NVidia Jetson Agx Orin - won't go into recovery
Hi I’m trying to flash the Nvidia Jetson Agx Orin kit with R35.4.1 and have followed the steps to force it into recovery:
When it’s off - press recovery button then power and release both
When it’s on - press recovery then reset and release both
On typing it lsusb on the host - I do see the Nvidia kit listed there however on trying to flash it (sudo ./flash.sh…) I see the error :
Error: probing the target board failed.
Make sure the target board is connected through
micro-B USB port and is in recovery mode.
I also tried putting it into recovery through the command: sudo reboot recovery-mode but I see the same result as above - it seems to boot the normal way. Attached are my boot logs for reference.
-desktop:~/Documents$ sudo reboot forced-recovery
[sudo] password for:
[ 276.176071] watchdog: watchdog0: watchdog did not stop!
[ 277.000114] Trying to unregister non-registered hwtime source
[ 277.209928] arm-smmu 8000000.iommu: disabling translation
[ 277.215909] arm-smmu 10000000.iommu: disabling translation
[ 277.221665] arm-smmu 12000000.iommu: disabling translation
[ 277.228322] reboot: Restarting system with command ‘forced-recovery’
ÿäÿâShutdown state requested 1
Rebooting system …
ÿâ
[0000.066] I> MB1 (version: 1.2.0.0-t234-54845784-562369e5)
[0000.071] I> t234-A01-1-Silicon (0x12347) Prod
[0000.075] I> Boot-mode : Coldboot
[0000.078] I> Entry timestamp: 0x00000000
[0000.082] I> last_boot_error: 0x0
[0000.085] I> BR-BCT: preprod_dev_sign: 0
[0000.089] I> rst_source: 0x3, rst_level: 0x1
[0000.093] I> Task: SE error check
[0000.096] I> Task: Bootchain select WAR set
[0000.100] I> Task: Enable SLCG
[0000.103] I> Task: CRC check
[0000.106] I> Task: Initialize MB2 params
[0000.110] I> MB2-params @ 0x40060000
[0000.114] I> Task: Crypto init
[0000.117] I> Task: Perform MB1 KAT tests
[0000.121] I> Task: NVRNG health check
[0000.124] I> NVRNG: Health check success
[0000.128] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.134] I> Task: Enabling and initialization of Bandwidth limiter
[0000.140] I> No request to configure MBWT settings for any PC!
[0000.146] I> Task: Secure debug controls
[0000.150] I> Task: strap war set
[0000.153] I> Task: Initialize SOC Therm
[0000.156] I> Task: Program NV master stream id
[0000.161] I> Task: Verify boot mode
[0000.166] I> Task: Alias fuses
[0000.170] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.177] I> Task: Print SKU type
[0000.180] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000000
[0000.186] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[0000.190] I> FUSE_OPT_TPC_DISABLE = 0x00000000
[0000.194] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0000.198] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0000.203] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0000.207] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.212] I> FUSE_OPT_FSI_DISABLE = 0x00000000
[0000.216] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0000.220] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.224] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.228] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.233] I> FUSE_SKU_INFO_0 = 0xd0
[0000.236] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.240] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.244] I> SKU: Prod
[0000.246] I> Task: Boost clocks
[0000.249] I> Initializing PLLC2 for AXI_CBB.
[0000.253] I> AXI_CBB : src = 35, divisor = 0
[0000.257] I> Task: Voltage monitor
[0000.260] I> VMON: Vmon re-calibration and fine tuning done
[0000.266] I> Task: UPHY init
[0000.271] I> HSIO UPHY init done
[0000.274] W> Skipping GBE UPHY config
[0000.277] I> Task: Boot device init
[0000.281] I> Boot_device: QSPI_FLASH instance: 0
[0000.285] I> Qspi clock source : pllc_out0
[0000.289] I> QSPI Flash: Macronix 64MB
[0000.293] I> QSPI-0l initialized successfully
[0000.297] I> Task: TSC init
[0000.300] I> Task: Load membct
[0000.303] I> RAM_CODE 0x4000431
[0000.306] I> Loading MEMBCT
[0000.309] I> Slot: 0
[0000.311] I> Binary[0] block-3840 (partition size: 0x40000)
[0000.316] I> Binary name: MEM-BCT-0
[0000.320] I> Size of crypto header is 8192
[0000.323] I> Size of crypto header is 8192
[0000.327] I> strt_pg_num(3840) num_of_pgs(16) read_buf(0x40050000)
[0000.334] I> BCH of MEM-BCT-0 read from storage
[0000.338] I> BCH address is : 0x40050000
[0000.342] I> MEM-BCT-0 header integrity check is success
[0000.347] I> Binary magic in BCH component 0 is MEM0
[0000.352] I> component binary type is 0
[0000.356] I> strt_pg_num(3856) num_of_pgs(115) read_buf(0x40040000)
[0000.362] I> MEM-BCT-0 binary is read from storage
[0000.367] I> MEM-BCT-0 binary integrity check is success
[0000.372] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.379] I> RAM_CODE 0x4000431
[0000.384] I> RAM_CODE 0x4000431
[0000.388] I> Task: Load Page retirement list
[0000.392] I> Task: SDRAM params override
[0000.396] I> Task: Save mem-bct info
[0000.400] I> Task: Carveout allocate
[0000.403] I> RCM blob carveout will not be allocated
[0000.408] I> Update CCPLEX IST carveout from MB1-BCT
[0000.413] I> ECC region[0]: Start:0x0, End:0x0
[0000.417] I> ECC region[1]: Start:0x0, End:0x0
[0000.421] I> ECC region[2]: Start:0x0, End:0x0
[0000.426] I> ECC region[3]: Start:0x0, End:0x0
[0000.430] I> ECC region[4]: Start:0x0, End:0x0
[0000.434] I> Non-ECC region[0]: Start:0x80000000, End:0x1080000000
[0000.440] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.445] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.449] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.454] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.465] I> allocated(CO:44) base:0x1049800000 size:0x36800000 align: 0x100000
[0000.472] I> allocated(CO:31) base:0x1040000000 size:0x8000000 align: 0x8000000
[0000.479] I> allocated(CO:43) base:0x103c000000 size:0x4000000 align: 0x200000
[0000.486] I> allocated(CO:39) base:0x1039e00000 size:0x2200000 align: 0x10000
[0000.493] I> allocated(CO:20) base:0x1036000000 size:0x2000000 align: 0x2000000
[0000.501] I> allocated(CO:24) base:0x1034000000 size:0x2000000 align: 0x2000000
[0000.508] I> allocated(CO:28) base:0x1032000000 size:0x2000000 align: 0x2000000
[0000.515] I> allocated(CO:29) base:0x1030000000 size:0x2000000 align: 0x2000000
[0000.522] I> allocated(CO:22) base:0x1048000000 size:0x1000000 align: 0x1000000
[0000.529] I> allocated(CO:41) base:0x1038e00000 size:0x1000000 align: 0x100000
[0000.537] I> allocated(CO:35) base:0x1038000000 size:0xe00000 align: 0x10000
[0000.543] I> allocated(CO:02) base:0x1049000000 size:0x800000 align: 0x800000
[0000.550] I> allocated(CO:03) base:0x102f800000 size:0x800000 align: 0x800000
[0000.558] I> allocated(CO:06) base:0x102f000000 size:0x800000 align: 0x800000
[0000.565] I> allocated(CO:56) base:0x102e800000 size:0x800000 align: 0x200000
[0000.572] I> allocated(CO:07) base:0x102e400000 size:0x400000 align: 0x400000
[0000.579] I> allocated(CO:33) base:0x102e000000 size:0x400000 align: 0x200000
[0000.586] I> allocated(CO:23) base:0x102de00000 size:0x200000 align: 0x200000
[0000.593] I> allocated(CO:01) base:0x102dd00000 size:0x100000 align: 0x100000
[0000.600] I> allocated(CO:04) base:0x102dc00000 size:0x100000 align: 0x100000
[0000.607] I> allocated(CO:05) base:0x102db00000 size:0x100000 align: 0x100000
[0000.614] I> allocated(CO:08) base:0x102da00000 size:0x100000 align: 0x100000
[0000.621] I> allocated(CO:09) base:0x102d900000 size:0x100000 align: 0x100000
[0000.628] I> allocated(CO:15) base:0x102d800000 size:0x100000 align: 0x100000
[0000.635] I> allocated(CO:17) base:0x102d700000 size:0x100000 align: 0x100000
[0000.642] I> allocated(CO:27) base:0x102d600000 size:0x100000 align: 0x100000
[0000.649] I> allocated(CO:42) base:0x102d500000 size:0x100000 align: 0x100000
[0000.656] I> allocated(CO:54) base:0x102d480000 size:0x80000 align: 0x80000
[0000.663] I> allocated(CO:34) base:0x102d470000 size:0x10000 align: 0x10000
[0000.670] I> allocated(CO:72) base:0x102d270000 size:0x200000 align: 0x10000
[0000.677] I> allocated(CO:47) base:0x102ce00000 size:0x400000 align: 0x200000
[0000.684] I> allocated(CO:48) base:0x102d250000 size:0x20000 align: 0x10000
[0000.690] I> allocated(CO:69) base:0x102d230000 size:0x20000 align: 0x10000
[0000.697] I> allocated(CO:49) base:0x102d220000 size:0x10000 align: 0x10000
[0000.704] I> allocated(CO:50) base:0x102d210000 size:0x10000 align: 0x10000
[0000.711] I> allocated(CO:52) base:0x102d200000 size:0x10000 align: 0x10000
[0000.718] I> NSDRAM base: 0x80000000, end: 0x102d270000, size: 0xfad270000
[0000.725] I> Task: Thermal check
[0000.728] I> max_chip_limit = 105
[0000.731] I> min_chip_limit = -28
[0000.734] I> max temp read = 33
[0000.737] I> min temp read = 33
[0000.740] I> Task: Update FSI SCR with thermal fuse data
[0000.745] I> Task: Enable WDT 5th expiry
[0000.749] I> Task: I2C register
[0000.752] I> Task: Set I2C bus freq
[0000.755] I> Task: Reset FSI
[0000.758] I> Task: Pinmux init
[0000.761] I> Task: Prod config init
[0000.765] I> Task: Pad voltage init
[0000.768] I> Task: Prod init
[0000.771] I> Task: Program rst req config reg
[0000.775] I> Task: Common rail init
[0000.778] I> DONE: Thermal config
[0000.782] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.790] I> DONE: SOC rail config
[0000.794] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0000.801] I> DONE: MEMIO rail config
[0000.804] I> DONE: GPU rail info
[0000.807] I> DONE: CV rail info
[0000.810] I> Task: Mem clock src
[0000.813] I> Task: Misc. board config
[0000.817] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0000.823] I> Task: SDRAM init
[0000.826] I> MemoryType: 4 MemBctRevision: 8
[0000.832] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 8
[0000.840] I> MSS CAR: Init PLLM
[0000.843] I> MSS CAR: Init PLLHUB
[0000.848] I> Encryption: MTS: en, TX: en, VPR: en, GSC: en
[0000.859] I> SDRAM initialized!
[0000.862] I> SDRAM Size in Total 0x1000000000
[0000.867] I> Task: Dram Ecc scrub
[0000.870] I> Task: DRAM alias check
[0000.899] I> Task: Program NSDRAM carveout
[0000.903] I> NSDRAM carveout encryption is enabled
[0000.908] I> Program NSDRAM carveout
[0000.912] I> Task: Register checker
[0000.919] I> Task: Enable clock-mon
[0000.933] I> FMON: Fmon re-programming done
[0000.938] I> Task: Mapper init
[0000.941] I> Task: SC7 Context Init
[0000.945] I> Task: CCPLEX IST init
[0000.949] I> Task: CPU WP0
[0000.953] I> Loading MCE
[0000.955] I> Slot: 0
[0000.958] I> Binary[8] block-22784 (partition size: 0x80000)
[0000.964] I> Binary name: MCE
[0000.967] I> Size of crypto header is 8192
[0000.972] I> Size of crypto header is 8192
[0000.976] I> strt_pg_num(22784) num_of_pgs(16) read_buf(0x4003e000)
[0000.984] I> BCH of MCE read from storage
[0000.988] I> BCH address is : 0x4003e000
[0000.993] I> MCE header integrity check is success
[0000.999] I> Binary magic in BCH component 0 is MTSM
[0001.004] I> component binary type is 8
[0001.008] I> Size of crypto header is 8192
[0001.012] I> strt_pg_num(22800) num_of_pgs(357) read_buf(0x40000000)
[0001.022] I> MCE binary is read from storage
[0001.027] I> MCE binary integrity check is success
[0001.033] I> Binary MCE loaded successfully at 0x40000000 (0x2c880)
[0001.040] I> Size of crypto header is 8192
[0001.055] I> Size of crypto header is 8192
[0001.060] I> Sending WP0 mailbox command to PSC
[0001.070] I> Task: XUSB Powergate
[0001.073] I> Skipping powergate XUSB.
[0001.077] I> Task: MB1 fixed firewalls
[0001.092] W> Firewall readback mismatch
[0001.103] I> Task: Load bpmp-fw
[0001.106] I> Slot: 0
[0001.109] I> Binary[15] block-9984 (partition size: 0x180000)
[0001.115] I> Binary name: BPMP_FW
[0001.119] I> Size of crypto header is 8192
[0001.123] I> Size of crypto header is 8192
[0001.128] I> strt_pg_num(9984) num_of_pgs(16) read_buf(0x807fe000)
[0001.136] I> BCH of BPMP_FW read from storage
[0001.140] I> BCH address is : 0x807fe000
[0001.145] I> BPMP_FW header integrity check is success
[0001.151] I> Binary magic in BCH component 0 is BPMF
[0001.156] I> component binary type is 15
[0001.160] I> Size of crypto header is 8192
[0001.165] I> strt_pg_num(10000) num_of_pgs(2037) read_buf(0x80000000)
[0001.184] I> BPMP_FW binary is read from storage
[0001.191] I> BPMP_FW binary integrity check is success
[0001.196] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xfea00)
[0001.204] I> Slot: 0
[0001.207] I> Binary[16] block-13056 (partition size: 0x400000)
[0001.213] I> Binary name: BPMP_FW_DTB
[0001.217] I> Size of crypto header is 8192
[0001.222] I> Size of crypto header is 8192
[0001.226] I> strt_pg_num(13056) num_of_pgs(16) read_buf(0x807fc000)
[0001.234] I> BCH of BPMP_FW_DTB read from storage
[0001.239] I> BCH address is : 0x807fc000
[0001.244] I> BPMP_FW_DTB header integrity check is success
[0001.250] I> Binary magic in BCH component 0 is BPMD
[0001.256] I> component binary type is 16
[0001.260] I> Size of crypto header is 8192
[0001.264] I> strt_pg_num(13072) num_of_pgs(259) read_buf(0x807db9f0)
[0001.274] I> BPMP_FW_DTB binary is read from storage
[0001.280] I> BPMP_FW_DTB binary integrity check is success
[0001.285] I> Binary BPMP_FW_DTB loaded successfully at 0x807db9f0 (0x20480)
[0001.294] I> Task: Load psc-fw
[0001.298] I> Slot: 0
[0001.300] I> Binary[17] block-21248 (partition size: 0xc0000)
[0001.307] I> Binary name: PSC_FW
[0001.310] I> Size of crypto header is 8192
[0001.315] I> Size of crypto header is 8192
[0001.319] I> strt_pg_num(21248) num_of_pgs(16) read_buf(0x80ffe000)
[0001.327] I> BCH of PSC_FW read from storage
[0001.332] I> BCH address is : 0x80ffe000
[0001.337] I> PSC_FW header integrity check is success
[0001.343] I> Binary magic in BCH component 0 is PFWP
[0001.348] I> component binary type is 17
[0001.352] I> Size of crypto header is 8192
[0001.357] I> strt_pg_num(21264) num_of_pgs(717) read_buf(0x80fa4600)
[0001.368] I> PSC_FW binary is read from storage
[0001.374] I> PSC_FW binary integrity check is success
[0001.380] I> Binary PSC_FW loaded successfully at 0x80fa4600 (0x59980)
[0001.388] I> Task: Load nvdec-fw
[0001.392] I> Slot: 0
[0001.394] I> Binary[7] block-6400 (partition size: 0x100000)
[0001.400] I> Binary name: NVDEC
[0001.404] I> Size of crypto header is 8192
[0001.408] I> Size of crypto header is 8192
[0001.413] I> strt_pg_num(6400) num_of_pgs(16) read_buf(0x800fe000)
[0001.421] I> BCH of NVDEC read from storage
[0001.425] I> BCH address is : 0x800fe000
[0001.430] I> NVDEC header integrity check is success
[0001.436] I> Binary magic in BCH component 0 is NDEC
[0001.441] I> component binary type is 7
[0001.445] I> Size of crypto header is 8192
[0001.450] I> strt_pg_num(6416) num_of_pgs(560) read_buf(0x80000000)
[0001.460] I> NVDEC binary is read from storage
[0001.466] I> NVDEC binary integrity check is success
[0001.471] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0001.479] I> Size of crypto header is 8192
[0001.500] I> Task: Load tsec-fw
[0001.503] I> TSEC-FW load support not enabled
[0001.508] I> Task: GPIO interrupt map
[0001.512] I> Task: SC7 context save
[0001.516] I> Slot: 0
[0001.518] I> Binary[27] block-0 (partition size: 0x100000)
[0001.524] I> Binary name: BR_BCT
[0001.528] I> Size of crypto header is 8192
[0001.532] I> Size of crypto header is 8192
[0001.537] I> strt_pg_num(0) num_of_pgs(16) read_buf(0xa0000000)
[0001.544] I> BR_BCT binary is read from storage
[0001.549] I> BR_BCT binary integrity check is success
[0001.555] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[0001.562] I> Slot: 0
[0001.565] I> Binary[13] block-23808 (partition size: 0x30000)
[0001.571] I> Binary name: SC7-FW
[0001.575] I> Size of crypto header is 8192
[0001.579] I> Size of crypto header is 8192
[0001.584] I> Size of crypto header is 8192
[0001.588] I> strt_pg_num(23808) num_of_pgs(16) read_buf(0xa0002000)
[0001.596] I> BCH of SC7-FW read from storage
[0001.601] I> BCH address is : 0xa0002000
[0001.606] I> SC7-FW header integrity check is success
[0001.612] I> Binary magic in BCH component 0 is WB0B
[0001.617] I> component binary type is 13
[0001.621] I> Size of crypto header is 8192
[0001.626] I> strt_pg_num(23824) num_of_pgs(345) read_buf(0xa0004000)
[0001.635] I> SC7-FW binary is read from storage
[0001.641] I> SC7-FW binary integrity check is success
[0001.646] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x2b0e0)
[0001.654] I> Slot: 0
[0001.657] I> Binary[22] block-24192 (partition size: 0x30000)
[0001.663] I> Binary name: PSC_RF
[0001.667] I> Size of crypto header is 8192
[0001.671] I> Size of crypto header is 8192
[0001.676] I> Size of crypto header is 8192
[0001.680] I> strt_pg_num(24192) num_of_pgs(16) read_buf(0xa002f0e0)
[0001.688] I> BCH of PSC_RF read from storage
[0001.693] I> BCH address is : 0xa002f0e0
[0001.698] I> PSC_RF header integrity check is success
[0001.703] I> Binary magic in BCH component 0 is PSCR
[0001.709] I> component binary type is 22
[0001.713] I> Size of crypto header is 8192
[0001.717] I> strt_pg_num(24208) num_of_pgs(223) read_buf(0xa00310e0)
[0001.727] I> PSC_RF binary is read from storage
[0001.732] I> PSC_RF binary integrity check is success
[0001.737] I> Binary PSC_RF loaded successfully at 0xa00310e0 (0x1bdd0)
[0001.761] I> Task: Save WP0 payload to SC7 ctx
[0001.765] I> Task: Load MB2rf binary to SC7 ctx
[0001.770] I> Slot: 0
[0001.773] I> Binary[14] block-24576 (partition size: 0x20000)
[0001.779] I> Binary name: MB2_RF
[0001.783] I> Size of crypto header is 8192
[0001.787] I> Size of crypto header is 8192
[0001.792] I> Size of crypto header is 8192
[0001.796] I> strt_pg_num(24576) num_of_pgs(16) read_buf(0xa00d6a88)
[0001.804] I> BCH of MB2_RF read from storage
[0001.809] I> BCH address is : 0xa00d6a88
[0001.814] I> MB2_RF header integrity check is success
[0001.819] I> Binary magic in BCH component 0 is MB2R
[0001.825] I> component binary type is 14
[0001.829] I> Size of crypto header is 8192
[0001.833] I> strt_pg_num(24592) num_of_pgs(224) read_buf(0xa00d8a88)
[0001.843] I> MB2_RF binary is read from storage
[0001.848] I> MB2_RF binary integrity check is success
[0001.853] I> Binary MB2_RF loaded successfully at 0xa00d8a88 (0x1bf80)
[0001.861] I> Task: Save fuse alias data to SC7 ctx
[0001.866] I> Task: Save PMIC data to SC7 ctx
[0001.871] I> Task: Save Pinmux data to SC7 ctx
[0001.876] I> Task: Save Pad Voltage data to SC7 ctx
[0001.881] I> Task: Save controller prod data to SC7 ctx
[0001.887] I> Task: Save prod cfg data to SC7 ctx
[0001.892] I> Task: Save I2C bus freq data to SC7 ctx
[0001.897] I> Task: Save SOCTherm data to SC7 ctx
[0001.902] I> Task: Save FMON data to SC7 ctx
[0001.906] I> Task: Save VMON data to SC7 ctx
[0001.911] I> Task: Save TZDRAM data to SC7 ctx
[0001.916] I> Task: Save GPIO int data to SC7 ctx
[0001.921] I> Task: Save clock data to SC7 ctx
[0001.925] I> Task: Save debug data to SC7 ctx
[0001.930] I> Task: Save MBWT data to SC7 ctx
[0001.939] I> SC7 context save done
[0001.943] I> Task: Load MB2/Applet/FSKP
[0001.947] I> Loading MB2
[0001.950] I> Slot: 0
[0001.952] I> Binary[6] block-8448 (partition size: 0x80000)
[0001.959] I> Binary name: MB2
[0001.962] I> Size of crypto header is 8192
[0001.966] I> Size of crypto header is 8192
[0001.971] I> strt_pg_num(8448) num_of_pgs(16) read_buf(0x8007e000)
[0001.979] I> BCH of MB2 read from storage
[0001.983] I> BCH address is : 0x8007e000
[0001.988] I> MB2 header integrity check is success
[0001.993] I> Binary magic in BCH component 0 is MB2B
[0001.999] I> component binary type is 6
[0002.003] I> Size of crypto header is 8192
[0002.007] I> strt_pg_num(8464) num_of_pgs(841) read_buf(0x80000000)
[0002.019] I> MB2 binary is read from storage
[0002.025] I> MB2 binary integrity check is success
[0002.030] I> Binary MB2 loaded successfully at 0x80000000 (0x691f0)
[0002.038] I> Task: Map CCPLEX SHARED carveout
[0002.043] I> Task: Prepare MB2 params
[0002.048] I> BR-BCT Boot Chain Fields
[0002.052] I> u32_non_gpio_select_boot_chain : 0
[0002.057] I> u32_num_boot_chains : 2
[0002.062] I> bf_bl_gpio_select_boot_chain_1b : 0
[0002.068] I> Task: Dram ecc test
[0002.071] I> Task: Misc NV security settings
[0002.076] I> NVDEC sticky bits programming done
[0002.081] I> Successfully powergated NVDEC
[0002.085] I> Task: Disable/Reload WDT
[0002.089] I> Task: Program misc carveouts
[0002.094] I> Program IPC carveouts
[0002.101] I> SLCG Global override status := 0x0
[0002.106] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-4d0906e6)
I> Emulation:
I> Entry timestamp: 0x0020a7a9
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0x102e800000, size:0x800000]
I> Task: ARI update carveout TZDRAM (0x50002034)
I> Task: Enable hot-plug capability (0x50028064)
I> Task: PSC mailbox init (0x500178b0)
I> Task: Crypto init (0x5000675c)
I> Task: Enable GP-SE clock (0x50002198)
I> Task: DICE Identity init (0x5001af00)
I> DICE is not enabled.
I> Task: Measured Boot init (0x5001b674)
I> Task: OEM SC7 context save init (0x5001a600)
I> Task: I2C register (0x50001ff8)
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout (0x50001fe0)
I> Task: Program CBB PCIE AMAP regions (0x5001ac14)
I> Task: Boot device init (0x50001f28)
I> Task: Partition Manager Init (0x50001f24)
I> Found 57 partitions in QSPI_FLASH (instance 0)
W> Cannot find any partition table for 00000003
PARTITION_MANAGER: Failed to publish partition.
I> Found 15 partitions in SDMMC_USER (instance 3)
I> Task: Load and authenticate registered FWs (0x5001e198)
I> Task: Load AUXP FWs (0x50027c04)
I> Successfully register SPE FW load task with MB2 loader
I> Skipping SCE FW load
I> Successfully register RCE FW load task with MB2 loader
I> Successfully register DCE FW load task with MB2 loader
I> Unpowergating APE
I> Unpowergate done
I> Successfully register APE FW load task with MB2 loader
I> Skipping FSI FW load
I> Successfully register XUSB FW load task with MB2 loader
I> Partition name: A_spe-fw
I> Size of partition: 589824
I> Binary@ device:3/0 block-55040 (partition size: 0x90000), name: A_spe-fw
I> Partition name: A_rce-fw
I> Size of partition: 1048576
I> Binary@ device:3/0 block-56192 (partition size: 0x100000), name: A_rce-fw
I> spe: Authentication Finalize Done
I> Binary spe loaded successfully at 0x102da00000
I> Partition name: A_dce-fw
I> Size of partition: 5242880
I> Binary@ device:3/0 block-44800 (partition size: 0x500000), name: A_dce-fw
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0x102d700000
I> dce : oem authentication of header done
I> dce : meta-blob integrity check is success.
I> dce : will be decompressed at 0x1036000000
I> version 1 Bin 1 BCheckSum 0 content_size 0 Content ChkSum 1 reserved_00 0
I> Reserved10 0 BlockMaxSize 5 Reserved11 0
I> dce : decompressed to 9528912 bytes
I> dce: plain binary integrity check is success
I> Partition name: A_adsp-fw
I> Size of partition: 2097152
I> Binary@ device:3/0 block-58240 (partition size: 0x200000), name: A_adsp-fw
I> dce: Authentication Finalize Done
I> Binary dce loaded successfully at 0x1036000000
I> Partition name: A_xusb-fw
I> Size of partition: 262144
I> Binary@ device:3/0 block-9472 (partition size: 0x40000), name: A_xusb-fw
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0x102e400000
I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0x102db00000
I> Task: Carveout setup (0x500208f8)
I> Program remaining OEM carveouts
I> Task: Enable FSITHERM (0x50017784)
I> Task: Enable FSI VMON (0x50017280)
I> FSI VMON: FSI Vmon re-calibration and fine tuning done
I> Task: Validate FSI Therm readings (0x50017364)
I> FSITHERM max temp = 35
I> FSITHERM min temp = 33
I> Task: Restore XUSB sec (0x50001ef8)
I> Task: Enable FSI SE clock (0x50017d0c)
I> Enable FSI-SE clock and 10ms delay…
I> Task: Initialize SBSA UART CAR (0x500020fc)
I> Task: Initialize CPUBL Params (0x50018cf8)
I> CPUBL-params @ 0x1032000000
I> Task: Ratchet update (0x50029100)
W> Skip ratchet update - OPTIN fuse not set
I> Task: Prepare eeprom data (0x50018ac4)
I> Task: Revoke PKC fuse (0x50001d44)
I> PKC revoke fuse burn not requested
I> Task: FSI padctl context save (0x5001a790)
I> Task: Unpowergate APE (0x50018474)
W> mb2_unpowergate_ape: skip! APE is in unpowergated state
I> Task: OEM firewalls (0x50024d68)
I> OEM firewalls configured
I> Task: Powergate APE (0x500185e8)
I> Powergating APE
I> Powergate done
I> Task: OEM firewall restore saved settings (0x500251bc)
I> Task: Unhalt AUXPs (0x50027e6c)
I> Unhalting SPE…
I> Enabling combined UART
ÿýÿàspe: early_init
ÿ¸ÿàvic initialized
ÿ¸ÿàtsc initialized
ÿ¸ÿàaon lic initialized
ÿ¸ÿàspe: tag is 5243985d1b1eb3f06fac6d36bd7e74ac
ÿ¸ÿàspe: SafeRTOS v8.4
ÿ¸ÿàspe: init
ÿ¸ÿàscheduler initialized
ÿ¸ÿàaon hsp initialized
ÿ¸ÿàtag initialized
ÿ¸ÿàtcu initialized
ÿ¸ÿàbpmp ipc initialized
ÿ¸ÿàspe: late init
ÿ¸ÿàcpu_nic clock initialized
ÿ¸ÿàapb clock initialized
ÿ¸ÿàpm initialized
ÿ¸ÿàbpmp hsp initialized
ÿ¸ÿàtop1 hsp initialized
ÿ¸ÿàccplex ipc initialized
ÿ¸ÿàspe: start scheduler
ÿ¸ÿá
I> Task: Trigger mailbox for PSC-BL1 exit (0x50017930)
I> Sending opcode 0x4d420802 to psc
ÿçINFO: Entering psc_monitor_init!
INFO: GSC22 BOM:0x1048002000 SIZE:0x1000000 CLIENT_ACCESS1:00180000
INFO: PSCFW BUILD VERSION: 8a33b23-73b589c-8a15f76-rel-t234
INFO: mstatus:0xa00000808
INFO: Supervisor entry_point:c108c00
ÿáI> Received ACK from psc
I> TasÿçINFO: MONITOR: user task addr:0x1048022000, blob offset:0x00020000
INFO: MONITOR: populated user images:13
ÿâ
bpmp: socket 0
bpmp: base binary md5 is 925eece486b7c46d91aa449178b5d322
bpmp: combined binary md5 is 6969245516d6bf7e0f2306a6a1fbec5c
bpmp: firmware tag ÿçINFO: mret to Supervisor!
INFO: psc supervisor init.
ÿâis 6969245516d6bf7e0f23-925eece486b
initialized vwdt
ÿçINFO: psc_irq_init…
INFO: enter idle taskÿâinitialized mail_early
initialized fuse
initialized vfrel
initialized hwwdt
initialized adc
fmon_populate_monitors: found 199 monitors
initialized fmon
initialized mc
initialized reset
initialized uphy_early
initialized emc_early
471 clocks registered
initialized clk_mach
initialized clk_cal_early
initialized clk_mach_early_config
initialized io_dpd
initialized soctherm
initialized regime
initialized i2c
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
initialized vrmon
initialized regulator
ÿç.
ÿák: Start secure NOR provision (0x5001aa2c)
I> Task: Load FSI keyblob (0x50017d54)
I> Skipping FSI key blob copy
ÿâinitialized avfs_clk_platform
initialized powergate
ÿáI> Task: Unhalt AUXPs (0x50027e74)
I> SCE unhalt skipped
I> Unhalting RCE
I> RCE unhalt succÿâinitialized dvs
ÿáessÿâinitialized clk_mach_config
initialized pm
suspend progress: 0x0
initialized suspend
initialized strap
initialized mce_dbell
ÿå[ 2.580218] Camera-FW on t234-rce-safe started
TCU early console enabled.
ÿáful
I> DCE unhalt successful
I> APE unhalt skipped
I> FSI unhalt skipped
I> Task: Load CPUBL (0x50018e1c)
I> Task: Load TOS (0x50019580)
I> Partition name: A_cpu-bootloader
I> Size of partition: 3670016
I> Binary@ device:3/0 block-24832 (partition size: 0x380000), name: A_cpu-bootloader
ÿè
ÿâinitialized emc
initialized emc_mrq
initialized clk_cal
initialized uphy_dt
initialized uphy_mrq
HSIO UPHY reset has been de-asserted 0x0
initialized uphy
ÿáI> Partition name: A_secure-os
I> Size of partition:ÿâinitialized pg_late
ÿá 41ÿâinitialized pg_mrq_init
swdtimer_init: reg polling start w period 47 ms
initialized swdtimer
initialized hwwdt_late
initialized bwmgr
initialized thermal_host_trip
initialized thermal_mrq
initialized oc_mrq
initialized reset_mrq
initialized mail_mrq
initialized fmon_mrq
initialized clk_mrq
initialized avfs_mrq
initialized i2c_mrq
initialized tag_mrq
initialized bwmgr_mrq
initialized console_mrq
missing prod DT calibration data for 199 fmons
initialized clk_sync_fmon_post
ÿá94304
I> Binary@ device:3/0 block-32000 (partition size: 0x400000), name: A_secure-os
I> cpubl_params: nsdram: carveout: 1, encryption: 1
I> NSDRAM carveout base: 0x80000000, size: 0xfad270000
ÿâinitialized clk_cal_late
initialized noc_late
initialized cvc
ÿáI> cpubl: Authentication Finalize Done
ÿâinitialized avfs_clk_mach_post
initialized avfs_clk_platform_post
initialized cvc_late
initialized rm
initialized console_late
handling unreferenced clks
enable can1_core
enable can1_host
enable can2_core
enable can2_host
enable pwm3
enable mss_encrypt
enable maud
enable pllg_ref
enable dsi_core
enable aza_2xbit
enable pllc4_muxed
enable xusb_ss
enable xusb_fs
enable xusb_falcon
enable xusb_core_mux
enable dsi_lp
enable sdmmc_legacy_tm
initialized clk_mach_post
initialized pg_pÿå[ 2.753704] Camerÿâost
initialized regulator_post
initialized profile
initialized mrq
initialized patrol_scrubber
initialized cactmon
initialized extras_post
bpmp: init cÿåa-FW on t234-rce-safe ready SHA1=8676d22a (crt 12.966 ms, total boot 187.511 mÿâomplete
ÿås)
ÿáI> Binary cpubl loaded successfully at 0x102ce00000
I> tos: Authentication Finalize Done
I> Binary tos loaded successfully at 0x103fdee000
I> Relocating OP-TEE dtb from: 0x103fefec50 to 0x103c000020, size: 0x2106
I> [0] START: 0x80000000, SIZE: 0xfad270000
I> [1] START: 0x1032000000, SIZE: 0x2000000
I> Setting NS memory ranges to OP-TEE dtb finished.
I> Partition name: A_eks
I> Binary@ device:3/0 block-44288 (partition size: 0x40000), name: A_eks
I> eks: Authentication Finalize Done
I> Binary eks loaded successfully at 0x102e800400
I> EKB detected (length: 0x410) @ VA:0x102e800400
I> Task: Prepare TOS params (0x500194f8)
I> Setting EKB blob info to OPTEE dtb finished.
I> Setting OPTEE arg3: 0x103c000020
I> Task: OEM SC7 context save (0x5001a88c)
I> OEM sc7 context saved
I> Task: Disable MSS perf stats (0x50027f00)
I> Task: Program display sticky bits (0x50027e7c)
I> Task: Storage device deinit (0x500020a0)
I> Task: SMMU external bypass disable (0x50017894)
I> Task: SMMU init (0x500177b0)
I> Task: Program GICv3 registers (0x50027fa0)
I> Task: Audit firewall settings (0x50024fbc)
I> Task: Bootchain failure check (0x500025e8)
I> Current Boot-Chain Slot: 0
I> BR-BCT Boot-Chain is 0, and status is 1. Set UPDATE_BRBCT bit to 0
I> MB2 finished
ÿäNOTICE: BL31: v2.6(release):346877e39
NOTICE: BL31: Built : 12:32:40, Aug 1 2023
I/TC: Physical secure memory base 0x103c040000 size 0x3fc0000
ÿèDCE: FW Boot Done
ÿäI/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 3.21 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Tue Aug 1 19:39:55 UTC 2023 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check Porting guidelines — OP-TEE documentation documentation
I/TC: Primary CPU initializing
I/TC: Test OEM keys are being used. This is insecure for shipping products!
I/TC: Primary CPU switching to normal world boot
ÿá
Jetson UEFI firmware (version 4.1-33958178 built on 2023-08-01T19:34:02+00:00)
ÿäI/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
ÿá
ÿäE/TC:?? 00 get_rpc_alloc_res:645 RPC allocation failed. Non-secure world result: ret=0xffff0000 ret_origin=0
E/LD: init_elf:486 sys_open_ta_bin(bc50d971-d4c9-42c4-82cb-343fb7f37896)
E/TC:?? 00 ldelf_init_with_ldelf:131 ldelf failed with res: 0xffff000c
ÿá
ESC to enter Setup.
F11 to enter Boot Manager Menu.
Enter to continue boot.
** WARNING: Test Key is used. **
L4TLauncher: Attempting Direct Boot
OpenAndReadUntrustedFileToBuffer: Failed to open \boot\dtb\kernel_tegra234-p3701
-0005-p3737-0000.dtb: Not Found
ExtLinuxBoot:sds Failed to Authenticate boot\extlinux\extlinux.conf (Not Found)
L4TLauncher: Unable to boot via extlinux: Not Found
L4TLauncher: Attempting Kernel Boot
EFI stub: Booting Linux Kernel…
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map…
ÿäI/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
I/TC: Secondary CPU 8 initializing
I/TC: Secondary CPU 8 switching to normal world boot
I/TC: Secondary CPU 9 initializing
I/TC: Secondary CPU 9 switching to normal world boot
I/TC: Secondary CPU 10 initializing
I/TC: Secondary CPU 10 switching to normal world boot
I/TC: Secondary CPU 11 initializing
I/TC: Secondary CPU 11 switching to normal world boot
ÿá[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.10.120-tegra (buildbrain@mobile-u64-6422-d7000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Tue Aug 1 12:32:50 PDT 2023
[ 0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[ 0.000000] OF: fdt: - 80000000 , c0000000
[ 0.000000] Machine model: Jetson AGX Orin Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x102531df98 SMBIOS=0xffff0000 SMBIOS 3.0=0x1005290000 MEMATTR=0x1006823018 ESRT=0x1005275898 RNG=0x1006d2f198 MEMRESERVE=0x1006826f18
[ 0.000000] efi: seeding entropy pool
[ 0.000000] esrt: Reserving ESRT space from 0x0000001005275898 to 0x00000010052758d0.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000001008c00000, size 512 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000001033ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000100469afff]
[ 0.000000] node 0: [mem 0x000000100469b000-0x0000001004a6efff]
[ 0.000000] node 0: [mem 0x0000001004a6f000-0x0000001004e1ffff]
[ 0.000000] node 0: [mem 0x0000001004e20000-0x0000001004ebffff]
[ 0.000000] node 0: [mem 0x0000001004ec0000-0x000000100527ffff]
[ 0.000000] node 0: [mem 0x0000001005280000-0x000000100529ffff]
[ 0.000000] node 0: [mem 0x00000010052a0000-0x00000010066dffff]
[ 0.000000] node 0: [mem 0x00000010066e0000-0x000000100677ffff]
[ 0.000000] node 0: [mem 0x0000001006780000-0x00000010067cffff]
[ 0.000000] node 0: [mem 0x00000010067d0000-0x00000010067fffff]
[ 0.000000] node 0: [mem 0x0000001006800000-0x000000100683ffff]
[ 0.000000] node 0: [mem 0x0000001006840000-0x000000100685ffff]
[ 0.000000] node 0: [mem 0x0000001006860000-0x000000100693ffff]
[ 0.000000] node 0: [mem 0x0000001006940000-0x000000100695ffff]
[ 0.000000] node 0: [mem 0x0000001006960000-0x000000100698ffff]
[ 0.000000] node 0: [mem 0x0000001006990000-0x0000001006b6ffff]
[ 0.000000] node 0: [mem 0x0000001006b70000-0x0000001006c3ffff]
[ 0.000000] node 0: [mem 0x0000001006c40000-0x0000001006cdffff]
[ 0.000000] node 0: [mem 0x0000001006ce0000-0x0000001006d1ffff]
[ 0.000000] node 0: [mem 0x0000001006d20000-0x0000001006faffff]
[ 0.000000] node 0: [mem 0x0000001006fb0000-0x00000010070affff]
[ 0.000000] node 0: [mem 0x00000010070b0000-0x000000100714ffff]
[ 0.000000] node 0: [mem 0x0000001007150000-0x000000100719ffff]
[ 0.000000] node 0: [mem 0x00000010071a0000-0x000000100723ffff]
[ 0.000000] node 0: [mem 0x0000001007240000-0x000000100775ffff]
[ 0.000000] node 0: [mem 0x0000001007760000-0x000000100793ffff]
[ 0.000000] node 0: [mem 0x0000001007940000-0x0000001028faffff]
[ 0.000000] node 0: [mem 0x0000001028fb0000-0x0000001028ffffff]
[ 0.000000] node 0: [mem 0x0000001029000000-0x000000102d1fffff]
[ 0.000000] node 0: [mem 0x000000102d210000-0x000000102d21ffff]
[ 0.000000] node 0: [mem 0x0000001032000000-0x0000001033ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000001033ffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 32 pages/cpu s90328 r8192 d32552 u131072
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 16188688
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 console=tty0 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb
[ 0.000000] Dentry cache hash table entries: 8388608 (order: 14, 67108864 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000effe0000-0x00000000fffe0000] (256MB)
[ 0.000000] Memory: 63769928K/65783872K available (18560K kernel code, 3166K rwdata, 7196K rodata, 3968K init, 1416K bss, 1489656K reserved, 524288K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=12.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[ 0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000750] Console: colour dummy device 80x25
[ 0.000930] printk: console [tty0] enabled
[ 0.000977] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.000988] pid_max: default: 32768 minimum: 301
[ 0.001095] LSM: Security Framework initializing
[ 0.001129] Yama: becoming mindful.
[ 0.001152] SELinux: Initializing.
[ 0.001309] Mount-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.001395] Mountpoint-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.003731] rcu: Hierarchical SRCU implementation.
[ 0.003849] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.004626] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t23x/concord/kernel-dts/tegra234-p3701-0005-p3737-0000.dts
[ 0.004637] DTB Build time: Aug 1 2023 12:44:17
[ 0.006295] Tegra Revision: A01 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.006626] Remapping and enabling EFI services.
[ 0.007209] smp: Bringing up secondary CPUs …
[ 0.035964] Detected PIPT I-cache on CPU1
[ 0.036006] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.036044] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.064715] Detected PIPT I-cache on CPU2
[ 0.064725] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.064739] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.093368] Detected PIPT I-cache on CPU3
[ 0.093377] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.093393] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.124076] Detected PIPT I-cache on CPU4
[ 0.124097] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[ 0.124124] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[ 0.152809] Detected PIPT I-cache on CPU5
[ 0.152818] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[ 0.152835] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[ 0.181477] Detected PIPT I-cache on CPU6
[ 0.181487] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[ 0.181501] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.210150] Detected PIPT I-cache on CPU7
[ 0.210161] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[ 0.210175] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.240871] Detected PIPT I-cache on CPU8
[ 0.240893] GICv3: CPU8: found redistributor 20000 region 0:0x000000000f540000
[ 0.240921] CPU8: Booted secondary processor 0x0000020000 [0x410fd421]
[ 0.269595] Detected PIPT I-cache on CPU9
[ 0.269605] GICv3: CPU9: found redistributor 20100 region 0:0x000000000f560000
[ 0.269618] CPU9: Booted secondary processor 0x0000020100 [0x410fd421]
[ 0.298886] Detected PIPT I-cache on CPU10
[ 0.298898] GICv3: CPU10: found redistributor 20200 region 0:0x000000000f580000
[ 0.298914] CPU10: Booted secondary processor 0x0000020200 [0x410fd421]
[ 0.328162] Detected PIPT I-cache on CPU11
[ 0.328174] GICv3: CPU11: found redistributor 20300 region 0:0x000000000f5a0000
[ 0.328189] CPU11: Booted secondary processor 0x0000020300 [0x410fd421]
[ 0.328247] smp: Brought up 1 node, 12 CPUs
[ 0.328312] SMP: Total of 12 processors activated.
[ 0.328317] CPU features: detected: Privileged Access Never
[ 0.328319] CPU features: detected: LSE atomic instructions
[ 0.328322] CPU features: detected: User Access Override
[ 0.328325] CPU features: detected: 32-bit EL0 Support
[ 0.328328] CPU features: detected: Common not Private translations
[ 0.328331] CPU features: detected: RAS Extension Support
[ 0.328334] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.328337] CPU features: detected: CRC32 instructions
[ 0.328340] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.347660] spectre-bhb mitigation disabled by command line option
[ 0.347662] spectre-bhb mitigation disabled by command line option
[ 0.347664] spectre-bhb mitigation disabled by command line option
[ 0.347666] spectre-bhb mitigation disabled by command line option
[ 0.347667] spectre-bhb mitigation disabled by command line option
[ 0.366419] CPU: All CPU(s) started at EL2
[ 0.369847] devtmpfs: initialized
[ 0.391666] Registered cp15_barrier emulation handler
[ 0.391679] Registered setend emulation handler
[ 0.391685] KASLR enabled
[ 0.391803] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.391820] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[ 0.394985] pinctrl core: initialized pinctrl subsystem
[ 0.395457] SMBIOS 3.0.0 present.
[ 0.395466] DMI: Unknown Jetson AGX Orin Developer Kit/Jetson AGX Orin Developer Kit, BIOS 4.1-33958178 08/01/2023
[ 0.395799] NET: Registered protocol family 16
[ 0.396715] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.396918] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.397116] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.397145] audit: initializing netlink subsys (disabled)
[ 0.397245] audit: type=2000 audit(0.396:1): state=initialized audit_enabled=0 res=1
[ 0.397435] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.397437] thermal_sys: Registered thermal governor ‘power_allocator’
[ 0.397442] thermal_sys: Registered thermal governor ‘pid_thermal_gov’
[ 0.400248] cpuidle: using governor menu
[ 0.400376] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.400496] ASID allocator initialised with 32768 entries
[ 0.400598] Serial: AMBA PL011 UART driver
[ 0.402650] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[ 0.402677] Tegra reboot handler registered.
[ 0.422374] mc: mapped MMIO address: 0xffff8000111f0000 → 0x2c10000
[ 0.422394] mc: mapped MMIO address: 0xffff800011210000 → 0x2c20000
[ 0.422401] mc: mapped MMIO address: 0xffff800011230000 → 0x2c30000
[ 0.422408] mc: mapped MMIO address: 0xffff800011250000 → 0x2c40000
[ 0.422415] mc: mapped MMIO address: 0xffff800011270000 → 0x2c50000
[ 0.422422] mc: mapped MMIO address: 0xffff800011290000 → 0x2b80000
[ 0.422428] mc: mapped MMIO address: 0xffff8000112b0000 → 0x2b90000
[ 0.422435] mc: mapped MMIO address: 0xffff8000112d0000 → 0x2ba0000
[ 0.422442] mc: mapped MMIO address: 0xffff8000112f0000 → 0x2bb0000
[ 0.422448] mc: mapped MMIO address: 0xffff800011310000 → 0x1700000
[ 0.422455] mc: mapped MMIO address: 0xffff800011330000 → 0x1710000
[ 0.422461] mc: mapped MMIO address: 0xffff800011350000 → 0x1720000
[ 0.422468] mc: mapped MMIO address: 0xffff800011370000 → 0x1730000
[ 0.422474] mc: mapped MMIO address: 0xffff800011390000 → 0x1740000
[ 0.422480] mc: mapped MMIO address: 0xffff8000113b0000 → 0x1750000
[ 0.422486] mc: mapped MMIO address: 0xffff8000113d0000 → 0x1760000
[ 0.422494] mc: mapped MMIO address: 0xffff8000113f0000 → 0x1770000
[ 0.422505] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.422548] mc-err: mcerr ops are set to t23x
[ 0.423264] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 80, base_baud = 0) is a SBSA
[ 1.681785] printk: console [ttyAMA0] enabled
[ 1.690516] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 1.697230] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 1.703931] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 1.710630] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 1.719550] ACPI: Interpreter disabled.
[ 1.724630] vdd-av1v1-hub: supplied by vdd-5v-sys
[ 1.729491] vbusA-cvb: supplied by vdd-5v-sys
[ 1.733975] vbusB-cvb: supplied by vdd-5v-sys
[ 1.738460] vdd-usbc1-vbus: supplied by vdd-5v-sys
[ 1.743375] vdd-usbc2-vbus: supplied by vdd-5v-sys
[ 1.748756] iommu: Default domain type: Translated
[ 1.753683] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.759980] SCSI subsystem initialized
[ 1.763810] usbcore: registered new interface driver usbfs
[ 1.769305] usbcore: registered new interface driver hub
[ 1.774625] usbcore: registered new device driver usb
[ 1.779873] mc: Linux media interface: v0.10
[ 1.784148] videodev: Linux video capture interface: v2.00
[ 1.789782] pps_core: LinuxPPS API ver. 1 registered
[ 1.794745] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 1.803882] PTP clock support registered
[ 1.808028] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.815189] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[ 1.822835] Registered efivars operations
[ 1.826987] FPGA manager framework
[ 1.830434] Advanced Linux Sound Architecture Driver Initialized.
[ 1.836799] Bluetooth: Core ver 2.22
[ 1.840382] NET: Registered protocol family 31
[ 1.844823] Bluetooth: HCI device and connection manager initialized
[ 1.851180] Bluetooth: HCI socket layer initialized
[ 1.856058] Bluetooth: L2CAP socket layer initialized
[ 1.861114] Bluetooth: SCO socket layer initialized
[ 1.866479] camchar: rtcpu character device driver loaded
[ 1.872111] clocksource: Switched to clocksource arch_sys_counter
[ 2.034733] VFS: Disk quotas dquot_6.6.0
[ 2.038708] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 2.045888] pnp: PnP ACPI: disabled
[ 2.051372] la/ptsa driver initialized.
[ 2.055274] NET: Registered protocol family 2
[ 2.059844] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 2.069598] tcp_listen_portaddr_hash hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 2.078369] TCP established hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 2.086942] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 2.094845] TCP: Hash tables configured (established 524288 bind 65536)
[ 2.101577] UDP hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 2.108642] UDP-Lite hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 2.116248] NET: Registered protocol family 1
[ 2.120905] RPC: Registered named UNIX socket transport module.
[ 2.126836] RPC: Registered udp transport module.
[ 2.131538] RPC: Registered tcp transport module.
[ 2.136239] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.142688] PCI: CLS 0 bytes, default 64
[ 2.146752] Trying to unpack rootfs image as initramfs…
[ 2.281440] Freeing initrd memory: 9552K
[ 2.287754] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 2.295705] kvm [1]: IPA Size Limit: 48 bits
[ 2.299996] kvm [1]: GICv3: no GICV resource entry
[ 2.304789] kvm [1]: disabling GICv2 emulation
[ 2.309251] kvm [1]: GIC system register CPU interface enabled
[ 2.315193] kvm [1]: vgic interrupt IRQ9
[ 2.319273] kvm [1]: VHE mode initialized successfully
[ 2.325173] Initialise system trusted keyrings
[ 2.329712] workingset: timestamp_bits=46 max_order=24 bucket_order=0
[ 2.338615] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.344780] NFS: Registering the id_resolver key type
[ 2.349847] Key type id_resolver registered
[ 2.354027] Key type id_legacy registered
[ 2.358079] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 2.364788] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 2.372197] ntfs: driver 2.1.32 [Flags: R/W].
[ 2.388331] NET: Registered protocol family 38
[ 2.392779] Key type asymmetric registered
[ 2.396877] Asymmetric key parser ‘x509’ registered
[ 2.401777] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 239)
[ 2.409228] io scheduler mq-deadline registered
[ 2.413762] io scheduler kyber registered
[ 2.422165] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 2.427767] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 2.433359] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 2.438948] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 2.447155] tegra_dc_assign_hw_data: no matching compatible node
[ 2.453173] tegradccommon module_init failed
[ 2.457443] tegradc module_init failed
[ 2.461463] EINJ: ACPI disabled.
[ 2.466349] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 2.473229] tegra-pmc: ### PMC reset source: BPMPWDT
[ 2.478194] tegra-pmc: ### PMC reset level: L1
[ 2.482635] tegra-pmc: ### PMC reset status reg: 0xd
[ 2.489036] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 4.154183] printk: console [ttyTCU0] enabled
[ 4.163357] arm-smmu 12000000.iommu: probing hardware configuration…
[ 4.171372] arm-smmu 12000000.iommu: SMMUv2 with:
[ 4.176205] arm-smmu 12000000.iommu: stage 1 translation
[ 4.181755] arm-smmu 12000000.iommu: stage 2 translation
[ 4.187295] arm-smmu 12000000.iommu: nested translation
[ 4.192758] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 4.200172] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 4.209266] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 4.215958] arm-smmu 12000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 4.222645] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 4.230157] arm-smmu 10000000.iommu: probing hardware configuration…
[ 4.236848] arm-smmu 10000000.iommu: SMMUv2 with:
[ 4.241665] arm-smmu 10000000.iommu: stage 1 translation
[ 4.247194] arm-smmu 10000000.iommu: stage 2 translation
[ 4.252721] arm-smmu 10000000.iommu: nested translation
[ 4.258162] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 4.265566] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 4.274605] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 4.281297] arm-smmu 10000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 4.287982] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 4.295103] arm-smmu 8000000.iommu: probing hardware configuration…
[ 4.301713] arm-smmu 8000000.iommu: SMMUv2 with:
[ 4.306445] arm-smmu 8000000.iommu: stage 1 translation
[ 4.311885] arm-smmu 8000000.iommu: stage 2 translation
[ 4.317331] arm-smmu 8000000.iommu: nested translation
[ 4.322689] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 4.330005] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 4.338928] arm-smmu 8000000.iommu: Supported page sizes: 0x00001000
[ 4.345533] arm-smmu 8000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 4.352136] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 4.359478] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 4.370044] tegra_profiler: version: 1.151, samples/io: 51/30
[ 4.376044] tegra_profiler: auth: init
[ 4.380232] nvsciipc: loaded module
[ 4.385444] tun: Universal TUN/TAP device driver, 1.6
[ 4.391111] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 4.398527] hns3: Copyright (c) 2017 Huawei Corporation.
[ 4.404036] e1000e: Intel(R) PRO/1000 Network Driver
[ 4.409131] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.415218] igb: Intel(R) Gigabit Ethernet Network Driver
[ 4.420756] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.426642] PPP generic driver version 2.4.2
[ 4.431062] PPP BSD Compression module registered
[ 4.435899] PPP Deflate Compression module registered
[ 4.441100] PPP MPPE Compression module registered
[ 4.446047] usbcore: registered new interface driver r8152
[ 4.451684] usbcore: registered new interface driver asix
[ 4.457225] usbcore: registered new interface driver ax88179_178a
[ 4.463500] usbcore: registered new interface driver cdc_ether
[ 4.469497] usbcore: registered new interface driver net1080
[ 4.475325] usbcore: registered new interface driver cdc_subset
[ 4.481410] usbcore: registered new interface driver zaurus
[ 4.487139] usbcore: registered new interface driver cdc_ncm
[ 4.492955] usbcore: registered new interface driver aqc111
[ 4.498802] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 4.505165] ohci-pci: OHCI PCI platform driver
[ 4.509736] ohci-platform: OHCI generic platform driver
[ 4.515412] tegra-xusb 3610000.xhci: Adding to iommu group 0
[ 4.521731] usbcore: registered new interface driver uas
[ 4.527222] usbcore: registered new interface driver usb-storage
[ 4.533547] tegra-xudc 3550000.xudc: Adding to iommu group 1
[ 4.539687] mousedev: PS/2 mouse device common for all mice
[ 4.545425] usbcore: registered new interface driver xpad
[ 4.552837] tegra_rtc c2a0000.rtc: registered as rtc1
[ 4.558298] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:28 UTC (28)
[ 4.566529] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.572946] i2c /dev entries driver
[ 4.576595] tegra-i2c 3160000.i2c: Adding to iommu group 2
[ 4.582447] tegra-i2c c240000.i2c: Adding to iommu group 2
[ 4.588184] tegra-i2c 3180000.i2c: Adding to iommu group 2
[ 4.593859] tegra-i2c 3190000.i2c: Adding to iommu group 2
[ 4.599536] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[ 4.605212] tegra-i2c c250000.i2c: Adding to iommu group 2
[ 4.610891] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[ 4.616631] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[ 4.624676] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 4.633246] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 4.642757] device-mapper: uevent: version 1.0.3
[ 4.647609] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 4.657690] sdhci: Secure Digital Host Controller Interface driver
[ 4.664044] sdhci: Copyright(c) Pierre Ossman
[ 4.668507] Synopsys Designware Multimedia Card Interface Driver
[ 4.674742] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.680953] sdhci-tegra 3460000.sdhci: Adding to iommu group 3
[ 4.681113] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[ 4.681339] sdhci-tegra 3400000.sdhci: Adding to iommu group 4
[ 4.700558] tegra-bpmp bpmp: firmware: 6969245516d6bf7e0f23-925eece486b
[ 4.708711] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[ 4.714099] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x82
[ 4.725677] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[ 4.731621] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
ÿâdebugfs initialized
ÿá[ 5.967240] hid: raw HID events driver (C) Jiri Kosina
[ 5.973033] usbcore: registered new interface driver usbhid
[ 5.978776] usbhid: USB HID core driver
[ 5.983513] tegra-dce d800000.dce: Adding to iommu group 5
[ 5.991029] dce: dce_ipc_channel_init:319 Invalid Channel State [0x0] for ch_type [2]
[ 5.999608] tegra234-aon c000000.aon: Adding to iommu group 6
[ 6.006100] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x5]
[ 6.013119] c000000.aon:hsp: probed
[ 6.015293] dce: dce_admin_send_cmd_ver:424 version : [0x2] err : [0x0]
[ 6.025661] tegra234-aon c000000.aon: init done
[ 6.026017] tegra23x-psc e860000.psc: Adding to iommu group 7
[ 6.030523] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [1] …
[ 6.036686] tegra23x-psc e860000.psc: ext_cfg base:(ptrval)
[ 6.044682] dce: dce_admin_setup_clients_ipc:529 Get queue info failed for [2]
[ 6.044889] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [3] …
[ 6.051148] tegra23x-psc e860000.psc: init done
[ 6.058923] dce: dce_start_boot_flow:173 DCE_BOOT_DONE
[ 6.067277] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 8
[ 6.084418] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 6.096476] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 6.105692] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 6.117641] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 6.129513] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 6.141275] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[ 6.153867] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[ 6.166718] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 6.179504] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (119)
[ 6.186331] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 6.198985] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=8676d22a01443bdbc66581b7dde3b6d6828cc925
[ 6.212485] t19x_cache tegra-cache: probed
[ 6.216923] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[ 6.239278] optee: probing for conduit method.
ÿá[ 6.243884] optee: revision 3.21 (d8269f24)
[ 6.302701] optee: dynamic shared memory is enabled
[ 6.312155] optee: initialized driver
[ 6.331748] nvpmodel: initialized successfully
[ 6.336434] tegra_hv: get_hvd: not initialized yet
[ 6.341376] user_ivc_mempool: hypervisor not present
[ 6.347469] usbcore: registered new interface driver snd-usb-audio
[ 6.354914] u32 classifier
[ 6.357720] input device check on
[ 6.361493] Actions configured
[ 6.365133] Initializing XFRM netlink socket
[ 6.369954] NET: Registered protocol family 10
[ 6.376433] Segment Routing with IPv6
[ 6.380274] NET: Registered protocol family 17
[ 6.384867] NET: Registered protocol family 15
[ 6.389491] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 6.403571] Bluetooth: RFCOMM socket layer initialized
[ 6.408965] Bluetooth: RFCOMM ver 1.11
[ 6.412848] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 6.418950] Bluetooth: HIDP socket layer initialized
[ 6.425353] 9pnet: Installing 9P2000 support
[ 6.429837] Key type dns_resolver registered
[ 6.435198] registered taskstats version 1
[ 6.439448] Loading compiled-in X.509 certificates
[ 6.456705] Loaded X.509 cert ‘Build time autogenerated kernel key: d94b64a20d69a5a32183bad4f211c4cae67041a9’
[ 6.467476] tegra194-pcie 14100000.pcie: Adding to iommu group 9
[ 6.480482] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 6.488708] tegra194-pcie 14160000.pcie: Adding to iommu group 10
[ 6.501215] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 6.508083] tegra194-pcie 141a0000.pcie: Adding to iommu group 11
[ 6.520227] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 6.552287] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 12
[ 6.563730] host1x 13e40000.host1x: Adding to iommu group 13
[ 6.596467] host1x 13e40000.host1x: initialized
[ 6.601525] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 14
[ 6.609702] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[ 6.621779] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 15
[ 6.629892] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[ 6.641920] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 16
[ 6.650017] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[ 6.662020] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 17
[ 6.670100] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[ 6.682096] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 18
[ 6.690218] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[ 6.702233] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 19
[ 6.710327] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[ 6.722316] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 20
[ 6.730454] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[ 6.742468] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 21
[ 6.750540] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[ 6.762551] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 22
[ 6.770663] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[ 6.782658] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 23
[ 6.790738] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[ 6.802735] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 24
[ 6.810814] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[ 6.822825] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 25
[ 6.830890] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[ 6.842902] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 26
[ 6.850995] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[ 6.863009] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 27
[ 6.871140] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[ 6.883159] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 28
[ 6.891261] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[ 6.903257] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 29
[ 6.911347] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[ 6.923362] falcon 15340000.vic: Adding to iommu group 30
[ 6.934299] falcon 15340000.vic: initialized
[ 6.939019] falcon 15380000.nvjpg: Adding to iommu group 31
[ 6.947976] falcon 15380000.nvjpg: initialized
[ 6.952692] falcon 15540000.nvjpg1: Adding to iommu group 32
[ 6.961690] falcon 15540000.nvjpg1: initialized
[ 6.966502] falcon 154c0000.nvenc: Adding to iommu group 33
[ 6.977250] falcon 154c0000.nvenc: initialized
[ 6.981976] falcon 15a50000.ofa: Adding to iommu group 34
[ 6.990694] falcon 15a50000.ofa: initialized
[ 6.995276] nvdec 15480000.nvdec: Adding to iommu group 35
[ 7.007339] nvdec 15480000.nvdec: initialized
[ 7.011957] tsec 15500000.tsec: Adding to iommu group 36
[ 7.022403] tsec 15500000.tsec: initialized
[ 7.030183] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 7.047786] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 7.067301] gpio-394 (camera-control-output-low): hogged as output/low
[ 7.074063] gpio-397 (camera-control-output-low): hogged as output/low
[ 7.080818] gpio-487 (camera-control-output-low): hogged as output/low
[ 7.087569] gpio-486 (camera-control-output-low): hogged as output/low
[ 7.095255] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[ 7.102609] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[ 7.109604] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 7.116178] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 7.122670] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 7.129076] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 7.137479] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 7.146034] tegra194-isp5 14800000.isp: Adding to iommu group 37
[ 7.155189] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 7.164775] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[ 7.171387] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 38
[ 7.179607] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 39
[ 7.187667] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
[ 7.197570] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[ 7.204390] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
[ 7.214289] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[ 7.221093] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[ 7.230984] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[ 7.237793] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 40
[ 7.246557] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18, iommu=smmu.0x0000000008000000)
[ 7.257920] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 41
[ 7.266655] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19, iommu=smmu.0x0000000008000000)
[ 7.278029] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 42
[ 7.286787] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20, iommu=smmu.0x0000000008000000)
[ 7.298146] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 43
[ 7.306853] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21, iommu=smmu.0x0000000008000000)
[ 7.318212] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to iommu group 44
[ 7.326916] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized (streamid=22, iommu=smmu.0x0000000008000000)
[ 7.338268] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to iommu group 45
[ 7.346978] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized (streamid=23, iommu=smmu.0x0000000008000000)
[ 7.358342] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to iommu group 46
[ 7.367069] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized (streamid=24, iommu=smmu.0x0000000008000000)
[ 7.378440] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to iommu group 47
[ 7.387157] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized (streamid=25, iommu=smmu.0x0000000008000000)
[ 7.398516] pva 16000000.pva0: Adding to iommu group 48
[ 7.423746] pva 16000000.pva0: initialized
[ 7.436344] nvdla 15880000.nvdla0: Adding to iommu group 49
[ 7.451733] nvdla 15880000.nvdla0: initialized
[ 7.458054] nvdla 158c0000.nvdla1: Adding to iommu group 50
[ 7.472648] nvdla 158c0000.nvdla1: initialized
[ 7.478939] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 2
[ 7.486021] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[ 7.493529] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 7.500149] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 7.506890] serial-tegra 3100000.serial: Adding to iommu group 2
[ 7.513512] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 26, base_baud = 0) is a TEGRA_UART
[ 7.523236] serial-tegra 3110000.serial: Adding to iommu group 2
[ 7.529829] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 78, base_baud = 0) is a TEGRA_UART
[ 7.539417] serial-tegra 3130000.serial: Adding to iommu group 2
[ 7.546012] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 79, base_baud = 0) is a TEGRA_UART
[ 7.572149] tegra-xusb 3610000.xhci: Firmware timestamp: 2023-02-10 03:48:10 UTC, Version: 80.05 release
[ 7.581906] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 7.587478] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 7.596107] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[ 7.605724] tegra-xusb 3610000.xhci: irq 236, io mem 0x03610000
[ 7.612200] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 7.620697] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.628128] usb usb1: Product: xHCI Host Controller
[ 7.633144] usb usb1: Manufacturer: Linux 5.10.120-tegra xhci-hcd
[ 7.639410] usb usb1: SerialNumber: 3610000.xhci
[ 7.644850] hub 1-0:1.0: USB hub found
[ 7.648737] hub 1-0:1.0: 4 ports detected
[ 7.653123] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 7.658678] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 7.666478] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 7.673983] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 7.682494] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.689922] usb usb2: Product: xHCI Host Controller
[ 7.694934] usb usb2: Manufacturer: Linux 5.10.120-tegra xhci-hcd
[ 7.701195] usb usb2: SerialNumber: 3610000.xhci
[ 7.706422] hub 2-0:1.0: USB hub found
[ 7.710299] hub 2-0:1.0: 4 ports detected
[ 7.738560] tegra23x-oc-event soctherm-oc-event: Finished tegra23x overcurrent event probing
[ 7.763373] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1964000 KHz, changing to: 2035200 KHz
[ 7.775987] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2009000 KHz, changing to: 2035200 KHz
[ 7.789177] cpufreq: cpufreq_online: CPU8: Running at unlisted initial frequency: 2009000 KHz, changing to: 2035200 KHz
[ 7.801110] tegra194-cpufreq e000000.ccplex: probed with ICC, cl:3
[ 7.808831] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 7.810845] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 7.816624] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[ 7.819936] mmc0: CQHCI version 5.10
[ 7.829180] irq: IRQ303: trimming hierarchy from :interrupt-controller@f400000-1
[ 7.831055] tegra194-pcie 14100000.pcie: IO 0x0030100000…0x00301fffff → 0x0030100000
[ 7.838696] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 303
[ 7.847346] tegra194-pcie 14100000.pcie: MEM 0x20a8000000…0x20afffffff → 0x0040000000
[ 7.847554] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[ 7.870433] tegra194-pcie 14100000.pcie: MEM 0x2080000000…0x20a7ffffff → 0x2080000000
[ 7.920107] usb 1-3: new full-speed USB device number 2 using tegra-xusb
[ 7.927657] mmc0: Command Queue Engine enabled
[ 7.932265] mmc0: periodic cache flush enabled
[ 7.936840] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 7.943737] mmcblk0: mmc0:0001 DG4064 59.2 GiB
[ 7.948606] mmcblk0rpmb: mmc0:0001 DG4064 partition 3 4.00 MiB, chardev (510:0)
[ 7.966425] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 7.984106] tegra194-pcie 14100000.pcie: Link up
[ 7.990840] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 7.997657] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 8.003293] pci_bus 0001:00: root bus resource [io 0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[ 8.013130] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[ 8.023958] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[ 8.031887] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 8.038225] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 8.048720] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[ 8.055054] pci 0001:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 8.060985] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[ 8.069394] pci 0001:01:00.0: supports D1 D2
[ 8.073791] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 8.084232] usb 1-3: New USB device found, idVendor=13d3, idProduct=3549, bcdDevice= 0.00
[ 8.085304] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[ 8.092660] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 8.100090] pci 0001:00:00.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 8.107435] usb 1-3: Product: Bluetooth Radio
[ 8.113785] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff 64bit]
[ 8.118259] usb 1-3: Manufacturer: Realtek
[ 8.118260] usb 1-3: SerialNumber: 00e04c000001
[ 8.135113] pci 0001:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 8.141420] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 8.146789] pci 0001:00:00.0: bridge window [io 0x1000-0x1fff]
[ 8.153057] pci 0001:00:00.0: bridge window [mem 0x20a8000000-0x20a80fffff]
[ 8.160419] pci 0001:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 8.169163] pci 0001:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 8.178141] pcieport 0001:00:00.0: Adding to iommu group 9
[ 8.184050] pcieport 0001:00:00.0: PME: Signaling with IRQ 64
[ 8.190484] pcieport 0001:00:00.0: AER: enabled with IRQ 64
[ 8.197032] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 8.204744] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[ 8.208967] usb 2-3: new SuperSpeedPlus Gen 2 USB device number 2 using tegra-xusb
[ 8.211919] tegra194-pcie 14160000.pcie: IO 0x0036100000…0x00361fffff → 0x0036100000
[ 8.228392] tegra194-pcie 14160000.pcie: MEM 0x2428000000…0x242fffffff → 0x0040000000
[ 8.237071] tegra194-pcie 14160000.pcie: MEM 0x2140000000…0x2427ffffff → 0x2140000000
[ 8.254443] usb 2-3: New USB device found, idVendor=0bda, idProduct=0420, bcdDevice= 1.40
[ 8.262869] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.270214] usb 2-3: Product: 4-Port USB 3.0 Hub
[ 8.274966] usb 2-3: Manufacturer: Generic
[ 8.289722] hub 2-3:1.0: USB hub found
[ 8.295762] hub 2-3:1.0: 4 ports detected
[ 8.372111] usb 1-4: new high-speed USB device number 3 using tegra-xusb
[ 8.550858] usb 1-4: New USB device found, idVendor=0bda, idProduct=5420, bcdDevice= 1.40
[ 8.559277] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.566627] usb 1-4: Product: 4-Port USB 2.0 Hub
[ 8.571379] usb 1-4: Manufacturer: Generic
[ 8.577438] hub 1-4:1.0: USB hub found
[ 8.582603] hub 1-4:1.0: 4 ports detected
[ 9.292277] usb 1-4.4: new full-speed USB device number 4 using tegra-xusb
[ 9.353675] tegra194-pcie 14160000.pcie: Phy link never came up
[ 9.359839] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 9.366653] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 9.372297] pci_bus 0004:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[ 9.382395] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[ 9.393222] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[ 9.401149] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 9.407500] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 9.411318] usb 1-4.4: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.11
[ 9.421589] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 9.421728] usb 1-4.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.427105] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 9.434606] usb 1-4.4: Product: USB Receiver
[ 9.443564] pcieport 0004:00:00.0: Adding to iommu group 10
[ 9.447669] usb 1-4.4: Manufacturer: Logitech
[ 9.453779] input: Logitech USB Receiver as /devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4:1.0/0003:046D:C52B.0001/input/input0
[ 9.458134] pcieport 0004:00:00.0: PME: Signaling with IRQ 66
[ 9.476177] pcieport 0004:00:00.0: AER: enabled with IRQ 66
[ 9.482133] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[ 9.488229] pci 0004:00:00.0: Removing from iommu group 10
[ 9.493879] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[ 9.501248] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 9.507804] vdd-3v3-pcie: supplied by vdd-3v3-sys
[ 9.512830] avdd-cam-2v8: supplied by vdd-3v3-sys
[ 9.517755] vdd-dp: supplied by vdd-3v3-sys
[ 9.522214] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 9.527299] dsi-vdd-1v8-bl-en: supplied by vdd-1v8-sys
[ 9.532341] hid-generic 0003:046D:C52B.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-3610000.xhci-4.4/input0
[ 9.546762] tegra194-isp5 14800000.isp: initialized
[ 9.549144] input: Logitech USB Receiver Mouse as /devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4:1.1/0003:046D:C52B.0002/input/input1
[ 9.564643] input: Logitech USB Receiver Consumer Control as /devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4:1.1/0003:046D:C52B.0002/input/input2
[ 9.578970] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[ 9.585402] (NULL device *): fops function table already registered
[ 9.592721] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[ 9.599581] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 9.604554] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 9.616416] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 303
[ 9.636331] input: Logitech USB Receiver System Control as /devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4:1.1/0003:046D:C52B.0002/input/input3
[ 9.650179] hid-generic 0003:046D:C52B.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-3610000.xhci-4.4/input1
[ 9.666731] hid-generic 0003:046D:C52B.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-3610000.xhci-4.4/input2
[ 9.717931] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[ 9.725111] tegra194-pcie 141a0000.pcie: IO 0x003a100000…0x003a1fffff → 0x003a100000
[ 9.733801] tegra194-pcie 141a0000.pcie: MEM 0x2b28000000…0x2b2fffffff → 0x0040000000
[ 9.742482] tegra194-pcie 141a0000.pcie: MEM 0x2740000000…0x2b27ffffff → 0x2740000000
[ 10.674401] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[ 10.861834] tegra194-pcie 141a0000.pcie: Phy link never came up
[ 10.867994] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[ 10.874811] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 10.880441] pci_bus 0005:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x3a100000-0x3a1fffff])
[ 10.890556] pci_bus 0005:00: root bus resource [mem 0x2b28000000-0x2b2fffffff] (bus address [0x40000000-0x47ffffff])
[ 10.901392] pci_bus 0005:00: root bus resource [mem 0x2740000000-0x2b27ffffff pref]
[ 10.909308] pci 0005:00:00.0: [10de:229a] type 01 class 0x060400
[ 10.915653] pci 0005:00:00.0: PME# supported from D0 D3hot
[ 10.929923] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 10.935314] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 10.944258] pcieport 0005:00:00.0: Adding to iommu group 11
[ 10.950234] pcieport 0005:00:00.0: PME: Signaling with IRQ 68
[ 10.956412] pcieport 0005:00:00.0: AER: enabled with IRQ 68
[ 10.962363] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 10.968456] pci 0005:00:00.0: Removing from iommu group 11
[ 10.968685] random: crng init done
[ 10.974108] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[ 10.984957] nvethernet 6810000.ethernet: Adding to iommu group 51
[ 10.991530] nvethernet 6810000.ethernet: failed to read skip mac reset flag, default 0
[ 10.999685] nvethernet 6810000.ethernet: failed to read MDIO address
[ 11.006234] nvethernet 6810000.ethernet: setting to default DMA bit mask
[ 11.013143] nvethernet 6810000.ethernet: failed to read UPHY GBE mode- default to 10G
[ 11.412159] nvethernet 6810000.ethernet: Ethernet MAC address: 3c:6d:66:0c:4b:3b
[ 11.420153] nvethernet 6810000.ethernet: macsec param in DT is missing or disabled
[ 11.427946] nvethernet 6810000.ethernet: Macsec not supported/Not enabled in DT
[ 11.437460] nvethernet 6810000.ethernet: eth0 (HW ver: 31) created with 10 DMA channels
[ 11.446214] irq: IRQ305: trimming hierarchy from :pmc@c360000
[ 11.452189] irq: IRQ306: trimming hierarchy from :interrupt-controller@f400000-1
[ 11.459860] irq: IRQ307: trimming hierarchy from :pmc@c360000
[ 11.465817] input: gpio-keys as /devices/platform/gpio-keys/input/input5
[ 11.473120] tegra-se-nvhost 15810000.se: Adding to iommu group 52
[ 11.479725] tegra-se-nvhost 15810000.se: initialized
[ 11.495723] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 11.502071] tegra-se-nvhost 15820000.se: Adding to iommu group 53
[ 11.508591] tegra-se-nvhost 15820000.se: initialized
[ 11.514668] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 11.521013] tegra-se-nvhost 15840000.se: Adding to iommu group 54
[ 11.527520] tegra-se-nvhost 15840000.se: initialized
[ 11.533659] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 11.540512] tegra_actmon d230000.actmon: in actmon_register()…
[ 11.546876] tegra_actmon d230000.actmon: bwmgr_disable = 1
[ 11.552902] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 11.561275] hvc_sysfs: hypervisor is not present
ÿâWARNING: clock_disable: clk_power_ungate on gated domain 35 for gpusysclk
WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc1clk
WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc0clk
ÿá[ 11.693173] ALSA device list:
[ 11.696236] No soundcards found.
[ 11.700350] Freeing unused kernel memory: 3968K
[ 11.705044] Run /init as init process
[ 11.720376] Root device found: mmcblk0p1
[ 11.728586] Found dev node: /dev/mmcblk0p1
[ 11.759948] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 11.771989] Rootfs mounted over mmcblk0p1
[ 11.790500] Switching from initrd to actual rootfs
[ 11.915601] systemd[1]: System time before build time, advancing clock.
[ 11.962678] systemd[1]: systemd 245.4-4ubuntu3.21 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 11.986311] systemd[1]: Detected architecture arm64.
[ 12.020990] systemd[1]: Set hostname to .
[ 12.202743] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 12.215811] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 12.225387] systemd[1]: Created slice system-modprobe.slice.
[ 12.231584] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 12.238292] systemd[1]: Created slice User and Session Slice.
[ 12.244335] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 12.252452] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 12.262225] systemd[1]: Reached target User and Group Name Lookups.
[ 12.268739] systemd[1]: Reached target Slices.
[ 12.273372] systemd[1]: Reached target Mounting snaps.
[ 12.278728] systemd[1]: Reached target Swap.
[ 12.283382] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 12.290248] systemd[1]: Listening on Syslog Socket.
[ 12.295409] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 12.302423] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 12.309388] systemd[1]: Listening on Journal Audit Socket.
[ 12.315178] systemd[1]: Listening on Journal Socket (/dev/log).
[ 12.321436] systemd[1]: Listening on Journal Socket.
[ 12.326700] systemd[1]: Listening on udev Control Socket.
[ 12.332385] systemd[1]: Listening on udev Kernel Socket.
[ 12.338876] systemd[1]: Mounting Huge Pages File System…
[ 12.345591] systemd[1]: Mounting POSIX Message Queue File System…
[ 12.352937] systemd[1]: Mounting RPC Pipe File System…
[ 12.359398] systemd[1]: Mounting Kernel Debug File System…
[ 12.366195] systemd[1]: Mounting Kernel Trace File System…
[ 12.373194] systemd[1]: Starting Journal Service…
[ 12.385688] systemd[1]: Starting Set the console keyboard layout…
[ 12.393156] systemd[1]: Starting Create list of static device nodes for the current kernel…
[ 12.403579] systemd[1]: Starting Load Kernel Module chromeos_pstore…
[ 12.410596] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 12.420172] systemd[1]: Starting Load Kernel Module efi_pstore…
[ 12.427632] systemd[1]: Starting Load Kernel Module pstore_blk…
[ 12.435166] systemd[1]: Starting Load Kernel Module pstore_zone…
[ 12.442585] systemd[1]: Starting Load Kernel Module ramoops…
[ 12.449607] systemd[1]: Starting NVIDIA specific first-boot udev script…
[ 12.457692] systemd[1]: Started Nameserver information manager.
[ 12.463984] systemd[1]: Reached target Network (Pre).
[ 12.469972] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 12.479327] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 12.496389] systemd[1]: Starting Load Kernel Modules…
[ 12.502677] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 12.509725] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 12.510645] systemd[1]: Starting udev Coldplug all Devices…
[ 12.511026] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 12.511204] tegra-carveouts tegra-carveouts: fsi :dma coherent mem declare 0x0000001038e00000,16777216
[ 12.511206] tegra-carveouts tegra-carveouts: assigned reserved memory node fsi-carveout
[ 12.511212] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x0000001049800000,914358272
[ 12.511213] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 12.511217] nvmap_page_pool_init: Total RAM pages: 16076934
[ 12.511218] nvmap_page_pool_init: nvmap page pool size: 2009616 pages (3754 MB)
[ 12.511275] nvmap_background_zero_thread: PP zeroing thread starting.
[ 12.511357] misc nvmap: created heap vpr base 0x0000001049800000 size (892928KiB)
[ 12.514445] misc nvmap: created heap fsi base 0x0000001038e00000 size (16384KiB)
[ 12.575545] nvgpu: 17000000.ga10b nvgpu_nvhost_syncpt_init:135 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[ 12.575545]
[ 12.615294] systemd[1]: Started Journal Service.
[ 12.644824] systemd-journald[306]: Received client request to flush runtime journal.
[ 12.927995] nvidia: loading out-of-tree module taints kernel.
[ 13.091421] OF: graph: no port node found in /i2c@c240000/ucsi_ccg@8/connector@0
[ 13.182856] OF: graph: no port node found in /i2c@c240000/ucsi_ccg@8/connector@0
[ 13.192096] OF: graph: no port node found in /i2c@c240000/ucsi_ccg@8/connector@0
[ 13.693484] using random self ethernet address
[ 13.698088] using random host ethernet address
[ 14.049940] using random self ethernet address
[ 14.054587] using random host ethernet address
[ 14.328913] CPU8: shutdown
[ 14.468869] CPU9: shutdown
[ 14.664749] CPU10: shutdown
[ 14.765206] IRQ 124: no longer affine to CPU11
[ 14.771013] CPU11: shutdown
[ 20.766643] audit: type=1326 audit(1728052429.675:2): auid=4294967295 uid=0 gid=0 ses=4294967295 subj=kernel pid=2154 comm=“port-occupied” exe=“/snap/cups/1059/scripts/port-occupied” sig=0 arch=c00000b7 syscall=198 compat=0 ip=0xffffa72082cc code=0x50000
[ 21.720370] audit: type=1326 audit(1728052430.631:3): auid=4294967295 uid=0 gid=0 ses=4294967295 subj=kernel pid=2219 comm=“cupsd” exe=“/snap/cups/1059/sbin/cupsd” sig=0 arch=c00000b7 syscall=198 compat=0 ip=0xffffa68082cc code=0x50000
Ubuntu 20.04.6 LTS yukti-desktop ttyTCU0
login: [ 21.817017] audit: type=1326 audit(1728052430.727:4): auid=4294967295 uid=0 gid=0 ses=4294967295 subj=kernel pid=2219 comm=“cupsd” exe=“/snap/cups/1059/sbin/cupsd” sig=0 arch=c00000b7 syscall=201 compat=0 ip=0xffffa6807c8c code=0x50000
[ 21.838539] audit: type=1326 audit(1728052430.731:5): auid=4294967295 uid=0 gid=0 ses=4294967295 subj=kernel pid=2219 comm=“cupsd” exe=“/snap/cups/1059/sbin/cupsd” sig=0 arch=c00000b7 syscall=55 compat=0 ip=0xffffa67f910c code=0x50000
[ 21.859979] audit: type=1326 audit(1728052430.739:6): auid=4294967295 uid=0 gid=0 ses=4294967295 subj=kernel pid=2219 comm=“cupsd” exe=“/snap/cups/1059/sbin/cupsd” sig=0 arch=c00000b7 syscall=201 compat=0 ip=0xffffa6807c8c code=0x50000
[ 21.881463] audit: type=1326 audit(1728052430.739:7): auid=4294967295 uid=0 gid=0 ses=4294967295 subj=kernel pid=2219 comm=“cupsd” exe=“/snap/cups/1059/sbin/cupsd” sig=0 arch=c00000b7 syscall=201 compat=0 ip=0xffffa6807c8c code=0x50000
[ 21.902931] audit: type=1326 audit(1728052430.739:8): auid=4294967295 uid=0 gid=0 ses=4294967295 subj=kernel pid=2219 comm=“cupsd” exe=“/snap/cups/1059/sbin/cupsd” sig=0 arch=c00000b7 syscall=201 compat=0 ip=0xffffa6807c8c code=0x50000
(`wsl.exe -l -v
Password:
The last time we saw the command “sudo reboot forced-recovery” triggers another reboot but not recovery mode is because the type C cable quality is not good.
Do you have other type C cable to test?
I tried with another USB C cable.
Also tried with the SDK manager -
Automatic setup doesn’t work. Error: Failed to use automatic setup. Please use manual setup
Manual setup doesn’t work - device doesn’t go into recovery but rather boots up just as described above.
Then please RMA the board. Cannot enter recovery mode is related to hardware.
Could you please share the process for RMA?
