USC-C port J40 not working
The flash port J40 on my Jetson AGX Orin Dev kit is not working. Running jetpack version 5.0.2.
I seem to get power from this port, but cannot communicate (usb mouse/keyboard won’t function on this port). I am also unable to flash using the SDK manager on this port. The device is detected, but flashing fails.
This issue seems similar: USB Type-C device mode problems, but I’m not sure how to apply the patch mentioned.
Please download the package and follow the README:
https://developer.nvidia.com/embedded/jetson-linux-r351
agx-orin-a04-overlay-351.tbz2
Thank you for the help. I have followed the steps, but the board fails to flash. I have the host connected to the j40 flash port (beside GPIO pins) and have followed the l4t_quick_start_guide.txt as instructed. The board is in recovery mode and lsusb shows:
Bus 001 Device 007: ID 0955:7023 NVIDIA Corp.
The output of failed flash is below:
$sudo ./flash.sh jetson-agx-orin-devkit mmcblk0p1
L4T BSP Information:
R35 , REVISION: 1.0
Target Board Information:
Name: jetson-agx-orin-devkit, Board Family: t186ref, SoC: Tegra 234,
OpMode: production, Boot Authentication: NS,
Disk encryption: disabled ,
copying emc_fuse_dev_params(/home/integer-tech/patch/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-diag-boot.dts)… done.
copying device_config(/home/integer-tech/patch/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-device-p3701-0000.dts)… done.
copying misc_config(/home/integer-tech/patch/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-misc-p3701-0000.dts)… done.
./tegraflash.py --chip 0x23 --applet “/home/integer-tech/patch/Linux_for_Tegra/bootloader/mb1_t234_prod.bin” --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3701-0000.dts --misc_config tegra234-mb1-bct-misc-p3701-0000.dts --bins “mb2_applet applet_t234.bin” --cmd “dump eeprom cvm cvm.bin; dump custinfo custinfo_out.bin; reboot recovery”
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0113 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.0129 ] File rcm_state open failed
[ 0.0134 ] ERROR: failed to read rcm_state
[ 0.0134 ]
[ 0.0145 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0147 ] Assuming zero filled SBK key
[ 0.0138 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
[ 0.0290 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0000.dts
[ 0.0521 ] Parsing partition layout
[ 0.0545 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0587 ] Parsing partition layout
[ 0.0612 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0640 ] Creating list of images to be signed
[ 0.0664 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[ 0.0687 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0708 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0714 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0851 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0858 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0976 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0982 ] adding BCH for mb2_t234_aligned.bin
[ 0.1047 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.1308 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.1315 ] adding BCH for mb2_t234_aligned.bin
[ 0.1543 ] Generating signatures
[ 0.1555 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1560 ] Assuming zero filled SBK key
[ 0.1826 ] Warning: pub_key.key is not found
[ 0.1822 ] Parsing dev params for multi chains
[ 0.1984 ] Generating br-bct
[ 0.2008 ] Updating dev and MSS params in BR BCT
[ 0.2010 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.2039 ] Updating bl info
[ 0.2062 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.2087 ] WARNING: boot chain is not completed. set to 0
[ 0.2104 ] Get Signed section of bct
[ 0.2128 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 0.2157 ] Signing BCT
[ 0.2169 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.2173 ] Assuming zero filled SBK key
[ 0.2242 ] Sha saved in br_bct_BR.sha
[ 0.2251 ] Warning: pub_key.key is not found
[ 0.2241 ] Updating BCT with signature
[ 0.2264 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 0.2288 ] Offset :4608 Len :3584
[ 0.2295 ] Generating SHA2 Hash
[ 0.2306 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 0.2311 ] Assuming zero filled SBK key
[ 0.2381 ] Sha saved in br_bct_BR.sha
[ 0.2378 ] Updating BCT with SHA2 Hash
[ 0.2401 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 0.2422 ] Offset :4608 Len :3584
[ 0.2428 ] Offset :68 Len :8124
[ 0.2433 ] Generating coldboot mb1-bct
[ 0.2456 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.2477 ] MB1-BCT version: 0.9
[ 0.2528 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.2533 ] Added Platform Config 9 data with size :- 80
[ 0.2533 ]
[ 0.2534 ] Updating mb1-bct with firmware information
[ 0.2556 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.2612 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 0.2660 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 0.2684 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 0.2717 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.2721 ] Assuming zero filled SBK key
[ 0.2762 ] Warning: pub_key.key is not found
[ 0.2778 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.2816 ] Generating recovery mb1-bct
[ 0.2839 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.2863 ] MB1-BCT version: 0.9
[ 0.2914 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.2918 ] Added Platform Config 9 data with size :- 80
[ 0.2918 ]
[ 0.2919 ] Updating mb1-bct with firmware information
[ 0.2943 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.2999 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[ 0.3046 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 0.3068 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 0.3100 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.3104 ] Assuming zero filled SBK key
[ 0.3146 ] Warning: pub_key.key is not found
[ 0.3160 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.3197 ] Error: Skip generating mem_bct because sdram_config is not defined
[ 0.3198 ] Copying signatures
[ 0.3221 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.3356 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.3362 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.3362 ] Boot Rom communication
[ 0.3385 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.3409 ] BR_CID: 0x80012344705DD5002000000007FD81C0
[ 0.4404 ] Sending bct_br
[ 0.5964 ] ERROR: might be timeout in USB write.
Error: Return value 3
Command tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
Reading board information failed.
Sorry for the late response, have you managed to get issue resolved or still need the support? Thanks
I have not. I cannot get the Orin to flash. I have tried from an Ubuntu 20.04 host and an Ubuntu 18.04 host. Both give the error: “ERROR: failed to read rcm_state”.
The Orin is in recovery mode (held the recovery mode button while powering on). lsusb command shows:
The flash attempts to run but fails each time. Not sure what else to try.
Following this thread: Cannot flash OS image to Orin Developer Kit via SDK Manager - Jetson & Embedded Systems / Jetson AGX Orin - NVIDIA Developer Forums and recalculating and setting the 0x50 0xff value did enable the port. I am still unable to flash, but I can connect devices on J40 now. I would prefer to flash and apply the patch correctly.
Please install this:
Cannot flash Orin dev kit with SDK Manager 1.8.0.10363 - #9 by WayneWWW
And run the manual steps:
Cannot flash Orin dev kit with SDK Manager 1.8.0.10363 - #6 by carolyuu
Both the Ubuntu 20.04 and Ubuntu 18.04 hosts already had binutils installed when I ran the command. The flash still fails with the same USB timeout error as above.
Do you have other type-C to type-A cables for a try? Would suggest use another cable to connect Orin developer kit with the host PC. Probably the issue is specific to certain cable.
I have tried several USB-A to USB-C cables and a USB-C to USB-C cable. The Orin is detected with the lsusb command, but flash still fails with: ERROR: might be timeout in USB write.
Changing the 0x50 0xff checksum value mitigates the ERROR: might be timeout in USB write issue, but then I get “parsing board information failed.” I may be calculating the checksum incorrectly. The result of sudo i2cdump -y 0 0x50 is:
No size specified (using byte-data access)
0 1 2 3 4 5 6 7 8 9 a b c d e f 0123456789abcdef
00: 02 00 fe 00 00 00 00 00 00 00 00 00 00 00 00 00 ?.?..
10: 00 00 00 0a 36 39 39 2d 31 33 37 30 31 2d 30 30 …?699-13701-00
20: 30 30 2d 35 30 30 20 4a 2e 30 00 00 00 00 00 00 00-500 J.0…
30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
40: 00 00 00 00 66 86 83 2d b0 48 31 34 32 32 31 32 …f??-?H142212
50: 32 31 30 31 37 36 38 00 00 00 00 00 00 00 00 00 2101768…
60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
90: 00 00 00 00 00 00 4e 56 43 42 00 00 4d 31 00 00 …NVCB…M1…
a0: 00 00 00 00 00 00 00 00 00 00 00 00 66 86 83 2d …f??-
b0: b0 48 0a 00 00 00 00 00 00 00 00 00 00 00 00 00 ?H?..
c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 67 …g
I think the original eeprom value is correct. The “usb timeout” error could be something else.
Could you dump the serial console log during flash failure from uart? (from micro usb port)
Serial console log:
Welcome to minicom 2.7.1
OPTIONS: I18n
Compiled on Aug 13 2017, 15:25:34.
Port /dev/ttyACM0, 12:54:08
Press CTRL-A Z for help on special keys
[0070.079] I> MB1 (version: 0.23.0.0-t234-54845784-92215740)
[0070.084] I> t234-A01-0-Silicon (0x12347) Prod
[0070.088] I> Boot-mode : BPMP Diagnostic
[0070.092] I> Emulation:
[0070.094] I> Entry timestamp: 0x00000000
[0070.098] I> last_boot_error: 0x0
[0070.101] I> BR-BCT: preprod_dev_sign: 0
[0070.105] I> rst_source: 0xb, rst_level: 0x1
[0070.109] I> Task: Crypto init (0x5001c0d9)
[0070.113] I> Task: Secure debug controls (0x5000cb19)
[0070.118] I> Task: strap war set (0x5000b739)
[0070.122] I> strap value(0x4000001) set to 0x4000001
[0070.127] I> Task: Program NV master stream id (0x5000cad1)
[0070.133] I> Task: Verify boot mode (0xd482021)
[0070.139] I> Task: Alias fuses (0x50010749)
[0070.143] E> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0070.150] I> Task: Print SKU type (0x5000fba9)
[0070.154] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000000
[0070.159] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[0070.164] I> FUSE_OPT_TPC_DISABLE = 0x00000000
[0070.168] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0070.172] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0070.176] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0070.181] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0070.185] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0070.189] I> FUSE_SKU_INFO_0 = 0xd0
[0070.192] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0070.196] I> FUSE_PACKAGE_INFO_0 = 0x2
[0070.200] I> SKU: Prod
[0070.202] I> Task: Boost clocks (0x50013db1)
[0070.206] I> Initializing PLLC2 for AXI_CBB.
[0070.210] I> AXI_CBB : src = 35, divisor = 0
[0070.214] I> Task: Voltage monitor (0x50013dbd)
[0070.219] I> VMON: Vmon re-calibration and fine tuning done
[0070.224] I> Task: UPHY init (0x5000da39)
[0070.229] E> UPHY: UPHY lane info table is empty in MB1 BCT.
[0070.234] I> Task: Boot device init (0x50000a3d)
[0070.239] I> Boot_device: RCM
[0070.242] I> USB configuration success
[0070.245] I> Task: TSC init (0x5001ed35)
[0070.249] I> Task: Enable WDT 5th expiry (0x5001f929)
[0070.254] I> Task: Disable WDT globally (0x5001f965)
[0070.259] I> Task: I2C register (0x50000a31)
[0070.263] I> Task: Reset FSI (0x50013db9)
[0070.267] I> Task: Enable clock-mon (0x5001ed25)
[0070.283] I> FMON: Fmon re-programming done
[0070.287] I> Task: MB1 fixed firewalls (0x5001e55d)
[0070.295] I> Task: Load MB2/Applet/FSKP (0x5000d451)
[0070.299] I> Loading MB2 Applet
[0070.302] I> Scratch RSV109: 0x00000000    active chain: 0
[0070.308] I> Slot: 0
[0070.310] I> Binary[21] block-0 (partition size: 0x50000)
[0070.315] I>  get_binary_info: Binary name: MB2-Applet
[0070.320] I> Size of crypto header is 8192
[0070.324] I> BCH load address is : 0x4004e000
[0070.328] I> Size of crypto header is 8192
[0070.332] I> BCH of MB2-Applet read from storage
[0070.337] I> BCH address is : 0x4004e000
[0070.341] I> MB2-Applet header integrity check is success
[0070.346] I> Binary magic in BCH component 0 is MB2A
[0070.351] I> component binary type is 21
[0070.355] I> Size of crypto header is 8192
[0070.367] I> MB2-Applet binary is read from storage
[0070.372] I> MB2-Applet binary integrity check is success
[0070.377] I> Binary MB2-Applet loaded successfully at 0x40000000 (0x41b80)
[0070.384] I> Task: Map CCPLEX SHARED carveout (0x5000d521)
[0070.389] I> Task: Prepare MB2 params (0x5000d5dd)
[0070.394] I> MB2-params @ 0x40060000
[0070.398] I> Region(2) already mapped
[0070.401] E> Failed to map carveout: 50
[0070.405] I> BR-BCT Boot Chain Fields
[0070.409] I>    u32_non_gpio_select_boot_chain  : 0
[0070.413] I>    u32_num_boot_chains             : 0
[0070.418] I>    bf_bl_gpio_select_boot_chain_1b : 0
[0070.423] I> Task: Misc NV security settings (0x5000ced5)
[0070.429] I> NVDEC sticky bits programming done
[0070.433] I> Task: Disable/Reload WDT (0x5001f991)
[0070.438] I> Programmed SLCG global override := 0x0
[0070.442] I> MB1: MSS reconfig completed
I> Applet (version: 0.0.0.0-t234-54845784-dee653cf)
I> Emulation:
I> Entry timestamp: 0xffffffff
I> Task: Pinmux init (0x4000062d)
I> Task: Boot device init (0x400012e5)
I> Applet do storage init
I> Boot_device: QSPI_FLASH instance: 0
I> Qspi clock source : clk_m
I> QSPI-0l initialized successfully
I> sdmmc DDR50 mode
I> sdmmc bdev is already initialized
E> Unknown device 7
E> Unknown device 8
I> Task: Partition Manager Init (0x40002d1d)
I> Found 57 partitions in QSPI_FLASH (instance 0)
W> Cannot find any partition table for 00000003
 > PARTITION_MANAGER: Failed to publish partition.
I> Found 11 partitions in SDMMC_USER (instance 3)
I> Task: I2C register (0x400006a5)
I> Task: Register exit handlers (0x400005f5)
I> Task: Enter 3p server (0x400018e1)
I> Populate chip info
I> RAM_CODE 0x4000001
I> Populate eeprom info
I> Populate eeprom info for module cvm
I> dump bct
I> Rebooting : reboot-recovery
The terminal output from the failed flash:
# L4T BSP Information:
# R35 , REVISION: 1.0
# Target Board Information:
# Name: jetson-agx-orin-devkit, Board Family: t186ref, SoC: Tegra 234,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
copying emc_fuse_dev_params(/home/tristan/Jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-diag-boot.dts)... done.
copying device_config(/home/tristan/Jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-device-p3701-0000.dts)... done.
copying misc_config(/home/tristan/Jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-misc-p3701-0000.dts)... done.
./tegraflash.py --chip 0x23 --applet "/home/tristan/Jetson/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3701-0000.dts --misc_config tegra234-mb1-bct-misc-p3701-0000.dts --bins "mb2_applet applet_t234.bin" --cmd "dump eeprom cvm cvm.bin; dump custinfo custinfo_out.bin; reboot recovery"
version 1.0.0
[   0.0105 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.0117 ] File rcm_state open failed
[   0.0122 ] ERROR: failed to read rcm_state
[   0.0122 ]
[   0.0135 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0139 ] Assuming zero filled SBK key
[   0.0130 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
[   0.0204 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0000.dts
[   0.0322 ] Parsing partition layout
[   0.0338 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.0364 ] Parsing partition layout
[   0.0382 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.0401 ] Creating list of images to be signed
[   0.0416 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[   0.0429 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.0447 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.0454 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.0526 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.0550 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.0609 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.0615 ] adding BCH for mb2_t234_aligned.bin
[   0.0651 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.0819 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.0825 ] adding BCH for mb2_t234_aligned.bin
[   0.1020 ] Generating signatures
[   0.1033 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.1036 ] Assuming zero filled SBK key
[   0.1215 ] Warning: pub_key.key is not found
[   0.1208 ] Parsing dev params for multi chains
[   0.1319 ] Generating br-bct
[   0.1334 ] Updating dev and MSS params in BR BCT
[   0.1336 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.1353 ] Updating bl info
[   0.1367 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.1381 ] WARNING: boot chain is not completed. set to 0
[   0.1406 ] Get Signed section of bct
[   0.1422 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   0.1438 ] Signing BCT
[   0.1450 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.1453 ] Assuming zero filled SBK key
[   0.1500 ] Sha saved in br_bct_BR.sha
[   0.1506 ] Warning: pub_key.key is not found
[   0.1495 ] Updating BCT with signature
[   0.1507 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   0.1518 ] Offset :4608 Len :3584
[   0.1539 ] Generating SHA2 Hash
[   0.1552 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   0.1555 ] Assuming zero filled SBK key
[   0.1556 ] Assuming zero filled SBK key
[   0.1604 ] Sha saved in br_bct_BR.sha
[   0.1599 ] Updating BCT with SHA2 Hash
[   0.1620 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   0.1634 ] Offset :4608 Len :3584
[   0.1639 ] Offset :68 Len :8124
[   0.1667 ] Generating coldboot mb1-bct
[   0.1684 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.1698 ] MB1-BCT version: 0.9
[   0.1720 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.1725 ] Added Platform Config 9 data with size :- 80
[   0.1725 ]
[   0.1726 ] Updating mb1-bct with firmware information
[   0.1740 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.1819 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   0.1849 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   0.1864 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   0.1893 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.1896 ] Assuming zero filled SBK key
[   0.1925 ] Warning: pub_key.key is not found
[   0.1939 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.1965 ] Generating recovery mb1-bct
[   0.1977 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.1989 ] MB1-BCT version: 0.9
[   0.2005 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.2009 ] Added Platform Config 9 data with size :- 80
[   0.2009 ]
[   0.2009 ] Updating mb1-bct with firmware information
[   0.2020 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.2071 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[   0.2103 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   0.2115 ] adding BCH for mb1_bct_MB1_aligned.bct
[   0.2142 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.2145 ] Assuming zero filled SBK key
[   0.2175 ] Warning: pub_key.key is not found
[   0.2180 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.2200 ] Error: Skip generating mem_bct because sdram_config is not defined
[   0.2201 ] Error: Skip generating mem_bct because sdram_config is not defined
[   0.2201 ] Copying signatures
[   0.2213 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.2317 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   0.2320 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   0.2320 ] Boot Rom communication
[   0.2335 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   0.2348 ] BR_CID: 0x80012344705DD5002000000007FD81C0
[   0.2362 ] Sending bct_br
[   0.2363 ] Sending mb1
[   0.2379 ] Sending psc_bl1
[   0.2455 ] Sending bct_mb1
[   0.2515 ] Boot Rom communication completed
[   0.2546 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[   0.2599 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --appendsigheader applet_t234_aligned.bin zerosbk
[   0.2616 ] adding BCH for applet_t234_aligned.bin
[   0.2793 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.2795 ] Assuming zero filled SBK key
[   0.2828 ] Warning: pub_key.key is not found
[   0.2831 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[   0.2869 ] Sending mb2_applet...
[   0.2883 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[   0.2896 ] BL: version 0.23.0.0-t234-54845784-92215740 last_boot_error: 0
[   0.4385 ] Sending applet
[   0.5580 ] completed
[   0.5609 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.5633 ] MB2 Applet version 01.00.0000
[   0.7552 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.7577 ] MB2 Applet version 01.00.0000
[   0.7620 ] Retrieving board information
[   0.7639 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails chip chip_info.bin
[   0.7659 ] MB2 Applet version 01.00.0000
[   0.7688 ] Saved platform info in chip_info.bin
[   0.7740 ] Chip minor revision: 1
[   0.7746 ] Bootrom revision: 0x7
[   0.7746 ] Ram code: 0x0
[   0.7746 ] Chip sku: 0xd0
[   0.7746 ] Chip Sample: prod
[   0.7746 ]
[   0.7751 ] Retrieving EEPROM data
[   0.7752 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/tristan/Jetson/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23 0
[   0.7767 ] MB2 Applet version 01.00.0000
[   0.7799 ] Saved platform info in /home/tristan/Jetson/Linux_for_Tegra/bootloader/cvm.bin
[   0.8163 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.8196 ] MB2 Applet version 01.00.0000
[   0.8246 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.8262 ] MB2 Applet version 01.00.0000
[   0.8287 ] Dumping customer Info
[   0.8305 ] tegrarcm_v2 --chip 0x23 0 --oem dump bct tmp.bct
[   0.8322 ] MB2 Applet version 01.00.0000
[   0.8351 ] Saved bct in tmp.bct
[   0.8436 ] tegrabct_v2 --brbct tmp.bct --chip 0x23 0 --custinfo /home/tristan/Jetson/Linux_for_Tegra/bootloader/custinfo_out.bin
[   0.8452 ] C[   0.8458 ] ustomer data saved in /home/tristan/Jetson/Linux_for_Tegra/bootloader/custinfo_out.bin successfully
[   0.8461 ] Rebooting to recovery mode
[   0.8484 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[   0.8546 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.8562 ] MB2 Applet version 01.00.0000
[   0.8586 ] Booting to recovery mode
[   0.8616 ] tegrarcm_v2 --chip 0x23 0 --reboot recovery
[   0.8639 ] MB2 Applet version 01.00.0000
Parsing board information failed.
Is this log still based on the eeprom change added by you?
It is. The J40 port was not working and lsusb did not detect the Orin prior to changing the eeprom value.
Could you still boot up the device and share the boot up log? If your eeprom value is wrong, then the log shall tell.
I can still boot the device. Does the boot log get stores in /var/log or somewhere else? I’m not seeing a boot.log file in /var/log.
I mean using serial console to capture log and share
Understood. Her is the serial console log during boot:
L4TLauncher: Attempting GRUB Boot
L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map...
��I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
I/TC: Secondary CPU 8 initializing
I/TC: Secondary CPU 8 switching to normal world boot
I/TC: Secondary CPU 9 initializing
I/TC: Secondary CPU 9 switching to normal world boot
I/TC: Secondary CPU 10 initializing
I/TC: Secondary CPU 10 switching to normal world boot
I/TC: Secondary CPU 11 initializing
I/TC: Secondary CPU 11 switching to normal world boot
��[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[    0.000000] Linux version 5.10.104-tegra (buildbrain@mobile-u64-5273-d7000) 2
[    0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[    0.000000] OF: fdt:  - 80000000 ,  c0000000
[    0.000000] Machine model: Jetson AGX Orin
[    0.000000] efi: EFI v2.70 by EDK II
[    0.000000] efi: RTPROP=0x805860318 MEMATTR=0x804430018 ESRT=0x8041c6f98 RNG
[    0.000000] efi: seeding entropy pool
[    0.000000] esrt: Reserving ESRT space from 0x00000008041c6f98 to 0x00000008.
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000817800000, B
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id sharl
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x0000000835ffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000007ffffffff]
[    0.000000]   node   0: [mem 0x0000000800000000-0x00000008021bffff]
[    0.000000]   node   0: [mem 0x00000008021c0000-0x0000000803cb8fff]
[    0.000000]   node   0: [mem 0x0000000803cb9000-0x0000000803e3dfff]
[    0.000000]   node   0: [mem 0x0000000803e3e000-0x00000008043fffff]
[    0.000000]   node   0: [mem 0x0000000804400000-0x000000080441ffff]
[    0.000000]   node   0: [mem 0x0000000804420000-0x000000080443ffff]
[    0.000000]   node   0: [mem 0x0000000804440000-0x000000080445ffff]
[    0.000000]   node   0: [mem 0x0000000804460000-0x00000008045fffff]
[    0.000000]   node   0: [mem 0x0000000804600000-0x00000008046effff]
[    0.000000]   node   0: [mem 0x00000008046f0000-0x000000080470ffff]
[    0.000000]   node   0: [mem 0x0000000804710000-0x00000008049affff]
[    0.000000]   node   0: [mem 0x00000008049b0000-0x00000008049bffff]
[    0.000000]   node   0: [mem 0x00000008049c0000-0x0000000804a5ffff]
[    0.000000]   node   0: [mem 0x0000000804a60000-0x0000000804a6ffff]
[    0.000000]   node   0: [mem 0x0000000804a70000-0x0000000804abffff]
[    0.000000]   node   0: [mem 0x0000000804ac0000-0x0000000804b4ffff]
[    0.000000]   node   0: [mem 0x0000000804b50000-0x0000000804e5ffff]
[    0.000000]   node   0: [mem 0x0000000804e60000-0x0000000804e6ffff]
[    0.000000]   node   0: [mem 0x0000000804e70000-0x0000000804e7ffff]
[    0.000000]   node   0: [mem 0x0000000804e80000-0x0000000804e8ffff]
[    0.000000]   node   0: [mem 0x0000000804e90000-0x0000000804ecffff]
[    0.000000]   node   0: [mem 0x0000000804ed0000-0x000000080535ffff]
[    0.000000]   node   0: [mem 0x0000000805360000-0x00000008053affff]
[    0.000000]   node   0: [mem 0x00000008053b0000-0x00000008053dffff]
[    0.000000]   node   0: [mem 0x00000008053e0000-0x00000008053fffff]
[    0.000000]   node   0: [mem 0x0000000805400000-0x000000080553ffff]
[    0.000000]   node   0: [mem 0x0000000805540000-0x00000008055dffff]
[    0.000000]   node   0: [mem 0x00000008055e0000-0x000000080568ffff]
[    0.000000]   node   0: [mem 0x0000000805690000-0x000000080572ffff]
[    0.000000]   node   0: [mem 0x0000000805730000-0x00000008057bffff]
[    0.000000]   node   0: [mem 0x00000008057c0000-0x000000080585ffff]
[    0.000000]   node   0: [mem 0x0000000805860000-0x000000080612ffff]
[    0.000000]   node   0: [mem 0x0000000806130000-0x000000080630ffff]
[    0.000000]   node   0: [mem 0x0000000806310000-0x00000008278bffff]
[    0.000000]   node   0: [mem 0x00000008278c0000-0x000000082790ffff]
[    0.000000]   node   0: [mem 0x0000000827910000-0x000000082b6affff]
[    0.000000]   node   0: [mem 0x000000082c400000-0x000000082c7fffff]
[    0.000000]   node   0: [mem 0x0000000834000000-0x0000000835ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000835ffffff]
[    0.000000] On node 0, zone Normal: 336 pages in unavailable ranges
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 32 pages/cpu s90136 r8192 d32744 u131072
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] CPU features: detected: Spectre-v4
[    0.000000] alternatives: patching kernel code
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 7925040
[    0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=
[    0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 by)
[    0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 byt)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000effff000-0x00000000fffff0)
[    0.000000] Memory: 30994768K/32205504K available (18432K kernel code, 3172K)
[    0.000000] random: get_random_u64 called from __kmem_cache_create+0x38/0x420
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=12.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 ji.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[    0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[    0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[    0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycless
[    0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398s
[    0.000780] Console: colour dummy device 80x25
[    0.000967] printk: console [tty0] enabled
[    0.001003] Calibrating delay loop (skipped), value calculated using timer f)
[    0.001011] pid_max: default: 32768 minimum: 301
[    0.001071] LSM: Security Framework initializing
[    0.001091] Yama: becoming mindful.
[    0.001108] SELinux:  Initializing.
[    0.001189] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, l)
[    0.001237] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 byt)
[    0.003104] rcu: Hierarchical SRCU implementation.
[    0.003196] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORd
[    0.003782] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.1s
[    0.003790] DTB Build time: Aug 10 2022 20:31:40
[    0.005277] Tegra Revision: A01 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[    0.005401] Remapping and enabling EFI services.
[    0.006637] smp: Bringing up secondary CPUs ...
[    0.035315] Detected PIPT I-cache on CPU1
[    0.035347] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[    0.035376] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[    0.063997] Detected PIPT I-cache on CPU2
[    0.064007] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[    0.064022] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[    0.092602] Detected PIPT I-cache on CPU3
[    0.092610] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[    0.092624] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[    0.123248] Detected PIPT I-cache on CPU4
[    0.123267] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c000
[    0.123292] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[    0.151927] Detected PIPT I-cache on CPU5
[    0.151936] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e000
[    0.151951] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[    0.180546] Detected PIPT I-cache on CPU6
[    0.180557] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f50000
[    0.180571] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[    0.209175] Detected PIPT I-cache on CPU7
[    0.209184] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f52000
[    0.209199] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[    0.239832] Detected PIPT I-cache on CPU8
[    0.239853] GICv3: CPU8: found redistributor 20000 region 0:0x000000000f54000
[    0.239879] CPU8: Booted secondary processor 0x0000020000 [0x410fd421]
[    0.268510] Detected PIPT I-cache on CPU9
[    0.268521] GICv3: CPU9: found redistributor 20100 region 0:0x000000000f56000
[    0.268536] CPU9: Booted secondary processor 0x0000020100 [0x410fd421]
[    0.297751] Detected PIPT I-cache on CPU10
[    0.297762] GICv3: CPU10: found redistributor 20200 region 0:0x000000000f5800
[    0.297777] CPU10: Booted secondary processor 0x0000020200 [0x410fd421]
[    0.326988] Detected PIPT I-cache on CPU11
[    0.326998] GICv3: CPU11: found redistributor 20300 region 0:0x000000000f5a00
[    0.327013] CPU11: Booted secondary processor 0x0000020300 [0x410fd421]
[    0.327065] smp: Brought up 1 node, 12 CPUs
[    0.327132] SMP: Total of 12 processors activated.
[    0.327137] CPU features: detected: Privileged Access Never
[    0.327139] CPU features: detected: LSE atomic instructions
[    0.327142] CPU features: detected: User Access Override
[    0.327145] CPU features: detected: 32-bit EL0 Support
[    0.327148] CPU features: detected: Common not Private translations
[    0.327151] CPU features: detected: RAS Extension Support
[    0.327153] CPU features: detected: Data cache clean to the PoU not requirede
[    0.327157] CPU features: detected: CRC32 instructions
[    0.327159] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.360509] CPU: All CPU(s) started at EL2
[    0.362796] devtmpfs: initialized
[    0.377862] Registered cp15_barrier emulation handler
[    0.377874] Registered setend emulation handler
[    0.377880] KASLR enabled
[    0.377991] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ms
[    0.378005] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[    0.379494] pinctrl core: initialized pinctrl subsystem
[    0.379937] DMI not present or invalid.
[    0.380173] NET: Registered protocol family 16
[    0.380910] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[    0.381110] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic als
[    0.381305] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic s
[    0.381331] audit: initializing netlink subsys (disabled)
[    0.381402] audit: type=2000 audit(0.380:1): state=initialized audit_enabled1
[    0.381554] thermal_sys: Registered thermal governor 'step_wise'
[    0.381556] thermal_sys: Registered thermal governor 'power_allocator'
[    0.381562] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[    0.383632] cpuidle: using governor menu
[    0.383738] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.383854] ASID allocator initialised with 32768 entries
[    0.383940] Serial: AMBA PL011 UART driver
[    0.385582] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[    0.385606] Tegra reboot handler registered.
[    0.403496] mc: mapped MMIO address: 0xffff8000111f0000 -> 0x2c10000
[    0.403511] mc: mapped MMIO address: 0xffff800011210000 -> 0x2c20000
[    0.403519] mc: mapped MMIO address: 0xffff800011230000 -> 0x2c30000
[    0.403525] mc: mapped MMIO address: 0xffff800011250000 -> 0x2c40000
[    0.403531] mc: mapped MMIO address: 0xffff800011270000 -> 0x2c50000
[    0.403537] mc: mapped MMIO address: 0xffff800011290000 -> 0x2b80000
[    0.403546] mc: mapped MMIO address: 0xffff8000112b0000 -> 0x2b90000
[    0.403552] mc: mapped MMIO address: 0xffff8000112d0000 -> 0x2ba0000
[    0.403559] mc: mapped MMIO address: 0xffff8000112f0000 -> 0x2bb0000
[    0.403565] mc: mapped MMIO address: 0xffff800011310000 -> 0x1700000
[    0.403571] mc: mapped MMIO address: 0xffff800011330000 -> 0x1710000
[    0.403577] mc: mapped MMIO address: 0xffff800011350000 -> 0x1720000
[    0.403584] mc: mapped MMIO address: 0xffff800011370000 -> 0x1730000
[    0.403590] mc: mapped MMIO address: 0xffff800011390000 -> 0x1740000
[    0.403596] mc: mapped MMIO address: 0xffff8000113b0000 -> 0x1750000
[    0.403602] mc: mapped MMIO address: 0xffff8000113d0000 -> 0x1760000
[    0.403610] mc: mapped MMIO address: 0xffff8000113f0000 -> 0x1770000
[    0.403622] nv-tegra-mc 2c10000.mc: No mssnvlink node
[    0.403643] mc-err: mcerr ops are set to t23x
[    0.403903] tegra234-cbb 13a00000.cbb-fabric: secure_irq = 21
[    0.403961] tegra234-cbb c600000.aon-fabric: secure_irq = 22
[    0.404001] tegra234-cbb d600000.bpmp-fabric: secure_irq = 23
[    0.404038] tegra234-cbb de00000.dce-fabric: secure_irq = 24
[    0.404077] tegra234-cbb be00000.rce-fabric: secure_irq = 25
[    0.404118] tegra234-cbb b600000.sce-fabric: secure_irq = 26
[    0.404342] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 66, base_baud =A
[    0.408362] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.408369] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.408372] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.408376] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.410080] ACPI: Interpreter disabled.
[    0.411352] vdd-av1v1-hub: supplied by vdd-5v-sys
[    0.411496] vbusA-cvb: supplied by vdd-5v-sys
[    0.411600] vbusB-cvb: supplied by vdd-5v-sys
[    0.411706] vdd-usbc1-vbus: supplied by vdd-5v-sys
[    0.411805] vdd-usbc2-vbus: supplied by vdd-5v-sys
[    0.412083] iommu: Default domain type: Translated
[    0.412137] eventlib_kernel: keventlib is initialized, test id: 0
[    0.412310] SCSI subsystem initialized
[    0.412375] usbcore: registered new interface driver usbfs
[    0.412388] usbcore: registered new interface driver hub
[    0.412405] usbcore: registered new device driver usb
[    0.412598] mc: Linux media interface: v0.10
[    0.412606] videodev: Linux video capture interface: v2.00
[    0.412763] pps_core: LinuxPPS API ver. 1 registered
[    0.412766] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giom>
[    0.412774] PTP clock support registered
[    0.412973] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[    0.412997] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[    0.414303] Registered efivars operations
[    0.414799] FPGA manager framework
[    0.414840] Advanced Linux Sound Architecture Driver Initialized.
[    0.415078] Bluetooth: Core ver 2.22
[    0.415093] NET: Registered protocol family 31
[    0.415096] Bluetooth: HCI device and connection manager initialized
[    0.415103] Bluetooth: HCI socket layer initialized
[    0.415107] Bluetooth: L2CAP socket layer initialized
[    0.415114] Bluetooth: SCO socket layer initialized
[    0.415746] camchar: rtcpu character device driver loaded
[    0.416162] clocksource: Switched to clocksource arch_sys_counter
[    0.566362] VFS: Disk quotas dquot_6.6.0
[    0.566398] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.566522] pnp: PnP ACPI: disabled
[    0.568232] la/ptsa driver initialized.
[    0.568286] NET: Registered protocol family 2
[    0.568482] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, l)
[    0.570681] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 26)
[    0.570721] TCP established hash table entries: 262144 (order: 9, 2097152 by)
[    0.570923] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, lin)
[    0.571350] TCP: Hash tables configured (established 262144 bind 65536)
[    0.571436] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.571493] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, line)
[    0.571630] NET: Registered protocol family 1
[    0.571884] RPC: Registered named UNIX socket transport module.
[    0.571894] RPC: Registered udp transport module.
[    0.571897] RPC: Registered tcp transport module.
[    0.571900] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.571913] PCI: CLS 0 bytes, default 64
[    0.572037] Trying to unpack rootfs image as initramfs...
[    0.681126] Freeing initrd memory: 8196K
[    0.682964] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters ae
[    0.683147] kvm [1]: IPA Size Limit: 48 bits
[    0.683307] kvm [1]: VHE mode initialized successfully
[    0.683893] Initialise system trusted keyrings
[    0.683968] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[    0.685887] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.686136] NFS: Registering the id_resolver key type
[    0.686150] Key type id_resolver registered
[    0.686153] Key type id_legacy registered
[    0.686184] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.686192] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registerin.
[    0.686204] ntfs: driver 2.1.32 [Flags: R/W].
[    0.697823] NET: Registered protocol family 38
[    0.697831] Key type asymmetric registered
[    0.697835] Asymmetric key parser 'x509' registered
[    0.697851] Block layer SCSI generic (bsg) driver version 0.4 loaded (major )
[    0.697914] io scheduler mq-deadline registered
[    0.697919] io scheduler kyber registered
[    0.701836] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    0.701864] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[    0.701883] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    0.701901] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[    0.704387] tegra_dc_assign_hw_data: no matching compatible node
[    0.704393] tegradccommon module_init failed
[    0.704396] tegradc module_init failed
[    0.704643] EINJ: ACPI disabled.
[    0.706181] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[    0.706190] tegra-pmc: ### PMC reset source: SYS_RESET_N
[    0.706194] tegra-pmc: ### PMC reset level: L0
[    0.706197] tegra-pmc: ### PMC reset status reg: 0x0
[    0.707393] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.713915] random: fast init done
[    0.714232] printk: console [ttyTCU0] enabled
[    2.385810] arm-smmu 12000000.iommu: probing hardware configuration...
[    2.391685] arm-smmu 12000000.iommu: SMMUv2 with:
[    2.396234] arm-smmu 12000000.iommu:         stage 1 translation
[    2.401586] arm-smmu 12000000.iommu:         stage 2 translation
[    2.407083] arm-smmu 12000000.iommu:         nested translation
[    2.412249] arm-smmu 12000000.iommu:         stream matching with 128 regists
[    2.419421] arm-smmu 12000000.iommu:         128 context banks (0 stage-2 on)
[    2.427907] arm-smmu 12000000.iommu:         Supported page sizes: 0x00001000
[    2.432453] arm-smmu 12000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    2.439013] arm-smmu 12000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    2.446431] arm-smmu 10000000.iommu: probing hardware configuration...
[    2.452054] arm-smmu 10000000.iommu: SMMUv2 with:
[    2.456777] arm-smmu 10000000.iommu:         stage 1 translation
[    2.462290] arm-smmu 10000000.iommu:         stage 2 translation
[    2.467714] arm-smmu 10000000.iommu:         nested translation
[    2.473141] arm-smmu 10000000.iommu:         stream matching with 128 regists
[    2.480316] arm-smmu 10000000.iommu:         128 context banks (0 stage-2 on)
[    2.488836] arm-smmu 10000000.iommu:         Supported page sizes: 0x00001000
[    2.493527] arm-smmu 10000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    2.500089] arm-smmu 10000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    2.507073] arm-smmu 8000000.iommu: probing hardware configuration...
[    2.513216] arm-smmu 8000000.iommu: SMMUv2 with:
[    2.517944] arm-smmu 8000000.iommu:  stage 1 translation
[    2.523456] arm-smmu 8000000.iommu:  stage 2 translation
[    2.528876] arm-smmu 8000000.iommu:  nested translation
[    2.534041] arm-smmu 8000000.iommu:  stream matching with 128 register groups
[    2.541217] arm-smmu 8000000.iommu:  128 context banks (0 stage-2 only)
[    2.549775] arm-smmu 8000000.iommu:  Supported page sizes: 0x00001000
[    2.554429] arm-smmu 8000000.iommu:  Stage-1: 48-bit VA -> 48-bit IPA
[    2.560988] arm-smmu 8000000.iommu:  Stage-2: 48-bit IPA -> 48-bit PA
[    2.568320] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe sl
[    2.577443] tegra_profiler: version: 1.147, samples/io: 49/28
[    2.581195] tegra_profiler: auth: init
[    2.585254] nvsciipc: loaded module
[    2.589580] tegra23x-qspi 3270000.spi: Adding to iommu group 0
[    2.594695] tegra23x-qspi 3270000.spi: Node prod has invalid entries
[    2.600893] tegra23x-qspi 3270000.spi: Node prod: Child has not proper settig
[    2.608065] tegra23x-qspi 3270000.spi: Node spi: Faild to read the Prod Sett.
[    2.615503] tegra23x-qspi 3270000.spi: Prod settings list not found
[    2.621817] tegra23x-qspi 3270000.spi: Failed to get reset control: -517
[    2.629026] tun: Universal TUN/TAP device driver, 1.6
[    2.634085] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - versin
[    2.640970] hns3: Copyright (c) 2017 Huawei Corporation.
[    2.646503] e1000e: Intel(R) PRO/1000 Network Driver
[    2.651292] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    2.657167] igb: Intel(R) Gigabit Ethernet Network Driver
[    2.662490] igb: Copyright (c) 2007-2014 Intel Corporation.
[    2.668251] PPP generic driver version 2.4.2
[    2.672599] PPP BSD Compression module registered
[    2.677197] PPP Deflate Compression module registered
[    2.682277] PPP MPPE Compression module registered
[    2.687272] usbcore: registered new interface driver r8152
[    2.692774] usbcore: registered new interface driver asix
[    2.698198] usbcore: registered new interface driver ax88179_178a
[    2.704324] usbcore: registered new interface driver cdc_ether
[    2.710275] usbcore: registered new interface driver net1080
[    2.715871] usbcore: registered new interface driver cdc_subset
[    2.721908] usbcore: registered new interface driver zaurus
[    2.727601] usbcore: registered new interface driver cdc_ncm
[    2.733287] usbcore: registered new interface driver aqc111
[    2.738815] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.745009] ohci-pci: OHCI PCI platform driver
[    2.749305] ohci-platform: OHCI generic platform driver
[    2.754658] tegra-xusb 3610000.xhci: Adding to iommu group 1
[    2.760625] usbcore: registered new interface driver uas
[    2.765587] usbcore: registered new interface driver usb-storage
[    2.771574] tegra-xudc 3550000.xudc: Adding to iommu group 2
[    2.777340] mousedev: PS/2 mouse device common for all mice
[    2.782735] usbcore: registered new interface driver xpad
[    2.790040] tegra_rtc c2a0000.rtc: registered as rtc1
[    2.793494] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:)
[    2.801278] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    2.807546] i2c /dev entries driver
[    2.811094] tegra-i2c 3160000.i2c: Adding to iommu group 3
[    2.816680] tegra-i2c c240000.i2c: Adding to iommu group 3
[    2.822086] tegra-i2c 3180000.i2c: Adding to iommu group 3
[    2.827482] tegra-i2c 3190000.i2c: Adding to iommu group 3
[    2.832813] tegra-i2c 31b0000.i2c: Adding to iommu group 3
[    2.838337] tegra-i2c 31c0000.i2c: Adding to iommu group 3
[    2.843748] tegra-i2c c250000.i2c: Adding to iommu group 3
[    2.849082] tegra-i2c 31e0000.i2c: Adding to iommu group 3
[    2.856804] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not en.
[    2.862693] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not en.
[    2.871732] device-mapper: uevent: version 1.0.3
[    2.875635] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-m
[    2.885148] sdhci: Secure Digital Host Controller Interface driver
[    2.890342] sdhci: Copyright(c) Pierre Ossman
[    2.894802] Synopsys Designware Multimedia Card Interface Driver
[    2.900925] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.907051] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[    2.907135] sdhci-tegra 3460000.sdhci: Adding to iommu group 4
[    2.907454] sdhci-tegra 3400000.sdhci: Adding to iommu group 5
[    2.925818] tegra-bpmp bpmp: firmware: 888a114dda6bea50b6c6-eac380526d6
[    2.933864] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[    2.937588] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x81
[    2.945886] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[    2.947764] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
��debugfs initialized
��[    4.181210] hid: raw HID events driver (C) Jiri Kosina
[    4.182178] usbcore: registered new interface driver usbhid
[    4.182357] usbhid: USB HID core driver
[    4.183083] tegra-dce d800000.dce: Adding to iommu group 6
[    4.184426] dce: dce_ipc_channel_init:314  Invalid Channel State [0x0] for c]
[    4.185290] tegra234-aon c000000.aon: Adding to iommu group 7
[    4.185791] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple t]
[    4.186103] dce: dce_admin_ipc_handle_signal:89   Spurious signal on channel.
[    4.186373] dce: dce_admin_send_cmd_ver:413  version : [0x2] err : [0x0]
[    4.186700] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple t]
[    4.187000] dce: dce_admin_setup_clients_ipc:542  Channel Reset Complete for.
[    4.187002] dce: dce_admin_ipc_handle_signal:89   Spurious signal on channel.
[    4.187225] dce: dce_admin_setup_clients_ipc:518  Get queue info failed for ]
[    4.187649]  c000000.aon:hsp: probed
[    4.187662] dce: dce_admin_ipc_handle_signal:89   Spurious signal on channel.
[    4.187769] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple t]
[    4.193237] tegra234-aon c000000.aon: init done
[    4.201783] dce: dce_admin_setup_clients_ipc:542  Channel Reset Complete for.
[    4.201785] dce: dce_admin_ipc_handle_signal:89   Spurious signal on channel.
[    4.201800] dce: dce_admin_ipc_handle_signal:89   Spurious signal on channel.
[    4.206726] tegra23x-psc e860000.psc: Adding to iommu group 8
[    4.214909] dce: dce_start_boot_flow:100  DCE_BOOT_DONE
[    4.223506] tegra23x-psc e860000.psc: ext_cfg base:(____ptrval____)
[    4.248940] tegra23x-psc e860000.psc: init done
[    4.253717] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 9
[    4.260705] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOV0
[    4.271761] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-04
[    4.276826] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX0
[    4.287940] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[10
[    4.298754] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[10
[    4.309945] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ve0
[    4.321688] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ve0
[    4.334199] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX0
[    4.345968] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (117)
[    4.352289] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is sucl
[    4.360640] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=60
[    4.373259] t19x_cache tegra-cache: probed
[    4.375651] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[    4.391482] optee: probing for conduit method.
[    4.391612] optee: revision 3.16 (65cc2218)
[    4.392283] optee: dynamic shared memory is enabled
[    4.395163] optee: initialized driver
[    4.410674] nvpmodel: initialized successfully
[    4.410884] tegra_hv: get_hvd: not initialized yet
[    4.411017] user_ivc_mempool: hypervisor not present
[    4.413635] usbcore: registered new interface driver snd-usb-audio
[    4.419737] u32 classifier
[    4.422018]     input device check on
[    4.425690]     Actions configured
[    4.429050] Initializing XFRM netlink socket
[    4.433783] NET: Registered protocol family 10
[    4.439086] Segment Routing with IPv6
[    4.441398] NET: Registered protocol family 17
[    4.445738] NET: Registered protocol family 15
[    4.450147] bridge: filtering via arp/ip/ip6tables is no longer available by.
[    4.463490] Bluetooth: RFCOMM socket layer initialized
[    4.468405] Bluetooth: RFCOMM ver 1.11
[    4.472330] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    4.478195] Bluetooth: HIDP socket layer initialized
[    4.483647] 9pnet: Installing 9P2000 support
[    4.487599] Key type dns_resolver registered
[    4.492899] registered taskstats version 1
[    4.496050] Loading compiled-in X.509 certificates
[    4.504376] Loaded X.509 cert 'Build time autogenerated kernel key: 90ac6101'
[    4.511145] tegra194-pcie 14100000.pcie: Adding to iommu group 10
[    4.522871] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[    4.524043] tegra194-pcie 14160000.pcie: Adding to iommu group 11
[    4.534810] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[    4.536218] tegra194-pcie 141a0000.pcie: Adding to iommu group 12
[    4.546785] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[    4.569409] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 13
[    4.572299] host1x 13e40000.host1x: Adding to iommu group 14
[    5.583033] t23x_init_gating_regs: Timed out waiting for syncpt ram init!
[    5.594066] host1x 13e40000.host1x: initialized
[    5.594534] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu gr5
[    5.595069] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (strea)
[    5.596707] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu gr6
[    5.597207] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (strea)
[    5.598787] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu gr7
[    5.599270] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (strea)
[    5.600859] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu gr8
[    5.601322] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (strea)
[    5.602901] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu gr9
[    5.603380] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (strea)
[    5.604940] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu gr0
[    5.605399] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (strea)
[    5.616117] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu gr1
[    5.622729] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (strea)
[    5.634156] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu gr2
[    5.640740] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (strea)
[    5.652184] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu gr3
[    5.658782] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (strea)
[    5.670196] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu gr4
[    5.676775] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (strea)
[    5.688227] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu gr5
[    5.694785] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (strea)
[    5.706262] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu gr6
[    5.712835] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (strea)
[    5.724280] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu gr7
[    5.730867] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (strea)
[    5.742316] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu gr8
[    5.748864] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (strea)
[    5.760333] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu gr9
[    5.766909] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (strea)
[    5.778352] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu gr0
[    5.784927] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (strea)
[    5.796419] falcon 15340000.vic: Adding to iommu group 31
[    5.805601] falcon 15340000.vic: initialized
[    5.805970] falcon 15380000.nvjpg: Adding to iommu group 32
[    5.813909] falcon 15380000.nvjpg: initialized
[    5.815322] falcon 15540000.nvjpg1: Adding to iommu group 33
[    5.824495] falcon 15540000.nvjpg1: initialized
[    5.825727] falcon 154c0000.nvenc: Adding to iommu group 34
[    5.835763] falcon 154c0000.nvenc: initialized
[    5.835995] falcon 15a50000.ofa: Adding to iommu group 35
[    5.844522] falcon 15a50000.ofa: initialized
[    5.845851] nvdec 15480000.nvdec: Adding to iommu group 36
[    5.856492] nvdec 15480000.nvdec: initialized
[    5.856722] tsec 15500000.tsec: Adding to iommu group 37
[    5.863678] random: crng init done
[    5.866534] tsec 15500000.tsec: initialized
[    5.870801] gic 2a41000.agic-controller: GIC IRQ controller registered
[    5.884151] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[    5.891880] gpio-394 (camera-control-output-low): hogged as output/low
[    5.892092] gpio-397 (camera-control-output-low): hogged as output/low
[    5.894872] gpio-487 (camera-control-output-low): hogged as output/low
[    5.901246] gpio-486 (camera-control-output-low): hogged as output/low
[    5.908645] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[    5.914525] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[    5.920799] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    5.927014] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[    5.932604] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    5.938125] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[    5.945701] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_isos
[    5.951852] tegra194-isp5 14800000.isp: Adding to iommu group 38
[    5.960207] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disU
[    5.967123] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[    5.973150] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group9
[    5.980914] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group0
[    5.987952] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolationU
[    5.997182] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[    6.003237] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolationU
[    6.012637] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[    6.018710] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolationU
[    6.028480] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[    6.034756] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to i1
[    6.043256] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized)
[    6.054072] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to i2
[    6.062675] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized)
[    6.073325] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to i3
[    6.081765] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized)
[    6.092584] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to i4
[    6.100966] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized)
[    6.111646] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to i5
[    6.120225] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized)
[    6.130902] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to i6
[    6.139467] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized)
[    6.150146] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to i7
[    6.158705] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized)
[    6.169400] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to i8
[    6.177983] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized)
[    6.188644] pva 16000000.pva0: Adding to iommu group 49
[    6.213229] pva 16000000.pva0: initialized
[    6.219414] nvdla 15880000.nvdla0: Adding to iommu group 50
[    6.228840] nvdla 15880000.nvdla0: initialized
[    6.230574] nvdla 158c0000.nvdla1: Adding to iommu group 51
[    6.239027] nvdla 158c0000.nvdla1: initialized
[    6.240749] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 3
[    6.241686] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[    6.242075] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[    6.242251] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[    6.244388] serial-tegra 3100000.serial: Adding to iommu group 3
[    6.250746] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 13, base_baud =T
[    6.259841] serial-tegra 3130000.serial: Adding to iommu group 3
[    6.265545] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 65, base_baud =T
[    6.274520] tegra23x-qspi 3270000.spi: Node prod has invalid entries
[    6.280272] tegra23x-qspi 3270000.spi: Node prod: Child has not proper settig
[    6.287616] tegra23x-qspi 3270000.spi: Node spi: Faild to read the Prod Sett.
[    6.295233] tegra23x-qspi 3270000.spi: Prod settings list not found
[    6.324845] tegra-xusb 3610000.xhci: Firmware timestamp: 2021-12-01 05:27:10e
[    6.325124] tegra-xusb 3610000.xhci: xHCI Host Controller
[    6.325320] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus nu1
[    6.326329] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x1200
[    6.333414] tegra-xusb 3610000.xhci: irq 235, io mem 0x03610000
[    6.339726] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, b0
[    6.347468] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber1
[    6.354730] usb usb1: Product: xHCI Host Controller
[    6.359718] usb usb1: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[    6.365844] usb usb1: SerialNumber: 3610000.xhci
[    6.371200] hub 1-0:1.0: USB hub found
[    6.374532] hub 1-0:1.0: 4 ports detected
[    6.378765] tegra-xusb 3610000.xhci: xHCI Host Controller
[    6.383965] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus nu2
[    6.391577] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSped
[    6.398996] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, b0
[    6.407153] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber1
[    6.414406] usb usb2: Product: xHCI Host Controller
[    6.419392] usb usb2: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[    6.425605] usb usb2: SerialNumber: 3610000.xhci
[    6.430724] hub 2-0:1.0: USB hub found
[    6.434024] hub 2-0:1.0: 4 ports detected
[    6.469094] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequz
[    6.472116] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequz
[    6.475618] cpufreq: cpufreq_online: CPU8: Running at unlisted initial frequz
[    6.477646] tegra194-cpufreq e000000.ccplex: probed with ICC
[    6.480911] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[    6.480926] sdhci-tegra 3400000.sdhci: Got CD GPIO
[    6.483425] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[    6.490469] mmc0: CQHCI version 5.10
[    6.494390] tegra194-pcie 14100000.pcie:       IO 0x0030100000..0x00301fffff0
[    6.496300] irq: IRQ302: trimming hierarchy from :interrupt-controller@f40001
[    6.496334] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 302
[    6.520022] tegra194-pcie 14100000.pcie:      MEM 0x20a8000000..0x20afffffff0
[    6.526788] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADt
[    6.528507] tegra194-pcie 14100000.pcie:      MEM 0x2080000000..0x20a7ffffff0
[    6.635207] mmc0: Command Queue Engine enabled
[    6.635348] mmc0: periodic cache flush enabled
[    6.635488] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[    6.636014] mmcblk0: mmc0:0001 G1M15M 59.3 GiB
[    6.636341] mmcblk0rpmb: mmc0:0001 G1M15M partition 3 4.00 MiB, chardev (511)
[    6.639719]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[    6.640164] tegra194-pcie 14100000.pcie: Link up
[    6.640344] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[    6.641588] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[    6.641775] pci_bus 0001:00: root bus resource [bus 00-ff]
[    6.641923] pci_bus 0001:00: root bus resource [io  0x0000-0xfffff] (bus add)
[    6.642182] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20affffff)
[    6.642464] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7fffff]
[    6.642724] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[    6.643043] pci 0001:00:00.0: PME# supported from D0 D3hot
[    6.647575] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[    6.647897] pci 0001:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[    6.651908] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[    6.660054] pci 0001:01:00.0: supports D1 D2
[    6.663253] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    6.674401] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80ffff]
[    6.677342] pci 0001:00:00.0: BAR 13: assigned [io  0x1000-0x1fff]
[    6.683644] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff]
[    6.691442] pci 0001:01:00.0: BAR 0: assigned [io  0x1000-0x10ff]
[    6.697502] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[    6.702717] pci 0001:00:00.0:   bridge window [io  0x1000-0x1fff]
[    6.709020] pci 0001:00:00.0:   bridge window [mem 0x20a8000000-0x20a80fffff]
[    6.716380] pci 0001:00:00.0: Max Payload Size set to  128/ 256 (was  256), 2
[    6.724925] pci 0001:01:00.0: Max Payload Size set to  128/ 128 (was  128), 2
[    6.733423] pcieport 0001:00:00.0: Adding to iommu group 10
[    6.738991] pcieport 0001:00:00.0: PME: Signaling with IRQ 51
[    6.744697] pcieport 0001:00:00.0: AER: enabled with IRQ 51
[    6.750990] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[    6.757454] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[    6.763193] tegra194-pcie 14160000.pcie:       IO 0x0036100000..0x00361fffff0
[    6.771848] tegra194-pcie 14160000.pcie:      MEM 0x2428000000..0x242fffffff0
[    6.780330] tegra194-pcie 14160000.pcie:      MEM 0x2140000000..0x2427ffffff0
[    6.799871] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411, bc1
[    6.800094] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    6.804221] usb 1-2: Product: USB2.1 Hub
[    6.807976] usb 1-2: Manufacturer: Generic
[    6.813744] hub 1-2:1.0: USB hub found
[    6.816735] hub 1-2:1.0: 5 ports detected
[    6.921232] usb 2-3: new SuperSpeedPlus Gen 2 USB device number 2 using tegrb
[    6.961109] usb 2-3: New USB device found, idVendor=0bda, idProduct=0420, bc0
[    6.961361] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    6.961575] usb 2-3: Product: 4-Port USB 3.0 Hub
[    6.961718] usb 2-3: Manufacturer: Generic
[    6.974249] hub 2-3:1.0: USB hub found
[    6.976893] hub 2-3:1.0: 4 ports detected
[    7.080158] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[    7.232498] usb 1-3: New USB device found, idVendor=13d3, idProduct=3549, bc0
[    7.232740] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    7.232958] usb 1-3: Product: Bluetooth Radio
[    7.233084] usb 1-3: Manufacturer: Realtek
[    7.233211] usb 1-3: SerialNumber: 00e04c000001
[    7.308162] usb 1-2.1: new high-speed USB device number 4 using tegra-xusb
[    7.415101] usb 1-2.1: New USB device found, idVendor=1ab2, idProduct=0001, 0
[    7.415355] usb 1-2.1: New USB device strings: Mfr=2, Product=3, SerialNumbe4
[    7.415579] usb 1-2.1: Product: ALVIUM 1800 U-511m
[    7.415738] usb 1-2.1: Manufacturer: Allied Vision
[    7.415887] usb 1-2.1: SerialNumber: 01TTN
[    7.536166] usb 1-4: new high-speed USB device number 5 using tegra-xusb
[    7.704282] usb 1-4: New USB device found, idVendor=0bda, idProduct=5420, bc0
[    7.704535] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    7.704753] usb 1-4: Product: 4-Port USB 2.0 Hub
[    7.704890] usb 1-4: Manufacturer: Generic
[    7.707080] hub 1-4:1.0: USB hub found
[    7.708486] hub 1-4:1.0: 4 ports detected
[    7.772162] usb 1-2.2: new high-speed USB device number 6 using tegra-xusb
[    7.884468] tegra194-pcie 14160000.pcie: Phy link never came up
[    7.884718] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[    7.884933] pci_bus 0004:00: root bus resource [bus 00-ff]
[    7.885119] pci_bus 0004:00: root bus resource [io  0x100000-0x1fffff] (bus )
[    7.885451] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242ffffff)
[    7.885782] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427fffff]
[    7.886078] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[    7.886417] pci 0004:00:00.0: PME# supported from D0 D3hot
[    7.894116] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[    7.894285] pci 0004:00:00.0: Max Payload Size set to  256/ 256 (was  256), 2
[    7.894762] pcieport 0004:00:00.0: Adding to iommu group 11
[    7.895113] pcieport 0004:00:00.0: PME: Signaling with IRQ 53
[    7.895501] pcieport 0004:00:00.0: AER: enabled with IRQ 53
[    7.895878] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[    7.896099] pci 0004:00:00.0: Removing from iommu group 11
[    7.896264] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[    7.900424] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[    7.905444] vdd-3v3-pcie: supplied by vdd-3v3-sys
[    7.910067] avdd-cam-2v8: supplied by vdd-3v3-sys
[    7.914707] vdd-dp: supplied by vdd-3v3-sys
[    7.918945] vdd-3v3-sd: supplied by vdd-3v3-sys
[    7.923906] dsi-vdd-1v8-bl-en: supplied by vdd-1v8-sys
[    7.930610] tegra194-isp5 14800000.isp: initialized
[    7.939409] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[    7.939658] (NULL device *): fops function table already registered
[    7.946809] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[    7.952758] sdhci-tegra 3400000.sdhci: Got CD GPIO
[    7.952769] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[    7.966267] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 302
[    8.016733] usb 2-3.1: new SuperSpeed Gen 1 USB device number 3 using tegra-b
[    8.043079] usb 2-3.1: New USB device found, idVendor=1ab2, idProduct=0001, 0
[    8.043316] usb 2-3.1: New USB device strings: Mfr=2, Product=3, SerialNumbe4
[    8.043498] usb 2-3.1: Product: ALVIUM 1800 U-511m
[    8.043623] usb 2-3.1: Manufacturer: Allied Vision
[    8.043750] usb 2-3.1: SerialNumber: 0267F
[    8.068766] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[    8.068975] tegra194-pcie 141a0000.pcie:       IO 0x003a100000..0x003a1fffff0
[    8.069203] tegra194-pcie 141a0000.pcie:      MEM 0x2b28000000..0x2b2fffffff0
[    8.069433] tegra194-pcie 141a0000.pcie:      MEM 0x2740000000..0x2b27ffffff0
[    8.118079] usb 1-2.2: New USB device found, idVendor=0b95, idProduct=1790, 0
[    8.118331] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumbe3
[    8.118536] usb 1-2.2: Product: AX88179A
[    8.118648] usb 1-2.2: Manufacturer: ASIX
[    8.118767] usb 1-2.2: SerialNumber: 005BAE27
[    8.167895] ax88179_178a 1-2.2:2.0 (unnamed net_device) (uninitialized): Fai2
[    8.178892] ax88179_178a 1-2.2:2.0 (unnamed net_device) (uninitialized): Fai2
[    8.391192] ax88179_178a 1-2.2:2.0 (unnamed net_device) (uninitialized): Fai2
[    8.416160] usb 1-4.3: new high-speed USB device number 7 using tegra-xusb
[    8.502846] ax88179_178a 1-2.2:2.0 (unnamed net_device) (uninitialized): Fai2
[    8.503145] ax88179_178a 1-2.2:2.0 (unnamed net_device) (uninitialized): invm
[    8.513810] ax88179_178a 1-2.2:2.0 (unnamed net_device) (uninitialized): Fai2
[    8.523100] usb 1-4.3: New USB device found, idVendor=1ab2, idProduct=0001, 0
[    8.523350] usb 1-4.3: New USB device strings: Mfr=2, Product=3, SerialNumbe4
[    8.523550] usb 1-4.3: Product: ALVIUM 1800 U-511m
[    8.523695] usb 1-4.3: Manufacturer: Allied Vision
[    8.523832] usb 1-4.3: SerialNumber: 01HPT
[    8.524769] ax88179_178a 1-2.2:2.0 (unnamed net_device) (uninitialized): Fai2
[    8.537323] ax88179_178a 1-2.2:2.0 (unnamed net_device) (uninitialized): Fai2
[    8.548330] ax88179_178a 1-2.2:2.0 (unnamed net_device) (uninitialized): Fai2
[    8.559337] ax88179_178a 1-2.2:2.0 (unnamed net_device) (uninitialized): Fai2
[    8.570611] ax88179_178a 1-2.2:2.0 (unnamed net_device) (uninitialized): Fai2
[    8.581613] ax88179_178a 1-2.2:2.0 (unnamed net_device) (uninitialized): Fai2
[    8.594243] ax88179_178a 1-2.2:2.0 (unnamed net_device) (uninitialized): Fai2
[    8.605251] ax88179_178a 1-2.2:2.0 (unnamed net_device) (uninitialized): Fai2
[    8.616289] ax88179_178a 1-2.2:2.0 (unnamed net_device) (uninitialized): Fai2
[    8.627257] ax88179_178a 1-2.2:2.0 (unnamed net_device) (uninitialized): Fai2
[    8.638268] ax88179_178a 1-2.2:2.0 (unnamed net_device) (uninitialized): Fai2
[    8.651112] ax88179_178a 1-2.2:2.0 (unnamed net_device) (uninitialized): Fai2
[    8.662266] ax88179_178a 1-2.2:2.0 (unnamed net_device) (uninitialized): Fai2
[    8.673270] ax88179_178a 1-2.2:2.0 (unnamed net_device) (uninitialized): Fai2
[    8.684057] ax88179_178a 1-2.2:2.0 (unnamed net_device) (uninitialized): Fai2
[    8.695062] ax88179_178a 1-2.2:2.0 (unnamed net_device) (uninitialized): Fai2
[    8.707819] ax88179_178a 1-2.2:2.0 (unnamed net_device) (uninitialized): Fai2
[    8.718988] ax88179_178a 1-2.2:2.0 (unnamed net_device) (uninitialized): Fai2
[    8.729986] ax88179_178a 1-2.2:2.0 (unnamed net_device) (uninitialized): Fai2
[    8.740986] ax88179_178a 1-2.2:2.0 (unnamed net_device) (uninitialized): Fai2
[    8.751767] ax88179_178a 1-2.2:2.0 (unnamed net_device) (uninitialized): Fai2
[    8.764527] ax88179_178a 1-2.2:2.0 (unnamed net_device) (uninitialized): Fai2
[    8.765034] ax88179_178a 1-2.2:2.0 eth0: register 'ax88179_178a' at usb-36102
[    8.878270] ax88179_178a 1-2.2:2.1 (unnamed net_device) (uninitialized): Fai2
[    8.889399] ax88179_178a 1-2.2:2.1 (unnamed net_device) (uninitialized): Fai2
[    9.028089] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADt
[    9.103490] ax88179_178a 1-2.2:2.1 (unnamed net_device) (uninitialized): Fai2
[    9.160307] tegra194-pcie 141a0000.pcie: Phy link never came up
[    9.160556] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[    9.160761] pci_bus 0005:00: root bus resource [bus 00-ff]
[    9.160932] pci_bus 0005:00: root bus resource [io  0x200000-0x2fffff] (bus )
[    9.161222] pci_bus 0005:00: root bus resource [mem 0x2b28000000-0x2b2ffffff)
[    9.161557] pci_bus 0005:00: root bus resource [mem 0x2740000000-0x2b27fffff]
[    9.161841] pci 0005:00:00.0: [10de:229a] type 01 class 0x060400
[    9.162175] pci 0005:00:00.0: PME# supported from D0 D3hot
[    9.169980] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[    9.170139] pci 0005:00:00.0: Max Payload Size set to  256/ 256 (was  256), 2
[    9.170604] pcieport 0005:00:00.0: Adding to iommu group 12
[    9.170951] pcieport 0005:00:00.0: PME: Signaling with IRQ 55
[    9.171475] pcieport 0005:00:00.0: AER: enabled with IRQ 55
[    9.171859] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[    9.172097] pci 0005:00:00.0: Removing from iommu group 12
[    9.172259] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[    9.177232] nvethernet 6810000.ethernet: Adding to iommu group 52
[    9.181636] nvethernet 6810000.ethernet: failed to read skip mac reset flag,0
[    9.189155] nvethernet 6810000.ethernet: failed to read MDIO address
[    9.195703] nvethernet 6810000.ethernet: setting to default DMA bit mask
[    9.202530] nvethernet 6810000.ethernet: failed to read UPHY GBE mode- defauG
[    9.215489] ax88179_178a 1-2.2:2.1 (unnamed net_device) (uninitialized): Fai2
[    9.220026] ax88179_178a 1-2.2:2.1 (unnamed net_device) (uninitialized): invm
[    9.237024] ax88179_178a 1-2.2:2.1 (unnamed net_device) (uninitialized): Fai2
[    9.249636] ax88179_178a 1-2.2:2.1 (unnamed net_device) (uninitialized): Fai2
[    9.260637] ax88179_178a 1-2.2:2.1 (unnamed net_device) (uninitialized): Fai2
[    9.271637] ax88179_178a 1-2.2:2.1 (unnamed net_device) (uninitialized): Fai2
[    9.282637] ax88179_178a 1-2.2:2.1 (unnamed net_device) (uninitialized): Fai2
[    9.293636] ax88179_178a 1-2.2:2.1 (unnamed net_device) (uninitialized): Fai2
[    9.306192] ax88179_178a 1-2.2:2.1 (unnamed net_device) (uninitialized): Fai2
[    9.317387] ax88179_178a 1-2.2:2.1 (unnamed net_device) (uninitialized): Fai2
[    9.328512] ax88179_178a 1-2.2:2.1 (unnamed net_device) (uninitialized): Fai2
[    9.339473] ax88179_178a 1-2.2:2.1 (unnamed net_device) (uninitialized): Fai2
[    9.350612] ax88179_178a 1-2.2:2.1 (unnamed net_device) (uninitialized): Fai2
[    9.363176] ax88179_178a 1-2.2:2.1 (unnamed net_device) (uninitialized): Fai2
[    9.374186] ax88179_178a 1-2.2:2.1 (unnamed net_device) (uninitialized): Fai2
[    9.385237] ax88179_178a 1-2.2:2.1 (unnamed net_device) (uninitialized): Fai2
[    9.396237] ax88179_178a 1-2.2:2.1 (unnamed net_device) (uninitialized): Fai2
[    9.407157] ax88179_178a 1-2.2:2.1 (unnamed net_device) (uninitialized): Fai2
[    9.419548] ax88179_178a 1-2.2:2.1 (unnamed net_device) (uninitialized): Fai2
[    9.430808] ax88179_178a 1-2.2:2.1 (unnamed net_device) (uninitialized): Fai2
[    9.441761] ax88179_178a 1-2.2:2.1 (unnamed net_device) (uninitialized): Fai2
[    9.452759] ax88179_178a 1-2.2:2.1 (unnamed net_device) (uninitialized): Fai2
[    9.463758] ax88179_178a 1-2.2:2.1 (unnamed net_device) (uninitialized): Fai2
[    9.476311] ax88179_178a 1-2.2:2.1 (unnamed net_device) (uninitialized): Fai2
[    9.487321] ax88179_178a 1-2.2:2.1 (unnamed net_device) (uninitialized): Fai2
[    9.487730] ax88179_178a 1-2.2:2.1 eth1: register 'ax88179_178a' at usb-36106
[    9.593829] ether_get_mac_address_dtb: bad mac address at /chosen/nvidia,eth.
[    9.594105] nvethernet 6810000.ethernet: No MAC address in local DT!
[    9.594293] nvethernet 6810000.ethernet: failed to get MAC address
[    9.596474] nvethernet: probe of 6810000.ethernet failed with error -22
[    9.597068] irq: IRQ304: trimming hierarchy from :pmc@c360000
[    9.597290] irq: IRQ305: trimming hierarchy from :interrupt-controller@f40001
[    9.597557] irq: IRQ306: trimming hierarchy from :pmc@c360000
[    9.597773] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    9.598692] tegra-se-nvhost 15810000.se: Adding to iommu group 53
[    9.599168] tegra-se-nvhost 15810000.se: initialized
[    9.609719] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[    9.609973] tegra-se-nvhost 15820000.se: Adding to ��WARNING: clock_disable:k
��iommu group 54
[    9.610409] tegra-se-nvhost 15820000.se: initialized
[    9.612773] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[    9.613024] tegra-se-nvhost 15840000.se: Adding to iommu group 55
[    9.613463] tegra-se-nvhost 15840000.se: initialized
[    9.619251] tegra-��WARNING: clock_disable: clk_power_ungate on gated domaink
��se-nvhost 15840000.se: tegra_se_probe: complete
[    9.620092] tegra_actmon d230000.actmon: in actmon_register()...
[    9.620449] tegra_actmon d230000.actmon: bwmgr_disable = 1
[    9.621208] tegra_actmon d230000.actmon: initialization Completed for the del
[    9.627482] hvc_sysfs: hypervisor is not pres��WARNING: clock_disable: clk_pk
��ent
[    9.765415] ALSA device list:
[    9.765523]   No soundcards found.
[    9.766183] Freeing unused kernel memory: 3968K
[    9.766374] Run /init as init process
[    9.777849] Root device found: mmcblk0p1
[    9.778442] Found dev node: /dev/mmcblk0p1
[    9.802411] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. )
[    9.803645] Rootfs mounted over mmcblk0p1
[    9.817506] Switching from initrd to actual rootfs
[    9.956699] systemd[1]: System time before build time, advancing clock.
[    9.998475] systemd[1]: systemd 245.4-4ubuntu3.19 running in system mode. (+)
[    9.999581] systemd[1]: Detected architecture arm64.
[   10.041273] systemd[1]: Set hostname to <orin2-desktop>.
[   10.249735] systemd[1]: system-modprobe.slice: unit configures an IP firewal.
[   10.250125] systemd[1]: (This warning is only shown for the first unit using)
[   10.251269] systemd[1]: Created slice system-modprobe.slice.
[   10.251916] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   10.252476] systemd[1]: Created slice User and Session Slice.
[   10.252762] systemd[1]: Started Forward Password Requests to Wall Directory .
[   10.253236] systemd[1]: Set up automount Arbitrary Executable File Formats F.
[   10.253608] systemd[1]: Reached target User and Group Name Lookups.
[   10.253846] systemd[1]: Reached target Slices.
[   10.254016] systemd[1]: Reached target Swap.
[   10.254401] systemd[1]: Listening on RPCbind Server Activation Socket.
[   10.254732] systemd[1]: Listening on Syslog Socket.
[   10.255008] systemd[1]: Listening on fsck to fsckd communication Socket.
[   10.255303] systemd[1]: Listening on initctl Compatibility Named Pipe.
[   10.256037] systemd[1]: Listening on Journal Audit Socket.
[   10.259354] systemd[1]: Listening on Journal Socket (/dev/log).
[   10.265467] systemd[1]: Listening on Journal Socket.
[   10.270460] systemd[1]: Listening on udev Control Socket.
[   10.275870] systemd[1]: Listening on udev Kernel Socket.
[   10.282406] systemd[1]: Mounting Huge Pages File System...
[   10.287892] systemd[1]: Mounting POSIX Message Queue File System...
[   10.294082] systemd[1]: Mounting RPC Pipe File System...
[   10.299477] systemd[1]: Mounting Kernel Debug File System...
[   10.305239] systemd[1]: Mounting Kernel Trace File System...
[   10.311157] systemd[1]: Starting Journal Service...
[   10.322503] systemd[1]: Starting Set the console keyboard layout...
[   10.323745] systemd[1]: Starting Create list of static device nodes for the .
[   10.330759] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[   10.336332] systemd[1]: Condition check resulted in Load Kernel Module drm b.
[   10.337204] systemd[1]: Starting Load Kernel Module efi_pstore...
[   10.351856] systemd[1]: Starting Load Kernel Module pstore_blk...
[   10.358104] systemd[1]: Starting Load Kernel Module pstore_zone...
[   10.364357] systemd[1]: Starting Load Kernel Module ramoops...
[   10.370282] systemd[1]: Starting NVIDIA specific first-boot udev script...
[   10.377382] systemd[1]: Started Nameserver information manager.
[   10.382287] systemd[1]: Reached target Network (Pre).
[   10.388970] systemd[1]: Condition check resulted in Set Up Additional Binary.
[   10.396427] systemd[1]: Condition check resulted in File System Check on Roo.
[   10.406020] pstore: Using crash dump compression: deflate
[   10.410320] systemd[1]: Starting Load Kernel Modules...
[   10.417438] printk: console [ramoops-1] enabled
[   10.420684] pstore: Registered ramoops as persistent store backend
[   10.420685] ramoops: using 0x200000@0x82c200000, ecc: 0
[   10.433130] systemd[1]: Starting Remount Root and Kernel File Systems...
[   10.439807] systemd[1]: Starting udev Coldplug all Devices...
[   10.444672] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[   10.445730] systemd[1]: Starting Uncomplicated firewall...
[   10.455908] nvmap_heap_init: nvmap_heap_init: created heap block cache
[   10.456727] systemd[1]: Started Journal Service.
[   10.461613] tegra-carveouts tegra-carveouts: fsi :dma coherent mem declare 06
[   10.475525] tegra-carveouts tegra-carveouts: assigned reserved memory node ft
[   10.475532] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 02
[   10.492759] tegra-carveouts tegra-carveouts: assigned reserved memory node vt
[   10.492764] nvmap_page_pool_init: Total RAM pages: 7817269
[   10.506319] nvmap_page_pool_init: nvmap page pool size: 977158 pages (3817 M)
[   10.506372] nvmap_background_zero_thread: PP zeroing thread starting.
[   10.506456] misc nvmap: created heap vpr base 0x0000000849800000 size (89292)
[   10.509490] misc nvmap: created heap fsi base 0x000000082f000000 size (16384)
[   10.556922] systemd-journald[318]: Received client request to flush runtime .
[   10.570312] nvgpu: 17000000.ga10b          nvgpu_nvhost_syncpt_init:135  [IN0
[   10.570312]
[   10.796310] ax88179_178a 1-2.2:2.0 eth0 (unregistered): Failed to write reg 9
[   10.796610] ax88179_178a 1-2.2:2.0 eth0 (unregistered): Failed to write reg 9
[   10.796867] ax88179_178a 1-2.2:2.0 eth0 (unregistered): Failed to write reg 9
[   10.813745] using random self ethernet address
[   10.813900] using random host ethernet address
[   10.865537] ax88179_178a 1-2.2:2.1 eth1 (unregistered): Failed to write reg 9
[   10.865838] ax88179_178a 1-2.2:2.1 eth1 (unregistered): Failed to write reg 9
[   10.866092] ax88179_178a 1-2.2:2.1 eth1 (unregistered): Failed to write reg 9
[   10.873024] nvidia: loading out-of-tree module taints kernel.
[   11.137261] 1 fixed-partitions partitions found on MTD device spi6.0
[   11.137485] Creating 1 MTD partitions on "spi6.0":
[   11.137655] 0x000000000000-0x000004000000 : "Whole_flash0"
[   11.189475] OF: graph: no port node found in /i2c@c240000/ucsi_ccg@8/connect0
[   11.276588] OF: graph: no port node found in /i2c@c240000/ucsi_ccg@8/connect0
[   11.276851] OF: graph: no port node found in /i2c@c240000/ucsi_ccg@8/connect0
[   11.593422] using random self ethernet address
[   11.593576] using random host ethernet address
[   12.426835] ax88179_178a 1-2.2:1.0 (unnamed net_device) (uninitialized): Fai2
[   13.588527] ax88179_178a 1-2.2:1.0 eth0: Failed to read reg index 0x0040: -32
[   15.749916] Bridge firewalling registered
Ubuntu 20.04.5 LTS orin2-desktop ttyTCU0
Your log dumped too late. We need some earlier log.
Please put the console ready, power on the board and capture the log since beginning.
