I have a problem with booing my device. with either sd card or nvme its just not starts. It stacks on booting screen with message WARNING TEST KEY IS DETECTED. it not response on keyboard, I can not run boot manager or setting. seems like hardware issues. how can I totally reset device or do something?
I use mac, and followed instructions from here Jetson Orin Nano Developer Kit Getting Started | NVIDIA Developer
Dump the log, or re-flash with SDK Manager, with which you need a physical Linux PC:
https://docs.nvidia.com/sdk-manager/install-with-sdkm-jetson/index.html
will it work for jetson orin nano developer kit ?
Of course it does.
Check the line of pins on the opposite side to the I/O connectors on the carrier board.
So I checked and here is logs I have
Summary
[0000.061] I> MB1 (version: 0.32.0.0-t234-54845784-57325615)
[0000.067] I> t234-A01-1-Silicon (0x12347) Prod
[0000.071] I> Boot-mode : Coldboot
[0000.074] I> Emulation:
[0000.077] I> Entry timestamp: 0x00000000
[0000.080] I> last_boot_error: 0x0
[0000.083] I> BR-BCT: preprod_dev_sign: 0
[0000.087] I> rst_source: 0x0, rst_level: 0x0
[0000.091] I> Task: Bootchain select WAR set (0x5000ba65)
[0000.096] I> Task: Enable SLCG (0x5000bab1)
[0000.100] I> Task: CRC check (0x5001ea19)
[0000.104] I> Task: Initialize MB2 params (0x5000cb51)
[0000.110] I> MB2-params @ 0x40060000
[0000.113] I> Task: Crypto init (0x5001d981)
[0000.117] I> Task: Secure debug controls (0x5000c0a9)
[0000.122] I> Task: strap war set (0x5000ba2d)
[0000.127] I> Task: Initialize SOC Therm (0x5001bd35)
[0000.131] I> Task: Program NV master stream id (0x5000c05d)
[0000.137] I> Task: Verify boot mode (0xd4820f1)
[0000.143] I> Task: Alias fuses (0x5001095d)
[0000.147] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.154] I> Task: Print SKU type (0x5000f5f1)
[0000.158] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c8
[0000.164] I> FUSE_OPT_GPC_DISABLE = 0x00000001
[0000.168] I> FUSE_OPT_TPC_DISABLE = 0x0000000f
[0000.172] I> FUSE_OPT_DLA_DISABLE = 0x00000003
[0000.176] I> FUSE_OPT_PVA_DISABLE = 0x00000001
[0000.181] I> FUSE_OPT_NVENC_DISABLE = 0x00000001
[0000.185] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.190] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0000.194] I> FUSE_OPT_EMC_DISABLE = 0x0000000c
[0000.198] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.202] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.206] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.210] I> FUSE_SKU_INFO_0 = 0xd5
[0000.214] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.218] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.222] I> SKU: Prod
[0000.224] I> Task: Boost clocks (0x500148a1)
[0000.228] I> Initializing PLLC2 for AXI_CBB.
[0000.232] I> AXI_CBB : src = 35, divisor = 0
[0000.236] I> Task: Voltage monitor (0x50014b49)
[0000.241] I> VMON: Vmon re-calibration and fine tuning done
[0000.246] I> Task: UPHY init (0x5000d065)
[0000.252] I> HSIO UPHY init done
[0000.255] E> Skipping GBE UPHY config
[0000.259] I> Task: Boot device init (0x50000be9)
[0000.263] I> Boot_device: QSPI_FLASH instance: 0
[0000.268] I> Qspi clock source : pllc_out0
[0000.272] I> QSPI Flash: Macronix 64MB
[0000.275] I> QSPI-0l initialized successfully
[0000.280] I> Task: TSC init (0x50020a4d)
[0000.284] I> Task: Load membct (0x50011fe9)
[0000.288] I> RAM_CODE 0x4000421
[0000.291] I> Loading MEMBCT
[0000.293] I> Slot: 0
[0000.295] I> Binary[0] block-0 (partition size: 0x40000)
[0000.300] I> get_binary_info: Binary name: MEM-BCT-0
[0000.305] I> Size of crypto header is 8192
[0000.309] I> BCH load address is : 0x40050000
[0000.313] I> Size of crypto header is 8192
[0000.318] I> BCH of MEM-BCT-0 read from storage
[0000.322] I> BCH address is : 0x40050000
[0000.326] I> MEM-BCT-0 header integrity check is success
[0000.331] I> Binary magic in BCH component 0 is MEM0
[0000.336] I> component binary type is 0
[0000.340] I> MEM-BCT-0 binary is read from storage
[0000.345] I> MEM-BCT-0 binary integrity check is success
[0000.350] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.357] I> RAM_CODE 0x4000421
[0000.362] I> RAM_CODE 0x4000421
[0000.366] I> Task: Load Page retirement list (0x500115b1)
[0000.371] I> Task: SDRAM params override (0x50011fc5)
[0000.376] I> Task: Save mem-bct info (0x50014fa1)
[0000.381] I> Task: Carveout allocate (0x50015005)
[0000.385] I> RCM blob carveout will not be allocated
[0000.390] I> ECC region[0]: Start:0x0, End:0x0
[0000.395] I> ECC region[1]: Start:0x0, End:0x0
[0000.399] I> ECC region[2]: Start:0x0, End:0x0
[0000.403] I> ECC region[3]: Start:0x0, End:0x0
[0000.407] I> ECC region[4]: Start:0x0, End:0x0
[0000.412] I> Non-ECC region[0]: Start:0x80000000, End:0x280000000
[0000.418] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.422] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.427] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.431] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.441] I> allocated(CO:44) base:0x249800000 size:0x36800000 align: 0x100000
[0000.448] I> allocated(CO:31) base:0x240000000 size:0x8000000 align: 0x8000000
[0000.455] I> allocated(CO:43) base:0x23c000000 size:0x4000000 align: 0x200000
[0000.462] I> allocated(CO:20) base:0x23a000000 size:0x2000000 align: 0x2000000
[0000.469] I> allocated(CO:24) base:0x238000000 size:0x2000000 align: 0x2000000
[0000.477] I> allocated(CO:28) base:0x236000000 size:0x2000000 align: 0x2000000
[0000.484] I> allocated(CO:22) base:0x248000000 size:0x1000000 align: 0x1000000
[0000.491] I> allocated(CO:35) base:0x235200000 size:0xe00000 align: 0x10000
[0000.498] I> allocated(CO:02) base:0x249000000 size:0x800000 align: 0x800000
[0000.504] I> allocated(CO:03) base:0x234800000 size:0x800000 align: 0x800000
[0000.511] I> allocated(CO:06) base:0x234000000 size:0x800000 align: 0x800000
[0000.518] I> allocated(CO:10) base:0x233800000 size:0x800000 align: 0x800000
[0000.525] I> allocated(CO:56) base:0x233000000 size:0x800000 align: 0x200000
[0000.532] I> allocated(CO:07) base:0x232c00000 size:0x400000 align: 0x400000
[0000.539] I> allocated(CO:33) base:0x232800000 size:0x400000 align: 0x200000
[0000.546] I> allocated(CO:23) base:0x235000000 size:0x200000 align: 0x200000
[0000.553] I> allocated(CO:01) base:0x232700000 size:0x100000 align: 0x100000
[0000.560] I> allocated(CO:04) base:0x232600000 size:0x100000 align: 0x100000
[0000.567] I> allocated(CO:05) base:0x232500000 size:0x100000 align: 0x100000
[0000.574] I> allocated(CO:08) base:0x232400000 size:0x100000 align: 0x100000
[0000.581] I> allocated(CO:09) base:0x232300000 size:0x100000 align: 0x100000
[0000.588] I> allocated(CO:15) base:0x232200000 size:0x100000 align: 0x100000
[0000.594] I> allocated(CO:17) base:0x232100000 size:0x100000 align: 0x100000
[0000.601] I> allocated(CO:27) base:0x232000000 size:0x100000 align: 0x100000
[0000.608] I> allocated(CO:42) base:0x231f00000 size:0x100000 align: 0x100000
[0000.615] I> allocated(CO:54) base:0x231e80000 size:0x80000 align: 0x80000
[0000.622] I> allocated(CO:34) base:0x231e70000 size:0x10000 align: 0x10000
[0000.629] I> allocated(CO:47) base:0x231a00000 size:0x400000 align: 0x200000
[0000.636] I> allocated(CO:72) base:0x231800000 size:0x200000 align: 0x10000
[0000.642] I> allocated(CO:48) base:0x231e50000 size:0x20000 align: 0x10000
[0000.649] I> allocated(CO:69) base:0x231e30000 size:0x20000 align: 0x10000
[0000.656] I> allocated(CO:49) base:0x231e20000 size:0x10000 align: 0x10000
[0000.663] I> allocated(CO:50) base:0x231e10000 size:0x10000 align: 0x10000
[0000.669] I> NSDRAM base: 0x80000000, end: 0x231e70000
[0000.674] I> Task: Thermal check (0x50021d55)
[0000.679] I> max_chip_limit = 105
[0000.682] I> min_chip_limit = -28
[0000.685] I> max temp read = 32
[0000.688] I> min temp read = 31
[0000.691] I> Task: Update FSI SCR with thermal fuse data (0x50021e61)
[0000.697] I> Task: Enable WDT 5th expiry (0x50021a41)
[0000.702] I> Task: I2C register (0x50000b85)
[0000.706] I> Task: Reset FSI (0x500148b1)
[0000.710] I> Task: Pinmux init (0x5001397d)
[0000.714] I> skipped mmio_addr = 0x9240008
[0000.718] I> skipped mmio_addr = 0x9240000
[0000.722] I> skipped mmio_addr = 0x9240010
[0000.726] I> skipped mmio_addr = 0x9240018
[0000.730] I> skipped mmio_addr = 0x9240020
[0000.734] I> skipped mmio_addr = 0x9240030
[0000.738] I> skipped mmio_addr = 0x9240028
[0000.742] I> skipped mmio_addr = 0x9240038
[0000.746] I> skipped mmio_addr = 0x9240040
[0000.750] I> skipped mmio_addr = 0x9240048
[0000.754] I> skipped mmio_addr = 0x9241000
[0000.758] I> skipped mmio_addr = 0x9241008
[0000.762] I> skipped mmio_addr = 0x9241010
[0000.765] I> skipped mmio_addr = 0x9241018
[0000.769] I> skipped mmio_addr = 0x9241020
[0000.773] I> skipped mmio_addr = 0x9241028
[0000.777] I> skipped mmio_addr = 0x9241030
[0000.781] I> skipped mmio_addr = 0x9241038
[0000.785] I> skipped mmio_addr = 0x9241040
[0000.789] I> skipped mmio_addr = 0x9242000
[0000.793] I> skipped mmio_addr = 0x9242008
[0000.797] I> Task: Prod config init (0x50013ddd)
[0000.801] I> Task: Pad voltage init (0x50013a2d)
[0000.806] I> Task: Prod init (0x50013e21)
[0000.810] I> Task: Common rail init (0x50014575)
[0000.814] I> DONE: Thermal config
[0000.818] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.826] I> DONE: SOC rail config
[0000.830] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0000.836] I> DONE: MEMIO rail config
[0000.840] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.
[0000.846] I> DONE: GPU rail info
[0000.850] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.
[0000.856] I> DONE: CV rail info
[0000.859] I> Task: Mem clock src (0x50011de9)
[0000.863] I> Task: Misc. board config (0x5001461d)
[0000.869] W> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0000.875] I> Task: SDRAM init (0x50011ded)
[0000.878] I> SDRAM-params @ 0xd485000
[0000.882] I> MemoryType: 4 MemBctRevision: 1
[0000.889] I> MSS code-drop: NvBootSdramInit
[0000.893] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevisio1
[0000.900] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevisio1
[0000.907] I> MSS CAR: Init PLLM
[0000.910] I> MSS CAR: Init PLLHUB
[0000.915] I> Encryption: MTS: en, TX: en, VPR: en, GSC: en
[0000.926] I> mb1_sdram_init Done !
[0000.930] I> SDRAM Size in Total 0x200000000
[0000.934] I> Task: Dram Ecc scrub (0x500116f5)
[0000.938] I> Task: DRAM alias check (0x50011fbd)
[0000.950] I> Task: Program NSDRAM carveout (0x50015961)
[0000.956] I> NSDRAM carveout encryption is enabled
[0000.961] I> Program NSDRAM carveout
[0000.965] I> Task: Register checker (0x50011fc1)
[0000.972] I> Task: Enable clock-mon (0x50020a35)
[0000.978] I> FMON: Fmon re-programming done
[0000.983] I> Task: Mapper init (0x5001ef4d)
[0000.988] I> Task: SC7 Context Init (0x50020d3d)
[0000.994] I> Task: CCPLEX IST init (0x5000c925)
[0001.000] I> Task: CPU WP0 (0x5000bb15)
[0001.005] I> Loading MCE
[0001.008] I> Slot: 0
[0001.010] I> Binary[8] block-0 (partition size: 0x80000)
[0001.016] I> get_binary_info: Binary name: MCE
[0001.021] I> Size of crypto header is 8192
[0001.025] I> BCH load address is : 0x4003e000
[0001.030] I> Size of crypto header is 8192
[0001.035] I> BCH of MCE read from storage
[0001.040] I> BCH address is : 0x4003e000
[0001.045] I> MCE header integrity check is success
[0001.050] I> Binary magic in BCH component 0 is MTSM
[0001.055] I> component binary type is 8
[0001.059] I> Size of crypto header is 8192
[0001.066] I> MCE binary is read from storage
[0001.071] I> MCE binary integrity check is success
[0001.076] I> Binary MCE loaded successfully at 0x40000000 (0x2c880)
[0001.084] I> Size of crypto header is 8192
[0001.098] I> Size of crypto header is 8192
[0001.103] I> Sending WP0 mailbox command to PSC
[0001.114] I> Task: XUSB Powergate (0x50000b91)
[0001.120] I> Skipping powergate XUSB.
[0001.123] I> Task: MB1 fixed firewalls (0x5002006d)
[0001.135] W> Firewall readback mismatch
[0001.139] W> Firewall readback mismatch
[0001.148] W> Firewall readback mismatch
[0001.157] I> Task: Load bpmp-fw (0x500203c9)
[0001.163] I> Slot: 0
[0001.165] I> Binary[15] block-0 (partition size: 0x180000)
[0001.171] I> get_binary_info: Binary name: BPMP_FW
[0001.177] I> Size of crypto header is 8192
[0001.181] I> BCH load address is : 0x807fe000
[0001.186] I> Size of crypto header is 8192
[0001.191] I> BCH of BPMP_FW read from storage
[0001.196] I> BCH address is : 0x807fe000
[0001.201] I> BPMP_FW header integrity check is success
[0001.207] I> Binary magic in BCH component 0 is BPMF
[0001.212] I> component binary type is 15
[0001.216] I> Size of crypto header is 8192
[0001.231] I> BPMP_FW binary is read from storage
[0001.239] I> BPMP_FW binary integrity check is success
[0001.244] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xfdd80)
[0001.252] I> Slot: 0
[0001.254] I> Binary[16] block-10000 (partition size: 0x400000)
[0001.261] I> get_binary_info: Binary name: BPMP_FW_DTB
[0001.267] I> Size of crypto header is 8192
[0001.271] I> BCH load address is : 0x807fc000
[0001.277] I> Size of crypto header is 8192
[0001.281] I> BCH of BPMP_FW_DTB read from storage
[0001.286] I> BCH address is : 0x807fc000
[0001.292] I> BPMP_FW_DTB header integrity check is success
[0001.298] I> Binary magic in BCH component 0 is BPMD
[0001.303] I> component binary type is 16
[0001.307] I> Size of crypto header is 8192
[0001.313] I> BPMP_FW_DTB binary is read from storage
[0001.319] I> BPMP_FW_DTB binary integrity check is success
[0001.325] I> Binary BPMP_FW_DTB loaded successfully at 0x807e31f0 (0x18e00)
[0001.333] I> Task: Load psc-fw (0x50020551)
[0001.339] I> Slot: 0
[0001.341] I> Binary[17] block-0 (partition size: 0xc0000)
[0001.347] I> get_binary_info: Binary name: PSC_FW
[0001.352] I> Size of crypto header is 8192
[0001.357] I> BCH load address is : 0x80ffe000
[0001.362] I> Size of crypto header is 8192
[0001.367] I> BCH of PSC_FW read from storage
[0001.372] I> BCH address is : 0x80ffe000
[0001.377] I> PSC_FW header integrity check is success
[0001.382] I> Binary magic in BCH component 0 is PFWP
[0001.388] I> component binary type is 17
[0001.392] I> Size of crypto header is 8192
[0001.400] I> PSC_FW binary is read from storage
[0001.406] I> PSC_FW binary integrity check is success
[0001.412] I> Binary PSC_FW loaded successfully at 0x80000000 (0x59980)
[0001.420] I> Task: Load nvdec-fw (0x500205c5)
[0001.425] I> Slot: 0
[0001.428] I> Binary[7] block-0 (partition size: 0x100000)
[0001.434] I> get_binary_info: Binary name: NVDEC
[0001.439] I> Size of crypto header is 8192
[0001.443] I> BCH load address is : 0x800fe000
[0001.449] I> Size of crypto header is 8192
[0001.453] I> BCH of NVDEC read from storage
[0001.458] I> BCH address is : 0x800fe000
[0001.463] I> NVDEC header integrity check is success
[0001.468] I> Binary magic in BCH component 0 is NDEC
[0001.474] I> component binary type is 7
[0001.478] I> Size of crypto header is 8192
[0001.486] I> NVDEC binary is read from storage
[0001.491] I> NVDEC binary integrity check is success
[0001.497] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0001.504] I> Size of crypto header is 8192
[0001.522] I> Task: Load tsec-fw (0x5002097d)
[0001.528] I> TSEC-FW load support not enabled
[0001.532] I> Task: GPIO interrupt map (0x500147b5)
[0001.538] I> Task: SC7 context save (0x50020d79)
[0001.544] I> Slot: 0
[0001.546] I> Binary[27] block-0 (partition size: 0x100000)
[0001.552] I> get_binary_info: Binary name: BR_BCT
[0001.558] I> Size of crypto header is 8192
[0001.562] I> Size of crypto header is 8192
[0001.567] I> BR_BCT binary is read from storage
[0001.572] I> BR_BCT binary integrity check is success
[0001.578] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[0001.585] I> Slot: 0
[0001.588] I> Binary[13] block-0 (partition size: 0x30000)
[0001.594] I> get_binary_info: Binary name: SC7-FW
[0001.599] I> Size of crypto header is 8192
[0001.603] I> Size of crypto header is 8192
[0001.608] I> BCH load address is : 0xa0002000
[0001.613] I> Size of crypto header is 8192
[0001.618] I> BCH of SC7-FW read from storage
[0001.622] I> BCH address is : 0xa0002000
[0001.628] I> SC7-FW header integrity check is success
[0001.633] I> Binary magic in BCH component 0 is WB0B
[0001.638] I> component binary type is 13
[0001.643] I> Size of crypto header is 8192
[0001.649] I> SC7-FW binary is read from storage
[0001.655] I> SC7-FW binary integrity check is success
[0001.660] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x26db0)
[0001.668] I> Slot: 0
[0001.670] I> Binary[22] block-0 (partition size: 0x30000)
[0001.676] I> get_binary_info: Binary name: PSC_RF
[0001.681] I> Size of crypto header is 8192
[0001.686] I> Size of crypto header is 8192
[0001.690] I> BCH load address is : 0xa002adb0
[0001.696] I> Size of crypto header is 8192
[0001.701] I> BCH of PSC_RF read from storage
[0001.705] I> BCH address is : 0xa002adb0
[0001.710] I> PSC_RF header integrity check is success
[0001.716] I> Binary magic in BCH component 0 is PSCR
[0001.721] I> component binary type is 22
[0001.725] I> Size of crypto header is 8192
[0001.731] I> PSC_RF binary is read from storage
[0001.737] I> PSC_RF binary integrity check is success
[0001.742] I> Binary PSC_RF loaded successfully at 0xa002cdb0 (0x1b140)
[0001.765] I> Task: Save WP0 payload to SC7 ctx (0x50021725)
[0001.772] I> Task: Load MB2rf binary to SC7 ctx (0x500216b9)
[0001.778] I> Slot: 0
[0001.781] I> Binary[14] block-0 (partition size: 0x20000)
[0001.787] I> get_binary_info: Binary name: MB2_RF
[0001.792] I> Size of crypto header is 8192
[0001.796] I> Size of crypto header is 8192
[0001.801] I> BCH load address is : 0xa00d6a48
[0001.806] I> Size of crypto header is 8192
[0001.811] I> BCH of MB2_RF read from storage
[0001.816] I> BCH address is : 0xa00d6a48
[0001.821] I> MB2_RF header integrity check is success
[0001.826] I> Binary magic in BCH component 0 is MB2R
[0001.832] I> component binary type is 14
[0001.836] I> Size of crypto header is 8192
[0001.842] I> MB2_RF binary is read from storage
[0001.847] I> MB2_RF binary integrity check is success
[0001.853] I> Binary MB2_RF loaded successfully at 0xa00d8a48 (0x1bfa0)
[0001.860] I> Task: Save Fuse-Bypass data to SC7 ctx (0x50021621)
[0001.868] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0001.876] I> SC7 context fuse-bypass data is empty
[0001.881] I> Task: Save PMIC data to SC7 ctx (0x5002144d)
[0001.887] I> Task: Save I2C bus freq data to SC7 ctx (0x500213d9)
[0001.894] I> Task: Save SOCTherm data to SC7 ctx (0x50021365)
[0001.901] I> Task: Save FMON data to SC7 ctx (0x500212f1)
[0001.907] I> Task: Save VMON data to SC7 ctx (0x50021279)
[0001.914] I> Task: Save TZDRAM data to SC7 ctx (0x5002178d)
[0001.920] I> Task: Save GPIO int data to SC7 ctx (0x50021561)
[0001.927] I> Task: Save clock data to SC7 ctx (0x50021205)
[0001.934] I> Task: Save debug data to SC7 ctx (0x50021191)
[0001.945] I> SC7 context save done
[0001.949] I> Task: Load MB2/Applet/FSKP (0x5000ca55)
[0001.954] I> Loading MB2
[0001.957] I> Slot: 0
[0001.960] I> Binary[6] block-0 (partition size: 0x80000)
[0001.966] I> get_binary_info: Binary name: MB2
[0001.971] I> Size of crypto header is 8192
[0001.975] I> BCH load address is : 0x8007e000
[0001.980] I> Size of crypto header is 8192
[0001.985] I> BCH of MB2 read from storage
[0001.990] I> BCH address is : 0x8007e000
[0001.995] I> MB2 header integrity check is success
[0002.000] I> Binary magic in BCH component 0 is MB2B
[0002.005] I> component binary type is 6
[0002.009] I> Size of crypto header is 8192
[0002.019] I> MB2 binary is read from storage
[0002.024] I> MB2 binary integrity check is success
[0002.029] I> Binary MB2 loaded successfully at 0x80000000 (0x68ee0)
[0002.037] I> Task: Map CCPLEX SHARED carveout (0x5000cbf9)
[0002.044] I> Task: Prepare MB2 params (0x5000cca9)
[0002.051] I> BR-BCT Boot Chain Fields
[0002.055] I> u32_non_gpio_select_boot_chain : 0
[0002.060] I> u32_num_boot_chains : 2
[0002.065] I> bf_bl_gpio_select_boot_chain_1b : 0
[0002.071] I> Task: Dram ecc test (0x50011791)
[0002.076] I> Task: Misc NV security settings (0x5000c529)
[0002.082] I> NVDEC sticky bits programming done
[0002.087] I> Successfully powergated NVDEC
[0002.092] I> Task: Disable/Reload WDT (0x50021a99)
[0002.098] I> Task: Program misc carveouts (0x50015381)
[0002.104] I> Program IPC carveouts
[0002.111] I> SLCG Global override status := 0x0
[0002.116] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-02a8384c)
I> Emulation:
I> Entry timestamp: 0x0020e0fa
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0x233000000, size:0x800000]
I> Task: ARI update carveout TZDRAM (0x50001e80)
I> Task: Enable hot-plug capability (0x50026bec)
I> Task: PSC mailbox init (0x50016a7c)
I> Task: Crypto init (0x500065a8)
I> Task: Enable GP-SE clock (0x50001fe4)
I> Task: DICE Identity init (0x50019e50)
I> DICE is not enabled.
I> Task: OEM SC7 context save init (0x50019550)
I> Task: I2C register (0x50001e44)
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout (0x50001e2c)
I> Task: Program CBB PCIE AMAP regions (0x50019b64)
I> Task: Boot device init (0x50001d74)
I> Task: Partition Manager Init (0x50001d70)
I> Found 57 partitions in QSPI_FLASH (instance 0)
I> Task: Load and authenticate registered FWs (0x5001ce48)
I> Task: Load AUXP FWs (0x5002678c)
I> Successfully register SPE FW load task with MB2 loader
I> Skipping SCE FW load
I> Successfully register RCE FW load task with MB2 loader
I> Successfully register DCE FW load task with MB2 loader
I> Unpowergating APE
I> Unpowergate done
I> Successfully register APE FW load task with MB2 loader
I> Skipping FSI FW load
I> Successfully register XUSB FW load task with MB2 loader
I> Partition name: A_spe-fw
I> Size of partition: 589824
I> Binary@ device:3/0 block-55040 (partition size: 0x90000), name: A_spe-fw
I> Partition name: A_rce-fw
I> Size of partition: 1048576
I> Binary@ device:3/0 block-56192 (partition size: 0x100000), name: A_rce-fw
I> spe: Authentication Finalize Done
I> Binary spe loaded successfully at 0x232400000
I> Partition name: A_dce-fw
I> Size of partition: 5242880
I> Binary@ device:3/0 block-44800 (partition size: 0x500000), name: A_dce-fw
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0x232100000
I> dce : oem authentication of header done
I> dce : meta-blob integrity check is success.
I> dce : will be decompressed at 0x23a000000
I> version 1 Bin 1 BCheckSum 0 content_size 0 Content ChkSum 1 reserved_00 0
I> Reserved10 0 BlockMaxSize 5 Reserved11 0
I> dce : decompressed to 9441408 bytes
I> dce: plain binary integrity check is success
I> Partition name: A_adsp-fw
I> Size of partition: 2097152
I> Binary@ device:3/0 block-58240 (partition size: 0x200000), name: A_adsp-fw
I> dce: Authentication Finalize Done
I> Binary dce loaded successfully at 0x23a000000
I> Partition name: A_xusb-fw
I> Size of partition: 262144
I> Binary@ device:3/0 block-9472 (partition size: 0x40000), name: A_xusb-fw
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0x232c00000
I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0x232500000
I> Task: Carveout setup (0x5001f55c)
I> Program remaining OEM carveouts
I> Task: Enable FSITHERM (0x50016950)
I> Task: Enable FSI VMON (0x500164d8)
I> Task: Validate FSI Therm readings (0x50016530)
I> Task: Restore XUSB sec (0x50001d44)
I> Task: Enable FSI SE clock (0x50016ed8)
I> Task: Initialize SBSA UART CAR (0x50001f48)
I> Task: Ratchet update (0x50027c88)
W> OPTIN fuse not set, skip ratchet update
I> Task: Initialize CPUBL Params (0x50017e0c)
I> CPUBL-params @ 0x236000000
I> Task: Prepare eeprom data (0x50017bd8)
I> Task: FSI padctl context save (0x500196e0)
E> Skipping FSI padctl config save: fsi not enabled
I> Task: Unpowergate APE (0x50017640)
W> mb2_unpowergate_ape: skip! APE is in unpowergated state
I> Task: OEM firewalls (0x500238fc)
I> OEM firewalls configured
I> Task: Powergate APE (0x500177b4)
I> Powergating APE
I> Powergate done
I> Task: OEM firewall restore saved settings (0x50023d50)
I> Task: Unhalt AUXPs (0x500269f4)
I> Unhalting SPE…
I> Enabling combined UART
����spe: early_init
vic initialized
tsc initialized
aon lic initialized
spe: tag is 243b265b351d6bb9cc7b2e3acc5d90f8
spe: SafeRTOS v8.4
spe: init
scheduler initialized
aon hsp initialized
tag initialized
tcu initialized
bpmp ipc initialized
spe: late init
cpu_nic clock initialized
apb clock initialized
pm initialized
bpmp hsp initialized
top1 hsp initialized
ccplex ipc initialized
spe: start scheduler
I> Task: Trigger mailbox for PSC-BL1 exit (0x50016afc)
I> Sending opcode 0x4d420802 to psc
��INFO: Entering psc_monitor_init!
INFO: GSC22 BOM:0x248002000 SIZE:0x1000000 CLIENT_ACCESS1:00180000
INFO: PSCFW BUILD VERSION: 8a33b23-73b589c-8a15f76-rel-t234
INFO: mstatus:0xa00000808
INFO: Supervisor entry_point:c108c00
��I> Received ACK from psc
I> Tas��INFO: MONITOR: user task addr:0x248022000, blob offset:0x00020000
INFO: MONITOR: populated user images:13
INFO: mret to Supervisor!
INFO: psc supervisor init.
INFO: psc_irq_init…
INFO: enter idle task.
bpmp: socket 0
bpmp: base binary md5 is 1377b684fe55be78e1d7fc3e0f143b55
bpmp: combined binary md5 is f0fadc45ec6216cb5b0bcb3771407fc2
bpmp: firmware tag is f0fadc45ec6216cb5b0b-1377b684fe5
initialized vwdt
initialized mail_early
initialized fuse
initialized vfrel
initialized hwwdt
initialized adc
fmon_populate_monitors: found 199 monitors
initialized fmon
initialized mc
initialized reset
initialized uphy_early
initialized emc_early
471 clocks registered
initialized clk_mach
initialized clk_cal_early
initialized clk_mach_early_config
initialized io_dpd
initialized soctherm
initialized tj_init
initialized regime
initialized i2c
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
initialized vrmon
initialized regulator
initialized avfs_clk_platform
initialized powergate
initialized dvs
initialized clk_mach_config
initialized pm
initialized suspend
initialized strap
initialized mce_dbell
��k: Start secure NOR provision (0x5001997c)
I> Task: Load FSI keyblob (0x50016f20)
I> Task: Unhalt AUXPs��initialized emc
initialized emc_mrq
�� (0x500269fc)
I> SCE unhalt skipped��initialized clk_cal
initialized uphy_dt
initialized uphy_mrq
HSIO UPHY reset has been de-asserted 0x0
initialized uphy
initialized pg_late
initialized pg_mrq_init
swdtimer_init: 0 reg polling start w period 47 ms
initialized swdtimer
initialized hwwdt_late
initialized bwmgr
initialized thermal_host_trip
initialized thermal_mrq
initialized oc_mrq
initialized reset_mrq
initialized mail_mrq
initialized fmon_mrq
initialized clk_mrq
initialized avfs_mrq
initialized i2c_mrq
initialized tag_mrq
initialized bwmgr_mrq
initialized console_mrq
missing prod DT calibration data for 199 fmons
initialized clk_sync_fmon_post
I> Unhalting RCE
I> RCE un��initialized clk��[ 2.578618] Camera-FW on t234-rce-safe started
TCU early console enabled.��_cal_late
initialized noc_late
initialized cvc
initialized avfs_clk_mach_po��
��st
initialized avfs_clk_platform_post
initialized cvc_late
initialized rm
initialized console_late
handling unreferenced clks
enable can1_core
enable can1_host
enable can2_core
enable can2_host
enable pwm3
enable mss_encrypt
enable maud
enable pllg_ref
enable dsi_core
enable aza_2xbit
enable xusb_ss
enable xusb_fs
enable xusb_falcon
enable xusb_core_mux
enable dsi_lp
clk_check_max_rates: pex1_c6_core rate 500000000 > max 250000000
clk_check_max_rates: pex2_c7_core rate 500000000 > max 250000000
clk_check_max_rates: pex2_c8_core rate 500000000 > max 250000000
clk_check_max_rates: pex2_c9_core rate 500000000 > max 250000000
clk_check_max_rates: pex2_c10_core rate 500000000 > max 250000000
clk_check_max_rates: pex0_c0_core rate 500000000 > max 250000000
clk_check_max_rates: pex0_c1_core rate 500000000 > max 250000000
clk_check_max_rates: pex0_c2_core rate 500000000 > max 250000000
clk_check_max_rates: pex0_c3_core rate 500000000 > max 250000000
clk_check_max_rates: pex0_c4_core rate 500000000 > max 250000000
clk_check_max_rates: pex1_c5_core rate 500000000 > max 250000000
initialized clk_mach_post
initialized pg_post
initialized regulator_post
initialized profile
initialized fuse_late
initialized mrq
initialized patrol_��[ 2.702492] Camera-FW on t234-rce-safe ready SHA1=0b67r
initialized cactmon
initialized extras_post
bpmp: init complete
��total boot 125.469 ms)
��halt successful
I> DCE unhalt successful
I> APE unhalt skipped
I> FSI unhalt skipped
I> Task: Load CPUBL (0x50017f04)
I> Task: Load TOS (0x50018608)
I> Task: Load and authenticate registered FWs (0x5001ce48)��
I> Partition name: A_cpu-bootloader
I> Size of partition: 3670016
I> Binary@ device:3/0 block-24832 (partition size: 0x380000), name: A_cpu-bootlr
I> Partition name: A_secure-os
I> Size of partition: 4194304
I> Binary@ device:3/0 block-32000 (partition size: 0x400000), name: A_secure-os
I> cpubl: Authentication Finalize Done
I> Binary cpubl loaded successfully at 0x231a00000
I> tos: Authentication Finalize Done
I> Binary tos loaded successfully at 0x23fdfe000
I> Relocating OP-TEE dtb from: 0x23feff770 to 0x231e30000, size: 0x1976
I> [0] START: 0x80000000, SIZE: 0x1b1e70000
I> [1] START: 0x236000000, SIZE: 0x2000000
I> Setting NS memory ranges to OP-TEE dtb finished.
I> Partition name: A_eks
I> Binary@ device:3/0 block-44288 (partition size: 0x40000), name: A_eks
I> eks: Authentication Finalize Done
I> Binary eks loaded successfully at 0x233000200
I> EKB detected (length: 0x410) @ VA:0x233000200
I> Task: Prepare TOS params (0x50018580)
��DCE: FW Boot Done
��I> Setting EKB blob info to OPTEE dtb finished.
I> Setting OPTEE arg3: 0x231e30000
I> Task: OEM SC7 context save (0x500197dc)
I> OEM sc7 context saved
I> Task: Disable MSS perf stats (0x50026a88)
I> Task: Program display sticky bits (0x50026a04)
I> Task: Storage device deinit (0x50001eec)
I> Task: SMMU external bypass disable (0x50016a60)
I> Task: SMMU init (0x5001697c)
I> Task: Program GICv3 registers (0x50026b28)
I> Task: Audit firewall settings (0x50023b50)
I> Task: Bootchain failure check (0x50002434)
I> Current Boot-Chain Slot: 0
I> BR-BCT Boot-Chain is 0, and status is 1. Set UPDATE_BRBCT bit to 0
I> MB2 finished
��NOTICE: BL31: v2.6(release):6363e7382
NOTICE: BL31: Built : 10:08:23, Feb 21 2023
I/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 3.19 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Tue Feb 24
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecturel
I/TC: Primary CPU initializing
I/TC: WARNING: Test OEM keys are being used!
I/TC: This is only for TZ-SE testing and should NOT be used for a shipping prod!
I/TC: Primary CPU switching to normal world boot
Jetson UEFI firmware (version 3.0-32616947 built on 2023-02-21T18:13:46+00:00)
ESC to enter Setup.
F11 to enter Boot Manager Menu.
Enter to continue boot.
** WARNING: Test Key is used. **
L4TLauncher: Attempting GRUB Boot
L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel…
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services…
��I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
��Failed to create /rm/vdd_cpu
debugfs initialized
��[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.15.122-tegra (buildbrain@mobile-u64-6517-d7000) )
[ 0.000000] Machine model: NVIDIA Jetson Orin Nano Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x20b5bd598 SMBIOS=0xffff0000 SMBIOS 3.0=0x20a530000
[ 0.000000] random: crng init done
[ 0.000000] secureboot: Secure boot disabled
[ 0.000000] esrt: Reserving ESRT space from 0x0000000207e62598 to 0x00000002.
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000021d000000, B
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id sharl
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x0000000237fffff]
[ 0.000000] NUMA: NODE_DATA [mem 0x230d63800-0x230d65fff]
[ 0.000000] Zon��WARNING: clock_disable: clk_power_ungate on gated domain 35k
��e ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000000237ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x0000000207ffffff]
[ 0.000000] node 0: [mem 0x0000000208000000-0x000000020a1bffff]
[ 0.000000] node 0: [mem 0x000000020a1c0000-0x000000020a222fff]
[ 0.000000] node 0: [mem 0x000000020a223000-0x000000020a397fff]
[ 0.000000] node 0: [mem 0x000000020a398000-0x000000020a51ffff]
[ 0.000000] node 0: [mem 0x000000020a520000-0x000000020a53ffff]
[ 0.000000] node 0: [mem 0x000000020a540000-0x000000020a77ffff]
[ 0.000000] node 0: [mem 0x000000020a780000-0x000000020a7cffff]
[ 0.000000] node 0: [mem 0x000000020a7d0000-0x000000020a8bffff]
[ 0.000000] node 0: [mem 0x000000020a8c0000-0x000000020a90ffff]
[ 0.000000] node 0: [mem 0x000000020a910000-0x000000020a95ffff]
[ 0.000000] node 0: [mem 0x000000020a960000-0x000000020a9affff]
[ 0.000000] node 0: [mem 0x000000020a9b0000-0x000000020aaeffff]
[ 0.000000] node 0: [mem 0x000000020aaf0000-0x000000020afeffff]
[ 0.000000] node 0: [mem 0x000000020aff0000-0x000000020b57ffff]
[ 0.000000] node 0: [mem 0x000000020b580000-0x000000020b58ffff]
[ 0.000000] node 0: [mem 0x000000020b590000-0x000000020b6affff]
[ 0.000000] node 0: [mem 0x000000020b6b0000-0x000000020b74ffff]
[ 0.000000] node 0: [mem 0x000000020b750000-0x000000020b84ffff]
[ 0.000000] node 0: [mem 0x000000020b850000-0x000000020b8effff]
[ 0.000000] node 0: [mem 0x000000020b8f0000-0x000000020b9effff]
[ 0.000000] node 0: [mem 0x000000020b9f0000-0x000000020ba8ffff]
[ 0.000000] node 0: [mem 0x000000020ba90000-0x000000020c35ffff]
[ 0.000000] node 0: [mem 0x000000020c360000-0x000000020c53ffff]
[ 0.000000] node 0: [mem 0x000000020c540000-0x000000022dceffff]
[ 0.000000] node 0: [mem 0x000000022dcf0000-0x000000022dd3ffff]
[ 0.000000] node 0: [mem 0x000000022dd40000-0x00000002317fffff]
[ 0.000000] node 0: [mem 0x0000000231a00000-0x0000000231e0ffff]
[ 0.000000] node 0: [mem 0x0000000236000000-0x0000000237ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000237ffffff]
[ 0.000000] On node 0, zone Normal: 512 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 16880 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 29 pages/cpu s80344 r8192 d30248 u118784
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Address authentication (architected algo)
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: detected: Hardware dirty bit management
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1756688
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 byt)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000fbfe0000-0x00000000fffe00)
[ 0.000000] Memory: 6537436K/7139392K available (19712K kernel code, 4056K r)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 ji.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycless
[ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398s
[ 0.000337] Console: colour dummy device 80x25
[ 0.000345] printk: console [tty0] enabled
[ 0.000402] Calibrating delay loop (skipped), value calculated using timer f)
[ 0.000408] pid_max: default: 32768 minimum: 301
[ 0.000443] LSM: Security Framework initializing
[ 0.000465] Yama: becoming mindful.
[ 0.000480] SELinux: Initializing.
[ 0.000554] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, l)
[ 0.000569] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 byt)
[ 0.001292] /cpus/cpu-map/cluster1: empty cluster
[ 0.001630] rcu: Hierarchical SRCU implementation.
[ 0.003629] Tegra Revision: A01 SKU: 213 CPU Process: 0 SoC Process: 0
[ 0.003873] Remapping and enabling EFI services.
[ 0.005057] smp: Bringing up secondary CPUs …
[ 0.033768] Detected PIPT I-cache on CPU1
[ 0.033808] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.033832] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.062485] Detected PIPT I-cache on CPU2
[ 0.062497] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.062512] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.091132] Detected PIPT I-cache on CPU3
[ 0.091143] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.091156] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.121826] Detected PIPT I-cache on CPU4
[ 0.121857] GICv3: CPU4: found redistributor 10200 region 0:0x000000000f50000
[ 0.121885] CPU4: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.150600] Detected PIPT I-cache on CPU5
[ 0.150613] GICv3: CPU5: found redistributor 10300 region 0:0x000000000f52000
[ 0.150631] CPU5: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.150694] smp: Brought up 1 node, 6 CPUs
[ 0.150699] SMP: Total of 6 processors activated.
[ 0.150703] CPU features: detected: 32-bit EL0 Support
[ 0.150705] CPU features: detected: Data cache clean to the PoU not requirede
[ 0.150707] CPU features: detected: Common not Private translations
[ 0.150708] CPU features: detected: CRC32 instructions
[ 0.150709] CPU features: detected: Data cache clean to Point of Persistence
[ 0.150710] CPU features: detected: Generic authentication (architected algo)
[ 0.150711] CPU features: detected: RCpc load-acquire (LDAPR)
[ 0.150712] CPU features: detected: LSE atomic instructions
[ 0.150713] CPU features: detected: Privileged Access Never
[ 0.150714] CPU features: detected: RAS Extension Support
[ 0.150716] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.166415] spectre-bhb mitigation disabled by command line option
[ 0.181057] CPU: All CPU(s) started at EL2
[ 0.182460] devtmpfs: initialized
[ 0.193743] KASLR enabled
[ 0.193842] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ms
[ 0.193854] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.195983] pinctrl core: initialized pinctrl subsystem
[ 0.196524] SMBIOS 3.0.0 present.
[ 0.196533] DMI: Unknown NVIDIA Orin NX Developer Kit/NVIDIA Orin NX Develop3
[ 0.196824] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.198004] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.198080] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic als
[ 0.198135] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic s
[ 0.198163] audit: initializing netlink subsys (disabled)
[ 0.198237] audit: type=2000 audit(0.196:1): state=initialized audit_enabled1
[ 0.199130] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.199133] thermal_sys: Registered thermal governor ‘user_space’
[ 0.199134] thermal_sys: Registered thermal governor ‘power_allocator’
[ 0.201093] cpuidle: using governor menu
[ 0.201232] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.201301] ASID allocator initialised with 32768 entries
[ 0.202449] Serial: AMBA PL011 UART driver
[ 0.211252] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 116, base_baud A
[ 0.220783] platform bpmp: Fixing up cyclic dependency with 2c60000.externalr
[ 0.228538] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.228543] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.228546] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.228548] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.229131] cryptd: max_cpu_qlen set to 1000
[ 0.230070] ACPI: Interpreter disabled.
[ 0.231047] VDD_1V8_AO: supplied by VDD_5V0_SYS
[ 0.231140] VDD_3V3_AO: supplied by VDD_5V0_SYS
[ 0.231358] VDD_AV10_HUB: supplied by VDD_5V0_SYS
[ 0.231651] iommu: Default domain type: Translated
[ 0.231654] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.231826] SCSI subsystem initialized
[ 0.231932] vgaarb: loaded
[ 0.232038] usbcore: registered new interface driver usbfs
[ 0.232052] usbcore: registered new interface driver hub
[ 0.232062] usbcore: registered new device driver usb
[ 0.232447] pps_core: LinuxPPS API ver. 1 registered
[ 0.232450] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giom>
[ 0.232455] PTP clock support registered
[ 0.232511] EDAC MC: Ver: 3.0.0
[ 0.233076] Registered efivars operations
[ 0.233535] FPGA manager framework
[ 0.233592] Advanced Linux Sound Architecture Driver Initialized.
[ 0.234072] clocksource: Switched to clocksource arch_sys_counter
[ 0.253574] VFS: Disk quotas dquot_6.6.0
[ 0.253615] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.253732] pnp: PnP ACPI: disabled
[ 0.255865] NET: Registered PF_INET protocol family
[ 0.256006] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, l)
[ 0.257469] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 655)
[ 0.257484] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes,)
[ 0.257492] TCP established hash table entries: 65536 (order: 7, 524288 byte)
[ 0.257570] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, lin)
[ 0.258101] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.258174] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.258198] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linea)
[ 0.258290] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.258523] RPC: Registered named UNIX socket transport module.
[ 0.258526] RPC: Registered udp transport module.
[ 0.258527] RPC: Registered tcp transport module.
[ 0.258528] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.258536] PCI: CLS 0 bytes, default 64
[ 0.258661] Unpacking initramfs…
[ 0.259266] hw perfevents: enabled with armv8_cortex_a78 PMU driver, 7 counte
[ 0.259413] kvm [1]: IPA Size Limit: 48 bits
[ 0.259430] kvm [1]: GICv3: no GICV resource entry
[ 0.259434] kvm [1]: disabling GICv2 emulation
[ 0.259445] kvm [1]: GIC system register CPU interface enabled
[ 0.259503] kvm [1]: vgic interrupt IRQ9
[ 0.259596] kvm [1]: VHE mode initialized successfully
[ 0.261557] Initialise system trusted keyrings
[ 0.261641] workingset: timestamp_bits=42 max_order=21 bucket_order=0
[ 0.264090] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.264343] NFS: Registering the id_resolver key type
[ 0.264355] Key type id_resolver registered
[ 0.264357] Key type id_legacy registered
[ 0.264389] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.264397] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registerin.
[ 0.264409] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.264545] 9p: Installing v9fs 9p2000 file system support
[ 0.279516] NET: Registered PF_ALG protocol family
[ 0.279526] Key type asymmetric registered
[ 0.279528] Asymmetric key parser ‘x509’ registered
[ 0.279572] Block layer SCSI generic (bsg) driver version 0.4 loaded (major )
[ 0.279575] io scheduler mq-deadline registered
[ 0.279578] io scheduler kyber registered
[ 0.287489] EINJ: ACPI disabled.
[ 0.296561] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.297785] SuperH (H)SCI(F) driver initialized
[ 0.298059] msm_serial: driver initialized
[ 0.298505] printk: console [ttyTCU0] enabled
[ 0.299232] arm-smmu 8000000.iommu: probing hardware configuration…
[ 0.299235] arm-smmu 8000000.iommu: SMMUv2 with:
[ 0.299239] arm-smmu 8000000.iommu: stage 1 translation
[ 0.299241] arm-smmu 8000000.iommu: stage 2 translation
[ 0.299243] arm-smmu 8000000.iommu: nested translation
[ 0.299246] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 0.299249] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 0.299260] arm-smmu 8000000.iommu: Supported page sizes: 0x61311000
[ 0.299263] arm-smmu 8000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 0.299265] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 0.300090] arm-smmu 10000000.iommu: probing hardware configuration…
[ 0.300093] arm-smmu 10000000.iommu: SMMUv2 with:
[ 0.300095] arm-smmu 10000000.iommu: stage 1 translation
[ 0.300096] arm-smmu 10000000.iommu: stage 2 translation
[ 0.300097] arm-smmu 10000000.iommu: nested translation
[ 0.300099] arm-smmu 10000000.iommu: stream matching with 128 regists
[ 0.300102] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 on)
[ 0.300105] arm-smmu 10000000.iommu: Supported page sizes: 0x61311000
[ 0.300106] arm-smmu 10000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 0.300108] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 0.300469] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.300471] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.300473] arm-smmu 12000000.iommu: stage 1 translation
[ 0.300474] arm-smmu 12000000.iommu: stage 2 translation
[ 0.300476] arm-smmu 12000000.iommu: nested translation
[ 0.300478] arm-smmu 12000000.iommu: stream matching with 128 regists
[ 0.300480] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 on)
[ 0.300484] arm-smmu 12000000.iommu: Supported page sizes: 0x61311000
[ 0.300486] arm-smmu 12000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 0.300487] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 0.304889] loop: module loaded
[ 0.305394] megasas: 07.717.02.00-rc1
[ 0.308295] tun: Universal TUN/TAP device driver, 1.6
[ 0.308737] thunder_xcv, ver 1.0
[ 0.308754] thunder_bgx, ver 1.0
[ 0.308765] nicpf, ver 1.0
[ 0.309427] hclge is initializing
[ 0.309439] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - versin
[ 0.309442] hns3: Copyright (c) 2017 Huawei Corporation.
[ 0.309463] e1000: Intel(R) PRO/1000 Network Driver
[ 0.309467] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 0.309489] e1000e: Intel(R) PRO/1000 Network Driver
[ 0.309491] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 0.309506] igb: Intel(R) Gigabit Ethernet Network Driver
[ 0.309509] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 0.309520] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.309522] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.309689] sky2: driver version 1.30
[ 0.310235] VFIO - User Level meta-driver version: 0.3
[ 0.311310] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.311315] ehci-pci: EHCI PCI platform driver
[ 0.311330] ehci-platform: EHCI generic platform driver
[ 0.311392] ehci-orion: EHCI orion driver
[ 0.311440] ehci-exynos: EHCI Exynos driver
[ 0.311486] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.311496] ohci-pci: OHCI PCI platform driver
[ 0.311512] ohci-platform: OHCI generic platform driver
[ 0.311568] ohci-exynos: OHCI Exynos driver
[ 0.311915] usbcore: registered new interface driver usb-storage
[ 0.313319] i2c_dev: i2c /dev entries driver
[ 0.315964] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-m
[ 0.317023] sdhci: Secure Digital Host Controller Interface driver
[ 0.317025] sdhci: Copyright(c) Pierre Ossman
[ 0.317407] Synopsys Designware Multimedia Card Interface Driver
[ 0.317914] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.318826] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.319447] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[ 0.319702] tegra-bpmp bpmp: Adding to iommu group 0
[ 0.320478] tegra-bpmp bpmp: firmware: f0fadc45ec6216cb5b0b-1377b684fe5
[ 0.454854] Freeing initrd memory: 10976K
[ 1.422641] clocksource: tsc: mask: 0xffffffffffffff max_cycles: 0xe6a171046s
[ 1.422652] clocksource: osc: mask: 0xffffffff max_cycles: 0xffffffff, max_is
[ 1.422655] clocksource: usec: mask: 0xffffffff max_cycles: 0xffffffff, max_s
[ 1.423022] usbcore: registered new interface driver usbhid
[ 1.423026] usbhid: USB HID core driver
[ 1.424637] tegra186-emc 2c60000.external-memory-controller: MRQ_BWMGR_INT nt
[ 1.427090] usbcore: registered new interface driver snd-usb-audio
[ 1.427831] NET: Registered PF_PACKET protocol family
[ 1.427965] 9pnet: Installing 9P2000 support
[ 1.428010] Key type dns_resolver registered
[ 1.428800] printk: console [tty0]: printing thread started
[ 1.429403] printk: console [ttyTCU0]: printing thread started
[ 1.429453] Loading compiled-in X.509 certificates
[ 1.436790] Loaded X.509 cert ‘Build time autogenerated kernel key: 6df01ab6’
[ 1.453952] tegra-gpcdma 2600000.dma-controller: Adding to iommu group 1
[ 1.454881] tegra-gpcdma 2600000.dma-controller: GPC DMA driver register 31 s
[ 1.455667] serial-tegra 3100000.serial: RX in PIO mode
[ 1.455671] serial-tegra 3100000.serial: TX in PIO mode
[ 1.455700] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 112, base_baud T
[ 1.456024] serial-tegra 3140000.serial: RX in PIO mode
[ 1.456026] serial-tegra 3140000.serial: TX in PIO mode
[ 1.456048] 3140000.serial: ttyTHS2 at MMIO 0x3140000 (irq = 195, base_baud T
[ 1.457185] tegra_rtc c2a0000.rtc: registered as rtc1
[ 1.457190] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 1.457474] tegra-i2c 3160000.i2c: Adding to iommu group 1
[ 1.459866] tegra-i2c 3180000.i2c: Adding to iommu group 1
[ 1.461430] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[ 1.462902] tegra-i2c c240000.i2c: Adding to iommu group 1
[ 1.464206] i2c 1-0025: Fixing up cyclic dependency with 3520000.padctl
[ 1.464550] tegra-i2c c250000.i2c: Adding to iommu group 1
[ 1.469144] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequz
[ 1.470979] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequz
[ 1.474255] tegra-xusb 3610000.usb: Adding to iommu group 2
[ 1.489027] tegra-xusb 3610000.usb: Firmware timestamp: 2021-12-01 05:27:10 C
[ 1.489036] tegra-xusb 3610000.usb: xHCI Host Controller
[ 1.489054] tegra-xusb 3610000.usb: new USB bus registered, assigned bus num1
[ 1.489801] tegra-xusb 3610000.usb: hcc params 0x0180ff05 hci version 0x120 0
[ 1.489827] tegra-xusb 3610000.usb: irq 121, io mem 0x03610000
[ 1.489978] tegra-xusb 3610000.usb: xHCI Host Controller
[ 1.489983] tegra-xusb 3610000.usb: new USB bus registered, assigned bus num2
[ 1.489988] tegra-xusb 3610000.usb: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.490792] hub 1-0:1.0: USB hub found
[ 1.490814] hub 1-0:1.0: 4 ports detected
[ 1.491705] hub 2-0:1.0: USB hub found
[ 1.491722] hub 2-0:1.0: 4 ports detected
[ 1.493920] sdhci-tegra 3400000.mmc: Adding to iommu group 3
[ 1.494612] irq: IRQ222: trimming hierarchy from :bus@0:pmc@c360000
[ 1.494692] irq: IRQ223: trimming hierarchy from :bus@0:interrupt-controller1
[ 1.494748] irq: IRQ224: trimming hierarchy from :bus@0:pmc@c360000
[ 1.494832] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 1.497409] sdhci-tegra 3400000.mmc: Got CD GPIO
[ 1.545964] ALSA device list:
[ 1.545971] No soundcards found.
[ 1.591596] irq: IRQ225: trimming hierarchy from :bus@0:interrupt-controller1
[ 1.591986] mmc0: SDHCI controller on 3400000.mmc [3400000.mmc] using ADMA 6t
[ 1.593516] Freeing unused kernel memory: 7680K
[ 1.593608] Run /init as init process
[ 1.612603] Checking overlayfs setting…
[ 1.623483] Overlayfs is disabled…
[ 1.630089] Root device found: mmcblk0p1
[ 1.850128] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 2.021348] hub 1-2:1.0: USB hub found
[ 2.022562] hub 1-2:1.0: 4 ports detected
[ 2.138927] usb 2-1: new SuperSpeed Plus Gen 2x1 USB device number 2 using tb
[ 2.192782] hub 2-1:1.0: USB hub found
[ 2.195240] hub 2-1:1.0: 4 ports detected
[ 2.302095] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[ 3.996991] mmc0: Skipping voltage switch
[ 4.197641] mmc0: new high speed SDXC card at address 59b4
[ 4.198915] mmcblk0: mmc0:59b4 SD128 119 GiB
[ 4.207712] GPT:Primary header thinks Alt. header is not at the end of the d.
[ 4.207717] GPT:57085951 != 249670655
[ 4.207720] GPT:Alternate GPT header not at the end of the disk.
[ 4.207722] GPT:57085951 != 249670655
[ 4.207723] GPT: Use GNU Parted to correct GPT errors.
[ 4.207742] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 6.070880] Found dev node: /dev/mmcblk0p1
[ 6.192781] EXT4-fs (mmcblk0p1): recovery complete
[ 6.192798] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. .
[ 6.203995] Rootfs mounted over mmcblk0p1
[ 6.235957] Switching from initrd to actual rootfs
[ 6.962509] systemd[1]: System time before build time, advancing clock.
[ 7.114361] NET: Registered PF_INET6 protocol family
[ 7.115949] Segment Routing with IPv6
[ 7.115959] In-situ OAM (IOAM) with IPv6
[ 7.192190] systemd[1]: systemd 249.11-0ubuntu3.11 running in system mode (+)
[ 7.192699] systemd[1]: Detected architecture arm64.
[ 7.194892] systemd[1]: Hostname set to <localhost.localdomain>.
[ 7.227021] systemd[1]: Using hardware watchdog ‘NVIDIA Tegra186 WDT’, versig
[ 7.227044] systemd[1]: Set hardware watchdog to 2min.
[ 7.787593] systemd[1]: /etc/systemd/system/nvs-service.service:41: Standard.
[ 7.799470] systemd[1]: /etc/systemd/system/nvargus-daemon.service:42: Stand.
[ 7.890765] systemd[1]: Queued start job for default target OEM Configuratio.
[ 7.911498] systemd[1]: Created slice Slice /system/modprobe.
[ 7.912230] systemd[1]: Set up automount Arbitrary Executable File Formats F.
[ 7.912375] systemd[1]: Reached target Slice Units.
[ 7.912443] systemd[1]: Reached target Swaps.
[ 7.912505] systemd[1]: Reached target Local Verity Protected Volumes.
[ 7.920772] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 7.921279] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 7.921468] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 7.921929] systemd[1]: Listening on Journal Audit Socket.
[ 7.922209] systemd[1]: Listening on Journal Socket (/dev/log).
[ 7.922513] systemd[1]: Listening on Journal Socket.
[ 7.926927] systemd[1]: Listening on udev Control Socket.
[ 7.927204] systemd[1]: Listening on udev Kernel Socket.
[ 7.929177] systemd[1]: Mounting Huge Pages File System…
[ 7.931113] systemd[1]: Mounting POSIX Message Queue File System…
[ 7.932942] systemd[1]: Mounting Kernel Debug File System…
[ 7.934857] systemd[1]: Mounting Kernel Trace File System…
[ 7.939222] systemd[1]: Starting Journal Service…
[ 7.941894] systemd[1]: Starting Set the console keyboard layout…
[ 7.944033] systemd[1]: Starting Create List of Static Device Nodes…
[ 7.945590] systemd[1]: Starting Load Kernel Module configfs…
[ 7.947545] systemd[1]: Starting Load Kernel Module efi_pstore…
[ 7.956210] systemd[1]: Starting Load Kernel Module fuse…
[ 7.957943] systemd[1]: Starting NVIDIA specific first-boot udev script…
[ 7.959777] systemd[1]: Started Nameserver information manager.
[ 7.973454] systemd[1]: Reached target Preparation for Network.
[ 7.973659] systemd[1]: Condition check resulted in File System Check on Roo.
[ 7.997453] fuse: init (API version 7.34)
[ 7.997985] systemd[1]: Starting Load Kernel Modules…
[ 8.000216] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 8.001973] systemd[1]: Starting Coldplug All udev Devices…
[ 8.013329] systemd[1]: Mounted Huge Pages File System.
[ 8.013820] systemd[1]: Mounted POSIX Message Queue File System.
[ 8.014106] systemd[1]: Mounted Kernel Debug File System.
[ 8.019124] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null). Quota mode: none.
[ 8.034182] systemd[1]: Started Journal Service.
[ 8.108171] systemd-journald[218]: Received client request to flush runtime .
[ 8.125010] nvsciipc: loading out-of-tree module taints kernel.
[ 8.126696] nvsciipc: loaded module
[ 8.258853] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 8.334808] tegra-host1x 13e00000.host1x: Adding to iommu group 4
[ 8.343130] host1x-context host1x-ctx.0: Adding to iommu group 5
[ 8.343328] host1x-context host1x-ctx.1: Adding to iommu group 6
[ 8.343471] host1x-context host1x-ctx.2: Adding to iommu group 7
[ 8.343645] host1x-context host1x-ctx.3: Adding to iommu group 8
[ 8.343814] host1x-context host1x-ctx.4: Adding to iommu group 9
[ 8.343976] host1x-context host1x-ctx.5: Adding to iommu group 10
[ 8.344119] host1x-context host1x-ctx.6: Adding to iommu group 11
[ 8.344260] host1x-context host1x-ctx.7: Adding to iommu group 12
[ 8.344400] host1x-context host1x-ctx.8: Adding to iommu group 13
[ 8.344543] host1x-context host1x-ctx.9: Adding to iommu group 14
[ 8.344679] host1x-context host1x-ctx.10: Adding to iommu group 15
[ 8.344813] host1x-context host1x-ctx.11: Adding to iommu group 16
[ 8.344950] host1x-context host1x-ctx.12: Adding to iommu group 17
[ 8.345079] host1x-context host1x-ctx.13: Adding to iommu group 18
[ 8.345219] host1x-context host1x-ctx.14: Adding to iommu group 19
[ 8.345352] host1x-context host1x-ctx.15: Adding to iommu group 20
[ 8.619358] nvgpu: 17000000.gpu nvgpu_nvhost_syncpt_init:135 [INFO0
[ 8.619358]
[ 9.467859] dce: dce_admin_send_rm_bootstrap:616 Error in handling rm boots]
[ 9.467861] dce: dce_start_admin_seq:652 RPC failed for DCE_ADMIN_CMD_RM_BOP
[ 9.467863] dce: dce_start_boot_flow:163 DCE_BOOT_FAILED: Admin flow didn’te
[ 9.467865] dce: dce_bootstrap_work_fn:207 DCE bootstrapping failed
[ 9.467865]
[ 9.822891] tegra186-cam-rtcpu bc00000.rtcpu: RTCPU trace: IOVM setup error:0
[ 9.822904] tegra186-cam-rtcpu bc00000.rtcpu: trace boot sync failed: -5
[ 9.828831] tegra186-cam-rtcpu bc00000.rtcpu: RTCPU trace: IOVM setup error:0
[ 9.828833] tegra186-cam-rtcpu bc00000.rtcpu: trace boot sync failed: -5
[ 9.829121] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: ivc channel driver mg
[ 9.829123] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: ivc channel driver mig
[ 9.829125] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: ivc channel driver mig
[ 9.829127] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivc channel drg
[ 9.829129] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivc channel drg
[ 9.829130] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: ivc channel driver mg
[ 10.237802] tegra-nvenc 154c0000.nvenc: _opp_is_duplicate: duplicate OPPs de1
[ 10.237814] tegra-nvenc 154c0000.nvenc: _opp_is_duplicate: duplicate OPPs de1
** 7766 printk messages dropped **
And after message tegra-nvenc 154c0000.nvenc: _opp_is_duplicate: duplicate OPPs de1 it doesn’t matter how long I wait. it goes nowhere
Also I think worth to mention I was trying to increase and use swap memory with my nvme. but I don’t think it worked and eventually I removed it. But after a couple times of running jetson it was always fail. So my question is how to reset all the setting to factory mode or what setting I should change to be able boot it again? By video you sent to me I can not modify any settings actually even through minicom utility
You just re-flash the device.
We don’t have anything otherwise called factory reset.
I flashed it a hundred times. It’s not helping. When on screen I see like press F11 or Esc to enter setup menu, I press keys but it doesn’t respond! I can not enter setup menu
What should I do? How to fix device?
You need to re-flash with SDK Manager, with which an Ubuntu PC is required.
The SD card image is not going to change anything.
Link on instructions? How to reflash with sdk manager?
