USB Timeout when flashing AGX Orin
I am trying to flash the Jetson AGX Orin (32GB) and when running the flashing tool with sudo ./flash.sh jetson-agx-orin-devkit mmcblk0p1 or sudo ./flash.sh jetson-agx-orin-devkit-as-jao-32gb mmcblk0p1 results in the following timeout error:
# L4T BSP Information:
# R35 , REVISION: 1.0
# Target Board Information:
# Name: jetson-agx-orin-devkit, Board Family: t186ref, SoC: Tegra 234,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
copying emc_fuse_dev_params(/home/flir/nvidia/nvidia_sdk/JetPack_5.0.2_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-diag-boot.dts)... done.
copying device_config(/home/flir/nvidia/nvidia_sdk/JetPack_5.0.2_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-device-p3701-0000.dts)... done.
copying misc_config(/home/flir/nvidia/nvidia_sdk/JetPack_5.0.2_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-misc-p3701-0000.dts)... done.
./tegraflash.py --chip 0x23 --applet "/home/flir/nvidia/nvidia_sdk/JetPack_5.0.2_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3701-0000.dts --misc_config tegra234-mb1-bct-misc-p3701-0000.dts --bins "mb2_applet applet_t234.bin" --cmd "dump eeprom cvm cvm.bin; dump custinfo custinfo_out.bin; reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[   0.0056 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.0062 ] File rcm_state open failed
[   0.0063 ] ERROR: failed to read rcm_state
[   0.0063 ]
[   0.0070 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0071 ] Assuming zero filled SBK key
[   0.0066 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
[   0.0105 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0000.dts
[   0.0156 ] Parsing partition layout
[   0.0161 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.0171 ] Parsing partition layout
[   0.0177 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.0184 ] Creating list of images to be signed
[   0.0190 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[   0.0194 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.0199 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.0200 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.0229 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.0231 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.0258 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.0259 ] adding BCH for mb2_t234_aligned.bin
[   0.0278 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.0365 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.0367 ] adding BCH for mb2_t234_aligned.bin
[   0.0473 ] Generating signatures
[   0.0479 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.0481 ] Assuming zero filled SBK key
[   0.0558 ] Warning: pub_key.key is not found
[   0.0554 ] Parsing dev params for multi chains
[   0.0593 ] Generating br-bct
[   0.0598 ] Updating dev and MSS params in BR BCT
[   0.0599 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.0606 ] Updating bl info
[   0.0610 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.0615 ] WARNING: boot chain is not completed. set to 0
[   0.0619 ] Get Signed section of bct
[   0.0624 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   0.0630 ] Signing BCT
[   0.0637 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.0638 ] Assuming zero filled SBK key
[   0.0654 ] Sha saved in br_bct_BR.sha
[   0.0656 ] Warning: pub_key.key is not found
[   0.0651 ] Updating BCT with signature
[   0.0656 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   0.0661 ] Offset :4608 Len :3584
[   0.0663 ] Generating SHA2 Hash
[   0.0669 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   0.0670 ] Assuming zero filled SBK key
[   0.0686 ] Sha saved in br_bct_BR.sha
[   0.0682 ] Updating BCT with SHA2 Hash
[   0.0687 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   0.0692 ] Offset :4608 Len :3584
[   0.0693 ] Offset :68 Len :8124
[   0.0694 ] Generating coldboot mb1-bct
[   0.0699 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.0704 ] MB1-BCT version: 0.9
[   0.0713 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.0714 ] Added Platform Config 9 data with size :- 80
[   0.0714 ]
[   0.0714 ] Updating mb1-bct with firmware information
[   0.0719 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.0732 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   0.0743 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   0.0747 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   0.0758 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.0759 ] Assuming zero filled SBK key
[   0.0769 ] Warning: pub_key.key is not found
[   0.0769 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.0777 ] Generating recovery mb1-bct
[   0.0782 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.0787 ] MB1-BCT version: 0.9
[   0.0796 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.0797 ] Added Platform Config 9 data with size :- 80
[   0.0797 ]
[   0.0797 ] Updating mb1-bct with firmware information
[   0.0802 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.0814 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[   0.0824 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   0.0829 ] adding BCH for mb1_bct_MB1_aligned.bct
[   0.0840 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.0841 ] Assuming zero filled SBK key
[   0.0851 ] Warning: pub_key.key is not found
[   0.0850 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.0858 ] Error: Skip generating mem_bct because sdram_config is not defined
[   0.0858 ] Copying signatures
[   0.0863 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.0894 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   0.0894 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   0.0894 ] Boot Rom communication
[   0.0899 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   0.0905 ] BR_CID: 0x80012344705DD2C10C0000000CFF01C0
[   0.1191 ] Sending bct_br
[   0.1623 ] ERROR: might be timeout in USB write.
Error: Return value 3
Command tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
Reading board information failed.
Using the SDK Manager tool also gives the same error, and I’ve tried several USB cables connected to the front USB-C port on the Orin and they all behave the same.
The device itself appears fine in lsusb, so I’m not sure what’s wrong:
Bus 003 Device 051: ID 0955:7023 NVIDIA Corp. APX
Bus 003 Device 050: ID 0955:7045 NVIDIA Corp. Tegra On-Platform Operator
please do me a favor to dump the UART log from your orin during flash with below method.
Need to use the micro usb port as above link indicates to dump.
Here is the entire boot output:
Welcome to minicom 2.7.1
OPTIONS: I18n
Compiled on Dec 23 2019, 02:06:26.
Port /dev/ttyACM0, 10:42:24
Press CTRL-A Z for help on special keys
[0000.061] I> MB1 (version: 0.23.0.0-t234-54845784-92215740)
[0000.067] I> t234-A01-0-Silicon (0x12347) Prod
[0000.071] I> Boot-mode : Coldboot
[0000.074] I> Emulation:
[0000.076] I> Entry timestamp: 0x00000000
[0000.080] I> last_boot_error: 0x0
[0000.083] I> BR-BCT: preprod_dev_sign: 0
[0000.087] I> rst_source: 0x0, rst_level: 0x0
[0000.091] I> Task: CRC check (0x5001cf71)
[0000.095] I> Skip CRC check as records_integrity fuse is not burned
[0000.101] I> Task: Crypto init (0x5001c0d9)
[0000.105] I> Task: Secure debug controls (0x5000cb19)
[0000.110] I> Task: strap war set (0x5000b739)
[0000.114] I> strap value(0x4000401) set to 0x4000401
[0000.119] I> Task: Initialize SOC Therm (0x5001a509)
[0000.124] I> Task: Program NV master stream id (0x5000cad1)
[0000.129] I> Task: Verify boot mode (0xd482021)
[0000.135] I> Task: Alias fuses (0x50010749)
[0000.140] E> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.147] I> Task: Print SKU type (0x5000fba9)
[0000.152] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000000
[0000.157] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[0000.161] I> FUSE_OPT_TPC_DISABLE = 0x00000000
[0000.165] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0000.170] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0000.174] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.178] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.182] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.186] I> FUSE_SKU_INFO_0 = 0xd0
[0000.190] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.194] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.197] I> SKU: Prod
[0000.200] I> Task: Boost clocks (0x50013db1)
[0000.204] I> Initializing PLLC2 for AXI_CBB.
[0000.208] I> AXI_CBB : src = 35, divisor = 0
[0000.212] I> Task: Voltage monitor (0x50013dbd)
[0000.216] I> VMON: Vmon re-calibration and fine tuning done
[0000.222] I> Task: UPHY init (0x5000da39)
[0000.226] E> UPHY: UPHY lane info table is empty in MB1 BCT.
[0000.231] I> Task: Boot device init (0x50000a3d)
[0000.236] I> Boot_device: QSPI_FLASH instance: 0
[0000.240] I> Qspi clock source : pllc_out0
[0000.244] I> QSPI Flash: Macronix 64MB
[0000.248] I> QSPI-0l initialized successfully
[0000.252] I> Task: TSC init (0x5001ed35)
[0000.256] I> Task: Load membct (0x5001190d)
[0000.260] I> RAM_CODE 0x4000401
[0000.263] I> Loading MEM-BCT to SysRAM
[0000.267] I> Scratch RSV109: 0x00000001    active chain: 0
[0000.272] I> Slot: 0
[0000.274] I> Binary[0] block-0 (partition size: 0x40000)
[0000.279] I>  get_binary_info: Binary name: MEM-BCT-0
[0000.284] I> Size of crypto header is 8192
[0000.288] I> BCH load address is : 0x40050000
[0000.292] I> Size of crypto header is 8192
[0000.297] I> BCH of MEM-BCT-0 read from storage
[0000.301] I> BCH address is : 0x40050000
[0000.305] I> MEM-BCT-0 header integrity check is success
[0000.310] I> Binary magic in BCH component 0 is MEM0
[0000.315] I> component binary type is 0
[0000.319] I> MEM-BCT-0 binary is read from storage
[0000.324] I> MEM-BCT-0 binary integrity check is success
[0000.329] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.336] I> RAM_CODE 0x4000401
[0000.341] I> RAM_CODE 0x4000401
[0000.345] I> Task: Load Page retirement list (0x50011139)
[0000.350] I> Task: SDRAM params override (0x50011b79)
[0000.355] I> Task: Save mem-bct info (0x50014071)
[0000.360] I> Task: Carveout allocate (0x500140d5)
[0000.364] I> RCM blob carveout will not be allocated
[0000.369] I> ECC region[0]: Start:0x0, End:0x0
[0000.373] I> ECC region[1]: Start:0x0, End:0x0
[0000.377] I> ECC region[2]: Start:0x0, End:0x0
[0000.382] I> ECC region[3]: Start:0x0, End:0x0
[0000.386] I> ECC region[4]: Start:0x0, End:0x0
[0000.390] I> Non-ECC region[0]: Start:0x80000000, End:0x480000000
[0000.396] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.401] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.405] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.410] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.420] I> allocated(CO:44) base:0x449800000 size:0x36800000 align: 0x100000
[0000.427] I> allocated(CO:31) base:0x440000000 size:0x8000000 align: 0x8000000
[0000.434] I> allocated(CO:39) base:0x43a000000 size:0x6000000 align: 0x200000
[0000.441] I> allocated(CO:20) base:0x438000000 size:0x2000000 align: 0x2000000
[0000.448] I> allocated(CO:24) base:0x436000000 size:0x2000000 align: 0x2000000
[0000.455] I> allocated(CO:28) base:0x434000000 size:0x2000000 align: 0x2000000
[0000.462] I> allocated(CO:29) base:0x432000000 size:0x2000000 align: 0x2000000
[0000.469] I> allocated(CO:43) base:0x430000000 size:0x2000000 align: 0x200000
[0000.476] I> allocated(CO:22) base:0x448000000 size:0x1000000 align: 0x1000000
[0000.484] I> allocated(CO:41) base:0x42f000000 size:0x1000000 align: 0x100000
[0000.491] I> allocated(CO:02) base:0x449000000 size:0x800000 align: 0x800000
[0000.497] I> allocated(CO:03) base:0x42e800000 size:0x800000 align: 0x800000
[0000.504] I> allocated(CO:06) base:0x42e000000 size:0x800000 align: 0x800000
[0000.511] I> allocated(CO:10) base:0x42d800000 size:0x800000 align: 0x800000
[0000.518] I> allocated(CO:56) base:0x42d000000 size:0x800000 align: 0x200000
[0000.525] I> allocated(CO:07) base:0x42cc00000 size:0x400000 align: 0x400000
[0000.532] I> allocated(CO:33) base:0x42c800000 size:0x400000 align: 0x200000
[0000.539] I> allocated(CO:47) base:0x42c400000 size:0x400000 align: 0x200000
[0000.546] I> allocated(CO:72) base:0x42c200000 size:0x200000 align: 0x10000
[0000.553] I> allocated(CO:01) base:0x42c100000 size:0x100000 align: 0x100000
[0000.560] I> allocated(CO:04) base:0x42c000000 size:0x100000 align: 0x100000
[0000.567] I> allocated(CO:05) base:0x42bf00000 size:0x100000 align: 0x100000
[0000.574] I> allocated(CO:08) base:0x42be00000 size:0x100000 align: 0x100000
[0000.580] I> allocated(CO:09) base:0x42bd00000 size:0x100000 align: 0x100000
[0000.587] I> allocated(CO:15) base:0x42bc00000 size:0x100000 align: 0x100000
[0000.594] I> allocated(CO:17) base:0x42bb00000 size:0x100000 align: 0x100000
[0000.601] I> allocated(CO:23) base:0x42ba00000 size:0x100000 align: 0x100000
[0000.608] I> allocated(CO:27) base:0x42b900000 size:0x100000 align: 0x100000
[0000.615] I> allocated(CO:42) base:0x42b800000 size:0x100000 align: 0x100000
[0000.622] I> allocated(CO:54) base:0x42b780000 size:0x80000 align: 0x80000
[0000.629] I> allocated(CO:26) base:0x42b740000 size:0x40000 align: 0x2000
[0000.635] I> allocated(CO:48) base:0x42b720000 size:0x20000 align: 0x10000
[0000.642] I> allocated(CO:69) base:0x42b700000 size:0x20000 align: 0x10000
[0000.649] I> allocated(CO:34) base:0x42b6f0000 size:0x10000 align: 0x10000
[0000.656] I> allocated(CO:35) base:0x42b6e0000 size:0x10000 align: 0x10000
[0000.662] I> allocated(CO:49) base:0x42b6d0000 size:0x10000 align: 0x10000
[0000.669] I> allocated(CO:50) base:0x42b6c0000 size:0x10000 align: 0x10000
[0000.676] I> allocated(CO:52) base:0x42b6b0000 size:0x10000 align: 0x10000
[0000.683] I> Task: Thermal check (0x5001fba1)
[0000.687] I> max_chip_limit = 115
[0000.690] I> min_chip_limit = -30
[0000.693] I> max temp read = 28
[0000.696] I> min temp read = 26
[0000.699] I> Task: Update FSI SCR with thermal fuse data (0x5001fc3d)
[0000.705] I> Task: Enable WDT 5th expiry (0x5001f929)
[0000.710] I> Task: Disable WDT globally (0x5001f965)
[0000.715] I> Task: I2C register (0x50000a31)
[0000.719] I> Task: Reset FSI (0x50013db9)
[0000.723] I> Task: Pinmux init (0x50013219)
[0000.727] I> Task: Prod config init (0x50013631)
[0000.732] I> Task: Pad voltage init (0x500132a5)
[0000.736] I> Task: Prod init (0x500136d5)
[0000.740] I> Task: Common rail init (0x50013bd1)
[0000.745] W>  Thermal config not found in BCT
[0000.749] W>  Generic i2c config not found in BCT
[0000.753] W>  Platform rail config not found in BCT
[0000.759] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.767] W>  MEMIO rail config not found in BCT
[0000.772] I> Task: Mem clock src (0x500119c5)
[0000.776] I> Task: Misc. board config (0x50013c29)
[0000.781] W>  Platform config not found in BCT
[0000.785] I> Task: SDRAM init (0x500119c9)
[0000.792] I> SDRAM-params @ 0xd485000
[0000.795] I> MSS code-drop: NvBootSdramInit
[0000.799] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 8
[0000.806] I> MSS CAR: Init PLLM
[0000.809] I> MSS CAR: Init PLLHUB
[0000.814] I> Encryption:   MTS: en, TX: dis, VPR: dis, GSC: en
[0000.826] I> mb1_sdram_init Done !
[0000.829] I> SDRAM Size in Total 0x400000000
[0000.833] I> Task: Dram Ecc scrub (0x50011261)
[0000.837] I> Task: DRAM alias check (0x50011b71)
[0000.855] I> Task: Program NSDRAM carveout (0x50014921)
[0000.862] I> NSDRAM carveout encryption is disabled
[0000.867] I> Program NSDRAM carveout
[0000.871] I> Task: Register checker (0x50011b75)
[0000.878] I> Task: Enable clock-mon (0x5001ed25)
[0000.895] I> FMON: Fmon re-programming done
[0000.899] I> Task: Mapper init (0x5001d451)
[0000.904] I> Task: SC7 Context Init (0x5001f02d)
[0000.911] I> Task: CCPLEX IST init (0x5000d335)
[0000.916] I> Task: CPU WP0 (0x5000c635)
[0000.922] I> Loading MCE
[0000.924] I> Scratch RSV109: 0x00000001    active chain: 0
[0000.930] I> Slot: 0
[0000.933] I> Binary[8] block-0 (partition size: 0x80000)
[0000.939] I>  get_binary_info: Binary name: MCE
[0000.943] I> Size of crypto header is 8192
[0000.948] I> BCH load address is : 0x4003e000
[0000.953] I> Size of crypto header is 8192
[0000.958] I> BCH of MCE read from storage
[0000.962] I> BCH address is : 0x4003e000
[0000.968] I> MCE header integrity check is success
[0000.973] I> Binary magic in BCH component 0 is MTSM
[0000.978] I> component binary type is 8
[0000.982] I> Size of crypto header is 8192
[0000.989] I> MCE binary is read from storage
[0000.994] I> MCE binary integrity check is success
[0000.999] I> Binary MCE loaded successfully at 0x40000000 (0x2c080)
[0001.007] I> Size of crypto header is 8192
[0001.021] I> Size of crypto header is 8192
[0001.026] I> Sending WP0 mailbox command to PSC
[0001.036] I> Task: MB1 fixed firewalls (0x5001e55d)
[0001.056] I> Task: Load bpmp-fw (0x5001e801)
[0001.061] I> Scratch RSV109: 0x00000001    active chain: 0
[0001.067] I> Slot: 0
[0001.070] I> Binary[15] block-0 (partition size: 0x180000)
[0001.076] I>  get_binary_info: Binary name: BPMP_FW
[0001.081] I> Size of crypto header is 8192
[0001.086] I> BCH load address is : 0x807fe000
[0001.091] I> Size of crypto header is 8192
[0001.096] I> BCH of BPMP_FW read from storage
[0001.101] I> BCH address is : 0x807fe000
[0001.106] I> BPMP_FW header integrity check is success
[0001.112] I> Binary magic in BCH component 0 is BPMF
[0001.117] I> component binary type is 15
[0001.121] I> Size of crypto header is 8192
[0001.136] I> BPMP_FW binary is read from storage
[0001.143] I> BPMP_FW binary integrity check is success
[0001.149] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xfb3c0)
[0001.157] I> Scratch RSV109: 0x00000001    active chain: 0
[0001.163] I> Slot: 0
[0001.165] I> Binary[16] block-10000 (partition size: 0x400000)
[0001.172] I>  get_binary_info: Binary name: BPMP_FW_DTB
[0001.178] I> Size of crypto header is 8192
[0001.182] I> BCH load address is : 0x807fc000
[0001.188] I> Size of crypto header is 8192
[0001.193] I> BCH of BPMP_FW_DTB read from storage
[0001.198] I> BCH address is : 0x807fc000
[0001.203] I> BPMP_FW_DTB header integrity check is success
[0001.209] I> Binary magic in BCH component 0 is BPMD
[0001.214] I> component binary type is 16
[0001.218] I> Size of crypto header is 8192
[0001.225] I> BPMP_FW_DTB binary is read from storage
[0001.230] I> BPMP_FW_DTB binary integrity check is success
[0001.236] I> Binary BPMP_FW_DTB loaded successfully at 0x807db9f0 (0x20440)
[0001.245] I> Task: Load psc-fw (0x5001ea0d)
[0001.251] I> Scratch RSV109: 0x00000001    active chain: 0
[0001.257] I> Slot: 0
[0001.259] I> Binary[17] block-0 (partition size: 0xc0000)
[0001.265] I>  get_binary_info: Binary name: PSC_FW
[0001.270] I> Size of crypto header is 8192
[0001.275] I> BCH load address is : 0x80ffe000
[0001.280] I> Size of crypto header is 8192
[0001.285] I> BCH of PSC_FW read from storage
[0001.290] I> BCH address is : 0x80ffe000
[0001.295] I> PSC_FW header integrity check is success
[0001.301] I> Binary magic in BCH component 0 is PFWP
[0001.306] I> component binary type is 17
[0001.310] I> Size of crypto header is 8192
[0001.320] I> PSC_FW binary is read from storage
[0001.326] I> PSC_FW binary integrity check is success
[0001.332] I> Binary PSC_FW loaded successfully at 0x80000000 (0x7d000)
[0001.340] I> Task: Load nvdec-fw (0x5001ea81)
[0001.346] I> Scratch RSV109: 0x00000001    active chain: 0
[0001.352] I> Slot: 0
[0001.354] I> Binary[7] block-0 (partition size: 0x100000)
[0001.360] I>  get_binary_info: Binary name: NVDEC
[0001.365] I> Size of crypto header is 8192
[0001.370] I> BCH load address is : 0x800fe000
[0001.375] I> Size of crypto header is 8192
[0001.380] I> BCH of NVDEC read from storage
[0001.384] I> BCH address is : 0x800fe000
[0001.390] I> NVDEC header integrity check is success
[0001.395] I> Binary magic in BCH component 0 is NDEC
[0001.400] I> component binary type is 7
[0001.405] I> Size of crypto header is 8192
[0001.412] I> NVDEC binary is read from storage
[0001.417] I> NVDEC binary integrity check is success
[0001.422] I> Binary NVDEC loaded successfully at 0x80000000 (0x35000)
[0001.433] I> Task: Load tsec-fw (0x5001ec6d)
[0001.438] I> TSEC-FW load support not enabled
[0001.443] I> Task: Program misc carveouts (0x5001445d)
[0001.449] I> Program IPC carveouts
[0001.456] I> Task: GPIO interrupt map (0x50013cc5)
[0001.463] I> Task: SC7 context save (0x5001f161)
[0001.468] I> NV_SC7 Context addr: 0xa0000000
[0001.474] I> Scratch RSV109: 0x00000001    active chain: 0
[0001.480] I> Slot: 0
[0001.482] I> Binary[27] block-0 (partition size: 0x100000)
[0001.488] I>  get_binary_info: Binary name: BR_BCT
[0001.493] I> Size of crypto header is 8192
[0001.498] I> Size of crypto header is 8192
[0001.503] I> BR_BCT binary is read from storage
[0001.508] I> BR_BCT binary integrity check is success
[0001.513] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[0001.521] I> Scratch RSV109: 0x00000001    active chain: 0
[0001.527] I> Slot: 0
[0001.530] I> Binary[13] block-0 (partition size: 0x30000)
[0001.536] I>  get_binary_info: Binary name: SC7-FW
[0001.541] I> Size of crypto header is 8192
[0001.545] I> Size of crypto header is 8192
[0001.550] I> BCH load address is : 0xa0002000
[0001.555] I> Size of crypto header is 8192
[0001.560] I> BCH of SC7-FW read from storage
[0001.565] I> BCH address is : 0xa0002000
[0001.570] I> SC7-FW header integrity check is success
[0001.576] I> Binary magic in BCH component 0 is WB0B
[0001.581] I> component binary type is 13
[0001.585] I> Size of crypto header is 8192
[0001.591] I> SC7-FW binary is read from storage
[0001.597] I> SC7-FW binary integrity check is success
[0001.602] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x25460)
[0001.610] I> Scratch RSV109: 0x00000001    active chain: 0
[0001.616] I> Slot: 0
[0001.619] I> Binary[22] block-0 (partition size: 0x30000)
[0001.625] I>  get_binary_info: Binary name: PSC_RF
[0001.630] I> Size of crypto header is 8192
[0001.634] I> Size of crypto header is 8192
[0001.639] I> BCH load address is : 0xa0029460
[0001.644] I> Size of crypto header is 8192
[0001.649] I> BCH of PSC_RF read from storage
[0001.654] I> BCH address is : 0xa0029460
[0001.659] I> PSC_RF header integrity check is success
[0001.665] I> Binary magic in BCH component 0 is PSCR
[0001.670] I> component binary type is 22
[0001.674] I> Size of crypto header is 8192
[0001.680] I> PSC_RF binary is read from storage
[0001.686] I> PSC_RF binary integrity check is success
[0001.691] I> Binary PSC_RF loaded successfully at 0xa002b460 (0x1bd20)
[0001.711] I> Scratch RSV109: 0x00000001    active chain: 0
[0001.717] I> Slot: 0
[0001.719] I> Binary[14] block-0 (partition size: 0x20000)
[0001.725] I>  get_binary_info: Binary name: MB2_RF
[0001.730] I> Size of crypto header is 8192
[0001.735] I> Size of crypto header is 8192
[0001.740] I> BCH load address is : 0xa008e240
[0001.745] I> Size of crypto header is 8192
[0001.750] I> BCH of MB2_RF read from storage
[0001.754] I> BCH address is : 0xa008e240
[0001.760] I> MB2_RF header integrity check is success
[0001.765] I> Binary magic in BCH component 0 is MB2R
[0001.771] I> component binary type is 14
[0001.775] I> Size of crypto header is 8192
[0001.781] I> MB2_RF binary is read from storage
[0001.786] I> MB2_RF binary integrity check is success
[0001.792] I> Binary MB2_RF loaded successfully at 0xa0090240 (0x1bdc0)
[0001.800] E> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0001.808] I> SC7 context fuse-bypass data is empty
[0001.816] I> SC7 context save done
[0001.820] I> Task: Load MB2/Applet/FSKP (0x5000d451)
[0001.826] I> Loading MB2
[0001.829] I> Scratch RSV109: 0x00000001    active chain: 0
[0001.834] I> Slot: 0
[0001.837] I> Binary[6] block-0 (partition size: 0x80000)
[0001.843] I>  get_binary_info: Binary name: MB2
[0001.848] I> Size of crypto header is 8192
[0001.852] I> BCH load address is : 0x8007e000
[0001.858] I> Size of crypto header is 8192
[0001.863] I> BCH of MB2 read from storage
[0001.867] I> BCH address is : 0x8007e000
[0001.872] I> MB2 header integrity check is success
[0001.878] I> Binary magic in BCH component 0 is MB2B
[0001.883] I> component binary type is 6
[0001.887] I> Size of crypto header is 8192
[0001.896] I> MB2 binary is read from storage
[0001.902] I> MB2 binary integrity check is success
[0001.907] I> Binary MB2 loaded successfully at 0x80000000 (0x686c0)
[0001.915] I> Task: Map CCPLEX SHARED carveout (0x5000d521)
[0001.922] I> Task: Prepare MB2 params (0x5000d5dd)
[0001.931] I> MB2-params @ 0x40060000
[0001.939] I> BR-BCT Boot Chain Fields
[0001.942] I>    u32_non_gpio_select_boot_chain  : 0
[0001.947] I>    u32_num_boot_chains             : 2
[0001.952] I>    bf_bl_gpio_select_boot_chain_1b : 0
[0001.959] I> Task: Dram ecc test (0x500112cd)
[0001.964] I> Task: Misc NV security settings (0x5000ced5)
[0001.971] I> NVDEC sticky bits programming done
[0001.976] I> Task: Disable/Reload WDT (0x5001f991)
[0001.982] I> Programmed SLCG global override := 0x0
[0001.987] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-e33bc3dc)
I> Emulation:
I> Entry timestamp: 0x001ee7d1
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0x42d000000, size:0x800000]
I> Task: ARI update carveout TZDRAM (0x50001e6c)
I> Task: Enable hot-plug capability (0x50020e7c)
I> Task: PSC mailbox init (0x50011ed0)
I> Task: Crypto init (0x5000513c)
I> Task: Enable GP-SE clock (0x50001fd0)
I> Task: I2C register (0x50001e30)
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout (0x50001e18)
I> Task: Boot device init (0x50001d60)
I> Task: Partition Manager Init (0x50001d5c)
I> Found 57 partitions in QSPI_FLASH (instance 0)
W> Cannot find any partition table for 00000003
 > PARTITION_MANAGER: Failed to publish partition.
I> Found 11 partitions in SDMMC_USER (instance 3)
I> Task: Load and authenticate registered FWs (0x50017428)
I> Task: Load AUXP FWs (0x50020a1c)
I> Successfully register SPE FW load task with MB2 loader
I> Skipping SCE FW load
I> Successfully register RCE FW load task with MB2 loader
I> Successfully register DCE FW load task with MB2 loader
I> Unpowergating APE
I> Unpowergate done
I> Successfully register APE FW load task with MB2 loader
I> Skipping FSI FW load
I> Successfully register XUSB FW load task with MB2 loader
I> Partition name: A_spe-fw
I> Size of partition: 589824
I> Binary@ device:3/0 block-55040 (partition size: 0x90000), name: A_spe-fw
I> Partition name: A_rce-fw
I> Size of partition: 1048576
I> Binary@ device:3/0 block-56192 (partition size: 0x100000), name: A_rce-fw
I> spe: Authentication Finalize Done
I> Binary spe loaded successfully at 0x42be00000
I> Partition name: A_dce-fw
I> Size of partition: 5242880
I> Binary@ device:3/0 block-44800 (partition size: 0x500000), name: A_dce-fw
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0x42bb00000
I> dce : oem authentication of header done
I> dce : meta-blob integrity check is success.
I> dce : will be decompressed at 0x438000000
I> version 1 Bin 1 BCheckSum 0 content_size 0 Content ChkSum 1 reserved_00  0
I> Reserved10 0 BlockMaxSize 5 Reserved11 0
I> dce : decompressed to 9423440 bytes
I> dce: plain binary integrity check is success
I> Partition name: A_adsp-fw
I> Size of partition: 2097152
I> Binary@ device:3/0 block-58240 (partition size: 0x200000), name: A_adsp-fw
I> dce: Authentication Finalize Done
I> Binary dce loaded successfully at 0x438000000
I> Partition name: A_xusb-fw
I> Size of partition: 262144
I> Binary@ device:3/0 block-9472 (partition size: 0x40000), name: A_xusb-fw
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0x42cc00000
I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0x42bf00000
I> Task: Carveout setup (0x50019c94)
I> Program remaining OEM carveouts
I> Task: Enable FSITHERM (0x50011da4)
I> Task: Enable FSI VMON (0x50011944)
I> FSI VMON: FSI Vmon re-calibration and fine tuning done
I> Task: Validate FSI Therm readings (0x5001199c)
I> FSITHERM max temp = 29
I> FSITHERM min temp = 27
I> Task: Restore XUSB sec (0x50001d30)
I> Task: Enable FSI SE clock (0x5001232c)
I> Enable FSI-SE clock and 10ms delay...
I> Task: Initialize SBSA UART CAR (0x50001f34)
I> Task: Initialize CPUBL Params (0x50013384)
I> CPUBL-params @ 0x434000000
I> Task: Prepare eeprom data (0x50013140)
I> Task: OEM firewalls (0x5001df14)
W> mb2_unpowergate_ape: skip! APE is in unpowergated state
I> OEM firewalls configured
I> Task: Unhalt AUXPs (0x50020c84)
I> Unhalting SPE..
I> Enabling combined UART
����spe: early_init
vic initialized
tsc initialized
aon lic initialized
spe: tag is 2e3d77fae66a40ac8e7a91531ae7d9b3
spe: SafeRTOS v8.4
spe: init
scheduler initialized
aon hsp initialized
tag initialized
tcu initialized
bpmp ipc initialized
spe: late init
cpu_nic clock initialized
apb clock initialized
pm initialized
bpmp hsp initialized
top1 hsp initialized
ccplex ipc initialized
spe: start scheduler
  I> Task: Trigger mailbox for PSC-BL1 exit (0x50011f50)
I> Sending opcode 0x4d420802 to psc
��INFO: Entering psc_monitor_init!
INFO: GSC22 BOM:0x448000000 SIZE:0x1000000 CLIENT_ACCESS1:00180000
INFO: PSCFW BUILD VERSION: e061f86-9e1f578-2508c43-dev-t234
INFO: mstatus:0xa00000808
INFO: Supervisor entry_point:c108c00
��I> Received ACK from psc
I> Task: Sta��INFO: MONITOR: user task addr:0x448022000, blob offset:0x00020000
  ��rt secure NOR provision (0x50014924)
I> Task: Load FSI keyblob (0x50012368)
I> Skipping FSI key blob copy
I> Task: Unhalt AUXPs (0x50020c8c)
I> SCE unhalt skipped
I> Unhalting RCE
I> RCE unhalt successful
I> DCE unhalt successful
I> APE unhalt skipped
I> FSI unhalt skipped
I> Task: Load CPUBL (0x5001347c)
I> Task: Load TOS (0x50013b38)
I> Scratch RSV109: 0x00000001    active ch��[     2.3729��bpmp: init
bpmp: base binary md5 is eac3805��35] Camera-FW on t234-rce-safe started
��INFO: MONITOR: populated user images��TCU early console enabled.
��:19
INFO: mret to Supervisor!
INFO: psc supervisor init.
INFO: psc_irq_init...
INFO: enter idle task.
��26d68ff45ffc86d0feae98e88
bpmp: combined binary md5 is 888a114dda6bea50b6c6bb224445ac85
bpmp: firmware tag is 888a114dda6bea50b6c6-eac380526d6
initialized vwdt
initialized mail_early
initialized fuse
initialized vfrel
initialized hwwdt
initialized adc
fmon_populate_monitors: found 199 monitors
initialized fmon
initialized mc
initialized reset
initialized uphy_early
initialized emc_early
471 clocks registered
initialized clk_mach
initialized clk_cal_early
initialized clk_mach_early_config
initialized io_dpd
initialized thermal
initialized soctherm
initialized tj_init
initialized regime
initialized i2c
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
initialized vrmon
initialized regulator
  ��ain: 0
I> Partition name: A_cpu-bootloader
I> Size of partition: 3670016
I> Binary@ device:3/0 block-24832 (partition size: ��initialized avfs_clk_platform
initialized powergate
��0x380000), name: A_cpu-bootloader
��initialized dvs
initialized clk_mach_config
initialized pm
initialized suspend
initialized strap
initialized emc
initialized emc_mrq
initialized clk_cal
initialized uphy_dt
initialized uphy_mrq
initialized uphy
initialized pg_late
initialized pg_mrq_init
swdtimer_init: 0 reg polling start w period 47 ms
initialized swdtimer
initialized hwwdt_late
initialized bwmgr
initialized thermal_host_trip
initialized thermal_mrq
initialized oc_mrq
initialized reset_mrq
initialized mail_mrq
initialized fmon_mrq
initialized clk_mrq
initialized avfs_mrq
initialized i2c_mrq
initialized tag_mrq
initialized bwmgr_mrq
initialized console_mrq
initialized mce_dbell
missing prod DT calibration data for 199 fmons
initialized clk_sync_fmon_post
��I> Scratch RSV109: 0x00000001    active chain: 0
I> Partition name: A_secure-os
I> Size of partition: 4194304
I> Binary@ device:3/0 block-32000��initialized clk_cal_late
initialized noc_late
initialized dmce
initialized cvc
�� (partition size: 0x400000), name��initialized avfs_clk_mach_post
initialized pm_post
initialized avfs_clk_platform_post
initialized cvc_late
initialized rm
initialized console_late
handling unreferenced clks
enable adspneon
enable can1_core
enable can1_host
enable can2_core
enable can2_host
enable mss_encrypt
enable maud
enable nvdec
enable pllg_ref
enable dsi_core
enable aza_2xbit
enable pllc4_muxed
enable xusb_ss
enable xusb_fs
enable xusb_falcon
enable xusb_core_mux
enable dsi_lp
enable sdmmc_legacy_tm
ini��[     2.609097] Camera-FW on t234-rce-safe ready SHA1=7a10e461 (crt 19.979 ms,��tialized clk_mach_post
initialized pg_post
initialized regulator_post
initialized prof�� total boot 257.200 ms)
��ile
initialized fuse_late
initialized mrq
initialized patrol_scrubber
initialized extras_post
bpmp: init complete
��DCE: FW Boot Done
��: A_secure-os
I> cpubl: Authentication Finalize Done
I> Binary cpubl loaded successfully at 0x42c400000
I> tos: Authentication Finalize Done
I> Binary tos loaded successfully at 0x431e06000
I> Relocating OP-TEE dtb from: 0x431eff700 to 0x42b700000, size: 0x996
I> [0] START: 0x80000000, SIZE: 0x3ab600000
I> [1] START: 0x42c400000, SIZE: 0x400000
I> [2] START: 0x42d000000, SIZE: 0x800000
I> Setting NS memory ranges to OP-TEE dtb finished.
I> Partition name: A_eks
I> Binary@ device:3/0 block-44288 (partition size: 0x40000), name: A_eks
I> eks: Authentication Finalize Done
I> Binary eks loaded successfully at 0x42d000400
I> EKB detected (length: 0x410) @ VA:0x42d000400
I> Task: Prepare TOS params (0x50013ab0)
I> Setting EKB blob info to OPTEE dtb finished.
I> Setting OPTEE arg3: 0x42b700000
I> Task: OEM SC7 context save (0x500146bc)
I> oem sc7 context saved
I> Task: Disable MSS perf stats (0x50020d18)
I> Task: Program display sticky bits (0x50020c94)
I> Task: Storage device deinit (0x50001ed8)
I> Task: SMMU external bypass disable (0x50011eb4)
I> Task: SMMU init (0x50011dd0)
I> Task: Program CBB PCIE AMAP regions (0x50014b08)
I> Task: Program GICv3 registers (0x50020db8)
I> Task: Audit firewall settings (0x5001e1c0)
I> Task: Bootchain failure check (0x500026a4)
I> Current Boot-Chain Slot: 0
I> BR-BCT Boot-Chain is 0, and status is 1. Set UPDATE_BRBCT bit to 0
I> MB2 finished
��NOTICE:  BL31: v2.6(release):4fa405dbd
NOTICE:  BL31: Built : 20:16:55, Aug 10 2022
I/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 3.16 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Thu Aug 11 03:23:19 UTC 2022 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: WARNING: Test OEM keys are being used!
I/TC: This is only for TZ-SE testing and should NOT be used for a shipping product!
E/TC:00 0 jetson_user_key_pta_init:700 jetson_user_key_pta_init: Failed (f0100006).
E/TC:00 0 call_initcalls:43 Initcall __text_start + 0x000dab50 failed
I/TC: Primary CPU switching to normal world boot
  Jetson UEFI firmware (version 1.0-d7fb19b built on 2022-08-10T20:18:13-07:00)
**  WARNING: Test Key is used.  **
L4TLauncher: Attempting GRUB Boot
L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map...
��I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
��[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[    0.000000] Linux version 5.10.104 (flir@flir-Precision-7560) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #5 SMP PREEMPT Thu Nov 24 17:49:11 EST 2022
[    0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[    0.000000] OF: fdt:  - 80000000 ,  c0000000
[    0.000000] Machine model: Jetson AGX Orin as NX-16GB
[    0.000000] efi: EFI v2.70 by EDK II
[    0.000000] efi: RTPROP=0x422c2d118 SMBIOS=0xffff0000 SMBIOS 3.0=0x403de0000 MEMATTR=0x404a8b018 ESRT=0x403e1af98 RNG=0x427c15998 MEMRESERVE=0x404a8ff18
[    0.000000] efi: seeding entropy pool
[    0.000000] esrt: Reserving ESRT space from 0x0000000403e1af98 to 0x0000000403e1afd0.
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000417800000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x0000000435ffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000fffdffff]
[    0.000000]   node   0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x00000003ffffffff]
[    0.000000]   node   0: [mem 0x0000000400000000-0x00000004021bffff]
[    0.000000]   node   0: [mem 0x00000004021c0000-0x0000000403ac4fff]
[    0.000000]   node   0: [mem 0x0000000403ac5000-0x0000000403c4bfff]
[    0.000000]   node   0: [mem 0x0000000403c4c000-0x0000000403dcffff]
[    0.000000]   node   0: [mem 0x0000000403dd0000-0x0000000403deffff]
[    0.000000]   node   0: [mem 0x0000000403df0000-0x000000040485ffff]
[    0.000000]   node   0: [mem 0x0000000404860000-0x00000004049effff]
[    0.000000]   node   0: [mem 0x00000004049f0000-0x0000000404a5ffff]
[    0.000000]   node   0: [mem 0x0000000404a60000-0x0000000404a7ffff]
[    0.000000]   node   0: [mem 0x0000000404a80000-0x0000000404a9ffff]
[    0.000000]   node   0: [mem 0x0000000404aa0000-0x0000000404d0ffff]
[    0.000000]   node   0: [mem 0x0000000404d10000-0x0000000404d5ffff]
[    0.000000]   node   0: [mem 0x0000000404d60000-0x0000000404d6ffff]
[    0.000000]   node   0: [mem 0x0000000404d70000-0x0000000404dbffff]
[    0.000000]   node   0: [mem 0x0000000404dc0000-0x000000040521ffff]
[    0.000000]   node   0: [mem 0x0000000405220000-0x000000040584ffff]
[    0.000000]   node   0: [mem 0x0000000405850000-0x00000004058effff]
[    0.000000]   node   0: [mem 0x00000004058f0000-0x000000040599ffff]
[    0.000000]   node   0: [mem 0x00000004059a0000-0x0000000405a3ffff]
[    0.000000]   node   0: [mem 0x0000000405a40000-0x0000000405acffff]
[    0.000000]   node   0: [mem 0x0000000405ad0000-0x0000000405b6ffff]
[    0.000000]   node   0: [mem 0x0000000405b70000-0x000000040643ffff]
[    0.000000]   node   0: [mem 0x0000000406440000-0x000000040661ffff]
[    0.000000]   node   0: [mem 0x0000000406620000-0x0000000427bcffff]
[    0.000000]   node   0: [mem 0x0000000427bd0000-0x0000000427c1ffff]
[    0.000000]   node   0: [mem 0x0000000427c20000-0x000000042b6affff]
[    0.000000]   node   0: [mem 0x000000042c400000-0x000000042c7fffff]
[    0.000000]   node   0: [mem 0x0000000434000000-0x0000000435ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000435ffffff]
[    0.000000] On node 0, zone Normal: 336 pages in unavailable ranges
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 32 pages/cpu s90136 r8192 d32744 u131072
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] CPU features: detected: Spectre-v4
[    0.000000] alternatives: patching kernel code
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 3796272
[    0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 console=tty0 firmware_class.path=/etc/firmware fbcon=map:0 net
[    0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000effe0000-0x00000000fffe0000] (256MB)
[    0.000000] Memory: 14505052K/15428288K available (18368K kernel code, 3170K rwdata, 7124K rodata, 3968K init, 1093K bss, 661092K reserved, 262144K cma-reserved)
[    0.000000] random: get_random_u64 called from __kmem_cache_create+0x38/0x420 with crng_init=0
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[    0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[    0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[    0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.000635] Console: colour dummy device 80x25
[    0.000810] printk: console [tty0] enabled
[    0.000844] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.000853] pid_max: default: 32768 minimum: 301
[    0.000915] LSM: Security Framework initializing
[    0.000936] Yama: becoming mindful.
[    0.000953] SELinux:  Initializing.
[    0.001014] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.001040] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.002484] rcu: Hierarchical SRCU implementation.
[    0.002568] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[    0.002995] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t23x/concord/kernel-dts/tegra234-p3701-0000-as-p3767-0000-p3737-00s
[    0.003003] DTB Build time: Aug 10 2022 20:31:43
[    0.004209] Tegra Revision: A01 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[    0.004323] Remapping and enabling EFI services.
[    0.005485] smp: Bringing up secondary CPUs ...
[    0.034031] Detected PIPT I-cache on CPU1
[    0.034060] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[    0.034083] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[    0.062580] Detected PIPT I-cache on CPU2
[    0.062589] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[    0.062602] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[    0.091063] Detected PIPT I-cache on CPU3
[    0.091072] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[    0.091084] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[    0.121584] Detected PIPT I-cache on CPU4
[    0.121603] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[    0.121629] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[    0.150155] Detected PIPT I-cache on CPU5
[    0.150164] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[    0.150179] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[    0.178667] Detected PIPT I-cache on CPU6
[    0.178676] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[    0.178689] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[    0.207180] Detected PIPT I-cache on CPU7
[    0.207189] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[    0.207203] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[    0.207256] smp: Brought up 1 node, 8 CPUs
[    0.207299] SMP: Total of 8 processors activated.
[    0.207303] CPU features: detected: Privileged Access Never
[    0.207306] CPU features: detected: LSE atomic instructions
[    0.207308] CPU features: detected: User Access Override
[    0.207311] CPU features: detected: 32-bit EL0 Support
[    0.207315] CPU features: detected: Common not Private translations
[    0.207318] CPU features: detected: RAS Extension Support
[    0.207320] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.207324] CPU features: detected: CRC32 instructions
[    0.207327] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.237834] CPU: All CPU(s) started at EL2
[    0.239573] devtmpfs: initialized
[    0.252904] Registered cp15_barrier emulation handler
[    0.252915] Registered setend emulation handler
[    0.252922] KASLR enabled
[    0.253021] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.253034] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.254557] pinctrl core: initialized pinctrl subsystem
[    0.255024] SMBIOS 3.0.0 present.
[    0.255030] DMI:  /, BIOS 1.0-d7fb19b 08/10/2022
[    0.255268] NET: Registered protocol family 16
[    0.255855] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.255961] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.256060] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.256085] audit: initializing netlink subsys (disabled)
[    0.256156] audit: type=2000 audit(0.252:1): state=initialized audit_enabled=0 res=1
[    0.256303] thermal_sys: Registered thermal governor 'step_wise'
[    0.256305] thermal_sys: Registered thermal governor 'power_allocator'
[    0.256317] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[    0.256902] cpuidle: using governor menu
[    0.256999] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.257081] ASID allocator initialised with 32768 entries
[    0.257162] Serial: AMBA PL011 UART driver
[    0.258675] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[    0.258697] Tegra reboot handler registered.
[    0.276099] mc: mapped MMIO address: 0xffff800010b10000 -> 0x2c10000
[    0.276110] mc: mapped MMIO address: 0xffff800010b30000 -> 0x2c20000
[    0.276118] mc: mapped MMIO address: 0xffff800010b50000 -> 0x2c30000
[    0.276124] mc: mapped MMIO address: 0xffff800010b70000 -> 0x2c40000
[    0.276132] mc: mapped MMIO address: 0xffff800010b90000 -> 0x2c50000
[    0.276139] mc: mapped MMIO address: 0xffff800010bb0000 -> 0x2b80000
[    0.276148] mc: mapped MMIO address: 0xffff800010bd0000 -> 0x2b90000
[    0.276155] mc: mapped MMIO address: 0xffff800010bf0000 -> 0x2ba0000
[    0.276163] mc: mapped MMIO address: 0xffff800010c10000 -> 0x2bb0000
[    0.276170] mc: mapped MMIO address: 0xffff800010c30000 -> 0x1700000
[    0.276176] mc: mapped MMIO address: 0xffff800010c50000 -> 0x1710000
[    0.276182] mc: mapped MMIO address: 0xffff800010c70000 -> 0x1720000
[    0.276189] mc: mapped MMIO address: 0xffff800010c90000 -> 0x1730000
[    0.276195] mc: mapped MMIO address: 0xffff800010cb0000 -> 0x1740000
[    0.276202] mc: mapped MMIO address: 0xffff800010cd0000 -> 0x1750000
[    0.276208] mc: mapped MMIO address: 0xffff800010cf0000 -> 0x1760000
[    0.276214] mc: mapped MMIO address: 0xffff800010d10000 -> 0x1770000
[    0.276224] nv-tegra-mc 2c10000.mc: No mssnvlink node
[    0.276239] mc-err: mcerr ops are set to t23x
[    0.276487] tegra234-cbb 13a00000.cbb-fabric: secure_irq = 21
[    0.276538] tegra234-cbb c600000.aon-fabric: secure_irq = 22
[    0.276580] tegra234-cbb d600000.bpmp-fabric: secure_irq = 23
[    0.276615] tegra234-cbb de00000.dce-fabric: secure_irq = 24
[    0.276648] tegra234-cbb be00000.rce-fabric: secure_irq = 25
[    0.276684] tegra234-cbb b600000.sce-fabric: secure_irq = 26
[    0.280283] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.280290] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.280293] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.280297] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.281893] ACPI: Interpreter disabled.
[    0.282981] vdd-av1v1-hub: supplied by vdd-5v-sys
[    0.283144] vbusA-cvb: supplied by vdd-5v-sys
[    0.283253] vbusB-cvb: supplied by vdd-5v-sys
[    0.283361] vdd-usbc1-vbus: supplied by vdd-5v-sys
[    0.283458] vdd-usbc2-vbus: supplied by vdd-5v-sys
[    0.283705] iommu: Default domain type: Translated
[    0.283745] eventlib_kernel: keventlib is initialized, test id: 0
[    0.283906] SCSI subsystem initialized
[    0.283971] usbcore: registered new interface driver usbfs
[    0.283985] usbcore: registered new interface driver hub
[    0.283998] usbcore: registered new device driver usb
[    0.284166] mc: Linux media interface: v0.10
[    0.284177] videodev: Linux video capture interface: v2.00
[    0.284309] pps_core: Using Landson's LinuxPPS!
[    0.284310] pps_core: LinuxPPS API ver. 1 registered
[    0.284315] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.284327] PTP clock support registered
[    0.284539] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[    0.284581] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[    0.285868] Registered efivars operations
[    0.286362] FPGA manager framework
[    0.286391] Advanced Linux Sound Architecture Driver Initialized.
[    0.286629] Bluetooth: Core ver 2.22
[    0.286643] NET: Registered protocol family 31
[    0.286646] Bluetooth: HCI device and connection manager initialized
[    0.286652] Bluetooth: HCI socket layer initialized
[    0.286656] Bluetooth: L2CAP socket layer initialized
[    0.286663] Bluetooth: SCO socket layer initialized
[    0.287251] camchar: rtcpu character device driver loaded
[    0.287487] clocksource: Switched to clocksource arch_sys_counter
[    0.439208] VFS: Disk quotas dquot_6.6.0
[    0.439253] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.439393] pnp: PnP ACPI: disabled
[    0.441125] la/ptsa driver initialized.
[    0.441180] NET: Registered protocol family 2
[    0.441379] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.443556] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    0.443581] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.443698] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.444150] TCP: Hash tables configured (established 131072 bind 65536)
[    0.444217] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.444251] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.444343] NET: Registered protocol family 1
[    0.444697] RPC: Registered named UNIX socket transport module.
[    0.444708] RPC: Registered udp transport module.
[    0.444711] RPC: Registered tcp transport module.
[    0.444714] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.444726] PCI: CLS 0 bytes, default 64
[    0.444842] Trying to unpack rootfs image as initramfs...
[    0.553388] Freeing initrd memory: 8196K
[    0.555274] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.555424] kvm [1]: IPA Size Limit: 48 bits
[    0.555565] kvm [1]: VHE mode initialized successfully
[    0.556134] Initialise system trusted keyrings
[    0.556232] workingset: timestamp_bits=46 max_order=22 bucket_order=0
[    0.558243] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.558502] NFS: Registering the id_resolver key type
[    0.558516] Key type id_resolver registered
[    0.558519] Key type id_legacy registered
[    0.558553] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.558562] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.558576] ntfs: driver 2.1.32 [Flags: R/W].
[    0.570255] NET: Registered protocol family 38
[    0.570263] Key type asymmetric registered
[    0.570267] Asymmetric key parser 'x509' registered
[    0.570285] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[    0.570341] io scheduler mq-deadline registered
[    0.570345] io scheduler kyber registered
[    0.573959] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    0.573987] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[    0.574006] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    0.574023] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[    0.576306] tegra_dc_assign_hw_data: no matching compatible node
[    0.576311] tegradccommon module_init failed
[    0.576315] tegradc module_init failed
[    0.576545] EINJ: ACPI disabled.
[    0.577895] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[    0.577902] tegra-pmc: ### PMC reset source: SYS_RESET_N
[    0.577907] tegra-pmc: ### PMC reset level: L0
[    0.577910] tegra-pmc: ### PMC reset status reg: 0x0
[    0.579056] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.584053] random: fast init done
[    0.584422] printk: console [ttyTCU0] enabled
[    2.138697] arm-smmu 12000000.iommu: probing hardware configuration...
[    2.144609] arm-smmu 12000000.iommu: SMMUv2 with:
[    2.149180] arm-smmu 12000000.iommu:         stage 1 translation
[    2.154483] arm-smmu 12000000.iommu:         stage 2 translation
[    2.159995] arm-smmu 12000000.iommu:         nested translation
[    2.165157] arm-smmu 12000000.iommu:         stream matching with 128 register groups
[    2.172334] arm-smmu 12000000.iommu:         128 context banks (0 stage-2 only)
[    2.180823] arm-smmu 12000000.iommu:         Supported page sizes: 0x00001000
[    2.185370] arm-smmu 12000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    2.191932] arm-smmu 12000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    2.199110] arm-smmu 10000000.iommu: probing hardware configuration...
[    2.204971] arm-smmu 10000000.iommu: SMMUv2 with:
[    2.209694] arm-smmu 10000000.iommu:         stage 1 translation
[    2.215207] arm-smmu 10000000.iommu:         stage 2 translation
[    2.220630] arm-smmu 10000000.iommu:         nested translation
[    2.226057] arm-smmu 10000000.iommu:         stream matching with 128 register groups
[    2.233235] arm-smmu 10000000.iommu:         128 context banks (0 stage-2 only)
[    2.241759] arm-smmu 10000000.iommu:         Supported page sizes: 0x00001000
[    2.246444] arm-smmu 10000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    2.253009] arm-smmu 10000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    2.259938] arm-smmu 8000000.iommu: probing hardware configuration...
[    2.266134] arm-smmu 8000000.iommu: SMMUv2 with:
[    2.270857] arm-smmu 8000000.iommu:  stage 1 translation
[    2.276369] arm-smmu 8000000.iommu:  stage 2 translation
[    2.281793] arm-smmu 8000000.iommu:  nested translation
[    2.286957] arm-smmu 8000000.iommu:  stream matching with 128 register groups
[    2.294132] arm-smmu 8000000.iommu:  128 context banks (0 stage-2 only)
[    2.302672] arm-smmu 8000000.iommu:  Supported page sizes: 0x00001000
[    2.307345] arm-smmu 8000000.iommu:  Stage-1: 48-bit VA -> 48-bit IPA
[    2.313907] arm-smmu 8000000.iommu:  Stage-2: 48-bit IPA -> 48-bit PA
[    2.320970] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[    2.329940] tegra_profiler: version: 1.147, samples/io: 49/28
[    2.334118] tegra_profiler: auth: init
[    2.338142] nvsciipc: loaded module
[    2.342465] tegra23x-qspi 3270000.spi: Adding to iommu group 0
[    2.347568] tegra23x-qspi 3270000.spi: Node prod_c_nonsecure has invalid entries
[    2.354860] tegra23x-qspi 3270000.spi: Node prod_c_nonsecure: Child has not proper setting
[    2.363085] tegra23x-qspi 3270000.spi: Node spi: Faild to read the Prod Setting.
[    2.370522] tegra23x-qspi 3270000.spi: Prod settings list not found
[    2.376741] tegra23x-qspi 3270000.spi: Failed to get reset control: -517
[    2.384044] tun: Universal TUN/TAP device driver, 1.6
[    2.389037] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    2.395987] hns3: Copyright (c) 2017 Huawei Corporation.
[    2.401512] e1000e: Intel(R) PRO/1000 Network Driver
[    2.406307] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    2.412188] igb: Intel(R) Gigabit Ethernet Network Driver
[    2.417506] igb: Copyright (c) 2007-2014 Intel Corporation.
[    2.423245] PPP generic driver version 2.4.2
[    2.427610] PPP BSD Compression module registered
[    2.432210] PPP Deflate Compression module registered
[    2.437294] PPP MPPE Compression module registered
[    2.442293] usbcore: registered new interface driver r8152
[    2.447790] usbcore: registered new interface driver asix
[    2.453218] usbcore: registered new interface driver ax88179_178a
[    2.459340] usbcore: registered new interface driver cdc_ether
[    2.465292] usbcore: registered new interface driver net1080
[    2.470890] usbcore: registered new interface driver cdc_subset
[    2.476925] usbcore: registered new interface driver zaurus
[    2.482620] usbcore: registered new interface driver cdc_ncm
[    2.488307] usbcore: registered new interface driver aqc111
[    2.493826] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.500028] ohci-pci: OHCI PCI platform driver
[    2.504320] ohci-platform: OHCI generic platform driver
[    2.509647] tegra-xusb 3610000.xhci: Adding to iommu group 1
[    2.515608] usbcore: registered new interface driver uas
[    2.520599] usbcore: registered new interface driver usb-storage
[    2.526571] tegra-xudc 3550000.xudc: Adding to iommu group 2
[    2.532285] mousedev: PS/2 mouse device common for all mice
[    2.537752] usbcore: registered new interface driver xpad
[    2.544993] tegra_rtc c2a0000.rtc: registered as rtc1
[    2.548508] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:26 UTC (26)
[    2.556291] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    2.562539] i2c /dev entries driver
[    2.566092] tegra-i2c 3160000.i2c: Adding to iommu group 3
[    2.571666] tegra-i2c c240000.i2c: Adding to iommu group 3
[    2.577069] tegra-i2c 3180000.i2c: Adding to iommu group 3
[    2.582488] tegra-i2c 3190000.i2c: Adding to iommu group 3
[    2.587823] tegra-i2c 31b0000.i2c: Adding to iommu group 3
[    2.593334] tegra-i2c 31c0000.i2c: Adding to iommu group 3
[    2.598761] tegra-i2c c250000.i2c: Adding to iommu group 3
[    2.604108] tegra-i2c 31e0000.i2c: Adding to iommu group 3
[    2.612304] device-mapper: uevent: version 1.0.3
[    2.614107] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[    2.623587] sdhci: Secure Digital Host Controller Interface driver
[    2.628736] sdhci: Copyright(c) Pierre Ossman
[    2.633020] Synopsys Designware Multimedia Card Interface Driver
[    2.639126] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.644969] sdhci-tegra 3460000.sdhci: Adding to iommu group 4
[    2.645243] sdhci-tegra 3400000.sdhci: Adding to iommu group 5
[    2.645294] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[    2.646092] tegra-bpmp bpmp: firmware: 888a114dda6bea50b6c6-eac380526d6
[    2.646974] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[    2.647504] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x81
[    2.651609] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[    2.685986] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
��debugfs initialized
��[    4.399550] hid: raw HID events driver (C) Jiri Kosina
[    4.400168] usbcore: registered new interface driver usbhid
[    4.400388] usbhid: USB HID core driver
[    4.401226] tegra-dce d800000.dce: Adding to iommu group 6
[    4.402638] dce: dce_ipc_channel_init:314  Invalid Channel State [0x0] for ch_type [2]
[    4.403673] tegra23x-psc e860000.psc: Adding to iommu group 7
[    4.404080] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x5]
[    4.404387] dce: dce_admin_ipc_handle_signal:89   Spurious signal on channel: [0]. Ignored...
[    4.404488] tegra23x-psc e860000.psc: ext_cfg base:(____ptrval____)
[    4.404852] dce: dce_admin_send_cmd_ver:413  version : [0x2] err : [0x0]
[    4.405096] tegra23x-psc e860000.psc: init done
[    4.405271] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x1]
[    4.405566] dce: dce_admin_setup_clients_ipc:542  Channel Reset Complete for Type [1] ...
[    4.405569] dce: dce_admin_ipc_handle_signal:89   Spurious signal on channel: [1]. Ignored...
[    4.405799] dce: dce_admin_setup_clients_ipc:518  Get queue info failed for [2]
[    4.405914] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 8
[    4.406040] dce: dce_admin_ipc_handle_signal:89   Spurious signal on channel: [1]. Ignored...
[    4.410093] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x2]
[    4.412115] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[    4.419613] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[    4.425127] dce: dce_admin_setup_clients_ipc:542  Channel Reset Complete for Type [3] ...
[    4.425129] dce: dce_admin_ipc_handle_signal:89   Spurious signal on channel: [3]. Ignored...
[    4.434008] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[    4.442198] dce: dce_start_boot_flow:100  DCE_BOOT_DONE
[    4.451058] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[    4.495447] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[    4.505843] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[    4.517731] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[    4.530147] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[    4.542146] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (116)
[    4.548151] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[    4.556508] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=7a10e4613e151d2bf1df37dd80d456800f5b94d0
[    4.569151] t19x_cache tegra-cache: probed
[    4.571519] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[    4.581295] optee: probing for conduit method.
[    4.581846] optee: revision 3.16 (65cc2218)
[    4.582545] optee: dynamic shared memory is enabled
[    4.591045] optee: initialized driver
[    4.604287] nvpmodel: initialized successfully
[    4.604537] tegra_hv: get_hvd: not initialized yet
[    4.604714] user_ivc_mempool: hypervisor not present
[    4.609439] usbcore: registered new interface driver snd-usb-audio
[    4.615645] u32 classifier
[    4.617881]     input device check on
[    4.621562]     Actions configured
[    4.624914] Initializing XFRM netlink socket
[    4.629687] NET: Registered protocol family 10
[    4.634903] Segment Routing with IPv6
[    4.637282] NET: Registered protocol family 17
[    4.641615] NET: Registered protocol family 15
[    4.646012] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    4.659369] Bluetooth: RFCOMM socket layer initialized
[    4.664284] Bluetooth: RFCOMM ver 1.11
[    4.668204] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    4.674063] Bluetooth: HIDP socket layer initialized
[    4.679523] 9pnet: Installing 9P2000 support
[    4.683466] Key type dns_resolver registered
[    4.688322] registered taskstats version 1
[    4.691923] Loading compiled-in X.509 certificates
[    4.699654] Loaded X.509 cert 'Build time autogenerated kernel key: 4c6fce1878e1bda60667b44b8a8dc4e03b576022'
[    4.707050] tegra194-pcie 14100000.pcie: Adding to iommu group 9
[    4.718430] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[    4.720039] tegra194-pcie 14160000.pcie: Adding to iommu group 10
[    4.730421] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[    4.731795] tegra194-pcie 141a0000.pcie: Adding to iommu group 11
[    4.742640] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[    4.776775] host1x 13e40000.host1x: Adding to iommu group 12
[    5.787177] t23x_init_gating_regs: Timed out waiting for syncpt ram init!
[    5.797286] host1x 13e40000.host1x: initialized
[    5.797789] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 13
[    5.798252] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[    5.799852] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 14
[    5.800270] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[    5.801866] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 15
[    5.802270] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[    5.803853] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 16
[    5.804297] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[    5.805865] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 17
[    5.806242] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[    5.807810] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 18
[    5.808229] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[    5.819335] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 19
[    5.825860] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[    5.837383] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 20
[    5.843889] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[    5.855426] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 21
[    5.855502] random: crng init done
[    5.861932] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[    5.876848] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 22
[    5.883375] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[    5.894864] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 23
[    5.901345] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[    5.912879] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 24
[    5.919402] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[    5.930907] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 25
[    5.937443] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[    5.948938] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 26
[    5.955430] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[    5.966968] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 27
[    5.973469] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[    5.984985] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 28
[    5.991495] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[    6.003040] falcon 15340000.vic: Adding to iommu group 29
[    6.012015] falcon 15340000.vic: initialized
[    6.012408] falcon 15380000.nvjpg: Adding to iommu group 30
[    6.020834] falcon 15380000.nvjpg: initialized
[    6.021975] falcon 15540000.nvjpg1: Adding to iommu group 31
[    6.030600] falcon 15540000.nvjpg1: initialized
[    6.032385] falcon 154c0000.nvenc: Adding to iommu group 32
[    6.042495] falcon 154c0000.nvenc: initialized
[    6.042725] falcon 15a50000.ofa: Adding to iommu group 33
[    6.050605] falcon 15a50000.ofa: initialized
[    6.052506] nvdec 15480000.nvdec: Adding to iommu group 34
[    6.063336] nvdec 15480000.nvdec: initialized
[    6.063570] tsec 15500000.tsec: Adding to iommu group 35
[    6.072128] tsec 15500000.tsec: initialized
[    6.074205] gic 2a41000.agic-controller: GIC IRQ controller registered
[    6.085929] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[    6.095434] gpio-394 (camera-control-output-low): hogged as output/low
[    6.095635] gpio-397 (camera-control-output-low): hogged as output/low
[    6.099328] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[    6.105202] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[    6.111168] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    6.118478] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[    6.124838] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    6.129315] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[    6.137876] tegra194-isp5 14800000.isp: Adding to iommu group 36
[    6.142558] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[    6.149002] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[    6.154745] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[    6.163866] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[    6.173179] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 37
[    6.180759] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 38
[    6.187797] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
[    6.196920] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[    6.202968] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
[    6.212730] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[    6.218970] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[    6.228667] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[    6.234734] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 39
[    6.243094] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18, iommu=smmu.0x0000000008000000)
[    6.253979] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 40
[    6.262487] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19, iommu=smmu.0x0000000008000000)
[    6.273222] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 41
[    6.281556] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20, iommu=smmu.0x0000000008000000)
[    6.292482] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 42
[    6.300813] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21, iommu=smmu.0x0000000008000000)
[    6.311548] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to iommu group 43
[    6.320068] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized (streamid=22, iommu=smmu.0x0000000008000000)
[    6.330802] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to iommu group 44
[    6.339333] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized (streamid=23, iommu=smmu.0x0000000008000000)
[    6.350034] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to iommu group 45
[    6.358560] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized (streamid=24, iommu=smmu.0x0000000008000000)
[    6.369301] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to iommu group 46
[    6.377817] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized (streamid=25, iommu=smmu.0x0000000008000000)
[    6.388567] pva 16000000.pva0: Adding to iommu group 47
[    6.411512] pva 16000000.pva0: initialized
[    6.414901] nvdla 15880000.nvdla0: Adding to iommu group 48
[    6.422080] nvdla 15880000.nvdla0: initialized
[    6.423777] nvdla 158c0000.nvdla1: Adding to iommu group 49
[    6.430431] nvdla 158c0000.nvdla1: initialized
[    6.432094] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 3
[    6.433051] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[    6.433452] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[    6.437740] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[    6.444335] serial-tegra 3100000.serial: Adding to iommu group 3
[    6.450683] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 13, base_baud = 0) is a TEGRA_UART
[    6.459792] serial-tegra 3130000.serial: Adding to iommu group 3
[    6.465372] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 65, base_baud = 0) is a TEGRA_UART
[    6.474413] tegra23x-qspi 3270000.spi: Node prod_c_nonsecure has invalid entries
[    6.481230] tegra23x-qspi 3270000.spi: Node prod_c_nonsecure: Child has not proper setting
[    6.489623] tegra23x-qspi 3270000.spi: Node spi: Faild to read the Prod Setting.
[    6.497238] tegra23x-qspi 3270000.spi: Prod settings list not found
[    6.526612] tegra-xusb 3610000.xhci: Firmware timestamp: 2021-12-01 05:27:10 UTC, Version: 80.03 release
[    6.526879] tegra-xusb 3610000.xhci: xHCI Host Controller
[    6.527051] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[    6.528053] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[    6.535414] tegra-xusb 3610000.xhci: irq 228, io mem 0x03610000
[    6.541544] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    6.549474] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.556732] usb usb1: Product: xHCI Host Controller
[    6.561720] usb usb1: Manufacturer: Linux 5.10.104 xhci-hcd
[    6.567319] usb usb1: SerialNumber: 3610000.xhci
[    6.572666] hub 1-0:1.0: USB hub found
[    6.576007] hub 1-0:1.0: 4 ports detected
[    6.580231] tegra-xusb 3610000.xhci: xHCI Host Controller
[    6.585438] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[    6.593053] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[    6.600457] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    6.608633] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.615886] usb usb2: Product: xHCI Host Controller
[    6.620870] usb usb2: Manufacturer: Linux 5.10.104 xhci-hcd
[    6.626561] usb usb2: SerialNumber: 3610000.xhci
[    6.631659] hub 2-0:1.0: USB hub found
[    6.634972] hub 2-0:1.0: 4 ports detected
[    6.649202] pca954x 2-0070: pca954x_probe: forcing device bus number, start 30.
[    6.649410] pca954x 2-0070: device detect skipped.
[    6.651422] pca954x 2-0070: probe failed
[    6.655024] pca954x: probe of 2-0070 failed with error -121
[    6.681655] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2008000 KHz, changing to: 1984000 KHz
[    6.684736] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2007000 KHz, changing to: 1984000 KHz
[    6.685703] tegra194-cpufreq e000000.ccplex: probed with ICC
[    6.690233] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[    6.692199] sdhci-tegra 3400000.sdhci: Got CD GPIO
[    6.699609] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[    6.703544] mmc0: CQHCI version 5.10
[    6.705930] tegra194-pcie 14100000.pcie:       IO 0x0030100000..0x00301fffff -> 0x0030100000
[    6.708360] irq: IRQ295: trimming hierarchy from :interrupt-controller@f400000-1
[    6.708398] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 295
[    6.731825] tegra194-pcie 14100000.pcie:      MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[    6.737360] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[    6.740315] tegra194-pcie 14100000.pcie:      MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[    6.836442] mmc0: Command Queue Engine enabled
[    6.836582] mmc0: periodic cache flush enabled
[    6.836715] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[    6.837113] mmcblk0: mmc0:0001 G1M15M 59.3 GiB
[    6.837459] mmcblk0rpmb: mmc0:0001 G1M15M partition 3 4.00 MiB, chardev (511:0)
[    6.840891]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[    6.847493] usb 1-3: new full-speed USB device number 2 using tegra-xusb
[    6.863492] tegra194-pcie 14100000.pcie: Link up
[    6.865356] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[    6.865542] pci_bus 0001:00: root bus resource [bus 00-ff]
[    6.865695] pci_bus 0001:00: root bus resource [io  0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[    6.865950] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[    6.866232] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[    6.866476] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[    6.866745] pci 0001:00:00.0: PME# supported from D0 D3hot
[    6.870606] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[    6.870874] pci 0001:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[    6.871162] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[    6.872106] pci 0001:01:00.0: supports D1 D2
[    6.875056] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    6.885536] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[    6.889146] pci 0001:00:00.0: BAR 13: assigned [io  0x1000-0x1fff]
[    6.895448] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff 64bit]
[    6.903215] pci 0001:01:00.0: BAR 0: assigned [io  0x1000-0x10ff]
[    6.909290] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[    6.914522] pci 0001:00:00.0:   bridge window [io  0x1000-0x1fff]
[    6.920822] pci 0001:00:00.0:   bridge window [mem 0x20a8000000-0x20a80fffff]
[    6.928180] pci 0001:00:00.0: Max Payload Size set to  128/ 256 (was  256), Max Read Rq  512
[    6.936707] pci 0001:01:00.0: Max Payload Size set to  128/ 128 (was  128), Max Read Rq  512
[    6.945208] pcieport 0001:00:00.0: Adding to iommu group 9
[    6.950488] pcieport 0001:00:00.0: PME: Signaling with IRQ 51
[    6.956089] pcieport 0001:00:00.0: AER: enabled with IRQ 51
[    6.962468] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[    6.968821] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[    6.974907] tegra194-pcie 14160000.pcie:       IO 0x0036100000..0x00361fffff -> 0x0036100000
[    6.983388] tegra194-pcie 14160000.pcie:      MEM 0x2428000000..0x242fffffff -> 0x0040000000
[    6.991873] tegra194-pcie 14160000.pcie:      MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[    6.999971] usb 1-3: New USB device found, idVendor=13d3, idProduct=3549, bcdDevice= 0.00
[    7.008589] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    7.015760] usb 1-3: Product: Bluetooth Radio
[    7.020221] usb 1-3: Manufacturer: Realtek
[    7.024421] usb 1-3: SerialNumber: 00e04c000001
[    7.124797] usb 2-3: new SuperSpeedPlus Gen 2 USB device number 2 using tegra-xusb
[    7.164854] usb 2-3: New USB device found, idVendor=0bda, idProduct=0420, bcdDevice= 1.40
[    7.165103] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    7.165309] usb 2-3: Product: 4-Port USB 3.0 Hub
[    7.165443] usb 2-3: Manufacturer: Generic
[    7.177503] hub 2-3:1.0: USB hub found
[    7.180093] hub 2-3:1.0: 4 ports detected
[    7.279486] usb 1-4: new high-speed USB device number 3 using tegra-xusb
[    7.447725] usb 1-4: New USB device found, idVendor=0bda, idProduct=5420, bcdDevice= 1.40
[    7.447974] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    7.448186] usb 1-4: Product: 4-Port USB 2.0 Hub
[    7.448318] usb 1-4: Manufacturer: Generic
[    7.450352] hub 1-4:1.0: USB hub found
[    7.451722] hub 1-4:1.0: 4 ports detected
[    8.109083] tegra194-pcie 14160000.pcie: Phy link never came up
[    8.109311] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[    8.109511] pci_bus 0004:00: root bus resource [bus 00-ff]
[    8.109674] pci_bus 0004:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[    8.109958] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[    8.110276] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[    8.110541] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[    8.110827] pci 0004:00:00.0: PME# supported from D0 D3hot
[    8.117704] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[    8.117855] pci 0004:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    8.118303] pcieport 0004:00:00.0: Adding to iommu group 10
[    8.118631] pcieport 0004:00:00.0: PME: Signaling with IRQ 53
[    8.119173] pcieport 0004:00:00.0: AER: enabled with IRQ 53
[    8.119520] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[    8.119758] pci 0004:00:00.0: Removing from iommu group 10
[    8.119916] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[    8.125025] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[    8.130041] vdd-3v3-pcie: supplied by vdd-3v3-sys
[    8.134685] avdd-cam-2v8: supplied by vdd-3v3-sys
[    8.139303] vdd-dp: supplied by vdd-3v3-sys
[    8.143569] vdd-3v3-sd: supplied by vdd-3v3-sys
[    8.148407] dsi-vdd-1v8-bl-en: supplied by vdd-1v8-sys
[    8.155003] tegra194-isp5 14800000.isp: initialized
[    8.160429] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[    8.164412] (NULL device *): fops function table already registered
[    8.172823] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[    8.177392] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[    8.177580] sdhci-tegra 3400000.sdhci: Got CD GPIO
[    8.199865] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 295
[    8.297172] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[    8.297392] tegra194-pcie 141a0000.pcie:       IO 0x003a100000..0x003a1fffff -> 0x003a100000
[    8.297646] tegra194-pcie 141a0000.pcie:      MEM 0x2b28000000..0x2b2fffffff -> 0x0040000000
[    8.297909] tegra194-pcie 141a0000.pcie:      MEM 0x2740000000..0x2b27ffffff -> 0x2740000000
[    9.251304] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[    9.404885] tegra194-pcie 141a0000.pcie: Phy link never came up
[    9.405118] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[    9.405318] pci_bus 0005:00: root bus resource [bus 00-ff]
[    9.405478] pci_bus 0005:00: root bus resource [io  0x200000-0x2fffff] (bus address [0x3a100000-0x3a1fffff])
[    9.405773] pci_bus 0005:00: root bus resource [mem 0x2b28000000-0x2b2fffffff] (bus address [0x40000000-0x47ffffff])
[    9.406092] pci_bus 0005:00: root bus resource [mem 0x2740000000-0x2b27ffffff pref]
[    9.406354] pci 0005:00:00.0: [10de:229a] type 01 class 0x060400
[    9.406634] pci 0005:00:00.0: PME# supported from D0 D3hot
[    9.413485] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[    9.413637] pci 0005:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    9.414107] pcieport 0005:00:00.0: Adding to iommu group 11
[    9.414435] pcieport 0005:00:00.0: PME: Signaling with IRQ 55
[    9.414986] pcieport 0005:00:00.0: AER: enabled with IRQ 55
[    9.415304] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[    9.415562] pci 0005:00:00.0: Removing from iommu group 11
[    9.415726] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[    9.421172] nvethernet 6810000.ethernet: Adding to iommu group 50
[    9.426177] nvethernet 6810000.ethernet: failed to read skip mac reset flag, default 0
[    9.433714] nvethernet 6810000.ethernet: failed to read MDIO address
[    9.440271] nvethernet 6810000.ethernet: setting to default DMA bit mask
[    9.447100] nvethernet 6810000.ethernet: failed to read UPHY GBE mode- default to 10G
[    9.841386] nvethernet 6810000.ethernet: Ethernet MAC address: 48:b0:2d:7b:6b:60
[    9.841948] nvethernet 6810000.ethernet: Macsec not enabled
[    9.842127] nvethernet 6810000.ethernet: Macsec: Reduced MTU: 1466 Max: 16383
[    9.844271] nvethernet 6810000.ethernet: eth0 (HW ver: 31) created with 10 DMA channels
[    9.844950] irq: IRQ297: trimming hierarchy from :pmc@c360000
[    9.845160] irq: IRQ298: trimming hierarchy from :interrupt-controller@f400000-1
[    9.845408] irq: IRQ299: trimming hierarchy from :pmc@c360000
[    9.845618] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    9.846474] tegra-se-nvhost 15810000.se: Adding to iommu group 51
[    9.846935] tegra-se-nvhost 15810000.se: initialized
[    9.855040] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[    9.855310] tegra-se-nvhost 15820000��WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpusysclk
��.se: Adding to iommu group 52
[    9.855732] tegra-se-nvhost 15820000.se: initialized
[    9.857976] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[    9.858239] tegra-se-nvhost 15840000.se: Adding to iommu group 53
[    9.858643] tegra-se-nvhost 15840000.se: initialize��WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc1clk
��d
[    9.862235] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[    9.862939] tegra_actmon d230000.actmon: in actmon_register()...
[    9.863230] tegra_actmon d230000.actmon: bwmgr_disable = 1
[    9.867972] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[    9.875701] ��WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc0clk
��hvc_sysfs: hypervisor is not present
[   10.009315] ALSA device list:
[   10.009417]   No soundcards found.
[   10.010089] Freeing unused kernel memory: 3968K
[   10.010257] Run /init as init process
[   10.022473] Root device found: mmcblk0p1
[   10.023098] Found dev node: /dev/mmcblk0p1
[   10.128347] EXT4-fs (mmcblk0p1): 4 orphan inodes deleted
[   10.128522] EXT4-fs (mmcblk0p1): recovery complete
[   10.132134] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[   10.133229] Rootfs mounted over mmcblk0p1
[   10.145082] Switching from initrd to actual rootfs
[   10.244086] systemd[1]: System time before build time, advancing clock.
[   10.303802] systemd[1]: systemd 245.4-4ubuntu3.17 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +K)
[   10.304855] systemd[1]: Detected architecture arm64.
[   10.326971] systemd[1]: Set hostname to <nvidia-orin>.
[   10.498297] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[   10.498715] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[   10.499967] systemd[1]: Created slice system-modprobe.slice.
[   10.500637] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   10.501213] systemd[1]: Created slice User and Session Slice.
[   10.501505] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   10.502012] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   10.502383] systemd[1]: Reached target User and Group Name Lookups.
[   10.502624] systemd[1]: Reached target Slices.
[   10.502812] systemd[1]: Reached target Swap.
[   10.503202] systemd[1]: Listening on RPCbind Server Activation Socket.
[   10.503556] systemd[1]: Listening on Syslog Socket.
[   10.503852] systemd[1]: Listening on fsck to fsckd communication Socket.
[   10.504147] systemd[1]: Listening on initctl Compatibility Named Pipe.
[   10.504591] systemd[1]: Listening on Journal Audit Socket.
[   10.507943] systemd[1]: Listening on Journal Socket (/dev/log).
[   10.514042] systemd[1]: Listening on Journal Socket.
[   10.519035] systemd[1]: Listening on udev Control Socket.
[   10.524479] systemd[1]: Listening on udev Kernel Socket.
[   10.531009] systemd[1]: Mounting Huge Pages File System...
[   10.536476] systemd[1]: Mounting POSIX Message Queue File System...
[   10.542669] systemd[1]: Mounting RPC Pipe File System...
[   10.548091] systemd[1]: Mounting Kernel Debug File System...
[   10.553857] systemd[1]: Mounting Kernel Trace File System...
[   10.559797] systemd[1]: Starting Journal Service...
[   10.564615] systemd[1]: Starting Set the console keyboard layout...
[   10.570745] systemd[1]: Starting Create list of static device nodes for the current kernel...
[   10.578427] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[   10.587786] systemd[1]: Starting NVIDIA specific first-boot udev script...
[   10.594848] systemd[1]: Started Nameserver information manager.
[   10.599914] systemd[1]: Reached target Network (Pre).
[   10.606829] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   10.613806] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[   10.624849] systemd[1]: Starting Load Kernel Modules...
[   10.629201] systemd[1]: Starting Remount Root and Kernel File Systems...
[   10.635859] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[   10.635927] systemd[1]: Starting udev Coldplug all Devices...
[   10.647563] systemd[1]: Mounted Huge Pages File System.
[   10.651433] systemd[1]: Started Journal Service.
[   10.700449] systemd-journald[275]: Received client request to flush runtime journal.
[   10.733008] nvmap_heap_init: nvmap_heap_init: created heap block cache
[   10.733294] tegra-carveouts tegra-carveouts: fsi :dma coherent mem declare 0x000000042f000000,16777216
[   10.733604] tegra-carveouts tegra-carveouts: assigned reserved memory node fsi-carveout
[   10.733846] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x0000000449800000,914358272
[   10.733848] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[   10.733852] nvmap_page_pool_init: Total RAM pages: 3694840
[   10.733853] nvmap_page_pool_init: nvmap page pool size: 461855 pages (1804 MB)
[   10.733919] nvmap_background_zero_thread: PP zeroing thread starting.
[   10.734011] misc nvmap: created heap vpr base 0x0000000449800000 size (892928KiB)
[   10.737384] misc nvmap: created heap fsi base 0x000000042f000000 size (16384KiB)
[   12.255408] spi-tegra114 3210000.spi: Adding to iommu group 3
[   12.271804] spi-tegra114 3230000.spi: Adding to iommu group 3
[   12.305216] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
[   12.314373] irq: IRQ300: trimming hierarchy from :pmc@c360000
[   12.314589] nct1008_nct72 4-004c: starting parse dt
[   12.314798] nct1008_nct72 4-004c: !!!Found deprecated property!!!
[   12.314997] nct1008_nct72 4-004c: success parsing dt
[   12.315254] nct1008_nct72 4-004c: success in enabling tmp451 VDD rail
[   12.351751] nct1008_nct72 4-004c: LOC shutdown limit 107
[   12.352572] nct1008_nct72 4-004c: EXT shutdown limit 107
[   12.389606] nct1008_nct72 4-004c: initial LOC temp: 27000
[   12.390310] nct1008_nct72 4-004c: initial EXT temp: 29000
[   12.391456] nct1008_nct72 4-004c: hi_b:-4, lo_b:0
[   12.392373] nct1008_nct72 4-004c: nct1008_probe: initialized
[   12.601917] nvadsp 2993000.adsp: Adding to iommu group 54
[   12.602235] nvadsp 2993000.adsp: in probe()...
[   12.602936] nvadsp 2993000.adsp: nvadsp_app_module_probe
[   12.621002] qspi_mtd spi6.0: MX25U51279G (65536 Kbytes)
[   12.621166] qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x4000000 (64MiB) .erasesize = 0x00010000 (64KiB) .numeraseregions = 0
[   12.750204] irq: IRQ302: trimming hierarchy from :pmc@c360000
[   12.757762] tegra-asoc: sound: Adding to iommu group 54
[   12.780018] OF: graph: no port node found in /i2c@c240000/ucsi_ccg@8/connector@0
[   12.780276] ucsi_ccg 1-0008: Port-0: no role switch found
[   12.780711] gpio gpiochip0: (tegra234-gpio): gpiochip_lock_as_irq: tried to flag a GPIO set as output for IRQ
[   12.781017] gpio gpiochip0: (tegra234-gpio): unable to lock HW IRQ 126 for IRQ
[   12.781235] genirq: Failed to request resources for 1-0008 (irq 302) on irqchip gpio
[   12.781475] ucsi_ccg 1-0008: request_threaded_irq failed - -5
[   12.782283] ucsi_ccg: probe of 1-0008 failed with error -5
[   12.863638] tegra210-adsp aconnect@2a41000:adsp_audio: Adding to iommu group 54
[   12.863895] tegra210_adsp_audio_probe: platform probe started
[   12.864410] tegra210-adsp tegra210-adsp: Default param-type to BYTE for mp3-dec1
[   12.864888] tegra210-adsp tegra210-adsp: Default param-type to BYTE for spkprot
[   12.865385] tegra210-adsp tegra210-adsp: Default param-type to BYTE for src
[   12.865834] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aac-dec1
[   12.866290] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aec
[   12.866719] tegra210-adsp tegra210-adsp: Default param-type to BYTE for wire
[   12.866911] tegra210-adsp tegra210-adsp: adma channel page address dt entry not found
[   12.867123] tegra210-adsp tegra210-adsp: using adma channel page 0
[   12.867354] nvadsp 2993000.adsp: ADSP OS firmware already loaded
[   12.868383] tegra-hda 3510000.hda: Adding to iommu group 55
[   12.919370] 1 fixed-partitions partitions found on MTD device spi6.0
[   12.919566] Creating 1 MTD partitions on "spi6.0":
[   12.919708] 0x000000000000-0x000004000000 : "Whole_flash0"
[   12.948868] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=3 as /devices/platform/3510000.hda/sound/card0/input1
[   12.949252] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=7 as /devices/platform/3510000.hda/sound/card0/input2
[   12.949613] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=8 as /devices/platform/3510000.hda/sound/card0/input3
[   12.949951] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=9 as /devices/platform/3510000.hda/sound/card0/input4
[   12.957250] usbcore: registered new interface driver btusb
[   13.012027] cryptd: max_cpu_qlen set to 1000
[   13.018477] usbcore: registered new interface driver rtk_btusb
[   13.019523] rtk_btusb: chip type value: 0x73
[   13.031449] rtk_btusb: config filename rtl8822cu_config
[   13.057695] rtk_btusb: Config file length 6, new length 6
[   13.087370] rtl88x2ce 0001:01:00.0: Adding to iommu group 9
[   13.087927] rtl88x2ce 0001:01:00.0: enabling device (0000 -> 0003)
[   13.205945] tegra210-adsp tegra210-adsp: Loaded app wire
[   13.206152] tegra210-adsp tegra210-adsp: Loaded app apm
[   13.206303] tegra210-adsp tegra210-adsp: Loaded app adma
[   13.206483] tegra210-adsp tegra210-adsp: Loaded app adma_tx
[   13.206667] nvadsp_set_adma_dump_reg: callback for adma reg dump is sent to 00000000d5b0dbe5
[   13.232193] tegra210-adsp tegra210-adsp: Tegra210 ADSP driver successfully registered
[   13.251453] rtk_btusb: btusb_open set HCI_RUNNING
[   13.251660] rtk_btcoex: Open BTCOEX
[   14.398839] nvgpu: 17000000.ga10b          nvgpu_nvhost_syncpt_init:135  [INFO]  syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[   14.398839]
[   14.565954] using random self ethernet address
[   14.566102] using random host ethernet address
[   15.165482] using random self ethernet address
[   15.165632] using random host ethernet address
[   18.401507] Bridge firewalling registered
Ubuntu 20.04.4 LTS nvidia-orin ttyTCU0
nvidia-orin login:
How you dumped the log is correct. But I need the log during flash error. Not the timing when you boot.
There is no output to the serial console after I put the Orin into recovery mode, even when flashing.
Sorry for more questions here
  1. I think your are using a ubuntu20.04 host as your flash pc , right?
  2. Do you have any other jetson (Orin/Xavier) on your side that you can flash and check if that host really can flash any jetson devices?
And one extra issue.
When you hit flash error, is your host side kernel log (dmesg) showing any new error?
  1. Yes, I’m running Ubuntu 20.04 natively (no VM)
  2. Perhaps, I will have to see if one is free
  3. In dmesg, no new error occurs when running the flashing tool but when looking at the log, there are USB errors sometimes (doesn’t always happen when I re-plug the USB port). I’ve already tried a couple different cables so I don’t think it’s a problem with the cable :
[259570.916064] usb 3-11: new full-speed USB device number 53 using xhci_hcd
[259571.066849] usb 3-11: New USB device found, idVendor=0955, idProduct=7045, bcdDevice= 0.01
[259571.066851] usb 3-11: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[259571.066852] usb 3-11: Product: Tegra On-Platform Operator
[259571.066853] usb 3-11: Manufacturer: NVIDIA
[259571.066854] usb 3-11: SerialNumber: TOPO5491A4BF
[259571.076043] hid-generic 0003:0955:7045.0021: hiddev2,hidraw6: USB HID v1.10 Device [NVIDIA Tegra On-Platform Operator] on usb-0000:00:14.0-11/input0
[259571.076360] cdc_acm 3-11:1.1: ttyACM0: USB ACM device
[259571.076633] cdc_acm 3-11:1.3: ttyACM1: USB ACM device
[259571.076908] cdc_acm 3-11:1.5: ttyACM2: USB ACM device
[259571.077196] cdc_acm 3-11:1.7: ttyACM3: USB ACM device
[260004.585537] wlp147s0: Limiting TX power to 11 dBm as advertised by 0c:d9:96:01:09:fe
[260263.207497] usb usb4-port2: config error
[260267.279498] usb usb4-port2: Cannot enable. Maybe the USB cable is bad?
[260271.767550] usb usb4-port2: Cannot enable. Maybe the USB cable is bad?
[260271.767585] usb usb4-port2: config error
[260275.839560] usb usb4-port2: Cannot enable. Maybe the USB cable is bad?
[260280.327587] usb usb4-port2: Cannot enable. Maybe the USB cable is bad?
[260284.815627] usb usb4-port2: Cannot enable. Maybe the USB cable is bad?
[260562.324915] usb 3-13: new high-speed USB device number 54 using xhci_hcd
[260562.474241] usb 3-13: New USB device found, idVendor=0955, idProduct=7023, bcdDevice= 4.01
[260562.474245] usb 3-13: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[260562.474246] usb 3-13: Product: APX
[260562.474247] usb 3-13: Manufacturer: NVIDIA Corp.
[260655.470067] usb 3-13: USB disconnect, device number 54
[260665.425420] usb usb4-port2: config error
[260669.497407] usb usb4-port2: Cannot enable. Maybe the USB cable is bad?
[260673.941466] usb usb4-port2: Cannot enable. Maybe the USB cable is bad?
[260673.941505] usb usb4-port2: config error
[260678.013445] usb usb4-port2: Cannot enable. Maybe the USB cable is bad?
[260682.501472] usb usb4-port2: Cannot enable. Maybe the USB cable is bad?
[260686.945488] usb usb4-port2: Cannot enable. Maybe the USB cable is bad?
[260740.309717] usb 3-13: new high-speed USB device number 55 using xhci_hcd
[260740.458801] usb 3-13: New USB device found, idVendor=0955, idProduct=7023, bcdDevice= 4.01
[260740.458805] usb 3-13: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[260740.458806] usb 3-13: Product: APX
[260740.458807] usb 3-13: Manufacturer: NVIDIA Corp.
[260846.799061] audit: type=1326 audit(1669651322.807:215): auid=1000 uid=1000 gid=1000 ses=3 subj=snap.slack.slack pid=4732 comm="slack" exe="/snap/slack/67/usr/lib/slack/slack" sig=0 arch=c000003e syscall=92 compat=0 ip=0x7fdb2119c3b7 code=0x50000
[260997.355663] audit: type=1326 audit(1669651473.366:216): auid=1000 uid=1000 gid=1000 ses=3 subj=snap.slack.slack pid=4732 comm="slack" exe="/snap/slack/67/usr/lib/slack/slack" sig=0 arch=c000003e syscall=92 compat=0 ip=0x7fdb2119c3b7 code=0x50000
[261076.075813] audit: type=1326 audit(1669651552.086:217): auid=1000 uid=1000 gid=1000 ses=3 subj=snap.slack.slack pid=4732 comm="slack" exe="/snap/slack/67/usr/lib/slack/slack" sig=0 arch=c000003e syscall=92 compat=0 ip=0x7fdb2119c3b7 code=0x50000
[261101.315710] audit: type=1326 audit(1669651577.326:218): auid=1000 uid=1000 gid=1000 ses=3 subj=snap.slack.slack pid=4732 comm="slack" exe="/snap/slack/67/usr/lib/slack/slack" sig=0 arch=c000003e syscall=92 compat=0 ip=0x7fdb2119c3b7 code=0x50000
[261133.319720] audit: type=1326 audit(1669651609.330:219): auid=1000 uid=1000 gid=1000 ses=3 subj=snap.slack.slack pid=4732 comm="slack" exe="/snap/slack/67/usr/lib/slack/slack" sig=0 arch=c000003e syscall=92 compat=0 ip=0x7fdb2119c3b7 code=0x50000
Is this ubuntu 20.04 or 20.04.5?
Ubuntu 20.04.5
$ lsb_release -a
No LSB modules are available.
Distributor ID:	Ubuntu
Description:	Ubuntu 20.04.5 LTS
Release:	20.04
Codename:	focal
$ uname -a
Linux flir-Precision-7560 5.14.0-1054-oem #61-Ubuntu SMP Fri Oct 14 13:05:50 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
Can you run apt-get update on your host, reboot and test again?
I did try that and it still failed to flash, but using a different computer worked so it’s something to do with my current machine. I’m not sure if you have any other ideas
Hi @guotl321 ,
Yes, we know this is the problem on your host. That was why we suggested to run apt-get update on your host.
Could you share us your linux kernel version of NG and Good host?
Good Host:
Linux autonomy-ai3 5.15.0-56-generic #62-20.04.1-Ubuntu SMP Tue Nov 22 21:24:20
UTC 2022 X86_64 x86_64 x86_64 GNU/Linux
Bad Host:
Thanks for info. It looks like an issue on upstream linux kernel.
We will suggest other users to use your good host kernel version in future.
