB2-params @ 0x40060000
[0000.112] I> Task: Crypto init
[0000.114] I> Task: Perform MB1 KAT tests
[0000.118] I> Task: NVRNG health check
[0000.122] I> NVRNG: Health check success
[0000.126] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.132] I> Task: Enabling and initialization of Bandwidth limiter
[0000.138] I> No request to configure MBWT settings for any PC!
[0000.143] I> Task: Secure debug controls
[0000.147] I> Task: strap war set
[0000.150] I> Task: Initialize SOC Therm
[0000.154] I> Task: Program NV master stream id
[0000.158] I> Task: Verify boot mode
[0000.164] I> Task: Alias fuses
[0000.167] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.178] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c0
[0000.183] I> FUSE_OPT_GPC_DISABLE = 0x00000002
[0000.187] I> FUSE_OPT_TPC_DISABLE = 0x000000f0
[0000.191] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0000.196] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0000.200] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0000.204] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.209] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0000.213] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0000.217] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.222] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.226] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.230] I> FUSE_SKU_INFO_0 = 0xd3
[0000.233] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.237] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.241] I> SKU: Prod
[0000.243] I> Task: Boost clocks
[0000.246] I> Initializing PLLC2 for AXI_CBB.
[0000.250] I> AXI_CBB : src = 35, divisor = 0
[0000.254] I> Task: Voltage monitor
[0000.258] I> VMON: Vmon re-calibration and fine tuning done
[0000.263] I> Task: UPHY init
[0000.268] I> HSIO UPHY init done
[0000.271] W> Skipping GBE UPHY config
[0000.275] I> Task: Boot device init
[0000.278] I> Boot_device: QSPI_FLASH instance: 0
[0000.283] I> Qspi clock source : pllc_out0
[0000.287] I> QSPI Flash: Macronix 64MB
[0000.290] I> QSPI-0l initialized successfully
[0000.294] I> Task: TSC init
[0000.297] I> Task: Load membct
[0000.300] I> RAM_CODE 0x4000401
[0000.303] I> Loading MEMBCT
[0000.306] I> Slot: 0
[0000.308] I> Binary[0] block-3840 (partition size: 0x40000)
[0000.313] I> Binary name: MEM-BCT-0
[0000.317] I> Size of crypto header is 8192
[0000.321] I> Size of crypto header is 8192
[0000.325] I> strt_pg_num(3840) num_of_pgs(16) read_buf(0x40050000)
[0000.331] I> BCH of MEM-BCT-0 read from storage
[0000.335] I> BCH address is : 0x40050000
[0000.339] I> MEM-BCT-0 header integrity check is success
[0000.344] I> Binary magic in BCH component 0 is MEM0
[0000.349] I> component binary type is 0
[0000.353] I> strt_pg_num(3856) num_of_pgs(115) read_buf(0x40040000)
[0000.360] I> MEM-BCT-0 binary is read from storage
[0000.364] I> MEM-BCT-0 binary integrity check is success
[0000.370] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.376] I> RAM_CODE 0x4000401
[0000.382] I> RAM_CODE 0x4000401
[0000.385] I> Task: Load Page retirement list
[0000.389] I> Task: SDRAM params override
[0000.393] I> Task: Save mem-bct info
[0000.397] I> Task: Carveout allocate
[0000.400] I> RCM blob carveout will not be allocated
[0000.405] I> Update CCPLEX IST carveout from MB1-BCT
[0000.410] I> ECC region[0]: Start:0x0, End:0x0
[0000.414] I> ECC region[1]: Start:0x0, End:0x0
[0000.418] I> ECC region[2]: Start:0x0, End:0x0
[0000.423] I> ECC region[3]: Start:0x0, End:0x0
[0000.427] I> ECC region[4]: Start:0x0, End:0x0
[0000.431] I> Non-ECC region[0]: Start:0x80000000, End:0x480000000
[0000.437] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.442] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.446] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.451] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.462] I> allocated(CO:43) base:0x47c000000 size:0x4000000 align: 0x200000
[0000.469] I> allocated(CO:39) base:0x479e00000 size:0x2200000 align: 0x10000
[0000.476] I> allocated(CO:20) base:0x476000000 size:0x2000000 align: 0x2000000
[0000.483] I> allocated(CO:24) base:0x474000000 size:0x2000000 align: 0x2000000
[0000.490] I> allocated(CO:28) base:0x472000000 size:0x2000000 align: 0x2000000
[0000.497] I> allocated(CO:22) base:0x478000000 size:0x1000000 align: 0x1000000
[0000.504] I> allocated(CO:35) base:0x479000000 size:0xe00000 align: 0x10000
[0000.511] I> allocated(CO:02) base:0x471800000 size:0x800000 align: 0x800000
[0000.518] I> allocated(CO:03) base:0x471000000 size:0x800000 align: 0x800000
[0000.525] I> allocated(CO:06) base:0x470800000 size:0x800000 align: 0x800000
[0000.532] I> allocated(CO:56) base:0x470000000 size:0x800000 align: 0x200000
[0000.539] I> allocated(CO:07) base:0x46fc00000 size:0x400000 align: 0x400000
[0000.546] I> allocated(CO:33) base:0x46f800000 size:0x400000 align: 0x200000
[0000.553] I> allocated(CO:23) base:0x46f600000 size:0x200000 align: 0x200000
[0000.560] I> allocated(CO:01) base:0x46f500000 size:0x100000 align: 0x100000
[0000.567] I> allocated(CO:04) base:0x46f400000 size:0x100000 align: 0x100000
[0000.573] I> allocated(CO:05) base:0x46f300000 size:0x100000 align: 0x100000
[0000.580] I> allocated(CO:08) base:0x46f200000 size:0x100000 align: 0x100000
[0000.587] I> allocated(CO:09) base:0x46f100000 size:0x100000 align: 0x100000
[0000.594] I> allocated(CO:15) base:0x46f000000 size:0x100000 align: 0x100000
[0000.601] I> allocated(CO:17) base:0x46ef00000 size:0x100000 align: 0x100000
[0000.608] I> allocated(CO:27) base:0x46ee00000 size:0x100000 align: 0x100000
[0000.615] I> allocated(CO:42) base:0x46ed00000 size:0x100000 align: 0x100000
[0000.622] I> allocated(CO:54) base:0x46ec80000 size:0x80000 align: 0x80000
[0000.629] I> allocated(CO:34) base:0x46ec70000 size:0x10000 align: 0x10000
[0000.636] I> allocated(CO:72) base:0x46ea70000 size:0x200000 align: 0x10000
[0000.642] I> allocated(CO:47) base:0x46e600000 size:0x400000 align: 0x200000
[0000.649] I> allocated(CO:48) base:0x46ea50000 size:0x20000 align: 0x10000
[0000.656] I> allocated(CO:69) base:0x46ea30000 size:0x20000 align: 0x10000
[0000.663] I> allocated(CO:49) base:0x46ea20000 size:0x10000 align: 0x10000
[0000.670] I> allocated(CO:50) base:0x46ea10000 size:0x10000 align: 0x10000
[0000.676] I> NSDRAM base: 0x80000000, end: 0x46ea70000, size: 0x3eea70000
[0000.683] I> Task: Thermal check
[0000.686] I> max_chip_limit = 105
[0000.689] I> min_chip_limit = -28
[0000.692] I> max temp read = 44
[0000.695] I> min temp read = 41
[0000.698] I> Task: Update FSI SCR with thermal fuse data
[0000.704] I> Task: Enable WDT 5th expiry
[0000.707] I> Task: I2C register
[0000.710] I> Task: Set I2C bus freq
[0000.714] I> Task: Reset FSI
[0000.716] I> Task: Pinmux init
[0000.720] I> skipped mmio_addr = 0x9240008
[0000.724] I> skipped mmio_addr = 0x9240000
[0000.727] I> skipped mmio_addr = 0x9240010
[0000.731] I> skipped mmio_addr = 0x9240018
[0000.735] I> skipped mmio_addr = 0x9240020
[0000.739] I> skipped mmio_addr = 0x9240030
[0000.743] I> skipped mmio_addr = 0x9240028
[0000.747] I> skipped mmio_addr = 0x9240038
[0000.751] I> skipped mmio_addr = 0x9240040
[0000.755] I> skipped mmio_addr = 0x9240048
[0000.759] I> skipped mmio_addr = 0x9241000
[0000.763] I> skipped mmio_addr = 0x9241008
[0000.767] I> skipped mmio_addr = 0x9241010
[0000.771] I> skipped mmio_addr = 0x9241018
[0000.775] I> skipped mmio_addr = 0x9241020
[0000.779] I> skipped mmio_addr = 0x9241028
[0000.783] I> skipped mmio_addr = 0x9241030
[0000.787] I> skipped mmio_addr = 0x9241038
[0000.790] I> skipped mmio_addr = 0x9241040
[0000.794] I> skipped mmio_addr = 0x9242000
[0000.798] I> skipped mmio_addr = 0x9242008
[0000.802] I> Task: Prod config init
[0000.806] I> Task: Pad voltage init
[0000.809] I> Task: Prod init
[0000.812] I> Task: Program rst req config reg
[0000.816] I> Task: Common rail init
[0000.819] I> DONE: Thermal config
[0000.823] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.831] I> DONE: SOC rail config
[0000.835] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0000.842] I> DONE: MEMIO rail config
[0000.846] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.
[0000.852] I> DONE: GPU rail info
[0000.856] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.
[0000.862] I> DONE: CV rail info
[0000.865] I> Task: Mem clock src
[0000.868] I> Task: Misc. board config
[0000.872] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0000.878] I> Task: SDRAM init
[0000.881] I> MemoryType: 4 MemBctRevision: 1
[0000.887] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 1
[0000.895] I> MSS CAR: Init PLLM
[0000.898] I> MSS CAR: Init PLLHUB
[0000.903] I> Encryption: MTS: en, TX: en, VPR: en, GSC: en
[0000.914] I> SDRAM initialized!
[0000.917] I> SDRAM Size in Total 0x400000000
[0000.921] I> Task: Dram Ecc scrub
[0000.924] I> Task: DRAM alias check
[0000.940] I> Task: Program NSDRAM carveout
[0000.944] I> NSDRAM carveout encryption is enabled
[0000.949] I> Program NSDRAM carveout
[0000.954] I> Task: Register checker
[0000.959] I> Task: Enable clock-mon
[0000.963] I> FMON: Fmon re-programming done
[0000.968] I> Task: Mapper init
[0000.971] I> Task: SC7 Context Init
[0000.975] I> Task: CCPLEX IST init
[0000.979] I> Task: CPU WP0
[0000.982] I> Loading MCE
[0000.985] I> Slot: 0
[0000.987] I> Binary[8] block-22784 (partition size: 0x80000)
[0000.994] I> Binary name: MCE
[0000.997] I> Size of crypto header is 8192
[0001.001] I> Size of crypto header is 8192
[0001.006] I> strt_pg_num(22784) num_of_pgs(16) read_buf(0x4003e000)
[0001.014] I> BCH of MCE read from storage
[0001.018] I> BCH address is : 0x4003e000
[0001.023] I> MCE header integrity check is success
[0001.028] I> Binary magic in BCH component 0 is MTSM
[0001.034] I> component binary type is 8
[0001.038] I> Size of crypto header is 8192
[0001.042] I> strt_pg_num(22800) num_of_pgs(357) read_buf(0x40000000)
[0001.052] I> MCE binary is read from storage
[0001.057] I> MCE binary integrity check is success
[0001.062] I> Binary MCE loaded successfully at 0x40000000 (0x2c880)
[0001.070] I> Size of crypto header is 8192
[0001.085] I> Size of crypto header is 8192
[0001.090] I> Sending WP0 mailbox command to PSC
[0001.099] I> Task: XUSB Powergate
[0001.103] I> Skipping powergate XUSB.
[0001.107] I> Task: MB1 fixed firewalls
[0001.123] W> Firewall readback mismatch
[0001.134] I> Task: Load bpmp-fw
[0001.137] I> Slot: 0
[0001.140] I> Binary[15] block-9984 (partition size: 0x180000)
[0001.146] I> Binary name: BPMP_FW
[0001.150] I> Size of crypto header is 8192
[0001.154] I> Size of crypto header is 8192
[0001.159] I> strt_pg_num(9984) num_of_pgs(16) read_buf(0x807fe000)
[0001.167] I> BCH of BPMP_FW read from storage
[0001.171] I> BCH address is : 0x807fe000
[0001.177] I> BPMP_FW header integrity check is success
[0001.182] I> Binary magic in BCH component 0 is BPMF
[0001.187] I> component binary type is 15
[0001.192] I> Size of crypto header is 8192
[0001.196] I> strt_pg_num(10000) num_of_pgs(2037) read_buf(0x80000000)
[0001.215] I> BPMP_FW binary is read from storage
[0001.222] I> BPMP_FW binary integrity check is success
[0001.227] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xfea00)
[0001.235] I> Slot: 0
[0001.238] I> Binary[16] block-13056 (partition size: 0x400000)
[0001.245] I> Binary name: BPMP_FW_DTB
[0001.248] I> Size of crypto header is 8192
[0001.253] I> Size of crypto header is 8192
[0001.257] I> strt_pg_num(13056) num_of_pgs(16) read_buf(0x807fc000)
[0001.265] I> BCH of BPMP_FW_DTB read from storage
[0001.276] I> BPMP_FW_DTB header integrity check is success
[0001.281] I> Binary magic in BCH component 0 is BPMD
[0001.287] I> component binary type is 16
[0001.291] I> Size of crypto header is 8192
[0001.296] I> strt_pg_num(13072) num_of_pgs(490) read_buf(0x807bebf0)
[0001.306] I> BPMP_FW_DTB binary is read from storage
[0001.312] I> BPMP_FW_DTB binary integrity check is success
[0001.318] I> Binary BPMP_FW_DTB loaded successfully at 0x807bebf0 (0x3d280)
[0001.327] I> Task: Load psc-fw
[0001.331] I> Slot: 0
[0001.333] I> Binary[17] block-21248 (partition size: 0xc0000)
[0001.340] I> Binary name: PSC_FW
[0001.343] I> Size of crypto header is 8192
[0001.347] I> Size of crypto header is 8192
[0001.352] I> strt_pg_num(21248) num_of_pgs(16) read_buf(0x80ffe000)
[0001.360] I> BCH of PSC_FW read from storage
[0001.364] I> BCH address is : 0x80ffe000
[0001.370] I> PSC_FW header integrity check is success
[0001.375] I> Binary magic in BCH component 0 is PFWP
[0001.380] I> component binary type is 17
[0001.385] I> Size of crypto header is 8192
[0001.389] I> strt_pg_num(21264) num_of_pgs(717) read_buf(0x80fa4600)
[0001.401] I> PSC_FW binary is read from storage
[0001.407] I> PSC_FW binary integrity check is success
[0001.412] I> Binary PSC_FW loaded successfully at 0x80fa4600 (0x59980)
[0001.421] I> Task: Load nvdec-fw
[0001.424] I> Slot: 0
[0001.427] I> Binary[7] block-6400 (partition size: 0x100000)
[0001.433] I> Binary name: NVDEC
[0001.436] I> Size of crypto header is 8192
[0001.441] I> Size of crypto header is 8192
[0001.445] I> strt_pg_num(6400) num_of_pgs(16) read_buf(0x800fe000)
[0001.453] I> BCH of NVDEC read from storage
[0001.458] I> BCH address is : 0x800fe000
[0001.463] I> NVDEC header integrity check is success
[0001.468] I> Binary magic in BCH component 0 is NDEC
[0001.474] I> component binary type is 7
[0001.478] I> Size of crypto header is 8192
[0001.482] I> strt_pg_num(6416) num_of_pgs(560) read_buf(0x80000000)
[0001.493] I> NVDEC binary is read from storage
[0001.499] I> NVDEC binary integrity check is success
[0001.504] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0001.512] I> Size of crypto header is 8192
[0001.532] I> Task: Load tsec-fw
[0001.536] I> TSEC-FW load support not enabled
[0001.540] I> Task: GPIO interrupt map
[0001.545] I> Task: SC7 context save
[0001.548] I> Slot: 0
[0001.551] I> Binary[27] block-0 (partition size: 0x100000)
[0001.557] I> Binary name: BR_BCT
[0001.560] I> Size of crypto header is 8192
[0001.569] I> strt_pg_num(0) num_of_pgs(16) read_buf(0xa0000000)
[0001.577] I> BR_BCT binary is read from storage
[0001.582] I> BR_BCT binary integrity check is success
[0001.587] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[0001.595] I> Slot: 0
[0001.597] I> Binary[13] block-23808 (partition size: 0x30000)
[0001.604] I> Binary name: SC7-FW
[0001.607] I> Size of crypto header is 8192
[0001.612] I> Size of crypto header is 8192
[0001.617] I> Size of crypto header is 8192
[0001.621] I> strt_pg_num(23808) num_of_pgs(16) read_buf(0xa0002000)
[0001.629] I> BCH of SC7-FW read from storage
[0001.633] I> BCH address is : 0xa0002000
[0001.639] I> SC7-FW header integrity check is success
[0001.644] I> Binary magic in BCH component 0 is WB0B
[0001.649] I> component binary type is 13
[0001.654] I> Size of crypto header is 8192
[0001.658] I> strt_pg_num(23824) num_of_pgs(345) read_buf(0xa0004000)
[0001.668] I> SC7-FW binary is read from storage
[0001.674] I> SC7-FW binary integrity check is success
[0001.679] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x2b0e0)
[0001.687] I> Slot: 0
[0001.689] I> Binary[22] block-24192 (partition size: 0x30000)
[0001.696] I> Binary name: PSC_RF
[0001.699] I> Size of crypto header is 8192
[0001.704] I> Size of crypto header is 8192
[0001.708] I> Size of crypto header is 8192
[0001.713] I> strt_pg_num(24192) num_of_pgs(16) read_buf(0xa002f0e0)
[0001.721] I> BCH of PSC_RF read from storage
[0001.725] I> BCH address is : 0xa002f0e0
[0001.731] I> PSC_RF header integrity check is success
[0001.736] I> Binary magic in BCH component 0 is PSCR
[0001.741] I> component binary type is 22
[0001.745] I> Size of crypto header is 8192
[0001.750] I> strt_pg_num(24208) num_of_pgs(223) read_buf(0xa00310e0)
[0001.759] I> PSC_RF binary is read from storage
[0001.765] I> PSC_RF binary integrity check is success
[0001.770] I> Binary PSC_RF loaded successfully at 0xa00310e0 (0x1bdd0)
[0001.793] I> Task: Save WP0 payload to SC7 ctx
[0001.798] I> Task: Load MB2rf binary to SC7 ctx
[0001.803] I> Slot: 0
[0001.805] I> Binary[14] block-24576 (partition size: 0x20000)
[0001.812] I> Binary name: MB2_RF
[0001.815] I> Size of crypto header is 8192
[0001.820] I> Size of crypto header is 8192
[0001.824] I> Size of crypto header is 8192
[0001.829] I> strt_pg_num(24576) num_of_pgs(16) read_buf(0xa00d6a88)
[0001.837] I> BCH of MB2_RF read from storage
[0001.841] I> BCH address is : 0xa00d6a88
[0001.847] I> MB2_RF header integrity check is success
[0001.852] I> Binary magic in BCH component 0 is MB2R
[0001.857] I> component binary type is 14
[0001.862] I> Size of crypto header is 8192
[0001.866] I> strt_pg_num(24592) num_of_pgs(224) read_buf(0xa00d8a88)
[0001.875] I> MB2_RF binary is read from storage
[0001.881] I> MB2_RF binary integrity check is success
[0001.886] I> Binary MB2_RF loaded successfully at 0xa00d8a88 (0x1bf80)
[0001.894] I> Task: Save fuse alias data to SC7 ctx
[0001.899] I> Task: Save PMIC data to SC7 ctx
[0001.904] I> Task: Save Pinmux data to SC7 ctx
[0001.908] I> Task: Save Pad Voltage data to SC7 ctx
[0001.914] I> Task: Save controller prod data to SC7 ctx
[0001.919] I> Task: Save prod cfg data to SC7 ctx
[0001.924] I> Task: Save I2C bus freq data to SC7 ctx
[0001.929] I> Task: Save SOCTherm data to SC7 ctx
[0001.934] I> Task: Save FMON data to SC7 ctx
[0001.939] I> Task: Save VMON data to SC7 ctx
[0001.943] I> Task: Save TZDRAM data to SC7 ctx
[0001.948] I> Task: Save GPIO int data to SC7 ctx
[0001.953] I> Task: Save clock data to SC7 ctx
[0001.958] I> Task: Save debug data to SC7 ctx
[0001.962] I> Task: Save MBWT data to SC7 ctx
[0001.971] I> SC7 context save done
[0001.975] I> Task: Load MB2/Applet/FSKP
[0001.979] I> Loading MB2
[0001.982] I> Slot: 0
[0001.985] I> Binary[6] block-8448 (partition size: 0x80000)
[0001.991] I> Binary name: MB2
[0001.994] I> Size of crypto header is 8192
[0001.999] I> Size of crypto header is 8192
[0002.003] I> strt_pg_num(8448) num_of_pgs(16) read_buf(0x8007e000)
[0002.011] I> BCH of MB2 read from storage
[0002.015] I> BCH address is : 0x8007e000
[0002.021] I> MB2 header integrity check is success
[0002.026] I> Binary magic in BCH component 0 is MB2B
[0002.031] I> component binary type is 6
[0002.035] I> Size of crypto header is 8192
[0002.040] I> strt_pg_num(8464) num_of_pgs(841) read_buf(0x80000000)
[0002.052] I> MB2 binary is read from storage
[0002.058] I> MB2 binary integrity check is success
[0002.063] I> Binary MB2 loaded successfully at 0x80000000 (0x691f0)
[0002.071] I> Task: Map CCPLEX SHARED carveout
[0002.076] I> Task: Prepare MB2 params
[0002.081] I> BR-BCT Boot Chain Fields
[0002.085] I> u32_non_gpio_select_boot_chain : 0
[0002.090] I> u32_num_boot_chains : 2
[0002.095] I> bf_bl_gpio_select_boot_chain_1b : 0
[0002.100] I> Task: Dram ecc test
[0002.104] I> Task: Misc NV security settings
[0002.108] I> NVDEC sticky bits programming done
[0002.113] I> Successfully powergated NVDEC
[0002.118] I> Task: Disable/Reload WDT
[0002.122] I> Task: Program misc carveouts
[0002.126] I> Program IPC carveouts
[0002.134] I> SLCG Global override status := 0x0
[0002.139] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-4d0906e6)
I> Emulation:
I> Entry timestamp: 0x00211df9
I> DMA heap: [base:0x470000000, size:0x800000]
I> Task: ARI update carveout TZDRAM (0x50002034)
I> Task: Enable hot-plug capability (0x50028064)
I> Task: PSC mailbox init (0x500178b0)
I> Task: Crypto init (0x5000675c)
I> Task: Enable GP-SE clock (0x50002198)
I> Task: DICE Identity init (0x5001af00)
I> DICE is not enabled.
I> Task: Measured Boot init (0x5001b674)
I> Task: OEM SC7 context save init (0x5001a600)
I> Task: I2C register (0x50001ff8)
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout (0x50001fe0)
I> Task: Program CBB PCIE AMAP regions (0x5001ac14)
I> Task: Boot device init (0x50001f28)
I> Task: Partition Manager Init (0x50001f24)
I> Found 57 partitions in QSPI_FLASH (instance 0)
I> Task: Load and authenticate registered FWs (0x5001e198)
I> Task: Load AUXP FWs (0x50027c04)
I> Skipping SCE FW load
I> Unpowergate done
I> Partition name: A_spe-fw
I> Binary@ device:3/0 block-55040 (partition size: 0x90000), name: A_spe-fw
I> Partition name: A_rce-fw
I> Binary@ device:3/0 block-56192 (partition size: 0x100000), name: A_rce-fw
I> Binary spe loaded successfully at 0x46f200000
I> Partition name: A_dce-fw
I> Binary@ device:3/0 block-44800 (partition size: 0x500000), name: A_dce-fw
I> Binary rce loaded successfully at 0x46ef00000
I> dce : will be decompressed at 0x476000000
I> dce : decompressed to 9449600 bytes
I> Partition name: A_adsp-fw
I> Binary@ device:3/0 block-58240 (partition size: 0x200000), name: A_adsp-fw
I> Binary dce loaded successfully at 0x476000000
I> Partition name: A_xusb-fw
I> Binary@ device:3/0 block-9472 (partition size: 0x40000), name: A_xusb-fw
I> Binary ape loaded successfully at 0x46fc00000
I> Binary xusb loaded successfully at 0x46f300000
I> Task: Carveout setup (0x500208f8)
I> Task: Enable FSITHERM (0x50017784)
I> Task: Enable FSI VMON (0x50017280)
I> Task: Validate FSI Therm readings (0x50017364)
I> Task: Restore XUSB sec (0x50001ef8)
I> Task: Enable FSI SE clock (0x50017d0c)
I> Task: Initialize SBSA UART CAR (0x500020fc)
I> Task: Initialize CPUBL Params (0x50018cf8)
I> CPUBL-params @ 0x472000000
I> Task: Ratchet update (0x50029100)
I> Task: Prepare eeprom data (0x50018ac4)
I> Task: Revoke PKC fuse (0x50001d44)
I> Task: FSI padctl context save (0x5001a790)
I> Task: Unpowergate APE (0x50018474)
I> Task: OEM firewalls (0x50024d68)
I> Task: Powergate APE (0x500185e8)
I> Powergating APE
I> Powergate done
I> Task: OEM firewall restore saved settings (0x500251bc)
I> Task: Unhalt AUXPs (0x50027e6c)
I> Unhalting SPE…
▒▒▒▒spe: early_init
▒▒▒▒vic initialized
▒▒▒▒tsc initialized
▒▒▒▒spe: init
▒▒▒▒tag initialized
▒▒▒▒tcu initialized
▒▒▒▒spe: late init
▒▒▒▒pm initialized
I> Task: Trigger mailbox for PSC-BL1 exit (0x50017930)
▒▒INFO: Entering psc_monitor_init!
INFO: GSC22 BOM:0x478002000 SIZE:0x1000000 CLIENT_ACCESS1:00180000
INFO: PSCFW BUILD VERSION: 8a33b23-73b589c-8a15f76-rel-t234
INFO: mstatus:0xa00000808
INFO: Supervisor entry_point:c108c00
I> Tas▒▒INFO: MONITOR: user task addr:0x478022000, blob offset:0x00020000
INFO: MONITOR: populated user images:13
INFO: mret to Supervisor!
INFO: psc supervisor init.
INFO: psc_irq_init…
INFO: enter idle task.
bpmp: socket 0
bpmp: base binary md5 is 925eece486b7c46d91aa449178b5d322
bpmp: combined binary md5 is 029a50a8fb4897d35f94a799f82169a9
bpmp: firmware tag is 029a50a8fb4897d35f94-925eece486b
initialized vwdt
initialized fuse
initialized vfrel
initialized hwwdt
initialized adc
initialized fmon
initialized mc
initialized reset
471 clocks registered
initialized io_dpd
initialized regime
initialized i2c
initialized vrmon
▒▒k: Start secure NOR provision (0x5001aa2c)
▒▒k: Load FSI keyblob (0x5▒▒initialized dvs
▒▒001▒▒initialized clk_mach_config
initialized pm
initialized suspend
initialized strap
▒▒7d54)
I> Task: Unhalt AUXPs (0x50027e74)
I> SCE unhalt skipped
I> Unhalting RCE
I> Task: Load CPUBL (0x50018e1c)
I> Task: Load TOS (0x50019580)
I> Partition name: A_cpu-bootloader
I> Binary@ device:3/0 block-24▒▒[ 2.539327] Camera-FW on t234-rce-safe started
▒▒832▒▒TCU early console enabled.
▒▒initialized emc
initialized emc_mrq
▒▒ (partition ▒▒initialized clk_cal
initialized uphy_dt
initialized uphy
▒▒size: 0x380000), name: A_cp▒▒initialized pg_late
initialized bwmgr
initialized oc_mrq
initialized clk_mrq
initialized i2c_mrq
initialized tag_mrq
▒▒u-bootloader
initialized cvc
initialized rm
enable can1_core
enable can1_host
▒▒[ 2.698680] Camer▒▒enable can2_core
enable can2_host
enable pwm3
enable▒▒a-FW on t234-rce-safe▒▒ mss_encrypt
enable maud
enable pllg_ref
enable dsi_core
enable aza_2xbit
enable xusb_ss
enable xusb_fs
enable xusb_falcon
enable xusb_core_mux
enable dsi_lp
initialized pg_post
initialized regulator_▒▒ ready SHA1=8676d22a (crt 21.574 ms, total boot 181.985 ms)
▒▒post
initialized profile
initialized mrq
initialized cactmon
bpmp: init complete
▒▒I> Partition name: A_secure-os
I> Binary@ device:3/0 block▒▒DCE: FW Boot Done
▒▒-32000 (partition size: 0x400000), name: A_secure-os
I> NSDRAM carveout base: 0x80000000, size: 0x3eea70000
I> Binary cpubl loaded successfully at 0x46e600000
I> Binary tos loaded successfully at 0x47fdee000
I> Relocating OP-TEE dtb from: 0x47fefec50 to 0x47c000020, size: 0x2106
I> [0] START: 0x80000000, SIZE: 0x3eea70000
I> [1] START: 0x472000000, SIZE: 0x2000000
I> Partition name: A_eks
I> Binary@ device:3/0 block-44288 (partition size: 0x40000), name: A_eks
I> Binary eks loaded successfully at 0x470000200
I> EKB detected (length: 0x410) @ VA:0x470000200
I> Task: Prepare TOS params (0x500194f8)
I> Setting OPTEE arg3: 0x47c000020
I> Task: OEM SC7 context save (0x5001a88c)
I> Task: Disable MSS perf stats (0x50027f00)
I> Task: Program display sticky bits (0x50027e7c)
I> Task: Storage device deinit (0x500020a0)
I> Task: SMMU external bypass disable (0x50017894)
I> Task: SMMU init (0x500177b0)
I> Task: Program GICv3 registers (0x50027fa0)
I> Task: Audit firewall settings (0x50024fbc)
I> Task: Bootchain failure check (0x500025e8)
I> Current Boot-Chain Slot: 0
I> BR-BCT Boot-Chain is 0, and status is 1. Set UPDATE_BRBCT bit to 0
I> MB2 finished
▒▒NOTICE: BL31: v2.6(release):346877e39
NOTICE: BL31: Built : 12:32:40, Aug 1 2023
I/TC: Physical secure memory base 0x47c040000 size 0x3fc0000
I/TC:
I/TC: OP-TEE version: 3.21 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Tue Aug 1 19:39:55 UTC 2023 aarch64
Jetson UEFI firmware (version 4.1-33958178 built on 2023-08-01T19:34:02+00:00)
▒▒E/TC:?? 00 get_rpc_alloc_res:645 RPC allocation failed. Non-secure world result: ret=0xffff0000 ret_origin=0
E/LD: init_elf:486 sys_open_ta_bin(bc50d971-d4c9-42c4-82cb-343fb7f37896)
E/TC:?? 00 ldelf_init_with_ldelf:131 ldelf failed with res: 0xffff000c
▒▒Unhandled Exception in EL3.
x30 = 0x0000000050000d00
x0 = 0x0000000000000000
x1 = 0x00000000be000011
x2 = 0x0000000000000000
x3 = 0x0000000000000011
x4 = 0x0000000000000004
x5 = 0x0000000013806944
x6 = 0x0000000447ff0308
x7 = 0x0000000000000000
x8 = 0x000000046ab83748
x9 = 0x000000005001c380
x10 = 0x55aaa055071dbd35
x11 = 0x55aa8255ce1abfe1
x12 = 0x0000000000000000
x13 = 0x000000000002700f
x14 = 0x0000000000000000
x15 = 0x0054004900550000
x16 = 0x000000044767aad8
x17 = 0x000000004d941070
x18 = 0x000000046aabb2f0
x19 = 0x000000005001cec0
x20 = 0x0000000000000000
x21 = 0x0000000000000000
x22 = 0x0000000000000000
x23 = 0x0000000000000000
x24 = 0x0000000000000000
x25 = 0x0000000000000000
x26 = 0x0000000000000000
x27 = 0x0000000000000000
x28 = 0x0000000000000000
x29 = 0x0000000000000000
scr_el3 = 0x000000000003073d
sctlr_el3 = 0x00000000b0cd183f
cptr_el3 = 0x0000000000000000
tcr_el3 = 0x0000000080823518
daif = 0x00000000000002c0
mair_el3 = 0x00000000004404ff
spsr_el3 = 0x00000000600003c9
elr_el3 = 0x000000046aab5280
ttbr0_el3 = 0x0000000050026ac1
esr_el3 = 0x00000000be000011
far_el3 = 0x0000000000000000
spsr_el1 = 0x0000000000000000
elr_el1 = 0x0000000000000000
spsr_abt = 0x0000000000000000
spsr_und = 0x0000000000000000
spsr_irq = 0x0000000000000000
spsr_fiq = 0x0000000000000000
sctlr_el1 = 0x0000000030d00800
actlr_el1 = 0x0000000000000000
cpacr_el1 = 0x0000000000300000
csselr_el1 = 0x0000000000000004
sp_el1 = 0x0000000000000000
esr_el1 = 0x0000000000000000
ttbr0_el1 = 0x0000000000000000
ttbr1_el1 = 0x0000000000000000
mair_el1 = 0x0000000000000000
amair_el1 = 0x0000000000000000
tcr_el1 = 0x0000000000000000
tpidr_el1 = 0x0000000000000000
tpidr_el0 = 0x0000000080000000
tpidrro_el0 = 0x0000000000000000
par_el1 = 0x0000000000000800
mpidr_el1 = 0x0000000081000000
afsr0_el1 = 0x0000000000000000
afsr1_el1 = 0x0000000000000000
contextidr_el1 = 0x0000000000000000
vbar_el1 = 0x0000000000000000
cntp_ctl_el0 = 0x0000000000000005
cntp_cval_el0 = 0x0000000010e88fcc
cntv_ctl_el0 = 0x0000000000000000
cntv_cval_el0 = 0x0000000000000000
cntkctl_el1 = 0x0000000000000000
sp_el0 = 0x000000046aabb2f0
isr_el1 = 0x0000000000000040
cpuectlr_el1 = 0xa000000b40543000
gicd_ispendr regs (Offsets 0x200 - 0x278)
Offset: value
0000000000000200: 0x0000000000000000
0000000000000204: 0x0000000000000000
0000000000000208: 0x0000000000000000
000000000000020c: 0x0000000000000000
0000000000000210: 0x0000000000000000
0000000000000214: 0x0000000000000000
0000000000000218: 0x0000000000010000
000000000000021c: 0x0000000000020000
0000000000000220: 0x0000000000000000
0000000000000224: 0x0000000000000000
0000000000000228: 0x0000000000000000
000000000000022c: 0x0000000000000000
0000000000000230: 0x0000000000000000
0000000000000234: 0x0000000000000000
0000000000000238: 0x0000000000000000
000000000000023c: 0x0000000000000000
0000000000000240: 0x0000000000000000
0000000000000244: 0x0000000000000000
0000000000000248: 0x0000000000000000
000000000000024c: 0x0000000000000000
0000000000000250: 0x0000000000000000
0000000000000254: 0x0000000000000000
0000000000000258: 0x0000000000000000
000000000000025c: 0x0000000000000000
0000000000000260: 0x0000000000000000
0000000000000264: 0x0000000000000000
0000000000000268: 0x0000000000000000
000000000000026c: 0x0000000000000000
0000000000000270: 0x0000000000000000
0000000000000274: 0x0000000000000000
0000000000000278: 0x0000000000000000
000000000000027c: 0x0000000000000000
  1. Please put the log as text attachment and upload them.
  2. How did this test conduct on your side? I mean how many carrier boards and modules do you have there?
  3. You told me you tried to flash jetpack6 to them but Jetson 3 log is still jetpack5.
jetson-elog-1420123084586.txt (39.7 KB)
jetson-elog-1420123084464.txt (36.5 KB)
These UART logs were obtained after attempting flashing with 6.1 downloaded through the SDK. They appear to be the same type of error as when it was our production build.
As I mentioned previously, we have over 20 other Jetson Orin NX modules, and several Nvidia devkits. All of our jetsons were flashed using the same devkit carrier, and all were successful except these 3.
My point here is did you ever swap the module from one carrier board to another one and see if this issue is related to a broken carrier board…
As you told us you have several devkits, then do the cross check…
And one of your log is still on rel-35.4.1 as I already told… please at least do as what you told us to flash it with rel-36…
We have already ruled out dev board functionality, as we are still able to flash other jetsons with it, including several after these 3 failed during operation. As for the one that says it is still at r35.4.1, we tried to install r36 but the flashing process fails on that jetson specifically.
To give a brief timeline of events:
These Jetsons have been previously flashed, and fully functional inside their end-use device, then after a brief time in service, they became unresponsive, removed from their devices and set aside for extended troubleshooting. After additional testing by our senior engineers, they concluded that these 3 Jetsons in particular exhibited signs of premature failure, as they are now unable to fully boot, or be re-flashed properly.
Given that this inquiry is being written on company time and we have substantial evidence to believe that the root cause is a hardware fault in the Jetson modules, we would like to start the RMA process as soon as possible.
You can RMA jetson #1 and #2 first.
But please share me the flash failure log as text attachment of your Jetson#3.
Here is flash log obtained from the SDK for the 3rd Jetson while attempting to install Jetpack 6.1.
jetson-flash-log-1420123084464.txt (11.4 KB)
send the UART log + host side log together…
There is “export logs” button on sdkmanager… please use that and attach full zip file.
Your log is still not completed…
SDKM_logs_JetPack_6.1_Linux_for_Jetson_Orin_NX_modules_2024-10-09_12-04-40.zip (310.3 KB)
Are you sure this uart log is captured when the flash failure happen? It looks like another boot log to me. Not related to any flash.
Sorry for the confusion, here is the UART output from the moment of failure. Unfortunately we weren’t able record much prior to this due to the limited number of lines kept on-screen for terminal application we used to record it.
jetson-flash-uart-log-1420123084464.txt (3.0 KB)
Ok. Please RMA this module.
