JETSON-AGX-ORIN reflash R35.6.0 ‘ERROR: might be timeout in USB write’
我们用的JETSON-AGX-ORIN 32G的CPU,自己定制的底板,JP版本是R35.6.0,用下列命令烧录主板时,报 'ERROR: might be timeout in USB write.'的错误,请求帮助,谢谢,3X
sudo ./flash.sh jetson-agx-orin-devkit mmcblk0p1
[   9.0635 ] BR_CID: 0x80012344705E35DB840000000D028100
[   9.2960 ] Sending bct_br
[   9.2980 ] Sending mb1
[   9.3025 ] Sending psc_bl1
[   9.3365 ] Sending bct_mb1
[   9.3568 ] Boot Rom communication completed
[   9.3569 ] Generating blob for T23x
[   9.3662 ] tegrahost_v2 --chip 0x23 0 --align blob_uefi_jetson_with_dtb_aligned.bin
[   9.3785 ] tegrahost_v2 --chip 0x23 0 --magicid CPBL --ratchet_blob ratchet_blob.bin --appendsigheader blob_uefi_jetson_with_dtb_aligned.bin zerosbk
[   9.3798 ] adding BCH for blob_uefi_jetson_with_dtb_aligned.bin
[   9.4905 ] tegrasign_v3.py --key None --list blob_uefi_jetson_with_dtb_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   9.4908 ] Assuming zero filled SBK key
[   9.5053 ] Warning: pub_key.key is not found
[   9.5055 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_uefi_jetson_with_dtb_aligned_sigheader.bin.encrypt blob_uefi_jetson_with_dtb_aligned_sigheader.bin.hash zerosbk
[   9.5241 ] Get magic id
[   9.5277 ] tegraparser_v2 --get_magic psc_fw
[   9.5304 ] PFWP
[   9.5370 ] partition type psc_fw, magic id = PFWP
[   9.5387 ] tegrahost_v2 --chip 0x23 0 --align blob_pscfw_t234_prod_aligned.bin
[   9.5444 ] tegrahost_v2 --chip 0x23 0 --magicid PFWP --ratchet_blob ratchet_blob.bin --appendsigheader blob_pscfw_t234_prod_aligned.bin zerosbk
[   9.5454 ] Header already present for blob_pscfw_t234_prod_aligned.bin
[   9.5679 ] tegrasign_v3.py --key None --list blob_pscfw_t234_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   9.5682 ] Assuming zero filled SBK key
[   9.5829 ] Warning: pub_key.key is not found
[   9.5876 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_pscfw_t234_prod_aligned_sigheader.bin.encrypt blob_pscfw_t234_prod_aligned_sigheader.bin.hash zerosbk
[   9.5973 ] Get magic id
[   9.6004 ] tegraparser_v2 --get_magic mts_mce
[   9.6023 ] MTSM
[   9.6093 ] partition type mts_mce, magic id = MTSM
[   9.6157 ] tegrahost_v2 --chip 0x23 0 --align blob_mce_flash_o10_cr_prod_aligned.bin
[   9.6263 ] tegrahost_v2 --chip 0x23 0 --magicid MTSM --ratchet_blob ratchet_blob.bin --appendsigheader blob_mce_flash_o10_cr_prod_aligned.bin zerosbk
[   9.6278 ] Header already present for blob_mce_flash_o10_cr_prod_aligned.bin
[   9.6384 ] tegrasign_v3.py --key None --list blob_mce_flash_o10_cr_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   9.6386 ] Assuming zero filled SBK key
[   9.6530 ] Warning: pub_key.key is not found
[   9.6548 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_mce_flash_o10_cr_prod_aligned_sigheader.bin.encrypt blob_mce_flash_o10_cr_prod_aligned_sigheader.bin.hash zerosbk
[   9.6616 ] Get magic id
[   9.6629 ] tegraparser_v2 --get_magic mb2_applet
[   9.6642 ] MB2A
[   9.6689 ] partition type mb2_applet, magic id = MB2A
[   9.6712 ] tegrahost_v2 --chip 0x23 0 --align blob_applet_t234_aligned.bin
[   9.6881 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --ratchet_blob ratchet_blob.bin --appendsigheader blob_applet_t234_aligned.bin zerosbk
[   9.6893 ] adding BCH for blob_applet_t234_aligned.bin
[   9.7107 ] tegrasign_v3.py --key None --list blob_applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   9.7109 ] Assuming zero filled SBK key
[   9.7201 ] Warning: pub_key.key is not found
[   9.7207 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_applet_t234_aligned_sigheader.bin.encrypt blob_applet_t234_aligned_sigheader.bin.hash zerosbk
[   9.7307 ] Generating recovery mb2-bct
[   9.7308 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_bct.cfg --recov --mb2bctcfg tegra234-mb2-bct-misc-p3701-0000_cpp.dtb --scr tegra234-mb2-bct-scr-p3701-0000_cpp.dtb
[   9.7319 ] ERROR: value 0x31 is out of range
[   9.7382 ] ERROR: value 0x31 is out of range
[   9.7388 ] ERROR: value 0x31 is out of range
[   9.7394 ] ERROR: value 0x31 is out of range
[   9.7401 ] WARNING: unknown property 'tfc_version'
[   9.7428 ] WARNING: unknown property 'addr_header_version'
[   9.7691 ] Updating mb2-bct with storage information
[   9.7728 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_bct_MB2.bct --updatestorageinfo flash.xml.bin
[   9.7851 ] Concatenating mb2-bct to mb2 binary
[   9.7852 ] mb2_bin_file = mb2_t234.bin
[   9.7852 ] mb2_bct_file = mb2_bct_MB2.bct
[   9.7858 ] Get magic id
[   9.7871 ] tegraparser_v2 --get_magic mb2_bootloader
[   9.7881 ] MB2B
[   9.7930 ] partition type mb2_bootloader, magic id = MB2B
[   9.7948 ] tegrahost_v2 --chip 0x23 0 --align blob_mb2_t234_with_mb2_bct_MB2_aligned.bin
[   9.8108 ] tegrahost_v2 --chip 0x23 0 --magicid MB2B --ratchet_blob ratchet_blob.bin --appendsigheader blob_mb2_t234_with_mb2_bct_MB2_aligned.bin zerosbk
[   9.8123 ] adding BCH for blob_mb2_t234_with_mb2_bct_MB2_aligned.bin
[   9.8437 ] tegrasign_v3.py --key None --list blob_mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   9.8440 ] Assuming zero filled SBK key
[   9.8590 ] Warning: pub_key.key is not found
[   9.8591 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin.encrypt blob_mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin.hash zerosbk
[   9.8739 ] Get magic id
[   9.8753 ] tegraparser_v2 --get_magic xusb_fw
[   9.8766 ] XUSB
[   9.8811 ] partition type xusb_fw, magic id = XUSB
[   9.8825 ] tegrahost_v2 --chip 0x23 0 --align blob_xusb_t234_prod_aligned.bin
[   9.8898 ] tegrahost_v2 --chip 0x23 0 --magicid XUSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_xusb_t234_prod_aligned.bin zerosbk
[   9.8970 ] adding BCH for blob_xusb_t234_prod_aligned.bin
[   9.9145 ] tegrasign_v3.py --key None --list blob_xusb_t234_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   9.9147 ] Assuming zero filled SBK key
[   9.9229 ] Warning: pub_key.key is not found
[   9.9289 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_xusb_t234_prod_aligned_sigheader.bin.encrypt blob_xusb_t234_prod_aligned_sigheader.bin.hash zerosbk
[   9.9414 ] Kernel DTB used: kernel_tegra234-p3701-0000-p3737-0000.dtb
[   9.9415 ] Concatenating kernel-dtb to dce-fw binary
[   9.9415 ] dce_bin = display-t234-dce.bin
[   9.9416 ] kernel_dtb = kernel_tegra234-p3701-0000-p3737-0000.dtb
[   9.9416 ] dce_with_dtb = display-t234-dce_with_kernel_tegra234-p3701-0000-p3737-0000.bin
[   9.9617 ] Get magic id
[   9.9653 ] tegraparser_v2 --get_magic dce_fw
[   9.9666 ] DCEF
[   9.9728 ] partition type dce_fw, magic id = DCEF
[   9.9816 ] tegrahost_v2 --chip 0x23 0 --align blob_display-t234-dce_with_kernel_tegra234-p3701-0000-p3737-0000_aligned.bin
[   9.9967 ] tegrahost_v2 --chip 0x23 0 --magicid DCEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_display-t234-dce_with_kernel_tegra234-p3701-0000-p3737-0000_aligned.bin zerosbk
[   9.9980 ] adding BCH for blob_display-t234-dce_with_kernel_tegra234-p3701-0000-p3737-0000_aligned.bin
[  10.2905 ] tegrasign_v3.py --key None --list blob_display-t234-dce_with_kernel_tegra234-p3701-0000-p3737-0000_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[  10.2907 ] Assuming zero filled SBK key
[  10.3162 ] Warning: pub_key.key is not found
[  10.3232 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_display-t234-dce_with_kernel_tegra234-p3701-0000-p3737-0000_aligned_sigheader.bin.encrypt blob_display-t234-dce_with_kernel_tegra234-p3701-0000-p3737-0000_aligned_sigheader.bin.hash zerosbk
[  10.3645 ] Get magic id
[  10.3658 ] tegraparser_v2 --get_magic nvdec
[  10.3668 ] NDEC
[  10.3729 ] partition type nvdec, magic id = NDEC
[  10.3745 ] tegrahost_v2 --chip 0x23 0 --align blob_nvdec_t234_prod_aligned.fw
[  10.3892 ] tegrahost_v2 --chip 0x23 0 --magicid NDEC --ratchet_blob ratchet_blob.bin --appendsigheader blob_nvdec_t234_prod_aligned.fw zerosbk
[  10.3908 ] Header already present for blob_nvdec_t234_prod_aligned.fw
[  10.4027 ] tegrasign_v3.py --key None --list blob_nvdec_t234_prod_aligned_sigheader.fw_list.xml --pubkeyhash pub_key.key --sha sha512
[  10.4029 ] Assuming zero filled SBK key
[  10.4165 ] Warning: pub_key.key is not found
[  10.4169 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_nvdec_t234_prod_aligned_sigheader.fw.encrypt blob_nvdec_t234_prod_aligned_sigheader.fw.hash zerosbk
[  10.4295 ] Get magic id
[  10.4310 ] tegraparser_v2 --get_magic bpmp_fw
[  10.4322 ] BPMF
[  10.4368 ] partition type bpmp_fw, magic id = BPMF
[  10.4397 ] tegrahost_v2 --chip 0x23 0 --align blob_bpmp_t234-TE992M-A1_prod_aligned.bin
[  10.4576 ] tegrahost_v2 --chip 0x23 0 --magicid BPMF --ratchet_blob ratchet_blob.bin --appendsigheader blob_bpmp_t234-TE992M-A1_prod_aligned.bin zerosbk
[  10.4590 ] Header already present for blob_bpmp_t234-TE992M-A1_prod_aligned.bin
[  10.4944 ] tegrasign_v3.py --key None --list blob_bpmp_t234-TE992M-A1_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[  10.4947 ] Assuming zero filled SBK key
[  10.5036 ] Warning: pub_key.key is not found
[  10.5037 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_bpmp_t234-TE992M-A1_prod_aligned_sigheader.bin.encrypt blob_bpmp_t234-TE992M-A1_prod_aligned_sigheader.bin.hash zerosbk
[  10.5217 ] Using bpmp-dtb concatenated with odmdata in blob
[  10.5225 ] Get magic id
[  10.5254 ] tegraparser_v2 --get_magic bpmp_fw_dtb
[  10.5266 ] BPMD
[  10.5330 ] partition type bpmp_fw_dtb, magic id = BPMD
[  10.5346 ] tegrahost_v2 --chip 0x23 0 --align blob_tegra234-bpmp-3701-0000-3737-0000_with_odm_aligned.dtb
[  10.5520 ] tegrahost_v2 --chip 0x23 0 --magicid BPMD --ratchet_blob ratchet_blob.bin --appendsigheader blob_tegra234-bpmp-3701-0000-3737-0000_with_odm_aligned.dtb zerosbk
[  10.5531 ] adding BCH for blob_tegra234-bpmp-3701-0000-3737-0000_with_odm_aligned.dtb
[  10.5795 ] tegrasign_v3.py --key None --list blob_tegra234-bpmp-3701-0000-3737-0000_with_odm_aligned_sigheader.dtb_list.xml --pubkeyhash pub_key.key --sha sha512
[  10.5798 ] Assuming zero filled SBK key
[  10.5871 ] Warning: pub_key.key is not found
[  10.5872 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_tegra234-bpmp-3701-0000-3737-0000_with_odm_aligned_sigheader.dtb.encrypt blob_tegra234-bpmp-3701-0000-3737-0000_with_odm_aligned_sigheader.dtb.hash zerosbk
[  10.6014 ] Get magic id
[  10.6049 ] tegraparser_v2 --get_magic sce_fw
[  10.6068 ] SCEF
[  10.6129 ] partition type sce_fw, magic id = SCEF
[  10.6149 ] tegrahost_v2 --chip 0x23 0 --align blob_camera-rtcpu-sce_aligned.img
[  10.6219 ] tegrahost_v2 --chip 0x23 0 --magicid SCEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_camera-rtcpu-sce_aligned.img zerosbk
[  10.6229 ] adding BCH for blob_camera-rtcpu-sce_aligned.img
[  10.6415 ] tegrasign_v3.py --key None --list blob_camera-rtcpu-sce_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[  10.6418 ] Assuming zero filled SBK key
[  10.6508 ] Warning: pub_key.key is not found
[  10.6509 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_camera-rtcpu-sce_aligned_sigheader.img.encrypt blob_camera-rtcpu-sce_aligned_sigheader.img.hash zerosbk
[  10.6574 ] Get magic id
[  10.6587 ] tegraparser_v2 --get_magic rce_fw
[  10.6663 ] RCEF
[  10.6728 ] partition type rce_fw, magic id = RCEF
[  10.6748 ] tegrahost_v2 --chip 0x23 0 --align blob_camera-rtcpu-t234-rce_aligned.img
[  10.6826 ] tegrahost_v2 --chip 0x23 0 --magicid RCEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_camera-rtcpu-t234-rce_aligned.img zerosbk
[  10.6838 ] adding BCH for blob_camera-rtcpu-t234-rce_aligned.img
[  10.7184 ] tegrasign_v3.py --key None --list blob_camera-rtcpu-t234-rce_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[  10.7187 ] Assuming zero filled SBK key
[  10.7394 ] Warning: pub_key.key is not found
[  10.7397 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_camera-rtcpu-t234-rce_aligned_sigheader.img.encrypt blob_camera-rtcpu-t234-rce_aligned_sigheader.img.hash zerosbk
[  10.7561 ] Get magic id
[  10.7591 ] tegraparser_v2 --get_magic ape_fw
[  10.7608 ] APEF
[  10.7649 ] partition type ape_fw, magic id = APEF
[  10.7668 ] tegrahost_v2 --chip 0x23 0 --align blob_adsp-fw_aligned.bin
[  10.7805 ] tegrahost_v2 --chip 0x23 0 --magicid APEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_adsp-fw_aligned.bin zerosbk
[  10.7845 ] adding BCH for blob_adsp-fw_aligned.bin
[  10.8025 ] tegrasign_v3.py --key None --list blob_adsp-fw_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[  10.8028 ] Assuming zero filled SBK key
[  10.8176 ] Warning: pub_key.key is not found
[  10.8190 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_adsp-fw_aligned_sigheader.bin.encrypt blob_adsp-fw_aligned_sigheader.bin.hash zerosbk
[  10.8254 ] Get magic id
[  10.8266 ] tegraparser_v2 --get_magic spe_fw
[  10.8277 ] SPEF
[  10.8328 ] partition type spe_fw, magic id = SPEF
[  10.8345 ] tegrahost_v2 --chip 0x23 0 --align blob_spe_t234_aligned.bin
[  10.8530 ] tegrahost_v2 --chip 0x23 0 --magicid SPEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_spe_t234_aligned.bin zerosbk
[  10.8560 ] adding BCH for blob_spe_t234_aligned.bin
[  10.8809 ] tegrasign_v3.py --key None --list blob_spe_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[  10.8812 ] Assuming zero filled SBK key
[  10.8904 ] Warning: pub_key.key is not found
[  10.8907 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_spe_t234_aligned_sigheader.bin.encrypt blob_spe_t234_aligned_sigheader.bin.hash zerosbk
[  10.9026 ] Get magic id
[  10.9042 ] tegraparser_v2 --get_magic tos
[  10.9075 ] TOSB
[  10.9129 ] partition type tos, magic id = TOSB
[  10.9153 ] tegrahost_v2 --chip 0x23 0 --align blob_tos-optee_t234_aligned.img
[  10.9227 ] tegrahost_v2 --chip 0x23 0 --magicid TOSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_tos-optee_t234_aligned.img zerosbk
[  10.9239 ] adding BCH for blob_tos-optee_t234_aligned.img
[  10.9826 ] tegrasign_v3.py --key None --list blob_tos-optee_t234_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[  10.9829 ] Assuming zero filled SBK key
[  10.9975 ] Warning: pub_key.key is not found
[  10.9995 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_tos-optee_t234_aligned_sigheader.img.encrypt blob_tos-optee_t234_aligned_sigheader.img.hash zerosbk
[  11.0100 ] Get magic id
[  11.0113 ] tegraparser_v2 --get_magic eks
[  11.0124 ] EKSB
[  11.0170 ] partition type eks, magic id = EKSB
[  11.0190 ] tegrahost_v2 --chip 0x23 0 --align blob_eks_t234_aligned.img
[  11.0322 ] tegrahost_v2 --chip 0x23 0 --magicid EKSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_eks_t234_aligned.img zerosbk
[  11.0336 ] adding BCH for blob_eks_t234_aligned.img
[  11.0424 ] tegrasign_v3.py --key None --list blob_eks_t234_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[  11.0426 ] Assuming zero filled SBK key
[  11.0506 ] Warning: pub_key.key is not found
[  11.0528 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_eks_t234_aligned_sigheader.img.encrypt blob_eks_t234_aligned_sigheader.img.hash zerosbk
[  11.0671 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[  11.0683 ] The number of images in blob is 16
[  11.0691 ] blobsize is 18733024
[  11.0694 ] Added binary blob_uefi_jetson_with_dtb_sigheader.bin.encrypt of size 3354688
[  11.0801 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 375168
[  11.0901 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 190592
[  11.0915 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 277312
[  11.0927 ] Not supported type: mb2_applet
[  11.0932 ] Added binary blob_mb2_t234_with_mb2_bct_MB2_sigheader.bin.encrypt of size 437264
[  11.0949 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164864
[  11.0978 ] Added binary blob_display-t234-dce_with_kernel_tegra234-p3701-0000-p3737-0000_sigheader.bin.encrypt of size 9536224
[  11.1072 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[  11.1099 ] Added binary blob_bpmp_t234-TE992M-A1_prod_sigheader.bin.encrypt of size 1046080
[  11.1117 ] Added binary blob_tegra234-bpmp-3701-0000-3737-0000_with_odm_sigheader.dtb.encrypt of size 379840
[  11.1192 ] Added binary blob_camera-rtcpu-sce_sigheader.img.encrypt of size 166304
[  11.1204 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 540000
[  11.1220 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 401008
[  11.1258 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[  11.1269 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1288096
[  11.1298 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[  11.1568 ] Sending membct and RCM blob
[  11.1589 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[  11.1603 ] BL: version 1.4.0.4-t234-54845784-e89ea9bc last_boot_error: 0
[  11.1618 ] Sending bct_mem
[  11.1625 ] Sending blob
[  11.2291 ] ERROR: might be timeout in USB write.
Error: Return value 3
Command tegrarcm_v2 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
Failed flashing t186ref.
serial console log 串口日志是
[0166.459] W> RATCHET: MB1 binary ratchet value 1 is larger than ratchet level 0 from HW fuses.
[0166.467] I> MB1 (version: 1.4.0.4-t234-54845784-e89ea9bc)
[0166.472] I> t234-A01-0-Silicon (0x12347) Prod
[0166.477] I> Boot-mode : Coldboot
[0166.480] I> Entry timestamp: 0x00000000
[0166.484] I> last_boot_error: 0x0
[0166.487] I> BR-BCT: preprod_dev_sign: 0
[0166.491] I> rst_source: 0x0, rst_level: 0x0
[0166.495] I> Task: SE error check
[0166.498] I> Task: Bootchain select WAR set
[0166.502] I> Task: Enable SLCG
[0166.505] I> Task: CRC check
[0166.507] I> Skip FUSE records CRC check as records_integrity fuse is not burned
[0166.515] I> Task: Initialize MB2 params
[0166.519] I> MB2-params @ 0x40060000
[0166.522] I> Task: Crypto init
[0166.525] I> Task: Perform MB1 KAT tests
[0166.529] I> Task: NVRNG health check
[0166.533] I> NVRNG: Health check success
[0166.537] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0166.543] I> Task: Enabling and initialization of Bandwidth limiter
[0166.549] I> No request to configure MBWT settings for any PC!
[0166.554] I> Task: Secure debug controls
[0166.558] I> Task: strap war set
[0166.561] I> Task: Initialize SOC Therm
[0166.565] I> Task: Program NV master stream id
[0166.569] I> Task: Verify boot mode
[0166.575] I> Task: Alias fuses
[0166.578] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0166.585] I> Task: Print SKU type
[0166.589] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000000
[0166.594] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[0166.598] I> FUSE_OPT_TPC_DISABLE = 0x00000000
[0166.602] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0166.607] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0166.611] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0166.615] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0166.620] I> FUSE_OPT_FSI_DISABLE = 0x00000000
[0166.624] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0166.628] I> FUSE_BOOTROM_PATCH_VERSION = 0x3
[0166.633] I> FUSE_PSCROM_PATCH_VERSION = 0x3
[0166.637] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x1
[0166.641] I> FUSE_SKU_INFO_0 = 0x90
[0166.644] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x1 CS
[0166.648] I> FUSE_PACKAGE_INFO_0 = 0x1
[0166.652] I> SKU: Prod
[0166.654] I> Task: Boost clocks
[0166.657] I> Initializing PLLC2 for AXI_CBB.
[0166.661] I> AXI_CBB : src = 35, divisor = 0
[0166.666] I> Task: Voltage monitor
[0166.669] I> VMON: Vmon re-calibration and fine tuning done
[0166.674] I> Task: UPHY init
[0166.679] I> HSIO UPHY init done
[0166.682] W> Skipping GBE UPHY config
[0166.686] I> Task: Boot device init
[0166.689] I> Boot_device: RCM
[0166.692] I> USB configuration success
[0168.248] I> Task: TSC init
[0168.251] I> Task: Load membct
[0168.254] I> RAM_CODE 0x4000001
[0168.257] I> Loading MEMBCT
[0168.259] I> Slot: 0
[0168.261] I> Binary[0] block-0 (partition size: 0x40000)
[0168.267] I> Binary name: MEM-BCT-0
[0168.270] I> Size of crypto header is 8192
[0168.274] I> Size of crypto header is 8192
[0168.278] I> BCH of MEM-BCT-0 read from storage
[0168.282] I> BCH address is : 0x40050000
[0168.286] I> MEM-BCT-0 header integrity check is success
[0168.291] I> Binary magic in BCH component 0 is MEM0
[0168.296] I> component binary type is 0
[0168.306] I> MEM-BCT-0 binary is read from storage
[0168.311] I> MEM-BCT-0 binary integrity check is success
[0168.316] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0168.322] I> RAM_CODE 0x4000001
[0168.328] I> RAM_CODE 0x4000001
[0168.331] I> Task: Load Page retirement list
[0168.336] I> Task: SDRAM params override
[0168.339] I> Task: Save mem-bct info
[0168.343] I> Task: Carveout allocate
[0168.346] I> Update CCPLEX IST carveout from MB1-BCT
[0168.351] I> ECC region[0]: Start:0x0, End:0x0
[0168.355] I> ECC region[1]: Start:0x0, End:0x0
[0168.360] I> ECC region[2]: Start:0x0, End:0x0
[0168.364] I> ECC region[3]: Start:0x0, End:0x0
[0168.368] I> ECC region[4]: Start:0x0, End:0x0
[0168.372] I> Non-ECC region[0]: Start:0x80000000, End:0x880000000
[0168.378] I> Non-ECC region[1]: Start:0x0, End:0x0
[0168.383] I> Non-ECC region[2]: Start:0x0, End:0x0
[0168.388] I> Non-ECC region[3]: Start:0x0, End:0x0
[0168.392] I> Non-ECC region[4]: Start:0x0, End:0x0
[0168.403] I> allocated(CO:44) base:0x849800000 size:0x36800000 align: 0x100000
[0168.410] I> allocated(CO:31) base:0x840000000 size:0x8000000 align: 0x8000000
[0168.417] I> allocated(CO:43) base:0x83c000000 size:0x4000000 align: 0x200000
[0168.424] I> allocated(CO:39) base:0x839e00000 size:0x2200000 align: 0x10000
[0168.431] I> allocated(CO:20) base:0x836000000 size:0x2000000 align: 0x2000000
[0168.438] I> allocated(CO:24) base:0x834000000 size:0x2000000 align: 0x2000000
[0168.446] I> allocated(CO:28) base:0x832000000 size:0x2000000 align: 0x2000000
[0168.453] I> allocated(CO:29) base:0x830000000 size:0x2000000 align: 0x2000000
[0168.460] I> allocated(CO:22) base:0x848000000 size:0x1000000 align: 0x1000000
[0168.467] I> allocated(CO:41) base:0x838e00000 size:0x1000000 align: 0x100000
[0168.474] I> allocated(CO:35) base:0x838000000 size:0xe00000 align: 0x10000
[0168.481] I> allocated(CO:02) base:0x849000000 size:0x800000 align: 0x800000
[0168.488] I> allocated(CO:03) base:0x82f800000 size:0x800000 align: 0x800000
[0168.495] I> allocated(CO:06) base:0x82f000000 size:0x800000 align: 0x800000
[0168.502] I> allocated(CO:56) base:0x82e800000 size:0x800000 align: 0x200000
[0168.509] I> allocated(CO:07) base:0x82e400000 size:0x400000 align: 0x400000
[0168.516] I> allocated(CO:33) base:0x82e000000 size:0x400000 align: 0x200000
[0168.523] I> allocated(CO:23) base:0x82de00000 size:0x200000 align: 0x200000
[0168.529] I> allocated(CO:01) base:0x82dd00000 size:0x100000 align: 0x100000
[0168.536] I> allocated(CO:05) base:0x82dc00000 size:0x100000 align: 0x100000
[0168.543] I> allocated(CO:08) base:0x82db00000 size:0x100000 align: 0x100000
[0168.550] I> allocated(CO:09) base:0x82da00000 size:0x100000 align: 0x100000
[0168.557] I> allocated(CO:15) base:0x82d900000 size:0x100000 align: 0x100000
[0168.564] I> allocated(CO:17) base:0x82d800000 size:0x100000 align: 0x100000
[0168.571] I> allocated(CO:27) base:0x82d700000 size:0x100000 align: 0x100000
[0168.578] I> allocated(CO:42) base:0x82d600000 size:0x100000 align: 0x100000
[0168.585] I> allocated(CO:54) base:0x82d580000 size:0x80000 align: 0x80000
[0168.592] I> allocated(CO:34) base:0x82d570000 size:0x10000 align: 0x10000
[0168.599] I> allocated(CO:72) base:0x82d370000 size:0x200000 align: 0x10000
[0168.605] I> allocated(CO:46) base:0x800000000 size:0x20000000 align: 0x20000000
[0168.613] I> allocated(CO:47) base:0x82ce00000 size:0x400000 align: 0x200000
[0168.620] I> allocated(CO:48) base:0x82d350000 size:0x20000 align: 0x10000
[0168.626] I> allocated(CO:69) base:0x82d330000 size:0x20000 align: 0x10000
[0168.633] I> allocated(CO:49) base:0x82d320000 size:0x10000 align: 0x10000
[0168.640] I> allocated(CO:50) base:0x82d310000 size:0x10000 align: 0x10000
[0168.647] I> allocated(CO:52) base:0x82d300000 size:0x10000 align: 0x10000
[0168.654] I> NSDRAM base: 0x80000000, end: 0x82d370000, size: 0x7ad370000
[0168.660] I> Task: Thermal check
[0168.663] I> Using min_chip_limit as min_tmon_limit
[0168.668] I> Using max_chip_limit as max_tmon_limit
[0168.673] I> BCT max_tmon_limit = 105
[0168.676] I> BCT min_tmon_limit = -28
[0168.680] I> BCT max_tmon_limit = 105
[0168.683] I> BCT min_tmon_limit = -28
[0168.687] I> SKU specific max_chip_limit = 125
[0168.691] I> SKU specific min_chip_limit = -43
[0168.695] I> BCT max_chip_limit = 105
[0168.699] I> BCT min_chip_limit = -28
[0168.702] I> enable_soctherm_polling = 0
[0168.706] I> max temp read = 29
[0168.709] I> min temp read = 27
[0168.712] I> Enabling thermtrip
[0168.715] I> Task: Update FSI SCR with thermal fuse data
[0168.720] I> Task: Enable WDT 5th expiry
[0168.724] I> Task: I2C register
[0168.727] I> Task: Set I2C bus freq
[0168.730] I> Task: Reset FSI
[0168.733] I> Task: Pinmux init
[0168.736] I> Task: Prod config init
[0168.740] I> Task: Pad voltage init
[0168.743] I> Task: Prod init
[0168.746] I> Task: Program rst req config reg
[0168.750] I> Task: Common rail init
[0168.754] I> DONE: Thermal config
[0168.757] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
請嘗試 Jetson AGX Orin FAQ 確認是否成功
如果失敗再附上 log 及 serial console log
謝謝
按照做了,还是一样的效果。
sudo -s
echo -1 > /sys/module/usbcore/parameters/autosuspend
reflash其他的模组,是能够成功的;就这个模组失败。
serial console log 全部贴上了,好像没看到失败信息。
没有成功,失败,每次都卡在这里,log就是最上面的贴。
烧其他module还没出现过这种情况。
請嘗試使用這個module在我們的dev kit上,並使用 r36.4.3 來確認是否問題還存在。
謝謝
